[mapguide-commits] r6708 - in branches/2.4/MgDev/Desktop: MapViewer MapViewer/AppLayoutEngine MapViewer/Properties MapViewerTest MgAppLayout
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed May 30 05:54:01 PDT 2012
Author: jng
Date: 2012-05-30 05:54:00 -0700 (Wed, 30 May 2012)
New Revision: 6708
   branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/AppLayout.cs
   branches/2.4/MgDev/Desktop/MapViewer/BaseInteractionComponents.cs
   branches/2.4/MgDev/Desktop/MapViewer/IMapViewer.cs
   branches/2.4/MgDev/Desktop/MapViewer/MgComponent.cs
   branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
   branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.Designer.cs
   branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.resx
   branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.Designer.cs
   branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx
   branches/2.4/MgDev/Desktop/MgAppLayout/Sheboygan.AppLayout
mg-desktop: Add 2 new components. Zoom Next and Zoom Previous. New APIs have been added to IMapViewer to allow navigation and inspection of the view history stack.
Modified: branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/AppLayout.cs
--- branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/AppLayout.cs	2012-05-29 13:59:28 UTC (rev 6707)
+++ branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/AppLayout.cs	2012-05-30 12:54:00 UTC (rev 6708)
@@ -107,6 +107,9 @@
                     new CommandItem("ZoomOut", false),
                     new CommandItem("InitialView", false),
                     new SeparatorItem(),
+                    new CommandItem("ZoomPrev", false),
+                    new CommandItem("ZoomNext", false),
+                    new SeparatorItem(),
                     new CommandItem("Select", false),
                     new CommandItem("SelectRadius", false),
                     new CommandItem("SelectPolygon", false),
@@ -242,7 +245,9 @@
                 new ComponentDefinition(typeof(Viewer.MgTooltipToggleComponent).FullName, "TooltipToggle"),
                 new ComponentDefinition(typeof(Viewer.MgViewerOptionsComponent).FullName, "ViewerOptions"),
                 new ComponentDefinition(typeof(Viewer.MgZoomInComponent).FullName, "ZoomIn"),
+                new ComponentDefinition(typeof(Viewer.MgZoomNextComponent).FullName, "ZoomNext"),
                 new ComponentDefinition(typeof(Viewer.MgZoomOutComponent).FullName, "ZoomOut"),
+                new ComponentDefinition(typeof(Viewer.MgZoomPreviousComponent).FullName, "ZoomPrev"),
                 new ComponentDefinition(typeof(Viewer.MgZoomToSelectionComponent).FullName, "ZoomToSelection")
             return layout;
Modified: branches/2.4/MgDev/Desktop/MapViewer/BaseInteractionComponents.cs
--- branches/2.4/MgDev/Desktop/MapViewer/BaseInteractionComponents.cs	2012-05-29 13:59:28 UTC (rev 6707)
+++ branches/2.4/MgDev/Desktop/MapViewer/BaseInteractionComponents.cs	2012-05-30 12:54:00 UTC (rev 6708)
@@ -84,6 +84,80 @@
     [ToolboxItem(true)]
+    public class MgZoomNextComponent : MgComponent
+        public MgZoomNextComponent()
+            this.Label = this.ToolTipText = Properties.Resources.TextZoomNext;
+            this.Icon = Properties.Resources.view_forward;
+        private void Evaluate()
+            var history = this.Viewer.ViewHistory;
+            var enabled = (history.Count > 1 && this.Viewer.ViewHistoryIndex < history.Count - 1);
+            foreach (var l in _listeners)
+                l.SetEnabled(enabled);
+        protected override void OnMapRefreshed(object sender, EventArgs e)
+            Evaluate();
+        protected override void OnViewerPropertyChanged(object sender, PropertyChangedEventArgs e)
+            if (e.PropertyName == "ViewHistoryIndex" || e.PropertyName == "ViewHistory")
+                Evaluate();
+            base.OnViewerPropertyChanged(sender, e);
+        public override void Invoke()
+            this.Viewer.NextView();
+    [ToolboxItem(true)]
+    public class MgZoomPreviousComponent : MgComponent
+        public MgZoomPreviousComponent()
+            this.Label = this.ToolTipText = Properties.Resources.TextZoomPrevious;
+            this.Icon = Properties.Resources.view_back;
+            var enabled = history.Count > 1;
+            Evaluate();
+                Evaluate();
+            this.Viewer.PreviousView();
     public class MgZoomToSelectionComponent : MgComponent
         private MgAgfReaderWriter _agfRw;
Modified: branches/2.4/MgDev/Desktop/MapViewer/IMapViewer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/IMapViewer.cs	2012-05-29 13:59:28 UTC (rev 6707)
+++ branches/2.4/MgDev/Desktop/MapViewer/IMapViewer.cs	2012-05-30 12:54:00 UTC (rev 6708)
@@ -4,6 +4,7 @@
 using OSGeo.MapGuide;
 using System.Drawing;
 using System.ComponentModel;
+using System.Collections.ObjectModel;
 namespace OSGeo.MapGuide.Viewer
@@ -294,8 +295,44 @@
         /// Gets or sets the amount of pixels to buffer out by when doing point-based selections with the Select tool
         /// </summary>
         int PointPixelBuffer { get; set; }
+        /// <summary>
+        /// Navigates to the previous view in the history stack
+        /// </summary>
+        void PreviousView();
+        /// <summary>
+        /// Navigates to the next view in the history stack
+        /// </summary>
+        void NextView();
+        /// <summary>
+        /// Gets whether the index in the view history stack
+        /// </summary>
+        int ViewHistoryIndex { get; }
+        /// <summary>
+        /// Gets the view history stack. The first item being the earliest and the last item being the most recent.
+        /// </summary>
+        ReadOnlyCollection<MgMapViewHistoryEntry> ViewHistory { get; }
+    public class MgMapViewHistoryEntry
+        public MgMapViewHistoryEntry(double x, double y, double scale)
+            this.X = x;
+            this.Y = y;
+            this.Scale = scale;
+        public double X { get; private set; }
+        public double Y { get; private set; }
+        public double Scale { get; private set; }
     /// <summary>
     /// Contains data of a MouseMapPositionChanged event
     /// </summary>
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgComponent.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgComponent.cs	2012-05-29 13:59:28 UTC (rev 6707)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgComponent.cs	2012-05-30 12:54:00 UTC (rev 6708)
@@ -102,6 +102,7 @@
                 viewer.PropertyChanged += OnViewerPropertyChanged;
                 viewer.MapLoaded += OnViewerMapLoaded;
+                viewer.MapRefreshed += OnMapRefreshed;
                 if (this.RequiresLoadedMap)
@@ -130,6 +131,8 @@
                 l.SetEnabled(this.Viewer.HasLoadedMap);
+        protected virtual void OnMapRefreshed(object sender, EventArgs e) { }
         protected virtual void OnViewerPropertyChanged(object sender, PropertyChangedEventArgs e)
             if (e.PropertyName == "IsBusy")
Modified: branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs	2012-05-29 13:59:28 UTC (rev 6707)
+++ branches/2.4/MgDev/Desktop/MapViewer/MgMapViewer.cs	2012-05-30 12:54:00 UTC (rev 6708)
@@ -11,6 +11,7 @@
 using System.Threading;
 using System.Xml;
 using System.Collections.Specialized;
@@ -155,11 +156,16 @@
         private MgCoordinateSystem _mapCs;
+        private int _viewHistoryIndex;
+        private List<MgMapViewHistoryEntry> _viewHistory;
         /// <summary>
         /// Initializes a new instance of the <see cref="MgMapViewer"/> class.
