[mapguide-commits] r6555 - in trunk/MgDev: . Server/src/Core
svn_mapguide at osgeo.org
Wed Mar 28 22:50:54 EDT 2012
Author: hubu
Date: 2012-03-28 19:50:54 -0700 (Wed, 28 Mar 2012)
New Revision: 6555
trunk/MgDev/Server/src/Core/Makefile.am
trunk/MgDev/configure
trunk/MgDev/configure.in
Update the FDO reference from 3.7.0 to 3.8.0
Modified: trunk/MgDev/Server/src/Core/Makefile.am
--- trunk/MgDev/Server/src/Core/Makefile.am 2012-03-21 05:51:35 UTC (rev 6554)
+++ trunk/MgDev/Server/src/Core/Makefile.am 2012-03-29 02:50:54 UTC (rev 6555)
@@ -97,7 +97,7 @@
-ldwftk \
-ldwfemap \
-lexpat \
- -lFDO-3.7.0 \
+ -lFDO-3.8.0 \
-lExpressionEngine \
-lxalanMsg \
-lxalan-c \
Modified: trunk/MgDev/configure
--- trunk/MgDev/configure 2012-03-21 05:51:35 UTC (rev 6554)
+++ trunk/MgDev/configure 2012-03-29 02:50:54 UTC (rev 6555)
@@ -20088,10 +20088,10 @@
fi;
if test $custom_inc = "DEFAULT"; then
- map_fdo_include="/usr/local/fdo-3.7.0/include"
+ map_fdo_include="/usr/local/fdo-3.8.0/include"
if test -d $map_fdo_include; then
- { echo "$as_me:$LINENO: Building with default location of FDO include files at /usr/local/fdo-3.7.0/include" >&5
-echo "$as_me: Building with default location of FDO include files at /usr/local/fdo-3.7.0/include" >&6;}
+ { echo "$as_me:$LINENO: Building with default location of FDO include files at /usr/local/fdo-3.8.0/include" >&5
+echo "$as_me: Building with default location of FDO include files at /usr/local/fdo-3.8.0/include" >&6;}
else
{ { echo "$as_me:$LINENO: error: the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option" >&5
echo "$as_me: error: the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option" >&2;}
@@ -20119,10 +20119,10 @@
fi;
if test $custom_lib = "DEFAULT"; then
- map_fdo_lib="/usr/local/fdo-3.7.0/lib"
+ map_fdo_lib="/usr/local/fdo-3.8.0/lib"
if test -d $map_fdo_lib; then
- { echo "$as_me:$LINENO: Building with default location of FDO libraries at /usr/local/fdo-3.7.0/lib" >&5
-echo "$as_me: Building with default location of FDO libraries at /usr/local/fdo-3.7.0/lib" >&6;}
+ { echo "$as_me:$LINENO: Building with default location of FDO libraries at /usr/local/fdo-3.8.0/lib" >&5
+echo "$as_me: Building with default location of FDO libraries at /usr/local/fdo-3.8.0/lib" >&6;}
else
{ { echo "$as_me:$LINENO: error: the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option" >&5
echo "$as_me: error: the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option" >&2;}
Modified: trunk/MgDev/configure.in
--- trunk/MgDev/configure.in 2012-03-21 05:51:35 UTC (rev 6554)
+++ trunk/MgDev/configure.in 2012-03-29 02:50:54 UTC (rev 6555)
@@ -54,7 +54,7 @@
fi
dnl *******************************************************
-dnl FDO 3.7.0 Configuration
+dnl FDO 3.8.0 Configuration
dnl Include / lib paths
# custom Fdo path specification
@@ -65,9 +65,9 @@
[custom_inc=DEFAULT])
- AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-3.7.0/include])
+ AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-3.8.0/include])
else
AC_MSG_ERROR([the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option])
fi
@@ -87,9 +87,9 @@
[custom_lib=DEFAULT])
- AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-3.7.0/lib])
+ AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-3.8.0/lib])
else
AC_MSG_ERROR([the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option])
fi
More information about the mapguide-commits
