[mapguide-commits] r6671 - branches/2.4/MgDev/Desktop/MgDesktop/Services
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon May 21 07:47:55 EDT 2012
Author: jng
Date: 2012-05-21 04:47:54 -0700 (Mon, 21 May 2012)
New Revision: 6671
   branches/2.4/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp
mg-desktop logging enhancement part 1 of many: Log public API access to MgResourceService. Methods under INTERNAL_API are also access logged if they are chained from a PUBLISHED_API call (eg. GetResourceContent)
Modified: branches/2.4/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp
--- branches/2.4/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp	2012-05-18 19:39:12 UTC (rev 6670)
+++ branches/2.4/MgDev/Desktop/MgDesktop/Services/ResourceService.cpp	2012-05-21 11:47:54 UTC (rev 6671)
@@ -194,16 +194,32 @@
     STRING packagePathname;
+    MG_LOG_OPERATION_MESSAGE(L"ApplyResourcePackage");
     MG_RESOURCE_SERVICE_TRY()
+    MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1,0,0),1);
+    MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgByteReader");
+    MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
     packagePathname = MgFileUtil::GenerateTempFileName();
     MgByteSink byteSink(packageStream);
     byteSink.ToFile(packagePathname);
     LoadResourcePackage(packagePathname);
-    MG_RESOURCE_SERVICE_CATCH(L"MgLibraryRepositoryManager.ApplyResourcePackage")
+    // Successful operation
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::ApplyResourcePackage")
+    if (mgException != NULL)
+        // Failed operation
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
     if (!packagePathname.empty())
         try
@@ -219,6 +235,9 @@
+    // Add access log entry for operation
+    MG_LOG_OPERATION_MESSAGE_ACCESS_ENTRY();
     MG_RESOURCE_SERVICE_THROW()
@@ -243,7 +262,20 @@
 void MgdResourceService::SetResource(MgResourceIdentifier* resource, MgByteReader* content, MgByteReader* header)
+    MG_LOG_OPERATION_MESSAGE(L"SetResource");
+    MG_RESOURCE_SERVICE_TRY()
+    MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1,0,0),3);
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == resource) ? L"MgResourceIdentifier" : resource->ToString().c_str());
+    MG_LOG_OPERATION_MESSAGE_ADD_SEPARATOR();
     CHECKARGUMENTNULL(resource, L"MgdResourceService::SetResource");
     //Only null check if not a folder, because otherwise this is a legit way of
     //creating a folder
@@ -272,57 +304,108 @@
             MgFdoConnectionPool::PurgeCachedConnections(resource);
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::SetResource")
+    MG_RESOURCE_SERVICE_THROW()
 void MgdResourceService::DeleteResource(MgResourceIdentifier* resource)
+    MG_LOG_OPERATION_MESSAGE(L"DeleteResource");
+    MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1, 0, 0), 1);
     CHECKARGUMENTNULL(resource, L"MgdResourceService::DeleteResource");
+    if (ResourceExists(resource))
+        if (resource->GetResourceType() == MgResourceType::FeatureSource)
+            //Invalidate any cached information
+            MgFeatureServiceCache* cache = MgFeatureServiceCache::GetInstance();
+            cache->RemoveEntry(resource);
+            //Boot pooled connections to ensure no locks are held (technically,
+            //the pooled connections are closed, but just to play safe)
+            MgFdoConnectionPool::PurgeCachedConnections(resource);
+        else if (resource->GetResourceType() == MgResourceType::Folder)
+            //TODO: We obviously need a fine-grained version instead of going nuclear
+            cache->Clear();
+            MgFdoConnectionPool::PurgeCachedConnectionsUnderFolder(resource);
-    if (!ResourceExists(resource))
-        return;
