[mapguide-commits] r6631 - in trunk/Tools/Maestro: Maestro Maestro.AddIn.ExtendedObjectModels Maestro.AddIn.ExtendedObjectModels/Properties Maestro.AddIn.ExtendedObjectModels/Resources Maestro.AddIn.ExtendedObjectModels/Templates Maestro.Base Maestro.Base/Editor Maestro.Base/Properties Maestro.Base/Resources Maestro.Base/UI Maestro.Base/UI/Preferences Maestro.Shared.UI Maestro.Shared.UI/Properties Maestro.Shared.UI/Resources
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed May 9 08:12:24 EDT 2012
Author: jng
Date: 2012-05-09 05:12:23 -0700 (Wed, 09 May 2012)
New Revision: 6631
Added:
   trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Resources/water.png
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_document.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_drawingsource.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_featuresource.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_fusion.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_layerdefinition.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_mapdefinition.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_printlayout.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_symboldefinition.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_symbolibrary.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_watermark.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_weblayout.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/icon_xmleditor.ico
   trunk/Tools/Maestro/Maestro.Base/Resources/water.png
   trunk/Tools/Maestro/Maestro.Shared.UI/Resources/cross.png
   trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Maestro.AddIn.ExtendedObjectModels.csproj
   trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Properties/Resources.resx
   trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WatermarkDefinition230ItemTemplate.cs
   trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WatermarkDefinition240ItemTemplate.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/SymbolDefinitionEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/WatermarkDefinitionEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs
   trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
   trunk/Tools/Maestro/Maestro.Base/UI/AboutDialog.cs
   trunk/Tools/Maestro/Maestro.Base/UI/AboutDialog.resx
   trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.resx
   trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs
   trunk/Tools/Maestro/Maestro.Shared.UI/IViewContent.cs
   trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj
   trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.resx
   trunk/Tools/Maestro/Maestro.Shared.UI/ViewContentBase.cs
   trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.Designer.cs
   trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs
   trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.resx
   trunk/Tools/Maestro/Maestro/changelog.txt
#1995: More post-DockPanelSuite integration changes
  - Add DockPanelSuite link to about dialog
  - Restore document tab context menu
  - Add support for document tab icons
  - Add document tab icons for all resource editors
  - Update the watermark icon
Modified: trunk/Tools/Maestro/Maestro/changelog.txt
--- trunk/Tools/Maestro/Maestro/changelog.txt	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro/changelog.txt	2012-05-09 12:12:23 UTC (rev 6631)
@@ -16,6 +16,7 @@
  - Http Connection Provider supports a GeoREST url parameter, which allows for feature manipulation support
  - New command to open sources by entering its resource id
  - New shortcut buttons to jump from Layer Definition to Feature/Drawing Source
+ - Fix: Row/Column mismatch in GetTile API (http implemenation)
  - Fix: MgCooker crashes with Map Definitions whose schema version is > 1.0.0
  - Fix: Incorrect RuntimeMapLayer property initialization for tiled maps
  - Fix: AllowOverpost and DisplayAsText properties for basic point style not exposed in editor UI
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Maestro.AddIn.ExtendedObjectModels.csproj
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Maestro.AddIn.ExtendedObjectModels.csproj	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Maestro.AddIn.ExtendedObjectModels.csproj	2012-05-09 12:12:23 UTC (rev 6631)
@@ -92,6 +92,7 @@
     <Content Include="Manifest.addin">
       <CopyToOutputDirectory>Always</CopyToOutputDirectory>
     </Content>
+    <None Include="Resources\water.png" />
     <None Include="Resources\edit.png" />
     <None Include="Resources\marker.png" />
     <None Include="Resources\application-browser.png" />
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Properties/Resources.Designer.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Properties/Resources.Designer.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:4.0.30319.239
+//     Runtime Version:4.0.30319.225
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -99,13 +99,6 @@
-        internal static System.Drawing.Bitmap edit {
-            get {
-                object obj = ResourceManager.GetObject("edit", resourceCulture);
-                return ((System.Drawing.Bitmap)(obj));
         /// <summary>
         ///   Looks up a localized string similar to SQLite Files|*.sqlite;*.db;*.slt;*.sdx.
         /// </summary>
@@ -520,5 +513,12 @@
                 return ResourceManager.GetString("TPL_WL_240_NAME", resourceCulture);
+        internal static System.Drawing.Bitmap water {
+            get {
+                object obj = ResourceManager.GetObject("water", resourceCulture);
+                return ((System.Drawing.Bitmap)(obj));
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Properties/Resources.resx	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Properties/Resources.resx	2012-05-09 12:12:23 UTC (rev 6631)
@@ -112,12 +112,12 @@
     <value>2.0</value>
   </resheader>
   <resheader name="reader">
-    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
   <resheader name="writer">
-    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
-  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="database_share" type="System.Resources.ResXFileRef, System.Windows.Forms">
     <value>..\Resources\database-share.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
   </data>
@@ -223,9 +223,6 @@
   <data name="TPL_WDFC_230_NAME" xml:space="preserve">
     <value>Watermark Definition - Compound (v2.3.0)</value>
   </data>
-  <data name="edit" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\edit.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
-  </data>
   <data name="TPL_WDFS_230_DESC" xml:space="preserve">
     <value>Create a new Watermark Definition using the v2.3.0 schema based on a Simple Symbol Definition</value>
   </data>
@@ -277,4 +274,7 @@
   <data name="TPL_CSD_240_NAME" xml:space="preserve">
     <value>Compound Symbol Definition (v2.4.0)</value>
   </data>
+  <data name="water" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\water.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
 </root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Resources/water.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Resources/water.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WatermarkDefinition230ItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WatermarkDefinition230ItemTemplate.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WatermarkDefinition230ItemTemplate.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -36,7 +36,7 @@
         public WatermarkDefinitionSimple230ItemTemplate()
             Category = Res.TPL_CATEGORY_MGOS23;
-            Icon = Res.edit;
+            Icon = Res.water;
             Description = Res.TPL_WDFS_230_DESC;
             Name = Res.TPL_WDFS_230_NAME;
             ResourceType = ResourceTypes.LayerDefinition.ToString();
@@ -61,7 +61,7 @@
         public WatermarkDefinitionCompound230ItemTemplate()
-            Icon = Res.edit;
+            Icon = Res.water;
             Description = Res.TPL_WDFC_230_DESC;
             Name = Res.TPL_WDFC_230_NAME;
Modified: trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WatermarkDefinition240ItemTemplate.cs
--- trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WatermarkDefinition240ItemTemplate.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.AddIn.ExtendedObjectModels/Templates/WatermarkDefinition240ItemTemplate.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -36,7 +36,7 @@
         public WatermarkDefinitionSimple240ItemTemplate()
             Category = Res.TPL_CATEGORY_MGOS24;
-            Icon = Res.edit;
+            Icon = Res.water;
             Description = Res.TPL_WDFS_240_DESC;
             Name = Res.TPL_WDFS_240_NAME;
@@ -61,7 +61,7 @@
         public WatermarkDefinitionCompound240ItemTemplate()
-            Icon = Res.edit;
+            Icon = Res.water;
             Description = Res.TPL_WDFC_240_DESC;
             Name = Res.TPL_WDFC_240_NAME;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/DrawingSourceEditor.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -59,5 +59,13 @@
             dsEditor.Bind(_edsvc);
+        public override Icon ViewIcon
+            get
+                return Properties.Resources.icon_drawingsource;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -149,6 +149,14 @@
+        public override bool IsExclusiveToDocumentRegion
+            get
+                return true;
         /// <summary>
         /// Performs any pre-save validation on the currently edited resource, by default
         /// this returns the results of a non-cascading <see cref="ResourceValidatorSet"/>
@@ -172,7 +180,7 @@
         private string GetTooltip(string item)
-            return string.Format(Properties.Resources.EditorTitleTemplate, item, Environment.NewLine, this.Resource.CurrentConnection.DisplayName);
+            return string.Format(Properties.Resources.EditorTitleTemplate, item, Environment.NewLine, this.Resource.CurrentConnection.DisplayName, this.Resource.ResourceVersion);
         private void UpdateTitle()
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/FeatureSourceEditor.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -118,5 +118,13 @@
                 return true;
+            get
+                return Properties.Resources.icon_featuresource;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/FusionEditor.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -58,5 +58,13 @@
             flexEditor.Bind(_edsvc);
+            get
+                return Properties.Resources.icon_fusion;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/LayerDefinitionEditor.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -145,5 +145,13 @@
+            get
+                return Properties.Resources.icon_layerdefinition;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/LoadProcedureEditor.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -57,5 +57,13 @@
                 lpEditor.Bind(service);
+            get
+                return Properties.Resources.icon_document;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/MapDefinitionEditor.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -105,5 +105,13 @@
                 return true;
+            get
+                return Properties.Resources.icon_mapdefinition;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/PrintLayoutEditor.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -45,5 +45,13 @@
             printLayoutEditorCtrl.Bind(service);
+            get
+                return Properties.Resources.icon_printlayout;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/SymbolDefinitionEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/SymbolDefinitionEditor.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/SymbolDefinitionEditor.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -56,5 +56,13 @@
                 csymCtrl.Bind(service);
+            get
+                return Properties.Resources.icon_symboldefinition;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/WatermarkDefinitionEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/WatermarkDefinitionEditor.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/WatermarkDefinitionEditor.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -58,5 +58,13 @@
             wmEditorCtrl.Bind(service);
+            get
+                return Properties.Resources.icon_watermark;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/WebLayoutEditor.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -45,5 +45,13 @@
             webLayoutEditorCtrl.Bind(service);
+            get
+                return Properties.Resources.icon_weblayout;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/XmlEditor.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -156,5 +156,13 @@
             editor.FindAndReplace(find, replace);
+            get
+                return Properties.Resources.icon_xmleditor;
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2012-05-09 12:12:23 UTC (rev 6631)
@@ -427,6 +427,19 @@
   </ItemGroup>
   <ItemGroup>
     <Content Include="Maestro.Base.addin" />
+    <None Include="Resources\icon_document.ico" />
+    <None Include="Resources\icon_xmleditor.ico" />
+    <None Include="Resources\icon_weblayout.ico" />
+    <None Include="Resources\icon_watermark.ico" />
+    <None Include="Resources\icon_symbolibrary.ico" />
+    <None Include="Resources\icon_symboldefinition.ico" />
+    <None Include="Resources\icon_printlayout.ico" />
+    <None Include="Resources\icon_mapdefinition.ico" />
+    <None Include="Resources\icon_layerdefinition.ico" />
+    <None Include="Resources\icon_fusion.ico" />
+    <None Include="Resources\icon_featuresource.ico" />
+    <None Include="Resources\icon_drawingsource.ico" />
     <None Include="Resources\folder-open-document.png" />
     <None Include="Resources\edit-diff.png" />
     <None Include="Resources\edit-language.png" />
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -1,7 +1,7 @@
 // <auto-generated>
@@ -663,13 +663,6 @@
-            get {
         internal static System.Drawing.Bitmap edit_diff {
             get {
                 object obj = ResourceManager.GetObject("edit_diff", resourceCulture);
@@ -694,7 +687,7 @@
         /// <summary>
-        ///   Looks up a localized string similar to Resource ID: {0}{1}Connection: {2}.
