[mapguide-commits] r6633 - in branches/maestro-4.0.x: Maestro Maestro.Editors/MapDefinition
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed May 9 08:39:10 EDT 2012
Author: jng
Date: 2012-05-09 05:39:10 -0700 (Wed, 09 May 2012)
New Revision: 6633
   branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs
   branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
   branches/maestro-4.0.x/Maestro/changelog.txt
Backport #1973
Modified: branches/maestro-4.0.x/Maestro/changelog.txt
--- branches/maestro-4.0.x/Maestro/changelog.txt	2012-05-09 12:31:20 UTC (rev 6632)
+++ branches/maestro-4.0.x/Maestro/changelog.txt	2012-05-09 12:39:10 UTC (rev 6633)
@@ -3,6 +3,8 @@
  - Uses new mg-desktop release (8 May 2012, .net 2.0, VC9)
  - New command to open sources by entering its resource id
  - New shortcut buttons to jump from Layer Definition to Feature/Drawing Source
+ - Fix: Groups/Layer info in Map Definition editor not updating via up/down keypress
+ - Fix: Row/Column mismatch in GetTile API (http implemenation)
  - Fix: AllowOverpost and DisplayAsText properties for basic point style not exposed in editor UI
  - Fix: Incorrect RuntimeMapLayer property initialization for tiled maps
  - Fix: Incorrect serialization of Map Extents
Modified: branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs
--- branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs	2012-05-09 12:31:20 UTC (rev 6632)
+++ branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs	2012-05-09 12:39:10 UTC (rev 6633)
@@ -121,12 +121,12 @@
             this.trvLayersGroup.NodeControls.Add(this.NODE_GROUP_ICON);
             this.trvLayersGroup.NodeControls.Add(this.NODE_GROUP_TEXT);
             this.trvLayersGroup.SelectedNode = null;
-            this.trvLayersGroup.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvLayersGroup_MouseDoubleClick);
+            this.trvLayersGroup.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvLayersGroup_ItemDrag);
+            this.trvLayersGroup.DragDrop += new System.Windows.Forms.DragEventHandler(this.trvLayersGroup_DragDrop);
+            this.trvLayersGroup.DragEnter += new System.Windows.Forms.DragEventHandler(this.trvLayersGroup_DragEnter);
             this.trvLayersGroup.DragOver += new System.Windows.Forms.DragEventHandler(this.trvLayersGroup_DragOver);
             this.trvLayersGroup.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvLayersGroup_MouseClick);
-            this.trvLayersGroup.DragDrop += new System.Windows.Forms.DragEventHandler(this.trvLayersGroup_DragDrop);
-            this.trvLayersGroup.DragEnter += new System.Windows.Forms.DragEventHandler(this.trvLayersGroup_DragEnter);
-            this.trvLayersGroup.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvLayersGroup_ItemDrag);
+            this.trvLayersGroup.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvLayersGroup_MouseDoubleClick);
             // NODE_GROUP_ICON
@@ -251,12 +251,12 @@
             this.trvLayerDrawingOrder.NodeControls.Add(this.NODE_DRAW_ICON);
             this.trvLayerDrawingOrder.NodeControls.Add(this.NODE_DRAW_TEXT);
             this.trvLayerDrawingOrder.SelectedNode = null;
-            this.trvLayerDrawingOrder.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvLayerDrawingOrder_MouseDoubleClick);
+            this.trvLayerDrawingOrder.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvLayerDrawingOrder_ItemDrag);
+            this.trvLayerDrawingOrder.DragDrop += new System.Windows.Forms.DragEventHandler(this.trvLayerDrawingOrder_DragDrop);
+            this.trvLayerDrawingOrder.DragEnter += new System.Windows.Forms.DragEventHandler(this.trvLayerDrawingOrder_DragEnter);
             this.trvLayerDrawingOrder.DragOver += new System.Windows.Forms.DragEventHandler(this.trvLayerDrawingOrder_DragOver);
             this.trvLayerDrawingOrder.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvLayerDrawingOrder_MouseClick);
-            this.trvLayerDrawingOrder.DragDrop += new System.Windows.Forms.DragEventHandler(this.trvLayerDrawingOrder_DragDrop);
