[mapguide-commits] r6683 - in trunk/Tools/Maestro: Maestro.Base/Editor Maestro.Base/Properties Maestro.Base/Services Maestro.Shared.UI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue May 22 12:41:17 EDT 2012
Author: jng
Date: 2012-05-22 09:41:16 -0700 (Tue, 22 May 2012)
New Revision: 6683
Added:
   trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.Designer.cs
   trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.cs
   trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.resx
   trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
   trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs
   trunk/Tools/Maestro/Maestro.Shared.UI/CancelException.cs
   trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj
#1978: Use a busy dialog with background thread for pre-save validation and resource preview preparations.
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs	2012-05-22 16:02:07 UTC (rev 6682)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs	2012-05-22 16:41:16 UTC (rev 6683)
@@ -121,20 +121,28 @@
             try
                 var validate = PropertyService.Get(ConfigProperties.ValidateOnSave, true);
-                if (validate)
+                if (this.IsDirty && validate)
-                    var errors = new List<ValidationIssue>(ValidateEditedResource()).ToArray();
-                    if (errors.Length > 0)
+                    BusyWaitDelegate del = () =>
-                        MessageService.ShowError(Properties.Resources.FixErrorsBeforeSaving);
-                        ValidationResultsDialog diag = new ValidationResultsDialog(this.Resource.ResourceID, errors);
-                        diag.ShowDialog(Workbench.Instance);
-                        e.Cancel = true;
-                    else
-                        e.Cancel = false;
+                        var errors = new List<ValidationIssue>(ValidateEditedResource()).ToArray();
+                        return errors;
+                    BusyWaitDialog.Run(Properties.Resources.PrgPreSaveValidation, del, (result) => {
+                        ValidationIssue[] errors = result as ValidationIssue[];
+                        if (errors.Length > 0)
+                            MessageService.ShowError(Properties.Resources.FixErrorsBeforeSaving);
+                            ValidationResultsDialog diag = new ValidationResultsDialog(this.Resource.ResourceID, errors);
+                            diag.ShowDialog(Workbench.Instance);
+                            e.Cancel = true;
+                        else
+                            e.Cancel = false;
                 else
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2012-05-22 16:02:07 UTC (rev 6682)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2012-05-22 16:41:16 UTC (rev 6683)
@@ -1611,6 +1611,26 @@
+        /// <summary>
+        ///   Looks up a localized string similar to Preparing resource preview.
+        /// </summary>
+        internal static string PrgPreparingResourcePreview {
+            get {
+                return ResourceManager.GetString("PrgPreparingResourcePreview", resourceCulture);
+        /// <summary>
+        ///   Looks up a localized string similar to Performing pre-save validation...
+        ///You can disable pre-save validation in Maestro options.
+        /// </summary>
+        internal static string PrgPreSaveValidation {
+            get {
+                return ResourceManager.GetString("PrgPreSaveValidation", resourceCulture);
         internal static System.Drawing.Bitmap printer {
             get {
                 object obj = ResourceManager.GetObject("printer", resourceCulture);
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2012-05-22 16:02:07 UTC (rev 6682)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2012-05-22 16:41:16 UTC (rev 6683)
@@ -120,18 +120,55 @@
   <data name="Menu_Tools_Options" xml:space="preserve">
     <value>Options</value>
   </data>
-  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
-  <data name="cross-circle" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\cross-circle.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <data name="cross-circle" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACN0lEQVQ4T6WSTWgTURSFH0mg
+        CUjTTMsYCsVFoYWKWbTQ7GsgdBHSIpTiVLpu6dK9ggit4MaFi4rVClpt1GqJRfBnrAQRYVIHJSr5WcxI
+        jFlkocxkNVzvGdJhIurGgY/cefec896dPEFE4n9wzbeEELeZu8w9IQa3hVhh7jCFDqhX0IMGWnjg/T0g
+        8zASUd8nk2ZzYcH6ubzs/Fhacr4rinUwOWmixwGZvwVkHvf1aQ1Fsb8tLpKpKF1g7ev8vP0oGtU4INN1
+        gk0cLRxWjbk5+8vsLJ+M6FM22wXWPs/MUCWbtbd6elR4vBE2eL434+OmPj3tmg+fd1NTBPzPQTpNL8bG
+        THi8gHUhtj6k05aaTFJueNjVt9ttajQaVKvVqFwuU7VapWuxGN2UZcqPjlrweAFX+Wvz7s6ziQl6mkjQ
+        jf5+KhaLpOs6lUolqlQqtMHmzQ73h4YceLyAK/yipVLOk5ERyg0M0DYL/WbDMNy1Q3bicQceL+AyH+dV
+        ImHlJYnyfzDX63VqNptuD+xIkgWPF7CGiyPLxj7P59/5AYsBzK1Wy+UlxohETHi8gIv8l1wKBtX9eNze
+        5VNg5l0Wvu2AGmb8Po9G7bVAQIXHC7jA1/IcX47VUEgrSJK9xyE6RvGxx/VrNq8Ggxq08HgBXItjzClu
+        nOX06+GwWejttT7GYg5AjTX0oIEWjz8gxO9HmeODQpxMCXH+tBC5M/ylAWqsoceaE0ycCfkDArxwhJEZ
+        1v0TbARtAAG/AFOx/3DrkH4UAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB6UlEQVQ4T2P4//8/AyUYrFmv
+        /RKDfsdlOLaf+4IBhh3mvZwJxDE2s54yWEx9wGDcdxOsXqP+FFgvVgOMe28wgDRA8RkgDcIxRBsAco1R
+        z3WwjUB8ZsaT//9BtMWU+zFEuQDmHcOuqyAnn+m8+uf/lAf//oPYQNfFYHhBt+3iTKDgGVy48eyP/0X7
+        vvzvvfnnP0gNUH0MShgAOUBbfv2vPfntf82Jb/+rj38F46pjX/9XHv36v2DPp/8ZW96DcfP5H/9B6tXr
+        TsbAA1Gp/NAZkIa0Te/gOGHdq//BSx7+95x947/LtMv/HSdfAGMQO2PHi/8gPXADZPJ2nmk8+/1/2aEv
+        /wsPfP4fvePdf88NL/67rnv+33nts/+mSx//15z3EIx9t77+D1Ivm78L4QLx9E0zxdI2nsGFVbd+/8+3
+        +ut/o13f/4PUANXHAA1BpAOgIINIynoMLJy8jkEgftUZoZ3//8vt+f8fxBZMWB0DUo9iALdxJAOXUQQG
+        5o5YzADEZyR2/f8Ponkil8TwuNczsErqMIAAPAzAPCyASVSDgS1o7hkQZrUri2EW00RRhWwAE1CGD4hl
+        gFgLiI1hmMmqeBmTUXIJlK8NpGWBmB+ImZENYAQKsEMNEQXSUjiwGFQzB5BmghtASXYGADrJ+mn64PZ5
+        AAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="Menu_Help" xml:space="preserve">
     <value>Help</value>
   </data>
-  <data name="document__plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document__plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACEklEQVQ4T4WSS0hUYRSAD5NF
+        gyA5mFJRMOBEmJSPRYM43SyChh70mAEXEkw+B73KyNjglBpCtKlNUSAlQdimTQQh2HI2bmbRohatJGtm
+        xAYf834fz7nM2ahzu/BtLv/33f8/9wfH9DQwzpmZm8TAf2i8NzUFd/x+uD05CWdsNgB+UWYwWSjgZjaL
+        66kUhhIJXI3H8XcspvElEEBaN0hYJMARrVZmKJ7LYZTEyPY2rkSj+GttDX+Gw/gjFMKPi4vID60dIiws
+        a4FbPp/gTlBgI5ncN/JqYQEFi93+mAAGbni9wnAqn8ct2n6lCO+Ej0POsHhwzeMRRtI0g1g6rRvhADkj
+        4sFVVRXUDAUSmYxuhAdLjioeXHa7hbFcsYgpmoNehP8OOWPiwcX+fsGTp0CG5qAXWacjkuMRDzpcLmG8
+        UCphlo5RKXJ/eRRblq5g3ctzy+ZZBU496QC40NMjeIsU4F1UirR87cK+jQk8NH/ij+H9UYB5E0B7d7fw
+        sEQXpUCB3ZEHAfry50uEgs5/A3jwzbG/JAfhnWkOGhUFzjscjI9vWol2sTvS+knBrsjdPcDrI0Hg56TV
+        Cqft9kfaXd0n0rukYusHm0bzqg2rntaF4HlNEF7UzLFvJOobrNZZCWgRgmfCg+Uj8S9ue9uJx1fO4gF/
+        bZidsgs0CWg2ms3j1U1Nz/SoctZ+N7iMEcP1w9/YIUw7Q/B728HeTjIAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="Service_Init_Url_Launcher" xml:space="preserve">
     <value>Initialized: URL Launcher</value>
@@ -148,41 +185,641 @@
   <data name="Menu_Help_About" xml:space="preserve">
     <value>About</value>
   </data>
-  <data name="arrow-180" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\arrow-180.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="arrow-180" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB+ElEQVQ4T2P4//8/AyUYrFmj
+        /hSDXvslBuO+mwwWUx8w2Mx6yuAw72UMEM+0n/uCAYb1Oy4zwDBIPUgvLgNigIacgWKwgca9N+CaQYbg
+        NmDK/RigK87MfPr/P4gGucio5zqKZtwG9N6IAXrjzIwn//93XfvzH8Q27LqKoRmrAbptF2OAzjoz9eG/
+        /0X7vvxvOvfzP4iPCwPVz4SHgXrdyRhgQJ6ZdO/v/4wt78G4cO+n/1XHvv6vPPr1f8WRL//LD0Nw2aEv
+        /6uPf/0PUg83QKn80Jn+23/+p216B8cJ6179D17y8L/n7Bv/XaZd/u84+QIYg9gRK+//B+mBGyCbvytG
+        Jm/nmY4rv/7HbHj732bZ8/9Wy5/8d133/L/z2mf/HVc/+2+/6ul/25VP/1uvePrfce3z/yD1cAOAHAbx
+        9E0xYmkbz4Sd/PWfb/XX/9o7vv8H8XFhoHpEGIAMACpkEExYHSMQv+qM2dH//yV2//8PYgsnr2MQSVmP
+        gUHq4S5gAAJWSR0GHvd6Bp7IJTHcEYvPKO/7/x9EAzEDl1EEBuY2jkQ1AGQICDCLaTKw2pXFsAXNPQPC
+        TKIaMCkMGtkFTEBZPiCWAWItIDZmMkouYbIqXgZiI2FtIFsWiPlBdiEbwAgUYIcaIgqkpXBgMahmDiDN
+        BDeAkuwMAP4K+lUpqC7eAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="plug--minus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\plug--minus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="plug--minus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACH0lEQVQ4T4WR32tSYRjH36KI
+        ykaFgYFKF+ZxeiSNwTxsI3Xp/JFHQSU82PyV6yKlwmI3DhMKvQ2K6q6rguiv2F0wY9APxgbBiNFN7CoY
+        DOrp+8gcyx22A5/3Ped9z/fzPs85QhxyWSwWkUqlRK1WG202mw86nY7U7XbFgMPyggWqqroKhcL86uo6
+        YX5UKpVEu93uSw66Itjsmc3m28FgcKHXWyGPx/NUURS5UqmIVqt1oOAOwp8ajQbxvLi4TFar9bnD4bga
+        j8f/a0evArfJZPpSr9epWq0SemfJssFgqNvt9n3t6AkWQqHQJsqkTCZD+XyeyuUySz6jnbnhdvQEH3K5
+        3FYymaREIkEomWKxGIXDYZZ83duOz+fT/YYfNU37E41GKRAIkNMpk9lsJUkaJZfLzZIVtHPPaDQKVLRP
+        kMDKGpeuKBMIyWSzOXeRZS+EV1iypne0isXvxWKRJif95PUq+G2+XcbGJojhd4DqwpAZsqxzOBgM09TU
+        DCQzND19g/z+yN/x8WvbkuT+bTCM/EDm/mMM78G7IcEzPG9oWpkikSyl07f4tA3wrSbErxdC/HyDe4SW
+        BrwV4vXAoeGGstkshzY1ba4/g/RlDK8Q2pqdpWF4nQV7wxx8CbbBTd68Dp7gJJS9NAyv8zuDkzl8FxjB
+        eXAWjIAz4DQ4CU6A4+AYOAqOsGCeJeAh4I/rADZwCfCPvggugHM7slM7or7kH9bA66xzFurjAAAAAElF
+        TkSuQmCC
+</value>
   </data>
-  <data name="scissors_blue" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\scissors-blue.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="scissors_blue" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACRUlEQVQ4T6VSS2gTURS9mSyD
+        QRGtRlOxkM+gdcAQiIImMQYbE2tIqqVmJUHcWPCDkj4k/q2gYBcuahYuhIpWorgQsSqEqhUpmE1WQQrR
+        QsBo1m7M8543HQ0ibhw43LnnN2+GISkl/Q8ok8lQNpvdxzBSqRRFo1EKBoPk9/vJ7XariR08dPjgRw4P
+        VmQ+nxdAMpk0/lUA3fIipwpweTweUa1WZS6XE5FIxPjbCcBDhw9+5H4V8L3h9XpFrVaTfDQRCASM7lfA
+        Dh46fPD/WYDd8Pl8ol6vy0QiIdho4BtgYgcP3Qr/LvDtJ9KzRKs3qRJ+smg0GjIcDguXyzWEiR28CsMH
+        P+fMVxi8Q5S5R3RgmihyHkWGruui2WzKeDw+U6lUJHbwSocPfs51Fzho6EGacYkxSeFiuW/30flWqyWd
+        gzfnKTVZVrypp7nA0V3goPTdse3F17NnyovfxmfanWsv2vJ46Y2077nexj0AHjp88HOBwzzB3tLBUOHl
+        O5g8R6Y+2AduvLr87Iu0x8YrjAlMtTPfM1Kau/r8q4QfObMgNnGrO3z28Sep7bwwq4UvDmu7rpCavIO3
+        SsSjz9+RMwtC556y2IFYfLIotdDYW22bGNG2HCbbxhhhqp35wsMFVXL6/scfyJkFm0dv7zg21cQpbFtP
+        vbd5hw/ZnL3mL7p0YVc864XphQ78yJkFy9xR6h8tMeaod+AkM/34uxkbGOsY6xl9DJ31E8oHP+esX9nF
+        ooW1fN/DWMlYznAuYQXPVYw1XV4XCn4Cnzlvq0a0CiQAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="MapGuide_Maestro" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\MapGuide Maestro.ico;System.Drawing.Icon, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="MapGuide_Maestro" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAABAAwAMDAQAAEABABoBgAAxgAAACAgEAABAAQA6AIAAC4HAAAYGBAAAQAEAOgBAAAWCgAAEBAQAAEA
+        BAAoAQAA/gsAADAwAAABAAgAqA4AACYNAAAgIAAAAQAIAKgIAADOGwAAGBgAAAEACADIBgAAdiQAABAQ
+        AAABAAgAaAUAAD4rAAAwMAAAAQAgAKglAACmMAAAICAAAAEAIACoEAAATlYAABgYAAABACAAiAkAAPZm
+        AAAQEAAAAQAgAGgEAAB+cAAAKAAAADAAAABgAAAAAQAEAAAAAACABAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAIAAAIAAAACAgACAAAAAgACAAICAAACAgIAAwMDAAAAA/wAA/wAAAP//AP8AAAD/AP8A//8AAP//
+        /wAAAAAAAAAAAAAAAIeHAAAAAAAAAAAAAAAAAAAAAAAAAAd8RsTEfEdwAAAAAAAAAAAAAAAAAAAAhGxH
+        d4iIx2xMdwAAAAAAAAAAAAAAAACEx3iPiIjo+PiHxHcAAAAAAAAAAAAAAAbHd2iOjufn7oiIh8xwAAAA
+        AAAAAAAACEV4ZiZo7Oznzm7uiIfEgAAAAAAAAAAAfGiOI2Nmjo6O6Ox+zoiERwAAAAAAAAAHx4iHYnpy
+        6Ofs7O7n5+6PxlAAAAAAAAB8aI7oanpyZ+jo6OjO7sjoh8cAAAAAAAfHiI6Ocno3pn6Ofn7ozu7IZ3yA
+        AAAAAAbPjo6I4nOnJyaO5+fu6M7uZnZAAAAAAHyIjo5+hienp6Zo5+fsjujoYmhlAAAAB0BgYERAUCBj
+        pzNo6MZCQEBAACBEcAAABAAAAAAAAAACenpmjgAAAAAAAAAAYAAAgAEBAQEhAhAANjYyhgAQEAECEBAQ
+        WAAAYzMzMzMzMzMzY6em6HMzMzMzMzMzdAAAwzMzMzMzMzMzNqZ4jhMzMzMzMzMzPAAHczkzOTOTOTOT
+        Yojo6HMzkzkzkzM5d3AMb4gzMzMzNzNqIAAABo6HJzMzM5M2dsAHz445M5M2JqemAAAABI6GejMzkzN6
+        d0AGf4gzMzMyYmJgMzMzM0jmNjMTMzM2KEAMiOgzMzk3iI8DEzkzMxaGpyMzMzN6Z8CGiI45MzM4iIYT
+        MzMzkzCGJyOTOTM3KGh8iIgzOTM4iOEzOTMzMzNIYjMzMzNqZ8eMiOczMzMX6BMzMzOTM5M2hiMzkzOG
+        aHeGj3YzM5M2djMzM5czMzMxaCEzMzfo+McMjiIzkzMyITM5MziHOTMzNmMzOTN2aEAGgmIzMzM1MzMz
+        M4iIMzMzMSOTMzMmKEAMdiczM5MwMzkzmI6Ogzk5MxMzMzNyZ8AHx6czkzMzOTMzjoiI5zMzMzM5M5N6
+        dnAIZ2MzMzOTMzMzj46OiHMzOTMzMzM2jHAAyCYzM5MzMzk2Zojo6OOTMzOTMzNidgAAdnIzkzMzkzNj
+        Jo6I6IdzMzMzkzMnxwAAhzOTMzMzMzN6Z+jo6O5zOTOTMzkzdwAAAxMzMzkzOXpyaIiOjo6HMzMzMzMz
+        EAAAAzMzOTM5MmImjo546M7sczkzOTOTcAAAAHdzMzd3hiYo6IZijo6Od3d3d4d3AAAAAAR3ZqaOiCam
+        jnpyZ+jn7u7u6IZAAAAAAAjHYnJo56Y2b2Knpifo7OzoiMdwAAAAAAB2hiemaCYmfnZ6c2Yn6OjohscA
+        AAAAAAAHyGJiKGJo6Go2Onpmjs6Ix3AAAAAAAAAAfIiGaGfo6Cenpzc26I+MfAAAAAAAAAAACGyGqI6I
+        52pzanqmeI5HcAAAAAAAAAAAAAZ3iI/iYnOnp6ciflxwAAAAAAAAAAAAAAB8bIh2JqYmImZ4fHcAAAAA
+        AAAAAAAAAAAAhsZ4d3eHh4fGyAAAAAAAAAAAAAAAAAAAAAjGxsZsbGyAAAAAAAAAAAAAAAAAAAAAAAAA
+        CIiIgAAAAAAAAAAAAAD///w///8AAP//gAH//wAA//wAAD//AAD/8AAAD/8AAP/gAAAH/wAA/4AAAAH/
+        AAD/AAAAAP8AAP4AAAAAfwAA/AAAAAA/AAD4AAAAAB8AAPgAAAAAHwAA8AAAAAAPAADgAAAAAAcAAOAA
+        AAAABwAAwAAAAAADAADAAAAAAAMAAMAAAAAAAwAAgAAAAAABAACAAAAAAAEAAIAAAAAAAQAAgAAAAAAB
+        AACAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAAABAACAAAAAAAEAAIAA
+        AAAAAQAAgAAAAAABAACAAAAAAAEAAMAAAAAAAwAAwAAAAAADAADAAAAAAAMAAOAAAAAABwAA4AAAAAAH
+        AADwAAAAAA8AAPgAAAAAHwAA+AAAAAAfAAD8AAAAAD8AAP4AAAAAfwAA/wAAAAD/AAD/gAAAAf8AAP/g
+        AAAH/wAA//AAAA//AAD//AAAP/8AAP//gAH//wAA///4H///AAAoAAAAIAAAAEAAAAABAAQAAAAAAAAC
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAgAAAAICAAIAAAACAAIAAgIAAAICAgADAwMAAAAD/AAD/
+        AAAA//8A/wAAAP8A/wD//wAA////AAAAAAAAAAB3dwAAAAAAAAAAAAAAAHRlyMfHRwAAAAAAAAAAAHx4
+        j46IiIx8AAAAAAAAAIR3Zo7n7u6Ih0gAAAAAAAfIhicn7n7O7OiMcAAAAAB8iOenpo5+js7uiMcAAAAI
+        yI6OJzYo5+fo7OZ2gAAABojo6Gp6dn6Ofs6GZ8AAAFBAQAQAJ6No5EAkACAHAAAAIAIQAQJ6Z2AAEAAQ
+        BAAHMzMzMzMzY2dzMzMzMzNwDDM5MzMzNyjo4zMzMzM3UAeIMzkzc3IAAHiHM5M5N2CM+DMzNiYgMzNO
+        diMzM3J4d44zMziIIzMTNeNjMzN6yH6IOTN4hjOTMzN2MzkzJnd4hzMzN3MzMzMxN2MzM4eMfIYzOTYz
+        Ezh5MzNjMzNud4hiMzMwMzN4hzMzEzEzcngGYzMzMzk3iOhzMzMzM3bAB2czkzkzN4iOgzkzE5MncAdy
+        MzMzM3JuiOczMzMzZ3AAMzM5MzNqiOjoczkzMzcAADOTMzNyd+jo7oYzM5MzAAAHcnOHYmiGZ47IaHeH
+        UAAACMcmeGam46Zn7u7ujIAAAAB+cmaKZ4ZzpyjsiMcAAAAAB3fihn6Cp6cuiIyAAAAAAACMdo6OY2N6
+        dofIAAAAAAAAAHaIYiamJnfHAAAAAAAAAAAAfIeHeHdnAAAAAAAAAAAAAAAIyMjgAAAAAAAA//w////A
+        A///AAD//AAAP/gAAB/wAAAP4AAAB+AAAAfAAAADwAAAA4AAAAGAAAABgAAAAQAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAIAAAAGAAAABgAAAAcAAAAPAAAAD4AAAB+AAAAfwAAAP+AAAH/wAAD//AAD//8AD///4
+        H/8oAAAAGAAAADAAAAABAAQAAAAAACABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAgAAAAICAAIAA
+        AACAAIAAgIAAAICAgADAwMAAAAD/AAD/AAAA//8A/wAAAP8A/wD//wAA////AAAAAAAAd8cAAAAAAAAA
+        AAd3iIiMcAAAAAAAB2Zo7O5ohnAAAAAAaIZ2fo7uyIwAAAAHh+MnbufO7oZwAAB36OdqN36OjOZ3AABA
+        QAADan5AAAAEAAcTExMwemgDMzExYAczMzMzJ44zEzMzcIeDMzY2AAGOMzM3aHjjEzdyMzNnYzEzZ8iD
+        M3hzMzMXYzM2d3jjM3czM5MzYzM4jHdjkzIzGIMzcxM2Z4ZzMxMziOczMTM3eAdjMzOTeI5zMzMycAcz
+        M5M2boiHM5M3cAgzEzNqiO7nMzMxAAB3N4dmhneOd+h3AAAGYmemhqZn7njAAAAAd24243o26IwAAAAA
+        B3iOenNqjHAAAAAAAAaGdmdncAAAAAAAAAAId36AAAAAAP/D/wD+AH8A+AAfAPAADwDgAAcAwAADAMAA
+        AwCAAAEAgAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAQCAAAEAgAADAMAAAwDgAAcA8AAPAPgA
+        HwD+AH8A/4H/ACgAAAAQAAAAIAAAAAEABAAAAAAAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAACA
+        AAAAgIAAgAAAAIAAgACAgAAAgICAAMDAwAAAAP8AAP8AAAD//wD/AAAA/wD/AP//AAD///8AAAAAd3cA
+        AAAAAHaOjowAAAB4Z25+yIcAAI6GNujuZgAAQAAndgBAUAMzMzZ3MzMweDM3IydzM3d4M3gzM2MzJ34z
+        czNTdjOHhpMxOIMzk2cGMzN+hzMzYAMzM2joczMwAHOGdn7n5wAAhmZ2o2h4AAAAeONnZwAAAAAAd3gA
+        AAD8PwAA8A8AAMADAADAAwAAgAEAAIABAAAAAAAAAAAAAAAAAAAAAAAAgAEAAIABAADAAwAAwAMAAPAP
+        AAD8PwAAKAAAADAAAABgAAAAAQAIAAAAAAAACQAAAAAAAAAAAAAAAQAAAAEAAAAAAAATDwgACxsFABgS
+        BwAADhMAARYdACUOCgA2FQ4AKhUUADwQEAAMIwsAGD8GABkkEQARMhUANigIAD8wDgAnIxQANioXAAAd
+        JwAMJy0AAiw6ADYvIQAuOCwANTMvACAwMQBFHhUAQT42ABpQGgAkWQIAI0sQACx0DAA1dwYAK3kYAD5+
+        HwATUC4AJF8kADhcLAAebDsAJX44AGxTGwBCfA4AUkQjAFpXOQABOUgAAkFPAAFDVgASSlYAGndJABdy
+        WQA2Zl4AKn1VAAFVcAA9WGwAEm5hABBzZQAEYXkAGmF5AAlzfQA/YHcAUk1OAHxRUwBRcEMAemZWAExV
+        YwBlYmEAnCwqAJ8wKwCMLzEAnjAwAKQ3KwCjOjYArEEsALJKLAC3US8ArEY3ALJMNQC4VTcAiG83AKtK
+        RQCrUUkAtVdHAK9UUwCyW1kAkXxAAK1kTQC7ZVQAn312ALhmYwC/cGUAu3l3AMVyVwDEeGkAwnx5ADeI
+        BgA3jRMAOJIXADWNKQA4myYAKogzADWYPgA5ozcAQ4sLAEmOEgBViRgATZIYAFaUGQBnmR8AW5ooAFeL
+        OQBmmyUAcZ8qAGiaNwB0oS0AZ6A1AHmmOgAbg18AIYZMADWeQQAkjVQAKptbADmsRwAuoFgAG4ZmAC6D
+        awAklWUAd5NTAHalSgBWgn8AfZ9hAHaZdwCIqTkA/LkeAMyfOADcoygA26k6AOerJgDssS0A/rwnAOKs
+        MwDvuj0A/78wAP7BNwCZnksAmZpWAK+OQgCzkkkAvJ9eAImsRACXsEgAiKhcALi3RQCtrV8AoLlcALK7
+        WQCtmnsAt5pzAIKlZgCapW0AmbhhAJuwfACjoWoAqLFpAKugdwDJoEEA3KxEAN+xTADEt1kA2rFWAOm5
+        TgDnulcAyoVrAMqIdQDQjnoAw5J2ANCQfQDBtmgA1L1tAOi/ZAC6wmgAvMVzAMvDXgD+xkYA/MpXAP/Q
+        XgDHxGcA2sVpANnNdgDpxWkA+8xjAP3QaQDnyXsA8ct3AOzRcwD91HYAAmiIAAd2iAAAbpMAB3GRABp5
+        kwAle4gARWyCAGR6iAAvgpMAR4aBAG6VigB5o5YAup2FAI6nhACYqYUAjKyaALihhwCttYUAurCFAKq4
+        lwC/v58AyImGAMqUiQDUmYgAzZSSANOckwDLo4YAz6yfANillwDfsqMA47+zAKnGgQC9xJ8AxMeMAN3H
+        jADFyZUA2suTAM3UlgDc15MA59OFAPzYhgDv3JsA+9uTAP3hnADLwqQA1sOkANnYpQDWzrQA7d6sAOfG
+        uADs1roA+N+yANfgtQD946cA/ui5ANrSyQDu08MA89zGAPvpxQD56dMA/vHVAP///wAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAA2tfX2gAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFxOQkJC
+        QkJERERBRE5ZAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANdOQkJCSlJc19ra11tSREFEQUbX
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADXR0ZQW976/vz39+3t7ff8/vTXT0RERNcAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAE5HT62VaOfsu6mlpIaGpKSoscHt/PNXREFGAAAAAAAAAAAAAAAAAAAAAAAAAADX
+        R0JY02VeXiiOp6SKiIiIiIeFhYWkqer481FBRNcAAAAAAAAAAAAAAAAAAAAAAFhHRdv+nl1jY2Afgry1
+        jY2MjIyJiYiHhYWp6vzXREFXAAAAAAAAAAAAAAAAAAAAVUVL8/jqlx5jeHhkXZS3tY2NjY2MjImDiYeH
+        irz34EZEUQAAAAAAAAAAAAAAAABYR07797+nsF1keHh4ZGWZt7W1jY2NjIyJiYODh4eo9/FXRFcAAAAA
+        AAAAAAAAANdHS/v3u6m2wW5eeHh4eGRdlMG1tY2NjY2MiYmDg4OHu2aVUkFcAAAAAAAAAAAAAEdK8/i7
+        sba2vbpdeHh4eHhkXW7AtrW1jY2MjImJg4ODqGddnU9EAAAAAAAAAAAAUEfe+L+xtry8vexlZHh4eHh4
+        eF5wwbW1jY2NjYyJiYODtmVeXZpGRgAAAAAAAABWBwYXFRERERERERUCCg0jeHh4eHhduLe1oycPDg4O
+        Dg4OEQICAgwICVkAAAAAAAAZAAAAAAAAAAAAAAAAAAAADXh4eHhhasGjAwAAAAAAAAAAAAAAAAAAAEMA
+        AAAAANgZEhISEhISEhISEhISEgUACnV4eHh4XbqQAAQFEhISEhISEhISEhISBUPXAAAAAEvExMTExMTE
+        xMTExMTExMTCMHh4eGRfXbKxMcTExMTExMTExMTExMTExDRGAAAAAEjExMTExMTExMTExMTExMTExXhk
+        ZWWUsuqwxcTFxMTExMTExMTExMTExDpEAAAAq0jExMTExMTExMTExMTExMTFfGQfoeS+u7G7gcXExMTE
+        xMTExMTExMTExMhEWQAAUEj54p/FxMTExMTCMnR3d3l4dQsAAQAAAQGRvLGvnyZ2NsXExMTExMN8YpxO
+        RgAASEz+7b7FxMTExMQ4IWF4eGRkHAAEBAQEBAQQp7e9gl94JcLExMTExMN4ZHFXRAAASFv+7L7FxMTE
+        xMQ3Hl1dXV0fAS3ExMTExMQrKbbqXmR4JcLExMTExMN4ZF3XRAAASK786r7FxMTExMQ3bOPw8PQaK8TE
+        xMTExMTEFE3pXWR4JcTFxMTExMN4eF2tRADZSN746unFxMTExMQ31vj49T4UxMTExMTExMTEwhOSgl94
+        JcLExMTExMN4eF3SRNeuSN/46unFxMTExMTC7vj4mhPCxMTExMTExMTExDcWr2VfJcLExMTExMNfX13S
+        RlyuSN/495XFxMTExMTCleXuGDfExMTExMTExMTExMQzKrlqI8LExMTExMeWgnDdQlzZSN78k17ExMTE
+        xMU3Hm87M8TExMTExMrKxMTExMTEM1OyG8LExMTExMe2wfjeQtcASN7hXV3ExMTExMQ3IB0zxMTExMTE
+        yubjxsXExMTExC6OIzfExMTExMpqamveQgAASdldXV3ExMTExMQ3JSvExMTExMTG5ezq08bExMTExMQi
+        G8LExMTExDldX12tRAAASatlYXXExMTExMQ3K8TExMTExMXV7Orq6s/ExMTExMTCK8LExMTExDlkYWtY
+        RAAATFpvYXjExMTExMTExMTExMTExNHs7Orqwb/MxMTExMTEwsTExMTExMN4X5VPSgAAqlCPXXnFxMTE
+        xMTExMTExMTEe/L37OrqwcG8y8TExMTExMTExMTExMN4XaJKWAAAAEytXWTExMTExMTExMTExMQ2XWVy
+        6+rBwcG9ucfExMTExMTExMTExDlfaK1CAAAAAExUJCLFxMTExMTExMTExDl1ZGFds+rBwby8t6bCxcTE
+        xMTExMTExDkbPU9GAAAAAK04xMTExMTExMTExMTExXl4ZF2T7MHBvby3traPwsTExMTExMTExMTExD9Z
+        AAAAAADExMTExMTExMTExMTEdnh4X3LswcHBwby2trW1fcTExMTExMTExMTExDQAAAAAAADGxMTExMTE
+        xMTExMQlZF1dXenBwemTmcG3tbW1izHExMTExMTExMTExMwAAAAAAAAAPkB/L3p6ejLNgdBoXWVllOrB
+        6WhfXbC3t7W1jYZ9fYB9gICBzck7PAAAAAAAAAAAAElbcl54ZGbqweqZZmVdaerqlF54YWWUu7e1jIyM
+        iYmDibXq+kpHAAAAAAAAAAAAAKtJqm9deF1xuOxyXWFfXXHqaV94eGRfZYK5toyDiYOMter7T0dcAAAA
+        AAAAAAAAAABaTKtvXWRdXWqyXWRhZYLqgl14eHh4ZF9dpo2JjIy16vtVR1UAAAAAAAAAAAAAAAAAWkyq
+        cl1dXV3pal1dmb3Ba2F4eHh4eHhfcLWMjbf3+lBFUAAAAAAAAAAAAAAAAAAAAFpMW9T2aF3pcG24vbe5
+        XXh4eHh4eHhkZbS3wfjfS0dVAAAAAAAAAAAAAAAAAAAAAACqSUzZcl3o7cHBwcFuX3h4eHh4eHh4X4L4
+        +6pHR1sAAAAAAAAAAAAAAAAAAAAAAAAAAExMWtz9+PiYZWhdeHh4eHh4ZGFlZZXeS0dKAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAACsSUlMqvOTXV1dXV9dX2VdZnKdrVVLR1sAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAKpMSUxarZuboaCgoZubq1pMS0urAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFtMSUlM
