[mapguide-commits] r6618 - in trunk/Tools/Maestro/Maestro.Editors: . LayerDefinition/Vector/Scales
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 8 07:13:26 EDT 2012
Author: jng
Date: 2012-05-08 04:13:26 -0700 (Tue, 08 May 2012)
New Revision: 6618
Added:
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.cs
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.resx
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.Designer.cs
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.resx
   trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
#1959: Expose AllowOverpost and DisplayAsText options in the editor UI
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.Designer.cs	2012-05-08 11:13:26 UTC (rev 6618)
@@ -0,0 +1,89 @@
+namespace Maestro.Editors.LayerDefinition.Vector.Scales
+    partial class PointStylePanel
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Component Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            this.chkEnable = new System.Windows.Forms.CheckBox();
+            this.chkDisplayAsText = new System.Windows.Forms.CheckBox();
+            this.chkAllowOverpost = new System.Windows.Forms.CheckBox();
+            this.SuspendLayout();
+            // chkEnable
+            this.chkEnable.AutoSize = true;
+            this.chkEnable.Location = new System.Drawing.Point(3, 3);
+            this.chkEnable.Name = "chkEnable";
+            this.chkEnable.Size = new System.Drawing.Size(92, 17);
+            this.chkEnable.TabIndex = 0;
+            this.chkEnable.Text = "Display Points";
+            this.chkEnable.UseVisualStyleBackColor = true;
+            this.chkEnable.CheckedChanged += new System.EventHandler(this.chkEnable_CheckedChanged);
+            // chkDisplayAsText
+            this.chkDisplayAsText.AutoSize = true;
+            this.chkDisplayAsText.Location = new System.Drawing.Point(114, 3);
+            this.chkDisplayAsText.Name = "chkDisplayAsText";
+            this.chkDisplayAsText.Size = new System.Drawing.Size(99, 17);
+            this.chkDisplayAsText.TabIndex = 1;
+            this.chkDisplayAsText.Text = "Display As Text";
+            this.chkDisplayAsText.UseVisualStyleBackColor = true;
+            this.chkDisplayAsText.CheckedChanged += new System.EventHandler(this.chkDisplayAsText_CheckedChanged);
+            // chkAllowOverpost
+            this.chkAllowOverpost.AutoSize = true;
+            this.chkAllowOverpost.Location = new System.Drawing.Point(230, 3);
+            this.chkAllowOverpost.Name = "chkAllowOverpost";
+            this.chkAllowOverpost.Size = new System.Drawing.Size(97, 17);
+            this.chkAllowOverpost.TabIndex = 2;
+            this.chkAllowOverpost.Text = "Allow Overpost";
+            this.chkAllowOverpost.UseVisualStyleBackColor = true;
+            this.chkAllowOverpost.CheckedChanged += new System.EventHandler(this.chkAllowOverpost_CheckedChanged);
+            // PointStylePanel
+            this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.Controls.Add(this.chkAllowOverpost);
+            this.Controls.Add(this.chkDisplayAsText);
+            this.Controls.Add(this.chkEnable);
+            this.Name = "PointStylePanel";
+            this.Size = new System.Drawing.Size(603, 23);
+            this.ResumeLayout(false);
+            this.PerformLayout();
+        #endregion
+        private System.Windows.Forms.CheckBox chkEnable;
+        private System.Windows.Forms.CheckBox chkDisplayAsText;
+        private System.Windows.Forms.CheckBox chkAllowOverpost;
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.cs	2012-05-08 11:13:26 UTC (rev 6618)
@@ -0,0 +1,112 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+    public partial class PointStylePanel : UserControl
+        public PointStylePanel()
+            InitializeComponent();
+        public bool DisplayEnabled
+            get { return chkEnable.Checked; }
+            set
+                if (value != chkEnable.Checked)
+                    chkEnable.Checked = value;
+                    var h = this.DisplayEnabledChanged;
+                    if (h != null)
+                        h(this, EventArgs.Empty);
+                chkDisplayAsText.Enabled = chkAllowOverpost.Enabled = value;
+        public event EventHandler DisplayEnabledChanged;
+        public bool DisplayAsText
+            get { return chkDisplayAsText.Checked; }
+            set