+        ///   Looks up a localized string similar to Resource ID: {0}{1}Connection: {2}{1}Resource Version: {3}.
         /// </summary>
         internal static string EditorTitleTemplate {
             get {
@@ -894,6 +887,90 @@
+        internal static System.Drawing.Icon icon_document {
+            get {
+                object obj = ResourceManager.GetObject("icon_document", resourceCulture);
+                return ((System.Drawing.Icon)(obj));
+        internal static System.Drawing.Icon icon_drawingsource {
+            get {
+                object obj = ResourceManager.GetObject("icon_drawingsource", resourceCulture);
+        internal static System.Drawing.Icon icon_featuresource {
+            get {
+                object obj = ResourceManager.GetObject("icon_featuresource", resourceCulture);
+        internal static System.Drawing.Icon icon_fusion {
+            get {
+                object obj = ResourceManager.GetObject("icon_fusion", resourceCulture);
+        internal static System.Drawing.Icon icon_layerdefinition {
+            get {
+                object obj = ResourceManager.GetObject("icon_layerdefinition", resourceCulture);
+        internal static System.Drawing.Icon icon_mapdefinition {
+            get {
+                object obj = ResourceManager.GetObject("icon_mapdefinition", resourceCulture);
+        internal static System.Drawing.Icon icon_printlayout {
+            get {
+                object obj = ResourceManager.GetObject("icon_printlayout", resourceCulture);
+        internal static System.Drawing.Icon icon_symboldefinition {
+            get {
+                object obj = ResourceManager.GetObject("icon_symboldefinition", resourceCulture);
+        internal static System.Drawing.Icon icon_symbolibrary {
+            get {
+                object obj = ResourceManager.GetObject("icon_symbolibrary", resourceCulture);
+        internal static System.Drawing.Icon icon_watermark {
+            get {
+                object obj = ResourceManager.GetObject("icon_watermark", resourceCulture);
+        internal static System.Drawing.Icon icon_weblayout {
+            get {
+                object obj = ResourceManager.GetObject("icon_weblayout", resourceCulture);
+        internal static System.Drawing.Icon icon_xmleditor {
+            get {
+                object obj = ResourceManager.GetObject("icon_xmleditor", resourceCulture);
         internal static System.Drawing.Bitmap images_stack {
             get {
                 object obj = ResourceManager.GetObject("images_stack", resourceCulture);
@@ -2775,6 +2852,13 @@
+            get {
         /// <summary>
         ///   Looks up a localized string similar to XML Editor:.
         /// </summary>
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2012-05-09 12:12:23 UTC (rev 6631)
@@ -1016,9 +1016,6 @@
   <data name="marker" type="System.Resources.ResXFileRef, System.Windows.Forms">
     <value>..\Resources\marker.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
   </data>
-  </data>
   <data name="Folder_Data" xml:space="preserve">
     <value>Data</value>
   </data>
@@ -1053,7 +1050,7 @@
     <value>You have already established such a connection</value>
   </data>
   <data name="EditorTitleTemplate" xml:space="preserve">
-    <value>Resource ID: {0}{1}Connection: {2}</value>
+    <value>Resource ID: {0}{1}Connection: {2}{1}Resource Version: {3}</value>
   </data>
   <data name="DwfHandlerAction" xml:space="preserve">
     <value>Create a Drawing Source</value>
@@ -1115,4 +1112,43 @@
   <data name="ResourceNotFound" xml:space="preserve">
     <value>Resource not found</value>
   </data>
+  </data>
+  <data name="icon_drawingsource" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_drawingsource.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="icon_featuresource" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_featuresource.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="icon_fusion" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_fusion.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="icon_layerdefinition" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_layerdefinition.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="icon_mapdefinition" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_mapdefinition.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="icon_printlayout" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_printlayout.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="icon_symboldefinition" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_symboldefinition.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="icon_symbolibrary" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_symbolibrary.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="icon_watermark" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_watermark.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="icon_weblayout" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_weblayout.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="icon_xmleditor" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_xmleditor.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="icon_document" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\icon_document.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
 </root>
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_document.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_document.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_drawingsource.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_drawingsource.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_featuresource.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_featuresource.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_fusion.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_fusion.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_layerdefinition.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_layerdefinition.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_mapdefinition.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_mapdefinition.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_printlayout.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_printlayout.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_symboldefinition.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_symboldefinition.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_symbolibrary.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_symbolibrary.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_watermark.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_watermark.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_weblayout.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_weblayout.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/icon_xmleditor.ico
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/icon_xmleditor.ico
Added: trunk/Tools/Maestro/Maestro.Base/Resources/water.png
Property changes on: trunk/Tools/Maestro/Maestro.Base/Resources/water.png
Modified: trunk/Tools/Maestro/Maestro.Base/UI/AboutDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/AboutDialog.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/UI/AboutDialog.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -55,6 +55,7 @@
         private TabPage licenseTab;
         private TextBox License;
         private TabControl tabControl;
+        private LinkLabel lnkDockPanel;
         private IServerConnection m_connection;
 		private AboutDialog()
@@ -105,18 +106,19 @@
             this.Localization = new System.Windows.Forms.Label();
             this.ServerVersion = new System.Windows.Forms.Label();
             this.thirdPartyTab = new System.Windows.Forms.TabPage();
+            this.lnkAdvTreeView = new System.Windows.Forms.LinkLabel();
+            this.linkLabel1 = new System.Windows.Forms.LinkLabel();
+            this.lnkSharpDevelop = new System.Windows.Forms.LinkLabel();
+            this.colorBrewerlinkLabel = new System.Windows.Forms.LinkLabel();
+            this.ziplibLinkLabel = new System.Windows.Forms.LinkLabel();
+            this.tfnetLinkLabel = new System.Windows.Forms.LinkLabel();
             this.label2 = new System.Windows.Forms.Label();
-            this.tfnetLinkLabel = new System.Windows.Forms.LinkLabel();
-            this.ziplibLinkLabel = new System.Windows.Forms.LinkLabel();
-            this.colorBrewerlinkLabel = new System.Windows.Forms.LinkLabel();
-            this.lnkSharpDevelop = new System.Windows.Forms.LinkLabel();
-            this.linkLabel1 = new System.Windows.Forms.LinkLabel();
-            this.lnkAdvTreeView = new System.Windows.Forms.LinkLabel();
             this.creditsTab = new System.Windows.Forms.TabPage();
             this.Credits = new System.Windows.Forms.TextBox();
             this.licenseTab = new System.Windows.Forms.TabPage();
             this.License = new System.Windows.Forms.TextBox();
             this.tabControl = new System.Windows.Forms.TabControl();
+            this.lnkDockPanel = new System.Windows.Forms.LinkLabel();
             ((System.ComponentModel.ISupportInitialize)(this.pictureBox1)).BeginInit();
             ((System.ComponentModel.ISupportInitialize)(this.PayPalImage)).BeginInit();
             this.thirdPartyTab.SuspendLayout();