+        TExMTExJSEtYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADerKurrNkAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAD///w///8AAP//gAH//wAA//wAAD//AAD/8AAAD/8AAP/gAAAH/wAA/4AAAAH/
+        AAAH/wAA//AAAA//AAD//AAAP/8AAP//gAH//wAA///4H///AAAoAAAAIAAAAEAAAAABAAgAAAAAAAAE
+        AAAAAAAAAAAAAAABAAAAAQAAAAAAAAoIBAAcCwkACRcGABIXBQAAExkAJBsJACQcEwAkIR0AAiYtABkv
+        LgAeMjYAXyIkABxJCwApYw0ANW0SABpPIQANTj4AIGQkACp9NABYRBcARUgxAGpGPwB6YiwAB05VAB9X
+        XgAee0cADWNZAANXawAAV3QALF52ABZmYAADYXgAHm97AAhxegAmbnEASU5FAHlFRQBWe18Af3RLAJws
+        LACfMzIAojUtAKc7LgCpPi8Aozk3AKxCLQCySS4ArEQzAKZBPgCqRDkAr0s7ALJMNAC6VzcAh0hIAINb
+        TgCnRkUAqUZDAKtJQwC4XUkAr1ZWALJbWQCUdE0AvWRNALdhVwC2Yl8AuGVeAKFwXACwdV8AhH9uALZk
+        YgC6amUAumxrAL9wZQC/f2MAtXdrAL5xawCyf2wAvXJwAMFpTADBbFUAw3NYAMBxZADGemQAxHpsAMl+
+        aADCenYAwXt5ADeGAAA3iQYAPIgFADSECAA7gw8AN4oMADuLCwA2jhIAPI4SADiTGAA4miYAKIY0AC+R
+        NQA2mDAANZY/ADabOAA5oC8AOqc+AEWMDABEjBMASIkWAEaRFQBUkxoAV44iAFiXIgBCjDYAYJAiAGad
+        KAB/misAZZ02AHGWOQB5pDUAJIRAADKFQQAql1UAMJ9RADqrRwAuoFkAMaRUACaWYABimkQAfpNAAHSd
+        QQB6mEcAZ4VqAIalNQD7uB4A3KUuAN+sOwDtriMA4KcqAOOqLADxsSEA/rskAP6+LADjqzEA7LQyAP/A
+        MwD/wToAiJlHAImWVwCZnFwApp9HALGQRwCrjF4ArZtWAIyvVQCKtFwAnLZUAKaiTwCmtEkAsrdKAKW3
+        VAC4u1IAs7xZALq6XACaj2EAt4diAJa2ZwCup2YAuK5jAKayYAC/tm4A3K1CAMi7RgDes1UA6rpMAOm9
+        WQDKgGgAy4d0AMOxYADlvGYAxsFZAP7EQgD/x0gA/chLAOzIVwD8ylcAycNhANzGaADJyHMA1sd1AO3A
+        YAD+zmIA/dFrAO3MegD2z3YA6NF4APzUeQACZ4cABXOJABZ2jQAAbpMABHCSAC1rhgA8eYUAPHeQADKB
+        igBSj4wARY2WAGWalQB3oJAAioiKAImpkwClsoQAtreDAMuOigDOkIQA0paFANSZhQDUnI4Ay5GSANKc
+        kwDIqY8A1qGRANmmlgDfsJkA2rymAMnPkQDlyoIA8c+CAOvSgwDz1IIA/taDAPXVigD+2owA69mWAPTX
+        kwD62pIA+dyZANvLpQDnwawA6MSpAOzJqwDk3KkA6siwAPLXtwD23bMA9t67AO/hpwD74qYA/eSsAP7m
+        sgD75roA/ei4AOHbxAD+68EA////AAAAAAAAAAAAAAAAAAAAV0hIVwAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAEwqKjpCTExBOSgoSAAAAAAAAAAAAAAAAAAAAAAAAEAyRN32+evk5Oj49d89KDwAAAAAAAAAAAAA
+        AAAAANwrTINgb7Krj4+Li4eIr+zwPSjbAAAAAAAAAAAAAABULN77XGZna6G1kpGRjo2Jiq7t2ihIAAAA
+        AAAAAAAAVDDv7LNyfHx8bru1kpKRjo6NjI/C4ThIAAAAAAAAANww7+ivuaJhfHxpbbS5kpKRjo2NhpCF
+        lDHbAAAAAAAALt/svr+/5mF8fHx8YaG5tZKRjo2NjXRdpCkAAAAAABYCCAcGBwYHAwMQfHx8bcCrFAYG
+        BgYGBAMDAjYAAAAABwUFBQUFBQUFBQFjfHxonxcBBQUFBQUFBQUFDAAAAFPIyMjIyMjIyMjIxXtpYmGf
+        p8XIyMjIyMjIyMgeRgAAL8jIyMjIyMjIyMjGe2yp48Oqx8jIyMjIyMjIyMopAAAv/dXJyMjIIWN9fnwN
+        AAEAAZe+vXF6IMjIyMl+gDgA2j/+5MnIyMgbYWFhDgkcHB0cCq26YXwcyMjIxnxtRtaxsPrkycjIyB/i
+        8u4LxcjIyMjFFaNiaSDIyMjJfGFLTlOx+eTJyMjIy/v1JCDIyMjIyMggJ3BlHMjIycZiYU1GU7H7m8jI
+        yMgjpkUdyMjIyMjIyMgcmXIcyMjJx6ycV0exsaZeycjIyBsPHMjIyMjT0cjIyMgZkxzIyMnHhZxXTN6w
+        XmHJyMjIHBjIyMjI0OzozsjIyMgRHMjIycZhbUTbAE9ufMjIyMjFycjIyM/r7ObBzcjIyMXFyMjJxnx1
+        MwAANYFnyMjIyMjIyMgipurpxMS7x8jIyMjIyMnGYpQsAABTPhLIyMjIyMjIyWRhcOnEwL+oyMjIyMjI
+        yckOQ0IAAADFyMjIyMnJych6fGG8xMS/ubmUyMjIyMjJyMgeAAAAAMnIyMjIycnIGmhhnMTkosK5t7Um
+        yMjIyMnJyMwAAAAAADeEeH951NVwXlrD53NhhcC3kpCdnZad1NIlAAAAAAAA2U92aGGg6HdhYYW9YXxi
+        bZ64kY2NjsDxNNcAAAAAAAAAsFF2YV1tnGFhnsNefHx8aG23jpHA8TNEAAAAAAAAAAAAsE+Vm168bp+/
+        n2J8fHx8Yp+57OA0UwAAAAAAAAAAAAAA2TWld/fpu7RufHx8fHxoc/VULtcAAAAAAAAAAAAAAAAAAE81
+        sfF1WV1iYmFhcJOYND8AAAAAAAAAAAAAAAAAAAAAAABTNU+lpZmYpaVPNVIAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAANmwUVGw2gAAAAAAAAAAAAAAAAD//D///8AD//8AAP/8AAA/+AAAH/AAAA/gAAAH4AAAB8AA
+        AAPAAAADgAAAAYAAAAGAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAAYAAAAGAAAABwAAAA8AA
+        AAPgAAAH4AAAB/AAAA/4AAAf/AAAP/8AAP//wAP///gf/ygAAAAYAAAAMAAAAAEACAAAAAAAQAIAAAAA
+        AAAAAAAAAAEAAAABAAAAAAAABg8DAAQMDAAXCAYAGQkJAAkQBAAHFggAGxQEABASCAAaFQoAGxgUADs1
+        HgANNT0ACD07ABpNIAAiQCUAVEEWAHRpPAAARV0ACVJWABBeUgATZ08AD2BSABJhXwAaZF8AHnFdAB16
+        WwAicEwALmVdAC92WgAIVW0AF1poAANYcgAAXXoAD2liAAxqbAAHbXkAD3x8AHBMVgB3WlcAWVpgAKM9
+        PQCvSjwAsE08AI5OUgCZV1MAp0VFAKlIRwCsTksAs1hPALleSwCvVFMAr1ZWALJaVwCyW1kAs11ZALVf
+        XACYYV4AlWpbAJF7UAC9YEIAs3hPAK5mVQC3YFUAu2VTALBrVwC2YFgAtWBdALR1VQC6bGkAoHNkALxx
+        bwC+c3AAwGlKAMJuVADDcFcAwnBYAMZ6ZgDJfGQAyH9rADSGCAA5kRUAOZQaADWMJQAzjysAN5cnADqX
+        IAA4mSMANpgsADmfLgAxjD4ALpI7ADSaNgA3nj0AOaEyADegOAA5pTsAOqg/AECLCgBBhxAATpMWAEaX
+        HwBLlh4ATJUfAFSWHQBEmCIASpkiAFGbJABcmiMAZ54pAGWbNQBumD0AdZI5AHKRPQB4kT0AZqAsAH2k
+        LwBmoDUAKpFGAC+YRQAxmkEAOqtEADOjTgA5rEgAfotFAHiTRABshFsAU4t/AICpPAC8pz8A1a45AO+x
+        JADxsiIA/rshAPu6KAD+vigA/78tAOauMgDirDQA4a04APi+OAD+wDEA/sE1AP/COgD+wjwAjodCAI+I
+        RgCMhk8Ajo5MAJKATgCUjUsAjJNKAIyTUgCwgVUAgKNCAIGtTgCSrkQAmK9DAI+wVQCNsFgAoqZKALyn
+        QACrtkoAtbZCAKK2UgC3vFUAiYJsAJeZYACSnm4Ao6NnAKSzYgCnu2UAuLlkALy0aAC3t3oAtbl8ANWx
+        SADhsEQA5rZMAMqAagDKiXwAzIx+AMu3YADEvWgA1rxpALvAYADNwFAA18RZAP7FRADyx04A/slOAOLF
+        VADkx1kA78RbAPfKVwD/zFIA9MVbAM7FZQDXy3UA7sNgAOvDZADpx28A/s5jAPXPaAD6z20A8813APDK
+        eADyzn4A/tRyAPrUewAAY4MAD22FAAFtjwALe4UAA3KMAA10jQASdY4AAG6TAARwkwAMdJMALHmAACJ7
+        jAB9n4MAaJKQAJ6OhwCPrJcApLOMALm6gwCyu5MAiK67AMuQjgDRmoUA1JqJANafkQDYoI0A26aPANyp
+        jwDfrI0Aw7aJAN2rkADkuJQA5ryWAOO3nADlu58A6L6YAM7KhwDPxo0A7NOBAPLThAD91oEA89SIAPvZ
+        jgDsyqwA/uOhAP3kuAD///8AAAAAAAAAAAAAAEhDOEcAAAAAAAAAAAAAAAAAAAAAADFDte/w8O+1MC8A
+        AAAAAAAAAAAAAAA/QXFuuLGLiouyz/A4MwAAAAAAAAAAACvq9VNdZ7+PjoiIg4rN5ykAAAAAAAAAK/LP
+        yGV7YWzAvI+IiIWEx6cuAAAAAABA6s/Hypxhe3tpu7yPjYiFjWOTMwAAAAADCgkHCQgGDnthc8cQBwcH
+        BwEFBAAAACcSEhISEhISDXt7UrYMEhISEhISEiwAACjZ2dnZ2dnZ1Viat8nd2dnZ2dnZ2SYA6ef22dnZ
+        GXd6VAYCAgvBrFsj2dnZd5XmT/P42dnZG5ufD9LZ2SERnWEi2dnWYXxFTPz429nZ3/6mIdnZ2dkglFYi
+        2dnWXn04S/ye2dnZHage2dnb29nZH6AW2dnYuu41s6lQ2dnZFRPZ2dvk4tnZ2RwU2dnXZJhF6pFf2dnZ
+        IdnZ2eH7+d7Z2dkh2dnWXpXmAD1V2dnZ2dnZGqv70cx/2dnZ2dnWUj8AADoX2dnZ2dklYGf30MrH3NnZ
+        2dnZGC0AAOXZ2dnZ2SRfUcbRxcq+sNPZ2dnZ2QAAAABGfnZa46piaPmAVqLCj4Khoa3gOQAAAAAASXFX
+        baRSUbloYV5ro4iIw/QrAAAAAAAAAEmXdZxsostpe3t7ar3Q7ysAAAAAAAAAAABLma79pXRhe3thUq5N
+        MgAAAAAAAAAAAAAAADxOlnFvb3KSRDIAAAAAAAAAAAAAAAAAAAAA6E5LS03oAAAAAAAAAAAA/8P/AP4A
+        fwD4AB8A8AAPAOAABwDAAAMAwAADAIAAAQCAAAEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAABAIAA
+        AQCAAAMAwAADAOAABwDwAA8A+AAfAP4AfwD/gf8AKAAAABAAAAAgAAAAAQAIAAAAAAAAAQAAAAAAAAAA
+        AAAAAQAAAAEAAAAAAAAEFQ8ABRQQAA0WEAASFxAAERgVABEZGAAuHx4AAis4AAQsOABEIiQAH10nACFe
+        IQBsViIAHX1UACN5RQA8eE0AP31QAARdbwAEX3MAB1p0ABFdcAAZfWAANWxsACNldwB+e0AAp2pPAKx6
+        SwC4ZV4Au35dALVuZgC6amcAu29qAL1wbwC/dHAAvnV0AMh8ZgDIfmkAwHh0AD2VIgA4miUAP5okADSa
+        NgAykzkAOqAxADmjNABRlR0ARZkoAFqCOgBDnT0AYoA6AHSXOgBAoDIAS6EwAFShMABfpDIAWKA3AGKh
+        LwB2pDQAfqo+ACCHVgA4okEAOqlBADqsRgA6rUgAGoZrAECTTQBvgkwAdJZBAHeQZABgjnoAgYw/AIyq
+        MgCDrD4Akaw/ALurLgDTrjcA8rQmAP67IgD+vi0A/8E2APbAPgD/wjsAg45JAKePSgCKrkAAhalKAJ60
+        SwCerlQAobJDAKS0SQC5t0QArrZXALGRewCWtmEAqqxwALy9eADStEkA7r1OAOu+WgDrv14AyoFqAMqC
+        bgDKh3QAzIt0AMmHfADPjHgAz5V2ANeefwDcp3cA3qV5AO3FTwD2xUkA/spSAM/IcwDpymUA6ctoAPLH
+        aQDrxHEA7dJ7AP7TdAACb44AFWqKABtsigADcY4AAG6SAARukAAAb5QAAnGRAAxzkAARdpQAHnuSACN+
+        kwCGpYwAxYOEAMyMggDTloIA2qKCAMC1kQDNwoQA1MmSAOTHggDqw5UA9tuZAOLUogAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAP///wAAAAAAAAAiHx8hAAAAAAAAAAAAABpTjWRkdm0cAAAAAAAAh2xYPTlwUE9NYmuG
+        AAAAAIl1cyw/N29ST05LGQAAAAcGBQUBC0BVDQQEAwIKAAB9fX19fUE3XEZ9fX19egBmkH19DyoMCAhU
+        VhZ9gDEiJY+Af4WKFH19FTMOfYAoHmZefX0RGH2Eg30XEX2BWiBqJ319FICCjIuBfRR9gC8mADB9gH+A
+        QnJ4X319fX0yAAB9fX9/PDZ3dHFFfX19ewAAAEMrYC46VzVbUUxhXQAAAACIRy47WUlAP0hxbmkAAAAA
+        AAAbjkooLDREJQAAAAAAAAAAAABqHR1nAAAAAAAA/D8AAPAPAADAAwAAwAMAAIABAACAAQAAAAAAAAAA
+        AAAAAAAAAAAAAIABAACAAQAAwAMAAMADAADwDwAA/D8AACgAAAAwAAAAYAAAAAEAIAAAAAAAgCUAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAChMSsCoDErHKAwK0ifLytqny8rgZ4uK4yeLiuMnS0qgZ0t
+        KmqdLCpInCwqHJwrKgIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACiNCsIojMqT6EyKp+hMiveoDEq/aAxKv6gMCv/ny8q/p4v
+        Kv6eLiv/ni4q/p0tKv6dLCr/nCwp/ZwrKd6cKyqfmyopT5sqKggAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApDYrHaM2K42jNCvoozQr/qIzKv6hMiv/pjw1/rVf
+        Wf7Cenb/youG/s6Tjv7Nk47/yYqG/sB4dv6zW1n/ojc1/pwsKf6cKyr/nCsp/pwqKuibKimNmykpHQAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKU4KxGlNyuQpDYr96Y7MP+wUkn/wHZv/9Sh
+        mv/t0cP//vHV///twv//6LD//eOk//3gnf/84Jz//eKh//7nrf//7L///vDS/+zQwf/OlJD/q0xK/5ws
+        Kv+cKir/myoq95sqKpCbKioRAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApjkrUKY4K+WmOi7+slRK/sGM
+        fP6LoVz/TpMc/s3Ulv742pT/7sdu/uW6Wf7fsUz/2qtE/tioP/7Ypz7/2qk//t6uRf7ktk//7MJg/vbR
+        ef7+4pz//ezF/ubGuf+5aGf+nCwr/psqKv+aKSnlmikpUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKc6KwSnOiyRpjkr/aY5
+        LP+8amD+rLSD/kSNEP43iwv/NYkW/kJ8Dv6Znkv/2rBX/t6qOv7krDH/6a8v/uyxLv7tsSz/6q4p/uWq
+        J/7fpSb/2qIo/tqkLv7frD3/7L9X/vvXgf/+6rj+58i7/q9UU/+bKin+mikp/ZspKpGaKCkEAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqDwsEag7
+        LLmoOyz/qT4v/9ObkP/979T/mbhh/zWFD/81lT7/NZQ9/zWNKf82gAT/iqc5/+3Oaf//xUL//8E4///B
+        Nv//wDP//78w//+/Lf//vir//Lsn//KzJP/nqiL/3aMm/92nMv/rvFD/+9iD//3rxP/Nk4//nS8u/5sq
+        Kv+bKSq5mykqEQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AACpPSwRqT0ryKg8K/6vSjv/5sS3/v/quf/21Ib+ra1f/jJ3Bv43n0L/OqpH/jqtSP45ozX/N4sJ/p6y
+        R/7/zl3//sRB/v7CPP7/wjn//sE2/v7AM/7/vy///r4s/v69KP7/vSX/+7ki/u6vIf/hpiX+4aw2/vLH
+        YP/+5aj+47+z/qU+Pv+bKyv+mykqyJsqKxEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAKo+KwSqPiy8qT0r/rBOPv7v1sb//uWr/vDJc//itVb+175u/jmEAv46qT//Oq1I/jqt
+        SP47rkn/OZwp/kGKCP60u1b//tFm/v7GRv7/wz///sI8/v7BOP7/wTX//sAx/v6/Lf7/vin//r0l/v+8
+        Iv/8uSD+7a4g/uKpK//su07+/eOi/tbOtP+0YmH+nS4u/psqKrybKioEAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAKs/LJarPyz/sU08/+/Xx//+46f/7cVu/+S2Vf/0wlT//tV4/26f
+        K/83jg//O61I/zuuSf87rkn/Oq1I/zmgMP84iAT/mLBG//zUcv//ylD//8VC///DPv//wjr//8E2///A
+        Mv//vy7//74p//+9Jf//vCH//7sf//e2H//mqyf/6cJr/0uOEf+HpFv/slxb/5wsLP+bKiqWAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAq0ArVatAK/2tRDH/6Me5/v7mrv7ux3L/6Lta/vnI
+        Wv/+zFv+/tBm/t7Pev43hwL/OqtE/jqtSP47rkn/Oq1I/jqtSP46pTr/N4oI/mydKP7s0XP//spR/v7G
+        RP7/xED//sI7/v7BN/7/wDL//r8u/v++Kf/+vCX+/rsh/v+7Hf/8uR7+67tN/lWJGP83hgH+mqVt/qtN
+        TP+bKir9mysrVQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACINCIVrEEs56xBLP/Xo5b//+u9//PO
+        fP/rvl///Mtf///OYf//zmP//9Bn//zbjv8+iQb/OqY6/zuuSf87rkn/O65J/zuuSf87rkn/OqpD/zeP
+        Ef9zoS3//tR0///IS///x0X//8RB///CPP//wTf//8Ay//+/Lf//vSj//7wk//+7IP//ux7/+8xW/0GB
+        CP82jR3/PYoI/6+be/+jPDz/mikp54YkJBUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABeJBiXNhUO/iUO
+        Cv41My//Ni8h/jIpFv40KhT/NiwV/jYsFf82LBb+Ni0Z/jMuH/4MHQD/DCML/hEyFf4gXyj/NqFD/jqt
+        SP47rkn/Oq1I/jqpQf43iQX/xcNl/v7OXv7+x0v/zJ84/mxTG/4/MA7/NikL/jYoCv82KAn+NigI/jYo
+        B/82KAb+NisS/g4dAf8LHwr+Cx0C/hkkEf8qFRT+PBAQ/ockJJcAAAAAAAAAAAAAAAAAAAAAAAAAAIEz
+        IyJBGRD5AAAA/gAAAP4AAAD/AAAA/gAAAP4AAAD/AAAA/gAAAP8AAAD+AAAA/gAAAP4AAAD/AAAA/gAA
+        AP4AAAD/ETMV/jinRv47rkn/Oq1I/jqtSP45miX/Ypoi/v3We/7JoEH/GBIH/gAAAP4AAAD/AAAA/gAA
+        AP8AAAD+AAAA/gAAAP8AAAD+AAAA/gAAAP8AAAD+AAAA/gAAAP8AAAD+AAAA/pEnJ/mQKCgiAAAAAAAA
+        AAAAAAAAAAAAAKFDLpU/IRv/ABoi/gAeKP4AHij/AB4o/gAeKP4AHij/AB4o/gAeKP8AHij+AB4o/gAe
+        KP4AHij/AB0n/gAWHf4ABQb/CBkK/jejRP47rkn/Oq1I/jqtSP46qkH/N4cC/tXLcv6vjkL/BgUC/gAH
+        Cv4AGCD/AB0n/gAeKP8AHij+AB4o/gAeKP8AHij+AB4o/gAeKP8AHij+AB4o/gAeKP8AHSf+ABYd/owv
+        Mf+YLCyVAAAAAAAAAAAAAAAArEYuD69GLfAFa47/AG6T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+        lP8Ab5T/AG+U/wBvlP8Ab5T/AG6T/wBtkv8AZIT/F3JZ/zmrSf87rkn/OqxG/zmiNP84lBn/N4cC/77C
+        Zv/pw2P/MGFe/wBniv8AbpL/AG6T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+        lP8AbpP/AG2S/z1WbP+bKyrwmysqEAAAAAAAAAAAsEYsXLBGLP4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBu
+        k/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/B3eJ/jepTf44mSL/N4kF/kWN
+        Df6Mrkn/vcNs/vvYhv7RvWz/DnSQ/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBv
+        lP8AbpP+AG6T/gBvlP8AbpP+AG6T/j9gd/+cLCv+nCsqXAAAAAAAAAAAsEcsqrBHLP4Eb5L/AG+U/gBu
+        k/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/AG6T/gBvk/4Ec47/IZNp/jij
+        P/4yeQD/qLFp/t3HjP7kxH7/5MBv/ui/ZP7wyGb/c5l8/glykf4Ab5P/AG6T/gBvlP8AbpP+AG6T/gBv
+        lP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/kVsgv+hNjT+nCwqqgAAAACxSC0FsUgt6bFH
+        Lf/a0sn/vcSf/5+ug/8GcZL/AG+U/wBvlP8Ab5T/AG+U/wBvlP8HaYj/K3tT/yGGTP8nmGL/KZtf/y6g
+        WP82qU7/OKE2/xg/Bv8DBgD/CQgG/wkIBf8JCAT/CQgE/xMPCP+zkkn//c1i/+fDYP/Btmn/m7B8/yV+
+        OP8ijFj/Em5h/wBpi/8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wZ2i/8omF//Kogz/4KlZv+oRUL/nCwq6Zws
+        KgWxSC0osUgs/rlZQP7+9N///N2X/ubKfP4JcpH/AG6T/gBuk/4Ab5T/AG6T/gBvlP8JY33+Pn4f/jiX
+        H/46rUf/OqtD/jqnPv44mSX/JFkC/gIJBf4ADxP/AA8U/gAPFP4ADxT/AA8U/gAOE/4nIxT/27JW/v7N
+        Xf7/03H/h6o8/jiQE/86rUj+H24//gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5h/86rEn+OJsp/mOg
+        N/+2Y2D+nSwq/pwsKiiySS1Wskks/sd6Zv7+8ND/+9qP/ufLfP4JcpH/AG6T/gBuk/4Ab5T/AG6T/gBv
+        lP8DYHb+LHQM/jeJBv43iAP/N4cB/jaGAP47dg7/ChQJ/gBEWv4AbJD/AGyQ/gBskP4AbJD/AGyQ/gBr
+        jv4AOUz/UkQj/vLEXf721oH/QosI/jmjNf86rUj+H24//gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5
+        h/86rUn+OaM3/j6KCP/Fh4P+ni8s/p0tKlazSi15s0ot/9KUgv/+7MT//NmK/+jMff8JcpL/AG+U/wBv
+        lP8Ab5T/AG+U/wBvlP8DYHb/V4s5/8DMjP/W16L/3dqo/+vatv9BPjb/ADdJ/wBskP8Ab5T/AG+U/wBv
+        lP8Ab5T/AG+U/wBvlP8Aao3/Ay47/4hvN//u04D/OYcC/zqkOP86rUj/H24//wBlhv8Ab5T/AG+U/wBv
+        lP8Ab5T/AG+U/wl5iP86rUn/OqpD/zeGAf/Alof/oDEv/50tKnmzSi2Qs0os/tmkk/7+6r3//dmJ/ujM
+        fv4JcpL/AG6T/gBuk/4Ab5T/AG6T/gBvlP8IYnz+v7+f/v3kt/7+5Lb/+N+y/ndrVf4CKzn/AGqO/gBu
+        k/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5P/AGWH/g8qLv68n17/i6tA/jiQE/86rUj+H24//gBl
+        hv8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5h/86rUn+Oq1H/jeIA/+6nYX+oDQx/p4tKpCzSy2cs0ss/t2t
+        nf7+6bn//dqL/ujRjv4JcpP/AG6T/gBuk/4Ab5T/AG6T/gBvlP8NZYD+y8Kk/v3mvP7947f/q5l7/gol
+        Lf4AZYf/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBggP4uOCz/wrZn/kOM
+        Cv84lRv+H208/gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/ghzff83jA3+OJUd/jeHAv+4oYf+oTUx/p4u
+        K5u0TC2dtEst/92unf/+6rz/+uGh/4yvXP8EcI//AG+U/wBvlP8Ab5T/AG+U/wBvlP8NZYH/fZ9h/8TP
+        lP/Ww6T/IDAx/wBffv8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+        lP8AVXH/Wlc5/9rHb/9ZlRr/HV4i/wBlhv8Ab5T/AG+U/wBvlP8Ab5T/AG+U/yB7if+4t0X/iak2/2uh
+        M//PrJ//oDMu/54uK520TC2StEwt/tqmlf787sv/ha1K/jKEDP4Cb43/AG6T/gBuk/4Ab5T/AG6T/gBv
+        lP8FYXn+LXUN/meaN/5HTkn/AFZz/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG+T/jiHk/4rgJL/AG6T/gBu
+        k/4Ab5T/AG6T/gBuk/4AbpP/A01k/pF8QP/CwV/+H1oa/gBlhv8AbpP+AG6T/gBvlP8AbpP+AG6T/ih9
+        h//3y1X++9Vy/v7ptv/UoJv+nzAr/p4vKpK1TS18tU0u/tiikv6pxoH/N4YA/jKEDP4Cb43/AG6T/gBu
+        k/4Ab5T/AG6T/gBvlP8DYHf+K3kY/iNLEP4CTGT/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5P/LIGU/trL
+        k/7Jw43/HHqS/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG2R/hJKVv+cmlD+KV8h/gBlhv8AbpP+AG6T/gBv
+        lP8AbpP+AG6T/id+jf9nmR/+Ypoh/luZI//Snpr+oDIs/p8vKn21TS1btk8w/9Scif84hgH/N4gE/zKF
+        D/8Cb47/AG+U/wBvlP8Ab5T/AG+U/wBvlP8DYnr/HWIz/wFDU/8AbpL/AG+U/wBvlP8Ab5T/AG+U/wBv
+        lP8YeZT/xsSW//7akf/92Ir/r7aI/w50kv8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBrj/8LRz7/GE4c/wBl
+        hv8Ab5T/AG+U/wBvlP8Ab5T/AG+U/w10f/82hwT/OJAS/zmHA//JjYj/oTIs/6AwK1u1Ti4utk8v/s+J
+        dP48iQb/OZwp/jWjRv4CcJD/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AXHn+AkFP/gBskP4Ab5T/AG6T/gBu
+        k/4Ab5T/AG6T/gtzk/6quJf//NqU/v3Zjv7+14f//NWA/o6nhP4EcJL/AG6T/gBuk/4Ab5T/AG6T/gBv
+        lP8AZ4r+AztD/gBlh/8AbpP+AG6T/gBvlP8AbpP+AG6T/ghzfv85ozf+OZ4s/lycLv+7bGf+oTIr/qAx
+        Ky62Ti4Itk8u7cNuU/5snDv/OJkj/jWoT/4CcJD/AG6T/gBuk/4Ab5T/AG6T/gBvlP8Aa4/+AGyQ/gBu
+        k/4Ab5T/AG6T/gBuk/4Ab5T/BXGU/oysmv772pb//dqQ/v3Yiv7+14T//dV9/vfQdv5rloH/AW6T/gBu
+        k/4Ab5T/AG6T/gBvlP8AbpP+AGqN/gBtkf8AbpP+AG6T/gBvlP8AbpP+AG6T/gl5h/86rUn+OJMX/oSp
+        W/+uTkf+oTIr7aEyKwgAAAAAtk8us71fQf+Wm1n/N4wM/zWoTv8CcJD/AG+U/wBvlP8Ab5T/AG+U/wBv
+        lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8AbpL/LoNr/+3erP/94af//tuR//7Xhv/+1oD//tR5//7S
+        cv/vy23/R4aB/wBuk/8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wl5
+        h/86q0X/N4cD/6ugd/+nPjb/ojMrswAAAAAAAAAAtk8uZrhTM/7BkXD/OogE/jWfP/4CcJD/AG6T/gBu
+        k/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/AG6T/gBuk/4Qc2X/NYUK/j6JB/5zpDj/79yb/v3X
+        hf7+1Hv//dN1/v3Rbv7+z2f/3cBl/iZ3g/4AbpP/AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBv
+        lP8AbpP+AG6T/ghzff83jA7+S5IZ/sOEe/+jNi3+ojQrZgAAAAAAAAAAtlAvFrZQLvWtZE3/OFws/xNN
+        LP8AbY//AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wp1gP8znUD/OZwp/zmf
+        Lf83hgH/vMVz//7XhP/+03b//tJw//7Qav//zmP//81c/8KwXv8Pbof/AG+U/wBvlP8Ab5T/AG+U/wBv
+        lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wZpgv8YSRr/UXBD/6tRSf+iNCv1ojUrFgAAAAAAAAAAAAAAAKtS
+        NKUaYXn/AGyQ/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBuk/4Ab5T/BG+H/i+e
+        Vf46rUn/Oqg//jeIBf6HrUf/99yW/v3UeP7+0nD//tBr/v7PZf7/zV7//stY/v7KUv6bm1r/BWyM/gBv
+        lP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AGqN/kxVY/+dOC+lAAAAAAAA
+        AAAAAAAAAAAAAGZcWTAAb5T/AG6T/gBuk/4Ab5T/AG6T/gBuk/4Ab5T/AG6T/gBvlP8AbpP+AG6T/gBu
+        k/4Baof/J45R/jqsRv46rEX/N48R/n+oP/793ZT//dR5/v3UeP7+1n7//tR1/v7OYv7/zFn//spT/v7J
+        Tf76xUf/a4FZ/gFsj/8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/gBvlP8AbpP+AG6T/j1Z
+        bP1yR0owAAAAAAAAAAAAAAAAAAAAAAAAAAABbpLxAG6T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+        lP8Ab5T/AG+U/wFskP8cbjj/OaM3/zeKCP83iAT/O4gE/+PUiv/+1Hf//tV6/+fUhv+KrEP/sLxe//7V
+        eP//y1X//8lO///ISf//xUP/77o9/z1rX/8AbZL/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+        lP8Ab5T/AG6T/yhgebUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA3ZHMsdllO8GViYf5Wgn//GndJ/huD
+        YP4cimz/G4Nf/ip/WP95oI7+eZuA/pKlh/5Njxf/N4oI/keODv45hwL/kLBM/v3aiP7+0nD/6NSE/k6R
+        FP44kRT/OIcD/s/IbP7/0Gb//spS/v7GRP7/wz7//sI5/tqqNP9+j1f+eZFc/nmRWv95kFj+eZBZ/nmS
+        X/95mXP+eaae/mR6iP9dTFT+dEdJ8EhWZSkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApVM3abhT
+        MP7Hel//eZ1F/jeMC/46qkL/OaI0/keNDf/12Yz+/tN0/v7Xgf6zwGj/R40O/j2JBf43jg//VpQa/v3b
+        jv7/1n3/k7BJ/jiPEv46rUj/OJgh/kaNDP6cskj/4sxs/v7NWv7/xkT//sE2/v+/MP/+viv+/r0m/v+8
+        Iv/+vCH+/r4p/v/IRf/+3In+7tK//qtENv+mOSv+mT0zaQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAt1EvArhRLq26VjT/x4Vp/2aZNP83jQ3/OqlA/zeOD/9pnSn/x8Zt//vckP9woC//N4gF/zme
+        LP84lRz/O4gD/2ecJ//83ZH/WJUb/ziUGv86rEb/Oq1I/zmfLf84kBP/Q4sJ/4+rPP/Vxl7//8tS//+/
+        Lf//vSf//7wj//+8I///vyv//8hG///agv/14Mj/slNF/6g7LP+nOiytpjksAgAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAALhSLw+4US7Nu1k4/smLb/5omjb/N4wL/jmgMP83jQz+N4cC/mCZ
+        If68w2n/OIcD/jmiNP45mST/QosJ/oysQP7+2of/g6g6/jeHAv46qUH/Oq1I/jqtSP46rUj/OaI0/jiS
+        Fv45iAP/x79U/v/DOP/+vSX+/r0n/v/BMf/+y07+/tyJ/vbhyP+3XE7+qDwr/qg7LM2nOisPAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4UjAYuFEu1rtZN/7KhWv/eZ5G/jeG
+        AP87iAX+N4YA/j+KB/7o1IP/YJkh/jeNDf43iAT/srxZ/v7Sa/7+1Xb/X5gf/jmcKf47rkn/Oq1I/jqt
+        SP47rkn/Oq1I/jqtSP44mCH/eqIr/v/LT//+vy7+/sU8/v/QXv/+4pz+79TA/rVWRv+pPSv+qT0r1qg8
+        LBgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAuFIwGLhR
+        Ls66VjT/x3le/7qwhf/X4LX/UZMZ/zeGAP/j1IT/daMy/2mdJ//EwmH//NNv///LVf/XyWn/OIcC/zqp
+        Qf87rkn/O65J/zuuSf87rkn/O65J/zuuSf86pDb/OogE/8vEXf//z13//9h6///rvP/fsqP/r0k2/6s/
+        LP+qPizOqT0sGAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAALhSLw+4US6tuFIv/rtZOf/NmoD+dJ9D/jqIBP7c15P//t6S/v7Zgf7+1nn/+dR2/v3V
+        dv5xnyr/OJQb/jqtSP47rkn/Oq1I/jqtSP47rkn/Oq1I/jqtSP46rUf/OJMY/n6pP//+6rn+89zG/sZ8
+        bP+sQSv+q0Ar/qs/LK2qPisPAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4US4Ct1EubbdQLvO6WDf+xnRa/sujhv7149L//u3E/v7m
+        rP6guVz/RYwM/lGRFP43igj/OqpC/jqtSP47rkn/Oq1I/jqtSP46qkL/OaM1/jiZIv43jAv/P4oK/oqr
+        Xv/VnZD+sUo1/q1CLP+sQSzzrEArbatALAIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhRLyS4US6vt1Au/bhT
+        Mv+5VDP/y4Fp/+jFtv9/q1X/PIkG/zeGAP83iQX/N40O/ziPEf84jxH/N40N/zeKB/83hgH/QowO/26g
+        QP+ho2r/xpN8/71mUv+xSzT/rkMt/a1DLK+sQiwkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAt1AuMbZPLau3Ty74tk8t/rlXOP7FcVf/0I96/rqWcP6zn3P/qKFs/qGhaP6hoWj/qKFt/rSf
+        dP6+l3b/zYp4/r9pU/63Vj7/sUox/rBFLfivRS2rrkUuMQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC2Ty4dtk8ucrZPLr+2Ti70tlAw/rdTNP64VDb/uVc5/rlY
+        O/64Vzv/t1U5/rZRNf60TjP/skou/rFILfSxSC2/sEcucrBHLh0AAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC2Ty8Ntk8vO7VO
+        Lmi1TS6LtU0uobRMLay0TC2ss0stobNLLYuzSi1oskouO7FJLg0AAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAD//8AD//8AAP/+