+                if (value != chkDisplayAsText.Checked)
+                    chkDisplayAsText.Checked = value;
+                    var h = this.DisplayAsTextChanged;
+                    if (h != null)
+        public event EventHandler DisplayAsTextChanged;
+        public bool AllowOverpost
+            get { return chkAllowOverpost.Checked; }
+            set
+                if (value != chkAllowOverpost.Checked)
+                    chkAllowOverpost.Checked = value;
+                    var h = this.AllowOverpostChanged;
+                    if (h != null)
+        public event EventHandler AllowOverpostChanged;
+        private void chkEnable_CheckedChanged(object sender, EventArgs e)
+            chkDisplayAsText.Enabled = chkAllowOverpost.Enabled = chkEnable.Checked;
+            if (h != null)
+        private void chkDisplayAsText_CheckedChanged(object sender, EventArgs e)
+            if (h != null)
+        private void chkAllowOverpost_CheckedChanged(object sender, EventArgs e)
+            if (h != null)
Added: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.resx	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/PointStylePanel.resx	2012-05-08 11:13:26 UTC (rev 6618)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.Designer.cs	2012-05-05 17:51:42 UTC (rev 6617)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.Designer.cs	2012-05-08 11:13:26 UTC (rev 6618)
@@ -29,23 +29,16 @@
             System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(VectorScaleRangeCtrl));
-            this.chkPoint = new System.Windows.Forms.CheckBox();
             this.chkLine = new System.Windows.Forms.CheckBox();
             this.chkArea = new System.Windows.Forms.CheckBox();
             this.chkComposite = new System.Windows.Forms.CheckBox();
+            this.compList = new Maestro.Editors.LayerDefinition.Vector.Scales.CompositeStyleListCtrl();
             this.areaList = new Maestro.Editors.LayerDefinition.Vector.Scales.ConditionListButtons();
             this.lineList = new Maestro.Editors.LayerDefinition.Vector.Scales.ConditionListButtons();
             this.pointList = new Maestro.Editors.LayerDefinition.Vector.Scales.ConditionListButtons();
-            this.compList = new Maestro.Editors.LayerDefinition.Vector.Scales.CompositeStyleListCtrl();
+            this.pointStylePanel = new Maestro.Editors.LayerDefinition.Vector.Scales.PointStylePanel();
-            // chkPoint
-            resources.ApplyResources(this.chkPoint, "chkPoint");
-            this.chkPoint.Name = "chkPoint";
-            this.chkPoint.UseVisualStyleBackColor = true;
-            this.chkPoint.CheckedChanged += new System.EventHandler(this.chkPoint_CheckedChanged);
             // chkLine
             resources.ApplyResources(this.chkLine, "chkLine");
@@ -67,6 +60,11 @@
             this.chkComposite.UseVisualStyleBackColor = true;
             this.chkComposite.CheckedChanged += new System.EventHandler(this.chkComposite_CheckedChanged);
+            // compList
+            resources.ApplyResources(this.compList, "compList");
+            this.compList.Name = "compList";
             // areaList
             resources.ApplyResources(this.areaList, "areaList");
@@ -85,10 +83,10 @@
             this.pointList.Name = "pointList";
             this.pointList.ItemChanged += new System.EventHandler(this.OnItemChanged);
-            // compList
+            // pointStylePanel
-            resources.ApplyResources(this.compList, "compList");
-            this.compList.Name = "compList";
+            resources.ApplyResources(this.pointStylePanel, "pointStylePanel");
+            this.pointStylePanel.Name = "pointStylePanel";
             // VectorScaleRangeCtrl
@@ -100,7 +98,7 @@
             this.Controls.Add(this.lineList);
             this.Controls.Add(this.chkLine);
             this.Controls.Add(this.pointList);
-            this.Controls.Add(this.chkPoint);
+            this.Controls.Add(this.pointStylePanel);
             this.Name = "VectorScaleRangeCtrl";
             resources.ApplyResources(this, "$this");
@@ -109,7 +107,6 @@
         #endregion
-        private System.Windows.Forms.CheckBox chkPoint;
         private ConditionListButtons pointList;
         private System.Windows.Forms.CheckBox chkLine;
         private ConditionListButtons lineList;
@@ -117,6 +114,7 @@
         private ConditionListButtons areaList;