         /// </summary>
         public MgMapViewer()
+            _viewHistory = new List<MgMapViewHistoryEntry>();
+            _viewHistoryIndex = -1;
             this.ShowVertexCoordinatesWhenDigitizing = false;
             this.FeatureTooltipsEnabled = false;
             this.TooltipsEnabled = false;
@@ -1070,6 +1076,12 @@
 #endif
             this.Focus();
+            //Reset history stack
+            _viewHistory.Clear();
+            OnPropertyChanged("ViewHistory");
+            OnPropertyChanged("ViewHistoryIndex");
             var handler = this.MapLoaded;
             if (handler != null)
                 handler(this, EventArgs.Empty);
@@ -1536,8 +1548,90 @@
             _extY2 = coord.Y - mcsHeight / 2;
+        private bool PruneHistoryEntriesFromCurrentView()
+            if (_viewHistoryIndex < _viewHistory.Count - 1)
+                int removed = 0;
+                for (int i = _viewHistory.Count - 1; i > _viewHistoryIndex; i--)
+                    _viewHistory.RemoveAt(i);
+                    removed++;
+                return removed > 0;
+            return false;
         internal void ZoomToView(double x, double y, double scale, bool refresh, bool raiseEvents)
+            ZoomToView(x, y, scale, refresh, raiseEvents, true);
+        /// <summary>
+        /// </summary>
+        public void PreviousView()
+            var newIndex = _viewHistoryIndex - 1;
+            if (newIndex < 0)
+                return;
+            var view = _viewHistory[newIndex];
+            ZoomToView(view.X, view.Y, view.Scale, true, true, false);
+            _viewHistoryIndex = newIndex;
+        /// <summary>
+        /// </summary>
+        public void NextView()
+            //Cannot advance from current view
+            if (_viewHistoryIndex == _viewHistory.Count - 1)
+                return;
+            var newIndex = _viewHistoryIndex + 1;
+            if (newIndex > _viewHistory.Count - 1)
+                return;
+        /// <summary>
+        /// </summary>
+        public int ViewHistoryIndex
+            get { return _viewHistoryIndex; }
+        /// <summary>
+        /// </summary>
+        public ReadOnlyCollection<MgMapViewHistoryEntry> ViewHistory
+            get { return _viewHistory.AsReadOnly(); }
+        internal void ZoomToView(double x, double y, double scale, bool refresh, bool raiseEvents, bool addToHistoryStack)
+            if (addToHistoryStack)
+                //If not current view, then any entries from the current view index are no longer needed
+                if (ViewHistoryIndex < _viewHistory.Count - 1)
+                    PruneHistoryEntriesFromCurrentView();
+                _viewHistory.Add(new MgMapViewHistoryEntry(x, y, scale));
+                _viewHistoryIndex = _viewHistory.Count - 1;
             _provider.SetViewCenterXY(x, y);
 #if VIEWER_DEBUG
             UpdateCenterDebugPoint();
Modified: branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.Designer.cs
--- branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.Designer.cs	2012-05-29 13:59:28 UTC (rev 6707)
+++ branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.Designer.cs	2012-05-30 12:54:00 UTC (rev 6708)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:2.0.50727.4971
+//     Runtime Version:2.0.50727.5420
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -757,6 +757,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Zoom Next.
+        /// </summary>
+        internal static string TextZoomNext {
+            get {
+                return ResourceManager.GetString("TextZoomNext", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Zoom Out.
         /// </summary>
         internal static string TextZoomOut {
@@ -766,6 +775,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Zoom Previous.
+        /// </summary>
+        internal static string TextZoomPrevious {
+            get {
+                return ResourceManager.GetString("TextZoomPrevious", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Zoom to Selection.
         /// </summary>
         internal static string TextZoomToSelection {
Modified: branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.resx
--- branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.resx	2012-05-29 13:59:28 UTC (rev 6707)
+++ branches/2.4/MgDev/Desktop/MapViewer/Properties/Resources.resx	2012-05-30 12:54:00 UTC (rev 6708)
@@ -445,4 +445,10 @@
   <data name="ThemedLayerTooltip" xml:space="preserve">
     <value>Name: {1}{0}Feature Source: {2}{0}Feature Class: {3}{0}Number of Rules: {4}</value>
   </data>
+  <data name="TextZoomNext" xml:space="preserve">
+    <value>Zoom Next</value>
+  </data>
+  <data name="TextZoomPrevious" xml:space="preserve">
+    <value>Zoom Previous</value>
+  </data>
 </root>
\ No newline at end of file
Modified: branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.Designer.cs
--- branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.Designer.cs	2012-05-29 13:59:28 UTC (rev 6707)
+++ branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.Designer.cs	2012-05-30 12:54:00 UTC (rev 6708)
@@ -55,7 +55,6 @@
             this.toolStripSeparator5 = new System.Windows.Forms.ToolStripSeparator();
             this.toolStripSeparator6 = new System.Windows.Forms.ToolStripSeparator();
             this.toolStripDropDownButton1 = new System.Windows.Forms.ToolStripDropDownButton();
-            this.toolStripSeparator7 = new System.Windows.Forms.ToolStripSeparator();
             this.toolStripSeparator8 = new System.Windows.Forms.ToolStripSeparator();
             this.toolStripDropDownButton2 = new System.Windows.Forms.ToolStripDropDownButton();
             this.lblLoading = new System.Windows.Forms.ToolStripLabel();
@@ -68,6 +67,8 @@
             this.lblScale = new System.Windows.Forms.ToolStripStatusLabel();
             this.lblSize = new System.Windows.Forms.ToolStripStatusLabel();
             this.lblLogo = new System.Windows.Forms.ToolStripStatusLabel();
+            this.toolStripSeparator14 = new System.Windows.Forms.ToolStripSeparator();
+            this.toolStripSeparator7 = new System.Windows.Forms.ToolStripSeparator();
             this.legendCtrl = new OSGeo.MapGuide.Viewer.MgLegend();
             this.propertiesCtrl = new OSGeo.MapGuide.Viewer.MgPropertyPane();
             this.mapViewer = new OSGeo.MapGuide.Viewer.MgMapViewer();
@@ -76,6 +77,8 @@
             this.toolStripButton3 = new System.Windows.Forms.ToolStripButton();
             this.toolStripButton4 = new System.Windows.Forms.ToolStripButton();
             this.toolStripButton5 = new System.Windows.Forms.ToolStripButton();
+            this.toolStripButton14 = new System.Windows.Forms.ToolStripButton();
+            this.toolStripButton13 = new System.Windows.Forms.ToolStripButton();
             this.toolStripButton6 = new System.Windows.Forms.ToolStripButton();
             this.toolStripButton7 = new System.Windows.Forms.ToolStripButton();
             this.toolStripButton8 = new System.Windows.Forms.ToolStripButton();
@@ -87,7 +90,7 @@
             this.toolStripMenuItem10 = new System.Windows.Forms.ToolStripMenuItem();
