[mapguide-commits] r7245 - sandbox/jng/swig-java/Common/MapGuideCommon/Services
svn_mapguide at osgeo.org
Fri Dec 7 08:27:03 PST 2012
Author: jng
Date: 2012-12-07 08:27:01 -0800 (Fri, 07 Dec 2012)
New Revision: 7245
sandbox/jng/swig-java/Common/MapGuideCommon/Services/MappingService.h
Remove characters that are tripping up javac compilation on linux
Modified: sandbox/jng/swig-java/Common/MapGuideCommon/Services/MappingService.h
--- sandbox/jng/swig-java/Common/MapGuideCommon/Services/MappingService.h 2012-12-07 01:54:38 UTC (rev 7244)
+++ sandbox/jng/swig-java/Common/MapGuideCommon/Services/MappingService.h 2012-12-07 16:27:01 UTC (rev 7245)
@@ -337,7 +337,7 @@
/// The requested image height in pixels.
/// \param format (String/string)
/// Input
- /// Image format, from MgImageFormats. Example: PNG, JPG, PNG8, etc
+ /// Image format, from MgImageFormats. Example: PNG, JPG, PNG8, etc
/// \param geomType (int)
/// Input
/// The type of symbolization required: 1=Point, 2=Line, 3=Area, 4=Composite
@@ -400,7 +400,7 @@
/// \return
/// A byte reader containing an XML document with the feature
/// information described in GML (Geography Markup Language). GML
- /// is defined by the OpenGIS® consortium. A specification for
+ /// is defined by the OpenGIS consortium. A specification for
/// this language can be found at: /// https://portal.opengeospatial.org/files/?artifact_id=7174
@@ -439,7 +439,7 @@
/// \return
/// Returns a byte reader containing an XML document with the feature
More information about the mapguide-commits
