[mapguide-commits] r6697 - in branches/2.4/MgDev/Desktop: DesktopUnmanagedApi/DotNet MgDesktop/Services
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri May 25 04:57:18 PDT 2012
Author: jng
Date: 2012-05-25 04:57:18 -0700 (Fri, 25 May 2012)
New Revision: 6697
   branches/2.4/MgDev/Desktop/DesktopUnmanagedApi/DotNet/MapGuideDesktopApiGen.xml
   branches/2.4/MgDev/Desktop/DesktopUnmanagedApi/DotNet/MapGuideDesktopConstants.xml
   branches/2.4/MgDev/Desktop/MgDesktop/Services/RenderingService.h
mg-desktop: API exposure cleanup
Modified: branches/2.4/MgDev/Desktop/DesktopUnmanagedApi/DotNet/MapGuideDesktopApiGen.xml
--- branches/2.4/MgDev/Desktop/DesktopUnmanagedApi/DotNet/MapGuideDesktopApiGen.xml	2012-05-25 10:35:34 UTC (rev 6696)
+++ branches/2.4/MgDev/Desktop/DesktopUnmanagedApi/DotNet/MapGuideDesktopApiGen.xml	2012-05-25 11:57:18 UTC (rev 6697)
@@ -95,7 +95,13 @@
     <Header path="../../MgDesktop/Exception/DwfSectionResourceNotFoundException.h" />
     <Header path="../../MgDesktop/Exception/InvalidDwfPackageException.h" />
     <Header path="../../MgDesktop/Exception/InvalidDwfSectionException.h" />
+    <Header path="../../MgDesktop/Exception/InvalidFeatureSourceException.h" />
+    <Header path="../../MgDesktop/Exception/InvalidLogEntryException.h" />
+    <Header path="../../MgDesktop/Exception/InvalidPrintLayoutFontSizeUnitsException.h" />
+    <Header path="../../MgDesktop/Exception/InvalidPrintLayoutPositionUnitsException.h" />
+    <Header path="../../MgDesktop/Exception/InvalidPrintLayoutSizeUnitsException.h" />
     <Header path="../../MgDesktop/Exception/ParameterNotFoundException.h" />
+    <Header path="../../MgDesktop/Exception/StylizeLayerFailedException.h" />
     <Header path="../../MgDesktop/Services/DataReader.h" />
     <Header path="../../MgDesktop/Services/DrawingService.h" />
Modified: branches/2.4/MgDev/Desktop/DesktopUnmanagedApi/DotNet/MapGuideDesktopConstants.xml
--- branches/2.4/MgDev/Desktop/DesktopUnmanagedApi/DotNet/MapGuideDesktopConstants.xml	2012-05-25 10:35:34 UTC (rev 6696)
+++ branches/2.4/MgDev/Desktop/DesktopUnmanagedApi/DotNet/MapGuideDesktopConstants.xml	2012-05-25 11:57:18 UTC (rev 6697)
@@ -77,7 +77,6 @@
     <Class name="MgUnitType" />
     <Class name="MgPageUnitsType" />
     <Class name="MgImageFormats" />
-    <Class name="MgConfigProperties" />
 </Classes>
@@ -88,7 +87,6 @@
     <Header path="../../MgDesktop/Services/ImageFormats.h" />
     <Header path="../../MgDesktop/Services/Rendering/MapPlotInstruction.h" />
     <Header path="../../MgDesktop/Services/Rendering/UnitType.h" />
-    <Header path="../../MgDesktop/System/ConfigProperties.h" />
 </Headers>
 </Parameters>
Modified: branches/2.4/MgDev/Desktop/MgDesktop/Services/RenderingService.h
--- branches/2.4/MgDev/Desktop/MgDesktop/Services/RenderingService.h	2012-05-25 10:35:34 UTC (rev 6696)
+++ branches/2.4/MgDev/Desktop/MgDesktop/Services/RenderingService.h	2012-05-25 11:57:18 UTC (rev 6697)
@@ -58,11 +58,6 @@
                                                MgdSelection* selection,
                                                MgRenderingOptions* options);
-    virtual MgByteReader* RenderDynamicOverlay(MgdMap* map,
-                                               MgdSelection* selection,
-                                               MgRenderingOptions* options,
-                                               ProfileRenderMapResult* pPRMResult);
     virtual MgByteReader* RenderMap(MgdMap* map,
                                     CREFSTRING format);
@@ -121,6 +116,11 @@
 INTERNAL_API:
+    virtual MgByteReader* RenderDynamicOverlay(MgdMap* map,
+                                               MgdSelection* selection,
+                                               MgRenderingOptions* options,
+                                               MdfModel::ProfileRenderMapResult* pPRMResult);
                                     MgEnvelope* extents,
@@ -166,7 +166,7 @@
                                     MgColor* backgroundColor,
                                     CREFSTRING format,
                                     bool bKeepSelection,
@@ -178,7 +178,7 @@
                                     CREFSTRING format,
                                     bool bClip,
-                                    ProfileRenderMapResult* pPRMResult = NULL);
+                                    MdfModel::ProfileRenderMapResult* pPRMResult = NULL);
 private:
     // used for tile generation
@@ -198,7 +198,7 @@
     MgByteReader* RenderDynamicOverlayInternal(MgdMap* map,
     // Internal help called by our PUBLISHED_API versions of RenderMap
     MgByteReader* RenderMapPublished(MgdMap* map,
@@ -222,7 +222,7 @@
                                     bool expandExtents,
                                     bool renderWatermark,
     MgByteReader* RenderMapInternal(MgdMap* map,
@@ -237,7 +237,7 @@
                                     bool expandExtents,
     void RenderForSelection(MgMap* map,
                          MgStringCollection* layerNames,
@@ -263,7 +263,7 @@
                       bool expandExtents,
                       double scale,
                       CREFSTRING format,
     void RenderSelection(MgdMap* map,
@@ -274,7 +274,7 @@
                          MgCoordinateSystem* dstCs,
                          double scale,
                          INT32 behavior,
     void RenderWatermarks(MgdMap* map,
                           MgReadOnlyLayerCollection* layers,
@@ -284,14 +284,14 @@
                           int drawHeight,
                           INT32 saveWidth,
                           INT32 saveHeight,
     MgByteReader* CreateImage(MgdMap* map,
                               Renderer* dr,
                               INT32 saveWidth,
                               INT32 saveHeight,
                               CREFSTRING format,
     // member data
     Ptr<MgFeatureService> m_svcFeature;
More information about the mapguide-commits mailing list
