[mapguide-commits] r6701 - in trunk/Tools/Maestro: Maestro.Shared.UI OSGeo.MapGuide.MaestroAPI/Mapping OSGeo.MapGuide.MaestroAPI/Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon May 28 08:49:03 PDT 2012
Author: jng
Date: 2012-05-28 08:49:02 -0700 (Mon, 28 May 2012)
New Revision: 6701
   trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
MaestroAPI: Fix initialization logic for attached MapSelection
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj
--- trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj	2012-05-28 14:37:48 UTC (rev 6700)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/Maestro.Shared.UI.csproj	2012-05-28 15:49:02 UTC (rev 6701)
@@ -66,7 +66,9 @@
     <Compile Include="..\Properties\SignedAssemblyInfo2.cs">
       <Link>SignedAssemblyInfo2.cs</Link>
     </Compile>
-    <Compile Include="BusyWaitDialog.cs" />
+    <Compile Include="BusyWaitDialog.cs">
+      <SubType>Form</SubType>
+    </Compile>
     <Compile Include="BusyWaitDialog.Designer.cs">
       <DependentUpon>BusyWaitDialog.cs</DependentUpon>
     </Compile>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs	2012-05-28 14:37:48 UTC (rev 6700)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMap.cs	2012-05-28 15:49:02 UTC (rev 6701)
@@ -951,8 +951,26 @@
                     _selection = new MapSelection(this);
                     var resId = this.ResourceID.Replace(".Map", ".Selection");
-                    var ser = new MgBinaryDeserializer(this.ResourceService.GetResourceData(resId, "RuntimeData"), this.CurrentConnection.SiteVersion);
-                    _selection.Deserialize(ser);
+                    var bLoadedSelection = false;
+                    if (this.ResourceService.ResourceExists(resId))
+                        var dataItems = this.ResourceService.EnumerateResourceData(resId);
+                        foreach (var item in dataItems.ResourceData)
+                            if (item.Name == "RuntimeData")
+                                var ser = new MgBinaryDeserializer(this.ResourceService.GetResourceData(resId, "RuntimeData"), this.CurrentConnection.SiteVersion);
+                                _selection.Deserialize(ser);
+                                bLoadedSelection = true;
+                                break;
+                    if (!bLoadedSelection)
                 return _selection;
@@ -1257,9 +1275,6 @@
         private void SaveSelectionXml(string resourceID)
-            if (this.Selection == null)
-                return;
             ResourceIdentifier.Validate(resourceID, ResourceTypes.RuntimeMap);
             string selectionID = resourceID.Substring(0, resourceID.LastIndexOf(".")) + ".Selection";
             System.IO.MemoryStream ms = new System.IO.MemoryStream();
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs	2012-05-28 14:37:48 UTC (rev 6700)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs	2012-05-28 15:49:02 UTC (rev 6701)
@@ -277,6 +277,8 @@
                 var fs = (IFeatureSource)this.Parent.ResourceService.GetResource(vl.ResourceId);
                 var cls = fs.GetClass(vl.FeatureName);
+                if (cls == null)
+                    throw new Exception(string.Format(Properties.Resources.ERR_CLASS_NOT_FOUND, vl.FeatureName));
                 var idProps = cls.IdentityProperties;
                 var propInfo = new PropertyInfo[idProps.Count];
@@ -290,9 +292,10 @@
                 this.IdentityProperties = propInfo;
-            catch (Exception ex) //Has to be a bug in MapGuide
+            catch (Exception ex) //Has to be a bug in MapGuide or in the FDO provider
-                Trace.TraceWarning("Could fetch and initialize identity properties for " + this.Name + " This is likely a bug in MapGuide " + Environment.NewLine + ex.ToString());
+                this.IdentityProperties = new PropertyInfo[0];
+                Trace.TraceWarning(string.Format(Properties.Resources.ERR_INIT_IDENTITY_PROPS, Environment.NewLine, this.Name, ex.ToString()));
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs	2012-05-28 14:37:48 UTC (rev 6700)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs	2012-05-28 15:49:02 UTC (rev 6701)
@@ -369,6 +369,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Class not found: {0}.
+        /// </summary>
+        internal static string ERR_CLASS_NOT_FOUND {
+            get {
+                return ResourceManager.GetString("ERR_CLASS_NOT_FOUND", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to A resource converter for {0} is already registered.
         /// </summary>
         internal static string ERR_CONVERTER_ALREADY_REGISTERED {
@@ -396,6 +405,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Could fetch and initialize identity properties for {1} This is likely a bug in MapGuide {0}{2}.
+        /// </summary>
+        internal static string ERR_INIT_IDENTITY_PROPS {
+            get {
+                return ResourceManager.GetString("ERR_INIT_IDENTITY_PROPS", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to There is no downgrade path to the desired resource version.
