[mapguide-commits] r6658 - branches/maestro-4.0.x/MgCooker
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu May 17 10:15:09 EDT 2012
Author: jng
Date: 2012-05-17 07:15:05 -0700 (Thu, 17 May 2012)
New Revision: 6658
   branches/maestro-4.0.x/MgCooker/SetupRun.cs
   branches/maestro-4.0.x/MgCooker/SetupRun.designer.cs
   branches/maestro-4.0.x/MgCooker/SetupRun.resx
Bump maximum allowed value for MgCooker
Modified: branches/maestro-4.0.x/MgCooker/SetupRun.cs
--- branches/maestro-4.0.x/MgCooker/SetupRun.cs	2012-05-17 14:10:30 UTC (rev 6657)
+++ branches/maestro-4.0.x/MgCooker/SetupRun.cs	2012-05-17 14:15:05 UTC (rev 6658)
@@ -42,6 +42,7 @@
         private SetupRun()
             InitializeComponent();
+            MetersPerUnit.Maximum = Int32.MaxValue;
         internal SetupRun(string userName, string password, IServerConnection connection, string[] maps, Dictionary<string, string> args)
Modified: branches/maestro-4.0.x/MgCooker/SetupRun.designer.cs
--- branches/maestro-4.0.x/MgCooker/SetupRun.designer.cs	2012-05-17 14:10:30 UTC (rev 6657)
+++ branches/maestro-4.0.x/MgCooker/SetupRun.designer.cs	2012-05-17 14:15:05 UTC (rev 6658)
@@ -50,6 +50,7 @@
             this.txtLowerX = new System.Windows.Forms.TextBox();
             this.label11 = new System.Windows.Forms.Label();
             this.grpDifferentConnection = new System.Windows.Forms.GroupBox();
+            this.chkUseDifferentConnection = new System.Windows.Forms.CheckBox();
             this.UseNativeAPI = new System.Windows.Forms.CheckBox();
             this.Password = new System.Windows.Forms.TextBox();
             this.Username = new System.Windows.Forms.TextBox();
@@ -73,7 +74,6 @@
             this.MaxColLimit = new System.Windows.Forms.NumericUpDown();
             this.label7 = new System.Windows.Forms.Label();
             this.toolTip1 = new System.Windows.Forms.ToolTip(this.components);
-            this.chkUseDifferentConnection = new System.Windows.Forms.CheckBox();
             this.panel1.SuspendLayout();
             this.panel2.SuspendLayout();
             this.BoundsOverride.SuspendLayout();
@@ -239,6 +239,12 @@
             this.grpDifferentConnection.Name = "grpDifferentConnection";
             this.grpDifferentConnection.TabStop = false;
+            // chkUseDifferentConnection
+            resources.ApplyResources(this.chkUseDifferentConnection, "chkUseDifferentConnection");
