[mapguide-commits] r6862 - in trunk/Tools/Maestro: Maestro.Base/Commands/SiteExplorer Maestro.Base/Properties OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Capability OSGeo.MapGuide.MaestroAPI.Local
svn_mapguide at osgeo.org
Fri Jul 6 07:58:34 PDT 2012
Author: jng
Date: 2012-07-06 07:58:34 -0700 (Fri, 06 Jul 2012)
New Revision: 6862
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/EditResourceHeaderCommand.cs
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/RepointCommand.cs
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ResourcePropertiesCommand.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalCapabilities.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Capability/ConnectionCapabilities.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IConnectionCapabilities.cs
Guard the local connection against commands that that require capabilities that this connection does not provide.
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/EditResourceHeaderCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/EditResourceHeaderCommand.cs 2012-07-06 13:47:48 UTC (rev 6861)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/EditResourceHeaderCommand.cs 2012-07-06 14:58:34 UTC (rev 6862)
@@ -37,6 +37,12 @@
var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
var conn = connMgr.GetConnection(exp.ConnectionName);
+ if (!IsValid(conn))
+ MessageService.ShowError(Properties.Resources.ConnectionDoesNotSupportRequiredInterfaces);
+ return;
var item = exp.SelectedItems[0];
var diag = new ResourceHeaderXmlDialog(item.ResourceId, conn.ResourceService);
if (item.IsFolder)
@@ -52,5 +58,10 @@
diag.ShowDialog();
+ private bool IsValid(OSGeo.MapGuide.MaestroAPI.IServerConnection conn)
+ return conn.Capabilities.SupportsResourceHeaders;
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/RepointCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/RepointCommand.cs 2012-07-06 13:47:48 UTC (rev 6861)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/RepointCommand.cs 2012-07-06 14:58:34 UTC (rev 6862)
@@ -41,6 +41,12 @@
var exp = wb.ActiveSiteExplorer;
+ return;
if (exp.SelectedItems.Length == 1)
var selected = exp.SelectedItems[0];
@@ -60,6 +66,11 @@
+ private bool IsValid(IServerConnection conn)
+ return conn.Capabilities.SupportsResourceReferences;
private void DoRepointMap(Workbench wb, OSGeo.MapGuide.MaestroAPI.IServerConnection conn, ResourceIdentifier resId)
var diag = new RepointerDialog(resId, conn.ResourceService);
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ResourcePropertiesCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ResourcePropertiesCommand.cs 2012-07-06 13:47:48 UTC (rev 6861)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/ResourcePropertiesCommand.cs 2012-07-06 14:58:34 UTC (rev 6862)
@@ -35,6 +35,12 @@
var conn = connMgr.GetConnection(wb.ActiveSiteExplorer.ConnectionName);
+ return;
//Can only show properties of one selected item
if (items.Length == 1)
@@ -43,5 +49,14 @@
dlg.ShowDialog(wb);
+ return conn.Capabilities.SupportsResourceHeaders &&
+ conn.Capabilities.SupportsResourceReferences &&
+ conn.Capabilities.SupportsResourceSecurity &&
+ conn.Capabilities.SupportsWfsPublishing &&
+ conn.Capabilities.SupportsWmsPublishing;
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2012-07-06 13:47:48 UTC (rev 6861)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs 2012-07-06 14:58:34 UTC (rev 6862)
@@ -459,6 +459,15 @@
/// <summary>
+ /// Looks up a localized string similar to The current connection does not support the required interfaces to perform this action.
+ /// </summary>
+ internal static string ConnectionDoesNotSupportRequiredInterfaces {
+ get {
+ return ResourceManager.GetString("ConnectionDoesNotSupportRequiredInterfaces", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Messages.
/// </summary>
internal static string Content_Messages {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2012-07-06 13:47:48 UTC (rev 6861)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx 2012-07-06 14:58:34 UTC (rev 6862)
@@ -2691,4 +2691,7 @@
<data name="LiveMapEditor" xml:space="preserve">
<value>Live Map Definition Editor</value>
</data>
+ <data name="ConnectionDoesNotSupportRequiredInterfaces" xml:space="preserve">
+ <value>The current connection does not support the required interfaces to perform this action</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Capability/ConnectionCapabilities.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Capability/ConnectionCapabilities.cs 2012-07-06 13:47:48 UTC (rev 6861)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Capability/ConnectionCapabilities.cs 2012-07-06 14:58:34 UTC (rev 6862)
@@ -279,5 +279,45 @@
return IsSupportedResourceType(resType.ToString());
+ /// <summary>
+ /// Gets whether this connection supports publishing resources for WFS
+ /// </summary>
+ public virtual bool SupportsWfsPublishing
+ get { return true; }
+ /// <summary>
+ /// Gets whether this connection supports publishing resources for WMS
+ /// </summary>
+ public virtual bool SupportsWmsPublishing
+ /// <summary>
+ /// Gets whether this connection supports resource reference tracking
+ /// </summary>
+ public virtual bool SupportsResourceReferences
+ /// <summary>
+ /// Gets whether this connection supports resource security
+ /// </summary>
+ public virtual bool SupportsResourceSecurity
+ /// <summary>
+ /// Gets whether this connection supports the concept of resource headers
+ /// </summary>
+ public virtual bool SupportsResourceHeaders
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IConnectionCapabilities.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IConnectionCapabilities.cs 2012-07-06 13:47:48 UTC (rev 6861)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IConnectionCapabilities.cs 2012-07-06 14:58:34 UTC (rev 6862)
@@ -57,6 +57,31 @@
bool SupportsResourcePreviews { get; }
/// <summary>
+ /// </summary>
+ bool SupportsWfsPublishing { get; }
+ /// <summary>
+ /// </summary>
+ bool SupportsWmsPublishing { get; }
+ /// <summary>
+ /// </summary>
+ bool SupportsResourceHeaders { get; }
+ /// <summary>
+ /// </summary>
+ bool SupportsResourceReferences { get; }
+ /// <summary>
+ /// </summary>
+ bool SupportsResourceSecurity { get; }
+ /// <summary>
/// Indicates if this current connection supports the specified resource type
/// </summary>
/// <param name="resType"></param>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalCapabilities.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalCapabilities.cs 2012-07-06 13:47:48 UTC (rev 6861)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalCapabilities.cs 2012-07-06 14:58:34 UTC (rev 6862)
@@ -67,5 +67,45 @@
get { return false; }
+ public override bool SupportsResourceReferences
+ get
+ return false;
+ public override bool SupportsResourceSecurity
+ get
+ return false;
+ public override bool SupportsWfsPublishing
+ get
+ return false;
+ public override bool SupportsWmsPublishing
+ get
+ return false;
+ public override bool SupportsResourceHeaders
+ get
+ return false;
More information about the mapguide-commits