             this.toolStripMenuItem11 = new System.Windows.Forms.ToolStripMenuItem();
             this.toolStripMenuItem27 = new System.Windows.Forms.ToolStripMenuItem();
-            this.toolStripButton13 = new System.Windows.Forms.ToolStripButton();
+            this.toolStripMenuItem31 = new System.Windows.Forms.ToolStripMenuItem();
             this.toolStripMenuItem8 = new System.Windows.Forms.ToolStripMenuItem();
             this.toolStripMenuItem25 = new System.Windows.Forms.ToolStripMenuItem();
             this.toolStripMenuItem26 = new System.Windows.Forms.ToolStripMenuItem();
@@ -140,6 +143,8 @@
             this.loadCompactViewerComponent = new OSGeo.MapGuide.Viewer.MgGenericInvokeComponent();
             this.profileComponent = new OSGeo.MapGuide.Viewer.MgGenericInvokeComponent();
             this.mgToolButtonComponentInvoker1 = new OSGeo.MapGuide.Viewer.MgToolButtonComponentInvoker();
+            this.mgZoomNextComponent1 = new OSGeo.MapGuide.Viewer.MgZoomNextComponent();
+            this.mgZoomPreviousComponent1 = new OSGeo.MapGuide.Viewer.MgZoomPreviousComponent();
             this.mgLayerSelectionHandler1 = new OSGeo.MapGuide.Viewer.MgLayerSelectionHandler();
             this.appMenu.SuspendLayout();
             this.appContextMenu.SuspendLayout();
@@ -376,6 +381,9 @@
             this.toolStripButton3,
             this.toolStripButton4,
             this.toolStripButton5,
+            this.toolStripSeparator7,
+            this.toolStripButton13,
+            this.toolStripButton14,
             this.toolStripSeparator3,
             this.toolStripButton6,
             this.toolStripButton7,
@@ -388,8 +396,6 @@
             this.toolStripButton12,
             this.toolStripSeparator6,
             this.toolStripDropDownButton1,
-            this.toolStripSeparator7,
-            this.toolStripButton13,
             this.toolStripSeparator8,
             this.toolStripDropDownButton2,
             this.lblLoading});
@@ -435,18 +441,15 @@
             this.toolStripMenuItem9,
             this.toolStripMenuItem10,
             this.toolStripMenuItem11,
-            this.toolStripMenuItem27});
+            this.toolStripMenuItem27,
+            this.toolStripSeparator14,
+            this.toolStripMenuItem31});
             this.toolStripDropDownButton1.Image = global::MapViewerTest.Properties.Resources.icon_tasks;
             this.toolStripDropDownButton1.ImageTransparentColor = System.Drawing.Color.Magenta;
             this.toolStripDropDownButton1.Name = "toolStripDropDownButton1";
             this.toolStripDropDownButton1.Size = new System.Drawing.Size(65, 22);
             this.toolStripDropDownButton1.Text = "Tools";
-            // toolStripSeparator7
-            this.toolStripSeparator7.Name = "toolStripSeparator7";
-            this.toolStripSeparator7.Size = new System.Drawing.Size(6, 25);
             // toolStripSeparator8
             this.toolStripSeparator8.Name = "toolStripSeparator8";
@@ -550,6 +553,16 @@
             this.lblLogo.Name = "lblLogo";
             this.lblLogo.Size = new System.Drawing.Size(137, 18);
+            // toolStripSeparator14
+            this.toolStripSeparator14.Name = "toolStripSeparator14";
+            this.toolStripSeparator14.Size = new System.Drawing.Size(151, 6);
+            // toolStripSeparator7
+            this.toolStripSeparator7.Name = "toolStripSeparator7";
+            this.toolStripSeparator7.Size = new System.Drawing.Size(6, 25);
             // legendCtrl
             this.legendCtrl.Dock = System.Windows.Forms.DockStyle.Fill;
@@ -557,6 +570,7 @@
             this.legendCtrl.LayerContextMenu = null;
             this.legendCtrl.Location = new System.Drawing.Point(3, 3);
             this.legendCtrl.Name = "legendCtrl";
+            this.legendCtrl.ShowTooltips = true;
             this.legendCtrl.Size = new System.Drawing.Size(235, 246);
             this.legendCtrl.TabIndex = 0;
             this.legendCtrl.ThemeCompressionLimit = 0;
@@ -577,6 +591,7 @@
             this.mapViewer.Dock = System.Windows.Forms.DockStyle.Fill;
             this.mapViewer.Location = new System.Drawing.Point(0, 0);
             this.mapViewer.Name = "mapViewer";
+            this.mapViewer.PointPixelBuffer = 2;
             this.mapViewer.SelectionColor = System.Drawing.Color.Blue;
             this.mapViewer.Size = new System.Drawing.Size(495, 658);
             this.mapViewer.TabIndex = 0;
@@ -645,6 +660,30 @@
             this.toolStripButton5.Text = "Zoom Extents";
             this.toolStripButton5.ToolTipText = "Zoom Extents";
+            // toolStripButton14
+            this.toolStripButton14.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+            this.toolStripButton14.Enabled = false;
+            this.toolStripButton14.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton14.Image")));
+            this.toolStripButton14.ImageTransparentColor = System.Drawing.Color.Magenta;
+            this.toolStripButton14.Name = "toolStripButton14";
+            this.toolStripButton14.Size = new System.Drawing.Size(23, 22);
+            this.mgToolButtonComponentInvoker1.SetTargetComponent(this.toolStripButton14, this.mgZoomNextComponent1);
+            this.toolStripButton14.Text = "Zoom Next";
+            this.toolStripButton14.ToolTipText = "Zoom Next";
+            // toolStripButton13
+            this.toolStripButton13.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
+            this.toolStripButton13.Enabled = false;
+            this.toolStripButton13.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton13.Image")));
+            this.toolStripButton13.ImageTransparentColor = System.Drawing.Color.Magenta;
+            this.toolStripButton13.Name = "toolStripButton13";
+            this.toolStripButton13.Size = new System.Drawing.Size(23, 22);
+            this.mgToolButtonComponentInvoker1.SetTargetComponent(this.toolStripButton13, this.mgZoomPreviousComponent1);
+            this.toolStripButton13.Text = "Zoom Previous";
+            this.toolStripButton13.ToolTipText = "Zoom Previous";
             // toolStripButton6
             this.toolStripButton6.DisplayStyle = System.Windows.Forms.ToolStripItemDisplayStyle.Image;
@@ -733,7 +772,7 @@
             this.toolStripMenuItem9.Enabled = false;
             this.toolStripMenuItem9.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem9.Image")));
             this.toolStripMenuItem9.Name = "toolStripMenuItem9";
-            this.toolStripMenuItem9.Size = new System.Drawing.Size(119, 22);
+            this.toolStripMenuItem9.Size = new System.Drawing.Size(154, 22);
             this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem9, this.mgBufferComponent1);
             this.toolStripMenuItem9.Text = "Buffer";
@@ -742,7 +781,7 @@
             this.toolStripMenuItem10.Enabled = false;
             this.toolStripMenuItem10.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem10.Image")));
             this.toolStripMenuItem10.Name = "toolStripMenuItem10";
-            this.toolStripMenuItem10.Size = new System.Drawing.Size(119, 22);
