[mapguide-commits] r6662 - in trunk/Tools/Maestro:
Maestro.Base/Commands Maestro.Base/Events
Maestro.Editors/Diagnostics
svn_mapguide at osgeo.org
Thu May 17 12:10:27 EDT 2012
Author: jng
Date: 2012-05-17 09:10:27 -0700 (Thu, 17 May 2012)
New Revision: 6662
trunk/Tools/Maestro/Maestro.Base/Commands/ServerMonitorCommand.cs
trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs
trunk/Tools/Maestro/Maestro.Editors/Diagnostics/ServerStatusMonitor.cs
#1958: Fix server status monitor. This was due to the actual initialization code commented out in the process of implementing multiple site support. This command will now be monitoring the active connection in a multiple connection session where the active session = the top-level parent connection of any selected node in the Site Explorer
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/ServerMonitorCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/ServerMonitorCommand.cs 2012-05-17 15:31:45 UTC (rev 6661)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/ServerMonitorCommand.cs 2012-05-17 16:10:27 UTC (rev 6662)
@@ -34,6 +34,20 @@
try
+ var wb = Workbench.Instance;
+ var exp = wb.ActiveSiteExplorer;
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = connMgr.GetConnection(exp.ConnectionName);
+ ISiteService siteSvc = null;
+ var svcTypes = conn.Capabilities.SupportedServices;
+ if (Array.IndexOf(svcTypes, (int)ServiceType.Site) >= 0)
+ siteSvc = (ISiteService)conn.GetService((int)ServiceType.Site);
+ if (siteSvc != null)
+ ServerStatusMonitor.Init(siteSvc);
ServerStatusMonitor.ShowWindow();
catch (Exception ex)
Modified: trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs
--- trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs 2012-05-17 15:31:45 UTC (rev 6661)
+++ trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs 2012-05-17 16:10:27 UTC (rev 6662)
@@ -95,12 +95,6 @@
var svc = ServiceRegistry.GetService<ServerConnectionManager>();
LoggingService.Info("There are now " + svc.GetConnectionNames().Count + " active connections"); //LOCALIZEME
//Debug.Assert(wb.ActiveSiteExplorer.ConnectionName == name);
- //TODO: Review this API design when we do decide to support multiple
- //site connections
- ServerStatusMonitor.Init(null);
static void OnConnectionAdded(object sender, string name)
@@ -123,18 +117,6 @@
var conn = svc.GetConnection(name);
- ISiteService siteSvc = null;
- var svcTypes = conn.Capabilities.SupportedServices;
- if (Array.IndexOf(svcTypes, (int)ServiceType.Site) >= 0)
- siteSvc = (ISiteService)conn.GetService((int)ServiceType.Site);
- ServerStatusMonitor.Init(siteSvc);
Modified: trunk/Tools/Maestro/Maestro.Editors/Diagnostics/ServerStatusMonitor.cs
--- trunk/Tools/Maestro/Maestro.Editors/Diagnostics/ServerStatusMonitor.cs 2012-05-17 15:31:45 UTC (rev 6661)
+++ trunk/Tools/Maestro/Maestro.Editors/Diagnostics/ServerStatusMonitor.cs 2012-05-17 16:10:27 UTC (rev 6662)
@@ -74,8 +74,19 @@
/// </summary>
public static void ShowWindow()
+ ShowWindow(true);
+ private static bool _cleanupOnClose = true;
+ /// <summary>
+ /// Shows the window.
+ /// </summary>
+ public static void ShowWindow(bool cleanupOnClose)
if (_smConn != null)
+ _cleanupOnClose = cleanupOnClose;
_smMonitor.DoPoll();
_smMonitor.StartTimer();
_smMonitor.Show();
@@ -93,6 +104,8 @@
_smMonitor.StopTimer();
_smMonitor.Hide();
+ if (_cleanupOnClose)
+ Init(null);
private void pollTimer_Tick(object sender, EventArgs e)
More information about the mapguide-commits
