[mapguide-commits] r6970 - in branches/2.4/MgDev/Desktop/Samples: AdvancedSample BasicSample SampleExtension
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Aug 30 11:10:01 PDT 2012
Author: jng
Date: 2012-08-30 11:10:00 -0700 (Thu, 30 Aug 2012)
New Revision: 6970
Added:
   branches/2.4/MgDev/Desktop/Samples/AdvancedSample/AdvancedSample.Nuget.Net40.csproj
   branches/2.4/MgDev/Desktop/Samples/AdvancedSample/app.config
   branches/2.4/MgDev/Desktop/Samples/BasicSample/BasicSample.Nuget.Net40.csproj
   branches/2.4/MgDev/Desktop/Samples/BasicSample/app.config
   branches/2.4/MgDev/Desktop/Samples/SampleExtension/SampleExtension.Nuget.Net40.csproj
Add a nuget-ready version of the samples
Property changes on: branches/2.4/MgDev/Desktop/Samples/AdvancedSample
___________________________________________________________________
Added: svn:ignore
   + bin
obj
Added: branches/2.4/MgDev/Desktop/Samples/AdvancedSample/AdvancedSample.Nuget.Net40.csproj
--- branches/2.4/MgDev/Desktop/Samples/AdvancedSample/AdvancedSample.Nuget.Net40.csproj	                        (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/AdvancedSample/AdvancedSample.Nuget.Net40.csproj	2012-08-30 18:10:00 UTC (rev 6970)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project ToolsVersion="4.0" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|x86' ">
+    <PlatformTarget>x86</PlatformTarget>
+    <OutputPath>bin\x86\Debug\</OutputPath>
+  </PropertyGroup>
+  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|x86' ">
+    <OutputPath>bin\x86\Release\</OutputPath>
+  </PropertyGroup>
+  <PropertyGroup>
+    <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+    <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+    <ProductVersion>9.0.30729</ProductVersion>
+    <SchemaVersion>2.0</SchemaVersion>
+    <ProjectGuid>{AB9B45B7-38BF-4FFD-B809-A23F74A6C505}</ProjectGuid>
+    <OutputType>WinExe</OutputType>
+    <AppDesignerFolder>Properties</AppDesignerFolder>
+    <RootNamespace>AdvancedSample</RootNamespace>
+    <AssemblyName>AdvancedSample</AssemblyName>
+    <TargetFrameworkVersion>v4.0</TargetFrameworkVersion>
+    <FileAlignment>512</FileAlignment>
+    <FileUpgradeFlags>
+    </FileUpgradeFlags>
+    <UpgradeBackupLocation>
+    </UpgradeBackupLocation>
+    <OldToolsVersion>3.5</OldToolsVersion>
+    <TargetFrameworkProfile>Client</TargetFrameworkProfile>
+    <PublishUrl>publish\</PublishUrl>
+    <Install>true</Install>
+    <InstallFrom>Disk</InstallFrom>
+    <UpdateEnabled>false</UpdateEnabled>
+    <UpdateMode>Foreground</UpdateMode>
+    <UpdateInterval>7</UpdateInterval>
+    <UpdateIntervalUnits>Days</UpdateIntervalUnits>
+    <UpdatePeriodically>false</UpdatePeriodically>
+    <UpdateRequired>false</UpdateRequired>
+    <MapFileExtensions>true</MapFileExtensions>
+    <ApplicationRevision>0</ApplicationRevision>
+    <ApplicationVersion>1.0.0.%2a</ApplicationVersion>
+    <IsWebBootstrapper>false</IsWebBootstrapper>
+    <UseApplicationTrust>false</UseApplicationTrust>
+    <BootstrapperEnabled>true</BootstrapperEnabled>
+  </PropertyGroup>
+  <ItemGroup>
+    <Reference Include="System" />
+    <Reference Include="System.Data" />
+    <Reference Include="System.Deployment" />
+    <Reference Include="System.Drawing" />
+    <Reference Include="System.Windows.Forms" />
+    <Reference Include="System.Xml" />
+  </ItemGroup>
+  <ItemGroup>
+    <Compile Include="MainForm.cs">
+      <SubType>Form</SubType>
+    </Compile>
+    <Compile Include="MainForm.Designer.cs">
+      <DependentUpon>MainForm.cs</DependentUpon>
