[mapguide-commits] r6637 - in branches/maestro-4.0.x: Maestro.Base/Commands Maestro.Base/Editor Maestro.Base/Properties Maestro.Editors Maestro.Editors/MapDefinition Maestro.Editors/Properties Maestro.Editors/SymbolDefinition
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed May 9 10:53:28 EDT 2012
Author: jng
Date: 2012-05-09 07:53:28 -0700 (Wed, 09 May 2012)
New Revision: 6637
   branches/maestro-4.0.x/Maestro.Base/Commands/MgCookerCommand.cs
   branches/maestro-4.0.x/Maestro.Base/Editor/ResourceEditorService.cs
   branches/maestro-4.0.x/Maestro.Base/Properties/Resources.Designer.cs
   branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx
   branches/maestro-4.0.x/Maestro.Editors/IEditorService.cs
   branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs
   branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
   branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx
   branches/maestro-4.0.x/Maestro.Editors/Properties/Resources.Designer.cs
   branches/maestro-4.0.x/Maestro.Editors/Properties/Resources.resx
   branches/maestro-4.0.x/Maestro.Editors/ResourceEditorServiceBase.cs
   branches/maestro-4.0.x/Maestro.Editors/SymbolDefinition/SymbolEditorService.cs
#1992: Add a button to convert base layer groups to regular groups. Layers in this converted group are put into the bottom of the draw order
#1993: Add the missing MgCooker shortcut in the Map Definition editor. Unfortunately this will still require a login prompt (because we don't store username/password and MgCooker is not yet capable of initializing from a session yet), but after login here MgCooker will correctly show the current Map Definition.
Modified: branches/maestro-4.0.x/Maestro.Base/Commands/MgCookerCommand.cs
--- branches/maestro-4.0.x/Maestro.Base/Commands/MgCookerCommand.cs	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Base/Commands/MgCookerCommand.cs	2012-05-09 14:53:28 UTC (rev 6637)
@@ -32,6 +32,11 @@
         public override void Run()
+            RunCooker();
+        internal static void RunCooker(params string [] args)
             string exe = PropertyService.Get(ConfigProperties.MgCookerPath, "");
             if (!File.Exists(exe))
@@ -50,6 +55,7 @@
             var procInfo = new ProcessStartInfo(exe);
             procInfo.WorkingDirectory = Path.GetDirectoryName(exe);
+            procInfo.Arguments = string.Join(" ", args);
             var proc = Process.Start(procInfo);
Modified: branches/maestro-4.0.x/Maestro.Base/Editor/ResourceEditorService.cs
--- branches/maestro-4.0.x/Maestro.Base/Editor/ResourceEditorService.cs	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Base/Editor/ResourceEditorService.cs	2012-05-09 14:53:28 UTC (rev 6637)
@@ -79,5 +79,18 @@
             _orm.Open(resourceId, _conn, false, _siteExp);
+        public override void RunProcess(string processName, params string[] args)
+            //HACK: Yeah yeah
+            if (processName.ToLower() == "mgcooker")
+                Maestro.Base.Commands.MgCookerCommand.RunCooker(args);
+            else
+                throw new ApplicationException(string.Format(Properties.Resources.ErrorUnknownExecutable, processName));
Modified: branches/maestro-4.0.x/Maestro.Base/Properties/Resources.Designer.cs
--- branches/maestro-4.0.x/Maestro.Base/Properties/Resources.Designer.cs	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Base/Properties/Resources.Designer.cs	2012-05-09 14:53:28 UTC (rev 6637)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:2.0.50727.5448
+//     Runtime Version:2.0.50727.5420
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -518,11 +518,12 @@
         ///  Andrew DeMerchant
         ///  Gabriele Monfardini
         ///  Gordon Luckett
+        ///  Hans Milling
         ///Many thanks to the following people who have translated Maestro into other languages:
         ///  José Manuel Cerrejón González (Spanish)
-        ///  Pierre Cardina [rest of string was truncated]&quot;;.
+        /// [rest of string was truncated]&quot;;.
         /// </summary>
         internal static string Contributors {
             get {
@@ -740,6 +741,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Unknown executable specified: {0}.
+        /// </summary>
+        internal static string ErrorUnknownExecutable {
+            get {
+                return ResourceManager.GetString("ErrorUnknownExecutable", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Autodesk DWF (*.dwf)|*.dwf.
