[mapguide-commits] r6829 - in trunk/Tools/Maestro: Maestro.MapViewer OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Mapping OSGeo.MapGuide.MaestroAPI/Services OSGeo.MapGuide.MaestroAPI.Http OSGeo.MapGuide.MaestroAPI.Local OSGeo.MapGuide.MaestroAPI.Native
svn_mapguide at osgeo.org
Sun Jul 1 06:54:36 PDT 2012
Author: jng
Date: 2012-07-01 06:54:36 -0700 (Sun, 01 Jul 2012)
New Revision: 6829
trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
This submission includes the following changes:
- Remove obsoleted QueryMapFeatures APIs in IMappingService
- Update the existing QueryMapFeatures API to take a RuntimeMap instead of a resource id to match updated rendering APIs
- Update the local QueryMapFeatures implementation to map directly to the newly implemented QueryFeatures API from the recent mg-desktop release.
Modified: trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs 2012-07-01 11:13:41 UTC (rev 6828)
+++ trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs 2012-07-01 13:54:36 UTC (rev 6829)
@@ -1726,7 +1726,9 @@
if (args.SelectionRenderingOptions != null)
- res.SelectionImage = Image.FromStream(_map.RenderDynamicOverlay(null, args.SelectionRenderingOptions.Format, args.SelectionRenderingOptions.Color, args.SelectionRenderingOptions.Behavior));
+ //HACK: HTTP provider is stateless, so passing the selection is not only redundant, but will probably break on large selections.
+ var sel = (_map.CurrentConnection.ProviderName.ToUpper().Equals("MAESTRO.HTTP")) ? null : _map.Selection;
+ res.SelectionImage = Image.FromStream(_map.RenderDynamicOverlay(sel, args.SelectionRenderingOptions.Format, args.SelectionRenderingOptions.Color, args.SelectionRenderingOptions.Behavior));
e.Result = res;
@@ -2034,7 +2036,7 @@
var sw = new Stopwatch();
sw.Start();
#endif
- _map.QueryMapFeatures(wkt, -1, true, "INTERSECTS", null);
+ _map.QueryMapFeatures(wkt, -1, true, "INTERSECTS", CreateQueryOptionsForSelection());
#if TRACE
sw.Stop();
Trace.TraceInformation("Selection processing completed in {0}ms", sw.ElapsedMilliseconds);
@@ -2046,6 +2048,14 @@
handler(this, EventArgs.Empty);
+ private QueryMapOptions CreateQueryOptionsForSelection()
+ return new QueryMapOptions()
+ LayerAttributeFilter = QueryMapFeaturesLayerAttributes.OnlySelectable | QueryMapFeaturesLayerAttributes.OnlyVisible
protected override void OnResize(EventArgs e)
OnControlResized(this, e);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2012-07-01 11:13:41 UTC (rev 6828)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs 2012-07-01 13:54:36 UTC (rev 6829)
@@ -1551,12 +1551,12 @@
format);
- public string QueryMapFeatures(string wkt, int maxFeatures, bool persist, string selectionVariant, QueryMapOptions extraOptions)
+ public virtual string QueryMapFeatures(string wkt, int maxFeatures, bool persist, string selectionVariant, QueryMapOptions extraOptions)
if (_mapSvc == null)
throw new NotSupportedException();
- var ret = _mapSvc.QueryMapFeatures(this.Name, maxFeatures, wkt, true, selectionVariant, extraOptions);
+ var ret = _mapSvc.QueryMapFeatures(this, maxFeatures, wkt, true, selectionVariant, extraOptions);
//Need to re-sync the selection as this will probably have been changed
ReloadSelection();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2012-07-01 11:13:41 UTC (rev 6828)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2012-07-01 13:54:36 UTC (rev 6829)
@@ -112,7 +112,7 @@
/// </summary>
public RuntimeMap Parent { get; private set; }
- private void Initialize(ILayerDefinition ldf)
+ protected void Initialize(ILayerDefinition ldf)
Check.NotNull(ldf, "ldf");
this.LayerDefinitionID = ldf.ResourceID;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs 2012-07-01 11:13:41 UTC (rev 6828)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs 2012-07-01 13:54:36 UTC (rev 6829)
@@ -171,32 +171,9 @@
#region Rendering
- /// <summary>
- /// Selects features from a runtime map, returning a selection Xml.