         /// </summary>
         internal static string ERR_NO_DOWNGRADE_PATH {
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx	2012-05-28 14:37:48 UTC (rev 6700)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx	2012-05-28 15:49:02 UTC (rev 6701)
@@ -119,19 +119,15 @@
   </resheader>
   <data name="ADF_MapInvalidError" xml:space="preserve">
     <value>Map with ID {0} does not point to a valid map</value>
-    <comment>An error message that is displayed if there is a MapID that does not reference a valid map</comment>
   </data>
   <data name="ADF_MapMissingError" xml:space="preserve">
     <value>Fusion application does not specify a map</value>
-    <comment>An error message that is displayed if the map is missing</comment>
   </data>
   <data name="ADF_MapValidationError" xml:space="preserve">
     <value>Error validating MapDefinition {0}, message: {1}</value>
-    <comment>An error message that is displayed if an error occurs while validating a map</comment>
   </data>
   <data name="ADF_ViewOutsideMapExtents" xml:space="preserve">
     <value>Fusion application specifies a start view that is outside the map's initial extents</value>
-    <comment>An error message that is displayed if the start view is outside the defined map</comment>
   </data>
   <data name="CannotCreateLoadProcedureSubType" xml:space="preserve">
     <value>Could not create load procedure of type: </value>
@@ -168,7 +164,6 @@
   </data>
   <data name="ERR_NO_REGISTERED_VALIDATOR" xml:space="preserve">
     <value>There is no registered validator for {0} v{1}. Validation cannot be performed</value>
-    <comment>A warning message that is displayed if there is no registered validator for the specified resource and version</comment>
   </data>
   <data name="ERR_NO_SERIALIZER" xml:space="preserve">
     <value>Could not find matching serializer for this resource: </value>
@@ -187,90 +182,69 @@
   </data>
   <data name="FS_ConnectionTestFailed" xml:space="preserve">
     <value>Connection test failed: {0}</value>
-    <comment>An error message that is displayed if a connection test on the feature source failed</comment>
   </data>
   <data name="FS_DefaultSpatialContextWarning" xml:space="preserve">
     <value>Spatial context extent appears to be invalid (or is the default extent returned by FDO provider. Meaning it very likely does not truly represent the extent of your data)</value>
-    <comment>A warning message that is displayed if the spatial context has the default extent</comment>
   </data>
   <data name="FS_EmptySpatialContextWarning" xml:space="preserve">
     <value>Empty spatial context extent detected</value>
-    <comment>A warning message that is displayed when the spatial context is empty</comment>
   </data>
   <data name="FS_NoPrimaryKeyOrView" xml:space="preserve">
     <value>Could not obtain identity properties for {0}. This class either has no identity properties and/or is derived from a view with no uniquely identifiable columns. Attempting to create feature joins from this class may produce unexpected results.</value>
-    <comment>A warning message that is displayed when we can't obtain identity properties from a class because it is a view</comment>
   </data>
   <data name="FS_NoSpatialContextWarning" xml:space="preserve">
     <value>No spatial contexts found. If this feature source is strictly used for Feature Joins, this warning can be safely ignored</value>
-    <comment>A warning message that is displayed when the featuresource fails to report its spatial context</comment>
   </data>
   <data name="FS_PrimaryKeyMissingInformation" xml:space="preserve">
     <value>No primary key defined for class: {0}, features will not be selectable and feature joins on this class may produce unexpected results</value>
-    <comment>An information message that is displayed if the schema has no primary key defined</comment>
   </data>
   <data name="FS_PrimaryKeyReadError" xml:space="preserve">
     <value>Failed to read identity properties: {0}</value>
-    <comment>An error message that is displayed if the primary key information could not be read</comment>
   </data>
   <data name="FS_SchemaReadError" xml:space="preserve">
     <value>Failed to read schema description: {0}</value>
-    <comment>An error message that is displayed if the schema information could not be read</comment>
   </data>
   <data name="FS_SchemasMissingWarning" xml:space="preserve">
     <value>No schemas found in datasource</value>
-    <comment>A warning message that is displayed if the featuresource has no schemas</comment>
   </data>
   <data name="FS_SpatialContextReadError" xml:space="preserve">
     <value>Failed to read spatial context: {0}</value>
-    <comment>An error message that is displayed if the spatial context could not be read</comment>
   </data>
   <data name="LDF_DrawingSourceError" xml:space="preserve">
     <value>Failed to load specified Drawing Source</value>
   </data>
   <data name="LDF_FeatureSourceLoadError" xml:space="preserve">
     <value>Failed to load specified Feature Source</value>
-    <comment>An error message that is displayed if the featuresource fails to load</comment>
   </data>
   <data name="LDF_GeometryMissingError" xml:space="preserve">
     <value>Failed to find geometry column {0} in schema {1} on featuresource {2}</value>
-    <comment>An error message that is displayed if the geometry is not present in the selected schema</comment>
   </data>
   <data name="LDF_LayerNullError" xml:space="preserve">
     <value>Layer is missing core information</value>
-    <comment>An error message that is displayed if the layer has a null reference</comment>
   </data>
   <data name="LDF_MinAndMaxScaleSwappedError" xml:space="preserve">
     <value>The minimum scale ({0}) is larger than the maximum scale ({1})</value>
-    <comment>An error message that is displayed if the scale ranges are reversed</comment>
   </data>