         /// </summary>
         internal static string Filter_Dwf_Files {
Modified: branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx
--- branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Base/Properties/Resources.resx	2012-05-09 14:53:28 UTC (rev 6637)
@@ -1103,4 +1103,7 @@
   <data name="ResourceNotFound" xml:space="preserve">
     <value>Resource not found</value>
   </data>
+  <data name="ErrorUnknownExecutable" xml:space="preserve">
+    <value>Unknown executable specified: {0}</value>
+  </data>
 </root>
\ No newline at end of file
Modified: branches/maestro-4.0.x/Maestro.Editors/IEditorService.cs
--- branches/maestro-4.0.x/Maestro.Editors/IEditorService.cs	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Editors/IEditorService.cs	2012-05-09 14:53:28 UTC (rev 6637)
@@ -245,5 +245,12 @@
         /// <param name="name"></param>
         /// <returns></returns>
         object GetCustomProperty(string name);
+        /// <summary>
+        /// Invokes the specified process name with the specified arguments
+        /// </summary>
+        /// <param name="processName"></param>
+        /// <param name="args"></param>
+        void RunProcess(string processName, params string[] args);
Modified: branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs
--- branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs	2012-05-09 14:53:28 UTC (rev 6637)
@@ -71,6 +71,9 @@
             this.toolStripSeparator4 = new System.Windows.Forms.ToolStripSeparator();
             this.btnMoveBaseLayerUp = new System.Windows.Forms.ToolStripButton();
             this.btnMoveBaseLayerDown = new System.Windows.Forms.ToolStripButton();
+            this.toolStripSeparator8 = new System.Windows.Forms.ToolStripSeparator();
+            this.btnBaseLayerGroupToRegular = new System.Windows.Forms.ToolStripButton();
+            this.btnInvokeMgCooker = new System.Windows.Forms.ToolStripButton();
             this.splitter1 = new System.Windows.Forms.Splitter();
             this.propertiesPanel = new System.Windows.Forms.Panel();
             this.contentPanel.SuspendLayout();
@@ -121,12 +124,12 @@
             this.trvLayersGroup.NodeControls.Add(this.NODE_GROUP_ICON);
             this.trvLayersGroup.NodeControls.Add(this.NODE_GROUP_TEXT);
             this.trvLayersGroup.SelectedNode = null;
-            this.trvLayersGroup.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvLayersGroup_ItemDrag);
+            this.trvLayersGroup.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvLayersGroup_MouseDoubleClick);
+            this.trvLayersGroup.DragOver += new System.Windows.Forms.DragEventHandler(this.trvLayersGroup_DragOver);
+            this.trvLayersGroup.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvLayersGroup_MouseClick);
             this.trvLayersGroup.DragDrop += new System.Windows.Forms.DragEventHandler(this.trvLayersGroup_DragDrop);
             this.trvLayersGroup.DragEnter += new System.Windows.Forms.DragEventHandler(this.trvLayersGroup_DragEnter);
-            this.trvLayersGroup.DragOver += new System.Windows.Forms.DragEventHandler(this.trvLayersGroup_DragOver);
-            this.trvLayersGroup.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvLayersGroup_MouseClick);
-            this.trvLayersGroup.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvLayersGroup_MouseDoubleClick);
+            this.trvLayersGroup.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvLayersGroup_ItemDrag);
             // NODE_GROUP_ICON
@@ -251,12 +254,12 @@
             this.trvLayerDrawingOrder.NodeControls.Add(this.NODE_DRAW_ICON);
             this.trvLayerDrawingOrder.NodeControls.Add(this.NODE_DRAW_TEXT);
             this.trvLayerDrawingOrder.SelectedNode = null;
-            this.trvLayerDrawingOrder.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvLayerDrawingOrder_ItemDrag);
+            this.trvLayerDrawingOrder.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvLayerDrawingOrder_MouseDoubleClick);
+            this.trvLayerDrawingOrder.DragOver += new System.Windows.Forms.DragEventHandler(this.trvLayerDrawingOrder_DragOver);
+            this.trvLayerDrawingOrder.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvLayerDrawingOrder_MouseClick);