+            this.toolStripMenuItem10.Size = new System.Drawing.Size(154, 22);
             this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem10, this.mgMeasureComponent1);
             this.toolStripMenuItem10.Text = "Measure";
@@ -751,7 +790,7 @@
             this.toolStripMenuItem11.Enabled = false;
             this.toolStripMenuItem11.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem11.Image")));
             this.toolStripMenuItem11.Name = "toolStripMenuItem11";
-            this.toolStripMenuItem11.Size = new System.Drawing.Size(119, 22);
+            this.toolStripMenuItem11.Size = new System.Drawing.Size(154, 22);
             this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem11, this.mgQueryComponent1);
             this.toolStripMenuItem11.Text = "Query";
@@ -760,21 +799,20 @@
             this.toolStripMenuItem27.Enabled = false;
             this.toolStripMenuItem27.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem27.Image")));
             this.toolStripMenuItem27.Name = "toolStripMenuItem27";
-            this.toolStripMenuItem27.Size = new System.Drawing.Size(119, 22);
+            this.toolStripMenuItem27.Size = new System.Drawing.Size(154, 22);
             this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem27, this.mgThemeComponent1);
             this.toolStripMenuItem27.Text = "Theme";
             this.toolStripMenuItem27.ToolTipText = "Theme";
-            // toolStripButton13
+            // toolStripMenuItem31
-            this.toolStripButton13.Enabled = false;
-            this.toolStripButton13.Image = ((System.Drawing.Image)(resources.GetObject("toolStripButton13.Image")));
-            this.toolStripButton13.ImageTransparentColor = System.Drawing.Color.Magenta;
-            this.toolStripButton13.Name = "toolStripButton13";
-            this.toolStripButton13.Size = new System.Drawing.Size(107, 22);
-            this.mgToolButtonComponentInvoker1.SetTargetComponent(this.toolStripButton13, this.mgViewerOptionsComponent1);
-            this.toolStripButton13.Text = "Viewer Options";
-            this.toolStripButton13.ToolTipText = "Viewer Options";
+            this.toolStripMenuItem31.Enabled = false;
+            this.toolStripMenuItem31.Image = ((System.Drawing.Image)(resources.GetObject("toolStripMenuItem31.Image")));
+            this.toolStripMenuItem31.Name = "toolStripMenuItem31";
+            this.toolStripMenuItem31.Size = new System.Drawing.Size(154, 22);
+            this.mgMenuItemComponentInvoker1.SetTargetComponent(this.toolStripMenuItem31, this.mgViewerOptionsComponent1);
+            this.toolStripMenuItem31.Text = "Viewer Options";
+            this.toolStripMenuItem31.ToolTipText = "Viewer Options";
             // toolStripMenuItem8
@@ -1218,6 +1256,20 @@
             this.profileComponent.Viewer = this.mapViewer;
             this.profileComponent.Invoked += new System.EventHandler(this.profileComponent_Invoked);
+            // mgZoomNextComponent1
+            this.mgZoomNextComponent1.Icon = ((System.Drawing.Image)(resources.GetObject("mgZoomNextComponent1.Icon")));
+            this.mgZoomNextComponent1.Label = "Zoom Next";
+            this.mgZoomNextComponent1.ToolTipText = "Zoom Next";
+            this.mgZoomNextComponent1.Viewer = this.mapViewer;
+            // mgZoomPreviousComponent1
+            this.mgZoomPreviousComponent1.Icon = ((System.Drawing.Image)(resources.GetObject("mgZoomPreviousComponent1.Icon")));
+            this.mgZoomPreviousComponent1.Label = "Zoom Previous";
+            this.mgZoomPreviousComponent1.ToolTipText = "Zoom Previous";
+            this.mgZoomPreviousComponent1.Viewer = this.mapViewer;
             // mgLayerSelectionHandler1
             this.mgLayerSelectionHandler1.Layers = new string[] {
@@ -1347,8 +1399,6 @@
         private System.Windows.Forms.ToolStripButton toolStripButton12;
         private System.Windows.Forms.ToolStripSeparator toolStripSeparator6;
         private System.Windows.Forms.ToolStripDropDownButton toolStripDropDownButton1;
-        private System.Windows.Forms.ToolStripSeparator toolStripSeparator7;
-        private System.Windows.Forms.ToolStripButton toolStripButton13;
         private System.Windows.Forms.ToolStripSeparator toolStripSeparator8;
         private System.Windows.Forms.ToolStripDropDownButton toolStripDropDownButton2;
         private System.Windows.Forms.ToolStripLabel lblLoading;
@@ -1388,6 +1438,13 @@
         private System.Windows.Forms.ToolStripMenuItem toolStripMenuItem29;
         private OSGeo.MapGuide.Viewer.MgLoadMapComponent mgLoadMapComponent1;
         private System.Windows.Forms.ToolStripMenuItem toolStripMenuItem30;
+        private System.Windows.Forms.ToolStripSeparator toolStripSeparator14;
+        private System.Windows.Forms.ToolStripMenuItem toolStripMenuItem31;
+        private System.Windows.Forms.ToolStripSeparator toolStripSeparator7;
+        private System.Windows.Forms.ToolStripButton toolStripButton14;
+        private OSGeo.MapGuide.Viewer.MgZoomNextComponent mgZoomNextComponent1;
+        private System.Windows.Forms.ToolStripButton toolStripButton13;
+        private OSGeo.MapGuide.Viewer.MgZoomPreviousComponent mgZoomPreviousComponent1;
Modified: branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx
--- branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx	2012-05-29 13:59:28 UTC (rev 6707)
+++ branches/2.4/MgDev/Desktop/MapViewerTest/MgAppWindow.resx	2012-05-30 12:54:00 UTC (rev 6708)
@@ -120,48 +120,65 @@
   <metadata name="appMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
     <value>17, 17</value>
   </metadata>
-  <metadata name="mgMenuItemComponentInvoker1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>168, 173</value>
-  </metadata>
-  <metadata name="mgLoadMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>498, 329</value>
-  </metadata>
   <metadata name="appContextMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
     <value>338, 17</value>
   </metadata>
+  <metadata name="appToolbar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>121, 17</value>
+  </metadata>
   <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
-  <data name="toolStripMenuItem13.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+  <data name="toolStripButton1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
         iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
-        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGDSURBVDhPY2AAAifP4P+4MEieKAAy4Oev3ygYJAbSHJOc
-        /K2itnX/lClz5PEaBtLw6MlLOIYZYGnvATY4Pq3gT0Nr72yshoAkcktq/99/+AyrARu37jkPksvMr/yP
-        YQjIaSDTQQqAhqyHuQTmAnt/fwEnr5A1IG/ce/AM7BIU79Q0dh3fsmP//zUbdhx28gpeihywyM519Aye
-        D3LJlu37/oMMg8uBAglkclB48iUXl1B+mATMBTC+jXeUoH9owjmQWpAeuAHO3mFgfzt5hYJDHR/Q0tL6
-        A1IL0gNXB9JIkQEwL4Cch+wFWFjAbHJzCxECefPeg6eoXiiva9+3def+/xu27r7g6BW8AtkLsBQKMSx0
-        1frNu44AA/I/KODh6nqmzpMFRQ0ocEChC/TSQpBtMBeAEhHIIFAUw6IRpAclrBrb+mZlFVT9BynYuG3P
-        eVDqgxkAS50gp2fkV/wHqcWZGkEuAWnAZgA4oKH5A2dMgZwG8gYsntHzB1GGYAtEbNkdpA4A8r5nBCK/
-        IMoAAAAASUVORK5CYII=