+            this.chkUseDifferentConnection.Name = "chkUseDifferentConnection";
+            this.chkUseDifferentConnection.UseVisualStyleBackColor = true;
             // UseNativeAPI
             resources.ApplyResources(this.UseNativeAPI, "UseNativeAPI");
@@ -349,9 +355,9 @@
             65536});
             resources.ApplyResources(this.MetersPerUnit, "MetersPerUnit");
             this.MetersPerUnit.Maximum = new decimal(new int[] {
-            10000,
+            1874919424,
+            2328306,
             0,
-            0,
             0});
             this.MetersPerUnit.Name = "MetersPerUnit";
             this.toolTip1.SetToolTip(this.MetersPerUnit, resources.GetString("MetersPerUnit.ToolTip"));
@@ -415,12 +421,6 @@
             resources.ApplyResources(this.label7, "label7");
             this.label7.Name = "label7";
-            // chkUseDifferentConnection
-            resources.ApplyResources(this.chkUseDifferentConnection, "chkUseDifferentConnection");
-            this.chkUseDifferentConnection.Name = "chkUseDifferentConnection";
-            this.chkUseDifferentConnection.UseVisualStyleBackColor = true;
             // SetupRun
             this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
Modified: branches/maestro-4.0.x/MgCooker/SetupRun.resx
--- branches/maestro-4.0.x/MgCooker/SetupRun.resx	2012-05-17 14:10:30 UTC (rev 6657)
+++ branches/maestro-4.0.x/MgCooker/SetupRun.resx	2012-05-17 14:15:05 UTC (rev 6658)
@@ -239,54 +239,54 @@
         AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
         LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
         ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAACC
-        DAAAAk1TRnQBSQFMAgEBBAEAAUwBAAFMAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+        DAAAAk1TRnQBSQFMAgEBBAEAAVQBAAFUAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
         AwABIAMAAQEBAAEgBgABIP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8A/wD/AP8AKgADHAEoAyQBNgMk
         ATYDJAE2AyQBNgMkATYDJAE2AyQBNgMkATYDJAE2AyQBNgMkATYDGwEmHAADFgEeAVsCWAHGAx0BKgMC
-        AQOgAAP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wMbASYcAAGH
-        Am0B9wH0AeYB4QH/AcoBuwG6Af0BjQGFAYQB+QFNAkwBkQMRAReYAAP9Af8B9QHoAeQB/wH0AeUB4AH/
+        AQOgAAP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wP9Af8D/QH/A/0B/wMbASYcAAGG
+        Am0B9wH0AeYB4QH/AccBugG5Af0BjAGEAYMB+QFNAkwBkQMRAReYAAP9Af8B9QHoAeQB/wH0AeUB4AH/
