[mapguide-commits] r6561 - in sandbox/liuar: . mtr
mtr/Common/Renderers mtr/Common/Stylization
mtr/Server/src/Common/Manager mtr/Server/src/Core
mtr/Server/src/Services/Mapping mtr/Server/src/Services/Rendering
mtr/Server/src/Services/Site
svn_mapguide at osgeo.org
Fri Mar 30 22:18:48 EDT 2012
Author: liuar
Date: 2012-03-30 19:18:48 -0700 (Fri, 30 Mar 2012)
New Revision: 6561
Added:
sandbox/liuar/mtr/
sandbox/liuar/mtr/Common/Renderers/AGGImageIO.cpp
sandbox/liuar/mtr/Common/Renderers/AGGImageIO.h
sandbox/liuar/mtr/Common/Renderers/AGGRenderer.cpp
sandbox/liuar/mtr/Common/Renderers/AGGRenderer.h
sandbox/liuar/mtr/Common/Renderers/Renderers.vcxproj
sandbox/liuar/mtr/Common/Stylization/LabelRenderer.cpp
sandbox/liuar/mtr/Common/Stylization/LabelRenderer.h
sandbox/liuar/mtr/Common/Stylization/Stylization.vcxproj
sandbox/liuar/mtr/Server/src/Common/Manager/FdoConnectionManager.cpp
sandbox/liuar/mtr/Server/src/Core/Server.cpp
sandbox/liuar/mtr/Server/src/Core/serverconfig.ini
sandbox/liuar/mtr/Server/src/Services/Mapping/MappingUtil.cpp
sandbox/liuar/mtr/Server/src/Services/Mapping/MappingUtil.h
sandbox/liuar/mtr/Server/src/Services/Mapping/ServerMappingService.cpp
sandbox/liuar/mtr/Server/src/Services/Mapping/ServerMappingService.vcxproj
sandbox/liuar/mtr/Server/src/Services/Rendering/ServerRenderingService.cpp
sandbox/liuar/mtr/Server/src/Services/Rendering/ServerRenderingService.h
sandbox/liuar/mtr/Server/src/Services/Rendering/ServerRenderingService.vcxproj
sandbox/liuar/mtr/Server/src/Services/Site/SiteOperation.cpp
Multi-threads rendering branch
Property changes on: sandbox/liuar/mtr
___________________________________________________________________
Added: svn:mergeinfo
+ /sandbox/rfc94:5099-5163
Modified: sandbox/liuar/mtr/Common/Renderers/AGGImageIO.cpp
--- trunk/MgDev/Common/Renderers/AGGImageIO.cpp 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Common/Renderers/AGGImageIO.cpp 2012-03-31 02:18:48 UTC (rev 6561)
@@ -1119,7 +1119,162 @@
gdImageDestroy(img2);
+RS_ByteData* AGGImageIO::Combine(vector<RS_ByteData*>* data, const size_t start, const size_t end)
+ vector<gdImagePtr> imgs;
+ imgs.reserve(end-start);
+ //TODO:
+ //TO BE Optimized
+ size_t firstNonEmptyData = 0;
+ for(size_t i = start; i<end; i++)
+ if((*data)[i]->GetNumBytes() != 0)
+ gdImagePtr img = gdImageCreateFromPngPtr((*data)[i]->GetNumBytes(),(*data)[i]->GetBytes());
+ imgs.push_back(img);
+ firstNonEmptyData = i;
+ break;
+ for(size_t i = firstNonEmptyData+1; i<end; i++)
+ if((*data)[i]->GetNumBytes() == 0)
+ continue;
+ gdImageSetTile(imgs[0], img);
+ gdImageFilledRectangle(imgs[0], 0, 0, gdImageSX(imgs[0])-1, gdImageSY(imgs[0])-1, gdTiled);
+ gdImageSaveAlpha(imgs[0], 1);
+ gdImageDestroy(img);
+ auto_ptr<RS_ByteData> byteData;
+ if(imgs.size() == 0)
+ byteData.reset(new RS_ByteData());
+ else
+ unsigned char* imgdata = NULL;
+ int size = 0;
+ imgdata = (unsigned char*)gdImagePngPtr(imgs[0], &size);
+ byteData.reset((NULL == imgdata)? new RS_ByteData() : new RS_ByteData(imgdata, size));
+ gdFree(imgdata);
+ vector<gdImagePtr>::iterator it = imgs.begin();
+ while(it != imgs.end())
+ gdImageDestroy(*it);
+ it++;
+ return byteData.release();
+RS_ByteData* AGGImageIO::Combine(vector<RS_ByteData*>* data,RS_ByteData* labelImg)
+ imgs.reserve(data->size());
+ vector<RS_ByteData*>::iterator i = data->begin();
+ while(i != data->end())
+ if((*i)->GetNumBytes() != 0)
+ gdImagePtr img = gdImageCreateFromPngPtr((*i)->GetNumBytes(),(*i)->GetBytes());
+ i++;
+ break;
+ i++;
+ if((*i)->GetNumBytes() == 0)
+ i++;
+ continue;
+ i++;
+ if(imgs.size() != 0)
+ gdImagePtr labelImgPtr = gdImageCreateFromPngPtr(labelImg->GetNumBytes(),labelImg->GetBytes());
+ gdImageSetTile(imgs[0], labelImgPtr);
+ gdImageDestroy(labelImgPtr);
+ else
+ imgs.push_back(gdImageCreateFromPngPtr(labelImg->GetNumBytes(),labelImg->GetBytes()));
+ int size = 0;
+ byteData.reset((NULL == imgdata)? NULL : new RS_ByteData(imgdata, size));
+ gdFree(imgdata);
+ it++;
+RS_ByteData* AGGImageIO::ReadPNG(const RS_String& src)
+ char mbfileIn[1024];
+ wcstombs(mbfileIn, src.c_str(), 1024);
+ // read in the images
+ FILE* fIn = fopen(mbfileIn, "rb");
+ // get the size
+ fseek (fIn , 0 , SEEK_END);
+ int size = ftell (fIn);
+ rewind (fIn);
+ gdImagePtr img = gdImageCreateFromPng(fIn);
+ fclose(fIn);
+ unsigned char* data = NULL;
+ data = (unsigned char*)gdImagePngPtr(img, &size);
+ byteData.reset((NULL == data)? NULL : new RS_ByteData(data, size));
+ gdFree(data);
// NOTE: the returned buffer contains the *inverted* image
unsigned int* AGGImageIO::DecodePNG(const unsigned char* src, size_t len, int& width, int& height)
Modified: sandbox/liuar/mtr/Common/Renderers/AGGImageIO.h
--- trunk/MgDev/Common/Renderers/AGGImageIO.h 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Common/Renderers/AGGImageIO.h 2012-03-31 02:18:48 UTC (rev 6561)
@@ -30,16 +30,22 @@
static RS_ByteData* Save(const RS_String& format,
unsigned int* src, int src_width, int src_height,
int dst_width, int dst_height, RS_Color& bgColor,
- RS_ColorVector* baseColorPalette = NULL);
+ RS_ColorVector* baseColorPalette = NULL);
static void Combine(const RS_String& src1, const RS_String& src2, const RS_String& dst);
+ static RS_ByteData* Combine(std::vector<RS_ByteData*>* data,RS_ByteData* labelImg);
+ static RS_ByteData* Combine(std::vector<RS_ByteData*>* data, const size_t start, const size_t end);
static unsigned int* DecodePNG(const unsigned char* src, size_t len, int& width, int& height);
// NOTE: the returned buffer contains the *non-inverted* image
static unsigned int* DecodeJPEG(const unsigned char* src, size_t len, int& width, int& height);
+ static RS_ByteData* ReadPNG(const RS_String& src);
private:
static unsigned char* ReadFile(const RS_String& fname, size_t& len);
static void UnmultiplyAlpha(unsigned int* argb, int len);
Modified: sandbox/liuar/mtr/Common/Renderers/AGGRenderer.cpp
--- trunk/MgDev/Common/Renderers/AGGRenderer.cpp 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Common/Renderers/AGGRenderer.cpp 2012-03-31 02:18:48 UTC (rev 6561)
@@ -237,7 +237,13 @@
return m_rows;
+void AGGRenderer::ClearBuffer()
+ c()->ren.clear(agg::argb8_packed(m_bgcolor.argb()).premultiply());
+ //TODO: anything eles to clear??
+ //m_imsym->ren.clear(agg::argb8_packed(0x0));
// This one writes into a file not returning a bytestream using
// default parameters for the width and height.