   <data name="LDF_MissingFeatureSourceError" xml:space="preserve">
     <value>No FeatureSource is assigned to the layer</value>
-    <comment>An error message that is displayed if the layer has no FeatureSource</comment>
   </data>
   <data name="LDF_MissingGeometryError" xml:space="preserve">
     <value>No Geometry is assigned to the layer</value>
-    <comment>An error message that is displayed if the layer has no geometry column selected</comment>
   </data>
   <data name="LDF_MissingScaleRangesError" xml:space="preserve">
     <value>No scale ranges are defined, no data can be displayed</value>
-    <comment>An error message that is displayed if there are no scale ranges defined</comment>
   </data>
   <data name="LDF_MultipleScaleRangesWarning" xml:space="preserve">
     <value>More than one scale ranges is defined, this is valid, but unsupported by Maestro</value>
-    <comment>A warning message that is displayed if a raster layer has multiple scale ranges defined</comment>
   </data>
   <data name="LDF_ScaleRangesOverlapInformation" xml:space="preserve">
     <value>The scale range {0}-{1} overlaps the range {2}-{3}</value>
-    <comment>A warning message that is displayed if two scaleranges overlap</comment>
   </data>
   <data name="LDF_SchemaAndColumnReadFailedError" xml:space="preserve">
     <value>Failed to validate column and schema</value>
-    <comment>An error message that is displayed if the schema and column read fails</comment>
   </data>
   <data name="LDF_SchemaMissingError" xml:space="preserve">
     <value>Failed to find schema {0} in featuresource {1}</value>
-    <comment>An error message that is displayed if the selected schema is not present in the FeatureSource</comment>
   </data>
   <data name="LDF_SheetLayerNotFound" xml:space="preserve">
     <value>Referenced sheet layer {0} not found in sheet {1} of referenced Drawing Source</value>
@@ -280,98 +254,75 @@
   </data>
   <data name="LDF_UnsupportedLayerTypeWarning" xml:space="preserve">
     <value>The layer has no type, or the type is unsupported by Maestro</value>
-    <comment>A  warning message that is displayed if the layer type is unknown</comment>
   </data>
   <data name="LoadProcFactoryMethodAlreadyRegistered" xml:space="preserve">
     <value>Factory method already registered for load procedure type: </value>
   </data>
   <data name="LPROC_ConvertToSdf3NotSupported" xml:space="preserve">
     <value>Convert to SDF option is not supported by Maestro</value>
-    <comment>A warning message about the lack of SDF conversion support</comment>
   </data>
   <data name="LPROC_DWFNotSupported" xml:space="preserve">
     <value>DWF Load Procedures cannot be executed by Maestro</value>
-    <comment>A warning message indicating the lack of DWF support in Maestro</comment>
   </data>
   <data name="LPROC_DWGNotSupported" xml:space="preserve">
     <value>DWG Load Procedures cannot be executed by Maestro</value>
-    <comment>A warning message indicating the lack of DWG support in Maestro</comment>
   </data>
   <data name="LPROC_GeneralizationNotSupported" xml:space="preserve">
     <value>Generalization of source data is not supported by Maestro</value>
-    <comment>A warning message about the lack of Generalization support</comment>
   </data>
   <data name="LPROC_RasterNotSupported" xml:space="preserve">
     <value>Raster Load Procedures cannot be executed by Maestro</value>
-    <comment>A warning message about the lack of Raster support</comment>
   </data>
   <data name="LPROC_Sdf2OptionsNotSupported" xml:space="preserve">
     <value>SDF 2 Migration options are not supported by Maestro. Ensure your source files are SDF3 files.</value>
-    <comment>A warning message about the lack of SDF2 support</comment>
   </data>
   <data name="LPROC_SourceFileNotFound" xml:space="preserve">
     <value>Source file not found: {0}</value>
-    <comment>An error message indicating that a source file in the load procedure does not exist</comment>
   </data>
   <data name="MDF_DataOutsideMapWarning" xml:space="preserve">
     <value>Data from {0} is not visible in the map's start extent</value>
-    <comment>A warning message that is displayed if a layer reports an extent that is outside the map's extent</comment>
   </data>
   <data name="MDF_DataReprojectionWarning" xml:space="preserve">
     <value>{0} has a different coordinate system than the map, this will impact performance as the coordinates are transformed while rendering the map. Maestro cannot validate the extent of the data.</value>
-    <comment>A warning message that is displayed if a layer reports a coordinate system that differs from the map's.</comment>
   </data>
   <data name="MDF_FeatureSourceReadError" xml:space="preserve">
     <value>Layer {0}'s FeatureSource could not be read: {1}</value>
-    <comment>An error message that is displayed if a FeatureSource fails to load</comment>
   </data>
   <data name="MDF_GroupHasDefaultLabelInformation" xml:space="preserve">
     <value>Group {0} has the default legend label</value>
-    <comment>An information message that is displayed if a group is assigned the default group label</comment>
   </data>
   <data name="MDF_GroupMissingLabelInformation" xml:space="preserve">
     <value>Group {0} does not have a legend label</value>
-    <comment>An information message that is displayed if a group has a blank legend label</comment>
   </data>
   <data name="MDF_LayerMissingLabelInformation" xml:space="preserve">
     <value>Layer {0} does not have a legend label</value>
-    <comment>An information message that is displayed if a layer has a blank legend label</comment>
   </data>
   <data name="MDF_LayerNameDuplicateWarning" xml:space="preserve">
     <value>The layer name {0} is used for both "{1}" and "{2}"</value>
-    <comment>A warning message that is displayed if two layers share the same layer name</comment>
   </data>
   <data name="MDF_LayerReadError" xml:space="preserve">