         private System.Windows.Forms.CheckBox chkComposite;
         private CompositeStyleListCtrl compList;
+        private PointStylePanel pointStylePanel;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.cs	2012-05-05 17:51:42 UTC (rev 6617)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.cs	2012-05-08 11:13:26 UTC (rev 6618)
@@ -44,6 +44,10 @@
         public VectorScaleRangeCtrl(IVectorScaleRange vsr, VectorLayerStyleSectionCtrl parent)
+            //WTF: These events don't show in the designer! So bind them here
+            pointStylePanel.DisplayEnabledChanged += new EventHandler(OnPointDisplayEnabledChanged);
+            pointStylePanel.DisplayAsTextChanged += new EventHandler(OnPointDisplayAsTextChanged);
+            pointStylePanel.AllowOverpostChanged += new EventHandler(OnPointAllowOverpostChanged);
             _init = true;
             try
@@ -55,12 +59,12 @@
                 _lns = vsr.LineStyle;
                 _ars = vsr.AreaStyle;
-                chkPoint.Checked = true;
+                pointStylePanel.DisplayEnabled = true;
                 chkLine.Checked = true;
                 chkArea.Checked = true;
                 chkComposite.Checked = true;
-                chkPoint.Checked = (_pts != null);
+                pointStylePanel.DisplayEnabled = (_pts != null);
                 chkLine.Checked = (_lns != null);
                 chkArea.Checked = (_ars != null);
@@ -75,6 +79,9 @@
                 if (_pts == null)
                     _pts = parent.Factory.CreateDefaultPointStyle();
+                pointStylePanel.DisplayAsText = _pts.DisplayAsText;
+                pointStylePanel.AllowOverpost = _pts.AllowOverpost;
                 if (_lns == null)
                     _lns = parent.Factory.CreateDefaultLineStyle();
@@ -122,6 +129,25 @@
+        void OnPointDisplayEnabledChanged(object sender, EventArgs e)
+            pointList.Visible = pointStylePanel.DisplayEnabled;
+            if (_init) return;
+            _vsr.PointStyle = (pointStylePanel.DisplayEnabled) ? _pts : null;
+            _parent.RaiseResourceChanged();
+        void OnPointAllowOverpostChanged(object sender, EventArgs e)
+            _pts.AllowOverpost = pointStylePanel.AllowOverpost;
+        void OnPointDisplayAsTextChanged(object sender, EventArgs e)
+            _pts.DisplayAsText = pointStylePanel.DisplayAsText;
         protected override void OnResize(EventArgs e)
             pointList.ResizeAuto();
@@ -131,15 +157,6 @@
             base.OnResize(e);
-        private void chkPoint_CheckedChanged(object sender, EventArgs e)
-            pointList.Visible = chkPoint.Checked;
-            if (_init) return;
-            _vsr.PointStyle = (chkPoint.Checked) ? _pts : null;
-            _parent.RaiseResourceChanged();
         private void chkLine_CheckedChanged(object sender, EventArgs e)
             lineList.Visible = chkLine.Checked;
Modified: trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.resx
--- trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.resx	2012-05-05 17:51:42 UTC (rev 6617)
+++ trunk/Tools/Maestro/Maestro.Editors/LayerDefinition/Vector/Scales/VectorScaleRangeCtrl.resx	2012-05-08 11:13:26 UTC (rev 6618)
@@ -112,50 +112,26 @@
     <value>2.0</value>
   </resheader>
-    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
-    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
-  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
-  <data name="chkPoint.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="chkLine.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
     <value>Top</value>
   </data>
-  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
-  <data name="chkPoint.Location" type="System.Drawing.Point, System.Drawing">
-    <value>0, 0</value>
+  <data name="chkLine.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+    <value>NoControl</value>
   </data>
-  <data name="chkPoint.Size" type="System.Drawing.Size, System.Drawing">
-    <value>598, 24</value>
-  </data>
-  <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
-  <data name="chkPoint.TabIndex" type="System.Int32, mscorlib">
-    <value>0</value>
-  </data>
-  <data name="chkPoint.Text" xml:space="preserve">
-    <value>Display Points (Note: Symbol previews only show the symbol. It doesn't consider color overrides or size/rotation settings)</value>
-  </data>
-  <data name="&gt;&gt;chkPoint.Name" xml:space="preserve">