@@ -272,7 +278,21 @@
AGGImageIO::Combine(fileIn1, fileIn2, fileOut);
+RS_ByteData* AGGRenderer::Combine(vector<RS_ByteData*>* in, RS_ByteData* label)
+ return AGGImageIO::Combine(in,label);
+RS_ByteData* AGGRenderer::Combine(vector<RS_ByteData*>* in, size_t start, size_t end)
+ return AGGImageIO::Combine(in,start,end);
+RS_ByteData* AGGRenderer::ReadPNG(const RS_String& src)
+ return AGGImageIO::ReadPNG(src);
void AGGRenderer::StartMap(RS_MapUIInfo* mapInfo,
RS_Bounds& extents,
@@ -1103,7 +1123,17 @@
return m_mapInfo;
+LabelRendererBase* AGGRenderer::GetLabeler()
+ return m_labeler;
+void AGGRenderer::SetLabeler(LabelRendererBase* labeler)
+ m_labeler = labeler;
RS_LayerUIInfo* AGGRenderer::GetLayerInfo()
Modified: sandbox/liuar/mtr/Common/Renderers/AGGRenderer.h
--- trunk/MgDev/Common/Renderers/AGGRenderer.h 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Common/Renderers/AGGRenderer.h 2012-03-31 02:18:48 UTC (rev 6561)
@@ -149,12 +149,25 @@
// AGGRenderer specific
+ RENDERERS_API virtual LabelRendererBase* GetLabeler();
+ RENDERERS_API virtual void SetLabeler(LabelRendererBase* labeler);
RENDERERS_API void Save(const RS_String& filename, const RS_String& format);
RENDERERS_API void Save(const RS_String& filename, const RS_String& format, int width, int height);
RENDERERS_API RS_ByteData* Save(const RS_String& format, int width, int height,
RENDERERS_API void Combine(const RS_String& fileIn1, const RS_String& fileIn2, const RS_String& fileOut);
+ RENDERERS_API RS_ByteData* Combine(vector<RS_ByteData*>*, RS_ByteData*);
+ RENDERERS_API RS_ByteData* Combine(vector<RS_ByteData*>* in, size_t start, size_t end);
+ RENDERERS_API RS_ByteData* ReadPNG(const RS_String& src);
+ RENDERERS_API void ClearBuffer();
RENDERERS_API void SetWorldToScreenTransform(SE_Matrix& xform);
RENDERERS_API void DrawString(const RS_String& s,
Modified: sandbox/liuar/mtr/Common/Renderers/Renderers.vcxproj
--- trunk/MgDev/Common/Renderers/Renderers.vcxproj 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Common/Renderers/Renderers.vcxproj 2012-03-31 02:18:48 UTC (rev 6561)
@@ -184,7 +184,7 @@
<IntrinsicFunctions>true</IntrinsicFunctions>
<FavorSizeOrSpeed>Speed</FavorSizeOrSpeed>
<OmitFramePointers>true</OmitFramePointers>
- <AdditionalIncludeDirectories>..\MdfModel;..\Stylization;..\..\Oem\FDO\inc;..\..\Oem\DWFTK7.1\develop\global\src;..\..\Oem\DWFTK7.1\develop\global\src\dwf;..\..\Oem\gd\gd;..\..\Oem\gd\freetype\include;..\..\Oem\agg-2.4\include;..\..\Oem\gd\lpng;..\..\Oem\agg-2.4\font_freetype;..\..\Oem\gd\zlib;..\..\Oem\FDO\inc\ExpressionEngine;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
+ <AdditionalIncludeDirectories>..\MdfModel;..\Stylization;..\..\Oem\ACE\ACE_wrappers;..\..\Oem\FDO\inc;..\..\Oem\DWFTK7.1\develop\global\src;..\..\Oem\DWFTK7.1\develop\global\src\dwf;..\..\Oem\gd\gd;..\..\Oem\gd\freetype\include;..\..\Oem\agg-2.4\include;..\..\Oem\gd\lpng;..\..\Oem\agg-2.4\font_freetype;..\..\Oem\gd\zlib;..\..\Oem\FDO\inc\ExpressionEngine;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
<PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;RENDERERS_EXPORTS;DWFCORE_STATIC;DWFTK_STATIC;DWFTK_USE_DWFCORE_ZLIB;DWFTK_BUILD_EXPAT;WHIP_STATIC_LIB;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
<ExceptionHandling>Async</ExceptionHandling>
<RuntimeLibrary>MultiThreadedDLL</RuntimeLibrary>
Modified: sandbox/liuar/mtr/Common/Stylization/LabelRenderer.cpp
--- trunk/MgDev/Common/Stylization/LabelRenderer.cpp 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Common/Stylization/LabelRenderer.cpp 2012-03-31 02:18:48 UTC (rev 6561)
@@ -23,6 +23,10 @@
extern void ProcessStylizerException(FdoException* exception, int line, wchar_t* file);
+#ifdef MULTI_RENDERERS
+ACE_Recursive_Thread_Mutex LabelRenderer::m_mutex;
+ACE_Recursive_Thread_Mutex LabelRenderer::m_mutex2;
+#endif
LabelRenderer::LabelRenderer(SE_Renderer* se_renderer)
@@ -88,6 +92,9 @@
LineBuffer* path,
double scaleLimit)
+ #ifdef MULTI_RENDERERS
+ ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, m_mutex));
+ #endif
// get the geometry type
int geomType = (path != NULL)? path->geom_type() : FdoGeometryType_None;
@@ -182,6 +189,10 @@
bool exclude,
LineBuffer* /*path*/)
+ #endif
BeginOverpostGroup(type, true, exclude);
// Add a new style SE label to the overpost groups.
@@ -346,7 +357,12 @@
for (int i=0; i<npts; ++i)
m_serenderer->ScreenToWorldPoint(pts[i].x, pts[i].y, tmp[i].x, tmp[i].y);
+ ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, m_mutex2));
+ #endif
m_overpost.AddRegion(tmp, npts);
Modified: sandbox/liuar/mtr/Common/Stylization/LabelRenderer.h
--- trunk/MgDev/Common/Stylization/LabelRenderer.h 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Common/Stylization/LabelRenderer.h 2012-03-31 02:18:48 UTC (rev 6561)
@@ -22,7 +22,9 @@
#include "SimpleOverpost.h"
#include "RS_FontEngine.h"
#include "BIDIConverter.h"
+#include "ace/Thread_Manager.h" //For mutex
+#endif
struct SE_RenderStyle;
@@ -139,6 +141,11 @@
std::map<RS_String, size_t> m_hStitchTable;
SimpleOverpost m_overpost;
BIDIConverter m_bidiConverter;
+ static ACE_Recursive_Thread_Mutex m_mutex;
+ static ACE_Recursive_Thread_Mutex m_mutex2;
+#endif
#endif
Modified: sandbox/liuar/mtr/Common/Stylization/Stylization.vcxproj
--- trunk/MgDev/Common/Stylization/Stylization.vcxproj 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Common/Stylization/Stylization.vcxproj 2012-03-31 02:18:48 UTC (rev 6561)
@@ -122,7 +122,7 @@
<AdditionalOptions>$(USRCFLAGS) %(AdditionalOptions)</AdditionalOptions>
<Optimization>Disabled</Optimization>
<AdditionalIncludeDirectories>..\MdfModel;..\Foundation;..\..\Oem\ACE\ACE_wrappers;..\..\Oem\FDO\inc;..\..\Oem\FDO\inc\ExpressionEngine;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
- <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;STYLIZATION_EXPORTS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;STYLIZATION_EXPORTS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MULTI_RENDERERS;%(PreprocessorDefinitions)</PreprocessorDefinitions>
<MinimalRebuild>true</MinimalRebuild>
<BasicRuntimeChecks>EnableFastChecks</BasicRuntimeChecks>
@@ -132,9 +132,9 @@
<ShowIncludes>false</ShowIncludes>
</ClCompile>
<Link>
- <AdditionalDependencies>FDO.lib;FDOCommon.lib;ExpressionEngine.lib;%(AdditionalDependencies)</AdditionalDependencies>
+ <AdditionalDependencies>ACEd.lib;FDO.lib;FDOCommon.lib;ExpressionEngine.lib;%(AdditionalDependencies)</AdditionalDependencies>
<OutputFile>$(OutDir)MgStylizationd.dll</OutputFile>
- <AdditionalLibraryDirectories>..\..\Oem\FDO\lib64;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+ <AdditionalLibraryDirectories>..\..\Oem\FDO\lib64;MULTI_RENDERERS;..\..\Oem\ACE\ACE_wrappers\lib64;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
<DelayLoadDLLs>FDO.dll;FDOCommon.dll;ExpressionEngine.dll;%(DelayLoadDLLs)</DelayLoadDLLs>
<GenerateDebugInformation>true</GenerateDebugInformation>
<ProgramDatabaseFile>$(OutDir)MgStylizationd.pdb</ProgramDatabaseFile>
@@ -188,16 +188,16 @@
<OmitFramePointers>false</OmitFramePointers>
- <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;STYLIZATION_EXPORTS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;STYLIZATION_EXPORTS;_CRT_SECURE_NO_DEPRECATE;_CRT_NONSTDC_NO_DEPRECATE;MULTI_RENDERERS;%(PreprocessorDefinitions)</PreprocessorDefinitions>
<WarningLevel>Level3</WarningLevel>
<DebugInformationFormat>ProgramDatabase</DebugInformationFormat>
</ClCompile>
<Link>
+ <AdditionalDependencies>ACE.lib;FDO.lib;FDOCommon.lib;ExpressionEngine.lib;%(AdditionalDependencies)</AdditionalDependencies>
<OutputFile>$(OutDir)MgStylization.dll</OutputFile>
+ <AdditionalLibraryDirectories>..\..\Oem\FDO\lib64;..\..\Oem\ACE\ACE_wrappers\lib64;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
<ProgramDatabaseFile>$(OutDir)MgStylization.pdb</ProgramDatabaseFile>
Modified: sandbox/liuar/mtr/Server/src/Common/Manager/FdoConnectionManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/FdoConnectionManager.cpp 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Server/src/Common/Manager/FdoConnectionManager.cpp 2012-03-31 02:18:48 UTC (rev 6561)
@@ -250,15 +250,16 @@
pFdoConnection = FindFdoConnection(resourceIdentifier);
+ STRING longTransactionName = (STRING)featureSource->GetLongTransaction();
+ // Update the long transaction name to any active one for the current request
+ MgLongTransactionManager::GetLongTransactionName(resourceIdentifier, longTransactionName);
if(NULL == pFdoConnection)
// Parse XML and get properties
STRING configDocumentName = (STRING)featureSource->GetConfigurationDocument();
- STRING longTransactionName = (STRING)featureSource->GetLongTransaction();
- // Update the long transaction name to any active one for the current request
- MgLongTransactionManager::GetLongTransactionName(resourceIdentifier, longTransactionName);
// Create a new connection
pFdoConnection = m_connManager->CreateConnection(provider.c_str());
@@ -294,6 +295,23 @@
resourceIdentifier->ToString(),
+ // Workaround for TB job issue.