+	    STRING contentPath = ResolveContentPath(resource);
+	    STRING dataPath = ResolveDataPath(resource);
+	    if (MgFileUtil::IsFile(contentPath))
+		    MgFileUtil::DeleteFile(contentPath);
-    if (resource->GetResourceType() == MgResourceType::FeatureSource)
-        //Invalidate any cached information
-        MgFeatureServiceCache* cache = MgFeatureServiceCache::GetInstance();
-        cache->RemoveEntry(resource);
-        //Boot pooled connections to ensure no locks are held (technically,
-        //the pooled connections are closed, but just to play safe)
-        MgFdoConnectionPool::PurgeCachedConnections(resource);
+		    if (MgFileUtil::IsDirectory(dataPath))
+			    MgFileUtil::DeleteDirectory(dataPath);
+        else if (MgFileUtil::IsDirectory(contentPath))
+            //For directory deletes, everything underneath
+            //is expendable too
+            MgFileUtil::DeleteDirectory(contentPath, true);
+			    MgFileUtil::DeleteDirectory(dataPath, true);
-    else if (resource->GetResourceType() == MgResourceType::Folder)
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::DeleteResource")
-        //TODO: We obviously need a fine-grained version instead of going nuclear
-        cache->Clear();
-        MgFdoConnectionPool::PurgeCachedConnectionsUnderFolder(resource);
-	STRING contentPath = ResolveContentPath(resource);
-	STRING dataPath = ResolveDataPath(resource);
-	if (MgFileUtil::IsFile(contentPath))
-		MgFileUtil::DeleteFile(contentPath);
-		if (MgFileUtil::IsDirectory(dataPath))
-			MgFileUtil::DeleteDirectory(dataPath);
-    else if (MgFileUtil::IsDirectory(contentPath))
-        //For directory deletes, everything underneath
-        //is expendable too
-        MgFileUtil::DeleteDirectory(contentPath, true);
-			MgFileUtil::DeleteDirectory(dataPath, true);
-void MgdResourceService::CopyResource(MgResourceIdentifier* sourceResource,
-    MgResourceIdentifier* destResource, bool overwrite)
+void MgdResourceService::CopyResource(MgResourceIdentifier* sourceResource, MgResourceIdentifier* destResource, bool overwrite)
+    MG_LOG_OPERATION_MESSAGE(L"CopyResource");
+    MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1, 0, 0), 3);
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == sourceResource) ? L"MgResourceIdentifier" : sourceResource->ToString().c_str());
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING((NULL == destResource) ? L"MgResourceIdentifier" : destResource->ToString().c_str());
+    MG_LOG_OPERATION_MESSAGE_ADD_BOOL(overwrite);
     CHECKARGUMENTNULL(sourceResource, L"MgdResourceService::CopyResource");
     CHECKARGUMENTNULL(destResource, L"MgdResourceService::CopyResource");
@@ -389,15 +472,75 @@
 		    MgFileUtil::CopyFile(src, dst, overwrite);
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::CopyResource")
 void MgdResourceService::MoveResource(MgResourceIdentifier* sourceResource, MgResourceIdentifier* destResource, bool overwrite)
+    MG_LOG_OPERATION_MESSAGE(L"MoveResource");
     MoveResource(sourceResource, destResource, overwrite, false);
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::MoveResource")
 void MgdResourceService::MoveResource(MgResourceIdentifier* sourceResource, MgResourceIdentifier* destResource, bool overwrite, bool cascade)
+    MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1, 0, 0), 4);
+    MG_LOG_OPERATION_MESSAGE_ADD_BOOL(cascade);
     CHECKARGUMENTNULL(sourceResource, L"MgdResourceService::MoveResource");
     CHECKARGUMENTNULL(destResource, L"MgdResourceService::MoveResource");
@@ -461,6 +604,22 @@
     DeleteResource(sourceResource);
 MgByteReader* MgdResourceService::GetResourceHeader(MgResourceIdentifier* resource)
@@ -482,6 +641,20 @@