-            this.trvLayerDrawingOrder.DragEnter += new System.Windows.Forms.DragEventHandler(this.trvLayerDrawingOrder_DragEnter);
-            this.trvLayerDrawingOrder.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvLayerDrawingOrder_ItemDrag);
+            this.trvLayerDrawingOrder.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvLayerDrawingOrder_MouseDoubleClick);
             // NODE_DRAW_ICON
@@ -366,12 +366,12 @@
             this.trvBaseLayers.NodeControls.Add(this.nodeIcon1);
             this.trvBaseLayers.NodeControls.Add(this.nodeTextBox1);
             this.trvBaseLayers.SelectedNode = null;
-            this.trvBaseLayers.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvBaseLayers_MouseDoubleClick);
+            this.trvBaseLayers.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvBaseLayers_ItemDrag);
+            this.trvBaseLayers.DragDrop += new System.Windows.Forms.DragEventHandler(this.trvBaseLayers_DragDrop);
+            this.trvBaseLayers.DragEnter += new System.Windows.Forms.DragEventHandler(this.trvBaseLayers_DragEnter);
             this.trvBaseLayers.DragOver += new System.Windows.Forms.DragEventHandler(this.trvBaseLayers_DragOver);
             this.trvBaseLayers.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvBaseLayers_MouseClick);
-            this.trvBaseLayers.DragDrop += new System.Windows.Forms.DragEventHandler(this.trvBaseLayers_DragDrop);
-            this.trvBaseLayers.DragEnter += new System.Windows.Forms.DragEventHandler(this.trvBaseLayers_DragEnter);
-            this.trvBaseLayers.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvBaseLayers_ItemDrag);
+            this.trvBaseLayers.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvBaseLayers_MouseDoubleClick);
             // nodeIcon1
Modified: branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2012-05-09 12:31:20 UTC (rev 6632)
+++ branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2012-05-09 12:39:10 UTC (rev 6633)
@@ -53,46 +53,81 @@
         void trvLayersGroup_KeyUp(object sender, KeyEventArgs e)
-            if (e.KeyCode == Keys.Delete)
+            if (e.KeyCode == Keys.Delete || e.KeyCode == Keys.Up || e.KeyCode == Keys.Down)
                 var group = GetSelectedLayerGroupItem() as GroupItem;
                 var layer = GetSelectedLayerGroupItem() as LayerItem;
-                if (layer != null)
+                if (e.KeyCode == Keys.Delete)
-                    RemoveSelectedLayerGroupItem(layer);
+                    if (layer != null)
+                        RemoveSelectedLayerGroupItem(layer);
+                    else if (group != null)
+                        RemoveSelectedLayerGroupItem(group);
-                else if (group != null)
+                else
-                    RemoveSelectedLayerGroupItem(group);
+                        OnDynamicLayerItemSelected(layer);
+                        OnDynamicGroupItemSelected(group);
         void trvLayerDrawingOrder_KeyUp(object sender, KeyEventArgs e)
                 var layer = GetSelectedDrawOrderItem() as LayerItem;
                 if (layer != null)
-                    RemoveSelectedDrawOrderLayerItem(layer);
+                        RemoveSelectedDrawOrderLayerItem(layer);
+                    else
+                        OnDrawOrderLayerItemSelected(layer);
         void trvBaseLayers_KeyUp(object sender, KeyEventArgs e)
                 var group = GetSelectedTiledLayerItem() as BaseLayerGroupItem;
                 var layer = GetSelectedTiledLayerItem() as BaseLayerItem;
-                if (group != null)
-                    RemoveSelectedTiledLayerItem(group);
+                    if (group != null)
+                        RemoveSelectedTiledLayerItem(group);
+                    else if (layer != null)
+                        RemoveSelectedTiledLayerItem(layer);
-                else if (layer != null)
+                else
-                    RemoveSelectedTiledLayerItem(layer);
+                        OnBaseLayerItemSelected(layer);
+                        OnBaseLayerGroupItemSelected(group);
More information about the mapguide-commits mailing list