+    </Compile>
+    <Compile Include="Program.cs" />
+    <Compile Include="Properties\AssemblyInfo.cs" />
+    <EmbeddedResource Include="MainForm.resx">
+    </EmbeddedResource>
+    <EmbeddedResource Include="Properties\Resources.resx">
+      <Generator>ResXFileCodeGenerator</Generator>
+      <LastGenOutput>Resources.Designer.cs</LastGenOutput>
+      <SubType>Designer</SubType>
+    <Compile Include="Properties\Resources.Designer.cs">
+      <AutoGen>True</AutoGen>
+      <DependentUpon>Resources.resx</DependentUpon>
+      <DesignTime>True</DesignTime>
+    </Compile>
+    <None Include="app.config" />
+    <None Include="Properties\Settings.settings">
+      <Generator>SettingsSingleFileGenerator</Generator>
+      <LastGenOutput>Settings.Designer.cs</LastGenOutput>
+    </None>
+    <Compile Include="Properties\Settings.Designer.cs">
+      <DependentUpon>Settings.settings</DependentUpon>
+      <DesignTimeSharedInput>True</DesignTimeSharedInput>
+    </Compile>
+  </ItemGroup>
+  <ItemGroup>
+    <Content Include="RedlineLayer.xml">
+      <CopyToOutputDirectory>Always</CopyToOutputDirectory>
+    </Content>
+  </ItemGroup>
+  <ItemGroup>
+    <BootstrapperPackage Include="Microsoft.Net.Client.3.5">
+      <Visible>False</Visible>
+      <ProductName>.NET Framework 3.5 SP1 Client Profile</ProductName>
+      <Install>false</Install>
+    </BootstrapperPackage>
+    <BootstrapperPackage Include="Microsoft.Net.Framework.3.5.SP1">
+      <ProductName>.NET Framework 3.5 SP1</ProductName>
+    <BootstrapperPackage Include="Microsoft.Windows.Installer.3.1">
+      <ProductName>Windows Installer 3.1</ProductName>
+  </ItemGroup>
+  <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+  <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+       Other similar extension points exist, see Microsoft.Common.targets.
+  <Target Name="BeforeBuild">
+  </Target>
+  <Target Name="AfterBuild">
+  </Target>
+  <PropertyGroup>
+    <PostBuildEvent>
+    </PostBuildEvent>
+  </PropertyGroup>
+</Project>
\ No newline at end of file
Added: branches/2.4/MgDev/Desktop/Samples/AdvancedSample/app.config
--- branches/2.4/MgDev/Desktop/Samples/AdvancedSample/app.config	                        (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/AdvancedSample/app.config	2012-08-30 18:10:00 UTC (rev 6970)
@@ -0,0 +1,3 @@
+<?xml version="1.0"?>
+<configuration>
+<startup><supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0,Profile=Client"/></startup></configuration>
Property changes on: branches/2.4/MgDev/Desktop/Samples/BasicSample
Added: svn:ignore
   + bin
obj
Added: branches/2.4/MgDev/Desktop/Samples/BasicSample/BasicSample.Nuget.Net40.csproj
--- branches/2.4/MgDev/Desktop/Samples/BasicSample/BasicSample.Nuget.Net40.csproj	                        (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/BasicSample/BasicSample.Nuget.Net40.csproj	2012-08-30 18:10:00 UTC (rev 6970)
@@ -0,0 +1,115 @@
+  </PropertyGroup>
+  </PropertyGroup>
+  <PropertyGroup>
+    <ProjectGuid>{BE473CB6-718D-4654-9B0F-F1F9A327BD07}</ProjectGuid>
+    <RootNamespace>BasicSample</RootNamespace>
+    <AssemblyName>BasicSample</AssemblyName>
+  </PropertyGroup>
+  <ItemGroup>
+  </ItemGroup>
+  <ItemGroup>
+    </Compile>
+    </Compile>
+    </Compile>
+    </None>
+    </Compile>
+  </ItemGroup>
+  <ItemGroup>
+  </ItemGroup>
+  </Target>
+  </Target>
+  <PropertyGroup>
+    <PostBuildEvent>
+    </PostBuildEvent>
+  </PropertyGroup>
+</Project>
Added: branches/2.4/MgDev/Desktop/Samples/BasicSample/app.config