     <value>Layer {0} could not be read: {1}</value>
-    <comment>An error message that is displayed if a LayerDefinition fails to load</comment>
   </data>
   <data name="MDF_MissingLayerGeometryColumnError" xml:space="preserve">
     <value>Layer {0} has no geometry column</value>
-    <comment>An error message that is displayed if a layer has no geometry column specified</comment>
   </data>
   <data name="MDF_MissingLayerSchemaError" xml:space="preserve">
     <value>Layer {0} has an invalid Schema</value>
-    <comment>An error message that is displayed if the layer has no schema specified</comment>
   </data>
   <data name="MDF_MissingSpatialContextWarning" xml:space="preserve">
     <value>{0} has no spatial context (eg. no coordinate system)</value>
-    <comment>A warning message that is displayed if the FeatureSource reports no spatial context</comment>
   </data>
   <data name="MDF_MultipleSpatialContextsInformation" xml:space="preserve">
     <value>{0} has more than one spatial context, the following test results may be inacurate</value>
-    <comment>An information message that is displayed if a FeatureSource reports multiple spatial contexts</comment>
   </data>
   <data name="MDF_RasterReprojectionError" xml:space="preserve">
     <value>{0} is a raster layer, and in another coordinate system than the map. No data will be displayed by the layer</value>
-    <comment>An error message that is displayed if a raster layer reports a different projection than the map, and the MapGuide server version does not support raster reprojection</comment>
   </data>
   <data name="MDF_ResourceReadError" xml:space="preserve">
     <value>{0} could not be processed for spatial info: {1}</value>
-    <comment>An error message that is displayed if a resource fails to load</comment>
   </data>
   <data name="MDF_UnsupportedLayerTypeWarning" xml:space="preserve">
     <value>Layer {0} is a type that is unsupported by Maestro</value>
-    <comment>A warning message that is displayed if a layer has a type that is not supported by Maestro</comment>
   </data>
   <data name="MovedResource" xml:space="preserve">
     <value>Moved resource: {0}</value>
@@ -414,11 +365,9 @@
   </data>
   <data name="WL_MapValidationError" xml:space="preserve">
-    <comment>An error message that is displayed if the map validation fails</comment>
   </data>
   <data name="WL_MissingMapError" xml:space="preserve">
     <value>Layout does not specify a map</value>
-    <comment>An error message that is displayed if no map is specified in the layout</comment>
   </data>
   <data name="WL_NonExistentMenuCommandReference" xml:space="preserve">
     <value>Context Menu contains a reference to a command that doesn't exist: {0}</value>
@@ -431,7 +380,6 @@
   </data>
   <data name="WL_StartViewOutsideExtentsWarning" xml:space="preserve">
     <value>Layout specifies a start view that is outside the map's initial extents</value>
-    <comment>A warning message that is displayed if the layout specifies a start center point that is outside the map's specified extents</comment>
   </data>
   <data name="ADF_Flyout_SelectMore" xml:space="preserve">
     <value>Select More</value>
@@ -478,9 +426,1125 @@
   <data name="ADF_Widget_ZoomOut_Label" xml:space="preserve">
     <value>Zoom Out</value>
   </data>
-  <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
-  <data name="BaseTemplate_ApplicationDefinition" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\BaseTemplate.ApplicationDefinition.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;iso-8859-1</value>
+  <data name="BaseTemplate_ApplicationDefinition" xml:space="preserve">
+    <value><?xml version="1.0"?>
+<ApplicationDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="ApplicationDefinition-1.0.0.xsd">
+  <TemplateUrl>fusion/templates/mapguide/slate/index.html</TemplateUrl>
+  <MapSet>
+    <MapGroup id="MgMainMapId">
+      <Map>
+        <Type>MapGuide</Type>
+        <SingleTile>true</SingleTile>
+        <Extension>
+          <ResourceId />
+          <SelectionAsOverlay>true</SelectionAsOverlay>
+          <SelectionColor>0x0000FFA0</SelectionColor>
+        </Extension>
+      </Map>
+      <Extension />
+    </MapGroup>
+  </MapSet>
+  <WidgetSet>
+    <Container xsi:type="UiItemContainerType">
+      <Name>Toolbar</Name>
+      <Type>Toolbar</Type>
+      <Position>top</Position>
+      <Extension />
+      <Item xsi:type="WidgetItemType">
+        <Function>Widget</Function>
+        <Widget>RefreshMap</Widget>
+      </Item>
+      <Item xsi:type="SeparatorItemType">
+        <Function>Separator</Function>
+      </Item>
+        <Widget>SelectRadius</Widget>
+      </Item>
+        <Widget>SelectPolygon</Widget>
+      </Item>
+        <Widget>ClearSelection</Widget>
+      </Item>
+      </Item>
+        <Widget>BufferPanel</Widget>
+      </Item>
+        <Widget>Measure</Widget>
+      </Item>
+        <Widget>FeatureInfo</Widget>
+      </Item>
+        <Widget>Query</Widget>
+      </Item>
+        <Widget>Theme</Widget>
+      </Item>
+        <Widget>Redline</Widget>
+      </Item>
+      </Item>
+        <Widget>Print</Widget>
+      </Item>
+        <Widget>ViewOptions</Widget>
+      </Item>
+        <Widget>About</Widget>
+      </Item>
+        <Widget>Help</Widget>
+      </Item>
+    </Container>
+      <Name>ToolbarSecondary</Name>
+      <Extension />
+        <Widget>Select</Widget>
+      </Item>
+        <Widget>Pan</Widget>
+      </Item>
+      </Item>
+        <Widget>Zoom</Widget>
+      </Item>
+        <Widget>ZoomIn</Widget>
+      </Item>
+        <Widget>ZoomOut</Widget>
+      </Item>
+        <Widget>InitialMapView</Widget>
+      </Item>
+        <Widget>ZoomToSelection</Widget>
+      </Item>
+      </Item>
+        <Widget>PreviousView</Widget>
+      </Item>
+        <Widget>NextView</Widget>
+      </Item>
+    </Container>
+      <Name>ToolbarVertical</Name>
+      <Position>left</Position>