+        AAB//wAA//gAAB//AAD/4AAAB/8AAP/AAAAD/wAA/wAAAAD/AAD+AAAAAH8AAPwAAAAAPwAA+AAAAAAf
+        AAD4AAAAAB8AAPAAAAAADwAA4AAAAAAHAADgAAAAAAcAAMAAAAAAAwAAwAAAAAADAACAAAAAAAEAAIAA
+        AAAAAQAAgAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAAAAAEAAIAA
+        AAAAAQAAgAAAAAABAADAAAAAAAMAAMAAAAAAAwAA4AAAAAAHAADgAAAAAAcAAPAAAAAADwAA8AAAAAAP
+        AAD4AAAAAB8AAPwAAAAAPwAA/gAAAAB/AAD/AAAAAP8AAP+AAAAB/wAA/+AAAAf/AAD/+AAAH/8AAP/+
+        AAB//wAA///AA///AAAoAAAAIAAAAEAAAAABACAAAAAAAIAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAChMisOoDErSqAwK36fLyugni8rsZ4u
+        KrGdLSqgnSwqfpwrKkqcKyoOAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKQ2KwGjNStLojQrsKIzK/mhMyv/rEpE/7hk
+        X/++cWz/vXBs/7ZiX/+pRkP/nSwq/5wrKvmbKiqwmyoqS5sqKgEAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAClOCs3pTgsyqpEOf+wdV//yKmP//be
+        u//85Kz/9deR//HQg//xz4L/9NWN//vipv/23LX/2KaX/7NdWv+bKir/myoqypsqKjcAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACnOiwCpzosgKY5LPy/c2n/ephH/zyO
+        E/9XjiL/w7Fg/9urQv/hqzT/5aww/+WsLf/iqSz/3KUu/9+sO//rv1r/+duT/+jEqf+yWlj/myoq/Jsp
+        KoCbKSoCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqTwsB6g8LK2pPi//1qGR//rn
+        u/87gw//NZY//zeZOP9EjBP/ubtQ///FQ///wTj//8A0//+/L//+viv/+Lgm/+2uI//gpyr/6rpM//re
+        mv/Smo7/nC0t/5spKq2bKSoHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKo+LAKqPiyvrEQ0/+fB
+        rP/42JH/5bxm/2CQIv86qkT/O65J/zqrQ/9Qkxb/3cdg///HSP//wz3//8E4///AMv//vy3//70n//67
+        Iv/xsSH/5Kww//bPdv/avKb/p0ZF/5sqKq+bKSoCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAq0AshKxC
+        L//nwq3/9tWL/+i7Wf/6yVv/tbxY/ziXH/87rkn/O65J/zqnPf9FkhX/xMBZ///LVf//xEH//8I7///A
+        NP//vy7//70n//+8If/7uB7/6rEw/4ShN/+Fl1L/pT8//5sqKoQAAAAAAAAAAAAAAAAAAAAAAAAAAJs7
+        JzqsQSz82qeV//nbmP/twGD//cxf///OYf/41n//O5AT/zuuSf87rkn/O65J/zqrRP84khb/uLxV///K
+        UP//xUP//8I8///ANP//vy3//70m//+7IP/+vij/f5or/zeJDf+aj2H/nzIy/JEnJzsAAAAAAAAAAAAA
+        AACDMyEBRxsSzhoKB/8kIR3/IhwQ/yMcDf8kHQ7/JB0P/yIfE/8IFAH/Ch8N/xpPIf84pkX/O65J/zqs
+        Rf9Kkxf/99Ft/96vQv9YRBf/KB4J/yQbB/8kGwX/JBoF/yQbBf8SFwX/BxQF/w4WB/8eDAz/ax0dzpAn
+        JwEAAAAAAAAAAJ9CLVAqGRb/ABQa/wAUGv8AFBr/ABQa/wAUGv8AFBr/ABQa/wAUGv8AEBX/AAMD/yp9
+        NP87rkn/O65J/zmbKP+tuVP/emIs/wADBP8AERf/ABQa/wAUGv8AFBr/ABQa/wAUGv8AFBr/ABQa/wAS
+        Gf9fIiT/mCsrUAAAAAAAAAAArkYuugJtkf8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBu
+        k/8BZYH/MJ9S/zqoP/85myf/PY8S/6i4Vv+up2b/AWWG/wBuk/8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+        lP8Ab5T/AG6T/ylfev+bKyq6AAAAALBHLROwRy37Am+T/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBv
+        lP8Ab5T/AG+T/wd2iv8wn1D/SIkW/6ayYP/lyoL/7shx/7+2bv8Udo//AG+T/wBvlP8Ab5T/AG+U/wBv
+        lP8Ab5T/AG+U/wBvlP8Ab5P/LWuG/54wL/ucKyoTsUgtU7JJLv/h28T/vbyG/wVwkv8Ab5T/AG+U/wBv
+        lP8eb3v/KIY0/y6gWf8xpFT/OKVA/xxJC/8DBAH/BgUD/wYFA/8KCAT/sZBH//PJX//RwXP/Qow2/yiS
+        VP8DYXj/AG+U/wBvlP8Ab5T/BHSN/y6dUv9imkT/pkE+/5wsKlOySS2HvmVN//7rwf/tz3//BnGS/wBv
+        lP8Ab5T/AG+U/w5iWP83jAz/OJMZ/zeQEv8vZgv/AiYt/wBSbf8AU27/AFNu/wBRbP8ZLy7/3rNV/8nD
+        Yf84lh7/N6NF/wRdbv8Ab5T/AG+U/wBvlP8GdYz/OqxJ/0GRGP+2ZGH/nSwqh7NKLanJfmj//uay/+/P
+        fv8GcZL/AG+U/wBvlP8Ab5T/FmZg/8nPkf/k3Kn/28ul/x4yNv8AZon/AG+U/wBvlP8Ab5T/AG+U/wBj
+        hP9FSDH/urpc/ziXH/83o0X/BF1u/wBvlP8Ab5T/AG+U/wZ1jP86rUn/OJIW/7V3a/+dLSqqs0stu86L
+        dv/+5az/79KH/wZxk/8Ab5T/AG+U/wBvlP88eYX//eW6//fesv9JTkX/AGCA/wBvlP8Ab5T/AG+U/wBv
+        lP8Ab5T/AG+U/wBZd/9/dEv/Xpkh/zaYMP8EXW7/AG+U/wBvlP8Ab5T/BnOH/ziZJP83jxH/sn9s/54u
+        K7u0TC28z4x3//3ouP+Mr1X/Am+Q/wBvlP8Ab5T/AG+U/yZucf+TtWL/hH9u/wBWcv8AbpP/AG+U/wBv
+        lP8CcJP/AW+T/wBvlP8Ab5T/AG+U/wdSaf+tm1b/XJEf/wRba/8Ab5T/AG+U/wBvlP8Xd4z/yLtG/6C4
+        Vv/Bgnr/ni8rvLRNLavNhnD/nb1v/zSECP8Bb4//AG+U/wBvlP8Ab5T/DWRb/zVtEv8IUGf/AG6T/wBv
+        lP8Ab5T/AW+U/4mpk/93oJD/AG+T/wBvlP8Ab5T/AG6T/x9XXv+MmkL/BFlo/wBvlP8Ab5T/AG+U/xp5
+        jv+NqDL/mrZU/8J6dv+fLyustU0uisqAaf83iQb/NI0X/wFvkP8Ab5T/AG+U/wBvlP8JXmP/B05V/wBu
+        k/8Ab5T/AG+U/wBvk/9lmpX/+tmS//fViP9Sj4z/AG+U/wBvlP8Ab5T/AG2R/w1OPv8DWGr/AG+U/wBv
+        lP8Ab5T/B3KF/ziTGf8+jA3/umpl/6AxK4q2Ti5YwWhN/1GTIf83qUv/AXCR/wBvlP8Ab5T/AG+U/wBi
+        g/8AbZH/AG+U/wBvlP8AbpP/RY2W//TXlv/+2Y3//taD/+3Nev8ygYr/AG6T/wBvlP8Ab5T/AGuO/wBk
+        hf8Ab5T/AG+U/wBvlP8GdIr/OqpD/2OcNv+rSUL/oTIrWLZPLhi6Vzj9fpNA/zaeOP8BcJH/AG+U/wBv
+        lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/whxev+Ssmb/69mW//7Yif/+1X3//tJz/9rBbf8WdYz/AG+U/wBv
+        lP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wZ0if84mib/i5VV/6Q5Mf2hMysYAAAAALZQL8GUdE3/IGQk/wBu
+        kf8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBvlP8EcYv/L5E1/ziWHv9Xlh7//tuP//7Tdv/+0Wz//s5i/7iu
+        Y/8Hbo7/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/BG2H/yRgD/+hcFz/ozUrwQAAAAAAAAAAn1M6Wwto
+        hv8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AW2O/ymXW/86rEb/PpEU/8bHdP/+1Xz//tFv//7P
+        Zf//zFz//spS/4uWXv8AbZH/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG6T/y9dc/+YOTJbAAAAAAAA
+        AABGYmsDAG6T+QBvlP8Ab5T/AG+U/wBvlP8Ab5T/AG+U/wBukv8ee0f/OZsn/ziQE/+etlX//tV6//TV
+        gf+yvFv/9NFz///LVP//yEv/+8NC/1Z7X/8AbpP/AG+U/wBvlP8Ab5T/AG+U/wBvlP8Ab5T/H2N/3WZL
+        UgMAAAAAAAAAAAAAAABYXmBMg1tO/meFav8khED/JpZg/zKFQf+lsof/sLOB/1eWIP9Ciwr/PYkG/+fS
+        gP/+1n3/Zp0o/ziWHv+Cpzb//dJt///ITP//wjz/7rc0/6ifSf+mn0j/pp9G/6aiT/+msoL/ioiK/3lF
+        Rf5gTlZKAAAAAAAAAAAAAAAAAAAAAAAAAAC3US+UwmtN/3CVOP85nCj/OJQb/6i4Vf/114T/daM0/zqT
+        GP84kBP/fqY3/9vNd/83jxH/Oq1H/zmbJ/9DkBL/pbNE/+zIV///wTP//70n//+8I///vy3//9Fj/+zJ
+        q/+rQjP/pjoslAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhRLge4Ui+6wnFS/3OXO/84lBr/N4kG/0mO
+        D/+gtVH/OJYe/zqQE/+jtEz/6NF4/zmLCv86rEX/O65J/zqsRv85nSv/TJIV//rIS///vSf//8I2///U
+        bv/syqv/r0s7/6g8LLqnOiwHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhRLgu4Ui+7wWpM/5mc
+        XP+KtFz/PIgE/8zJcv9Ukxf/qrZN///PYP+xuE7/OZwo/zuuSf87rkn/O65J/zuuSf84mCL/s7dG///M
+        VP//35P/37CZ/65GNP+qPiy7qTwsCwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALhR
+        Lge4US6UuVUz/rqLZf90nUH/7+Gn///cjP/dy23/ycJa/1GUGP86q0T/O65J/zuuSf87rkn/Oq1H/zmg
+        L/9fmib/8te3/8Z6aP+sQSz+q0AslKo+LAcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAC3US5KuFEv271dPv/OiHD/6siw/2ifN/83hgD/N48Q/ziZI/84mSP/OJYe/ziQ
+        E/9Ulyb/hZhM/7OGY/+zTjj/rUMs26xBLEoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC3UC4Et08uXrZPLsi4UjL+wmtQ/7+BYf+0iWH/q41e/6yM
+        Xv+0iGL/v39j/71kTf+0Tzb+sEYtyK9FLV6uQy0EAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALZPLh62Ty5gtU4uk7VN
+        LrW0TC3GtEstxrNKLbWySi2TsUktYLFILR4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAP/gB///AAD//gAAf/gAAB/wAAAP4AAAB+AAAAfAAAADgAAAAYAAAAGAAAABAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAAGAAAABgAAAAcAAAAPgAAAH4AAAB/AA
+        AA/4AAAf/gAAf/8AAP//4Af/KAAAABgAAAAwAAAAAQAgAAAAAABgCQAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACHKyMCoTIqO6AxK36fMCusny8rwp4uKsKdLSqsnCwpfpwr
+        KjuFJCQCAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkzEmBKQ2
+        K2mnPjTctmBY/syMfv/dq5D/5LiV/+S4lP7cqY//yol8/qxOS/+cKyrcmyopaY4mJgQAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAClOSslpjkrzLBrV/5ykT3+ZZs1/ta8af7hsET+4q04/uKs
+        NP7hrTj+5rZM/vHOff7mvJb+s11Z/psqKcyaKSklAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKk8
+        LDqqPy/t2KGM/s7Kh/81jCX/N549/kyVH//ixVT//8I7//7BNf7/vy7/+7oo/u+xJP/mrjL/8813/tOa
+        hv+dLy/tmykqOgAAAAAAAAAAAAAAAAAAAAAAAAAAqj8rJ6xCMO7jt5z/8Mp4/uvDZP9Glx//Oq1I/jqp
+        Qf9anCX/5MdZ//7FQ/7/wjn//sAx/v++Kf/+uyL/8bIi/u7DYP+XmWD/oTg47psqKicAAAAAAAAAAAAA
+        AACGMyIFrEErztumj/7zzn/+98dd/v7OY/6Ur0T+OqtE/jqtSP46q0X+RZgh/tfEWf7+xkX+/sI8/v7A
+        Mv7+vin+/rsg/vi+OP5BhxD+jIZP/p0vL86LJSUFAAAAAAAAAABjJhltFwgG/hsYFP8ZFAr/GxYK/hsW
+        C/8QEgj/BxUI/hpNIP86rEj/OqxH/2agLP7xw1n/VEEW/h0WBv8bFAT/GxQD/hsVBv8GDwP/CRAE/hkJ
+        Cf+NJiZsAAAAAJQ8JwNlRUHhAEVc/gBGXv8ARl7/AEZe/gBGXv8ARl7/AERa/gg9O/85qkj/OqpD/ziT
+        F/7Lt2D/DTU9/gBEW/8ARl7/AEZe/gBGXv8ARl7/AEZe/gBEWv9/NzzhkCcnBLBHLEFZWmD+AG+T/gBu
+        k/4AbpP+AG6T/gBuk/4AbpP+AG6T/gt7hf42mCz+gKNC/sS9aP7px2/+InuM/gBvk/4AbpP+AG6T/gBu
+        k/4AbpP+AG6T/gBuk/5wTFb+nCsqQbFILYXQmoX/z8aN/gRwk/8Ab5T/AG6T/h5xXf8vmEX/M6NO/jOP
+        K/8HFwj/BAwN/wQMDP47NR7/78Rd/ri5ZP8ukjv/DGps/gBvlP8Ab5T/A3OO/jGaQf+Re1D/nCwqhbJJ
+        LbPlu5//8tOE/gRwk/8Ab5T/AG6T/iJwTP+BrU7/jbBY/iJAJf8AY4P/AG2S/wBtkv4AX3//dGk8/piv
+        Q/86qD//D2li/gBvlP8Ab5T/BHSN/jqqQ/9+i0X/ni4ss7NLLcrsyar/89SI/gRwk/8Ab5T/AG6T/miS
+        kP/95Lj/iYJs/gBaeP8Ab5T/AG+U/wBuk/4Ab5T/A1hy/o6OTP87lyD/D2li/gBvlP8Ab5T/BHKL/jmf
+        Lv94k0T/nzEuyrRMLcvsy67+j7BV/gFvkf4AbpP+AG6T/i92Wv6Snm7+CFVt/gBuk/4AbpP+DnWT/gpz
+        k/4AbpP+AG6T/hdaaP6ipkr+D2BS/gBuk/4AbpP+EnWO/s3AUP7Dton+nzAsy7VNLrWjo2f/NIYI/gFv
+        kP8Ab5T/AG6T/hNnT/8JUlb/AG6T/gBvlP8GcZT/sruT/6SzjP4DcJP/AG6T/gBuk/8uZV3/EF5S/gBv
+        lP8Ab5T/DXSN/k6TFv+Mk1L/oDErtbZOLoiOh0L+N6A4/gFvkv4AbpP+AG6T/gBdev4AbpP+AG6T/gFv
+        lP6PrJf+/dmP/v3Wgv59n4P+AG6T/gBuk/4AbZH+AF56/gBuk/4AbpP+BHKL/jmgMf6SgE7+oTIriLZP
+        LkazeE//N5cn/gFvkv8Ab5T/AG6T/gBvlP8Ab5T/AG6T/h16W/+nu2X/+tmO//3Uev76z23/U4t//gBu
+        k/8Ab5T/AG6T/gBvlP8Ab5T/BHKL/jyUHP+uZlX/oTMrRqRJKwWKWkrmEmFf/gBukv8Ab5T/AG6T/gBv
+        lP8Ab5T/D3x8/jikPP9Llh7/7NOB//7ScP7+z2T/78RZ/ix5gP8Ab5T/AG6T/gBvlP8Ab5T/AW2P/hpk
+        X/+ORUHmnTIqBQAAAAAhaICIAG6T/gBuk/4AbpP+AG6T/gBuk/4HbXn+NJo2/jmTGP7Xy3X++NR8/s7F
+        Zf7+zmL+/slO/tWxSP4PbYX+AG6T/gBuk/4AbpP+AG6T/gBuk/5HVmZ4AAAAAAAAAAA4YnALjlhG1WyE
+        W/8qkUb/MYw+/rm6g/+ks2L/QIsK/laWHv/+14H/gKk8/zmXIP6stkr/98pX/v/DPP/Vrjn/vKdA/ryn
+        P/+8tGj/no6H/oRCP9VPU2AKAAAAAAAAAAAAAAAAuFEuL71hQfJ0kzn/OJkj/meeKf+itlL/OJQa/juQ
+        E/+7wGD/UpYc/zqsRv45ojT/UZsk/rW2Qv//vyz//r4o/v/MUv/ovpj/q0Ey8qc6LC8AAAAAAAAAAAAA
+        AAAAAAAAAAAAALhRL0G+YUHyjJNK/magNf6QrkT+Xpki/qq2S/71z2j+Q5kj/jqtSP46rUj+Oq1I/kqZ
+        Iv7yx07+/tZ0/t+sjf6tRDLyqTwrQQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4US4vuFMx17CB
+        Vf+1uXz//uOh/re8Vf99pC//OqY7/zqtSP46rUf/OqY6/jqWHf+3t3r/xnll/qxBLNerPywvAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAsk4sCbdQLne3UTDoyXth/pSNS/93kTr/bpg9/26Y
+        Pf54kT3/j4hG/rR1Vf+zTzjorkMtd6pBKwkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAACtSysHtk8uTLZPL4+2UTK8t1I00rZRM9K0TTG8skkuj7BHLUyqRCsHAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAP4AfwD4AB8A8AAPAOAABwDAAAMAgAABAIAAAQAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAABAIAAAQDAAAMA4AAHAPAADwD4AB8A/gB/ACgA
+        AAAQAAAAIAAAAAEAIAAAAAAAQAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAcSUeE58y
+        Km2jNzGxrU1I06xLSNOgMjCxmiopbm8eHhMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAApDgrbaJi
+        RfGDjkn/5MeC/+u/Xv/rvlr/68Rx/9ynd/+0XVXxmikpbQAAAAAAAAAAAAAAAAAAAAAAAAAAqj8umNee
+        f/+erlT/OKJB/2KhL//2xUn//8E2//29LP/ytCb/7r1O/8+Vdv+eMDGYAAAAAAAAAAAAAAAApT4qb9qi
+        gv/yx2n/6cpl/zqgMf86rEb/X6Qy/+3FT///wjv//78u//67Iv+7qy7/fntA/5krK28AAAAAbSsdFCMU
+        EvIRGRj/ERgU/xEZFv8EFQ//H10n/zqtSP+KrkD/bFYi/xMXEP8SFxD/DRYQ/wUUEP86FxnydCAgFK1F
+        LHIBbpP/AG+U/wBvlP8Ab5T/AG6T/xqGa/9YoDf/rrZX/2COev8AbpP/AG+U/wBvlP8Ab5T/FWqK/5ws
+        K3K1UDW24tSi/wJvk/8Ab5T/I3lF/zSaNv8hXiH/Ais4/wQsOP+nj0r/halK/xl9YP8Ab5T/AnKQ/0Od
+        Pf+lPz22v2dO2Pbbmf8DcJP/AG+U/4aljP/AtZH/B1p0/wBvlP8Ab5T/EV1w/3SXOv8dfVT/AG+U/wNx
+        jv84miX/qFRL2MFrUNmWtmH/AW+R/wBvlP8/fVD/I2V3/wBuk/8jfpP/HnuS/wBvlP81bGz/PHhN/wBv
+        lP8Mc5D/pLRJ/7BWUdm9YUS4PZUi/wBvkv8Ab5T/BF9z/wBuk/8RdpT/1MmS/83ChP8Mc5H/AG6T/wRd
+        b/8Ab5T/A3GO/0WZKP+pRT+4tlEwdVqCOv8Ab5L/AG+U/wBvlP8Bb5H/QJNN/8/Ic//+03T/qqxw/wFu
+        kv8Ab5T/AG+U/wJvjv9igDr/ojUsdWhCNRcDbZD9AG+U/wBvlP8AbpP/IIdW/1ShMP/t0nv/6cto//7K
+        U/93kGT/AG6T/wBvlP8Ab5T/E2eG9nQyLhcAAAAAj1dEd2+CTP8ykzn/vL14/1KWHf92pDT/nrRL/0uh
+        MP+5t0T/9sA+/9OuN//StEn/sZF7/4dCPXcAAAAAAAAAAGYtGQG6WTiggYw//1GVHf9+qj7/obJD/4Os
+        Pv86rUj/OqlB/4yqMv//y1H/3qV5/6pAL6BnJBsBAAAAAAAAAAAAAAAAaC4aAbhSL3epdkX26sOV/5Gs
+        P/8/miT/OaM0/0CgMv90lkH/xnhh9qxALHdpJhsBAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkT8kGLdQ
+        L3m7YkO8smxG3rFrRt64XUO8sUkveZA4JRgAAAAAAAAAAAAAAAAAAAAA8A8AAOAHAADAAwAAgAEAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAEAAIABAADAAwAA8A8AAA==
+</value>
   </data>
   <data name="Service_Init_Open_Resource_Manager" xml:space="preserve">
     <value>Initialized: Open Resource Manager</value>
   </data>
-  <data name="plug__arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\plug--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="plug__arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACVUlEQVQ4T4WRXWhSYRjHTyGM
+        mI4KIwdHCRKPn0tr4DnoSF06P/IDVMKTy69ctJQaLiRQxGDp3agGo4tud9VVEEGXiy4WGvaxkA0WQ6S7
+        QSMIBvX0vIJLm2wHfrxf/H/v85yXoo74pFIpFQgEqEwmoyoUCnOVSoWpVqtUl6PyFBH4fD5NLBbLb2xs
+        A473E4kEVS6XO5LDPice1mmavmmz2Yr1ehP0ev0Cx3HaVCpFlUqlQwW3MPwhl8sBGVdXGyCTyZaUSuVF
+        j8fT186gCnQSieRLNpuFdDoN2DuRNIRCYVahUBxoZ5CgaLfbd7BMCIVCEI1GIZlMEslnbGfm/3YGCV5E
+        IpFffr8fvF4vYMngdrvB4XAQyXpvOyzLDvyHazzP/3a5XGC1WkGt1gJNy4BhVKDR6Iikie3cFYvFFFZ0
+        QODFnU1SOseZMKQFuVy9j1ZrQOEFItkcdLUPN7fi8TiYzRYwGDh8Nnaf8XETEJjE4q6cf7RIu+9RZ6/c
+        7vNsk7DN5oCJiSmUTMHk5FWwWJx/jMbLewyj+ykUjrQuVd632KVvNePTrehY5VOf4DGu2jyfBKczDMHg
+        NCm1TYce7jK5lz9U+TffteW1rxiqLbcByKhbaES7Bh4nEA6HSWiH52c6IxI8/+Bt7UkLYHYdYPrjP3JN
+        AHJGBL1hElxG9pBrQ/QYNZp5/Uwy+6rWC/sOgKzxrFNB92YSvoOIkdPISWQEESHDyAlkSHR9pS6KrtSH
+        7cUbuD5GBHkiQeYRDaJE5Mg5hDz0KHIGOUVkAvP8c4FpLoFzAXL8L0AoE8TVvKFBAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="Menu_Edit_Paste" xml:space="preserve">
     <value>Paste</value>
   </data>
-  <data name="navigation-000-white" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\navigation-000-white.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="navigation-000-white" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACL0lEQVQ4T6WQTWgTURSFHyou
+        RRcFrYvEIu50YRaCikUsTf2Ny1YUExtUFHUjilroJhh0oUsRdKG4EzdW6EpUbKkKiZM6bZNayaTJND9j
+        ZmIz00maweO7DzMhULsx8MF955x7Ju8xAOx/EMvdoTF29EqCnRrKsHORkjd892eUI3Gsv9AcJY8ylKUd
+        2m0r6L+dDoYjWe3FqIEfuWXY9d8CmkkjjzIrFhy+/DUYGp6pz2WX4DgOGo1GG6SRRxnKtv2Dvaffef0X
+        xrVUehG1Wg22bQv2nfkgaJ7Jowxlace9ws7ASPT+UxmWZaFarbqcvfUR3BM0dcrceyKTFnULtve+lGJT
+        JVQqFRdN06AoCgIX34D7gng8jkRiEu8n5ugsuQVdPa+ssmFC13XweVUkaRIzyTRlLLdgR9+oVdZNqGoe
+        fF4VWU5iOpmhTKtg18lx6ZNUwuxsBuXyrzYGh6bAfUE2W0QqpeDtWIbOrSvsGZjmj6hifr6EdDrvErrz
+        HdwT5PO60BWlgMijDGmtRzwQzHqPXFrQYt+q/BoV5HKGoDukCjTNdLWJmAHK0o77BgcHC6znvB4cuGHU
+        47KNYtFGoWDDNB0BzaR9SSyhn2coSztuwbbd11mX7ybzHR8JBq4Z2sPnFg8vQ807UBccfE7U8eCZiRNX
+        DY0ymzr3M/q5BeLE2DrO1g5PX6/v2OvHh8JFmX/JImgmrcPj9/OMh7N+pYI1XNzA2czp/AdbuL6Rs7ZZ
+        8Acd9ZrhecHpOQAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="clipboard_paste" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\clipboard-paste.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="clipboard_paste" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACc0lEQVQ4T43SW0hUURQG4PWS
+        0JsIFUQ9lWMTFo63RqXRLKoRDMbMcbyMWtqY5qBOjsEEFmlRJAaTlJRdTLtn+ZBBL4EE9rBDu0AlIURZ
+        D4VQjo3j7W+v0+xT+tSBj7M5Z6+ftdc5dC6diLVn/HXIaozIzc3NkVxhOfzs3z2qTisOB3TIDYKdMNFw
+        12H3l5GRD2C85mfqvbx36AF+GRAm3rfvRV9NKgYHX2Fo6B1GRz9reM3P+N1bfynkfqHq6OxmUsTrtiJc
+        L4nFRftaXCtej5v74nC7Ih7dpRtwuSAGPWUb8bK1ALJGqDpqTSVFDJ9x4NnRbDz2ZGguNNjQ1ujQnW8q
+        Q2eLC83bl72pLbSQ25FGdNqsEy9O5eGpb6fO7yvGr7k5/JyexvepKYwFAugbGECtPeWjzeeLzvZ6iU4m
+        6cTzZhueeLfqWr35mJyZwfjkJL5NTODT+Dh6+vvBlyyukgx0PIEUwe0/qrNoeGDHqrIRnJ3Fj2BQD/F3
+        d0OJtlqPUFMcKYLbv38gWRvkpfxoNJRkIiSPEAiFFoRwJ2Oyq23V1W7yxZIi+uvTcaVwHTodBo3HmYkZ
+        GRCUM1gcwjOxVFTUUaORFPGg2oyrRUZdXfEWzM3PIySPsTiEB2t2Oj1UbyBF9MqALtm+4i7MwLwc2Kzs
+        YnFIQAbE2+1e2r2SyL1GI3qrNmk/i1KZl6ZNnEO4Ez4Oz4QHOyXvMVlZPuJr1woi1+o/AbfKTboaWzzy
+        raYFHFkmJBlXfY00mVqiEhPLuX6ptHxPJImHB1O0r3CvMgl3XYm6O/sTwPi3ZryXa8K1FCUXsclL6MaO
+        CBL/g/dyjRT1G7y5F+bDPK+HAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="Content_SiteExplorer" xml:space="preserve">
     <value>Site Explorer</value>
   </data>
-  <data name="document_copy" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document-copy.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document_copy" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB70lEQVQ4T42SPUubYRSGz+Kg
+        IphFqCAFY4YiWboIUkyLhZjQWhULWVwcNJUgRqpECWazP6DkF9S2UkTqoAjBqnF3dOtQBC1YNOb7+/Tc
+        Dz3yECvkgQteeN735lz3eWlybY3exmKvhZkH6JuIRmlsZQXvGUYnh8nf30aurhYiXArBXLXK18Ui/87n
+        +TyT4V/pNO8kk4w7wWUHaOCg10MmWXiXLZf5TzbLF6kU/7y64rPLS/68t8c4uBdcOoEGvIlEiF4tLYG5
+        XKXCN7mcCUmcnvLXoyNejcfveBEMfv+neKdkAkbCYRAqiMJtoWBCtk9OuBklE/AyFALzJQnISgcI2Rb3
+        ZpRMwPPZWbBQrtU4Lz0gZOv4mG0l7eXjxgYrLp8vKhA9m54Gi9V6nYvSA0K2Dg/ZVmosFxuCNvRpYGoK
+        vK9JQEU0EPLt4IBtJS1XJzmXoqENfXoaCIDluqyrKhoI2Uwk2FbScnUS/CvQhj65x8dBBPuuyxQI+bK/
+        z7aSlquT3JRKDG3oU6vDQT0eT8z8MQgRPu3usq2k5eokaekJ2tDHedzudIY73O4PSp/X+8NW0nJ1EqwY
+        2tDH6RQeCd3KE79/3VbScnWSvBQN7d6hIRPQeDoblaCDTlAstlOSZ7wjHzr+F3BPydbTZ2jLx71/Ad5i
+        gsnRJ2HiAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="server" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\server.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="server" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABaUlEQVQ4T42SMWvCUBRGr+LU
+        jqVQujh1dtDFxSVDBhFB9DdokCAigpNDBscundw7+A8cRDAEFKQiySAYXESy+Ceu95Z3H0IerYGTId+5
+        ZwogIjSbzV9arVaNaP9DTXy+BX41Gg2hc71eMUkSI7yR2xFfB+r1Oiicy+WCcRwb4Y08R3wdqFaroOj6
+        vo/r9doIb+R1xdcB27ZB4Z7PZzydTkZ4I88VXwcsywJF73g84n6/N8IbeT3xdaBSqYCiP5/PcbFYGOGN
+        vL74OlAul0ExOBwOGIahEd7IG4ivA6VSCRTD3W6HQRCkmE6nyBt5Q/F1oFAogGK03W5xtVqliKIIeSNv
+        JL4O5PN5UIw3mw0ul0sjvJE3Fl8HstksKGb0G+NfkDcTXwcymQzkcjnmy3VddBwnRfGniLyxwy7f6ADQ
+        Q9UPGj4nkwl6nmeEN3bY5Zv7wAsV2zR8PwK5Hbp/vQ880Yc34v1B2H3mwA1XqPmpzb5U7wAAAABJRU5E
+        rkJggg==
+</value>
   </data>
   <data name="Menu_Edit" xml:space="preserve">
     <value>Edit</value>
@@ -190,8 +827,21 @@
   <data name="SiteExplorer_Refresh" xml:space="preserve">
     <value>Refresh</value>
   </data>
-  <data name="plug__plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\plug--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="plug__plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACTElEQVQ4T4WR3WtScRjHn1YS
+        KzPdTmChEmTqfCGNwZRNUofv+VIq4cHwba4gJcLWCBxiEBqti6AXBosIuuyqP2F3gcqgGmODYsHYReFV
+        EBvU0/MTHLrJduDD7/x+nu/nPF8PwCGXXC6HcDgM+Xx+pFQq3atWq+parQYdDssDEwSDQV0ymZxdW9tA
+        WmfS6TRUKpW25KDLQz82ZDLZlMPhmGs0VtFoND62WCz6bDYL5XL5QMEtCjeLxSKydWlpGRUKxQuNRnPZ
+        7/f31Ok3gUEqlX4pFAqYy+WQujPJslAoLKhUqn11+gnmnE5ni8bEaDSKiUQCM5kMk3ymOtN76/QTfIjH
+        439CoRAGAgGkkdHn86HL5WKSr911zGZz3//wE8/zf71eL9rtdtRq9SiTKVCtHkGdzsAkq1TnLsdxQBPt
+        EwToZJ2NbrGMU0iPSqV2F73eRMJLTLLe79VBOvyWSqVwYsKGJpOFPpt5l9HRceQeXkB4KtmGB6c/QvQE
+        QGiwx7PBwg6HC61WN0ncODl5FW02z7+xsSs7arXh99Enw9tTrRmE91wd3g0DvBnqETyn3SbPZ9DjiWEk
+        cpONukmsQE74C+bFW/BKshL7OY0UrLdZHFroGHi6wVgsxkItnqeHaCUicPEYwEtx3b51HffCzpmgO8yC
+        r4kd4kbb7j4O8Ey0APOiOkP/w4qd+/Z515tZ+A7BEaycmBARp4iTxCA8EjbPfdchrQ3aDxBHmGCWSYj7
+        hI7QEEriPME+9FniDCGBsOAt3BY04ZpgkfbUDQb+AzWA+1Qy0hyuAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="Menu_Edit_Cut" xml:space="preserve">
     <value>Cut</value>
@@ -204,13 +854,26 @@
   </data>
   <data name="About_VersionLabel" xml:space="preserve">
     <value>Version: {0}</value>
-    <comment>A label that displays the current version</comment>
   </data>
   <data name="SiteExplorer_Disconnect" xml:space="preserve">
     <value>Disconnect</value>
   </data>
-  <data name="navigation" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\navigation.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="navigation" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACgUlEQVQ4T6WPX0hTcRTHf96p
+        ROpbli6IhZpkk6noEEsti1wLyvDvLNDZpkZFYkSZUPSiWG+BBaX10ENQRKGrruKylFAzMP9uzmm7aM1s
+        Puhu4MPG6Zxr7poUPfSDD5zfOef7+d3LAID9D1JYoW5nisSXTKHhkY4oRVKnCbmHvPoF1SZpRju0ixnK
+        bhToItKt7QeqJx1VtxaXLt4RfbXNoq+yaXEpu9LuoBkKdH8T6CKz3vZU3Vz0mhu/Q9kNN+TV2qHkqkuq
+        zY0LUNGw4N2S2d2DAt2GL2iLjkjjLaaGb15DvQuK6z6D/twIfuHqoTtBs9Jrs97w1NcWhbotWv6FhOfm
+        fcbhqaIrTjhWMyFx5Oww9A8vBCRr/fxLDkgpHphSYCYg4OKfthbVTS/nnhmCNXJMH0BzgofuPgHcbjcI
+        ggCxh59BvP4FaA3vlikjC+Iedxjqp32HKj/CysqKtDw+Pg42mw2cTie4XC6Ym5uD+fl52KW3QHKB1cdh
+        RhbEPOosvDzp31vWD2NjYzA6OvrHsMfjgYS8N6Ap7PFzmJEFqocPcsyfvEmGQdh9vOs3LNYJ6WUK00xT
+        MoiS914OM7Jgx/3quFzrTPrpSUgrt0uknBqBjl4hEFbn9wZmykx+hsOMLNh+N3rTzhY+3egQM6q/QkbV
+        F0gtswXCmuIBqUckn7SLoaoWnsOMLFA2My7qtj4strVPWyGI2ReWIAtJLh2SoJpILXeJm2Na+2iXw0xA
+        wPAEhcayoDDj0dDIpi5VJi9ojbPi/poffoJq6tGMdmiXznpBMN63IXsYpzrIgvOvs5DzT1hIbe8qWFOP
+        ZowlIlFI8HoBh41wZCui/Af0EO1yJPgJP5onawv8eSgAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="Menu_File_Quit" xml:space="preserve">