--- branches/2.4/MgDev/Desktop/Samples/BasicSample/app.config	                        (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/BasicSample/app.config	2012-08-30 18:10:00 UTC (rev 6970)
@@ -0,0 +1,3 @@
+<configuration>
Added: branches/2.4/MgDev/Desktop/Samples/SampleExtension/SampleExtension.Nuget.Net40.csproj
--- branches/2.4/MgDev/Desktop/Samples/SampleExtension/SampleExtension.Nuget.Net40.csproj	                        (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/SampleExtension/SampleExtension.Nuget.Net40.csproj	2012-08-30 18:10:00 UTC (rev 6970)
@@ -0,0 +1,228 @@
+  <PropertyGroup>
+    <ProductVersion>8.0.30703</ProductVersion>
+    <ProjectGuid>{942C10FD-F7F5-4E68-806D-32EB23A1DD35}</ProjectGuid>
+    <OutputType>Library</OutputType>
+    <RootNamespace>SampleExtension</RootNamespace>
+    <AssemblyName>SampleExtension</AssemblyName>
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|x64'">
+    <DebugSymbols>true</DebugSymbols>
+    <OutputPath>bin\x64\Debug\</OutputPath>
+    <DefineConstants>DEBUG;TRACE</DefineConstants>
+    <DebugType>full</DebugType>
+    <PlatformTarget>x64</PlatformTarget>
+    <ErrorReport>prompt</ErrorReport>
+    <CodeAnalysisIgnoreBuiltInRuleSets>true</CodeAnalysisIgnoreBuiltInRuleSets>
+    <CodeAnalysisIgnoreBuiltInRules>true</CodeAnalysisIgnoreBuiltInRules>
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Release|x64'">
+    <OutputPath>..\bin\Release64\</OutputPath>
+    <DefineConstants>TRACE</DefineConstants>
+    <Optimize>true</Optimize>
+    <DebugType>pdbonly</DebugType>
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Debug|x86'">
+  </PropertyGroup>
+  <PropertyGroup Condition="'$(Configuration)|$(Platform)' == 'Release|x86'">
+  </PropertyGroup>
+  <ItemGroup>
+    <Reference Include="System.Core" />
+    <Reference Include="System.Xml.Linq" />
+    <Reference Include="System.Data.DataSetExtensions" />
+    <Reference Include="Microsoft.CSharp" />
+  </ItemGroup>
+  <ItemGroup>
+    <Compile Include="AnalyzingFeatures.cs" />
+    <Compile Include="AnalyzingFeatures.Designer.cs">
+      <DependentUpon>AnalyzingFeatures.cs</DependentUpon>
+    </Compile>
+    <Compile Include="BufferHelper.cs" />
+    <Compile Include="CustomOutput.cs" />
+    <Compile Include="CustomOutput.Designer.cs">
+      <DependentUpon>CustomOutput.cs</DependentUpon>
+    </Compile>
+    <Compile Include="DigitizingAndRedlining.cs" />
+    <Compile Include="DigitizingAndRedlining.Designer.cs">
+      <DependentUpon>DigitizingAndRedlining.cs</DependentUpon>
+    </Compile>
+    <Compile Include="HelloMap.cs" />
+    <Compile Include="HelloMap.Designer.cs">
+      <DependentUpon>HelloMap.cs</DependentUpon>
+    </Compile>
+    <Compile Include="HelloViewer.cs" />
+    <Compile Include="HelloViewer.Designer.cs">
+      <DependentUpon>HelloViewer.cs</DependentUpon>
+    </Compile>
+    <Compile Include="InteractingWithLayers.cs" />
+    <Compile Include="InteractingWithLayers.Designer.cs">
+      <DependentUpon>InteractingWithLayers.cs</DependentUpon>
+    </Compile>
+    <Compile Include="LayerDefinitionFactory.cs" />
+    <Compile Include="Layers.Designer.cs" />
+    <Compile Include="LayerVisibilityDialog.cs">
+    </Compile>
+    <Compile Include="LayerVisibilityDialog.Designer.cs">
+      <DependentUpon>LayerVisibilityDialog.cs</DependentUpon>
+    </Compile>
+    <Compile Include="MgPlotToDwfComponent.cs" />
+    <Compile Include="MgProfileComponent.cs" />
+    <Compile Include="MgSampleTaskPaneComponent.cs" />
+    <Compile Include="MgStartupComponent.cs" />