 void MgdResourceService::SetResourceData(MgResourceIdentifier* resource,
     CREFSTRING dataName, CREFSTRING dataType, MgByteReader* data)
+    MG_LOG_OPERATION_MESSAGE(L"SetResourceData");
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(dataName.c_str());
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(dataType.c_str());
     CHECKARGUMENTNULL(resource, L"MgdResourceService::SetResourceData");
     CHECKARGUMENTNULL(data, L"MgdResourceService::SetResourceData");
@@ -496,10 +669,37 @@
 	Ptr<MgByteSink> sink = new MgByteSink(data);
 	sink->ToFile(path);
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::SetResourceData")
 void MgdResourceService::DeleteResourceData(MgResourceIdentifier* resource, CREFSTRING dataName)
+    MG_LOG_OPERATION_MESSAGE(L"DeleteResourceData");
+    MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1, 0, 0), 2);
     CHECKARGUMENTNULL(resource, L"MgdResourceService::DeleteResourceData");
     if (dataName.empty())
@@ -512,11 +712,42 @@
         throw new MgResourceDataNotFoundException(L"MgdResourceService::DeleteResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
     MgFileUtil::DeleteFile(path);
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::DeleteResourceData")
 void MgdResourceService::RenameResourceData(MgResourceIdentifier* resource,
     CREFSTRING oldDataName, CREFSTRING newDataName, bool overwrite)
+    MG_LOG_OPERATION_MESSAGE(L"RenameResourceData");
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(oldDataName.c_str());
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(newDataName.c_str());
     CHECKARGUMENTNULL(resource, L"MgdResourceService::RenameResourceData");
@@ -538,12 +769,58 @@
         throw new MgResourceDataNotFoundException(L"MgdResourceService::RenameResourceData", __LINE__, __WFILE__, NULL, L"", NULL);
 	MgFileUtil::RenameFile(path, oldDataName, newDataName, overwrite);
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::RenameResourceData")
 MgByteReader* MgdResourceService::GetResourceData(MgResourceIdentifier* resource, CREFSTRING dataName)
+    Ptr<MgByteReader> ret;
+    MG_LOG_OPERATION_MESSAGE(L"GetResourceData");
     STRING preProcessTags(L"");
-    return GetResourceData(resource, dataName, preProcessTags);
+    ret = GetResourceData(resource, dataName, preProcessTags);
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::GetResourceData")
+    return ret.Detach();
 bool MgdResourceService::ListDirectories(MgStringCollection* directoryNames, CREFSTRING path)
@@ -705,13 +982,73 @@
         INT32 depth, CREFSTRING type, INT32 properties,
         CREFSTRING fromDate, CREFSTRING toDate)
-    return EnumerateResources(resource, depth, type, properties, fromDate, toDate, true);
+    MG_LOG_OPERATION_MESSAGE(L"EnumerateResources");
+    MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1, 0, 0), 6);
+    MG_LOG_OPERATION_MESSAGE_ADD_INT32(depth);
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(type.c_str());
+    MG_LOG_OPERATION_MESSAGE_ADD_INT32(properties);
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(fromDate.c_str());
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(toDate.c_str());
+    ret = EnumerateResources(resource, depth, type, properties, fromDate, toDate, true);
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::EnumerateResources")
 MgByteReader* MgdResourceService::EnumerateResources(MgResourceIdentifier* resource,
         CREFSTRING fromDate, CREFSTRING toDate, bool computeChildren)
+    Ptr<MgByteReader> response;
+    MG_LOG_OPERATION_MESSAGE_INIT(MG_API_VERSION(1, 0, 0), 7);
+    MG_LOG_OPERATION_MESSAGE_ADD_BOOL(computeChildren);
     CHECKARGUMENTNULL(resource, L"MgdResourceService::EnumerateResources");
     //Disregard: properties, fromDate, toDate.