- /// </summary>
- /// <param name="runtimeMapName">The map to query. NOT a resourceID, only the map name!</param>
- /// <param name="wkt">The WKT of the geometry to query with (always uses intersection)</param>
- /// <param name="persist">True if the selection should be saved in the runtime map, false otherwise.</param>
- /// <returns>The selection Xml, or an empty string if there were no data.</returns>
- public string QueryMapFeatures(string runtimeMapName, string wkt, bool persist)
- return QueryMapFeatures(runtimeMapName, wkt, persist, QueryMapFeaturesLayerAttributes.Default, false);
+ public abstract string QueryMapFeatures(RuntimeMap rtMap, int maxFeatures, string wkt, bool persist, string selectionVariant, QueryMapOptions extraOptions);
/// <summary>
- /// </summary>
- /// <param name="attributes">The type of layer to include in the query</param>
- /// <param name="raw">True if the result should contain the tooltip and link info</param>
- abstract public string QueryMapFeatures(string runtimeMapName, string wkt, bool persist, QueryMapFeaturesLayerAttributes attributes, bool raw);
- public abstract string QueryMapFeatures(string runtimeMapName, int maxFeatures, string wkt, bool persist, string selectionVariant, QueryMapOptions extraOptions);
- /// <summary>
/// Renders a minature bitmap of the layers style
/// </summary>
/// <param name="scale">The scale for the bitmap to match</param>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs 2012-07-01 11:13:41 UTC (rev 6828)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs 2012-07-01 13:54:36 UTC (rev 6829)
@@ -316,37 +316,15 @@
System.Drawing.Image GetLegendImage(double scale, string layerdefinition, int themeIndex, int type, int width, int height, string format);
/// <summary>
- /// </summary>
- [Obsolete("Use the version of QueryMapFeatures that isn't marked Obsolete")]
- string QueryMapFeatures(string runtimeMapName, string wkt, bool persist, QueryMapFeaturesLayerAttributes attributes, bool raw);
- /// <summary>
- /// </summary>
- string QueryMapFeatures(string runtimeMapName, string wkt, bool persist);
- /// <summary>
/// Identifies features that meet the specified spatial selection criteria. These features can be persisted as selected features in a map. QueryMapFeatures returns an XML document describing the set of selected features. If a single feature is selected, the XML contains the tooltip, hyperlink, and properties of the feature.
/// </summary>
- /// <param name="runtimeMapName"></param>
+ /// <param name="map"></param>
/// <param name="maxFeatures"></param>
/// <param name="wkt"></param>
/// <param name="persist"></param>
/// <param name="selectionVariant"></param>
/// <param name="extraOptions"></param>
/// <returns></returns>
- string QueryMapFeatures(string runtimeMapName, int maxFeatures, string wkt, bool persist, string selectionVariant, QueryMapOptions extraOptions);
+ string QueryMapFeatures(RuntimeMap map, int maxFeatures, string wkt, bool persist, string selectionVariant, QueryMapOptions extraOptions);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2012-07-01 11:13:41 UTC (rev 6828)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2012-07-01 13:54:36 UTC (rev 6829)
@@ -1800,8 +1800,9 @@
- public override string QueryMapFeatures(string runtimeMapName, int maxFeatures, string wkt, bool persist, string selectionVariant, QueryMapOptions extraOptions)
+ public override string QueryMapFeatures(RuntimeMap map, int maxFeatures, string wkt, bool persist, string selectionVariant, QueryMapOptions extraOptions)
+ string runtimeMapName = map.Name;
//The request may execeed the url limit of the server, when large geometries
System.IO.MemoryStream ms = new System.IO.MemoryStream();
System.Net.WebRequest req = m_reqBuilder.QueryMapFeatures(runtimeMapName, maxFeatures, wkt, persist, selectionVariant, extraOptions, ms);