-    <value>chkPoint</value>
-  </data>
-  <data name="&gt;&gt;chkPoint.Type" xml:space="preserve">
-    <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
-  </data>
-  <data name="&gt;&gt;chkPoint.Parent" xml:space="preserve">
-    <value>$this</value>
-  </data>
-  <data name="&gt;&gt;chkPoint.ZOrder" xml:space="preserve">
-    <value>7</value>
-  </data>
-  <data name="chkLine.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
-    <value>Top</value>
-  </data>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
   <data name="chkLine.Location" type="System.Drawing.Point, System.Drawing">
-    <value>0, 121</value>
+    <value>0, 120</value>
   </data>
   <data name="chkLine.Size" type="System.Drawing.Size, System.Drawing">
   </data>
+  <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="chkLine.TabIndex" type="System.Int32, mscorlib">
     <value>2</value>
   </data>
@@ -166,7 +142,7 @@
     <value>chkLine</value>
   </data>
   <data name="&gt;&gt;chkLine.Type" xml:space="preserve">
+    <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name="&gt;&gt;chkLine.Parent" xml:space="preserve">
@@ -177,8 +153,11 @@
   <data name="chkArea.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
     <value>Top</value>
   </data>
+  <data name="chkArea.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+  </data>
   <data name="chkArea.Location" type="System.Drawing.Point, System.Drawing">
-    <value>0, 242</value>
+    <value>0, 241</value>
   </data>
   <data name="chkArea.Size" type="System.Drawing.Size, System.Drawing">
@@ -193,7 +172,7 @@
     <value>chkArea</value>
   </data>
   <data name="&gt;&gt;chkArea.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;chkArea.Parent" xml:space="preserve">
@@ -204,8 +183,11 @@
   <data name="chkComposite.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
     <value>Top</value>
   </data>
+  <data name="chkComposite.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+  </data>
   <data name="chkComposite.Location" type="System.Drawing.Point, System.Drawing">
-    <value>0, 363</value>
+    <value>0, 362</value>
   </data>
   <data name="chkComposite.Size" type="System.Drawing.Size, System.Drawing">
@@ -220,7 +202,7 @@
     <value>chkComposite</value>
   </data>
   <data name="&gt;&gt;chkComposite.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;chkComposite.Parent" xml:space="preserve">
@@ -228,11 +210,35 @@
   <data name="&gt;&gt;chkComposite.ZOrder" xml:space="preserve">
     <value>1</value>
   </data>
+  <data name="compList.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+    <value>Fill</value>
+  </data>
+  <data name="compList.Location" type="System.Drawing.Point, System.Drawing">
+    <value>0, 386</value>
+  </data>
+  <data name="compList.Size" type="System.Drawing.Size, System.Drawing">
+    <value>598, 109</value>
+  </data>
+  <data name="compList.TabIndex" type="System.Int32, mscorlib">
+    <value>7</value>
+  </data>
+  <data name="&gt;&gt;compList.Name" xml:space="preserve">
+    <value>compList</value>
+  </data>
+  <data name="&gt;&gt;compList.Type" xml:space="preserve">
+    <value>Maestro.Editors.LayerDefinition.Vector.Scales.CompositeStyleListCtrl, Maestro.Editors, Version=5.0.0.6514, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
+  </data>
+  <data name="&gt;&gt;compList.Parent" xml:space="preserve">
+    <value>$this</value>
+  </data>
+  <data name="&gt;&gt;compList.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
   <data name="areaList.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
     <value>Top</value>
   </data>
   <data name="areaList.Location" type="System.Drawing.Point, System.Drawing">
-    <value>0, 266</value>
+    <value>0, 265</value>
   </data>
   <data name="areaList.Size" type="System.Drawing.Size, System.Drawing">
     <value>598, 97</value>
@@ -244,7 +250,7 @@
     <value>areaList</value>
   </data>
   <data name="&gt;&gt;areaList.Type" xml:space="preserve">
-    <value>Maestro.Editors.LayerDefinition.Vector.Scales.ConditionListButtons, Maestro.Editors, Version=3.5.0.6040, Culture=neutral, PublicKeyToken=null</value>
+    <value>Maestro.Editors.LayerDefinition.Vector.Scales.ConditionListButtons, Maestro.Editors, Version=5.0.0.6514, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
   </data>
   <data name="&gt;&gt;areaList.Parent" xml:space="preserve">
@@ -256,7 +262,7 @@
     <value>Top</value>
   </data>