@@ -170,6 +172,7 @@
             // thirdPartyTab
             resources.ApplyResources(this.thirdPartyTab, "thirdPartyTab");
+            this.thirdPartyTab.Controls.Add(this.lnkDockPanel);
             this.thirdPartyTab.Controls.Add(this.lnkAdvTreeView);
             this.thirdPartyTab.Controls.Add(this.linkLabel1);
             this.thirdPartyTab.Controls.Add(this.lnkSharpDevelop);
@@ -180,24 +183,27 @@
             this.thirdPartyTab.Name = "thirdPartyTab";
             this.thirdPartyTab.UseVisualStyleBackColor = true;
-            // label2
+            // lnkAdvTreeView
-            resources.ApplyResources(this.label2, "label2");
-            this.label2.Name = "label2";
+            resources.ApplyResources(this.lnkAdvTreeView, "lnkAdvTreeView");
+            this.lnkAdvTreeView.Name = "lnkAdvTreeView";
+            this.lnkAdvTreeView.TabStop = true;
+            this.lnkAdvTreeView.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkAdvTreeView_LinkClicked);
-            // tfnetLinkLabel
+            // linkLabel1
-            resources.ApplyResources(this.tfnetLinkLabel, "tfnetLinkLabel");
-            this.tfnetLinkLabel.Name = "tfnetLinkLabel";
-            this.tfnetLinkLabel.TabStop = true;
-            this.tfnetLinkLabel.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.tfnetLinkLabel_LinkClicked);
+            resources.ApplyResources(this.linkLabel1, "linkLabel1");
+            this.linkLabel1.Name = "linkLabel1";
+            this.linkLabel1.TabStop = true;
+            this.linkLabel1.UseCompatibleTextRendering = true;
+            this.linkLabel1.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkIcons_Clicked);
-            // ziplibLinkLabel
+            // lnkSharpDevelop
-            resources.ApplyResources(this.ziplibLinkLabel, "ziplibLinkLabel");
-            this.ziplibLinkLabel.Name = "ziplibLinkLabel";
-            this.ziplibLinkLabel.TabStop = true;
-            this.ziplibLinkLabel.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.ziplibLinkLabel_LinkClicked);
+            resources.ApplyResources(this.lnkSharpDevelop, "lnkSharpDevelop");
+            this.lnkSharpDevelop.Name = "lnkSharpDevelop";
+            this.lnkSharpDevelop.TabStop = true;
+            this.lnkSharpDevelop.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkSharpDevelop_LinkClicked);
             // colorBrewerlinkLabel
@@ -207,27 +213,24 @@
             this.colorBrewerlinkLabel.UseCompatibleTextRendering = true;
             this.colorBrewerlinkLabel.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkColorBrewer_Clicked);
-            // lnkSharpDevelop
+            // ziplibLinkLabel
-            resources.ApplyResources(this.lnkSharpDevelop, "lnkSharpDevelop");
-            this.lnkSharpDevelop.Name = "lnkSharpDevelop";
-            this.lnkSharpDevelop.TabStop = true;
-            this.lnkSharpDevelop.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkSharpDevelop_LinkClicked);
+            resources.ApplyResources(this.ziplibLinkLabel, "ziplibLinkLabel");
+            this.ziplibLinkLabel.Name = "ziplibLinkLabel";
+            this.ziplibLinkLabel.TabStop = true;
+            this.ziplibLinkLabel.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.ziplibLinkLabel_LinkClicked);
-            // linkLabel1
+            // tfnetLinkLabel
-            resources.ApplyResources(this.linkLabel1, "linkLabel1");
-            this.linkLabel1.Name = "linkLabel1";
-            this.linkLabel1.TabStop = true;
-            this.linkLabel1.UseCompatibleTextRendering = true;
-            this.linkLabel1.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkIcons_Clicked);
+            resources.ApplyResources(this.tfnetLinkLabel, "tfnetLinkLabel");
+            this.tfnetLinkLabel.Name = "tfnetLinkLabel";
+            this.tfnetLinkLabel.TabStop = true;
+            this.tfnetLinkLabel.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.tfnetLinkLabel_LinkClicked);
-            // lnkAdvTreeView
+            // label2
-            resources.ApplyResources(this.lnkAdvTreeView, "lnkAdvTreeView");
-            this.lnkAdvTreeView.Name = "lnkAdvTreeView";
-            this.lnkAdvTreeView.TabStop = true;
-            this.lnkAdvTreeView.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkAdvTreeView_LinkClicked);
+            resources.ApplyResources(this.label2, "label2");
+            this.label2.Name = "label2";
             // creditsTab
@@ -264,6 +267,13 @@
             this.tabControl.Name = "tabControl";
             this.tabControl.SelectedIndex = 0;
+            // lnkDockPanel
+            resources.ApplyResources(this.lnkDockPanel, "lnkDockPanel");
+            this.lnkDockPanel.Name = "lnkDockPanel";
+            this.lnkDockPanel.TabStop = true;
+            this.lnkDockPanel.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkDockPanel_LinkClicked);
             // AboutDialog
             resources.ApplyResources(this, "$this");
@@ -362,7 +372,12 @@
         private void lnkAdvTreeView_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
-            _launcher.OpenUrl("http://www.codeproject.com/KB/tree/treeviewadv.aspx");
+            _launcher.OpenUrl("http://sourceforge.net/projects/treeviewadv/");
+        private void lnkDockPanel_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+            _launcher.OpenUrl("https://github.com/lextm/sharpsnmplib/tree/master/WinFormsUI");
Modified: trunk/Tools/Maestro/Maestro.Base/UI/AboutDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/AboutDialog.resx	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/UI/AboutDialog.resx	2012-05-09 12:12:23 UTC (rev 6631)
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
-  <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
   <data name="pictureBox1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
         iVBORw0KGgoAAAANSUhEUgAAAQAAAAEACAYAAABccqhmAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
@@ -1000,7 +1000,7 @@
   <data name="pictureBox1.Size" type="System.Drawing.Size, System.Drawing">
     <value>256, 256</value>
   </data>
-  <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
   <data name="pictureBox1.TabIndex" type="System.Int32, mscorlib">
     <value>0</value>
   </data>
@@ -1008,7 +1008,7 @@
     <value>pictureBox1</value>
   </data>
   <data name="&gt;&gt;pictureBox1.Type" xml:space="preserve">
-    <value>System.Windows.Forms.PictureBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.PictureBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name="&gt;&gt;pictureBox1.Parent" xml:space="preserve">
     <value>$this</value>
@@ -1032,7 +1032,7 @@
     <value>linkLabel</value>
   </data>
   <data name="&gt;&gt;linkLabel.Type" xml:space="preserve">
-    <value>System.Windows.Forms.LinkLabel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.LinkLabel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name="&gt;&gt;linkLabel.Parent" xml:space="preserve">
@@ -1059,7 +1059,7 @@
     <value>label1</value>
   </data>
   <data name="&gt;&gt;label1.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name="&gt;&gt;label1.Parent" xml:space="preserve">
@@ -1083,7 +1083,7 @@
     <value>Version</value>
   </data>
   <data name="&gt;&gt;Version.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;Version.Parent" xml:space="preserve">
@@ -1091,9 +1091,6 @@
   <data name="&gt;&gt;Version.ZOrder" xml:space="preserve">
     <value>4</value>
   </data>
-  <metadata name="ToolTip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 17</value>
-  </metadata>
   <data name="PayPalImage.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
         R0lGODlhTAAZAIcAAP///whlle3t7QAzaQIBAf6kAv5SBHGYsCMlYqy4xOUCI9fn5xBaYMPJ0QINb9TW
@@ -1132,6 +1129,9 @@
   <data name="PayPalImage.TabIndex" type="System.Int32, mscorlib">
     <value>5</value>
   </data>
+  <metadata name="ToolTip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 17</value>
+  </metadata>
   <data name="PayPalImage.ToolTip" xml:space="preserve">
     <value>Click here to open the donation page</value>
   </data>
@@ -1139,7 +1139,7 @@
     <value>PayPalImage</value>
   </data>
   <data name="&gt;&gt;PayPalImage.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;PayPalImage.Parent" xml:space="preserve">
@@ -1147,9 +1147,6 @@
   <data name="&gt;&gt;PayPalImage.ZOrder" xml:space="preserve">
     <value>3</value>
   </data>
-  </metadata>
   <data name="Localization.Location" type="System.Drawing.Point, System.Drawing">
     <value>16, 64</value>
   </data>
@@ -1166,7 +1163,7 @@
     <value>Localization</value>
   </data>
   <data name="&gt;&gt;Localization.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;Localization.Parent" xml:space="preserve">
@@ -1174,7 +1171,7 @@
   <data name="&gt;&gt;Localization.ZOrder" xml:space="preserve">
     <value>2</value>
   </data>
   <data name="ServerVersion.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
     <value>NoControl</value>
   </data>
@@ -1194,7 +1191,7 @@
     <value>ServerVersion</value>
   </data>
   <data name="&gt;&gt;ServerVersion.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;ServerVersion.Parent" xml:space="preserve">
@@ -1205,173 +1202,155 @@
   <data name="thirdPartyTab.AutoScroll" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
-  <data name="&gt;&gt;lnkAdvTreeView.Name" xml:space="preserve">