@@ -1818,48 +1819,6 @@
return sr.ReadToEnd();
- public override string QueryMapFeatures(string runtimeMapName, string wkt, bool persist, QueryMapFeaturesLayerAttributes attributes, bool raw)
- //The request may execeed the url limit of the server, when large geometries
- System.IO.MemoryStream ms = new System.IO.MemoryStream();
- System.Net.WebRequest req = m_reqBuilder.QueryMapFeatures(runtimeMapName, persist, wkt, ms, attributes);
- req.Timeout = 200 * 1000;
- ms.Position = 0;
- using (System.IO.Stream rs = req.GetRequestStream())
- Utility.CopyStream(ms, rs);
- rs.Flush();
- System.Xml.XmlDocument doc = new System.Xml.XmlDocument();
-#if DEBUG
- System.IO.MemoryStream xms = new System.IO.MemoryStream();
- Utility.CopyStream(req.GetResponse().GetResponseStream(), xms);
- xms.Position = 0;
- string f = System.Text.Encoding.UTF8.GetString(xms.ToArray());
- if (raw)
- return f;
- xms.Position = 0;
- doc.Load(xms);
-#else
- if (raw)
- return System.Text.Encoding.UTF8.GetString(xms.ToArray());
- doc.Load(req.GetResponse().GetResponseStream());
-#endif
- if (doc.SelectSingleNode("FeatureInformation/FeatureSet") != null && doc["FeatureInformation"]["FeatureSet"].ChildNodes.Count > 0)
- return "<FeatureSet>" + doc["FeatureInformation"]["FeatureSet"].InnerXml + "</FeatureSet>";
- else
- return "";
public override string[] GetSchemas(string resourceId)
var req = m_reqBuilder.GetSchemas(resourceId);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2012-07-01 11:13:41 UTC (rev 6828)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2012-07-01 13:54:36 UTC (rev 6829)
@@ -629,7 +629,7 @@
public override Version SiteVersion
- get { return new Version(2, 4, 0, 0); }
+ get { return typeof(MgdMap).Assembly.GetName().Version; }
public override string[] GetCustomPropertyNames()
@@ -1107,7 +1107,7 @@
var ldfId = new MgResourceIdentifier(ldf.ResourceID);
var layer = new MgdLayer(ldfId, GetResourceService());
- return new LocalRuntimeMapLayer(impl, layer);
+ return new LocalRuntimeMapLayer(impl, layer, this);
public Stream RenderDynamicOverlay(Mapping.RuntimeMap map, Mapping.MapSelection selection, string format)
@@ -1263,19 +1263,57 @@
return new System.Drawing.Bitmap(new MgReadOnlyStream(fetch));
- public string QueryMapFeatures(string runtimeMapName, string wkt, bool persist, QueryMapFeaturesLayerAttributes attributes, bool raw)
+ public string QueryMapFeatures(RuntimeMap rtMap, int maxFeatures, string wkt, bool persist, string selectionVariant, QueryMapOptions extraOptions)
- return string.Empty; //TODO: Not needed for Live Map Editor, but will have problems when viewer component is used standalone
+ var impl = rtMap as LocalRuntimeMap;
+ if (impl == null)
+ throw new ArgumentException("Instance is not a LocalRuntimeMap", "map"); //LOCALIZEME
+ var rs = GetRenderingService();
+ var res = GetResourceService();
+ var map = impl.GetWrappedInstance();
- public string QueryMapFeatures(string runtimeMapName, int maxFeatures, string wkt, bool persist, string selectionVariant, QueryMapOptions extraOptions)
+ MgWktReaderWriter r = new MgWktReaderWriter();
+ MgStringCollection layerNames = null;
+ string featureFilter = "";
+ int layerAttributeFilter = 0;
+ int op = MgFeatureSpatialOperations.Intersects;
+ if (selectionVariant == "TOUCHES")
+ op = MgFeatureSpatialOperations.Touches;
+ else if (selectionVariant == "INTERSECTS")
+ op = MgFeatureSpatialOperations.Intersects;
+ else if (selectionVariant == "WITHIN")
+ op = MgFeatureSpatialOperations.Within;
+ else if (selectionVariant == "ENVELOPEINTERSECTS")
+ op = MgFeatureSpatialOperations.EnvelopeIntersects;
+ else
+ throw new ArgumentException("Unknown or unsupported selection variant: " + selectionVariant);
+ if (extraOptions != null)
+ if (!string.IsNullOrEmpty(extraOptions.FeatureFilter))
+ featureFilter = extraOptions.FeatureFilter;