         AfIB4gHdAf8B8QHgAdkB/wHwAd0B1gH/Ae8B2wHTAf8B7gHZAdEB/wHuAdgB0AH/Ae4B2AHQAf8B7gHY
         AdAB/wP9Af8DGwEmGAABLAIrAUMB9QHoAeMB/wH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/
-        AakBmwGYAfoBaQJaAfABNgI1AVgDCwEPDAADHQEqAx0BKiAAAwUBBwMdASoDHQEqTAAD/QH/AfcB7QHp
-        Af8B9gHqAeYB/wH0AecB4wH/Ad0BtQGwAf8BvQFrAWYB/wG+AW8BagH/AeMBwgG8Af8B7wHaAdIB/wHu
-        AdgB0AH/Ae4B2AHQAf8D/QH/AxsBJhgAAZECewH4AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHd
-        Af8B8gHhAdsB/wHxAd8B2QH/AfAB3QHXAf8B7wHcAdUB/wGeAYkBgwH6AVkCVwHCCwAB/ygAAzABTAMA
-        Af9MAAP9Af8B+AHwAe0B/wHtAdcB0gH/AbkBiQFpAf8BWQGTASkB/wHqAbEBMQH/AegBrgEoAf8B6wHB
-        AVwB/wGxAVMBTgH/Ae4B2QHSAf8B7gHZAdIB/wP9Af8DGwEmFAADQAFwAfUB6QHlAf8B9QHoAeMB/wH0
+        AaYBmQGVAfoBaAJaAfABNgI1AVgDCwEPDAADHQEqAx0BKiAAAwUBBwMdASoDHQEqTAAD/QH/AfcB7QHp
+        Af8B9gHqAeYB/wH0AecB4wH/Ad0BtQGwAf8BvQFqAWUB/wG+AW4BaQH/AeMBwgG8Af8B7wHaAdIB/wHu
+        AdgB0AH/Ae4B2AHQAf8D/QH/AxsBJhgAAY4CegH4AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHd
+        Af8B8gHhAdsB/wHxAd8B2QH/AfAB3QHXAf8B7wHcAdUB/wGcAYYBgAH6AVkCVwHCCwAB/ygAAzABTAMA
+        Af9MAAP9Af8B+AHwAe0B/wHtAdcB0gH/AbkBiQFoAf8BWAGTASgB/wHqAbEBMAH/AegBrgEnAf8B6wHB
+        AVsB/wGxAVIBTQH/Ae4B2QHSAf8B7gHZAdIB/wP9Af8DGwEmFAADQAFwAfUB6QHlAf8B9QHoAeMB/wH0
         AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AfEB3wHZAf8B8AHdAdcB/wHvAdwB1QH/Ae8B2gHT
         Af8DOAFcCwAB/wgAAUYCRQF/AwAEAQECA0UBfQQAAygBPAMlATcEAAMvAUoDAAH/DAADEQEXA1gB0QMA
-        Af8DKAE8EAADOAFcAwAB/xgAA/0B/wH2AeoB5gH/AegBvwGcAf8B+wHLAVwB/wE2Aa0BQwH/AU4BnQEk
-        Af8B/gHEATwB/wH+Ab4BJwH/AfYBtgEdAf8BlwFsAUkB/wHwAd0B1gH/A/0B/wMbASYUAAGYAYcBhQH4
+        Af8DKAE8EAADOAFcAwAB/xgAA/0B/wH2AeoB5gH/AegBvwGcAf8B+wHLAVsB/wE1Aa0BQgH/AU0BnQEj
+        Af8B/gHEATsB/wH+Ab4BJgH/AfYBtgEcAf8BlwFrAUgB/wHwAd0B1gH/A/0B/wMbASYUAAGWAYQBggH4
         AfUB6QHlAf8B9QHoAeMB/wH0AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AfEB3wHZAf8B8AHd
-        AdcB/wHvAdwB1QH/AXkCYgH2AwQBBgsAAf8LAAH/A0UBfQNIAYUDAAH/BwAB/wMAAf8EAAMvAUoDAAH/
-        EAADQgF0AwAB/xQAAw0BEQNaAdUYAAP9Af8BuQFZAUQB/wH6Ac4BaAH/AaQBtgFQAf8BNgGtAUQB/wE1
-        Aa0BQwH/AckBvwFSAf8B/gHEATsB/wH+AcABLAH/ATQBpQE7Af8BvAFrAWgB/wP9Af8DGwEmEAADUAGe
+        AdcB/wHvAdwB1QH/AXcCYgH2AwQBBgsAAf8LAAH/A0UBfQNIAYUDAAH/BwAB/wMAAf8EAAMvAUoDAAH/
+        EAADQgF0AwAB/xQAAw0BEQNaAdUYAAP9Af8BuQFYAUMB/wH6Ac4BZwH/AaQBtgFPAf8BNQGtAUMB/wE0