-    <value>lnkAdvTreeView</value>
+  <data name="lnkDockPanel.AutoSize" type="System.Boolean, mscorlib">
+    <value>True</value>
   </data>
-  <data name="&gt;&gt;lnkAdvTreeView.Type" xml:space="preserve">
+  <data name="lnkDockPanel.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+    <value>NoControl</value>
   </data>
-  <data name="&gt;&gt;lnkAdvTreeView.Parent" xml:space="preserve">
-    <value>thirdPartyTab</value>
+  <data name="lnkDockPanel.Location" type="System.Drawing.Point, System.Drawing">
+    <value>8, 122</value>
   </data>
-  <data name="&gt;&gt;lnkAdvTreeView.ZOrder" xml:space="preserve">
-    <value>0</value>
+  <data name="lnkDockPanel.Size" type="System.Drawing.Size, System.Drawing">
+    <value>195, 13</value>
   </data>
-  <data name="&gt;&gt;linkLabel1.Name" xml:space="preserve">
-    <value>linkLabel1</value>
+  <data name="lnkDockPanel.TabIndex" type="System.Int32, mscorlib">
+    <value>7</value>
   </data>
-  <data name="&gt;&gt;linkLabel1.Type" xml:space="preserve">
+  <data name="lnkDockPanel.Text" xml:space="preserve">
+    <value>DockPanelSuite (Mono patch by Lex Li)</value>
   </data>
-  <data name="&gt;&gt;linkLabel1.Parent" xml:space="preserve">
+  <data name="&gt;&gt;lnkDockPanel.Name" xml:space="preserve">
+    <value>lnkDockPanel</value>
   </data>
-  <data name="&gt;&gt;linkLabel1.ZOrder" xml:space="preserve">
-    <value>1</value>
+  <data name="&gt;&gt;lnkDockPanel.Type" xml:space="preserve">
   </data>
-  <data name="&gt;&gt;lnkSharpDevelop.Name" xml:space="preserve">
-    <value>lnkSharpDevelop</value>
-  </data>
-  <data name="&gt;&gt;lnkSharpDevelop.Type" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;lnkSharpDevelop.Parent" xml:space="preserve">
+  <data name="&gt;&gt;lnkDockPanel.Parent" xml:space="preserve">
   </data>
-  <data name="&gt;&gt;lnkSharpDevelop.ZOrder" xml:space="preserve">
-    <value>2</value>
+  <data name="&gt;&gt;lnkDockPanel.ZOrder" xml:space="preserve">
+    <value>0</value>
   </data>
-  <data name="&gt;&gt;colorBrewerlinkLabel.Name" xml:space="preserve">
-    <value>colorBrewerlinkLabel</value>
+  <data name="lnkAdvTreeView.AutoSize" type="System.Boolean, mscorlib">
   </data>
-  <data name="&gt;&gt;colorBrewerlinkLabel.Type" xml:space="preserve">
+  <data name="lnkAdvTreeView.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
   </data>
-  <data name="&gt;&gt;colorBrewerlinkLabel.Parent" xml:space="preserve">
+  <data name="lnkAdvTreeView.Location" type="System.Drawing.Point, System.Drawing">
+    <value>8, 98</value>
   </data>
-  <data name="&gt;&gt;colorBrewerlinkLabel.ZOrder" xml:space="preserve">
-    <value>3</value>
+  <data name="lnkAdvTreeView.Size" type="System.Drawing.Size, System.Drawing">
+    <value>104, 13</value>
   </data>
-  <data name="&gt;&gt;ziplibLinkLabel.Name" xml:space="preserve">
-    <value>ziplibLinkLabel</value>
+  <data name="lnkAdvTreeView.TabIndex" type="System.Int32, mscorlib">
+    <value>6</value>
   </data>
-  <data name="&gt;&gt;ziplibLinkLabel.Type" xml:space="preserve">
+  <data name="lnkAdvTreeView.Text" xml:space="preserve">
+    <value>Advanced TreeView</value>
   </data>
-  <data name="&gt;&gt;ziplibLinkLabel.Parent" xml:space="preserve">
+  <data name="&gt;&gt;lnkAdvTreeView.Name" xml:space="preserve">
+    <value>lnkAdvTreeView</value>
   </data>
-  <data name="&gt;&gt;ziplibLinkLabel.ZOrder" xml:space="preserve">
-    <value>4</value>
+  <data name="&gt;&gt;lnkAdvTreeView.Type" xml:space="preserve">
   </data>
-  <data name="&gt;&gt;tfnetLinkLabel.Name" xml:space="preserve">
-    <value>tfnetLinkLabel</value>
-  </data>
-  <data name="&gt;&gt;tfnetLinkLabel.Type" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;tfnetLinkLabel.Parent" xml:space="preserve">
+  <data name="&gt;&gt;lnkAdvTreeView.Parent" xml:space="preserve">
   </data>
-  <data name="&gt;&gt;tfnetLinkLabel.ZOrder" xml:space="preserve">
-    <value>5</value>
+  <data name="&gt;&gt;lnkAdvTreeView.ZOrder" xml:space="preserve">
+    <value>1</value>
   </data>
-  <data name="&gt;&gt;label2.Name" xml:space="preserve">
-    <value>label2</value>
+  <data name="linkLabel1.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
   </data>
-  <data name="&gt;&gt;label2.Type" xml:space="preserve">
+  <data name="linkLabel1.LinkArea" type="System.Windows.Forms.LinkArea, System.Windows.Forms">
+    <value>55, 29</value>
   </data>
-  <data name="&gt;&gt;label2.Parent" xml:space="preserve">
+  <data name="linkLabel1.Location" type="System.Drawing.Point, System.Drawing">
+    <value>8, 147</value>
   </data>
-  <data name="&gt;&gt;label2.ZOrder" xml:space="preserve">
-    <value>6</value>
+  <data name="linkLabel1.Size" type="System.Drawing.Size, System.Drawing">
+    <value>304, 45</value>
   </data>
-  <data name="thirdPartyTab.Location" type="System.Drawing.Point, System.Drawing">
-    <value>4, 22</value>
+  <data name="linkLabel1.TabIndex" type="System.Int32, mscorlib">
+    <value>5</value>
   </data>
-  <data name="thirdPartyTab.Size" type="System.Drawing.Size, System.Drawing">
-    <value>320, 185</value>
+  <data name="linkLabel1.Text" xml:space="preserve">
+    <value>This product uses icons produced by Yusuke Kamiyamane (http://p.yusukekamiyamane.com) licensed under Creative Commons 3.0</value>
   </data>
-  <data name="thirdPartyTab.TabIndex" type="System.Int32, mscorlib">
-    <value>2</value>
+  <data name="&gt;&gt;linkLabel1.Name" xml:space="preserve">
+    <value>linkLabel1</value>
   </data>
-  <data name="thirdPartyTab.Text" xml:space="preserve">
-    <value>Thirdparty</value>
+  <data name="&gt;&gt;linkLabel1.Type" xml:space="preserve">
   </data>
-  <data name="&gt;&gt;thirdPartyTab.Name" xml:space="preserve">
+  <data name="&gt;&gt;linkLabel1.Parent" xml:space="preserve">
   </data>
-  <data name="&gt;&gt;thirdPartyTab.Type" xml:space="preserve">
-    <value>System.Windows.Forms.TabPage, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
-  </data>
-  <data name="&gt;&gt;thirdPartyTab.Parent" xml:space="preserve">
-    <value>tabControl</value>
-  </data>
-  <data name="&gt;&gt;thirdPartyTab.ZOrder" xml:space="preserve">
+  <data name="&gt;&gt;linkLabel1.ZOrder" xml:space="preserve">
     <value>2</value>
   </data>
-  <data name="label2.AutoSize" type="System.Boolean, mscorlib">
+  <data name="lnkSharpDevelop.AutoSize" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
-  <data name="label2.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+  <data name="lnkSharpDevelop.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
   </data>
-  <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
-    <value>8, 8</value>
+  <data name="lnkSharpDevelop.Location" type="System.Drawing.Point, System.Drawing">
+    <value>8, 30</value>
   </data>
-  <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
-    <value>239, 13</value>
+  <data name="lnkSharpDevelop.Size" type="System.Drawing.Size, System.Drawing">
+    <value>78, 13</value>
   </data>
-  <data name="label2.TabIndex" type="System.Int32, mscorlib">
-    <value>0</value>
+  <data name="lnkSharpDevelop.TabIndex" type="System.Int32, mscorlib">
+    <value>4</value>
   </data>
-  <data name="label2.Text" xml:space="preserve">
-    <value>This program uses the following thirdparty libraries</value>
+  <data name="lnkSharpDevelop.Text" xml:space="preserve">
+    <value>Sharp Develop</value>
   </data>
+  <data name="&gt;&gt;lnkSharpDevelop.Name" xml:space="preserve">
+    <value>lnkSharpDevelop</value>
   </data>
+  <data name="&gt;&gt;lnkSharpDevelop.Type" xml:space="preserve">
   </data>
+  <data name="&gt;&gt;lnkSharpDevelop.Parent" xml:space="preserve">
   </data>
-    <value>6</value>
+  <data name="&gt;&gt;lnkSharpDevelop.ZOrder" xml:space="preserve">
+    <value>3</value>
   </data>
-  <data name="tfnetLinkLabel.AutoSize" type="System.Boolean, mscorlib">
-    <value>True</value>
-  </data>
-  <data name="tfnetLinkLabel.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+  <data name="colorBrewerlinkLabel.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
   </data>
-  <data name="tfnetLinkLabel.Location" type="System.Drawing.Point, System.Drawing">
-    <value>8, 52</value>
+  <data name="colorBrewerlinkLabel.LinkArea" type="System.Windows.Forms.LinkArea, System.Windows.Forms">
+    <value>84, 23</value>
   </data>
-  <data name="tfnetLinkLabel.Size" type="System.Drawing.Size, System.Drawing">
-    <value>99, 13</value>
+  <data name="colorBrewerlinkLabel.Location" type="System.Drawing.Point, System.Drawing">
+    <value>11, 172</value>
   </data>
-  <data name="tfnetLinkLabel.TabIndex" type="System.Int32, mscorlib">
-    <value>1</value>
+  <data name="colorBrewerlinkLabel.Size" type="System.Drawing.Size, System.Drawing">
+    <value>304, 32</value>
   </data>
-  <data name="tfnetLinkLabel.Text" xml:space="preserve">
-    <value>.net Topology Suite</value>
+  <data name="colorBrewerlinkLabel.TabIndex" type="System.Int32, mscorlib">
+    <value>3</value>
   </data>
+  <data name="colorBrewerlinkLabel.Text" xml:space="preserve">
+    <value>This product includes color specifications and designs developed by Cynthia Brewer (http://colorbrewer.org/).</value>
   </data>
+  <data name="&gt;&gt;colorBrewerlinkLabel.Name" xml:space="preserve">
+    <value>colorBrewerlinkLabel</value>
   </data>
+  <data name="&gt;&gt;colorBrewerlinkLabel.Type" xml:space="preserve">