             this.trvLayerDrawingOrder.DragDrop += new System.Windows.Forms.DragEventHandler(this.trvLayerDrawingOrder_DragDrop);
             this.trvLayerDrawingOrder.DragEnter += new System.Windows.Forms.DragEventHandler(this.trvLayerDrawingOrder_DragEnter);
-            this.trvLayerDrawingOrder.DragOver += new System.Windows.Forms.DragEventHandler(this.trvLayerDrawingOrder_DragOver);
-            this.trvLayerDrawingOrder.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvLayerDrawingOrder_MouseClick);
-            this.trvLayerDrawingOrder.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvLayerDrawingOrder_MouseDoubleClick);
+            this.trvLayerDrawingOrder.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvLayerDrawingOrder_ItemDrag);
             // NODE_DRAW_ICON
@@ -366,12 +369,12 @@
             this.trvBaseLayers.NodeControls.Add(this.nodeIcon1);
             this.trvBaseLayers.NodeControls.Add(this.nodeTextBox1);
             this.trvBaseLayers.SelectedNode = null;
-            this.trvBaseLayers.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvBaseLayers_ItemDrag);
+            this.trvBaseLayers.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvBaseLayers_MouseDoubleClick);
+            this.trvBaseLayers.DragOver += new System.Windows.Forms.DragEventHandler(this.trvBaseLayers_DragOver);
+            this.trvBaseLayers.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvBaseLayers_MouseClick);
             this.trvBaseLayers.DragDrop += new System.Windows.Forms.DragEventHandler(this.trvBaseLayers_DragDrop);
             this.trvBaseLayers.DragEnter += new System.Windows.Forms.DragEventHandler(this.trvBaseLayers_DragEnter);
-            this.trvBaseLayers.DragOver += new System.Windows.Forms.DragEventHandler(this.trvBaseLayers_DragOver);
-            this.trvBaseLayers.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvBaseLayers_MouseClick);
-            this.trvBaseLayers.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvBaseLayers_MouseDoubleClick);
+            this.trvBaseLayers.ItemDrag += new System.Windows.Forms.ItemDragEventHandler(this.trvBaseLayers_ItemDrag);
             // nodeIcon1
@@ -397,7 +400,10 @@
             this.btnRemoveBaseLayer,
             this.toolStripSeparator4,
             this.btnMoveBaseLayerUp,
-            this.btnMoveBaseLayerDown});
+            this.btnMoveBaseLayerDown,
+            this.toolStripSeparator8,
+            this.btnBaseLayerGroupToRegular,
+            this.btnInvokeMgCooker});
             resources.ApplyResources(this.toolStrip3, "toolStrip3");
             this.toolStrip3.Name = "toolStrip3";
@@ -459,6 +465,26 @@
             this.btnMoveBaseLayerDown.Name = "btnMoveBaseLayerDown";
             this.btnMoveBaseLayerDown.Click += new System.EventHandler(this.btnMoveBaseLayerDown_Click);
+            // toolStripSeparator8
+            this.toolStripSeparator8.Name = "toolStripSeparator8";
+            resources.ApplyResources(this.toolStripSeparator8, "toolStripSeparator8");
+            // btnBaseLayerGroupToRegular
+            this.btnBaseLayerGroupToRegular.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+            resources.ApplyResources(this.btnBaseLayerGroupToRegular, "btnBaseLayerGroupToRegular");
+            this.btnBaseLayerGroupToRegular.Image = global::Maestro.Editors.Properties.Resources.arrow_curve_180_left;
+            this.btnBaseLayerGroupToRegular.Name = "btnBaseLayerGroupToRegular";
+            this.btnBaseLayerGroupToRegular.Click += new System.EventHandler(this.btnBaseGroupToRegular_Click);
+            // btnInvokeMgCooker
+            this.btnInvokeMgCooker.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+            resources.ApplyResources(this.btnInvokeMgCooker, "btnInvokeMgCooker");
+            this.btnInvokeMgCooker.Name = "btnInvokeMgCooker";
+            this.btnInvokeMgCooker.Click += new System.EventHandler(this.btnInvokeMgCooker_Click);
             // splitter1
             resources.ApplyResources(this.splitter1, "splitter1");
@@ -539,5 +565,8 @@
         private System.Windows.Forms.ToolStripButton btnMoveGroupUp;