+ // The job state of a TB connection may be changed during the connection life cycle.
+ // But MG Server have no API to set the job state now. If we want to set the correct
+ // job state for the connection, we need to call ActivateLongTransaction() to set the
+ // job id again.
+ else
+ if (providerInfo->GetProviderName() == L"Autodesk.Topobase" && longTransactionName != L"")
+ STRING tmpLtName = L"1";
+ if (longTransactionName != tmpLtName)
+ ActivateLongTransaction(pFdoConnection, tmpLtName);
+ ActivateLongTransaction(pFdoConnection, longTransactionName);
#ifdef _DEBUG_FDOCONNECTION_MANAGER
ShowProviderInfoCache();
@@ -684,9 +702,10 @@
INT32 useLimit = providerInfo->GetUseLimit();
if (useLimit == -1 || pFdoConnectionCacheEntry->nUseTotal <= useLimit)
- if((!pFdoConnectionCacheEntry->bInUse) ||
- (providerInfo->GetThreadModel() == FdoThreadCapability_PerCommandThreaded) ||
- (providerInfo->GetThreadModel() == FdoThreadCapability_MultiThreaded))
+ if((!pFdoConnectionCacheEntry->bInUse))
+ //if((!pFdoConnectionCacheEntry->bInUse) ||
+ // (providerInfo->GetThreadModel() == FdoThreadCapability_PerCommandThreaded) ||
+ // (providerInfo->GetThreadModel() == FdoThreadCapability_MultiThreaded))
// It is not in use or the provider is a PerCommandThreaded/MultiThreaded provider so claim it
pFdoConnectionCacheEntry->lastUsed = ACE_OS::gettimeofday();
Modified: sandbox/liuar/mtr/Server/src/Core/Server.cpp
--- trunk/MgDev/Server/src/Core/Server.cpp 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Server/src/Core/Server.cpp 2012-03-31 02:18:48 UTC (rev 6561)
@@ -36,6 +36,110 @@
#include "Renderer.h"
#include "MappingUtil.h"
+#ifdef _REALDWG
+#include "dbmain.h"
+#include "acestext.h"
+#include <dbapserv.h>
+class AcDsHostApp : public AcDbHostApplicationServices
+ Acad::ErrorStatus findFile(wchar_t* pcFullPathOut, int nBufferLength,
+ const wchar_t* pcFilename, AcDbDatabase* pDb = NULL,
+ AcDbHostApplicationServices::FindFileHint hint = kDefault)
+ wchar_t pExtension[5];
+ switch (hint)
+ case kCompiledShapeFile:
+ wcscpy(pExtension, L".shx");
+ break;
+ case kTrueTypeFontFile:
+ wcscpy(pExtension, L".ttf");
+ break;
+ case kPatternFile:
+ wcscpy(pExtension, L".pat");
+ break;
+ case kARXApplication:
+ wcscpy(pExtension, L".dbx");
+ break;
+ case kFontMapFile:
+ wcscpy(pExtension, L".fmp");
+ break;
+ case kXRefDrawing:
+ wcscpy(pExtension, L".AcDs");
+ break;
+ case kFontFile: // Fall through. These could have
+ case kEmbeddedImageFile: // various extensions
+ default:
+ pExtension[0] = L'\0';
+ break;
+ wchar_t* filePart;
+ DWORD result;
+ result = SearchPath(NULL, pcFilename, pExtension, nBufferLength,
+ pcFullPathOut, &filePart);
+ if (result && result < (DWORD)nBufferLength)
+ return Acad::eOk;
+ else
+ return Acad::eFileNotFound;
+static AcDsHostApp *s_pApp = NULL;
+static AcDbDatabase *s_pWorkingDatabase = NULL;
+const STRING RealDWGLCID = L"RealDWGLCID";
+void initRealDWG(long lcid)
+ MG_TRY()
+ // Initialization: needs to be done when MapGuide executable initializes.
+ // We are running outside ACAD.
+ // Create application services
+ s_pApp = new AcDsHostApp;
+ Acad::ErrorStatus stat = acdbSetHostApplicationServices(s_pApp);
+ if ( stat != Acad::eOk )
+ throw FdoException::Create(acadErrorStatusText(stat));
+ MgConfiguration* pConfiguration = MgConfiguration::GetInstance();
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%t) Initializing RealDWG with language:%d.\n"), lcid));
+ stat = acdbValidateSetup(lcid);
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%t) RealDWG is initialized with language:%d.\n"), lcid));
+ // RealDWG needs the working database to be set. Create a dummy database
+ // for this purpose. Setting it as the working database does not affect
+ // the access of other databases.
+ s_pWorkingDatabase = new AcDbDatabase(Adesk::kTrue, Adesk::kTrue);
+ s_pApp->setWorkingDatabase(s_pWorkingDatabase);
+ MG_CATCH_AND_THROW(L"initRealDWG");
+void cleanupRealDWG()
+ MG_TRY()
+ if (s_pApp)
+ if ( s_pWorkingDatabase )
+ s_pApp->setWorkingDatabase(NULL);
+ delete s_pWorkingDatabase;
+ acdbCleanUp();
+ delete s_pApp;
+ ACE_DEBUG ((LM_DEBUG, ACE_TEXT("(%t) RealDWG is cleaned up.\n")));
+ MG_CATCH_AND_THROW(L"cleanupRealDWG");
+#endif
#ifdef _DEBUG
void DebugOutput(const ACE_TCHAR* format, ...)
@@ -926,6 +1030,12 @@
ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%t) MgServer::open() - Initializing Event Timer Manager.\n")));
m_eventTimerManager.Initialize();
+#ifdef _REALDWG
+ int lcid = 0x00000409; // English
+ pConfiguration->GetIntValue(MgConfigProperties::GeneralPropertiesSection, RealDWGLCID, lcid, 0x00000409);
+ initRealDWG(lcid);
+#endif
// Feature Service
bool bDataConnectionPoolEnabled = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolEnabled;
INT32 nDataConnectionPoolSize = MgConfigProperties::DefaultFeatureServicePropertyDataConnectionPoolSize;
@@ -1233,6 +1343,10 @@
nResult = svc();
+#ifdef _REALDWG
+ cleanupRealDWG();
+#endif
MG_LOG_TRACE_ENTRY(L"MgServer::open() - End");
return nResult;
Modified: sandbox/liuar/mtr/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Server/src/Core/serverconfig.ini 2012-03-31 02:18:48 UTC (rev 6561)
@@ -41,6 +41,8 @@
# DefaultMessageLocale ISO 639-1 name for the message locale
# Length = 2
# Example: en
+# RealDWGLCID LCID of the locale of RealDWG. (not used by MapGuide Open Source)
+# Example: 1033
# DisplayName Display name of the server
# 0 <= Length <= 255
# Reserved Characters: \/:*?"<>|
@@ -86,6 +88,7 @@
ConnectionTimeout = 120
ConnectionTimerInterval = 60
DefaultMessageLocale = en
+RealDWGLCID = 1033
DisplayName =
FdoPath = FDO/
LicenseServerPath = @localhost
Modified: sandbox/liuar/mtr/Server/src/Services/Mapping/MappingUtil.cpp
--- trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Server/src/Services/Mapping/MappingUtil.cpp 2012-03-31 02:18:48 UTC (rev 6561)
@@ -30,8 +30,8 @@
#include "Stylizer.h"
#include "SymbolVisitor.h"
#include "SymbolDefinition.h"
-#include "TransformCache.h"
#include <algorithm>
//For logging
@@ -49,6 +49,8 @@
extern long GetTickCount();
#endif
+#define POOL_SIZE 4
+#define MAX_TIMEOUT 100000000
MdfModel::MapDefinition* MgMappingUtil::GetMapDefinition(MgResourceService* svcResource, MgResourceIdentifier* resId)
@@ -369,7 +371,12 @@
double scale,
bool selection,
bool extractColors,
- ProfileRenderLayersResultBase* pPRLsResult)
+ ProfileRenderLayersResultBase* pPRLsResult,
+ deque<Renderer*>* subRenderers,
+ vector<RS_ByteData*>* subImgs,
+ INT32 saveWidth,
+ INT32 saveHeight,
+ STRING format)
#ifdef _DEBUG
long dwStart = GetTickCount();
@@ -380,6 +387,16 @@
// stylization operation.
