[mapguide-commits] r6591 - sandbox/adsk/2.3r/Common/Stylization
svn_mapguide at osgeo.org
Wed Apr 25 17:29:46 EDT 2012
Author: waltweltonlair
Date: 2012-04-25 14:29:46 -0700 (Wed, 25 Apr 2012)
New Revision: 6591
sandbox/adsk/2.3r/Common/Stylization/DefaultStylizer.cpp
sandbox/adsk/2.3r/Common/Stylization/DefaultStylizer.h
Merge trunk changeset 6590 into adsk/2.3r branch stream.
This is for ticket #1986 (Stylization: allow retrieving visibility information)
Modified: sandbox/adsk/2.3r/Common/Stylization/DefaultStylizer.cpp
--- sandbox/adsk/2.3r/Common/Stylization/DefaultStylizer.cpp 2012-04-25 21:20:13 UTC (rev 6590)
+++ sandbox/adsk/2.3r/Common/Stylization/DefaultStylizer.cpp 2012-04-25 21:29:46 UTC (rev 6591)
@@ -535,3 +535,91 @@
delete m_pRasterAdapter;
m_pRasterAdapter = NULL;
+bool DefaultStylizer::HasValidScaleRange(MdfModel::VectorLayerDefinition* layer,
+ double mapScale)
+ // look through the scale ranges to find a valid one
+ MdfModel::VectorScaleRangeCollection* scaleRanges = layer->GetScaleRanges();
+ MdfModel::VectorScaleRange* scaleRange = Stylizer::FindScaleRange(*scaleRanges, mapScale);
+ return (NULL != scaleRange);
+FdoFilter* DefaultStylizer::GetRulesFilter(MdfModel::VectorLayerDefinition* layer,
+ double mapScale)
+ // no range -- fast return, the layer is invisible at this scale
+ if (NULL == scaleRange)
+ return NULL;
+ // extract all the composite styles once
+ MdfModel::FeatureTypeStyleCollection* ftsc = scaleRange->GetFeatureTypeStyles();
+ std::vector<CompositeTypeStyle*> compTypeStyles;
+ for (int i=0; i<ftsc->GetCount(); ++i)
+ MdfModel::FeatureTypeStyle* fts = ftsc->GetAt(i);
+ if (FeatureTypeStyleVisitor::DetermineFeatureTypeStyle(fts) == FeatureTypeStyleVisitor::ftsComposite)
+ compTypeStyles.push_back((CompositeTypeStyle*)fts);
+ size_t numTypeStyles = compTypeStyles.size();
+ _ASSERT(numTypeStyles > 0);
+ if (numTypeStyles == 0)
+ return NULL;
+ // Build a filter by combining the filters for each rule
+ MdfString filterstr;
+ for (size_t i=0; i<numTypeStyles; ++i)
+ CompositeTypeStyle* style = compTypeStyles.at(i);
+ RuleCollection* rulecoll = style->GetRules();
+ int nRules = rulecoll->GetCount();
+ for (int j=0; j<nRules; ++j)
+ CompositeRule* r = static_cast<CompositeRule*>(rulecoll->GetAt(j));
+ const MdfString& temp = r->GetFilter();
+ if (!temp.empty())
+ if (filterstr.empty())
+ filterstr.append(L"("); // start filter
+ else
+ filterstr.append(L" OR ");
+ filterstr.append(temp.c_str());
+ filterstr.append(L")");
+ // Output filter
+ FdoFilter* filter = NULL;
+ if (!filterstr.empty())
+ filterstr.append(L")"); // close filter
+ try
+ filter = FdoFilter::Parse(filterstr.c_str());
+ catch (FdoException* e)
+ e->Release();
+ return filter;
Modified: sandbox/adsk/2.3r/Common/Stylization/DefaultStylizer.h
--- sandbox/adsk/2.3r/Common/Stylization/DefaultStylizer.h 2012-04-25 21:20:13 UTC (rev 6590)
+++ sandbox/adsk/2.3r/Common/Stylization/DefaultStylizer.h 2012-04-25 21:29:46 UTC (rev 6591)
@@ -68,6 +68,11 @@
STYLIZATION_API virtual void SetGeometryAdapter(FdoGeometryType type, GeometryAdapter* stylizer);
+ STYLIZATION_API virtual bool HasValidScaleRange(MdfModel::VectorLayerDefinition* layer,
+ double mapScale);
+ STYLIZATION_API virtual FdoFilter* GetRulesFilter(MdfModel::VectorLayerDefinition* layer,
+ double mapScale);
private:
int StylizeVLHelper(MdfModel::VectorLayerDefinition* layer,
MdfModel::VectorScaleRange* scaleRange,
More information about the mapguide-commits
