[mapguide-commits] r6665 - trunk/MgDev/Server/src/Services/Rendering
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri May 18 06:28:25 EDT 2012
Author: jng
Date: 2012-05-18 03:28:25 -0700 (Fri, 18 May 2012)
New Revision: 6665
   trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp
   trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp
#1105: Add extents to logged map rendering calls. Note that profiled versions of these calls do not log extents.
Modified: trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp
--- trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp	2012-05-18 10:25:19 UTC (rev 6664)
+++ trunk/MgDev/Server/src/Services/Rendering/OpRenderDynamicOverlay.cpp	2012-05-18 10:28:25 UTC (rev 6665)
@@ -71,6 +71,9 @@
             selection->SetMap(map);
         Ptr<MgRenderingOptions> options = (MgRenderingOptions*)m_stream->GetObject();
+        Ptr<MgEnvelope> env = map->GetDataExtent();
+        Ptr<MgCoordinate> ll = env->GetLowerLeftCoordinate();
+        Ptr<MgCoordinate> ur = env->GetUpperRightCoordinate();
         BeginExecution();
@@ -85,6 +88,20 @@
         MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
         MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgColor");
         MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+        // [(llx lly) (urx ury)]
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(L" [");
+        MG_LOG_OPERATION_MESSAGE_PARAMETERS_START()
+        MG_LOG_OPERATION_MESSAGE_ADD_DOUBLE(ll->GetX());
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(L" ");
+        MG_LOG_OPERATION_MESSAGE_ADD_DOUBLE(ll->GetY());
+        MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+        MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+        MG_LOG_OPERATION_MESSAGE_ADD_DOUBLE(ur->GetX());
+        MG_LOG_OPERATION_MESSAGE_ADD_DOUBLE(ur->GetY());
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"] ");
         Validate();
Modified: trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp
--- trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp	2012-05-18 10:25:19 UTC (rev 6664)
+++ trunk/MgDev/Server/src/Services/Rendering/OpRenderMap.cpp	2012-05-18 10:28:25 UTC (rev 6665)
@@ -76,6 +76,10 @@
         bool bKeepSelection = false;
         m_stream->GetBoolean(bKeepSelection);
         BeginExecution();
@@ -87,7 +91,20 @@
         MG_LOG_OPERATION_MESSAGE_ADD_BOOL(bKeepSelection);
         Validate();
         Ptr<MgByteReader> byteReader =
@@ -105,6 +122,10 @@
         if(selection)
         STRING format;
         m_stream->GetString(format);
@@ -126,6 +147,20 @@
         MG_LOG_OPERATION_MESSAGE_ADD_BOOL(bClip);
         Validate();
@@ -145,6 +180,8 @@
         Ptr<MgEnvelope> extents = (MgEnvelope*)m_stream->GetObject();
+        Ptr<MgCoordinate> ll = extents->GetLowerLeftCoordinate();
+        Ptr<MgCoordinate> ur = extents->GetUpperRightCoordinate();
         INT32 width = 0;
         m_stream->GetInt32(width);
@@ -179,6 +216,20 @@
         Validate();
@@ -197,6 +248,9 @@
         if(selection)
         Ptr<MgCoordinate> center = (MgCoordinate*)m_stream->GetObject();
         double scale = 0.0;
@@ -237,6 +291,20 @@
         Validate();
More information about the mapguide-commits mailing list