+      <Extension />
+        <Widget>SelectNoLabel</Widget>
+      </Item>
+        <Widget>PanNoLabel</Widget>
+      </Item>
+      </Item>
+        <Widget>ZoomNoLabel</Widget>
+      </Item>
+        <Widget>ZoomInNoLabel</Widget>
+      </Item>
+        <Widget>ZoomOutNoLabel</Widget>
+      </Item>
+        <Widget>InitialMapViewNoLabel</Widget>
+      </Item>
+        <Widget>ZoomToSelectionNoLabel</Widget>
+      </Item>
+      </Item>
+        <Widget>PreviousViewNoLabel</Widget>
+      </Item>
+        <Widget>NextViewNoLabel</Widget>
+      </Item>
+    </Container>
+      <Name>Statusbar</Name>
+      <Type>Splitterbar</Type>
+      <Position>bottom</Position>
+      <Extension />
+        <Widget>StatusCoords</Widget>
+      </Item>
+        <Widget>StatusSelection</Widget>
+      </Item>
+        <Widget>StatusScale</Widget>
+      </Item>
+        <Widget>StatusViewSize</Widget>
+      </Item>
+    </Container>
+      <Name>FileMenu</Name>
+      <Extension />
+        <Widget>MapMenu</Widget>
+      </Item>
+        <Widget>BasemapSwitcher</Widget>
+      </Item>
+      <Item xsi:type="FlyoutItemType">
+        <Function>Flyout</Function>
+        <Label>View</Label>
+          <Widget>ShowOverviewMap</Widget>
+        </Item>
+          <Widget>ShowTaskWindow</Widget>
+        </Item>
+          <Widget>ShowLegendWindow</Widget>
+        </Item>
+          <Widget>ShowSelectionWindow</Widget>
+        </Item>
+      </Item>
+    </Container>
+      <Name>MapRightClickMenu</Name>
+      <Type>ContextMenu</Type>
+      <Extension />
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+        <Label>Zoom</Label>
+        </Item>
+        </Item>
+        </Item>
+        </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+        <Label>Select More</Label>
+        </Item>
+        </Item>
+          <Widget>SelectWithin</Widget>
+        </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+    </Container>
+      <Name>TaskMenu</Name>
+      <Extension />
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+    </Container>
+    <MapWidget>
+      <Name>Map</Name>
+      <Type>Map</Type>
+      <Extension>
+        <MenuContainer>MapRightClickMenu</MenuContainer>
+      </Extension>
+      <MapId>MgMainMapId</MapId>
+    </MapWidget>
+    <Widget xsi:type="UiWidgetType">
+      <Name>About</Name>
+      <Type>About</Type>
+      <Location />
+      <Extension>
+        <AboutURL>widgets/About/About.html</AboutURL>
+      </Extension>
+      <ImageUrl>images/icons.png</ImageUrl>
+      <ImageClass>about</ImageClass>
+      <Label>About</Label>
+      <Tooltip>Click to show information about this application</Tooltip>
+      <StatusText />
+      <Disabled>false</Disabled>
+    </Widget>
+    <Widget>
+      <Name>ActivityIndicator</Name>
+      <Type>ActivityIndicator</Type>
+      <Location />
+      <Extension>
+        <ElementId />
+      </Extension>
+    </Widget>
+      <Name>BasemapSwitcher</Name>
+      <Type>BasemapSwitcher</Type>
+      <Location />
+      <Extension />
+      <ImageClass>options</ImageClass>
+      <Label>External Providers</Label>
+      <Tooltip>Click to change the basemap</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>BufferPanel</Name>
+      <Type>BufferPanel</Type>
+      <Extension>
+        <Target>TaskPane</Target>
+      </Extension>
+      <ImageClass>buffer</ImageClass>
+      <Label>Buffer</Label>
+      <Tooltip>Click to create a buffer</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>ClearSelection</Name>
+      <Type>ClearSelection</Type>
+      <Extension />
+      <ImageClass>select-clear</ImageClass>
+      <Label>Clear Selection</Label>
+      <Tooltip>Click to clear the current selection</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>PreviousView</Name>
+      <Type>ExtentHistory</Type>
+      <Extension>
+        <Direction>Previous</Direction>
+      </Extension>
+      <ImageClass>view-back</ImageClass>
+      <Label>Previous</Label>
+      <Tooltip>Zoom to previous extents</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>NextView</Name>
+      <Extension>
+        <Direction>Next</Direction>
+      </Extension>
+      <ImageClass>view-forward</ImageClass>
+      <Label>Next</Label>
+      <Tooltip>Zoom to next extents</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>Help</Name>
+      <Type>Help</Type>
+      <Location />
+      <Extension>
+        <Target>HelpWindow</Target>
+        <Url>widgets/Help/Help.html</Url>
+      </Extension>
+      <ImageClass>help</ImageClass>
+      <Label>Help</Label>
+      <Tooltip>Click to get help</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>InitialMapView</Name>
+      <Type>InitialMapView</Type>
+      <Location />
+      <Extension>
+        <ViewType>initial</ViewType>
+      </Extension>
+      <ImageClass>zoom-full</ImageClass>
+      <Label>Zoom Extents</Label>
+      <Tooltip>Click to zoom to the full map extents</Tooltip>
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Name>Legend</Name>
+      <Type>Legend</Type>
+      <Location />
+      <Extension>
+        <HideInvisibleLayers>true</HideInvisibleLayers>
+        <ShowRootFolder>false</ShowRootFolder>
+        <DisabledLayerIcon>images/icons/legend-layer.png</DisabledLayerIcon>
+        <RootFolderIcon>images/icons/legend-map.png</RootFolderIcon>
+        <ShowMapFolder>false</ShowMapFolder>
+        <LayerThemeIcon>images/icons/legend-theme.png</LayerThemeIcon>
+        <LayerRasterIcon>images/icons/legend-raster.png</LayerRasterIcon>
+        <LayerInfoIcon>images/icons/tree_layer_info.png</LayerInfoIcon>
+        <LayerDWFIcon>images/icons/legend-DWF.png</LayerDWFIcon>
+        <GroupInfoIcon>images/icons/tree_group_info.png</GroupInfoIcon>
+      </Extension>
+    </Widget>
+      <Name>MapMenu</Name>
+      <Type>MapMenu</Type>
+      <Location />
+      <Extension>
+        <Folder />
+      </Extension>
+      <ImageUrl />
