[mapguide-commits] r6943 - in trunk/Tools/Maestro/Maestro.Editors: MapDefinition Resources
svn_mapguide at osgeo.org
Tue Aug 21 03:20:45 PDT 2012
Author: jng
Date: 2012-08-21 03:20:45 -0700 (Tue, 21 Aug 2012)
New Revision: 6943
Added:
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.cs
trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.resx
trunk/Tools/Maestro/Maestro.Editors/Resources/folder-horizontal-open.png
Missed some files from previous submission
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.Designer.cs 2012-08-21 10:20:45 UTC (rev 6943)
@@ -0,0 +1,109 @@
+namespace Maestro.Editors.MapDefinition
+ partial class LiveMapEditorRepositoryView
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(LiveMapEditorRepositoryView));
+ this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.btnAddToMap = new System.Windows.Forms.ToolStripButton();
+ this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
+ this.btnEdit = new System.Windows.Forms.ToolStripButton();
+ this.btnRefresh = new System.Windows.Forms.ToolStripButton();
+ this.repoView = new Maestro.Editors.Common.RepositoryView();
+ this.toolStrip1.SuspendLayout();
+ this.SuspendLayout();
+ // toolStrip1
+ this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.btnAddToMap,
+ this.toolStripSeparator1,
+ this.btnEdit,
+ this.btnRefresh});
+ resources.ApplyResources(this.toolStrip1, "toolStrip1");
+ this.toolStrip1.Name = "toolStrip1";
+ // btnAddToMap
+ this.btnAddToMap.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.btnAddToMap, "btnAddToMap");
+ this.btnAddToMap.Image = global::Maestro.Editors.Properties.Resources.map__plus;
+ this.btnAddToMap.Name = "btnAddToMap";
+ this.btnAddToMap.Click += new System.EventHandler(this.btnAddToMap_Click);
+ // toolStripSeparator1
+ this.toolStripSeparator1.Name = "toolStripSeparator1";
+ resources.ApplyResources(this.toolStripSeparator1, "toolStripSeparator1");
+ // btnEdit
+ this.btnEdit.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ resources.ApplyResources(this.btnEdit, "btnEdit");
+ this.btnEdit.Image = global::Maestro.Editors.Properties.Resources.document__pencil;
+ this.btnEdit.Name = "btnEdit";
+ this.btnEdit.Click += new System.EventHandler(this.btnOpen_Click);
+ // btnRefresh
+ this.btnRefresh.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+ this.btnRefresh.Image = global::Maestro.Editors.Properties.Resources.arrow_circle_135;
+ resources.ApplyResources(this.btnRefresh, "btnRefresh");
+ this.btnRefresh.Name = "btnRefresh";
+ this.btnRefresh.Click += new System.EventHandler(this.btnRefresh_Click);
+ // repoView
+ resources.ApplyResources(this.repoView, "repoView");
+ this.repoView.Name = "repoView";
+ this.repoView.ItemSelected += new System.EventHandler(this.repoView_ItemSelected);
+ // LiveMapEditorRepositoryView
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+ this.Controls.Add(this.repoView);
+ this.Controls.Add(this.toolStrip1);
+ this.Name = "LiveMapEditorRepositoryView";
+ resources.ApplyResources(this, "$this");
+ this.toolStrip1.ResumeLayout(false);
+ this.toolStrip1.PerformLayout();
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.ToolStrip toolStrip1;
+ private Common.RepositoryView repoView;
+ private System.Windows.Forms.ToolStripButton btnEdit;
+ private System.Windows.Forms.ToolStripButton btnRefresh;
+ private System.Windows.Forms.ToolStripButton btnAddToMap;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator1;
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.cs 2012-08-21 10:20:45 UTC (rev 6943)
@@ -0,0 +1,100 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.ObjectModels.Common;
+ public partial class LiveMapEditorRepositoryView : UserControl
+ public LiveMapEditorRepositoryView()
+ InitializeComponent();
+ public void Init(IResourceService resSvc, ResourceTypes[] filteredTypes)
+ repoView.Init(resSvc, false);
+ repoView.ClearResourceTypeFilters();
+ if (filteredTypes != null)
+ foreach (var rt in filteredTypes)
+ repoView.AddResourceTypeFilter(rt);
+ private void btnAddToMap_Click(object sender, EventArgs e)
+ var h = this.RequestAddToMap;
+ if (h != null)
+ h(this, EventArgs.Empty);
+ private void btnOpen_Click(object sender, EventArgs e)
+ var h = this.RequestEdit;
+ if (h != null)
+ public event EventHandler RequestAddToMap;
+ public event EventHandler RequestEdit;
+ public IRepositoryItem SelectedItem