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAD3SURBVDhPlZNLCoMwEIY9V5B241lcFEorUnqsLrxAT9C1
+        W9GF+EARRfDBlH/AEGsiduADSTLfTBJjWUoIIQLbtsmE7/ukrt98I3EvINiVQBBFkREkI4wSCOI41pIk
+        CScuoZWEYUjDMGip65oFv8hzECcnsM8O6bh5D5amaboCHUsBEk2BuXEcKcsyyvNcIgWu63LlPQHWQNK2
+        LZVlybBAbX1PgAKe/6RpmqiqKoYFmOi6jjGdgToPQdM0jBQURUFHQIF5nnkbQApwfUdYBH3fE5ACU+u6
+        cXRgFOAQX+/PCoypoo3gn1u4XO+81eW14vUe+hNRxPSMv4YPeJAk7UvrAAAAAElFTkSuQmCC
 </value>
   </data>
-  <metadata name="mgRefreshMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>405, 173</value>
+  <metadata name="mgToolButtonComponentInvoker1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>183, 95</value>
   </metadata>
-  <data name="mgRefreshMapComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+  <metadata name="mgPrintComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 95</value>
+  </metadata>
+  <data name="mgPrintComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
 </value>
   </data>
-  <data name="toolStripMenuItem14.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+  <data name="toolStripButton2.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAADgSURBVDhPhZPNCoJAFIV9spZtepfeoGWP2CaCKKQwNf9K
+        848b58IZdGqcC4cDjvfzm4XBar0RV7a7vQS+wbJrLuFNkEUGAOdrqPm0rdMG7/01wgG/RIDLCIAfCADh
+        PdK0XacGNLIby5gZBAu3KNYQQCO7CZhBAIjiRNP1vRrQyG5eYdoBFuL0qSGARr7GrgLSLNf0w6AGNJr2
+        I0nFjgFkRSkIATTytQEU1UuQYRzVgEa+NoB3XQtCAI3QeVk5YwB10whCAI18bQD8mQ7Hk16BRr5WgD14
+        SCNfOwFLv7h99gUnGcVV+atLwAAAAABJRU5ErkJggg==
+</value>
+  </data>
+  <metadata name="mgCopyMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 56</value>
+  </metadata>
+  <data name="mgCopyMapComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+</value>
+  </data>
+  <data name="toolStripButton3.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
         YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIESURBVDhPnZPNSxtRFMX9T2ppN7axH2SjqaGpsU0TjJJi
         RhsZm0WaUqVRBCmIMX9BV3Xl0pWgpFAsFNS46aJQsRRqxQkx5sPPmIzGmRhJMsd3B6ZkTCPFgcN9783h
         9+6cyzQ0VD2vR0aHHS5X9E7zA6Xx5m00Ge4rtKfzat8/1509nGB5+hzTc2GsrG/gWzSm1un5MFrNFjhc
@@ -175,7 +192,7 @@
 </value>
   </data>
   <metadata name="mgZoomInComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 251</value>
+    <value>407, 134</value>
   </metadata>
   <data name="mgZoomInComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -192,7 +209,7 @@
         JC4A2evLqnFhjAkAAAAASUVORK5CYII=
 </value>
   </data>
-  <data name="toolStripMenuItem15.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+  <data name="toolStripButton4.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
         YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAH5SURBVDhPnZPLSxtRFMb9T2qpm7ZRW7KpqaHBaNMEU0kx
@@ -208,7 +225,7 @@
 </value>
   </data>
   <metadata name="mgZoomOutComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>436, 251</value>
+    <value>826, 134</value>
   </metadata>
   <data name="mgZoomOutComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -225,41 +242,8 @@
         AAAAAElFTkSuQmCC
 </value>
   </data>
-  <data name="toolStripMenuItem16.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+  <data name="toolStripButton5.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
-        R0lGODlhEAAQAIZvAISChAEBAXBJJai7zsfb8Nrn9M/a5Nnm81tgZNDh8sXa77jH16jR4+fu9dDh8brT
-        7erv89jm8uzw9ODq9Ku0vNHh8mRrcvT3+aStttri6oOGiJqbncrc7oaKjZ+fn9Di6JSVl67C1a6yt5u2
-        0F5cWsjd5IiOlM3U2Tg3N398ezAvLujjjKCnr5u83uXq73V5fnh3d+nv9OLaid/s76/N6pyzy9fn65mi
-        rLCurXahzJDO1tfb3+Do8dDg8UdKTb7L2EpMTFhYWZy20K22v6jG5KWqsaq8z+7sj7C/z6amp6C50uLr
-        9evw9aTF52RgX250esjQ2ISAf2xtb7S3u+Tr8WBocMPT43yQo7vU7cbb7+Hr9JGRkt7m7YSFiL7H0cza
-        6IWUo7bBzeqxd6uvs6uoqOLs9c7X31xbXbe/x+fs8evv84SHi8vY5XyPoq7L5wAAAAAAAAAAAAAAAAAA
-        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
-        AABvACwAAAAAEAAQAAAIwgABvBFIcOCbgwgTJsQRxUkKMgkFBpj4xsMULz/CFNmiMMCRNxugcEkTg8cX
-        JGsOSlyRRAQENRcaTIjAAQwIhAFkwDghIQMVLQd6KKhxxuBEEi6YsLFSoIKCB0RQKJSyo0GZAgmyMKAh
-        xIfBNwFMjFlywAEBBjqaXHmCcwaaLmYSEMDSIoeSKhSM2njDQsONEG5GtLGAIGGADyXeDOkQRAWQFxgQ
-        CBAjECxFAwuMLDDwZoAAAQpDI/RcsHToAaJTvwkIADs=
-</value>
-  </data>
-  <metadata name="mgZoomToSelectionComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>200, 251</value>
-  </metadata>
-  <data name="mgZoomToSelectionComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-</value>
-  </data>
-  <data name="toolStripMenuItem17.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
         YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAFqSURBVDhPpZPbTsJAEIZ5NaPxAXgI5UK50Qt9LmPSeBYQ
         g2gFEWiVIsUWSjm2pdfjzOyyFbyrF1/+Ofwz2c1mMztb2bPd7SykgWYzNOj5k1TQLC+o6K1UqAXVmgHV
@@ -271,7 +255,7 @@
 </value>
   </data>
   <metadata name="mgInitialViewComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 95</value>
+    <value>384, 56</value>
   </metadata>
   <data name="mgInitialViewComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -285,360 +269,83 @@
         AeYbqBNEyxii5RKJIWRF4qTG/VjWf3l5wX+/8w9/3Qe1qQ/dtwAAAABJRU5ErkJggg==
 </value>
   </data>
-  <data name="toolStripMenuItem18.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+  <data name="toolStripButton13.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
-        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGTSURBVDhPlVNNSwJRFPV/tQpaiW1qFrmKICIqKMmICjIw
-        A4tIRCNpIFFKkUgMQ8FKyz4ohBBh3BlFH5vqL5w4F5/OqBsvHObjvnPeuWfe2Gz9F/qnNBlOp5NkNK/9
-        6ZhI4qD1/PP7h/L9A7a29+BaWoN7xYPQgY584RJGva7sys49MT23iHn3KoL7Eby9f6B4UxaBiB4VwWg8
-        gcenZ2iaZhZrOxifnAXr8+sbL9UaGo1X0BWL9ywKsedwDHdnQAGOYCZWKhVxw1r3BeVKJ3TXHKMdIEfY
-        2PTLzLRqJnJXFt+z9KMYKG6Jn9Z3A2EMDNqRSKXFjSJysXLGsXjPvDLZXPdZYOIUSaVzkj5BcRLNuC6W
-        MDo20RZgc2rGBWbBBkU4TufuSoSiFgF+LkItiB0nxSZHIQyj0eXCIjBkHwGD5DngzleluxZyhVtk80UJ
-        Vm3AnOjSEiTn8nj90qCbs2xBsjg5vUA8eS6o1gwEQrqsYcg9fwQ2uMC3E0boMNECiQvLXumZjnfvn0mJ
-        cDSCJAV+xk7WP7yJ9EN8DX7nAAAAAElFTkSuQmCC
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIWSURBVDhPnZNbaxNREMf3i9TGW0WbeosPQi/RJBoSGiWg
+        21LZmocYRCGpdyitfVD0xTfBFxH6DQSl+CCCILFCRX3xoZuiaRKj1babJptsLrv7d+ZAoJekiAPDnHN2
+        5nfm/IeVpHV2aex6IhgOpw70HLYdO/dgv/OQzXs+X5/Xcj14TlY9/iCmX8zg3XwKyYVvIk6/nEGv24Ng
+        WE61hZw5L6sXL1/B3Pc0PmVy+Ez+cTGLuXQGC7+XUTQMPHn6DJy3BXL11p2ELzCIL5ksvuZ/YqlYgl6r
+        iXV6ZRV108TRY8dFHPD4wPkbIGflEfX56zeY/7WEnKbBsm2sVSrIF9bQsCxRzM5mEkTTNGsDwHnwiK1S
+        8SLdVm00YBPgh1aAUa+Lwh2du1p6V1f3IwHqdOxGdlUTN3Lxil4WgGVdh7mpA/5ukB5cx2CCPJacNLI8
+        Ffwp6aKYI+vAXqgY4kncCcccdXnv/gO7+QSGSPIFRX2bfA+tXGnperWGhmmB4yvSivObgI4OR1EaH5+M
+        9/WfQIlaK5P67bxIwvb2ucH5TcDefd0PxXp4eDR14+ZtVEk4Vn6z83k8cQ3KaARe32mhwRZTFEU96TmF
+        2dkPaNA02Dgm6Xn9A24MDY0gFAohFou1h0xOTcUZ1EOj5elw5D2f880ulwuBQADRaLQ9ZLufpgnx+/2I
+        RLZ5zr9AvF7v/3XBcO6EfWLiLv4CUX/gaLRksWEAAAAASUVORK5CYII=
 </value>
   </data>
-  <metadata name="mgPanComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>214, 95</value>
+  <metadata name="mgZoomPreviousComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>687, 17</value>
   </metadata>