TransformCacheMap transformCache;
+ // Create a LayerRenderingWorkers pool
+ LayerRenderingWorkers pool;
+ pool.activate(THR_NEW_LWP | THR_JOINABLE, POOL_SIZE);
+ //vector<RenderData> renderData;
+ //renderData.reserve(layers->GetCount());
+ #endif
// Get the layers' resource content in a single request by adding them to a collection
for (int i = layers->GetCount()-1; i >= 0; i--)
@@ -387,7 +404,7 @@
RSMgFeatureReader* rsReader = NULL;
Ptr<MgLayerBase> mapLayer = layers->GetItem(i);
//don't send data if layer is not currently visible
if ((!selection) && (!mapLayer->IsVisible()))
continue;
@@ -405,8 +422,42 @@
if (!needsRefresh)
continue;
+ RenderData renderData;
+ renderData.pPRLsResult = pPRLsResult;
+ renderData.i = i;
+ renderData.mapLayer = mapLayer;
+ renderData.scale = scale;
+ renderData.svcResource = svcResource;
+ renderData.svcDrawing = svcDrawing;
+ renderData.svcFeature = svcFeature;
+ renderData.map = map;
+ renderData.selection = selection;
+ renderData.expandExtents = expandExtents;
+ renderData.csFactory = csFactory;
+ renderData.dstCs = dstCs;
+ renderData.overrideFilters = overrideFilters;
+ renderData.extractColors = extractColors;
+ renderData.sub_drs = subRenderers;
+ renderData.transformCache = &transformCache;
+ renderData.saveWidth = saveWidth;
+ renderData.saveHeight = saveHeight;
+ renderData.format = format;
+ size_t displayOrder = subImgs->size()-(size_t)(mapLayer->GetDisplayOrder()/100);
+ renderData.subImg = (RS_ByteData**)(&subImgs->at(displayOrder));
+ ACE_Message_Block *mb = new ACE_Message_Block(sizeof(RenderData));
+ //ACE_CDR::mb_align(mb); //MR_TODO: I need to figure out why.
+ ACE_OS::memcpy(mb->wr_ptr(), &renderData, sizeof(RenderData));
+ // Ask the worker pool to do the job.
+ pool.putq (mb);
+#else
#ifdef _DEBUG
long dwLayerStart = GetTickCount();
ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **LAYERSTART** Name:%W VAS:%W\n", i, (mapLayer->GetName()).c_str(), mapLayer->IsVisibleAtScale(scale)? L"True" : L"False"));
@@ -917,9 +968,15 @@
pPRLResult->SetError(message);
} // if exception
+#endif
} // for all layers
+ ACE_Message_Block *mb = new ACE_Message_Block(0,ACE_Message_Block::MB_HANGUP);
+ pool.putq (mb);
+ ACE_Thread_Manager::instance()->wait_grp(pool.grp_id());
+#endif
#ifdef _DEBUG
ACE_DEBUG((LM_INFO, L"(%t)StylizeLayers() **MAPDONE** Layers:%d Total Time:%6.4f (s)\n\n", layers->GetCount(), (GetTickCount()-dwStart)/1000.0));
#endif
@@ -927,7 +984,10 @@
TransformCache::Clear(transformCache);
+void* MgMappingUtil::RenderLayer(void* param)
+ return NULL;
// When rendering a tile, we need to compute the extent used to determine
// which features to render into it. Features in adjacent tiles, but not
@@ -1581,3 +1641,619 @@
+int LayerRenderingWorkers::svc()
+ while(true)
+ ACE_Message_Block *mb = NULL;
+ if (this->getq (mb) == -1)
+ ACE_TEXT ("LayerRenderingWorkers shutting down\n")));
+ break;
+ if (mb->msg_type () == ACE_Message_Block::MB_HANGUP)
+ this->putq(mb);
+ break;
+ // Process the message.
+ process_message (mb);
+ return 0;
+void LayerRenderingWorkers::process_message(ACE_Message_Block *mb)
+ static ACE_Recursive_Thread_Mutex sg_subRenderersMutex;
+ ACE_DEBUG ((LM_DEBUG,ACE_TEXT ("Processing message\n")));
+ RenderData* renderData = new RenderData();
+ ACE_OS::memcpy(renderData, mb->rd_ptr(), sizeof(RenderData));
+ mb->release ();
+ Ptr<MgUserInformation> adminUserInfo = new MgUserInformation(MgUser::Administrator, L"");
+ MgUserInformation::SetCurrentUserInfo(adminUserInfo);
+ auto_ptr<MdfModel::LayerDefinition> ldf;
+ RSMgFeatureReader* rsReader = NULL;
+ //RenderData* renderData = static_cast<RenderData*>(mb->data_block());
+ int i = renderData->i;
+ MgLayerBase* mapLayer = renderData->mapLayer;
+ double scale = renderData->scale;
+ ProfileRenderLayersResultBase* pPRLsResult = renderData->pPRLsResult;
+ MgResourceService* svcResource = renderData->svcResource;
+ MgFeatureService* svcFeature = renderData->svcFeature;
+ MgDrawingService* svcDrawing = renderData->svcDrawing;
+ MgMap* map = renderData->map;
+ bool selection = renderData->selection;
+ bool expandExtents = renderData->expandExtents;
+ MgCoordinateSystemFactory* csFactory = renderData->csFactory;
+ MgCoordinateSystem* dstCs = renderData->dstCs;
+ MgStringCollection* overrideFilters = renderData->overrideFilters;
+ TransformCacheMap* pTransformCache = renderData->transformCache;
+ bool extractColors = renderData->extractColors;
+ deque<Renderer*>* subRenderers = renderData->sub_drs;
+ Renderer* dr = NULL;
+ ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, sg_subRenderersMutex));
+ if(subRenderers->front() != NULL)
+ dr = subRenderers->front();
+ subRenderers->pop_front();
+ else
+ ACE_DEBUG ((LM_INFO,ACE_TEXT ("Renderers Fetching Error!")));
+ INT32 saveWidth = renderData->saveWidth;
+ INT32 saveHeight = renderData->saveHeight;
+ STRING format = renderData->format;
+ // initialize the stylizer
+ RSMgSymbolManager mgr(svcResource);
+ dr->SetSymbolManager(&mgr);
+ SEMgSymbolManager semgr(svcResource);
+ DefaultStylizer* ds = new DefaultStylizer(&semgr);
+ RS_Color bgcolor(0, 0, 0, 255); //not used -- GDRenderer is already initialized to the correct bgcolor
+ #ifdef _DEBUG
+ long dwLayerStart = GetTickCount();
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **LAYERSTART** Name:%W VAS:%W\n", i, (mapLayer->GetName()).c_str(), mapLayer->IsVisibleAtScale(scale)? L"True" : L"False"));
+ #endif
+ MG_SERVER_MAPPING_SERVICE_TRY()
+ // Just profile visible layers?