+        Aa0BQgH/AckBvwFRAf8B/gHEAToB/wH+AcABKwH/ATMBpQE6Af8BvAFqAWcB/wP9Af8DGwEmEAADUAGe
         AfYB6wHnAf8B9QHpAeUB/wH1AegB4wH/AfQB5gHhAf8B8wHkAd8B/wHyAeMB3QH/AfIB4QHbAf8B8QHf
-        AdkB/wHwAd0B1wH/Ab0BswGvAfwDKAE8DwAB/ygAAy8BSgMAAf8QAANCAXQDAAH/NAAD/QH/AeoBwwGh
-        Af8B/QHWAYQB/wGbAbYBVgH/ATQBnwEpAf8B8QHYAZEB/wH9AdEBbAH/AZwBsAE9Af8BNgGtAUQB/wE2
-        Aa0BRAH/AZgBZwFGAf8D/QH/AxsBJhAAAZsBiQGIAfcB9gHrAecB/wH1AekB5QH/AfUB6AHjAf8B9AHm
-        AeEB/wHzAeQB3wH/AfIB4wHdAf8B8gHhAdsB/wHxAd8B2QH/AfAB3QHXAf8BaQJZAesDAQECDwAB/ygA
-        Ay8BSgMAAf8QAANCAXQDAAH/FAADAgEDA1EBoRgAA/0B/wH6AeIBuQH/ATcBmgEgAf8C1AGbAf8B/QHj
-        AbUB/wH9Ad0BnQH/Af0B1AF1Af8B5AHIAVoB/wE1AawBQgH/AUwBnAEhAf8BngGKAVcB/wP9Af8DGwEm
+        AdkB/wHwAd0B1wH/AbsBsQGtAfwDKAE8DwAB/ygAAy8BSgMAAf8QAANCAXQDAAH/NAAD/QH/AeoBwwGh
+        Af8B/QHWAYQB/wGbAbYBVQH/ATMBnwEoAf8B8QHYAZEB/wH9AdEBawH/AZwBsAE8Af8BNQGtAUMB/wE1
+        Aa0BQwH/AZgBZgFFAf8D/QH/AxsBJhAAAZcBiAGHAfcB9gHrAecB/wH1AekB5QH/AfUB6AHjAf8B9AHm
+        AeEB/wHzAeQB3wH/AfIB4wHdAf8B8gHhAdsB/wHxAd8B2QH/AfAB3QHXAf8BaAJZAesDAQECDwAB/ygA
+        Ay8BSgMAAf8QAANCAXQDAAH/FAADAgEDA1EBoRgAA/0B/wH6AeIBuQH/ATYBmgEfAf8C1AGbAf8B/QHj
+        AbUB/wH9Ad0BnQH/Af0B1AF0Af8B5AHIAVkB/wE0AawBQQH/AUsBnAEgAf8BngGKAVYB/wP9Af8DGwEm
         DAABXAJZAckB9wHtAekB/wH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0AeYB4QH/AfMB5AHfAf8B8gHj
-        Ad0B/wHyAeEB2wH/AfEB3wHZAf8BrAGdAZoB+gMbASYTAAH/KAADLwFKAwAB/xAAA0IBdAMAAf8UAAM+
-        AWsDAAH/GAAD/QH/AWkBkAExAf8BNgGtAUQB/wE2Aa0BRAH/Aa8BwQFwAf8B/QHbAZUB/wH9AdMBcAH/
-        Af4BygFOAf8BPgGaASAB/wE0AZcBGwH/AZwBaQFHAf8D/QH/AxsBJggAAwQBBQGvAaIBoQH6AfcB7QHp
+        Ad0B/wHyAeEB2wH/AfEB3wHZAf8BqQGbAZgB+gMbASYTAAH/KAADLwFKAwAB/xAAA0IBdAMAAf8UAAM+
+        AWsDAAH/GAAD/QH/AWgBkAEwAf8BNQGtAUMB/wE1Aa0BQwH/Aa8BwQFvAf8B/QHbAZUB/wH9AdMBbwH/
+        Af4BygFNAf8BPQGaAR8B/wEzAZcBGgH/AZwBaAFGAf8D/QH/AxsBJggAAwQBBQGsAaABnwH6AfcB7QHp
         Af8B9gHrAecB/wH1AekB5QH/AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHdAf8B8gHhAdsB/wHx
-        Ad8B2QH/AV0CWQHSFwAB/ygAAy8BSgMAAf8QAANCAXYDAAH/NAAD/QH/Ab4BawFLAf8BNgGtAUQB/wE1
-        AaMBMgH/ATUBrQFDAf8BwAHCAWMB/wH+Ac4BXgH/Af4BxgFAAf8BVQGUARIB/wHCAboBQgH/AcUBgQF0
-        Af8D/QH/AxsBJggAAWQCWgHnAfgB7gHrAf8B9wHtAekB/wH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0
-        AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AZsBjQGKAfgDEwEaFwAB/ygAAy8BSgMAAf8MAAMI