-  <data name="mgPanComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+  <data name="mgZoomPreviousComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
 </value>
   </data>
-  <data name="toolStripMenuItem19.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+  <data name="toolStripButton14.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
-        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAACcSURBVDhPY2BMZZzJmMb4nywM1MsA0rjxRDMcv//y7D8I
-        I4vhYoP0YjXA0t6DKEPwGkCMIXgN+PPn739ChuA14NWb9/9BGJ8heA34+u37fxjGZQheA/6jAWyGEG0A
-        SDMMI0cxQQNAmkAAZjt6+iAYjcgGfPz6EiNxEUxIIBvRXYGcKrEaAFIAcyrZBqDnDZKikZhMBFMD8QKF
-        2RkA39ChmP3112gAAAAASUVORK5CYII=
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGQSURBVDhPrVPLTsJQEOUvjN/BAhIeG8W/kMRgKpEfgJ2G
+        vUEjD/kFtrpywcbELjDoClATxWflUTB93rY4zlxpUgMFF05y0mk758yZ6W0g4IloNJpHvCK+pqA8762Z
+        m8disdVwOPy2nU6r56Jo3nSf4PrhEc7qdba5taPRO6rxFaKuhXJFv/3oAaE7lOG+1+d5+12Cg8KhQTWu
+        QDweB4TA78liKpXS7yQJiUMwLAso+ooCzLY5THzW7nQmtVrtlDhTgR8RslcXRfYsj8DEYgrLcYAhCqUS
+        FS0EOYAXWYaBqnKyjcQedj8ql5eSSZwLSKMxDFUNVMb4daConFysnIA9mXBYtgOtVgtmRqDlXDYa7FPX
+        wQsScJDoPrvAMd1F/lpiJBLZ381kNMUwQEMH8zDG8TaTScv3TNAiK9WqoaALWp4XKgofF4t8pPXEBh9h
+        JkKh0ArZEwRBv2o2mWGaQKA8iZ3dL5HNZv1FSJXGmXeUqXMwGOQulor4Hdd/F8nlcovH+YsT36Uu+32J
+        SFhLJPa+AcvEqpIKE7rWAAAAAElFTkSuQmCC
 </value>
   </data>
-  <metadata name="mgSelectComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>229, 212</value>
+  <metadata name="mgZoomNextComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>1124, 17</value>
   </metadata>
-  <data name="mgSelectComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+  <data name="mgZoomNextComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
+</value>
+  </data>
+  <data name="toolStripButton6.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
 </value>
   </data>
-  <data name="toolStripMenuItem20.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
-        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAEOSURBVDhPY2CgANjY2PwnWztI8+aOgP8Mbs5B/0EYZBIx
-        bJi6TW2+/799eQ0xgBhnwNSBbN7Y6gPWfO5QL1F64ebDNH//+gaseeMMH+JdgE0zyCVEeQGk+dSpU/9B
-        9PnDfWCbQZoJxkKMAoM5SNGZM2f+f//+/f+FCxfAmlA04wrEWCUGmwRVhjWbXBkgNp8//3/FihX/Gxsb
-        UW3GZUCCIsOTwz4M/3+lMPzf4wkxpKGhgbCzYUEep8qw6UYYw/+bwQz/dzoz/G/WgxiCEeU4vaDMMLHP
-        nOH/CjuG/32GDP+LtRn+xyow2BNtQAgDA2e8MsOMBBWGI0nqDPDUSkyiI00NqUkZqxdIzUzIhgAAH4zC
-        0srGPRUAAAAASUVORK5CYII=
-</value>
-  </data>
-  <metadata name="mgClearSelectionComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 56</value>
+  <metadata name="mgSelectComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 134</value>
   </metadata>
-  <data name="mgClearSelectionComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+  <data name="mgSelectComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
-</value>
-  </data>
-  <data name="toolStripMenuItem21.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAFoSURBVDhPpVNdKwRRGN47jZ/g57hQJGSzmxSTUv4DF26F
-        tRa12JLaXVtKMimJ3ZKLsUyWbEImdsUwF37C4zwzTZ2z7a4pp956v57ned9zZiIRcbTJgy5NNzIduvGj
-        jRtVbcKYY461UIeAWNpC2qxj/swG/U7dgAz2REhMgUYRJhaKNmZSOfR0R5GtfKA3YSokJIwLYvbR6HNq
-        T4QEiyJJcGD520/0LfskNPrMsT6byiNTfgdX9gnEaKMbFgp3fkNgjGWTa4mSDQr7BGI/qvQnTezdqySM
-        m+XGNsUKQli5ZJIMJC+xX3WUSWRl1tjD3qYvxcLhg+OZDKTP3OCKD275vCwePX55JhMwHkqFAA+vlnH8
-        /K2AGTPfUjm4xKhoOn1RwYyZbzs2b3Nq+wYl21WUGY+s/QEOPqTsVU0Bn7+6iK2HAAcEuesalrYKHsnF
-        m4t4WHDwJU7vVHDy5GDXqoN+250b3/A/v/MvkqOAAMpRUaEAAAAASUVORK5CYII=
-</value>
-  </data>
-  <metadata name="mgBufferComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 290</value>
-  </metadata>
-  <data name="mgBufferComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-</value>
-  </data>
-  <data name="toolStripMenuItem22.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAABjSURBVDhPY2AY+sDGxuY/Ob6A64MxiDUIQz1IgFwMdjlV
-        XEBRGJCjGUXPxCC2VfVBbP/QMVD8PzZxmBhIH9ggkMD/Fyn/F5ea/SeFBumDG/D9FNt/UjDIIrgBFHuB
-        4kAccAMAwje0sEjeZewAAAAASUVORK5CYII=
-</value>
-  </data>
-  <metadata name="mgMeasureComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>585, 290</value>
-  </metadata>
-  <data name="mgMeasureComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-</value>
-  </data>
-  <data name="toolStripMenuItem23.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAHySURBVDhPnZPLSxtRFMb9T6rUTW3Ulmw0GhqMNk0wSqCO
-        YhnNIkZUjCKUgvj4C7rSlUtXQksKRUHQxk0XhYpF8IETkpiHjxiT0TgTI0nm6z0DloxJbOmFj3Mf5/7u
-        me8wVVVFY2hyasLmcPjr6l8o1TW1eKZrVGhN+8V5ZeedbznB1PEGS5+82No/xHd/QI1Ln71oNppgc3D+
-        ipCuHk74uLCIH4EQdiIx/GLaDkfx8zii6ujsHIPDI6C8EsjY+w8TbRYbdo7D2D89Qzx9A+nuTp3vxk7+
-        aDsYQqupDZSvgXRz/cLK6hqOzuOIiSIKioLrTAZC/AKH7OViLXu/oJt7UIWu4aVyEI0hnEwhm8tBYYAT
-        8QrBxCUCD7QXieI5M1hTwZPqpwhfJnF6da1eTkqyCoimxBKFLhKg7mgAOkaMsIPEjaRepkg+lFOQ+UL5
-        GgD3jhfWv/kgypm/yvt1FZSvAUxPz3qaDUbI2Sxk5n45kTepdBpNhlZQfkkr+/oG/J7JKci3t8gVCiWS
-        WFdGx8bBDzhhbn+t9eCexvO88Ir12efbgsS8yOfzLErY2NiEocWI3t5+2O12uN3uypDZ+XkPgepZa6k7
-        FGlN+/SyXq+H1WqFy+WqDHnsp7mHWCwWOJ2PfM6/QMxm8/9VQXCqhDQzM4ffTfzkLal2r4sAAAAASUVO
-        RK5CYII=
-</value>
-  </data>
-  <metadata name="mgQueryComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>411, 290</value>
-  </metadata>
-  <data name="mgQueryComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        RK5CYII=
-</value>
-  </data>
-  <data name="toolStripMenuItem24.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAC0SURBVDhPrZPLCsIwEEXzXeKyS/0bQUFxISiKK8EH/TXF
-        QtRiKBaLSqyrkQnkgovCkBg4zFyYOYRAlIo9raSTtpMuhcC7ihfPuQGD2Yak8K4TxOAEoQc3OGQnkrI/
-        avJAkOmcepMV4CwBAn0x1J+u6fmyrvrMfRM8A0F+LX5enrMECExRUggQ3MqKhvMt4CwBgnv1oNFiR3X9
-        cdVn7pvgGQj48cbLFHCWAIG1bwrhP4LY3/gFpD/IGPp59QYAAAAASUVORK5CYII=
-</value>
-  </data>
-  <metadata name="mgViewerOptionsComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>190, 290</value>
-  </metadata>
-  <data name="mgViewerOptionsComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-</value>
-  </data>
-  <data name="toolStripMenuItem1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        R0lGODlhEAAQAIMAAAAAAP///ydYF5fYTmBfDJlmAGYzALWEU8yZZtSmeP/jyP///wAAAAAAAAAAAAAA
-        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIcwAXCBxIcIGAgwUTGhQQAKHAAhAj
-        FiDAcMAAhBATINioAEFFixchKhhJUsFBARcPFtC4kWNLlAIMLFiZoGZNBTZhyixwoKdPBT51zvT5M+jF
-        nSWTmjy4k2hPoE6bOoVKVCpRqj6tFo0604DXr2DBKhwrMCAAOw==
-</value>
-  </data>
-  <metadata name="mgLoadPackageComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 212</value>
-  </metadata>
-  <data name="mgLoadPackageComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-</value>
-  </data>
-  <data name="toolStripMenuItem2.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-</value>
-  </data>
-  <data name="toolStripMenuItem3.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-</value>
-  </data>
-  <data name="toolStripMenuItem4.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        RK5CYII=
-</value>
-  </data>
