[mapguide-commits] r6627 - in branches/maestro-4.0.x: Maestro Maestro.Base Maestro.Base/Commands Maestro.Base/Properties Maestro.Base/Resources Maestro.Base/UI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 8 10:12:33 EDT 2012
Author: jng
Date: 2012-05-08 07:12:33 -0700 (Tue, 08 May 2012)
New Revision: 6627
Added:
   branches/maestro-4.0.x/Maestro.Base/Commands/OpenResourceIdCommand.cs
   branches/maestro-4.0.x/Maestro.Base/Resources/folder-open-document.png
   branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.Designer.cs
   branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.cs
   branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.resx
   branches/maestro-4.0.x/Maestro.Base/Maestro.Base.addin
   branches/maestro-4.0.x/Maestro.Base/Maestro.Base.csproj
   branches/maestro-4.0.x/Maestro.Base/Properties/Resources.Designer.cs
   branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx
   branches/maestro-4.0.x/Maestro/changelog.txt
Backport #1937 to 4.0.x and a changelog.txt update
Modified: branches/maestro-4.0.x/Maestro/changelog.txt
--- branches/maestro-4.0.x/Maestro/changelog.txt	2012-05-08 13:43:13 UTC (rev 6626)
+++ branches/maestro-4.0.x/Maestro/changelog.txt	2012-05-08 14:12:33 UTC (rev 6627)
@@ -1,4 +1,20 @@
-4.0
+4.0.1
+ - Uses new mg-desktop release (8 May 2012, .net 2.0, VC9)
+ - New command to open sources by entering its resource id
+ - New shortcut buttons to jump from Layer Definition to Feature/Drawing Source
+ - Fix: AllowOverpost and DisplayAsText properties for basic point style not exposed in editor UI
+ - Fix: Incorrect RuntimeMapLayer property initialization for tiled maps
+ - Fix: Incorrect serialization of Map Extents
+ - Fix: MgCooker crashes with Map Definitions whose schema version is > 1.0.0
+ - Fix: Clear connection status before testing it in Feature Source Editor
+ - Fix: ResourcePicker fixes to optimize usability
+ - Fix: Map Definition Editor dirty state flagging
+ - Fix: Web Layout Editor usability and UI fixes
+ - Fix: Unnecessary dirty state flagging in Generic Feature Source Editor and Layer Definition editors
+ - Fix: Workaround Oracle issue with SpatialExtents()
+4.0
  - Map Definition Editor support for specifying a Google/Yahoo/Bing/OSM compatible finite scale list
Copied: branches/maestro-4.0.x/Maestro.Base/Commands/OpenResourceIdCommand.cs (from rev 6510, trunk/Tools/Maestro/Maestro.Base/Commands/OpenResourceIdCommand.cs)
--- branches/maestro-4.0.x/Maestro.Base/Commands/OpenResourceIdCommand.cs	                        (rev 0)
+++ branches/maestro-4.0.x/Maestro.Base/Commands/OpenResourceIdCommand.cs	2012-05-08 14:12:33 UTC (rev 6627)
@@ -0,0 +1,59 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Text;
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+using Maestro.Base.UI;
+using System.Windows.Forms;
+namespace Maestro.Base.Commands
+    internal class OpenResourceIdCommand : AbstractMenuCommand
+        public override void Run()
+            var wb = Workbench.Instance;
+            var exp = wb.ActiveSiteExplorer;
+            var omgr = ServiceRegistry.GetService<OpenResourceManager>();
+            var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+            if (connMgr.GetConnectionNames().Count == 0)
+                MessageBox.Show(Properties.Resources.NoOpenConnections);
+                return;
+            var diag = new OpenResourceIdDialog(connMgr);
+            if (diag.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+                if (diag.SelectedConnection.ResourceService.ResourceExists(diag.SelectedResourceId))
+                    omgr.Open(diag.SelectedResourceId, diag.SelectedConnection, false, exp);
+                else
+                    MessageBox.Show(Properties.Resources.ResourceNotFound);
Modified: branches/maestro-4.0.x/Maestro.Base/Maestro.Base.addin
--- branches/maestro-4.0.x/Maestro.Base/Maestro.Base.addin	2012-05-08 13:43:13 UTC (rev 6626)
+++ branches/maestro-4.0.x/Maestro.Base/Maestro.Base.addin	2012-05-08 14:12:33 UTC (rev 6627)
@@ -88,6 +88,11 @@
                           icon="document__plus"
                           class="Maestro.Base.Commands.NewItemCommand" />
             </Condition>
+            <MenuItem id="OpenResource"
+                      label="${res:Menu_File_OpenResource}"
+                      icon="folder_open_document"
+                      shortcut="Control|O"
+                      class="Maestro.Base.Commands.OpenResourceIdCommand" />