+ if (extraOptions.LayerNames != null && extraOptions.LayerNames.Length > 0)
+ layerNames = new MgStringCollection();
+ foreach (var name in extraOptions.LayerNames)
+ layerNames.Add(name);
+ layerAttributeFilter = (int)extraOptions.LayerAttributeFilter;
+ MgdFeatureInformation info = rs.QueryFeatures(map, layerNames, r.Read(wkt), op, featureFilter, maxFeatures, layerAttributeFilter);
+ string xml = "";
+ GetByteReaderMethod fetch = () => { return info.ToXml(); };
+ using (var sr = new StreamReader(new MgReadOnlyStream(fetch)))
+ xml = sr.ReadToEnd();
+ impl.Selection.LoadXml(xml);
+ return xml;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs 2012-07-01 11:13:41 UTC (rev 6828)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalRuntimeMap.cs 2012-07-01 13:54:36 UTC (rev 6829)
@@ -24,6 +24,8 @@
using OSGeo.MapGuide.MaestroAPI.Mapping;
using System.Drawing;
using OSGeo.MapGuide.ObjectModels;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
namespace OSGeo.MapGuide.MaestroAPI.Local
@@ -36,10 +38,12 @@
internal class LocalRuntimeMap : RuntimeMap
private MgdMap _impl;
+ private LocalConnection _conn;
public LocalRuntimeMap(LocalConnection conn, MgdMap map) : base(conn)
_impl = map;
+ _conn = conn;
InitializeLayersAndGroups();
_disableChangeTracking = false;
@@ -61,7 +65,7 @@
//Then layers
for (int i = 0; i < layers.GetCount(); i++)
- this.Layers.Add(new LocalRuntimeMapLayer(this, layers.GetItem(i)));
+ this.Layers.Add(new LocalRuntimeMapLayer(this, layers.GetItem(i), _conn));
@@ -433,10 +437,13 @@
private LocalRuntimeMap _parent;
private MgLayerBase _impl;
- public LocalRuntimeMapLayer(LocalRuntimeMap parent, MgLayerBase layer) : base(parent)
+ internal LocalRuntimeMapLayer(LocalRuntimeMap parent, MgLayerBase layer, IResourceService resSvc) : base(parent)
_parent = parent;
_impl = layer;
+ var ldfId = layer.GetLayerDefinition();
+ var ldf = (ILayerDefinition)resSvc.GetResource(ldfId.ToString());
+ Initialize(ldf);
@@ -565,7 +572,7 @@
get
- return _impl.GetClassName();
+ return _impl.GetFeatureClassName();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2012-07-01 11:13:41 UTC (rev 6828)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2012-07-01 13:54:36 UTC (rev 6829)
@@ -1334,8 +1334,9 @@
return new MgReadOnlyStream(fetch);
+ public override string QueryMapFeatures(RuntimeMap rtMap, int maxFeatures, string wkt, bool persist, string selectionVariant, QueryMapOptions extraOptions)
+ string runtimeMapName = rtMap.Name;
MgRenderingService rs = this.Connection.CreateService(MgServiceType.RenderingService) as MgRenderingService;
MgResourceService res = this.Connection.CreateService(MgServiceType.ResourceService) as MgResourceService;
MgMap map = new MgMap();
@@ -1387,31 +1388,6 @@
return xml;
- MgRenderingService rs = this.Connection.CreateService(MgServiceType.RenderingService) as MgRenderingService;
- MgResourceService res = this.Connection.CreateService(MgServiceType.ResourceService) as MgResourceService;
- MgMap map = new MgMap();
- string mapname = runtimeMapName.IndexOf(":") > 0 ? new ResourceIdentifier(runtimeMapName).Path : runtimeMapName;
- map.Open(res, mapname);
- MgWktReaderWriter r = new MgWktReaderWriter();
- MgFeatureInformation info = rs.QueryFeatures(map, null, r.Read(wkt), (int)MgFeatureSpatialOperations.Intersects, "", -1, (int)attributes);
- string xml = "";
- GetByteReaderMethod fetch = () => { return info.ToXml(); };
- using (var sr = new StreamReader(new MgReadOnlyStream(fetch)))
- xml = sr.ReadToEnd();
- MgSelection sel = new MgSelection(map, xml);
- sel.Save(res, mapname);
- LogMethodCall("QueryMapFeatures", true, runtimeMapName, wkt, persist, (int)attributes, raw);
- return xml;
internal void InsertFeatures(MgResourceIdentifier fsId, string className, MgPropertyCollection props)
try
More information about the mapguide-commits