+ TransformCache* TCForProfile = NULL;
+ double minScale_Profile = 0.0;
+ double maxScale_Profile = MdfModel::VectorScaleRange::MAX_MAP_SCALE;
+ if(NULL != pPRLsResult)
+ ProfileRenderLayerResult* pPRLResult = new ProfileRenderLayerResult(); // points points to Profile Render Layers Result
+ // Set the start time of stylizing layer
+ pPRLResult->SetRenderTime(MgTimerUtil::GetTime());
+ ProfileRenderLayerResultCollection* pPRLResultColl = pPRLsResult->GetProfileRenderLayerResults();
+ pPRLResultColl->Adopt(pPRLResult);
+ //get layer definition
+ Ptr<MgResourceIdentifier> layerid = mapLayer->GetLayerDefinition();
+ ldf.reset(MgLayerBase::GetLayerDefinition(svcResource, layerid));
+ Ptr<MgLayerGroup> group = mapLayer->GetGroup();
+ MgLogDetail logDetail(MgServiceType::MappingService, MgLogDetail::InternalTrace, L"MgMappingUtil.StylizeLayers", mgStackParams);
+ logDetail.AddString(L"Map",map->GetName());
+ logDetail.AddResourceIdentifier(L"LayerId",layerid);
+ logDetail.Create();
+ //base map layers are not editable
+ bool bEditable = true;
+ if (mapLayer->GetLayerType() == MgLayerType::BaseMap)
+ bEditable = false;
+ //layer legend and ui specific information
+ RS_UIGraphic uig(NULL, 0, mapLayer->GetLegendLabel());
+ RS_LayerUIInfo layerInfo( mapLayer->GetName(),
+ mapLayer->GetObjectId(),
+ mapLayer->GetSelectable(),
+ mapLayer->GetVisible(),
+ bEditable,
+ (group.p)? group->GetName() : L"",
+ (group.p)? group->GetObjectId() : L"",
+ mapLayer->GetDisplayInLegend(),
+ mapLayer->GetExpandInLegend(),
+ -mapLayer->GetDisplayOrder(),
+ uig);
+ MdfModel::VectorLayerDefinition* vl = dynamic_cast<MdfModel::VectorLayerDefinition*>(ldf.get());
+ MdfModel::DrawingLayerDefinition* dl = dynamic_cast<MdfModel::DrawingLayerDefinition*>(ldf.get());
+ MdfModel::GridLayerDefinition* gl = dynamic_cast<MdfModel::GridLayerDefinition*>(ldf.get());
+ if (vl) //############################################################################ vector layer
+ // Modify the layer scale range to also support infinite
+ // Need to apply default style as one will not be defined
+ if (selection)
+ MdfModel::VectorScaleRangeCollection* scaleRanges = vl->GetScaleRanges();
+ if (scaleRanges)
+ MdfModel::VectorScaleRange* scaleRange = scaleRanges->GetAt(0);
+ if (scaleRange)
+ scaleRange->SetMinScale(0.0);
+ scaleRange->SetMaxScale(MdfModel::VectorScaleRange::MAX_MAP_SCALE);
+ // make sure we have a valid scale range
+ MdfModel::VectorScaleRange* scaleRange = Stylizer::FindScaleRange(*vl->GetScaleRanges(), scale);
+ if (scaleRange)
+ minScale_Profile = scaleRange->GetMinScale();
+ maxScale_Profile = scaleRange->GetMaxScale();
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W\n", i, (mapLayer->GetName()).c_str()));
+ #endif
+ // get feature source id
+ STRING sfeatResId = vl->GetResourceID();
+ Ptr<MgResourceIdentifier> featResId = new MgResourceIdentifier(sfeatResId);
+ // get the feature extent to use with the query
+ RS_Bounds extent = dr->GetBounds();
+ // if requested, expand the feature extent to account for stylization
+ if (expandExtents)
+ // get the additional offset to account for stylization
+ double mcsOffset = MgMappingUtil::ComputeStylizationOffset(map, scaleRange, scale);
+ extent.minx -= mcsOffset;
+ extent.miny -= mcsOffset;
+ extent.maxx += mcsOffset;
+ extent.maxy += mcsOffset;
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Extents:%f,%f to %f,%f Expanded:%d\n", i, (mapLayer->GetName()).c_str(), extent.minx, extent.miny, extent.maxx, extent.maxy, expandExtents));
+ #endif
+ //get a transform from layer coord sys to map coord sys
+ TransformCache* item = TransformCache::GetLayerToMapTransform(*pTransformCache, vl->GetFeatureName(), featResId, dstCs, csFactory, svcFeature);
+ TCForProfile = item;
+ Ptr<MgCoordinateSystem> layerCs = item? item->GetCoordSys() : NULL;
+ MgCSTrans* xformer = item? item->GetTransform() : NULL;
+ //extract hyperlink and tooltip info
+ if (!vl->GetToolTip().empty()) layerInfo.hastooltips() = true;
+ if (vl->GetUrlData() && !vl->GetUrlData()->GetUrlContent().empty())
+ layerInfo.hashyperlinks() = true;
+ //set up the property name mapping -- it tells us what
+ //string the viewer should be displaying as the name of each
+ //feature property
+ // TODO: check to see if name is FeatureClass or Extension name
+ RS_FeatureClassInfo fcinfo(vl->GetFeatureName());
+ MdfModel::NameStringPairCollection* pmappings = vl->GetPropertyMappings();
+ for (int j=0; j<pmappings->GetCount(); j++)
+ MdfModel::NameStringPair* m = pmappings->GetAt(j);
+ fcinfo.add_mapping(m->GetName(), m->GetValue());
+ // check for overridden feature query filter and remember it.
+ // we will use this when making feature queries
+ STRING overrideFilter = L"";
+ if (overrideFilters)
+ overrideFilter = overrideFilters->GetItem(i);
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Override Filter(size=%d):\n%W\n", i, (mapLayer->GetName()).c_str(), overrideFilter.length(), overrideFilter.empty() ? L"(Empty)" : overrideFilter.c_str()));
+ #endif
+ // create the reader we'll use
+ rsReader = MgMappingUtil::ExecuteFeatureQuery(svcFeature, extent, vl, overrideFilter.c_str(), dstCs, layerCs, item);
+ // create an automatic FdoPtr around the reader
+ FdoPtr<FdoIFeatureReader> fdoReader = (NULL == rsReader) ? NULL : rsReader->GetInternalReader();
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Query Done.\n", i, (mapLayer->GetName()).c_str()));
+ #endif
+ if (NULL != fdoReader.p)
+ // stylize into output format
+ dr->StartLayer(&layerInfo, &fcinfo);
+ ds->StylizeVectorLayer(vl, dr, rsReader, xformer, scale, NULL, NULL);
+ dr->EndLayer();
+ // color extraction for RFC60 only when needed
+ if (extractColors)
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) //ExtractColors// -Vector- Name:%W Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0));
+ #endif
+ MgMappingUtil::ExtractColors(map, scaleRange, ds);
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) ##ExtractColors## -Vector- Name:%W Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0));
+ #endif
+ else // not scaleRange
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **NOT Stylizing - NO SCALE RANGE** Name:%W\n", i, (mapLayer->GetName()).c_str()));
+ #endif
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **LAYEREND** -Vector- Name:%W Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0));
+ #endif
+ else if (gl) //############################################################################ grid layer
+ // TODO: FDO RFP - Make FdoPtr's reference counter thread-safe.
+ static ACE_Recursive_Thread_Mutex sg_fdoRfpMutex;
+ MdfModel::GridScaleRange* scaleRange = Stylizer::FindScaleRange(*gl->GetScaleRanges(), scale);
+ if (scaleRange)
+ //get feature source id
+ STRING sfeatResId = gl->GetResourceID();
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Extents:%f,%f to %f,%f\n", i, (mapLayer->GetName()).c_str(), extent.minx, extent.miny, extent.maxx, extent.maxy));
+ #endif
+ //now get the coordinate system of the layer data
+ // Feature Service caches these so we only take the performance hit on
+ // the 1st one that is not cached.
+ // Need to determine the name of the spatial context for this layer
+ MdfModel::MdfString featureName = gl->GetFeatureName();
+ TransformCache* item = NULL;
+ ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, sg_fdoRfpMutex));
+ item = TransformCache::GetLayerToMapTransform(*pTransformCache, gl->GetFeatureName(), featResId, dstCs, csFactory, svcFeature);
+ // Test if layer and map are using the same coordinate systems
+ if (NULL == layerCs.p || NULL == dstCs || layerCs->GetCsCode() == dstCs->GetCsCode())
+ // No transform required
+ xformer = NULL;
+ RS_FeatureClassInfo fcinfo(gl->GetFeatureName());
+ //check for overridden feature query filter and remember it.
+ //we will use this when making feature queries
+ // Clip request bounds to limits of spatial context for layer
+ // Some WMS/WFS servers fail if request bounds are out of range.
+ // On error, ignore the exception and use the original extent.
+ MG_TRY()
+ Ptr<MgSpatialContextReader> contextReader = svcFeature->GetSpatialContexts(featResId, false);
+ STRING layerWkt = layerCs->ToString();
+ while (contextReader.p != NULL && contextReader->ReadNext())
+ // Try to find wkt for feature's coordinate system
+ STRING code = contextReader->GetCoordinateSystem();
+ STRING wkt = contextReader->GetCoordinateSystemWkt();
+ if (wkt.empty() && !code.empty())
+ MgCoordinateSystemFactory factory;
+ wkt = factory.ConvertCoordinateSystemCodeToWkt(code);
+ // If the source data does not have a coordinate system, or it is the same
+ // as the layer then we are probably using the right spatial context
+ if (wkt.empty() || wkt == layerWkt)
+ // If the extent is known, clip the request to it.
