[mapguide-commits] r6485 - trunk/Installer/Libraries/MapGuide Web
Extensions
svn_mapguide at osgeo.org
Tue Feb 7 10:42:03 EST 2012
Author: jng
Date: 2012-02-07 07:42:03 -0800 (Tue, 07 Feb 2012)
New Revision: 6485
trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs
IIS7 wix installer updates and fixes
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs 2012-02-07 15:40:11 UTC (rev 6484)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs 2012-02-07 15:42:03 UTC (rev 6485)
@@ -12,12 +12,12 @@
<!-- Create the application pool -->
<CustomAction Id="MapGuideIIS7_I_CreateAppPool_Cmd" Property="MapGuideIIS7_I_CreateAppPool" Execute="immediate"
- Value="[AppCmd] add apppool /name:"[APP_POOL_NAME]"" />
+ Value="[AppCmd] add apppool /name:"[APP_POOL_NAME]" /managedRuntimeVersion:"v4.0"" />
<CustomAction Id="MapGuideIIS7_I_CreateAppPool" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<!-- Set up FastCGI -->
<CustomAction Id="MapGuideIIS7_I_CreateFastCgi_Cmd" Property="MapGuideIIS7_I_CreateFastCgi" Execute="immediate"
- Value="[AppCmd] add apppool set config /section:system.webServer/fastCGI /+[\[]fullPath="[PHPLOCATION]php-cgi.exe"[\]]" />
+ Value="[AppCmd] set config /section:system.webServer/fastCGI /+[\[]fullPath="[PHPLOCATION]php-cgi.exe"[\]]" />
<CustomAction Id="MapGuideIIS7_I_CreateFastCgi" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
<!-- Set the application pool's properties -->
@@ -67,7 +67,7 @@
<!-- Set App Pool to 32-bit mode (applies to 64-bit windows) -->
<CustomAction Id="MapGuideIIS7_I_Set32BitAppPool_Cmd" Property="MapGuideIIS7_I_Set32BitAppPool" Execute="immediate"
- Value="[AppCmd] apppool set /apppool.name:"[APP_POOL_NAME]" /enable32BitAppOnWin64:true" />
+ Value="[AppCmd] set apppool /apppool.name:"[APP_POOL_NAME]" /enable32BitAppOnWin64:true" />
<CustomAction Id="MapGuideIIS7_I_Set32BitAppPool" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no" />
<!-- Make the MapGuide application run in the MapGuide app pool -->
More information about the mapguide-commits