+  </data>
+  <data name="&gt;&gt;colorBrewerlinkLabel.Parent" xml:space="preserve">
   </data>
-    <value>5</value>
+  <data name="&gt;&gt;colorBrewerlinkLabel.ZOrder" xml:space="preserve">
+    <value>4</value>
   </data>
   <data name="ziplibLinkLabel.AutoSize" type="System.Boolean, mscorlib">
     <value>True</value>
@@ -1395,134 +1374,98 @@
   </data>
   </data>
   </data>
-    <value>4</value>
+    <value>5</value>
   </data>
-  <data name="colorBrewerlinkLabel.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+  <data name="tfnetLinkLabel.AutoSize" type="System.Boolean, mscorlib">
+  </data>
+  <data name="tfnetLinkLabel.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
   </data>
-  <data name="colorBrewerlinkLabel.LinkArea" type="System.Windows.Forms.LinkArea, System.Windows.Forms">
-    <value>84, 23</value>
+  <data name="tfnetLinkLabel.Location" type="System.Drawing.Point, System.Drawing">
+    <value>8, 52</value>
   </data>
-  <data name="colorBrewerlinkLabel.Location" type="System.Drawing.Point, System.Drawing">
-    <value>11, 172</value>
+  <data name="tfnetLinkLabel.Size" type="System.Drawing.Size, System.Drawing">
+    <value>99, 13</value>
   </data>
-  <data name="colorBrewerlinkLabel.Size" type="System.Drawing.Size, System.Drawing">
-    <value>304, 32</value>
+  <data name="tfnetLinkLabel.TabIndex" type="System.Int32, mscorlib">
+    <value>1</value>
   </data>
-  <data name="colorBrewerlinkLabel.TabIndex" type="System.Int32, mscorlib">
-    <value>3</value>
+  <data name="tfnetLinkLabel.Text" xml:space="preserve">
+    <value>.net Topology Suite</value>
   </data>
-  <data name="colorBrewerlinkLabel.Text" xml:space="preserve">
-    <value>This product includes color specifications and designs developed by Cynthia Brewer (http://colorbrewer.org/).</value>
+  <data name="&gt;&gt;tfnetLinkLabel.Name" xml:space="preserve">
+    <value>tfnetLinkLabel</value>
   </data>
+  <data name="&gt;&gt;tfnetLinkLabel.Type" xml:space="preserve">
   </data>
-  </data>
+  <data name="&gt;&gt;tfnetLinkLabel.Parent" xml:space="preserve">
   </data>
-    <value>3</value>
+  <data name="&gt;&gt;tfnetLinkLabel.ZOrder" xml:space="preserve">
+    <value>6</value>
   </data>
-  <data name="lnkSharpDevelop.AutoSize" type="System.Boolean, mscorlib">
+  <data name="label2.AutoSize" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
-  <data name="lnkSharpDevelop.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+  <data name="label2.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
   </data>
-  <data name="lnkSharpDevelop.Location" type="System.Drawing.Point, System.Drawing">
-    <value>8, 30</value>
+  <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
+    <value>8, 8</value>
   </data>
-  <data name="lnkSharpDevelop.Size" type="System.Drawing.Size, System.Drawing">
-    <value>78, 13</value>
+  <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+    <value>239, 13</value>
   </data>
-  <data name="lnkSharpDevelop.TabIndex" type="System.Int32, mscorlib">
-    <value>4</value>
+  <data name="label2.TabIndex" type="System.Int32, mscorlib">
+    <value>0</value>
   </data>
-  <data name="lnkSharpDevelop.Text" xml:space="preserve">
-    <value>Sharp Develop</value>
+  <data name="label2.Text" xml:space="preserve">
+    <value>This program uses the following thirdparty libraries</value>
   </data>
+  <data name="&gt;&gt;label2.Name" xml:space="preserve">
+    <value>label2</value>
   </data>
+  <data name="&gt;&gt;label2.Type" xml:space="preserve">
   </data>
+  <data name="&gt;&gt;label2.Parent" xml:space="preserve">
   </data>
-    <value>2</value>
+  <data name="&gt;&gt;label2.ZOrder" xml:space="preserve">
+    <value>7</value>
   </data>
-  <data name="linkLabel1.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
-    <value>NoControl</value>
+  <data name="thirdPartyTab.Location" type="System.Drawing.Point, System.Drawing">
+    <value>4, 22</value>
   </data>
-  <data name="linkLabel1.LinkArea" type="System.Windows.Forms.LinkArea, System.Windows.Forms">
-    <value>55, 29</value>
+  <data name="thirdPartyTab.Size" type="System.Drawing.Size, System.Drawing">
+    <value>320, 185</value>
   </data>
-  <data name="linkLabel1.Location" type="System.Drawing.Point, System.Drawing">
-    <value>11, 127</value>
+  <data name="thirdPartyTab.TabIndex" type="System.Int32, mscorlib">
+    <value>2</value>
   </data>
-  <data name="linkLabel1.Size" type="System.Drawing.Size, System.Drawing">
-    <value>304, 45</value>
+  <data name="thirdPartyTab.Text" xml:space="preserve">
+    <value>Thirdparty</value>
   </data>
-  <data name="linkLabel1.TabIndex" type="System.Int32, mscorlib">
-    <value>5</value>
-  </data>
-  <data name="linkLabel1.Text" xml:space="preserve">
-    <value>This product uses icons produced by Yusuke Kamiyamane (http://p.yusukekamiyamane.com) licensed under Creative Commons 3.0</value>
-  </data>
-  </data>
-  </data>
+  <data name="&gt;&gt;thirdPartyTab.Name" xml:space="preserve">
   </data>
-    <value>1</value>
+  <data name="&gt;&gt;thirdPartyTab.Type" xml:space="preserve">
+    <value>System.Windows.Forms.TabPage, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
-  <data name="lnkAdvTreeView.AutoSize" type="System.Boolean, mscorlib">
+  <data name="&gt;&gt;thirdPartyTab.Parent" xml:space="preserve">
+    <value>tabControl</value>
   </data>
-  <data name="lnkAdvTreeView.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
+  <data name="&gt;&gt;thirdPartyTab.ZOrder" xml:space="preserve">
+    <value>2</value>
   </data>
-  <data name="lnkAdvTreeView.Location" type="System.Drawing.Point, System.Drawing">
-    <value>8, 98</value>
-  </data>
-  <data name="lnkAdvTreeView.Size" type="System.Drawing.Size, System.Drawing">
-    <value>104, 13</value>
-  </data>
-  <data name="lnkAdvTreeView.TabIndex" type="System.Int32, mscorlib">
-    <value>6</value>
-  </data>
-  <data name="lnkAdvTreeView.Text" xml:space="preserve">
-    <value>Advanced TreeView</value>
-  </data>
-  </data>
-  </data>
-  </data>
-    <value>0</value>
-  </data>
   <data name="Credits.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
     <value>Fill</value>
   </data>
@@ -1545,7 +1488,7 @@
     <value>Credits</value>
   </data>
   <data name="&gt;&gt;Credits.Type" xml:space="preserve">
-    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name="&gt;&gt;Credits.Parent" xml:space="preserve">
     <value>creditsTab</value>
@@ -1569,7 +1512,7 @@
   </data>
   <data name="&gt;&gt;creditsTab.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;creditsTab.Parent" xml:space="preserve">
@@ -1577,42 +1520,6 @@
   <data name="&gt;&gt;creditsTab.ZOrder" xml:space="preserve">
     <value>1</value>
   </data>
-  <data name="&gt;&gt;License.Name" xml:space="preserve">
-    <value>License</value>
-  </data>
-  <data name="&gt;&gt;License.Type" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;License.Parent" xml:space="preserve">
-    <value>licenseTab</value>
-  </data>
-  <data name="&gt;&gt;License.ZOrder" xml:space="preserve">
-    <value>0</value>
-  </data>
-  <data name="licenseTab.Location" type="System.Drawing.Point, System.Drawing">
-  </data>
-  <data name="licenseTab.Size" type="System.Drawing.Size, System.Drawing">
-  </data>
-  <data name="licenseTab.TabIndex" type="System.Int32, mscorlib">
-    <value>0</value>
-  </data>
-  <data name="licenseTab.Text" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;licenseTab.Name" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;licenseTab.Type" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;licenseTab.Parent" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;licenseTab.ZOrder" xml:space="preserve">
-    <value>0</value>
-  </data>
   <data name="License.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
     <value>Fill</value>
   </data>
@@ -1655,7 +1562,7 @@
   </data>
   </data>
@@ -1663,6 +1570,30 @@
     <value>0</value>
   </data>
+  <data name="licenseTab.Location" type="System.Drawing.Point, System.Drawing">
+  </data>
+  <data name="licenseTab.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="licenseTab.TabIndex" type="System.Int32, mscorlib">
+    <value>0</value>
+  </data>
+  <data name="licenseTab.Text" xml:space="preserve">
+    <value>License</value>
+  </data>
+  <data name="&gt;&gt;licenseTab.Name" xml:space="preserve">
+    <value>licenseTab</value>
+  </data>
+  <data name="&gt;&gt;licenseTab.Type" xml:space="preserve">
+  </data>
+  <data name="&gt;&gt;licenseTab.Parent" xml:space="preserve">
+  </data>
+  <data name="&gt;&gt;licenseTab.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
   <data name="tabControl.Location" type="System.Drawing.Point, System.Drawing">
     <value>16, 80</value>
   </data>
@@ -1676,7 +1607,7 @@
   </data>
   <data name="&gt;&gt;tabControl.Type" xml:space="preserve">
-    <value>System.Windows.Forms.TabControl, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.TabControl, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name="&gt;&gt;tabControl.Parent" xml:space="preserve">
@@ -1684,7 +1615,7 @@
   <data name="&gt;&gt;tabControl.ZOrder" xml:space="preserve">
     <value>1</value>
   </data>
-  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
     <value>True</value>
   </metadata>
   <data name="$this.AutoScaleBaseSize" type="System.Drawing.Size, System.Drawing">