+      <ImageClass />
+      <Label>Maps</Label>
+      <Tooltip>Choose a map theme</Tooltip>
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Name>Maptip</Name>
+      <Type>Maptip</Type>
+      <Location />
+      <Extension>
+        <Tolerance>2</Tolerance>
+        <Target>MaptipWindow</Target>
+        <WinFeatures>menubar=no,location=no,resizable=no,status=no</WinFeatures>
+        <Delay>350</Delay>
+        <Layer />
+      </Extension>
+    </Widget>
+      <Name>Measure</Name>
+      <Type>Measure</Type>
+      <Location />
+      <Extension>
+        <DistancePrecision>4</DistancePrecision>
+        <MeasureTooltipContainer>MeasureContainerBox</MeasureTooltipContainer>
+        <MeasureTooltipType>static</MeasureTooltipType>
+        <MeasureTipPositionLeft>15</MeasureTipPositionLeft>
+        <Units>none</Units>
+        <LineStyleWidth>2</LineStyleWidth>
+        <MeasureTipPositionTop>100</MeasureTipPositionTop>
+        <LineStyleColor>rgba(0,0,255,0.3)</LineStyleColor>
+        <FillStyle>rgba(0,0,255, 0.3)</FillStyle>
+        <AreaPrecision>4</AreaPrecision>
+        <Type>Both</Type>
+      </Extension>
+      <ImageClass>measure</ImageClass>
+      <Label>Measure</Label>
+      <Tooltip>Measure distances and areas on the map</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>FeatureInfo</Name>
+      <Type>FeatureInfo</Type>
+      <Location />
+      <Extension>
+      </Extension>
+      <ImageClass>featureinfo</ImageClass>
+      <Label>Feature Info</Label>
+      <Tooltip>Click to display selected feature info</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>Query</Name>
+      <Type>Query</Type>
+      <Location />
+      <Extension>
+      </Extension>
+      <ImageClass>query</ImageClass>
+      <Label>Query</Label>
+      <Tooltip>Click to execute a custom query</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>Theme</Name>
+      <Type>Theme</Type>
+      <Location />
+      <Extension>
+      </Extension>
+      <ImageClass>theme</ImageClass>
+      <Label>Theme</Label>
+      <Tooltip>Click to create a themed layer</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>Redline</Name>
+      <Type>Redline</Type>
+      <Location />
+      <Extension>
+        <FeatureStyle />
+      </Extension>
+      <ImageClass>redline</ImageClass>
+      <Label>Redline</Label>
+      <Tooltip>Click to draw redline features</Tooltip>
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Name>Navigator</Name>
+      <Type>Navigator</Type>
+      <Location />
+      <Extension />
+    </Widget>
+    <Widget>
+      <Name>OverviewMap</Name>
+      <Type>OverviewMap</Type>
+      <Location />
+      <Extension>
+        <MinRatio>32</MinRatio>
+        <MapId />
+        <MaxRatio>128</MaxRatio>
+      </Extension>
+    </Widget>
+      <Name>Pan</Name>
+      <Type>Pan</Type>
+      <Location />
+      <Extension />
+      <ImageClass>pan</ImageClass>
+      <Label>Pan</Label>
+      <Tooltip>Click and drag to pan the map</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>Print</Name>
+      <Type>Print</Type>
+      <Extension>
+        <ShowPrintUI>true</ShowPrintUI>
+        <ShowNorthArrow>false</ShowNorthArrow>
+        <PageTitle />
+        <ImageBaseUrl />
+        <ShowLegend>false</ShowLegend>
+        <ShowTitle>false</ShowTitle>
+      </Extension>
+      <ImageClass>file-print</ImageClass>
+      <Label>Print</Label>
+      <Tooltip>Print the current map view</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>RefreshMap</Name>
+      <Type>RefreshMap</Type>
+      <Location />
+      <Extension />
+      <ImageClass>view-refresh</ImageClass>
+      <Label>Refresh</Label>
+      <Tooltip>Click to redraw the map</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>SaveMap</Name>
+      <Type>SaveMap</Type>
+      <Extension>
+        <Format>png</Format>
+        <Scale />
+        <ResourceId />
+      </Extension>
+      <ImageClass>file-save</ImageClass>
+      <Label>Save map</Label>
+      <Tooltip>Click to save the map as an image</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>Select</Name>
+      <Type>Select</Type>
+      <Location />
+      <Extension>
+        <Tolerance>3</Tolerance>
+        <SelectionType>INTERSECTS</SelectionType>
+        <QueryActiveLayer>false</QueryActiveLayer>
+      </Extension>
+      <ImageClass>select</ImageClass>
+      <Label>Select</Label>
+      <Tooltip>Click to select features</Tooltip>
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Name>SelectionPanel</Name>
+      <Type>SelectionPanel</Type>
+      <Location />
+      <Extension />
+    </Widget>
+      <Name>SelectPolygon</Name>
+      <Type>SelectPolygon</Type>
+      <Location />
+      <Extension>
+      </Extension>
+      <ImageClass>select-polygon</ImageClass>
+      <Label>Select Polygon</Label>
+      <Tooltip>Draw a polygon to perform a selection</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>SelectRadius</Name>
+      <Type>SelectRadius</Type>
+      <Extension>
+        <RadiusTooltipType>dynamic</RadiusTooltipType>
+        <RadiusTooltipContainer />
+        <DefaultRadius>20</DefaultRadius>
+      </Extension>
+      <ImageClass>select-radius</ImageClass>
+      <Label>Select Radius</Label>
+      <Tooltip>Click to select within a radius</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>SelectWithin</Name>
+      <Type>SelectWithin</Type>
+      <Location />
+      <Extension>
+        <DisableIfSelectionEmpty>true</DisableIfSelectionEmpty>
+      </Extension>
+      <ImageClass>select-features</ImageClass>
+      <Label>Select within</Label>
+      <Tooltip>Click to select features within this selection</Tooltip>
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Name>TaskPane</Name>
+      <Type>TaskPane</Type>
+      <Location />
+      <Extension>
+        <MenuContainer>TaskMenu</MenuContainer>
+        <InitialTask />
+      </Extension>
+    </Widget>
+      <Name>ViewOptions</Name>