@@ -763,7 +1100,6 @@
     STRING rtype = resource->GetResourceType();
     STRING path = ResolveContentPath(resource);
-    Ptr<MgByteReader> response;
     STRING xml = L"<ResourceList xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"ResourceList-1.0.0.xsd\">";
     if (MgResourceType::Folder == rtype)
@@ -810,11 +1146,37 @@
     source->SetMimeType(MgMimeType::Xml);
     response = source->GetReader();
     return response.Detach();
 MgByteReader* MgdResourceService::EnumerateResourceData(MgResourceIdentifier* resource)
+    Ptr<MgByteReader> reader;
+    MG_LOG_OPERATION_MESSAGE(L"EnumerateResourceData");
     CHECKARGUMENTNULL(resource, L"MgdResourceService::EnumerateResourceData");
@@ -845,10 +1207,26 @@
     std::string ccontent = MgUtil::WideCharToMultiByte(content);
-	Ptr<MgByteReader> reader;
 	Ptr<MgByteSource> byteSource = new MgByteSource((unsigned char*)ccontent.c_str(), (INT32)ccontent.length());
     byteSource->SetMimeType(MgMimeType::Xml);
 	reader = byteSource->GetReader();
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::EnumerateResourceData")
 	return reader.Detach();
@@ -869,22 +1247,62 @@
 bool MgdResourceService::ResourceExists(MgResourceIdentifier* resource)
+    bool ret = false;
+    MG_LOG_OPERATION_MESSAGE(L"ResourceExists");
     CHECKARGUMENTNULL(resource, L"MgdResourceService::ResourceExists");
     STRING type = resource->GetResourceType();
     if (MgResourceType::Folder == type)
-        return MgFileUtil::IsDirectory(path);
+        ret = MgFileUtil::IsDirectory(path);
     else
-	    return MgFileUtil::IsFile(path);
+	    ret = MgFileUtil::IsFile(path);
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::ResourceExists")
+    return ret;
 MgStringCollection* MgdResourceService::GetResourceContents(MgStringCollection* resources, MgStringCollection* preProcessTags)
+    Ptr<MgStringCollection> contents;
+    MG_LOG_OPERATION_MESSAGE(L"GetResourceContents");
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(L"MgStringCollection");
     CHECKARGUMENTNULL(resources, L"MgdResourceService::GetResourceContents");
-    Ptr<MgStringCollection> contents = new MgStringCollection();
+    contents = new MgStringCollection();
     for (INT32 i = 0; i < resources->GetCount(); i++)
         Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(resources->GetItem(i));
@@ -893,6 +1311,23 @@
         STRING xml = content->ToString();
         contents->Add(xml);
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::GetResourceContents")
     return contents.Detach();
@@ -901,6 +1336,18 @@
 MgByteReader* MgdResourceService::GetResourceContent(MgResourceIdentifier* resource,
     CREFSTRING preProcessTags)
+    Ptr<MgByteReader> content;
+    MG_LOG_OPERATION_MESSAGE(L"GetResourceContent");
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(preProcessTags);
 	CHECKARGUMENTNULL(resource, L"MgdResourceService::GetResourceContent");
     STRING resType = resource->GetResourceType();
@@ -920,12 +1367,26 @@
         throw new MgResourceNotFoundException(L"MgdResourceService::GetResourceContent", __LINE__, __WFILE__, &arguments, L"", NULL);
-    Ptr<MgByteReader> content;
     Ptr<MgByteSource> source = new MgByteSource(path);
     content = source->GetReader();
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::GetResourceContent")
     return content.Detach();
@@ -1003,13 +1464,40 @@
     Ptr<MgByteReader> byteReader;
+    MG_LOG_OPERATION_MESSAGE(L"EnumerateUnmanagedData");
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(path.c_str());
+    MG_LOG_OPERATION_MESSAGE_ADD_BOOL(recursive);
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(filter.c_str());
     MG_LOG_TRACE_ENTRY(L"MgdResourceService::EnumerateUnmanagedData()");
     byteReader = MgUnmanagedDataManager::GetInstance()->EnumerateUnmanagedData(path, recursive, type, filter);
-    MG_RESOURCE_SERVICE_CATCH_AND_THROW(L"MgdResourceService::EnumerateUnmanagedData")
+    MG_RESOURCE_SERVICE_CATCH(L"MgdResourceService::EnumerateUnmanagedData")
     return byteReader.Detach();
\ No newline at end of file
More information about the mapguide-commits mailing list