-  <data name="toolStripMenuItem28.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        R0lGODlhEAAQAIMAAAAAAP///6e6zXG39mCc0bzd+87trIC4QpfYTv/eStm9P//vqmdnZywsLP///wAA
-        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAOACwAAAAAEAAQAAAIeQAdCBxIsKADBggTIjQokIGBhxAb
-        MDxoAIFFBAckMnRoUaFCghwRMFhAsqTGhhVFLkjAMoGCkxQPHBjJ0qPCBjhpJmBQoKfPBgKCCtDJc4DR
-        AQRgjlSgoOjRpCBxNnBqFOpAoUMLHEUKE2QBAmDBdh3IQKrZiVixBgQAOw==
-</value>
-  </data>
-  <metadata name="mgThemeComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>320, 329</value>
-  </metadata>
-  <data name="mgThemeComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-</value>
-  </data>
-  <data name="toolStripMenuItem12.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-</value>
-  </data>
-  <metadata name="appToolbar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>121, 17</value>
-  </metadata>
-  <data name="toolStripButton1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAD3SURBVDhPlZNLCoMwEIY9V5B241lcFEorUnqsLrxAT9C1
-        W9GF+EARRfDBlH/AEGsiduADSTLfTBJjWUoIIQLbtsmE7/ukrt98I3EvINiVQBBFkREkI4wSCOI41pIk
-        CScuoZWEYUjDMGip65oFv8hzECcnsM8O6bh5D5amaboCHUsBEk2BuXEcKcsyyvNcIgWu63LlPQHWQNK2
-        LZVlybBAbX1PgAKe/6RpmqiqKoYFmOi6jjGdgToPQdM0jBQURUFHQIF5nnkbQApwfUdYBH3fE5ACU+u6
-        cXRgFOAQX+/PCoypoo3gn1u4XO+81eW14vUe+hNRxPSMv4YPeJAk7UvrAAAAAElFTkSuQmCC
-</value>
-  </data>
-  <metadata name="mgToolButtonComponentInvoker1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>409, 134</value>
-  </metadata>
-  <metadata name="mgPrintComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>243, 134</value>
-  </metadata>
-  <data name="mgPrintComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-</value>
-  </data>
-  <data name="toolStripButton2.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAADgSURBVDhPhZPNCoJAFIV9spZtepfeoGWP2CaCKKQwNf9K
-        848b58IZdGqcC4cDjvfzm4XBar0RV7a7vQS+wbJrLuFNkEUGAOdrqPm0rdMG7/01wgG/RIDLCIAfCADh
-        PdK0XacGNLIby5gZBAu3KNYQQCO7CZhBAIjiRNP1vRrQyG5eYdoBFuL0qSGARr7GrgLSLNf0w6AGNJr2
-        I0nFjgFkRSkIATTytQEU1UuQYRzVgEa+NoB3XQtCAI3QeVk5YwB10whCAI18bQD8mQ7Hk16BRr5WgD14
-        SCNfOwFLv7h99gUnGcVV+atLwAAAAABJRU5ErkJggg==
-</value>
-  </data>
-  <metadata name="mgCopyMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>235, 56</value>
-  </metadata>
-  <data name="mgCopyMapComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-</value>
-  </data>
-  <data name="toolStripButton3.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIESURBVDhPnZPNSxtRFMX9T2ppN7axH2SjqaGpsU0TjJJi
-        RhsZm0WaUqVRBCmIMX9BV3Xl0pWgpFAsFNS46aJQsRRqxQkx5sPPmIzGmRhJMsd3B6ZkTCPFgcN9783h
-        9+6cyzQ0VD2vR0aHHS5X9E7zA6Xx5m00Ge4rtKfzat8/1509nGB5+hzTc2GsrG/gWzSm1un5MFrNFjhc
-        XLQupMvNCR8+TuF7LI61ZBo/mVYTKfzYTqra3NvHqzdvQb4ayNDY++F2mwNr2wms7+7hIH8K6fwcTzrs
-        +JXe+avVrTjaLO0gvw7SzXmE2YUv2Nw/QFoUUVEUnBQKKmCD3VytmfAndHOXujDce6j8SaWRyOZQLJWg
-        MMCOeKwCYpkjnX4nU7jLAtZ1cKPxFhJHWewen6CH68cLtwcu90sVQFVTKicifpgBTUcHMDBikr3InErI
-        SrJaKQcCUK3WFsuI/DoA188LX5cjEOWCTgS4fBb+vADy6wDj48FAq8kMuViEzNLXRABtTdnk8nm0mNpA
-        /ppR9vUNRAMjo5DPzlCqVGoksakMDr0DP+CFteOZPgONxvO88JjNORJZgcSyKJfLrEpYXFyC6ZEZvb0e
-        OJ1O+P3++pBgKBQgUDMbLU2HKu3pnG42Go2w2+3w+Xz1IVf9NBrEZrPB673ic/4HYrVar9cFwakT0sTE
-        JC4A2evLqnFhjAkAAAAASUVORK5CYII=
-</value>
-  </data>
-  <data name="toolStripButton4.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAH5SURBVDhPnZPLSxtRFMb9T2qpm7ZRW7KpqaHBaNMEU0kx
-        o42MZpGmqDSKIIL4+Atc6cplVwUlhWKhoMaNi0LFUvCBE5KYh48Yk9E4EyNJ5vOegJIxiS0d+Dj33vn4
-        3TPfYWpqSp4PwyNDFpvN/6T+mVL7sA6PNY0K7em81Fdx3d7JCYa2N5hf8GJtexfr/kCxzi960aQ3wGLj
-        /FUhb+2cMDM7h5+BEDYjMfxm2ghH8Ws/UtTe0TH6PvaDfGWQwdGxoRaTBZv7YWwfHiGevoB0dVVc/4kd
-        3GojGEKzoQXkV0E6OIfwZek79o7jiIkiCoqC80wGQvwEu+zmUn32fkUHd6cLTcNzZScaQziZQjaXg8IA
-        B+IZgolTBO5oKxLFUxawqoMHtY8QPk3i8OwcnVwP3tkdsNnflymaEhE6SYCmowJoGDHCXiQuJCQluVgp
-        h0oKslzIrwJwPbzwY9UHUc78Vd5vSyC/CjA+Pulp0ukhZ7OQWfqVRNmk0mm80DWD/GWj7O7u9XuGRyBf
-        XiJXKJRJYlMZGPwEvtcJY+trdQY3NJ7nhVdszj7fGiSWRT6fZ1XC8vIKdC/16OpywGq1wu12V4dMTk97
-        CFTPRkvToUp7OqebtVotzGYzXC5Xdch9P80NxGQywem853P+BWI0Gv+vC4JTJ6SJiSlcA6LH15rL3j8W
-        AAAAAElFTkSuQmCC
-</value>
-  </data>
-  <data name="toolStripButton5.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
-        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAFqSURBVDhPpZPbTsJAEIZ5NaPxAXgI5UK50Qt9LmPSeBYQ
-        g2gFEWiVIsUWSjm2pdfjzOyyFbyrF1/+Ofwz2c1mMztb2bPd7SykgWYzNOj5k1TQLC+o6K1UqAXVmgHV
-        Whsh3Yhf23+uJ7yizifQGx/w8kaYoKOu0cAakts7Uot09pnJgnqzA2u0MCdk/Vy7Y3Nu/5i13vrknjpB
-        0/iCpokYXQHFTBe0yyIbtYsCvGNOMSnNqAWm1QezYyOoGBsE5lfXJTaRmpbsr3zoVQss2wGr54JlIz2K
-        Hbi5f2TDLSr1OrLOPo7dZIHteEDQAGmx9MRxoVThXDAU+i3yvvTzK7hDH1xvzEP5gxPWh/IzDLDmeqJH
-        DCgekgrUFfzxDEbjqXqm/OEp5z4yot6EFFmp7KkF0/kCiM3/MJ0HXBesYqmzIDnBIgxhEUYQICIWeQLm
-        AeYbqBNEyxii5RKJIWRF4qTG/VjWf3l5wX+/8w9/3Qe1qQ/dtwAAAABJRU5ErkJggg==
-</value>
-  </data>
-  <data name="toolStripButton6.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
-    <value>
@@ -681,7 +388,7 @@
 </value>
   </data>
   <metadata name="mgPolygonSelectComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>375, 95</value>
+    <value>742, 56</value>
   </metadata>
   <data name="mgPolygonSelectComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -706,6 +413,22 @@
 </value>
   </data>
+  <metadata name="mgPanComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>581, 56</value>
+  </metadata>
+  <data name="mgPanComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGTSURBVDhPlVNNSwJRFPV/tQpaiW1qFrmKICIqKMmICjIw
+        A4tIRCNpIFFKkUgMQ8FKyz4ohBBh3BlFH5vqL5w4F5/OqBsvHObjvnPeuWfe2Gz9F/qnNBlOp5NkNK/9
+        6ZhI4qD1/PP7h/L9A7a29+BaWoN7xYPQgY584RJGva7sys49MT23iHn3KoL7Eby9f6B4UxaBiB4VwWg8
+        gcenZ2iaZhZrOxifnAXr8+sbL9UaGo1X0BWL9ywKsedwDHdnQAGOYCZWKhVxw1r3BeVKJ3TXHKMdIEfY
+        2PTLzLRqJnJXFt+z9KMYKG6Jn9Z3A2EMDNqRSKXFjSJysXLGsXjPvDLZXPdZYOIUSaVzkj5BcRLNuC6W
+        MDo20RZgc2rGBWbBBkU4TufuSoSiFgF+LkItiB0nxSZHIQyj0eXCIjBkHwGD5DngzleluxZyhVtk80UJ
+        Vm3AnOjSEiTn8nj90qCbs2xBsjg5vUA8eS6o1gwEQrqsYcg9fwQ2uMC3E0boMNECiQvLXumZjnfvn0mJ
+        cDSCJAV+xk7WP7yJ9EN8DX7nAAAAAElFTkSuQmCC
+</value>
+  </data>
   <data name="toolStripButton10.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -717,6 +440,20 @@
 </value>
   </data>
+  <metadata name="mgClearSelectionComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>906, 17</value>
+  </metadata>
+  <data name="mgClearSelectionComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAEOSURBVDhPY2CgANjY2PwnWztI8+aOgP8Mbs5B/0EYZBIx
+        bJi6TW2+/799eQ0xgBhnwNSBbN7Y6gPWfO5QL1F64ebDNH//+gaseeMMH+JdgE0zyCVEeQGk+dSpU/9B
+        9PnDfWCbQZoJxkKMAoM5SNGZM2f+f//+/f+FCxfAmlA04wrEWCUGmwRVhjWbXBkgNp8//3/FihX/Gxsb
+        UW3GZUCCIsOTwz4M/3+lMPzf4wkxpKGhgbCzYUEep8qw6UYYw/+bwQz/dzoz/G/WgxiCEeU4vaDMMLHP
+        nOH/CjuG/32GDP+LtRn+xyow2BNtQAgDA2e8MsOMBBWGI0nqDPDUSkyiI00NqUkZqxdIzUzIhgAAH4zC
+        0srGPRUAAAAASUVORK5CYII=
+</value>
+  </data>
   <data name="toolStripButton11.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -730,6 +467,22 @@
 </value>
   </data>