             <MenuItem type="Separator" />
             <Condition action="Disable" name="EditorFunction">
                 <Condition action="Disable" name="HasDocuments">
Modified: branches/maestro-4.0.x/Maestro.Base/Maestro.Base.csproj
--- branches/maestro-4.0.x/Maestro.Base/Maestro.Base.csproj	2012-05-08 13:43:13 UTC (rev 6626)
+++ branches/maestro-4.0.x/Maestro.Base/Maestro.Base.csproj	2012-05-08 14:12:33 UTC (rev 6627)
@@ -72,6 +72,7 @@
     <Compile Include="Commands\CutCommand.cs" />
     <Compile Include="Commands\EditAsXmlCommand.cs" />
     <Compile Include="Commands\EditPackageCommand.cs" />
+    <Compile Include="Commands\OpenResourceIdCommand.cs" />
     <Compile Include="Commands\SiteExplorer\EditResourceHeaderCommand.cs" />
     <Compile Include="Commands\LoadPackageCommand.cs" />
     <Compile Include="Commands\LocalFeatureSourcePreviewCommand.cs" />
@@ -290,6 +291,12 @@
     <Compile Include="UI\NewResourceDialog.Designer.cs">
       <DependentUpon>NewResourceDialog.cs</DependentUpon>
     </Compile>
+    <Compile Include="UI\OpenResourceIdDialog.cs">
+      <SubType>Form</SubType>
+    </Compile>
+    <Compile Include="UI\OpenResourceIdDialog.Designer.cs">
+      <DependentUpon>OpenResourceIdDialog.cs</DependentUpon>
+    </Compile>
     <Compile Include="UI\OutboundRequestViewer.cs">
       <SubType>UserControl</SubType>
     </Compile>
@@ -402,6 +409,7 @@
   </ItemGroup>
   <ItemGroup>
     <Content Include="Maestro.Base.addin" />
+    <Content Include="Resources\folder-open-document.png" />
     <None Include="Resources\edit-language.png" />
     <None Include="Resources\box--pencil.png" />
     <None Include="Resources\Contributors.txt" />
@@ -530,6 +538,9 @@
       <SubType>Designer</SubType>
     </EmbeddedResource>
+    <EmbeddedResource Include="UI\OpenResourceIdDialog.resx">
+    </EmbeddedResource>
     <EmbeddedResource Include="UI\OutboundRequestViewer.resx">
       <DependentUpon>OutboundRequestViewer.cs</DependentUpon>
     </EmbeddedResource>
Modified: branches/maestro-4.0.x/Maestro.Base/Properties/Resources.Designer.cs
--- branches/maestro-4.0.x/Maestro.Base/Properties/Resources.Designer.cs	2012-05-08 13:43:13 UTC (rev 6626)
+++ branches/maestro-4.0.x/Maestro.Base/Properties/Resources.Designer.cs	2012-05-08 14:12:33 UTC (rev 6627)
@@ -843,6 +843,13 @@
+        internal static System.Drawing.Bitmap folder_open_document {
+            get {
+                object obj = ResourceManager.GetObject("folder_open_document", resourceCulture);
+                return ((System.Drawing.Bitmap)(obj));
         /// <summary>
         ///   Looks up a localized string similar to Symbols.
         /// </summary>
@@ -905,6 +912,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Invalid Resource ID.
+        /// </summary>
+        internal static string InvalidResourceId {
+            get {
+                return ResourceManager.GetString("InvalidResourceId", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to {0} items copied and placed in clipboard.
         /// </summary>
         internal static string ItemsCopied {
@@ -1138,6 +1154,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Open Resource.
+        /// </summary>
+        internal static string Menu_File_OpenResource {
+            get {
+                return ResourceManager.GetString("Menu_File_OpenResource", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Preview Resource.
         /// </summary>
         internal static string Menu_File_PreviewResource {
@@ -1409,6 +1434,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to No Open Connections.
+        /// </summary>
+        internal static string NoOpenConnections {
+            get {
+                return ResourceManager.GetString("NoOpenConnections", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to The following resources were not copied or moved because they would be overwriting resources currently open: {0}The following resources were not moved because they are currently open: {1}.
         /// </summary>
         internal static string NotCopiedOrMovedDueToOpenEditors {
@@ -1714,6 +1748,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Resource not found.
+        /// </summary>
+        internal static string ResourceNotFound {
+            get {
+                return ResourceManager.GetString("ResourceNotFound", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to This selected resource is not re-pointable.