         private System.Windows.Forms.ToolStripButton btnMoveGroupDown;
         private System.Windows.Forms.ToolStripSeparator toolStripSeparator7;
+        private System.Windows.Forms.ToolStripSeparator toolStripSeparator8;
+        private System.Windows.Forms.ToolStripButton btnBaseLayerGroupToRegular;
+        private System.Windows.Forms.ToolStripButton btnInvokeMgCooker;
Modified: branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2012-05-09 14:53:28 UTC (rev 6637)
@@ -371,6 +371,45 @@
+        private void btnBaseGroupToRegular_Click(object sender, EventArgs e)
+            var group = GetSelectedTiledLayerItem() as BaseLayerGroupItem;
+            if (group != null)
+                int counter = 0;
+                string groupName = group.Tag.Name;
+                while (_map.GetGroupByName(groupName) != null)
+                    counter++;
+                    groupName = group.Tag.Name + "(" + counter + ")";
+                _map.AddGroup(groupName);
+                int layerCount = _map.GetLayerCount();
+                foreach (var layer in group.Tag.BaseMapLayer)
+                    //We an avoid a duplicate name check because the Map Definition should already ensure uniqueness
+                    //among existing layers
+                    var dlayer = _map.AddLayer(groupName, layer.Name, layer.ResourceId);
+                    dlayer.ExpandInLegend = layer.ExpandInLegend;
+                    dlayer.LegendLabel = layer.LegendLabel;
+                    dlayer.Selectable = layer.Selectable;
+                    dlayer.ShowInLegend = layer.ShowInLegend;
+                    //HACK-ish, but we need to relocate this
+                    _map.RemoveLayer(dlayer);
+                    //Add to bottom
+                    _map.InsertLayer(layerCount, dlayer);
+                    layerCount++;
+                //Detach the base layer group
+                _map.BaseMap.RemoveBaseLayerGroup(group.Tag);
+                MessageBox.Show(string.Format(Properties.Resources.BaseLayerGroupConvertedToLayerGroup, group.Tag.Name, groupName));
+                this.RefreshModels();
+                tabControl1.SelectedIndex = 0; //Switch to Layer Groups
         private void btnDLAddLayer_Click(object sender, EventArgs e)
             using (var picker = new ResourcePicker(_edSvc.ResourceService, ResourceTypes.LayerDefinition, ResourcePickerMode.OpenResource))
@@ -869,6 +908,7 @@
             btnAddBaseLayer.Enabled = true;
             btnRemoveBaseLayerGroup.Enabled = true;
+            btnBaseLayerGroupToRegular.Enabled = true;
             propertiesPanel.Controls.Clear();
             var item = new GroupPropertiesCtrl(group.Tag);
@@ -882,6 +922,7 @@
             btnRemoveBaseLayer.Enabled = true;
             btnMoveBaseLayerDown.Enabled = true;
             btnMoveBaseLayerUp.Enabled = true;
+            btnBaseLayerGroupToRegular.Enabled = false;
             var item = new LayerPropertiesCtrl(layer.Tag, _edSvc.ResourceService);
@@ -1306,5 +1347,35 @@
+        private void btnInvokeMgCooker_Click(object sender, EventArgs e)
+            if (_edSvc.IsNew || _edSvc.IsDirty)
+                MessageBox.Show(Properties.Resources.SaveMapBeforeTiling);
+                return;
+            var conn = _map.CurrentConnection;
+            //HACK: Can't support other connection types beyond HTTP atm
+            if (!conn.ProviderName.ToLower().Contains("maestro.http"))
+                MessageBox.Show(string.Format(Properties.Resources.UnsupportedConnectionType, conn.ProviderName));
+                return;
+            if (_map.BaseMap == null || _map.BaseMap.GroupCount == 0)
+                MessageBox.Show(Properties.Resources.NotATiledMap);
+                return;
+            //HACK: This will ask for login again because we don't store username/password and MgCooker does not
+            //support initialization from a session id yet. But at least MgCooker will launch with the correct
+            //map definition loaded
+            _edSvc.RunProcess("MgCooker",
+                              "--mapagent=" + conn.GetCustomProperty("BaseUrl"),
+                              "--mapdefinitions=" + _edSvc.ResourceID);
