[mapguide-commits] r6760 - in trunk/Tools/Maestro: Maestro.Base/Commands/SiteExplorer OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI.Http OSGeo.MapGuide.MaestroAPI.Local OSGeo.MapGuide.MaestroAPI.Native
svn_mapguide at osgeo.org
Thu Jun 14 02:07:38 PDT 2012
Author: jng
Date: 2012-06-14 02:07:38 -0700 (Thu, 14 Jun 2012)
New Revision: 6760
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs
#2027: Add connection support for broadcasting change of session ids
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs 2012-06-14 02:27:24 UTC (rev 6759)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/TestResourceCompatibilityCommand.cs 2012-06-14 09:07:38 UTC (rev 6760)
@@ -298,5 +298,8 @@
public event RequestEventHandler RequestDispatched;
+ public event EventHandler SessionIDChanged;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs 2012-06-14 02:27:24 UTC (rev 6759)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs 2012-06-14 09:07:38 UTC (rev 6760)
@@ -120,6 +120,11 @@
string SessionID { get; }
/// <summary>
+ /// Raised when the session ID has changed
+ /// </summary>
+ event EventHandler SessionIDChanged;
+ /// <summary>
/// Gets or sets a value indicating if the session should automatically be restarted if it expires
/// </summary>
bool AutoRestartSession { get; set; }
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs 2012-06-14 02:27:24 UTC (rev 6759)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/MgServerConnectionBase.cs 2012-06-14 09:07:38 UTC (rev 6760)
@@ -104,13 +104,32 @@
RestartSession(true);
/// <summary>
/// Restarts the server session, and creates a new session ID
/// </summary>
/// <param name="throwException">If set to true, the call throws an exception if the call failed</param>
/// <returns>True if the creation succeed, false otherwise</returns>
- abstract public bool RestartSession(bool throwException);
+ public bool RestartSession(bool throwException)
+ var oldSessionId = this.SessionID;
+ var ret = RestartSessionInternal(throwException);
+ var newSessionId = this.SessionID;
+ if (!string.IsNullOrEmpty(oldSessionId))
+ if (oldSessionId != newSessionId)
+ var h = this.SessionIDChanged;
+ if (h != null)
+ h(this, EventArgs.Empty);
+ return ret;
+ protected abstract bool RestartSessionInternal(bool throwException);
#endregion
#region Site
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2012-06-14 02:27:24 UTC (rev 6759)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2012-06-14 09:07:38 UTC (rev 6760)
@@ -1145,7 +1145,7 @@
/// </summary>
- public override bool RestartSession(bool throwException)
+ protected override bool RestartSessionInternal(bool throwException)
if (m_username == null || m_password == null)
if (throwException)
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2012-06-14 02:27:24 UTC (rev 6759)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2012-06-14 09:07:38 UTC (rev 6760)
@@ -45,6 +45,8 @@
//IMappingService,
IDrawingService
+ public event EventHandler SessionIDChanged; //Not used
public static LocalConnection Create(NameValueCollection initParams)
return new LocalConnection(initParams);
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2012-06-14 02:27:24 UTC (rev 6759)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2012-06-14 09:07:38 UTC (rev 6760)
@@ -762,7 +762,7 @@
/// </summary>
if (throwException)
More information about the mapguide-commits