         /// </summary>
         internal static string ResourceNotRepointable {
Modified: branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx
--- branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx	2012-05-08 13:43:13 UTC (rev 6626)
+++ branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx	2012-05-08 14:12:33 UTC (rev 6627)
@@ -1088,4 +1088,19 @@
   <data name="Menu_Tools_Translate_Desc" xml:space="preserve">
     <value>Translate this Layout</value>
   </data>
+  <data name="InvalidResourceId" xml:space="preserve">
+    <value>Invalid Resource ID</value>
+  </data>
+  <data name="folder_open_document" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\folder-open-document.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="Menu_File_OpenResource" xml:space="preserve">
+    <value>Open Resource</value>
+  </data>
+  <data name="NoOpenConnections" xml:space="preserve">
+    <value>No Open Connections</value>
+  </data>
+  <data name="ResourceNotFound" xml:space="preserve">
+    <value>Resource not found</value>
+  </data>
 </root>
\ No newline at end of file
Copied: branches/maestro-4.0.x/Maestro.Base/Resources/folder-open-document.png (from rev 6510, trunk/Tools/Maestro/Maestro.Base/Resources/folder-open-document.png)
(Binary files differ)
Copied: branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.Designer.cs (from rev 6510, trunk/Tools/Maestro/Maestro.Base/UI/OpenResourceIdDialog.Designer.cs)
--- branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.Designer.cs	                        (rev 0)
+++ branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.Designer.cs	2012-05-08 14:12:33 UTC (rev 6627)
@@ -0,0 +1,158 @@
+namespace Maestro.Base.UI
+    partial class OpenResourceIdDialog
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Windows Form Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            this.label1 = new System.Windows.Forms.Label();
+            this.cmbConnection = new System.Windows.Forms.ComboBox();
+            this.label2 = new System.Windows.Forms.Label();
+            this.txtResourceId = new System.Windows.Forms.TextBox();
+            this.btnOpen = new System.Windows.Forms.Button();
+            this.btnCancel = new System.Windows.Forms.Button();
+            this.lblMessage = new System.Windows.Forms.Label();
+            this.btnBrowse = new System.Windows.Forms.Button();
+            this.SuspendLayout();
+            // label1
+            this.label1.AutoSize = true;
+            this.label1.Location = new System.Drawing.Point(13, 13);
+            this.label1.Name = "label1";
+            this.label1.Size = new System.Drawing.Size(61, 13);
+            this.label1.TabIndex = 0;
+            this.label1.Text = "Connection";
+            // cmbConnection
+            this.cmbConnection.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+                        | System.Windows.Forms.AnchorStyles.Right)));
+            this.cmbConnection.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+            this.cmbConnection.FormattingEnabled = true;
+            this.cmbConnection.Location = new System.Drawing.Point(110, 10);
+            this.cmbConnection.Name = "cmbConnection";
+            this.cmbConnection.Size = new System.Drawing.Size(321, 21);
+            this.cmbConnection.TabIndex = 1;
+            // label2
+            this.label2.AutoSize = true;
+            this.label2.Location = new System.Drawing.Point(12, 40);
+            this.label2.Name = "label2";
+            this.label2.Size = new System.Drawing.Size(67, 13);
+            this.label2.TabIndex = 2;
+            this.label2.Text = "Resource ID";
+            // txtResourceId
+            this.txtResourceId.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+            this.txtResourceId.Location = new System.Drawing.Point(110, 37);
+            this.txtResourceId.Name = "txtResourceId";
+            this.txtResourceId.Size = new System.Drawing.Size(291, 20);
+            this.txtResourceId.TabIndex = 3;
+            // btnOpen
+            this.btnOpen.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+            this.btnOpen.Location = new System.Drawing.Point(275, 68);
+            this.btnOpen.Name = "btnOpen";
+            this.btnOpen.Size = new System.Drawing.Size(75, 23);
+            this.btnOpen.TabIndex = 4;
+            this.btnOpen.Text = "Open";
+            this.btnOpen.UseVisualStyleBackColor = true;
+            this.btnOpen.Click += new System.EventHandler(this.btnOpen_Click);
+            // btnCancel
+            this.btnCancel.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+            this.btnCancel.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+            this.btnCancel.Location = new System.Drawing.Point(356, 68);
+            this.btnCancel.Name = "btnCancel";
+            this.btnCancel.Size = new System.Drawing.Size(75, 23);
+            this.btnCancel.TabIndex = 5;
+            this.btnCancel.Text = "Cancel";
+            this.btnCancel.UseVisualStyleBackColor = true;
+            this.btnCancel.Click += new System.EventHandler(this.btnCancel_Click);