+ Ptr<MgByteReader> agfExtent = contextReader->GetExtent();
+ MgAgfReaderWriter agfReader;
+ Ptr<MgGeometry> geom = agfReader.Read(agfExtent);
+ if (geom != NULL)
+ Ptr<MgEnvelope> envelope = geom->Envelope();
+ Ptr<MgCoordinate> ll = envelope->GetLowerLeftCoordinate();
+ Ptr<MgCoordinate> ur = envelope->GetUpperRightCoordinate();
+ double llx = ll->GetX();
+ double lly = ll->GetY();
+ double urx = ur->GetX();
+ double ury = ur->GetY();
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Extents(SpatialContext):%f,%f to %f,%f\n", i, (mapLayer->GetName()).c_str(), llx, lly, urx, ury));
+ #endif
+ if (NULL != xformer)
+ xformer->TransformExtent(llx, lly, urx, ury);
+ RS_Bounds layerExtent(llx, lly, urx, ury);
+ RS_Bounds clippedExtent = RS_Bounds::Intersect(extent, layerExtent);
+ if (clippedExtent.IsValid())
+ extent = clippedExtent;
+ break;
+ if(contextReader.p != NULL)
+ contextReader->Close();
+ MG_CATCH_AND_RELEASE()
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **Stylizing** Name:%W Extents(Using):%f,%f to %f,%f\n", i, (mapLayer->GetName()).c_str(), extent.minx, extent.miny, extent.maxx, extent.maxy));
+ #endif
+ double pixelsPerMapUnit = dr->GetMetersPerUnit() / METERS_PER_INCH * dr->GetDpi() / dr->GetMapScale();
+ int width = (int)(extent.width() * pixelsPerMapUnit + 0.5);
+ int height = (int)(extent.height() * pixelsPerMapUnit + 0.5);
+ //perform the raster query
+ FdoPtr<FdoIFeatureReader> fdoReader;
+ rsReader = MgMappingUtil::ExecuteRasterQuery(svcFeature, extent, gl, overrideFilter.c_str(), dstCs, layerCs, width, height);
+ fdoReader = (NULL == rsReader) ? NULL : rsReader->GetInternalReader();
+ //stylize grid layer
+ ds->StylizeGridLayer(gl, dr, rsReader, xformer, scale, NULL, NULL);
+ dr->EndLayer();
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **LAYEREND** -Grid- Name:%W Time:%6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0));
+ #endif
+ else if (dl) //############################################################################ drawing layer
+ minScale_Profile = dl->GetMinScale();
+ maxScale_Profile = dl->GetMaxScale();
+ if (scale >= dl->GetMinScale() && scale < dl->GetMaxScale())
+ Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(dl->GetResourceID());
+ //get the resource content to see if there is a coordinate system
+ Ptr<MgByteReader> rdr = svcResource->GetResourceContent(resId);
+ STRING st = rdr->ToString();
+ //now look for a coordinate space tag and extract the contents
+ size_t i0 = st.find(L"<CoordinateSpace>");
+ size_t i1 = st.find(L"</CoordinateSpace>");
+ TransformCache* cached = NULL;
+ MgCSTrans* xformer = NULL;
+ if (i0 != STRING::npos && i1 != STRING::npos)
+ i0 += wcslen(L"<CoordinateSpace>");
+ STRING cs = st.substr(i0, i1 - i0);
+ if (!cs.empty() && cs != dstCs->ToString())
+ // Create coordinate system transformer
+ TransformCacheMap::const_iterator iter = pTransformCache->find(cs);
+ if (pTransformCache->end() != iter) cached = (*iter).second;
+ if (NULL != cached)
+ xformer = cached->GetTransform();
+ else
+ Ptr<MgCoordinateSystem> srcCs = csFactory->Create(cs);
+ if (srcCs.p)
+ xformer = new MgCSTrans(srcCs, dstCs);
+ cached = new TransformCache(xformer, srcCs);
+ pTransformCache->operator[](cs) = cached;
+ TCForProfile = cached;
+ //get DWF from drawing service
+ Ptr<MgByteReader> reader = svcDrawing->GetSection(resId, dl->GetSheet());
+ RSMgInputStream is(reader);
+ dr->StartLayer(&layerInfo, NULL);
+ ds->StylizeDrawingLayer(dl, dr, &is, xformer, scale);
+ dr->EndLayer();
+ #ifdef _DEBUG
+ ACE_DEBUG((LM_INFO, L"(%t) StylizeLayers(%d) **LAYEREND** -Drawing- Name:%W Time = %6.4f (s)\n", i, (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0));
+ #endif
+ } // end layer switch
+ //dr->EndMap();
+ *(renderData->subImg) = ((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight,NULL);
+ ((AGGRenderer*)dr)->ClearBuffer();
+ subRenderers->push_back(dr);
+ // Get current ProfileRenderLayerResult
+ ProfileRenderLayerResult* pPRLResult = pPRLResultColl->GetAt(pPRLResultColl->GetCount()-1); //TODO: check index
+ // Calculate the time spent on stylizing layer
+ double stylizeLayerTime = MgTimerUtil::GetTime() - pPRLResult->GetRenderTime();
+ pPRLResult->SetRenderTime(stylizeLayerTime);
+ pPRLResult->SetResourceId(layerid->ToString());
+ pPRLResult->SetLayerName(mapLayer->GetName());
+ if(vl)
+ pPRLResult->SetLayerType(L"Vector Layer"); //NOXLATE?
+ else if(dl)
+ pPRLResult->SetLayerType(L"Drawing Layer"); //NOXLATE?
+ else if(gl)
+ pPRLResult->SetLayerType(L"Grid Layer"); //NOXLATE?
+ else
+ pPRLResult->SetLayerType(L"Unknown Type"); //NOXLATE?
+ pPRLResult->SetFeatureClassName(mapLayer->GetFeatureClassName());
+ STRING layerCsCode = L"";
+ if(NULL != TCForProfile)
+ Ptr<MgCoordinateSystem> layerCS = TCForProfile->GetCoordSys();
+ layerCsCode = layerCS->GetCsCode();
+ pPRLResult->SetCoordinateSystem(layerCsCode);
+ ScaleRange* pScaleRange = new ScaleRange();
+ pScaleRange->SetMinScale(minScale_Profile);
+ pScaleRange->SetMaxScale(maxScale_Profile);
+ pPRLResult->AdoptScaleRange(pScaleRange);
+ STRING filter = L""; // NOXLATE
+ filter = overrideFilters->GetItem(i);
+ pPRLResult->SetFilter(filter.empty()? mapLayer->GetFilter() : filter);
+ MG_SERVER_MAPPING_SERVICE_CATCH(L"MgMappingUtil.StylizeLayers");
+ delete rsReader;
+ //delete renderData;
+ if (mgException.p)
+ // TODO: Eventually this should be used to indicate visually to the client what
+ // layer failed in addition to logging the error.
+ MgServerManager* serverManager = MgServerManager::GetInstance();
+ STRING locale = (NULL == serverManager)? MgResources::DefaultMessageLocale : serverManager->GetDefaultMessageLocale();
+ // Get the layer that failed
+ MgStringCollection arguments;
+ arguments.Add(mapLayer->GetName());
+ // Get the reason why the layer failed to stylize
+ MgStringCollection argumentsWhy;
+ argumentsWhy.Add(mgException->GetExceptionMessage(locale));
+ Ptr<MgStylizeLayerFailedException> exception;
+ exception = new MgStylizeLayerFailedException(L"MgMappingUtil.StylizeLayers", __LINE__, __WFILE__, &arguments, L"MgFormatInnerExceptionMessage", &argumentsWhy);
+ STRING message = exception->GetExceptionMessage(locale);
+ STRING stackTrace = exception->GetStackTrace(locale);
+ MG_LOG_EXCEPTION_ENTRY(message.c_str(), stackTrace.c_str());
+#if defined(_DEBUG) || defined(_DEBUG_PNG8)
+ STRING details = mgException->GetDetails(locale);
+ wstring err = L"\n %t Error during stylization of layer ";
+ err += mapLayer->GetName();
+ err += L"\n";
+ err += L"Details: ";
+ err += details;
+ err += L"\n";
+ ACE_DEBUG( (LM_DEBUG, err.c_str()) );
+#endif
+ // TODO could throw here depending on a serverconfig setting (RFC64)
+// throw exception;
+ pPRLResult->SetError(message);
+ } // if exception
Modified: sandbox/liuar/mtr/Server/src/Services/Mapping/MappingUtil.h
--- trunk/MgDev/Server/src/Services/Mapping/MappingUtil.h 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Server/src/Services/Mapping/MappingUtil.h 2012-03-31 02:18:48 UTC (rev 6561)
@@ -23,6 +23,7 @@
//For profiling
#include "ProfileRenderLayersResult.h"
+#include "TransformCache.h"
//fwd declare
class MgResourceService;
@@ -38,6 +39,7 @@
class RSMgFeatureReader;
class TransformCache;
class SE_SymbolManager;
+class RS_ByteData;
namespace MdfModel
@@ -65,7 +67,12 @@
double scale,
bool selection = false,
bool extractColors = false,
- ProfileRenderLayersResultBase* = NULL);
+ ProfileRenderLayersResultBase* = NULL,
+ deque<Renderer*>* = NULL,
+ vector<RS_ByteData*>* = NULL,
+ INT32 saveWidth = 0,
+ INT32 saveHeight = 0,
+ STRING format = NULL);
static RSMgFeatureReader* ExecuteFeatureQuery(MgFeatureService* svcFeature,
RS_Bounds& extent,
@@ -108,6 +115,44 @@
// TODO: currently they are interpreted as ffffffff 32 bit RGBA string values.