+      <Type>ViewOptions</Type>
+      <Location />
+      <Extension>
+        <DisplayUnits />
+      </Extension>
+      <Label>Options</Label>
+      <Tooltip>Click to change the units displayed</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>Zoom</Name>
+      <Type>Zoom</Type>
+      <Extension>
+        <Tolerance>5</Tolerance>
+        <Factor>2</Factor>
+        <Direction>in</Direction>
+      </Extension>
+      <ImageClass>zoom-in</ImageClass>
+      <Label>Zoom Rectangle</Label>
+      <Tooltip>Click or click and drag on the map to zoom in</Tooltip>
+      <StatusText>Click or click and drag on the map to zoom in</StatusText>
+    </Widget>
+      <Name>ZoomOut</Name>
+      <Type>ZoomOnClick</Type>
+      <Location />
+      <Extension>
+        <Factor>0.5</Factor>
+      </Extension>
+      <ImageClass>zoom-out-fixed</ImageClass>
+      <Label>Zoom Out</Label>
+      <Tooltip>Zoom out to display a larger area</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>ZoomIn</Name>
+      <Location />
+      <Extension>
+        <Factor>2.0</Factor>
+      </Extension>
+      <ImageClass>zoom-in-fixed</ImageClass>
+      <Label>Zoom In</Label>
+      <Tooltip>Zoom in to display more detail</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>ZoomToSelection</Name>
+      <Type>ZoomToSelection</Type>
+      <Location />
+      <Extension>
+        <MaximumZoomDimension>-1</MaximumZoomDimension>
+        <ZoomFactor>2</ZoomFactor>
+      </Extension>
+      <ImageClass>select-zoom</ImageClass>
+      <Label>Zoom Selection</Label>
+      <Tooltip>Click to zoom to the selection</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>InitialMapViewNoLabel</Name>
+      <Location />
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Name>NextViewNoLabel</Name>
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Name>PanNoLabel</Name>
+      <Type>Pan</Type>
+      <Location />
+      <Extension />
+      <Label />
+      <StatusText />
+    </Widget>
+      <Name>PreviousViewNoLabel</Name>
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Name>SelectNoLabel</Name>
+      <Location />
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Name>ZoomNoLabel</Name>
+      <Type>Zoom</Type>
+      <Extension>
+      </Extension>
+      <Label />
+    </Widget>
+      <Name>ZoomInNoLabel</Name>
+      <Location />
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Name>ZoomOutNoLabel</Name>
+      <Location />
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Name>ZoomToSelectionNoLabel</Name>
+      <Location />
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Name>ShowOverviewMap</Name>
+      <Type>InvokeScript</Type>
+      <Location />
+      <Extension>
+        <Script>showOverviewMap()</Script>
+        <Target />
+      </Extension>
+      <ImageUrl />
+      <ImageClass />
+      <Label>Show Overview Map</Label>
+      <Tooltip>Display the overview map window</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>ShowTaskWindow</Name>
+      <Location />
+      <Extension>
+        <Script>showTaskPane()</Script>
+        <Target />
+      </Extension>
+      <ImageUrl />
+      <ImageClass />
+      <Label>Show Task Pane</Label>
+      <Tooltip>Display the task pane window</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>ShowLegendWindow</Name>
+      <Location />
+      <Extension>
+        <Script>showLegend()</Script>
+        <Target />
+      </Extension>
+      <ImageUrl />
+      <ImageClass />
+      <Label>Show Legend</Label>
+      <Tooltip>Display the legend window</Tooltip>
+      <StatusText />
+    </Widget>
+      <Name>ShowSelectionWindow</Name>
+      <Location />
+      <Extension>
+        <Script>showSelectionPanel()</Script>
+        <Target />
+      </Extension>
+      <ImageUrl />
+      <ImageClass />
+      <Label>Show Selection Panel</Label>
+      <Tooltip>Display the selection window</Tooltip>
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Name>StatusCoords</Name>
+      <Type>CursorPosition</Type>
+      <Extension>
+        <Precision>4</Precision>
+        <Template>x: {x}, y: {y}</Template>
+        <Units>dd</Units>
+      </Extension>
+    </Widget>
+    <Widget>
+      <Name>StatusSelection</Name>
+      <Type>SelectionInfo</Type>
+      <Location />
+      <Extension>
+        <EmptyText>No features selected</EmptyText>
+        <Template>{0} feature(s) selected on {1} layer(s)</Template>
+      </Extension>
+    </Widget>
+    <Widget>
+      <Name>StatusScale</Name>
+      <Type>EditableScale</Type>
+      <Extension>
+      </Extension>
+    </Widget>
+    <Widget>
+      <Name>StatusViewSize</Name>
+      <Type>ViewSize</Type>
+      <Location />
+      <Extension>
+        <Precision>2</Precision>
+        <Template>{w} x {h} {units}</Template>
+        <Units>Meters</Units>
+      </Extension>
+    </Widget>
+      <Name>StatusOverviewMap</Name>
+      <Location />
+      <Extension>
+        <Target />
+      </Extension>
+      <ImageClass>iconNavigator</ImageClass>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Name>StatusNavigator</Name>
+      <Location />
+      <Extension>
+        <Target />
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+  </WidgetSet>
+  <Extension />
+</ApplicationDefinition></value>
   </data>
   <data name="UnknownSymbolDefVersion" xml:space="preserve">
     <value>Unknown Symbol Definition version: </value>
@@ -545,8 +1609,1135 @@
   <data name="Infinity" xml:space="preserve">
     <value>Infinity</value>
   </data>
-  <data name="BaseTemplate240_ApplicationDefinition" type="System.Resources.ResXFileRef, System.Windows.Forms">
-    <value>..\Resources\BaseTemplate.ApplicationDefinition1.xml;System.String, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089;Windows-1252</value>
+  <data name="BaseTemplate240_ApplicationDefinition" xml:space="preserve">
+  <MapSet>
+      <Map>
+        <Extension>
+          <ResourceId />