   <data name="lineList.Location" type="System.Drawing.Point, System.Drawing">
-    <value>0, 145</value>
+    <value>0, 144</value>
   </data>
   <data name="lineList.Size" type="System.Drawing.Size, System.Drawing">
@@ -268,7 +274,7 @@
     <value>lineList</value>
   </data>
   <data name="&gt;&gt;lineList.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;lineList.Parent" xml:space="preserve">
@@ -280,7 +286,7 @@
     <value>Top</value>
   </data>
   <data name="pointList.Location" type="System.Drawing.Point, System.Drawing">
-    <value>0, 24</value>
+    <value>0, 23</value>
   </data>
   <data name="pointList.Size" type="System.Drawing.Size, System.Drawing">
@@ -292,7 +298,7 @@
     <value>pointList</value>
   </data>
   <data name="&gt;&gt;pointList.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;pointList.Parent" xml:space="preserve">
@@ -300,31 +306,31 @@
   <data name="&gt;&gt;pointList.ZOrder" xml:space="preserve">
     <value>6</value>
   </data>
-  <data name="compList.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
-    <value>Fill</value>
+  <data name="pointStylePanel.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+    <value>Top</value>
   </data>
-  <data name="compList.Location" type="System.Drawing.Point, System.Drawing">
-    <value>0, 387</value>
+  <data name="pointStylePanel.Location" type="System.Drawing.Point, System.Drawing">
+    <value>0, 0</value>
   </data>
-  <data name="compList.Size" type="System.Drawing.Size, System.Drawing">
-    <value>598, 108</value>
+  <data name="pointStylePanel.Size" type="System.Drawing.Size, System.Drawing">
+    <value>598, 23</value>
   </data>
-  <data name="compList.TabIndex" type="System.Int32, mscorlib">
-    <value>7</value>
+  <data name="pointStylePanel.TabIndex" type="System.Int32, mscorlib">
+    <value>8</value>
   </data>
-  <data name="&gt;&gt;compList.Name" xml:space="preserve">
-    <value>compList</value>
+  <data name="&gt;&gt;pointStylePanel.Name" xml:space="preserve">
+    <value>pointStylePanel</value>
   </data>
-  <data name="&gt;&gt;compList.Type" xml:space="preserve">
-    <value>Maestro.Editors.LayerDefinition.Vector.Scales.CompositeStyleListCtrl, Maestro.Editors, Version=3.5.0.6040, Culture=neutral, PublicKeyToken=null</value>
+  <data name="&gt;&gt;pointStylePanel.Type" xml:space="preserve">
+    <value>Maestro.Editors.LayerDefinition.Vector.Scales.PointStylePanel, Maestro.Editors, Version=5.0.0.6514, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
   </data>
-  <data name="&gt;&gt;compList.Parent" xml:space="preserve">
+  <data name="&gt;&gt;pointStylePanel.Parent" xml:space="preserve">
   </data>
-  <data name="&gt;&gt;compList.ZOrder" xml:space="preserve">
-    <value>0</value>
+  <data name="&gt;&gt;pointStylePanel.ZOrder" xml:space="preserve">
+    <value>7</value>
   </data>
-  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
     <value>True</value>
   </metadata>
   <data name="$this.Size" type="System.Drawing.Size, System.Drawing">
@@ -334,6 +340,6 @@
     <value>VectorScaleRangeCtrl</value>
   </data>
   <data name="&gt;&gt;$this.Type" xml:space="preserve">
-    <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
 </root>
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj	2012-05-05 17:51:42 UTC (rev 6617)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj	2012-05-08 11:13:26 UTC (rev 6618)
@@ -730,6 +730,12 @@
     <Compile Include="LayerDefinition\Vector\Scales\ItemStyle.designer.cs">
       <DependentUpon>ItemStyle.cs</DependentUpon>
     </Compile>
+    <Compile Include="LayerDefinition\Vector\Scales\PointStylePanel.cs">
+      <SubType>UserControl</SubType>
+    </Compile>
+    <Compile Include="LayerDefinition\Vector\Scales\PointStylePanel.Designer.cs">
+      <DependentUpon>PointStylePanel.cs</DependentUpon>
+    </Compile>
     <Compile Include="LayerDefinition\Vector\Scales\SymbolInstanceEditors\ReferenceCtrl.cs">
     </Compile>
@@ -1542,6 +1548,9 @@
     <EmbeddedResource Include="LayerDefinition\Vector\Scales\ItemStyle.resx">
     </EmbeddedResource>
+    <EmbeddedResource Include="LayerDefinition\Vector\Scales\PointStylePanel.resx">
+    </EmbeddedResource>
     <EmbeddedResource Include="LayerDefinition\Vector\Scales\SymbolInstanceEditors\ReferenceCtrl.resx">
       <DependentUpon>ReferenceCtrl.cs</DependentUpon>
     </EmbeddedResource>
More information about the mapguide-commits mailing list