     <value>Quit</value>
@@ -220,26 +883,209 @@
   </data>
   <data name="About_ServerVersionLabel" xml:space="preserve">
     <value>MapGuide Version: {0} ({1})</value>
-    <comment>A label that displays the version of the current MapGuide server</comment>
   </data>
   <data name="About_LanguageLabel" xml:space="preserve">
     <value>Selected language: {0}, OS Language: {1}</value>
-    <comment>A label that displays the current language settings</comment>
   </data>
-  <data name="application_task" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\application-task.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="application_task" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABmElEQVQ4T6WUPUgCQBiGD5wa
+        BCGKCIKQSFqCbHFycnEQVHCIdq2IIIKWoK2m1qZMBEkkRQRRRHHJ/ClNFJQUdHHQUERBQRHl7b6DGsWf
+        g4f3444H7jvujgFgy8BMJpOcc8Qxzwk5cmY0Go8TiUShUqmgXC6hWCwin88hk8kglUqBryEeJz54/YVk
+        Mo90+huh0HuBXKbX608jkQjC4TCfDCEYDMLv98Pn88Hr9cLtdsPlcsHpdMLhcMBut8Nms8FqtUIikZip
+        BQs/g4UGucxgMJxMJhN8/iQwHo9FHr7KRT0NcshlOp3ubDQa4cC1jcfcg8jhcIhqtQpqjc7ij1gsJmpK
+        cshlWq32fDAYoN/vY/9lS+QskEMu02g0F71eD51OZy7IIZep1erLbreLSCmIVqslcs++IeppkEMuU6lU
+        V+12G7vPa7h/uxVZr9eRzWbh8XjEPaCMRqP/BAIBkEMuUyqV181mE7VaDTtPqyJngRxymUKhuKGtNhqN
+        uSCHXCaVSi0ymexuEchlfKxw1jmbc0LOylJPmb6BX0e9uo6xgLh6AAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="navigation-180-white" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\navigation-180-white.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="navigation-180-white" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACMElEQVQ4T6WQTWgTURSFHyou
+        RRcFrYvEIu50YRaCikUsTf2Ny1YUExtUFHUjilroJhh0oUsRdKG4EzcW6UpUbKkKiZM6zU+tJGkyzc+Y
+        mdjMdJJm8Pjuw0wI1G4c+ODec889b95jANj/IJZ7AxPs6JUYOzWSZedCZXfw7s8wR+KYf6E6TDPykJd2
+        aLcjYPB22h8M5dQX4zp+5JdhNX4LqCaNZuRZMeDw5a/+wGiiMZdbgm3baDabHZBGM/KQt+MP9p5+5/Ze
+        mFRT6UXU63VYliXYd+aDoNXTjDzkpR3nCjt9Y+H7T2WYpolarSbgmuDsrY+ORjp57j2RaRZ2Arb3v5Qi
+        M2VUq1UB7wW+i28QjycQi00jGo0KqH4/NUdzyQno6XtlVnQDmqaB16siSdNIJNPkMZ2AHQPjZkUzoCgF
+        8HpVZDmJeDJLnnbArpOT0iepjNnZLHK5EngvGB6ZQaXyq4NUKoO3E1mat6+wZyjOH1HB/HwZ6XQBhYIG
+        rgkCd74LrUUmU0ToUZZm7Uc84M+5j1xaUCPfavwaVeTzOlTVQG9AEVDfYiqig7y047zBweEi6zuv+Ydu
+        6I2obKFUslAsWjAMW0A1aV9iSxjkHvLSjhOwbfd11uO5yTzHx/y+a7r68LnJzctQCjaUBRufYw08eGbg
+        xFVdJc+m7v2MPidAdIyt42ztcg30e469fnwoWJL5SSZBNWldLq+Xe1yc9SsFrOHiBs5mTvc/2ML1jZy1
+        rYA/mPmaEqC8vtwAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="loading" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\loading.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="loading" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhIAAgAPUAAP///xRWirDG142txmyVtVqIrE1/plaFqmOOsXugvZazyqe/03GZuEN4oUJ3oEd7
+        o1CBqH6ivqzD1bTJ2XWcukB1n7bK2jpxnWiStJy3zTdvmzNsmZGvyKC6z4ipw1+Mr4SmwS9plzFrmC1o
+        lqO90ShklL/R3iRhkrnN3MPT4NHe6NXg6drk7Mza5cjX4+Tr8e3y9efu8/H09/b4+vz8/d7n7hdYixRW
+        ih1cjgAAAAAAAAAAAAAAAAAAAAAAAAAAACH+GkNyZWF0ZWQgd2l0aCBhamF4bG9hZC5pbmZvACH5BAAH
+        AAAAIf8LTkVUU0NBUEUyLjADAQAAACwAAAAAIAAgAAAG/0CAcEicDBCOS8lBbDqfgAUidDqVSlaoligg
+        bEbX8Amy3S4MoXQ6fC1DM5eNeh0+uJ0Lx0YuWj8IEQoKd0UQGhsaIooGGYRQFBcakocRjlALFReRGhcD
+        llAMFZmalZ9OAg0VDqofpk8Dqw0ODo2uTQSzDQ12tk0FD8APCb1NBsYGDxzERMcGEB3LQ80QtdEHEAfZ
+        g9EACNnZHtwACd8FBOIKBwXqCAvcAgXxCAjD3BEF8xgE28sS8wj6CLi7Q2PLAAz6GDBIQMLNjIJaLDBI
+        uBCEAhRQYMh4WEYCgY8JIoDwoGCBhRQqVrBg8SIGjBkcAUDEQ2GhyAEcMnSQYMFEC0QVLDXCpEFUiwAQ
+        IUEMGJCBhEkTLoC2hPFyhhsLGW4K6rBAAIoUP1m6hOEIK04FGRY8jaryBdlPJgQscLpgggmULMoEAQAh
+        +QQABwABACwAAAAAIAAgAAAG/0CAcEicDDCPSqnUeCBAxKiUuEBoQqGltnQSTb9CAUMjEo2woZHWpgBP
+        FxDNZoPGqpc3iTvaeWjkG2V2dyUbe1QPFxd/ciIGDBEKChEEB4dCEwcVFYqLBxmXYAkOm6QVEaFgCw+k
+        DQ4NHKlgFA21rlCyUwIPvLwIuV8cBsMGDx3AUwzEBr/IUggHENKozlEH19dt1UQF2AfH20MF3QcF4OEA
+        CN0FCNroBAUfCAgD6EIR8ggYCfYAGfoICBBYYE+APgwCPfQDgZAAgwTntkkQyIBCggh60HFg8DACiAEZ
+        t1kAcTHCgAEKFqT4MoPGJQERYp5UkGGBBRcqWLyIAWNGy0JQEmSi7LBgggmcOmHI+BnKAgeUCogaRbqz
+        J9NLKEhIIioARYoWK2rwXNrSZSgTC7haOJpTrNIZzkygQMF2RdI9QQAAIfkEAAcAAgAsAAAAACAAIAAA
+        Bv9AgHBInHAwj0ZI9HggBhOidDpcYC4b0SY0GpW+pxFiQaUKKJWLRpPlhrjf0ulEKBMXh7R6LRK933En
+        NyR2Qh0GFYkXexttJV5fNgiFAAsGDhUOmIsQFCAKChEEF5GUEwVJmpoHGWUKGgOUEQ8GBk0PIJS6CxC1
+        vgq6ugm+tbnBhQIHEMoGdceFCgfS0h3PhQnTB87WZQQFBQcFHtx2CN8FCK3kVAgfCO9k61PvCBgYhPJS
+        GPUYBOr5Qxj0I8AAGMAhIAgQZGDsIIAMCxNEEOAQwAQKCSR+qghAgcQIHgZIqDhB44ABCkxUDBVSQYYO
+        Kg9aOMlBQYcFEkyokInS5oJECSZcqKgRA8aMGTRoWLOQIQOJBRaCqmDxAoYMpORMLHgaVShVq1jJpbAg
+        oevUqleVynNhQioLokaRqpWnYirctHPLBAEAIfkEAAcAAwAsAAAAACAAIAAABv9AgHBInCgIBsNmkyQM
+        JsSodLggNC5YjWYZGoU0iMV0Kkg8Kg5HdisKuUelEkEwHko+jXS+ctFuRG1ucSUPYmMdBw8GDw15an1L
+        bV6DJSIKUxIHSUmMDgcJIAoKIAwNI3BxODcPUhMIBhCbBggdYwoGgycEUyAHvrEHHnVDCSc3DpgFvsuX
+        w0MeCGMRB8q+A87YAAIF3NwU2dgZH9wIYeDOIOXl3+fDDBgYCE7twwT29rX0Y/cMDBL6+/oxSPAPoJQE
+        CBNEMGSQCAiEEUDkazhEgUIQA5pRFLJAoYeMJjYKsQACI4cMDDdmGMBBQQYSIUVaaPlywYQWIgEsUNBh
+        gQRHCyZUiDRBgoRNFClasIix0YRPoC5UsHgBQ8YMGjQAmpgAVSpVq1kNujBhIurUqlcpqnBh9mvajSxW
+        nAWLNWeMGDBm6K2LLQgAIfkEAAcABAAsAAAAACAAIAAABv9AgHBInCgYB8jlAjEQOBOidDqUMAwNR2V7
+        0XhFF8SCShVEDIbHo5GtdL0bkWhDEJCrmCY63V5+RSEhIw9jZCQIB0l7aw4NfnGAISUlGhlUEoiJBwZN
+        BQkeGRkgDA8agYGTGoVDEwQHBZoHGB1kGRAiIyOTJQ92QwMFsMIDd0MJIruTBFUICB/PCJbFv7qTNjYS
+        Qh4YGM0IHNNSCSUnNwas3NwEEeFTDhpSGQTz86vtQtlSAwwEDAzs96ZFYECBQQJpAe9ESMAwgr2EUxJE
+        iAACRBSIZCSCGDDgIsYpFTlC+UiFA0cFCnyRJNKBg4IMHfKtrIKyAwkJLmYOMQHz5gRVEzqrkFggAIUJ
+        FUEBmFggwYIJFypqJEUxAUUKqCxiBHVhFOqKGjFgzNDZ4qkKFi9gyJhBg8ZMFS3Opl3rVieLu2FnsE0K
+        4MXcvXzD0q3LF4BewAGDAAAh+QQABwAFACwAAAAAIAAgAAAG/0CAcEicKBKHg6ORZCgmxKh0KElADNiH
+        o8K9XCqYxXQ6ARWSV2yj4XB4NZoLQTCmEg7nQ9rwYLsvcBsiBmJjCwgFiUkHWX1tbxoiIiEXGVMSBAgf
+        ikkIEQMZGR4JBoCCkyMXhUMTFAgYCJoFDB1jGQeSISEjJQZQQwOvsbEcdUMRG7ohJSUEdgTQBBi1xsAb
+        I7vMhQPR0ArVUQm8zCUIABYJFAkMDB7gUhDkzBIkCfb2Eu9RGeQnJxEcEkSIAGKAPikPSti4YYPAABAg
+        PIAgcTAKgg0E8gGIOKAjnYp1Og7goAAFyDokFYQycXKMAgUdOixg2VJKTBILJNCsSYTeAlYBFnbyFIJC
+        AlATKVgMHeJCQtAULlQsHWICaVQWL6YCUGHiao0XMLSqULECKwwYM6ayUIE1BtoZNGgsZWFWBly5U1+4
+        nQFXq5CzfPH6BRB4MBHBhpcGAQAh+QQABwAGACwAAAAAIAAgAAAG/0CAcEgEZBKIgsFQKFAUk6J0Kkl8
+        DljI0vBwOB6ExXQ6GSSb2MO2W2lXKILxUEJBID6FtHr5aHgrFxcQYmMLDHZ2eGl8fV6BGhoOGVMCDAQE
+        GIgIBCADHRkDCQeOkBsbF4RDFiCWl5gJqUUZBxcapqYGUUMKCQmWlgpyQxG1IiHHBEMTvcywwkQcGyIi
+        IyMahAoR2todz0URxiHVCAAoIOceIMHeRQfHIyUjEgsD9fUW7LIlxyUlER0KOChQMClfkQf9+hUAmKFh
+        HINECCQs0aCDRRILTEAk4mGiCBIYJUhwsXFXwhMlRE6wYKFFSSEKTpZYicJEChUvp5iw6cLFikWcUnq6
+        UKGCBdAiKloUZVEjxtEhLIrWeBEDxlOoLF7AgCFjxlUAMah2nTGDxtetZGmoNXs1LduvANLCJaJ2rt27
+        ePPKCQIAIfkEAAcABwAsAAAAACAAIAAABv9AgHBIBHRABMzhgEEkFJOidCoANT+F7PJg6DIW06llkGwi
+        CtsDpGtoPBKC8HACYhCSiDx6ue42Kg4HYGESEQkJdndme2wPfxUVBh1iEYaHDHYJAwokHRwgBQaOjxcP
+        g0Mon5WWIKdFHR8OshcXGhBRQyQDHgMDIBGTckIgf7UbGgxDJgoKvb1xwkMKFcbHgwvM2RLRRREaGscb
+        GAApHeYdGa7cQgcbIiEiGxIoC/X1KetFGSLvIyEgFgQImCDAQj4pEEIoFIHAgkMTKFwcLMJAYYgRBkxo
+        dOFCxUQiHkooLLEhBccWKlh8lFZixIgSJVCqWMHixUohCmDqTMmixotJGDcBhNQpgkXNGDBgBCWgs8SD
+        Fy+SwpgR9AOOGzZOfEA6dcYMGkEBTGCgIQGArjTShi3iVe1atl/fTokrVwrYunjz6t3Lt+/bIAAh+QQA
+        BwAIACwAAAAAIAAgAAAG/0CAcEgEdDwMAqJAIEQyk6J0KhhQCBiEdlk4eCmS6dSiSFCuTe2n64UYIBGB
+        eGgZJO6JpBKx9h7cBg8FC3MTAyAgEXcUSVkfH34GkoEGHVMoCgOHiYoRChkkHQogCAeTDw0OBoRFopkD
+        HiADYVMdCIEPDhUVB1FDExkZCsMcrHMAHgYNFboVFEMuCyShohbHRAoPuxcXFawmEuELC9bXRBEV3NwE
+        ACooFvAC5eZEHxca+BoSLSb9/S30imTIt2GDBxUtXCh0EVCKAQ0iCiJQQZHiioZFGGwIEdEAi48fa2Ak
+        MiBEiBEhLrxYGeNFjJFDFJwcMUIEjJs4YQqRSbOmjFQZM2TIgKETWQmaJTQAXTqjKIESUEs8oEGValOd
+        DqKWKEBjCI2rIxWcgHriBAgiVHVqKDF2LK2iQ0DguFEWAdwpCW7gMHa3SIK+gAMLHky4sOGAQQAAIfkE
+        AAcACQAsAAAAACAAIAAABv9AgHBIBCw4kQQBQ2F4MsWoFGBRJBNNAgHBLXwSkmnURBqAIleGlosoHAoF
+        kEAsNGU4AzMogdViEB8fbwcQCGFTJh0KiwMeZ3xqf4EHlBAQBx1SKQskGRkKeB4DGR0LCxkDGIKVBgYH
+        h0QWEhKcnxkTUyQElq2tBbhDKRYWAgKmwHQDB70PDQlDKikmJiiyJnRECgYPzQ4PC0IqLS4u0y7YRR7c
+        DhUODAA1Kyrz5OhRCOzsDQIvNSz/KljYK5KBXYUKFwbEWNhP4MAiBxBeuEAAhsWFMR4WYVBBg8cDM2bI
+        sAhDI5EBGjakrBCypQyTQxRsELGhJo2bNELCFKJAhM9dmkNyztgJYECIoyIuEKFBFACDECNGhDDQtMiD
+        o1ERVI1ZAmpUEFuFPCgRtYQIWE0TnCjB9oTWrSBKrGVbAtxWAjfmniAQVsiAvCcuzOkLAO+ITIT9KkjM
+        uLFjmEEAACH5BAAHAAoALAAAAAAgACAAAAb/QIBwSARMOgNPIgECDTrFqBRgWmQUgwEosmQQviDJNOqy
+        LDpXThLU/WIQCM9kLGyhBJIFKa3leglvHwUEYlMqJiYWFgJ6aR5sCV5wCAUFCCRSLC0uLoiLCwsSEhMC
+        ewmAcAcFBx+FRCsqsS4piC5TCwkIHwe8BxhzQy8sw7AtKnRCHJW9BhFDMDEv0sMsyEMZvBAG2wtCMN/f
+        MTHWRAMH29sUQjIzMzLf5EUE6A8GAu347fFEHdsPDw4GzKBBkOC+Ih8AOqhAwKAQGgeJJGjgoOIBiBGl
+        DKi48EHGKRkqVLhA8qMUBSQvaLhgMsoAlRo0OGhZhEHMDRoM0CRiYIPPVQ0IdgrJIKLoBhEehAI4EEJE
+        0w2uWiYIQZVq0J0DRjgNMUJDN5oJSpQYwXUEAZoCNIhdW6KBgJ0XcLANAUWojRNiNShQutRG2698N2B4
+        y1dI1MJjggAAIfkEAAcACwAsAAAAACAAIAAABv9AgHBIBJgkHQVnwFQsitAooHVcdDIKxcATSXgHAimU
+        RUVZJFbstpugEBiDiVhYU7VcJjM6uQR1GQQECBQSYi8sKyoqeCYCEiRZA34JgIIIBE9QMDEvNYiLJqGh
+        KEgDlIEIqQiFRTCunCyKKlISIKgIHwUEckMzMzIymy8vc0IKGKkFBQcgvb6+wTDFQx24B8sFrDTbNM/T
+        RArLB+MJQjRD3d9FDOMHEBBhRNvqRB3jEAYGA/TFCPn5DPjNifDPwAeBYjg8MPBgIUIpGRo+cNDgYZQM
+        DRo4qFDRYpEBDkJWeOCxSAKRFQ6UJHLgwoUKFwisFJJBg4YLN/fNPKBhg81UC6xKRhAhoqcGmSsHbCAq
+        wmcmjwlEhGAqAqlFBQZKhNi69UE8hAgclBjLdYQGEh4PnBhbYsTYCxlKMrDBduyDpx5trF2L4WtJvSE+
+        4F2ZwYNfKEEAACH5BAAHAAwALAAAAAAgACAAAAb/QIBwSAS0TBPJIsPsSIrQKOC1crlMFmVGwRl4QAqB
+        NBqrrVRXlGDRUSi8kURCYRkPYbEXa9W6ZklbAyBxCRQRYlIzMzJ4emhYWm+DchQMDAtSNDSLeCwqKn1+
+        CwqTCQwEqE9RmzONL1ICA6aoBAgUE5mcdkIZp7UICAO5MrtDJBgYwMCqRZvFRArAHx8FEc/PCdMF24jX
+        YyTUBwUHCt67BAfpBwnmdiDpEBAI7WMK8BAH9FIdBv39+lEy+PsHsAiHBwMLFknwoOGDDwqJFGjgoCKB
+        iLwcVNDoQBjGAhorVGjQrWCECyhFMsA44IIGDSkxKUywoebLCxQUChQRIoRNQwMln7lJQKBCiZ49a1Yg
+        Qe9BiadHQ4wY4fNCBn0lTkCVOjWEAZn0IGiFWmLEBgJBzZ1YyzYEArAADZy4UOHDAFxjggAAIfkEAAcA
+        DQAsAAAAACAAIAAABv9AgHBIBLxYKlcKZRFMLMWoVAiDHVdJk0WyyCgW0Gl0RobFjtltV8EZdMJiAG0+
+        k1lZK5cJNVl02AMgAxNxQzRlMTUrLSkmAn4KAx4gEREShXKHVYlIehJ/kiAJCRECmIczUyYdoaMUEXBS
+        c5gLlKMMBAOYuwu3BL+Xu4UdFL8ECB7CmCC/CAgYpspiCxgYzggK0nEU1x8R2mIDHx8FBQTgUwrkBwUf
+        6FIdBQfsB+9RHfP59kUK+fP7RCIYgDAQAcAhCAwoNEDhIIAODxYa4OAQwYOIEaPtA+GgY4MGDQFyaNCx
+        goMHCwBGqHChgksHCfZlOKChZssKEDQWQkAgggJNBREYPBCxoaaGCxdQKntQomnTECFEiNBQVMODDNJu
+        OB0BteuGohBSKltgY2uIEWiJamCgc5cGHCecPh2hAYFYbRI+uCxxosIDBIPiBAEAIfkEAAcADgAsAAAA
+        ACAAIAAABv9AgHBIBNBmM1isxlK1XMWotHhUvpouk8WSmnqHVdhVlZ1IFhLTV0qrxsZlSSfTQa2JbaSy
+        tnKlUBMLHQqEAndDSDJWTX9nGQocAwMTh18uAguPkhEDFpVfFpADIBEJCp9fE6OkCQmGqFMLrAkUHLBe
+        HK0UDAyUt1ESCbwEBBm/UhHExCDHUQrKGBTNRR0I1ggE00Qk19baQ9UIBR8f30IKHwUFB+XmIAfrB9nm
+        BAf2BwnmHRAH/Aen3zAYMACB36tpIAYqzKdNgYEHCg0s0BbhgUWIDyKsEXABYJQMBxxUcOCgwYMDB6fY
+        wHGiAQFTCiIwMKDhwoWRIyWuUXCihM9DEiNGhBi6QUPNCkgNdLhz44RToEGFhiha8+aBiWs6OH0KVaiI
+        DUVvMkj5ZcGHElyDTv16AQNWVKoQlAwxwiKCSV+CAAAh+QQABwAPACwAAAAAIAAgAAAG/0CAcEgk0mYz
+        GOxVKzqfT9pR+WKprtCs8yhbWl2mlEurlSZjVRXYMkmRo8dzbaVKmSaLBer9nHVjXyYoAgsdHSZ8Wixr
+        EoUKGXuJWS6EHRkKAySSWiYkl5gDE5tZFgocAx4gCqNZHaggEQkWrE8WA7AJFJq0ThwRsQkcvE4ZCbkJ
+        IMNFJAkMzgzKRAsMBNUE0UML1hjX2AAdCBjh3dgDCOcI0N4MHx/nEd4kBfPzq9gEBwX5BQLlB///4D25
+        lUgBBAgAC0h4AuJEiQRvPBiYeBBCMmI2cJQo8SADlA4FHkyk+KFfkQg2bGxcaYCBqgwgEhxw0OCByIkH
+        FjyRsGFliU8QQEUI1aDhQoUKDWiKPNAhy4IGDkuMGBE0BNGiRyvQLKBTiwAMK6eO2CBiA1GjRx8kMPlm
+        wYcNIahumHv2wgMCXTdNMGczxAaRBDiIyhIEACH5BAAHABAALAAAAAAgACAAAAb/QIBwSCwOabSZcclk
+        ImcwWKxJXT6lr1p1C3hCY7WVasV1JqGwF0vlcrXKzJlMWlu7TCgXnJm2p1AWE3tNLG0mFhILgoNLKngT
+        iR0mjEsuApEKC5RLAgsdCqAom0UmGaADAxKjRR0cqAMKq0QLAx4gIAOyQxK3Eb66QhK+CcTAABLEycYk
+        CRTOCcYKDATUEcYJ1NQeRhaMCwgYGAQYGUUXD4wJCOvrAkMVNycl0HADHwj3CNtCISfy8rm4ZDhQoGAB
+        DKqEYCghr0SJEfSoDDhAkeCBfUImXGg4IsQIA+WWdEAAoSJFDIuGdAjhMITLEBsMUACRIQOIBAceGDBg
+        soAmVSMKRDgc0VHEBg0aLjhY+kDnTggQCpBosuBBx44wjyatwHTnTgQJmwggICKE0Q1HL1TgWqFBUwMJ
+        3HH5pgEm0gtquTowwCAsnAkDMOzEW5KBgpRLggAAIfkEAAcAEQAsAAAAACAAIAAABv9AgHBILBqPyGSS
+        pmw2aTOntAiVwaZSGhQWi2GX2pk1Vnt9j+EZDPZisc5INbu2UqngxzlL5Urd8UVtfC4mJoBGfCkmFhMu
+        h0QrihYCEoaPQ4sCCx0Sl5gSmx0dnkImJB0ZChmkACapChwcrCiwA7asErYeu0MeBxGAJCAeIBG2Gic2
+        JQ2AAxHPCQoRJycl1gpwEgnb2yQS1uAGcCAMDBQUCRYAH9XgCV8KBPLyA0IL4CEjG/VSHRjz8joJIWAt
+        hMENwJpwQMAQAQYE/IQIcFBihMEQIg6sOtKBQYECDREwmFCExIURFkNs0HDhQAIPGTI4+3Cg5oECHxAQ
+        EFgkwwVPjCI2rLzgwEGDBw8MGLD5ESSJJAsMBF3JsuhRpQYg1CxwYGcTAQQ0iL1woYJRpFi3giApZQGG
+        CmQryHWQVCmEBDyxTOBAoGbRmxQUsEUSBAAh+QQABwASACwAAAAAIAAgAAAG/0CAcEgsGo/IpHLJbDqf
+        0CiNNosyp1UrckqdwbRHrBcWAxdnaBjsxTYTZepXjcVyE2Nylqq1sgtjLCt7Li1+QoMuJimGACqJJigo
+        jCqQFgISBg8PBgZmLgKXEgslJyclJRlgLgusHR0ip6cRYCiuGbcOsSUEYBIKvwoZBaanD2AZHAMDHB0R
+        piEhqFYTyh7KCxIjJSMjIRBWHCDi4hYACNzdIrNPHQkR7wkKQgsb3NAbHE4LFBQJ/gkThhCAdu/COiUK
+        CChk4E/eEAEPNkjcoOHCgQ5ISCRAgEEhAQYRyhEhcUGihooOHBSIMMDVABAEEMjkuFDCkQwOTl64UMFB
+        A0hNnA4ILfDhw0wCC5IsgLCzQs+fnAwIHWoUAQWbSgQwcOrUwSZOEIYWKIBgQMAmCwg8SPnVQNihCbBC
+        maCAQYEDnMgmyHAWSRAAIfkEAAcAEwAsAAAAACAAIAAABv9AgHBILBqPyKRyyWw6n9CodEpV0qrLK/ZI
+        o822w2t39gUDut4ZDAAyDLDkmQxGL5xsp8t7OofFYi8OJYMlBFR+gCwsIoQle1IxNYorKo0lClQ1lCoq
+        LoQjJRxULC0upiaMIyElIFQqKSkmsg8lqiEMVC4WKBa9CCG2BlQTEgISEhYgwCEiIhlSJgvSJCQoEhsi
+        zBsHUiQZHRnfJgAIGxrnGhFQEgrt7QtCCxob5hoVok0SHgP8HAooQxjMO1fBQaslHSKA8MDQAwkiAgxo
+        uHDBgcUPHZBIAJEgQYSPEQYAJEKiwYUKFRo0ePAAAYgBHTooGECBAAEGDDp6FHAkwwNNlA5WGhh64EAB
+        BEgR2CRAwaOEJAsOOEj5YCiEokaTYlgKgqcSAQkeCDVwFetRBBiUDrDgZAGDoQbMFijwAW1XKRMUJKhb
+        VGmEDBOUBAEAIfkEAAcAFAAsAAAAACAAIAAABv9AgHBILBqPyKRyyWw6n9CodEqFUqrJRQkHwhoRp5Pt
+        NPAKJaVTaf0xA0DqdUnhpdEK8lKDagfYZw8lIyMlBFQzdjQzMxolISElHoeLizIig490UzIwnZ0hmCKa
+        UjAxpi8vGqAiIpJTMTWoLCwGGyIhGwxULCu9vQgbwRoQVCotxy0qHsIaFxlSKiYuKdQqEhrYGhUFUiYW
+        JijhKgAEF80VDl1PJgsSAhMTJkILFRfoDg+jSxYZJAv/ElwMoVChQoMGDwy4UiJBgYIMGTp0mEBEwAEH
+        6BIaQNABiQAOHgYMcKiggzwiCww4QGig5QEMI/9lUAAiQQQQIQdwUIDiSAdQAxoNQDhwoAACBBgIEGCQ
+        wOZNEAMoIllQQCNRokaRKmXaNMIAC0sEJHCJtcAHrUqbJlAAtomEBFcLmEWalEACDgKkTMiQQKlRBgxA
+        dGiLJAgAIfkEAAcAFQAsAAAAACAAIAAABv9AgHBILBqPyKRyyWw6n0yFBtpcbHBTanLiKJVsWa2R4PXe
+        NuLiouwdKdJERGk08ibgQ8mmFAqVIHhDICEjfSVvgQAIhH0GiUIGIiEiIgyPABoblCIDjzQboKAZcDQ0
+        AKUamamIWjMzpTQzFakaFx5prrkzELUaFRRpMMLDBBfGDgdpLzExMMwDFxUVDg4dWi8sLC8vNS8CDdIO
+        DQhaKior2doADA7TDwa3Ty0uLi3mK0ILDw7vBhCsS1xYMGEiRQoX+IQk6GfAwIFOS1BIkGDBAgoULogI
+        KNAPwoEDBEggsUAiA4kFEwVYaKHmQEOPHz8wGJBhwQISHQYM4KAgQ4dYkxIyGungEuaBDwgwECDAIEEE
+        EDp5ZjBpIokEBB8LaEWQlCmFCE897FTQoaoSASC0bu3KNIFbEFAXmGUiIcEHpFyXNnUbIYMFLRMygGDA
+        AAEBpxwW/E0SBAAh+QQABwAWACwAAAAAIAAgAAAG/0CAcEgsGo9I4iLJZAowuKa0uHicTqXpNLPBnnAT
+        LXOxKZnNUfFx8jCPzgb1kfAOhcwJuZE8GtlDA3pGGCF+hXmCRBIbIiEiIgeJRR4iGo8iGZJECBudGnGa
+        QwYangyhQw4aqheBpwAXsBcVma6yFQ4VCq4AD7cODq2nBxXEDYh6NEQ0BL8NDx+JNNIA0gMODQbZHXoz
+        3dI0MwIGD9kGGHowMN3dQhTk2QfBUzEx6ekyQgvZEAf9tFIsWNR4Qa/ekAgG+vUroKuJihYqVgisEYOI
+        gA8KDxRAkGDJERcmTLhwoSIiiz0FNGpEgIFAggwkBEyQIGHBAgEWQo5UcdIIiVcPBQp8QICAAAMKCUB4
+        GKAgQ4cFEiygMJFCRRIJBDayJGA0QQQQA5jChDrBhFUmE0AQLdo16dKmThegcKFFAggMLRkk2AtWrIQU
+        eix0GPB1b9gOAkwwCQIAIfkEAAcAFwAsAAAAACAAIAAABv9AgHBInAw8xKRymVx8Sqcbc8oUEErYU4nK
+        HS4e2LCN0KVmLthR+HQoMxeX0SgUCjcQbuXEEJr3SwYZeUsMIiIhhyIJg0sLGhuGIhsDjEsEjxuQEZVK
+        EhcajxptnEkDn6AagqREGBeuFxCrSQcVFQ4Oi7JDD7a3lLpCDbYNDarADQ4NDw8KwEIGy9C/wAUG1gab
+        zgzXBnjOAwYQEAcHHc4C4+QHDJU0SwnqBQXNeTM07kkSBQfyHwjmZWTMsOfu3hAQ/AogQECAHpUYMAQS
+        xCdkAoEC/hgSACGBCQsWNSDCGDhDyYKFCwkwoJCAwwIBJkykcJGihQoWL0SOXEKCAAZVDCoZRADhgUOG
+        DhIsoHBhE2ROGFMEUABKgCWIAQMUdFiQ1IQLFTdDcrEwQGWCBEOzHn2JwquLFTXcCBhwNsFVox1ILJiw
+        dEUlCwsUDOCQdasFE1yCAAA7AAAAAAAAAAAA
+</value>
   </data>
   <data name="Menu_File_Login" xml:space="preserve">
     <value>Login</value>
   </data>
-  <data name="navigation-180" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\navigation-180.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="navigation-180" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACe0lEQVQ4T6WPXUiTYRTHH9+p
+        ROpdli6IhTPJlDmZMiy1L3ItKMH8mAU626ZRlBhRJhTdKNZdYEFpXXQRFFGp1fyslFIxsLmtfTjtHa5a
+        Sy90b7CLjdNznnKvSNFFB35wnvOc/+99XgIA5H9gYUlWD5FkPycShZnSlyLJ6TdQblNe/AZ7A7vDHdyl
+        GcyuFWiS1EM9expc7vrri0vnbgrhpg4hbGpfXCo2Od14RwWavwk0yUWvR+qvLQaNbd+h5upXqLrEQ2mT
+        k/XGtgDUtQaCGwpfjVCBZs0LulOT8sy9htZvQV0LD5XNnxgrpT09zc54V315PpioetkryepOFX8h84lx
+        l94yU3HRA4cbPzJWatwSgIOnLNF52Xk35FZOzEhoJirgMh51VTTPLpecnAIEKxQKwfAYDxnapwz5gccM
+        7PN1b5YxIwrSH/TpWmbD+03vWdDr9YLdbgeHwwEejwd4ngefzwd+vx+2aXtBeXQozNGMKEi7319+wRXZ
+        WTMONpsNrFbrH8MLCwuQWToMivKRCEczokB27+5e44dgjm4Sth8ZjIaf9VnZeTWKqkkqeRvkaEYUbLnT
+        kF4yNKc+4YK8WidklY1Gnz3wbh5yj0+z+QrSQvMcRzOiYPOt1HVbO81qvVsoaPgCBfWfQVE5wf4Zn62q
+        cbAZojzmFOJlnWaOZkSBtINwKTe0CfKusfw6r1B8dgmKKMrqKQb2iKqWF9andY3hLkczUQGhFRMvJzEJ
+        +kPxye2DskKzN18/L+xu/BFBsMcZ3uEO7mKtFsTS8ybKDsLJ9pHYsisk7sxDEtc0+gva4wzvCMmmpFBi
+        Vws4OkikbKRI/wF+CHc5FPwEO0ImlGXCA6EAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="Menu_File_NewResource" xml:space="preserve">
     <value>New Resource</value>
@@ -253,35 +1099,147 @@
   <data name="Menu_File_Connect" xml:space="preserve">
     <value>Connect</value>
   </data>
-  <data name="arrow-circle-045-left" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\arrow-circle-045-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="arrow-circle-045-left" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC0klEQVQ4T6WPa0iTcRTG/47y
+        g5aKpbiRZZJmWmTNxCtaiy7SksLIVmmkKOmsbCSjNMolZIg5vFBRqY28lHO6vKBNTbOSeG0gVpTLlDnn
+        xEtT5lCs0/lvXSiCPvTCj/c5z3nOs3cEAMj/YDneJtWQ4JJhEn5bRyLujnEi7xmESAXCIJ1IHsLHnRPN
+        0Cy9ofxZwOeV6dXJbTNaSd+CSar5CogRtTpJZazglerFWOD594LiIf6ucl1f4eAXyFEvQDYz/wMj6rfo
+        NeCuYGfpSHxw8RD7ty8IuPGBE1YyqJYOLEJW9yykq6bN+8q1moCCAQbpRN16pnVamdk9W4CZtNDijzy8
+        seXmv7f+Bf/cfmF8vV4rbp+C1AaDGWdmy/U3AhqgoI5C71pynV6KmbQjNbr9OLMRa4Fvdm+lqGPCJKzT
+        wY6idxo/yWsBXdLjDVcYsvGqmqC3NSy/X3xKPiIUthhi8MYLsRZ4XXjOZDydhKRaLVC9PquH+OKhe7qK
+        rBG1E4/zHcRT3EVz3LgHnyIxG+F98YWHd+ZLawGGmNQWA5zAAqrdzz4hqxBasPpc2y3q/Qn16d5SwE5t
+        qoypHjZFV49AYO4rDTulUbAyUUHcUhoJR9h8DPdMkmoSDin0FuKaxoF6iLUAw0JuXq82tGoMohWjZpyZ
+        FQm1Asf4h8T5pJzui6h3sHkKAmSjsLd+AuhMf8RS4BhXzXFOlKuDHhvBr+Yz7FaOmzdJujUOx6sYCtVh
+        DTOwrmoK9rTOAtXfd9aC5UcriH2sjO+QIO9bqzSDW+0ceDeaIVA1b4FqjmIO/JvNYHf4PhP1bN7yRqwF
+        9GG5+pAl4Rl821iZ2v5Sj3ZZmcFkp1yEkK5F2FwzbnKV9Ghx17H0wJ0chKGwXHx+FWCHPeJh4+q3nRV0
+        +jIrqvARi3+z1wLV6Nm4+vIww2VxE0WsEJGM5n9+AQ62iBPCRjj/gGZcaP4bffAO2z+OFqAAAAAASUVO
+        RK5CYII=
+</value>
   </data>
   <data name="Content_WebBrowser" xml:space="preserve">
     <value>Embedded Web Browser</value>
   </data>
-  <data name="cross_script" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\cross-script.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="cross_script" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACFElEQVQ4T6WTT0iTcRjHn3D6
+        5nJbr+2dZo3Ci0KE6EC9rpNEl52yS4HFhKyItJIKCwnBlVYUFh0a2b95yYJRHdYunYJJZBZEeogxhJAu
+        ecnSt88zt5cF0WWDz37P832e5/v7A6/Yti3lUNawbpw3SIjIlEgXZArcfII2CXfhHjwE+nZRH4JnEHUM
+        tAiZ3wMD9nJf39pMe3tO8/slBg9ERhNVVe/QXz8S2QsbHIM4jRBlp8zbjo7ct54eO9vdvTIdCHziBKEp
+        rzeebm5eoJ6kb4duiEH+9Pk/NdBj3qF5QiQGmZlw+PvnSGT1ZVNTNt3SkkV7jlm99v7PQK7TMIbROCap
+        1tYfqVBo5XZ19Ry5XANdlb9OcAmhyLCINcIjJRoaFpONjT/HDWM27vd/HausnKUmF2CwgHOFonCewpDI
+        jceWlUsHg6sxw5i7KHIY7ektt3ue9cW5fxmcRFROi/ROeDzzmbo6e9Lny51FYkh06AzGMZfrI+tIP/mp
+        0kc8RnKc1z3Bvd9b1q83prlMnMTUVGM9oQ6gDcMresM641whSgJX4253bqG21h6sqPjQy0NG0Iu/ToKj
+        632XYfSIiMsxqKdwiN2/mObadE3NEvGVrSXDpWHbem9/l0ibY4C2ncLBA5jsF0kFRPag7QRC8YEHNoMF
+        24IinbtF9pUaeCn4QTdWdFAHNsFGMAqr5tprwhbHoJzP+Q95lHpGrVHH8wAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="disk" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\disk.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="disk" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABwklEQVQ4T6XOT0iTcRzH8e+e
+        7e7BgxDixbuXELyKlxQPgiwx/JOa4UE8CR4UFcTUubUJk4nhX6ytRHCCqJvicuEk6KBWZKgVRaIM/IPK
+        YLBPv8+jgwR5VBy8tvH7fd7PJgDkPqTa7FRcdUqvta3t+W1we9E4RarUm+LYenOi/giQuAE33LJhK0/N
+        DnJujkYRTyQQi8cNccMtG7ZSabZT3/rwAc5UfHR+bogbbtmwlQqzjdyfBv/iMBbD3vGxIW64ZcNWyrQu
+        8nz0/Ma++vUf0aghbrhlw1aeaJ00GHH/xO7OEf6cnhrihls2bKVU66ChsGsbga7NW+GWDVsp0dppNOTY
+        Qs/jcXRbx67Fu6S1/l9gw1asWitNLPZ8gb30NSKRNayshK/gGe/eNYXhLPPhQ98O2LCVYq2ZfAsvNuAq
+        f4tgMISW/H7dzMycjme84wM8z6bx/uV3sGErRVoTTQW7P8NdNQW/P6B/ks/n1yXP+ICR+nks27+BDVtJ
+        NaVLjqk4t8DUEGh/9OpwcnIBA7V+ndc7q0ue8QHexhCWbF/BPVu+MpSsTMmuyZPaVYvFYrsO7/73UAqH