@@ -1703,12 +1634,12 @@
     <value>ToolTip</value>
   </data>
   <data name="&gt;&gt;ToolTip.Type" xml:space="preserve">
-    <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.ToolTip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name="&gt;&gt;$this.Name" xml:space="preserve">
     <value>AboutDialog</value>
   </data>
   <data name="&gt;&gt;$this.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
 </root>
Modified: trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.Designer.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.Designer.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -40,6 +40,9 @@
             this.chkOutbound = new System.Windows.Forms.CheckBox();
             this.chkMessages = new System.Windows.Forms.CheckBox();
             this.groupBox2 = new System.Windows.Forms.GroupBox();
+            this.label7 = new System.Windows.Forms.Label();
+            this.btnBrowseRtMapInspector = new System.Windows.Forms.Button();
+            this.txtRtMapInspector = new System.Windows.Forms.TextBox();
             this.btnBrowseFsPreview = new System.Windows.Forms.Button();
             this.txtFsPreview = new System.Windows.Forms.TextBox();
             this.btnBrowseMgCooker = new System.Windows.Forms.Button();
@@ -51,9 +54,6 @@
             this.cmbOpenedColor = new Maestro.Editors.Common.ColorComboBox();
             this.label6 = new System.Windows.Forms.Label();
             this.label5 = new System.Windows.Forms.Label();
-            this.btnBrowseRtMapInspector = new System.Windows.Forms.Button();
-            this.txtRtMapInspector = new System.Windows.Forms.TextBox();
-            this.label7 = new System.Windows.Forms.Label();
             this.groupBox1.SuspendLayout();
             this.groupBox2.SuspendLayout();
             this.groupBox3.SuspendLayout();
@@ -138,6 +138,24 @@
             this.groupBox2.Name = "groupBox2";
             this.groupBox2.TabStop = false;
+            // label7
+            resources.ApplyResources(this.label7, "label7");
+            this.label7.Name = "label7";
+            // btnBrowseRtMapInspector
+            resources.ApplyResources(this.btnBrowseRtMapInspector, "btnBrowseRtMapInspector");
+            this.btnBrowseRtMapInspector.Name = "btnBrowseRtMapInspector";
+            this.btnBrowseRtMapInspector.UseVisualStyleBackColor = true;
+            this.btnBrowseRtMapInspector.Click += new System.EventHandler(this.btnBrowseRtMapInspector_Click);
+            // txtRtMapInspector
+            resources.ApplyResources(this.txtRtMapInspector, "txtRtMapInspector");
+            this.txtRtMapInspector.Name = "txtRtMapInspector";
+            this.txtRtMapInspector.ReadOnly = true;
             // btnBrowseFsPreview
             resources.ApplyResources(this.btnBrowseFsPreview, "btnBrowseFsPreview");
@@ -206,24 +224,6 @@
             resources.ApplyResources(this.label5, "label5");
             this.label5.Name = "label5";
-            // btnBrowseRtMapInspector
-            resources.ApplyResources(this.btnBrowseRtMapInspector, "btnBrowseRtMapInspector");
-            this.btnBrowseRtMapInspector.Name = "btnBrowseRtMapInspector";
-            this.btnBrowseRtMapInspector.UseVisualStyleBackColor = true;
-            this.btnBrowseRtMapInspector.Click += new System.EventHandler(this.btnBrowseRtMapInspector_Click);
-            // txtRtMapInspector
-            resources.ApplyResources(this.txtRtMapInspector, "txtRtMapInspector");
-            this.txtRtMapInspector.Name = "txtRtMapInspector";
-            this.txtRtMapInspector.ReadOnly = true;
-            // label7
-            resources.ApplyResources(this.label7, "label7");
-            this.label7.Name = "label7";
             // GeneralPreferencesCtrl
             this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
Modified: trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.resx	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.resx	2012-05-09 12:12:23 UTC (rev 6631)
@@ -112,16 +112,16 @@
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
   <data name="label1.AutoSize" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
   <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
     <value>13, 14</value>
   </data>
@@ -138,7 +138,7 @@
   </data>
   </data>
@@ -165,7 +165,7 @@
     <value>rdAjax</value>
   </data>
   <data name="&gt;&gt;rdAjax.Type" xml:space="preserve">
-    <value>System.Windows.Forms.RadioButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.RadioButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name="&gt;&gt;rdAjax.Parent" xml:space="preserve">
@@ -195,7 +195,7 @@
     <value>rdFusion</value>
   </data>
   <data name="&gt;&gt;rdFusion.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;rdFusion.Parent" xml:space="preserve">
@@ -222,7 +222,7 @@
   </data>
   </data>
@@ -230,7 +230,7 @@
     <value>5</value>
   </data>
   <data name="txtTemplatePath.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
     <value>Top, Left, Right</value>
   </data>
@@ -247,7 +247,7 @@
     <value>txtTemplatePath</value>
   </data>
   <data name="&gt;&gt;txtTemplatePath.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;txtTemplatePath.Parent" xml:space="preserve">
@@ -274,7 +274,7 @@
     <value>btnBrowseTemplatePath</value>
   </data>
   <data name="&gt;&gt;btnBrowseTemplatePath.Type" xml:space="preserve">
-    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
   <data name="&gt;&gt;btnBrowseTemplatePath.Parent" xml:space="preserve">
@@ -285,66 +285,6 @@
   <data name="groupBox1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
-  <data name="&gt;&gt;chkShowTipOfTheDay.Name" xml:space="preserve">
-    <value>chkShowTipOfTheDay</value>
-  </data>
-  <data name="&gt;&gt;chkShowTipOfTheDay.Type" xml:space="preserve">
-    <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
-  </data>
-  <data name="&gt;&gt;chkShowTipOfTheDay.Parent" xml:space="preserve">
-    <value>groupBox1</value>
-  </data>
-  <data name="&gt;&gt;chkShowTipOfTheDay.ZOrder" xml:space="preserve">
-    <value>0</value>
-  </data>
-  <data name="&gt;&gt;chkOutbound.Name" xml:space="preserve">
-    <value>chkOutbound</value>
-  </data>
-  <data name="&gt;&gt;chkOutbound.Type" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;chkOutbound.Parent" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;chkOutbound.ZOrder" xml:space="preserve">
-    <value>1</value>
-  </data>
-  <data name="&gt;&gt;chkMessages.Name" xml:space="preserve">
-    <value>chkMessages</value>
-  </data>
-  <data name="&gt;&gt;chkMessages.Type" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;chkMessages.Parent" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;chkMessages.ZOrder" xml:space="preserve">
-    <value>2</value>
-  </data>
-  <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
-    <value>16, 93</value>
-  </data>
-  <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
-    <value>426, 50</value>
-  </data>
-  <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
-    <value>6</value>
-  </data>
-  <data name="groupBox1.Text" xml:space="preserve">
-    <value>Show on Startup</value>
-  </data>
-  <data name="&gt;&gt;groupBox1.Name" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;groupBox1.Type" xml:space="preserve">
-    <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
-  </data>
-  <data name="&gt;&gt;groupBox1.Parent" xml:space="preserve">
-    <value>$this</value>
-  </data>
-  <data name="&gt;&gt;groupBox1.ZOrder" xml:space="preserve">
-    <value>2</value>
-  </data>
   <data name="chkShowTipOfTheDay.AutoSize" type="System.Boolean, mscorlib">
     <value>True</value>
   </data>
@@ -364,7 +304,7 @@
   </data>
+    <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
@@ -391,7 +331,7 @@
   </data>
   </data>
@@ -418,7 +358,7 @@
   </data>
   </data>
@@ -426,6 +366,30 @@
     <value>2</value>
   </data>
+  <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
+    <value>16, 93</value>
+  </data>
+  <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
+    <value>426, 50</value>
+  </data>
+  <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
+    <value>6</value>
+  </data>
+  <data name="groupBox1.Text" xml:space="preserve">
+    <value>Show on Startup</value>
+  </data>
+  <data name="&gt;&gt;groupBox1.Name" xml:space="preserve">
+    <value>groupBox1</value>
+  </data>
+  <data name="&gt;&gt;groupBox1.Type" xml:space="preserve">
+    <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;groupBox1.Parent" xml:space="preserve">
+    <value>$this</value>
+  </data>
+  <data name="&gt;&gt;groupBox1.ZOrder" xml:space="preserve">
+    <value>2</value>
+  </data>
   <data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
@@ -448,7 +412,7 @@
     <value>label7</value>
   </data>
   <data name="&gt;&gt;label7.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;label7.Parent" xml:space="preserve">
     <value>groupBox2</value>
@@ -478,7 +442,7 @@
     <value>btnBrowseRtMapInspector</value>
   </data>
   <data name="&gt;&gt;btnBrowseRtMapInspector.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;btnBrowseRtMapInspector.Parent" xml:space="preserve">
@@ -502,7 +466,7 @@
     <value>txtRtMapInspector</value>
   </data>
   <data name="&gt;&gt;txtRtMapInspector.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;txtRtMapInspector.Parent" xml:space="preserve">