// The color palette passed to the renderer is a std::vector<RS_Color>
static void ParseColorStrings(RS_ColorVector* tileColorPalette, MgMap* map);
+ static void* MgMappingUtil::RenderLayer(void* param);
+struct RenderData
+ ProfileRenderLayersResultBase* pPRLsResult;
+ int i;
+ MgLayerBase* mapLayer;
+ double scale;
+ MgResourceService* svcResource;
+ MgFeatureService* svcFeature;
+ MgDrawingService* svcDrawing;
+ MgMap* map;
+ bool selection;
+ bool expandExtents;
+ MgCoordinateSystemFactory* csFactory;
+ MgCoordinateSystem* dstCs;
+ MgStringCollection* overrideFilters;
+ TransformCacheMap* transformCache;
+ bool extractColors;
+ Stylizer* ds;
+ deque<Renderer*>* sub_drs;
+ INT32 saveWidth;
+ INT32 saveHeight;
+ STRING format;
+ RS_ByteData** subImg;
+class LayerRenderingWorkers : public ACE_Task<ACE_MT_SYNCH>
+public:
+ // LayerRenderingWorkers();
+ virtual int svc(void);
+ void process_message(ACE_Message_Block *mb);
#endif
Modified: sandbox/liuar/mtr/Server/src/Services/Mapping/ServerMappingService.cpp
--- trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.cpp 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Server/src/Services/Mapping/ServerMappingService.cpp 2012-03-31 02:18:48 UTC (rev 6561)
@@ -709,8 +709,8 @@
//finally generate graphics data for the layers that need it
- MgMappingUtil::StylizeLayers(m_svcResource, m_svcFeature, m_svcDrawing, m_pCSFactory, map,
- rolc, NULL, &ds, &dr, dstCs, false, true, map->GetViewScale());
+ //MgMappingUtil::StylizeLayers(m_svcResource, m_svcFeature, m_svcDrawing, m_pCSFactory, map,
+ // rolc, NULL, &ds, &dr, dstCs, false, true, map->GetViewScale(),m_subImgs);
dr.EndMap();
@@ -1292,8 +1292,8 @@
//stylize all the map layers
- rolc, NULL, &ds, &dr, dstCs, false, false, dMapScale);
+ // MgMappingUtil::StylizeLayers(m_svcResource, m_svcFeature, m_svcDrawing, m_pCSFactory, map,
+ // rolc, NULL, &ds, &dr, dstCs, false, false, dMapScale);
// Finish adding the map to the page
// Calculate the the height of the map bounds on the page (in page units)
Modified: sandbox/liuar/mtr/Server/src/Services/Mapping/ServerMappingService.vcxproj
--- trunk/MgDev/Server/src/Services/Mapping/ServerMappingService.vcxproj 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Server/src/Services/Mapping/ServerMappingService.vcxproj 2012-03-31 02:18:48 UTC (rev 6561)
@@ -118,7 +118,7 @@
<ClCompile>
<AdditionalIncludeDirectories>..\..\Common;..\..\Common\Base;..\..\Common\Manager;..\Feature;..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Common\MapGuideCommon;..\..\..\..\Common\MdfModel;..\..\..\..\Common\MdfParser;..\..\..\..\Common\Renderers;..\..\..\..\Common\Stylization;..\..\..\..\Oem\ACE\ACE_wrappers;..\..\..\..\Oem\dbxml\xerces-c-src\src;..\..\..\..\Oem\FDO\inc;..\..\..\..\Oem\FDO\inc\ExpressionEngine;..\..\Gws\Include;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
- <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;MG_SERVER_MAPPING_EXPORTS;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;MG_SERVER_MAPPING_EXPORTS;MULTI_RENDERERS;%(PreprocessorDefinitions)</PreprocessorDefinitions>
@@ -172,7 +172,7 @@
<ClCompile>
<Optimization>MaxSpeed</Optimization>
- <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;MG_SERVER_MAPPING_EXPORTS;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;MG_SERVER_MAPPING_EXPORTS;MULTI_RENDERERS;%(PreprocessorDefinitions)</PreprocessorDefinitions>
Modified: sandbox/liuar/mtr/Server/src/Services/Rendering/ServerRenderingService.cpp
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Server/src/Services/Rendering/ServerRenderingService.cpp 2012-03-31 02:18:48 UTC (rev 6561)
@@ -33,8 +33,8 @@
// Profile
#include "ProfileRenderMapResult.h"
// the maximum number of allowed pixels for rendered images
static const INT32 MAX_PIXELS = 16384*16384;
static const INT32 FILTER_VISIBLE = 1;
@@ -378,9 +378,6 @@
StylizationUtil::ParseColor(map->GetBackgroundColor(), bgColor);
bgColor.alpha() = 0;
- // initialize the renderer
- auto_ptr<SE_Renderer> dr(CreateRenderer(width, height, bgColor, true));
// create a temporary collection containing all the dynamic layers
Ptr<MgLayerCollection> layers = map->GetLayers();
Ptr<MgReadOnlyLayerCollection> roLayers = new MgReadOnlyLayerCollection();
@@ -392,6 +389,13 @@
roLayers->Add(layer);
+ // initialize the renderer
+ auto_ptr<SE_Renderer> dr(CreateRendererWithSubRenderers(roLayers->GetCount(), width, height, bgColor, true));
+#else
+ auto_ptr<SE_Renderer> dr(CreateRenderer(width, height, bgColor, true));
+#endif
if(NULL != pPRMResult)
Ptr<MgResourceIdentifier> mapResId = map->GetMapDefinition();
@@ -984,7 +988,12 @@
// begin map stylization
dr->StartMap(&mapInfo, b, scale, map->GetDisplayDpi(), map->GetMetersPerUnit(), NULL);
+ for(int i =0; i<m_subRenderers.size(); i++)
+ m_subRenderers[i]->StartMap(&mapInfo, b, scale, map->GetDisplayDpi(), map->GetMetersPerUnit(), NULL);
+#endif
MG_TRY()
// if no layer collection is supplied, then put all layers in a temporary collection
@@ -1004,7 +1013,7 @@
if (behavior & MgRenderingOptions::RenderLayers) // this is for tiles so observer colormaps
- RenderLayers(map, tempLayers, &ds, dr, dstCs, expandExtents, scale, format, pPRMResult);
+ RenderLayers(map, tempLayers, &ds, dr, dstCs, expandExtents, scale, format, pPRMResult, saveWidth, saveHeight);
// now we need to stylize the selection on top (this is not for tiles!)
@@ -1037,6 +1046,17 @@
dr->EndMap();
+ deque<Renderer*>::iterator it = m_subRenderers.begin();
+ while(it != m_subRenderers.end())
+ ((AGGRenderer*)(*it))->SetLabeler(NULL);
+ delete (*it);
+ (*it) = NULL;
+ it++;
+#endif
ProfileRenderLabelsResult* pPRLablesResult = pPRMResult->GetProfileRenderLabelsResult();
@@ -1531,7 +1551,36 @@
// Do nothing. No connection properties are required for server-side service objects.
+SE_Renderer* MgServerRenderingService::CreateRendererWithSubRenderers(int subRenderersCount,
+ int width,
+ int height,
+ RS_Color& bgColor,
+ bool requiresClipping,
+ bool localOverposting,
+ double tileExtentOffset)
+ SE_Renderer* mainRenderer = CreateRenderer(width,height,bgColor,requiresClipping,localOverposting,tileExtentOffset);
+ //m_subRenderers.reserve(POOL_SIZE);
+ m_subImgs.reserve(subRenderersCount);
+ for(int i = 0; i<POOL_SIZE; i++)
+ SE_Renderer* subRenderer = CreateRenderer(width,height,bgColor,requiresClipping,localOverposting,tileExtentOffset);
+ ((AGGRenderer*)subRenderer)->SetLabeler(((AGGRenderer*)mainRenderer)->GetLabeler());
+ m_subRenderers.push_back(subRenderer);
+ for(int i =0; i<subRenderersCount; i++)
+ //m_subRenderers.push_back(CreateRenderer(width,height,bgColor,requiresClipping,localOverposting,tileExtentOffset));
+ //((AGGRenderer*)m_subRenderers[i])->SetLabeler(((AGGRenderer*)mainRenderer)->GetLabeler());
+ RS_ByteData* img = new RS_ByteData();
+ m_subImgs.push_back(img);
+ return mainRenderer;
SE_Renderer* MgServerRenderingService::CreateRenderer(int width,
int height,
@@ -1567,7 +1616,9 @@
bool expandExtents,
double scale,
CREFSTRING format,
- ProfileRenderMapResult* pPRMResult)
+ ProfileRenderMapResult* pPRMResult,
+ INT32 saveWidth,
+ INT32 saveHeight)
ProfileRenderLayersResult* pPRLsResult = NULL; // pointer points to Profile Render Layers Result
@@ -1582,7 +1633,7 @@
layers, NULL, ds, dr, dstCs, expandExtents, false, scale,
- false, hasColorMap(format), pPRLsResult);
+ false, hasColorMap(format), pPRLsResult, &m_subRenderers,&m_subImgs,saveWidth,saveHeight,format);
@@ -1591,7 +1642,7 @@
// Calculate the time spent on stylizing layers
double stylizeLayersTime = MgTimerUtil::GetTime() - pPRLsResult->GetRenderTime();
pPRLsResult->SetRenderTime(stylizeLayersTime);
@@ -1929,6 +1980,23 @@
+ACE_THR_FUNC_RETURN GetCombineWorker(void* param)
+ // get the data for this thread
+ CreateImgThreadData* threadData = (CreateImgThreadData*)param;
+ try
+ threadData->data = ((AGGRenderer*)threadData->dr)->Combine(threadData->pSubImgs,threadData->start,threadData->end);
+ catch (...)