+        L1tJUV/SlAd3xCblH+s4aw2T/BzJAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="clock" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\clock.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="clock" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACKklEQVQ4T6WR32tSYRjHD8Mb
+        xaIbK/oLhAxFkImEgU0R5y9Qb8pJHCgmLW/1diCMgZMuxqCNsW4Xu9vlqLHdBM0dY61Mzbkd80i0pcMb
+        u3p7voedFy3GLjrw5X3O83y/n/d9zxEYY8L/SA2Hw2EhGo0KsVhMiMfj1xKJxDgpRhIvhHocM3jgRQbZ
+        vwHmJ6KYXlpbe1OqVJrt09MBhBo9zAhgvgxgfjo9nduWpFa902E/z8/Zu50ddYXQw+xZOp0jgHnkBKFQ
+        6PrjqamZ7f391sfjY/aj11NDhUKBA9DDbLdcbiVTqRlk+BUCgYDr5fLyRqnRYDVF4aF8Ps9rADGTmk22
+        tLq6gQwH+Hy+R2/39k4AGFYymRx512bvDw5OkOEAj8fzvFSvDzSDdu9IJDJygk63qwK/yPIAGQ5wu90v
+        pEZDBWhhh8PBstks8/v9jH4hE0WRZTIZ9np9nVXb7QEyHOByuVK7kiQPA77RXZ1OJ8OqqU51qVpl5UpF
+        RoYDaLcHxcXFTXxlHFM7BYJajRWzT7LMXq2sbCLDAXa7/cbDiYnsh8ND5fvZ2UhoGNCm2edaTfF6vVlk
+        OMBmswkWi8UamJych+FXv/8PBL360ZESDAbn4UWGAwR6DAaDYDKZ7FardbawsLBVqVaVbr//u0f6StBi
+        sbhFoVl44MUzDNDR+y3SXZ1Od1+v16eMRmOONHehHHqYkece6TZJNwwYo4aRdJN05wphI3jHAPgDEUJm
+        RtMH560AAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="disk__arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\disk--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="disk__arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACIElEQVQ4T5XNX0hTYRjH8Xfn
+        7N6LLqKIILyMvClJGgVhUEpIIKuMM0vLkBBvCkYYuZA5XVv702Rl5ezvViI1yZab1dqqmRX5J00ry1il
+        xkANk8Fgv97n0KqFzDrw4Rye9/0+h5WLFlYuWmXq2tpFbTo/cZaTirZ2shzDAOOhvKCSO8kXHFzMBvvr
+        8Y11w5MF6m67vKCML+DMo9e+gZ7kX07ciWK3620a52cgV/t0co2+T2L7RDOxDLbGkEgmEU8k0hSdfgl7
+        FDg0BGj6fzs8AmQfDT9ne0UTsfW3fMV3Hs/Mz6epvtyH/PrQL1sMYeQ9BlZpbk4tq/JJrFQ0EseL5i+Y
+        jscxMTubkarGh3WVt6Fa7Qyo1rsYkwQDcfY6o5jif/8Qi2VUarsPve4ZqKGW7RH0pDniGMf7sRl8mpvL
+        iO7QXWqoZSVCHbkQtr6D3zD4T+guNdSyXYKOtAbNo2jceQkN6osLorOUnqaPoIZaphaOkyvdjUMwlVxF
+        JNKDUCichmZ0dkMbhkXy4JFtDNRQy4qFGuLpqh+AVXMdgUAQxwqaZB0dPhnN6IwWOA/cwsNTb0ANtWyH
+        oCXtgYZXcJS1w+v1y2/i8XhlqRktcFXdxQPTCKihli1RrGB5iuLNhYpqv27buem2ti6cqfDK3O5OWWpG
+        C9xHgrhnHAbdp5aelVxONsvdn88qniiVSuNC6OxPa9n2lp8ty+IfS7nl/4marB9dh0ZMPnnUHQAAAABJ
+        RU5ErkJggg==
+</value>
   </data>
-  <data name="document_code" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document-code.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document_code" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACEElEQVQ4T42Sz0vTcRjHn6t0
+        65CnDoLrIIIHD40OCUHQwMJwgQwvMkyHG7IxHH5LBQ/rD/APENOOHQbpKRgaJNIhiTUSjHBrboxhud+/
+        n97Phz3DwLQPvODz/fJ5vXk+z+ch5/IyCc9WVh6D59fQP760RE8ti8YWFw0kPzrMlJpN/lWrcbZc5lSx
+        yIlCgU/yeUNkb49xbgbY/gqQjw6zhXqdcxDT5+f8I5fjo0yGv56eciyV4jc7OywLZ2eBrVvBk1CIOniK
+        CDgrlS4NWdvaYsXmcLwEJNBoMKjMlRsN/o3y/xUilch14MypR4/8fsVbQQ/ylcqVIRIAx6sePfT5FF8V
+        AcVq9coQaSwcn3r0wONR5uutFpfRh2/HxxwOhzmJJp6k02b/OR43jZXXgTOvHt2fnlb8DQRkslm2LIs/
+        Hhx0K/mwv2/+HSUSnMUV4fjVo3tTU0qg2W7zu+1tfr25aSq5eJ31jQ1+G4mYOYETUI/uTk4qwRYCpAK3
+        283R3d1uyPto1Pz7nkxyHsFwgurR8MSEstDGoDRxjS+xGLtcLv6JIUrg6WT/6fDQvI4MG5wF9ah/ZISG
+        nE4hJJPWRhUSIv2o4VWqmI2L1ynhW86KI65Zt+12uuNwvDCzek2IDJucFUdXDza3eu32VQ0wIUB6Io2V
+        auSJZU5q+Jaz4gBx6SYY7OnrC9wYGHj1P8hZccT9A/S/eqCvfnWTAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="document_search_result" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document-search-result.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document_search_result" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACsUlEQVQ4T32Sa0iTURjHj2aa
+        SkUmTiNBUpeT5sCEUJIN24eELhpdjFREyMtcc0pmhihDRSfMLyaEgRE4I1u4EkSUgYww8ENChUOzVrrp
+        1Nzc5q4qT895c2st6MAPznl5/r9zeV5yvaWFBHKjtfUyUvEfUq41N5OCpiYCAITQRRBVzr09sHk8YHa7
+        weRwwLLdDj9sNnij1QLWViGpfgGdBFG97fWCGYMbGDRubcHi+jrMra6CcmwMNwXA+moklTnBpYaGYETO
+        nR3Ycjr/kfQODoKP1Pz8ZkZwsa4uGLFlexuWcNfljQ1YMZthzWoFg8XiPwm9DubEjCBPJPJzAedCsViy
+        aDDATyyip7DsXyVQsowb0DpGwK+o8COorEyRKhRdm1arp6OvT5MmFD4+jch6ezXGzU2PT2JCMdZKGcH5
+        8vJAbur0+s+KgYGJK/eaumbmV15RCmofyTv7+yfoo5rwOrQ7mKtnBOdKSgKRuL1eZ15ZWfczzfzQi3dL
+        oxTV9FeVoLS0m3YGT8K0GHP3GUFmUVEgtVRQKJW2qab1w3MG2wRF89E4ehW/0TfRYzvt2GbMPWAE3MLC
+        QO58WljQvZycHJENDMm+mazj39dsk93K4fbB8fGRddoJoxEc2GbMPWQErOxsEp+TQ07k5pKTfL7guVo9
+        7d3ddam1WlVNT09jjULR+HpqSmWx210fdDqgEjf+qYl8fisjOMzlkiM8HjmelZXZIJeP0D/tiVI58352
+        9ovD5XJR6FxYXPwUazt9HOXx7v4RZGQI6js61DRc196ujuJwhGHJydVI2z50zo1gs0MiORxCoRszgvC4
+        OBKVnt5FwxKZ7O2hpKSzB2NjSWhMzF+EREYS3zgQHU0iWKzfAhzRYQkJt8PZbHlYfPwtXJ9B0pBTSCLC
+        Qo7ROiQcCfWJqOAXIWscMdZSSXsAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="tick" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\tick.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="tick" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACHElEQVQ4T2P4//8/AyWYIs0g
+        i8EGMEwXZGCYLcTAMAeIQTSIv0iYgWGpCAQvA+IVogwMK0XlGVaJngFiD4blIhC9OA2YCTRkPtAwEIYY
+        JgDUtCHtXfl/IH0GiD1IMYCNYbHIPMNjzk+jHmX/j39Z8BvIP0OsAYwMC4RbFXYY3wu4kfjf+2rML54V
+        cpcYFgr7oBvgAfT/GSD2AIfBZH5Y2GQKr1K54XY+/J/L2dC/AssVrwHDKhloKFIYTBMEaTqT9Kr4L4hm
+        APFBBkwT9OGYK3FZZ5vtb7X15v/4FsjfAspXM8yABDrCBZP4z8Q8zf3lcSHyf8TDzD8MQD4Q57JMFT6t
+        vMXkh+Imo//88+XvA8V6GKYIMDFMFWAAYYQBfXweDL18Z/xvxv9U2mP83+FCwA8QX2qT1mfpHTr/+RfJ
+        PQHy5zH083MADQBrZvDmQDKgl4+BoYPXg6Gd94zxKedvEoc1/2ucsfwvfkjjP/8quVdA8XUMXbwCQAMY
+        GLw4GGAA4QJ3dgaGVC4GhmZuD4Ym7jPSB7S+CJ9V+c+3TfY9YzPPboZWHmkGV6AaNIAwACahwMzAEM7m
+        wVDEfoZrmdgLxjKOI0C+JoMcE4ZmkACyASAVQPcxyAOxLoMxUxpDPNMZBm3GUCBfE4iVgFgKiIFJkoEH
+        iNmAmBHZAEagAMhzwNBhEIcqloSygZmAARhvDLxADPQnWDPQqUgGUJKdAYAsiHz3wn5/AAAAAElFTkSu
+        QmCC
+</value>
   </data>
-  <data name="cross_small" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\cross-small.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="cross_small" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAA0ElEQVQ4T2P4//8/AyWYIs0g
+        i4ebASsYGBhWMjB4APEZEL0UjQ+SRw9wFIElQAVAfOZfScl/EA3E1Wh8/AbMBxowD2jzXKDmH8nJ/5Hp
+        hQwMxosIuWAqUAEUVwPpMx+8vf+D6CkMDIU9QLkuQgaAFHQDXQBUfOaFoeF/ZBokTtAAJaABzUDND2Vl
+        /4PoZKDNyHyQPN5ABMrLWTMwJGUCNcsyMPgD+dL2DAxRIL4VA0MKkK9IyAB+oCJxIJYEYmEg5gNiASQx
+        QbwGkJOpBj4vAADjam5oGtX6AwAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="Log_Saved" xml:space="preserve">
     <value>Message Log saved to {0}</value>
@@ -289,8 +1247,18 @@
   <data name="Menu_View_MessageLog" xml:space="preserve">
     <value>Message Log</value>
   </data>
-  <data name="reports_stack" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\reports-stack.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="reports_stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABm0lEQVQ4T42Ry0tCQRTG5/EP
+        hEFYK6lVLpVaeJMsjTbRJjdu2hQlESnEbRPoptplRBC4D/orekeLiDZBBXGhTYsgytTM9+mMOtadm+XA
+        j2Ee5/vON0MAgBA7IWyKEa5zwleQ+pxADv4gIe4RIaAUEvtSLwnGYvN41nLwZX6I/CqQ4GF+p21r4Iw7
+        IZAMgLYz2mR2PwJVlOVRFIgqAu04+3f9UK5WgS/yI8TUQVvOnk0fFCoVYGF2jNQFuhyOfzNL5+EtH3yW
+        y8Bm2AlSF8AxZxgGJJNJqGB7xlPOhMgsnQfXvPBRKgGbZqdIU4BM6PqCyFZEdRWxL521DS+ki0VgIXaG
+        WDvI4eH9Y9aEyCyd3asapAoFYEF2jnx3MBIOR0S2TD5vQexLZ098CNK4puP0gnZSawepXA5uHt5NiMxN
+        50mWoQP0kvbTPXy7PvmIxB0K6SLbSzZrQew3ncfoFRb2NLBZfuE5nYbr2zcTtcyqs/g7MRrfSGwu17rI
+        9opvoFLLrDorAg6RqZatFTKzLFQEOnDd/SObzKjONrX+CySWIL/K0gqeAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="Menu_View" xml:space="preserve">
     <value>View</value>
@@ -301,41 +1269,190 @@
   <data name="Error_Closeable_Singleton_Content" xml:space="preserve">
     <value>Singleton view content cannot be closed by users. The AllowUserClose property must return false</value>
   </data>
-  <data name="applications_stack" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\applications-stack.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="applications_stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABc0lEQVQ4T5WSMWvCQBiGv8Ut
+        pZMIxcVMri4ZI4hjBhUdikvpYKmLS5cu/Qv5Bw4OdXCRokYQHKoGETooLhldgw5ZxMm399kkikZJAw+5
+        cHdv7uU5IvdJp9NULBZ9SqWSLHgUVK7AczJFo1E63VwoFMilbJrm0rIsLBZzzGYzTCYmxuMpptM5DON7
+        KdaVz/96+M7lcszrYDBAv99Hp9NBu91Gq9VCs9lEo9FAvV5HJBKpXASIYxEjgl72+z1uwWuu9s7n85+G
+        YaDb7foMh0OsVitst1vsdjtomlY9BITtPRr9oNfrYb1ew3EcZDKZmnfc0L11XYdt29hsNlAU5e0Q8J/e
+        qqp+JRKJDyYejz/zZt93mN7ZbPZdXJ0Hl3vuf9N3UO9UKuXdPwrl+7y36E7JZPIvJIzv896xWIwYSZKI
+        2CU7ZbdB8NxF72MBInbJTtltEJ5vWZZPtx3H7JKdstsgfN9Ed4EJwuWT5/XaW6yputouMn4B8esdOkQY
+        S3EAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="application_browser" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\application-browser.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="application_browser" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACiklEQVQ4T6WUXUiTURiAT3rl
+        heBNXQTdCGF2E+1qUIwkiwwsleyHfonUrAhCMTAKE7xINCORgnSslqYNZSmJusrQnH9zttraVkNJdLOt
+        uaWbzrH19H1eBF2aLzycc97D8/KeA+cIQGwEkZ+fnypxSqJwnchOqsjLyzttNBqtLpcLp9OBzWbDYvmI
+        yWRiZGQEaY+hIZlRaT7B8LCF8XE7PT0frLIrcnJyig0GA319fVKyh+7ubrq6utDr9XR0dKDT6WhtbaWl
+        pQWtVotGo0GtVtPY2EhiYmKhfIQi6Q7+K2RX5ObmXo7H48RisX8Ir8YwTC1T1h8kX7/Awbafa6O8lvPL
+        0TiyK7Kzs69Eo1EikchfvnnDFHS6uaB3Uz/qp/XLIp3ORSYXY7z6vsLVXh+FXR5kV2RlZV1bWVkhFAqt
+        YZ8LcPL5VyoMs+jsAUyS1Gz7xRNzAKM3gj0K9lVQfw6yufxdm8jMzLy+tLREIBBg3rfAuSYzd3qmuTfo
+        oc8TkQr8ptkaoF3qYPBHhLFgjLEwGEOQeNfxXqhUqhvBYBCfz4fug5Ps+wOcb/vK5c5pnjpDVL6b5fbb
+        WV44luj3w53XLrRSvmMeEkqNA0KpVJb4/X7cbjeXHvZSrLVwSG3ngMbBUa2DEy9dnG2folg/zRnNJ47U
+        j1JniVIuVUso6BwSCoWizOv1MjMzw76SZ5R2z5PRYGVX3QTKx1b2PLGiarSxt2GSc+1ubg7FuWYIo6oz
+        s+m4ekSkpaXdktv3eDwoCh6hrHjDfvUc26tG2VEzQXqNmZ21ZtKrx1FUm1E9sHOsPcy20l7E4dpxkZyc
+        XJSSklIlIzIqTeti98UmIUWSxBaJretEdpI29JTlb+APrpaoVzbDpskAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="application_sidebar_list" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\application-sidebar-list.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="application_sidebar_list" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB90lEQVQ4T6WUz4sSYRyHX/C0
+        B8FTh457ka6ePHnykAdBBaHoGrsVFUTQpQ5dgg79CWaylkwIYgji6uouozO6jmGmos5arVrjriZKGopo
+        n97vHvY0BNu+8MDwPjzD+77zgwFgl4F5vd5Nzk3O1gWhZpN5PJ5bsizX2u02Wq0m6vU6KpVPKJVKKBQK
+        4A6SRBzy64/I5ytQlAYSiVyNWuZyue6mUikkk0k+mUA8HkcsFkM0GkUkEkE4HIYgCAiFQggGgwgEAvD7
+        /fD5fDAYDFu0he2j3gzNzq9z1O4Uqqryo/n3oJa53e47t4U/uOH7jeuvTmF91sa1B5/RaDSwXq+xWq10
+        IUctczqd96pHP6HUfpxTUYeoVqtYLpdYLBa6kKOWORyO++XmKV4KTXzYLSASlyEqxyiXy5jP55jNZrqQ
+        o5bZ7faHpbqGw0oHYvELdg9UpLJf+UkrmE6nGI/HupCjltlstkfF6nc8f1PD67f78L87wF7umD+uPCaT
+        CYbDoS7kqGVWq/VxVukgnfuGjNTBvtxDWupBFEWMRiNomqYLOWqZxWJ5kpa6fAUt7AgSdt7n+Q00ZDIZ
+        DAYDdLtdXchRy8xm89OMrCGnnJyRLZ7wLWhnLxQtv9/v60KOWmY0GrdNJtOL/4FaxscG5wrn6gWhZuNS
+        nzL9Bv4CC9e7f90EUzwAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="database_share" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\database-share.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="database_share" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACqklEQVQ4T5WSa0iTURjHz6oP
+        Db8EpfghDLpRKH5RhBXJGIE52VzNVaybEGibFZZ9UNIuGDgIxRRzF3NL1FDx0tzm5iWdl3nZ61Rkajd1
+        inOogRJlkPDvvAMTh4Ed+MF5Xt73d97n/xwik8lIACJap+wC9j0S+DERi8UpS0tLmJ6ehtvtBsOMwmzu
+        hdU6hL6+SfrMi4WFnxCJREqJRLKzwOv1wuVyob29HSaTBbqyWhgqjGg29WJg8CNmPav/K6iBvqIJRnM3
+        +ocmMOP5tiXg8xO2tUFbiFIoFM1arRZqtRoqlQqZmZnIzs7270tLS5GRkdFCW4jxtxASEhMoCMhgBKYW
+        O0y2HnQ5hjHi/ozZheWtPyAkfJuEDTEwA62+GrrKGtRbrOh2Mvjkmd8uYCWbo9xJoNFXQVv1DnUtZnQ5
+        BzE1N/NvQXLiuV1lIBQKYxISEghd4cMsUqk0lcUgP2gbe6OEU6uEqyEfTocdzbYONLbaYOu3Y2DChSnv
+        V/D5/FSBQEBIenoRJJKH2NjYgNFoBL7U+Pk9WYn51jy0qpJQnnsbakMxqqz1aGM6MT43gcjIyLQs4WFC
+        4uPTwONdh8/nQ3V1NdZdOqz1Ff3lB6PBVH0WGp/Go+r1Ixhr82EpkKNQxHV0JO9Tkujoy4iISPRfXY1G
+        g+8DJRgtT4O94BraVDKMGe5h+cNL/KLit/fPgCm7g1V6AFs3yffqSFycAlFRMiwuLiI0NPT5K2nw+GDJ
+        jRXP+ydgNCmw5Eqgv8uDNjUanflyzBtz1nvyLrgbFMe69Bf3XKEhnlhjCQoKyuNyuQ/OhpGbj2NJXeGl
+        Q+OOwqsrPksuNmHr4qTgkRcCTsn5oxye+BSHnQIJo5ymRFCOU05SoqjoFit6xifMJjmxpDb2CKH3lxyg
+        7Kdw/gAsOxzv+3rD2AAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="database__arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\database--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="database__arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACRElEQVQ4T5WSX0hTURzHz8Mc
+        Wy+BD1F7DYSg9VC0WhANwkW1BmPsbT02aK0eGkMrif0hehmMFNO5cuaczk1NU3e3eafiWrZ5Z+tWOpKc
+        XXGQFFQvPX47V4wwDbYDH845nN/3C+fLl5hMJrLNFbpbqkSc3dL9ERO9Xm/Z3NxEuVzG0tISeP4d0ul5
+        TExkwbKLyOVWsLz8BZXKL9BZq8FgICI7DCqVCorFIhWmkUymEAoNI/Akhv6BBBLJPBa4T/gs/KzBoG8Y
+        XdQgHImDSb1GnlvBmvC9FoMh+J8Ooi8yiXjqFXJcCWXh238NTthstvFAIAC/3w+fz4eWlhY0NzfD6XTC
+        6/VCfHM4HAzNQLVnBv+GyE5nMRafAZPOIpMvgi+tYq3ytfov9IZj6AiG0RMdwYupaWQLRawIGzUY9Efx
+        OBhCMBrDKDuFl4UCPgpCDQYDUbT3PEN3bBDP2QTmCnncZQRccHT1NNo7icbWuqMHVYV4vo3/oX5UWj7V
+        tmo+9pAnxGg0bqHT6XY1kZ3NwNLN4WJrAZfb30DfwcPQ9R4dGwAVc8oHRTNRqVREq9USjUZzbWcTk+iN
+        RHDGxaJ1HbB+AK6+/Yu9BBy+k+GIuBoaGohSqby+l8ElVwzHm8Zw8t441PcZnHVP4XQWOGid5A7ZGLOo
+        l1MOKBQK+64ezM5hKDGBkZlJJBemMV/KQdU0iv2mzvV9527f2taSeno4KpfLb8pkMlddXZ1LIpGIuCke
+        evdIpVIPffPQGbdUfWNRekQXEDWU+t+QVDs9OokdeQAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="images_stack" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\images-stack.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="images_stack" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACAElEQVQ4T6WRXUiTURjHz03o
+        lK0EE1SwL9JCvJj4dZF14S5sMEVJB13YRYiitpjKbt7cuhGxZJDlLoKapkwqxUVRM9YkEwTPhR8QTENE
+        /ID0ItLEhrp/5znqcFim+MKf83J4nv/v/fEyAOw4YSVWK7vR0LD3NIi7ikPGEFZQYrOxIkWpFF+E4H9C
+        MzS7j1ysKK5+zvH86bV/5pUzA5vBIAwWS5UsOCr5hVOH31tbuG4211CBdN4l6x9wFLRwFNs5DA85bj7m
+        uOXguNfN0ebxS7KrS49fGxvQVVebjuTc+WlEkjvaC/EjEMDV8nIzIw9qHe2N/UtOh+5o5uXAsCQ3N2Vh
+        eX0dOWVldYw8qHWs7yz875Mw+WE7Ux/PYHrgPL55z2HSkyTJLq9Pku+atFhcW0O60Whh5EGtt3VX4LRl
+        YO7zJcwPXsbyRDYCK0b8nNFhYShVkq2vvZLscLuxJIpS9HqFkQe15iYmoiAtFfY76ehpyYR/uFT86Uas
+        fDdhdjBbkmvb+yX5Yn6+75RW26hOTq5g5EGtbnuUSDTePlLjXasGX1wxWPiagHFPHHzPToaRL+TlNTPG
+        EkRUjDyo9UltZChtdSo476sw9EaN3tYoOOoj95FPaDRiXzzkQT7zq6sHhmbCyNvrjJEH+RwmNBsi7xaI
+        M0IkfseJvA6Kas+efP0DD+tcAk1PV7wAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="layer" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\layer.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="layer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABwElEQVQ4T6XS6ytDcRzH8e8z
+        yTMkUUpJLsntP/AP8ERJuSV3kdwe+QvkkrtaybXUMcPmNilmdjEP7IHNZbScmWNnmLtH8/sclvFAR1av
+        zvme832fXRr5/X76D8pu10Ick8sUyoRdNERZbeuQZzrxrlz73iyC79X8G+xgFw1aymxdgyLh7nXP6XnS
+        yoFdNGgpo2UVit23L4Zz4XFNDuyiQUvpzStQ6vI+60/dD8tyYBcNWkpr0kAZ++g6G3+vDnbgvFPq7eKE
+        1no1pN6/7J03851gPPHOoEFLqY1LUH4mPG1Znb4F2D+75Vg0OmfiuznjRZfE8EVn80yhQUspDYtQcex+
+        2GShcvvQMzlvdvVxBr6XM0p6pCPmj2s9Ops4gwYtJdWroOqQv9/YsArj7F0H5ozf9LM5QLrHHjCLBi0l
+        1iqhxuK40ShN/Agz/AnnwTOuS7PO7uHQoKWEag7q9EeiSmV2KQLY11AA5p/nO3ZRhQYtxVfMQgP7ZTUL
+        FteYZO/zGJiDj+wedtGgpZDoZIotmayc3nKssr/o8u6RqP4NdrCLBi1e4WFpuTkR+YNNkQWKDjmwiwYt
+        HhDKRDExf4Qm9B0h5nPvHST9+wAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="map" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\map.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="map" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACnklEQVQ4T52RSU9TUQBGu1V/
+        gMYdS8PGhQtDXLgwcWEwMYYNCzYNFMFSBqENswwCgUIjg6KCgMVQELAyyVQGsVBskakWFASEgoWIYssU
+        huO7L/4A8SVf8hbnnLx3ryIoLS1QWth/LBBQKG6npKiklxM/fz2F4lZiYvixpNcOJdM8ms3QdAnOuVrs
+        c10Yp6bJsq2gG3QT0+lG3eImosmN4IUnf8FNrTbi8PiY55YEuuf02FbKGXWVs7lr4ZN3lro1H6lWN5lO
+        SLZDhNmN4IUnB27ExUXuHx1R3hlDq+sBlq8GOsf0fPe+ZmPHysjPJfI/LJD3GdIn4W7LMoIXnhy4rtGo
+        dw8PKWmJ5ElXLDX9iZgdOfRNGJicqcE2206dy0WGdZGEviU0HUsIXnhy4FpkZJTv4ICixnDq7EmYpzMx
+        DiQxvPyYhU0TP3Z66XX2Ylr7jX7+mNjuRQQvPDlwVaWK3trfR/8yDKNVS/1YCs+64+mZL8KxWsHqVjMO
+        V4P0K4tULO+j61tA8MKTA1eUytjNvT0KK1VUD8RTa9NR1qahbSaX/oWHONdrsE9XsOyz07nhIX3wC4IX
+        nhy4HBISt7G7i6EsgvyqUArqQiltV/OoPZrKHh317zKwOsuwT1XTNdFB8fA4gheeHLgUHBzv2dmhxKDG
+        aNZR3XuPAlMoJkcyZmeWdLWFNL3PZuVXI+vbgzQ5LAheeHLgYlCQdnV7m9J8Dab6FGpaE8g1KjGOaGn4
+        mCpdbQ4vLMlMearweFsYHH+F4IUnBy4EBiau+HyU5kVRnB+FvjicvAolebVK9A0qit+oefpWOpu+NLps
+        ekbGKxG88OTAuYCA+x7pVL95vf88wQtPDpzy87tzxt8/56QTnhyQntPSzko7f4IJ/rQI/AE63awC7yrB
+        bwAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="printer" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\printer.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="printer" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACYklEQVQ4T42SX0hTYRjGX1To
+        omIggdDVLvJi5o0IJjrI5ZgtNuG4KVsodtPZGSNScirHzY2mTIQSDPVK8MKBN6JSyVTUGAkTuqyLBInU
+        iQRZ+OdChz5978nBxJTew+/84/c853zwkbO7mzLUh0J2gXwJdxzBIEldXecgfpmF51c6jdTBATb29/F9
+        b09jJpGAcDyCwgsFkqpSFsrvoyNs7O7i684Ovmxv43MqhdjsLHiEp1hbW/UmRSGmzuMhcjgcVCfLVNvR
+        wXj3j4/xQ3w1u+TN+DgyFFqtAQE9qK/XstrJ6XSSo6mJbG1tvgNR8PPw8EIJ/wkvhx12tcxZQY54sAs8
+        eXl5r/x+P66CHXY5IwpySJKkW6qqhnbEmhVFQSQSQTAYvEAgEEA4HNacra0tdHZ2hjhLNpvNMDg4OLa2
+        tgaXy4X29nbIsozm5mZIUh2qq82orDSirOwerNZHmjM3t4yent4xzlJNTU3V5OTk8urqKsxmswh7YLFY
+        YTRWieD9c5jNDzVnZmYBAwPDy5wlk8nkSiaT60tLSygpKUFDQ6OQ7P/EYqnVHFkcExPv1zlLFRUVz+Lx
+        OGKxGPR6PZzOJ7DbH18KO6Ojo5iamgJnqbS01J9IfMT0dBw+33P09w+jr28I0ehwFiPi/i9ebysWFj5p
+        cJYMBoO6uLiC+fkVuN3u/yJTwFnS6XQt+fn5vUxubm5fSmyY6mgKr9+mMPTuAypfuHG3UYXRO4Jvm5tg
+        J+NzlsTcFNxmCsrLX2qbPmtOTk/BpE9OkBZXdjL+WZY7iK4VFNCN4uKn14uKolfBDruZ+QOvqgI74xfB
+        qAAAAABJRU5ErkJggg==
+</value>
   </data>
-  <data name="document" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABp0lEQVQ4T42SzUoCYRSGz1ba
+        tahVC0FbSNCiRdIiIQgSKooMWrhxUSk6yIgoVhq06QK6BbuANl5A11CLVlGgRUjl//h7es/gCYIa++CB
+        meE8L+c7cyhUKJCwf36+BY4m4NnL52n35IR2cjkbkg9jjluDAX90u/zWbnO52eTnRoOf6nWbm9tbRt0x
+        8P4IkJcx0Uavx1WIL7UaP1ar/PD6yveVCt+Vy3xdKrEc1EaB97uD7WyWxsSaCHhvtX4NuSoWWfEGg2eA
+        BNpMp5V4u9/nT7T/V4h0IteBE1ePNkxTSXQwg3qn4xgiAXAS6tG6YSiGhYCmZTmGyGDhGOrRWiymJHvD
+        IbcxB6cQ+TtwkurR6uGhYvYRYGEOTiFvuCIcUz1aiUSU1GA04i6u4RQiewInpR4th8NKeogA6cIppI4r
+        wkmrR0sHB0pmhEUZIMApRJYNTkY98gQCtBgKCVnZtBG6cAppYUZSK4649pnz+2k+GDy1d3VCiCyb1Iqj
+        x4WHmVm//0ID7BAgM5HBypXkF8uedPEuteIAcWkaLLjc7tSUz3f5H6RWHHG/API/kG3WfDzsAAAAAElF
+        TkSuQmCC
+</value>
   </data>
-  <data name="folder_horizontal" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\folder-horizontal.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="folder_horizontal" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABLUlEQVQ4T6XUvUoDQRSG4a/K
+        JVh4EXsPVl6FVQrBykJEQZEkrIn/GBSMEIQIoogiFinEFIKgxoiCiGBABTG66MrihpC47B7nExt1txhT
+        PMWZM285AxFBO1BOI1IlA0NJRDDYMo4rqSh+EIjbbErNcaRqWdJ1EohRrMv3/TiOTJjibkvgbP7AM+ts
+        4svvHWfu2eIwhYxvr4v3VPjDVxdrZVNu94dCscVBAlOetSqth3yoD7UL472uCVuUxjDbelyRxt2SFjZs
+        sTeCbOM+J+5NVgsbtigOY7FeXRDnakYLG7bYHUTu/XpO7Iu0FjZssTWAvHM5KS+VpBY2bLHRj8Lb+bg8
+        H49qYcMWy73YcdRgnya1sGGLvm7MT/eg9B9s1WtATOlQOjWxibX1lPkNfAJSiLGOr2CqXQAAAABJRU5E
+        rkJggg==
+</value>
   </data>
-  <data name="blueprints" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\blueprints.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="blueprints" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACLklEQVQ4T4WSTUhUURTHz8q2
+        BW2azURMJFkQBIEQjqsoaJHmQIuWWREMlZl9qOnCTS6UgoohZ1pUZpPDUFEUVkrqaM2FMiVnkomk6cOQ
+        t3Dec56r0/lfmsfzMdWFH9zLfed/fufyKBhboNpbvzTY/zlH5KzKURUKBbY2NFBlfT1tqaujUoETUtP3
+        gwTVNlnkxNwKnxle5lMvinxyqMiHB/IsxceEwF8DYLA7klfJ3AqPfrV54KPF/TMW3/lg8YG+DGNJ8XFh
+        s9tglXIw+tPaf2+RQ/FFPprI6pATTw2u6U45+MLPlEDQ/adyy+0n3JjIcPfEkg6BCcbZdTWnBILuf5XD
+        0UfcOJjh8HNDj4M32dmTVQJR9fV5oC6mTI7P4tIoq1zVPurc4WF3XJ5RAhE0oNM6UeB4xnJCvMp7o/N8
+        +qXB96VJy2uLt3W9UwIRNKDTNlngsbzNTa8Mvjll6m5u5dobOafB+TGTKzvTSiCCBnTa3xR4MGvxAwEh
+        6FYaB8r7InPyTxg65MK4yYHWlBKIoAGdS28LPP7N5uYRQ3/Yk15apbzn2qxuAMtkzuaNZ0eUQAQN6HSk
+        xeCTpQNi06bTDQ8L5ereaYblw882d6plXn8kqSp824mgAZ0O6ZiQgFIIurmV/c3D1pqDMVWiIniun4g2
+        0YZDVwg6j7/YnPpu6xCMggC3sr9paEoKfB7WyZnWQqfrvckIgQnGwZt4leVbXeBdftG569Yrt3eUPdW/
+        Ab7ReT9BDLTyAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="SiteExplorer_SelectedFolder_CreatePackage" xml:space="preserve">
     <value>Package folder</value>
@@ -364,8 +1481,18 @@
   <data name="Content_Welcome" xml:space="preserve">
     <value>Getting Started</value>
   </data>
-  <data name="cross" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\cross.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="cross" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABfUlEQVQ4T6WTu0vDUBTGz1+g
+        VBtB1KBgdSsUNFvHQoZChw4upWoRupYO7a6giw66KCj4wgciuAiKg5M4XcFBUHAVBxdXcfD4fTGJqaZT