@@ -529,7 +493,7 @@
     <value>btnBrowseFsPreview</value>
   </data>
   <data name="&gt;&gt;btnBrowseFsPreview.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;btnBrowseFsPreview.Parent" xml:space="preserve">
@@ -553,7 +517,7 @@
     <value>txtFsPreview</value>
   </data>
   <data name="&gt;&gt;txtFsPreview.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;txtFsPreview.Parent" xml:space="preserve">
@@ -580,7 +544,7 @@
     <value>btnBrowseMgCooker</value>
   </data>
   <data name="&gt;&gt;btnBrowseMgCooker.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;btnBrowseMgCooker.Parent" xml:space="preserve">
@@ -607,7 +571,7 @@
     <value>label4</value>
   </data>
   <data name="&gt;&gt;label4.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;label4.Parent" xml:space="preserve">
@@ -631,7 +595,7 @@
     <value>txtMgCooker</value>
   </data>
   <data name="&gt;&gt;txtMgCooker.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;txtMgCooker.Parent" xml:space="preserve">
@@ -658,7 +622,7 @@
     <value>label3</value>
   </data>
   <data name="&gt;&gt;label3.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;label3.Parent" xml:space="preserve">
@@ -682,7 +646,7 @@
   </data>
   <data name="&gt;&gt;groupBox2.Type" xml:space="preserve">
   </data>
   <data name="&gt;&gt;groupBox2.Parent" xml:space="preserve">
@@ -693,78 +657,6 @@
   <data name="groupBox3.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
-  <data name="&gt;&gt;cmbModifiedColor.Name" xml:space="preserve">
-    <value>cmbModifiedColor</value>
-  </data>
-  <data name="&gt;&gt;cmbModifiedColor.Type" xml:space="preserve">
-    <value>Maestro.Editors.Common.ColorComboBox, Maestro.Editors, Version=4.0.0.6359, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
-  </data>
-  <data name="&gt;&gt;cmbModifiedColor.Parent" xml:space="preserve">
-    <value>groupBox3</value>
-  </data>
-  <data name="&gt;&gt;cmbModifiedColor.ZOrder" xml:space="preserve">
-    <value>0</value>
-  </data>
-  <data name="&gt;&gt;cmbOpenedColor.Name" xml:space="preserve">
-    <value>cmbOpenedColor</value>
-  </data>
-  <data name="&gt;&gt;cmbOpenedColor.Type" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;cmbOpenedColor.Parent" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;cmbOpenedColor.ZOrder" xml:space="preserve">
-    <value>1</value>
-  </data>
-  <data name="&gt;&gt;label6.Name" xml:space="preserve">
-    <value>label6</value>
-  </data>
-  <data name="&gt;&gt;label6.Type" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;label6.Parent" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;label6.ZOrder" xml:space="preserve">
-    <value>2</value>
-  </data>
-  <data name="&gt;&gt;label5.Name" xml:space="preserve">
-    <value>label5</value>
-  </data>
-  <data name="&gt;&gt;label5.Type" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;label5.Parent" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;label5.ZOrder" xml:space="preserve">
-    <value>3</value>
-  </data>
-  <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
-    <value>16, 149</value>
-  </data>
-  <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
-    <value>426, 90</value>
-  </data>
-  <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
-    <value>8</value>
-  </data>
-  <data name="groupBox3.Text" xml:space="preserve">
-    <value>Site Explorer</value>
-  </data>
-  <data name="&gt;&gt;groupBox3.Name" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;groupBox3.Type" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;groupBox3.Parent" xml:space="preserve">
-  </data>
-  <data name="&gt;&gt;groupBox3.ZOrder" xml:space="preserve">
-    <value>0</value>
-  </data>
   <data name="cmbModifiedColor.Location" type="System.Drawing.Point, System.Drawing">
     <value>187, 49</value>
   </data>
@@ -778,7 +670,7 @@
   </data>
+    <value>Maestro.Editors.Common.ColorComboBox, Maestro.Editors, Version=5.0.0.6514, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
   </data>
@@ -799,7 +691,7 @@
   </data>
   </data>
@@ -826,7 +718,7 @@
   </data>
   </data>
@@ -853,7 +745,7 @@
   </data>
   </data>
@@ -861,7 +753,31 @@
     <value>3</value>
   </data>
+  <data name="groupBox3.Location" type="System.Drawing.Point, System.Drawing">
+    <value>16, 149</value>
+  </data>
+  <data name="groupBox3.Size" type="System.Drawing.Size, System.Drawing">
+    <value>426, 90</value>
+  </data>
+  <data name="groupBox3.TabIndex" type="System.Int32, mscorlib">
+    <value>8</value>
+  </data>
+  <data name="groupBox3.Text" xml:space="preserve">
+    <value>Site Explorer</value>
+  </data>
+  <data name="&gt;&gt;groupBox3.Name" xml:space="preserve">
+    <value>groupBox3</value>
+  </data>
+  <data name="&gt;&gt;groupBox3.Type" xml:space="preserve">
+  </data>
+  <data name="&gt;&gt;groupBox3.Parent" xml:space="preserve">
+  </data>
+  <data name="&gt;&gt;groupBox3.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
     <value>True</value>
   </metadata>
   <data name="$this.Size" type="System.Drawing.Size, System.Drawing">
@@ -871,6 +787,6 @@
     <value>GeneralPreferencesCtrl</value>
   </data>
-    <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Windows.Forms.UserControl, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Base/UI/RepositoryTreeModel.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -93,7 +93,7 @@
                         this.Icon = Properties.Resources.marker;
                         break;
                     case ResourceTypes.WatermarkDefinition:
-                        this.Icon = Properties.Resources.edit;
+                        this.Icon = Properties.Resources.water;
                         break;
                     default:
                         this.Icon = Properties.Resources.document;
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/IViewContent.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/IViewContent.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/IViewContent.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -126,9 +126,24 @@
         /// </summary>
         bool IsAttached { get; }
         /// <summary>
+        /// Gets whether this view resides in a modal window. Only applies if the <see cref="DefaultRegion"/>
+        /// is Floating
+        /// </summary>
+        bool IsModalWindow { get; }
+        /// <summary>
+        /// Gets whether this view is set exclusively to the document region. If true, this view will always
+        /// be placed into the document region regardless of the regions specified in the <see cref="DefaultRegion"/>
+        /// property
+        /// </summary>
+        bool IsExclusiveToDocumentRegion { get; }
+        /// <summary>
         /// Indicates the default region this view content will be put in
         /// </summary>
         ViewRegion DefaultRegion { get; }
+        /// <summary>
+        /// Gets the icon for this view
+        /// </summary>
+        Icon ViewIcon { get; }
     /// <summary>
@@ -137,28 +152,28 @@
     public enum ViewRegion
         /// <summary>
+        /// The view content will reside in a floating dialog
+        /// </summary>
+        Floating = 1,
+        /// <summary>
         /// The view content will be docked to the left
         /// </summary>
-        Left,
+        Left = 2,
         /// <summary>
         /// The view content will be docked to the right
         /// </summary>
-        Right,
+        Right = 4,
         /// <summary>
+        /// The view content will be docked to the top
+        /// </summary>
+        Top = 8,
+        /// <summary>
         /// The view content will be docked to the bottom
         /// </summary>
-        Bottom,
+        Bottom = 16,
         /// <summary>
         /// The view content will be docked to the center, (in a tabbed document interface)
         /// </summary>
-        Document,
-        /// <summary>
-        /// The view content will reside in a floating dialog
-        /// </summary>
-        Floating,
-        /// <summary>
-        /// The view content will reside in a modal dialog
-        /// </summary>
-        Dialog
+        Document = 32
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj
--- trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj	2012-05-09 12:12:23 UTC (rev 6631)
@@ -189,6 +189,9 @@
       <Name>WinFormsUI</Name>
     </ProjectReference>
   </ItemGroup>
+  <ItemGroup>
+    <None Include="Resources\cross.png" />
+  </ItemGroup>
   <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
   <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
        Other similar extension points exist, see Microsoft.Common.targets.
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.Designer.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.Designer.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:4.0.30319.239
+//     Runtime Version:4.0.30319.225
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -74,6 +74,13 @@
+        internal static System.Drawing.Bitmap cross {
+            get {
+                object obj = ResourceManager.GetObject("cross", resourceCulture);
+                return ((System.Drawing.Bitmap)(obj));
         /// <summary>
         ///   Looks up a localized string similar to The specified view content type is not registered in any addin files: {0}.