+            // lblMessage
+            this.lblMessage.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+            this.lblMessage.ForeColor = System.Drawing.Color.Red;
+            this.lblMessage.Location = new System.Drawing.Point(13, 73);
+            this.lblMessage.Name = "lblMessage";
+            this.lblMessage.Size = new System.Drawing.Size(256, 18);
+            this.lblMessage.TabIndex = 6;
+            // btnBrowse
+            this.btnBrowse.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+            this.btnBrowse.Location = new System.Drawing.Point(407, 35);
+            this.btnBrowse.Name = "btnBrowse";
+            this.btnBrowse.Size = new System.Drawing.Size(24, 23);
+            this.btnBrowse.TabIndex = 7;
+            this.btnBrowse.Text = "...";
+            this.btnBrowse.UseVisualStyleBackColor = true;
+            this.btnBrowse.Click += new System.EventHandler(this.btnBrowse_Click);
+            // OpenResourceIdDialog
+            this.AcceptButton = this.btnOpen;
+            this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.CancelButton = this.btnCancel;
+            this.ClientSize = new System.Drawing.Size(443, 103);
+            this.ControlBox = false;
+            this.Controls.Add(this.btnBrowse);
+            this.Controls.Add(this.lblMessage);
+            this.Controls.Add(this.btnCancel);
+            this.Controls.Add(this.btnOpen);
+            this.Controls.Add(this.txtResourceId);
+            this.Controls.Add(this.label2);
+            this.Controls.Add(this.cmbConnection);
+            this.Controls.Add(this.label1);
+            this.Name = "OpenResourceIdDialog";
+            this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+            this.Text = "Open Resource";
+            this.ResumeLayout(false);
+            this.PerformLayout();
+        #endregion
+        private System.Windows.Forms.Label label1;
+        private System.Windows.Forms.ComboBox cmbConnection;
+        private System.Windows.Forms.Label label2;
+        private System.Windows.Forms.TextBox txtResourceId;
+        private System.Windows.Forms.Button btnOpen;
+        private System.Windows.Forms.Button btnCancel;
+        private System.Windows.Forms.Label lblMessage;
+        private System.Windows.Forms.Button btnBrowse;
Copied: branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.cs (from rev 6510, trunk/Tools/Maestro/Maestro.Base/UI/OpenResourceIdDialog.cs)
--- branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.cs	                        (rev 0)
+++ branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.cs	2012-05-08 14:12:33 UTC (rev 6627)
@@ -0,0 +1,99 @@
+#endregion
+using System;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using OSGeo.MapGuide.MaestroAPI;
+using System.Collections;
+using Maestro.Editors.Generic;
+    public partial class OpenResourceIdDialog : Form
+        private OpenResourceIdDialog()
+            InitializeComponent();
+        public OpenResourceIdDialog(ServerConnectionManager connMgr)
+            : this()
+            var items = new List<KeyValuePair<string, IServerConnection>>();
+            foreach (var name in connMgr.GetConnectionNames())
+                items.Add(new KeyValuePair<string, IServerConnection>(name, connMgr.GetConnection(name)));
+            cmbConnection.DisplayMember = "Key";
+            cmbConnection.DataSource = items;
+            cmbConnection.SelectedIndex = 0;
+        protected override void OnLoad(EventArgs e)
+            this.ActiveControl = txtResourceId;
+        public IServerConnection SelectedConnection
+            get
+                return ((KeyValuePair<string, IServerConnection>)cmbConnection.SelectedItem).Value;
+        public string SelectedResourceId
+            get { return txtResourceId.Text; }
+        private void btnOpen_Click(object sender, EventArgs e)
+            lblMessage.Text = "";
+            if (ResourceIdentifier.Validate(txtResourceId.Text) && !ResourceIdentifier.IsFolderResource(txtResourceId.Text))
+                this.DialogResult = System.Windows.Forms.DialogResult.OK;
+            else
+                lblMessage.Text = "Resource ID is not valid";
+        private void btnCancel_Click(object sender, EventArgs e)
+            this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+        private void btnBrowse_Click(object sender, EventArgs e)
+            using (var picker = new ResourcePicker(SelectedConnection.ResourceService, ResourcePickerMode.OpenResource))
+                if (picker.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+                    txtResourceId.Text = picker.ResourceID;
Copied: branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.resx (from rev 6510, trunk/Tools/Maestro/Maestro.Base/UI/OpenResourceIdDialog.resx)
--- branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.resx	                        (rev 0)
+++ branches/maestro-4.0.x/Maestro.Base/UI/OpenResourceIdDialog.resx	2012-05-08 14:12:33 UTC (rev 6627)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+</root>
More information about the mapguide-commits mailing list