+        hx+353yPezNUVFU6oaMwL/YKDkXkCJyIuMDw5LzvE6cx87eAIaPNpvIEbqTA0z5qtVBrKfCN5qvR0Id8
+        Xj/rdcXOAJYQ81apeNpLqRRovy/YxXOAuwPje7Wq146jr+WyciaPhYK3u8vlvB29zISfwAGCbEHYhOG5
+        WNSLdFpvs1m9ymR027L02LaVGj30xhbAIBswrMN4nkrpXiLhcZBMKnfU6PlXsIjlElgBqzCtwXyGW08R
+        DuCOGj30MhN+QlCw/GMwlwjGQY2edgUUzA3CAZzb7NyWF8zjOcDcIxzAeQG3kTiNmfATbAxTMNYRekIJ
+        T87D2JM4jZmwAL8HwdiEyNw0wpMis5hHwRAYACOOyAw1ejCPMxMt6MKiF/T79OHsAd2AWgJYET3JfVjQ
+        yd/5G8s+qAWdGU8YAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="Menu_File_CloseActiveDocument" xml:space="preserve">
     <value>Close Active Document</value>
@@ -461,100 +1588,77 @@
     <value>Failed to decode the current bounds,
 you must re-enter the epsg code in the SRS tag manually.
 Error message: {0}.</value>
-    <comment>An error message that is displayed if the bounds are in an unexpected format</comment>
   </data>
   <data name="ResProp_EpsgMissingWarning" xml:space="preserve">
     <value>You must manually enter the EPSG code for the generated bounds.</value>
-    <comment>A warning that is displayed when the user must re-enter the EPSG code</comment>
   </data>
   <data name="ResProp_InheritedAccess" xml:space="preserve">
     <value>Inherited</value>
-    <comment>A value that indicates that the user has inherited access to the resource</comment>
   </data>
   <data name="ResProp_MissingBoundsError" xml:space="preserve">
     <value>Missing bounds tag</value>
-    <comment>An error message that is shown if the resource is missing an expected bounds tag</comment>
   </data>
   <data name="ResProp_NoAccess" xml:space="preserve">
     <value>No access</value>
-    <comment>A value that indicates that the user has no access to the resource</comment>
   </data>
   <data name="ResProp_NoSpatialDataError" xml:space="preserve">
     <value>No spatial data found in FeatureSource</value>
-    <comment>An error message that is displayed if the attempt to read the data reveals that there are no spatial data in the featuresource</comment>
   </data>
   <data name="ResProp_NoSpatialDataWithFailuresError" xml:space="preserve">
     <value>No spatial data found in FeatureSource, one or more queries failed to execute</value>
-    <comment>An error message that is displayed if the attempt to read the data reveals that there are no spatial data in the featuresource and that the resource produced an error</comment>
   </data>
   <data name="ResProp_ReadOnlyAccess" xml:space="preserve">
     <value>Read only</value>
-    <comment>A value that indicates that the user has readonly access to the resource</comment>
   </data>
   <data name="ResProp_ReadWriteAccess" xml:space="preserve">
     <value>Read/write</value>
-    <comment>A value that indicates that the user has read/write access to the resource</comment>
   </data>
   <data name="ResProp_ReferenceReadError" xml:space="preserve">
     <value>Failed to read resource references</value>
-    <comment>An error message that is displayed when an attempt to read the resource references fail</comment>
   </data>
   <data name="ResProp_ReferenceReadSpecificError" xml:space="preserve">
     <value>Failed to read resource references: {0}</value>
   </data>
   <data name="ResProp_SaveError" xml:space="preserve">
     <value>Failed to save the resource properties: {0}</value>
-    <comment>An error message that is displayed if the save operation fails</comment>
   </data>
   <data name="ResProp_WFSBoundsReadError" xml:space="preserve">
     <value>Failed to obtain the extent for the WFS data.
 Error message: {0}</value>
-    <comment>An error message that is displayed if the attempt to read the data bounds fail</comment>
   </data>
   <data name="ResProp_WMSBoundsReadError" xml:space="preserve">
     <value>Failed to obtain the extent for the WMS data.
   </data>
   <data name="BoundsPicker_BoundsDecodeError" xml:space="preserve">
 you may enter new bounds, and these will replace the current.
-    <comment>An error message that is displayed when the bounds fails to parse</comment>
   </data>
   <data name="BoundsPicker_IncompleBoundsError" xml:space="preserve">
     <value>You have not entered all the required information.</value>
-    <comment>An error message that is displayed if the user clicks OK before filling out all required fields</comment>
   </data>
   <data name="BoundsPicker_InvalidMaxXError" xml:space="preserve">
     <value>Failed to convert the Max X value</value>
-    <comment>An error message that is displayed when the Max X value is invalid</comment>
   </data>
   <data name="BoundsPicker_InvalidMaxYError" xml:space="preserve">
     <value>Failed to convert the Max Y value</value>
-    <comment>An error message that is displayed when the Max Y value is invalid</comment>
   </data>
   <data name="BoundsPicker_InvalidMinXError" xml:space="preserve">
     <value>Failed to convert the Min X value</value>
-    <comment>An error message that is displayed when the Min X value is invalid</comment>
   </data>
   <data name="BoundsPicker_InvalidMinYError" xml:space="preserve">
     <value>Failed to convert the Min Y value</value>
-    <comment>An error message that is displayed when the Min Y value is invalid</comment>
   </data>
   <data name="BoundsPicker_MissingBoundsError" xml:space="preserve">
-    <comment>An error message that indicates that there was no bound tag</comment>
   </data>
   <data name="BoundsPicker_NumbersInRegionalError" xml:space="preserve">
     <value>The values you have entered appears to be in local regional format, but are required in US regional format.
 Do you want to convert the values?</value>
-    <comment>A message that is displayed when it is detected that the user enters number in local format</comment>
   </data>
   <data name="BoundsPicker_UseInvalidCoordinatesWarning" xml:space="preserve">
     <value>The coordinates you have entered appears to be invalid, do you want to use them anyway?</value>
-    <comment>A message displayed when the coordinates cannot be validated</comment>
   </data>
   <data name="SiteExplorer_SelectedItem_Properties" xml:space="preserve">
     <value>Properties</value>
@@ -573,33 +1677,24 @@
   </data>
   <data name="ValidationBuildingList" xml:space="preserve">
     <value>Building resource list...</value>
-    <comment>A message that is displayed while building the list of resources to validate</comment>
   </data>
   <data name="ValidationResourceLoadFailed" xml:space="preserve">
     <value>Failed to load resource: {0}</value>
-    <comment>An error message that is displayed if an error occurs while validating the resource</comment>
   </data>
   <data name="SiteExplorer_ValidateResources" xml:space="preserve">
     <value>Validate</value>
   </data>
   <data name="ValidationValidating" xml:space="preserve">
     <value>Validating ...</value>
-    <comment>A message that is displayed while the validator runs</comment>
   </data>
   <data name="ValidationFailedError" xml:space="preserve">
     <value>Failed to save file: {0}</value>
-    <comment>An error message that is displayed if the log was not saved</comment>
   </data>
   <data name="ValidationProgressMessage" xml:space="preserve">
     <value>Validating resource: {0}</value>
-    <comment>The header text for a resource in the validation log</comment>
   </data>
   <data name="ValidationResultFormat" xml:space="preserve">
     <value>{0} - {1}: {2}</value>
-    <comment>The format used to write the results into the log file.
-{0} is the status, eg. warning
-{1} is the resource id
-{2} is the validation message</comment>
   </data>
   <data name="ValidationNoIssues" xml:space="preserve">
     <value>No issues found during validation</value>
@@ -628,8 +1723,20 @@
   <data name="SiteExplorer_NewFolder" xml:space="preserve">
     <value>New Folder</value>
   </data>
-  <data name="folder__plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\folder--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="folder__plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACDUlEQVQ4T43OXUjTYRTH8XNh
+        gRJDd7Gk2yICZSu8C8K8qJsuIiG66E0rFkJXUZG4lK2xaavVYuKWbikT7U1p9EIks6JXdWbQC5GhlKYb
+        0/VvLnOp+3Ue6dlFqz8d+HAGO9+HPw3UEwnheqpk5v9UKTvqt5NkwfcgkOhWxzfcWGRHfTaSrPh2A+mp
+        TlXihhur7OiZlSTbYvwqFqLtqsQNNzbZ0ZPTJDUsxDowP9GmStxw0yA7emQmyTEfCSA15lMlbrhxyI56
+        60hypr74MTvqUfUz0gZunL21RCFGPacyXD8+NSM57P6n1LgfIw9N4MbFSu6b+IF7NRnu2ZEmJN5f+Cvx
+        38dQNTuJxXQa3LlFS7sduWR05lKpV/N2wy09Knq2QHnjyJL8cBFDXVUQe2ZuDneqqYnx+LS0/LKWCv0F
+        sUPx4zB0FWH6lT1L4p0T4WtGiD2hKAieoEuMp0Xr5UfChZ78qZ0xIwyd65bsu1mK2KAlQ3l9Bi86DkDs
+        4WgU3cfIx3ga88Nlk+X4k6F1LaL9dRlf+aueBvZD7LK+NK4fpVbGc07jpbOa8Er7injx503Qe9Ys2du+
+        EZHnpoz4SytCzbsgtv5uEoEjdKWmXDxAlMd0uto8ZdVoEda7VmN6wJxFGbIheH4bxG48SLcrNtOO3y1p
+        +Udxwfacx7rDy2ZKjDmTjj30QE3VVmoRDdP+AgqRc9vLR4PDAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="RenameTo" xml:space="preserve">
     <value>Rename to</value>
@@ -685,11 +1792,35 @@
   <data name="TPL_RLDF_NAME" xml:space="preserve">
     <value>Raster Layer Definition (v1.0.0)</value>
   </data>
-  <data name="box__arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\box--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="box__arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB7klEQVQ4T6XRX0hTYRjH8Wee
+        gzcWBl4IXngjBgleheBVTTBKwWpRInOiiQxZpMRSMZVmEhoJsvAvMw3UqdNksq0/TjRLJWFKBoEholEG
+        hqhUBF3o4/tbnuMZBgoe+Oxs7/N835sRM9Nx0Hi+DPKbfLlQeKyw6SmgpZ1hFw1aGrspQ1ygMqFnc/QR
+        b/jrghyFSSGUc+xgFw1a8ufKNJonX/zcmDGpvaD3bgoruu+cUy/GDnbRoKXX4kO4vey8tfLdY2OFt/oy
+        K4YqLqnnmGMXDVp6kSNB085i7zYvuVix5CoTX/8JtJnVc8yxiwYtebIlaP37sZN/vW9S+etusMJjywiZ
+        YRcNWnIbJXD8mXPw1qRdhdhVlhq8xGnVh8ywiwYtDWZJ0PlzppnXx+tViPFbeWtn2EWDlvoyJejaeNvA
+        ayO1h6rpn2D3y2FGg5a6r4eB84f471d9Dw5ldMxydvsclxbnTVuKLETPDGEw8M1bzV/cVQeUtLj5WsNE
+        iJZV5vP3vZuJDz+Y6HSUjhrTda9Whip4+fm9A9JqfPzkK7PlE3PO/D7rAnNc+bsAiSfWfFbXUZuqm/qf
+        FJN1LaGg9bdW8hRzfMHT9VMXSotxQaQQLcQcxUlj1zycMNjNey3uONojnblC4Yb2NsEUcdUejHYBWd04
+        Q/Z8szgAAAAASUVORK5CYII=
+</value>
   </data>
-  <data name="box__plus" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\box--plus.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="box__plus" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB8ElEQVQ4T6WSXUhTYRjHn3mO
+        giloCgpeeCOa+DGh6KILQ1FIAgMrQxQpJZYSXkiFlAZHb1wYROLCNdE+3KbTZDCNakMlJigcgrqTkKn0
+        gTZmaAhe5OP7X53DRmaBD/zOc973+f+em3OImekw0EyjDOTZRrlJ0KOhlJAaSeQMWThwabpBBllqR559
+        w3ePQ15zGFvTySi0e2SQhQOXvJdl8l2Rzyz2VfojFzhvlrLGcOtpfTEyyMKBS6/FQ9AScFxf/uJRWGOy
+        8xxrTLRX6PeYIwsHLr2sl4Bl96PzJy+5WGPJ1SZef6FaTfo95sjCgUueOgn073wY4q15i47XXM0aHqUy
+        aoYsHLjkrpWAbfudjb/7H+pAdrWVh5c4bpREzZCFA5fGayQwtLnwiIMz93Ug46z1yBmycODSyCUJPA+9
+        fcBrb7oPpN5dxkXjBdwwVcFw4NLwxRjgWBff/vNU14EYnXl8NXSLi0bzGc6F20eInlTFgLFPk5284r67
+        L3X2Yi58eixM9TcTG5/lcnpv8gYNpFgpJ9VAfWcNr5Yn2jnw4s6+FD7O5tKv5/+ALMkqico0nTAMdpcb
+        5v7G8db4tTQl8QcoWC1m9KNdiUG6lmDHgiRBuiDjnygJ7zMC+Uyi/3bg/medEr9tS5yVmmPVcMdZ1B7O
+        fyT2oAVNdAAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="Filter_Dwf_Files" xml:space="preserve">
     <value>Autodesk DWF (*.dwf)|*.dwf</value>
@@ -775,8 +1906,19 @@
   <data name="XmlEditor" xml:space="preserve">
     <value>XML Editor:</value>
   </data>
-  <data name="disks" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\disks.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="disks" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB2UlEQVQ4T42Q70sTcRzHP3e3
+        fyChJz0Jwgc+HUoPo2ilIvpkbidjzDXE6qk9CJSYU6O8tbU56CwHIzVhyCzIsqhJTTP0gQ+EggkNKdAH
+        gixD3APbp3ufKLe7BTt4wfH58f5+vy8KSDG6IT2uQKvd0gi7gsHe/4E+5ggBxyFRI5H8zD6XmflvuWwB
+        dfS1nchpQJd/mLqlRyfENlK7fHh0xH9KJQuoo6/NH58OtKtSl3+IfJICEusTO7ynLW8XixZQRx9zFQEI
+        kf0h8ooP1DX1F28VfvP2wYEF1NHHHAIswmRHaGk8/I4T91/rhK+85HHne/44+u2UL2MF9ogjExBXk7A7
+        DSo/dD3nUfckK/IUrz75ybIYSkFaTcIU9zSvrHzliGeGx7pneTn+g13ivemahQXbkrywkNWXk7ff8KdI
+        np1if7pmYQPXn3Em84HVnlf8om+Rs8p3bhf65gkiIMQoyPyP/lUpsGGz2ZRrws3lE5qEjqcEEZ+jm7oc
+        SDJiFKZfl+iciTqCCJwIOZCUyy3pVBN2WfRp+6YPyQiAHEi664jz3Nx8VWGXRC+dFc5XJtiF1k7IGGxO
+        7kESnpBOv60ujOiM9QpEjfXCxQDEQJIRk7CUtnzBGGAXW+gfW6hPXoP3cZ4AAAAASUVORK5CYII=
+</value>
   </data>
   <data name="Menu_File_SaveAll" xml:space="preserve">
     <value>Save All</value>
@@ -802,8 +1944,20 @@
   <data name="ResourcesRepointed" xml:space="preserve">
     <value>{0} resources re-pointed to {1}</value>
   </data>
-  <data name="document__arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\document--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="document__arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACEUlEQVQ4T4WSO2hTYRTHz6RU
+        waGDj8Gh2IgUH6BIL4UY8AEGtCimJcPt0KG2aRNL0tSQPlIQNZuDGYSCBaUZHAWtjpLiFqQGC9ZBqSWx
+        lGht3u+/51zzYRG9/eDHvVy+/49zzj3kCIVI6JmZucrc3IH2G9PTdH1igq4Fg3TMaiWSD00G87UaNstl
+        bBQKSOZy+JrNYjWTMXgei4HvDTIWJRCJYWsylK1UkObgt60tfEmnsbK+juVUCh+SSUQXFiCH7w4xFgkb
+        gu5AQOHKseBHPv9PSWR+HgqL3T7FkEBX/H7FSKFaxU8u/38SqUTa4cyIytFlr1fhLvIMMsWiqUQEnHGr
+        HF3yeBSeEgtypZKpRAbLGY/K0XmXSzFaqddR4DmYSeTvcGZU5ejcwIDCW2VBiedgJtngFjnjVTnq6u9X
+        +GqNBsrchpnk7pvvsIaeRrsmn9DZ8VmiTl1X+OsskCrMJH3PktAeJNY6I5/1k+EE0RmnU3G7wYtSY8F2
+        SejFKnofr6CnSe/cJzxKAhyOn7i3pFO7zUanHA4hIJvW4Cq2S7oj7/BwDRheBvre/2HsI3AkuBgnOYc1
+        jY7a7ZPGrv4lGYsmcDG8+Jv7MeOpvQUODr+MH3K/0iXfwuw/oGl3lMCQMDITGay0JL9Y9sQ69Rr7nLOp
+        PTbfrWaWWvnleEtbm29vR0d4J3ZfGF/addoxJxmm9RfQp5NnTum+ngAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="ResourceNotRepointable" xml:space="preserve">
     <value>This selected resource is not re-pointable</value>
@@ -874,17 +2028,57 @@
   <data name="SiteExplorer_SaveResource" xml:space="preserve">
     <value>Save Resource XML</value>
   </data>
-  <data name="server__arrow" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\server--arrow.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="server__arrow" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAB6ElEQVQ4T43SwWvTYBgG8K+l
+        eFDcQRGqoIUNwYsWWcF1h07opLAipbU9CNGbbpkrY5TJdikYsPO0gxsbhXkTrN6lhxppiWuhpNRGWmwp
+        SlbKoP/Eu/dN9mWBhrHA7xCe53v4CGEAwJLJpCGVSj1Fi+d5svVDDh0cCzO7/9mDLY0xGkgkEtzSaDSC
+        4XDoiLLZbU3Hw+qjnX+CNRCLxdgpcTAYQK/Xs2QKbYjv/zE8y7fhoXSo7w8B8LB6//1vwbhBNBrl3lQq
+        FahWq5b5D7/g4wBguQ3wonUm8xdgalNRjYFIJMKldV2Hfr9vebWnwNw72fBY+gm3X387mjkE8C5/V2+u
+        FM0bhMNhbrXb7UKz2XRE2bXnn46uCl/UiZdfBRwxP2IoFOLWisUilEolR5R5o9nqpfiBgCPMGggGg+xU
+        ptPpQKvVckQZ9jJ35kU2ubDK7sXfmjcIBALceqPRAEVRxuTzeaAMu+u2vjng9/u5jXq9DuVyeYymaUAZ
+        djdsfXPA5/Nx2VqtBrIsO6IMu1lb3xxwu91cAX9jOA92C7a+OeByuZjH4yE76XQaRFEcM61OA2XUoS6d
+        MR4aoAdX72KwncvlQJIkR5RRh7rm6bOB67i4iMHni8DuEh69YR+4jC9edOuCqHuFBk4Axf7pl4umza0A
+        AAAASUVORK5CYII=
+</value>
   </data>
-  <data name="arrow_circle_double" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\arrow-circle-double.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="arrow_circle_double" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAAC2klEQVQ4T6WPb0hTURjGr8Mk
+        k2qiJRP/TNGU1YdyM5hhDockgoYkZbQyTfqQG0qiLEU/mJYuZxtpZJaV0pyppTbNv00jJenYIv+ga8HC
+        qQvKnKbOmp7ec2dQGPShCz/O8z7vc557L4Uxpv4H+rKg+lMlgP4C8dlAIMCKuGt2Cr89TfFvfqRClQYa
+        uiC8akYEC1RuxFg+uU6jNGBMvDL9ekTua2vC2WfzcZH3ZiPBY20qIAZQCKCyCRsuQKtYNmbDZC4ZtQmu
+        vP2RVqT7LpFP2CTCalMSv8Lo/8cX8K7rPfk3DNqi4RWc82IBy0ZWMdE8xXsEcI8+NEkvDS4q8wa+KUre
+        WRVhFR+kcIfJLZu0/8L+klHxyQbTVHbPF5w/aMEwI9nICn2GyCeoA7KxENDFWdq5VshoEutNKphjAXsB
+        p2C4TtxuXspoM+PoKr0B5nIAbUDtK9RRey+/iTlSpe+GzDhkdbArBewFgTkDKL3DjMWaGUx0UP4QtSd3
+        UARU+mX3U76Zz6mgvFck1w8ZC2QtRAP2Agj0n9fMWpKbpy1Ee2d0U35ZfRQb8LnYWwmIvNK7SA5BBkMW
+        E02K6QJWWntpfJ1RF6eeGuddHepmXWiLcU99QnwC2qAcdgbI4Hi1cQm8OrKnCyAcy72GVIfUZk2U2tQK
+        c7HbucchrsmNZIdEvfOYnNEtnzFkME8+PAWzmLyELth5pp7pltokFXYsKjgNXxUH1bNKdo5WuuO0mgsg
+        /tMFLOxcxAHqOUw0M6VJC3c8mUmP7AXbT6kol8Raf2ZKQxKvyyrxal6W+LSspAW1WQXbTtQgTrsVuzcu
+        49AuKyYzUOh8/AHl6MGxF5CHsTuYcgzPZm1NrIn0yH8Z53XflMDutEVsib+DgnvWsHeHjYbbt4aJB4jo
+        i78KQLoAbAdnV66DD/+wA+eYkBEQJWCEZaoYsbfQJsIyayHv+3uBExhMgAV4/gOS2UXyPwFnEw2I72Hm
+        QAAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="SiteExplorer_PurgeFsCache" xml:space="preserve">
     <value>Purge Cached Schema Information</value>
   </data>
-  <data name="system_monitor" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\system-monitor.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="system_monitor" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACA0lEQVQ4T6WUPYsaURSGb7WN
+        2KYI+BNsbFxQoiyujjrj9wyrO36z41fcjLvuxFRJsZAuEEK6QAIJ+QOpkhSpBNFgYWEhRBA0hUXalG/O
+        uUV6dwce5t7iOec9B2YEAHEfhK7rGmHdEU3kcrn2fr/Hbrc7CHbYFZlMprPdbpFOp6FpmiSZTCKRSCAe
+        jyMWiyEajSIcDuP4OIBA4BFUNQV22BWqqnY3m40UHcfBcDiEbdtof3qDVquFRqOBfF7H6WkSipImWcfJ
+        SQzssCsURXm8Xq/5gsFggH6/j06nA+vHZ1SrVeqSpxQaJcpTyiIVq8o7O+yKSCRyuVqtZORerwfLslCv
+        12H9+o5stkBjZCidQfOaMIwGSqUWNcuDHXYFzWYvl0s5a7PZRPP9KxSLRVlAVQvQrwfyXHv3GuVyF7Xa
+        E0p1BnbYFcFg8GqxWEC5vUbt6wcU395KgTm7uZFvw6ih/u0jXvz+iS9//6BQMMEOu8Lv9w/n8zlCoRBF
+        ziKVStE4SepsS7k0cmgkmzpfygSVShe6XgY77Aqfz+fMZjNZgBdJi6Fl6TDNDs6fjWisK1xcOLSbp//R
+        9QrYYVd4vd7RZDKRS+QijKJolMSgRLz1cxmZu7LImGYd7LArPB7P8+l0ivF4fBDssCtcLlfb7Xa/vAvs
+        CnqOiAfEwwNh5+henzL/Bv4BjuUj9lP+EFEAAAAASUVORK5CYII=
+</value>
   </data>
   <data name="SchemaInformationPurged" xml:space="preserve">
     <value>Schema information for {0} purged</value>
@@ -897,67 +2091,51 @@
   </data>
   <data name="CloseButtonText" xml:space="preserve">
     <value>Close</value>
-    <comment>The text on the close button</comment>
   </data>
   <data name="Prof_LayerDefinitionProfilingError" xml:space="preserve">
     <value>Failed while profiling Layer Definition: {0}{2}============= ERROR DETAILS =========={2}{1}{2} ======== END ERROR DETAILS =============</value>
-    <comment>An error message that is displayed when the layer definition profiling fails</comment>
   </data>
   <data name="Prof_LogMessageDone" xml:space="preserve">
     <value>*** Done ***</value>
-    <comment>A message written in the log to indicate that the operation is complete</comment>
   </data>
   <data name="Prof_LogMessageFeatureSource" xml:space="preserve">
     <value>Profiling FeatureSource: {0}</value>
-    <comment>A message written in the log when profiling a featuresource</comment>
   </data>
   <data name="Prof_LogMessageIdentifyFetching" xml:space="preserve">
     <value>Identity fetching (ms): </value>
-    <comment>A message written in the log when profiling identity fetching</comment>
   </data>
   <data name="Prof_LogMessageLayerDefinition" xml:space="preserve">
     <value>Profiling LayerDefinition: {0}</value>
-    <comment>A message written in the log when profiling a layerdefinition</comment>
   </data>
   <data name="Prof_LogMessageMapDefinition" xml:space="preserve">
     <value>Profiling MapDefinition: {0}</value>
-    <comment>A message written in the log when profiling a mapdefinition</comment>
   </data>
   <data name="Prof_LogMessageRenderingMap" xml:space="preserve">
     <value>Full map rendering (ms): </value>
-    <comment>A message written in the log when profiling runtime map rendering</comment>
   </data>
   <data name="Prof_LogMessageRenderingScales" xml:space="preserve">
     <value>Rendering scales (ms): </value>
-    <comment>A message written in the log when profiling a scale rendering</comment>
   </data>
   <data name="Prof_LogMessageRuntimeLayer" xml:space="preserve">
     <value>Runtime layer creation (ms): </value>
-    <comment>A message written in the log when profiling a runtime layer creation</comment>
   </data>
   <data name="Prof_LogMessageRuntimeMap" xml:space="preserve">
     <value>Total for runtime Map Generation (ms): </value>
-    <comment>A message written in the log when profiling runtime map generation</comment>
   </data>
   <data name="Prof_LogMessageRuntimeMapTotal" xml:space="preserve">
     <value>Runtime map generation in one go (ms):</value>
   </data>
   <data name="Prof_LogMessageScaleRange" xml:space="preserve">
     <value>Time to render scale range [{0} : {1}] (ms):  </value>
-    <comment>A message written in the log when profiling a certain scalerange</comment>
   </data>
   <data name="Prof_LogMessageUnsupportedResourceType" xml:space="preserve">
     <value>The resource type is not supported for profiling</value>
-    <comment>A message written in the log if a certain resource is not supported</comment>
   </data>
   <data name="Prof_MapRenderingError" xml:space="preserve">
     <value>Failed while profiling MapDefinition rendering: {0}{2}============= ERROR DETAILS =========={2}{1}{2} ======== END ERROR DETAILS =============</value>
