[mapguide-commits] r6533 - in sandbox/adsk/2.3r/Oem/SWIGEx: Source/Modules Win32
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Mar 2 01:27:11 EST 2012
Author: hubu
Date: 2012-03-01 22:27:11 -0800 (Thu, 01 Mar 2012)
New Revision: 6533
   sandbox/adsk/2.3r/Oem/SWIGEx/Source/Modules/java.cxx
   sandbox/adsk/2.3r/Oem/SWIGEx/Win32/Swig.exe
On behalf of Andy Zhang.
Fix ticket #1960: : ByteSource and ByteReader memory leak in Java Api
The generated Java method MgByteSource::GetReader() is like below:
public MgByteReader GetReader() throws MgException  {
    long cPtr = MapGuideJavaApiJNI.MgByteSource_GetReader(swigCPtr);
    return (cPtr == 0) ? null : (MgByteReader)ObjectFactory.createObject(MapGuideJavaApiJNI.getClassId(cPtr), cPtr, false);
The last parameter indicated whether the object owns memory itself. In Java API, it is always false. That means it will not call MapGuideJavaApiJNI.delete_MgByteReader(swigCPtr) when deleting the object, which results in memory leak.
Now change the last parameter to 'true' to fix this issue. The change is consistant with CSharp.
Modified: sandbox/adsk/2.3r/Oem/SWIGEx/Source/Modules/java.cxx
--- sandbox/adsk/2.3r/Oem/SWIGEx/Source/Modules/java.cxx	2012-02-28 10:20:10 UTC (rev 6532)
+++ sandbox/adsk/2.3r/Oem/SWIGEx/Source/Modules/java.cxx	2012-03-02 06:27:11 UTC (rev 6533)
@@ -2000,7 +2000,7 @@
       addThrows(n, "tmap:javaout", n);
 	  if(returnObject)
-		  Replaceall(tm, "new $javaclassname(cPtr, $owner)", "($javaclassname)ObjectFactory.createObject($module.getClassId(cPtr), cPtr, $owner)");
+		  Replaceall(tm, "new $javaclassname(cPtr, $owner)", "($javaclassname)ObjectFactory.createObject($module.getClassId(cPtr), cPtr, true)");
 		  Replaceall(tm, "$module", imclass_name);
       if (Getattr(n,"feature:new"))
Modified: sandbox/adsk/2.3r/Oem/SWIGEx/Win32/Swig.exe
(Binary files differ)
More information about the mapguide-commits mailing list