+ throw;
+ return 0;
inline MgByteReader* MgServerRenderingService::CreateImage(MgMap* map,
Renderer* dr,
@@ -1968,9 +2036,150 @@
// get a byte representation of the image
auto_ptr<RS_ByteData> data;
Ptr<MgByteSource> bs;
+ long lSize;
+ char * buffer;
try
+ // for(int i = 0; i<10; i++)
+ // if (wcscmp(m_rendererName.c_str(), L"AGG") == 0)
+ // /// RFC60 code to correct colormaps by UV
+ // // We examine the expressions collected from xml definitions of all layers.
+ // // The map object has a list from all color entries found in the most recent
+ // // layer stylization.
+ // // * TODO - currently they are interpreted as ffffffff 32-bit RGBA string values
+ // // * adding expresssions and other interpretations should be done in ParseColorStrings
+ // // * the color Palette for the renderer is a vector<RS_Color>
+ // if (hasColorMap(format))
+ // RS_ColorVector tileColorPalette;
+ // MgMappingUtil::ParseColorStrings(&tileColorPalette, map);
+ //// printf("<<<<<<<<<<<<<<<<<<<<< MgServerRenderingService::ColorPalette->size(): %d\n", tileColorPalette.size());
+ // ((AGGRenderer*)m_subRenderers[i])->Save(fileName,format, saveWidth, saveHeight);
+ // //data.reset(((AGGRenderer*)dr)->ReadPNG(fileName));
+ // //data.reset( ((AGGRenderer*)m_subRenderers[i])->Save(format, saveWidth, saveHeight,&tileColorPalette));
+ // //break;
+ // else
+ // //((AGGRenderer*)m_subRenderers[i])->Save(fileName,format, saveWidth, saveHeight);
+ // //data.reset(((AGGRenderer*)m_subRenderers[i])->Save(format, saveWidth, saveHeight,NULL));
+ // //data.reset(((AGGRenderer*)m_subRenderers[i])->ReadPNG(fileName));
+ // //break;
+ // else
+ // ((GDRenderer*)m_subRenderers[i])->Save(fileName,format, saveWidth, saveHeight);
+ double comineStart = MgTimerUtil::GetTime();
+ //RS_String file2;
+ //for(int i = 0; i<10; i++)
+ // if(i==9)
+ // //the last image don't need to be combined
+ // break;
+ // RS_String file1;
+ // MgUtil::Int32ToString(i,file1);
+ // file1.append(L".");
+ // file1.append(format);
+ // MgUtil::Int32ToString(i+1,file2);
+ // file2.append(L".");
+ // file2.append(format);
+ // ((AGGRenderer*)dr)->Combine(file1,file2,file2);
+ // else
+ // _ASSERT("NOT SUPPORT");
+ // //((GDRenderer*)dr)->Combine(file1,file2,file2);
+#ifdef MULTI_THREAD_COMBINE
+ ACE_Thread_Manager* manager = ACE_Thread_Manager::instance();
+ const int THREAD_GROUP = 65535;
+ CreateImgThreadData threadData1, threadData2;
+ threadData1.dr = dr;
+ threadData1.pSubImgs = &m_subImgs;
+ threadData1.start = 0;
+ threadData1.end = m_subImgs.size()/2;
+ threadData2.dr = dr;
+ threadData2.pSubImgs = &m_subImgs;
+ threadData2.start = m_subImgs.size()/2;
+ threadData2.end = m_subImgs.size();
+ manager->spawn(ACE_THR_FUNC(GetCombineWorker), &threadData1, 0, NULL, NULL, 0, THREAD_GROUP);
+ manager->spawn(ACE_THR_FUNC(GetCombineWorker), &threadData2, 0, NULL, NULL, 0, THREAD_GROUP);
+ vector<RS_ByteData*> tempSubImgs;
+ tempSubImgs.reserve(3); // label thread1 thread2
+ RS_ByteData* labelImg = ((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight,NULL);
+ manager->wait_grp(THREAD_GROUP);
+ // Clear m_subImgs
+ vector<RS_ByteData*>::iterator it = m_subImgs.begin();
+ while(it != m_subImgs.end())
+ delete *it;
+ *it = NULL;
+ it++;
+ // combine temp images
+ tempSubImgs.push_back(threadData1.data);
+ tempSubImgs.push_back(threadData2.data);
+ tempSubImgs.push_back(labelImg);
+ data.reset(((AGGRenderer*)dr)->Combine(&tempSubImgs,0,3));
+ // Clear temp subImgs
+ it = tempSubImgs.begin();
+ while(it != tempSubImgs.end())
+ delete *it;
+ *it = NULL;
+ it++;
+#else
+ data.reset(((AGGRenderer*)dr)->Combine(&m_subImgs,labelImg));
+ delete *it;
+ *it = NULL;
+ it++;
+#endif
+ ACE_DEBUG((LM_INFO, L"(%t) CombineImage() total time = %6.4f (ms)\n", (MgTimerUtil::GetTime()- comineStart)));
+#else
+ try
// call the image renderer to create the image
@@ -1996,6 +2205,7 @@
else
data.reset(((GDRenderer*)dr)->Save(format, saveWidth, saveHeight));
+#endif
catch (exception e)
ACE_DEBUG((LM_DEBUG, L"(%t) %w caught in RenderingService ColorPaletteGeneration\n", e.what()));
Modified: sandbox/liuar/mtr/Server/src/Services/Rendering/ServerRenderingService.h
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.h 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Server/src/Services/Rendering/ServerRenderingService.h 2012-03-31 02:18:48 UTC (rev 6561)
@@ -24,6 +24,7 @@
class FeatureInfoRenderer;
class MgFeatureInformation;
class Stylizer;
+class RS_ByteData;
namespace MdfModel
@@ -235,6 +236,14 @@
bool localOverposting = false,
double tileExtentOffset = 0.0);
+ SE_Renderer* MgServerRenderingService::CreateRendererWithSubRenderers(int subRenderersCount,
+ int width,
+ int height,
+ bool localOverposting = false,
+ double tileExtentOffset = 0.0);
void RenderLayers(MgMap* map,
MgReadOnlyLayerCollection* layers,
Stylizer* ds,
@@ -243,7 +252,9 @@
bool expandExtents,
double scale,
CREFSTRING format,
- ProfileRenderMapResult* pPRMResult);
+ INT32 saveWidth,
+ INT32 saveHeight);
void RenderSelection(MgMap* map,
MgSelection* selection,
@@ -288,6 +299,17 @@
INT32 m_renderSelectionBatchSize;
INT32 m_maxRasterImageWidth;
INT32 m_maxRasterImageHeight;
+ deque<Renderer*> m_subRenderers;
+ vector<RS_ByteData*> m_subImgs;
+struct CreateImgThreadData
+ Renderer* dr;
+ vector<RS_ByteData*>* pSubImgs;
+ size_t start;
+ size_t end;
+ RS_ByteData* data;
#endif
Modified: sandbox/liuar/mtr/Server/src/Services/Rendering/ServerRenderingService.vcxproj
--- trunk/MgDev/Server/src/Services/Rendering/ServerRenderingService.vcxproj 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Server/src/Services/Rendering/ServerRenderingService.vcxproj 2012-03-31 02:18:48 UTC (rev 6561)
@@ -117,7 +117,7 @@
<ClCompile>
<AdditionalIncludeDirectories>..\..\Common;..\..\Common\Base;..\..\Common\Manager;..\Feature;..\Mapping;..\..\..\..\Common\Foundation;..\..\..\..\Common\Geometry;..\..\..\..\Common\PlatformBase;..\..\..\..\Common\MapGuideCommon;..\..\..\..\Common\MdfModel;..\..\..\..\Common\Renderers;..\..\..\..\Common\Stylization;..\..\..\..\Oem\ACE\ACE_wrappers;..\..\..\..\Oem\dbxml\xerces-c-src\src;..\..\..\..\Oem\FDO\inc;..\..\..\..\Oem\FDO\inc\ExpressionEngine;%(AdditionalIncludeDirectories)</AdditionalIncludeDirectories>
- <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;MG_SERVER_RENDERING_EXPORTS;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <PreprocessorDefinitions>WIN32;_DEBUG;_WINDOWS;_USRDLL;MG_SERVER_RENDERING_EXPORTS;MULTI_RENDERERS;MULTI_THREAD_COMBINE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
@@ -169,7 +169,7 @@
<ClCompile>
- <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;MG_SERVER_RENDERING_EXPORTS;%(PreprocessorDefinitions)</PreprocessorDefinitions>
+ <PreprocessorDefinitions>WIN32;NDEBUG;_WINDOWS;_USRDLL;MG_SERVER_RENDERING_EXPORTS;MULTI_RENDERERS;MULTI_THREAD_COMBINE;%(PreprocessorDefinitions)</PreprocessorDefinitions>
Modified: sandbox/liuar/mtr/Server/src/Services/Site/SiteOperation.cpp
--- trunk/MgDev/Server/src/Services/Site/SiteOperation.cpp 2012-01-31 01:16:56 UTC (rev 6468)
+++ sandbox/liuar/mtr/Server/src/Services/Site/SiteOperation.cpp 2012-03-31 02:18:48 UTC (rev 6561)
@@ -83,5 +83,5 @@
void MgSiteOperation::Validate()
AuthenticateCurrentUser();
- CheckLicense();
+ //CheckLicense();
More information about the mapguide-commits