-    <comment>An error message displayed when profiling mapdefinition rendering fails</comment>
   </data>
   <data name="Prof_RuntimeMapProfilingError" xml:space="preserve">
     <value>Failed while profiling MapDefinition runtime {0}{2}============= ERROR DETAILS =========={2}{1}{2} ======== END ERROR DETAILS =============</value>
-    <comment>An error message displayed when profiling a mapdefinition fails</comment>
   </data>
   <data name="Prof_MapRenderingImageSize" xml:space="preserve">
     <value>Rendered image size is: {0}</value>
@@ -1013,8 +2191,18 @@
   <data name="KeepAliveFailed" xml:space="preserve">
     <value>Failed to keep session alive. This would happen if connectivity to the MapGuide Server has been lost (it has been stopped or restarted). Refresh the Site Explorer to create a new session. Also close any existing editors and re-open them.</value>
   </data>
-  <data name="marker" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\marker.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="marker" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABlklEQVQ4T4WSP0iCURTF75Og
+        oWwp+gNurQ0tzq6igyBokkOUhAkqiOZQkyCCW0stQkUukkMUjbUEQpRRS1s0BI6SGoqVdrvH/KQanh/8
+        ON85977jg09iZjKoKEXCpBATDoVCX+GRD3aNM38CWZgT9usOx20nm23wzg5D4ZFj/vsH8f6/INFwue45
+        leKvZHIAPHIpSGgLXpTKd9Lpt24iwYVAgFe93p7CI8dcW/CkVLGbyXQ7sRgvOZ1st9t7Co8cc23Bo1IH
+        rXi8+hmNcs7jYYfN1lN45JhrC+6UCj5brXcfcuX3cHgAPHLMtQUlpaZKJtNpbWOj3g6F2AAeOebagiv5
+        zhdKrZbn58vtSIRb6+sMhUeOubbgnIiEsTOik4rbXW2urTEUHjnm2oKiLIBjouVLi+WhKZ8QCm/MtAV5
+        OdzHfERUaqysMFQyM/LtYTeQOW0KuR+u634/Q+GR49HeoL9DMXnZI7qp+XwMhTeeYQUmWRwXpnfl4Kv8
+        laHiZ4UJYWRYwYgszQgLQaItHIaKXxQswuj/gm+HNTFEuMVJpAAAAABJRU5ErkJggg==
+</value>
   </data>
   <data name="Folder_Data" xml:space="preserve">
     <value>Data</value>
@@ -1040,8 +2228,28 @@
   <data name="ResourceUpgraded" xml:space="preserve">
     <value>Resource upgraded to schema version {0}.{1}.{2}</value>
   </data>
-  <data name="Contributors" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\Contributors.txt;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+  <data name="Contributors" xml:space="preserve">
+    <value>Programming:
+  Jackie Ng (Maestro 2.0+)
+  Kenneth Skovhede (Maestro 1.0 - 2.0)
+Many thanks to the following people for providing patches and actively testing releases to help make Maestro a better quality applicaton for all:
+  Jason Birch
+  Crispin Hoult
+  Zac Spitzer
+  Gunter Becker
+  Andrew DeMerchant
+  Gabriele Monfardini
+  Gordon Luckett
+  Hans Milling
+Many thanks to the following people who have translated Maestro into other languages:
+  José Manuel Cerrejón González (Spanish)
+  Pierre Cardinal (French)
+  Ivan Miličević (Croatian)</value>
   </data>
   <data name="SiteExplorer_CopyResourceIds" xml:space="preserve">
     <value>Copy Resource IDs to clipboard</value>
@@ -1061,8 +2269,20 @@
   <data name="EditPackage" xml:space="preserve">
     <value>Package Editor</value>
   </data>
-  <data name="box__pencil" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\box--pencil.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="box__pencil" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACEElEQVQ4T6XRXUhTcRjH8ee/
+        c6DLiIigiygiA6Fuostigb0QaKQlYYi2iQ3C6A3GsuKYgqsZvaBRDDyr7EymyWLrxSZbhUovw4uozGK4
+        oIQiplQ0uqin81v8D9sybzrw2dn+z/P934yYmf4HJRwqqA8cqsvkkzQ7JfPlz7CLBi3F96qwInm89Mb0
+        0GnOxLw5fte6AvIcO9hFg5ZidSoN1atbJjrLh/MvCB7dyFLPoQ3WxdjBLhq0NGh+mJomjf3pqYjGUrSl
+        gqWB5q3WOebYRYOW7tQq0PXrbfAnp0IspUJu8+sfySuN1jnm2EWDliJ7FLj847nOXx93WWLeXSxFtPKC
+        GXbRJNbYiMI1Cvi/j/l5ZviCBXHIXZa7xDhiL5hNX/Xwi0UiPSqEnfp3K6B/eXKJPyc6LIjxW77lbDzc
+        xoMnG5g1jW8J8ZB6qxW4nnl0jj/eb59TKrqPDV8TZ7NZPrB6wbhOtJl6dtrA+GT+9x9un/qnN2EnJwKr
+        ODvlYe/Bam7bNO9uoFQQBXbYoO99tIXfhU/M6nV/Pcf1klzc61vOz645GA1aKlkoqHObuJceaObJm8f+
+        8ipUy/Hulbk4eGYZP9VrGLto0OJZ2rhWdLeXiZFiHRVizGgVGcQXD4sZb6V4KXfQoMUF802LTUuKtTrF
+        Wf42wec9YsRZRZVFczRo53zYtV30uevE+oaq2fd+A3LlMACdPVtkAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="EditRawHeader" xml:space="preserve">
     <value>Edit Raw Header XML</value>
@@ -1070,8 +2290,17 @@
   <data name="ItemsTranslated" xml:space="preserve">
     <value>{0} items were successfully translated</value>
   </data>
-  <data name="edit_language" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\edit-language.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="edit_language" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABMElEQVQ4T6XUP0uCURTH8fsM
+        0TNJFEEUFC0J0R9pqPcgVODQ4CaIb8EhgtaWpqaGptqygkAIwgyChoLm3kBv4+n7s3OvV80MFD7cc3/3
+        3IPyqC7LMjcOlySJ7GHRap9pPcB1lKtWFnp8cUMoV8hZ7bO/VucHLHFpH3VMYc3UWC+ivWpl/jwMiN+2
+        6nXcj6CeMKDB5hAlTGADTexgGie2V61MZ+oJA47Y3OEBM9i0Wvth1DPwEZYJU8yhEDmlfuzL1DMwoGID
+        tLZHUE/PgCLBCyax1Uf52S95z4BbGi41Fa//FAbscuEdesbxI121/Ji1jHMo634T3c/rCZ9YsX2etYoP
+        tLBgVCvTmXo6rxRveMa8+WKVNrajXLUyf667nQE5zEaNftCwVb26k471U9bfwDdY8a5H6+SIIQAAAABJ
+        RU5ErkJggg==
+</value>
   </data>
   <data name="Menu_Tools_Translate" xml:space="preserve">
     <value>Translate</value>
@@ -1082,8 +2311,19 @@
   <data name="RtMapInspector" xml:space="preserve">
     <value>Runtime Map Inspector</value>
   </data>
-  <data name="edit_diff" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\edit-diff.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="edit_diff" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAABxUlEQVQ4T52SSyhEYRTHzyys
+        SRZeWXikYTzzKKEhhJm8Zsx45BGGIWFDs1BkQeSdrYWFFTWSR8L0Ge8NiQ2lFJKwsrE7zrm56nJvya3f
+        vfU/5/z/p+9+0DL8Khwjb6gG1+oHH0Gn0zGrxBqxTmywFpvZBUAN6D3/UMU194J1Aw/C5roFQ1a3Atas
+        fTfAL2m4tn0Wa50zWOOcxuq26W/Dnol75B41LL3XAgo7zjQ30NpM1nkWMuu9kgGnVrdOYRXjmPxlam0a
+        Q0vjKFYQ5Q0jUp1nIdm6+e8NeBb0JrdkwKl2xwTamsexkpDXLO3cQ+5RI8a8IiAif0lzA5PTg5EFSyIs
+        fQgCouwKWCNTgPC8ZUGgBoIC5HuwT//+gDgijvke6E0bkgEEpwyBf4RdAWtc05t2ILpoi9LrFLDGNUis
+        OJETtsl1l/AQghPiyw7BUOI1UiOdwW9izB4BKbYLiRBDuwLWkq1nxoTyE5x3v6qeE9cg1X4p0qquUIv+
+        uSdpuNA2gAWWfswtc2G2uVfSeIZSOyA0rlMVQ/6iMavhDhfW3lU34BrQ40sE/jjhU9KCGb+gjJqc5mdU
+        I6nYvfdtIA/88Rv4FezzCS20Bem86KckAAAAAElFTkSuQmCC
+</value>
   </data>
   <data name="Menu_Tools_XmlChanges" xml:space="preserve">
     <value>View Changes</value>
@@ -1100,8 +2340,23 @@
   <data name="InvalidResourceId" xml:space="preserve">
     <value>Invalid Resource ID</value>
   </data>
-  <data name="folder_open_document" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\folder-open-document.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="folder_open_document" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACkklEQVQ4T43SX0hTURzA8d9b
+        9O/BHjPowfZkRgTRgxVFJgrBRKT2kJWjEsUsKyprtZyumdoSZ86hGdU0LUOTsJXGahCYthIUs6au/fPf
+        nJvzOvfXX+ccusINgg584Hfhni/ncC8MqACoL+WQQ5T8pxx+H/STzX+UcpZynPl4CmeNJ5Ebuo0xRyPi
+        5BOh2RYk75fy+6BPCTwlLrzEFe8LDNpr0dNXiG+1h/DdG7VAT68GO8vi69Ql+6FKvg/gU9kqVWy+DaMz
+        eibmfY7mjnPo9HhwiuPQQdj8fnxlMqFSnmrIlMlEGcXFACbFqoqouwUjk48ZOn9uleKwxYLfRkdx3O3G
+        kakpbO7uRrrI5jxCBEY58O5Fpp9iyPGQobPpkQS/j42xyKTPxyIavX6VKD1dBj03gVcdcjVhwFrP0NnY
+        eBR/TEywyBy5Ah+hJ6HXSSsqKgDDDeDVLtsakLPUMnTu1WWixWplEe/SkiDiWFzElIKCQnh9DXjawIQW
+        /aPVDJ0NdWIct9lYZGF5WRCZDgTwQG7uBei8ArwG7mcN+oYrGTp31xxBKwnQCBcMCiLz5HmvVHoRFMcA
+        2i8xTf4RNXoGVQydu+6noc1uZ5FAOCyI+Mnznuzsy0DXrSyAZ+dB7xuqQLdZwdC5ozIV7Q4HiwQjEUGE
+        I4FdEgk5P8BaYpPuLHR5B8mv3C9nvOQU7XdT0Ol0skgkGhVElkhwu1hMviFAHLEtPxXq31fv9o8b8sJz
+        Awqc/6rE1jsH0eVyoZOIraxglAjHYhgisRCZ45OTy9kV6Dq8A0B3BjK0p0HXdn3LB3Nz5q+rWWvs60Qi
+        zYbExIqNSUmqv61PSMgXBMhm0EgB1CdgZ9VxkJVJ4AF5YSux+R/ifgP/44T3ShVnvwAAAABJRU5ErkJg
+        gg==
+</value>
   </data>
   <data name="Menu_File_OpenResource" xml:space="preserve">
     <value>Open Resource</value>
@@ -1112,46 +2367,319 @@
   <data name="ResourceNotFound" xml:space="preserve">
     <value>Resource not found</value>
   </data>
-  <data name="water" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\water.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="water" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAZdEVYdFNvZnR3YXJlAEFkb2JlIEltYWdlUmVhZHlxyWU8AAACQ0lEQVQ4T2P4//8/g93cF1ix
+        /byXpjaznzFgwyB9IAwmbOc8x4b5geI5QM38BA2wnvWUAQtWBYrlW818omo54zEDOkZxATYFQDH3xr1v
+        uyymP/Iwn/aQAR2jGGA29QEDGuYAaij89PPfMdMp94uNJ93lAGIGZIxigMnkewzIGKjJPG/T8x6gAWdy
+        Nj7rM5xw28qg/xYDMkYxwGjiHQYkzA5kFx158G3rgw9/zhy+/3WbXu+Ncp3uaxxAzADDKAYAFTDAMNAW
+        p/S1Tybdfff7zJWXv86A6ORVD6drdV5xU2+7yADDKAbo9lxnAGGgIXxAXHf26fd9Dz/8PnPt9a8zxx7/
+        OLPv7pd9Gu2X2tRaL/CrtpxnAGEUA7S7rjJAsW/2usdz773/cwao4MzNN7/P7Lj97cyBBz/OpK28v0S5
+        6WwwEDOAMIoBQNMZoLhm6YWPe0EaLr74Bda46upXMF509v1+xYbTrQr1pxhAGMUAmLOAdPfKq19OzTn3
+        +QwMn3v+E8xeeeXLabnaE9OAmAGEUQyAOQtIdy8+//HI9DOfz0w48RGOQfyF5z4clak+NkW66iiDSMwU
+        VAMYgEAifgbIaWn56+6vO/jw+5kZZz6d6TzyAUyD+Dmr72ySrDicIxw1CaQcwwBGoBgHp7K5mkzVkYmF
+        a++sO/fk65FXX/+cAdJH81bf3ihRun8au6KZOkgdEDOheAEkAMT8QCzHKqFuIZo0v1yy/OAMifJD8yXK
+        DswUTphbySqhZgmUVwBiASBmhhkAANooLu4WadDEAAAAAElFTkSuQmCC
+</value>
   </data>
-  <data name="icon_drawingsource" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_drawingsource.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_drawingsource" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAABAAEAEBAAAAAAIABoBAAAFgAAACgAAAAQAAAAIAAAAAEAIAAAAAAAQAQAAAAAAAAAAAAAAAAAAAAA
+        AAAAAAAfdz8GpZ5TB82eUwfNnlMHzZ5TB82eUwfNnlMHzZ5TB82eUwfNdz8GpwAAACP///8B////Af//
+        /wH///8BAAAAEa9kFM300IT/+OCz//LLf//zy3//88p+//PJff/43rH/9syA/69kFM0AAAAR////Af//
+        /wH///8B////Af///wHAdSDN+OCz//jmxv/12q3/+OXF//XZrP/12az/+OTE//jdr/+7ch/RAAAAGwAA
+        ABsAAAAbAAAAGwAAABH///8BxnskzfLLf//12q3/9dqs/+7AdP/12az/7r9z//XYqv/0xXn/v3Qf9Z5T
+        B82eUwfNnlMHzXc/BqcAAAAj////AcuAKM3zy3//9dqs/+7AdP/0057/7r9z//XYqv/116r/9MR4/9OP
+        Of/zyX3/+N6x//bMgP+vZBTN////Af///wHPhCzN88p+//jlxf/uwHT/7r9z//LLjv/uvXH/9dep//XC
+        dv/XlUb/9dms//jkxP/43a//wHUgzf///wH///8B1IkwzfPJff/12az/9dmr/+6+cv/uvXH/7rxw//XW
+        qP/2v3P/25lJ/+6/c//12Kr/9MV5/8Z7JM3///8B////AdmOM83zyHz/+OTE/+6+cv/00Zv/7rxw/+65
+        bf/11Kb/97xw/92XQP/12Kr/9deq//TEeP/LgCjN////Af///wHdkjbN88d7//XYqv/116r/7rxw//LH
+        iv/utmr/9dKk//e7b//hnUj/7r1x//XXqf/1wnb/z4Qszf///wH///8B4ZY5zfTGev/116r/7rxw//XW
+        qP/utmr/xoo+/8aKPv/Gij7/w30r/+68cP/11qj/9r9z/9SJMM3///8B////AeSZPM353a//+OPD//XW
+        qP/11Kb/9dKk/9icUP//////sp1t/9isZf/uuW3/9dSm//e8cP/ZjjPN////Af///wHnnD7N98h8//nb
+        rf/2v3P/97xw//e7b//kqFz/taN2/9itZf/yx4r/7rZq//XSpP/3u2//3ZI2zf///wH///8B6p9Ameqf
+        QM3qn0DN6p9AzeidP/Xsp0z/7KpV/9mtZv/11qj/7rZq/8aKPv/Gij7/xoo+/7htGs3///8B////Af//
+        /wH///8B////Af///wHkmTzN+d2v//jjw//11qj/9dSm//XSpP/YnFD//////1JSKGlSUigl////Af//
+        /wH///8B////Af///wH///8B55w+zffIfP/5263/9r9z//e8cP/3u2//5Khc/1RUKmdUVCol////Af//
+        /wH///8B////Af///wH///8B////AeqfQJnqn0DN6p9AzeqfQM3qn0DN6p9AzeqfQM1VVSsl////Af//
+        /wH///8BAAD//wAA//8AAP//AAD//wAA//8AAP//AAD//wAA//8AAP//AAD//wAA//8AAP//AAD//wAA
+        //8AAP//AAD//w==
+</value>
   </data>
-  <data name="icon_featuresource" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_featuresource.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_featuresource" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAAAAAAfAAAAKQAAAC0AAAAlAAAAJwAAADMAHjtfAD57qwBAgM0AQIDNAECAzQA+fasAHz5RAAAAEQAA
+        AAn///8BJQAA8SUAAPELCwuHCQkJcQAeO18APnurFFKQ01iQxu2Dtuj/g7bo/4O26P9YkMbtFVSTzwFC
+        hJUBIkQ5////AWlHR/9VMzP/5+fn/xgYGIEVU5HTXZXJ7X6x4f9mmcz/UIO2/zlsn/80Z5r/Wo2//32y
+        4/dIh8PVI2muwQJRn1dWNDT/Tyws/97e3v+ZmZn/lcjz/2ue0P9bjsH/VYi7/22g0f+Lvuv/m874/zpu
+        of9onMz/ksXw/5vO+P8DWrCba0lJ/1w5Of/o6Oj/pqam/5vO9/+SxfH/ksXx/5LF8f+ZzPX/ea3Y/0l/
+        r/90lqX/jaqy/1qOtv8JTZDHBGC9a5JwcP9yUFD//Pz8/7Kysv+p3P//qdz//6TX+/+HuuP/VIi6/2OD
+        nv+ToJj/rbil/7/Mu//W4tP/Li4ua////wErAADNKwAAzVNTU2dTU1NnE1qguWqd0f9qmsv/ja7O/8HG
+        y/+9ubP/ubqv/8HHuf/O1sj/3ebY/0BAQGf///8B////Af///wH///8B////AT1PYDNpaWmzmpqa/5iY
+        mP+IiIj/eHh4/3x8fP+IiIj/l5eX/3Nzc7dKSko3////Af///wH///8B////Af///wFOTk5n5ubm/87O
+        zv+8vLz/trS0/6Wfmf+npZr/tber/8nLwP/f4tj/TU1Na////wH///8B////Af///wH///8BTk5OZ+bm
+        5v/Ozs7/vLy8/7a0tP+mn5r/qaSb/7i2rf/My8L/4+Ha/01NTWv///8B////Af///wH///8B////AU5O
+        Tmfq6ur/3t7e/9XV1f/PzMz/wbe0/8O5tP/NxsD/29XP/+vl4P9NTU1r////Af///wH///8B////Af//
+        /wFOTk4zaWlps5qamv+YmJj/iIiI/3h4eP98fHz/iIiI/5eXl/9zc3O3TU1NN////wH///8B////Af//
+        /wH///8BTk5OZ+bm5v/Ozs7/vLy8/7a0tP+pnJv/sKKf/8K1sv/Wysf/7eHf/01NTWv///8B////Af//
+        /wH///8B////AU5OTmfm5ub/zs7O/7y8vP+2tLT/qpyb/7KioP/EtLP/2cnI//Dh4P9NTU1r////Af//
+        /wH///8B////Af///wFOTk5n6urq/97e3v/V1dX/0MzM/8S1tf/KuLj/18XF/+bV1f/25eX/TU1Na///
+        /wH///8B////Af///wH///8BVVVVTVVVVWdVVVVnVVVVZ1VVVWdVVVVnVVVVZ1VVVWdVVVVnVVVVZ1VV
+        VU3///8BAAD//wAA//8AAP//AAD//wAA//8AAP//AAD//wAA//8AAP//AAD//wAA//8AAP//AAD//wAA
+        //8AAP//AAD//w==
+</value>
   </data>
-  <data name="icon_fusion" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_fusion.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_fusion" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAAcHBxhISEhfyEhIX8hISF/ISEhfyEhIX8hISF/ISEhfyEhIX8cHBxrAAAAG////wH///8B////Af//
+        /wH///8BNjY2de3t7f/q6ur/6urq/+rq6v/q6ur/6urq/+rq6v/t7e3/NjY2dQAAAA3///8B////Af//
+        /wH///8B////AUJCQm/x8fH/7Ozs/+zs7P/s7Oz/7Ozs/+zs7P/s7Oz/8fHx/0JCQm////8B////Af//
+        /wH///8B////Af///wFMTExr+Pj4//b29v/29vb/9vb2//b29v/29vb/9vb2//j4+P9ERER5AAAAGwAA
+        ABsAAAAP////Af///wH///8BVFRUZ/7+/v/+/v7//v7+//7+/v/+/v7//v7+//7+/v/+/v7/Pj4+syEh
+        IX8hISF/HBwcY////wH///8B////AVBQUGm7u7v/uLi4/7S0tP+wsLD/q6ur/6enp/+ioqL/np6e/4+P
+        j//q6ur/7e3t/zY2NnX///8B////Af///wFSUlJbxsbG1dnZ2f/R0tL/ysrK/8bFxf/IxMT/0cjI/83D
+        w/+2trb/7Ozs//Hx8f9CQkJv////Af///wH///8BVVVVI1VVVVlVVVVnUVFRp7e3t/+1tbX/tbW1/7W1
+        tf++vr7/4eHh//b29v/4+Pj/REREeQAAABsAAAAbAAAAD////wH///8B////AVRUVGf+/v7//v7+//7+
+        /v/+/v7//v7+//7+/v/+/v7//v7+/z4+PrMhISF/ISEhfxwcHGP///8B////Af///wFQUFBpu7u7/7i4
+        uP+0tLT/sLCw/6urq/+np6f/oqKi/56env+Pj4//6urq/+3t7f82NjZ1////Af///wH///8BUlJSW8bG
+        xtXZ2dn/0dLS/8rKyv/GxcX/yMTE/9HIyP/Nw8P/tra2/+zs7P/x8fH/QkJCb////wH///8B////AVVV
+        VSNVVVVZVVVVZ1FRUae3t7f/tbW1/7W1tf+1tbX/vr6+/+Hh4f/29vb/+Pj4/0xMTGv///8B////Af//
+        /wH///8B////Af///wFUVFRn/v7+//7+/v/+/v7//v7+//7+/v/+/v7//v7+//7+/v9UVFRn////Af//
+        /wH///8B////Af///wH///8BUFBQabu7u/+4uLj/tLS0/7CwsP+rq6v/p6en/6Kiov+enp7/BQUFZ///
+        /wH///8B////Af///wH///8B////AVJSUlvGxsbV2dnZ/9HS0v/Kysr/xsXF/8jExP/RyMj/wre31VJS
+        Ulv///8B////Af///wH///8B////Af///wFVVVUjVVVVWVVVVWdVVVVnVVVVZ1VVVWdVVVVnVVVVZ1VV
+        VVlVVVUjAAD//wAA//8AAP//AAD//wAA//8AAP//AAD//wAA//8AAP//AAD//wAA//8AAP//AAD//wAA
+        //8AAP//AAD//w==
+</value>
   </data>
-  <data name="icon_layerdefinition" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_layerdefinition.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_layerdefinition" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAAAAAAJAAAAFwAAABsAAAAbAAAAGwAAABsAAAAbAAAAGwAAABsAAAAbAAAAGwAAABsAAAAbAAAAGwAA
+        ABcAAAAJAAAAE08tC0OVVRNxnFgUfZxYFH2cWBR9nFgUfZxYFH2cWBR9nFgUfZxYFH2cWBR9nFgUfZVV
+        E3FPLQtDAAAAE////wGjXxtn3cGlue3bybfs2ca17NnGtezZxrXs2ca17NnGtezZxrXs2ca17NnGte3b
+        ybfdwaW5o18bZ////wH///8BqWUhb+3byLXlzLGf5cyxn+XLsZ/lzLGf5cyxn+XMsZ/lzLGf5cyxn+XM
+        sZ/ly7Gf7dvItallIW////8B////AaxoJGvs2cWx5cqwneXKsJ3lyrCd5cqvneXKr53lyrCd5cqvneXK
+        r53lyrCd5cqvnezYxLGsaCRr////Af///wGuaiZp7t3MteTJrpnkya6X5Mmul+TJrpnkya6Z5Mmul+TJ
+        rpfkya6X5MmumeTJrpfr2MOtrmomaf///wH///8BsGwoZ/Lk1r3p0ryh5MmtleTIrZXkyK2V5MitleTI
+        rZPkyK2T5Mitk+TIrZXkyK2V7NfDqbBsKGf///8B////AbJuKmXz59q/797Nr+vWwqPlyq+T5MeskeTI
+        rJHkyKyP5MiskeTHrJHkx6yR5Misj+zXw6eybipl////Af///wGzbytj9enewfHh0rHx4dKx797NrejS
+        u5nkya2P48isjePIrI3jx6yN48esjePHrI3r18Ols28rY////wH///8BtXEtYfXr4cPy5Ne18uTXtfLk
+        17Xy5Ne18OHRr+zYxaPo0ruX5s20keTKr4vkyq+L7dvIp7VxLWH///8B////AbdzL2H27eXF8+fct/Pn
+        3Lfz59y38+fct/Pn3Lfz59y38+fct/Pn3Lfz59y38+fct/bt5cW3cy9h////Af///wG4dDBf9+/nx/Tp
+        37n06d+59OnfufTp37n06d+59OnfufTp37n06d+59OnfufTp37n37+fHuHQwX////wH///8BuXUxXfjw
+        6cv16+G79evhu/Xr4bv16+G79evhu/Xr4bv16+G79evhu/Xr4bv16+G7+PDpy7l1MV3///8B////Abp2
+        MlHt28m3+fHqzfjx6cv48enL+PHpy/jx6cv48enL+PHpy/jx6cv48enL+fHqze3bybe6djJR////Af//
+        /wG7dzMfu3czT7t3M1u7dzNbu3czW7t3M1u7dzNbu3czW7t3M1u7dzNbu3czW7t3M1u7dzNPu3czH///
+        /wH///8B////Af///wH///8B////Af///wH///8B////Af///wH///8B////Af///wH///8B////Af//
+        //8AAP//AAD//w==
+</value>
   </data>
-  <data name="icon_mapdefinition" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_mapdefinition.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_mapdefinition" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAAAAAALAAAAFwAAABsAAAAbAAAAGwAAABsAAAAbAAAAGwAAABsAAAAbAAAAGwAAABsAAAAbAAAAFwAA
+        AAv///8BISEJaSsrC4crKwuHKysLhysrC4crKwuHKysLhysrC4crKwuHKysLhysrC4crKwuHKysLhysr
+        C4chIQlp////ATo6GIH5+en/8/Pi//Pz4v/z8+L/8/Pi//Pz4v/z8+L/8/Pi//Pz4v/z8+L/8/Pi//Pz
+        4v/5+en/OjoYgf///wFNTSl79PTk/26Jlf9ui5P/aJON/2Odif9jpYn/Z6uN/22yk/91uJv/f7+l/43J
+        uv+e0Mj/9PTk/01NKXv///8BVVUwd/X15v9vi5X/faqp/3a0ov9jpIj/d8ik/37Pq/+H17T/fL6j/6Dp
+        0/+z8+n/rNDC//X15v9VVTB3////AVpaNHX29un/bZCU/3ixpP90vaH/ZamM/3zNqf+E1bH/jty7/4XF
+        rv+t8OT/wvXq/77Nrv/29un/Wlo0df///wFeXjhz9/fr/2qWkP9loIv/ZaiM/222lf9wtpf/eLye/4LD
+        qv+W1cb/odPM/7fRuv/Qx5P/9/fr/15eOHP///8BY2M8c/j47v9nno7/dcGh/3jJpf9vtZb/iNi1/5Lf
+        wP+i6tX/ndTM/8z04//p67n/28KA//j47v9jYzxz////AWdnQHH5+fH/ZqaN/3fGpP99zqr/dbuc/4/d
+        vP+d5s3/r/Hm/6vXzf/g78j/+eOd/9+/eP/5+fH/Z2dAcf///wFra0Rv+/v0/2itj/97zKj/g9Sx/3vB
+        pP+Y48f/qe7f/7327f+91b3/8uep//7djf/gu3L/+/v0/2trRG////8Bb29Hbfz89/9rs5T/crqa/3rA
+        ov+HzbH/kNG//6LY0v+22cn/19eo/+DGgv/hv3b/4bdv//z89/9vb0dt////AXNzS2v9/fn/cbmZ/4bX
+        tP+Q3r7/jc65/7Dz6P/G9uv/4e/I/9/Li///2on//9KA/+OzbP/9/fn/c3NLa////wF3d05r/v78/3a+
+        n/+N3Lv/meTJ/5nXyv++9+7/2fPW//TnqP/lxn7//9WD///MfP/lsWr//v78/3d3Tmv///8BenpRaf//
+        /v98xKX/hcqv/5TUxP+l3NX/utzM/9TTpP/kyYT/5cJ4/+W5cf/ls23/5a5q/////v96elFp////AX19
+        U2f/////////////////////////////////////////////////////////////////////fX1TZ///
+        /wF/f1VNf39VZ39/VWd/f1Vnf39VZ39/VWd/f1Vnf39VZ39/VWd/f1Vnf39VZ39/VWd/f1Vnf39VZ39/
+        //8AAP//AAD//w==
+</value>
   </data>
-  <data name="icon_printlayout" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_printlayout.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_printlayout" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAD///8B////Af///wEsLAxlKioLhyoqC4cqKguHKioLhyoqC4cqKguHKioLhyoqC4csLAxl////Af//
+        /wH///8BAAAADQAAABsAAAAbODgXg//////////////////////+/v3//v79//39+//+/vv/ODgXgwAA
+        ABsAAAAbAAAADQ8PD3ESEhKFEhIShQMDA4nl5eX/5YdD/+Wzjv/AtJX/WXM7/3pcK/+XaTz/4+Pf/wMD
+        A4kSEhKFEhIShQ8PD3EpKSl7xb29/8W6uv9ZWVn/WVlZ/1lZWf9ZWVn/WVlZ/1lZWf9ZWVn/WVlZ/1lZ
+        Wf9ZWVn/zLu7/8y7u/8pKSl7MzMzdcTCwv+4sLD/b2tr/5aKiv+ViIj/loeH/5aHh/+Wh4f/l4eH/5eH
+        h/+Xh4f/cWlp/8y7u//Mu7v/MzMzdTo6Om24uLj/paWl/yAgIP9gVFT/Wk1N/1pNTf9aTU3/Wk1N/1pN
+        Tf9aTU3/Wk1N/yAgIP+dnZ3/r6+v/zo6Om1BQUFZyMjI3b6+vv8xMTH/XFZW/01ERP9NRET/TURE/01E
+        RP9NRET/TURE/05GRv8xMTH/Zv9m/7WoqN1BQUFZR0dHQa2trb/Jycn/RERE/2dmZv9JRkb/QDw8/z87
+        O/8/Ozv/Pzs7/z87O/9IRET/RERE/7uxsf+Wj4+/R0dHQUxMTCmSkpKh2tra/1hYWP92dnb/ZmZm/19f
+        X/9SUVH/REND/zw7O/83Njb/SklJ/1hYWP+/ubn/hYSEoUxMTClRUVEVenp6f+jo6P9oaGj/g4OD/319
+        ff99fX3/fX19/319ff99fX3/fHx8/4CAgP9oaGj/5OTk/3h4eH9RUVEVU1NTA1RUVE1UVFRnBAQEjXV1
+        df91dXX/dXV1/3V1df91dXX/dXV1/3V1df91dXX/BAQEjVRUVGdUVFRNU1NTA////wH///8B////AXR0
+        TGv6+vT/9fXt//Ly6v/u7uL/6OjZ/+bm1f/l5dT/8vLh/3R0TGv///8B////Af///wH///8B////Af//
+        /wF3d05p+vrz//Ly6v/u7uL/6OjZ/+bm1f+kpJP/pKST/6Skk/9JSSV9////Af///wH///8B////Af//
+        /wH///8BenpRafn58P/u7uL/6OjZ/+bm1f/l5dT/tral//////96elFpcXFJIf///wH///8B////Af//
+        /wH///8B////AX19U2f7++//9PTl//Pz4v/y8uH/8vLh/8LCsf99fVNnfX1TJf///wH///8B////Af//
+        /wH///8B////Af///wF/f1VNf39VZ39/VWd/f1Vnf39VZ39/VWd/f1Vnf39VJf///wH///8B////Af//
+        //8AAP//AAD//w==
+</value>
   </data>
-  <data name="icon_symboldefinition" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_symboldefinition.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_symboldefinition" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAD///8B////Af///wEAAAAFAAAAFwAAAC0AAGd7AACVywAAZ3sAAAAxAAAAHQAAAAf///8B////Af//
+        /wH///8B////Af///wH///8BAAAAAwAAAA0AAAAXAACVy1ZW7/8AAJXLAAAAGQAAAA8AAAAF////Af//
+        /wH///8B////Af///wH///8B////Af///wH///8B////AQAAlstYWPD/AACWy////wH///8B////Af//
+        /wH///8B////Af///wH///8B////Af///wH///8B////Af///wEAAJvJW1vx/wAAm8n///8B////Af//
+        /wH///8B////Af///wH///8B////Af///wH///8B////Af///wEAAKMNAACixV9f8v8AAKLFAACjDf//
+        /wH///8B////Af///wH///8B////Af///wH///8B////Af///wH///8BAACqWxwcvdFjY/X/HBy90QAA