+ get { return repoView.SelectedItem; }
+ private void repoView_ItemSelected(object sender, EventArgs e)
+ var item = repoView.SelectedItem;
+ var condition = (item != null && !item.IsFolder && (item.ResourceType == ResourceTypes.LayerDefinition));
+ btnAddToMap.Enabled = btnEdit.Enabled = condition;
+ btnRefresh.Enabled = !condition;
+ private void btnRefresh_Click(object sender, EventArgs e)
+ if (item.IsFolder)
+ repoView.RefreshModel(item.ResourceId);
+ else
+ var parent = ResourceIdentifier.GetParentFolder(item.ResourceId);
+ repoView.RefreshModel(parent);
Added: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.resx
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/LiveMapEditorRepositoryView.resx 2012-08-21 10:20:45 UTC (rev 6943)
@@ -0,0 +1,246 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="btnAddToMap.Enabled" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="btnAddToMap.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ <value>Magenta</value>
+ </data>
+ <data name="btnAddToMap.Size" type="System.Drawing.Size, System.Drawing">
+ <value>23, 22</value>
+ </data>
+ <data name="btnAddToMap.Text" xml:space="preserve">
+ <value>Add to Map</value>
+ </data>
+ <data name="toolStripSeparator1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>6, 25</value>
+ </data>
+ <data name="btnEdit.Enabled" type="System.Boolean, mscorlib">
+ </data>
+ <data name="btnEdit.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="btnEdit.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnEdit.Text" xml:space="preserve">
+ <value>Edit Resource</value>
+ </data>
+ <data name="btnRefresh.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+ </data>
+ <data name="btnRefresh.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnRefresh.Text" xml:space="preserve">
+ <value>Refresh</value>
+ </data>
+ <data name="toolStrip1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 0</value>
+ </data>
+ <data name="toolStrip1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>254, 25</value>
+ </data>
+ <data name="toolStrip1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="toolStrip1.Text" xml:space="preserve">
+ <value>toolStrip1</value>
+ </data>
+ <data name=">>toolStrip1.Name" xml:space="preserve">
+ </data>
+ <data name=">>toolStrip1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>toolStrip1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>toolStrip1.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="repoView.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Fill</value>
+ </data>
+ <data name="repoView.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 25</value>
+ </data>
+ <data name="repoView.Size" type="System.Drawing.Size, System.Drawing">
+ <value>254, 356</value>
+ </data>
+ <data name="repoView.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>repoView.Name" xml:space="preserve">
+ <value>repoView</value>
+ </data>
+ <data name=">>repoView.Type" xml:space="preserve">
+ <value>Maestro.Editors.Common.RepositoryView, Maestro.Editors, Version=5.0.0.6640, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
+ </data>
+ <data name=">>repoView.Parent" xml:space="preserve">
+ </data>
+ <data name=">>repoView.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <value>True</value>
+ </metadata>
+ <data name="$this.Size" type="System.Drawing.Size, System.Drawing">
+ <value>254, 381</value>
+ </data>
+ <data name=">>btnAddToMap.Name" xml:space="preserve">
+ <value>btnAddToMap</value>
+ </data>
+ <data name=">>btnAddToMap.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>toolStripSeparator1.Name" xml:space="preserve">
+ <value>toolStripSeparator1</value>
+ </data>
+ <data name=">>toolStripSeparator1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnEdit.Name" xml:space="preserve">
+ <value>btnEdit</value>
+ </data>
+ <data name=">>btnEdit.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnRefresh.Name" xml:space="preserve">
+ <value>btnRefresh</value>
+ </data>
+ <data name=">>btnRefresh.Type" xml:space="preserve">
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>LiveMapEditorRepositoryView</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Editors/Resources/folder-horizontal-open.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Resources/folder-horizontal-open.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
More information about the mapguide-commits