+    <Compile Include="ModifyingMapsAndLayers.cs" />
+    <Compile Include="ModifyingMapsAndLayers.Designer.cs">
+      <DependentUpon>ModifyingMapsAndLayers.cs</DependentUpon>
+    </Compile>
+    <Compile Include="ParcelQueryResultWindow.cs">
+    </Compile>
+    <Compile Include="ParcelQueryResultWindow.Designer.cs">
+      <DependentUpon>ParcelQueryResultWindow.cs</DependentUpon>
+    </Compile>
+    <Compile Include="PrePostRendering.cs" />
+    <Compile Include="PrePostRendering.Designer.cs">
+      <DependentUpon>PrePostRendering.cs</DependentUpon>
+    </Compile>
+    <Compile Include="ResourceIdDialog.cs">
+    </Compile>
+    <Compile Include="ResourceIdDialog.Designer.cs">
+      <DependentUpon>ResourceIdDialog.cs</DependentUpon>
+    </Compile>
+    <Compile Include="SampleComponents.cs" />
+    <Compile Include="SamplesTaskPane.cs" />
+    <Compile Include="SamplesTaskPane.Designer.cs">
+      <DependentUpon>SamplesTaskPane.cs</DependentUpon>
+    </Compile>
+    <Compile Include="SelectedFeaturesWindow.cs">
+    </Compile>
+    <Compile Include="SelectedFeaturesWindow.Designer.cs">
+      <DependentUpon>SelectedFeaturesWindow.cs</DependentUpon>
+    </Compile>
+    <Compile Include="WorkingWithFeatureData.cs" />
+    <Compile Include="WorkingWithFeatureData.Designer.cs">
+      <DependentUpon>WorkingWithFeatureData.cs</DependentUpon>
+    </Compile>
+    <Compile Include="XmlResponseDialog.cs">
+    </Compile>
+    <Compile Include="XmlResponseDialog.Designer.cs">
+      <DependentUpon>XmlResponseDialog.cs</DependentUpon>
+    </Compile>
+    <Service Include="{94E38DFF-614B-4cbd-B67C-F211BB35CE8B}" />
+  </ItemGroup>
+  <ItemGroup>
+    <EmbeddedResource Include="AnalyzingFeatures.resx">
+    <EmbeddedResource Include="CustomOutput.resx">
+    <EmbeddedResource Include="DigitizingAndRedlining.resx">
+    <EmbeddedResource Include="HelloMap.resx">
+    <EmbeddedResource Include="HelloViewer.resx">
+    <EmbeddedResource Include="InteractingWithLayers.resx">
+    <EmbeddedResource Include="Layers.resx" />
+    <EmbeddedResource Include="LayerVisibilityDialog.resx">
+    <EmbeddedResource Include="ModifyingMapsAndLayers.resx">
+    <EmbeddedResource Include="ParcelQueryResultWindow.resx">
+    <EmbeddedResource Include="PrePostRendering.resx">
+    <EmbeddedResource Include="ResourceIdDialog.resx">
+    <EmbeddedResource Include="SamplesTaskPane.resx">
+    <EmbeddedResource Include="SelectedFeaturesWindow.resx">
+    <EmbeddedResource Include="WorkingWithFeatureData.resx">
+    <EmbeddedResource Include="XmlResponseDialog.resx">
+  </ItemGroup>
+  <ItemGroup>
+    <None Include="Resources\arearule.templ" />
+    <None Include="Resources\areatypestyle.templ" />
+    <None Include="Resources\layerdefinition.templ" />
+    <None Include="Resources\linerule.templ" />
+    <None Include="Resources\linetypestyle.templ" />
+    <None Include="Resources\marksymbol.templ" />
+    <None Include="Resources\pointrule.templ" />
+    <None Include="Resources\pointtypestyle.templ" />
+    <None Include="Resources\scalerange.templ" />
+    <None Include="Resources\textsymbol.templ" />
+  </ItemGroup>
+  <ItemGroup>
+    <Content Include="Resources\BufferLayerDefinition.txt" />
+    <Content Include="Resources\ParcelMarker.txt" />
+    <Content Include="Resources\RecentlyBuilt.txt" />
+    <Content Include="Resources\Redline.txt" />
+  </ItemGroup>
+  <PropertyGroup>
+    <PostBuildEvent>
+    </PostBuildEvent>
+  </PropertyGroup>
+  </Target>
+  </Target>
+</Project>
More information about the mapguide-commits mailing list