+        </Extension>
+      </Map>
+      <Extension />
+    </MapGroup>
+  </MapSet>
+  <WidgetSet>
+      <Extension />
+      </Item>
+            <Widget>Maptip</Widget>
+        </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+    </Container>
+      <Extension />
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+    </Container>
+      <Extension />
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+    </Container>
+      <Extension />
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+    </Container>
+      <Extension />
+      </Item>
+      </Item>
+        </Item>
+        </Item>
+        </Item>
+        </Item>
+      </Item>
+    </Container>
+      <Extension />
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+        </Item>
+        </Item>
+        </Item>
+        </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+        </Item>
+        </Item>
+        </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+    </Container>
+      <Extension />
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+      </Item>
+    </Container>
+    <MapWidget>
+      <Name>Map</Name>
+      <Type>Map</Type>
+      <Extension>
+      </Extension>
+    </MapWidget>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Location />
+      <Extension>
+        <ElementId />
+      </Extension>
+    </Widget>
+      <Location />
+      <Extension />
+      <StatusText />
+    </Widget>
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Extension />
+      <StatusText />
+    </Widget>
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Name>Help</Name>
+      <Type>Help</Type>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Location />
+      <Extension>
+      </Extension>
+    </Widget>
+      <Location />
+      <Extension>
+        <Folder />
+      </Extension>
+      <ImageUrl />
+      <ImageClass />
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+        <Layer />
+      </Extension>
+      <ImageUrl />
+      <ImageClass />
+      <Label>Maptip</Label>
+      <Tooltip>Click to Enable/Disable get information about features from Server</Tooltip>
+      <StatusText>Click to Enable/Disable get information about features from Server</StatusText>
+    </Widget>
+      <Location />
+      <Extension>
+        <Type>Both</Type>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+        <FeatureStyle />
+      </Extension>
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Location />
+      <Extension />
+    </Widget>
+    <Widget>
+      <Location />
+      <Extension>
+        <MapId />
+      </Extension>
+    </Widget>
+      <Name>Pan</Name>
+      <Type>Pan</Type>
+      <Location />
+      <Extension />
+      <StatusText />
+    </Widget>
+      <Extension>
+        <PageTitle />
+        <ImageBaseUrl />
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension />
+      <StatusText />
+    </Widget>
+      <Extension>
+        <Scale />
+        <ResourceId />
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Location />
+      <Extension />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Location />
+      <Extension>
+        <InitialTask />
+      </Extension>
+    </Widget>
+      <Location />
+      <Extension>
+        <DisplayUnits />
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Name>Zoom</Name>
+      <Type>Zoom</Type>
+      <Extension>
+      </Extension>
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Type>Pan</Type>
+      <Location />
+      <Extension />
+      <Label />
+      <StatusText />
+    </Widget>
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Type>Zoom</Type>
+      <Extension>
+      </Extension>
+      <Label />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+        <Target />
+      </Extension>
+      <ImageUrl />
+      <ImageClass />
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+        <Target />
+      </Extension>
+      <ImageUrl />
+      <ImageClass />
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+        <Target />
+      </Extension>
+      <ImageUrl />
+      <ImageClass />
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+        <Target />
+      </Extension>
+      <ImageUrl />
+      <ImageClass />
+      <StatusText />
+    </Widget>
+    <Widget>
+      <Extension>
+        <Units>dd</Units>
+      </Extension>
+    </Widget>
+    <Widget>
+      <Location />
+      <Extension>
+      </Extension>
+    </Widget>
+    <Widget>
+      <Extension>
+      </Extension>
+    </Widget>
+    <Widget>
+      <Location />
+      <Extension>
+      </Extension>
+    </Widget>
+      <Location />
+      <Extension>
+        <Target />
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+      <Location />
+      <Extension>
+        <Target />
+      </Extension>
+      <Label />
+      <StatusText />
+    </Widget>
+  </WidgetSet>
+  <Extension />
   </data>
   <data name="LDF_SymbolDefintionReferenceNotFound" xml:space="preserve">
     <value>The Layer Definition contains a Composite Rule pointing to a non-existent Symbol Definition: {0}</value>
@@ -565,9 +2756,14 @@
   </data>
   <data name="TS_ThreadFailureError" xml:space="preserve">
     <value>All threads crashed, and the tile set was only partially created</value>
-    <comment>An error message that displays if the render threads crash</comment>
   </data>
   <data name="FS_ValidationTimeout" xml:space="preserve">
     <value>Maestro could not fully validate the feature source due to a a mapagent error. Assuming it is because of timeout: {0}</value>
   </data>
+  <data name="ERR_CLASS_NOT_FOUND" xml:space="preserve">
+    <value>Class not found: {0}</value>
+  </data>
+  <data name="ERR_INIT_IDENTITY_PROPS" xml:space="preserve">
+    <value>Could fetch and initialize identity properties for {1} This is likely a bug in MapGuide {0}{2}</value>
+  </data>
 </root>
\ No newline at end of file
More information about the mapguide-commits mailing list