+        qlv///8B////Af///wH///8B////Af///wH///8B////Af///wH///8BAAC0CwAAsq9SUuXtYmL1/1JS
+        5e0AALKvAAC0C////wH///8B////Af///wH///8B////Af///wH///8B////AQEBvGEjI8zNbW34/2Vl
+        9v9tbfj/IyPMzQEBvGH///8B////Af///wH///8B////Af///wH///8B////AQEBxRUCAsWxaGjw8Wlp
+        +P9pafj/aWn4/2ho8PECAsWxAQHFFf///wH///8B////Af///wH///8B////Af///wEBAc1nNTXezXR0
+        +v9sbPn/bGz5/2xs+f90dPr/NTXezQEBzWf///8B////Af///wH///8B////Af///wH///8BAQHVn3Nz
+        9u1ubvv/VVWb/z8/Sv9VVZv/bm77/3Nz9u0BAdWf////Af///wH///8B////Af///wH///8B////AQEB
+        3KuGhv39cXH8/0tLV/9ISEj/S0tX/3Fx/P+Ghv39AQHcq////wH///8B////Af///wH///8B////Af//
+        /wEBAeKjhIT883R0/f9jY6j/VlZh/2NjqP90dP3/hIT88wEB4qP///8B////Af///wH///8B////Af//
+        /wH///8BAQHldU9P8s+Bgf//dnb+/3Z2/v92dv7/gYH//09P8s8BAeV1////Af///wH///8B////Af//
+        /wH///8B////AQEB5RkBAeWfSkrxy4mJ/POQkP//iYn880pK8csBAeWfAQHlGf///wH///8B////Af//
+        /wH///8B////Af///wH///8BAQHlEwEB5XEBAeWhAQHlqQEB5aEBAeVxAQHlE////wH///8B////Af//
+        //8AAP//AAD//w==
+</value>
   </data>
-  <data name="icon_symbolibrary" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_symbolibrary.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_symbolibrary" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAAAAAAHAAAAGQAAABsAAAAbAAAAGwAAABsAAAAbAAAAGwAAABsAAAAbAAAAGwAAAAn///8B////Af//
+        /wH///8BJiYNZzExEIUxMRCFMTEQhTExEIUxMRCFMTEQhTExEIUxMRCFMTEQhTExEIUmJg1n////Af//
+        /wH///8B////AUpKJ3v5+er/8/Pk//Pz5P/z8+T/8/Pk//Pz5P/z8+T/8/Pk//Pz5P/5+er/Q0MjiQAA
+        ABsAAAAJ////Af///wFXVzJ39fXm/whylP8IcpT/CHKU/wlzlf8JgJ//DbHE/wqSrf8IdJb/9fXm/0hI
+        Jb8xMRCFJiYNZ////wH///8BXl44c/f36/8KjrD/C46w/w2Rs/8OkrT/EabD/xrV5f8WuNH/D52+//f3
+        6/+wsJb/+fnq/0NDI4kAAAAbAAAACWVlPnH5+e//Gxs9/ystTv8ybY7/NYys/1bH2P+F////buny/zfC
+        4f/5+e//uaBy//X15v9ISCW/MTEQhSYmDWdra0Rv+/v0/zxEY/80f5//KMHj/ynC5P830uv/V/L5/0Tf
+        8f8rxOX/+/v0/7yrfv/39+v/sLCW//n56v9KSid7cXFJbf39+P8gr9D/HrbY/x632f8et9n/H7ra/yK/
+        3f8hvNv/HrjZ//39+P++vKb/+fnv/zFub//19eb/V1cyd3Z2TWv+/vz/FK3P/xStz/8Urc//FK3P/xSt
+        z/8Vrc//FK3P/xStz//+/vz/x7+p//v79P82h4n/9/fr/15eOHN7e1Fp/////////v////7////+////
+        /v////7////+/////v////7//////8q9o//9/fj/T6Ch//n57/9lZT5xfn5VTX5+VWd7e1Kny8u5/8uK
+        Sv/LjE7/y45S/8uLTf/Lk1r/y5Zf/8unfP/YuJX//v78/0qkpv/7+/T/a2tEb////wH///8Be3tRaf//
+        //////7////+/////v////7////+/////v////7////+//////9En6L//f34/3FxSW3///8B////AX5+
+        VU1+flVne3tSp8vLuf8/mp7/P5qe/z+anv8/mp7/P5qe/z+anv8/mp7/NJ+q//7+/P92dk1r////Af//
+        /wH///8B////AXt7UWn////////+/////v////7////+/////v////7////+/////v//////e3tRaf//
+        /wH///8B////Af///wF+flVNfn5VZ35+VWd+flVnfn5VZ35+VWd+flVnfn5VZ35+VWd+flVnfn5VZ35+
+        VU3///8B////Af///wH///8B////Af///wH///8B////Af///wH///8B////Af///wH///8B////Af//
+        //8AAP//AAD//w==
+</value>
   </data>
-  <data name="icon_watermark" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_watermark.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_watermark" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAD///8BAAAAAwAAAA8AAAAfJxgFOZ9iFXfBdxmZwncYn8B2GJmdYBN5JhgFOQAAACEAAAARAAAAA///
+        /wH///8B////Af///wEAAAAJNyMJJ8R6HJHcrXGv9eTOxfz16s315M7F26tusb91GJc2IQcnAAAACQAA
+        AAP///8B////Af///wH///8B////Acp/IGffrm+v9+HBzfLMmM3wxInN8syYzffhwc3cq2yzw3gZbf//
+        /wH///8B////Af///wH///8B////Af///wHNgiOL8c+jxfPMl83xyJDN8ciQzfHIkM3zzJfN8M6hxcZ7
+        HJX///8B////Af///wH///8B////Af///wH///8Bz4Qli/TVqcvzzpzN886czfPOnM35587N886czfTU
+        qcvIfR6X////Af///wH///8B////Af///wH///8B////AdKHKH3x0KW9+ODAzfro0c344MDN9dWqzfXV
+        qs3vzaK/y4Ahhf///wH///8B////Af///wH///8B////Af///wHViitN465rnfzv3s3////N++zZzfbb
+        uM344MDN36lmpc2CI1P///8B////Af///wH///8B////Af///wH///8B2I0uD9iNLn/35c2/+/Dhzfrr
+        1s3448bN9N2+v9KHKIfQhSYP////Af///wH///8B////Af///wH///8B////Af///wHajzBD5K1nk/vu
+        3c366dTN++7dzeGqY5fUiSpH////Af///wH///8B////Af///wH///8B////Af///wH///8B3JEyB9yR
+        MnP24MS1/PDgzfXfw7fYjS531ossCf///wH///8B////Af///wH///8B////Af///wH///8B////Af//
+        /wHflDU357Jujf758s3msWyP25AxO////wH///8B////Af///wH///8B////Af///wH///8B////Af//
+        /wH///8B4JU2CeGWN3H++fLH35Q1c92SMwn///8B////Af///wH///8B////Af///wH///8B////Af//
+        /wH///8B////Af///wHjmDlH7b2Bi+KXOEn///8B////Af///wH///8B////Af///wH///8B////Af//
+        /wH///8B////Af///wH///8B5Zo7JeWaO2/kmTol////Af///wH///8B////Af///wH///8B////Af//
+        /wH///8B////Af///wH///8B////AeecPQ/nnD1t5ps8D////wH///8B////Af///wH///8B////Af//
+        /wH///8B////Af///wH///8B////Af///wH///8B6Z4/Nf///wH///8B////Af///wH///8B////Af//
+        //8AAP//AAD//w==
+</value>
   </data>
-  <data name="icon_weblayout" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_weblayout.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_weblayout" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAD///8B////Af///wH///8B////Af///wH///8B////Af///wH///8B////Af///wH///8B////Af//
+        /wH///8BAAAACQAAABcAAAAbAAAAGwAAABsAAAAbAAAAGwAAABsAAAAbAAAAGwAAABsAAAAbAAAAGwAA
+        ABsAAAAXAAAACQ0NDWcQEBCFEBAQhYJBAM2CQQDNgkEAzYJBAM2CQQDNgkEAzYJBAM2CQQDNgkEAzYJB
+        AM2CQQDNgkEAzWIxAJ0nJyd76+vr/+fn5/+XZTL/vIA4/+WeQ//JhSX/zYwo/86MKf/OjSr/y4op/86K
+        Mv/XkD7/9a1U/7l0Hf+NSgDLMjIyd+rq6v/i4uL/onNA/+i2dP/UlUH/zY8v/9SYOP/Umzv/1Zw+/8+V
+        PP/mrV7//cV3//W7bP/Ojz7/nlYByTg4OHPt7e3/5ubm/7mSZP/Ro2n/155I/9igRf/Yo0//3KpX/96t
+        Xf/fsGn/0qBc/8mTTv/60Y//7b96/7JlAsU+Pj5x8PDw/+vr6//ZxKv/wo5N/9qpX//fsmj/9Nmh/+S+
+        gv/kvX3/89in///tv//ctX7/9Nmj///orv/GdALDREREb/Pz8//v7+//7uvo/86dXv/fuH7/58OJ//jn
+        uv/+8sz/79Sl//LZrf/46cP//PDK///1yv//9Mb/2IEDwUlJSW339/f/9PT0//T09P/v5df/2qRY/+S7
+        gP/v16v//PLM//HVpf/vzpv/+OrG///61///+df/8NOe/756FalNTU1r+vr6//j4+P/4+Pj/+Pj4//Xq
+        2//msmX/5rBg/+3Jk//y1qj/8tmy//zyz//34bH/67lr/+ezZv9NTU1rUVFRaf39/f/8/Pz//Pz8//z8
+        /P/8/Pz//Pn1//beu//wv3b/7rBV/+ypRv/usFX/8L92//beu//9+vb/UVFRaVVVVWf/////////////
+        /////////////////////////////////////////////////////////////1VVVWdQUFBpu7u7/7q6
+        uv+4uLj/tra2/7Ozs/+wsLD/rq6u/6urq/+oqKj/pqam/6Ojo/+goKD/np6e/5ycnP8DAwNnUlJSW8bG
+        xtXc3Nz/2NnZ/9XV1f/Q0dH/zMzM/8jIyP/Gxsb/xsXF/8nFxf/Nxsb/0cfH/9fLy//EuLjVUlJSW1VV
+        VSNVVVVZVVVVZ1VVVWdVVVVnVVVVZ1VVVWdVVVVnVVVVZ1VVVWdVVVVnVVVVZ1VVVWdVVVVnVVVVWVVV
+        VSP///8B////Af///wH///8B////Af///wH///8B////Af///wH///8B////Af///wH///8B////Af//
+        //8AAP//AAD//w==
+</value>
   </data>
-  <data name="icon_xmleditor" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_xmleditor.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_xmleditor" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        AAAAAAATAAAALSEhCXMqKguHKioLhyoqC4cqKguHKioLhyoqC4cqKguHKioLhyoqC4cqKguHISEJcwAA
+        AC0AAAATAAAACQAAABc4OBeD///////////////////+//7+/f/+/vz//f37//39+v/8/Pj//v75/zg4
+        F4MAAAAXAAAACf///wH///8BSUkme////////////v7+//39/P/9/fv//Pz5//v7+P/6+vb/+Pj0//v7
+        9v9JSSZ7////Af///wH///8B////AVRUL3f//////v7+//39/P/9/fv//Pz5//v7+P/6+vb/+Pj0//f3
+        8v/7+/X/VFQvd////wH///8B////Af///wFYWDN3///+//39/P/U1NL/Wlpa/+bm5P/l5eL/Wlpa/9DQ
+        y//29vD/+vrz/1hYM3f///8B////Af///wH///8BXFw3df7+/f/q6uj/Y2Nj/8HBv//6+vb/+Pj0/7+/
+        vP9jY2P/4+Pd//r68v9cXDd1////Af///wH///8B////AWFhOnP+/vz/tbW0/6Ojov/6+vb/+Pj0//f3
+        8v/29vD/oaGf/7Gxrf/5+e//YWE6c////wH///8B////Af///wFlZT5x/f37/+rq6P96enr/ycnG//f3
+        8v/29vD/x8fD/3p6ev/i4tn/9/fq/2VlPnH///8B////Af///wH///8BaWlCb/39+v/6+vb/3NzY/4aG
+        hv/o6OP/5+fh/4aGhv/W1s//7Ozf//T05f9paUJv////Af///wH///8B////AW1tRW38/Pj/+Pj0//f3
+        8v/29vD/9fXu//T07P/x8ef/7Ozf/+jo2f/z8+L/bW1Fbf///wH///8B////Af///wFxcUht/Pz3//f3
+        8v/29vD/9fXu//T07P/x8ef/7Ozf/+jo2f/m5tX/8vLh/3FxSG3///8B////Af///wH///8BdHRMa/v7
+        9v/29vD/9fXu//T07P/x8ef/7Ozf/+jo2f/m5tX/5eXU//Ly4f90dExr////Af///wH///8B////AXd3
+        Tmn6+vT/9fXu//T07P/x8ef/7Ozf/+jo2f/m5tX/pKST/6Skk/+kpJP/SUklff///wH///8B////Af//
+        /wF6elFp+vrz//T07P/x8ef/7Ozf/+jo2f/m5tX/5eXU/7a2pf//////enpRaXp6USX///8B////Af//
+        /wH///8BfX1TZ/z89f/5+e//9vbq//T05f/z8+L/8vLh//Ly4f/CwrH/fX1TZ319UyX///8B////Af//
+        /wH///8B////AX9/VU1/f1Vnf39VZ39/VWd/f1Vnf39VZ39/VWd/f1Vnf39VZ39/VSX///8B////Af//
+        //8AAP//AAD//w==
+</value>
   </data>
-  <data name="icon_document" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\icon_document.ico;System.Drawing.Icon, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+  <data name="icon_document" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        8v/7+/X/VFQvd////wH///8B////Af///wFYWDN3///+//39/P/9/fv//Pz5//v7+P/6+vb/+Pj0//f3
+        8v/29vD/+vrz/1hYM3f///8B////Af///wH///8BXFw3df7+/f/9/fv//Pz5//v7+P/6+vb/+Pj0//f3
+        8v/29vD/9fXu//r68v9cXDd1////Af///wH///8B////AWFhOnP+/vz//Pz5//v7+P/6+vb/+Pj0//f3
+        8v/29vD/9fXu//T07P/5+e//YWE6c////wH///8B////Af///wFlZT5x/f37//v7+P/6+vb/+Pj0//f3
+        8v/29vD/9fXu//T07P/x8ef/9/fq/2VlPnH///8B////Af///wH///8BaWlCb/39+v/6+vb/+Pj0//f3
+        8v/29vD/9fXu//T07P/x8ef/7Ozf//T05f9paUJv////Af///wH///8B////AW1tRW38/Pj/+Pj0//f3
+        //8AAP//AAD//w==
+</value>
   </data>
   <data name="ErrorUnknownExecutable" xml:space="preserve">
     <value>Unknown executable specified: {0}</value>
   </data>
+  <data name="PrgPreSaveValidation" xml:space="preserve">
+    <value>Performing pre-save validation...
+You can disable pre-save validation in Maestro options</value>
+  </data>
+  <data name="PrgPreparingResourcePreview" xml:space="preserve">
+    <value>Preparing resource preview</value>
+  </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs	2012-05-22 16:02:07 UTC (rev 6682)
+++ trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs	2012-05-22 16:41:16 UTC (rev 6683)
@@ -20,6 +20,7 @@
 using System;
 using System.Collections.Generic;
 using System.Text;
+using Maestro.Shared.UI;
 using OSGeo.MapGuide.MaestroAPI.Resource;
 using OSGeo.MapGuide.MaestroAPI;
 using Maestro.Base.Editor;
@@ -39,21 +40,25 @@
         public void Preview(IResource res, IEditorService edSvc)
             IServerConnection conn = res.CurrentConnection;
-            string mapguideRootUrl = (string)conn.GetCustomProperty("BaseUrl");
-            //Save the current resource to another session copy
-            string resId = "Session:" + edSvc.SessionID + "//" + Guid.NewGuid() + "." + res.ResourceType.ToString();
-            edSvc.ResourceService.SetResourceXmlData(resId, ResourceTypeRegistry.Serialize(res));
-            //Copy any resource data
-            var previewCopy = edSvc.ResourceService.GetResource(resId);
-            res.CopyResourceDataTo(previewCopy);
-            //Now feed it to the preview engine
-            var url = new ResourcePreviewEngine(mapguideRootUrl, edSvc).GeneratePreviewUrl(previewCopy);
-            var launcher = ServiceRegistry.GetService<UrlLauncherService>();
-            launcher.OpenUrl(url);
+            BusyWaitDialog.Run(Properties.Resources.PrgPreparingResourcePreview, () => {
+                string mapguideRootUrl = (string)conn.GetCustomProperty("BaseUrl");
+                //Save the current resource to another session copy
+                string resId = "Session:" + edSvc.SessionID + "//" + Guid.NewGuid() + "." + res.ResourceType.ToString();
+                edSvc.ResourceService.SetResourceXmlData(resId, ResourceTypeRegistry.Serialize(res));
+                //Copy any resource data
+                var previewCopy = edSvc.ResourceService.GetResource(resId);
+                res.CopyResourceDataTo(previewCopy);
+                //Now feed it to the preview engine
+                return new ResourcePreviewEngine(mapguideRootUrl, edSvc).GeneratePreviewUrl(previewCopy);
+            }, (result) => {
+                if (result != null) {
+                    var url = result.ToString();
+                    var launcher = ServiceRegistry.GetService<UrlLauncherService>();
+                    launcher.OpenUrl(url);
         public bool IsPreviewable(IResource res)
Added: trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.Designer.cs	2012-05-22 16:41:16 UTC (rev 6683)
@@ -0,0 +1,67 @@
+namespace Maestro.Shared.UI
+    partial class BusyWaitDialog
+        /// <summary>
+        /// Designer variable used to keep track of non-visual components.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Disposes resources used by the form.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing) {
+                if (components != null) {
+                    components.Dispose();
+            base.Dispose(disposing);
+        /// <summary>
+        /// This method is required for Windows Forms designer support.
+        /// Do not change the method contents inside the source code editor. The Forms designer might
+        /// not be able to load this method if it was changed manually.
+        /// </summary>
+        private void InitializeComponent()
+            System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(BusyWaitDialog));
+            this.bgWorker = new System.ComponentModel.BackgroundWorker();
+            this.lblBusy = new System.Windows.Forms.Label();
+            this.progressBar1 = new System.Windows.Forms.ProgressBar();
+            this.SuspendLayout();
+            // bgWorker
+            this.bgWorker.DoWork += new System.ComponentModel.DoWorkEventHandler(this.BgWorker_DoWork);
+            this.bgWorker.RunWorkerCompleted += new System.ComponentModel.RunWorkerCompletedEventHandler(this.BgWorker_RunWorkerCompleted);
+            // lblBusy
+            resources.ApplyResources(this.lblBusy, "lblBusy");
+            this.lblBusy.Name = "lblBusy";
+            // progressBar1
+            resources.ApplyResources(this.progressBar1, "progressBar1");
+            this.progressBar1.Name = "progressBar1";
+            this.progressBar1.Style = System.Windows.Forms.ProgressBarStyle.Marquee;
+            // BusyWaitDialog
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
+            resources.ApplyResources(this, "$this");
+            this.ControlBox = false;
+            this.Controls.Add(this.lblBusy);
+            this.Controls.Add(this.progressBar1);
+            this.Name = "BusyWaitDialog";
+            this.ResumeLayout(false);
+        private System.Windows.Forms.ProgressBar progressBar1;
+        private System.Windows.Forms.Label lblBusy;
+        private System.ComponentModel.BackgroundWorker bgWorker;
Added: trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.cs	2012-05-22 16:41:16 UTC (rev 6683)
@@ -0,0 +1,86 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Drawing;
+using System.Windows.Forms;
+    public delegate object BusyWaitDelegate();
+    /// <summary>
+    /// A generic dialog for some potentially long task that cannot be measured
+    /// </summary>
+    public partial class BusyWaitDialog : Form
+        private BusyWaitDelegate _action;
+        internal BusyWaitDialog(BusyWaitDelegate action)
+            // The InitializeComponent() call is required for Windows Forms designer support.
+            InitializeComponent();
+            _action = action;
+        protected override void OnLoad(EventArgs e)
+            base.OnLoad(e);
+            bgWorker.RunWorkerAsync();
+        public object ReturnValue { get; private set; }
+        public static void Run(string message, BusyWaitDelegate action, Action<object> onComplete)
+            if (action == null)
+                throw new ArgumentNullException("action");
+            if (onComplete == null)
+                throw new ArgumentNullException("onComplete");
+            var frm = new BusyWaitDialog(action);
+            frm.lblBusy.Text = message;
+            if (frm.ShowDialog() == DialogResult.OK)
+                onComplete.Invoke(frm.ReturnValue);
+        void BgWorker_DoWork(object sender, System.ComponentModel.DoWorkEventArgs e)
+            e.Result = _action.Invoke();
+        void BgWorker_RunWorkerCompleted(object sender, System.ComponentModel.RunWorkerCompletedEventArgs e)
+            if (e.Error != null)
+                ErrorDialog.Show(e.Error);
+            else
+                this.ReturnValue = e.Result;
+            this.DialogResult = DialogResult.OK;
Added: trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.resx
--- trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.resx	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.resx	2012-05-22 16:41:16 UTC (rev 6683)
@@ -0,0 +1,204 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+  <metadata name="bgWorker.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 17</value>
+  </metadata>
+  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="lblBusy.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+    <value>Fill</value>
+  </data>
+  <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+  <data name="lblBusy.Location" type="System.Drawing.Point, System.Drawing">
+    <value>0, 0</value>
+  </data>
+  <data name="lblBusy.Size" type="System.Drawing.Size, System.Drawing">
+    <value>422, 164</value>
+  </data>
+  <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+  <data name="lblBusy.TabIndex" type="System.Int32, mscorlib">
+    <value>0</value>
+  </data>
+  <data name="lblBusy.Text" xml:space="preserve">
+    <value>label1</value>
+  </data>
+  <data name="lblBusy.TextAlign" type="System.Drawing.ContentAlignment, System.Drawing">
+    <value>MiddleCenter</value>
+  </data>
+  <data name="&gt;&gt;lblBusy.Name" xml:space="preserve">
+    <value>lblBusy</value>
+  </data>
+  <data name="&gt;&gt;lblBusy.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;lblBusy.Parent" xml:space="preserve">
+    <value>$this</value>
+  </data>
+  <data name="&gt;&gt;lblBusy.ZOrder" xml:space="preserve">
+    <value>0</value>
+  </data>
+  <data name="progressBar1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+    <value>Bottom</value>
+  </data>
+  <data name="progressBar1.Location" type="System.Drawing.Point, System.Drawing">
+    <value>0, 164</value>
+  </data>
+  <data name="progressBar1.Size" type="System.Drawing.Size, System.Drawing">
+    <value>422, 23</value>
+  </data>
+  <data name="progressBar1.TabIndex" type="System.Int32, mscorlib">
+    <value>1</value>
+  </data>
+  <data name="&gt;&gt;progressBar1.Name" xml:space="preserve">
+    <value>progressBar1</value>
+  </data>
+  <data name="&gt;&gt;progressBar1.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ProgressBar, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;progressBar1.Parent" xml:space="preserve">
+  </data>
+  <data name="&gt;&gt;progressBar1.ZOrder" xml:space="preserve">
+    <value>1</value>
+  </data>
+  <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+    <value>True</value>
+  </metadata>
+  <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+    <value>422, 187</value>
+  </data>
+  <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+    <value>CenterParent</value>
+  </data>
+  <data name="$this.Text" xml:space="preserve">
+    <value>Please Wait</value>
+  </data>
+  <data name="&gt;&gt;bgWorker.Name" xml:space="preserve">
+    <value>bgWorker</value>
+  </data>
+  <data name="&gt;&gt;bgWorker.Type" xml:space="preserve">
+    <value>System.ComponentModel.BackgroundWorker, System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+  <data name="&gt;&gt;$this.Name" xml:space="preserve">
+    <value>BusyWaitDialog</value>
+  </data>
+  <data name="&gt;&gt;$this.Type" xml:space="preserve">
+    <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
+</root>
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/CancelException.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/CancelException.cs	2012-05-22 16:02:07 UTC (rev 6682)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/CancelException.cs	2012-05-22 16:41:16 UTC (rev 6683)
@@ -1,4 +1,23 @@
-using System;
+#endregion
+using System;
 using System.Text;
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj
--- trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj	2012-05-22 16:02:07 UTC (rev 6682)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj	2012-05-22 16:41:16 UTC (rev 6683)
@@ -66,6 +66,10 @@
     <Compile Include="..\Properties\SignedAssemblyInfo2.cs">
       <Link>SignedAssemblyInfo2.cs</Link>
     </Compile>
+    <Compile Include="BusyWaitDialog.cs" />
+    <Compile Include="BusyWaitDialog.Designer.cs">
+      <DependentUpon>BusyWaitDialog.cs</DependentUpon>
+    </Compile>
     <Compile Include="CancelException.cs" />
     <Compile Include="CheckBoxBinder.cs" />
     <Compile Include="CollapsiblePanel.cs">
@@ -125,6 +129,9 @@
     <Service Include="{94E38DFF-614B-4cbd-B67C-F211BB35CE8B}" />
   </ItemGroup>
   <ItemGroup>
+    <EmbeddedResource Include="BusyWaitDialog.resx">
+    </EmbeddedResource>
     <EmbeddedResource Include="CollapsiblePanel.resx">
       <DependentUpon>CollapsiblePanel.cs</DependentUpon>
       <SubType>Designer</SubType>
More information about the mapguide-commits mailing list
