[mapguide-commits] r7241 - sandbox/adsk/2.5k/Common/Stylization
svn_mapguide at osgeo.org
Thu Dec 6 09:42:11 PST 2012
Author: waltweltonlair
Date: 2012-12-06 09:42:11 -0800 (Thu, 06 Dec 2012)
New Revision: 7241
sandbox/adsk/2.5k/Common/Stylization/SE_StyleVisitor.cpp
Merge trunk changeset 7240 into adsk/2.4k branch stream.
This is for ticket #2197 (The usage of "swscanf" results in bad performance in MgStylization.dll).
Modified: sandbox/adsk/2.5k/Common/Stylization/SE_StyleVisitor.cpp
--- sandbox/adsk/2.5k/Common/Stylization/SE_StyleVisitor.cpp 2012-12-06 17:34:56 UTC (rev 7240)
+++ sandbox/adsk/2.5k/Common/Stylization/SE_StyleVisitor.cpp 2012-12-06 17:42:11 UTC (rev 7241)
@@ -1,5 +1,5 @@
-// Copyright (C) 2007-2011 by Autodesk, Inc.
+// Copyright (C) 2007-2012 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
@@ -144,8 +144,81 @@
+#ifdef _DEBUG
+inline bool IsTag(const wchar_t& item)
+ return (item == L'm' || item == L'M'
+ || item == L'l' || item == L'L'
+ || item == L'h' || item == L'H'
+ || item == L'v' || item == L'V'
+ || item == L'a' || item == L'A'
+ || item == L'z' || item == L'Z');
+#endif
bool SE_StyleVisitor::ParseDouble(const wchar_t*& str, double& val)
+ // Using "swscanf" results in slow performance. We therefore first try to parse it
+ // using a quick algorithm which implements the same functionality as the statement:
+ // swscanf(str, L" %lf%n", &val, &length)
+ // If this quick algorithm fails, parse it again with "swscanf" to get the same
+ // robust behavior as before.
+ // The source "str" is like "918 v -49.12458 M 87.76316,113.56123".
+ bool quick_parse = true;
+ const int BUFFER_SIZE = 128;
+ wchar_t buffer[BUFFER_SIZE];
+ int buffer_len = 0;
+ const wchar_t* strTmp = str;
+ while (*strTmp != L'\0')
+ if (*strTmp == L' ')
+ if (buffer_len > 0)
+ break;
+ else
+ strTmp++;
+#ifdef _DEBUG // We shouldn't be here unless the geometry string is malformed.
+ else if (*strTmp == L',')
+ // unexpected comma and ParseDoublePair should be used
+ _ASSERT(false);
+ quick_parse = false;
+ break;
+ else if (IsTag(*strTmp))
+ // white-space must be missing
+ _ASSERT(false);
+ quick_parse = (buffer_len > 0);
+ break;
+#endif
+ else
+ buffer[buffer_len] = *strTmp++;
+ buffer_len++;
+ if (buffer_len >= BUFFER_SIZE)
+ // the buffer is too small
+ _ASSERT(false);
+ break;
+ if (quick_parse && buffer_len > 0 && buffer_len < BUFFER_SIZE)
+ buffer[buffer_len] = L'\0';
+ val = _wtof(buffer);
+ str = strTmp;
+ return true;
+ // The quick parser algorithm failed. Perhaps the geometry string is
+ // empty or malformed. Fallback and directly parse it using "swscanf".
size_t length = 0;
swscanf(str, L" %lf%n", &val, &length);
str += length;
@@ -155,6 +228,100 @@
bool SE_StyleVisitor::ParseDoublePair(const wchar_t*& str, double& x, double& y)
+ // swscanf(str, L" %lf , %lf%n", &x, &y, &length)
+ // The source "str" is like "228.85853,113.60915 h 0.95853 L 230.82351,113.56123 ".
+ bool read_x = false;
+ if (read_x)
+ break;
+ else
+ strTmp++;
+ else
+ if (buffer_len == 0)
+ strTmp++;
+ else
+ // the comma must be missing or ParseDouble should be used
+ _ASSERT(false);
+ break;
+ _ASSERT(false);
+ break;
+ if (!read_x)
+ x = _wtof(buffer);
+ read_x = true;
+ else
+ // malformed geometry string
+ _ASSERT(false);
+ break;
+ buffer_len = 0;
+ strTmp++;
+ // the white-space must be missing
+ _ASSERT(false);
+ quick_parse = (read_x && buffer_len > 0);
+ break;
+#endif
+ else
+ buffer_len++;
+ _ASSERT(false);
+ break;
+ if (quick_parse && read_x && buffer_len > 0 && buffer_len < BUFFER_SIZE)
+ y = _wtof(buffer);
+ str = strTmp;
+ return true;
size_t length = 0;
swscanf(str, L" %lf , %lf%n", &x, &y, &length);
str += length;
More information about the mapguide-commits