-        AQsBWgJVAd4DAAH/NAAD/QH/AfcB7QHpAf8BcQGQATUB/wGnAbUBSgH/ATYBkwEUAf8BqgG3AUwB/wFJ
-        AZ4BJQH/AfIBwgE9Af8B/gG9ASIB/wHFAXQBYAH/AfkB8QHuAf8D/QH/AxsBJgQAAxIBGQGwAqQB+gH4
+        Ad8B2QH/AV0CWQHSFwAB/ygAAy8BSgMAAf8QAANCAXYDAAH/NAAD/QH/Ab4BagFKAf8BNQGtAUMB/wE0
+        AaMBMQH/ATQBrQFCAf8BwAHCAWIB/wH+Ac4BXQH/Af4BxgE/Af8BVAGUAREB/wHCAboBQQH/AcUBgQFz
+        Af8D/QH/AxsBJggAAWQCXAHnAfgB7gHrAf8B9wHtAekB/wH2AesB5wH/AfUB6QHlAf8B9QHoAeMB/wH0
+        AeYB4QH/AfMB5AHfAf8B8gHjAd0B/wHyAeEB2wH/AZkBigGHAfgDEwEaFwAB/ygAAy8BSgMAAf8MAAMI
+        AQsBWgJWAd4DAAH/NAAD/QH/AfcB7QHpAf8BcAGQATQB/wGnAbUBSQH/ATUBkwETAf8BqgG3AUsB/wFI
+        AZ4BJAH/AfIBwgE8Af8B/gG9ASEB/wHFAXMBXwH/AfkB8QHuAf8D/QH/AxsBJgQAAxIBGQGtAqIB+gH4
         Ae4B6wH/AfcB7QHpAf8B9gHrAecB/wH1AekB5QH/AfUB6AHjAf8B9AHmAeEB/wHzAeQB3wH/AfIB4wHd
-        Af8B8gHhAdsB/wNUAa8YAAFXAlQB3wFJAkgBhyAAAwsBDwNVAbcBVwJUAd9MAAP9Af8B+QHxAe4B/wHy
-        AeEB2wH/Aa0BhgFRAf8B7gHYAYsB/wFKAZ4BJQH/ATUBrQFDAf8BOwGUARcB/wG7AV4BSgH/AfgB8AHt
-        Af8B+QHxAe4B/wP9Af8DGwEmCAADAQECAVICUQGnAZUCigH5AfYB6wHnAf8B9QHpAeUB/wH1AegB4wH/
-        AfQB5gHhAf8B8wHkAd8B/wHyAeMB3QH/AZgBhAF+AfgDDgETmAAD/QH/AfkB8QHuAf8B+QHxAe4B/wH5
+        Af8B8gHhAdsB/wNUAa8YAAFXAlYB3wFJAkgBhyAAAwsBDwNVAbcBVwJWAd9MAAP9Af8B+QHxAe4B/wHy
+        AeEB2wH/Aa0BhgFQAf8B7gHYAYsB/wFJAZ4BJAH/ATQBrQFCAf8BOgGUARYB/wG7AV0BSQH/AfgB8AHt
+        Af8B+QHxAe4B/wP9Af8DGwEmCAADAQECAVICUQGnAZICiQH5AfYB6wHnAf8B9QHpAeUB/wH1AegB4wH/
+        AfQB5gHhAf8B8wHkAd8B/wHyAeMB3QH/AZYBgQF9AfgDDgETmAAD/QH/AfkB8QHuAf8B+QHxAe4B/wH5
         AfEB7gH/AewB0gHJAf8B0gGVAYIB/wHUAZoBiQH/AfIB4QHcAf8B+QHxAe4B/wH5AfEB7gH/AfkB8QHu
-        Af8D/QH/AxsBJhQAAx0BKQFhAlgB5AGiAY4BjQH5AfQB5gHhAf8B8wHkAd8B/wHyAeMB3QH/AUkCSAGI
+        Af8D/QH/AxsBJhQAAx0BKQFhAlkB5AGeAY0BjAH5AfQB5gHhAf8B8wHkAd8B/wHyAeMB3QH/AUkCSAGI
         nAAD/QH/AfoB9gH0Af8B+gH2AfQB/wH6AfYB9AH/AfoB9gH0Af8B+gH2AfQB/wH6AfYB9AH/AfoB9gH0
-        Af8B+gH2AfQB/wH6AfYB9AH/AfoB9gH0Af8D/QH/AxsBJiAAAz4BawGTAnsB+gGRAnoB+AMHAQqcAAGl
+        Af8B+gH2AfQB/wH6AfYB9AH/AfoB9gH0Af8D/QH/AxsBJiAAAz4BawGQAnoB+gGOAnkB+AMHAQqcAAGl
         AqAB/wGkAaABnwH/AaQCnwH/AaMCngH/AaICnQH/AaECnAH/AaACmwH/AZ8CmgH/AZ0CmQH/AZwBmAGX
         Af8BmwKWAf8BmQKVAf/IAAFCAU0BPgcAAT4DAAEoAwABQAMAASADAAEBAQABAQYAAQEWAAP/gQABwAEB
         AfwBPwT/AcABAQH8AQ8E/wHAAQEB+AEBAc8B8QL/AcABAQH4AQAB3wH5Av8BwAEBAfABAAHYAUkBwwHP
More information about the mapguide-commits mailing list