Modified: branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx	2012-05-09 14:53:28 UTC (rev 6637)
@@ -594,6 +594,47 @@
   <data name="btnMoveBaseLayerDown.ToolTipText" xml:space="preserve">
     <value>Move selected layer down</value>
   </data>
+  <data name="toolStripSeparator8.Size" type="System.Drawing.Size, System.Drawing">
+    <value>6, 25</value>
+  </data>
+  <data name="btnBaseLayerGroupToRegular.Enabled" type="System.Boolean, mscorlib">
+    <value>False</value>
+  </data>
+  <data name="btnBaseLayerGroupToRegular.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+    <value>Magenta</value>
+  </data>
+  <data name="btnBaseLayerGroupToRegular.Size" type="System.Drawing.Size, System.Drawing">
+    <value>23, 22</value>
+  </data>
+  <data name="btnBaseLayerGroupToRegular.Text" xml:space="preserve">
+    <value>Convert Tiled Group to Regular Group</value>
+  </data>
+  <data name="btnInvokeMgCooker.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAKcSURBVDhPfZHbT9JhGMe9qr+g27xoa8ta5ShQUJEsFA8N
+        bbNJ2tJ5WE1ucg1aTiaN1mJiBzMrRDBBSKHhIZFEEBGQg/wAD2nlocMWq4u6ccHml36r2c0Pe7fP9u55
+        3/fzfPe8aWkpFq/GdLj42lRHznWlk92inOM1jXSXCF7RUt2l1Eqbp5voUsmvWosBnKG7KNQzkak6j3rD
+        +k5x9WvpfyUlTbZi5v2GnVKTAumP+Cgf1YKlEyLPsoKj1gRqR2LgVpiv7ilhi59HCnRMcLRnkKXJRYX5
+        KYTBBMpcCdBM4zg52An+zb5vRUXC/RRJJudWOl3WgoJBJlj92RBalehe2UYrEYfAm8AJTSuOqwRgyBuR
+        lfOATREcyW9ntJkJMNQNaBh/gtHNOJSrcUjCcdTMfiQTlSCrnwe+Vo5TjM6LFAGNJTrYZliHNBpHuakD
+        PH0VRK4ZiEJxVLzxgqlh4hyZjqO4AjpTkZtyDo3tvpAouA2BZRBccvrsgRyUjQ6g0JkAwxrDaXUlcpul
+        sYwMyb6UAv5lE1c8/H6n3vUV2eQQWQMXwLVtgTaVwKHxbeR13EbVpT7xnr/Q1aXM63xsQ+09I/LVNcmz
+        E2tJ+sTPJM/2I1n3kIBEMgKDwWjfUzA5OTXscvkwNOzAHfk0JPJZtMrsuCF+CYVCB7vdDZfLC5lMdowi
+        IYsHvN5APBxeQji8iECAgM+38OeB0+mG3x9CKBRBNLoMlUqjoAh6e9WVBLGEYDD6j0AgCn8gAp8/jHkf
+        gbk5PzyeBZjNltUUghfVa++2yJgeCsHgMtn5A/R19ZjWGTEz49lMKdjY+IKxMSsFIvwWnz5/x/wzFdZC
+        y2SKeaqgp0eZTR5E3G73osOxi2PRat3FTu7/otcbtbsJfgMnls65GQK1+wAAAABJRU5ErkJggg==
+</value>
+  </data>
+  <data name="btnInvokeMgCooker.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
+  </data>
+  <data name="btnInvokeMgCooker.Size" type="System.Drawing.Size, System.Drawing">
+  </data>
+  <data name="btnInvokeMgCooker.Text" xml:space="preserve">
+    <value>Start MgCooker</value>
+  </data>
   <data name="toolStrip3.Location" type="System.Drawing.Point, System.Drawing">
     <value>3, 3</value>
   </data>
@@ -885,10 +926,28 @@
   <data name="&gt;&gt;btnMoveBaseLayerDown.Type" xml:space="preserve">
     <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
+  <data name="&gt;&gt;toolStripSeparator8.Name" xml:space="preserve">
+    <value>toolStripSeparator8</value>
+  </data>
+  <data name="&gt;&gt;toolStripSeparator8.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ToolStripSeparator, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;btnBaseLayerGroupToRegular.Name" xml:space="preserve">
+    <value>btnBaseLayerGroupToRegular</value>
+  </data>
+  <data name="&gt;&gt;btnBaseLayerGroupToRegular.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ToolStripButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;btnInvokeMgCooker.Name" xml:space="preserve">
+    <value>btnInvokeMgCooker</value>
+  </data>
+  <data name="&gt;&gt;btnInvokeMgCooker.Type" xml:space="preserve">
+  </data>
   <data name="&gt;&gt;$this.Name" xml:space="preserve">
     <value>MapLayersSectionCtrl</value>
   </data>
   <data name="&gt;&gt;$this.Type" xml:space="preserve">
-    <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=3.5.0.5977, Culture=neutral, PublicKeyToken=null</value>
+    <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=4.0.0.6359, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
   </data>
 </root>
Modified: branches/maestro-4.0.x/Maestro.Editors/Properties/Resources.Designer.cs
--- branches/maestro-4.0.x/Maestro.Editors/Properties/Resources.Designer.cs	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Editors/Properties/Resources.Designer.cs	2012-05-09 14:53:28 UTC (rev 6637)
@@ -1,7 +1,7 @@
 // <auto-generated>
@@ -211,6 +211,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Base Layer Group ({0}) converted to Regular Group ({1}).