         /// </summary>
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.resx	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/Properties/Resources.resx	2012-05-09 12:12:23 UTC (rev 6631)
@@ -112,34 +112,37 @@
     <value>2.0</value>
   </resheader>
   <resheader name="reader">
-    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
   <resheader name="writer">
-    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
-  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
-  <data name="plus-white" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\plus-white.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="chevron" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\chevron.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
   </data>
-  <data name="minus-white" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\minus-white.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
-  </data>
   <data name="chevron-expand" type="System.Resources.ResXFileRef, System.Windows.Forms">
     <value>..\Resources\chevron-expand.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
   </data>
-  <data name="chevron" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\chevron.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
-  </data>
-  <data name="ErrorLogTemplate" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\ErrorLogTemplate.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
-  </data>
   <data name="FileSaved" xml:space="preserve">
     <value>File saved</value>
   </data>
   <data name="Error_ViewContent_Not_Registered" xml:space="preserve">
     <value>The specified view content type is not registered in any addin files: {0}</value>
   </data>
+  <data name="ErrorLogTemplate" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\ErrorLogTemplate.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+  </data>
+  <data name="plus-white" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\plus-white.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
+  <data name="minus-white" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\minus-white.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
   <data name="Error_ViewContent_Type_Not_Singleton" xml:space="preserve">
     <value>The specified view content type is not a singleton: {0}</value>
   </data>
+  <data name="cross" type="System.Resources.ResXFileRef, System.Windows.Forms">
+    <value>..\Resources\cross.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  </data>
 </root>
Added: trunk/Tools/Maestro/Maestro.Shared.UI/Resources/cross.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.Shared.UI/Resources/cross.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/ViewContentBase.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/ViewContentBase.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/ViewContentBase.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -41,6 +41,10 @@
             InitializeComponent();
+        public virtual bool IsModalWindow { get { return false; } }
+        public virtual bool IsExclusiveToDocumentRegion { get { return false; } }
         private string _title;
         /// <summary>
@@ -274,6 +278,14 @@
             get { return ViewRegion.Document; }
+        /// <summary>
+        /// </summary>
+        public virtual Icon ViewIcon
+            get { return null; }
         /// <summary>
         /// Fired when the view has been closed internally
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.Designer.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.Designer.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.Designer.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -28,20 +28,59 @@
         /// </summary>
         private void InitializeComponent()
+            this.components = new System.ComponentModel.Container();
             System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(WorkbenchBase));
+            this.documentTabContextMenu = new System.Windows.Forms.ContextMenuStrip(this.components);
+            this.closeToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+            this.closeAllToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+            this.closeAllButThisToolStripMenuItem = new System.Windows.Forms.ToolStripMenuItem();
+            this.documentTabContextMenu.SuspendLayout();
             this.SuspendLayout();
-            // Workbench
+            // documentTabContextMenu
+            this.documentTabContextMenu.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+            this.closeToolStripMenuItem,
+            this.closeAllToolStripMenuItem,
+            this.closeAllButThisToolStripMenuItem});
+            this.documentTabContextMenu.Name = "documentTabContextMenu";
+            resources.ApplyResources(this.documentTabContextMenu, "documentTabContextMenu");
+            // closeToolStripMenuItem
+            resources.ApplyResources(this.closeToolStripMenuItem, "closeToolStripMenuItem");
+            this.closeToolStripMenuItem.Name = "closeToolStripMenuItem";
+            this.closeToolStripMenuItem.Click += new System.EventHandler(this.closeToolStripMenuItem_Click);
+            // closeAllToolStripMenuItem
+            resources.ApplyResources(this.closeAllToolStripMenuItem, "closeAllToolStripMenuItem");
+            this.closeAllToolStripMenuItem.Name = "closeAllToolStripMenuItem";
+            this.closeAllToolStripMenuItem.Click += new System.EventHandler(this.closeAllToolStripMenuItem_Click);
+            // closeAllButThisToolStripMenuItem
+            resources.ApplyResources(this.closeAllButThisToolStripMenuItem, "closeAllButThisToolStripMenuItem");
+            this.closeAllButThisToolStripMenuItem.Name = "closeAllButThisToolStripMenuItem";
+            this.closeAllButThisToolStripMenuItem.Click += new System.EventHandler(this.closeAllButThisToolStripMenuItem_Click);
+            // WorkbenchBase
-            this.Name = "Workbench";
+            this.Name = "WorkbenchBase";
             this.WindowState = System.Windows.Forms.FormWindowState.Maximized;
+            this.documentTabContextMenu.ResumeLayout(false);
             this.ResumeLayout(false);
         #endregion
+        private System.Windows.Forms.ContextMenuStrip documentTabContextMenu;
+        private System.Windows.Forms.ToolStripMenuItem closeToolStripMenuItem;
+        private System.Windows.Forms.ToolStripMenuItem closeAllToolStripMenuItem;
+        private System.Windows.Forms.ToolStripMenuItem closeAllButThisToolStripMenuItem;
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs	2012-05-09 12:12:23 UTC (rev 6631)
@@ -57,6 +57,7 @@
             //contentPanel.ViewActivated += new ViewContentActivateEventHandler(OnViewActivated);
             contentPanel = new DockPanel();
             contentPanel.DocumentStyle = DocumentStyle.DockingWindow;
+            contentPanel.ShowDocumentIcon = true;
             contentPanel.Dock = DockStyle.Fill;
             contentPanel.DockLeftPortion = 250;
             contentPanel.DockBottomPortion = 150;
@@ -253,41 +254,43 @@
             DockContent content = new DockContent();
             content.TabText = vc.Title;
             content.Text = vc.Title;
-            content.ToolTipText = vc.Title;
+            content.ToolTipText = vc.Description;
             content.CloseButton = vc.AllowUserClose;
+            content.CloseButtonVisible = vc.AllowUserClose;
             content.Tag = vc;
+            var icon = vc.ViewIcon;
+            if (icon != null)
+                content.Icon = icon;
+                content.ShowIcon = true;
-            switch (vc.DefaultRegion)
+            if (vc.IsExclusiveToDocumentRegion)
-                case ViewRegion.Bottom:
-                    content.DockAreas = DockAreas.DockBottom;
-                    break;
-                case ViewRegion.Left:
-                    content.DockAreas = DockAreas.DockLeft;
-                    break;
-                case ViewRegion.Right:
-                    content.DockAreas = DockAreas.DockRight;
-                    break;
-                case ViewRegion.Document:
-                    content.DockAreas = DockAreas.Document;
-                    break;
-                case ViewRegion.Floating:
-                    content.DockAreas = DockAreas.Float;
-                    break;
+                content.DockAreas = DockAreas.Document;
+            else
+                content.DockAreas = (DockAreas)(vc.DefaultRegion);
             vc.SetParentForm(content);
             vc.TitleChanged += (sender, e) =>
+            vc.DescriptionChanged += (sender, e) =>
+            if (vc.AllowUserClose && vc.IsExclusiveToDocumentRegion)
+                content.TabPageContextMenuStrip = documentTabContextMenu;
             content.ClientSize = vc.ContentControl.Size;
             vc.ContentControl.Dock = DockStyle.Fill;
             content.Controls.Add(vc.ContentControl);
-            if (vc.DefaultRegion == ViewRegion.Dialog)
+            if (vc.IsModalWindow && vc.DefaultRegion == ViewRegion.Floating)
                 content.StartPosition = FormStartPosition.CenterParent;
                 content.ShowDialog();
@@ -305,6 +308,55 @@
             // you might want to update the status less frequently.
             _workbenchInitializer.UpdateMenuItemStatus(menu, _toolstrips.Values);
+        private void closeToolStripMenuItem_Click(object sender, EventArgs e)
+            var doc = contentPanel.ActiveDocument as DockContent;
+            if (doc != null)
+                var view = doc.Tag as IViewContent;
+                view.Close();
+        private void closeAllToolStripMenuItem_Click(object sender, EventArgs e)
+            var closeMe = new List<IViewContent>();
+            foreach (var doc in contentPanel.Documents)
+                var cnt = doc as DockContent;
+                if (cnt != null)
+                    var view = cnt.Tag as IViewContent;
+                    if (view != null)
+                        closeMe.Add(view);
+            foreach (var view in closeMe)
+                view.Close();
+        private void closeAllButThisToolStripMenuItem_Click(object sender, EventArgs e)
+                if (doc == contentPanel.ActiveDocument)
+                    continue;
+                if (cnt != null)
+                    if (view != null)
+                view.Close();
     /// <summary>
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.resx
--- trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.resx	2012-05-09 11:37:07 UTC (rev 6630)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.resx	2012-05-09 12:12:23 UTC (rev 6631)
@@ -112,22 +112,109 @@
     <value>2.0</value>
   </resheader>
   </resheader>
   </resheader>
+  <metadata name="documentTabContextMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+  </metadata>
+  <data name="closeToolStripMenuItem.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABfUlEQVQ4T6WTu0vDUBTGz1+g
+        VBtB1KBgdSsUNFvHQoZChw4upWoRupYO7a6giw66KCj4wgciuAiKg5M4XcFBUHAVBxdXcfD4fTGJqaZT
+        hx+353yPezNUVFU6oaMwL/YKDkXkCJyIuMDw5LzvE6cx87eAIaPNpvIEbqTA0z5qtVBrKfCN5qvR0Id8
+        Xj/rdcXOAJYQ81apeNpLqRRovy/YxXOAuwPje7Wq146jr+WyciaPhYK3u8vlvB29zISfwAGCbEHYhOG5
+        WNSLdFpvs1m9ymR027L02LaVGj30xhbAIBswrMN4nkrpXiLhcZBMKnfU6PlXsIjlElgBqzCtwXyGW08R
+        DuCOGj30MhN+QlCw/GMwlwjGQY2edgUUzA3CAZzb7NyWF8zjOcDcIxzAeQG3kTiNmfATbAxTMNYRekIJ
+        T87D2JM4jZmwAL8HwdiEyNw0wpMis5hHwRAYACOOyAw1ejCPMxMt6MKiF/T79OHsAd2AWgJYET3JfVjQ
+        yd/5G8s+qAWdGU8YAAAAAElFTkSuQmCC
+</value>
+  </data>
+  <data name="closeToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+    <value>166, 22</value>
+  </data>
+  <data name="closeToolStripMenuItem.Text" xml:space="preserve">
+    <value>Close</value>
+  </data>
+  <data name="closeAllToolStripMenuItem.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="closeAllToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="closeAllToolStripMenuItem.Text" xml:space="preserve">
+    <value>Close All</value>
+  </data>
+  <data name="closeAllButThisToolStripMenuItem.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="closeAllButThisToolStripMenuItem.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="closeAllButThisToolStripMenuItem.Text" xml:space="preserve">
+    <value>Close All But This</value>
+  </data>
+  <data name="documentTabContextMenu.Size" type="System.Drawing.Size, System.Drawing">
+    <value>167, 92</value>
+  </data>
+  <data name="&gt;&gt;documentTabContextMenu.Name" xml:space="preserve">
+    <value>documentTabContextMenu</value>
+  </data>
+  <data name="&gt;&gt;documentTabContextMenu.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ContextMenuStrip, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
     <value>True</value>
   </metadata>
   <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
     <value>792, 566</value>
   </data>
+  <data name="&gt;&gt;closeToolStripMenuItem.Name" xml:space="preserve">
+    <value>closeToolStripMenuItem</value>
+  </data>
+  <data name="&gt;&gt;closeToolStripMenuItem.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ToolStripMenuItem, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;closeAllToolStripMenuItem.Name" xml:space="preserve">
+    <value>closeAllToolStripMenuItem</value>
+  </data>
+  <data name="&gt;&gt;closeAllToolStripMenuItem.Type" xml:space="preserve">
+  </data>
+  <data name="&gt;&gt;closeAllButThisToolStripMenuItem.Name" xml:space="preserve">
+    <value>closeAllButThisToolStripMenuItem</value>
+  </data>
+  <data name="&gt;&gt;closeAllButThisToolStripMenuItem.Type" xml:space="preserve">
+  </data>
-    <value>Workbench</value>
+    <value>WorkbenchBase</value>
   </data>
   </data>
 </root>
More information about the mapguide-commits mailing list