+        /// </summary>
+        internal static string BaseLayerGroupConvertedToLayerGroup {
+            get {
+                return ResourceManager.GetString("BaseLayerGroupConvertedToLayerGroup", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Between {0} and {1}.
         /// </summary>
         internal static string BetweenLabel {
@@ -2166,6 +2175,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to This is not a Map Definition with tiled layers.
+        /// </summary>
+        internal static string NotATiledMap {
+            get {
+                return ResourceManager.GetString("NotATiledMap", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to No transformation required.
         /// </summary>
         internal static string NoTransformationRequired {
@@ -2581,6 +2599,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to You must save this map first before you can run MgCooker.
+        /// </summary>
+        internal static string SaveMapBeforeTiling {
+            get {
+                return ResourceManager.GetString("SaveMapBeforeTiling", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Save Resource.
         /// </summary>
         internal static string SaveResource {
@@ -3071,6 +3098,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Invoking MgCooker is not supported for this connection type: {0}.
+        /// </summary>
+        internal static string UnsupportedConnectionType {
+            get {
+                return ResourceManager.GetString("UnsupportedConnectionType", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Updating Configuration Document.
         /// </summary>
         internal static string UpdatingConfiguration {
Modified: branches/maestro-4.0.x/Maestro.Editors/Properties/Resources.resx
--- branches/maestro-4.0.x/Maestro.Editors/Properties/Resources.resx	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Editors/Properties/Resources.resx	2012-05-09 14:53:28 UTC (rev 6637)
@@ -1319,4 +1319,16 @@
   <data name="PromptResetOdbcConfigDocument" xml:space="preserve">
     <value>Changing the DSN will reset the current configuration document. Proceed?</value>
   </data>
+  <data name="SaveMapBeforeTiling" xml:space="preserve">
+    <value>You must save this map first before you can run MgCooker</value>
+  </data>
+  <data name="UnsupportedConnectionType" xml:space="preserve">
+    <value>Invoking MgCooker is not supported for this connection type: {0}</value>
+  </data>
+  <data name="NotATiledMap" xml:space="preserve">
+    <value>This is not a Map Definition with tiled layers</value>
+  </data>
+  <data name="BaseLayerGroupConvertedToLayerGroup" xml:space="preserve">
+    <value>Base Layer Group ({0}) converted to Regular Group ({1})</value>
+  </data>
 </root>
Modified: branches/maestro-4.0.x/Maestro.Editors/ResourceEditorServiceBase.cs
--- branches/maestro-4.0.x/Maestro.Editors/ResourceEditorServiceBase.cs	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Editors/ResourceEditorServiceBase.cs	2012-05-09 14:53:28 UTC (rev 6637)
@@ -481,5 +481,7 @@
             get { return _conn.Capabilities.SupportedServices; }
+        public abstract void RunProcess(string processName, params string[] args);
Modified: branches/maestro-4.0.x/Maestro.Editors/SymbolDefinition/SymbolEditorService.cs
--- branches/maestro-4.0.x/Maestro.Editors/SymbolDefinition/SymbolEditorService.cs	2012-05-09 13:31:51 UTC (rev 6636)
+++ branches/maestro-4.0.x/Maestro.Editors/SymbolDefinition/SymbolEditorService.cs	2012-05-09 14:53:28 UTC (rev 6637)
@@ -220,5 +220,10 @@
             return _inner.GetCustomProperty(name);
+        public void RunProcess(string processName, params string[] args)
+            throw new NotImplementedException();
More information about the mapguide-commits mailing list