+  <metadata name="mgRefreshMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>813, 95</value>
+  </metadata>
+  <data name="mgRefreshMapComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGDSURBVDhPY2AAAifP4P+4MEieKAAy4Oev3ygYJAbSHJOc
+        /K2itnX/lClz5PEaBtLw6MlLOIYZYGnvATY4Pq3gT0Nr72yshoAkcktq/99/+AyrARu37jkPksvMr/yP
+        YQjIaSDTQQqAhqyHuQTmAnt/fwEnr5A1IG/ce/AM7BIU79Q0dh3fsmP//zUbdhx28gpeihywyM519Aye
+        D3LJlu37/oMMg8uBAglkclB48iUXl1B+mATMBTC+jXeUoH9owjmQWpAeuAHO3mFgfzt5hYJDHR/Q0tL6
+        A1IL0gNXB9JIkQEwL4Cch+wFWFjAbHJzCxECefPeg6eoXiiva9+3def+/xu27r7g6BW8AtkLsBQKMSx0
+        1frNu44AA/I/KODh6nqmzpMFRQ0ocEChC/TSQpBtMBeAEhHIIFAUw6IRpAclrBrb+mZlFVT9BynYuG3P
+        eVDqgxkAS50gp2fkV/wHqcWZGkEuAWnAZgA4oKH5A2dMgZwG8gYsntHzB1GGYAtEbNkdpA4A8r5nBCK/
+        IMoAAAAASUVORK5CYII=
+</value>
+  </data>
   <data name="toolStripButton12.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -741,7 +494,7 @@
 </value>
   </data>
   <metadata name="mgTooltipToggleComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>402, 212</value>
+    <value>190, 134</value>
   </metadata>
   <data name="mgTooltipToggleComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -753,6 +506,12 @@
         AABJRU5ErkJggg==
 </value>
   </data>
+  <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>600, 173</value>
+  </metadata>
+  <metadata name="statusBar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>237, 17</value>
+  </metadata>
   <data name="toolStripMenuItem9.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -765,6 +524,24 @@
 </value>
   </data>
+  <metadata name="mgMenuItemComponentInvoker1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>576, 95</value>
+  </metadata>
+  <metadata name="mgBufferComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>1019, 134</value>
+  </metadata>
+  <data name="mgBufferComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAFoSURBVDhPpVNdKwRRGN47jZ/g57hQJGSzmxSTUv4DF26F
+        tRa12JLaXVtKMimJ3ZKLsUyWbEImdsUwF37C4zwzTZ2z7a4pp956v57ned9zZiIRcbTJgy5NNzIduvGj
+        jRtVbcKYY461UIeAWNpC2qxj/swG/U7dgAz2REhMgUYRJhaKNmZSOfR0R5GtfKA3YSokJIwLYvbR6HNq
+        T4QEiyJJcGD520/0LfskNPrMsT6byiNTfgdX9gnEaKMbFgp3fkNgjGWTa4mSDQr7BGI/qvQnTezdqySM
+        m+XGNsUKQli5ZJIMJC+xX3WUSWRl1tjD3qYvxcLhg+OZDKTP3OCKD275vCwePX55JhMwHkqFAA+vlnH8
+        /K2AGTPfUjm4xKhoOn1RwYyZbzs2b3Nq+wYl21WUGY+s/QEOPqTsVU0Bn7+6iK2HAAcEuesalrYKHsnF
+        m4t4WHDwJU7vVHDy5GDXqoN+250b3/A/v/MvkqOAAMpRUaEAAAAASUVORK5CYII=
+</value>
+  </data>
   <data name="toolStripMenuItem10.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -773,6 +550,17 @@
 </value>
   </data>
+  <metadata name="mgMeasureComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>412, 173</value>
+  </metadata>
+  <data name="mgMeasureComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAABjSURBVDhPY2AY+sDGxuY/Ob6A64MxiDUIQz1IgFwMdjlV
+        XEBRGJCjGUXPxCC2VfVBbP/QMVD8PzZxmBhIH9ggkMD/Fyn/F5ea/SeFBumDG/D9FNt/UjDIIrgBFHuB
+        4kAccAMAwje0sEjeZewAAAAASUVORK5CYII=
+</value>
+  </data>
   <data name="toolStripMenuItem11.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -788,6 +576,24 @@
         RK5CYII=
 </value>
   </data>
+  <metadata name="mgQueryComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>238, 173</value>
+  </metadata>
+  <data name="mgQueryComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAJcEhZcwAADrwAAA68AZW8ckkAAAHySURBVDhPnZPLSxtRFMb9T6rUTW3Ulmw0GhqMNk0wSqCO
+        YhnNIkZUjCKUgvj4C7rSlUtXQksKRUHQxk0XhYpF8IETkpiHjxiT0TgTI0nm6z0DloxJbOmFj3Mf5/7u
+        me8wVVVFY2hyasLmcPjr6l8o1TW1eKZrVGhN+8V5ZeedbznB1PEGS5+82No/xHd/QI1Ln71oNppgc3D+
+        ipCuHk74uLCIH4EQdiIx/GLaDkfx8zii6ujsHIPDI6C8EsjY+w8TbRYbdo7D2D89Qzx9A+nuTp3vxk7+
+        aDsYQqupDZSvgXRz/cLK6hqOzuOIiSIKioLrTAZC/AKH7OViLXu/oJt7UIWu4aVyEI0hnEwhm8tBYYAT
+        8QrBxCUCD7QXieI5M1hTwZPqpwhfJnF6da1eTkqyCoimxBKFLhKg7mgAOkaMsIPEjaRepkg+lFOQ+UL5
+        GgD3jhfWv/kgypm/yvt1FZSvAUxPz3qaDUbI2Sxk5n45kTepdBpNhlZQfkkr+/oG/J7JKci3t8gVCiWS
+        WFdGx8bBDzhhbn+t9eCexvO88Ir12efbgsS8yOfzLErY2NiEocWI3t5+2O12uN3uypDZ+XkPgepZa6k7
+        FGlN+/SyXq+H1WqFy+WqDHnsp7mHWCwWOJ2PfM6/QMxm8/9VQXCqhDQzM4ffTfzkLal2r4sAAAAASUVO
+        RK5CYII=
+</value>
+  </data>
   <data name="toolStripMenuItem27.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -796,15 +602,38 @@
 </value>
   </data>
-  <data name="toolStripButton13.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+  <metadata name="mgThemeComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>903, 173</value>
+  </metadata>
+  <data name="mgThemeComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
+        R0lGODlhEAAQAIMAAAAAAP///6e6zXG39mCc0bzd+87trIC4QpfYTv/eStm9P//vqmdnZywsLP///wAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAAOACwAAAAAEAAQAAAIeQAdCBxIsKADBggTIjQokIGBhxAb
+        MDxoAIFFBAckMnRoUaFCghwRMFhAsqTGhhVFLkjAMoGCkxQPHBjJ0qPCBjhpJmBQoKfPBgKCCtDJc4DR
+        AQRgjlSgoOjRpCBxNnBqFOpAoUMLHEUKE2QBAmDBdh3IQKrZiVixBgQAOw==
+</value>
+  </data>
+  <data name="toolStripMenuItem31.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAJcEhZcwAADr4AAA6+AepCscAAAAC0SURBVDhPrZPLCsIwEEXzXeKyS/0bQUFxISiKK8EH/TXF
 </value>
   </data>
+  <metadata name="mgViewerOptionsComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 173</value>
+  </metadata>
+  <data name="mgViewerOptionsComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        QtRiKBaLSqyrkQnkgovCkBg4zFyYOYRAlIo9raSTtpMuhcC7ihfPuQGD2Yak8K4TxOAEoQc3OGQnkrI/
+        avJAkOmcepMV4CwBAn0x1J+u6fmyrvrMfRM8A0F+LX5enrMECExRUggQ3MqKhvMt4CwBgnv1oNFiR3X9
+        cdVn7pvgGQj48cbLFHCWAIG1bwrhP4LY3/gFpD/IGPp59QYAAAAASUVORK5CYII=
+</value>
+  </data>
   <data name="toolStripMenuItem8.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -820,7 +649,7 @@
 </value>
   </data>
   <metadata name="plotToDwfComponent.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>429, 56</value>
+    <value>211, 56</value>
   </metadata>
   <data name="plotToDwfComponent.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -851,7 +680,7 @@
 </value>
   </data>
   <metadata name="loadCompactViewerComponent.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 134</value>
+    <value>960, 56</value>
   </metadata>
   <data name="loadCompactViewerComponent.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -882,7 +711,7 @@
 </value>
   </data>
   <metadata name="profileComponent.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 173</value>
+    <value>425, 95</value>
   </metadata>
   <data name="profileComponent.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -898,9 +727,6 @@
         RU5ErkJggg==
 </value>
   </data>
-  <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 329</value>
-  </metadata>
   <data name="toolStripMenuItem5.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
     <value>
@@ -944,11 +770,247 @@
 </value>
   </data>
-  <metadata name="statusBar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>237, 17</value>
+  <metadata name="mgLoadMapComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>1081, 173</value>
   </metadata>
+  <data name="toolStripMenuItem1.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIMAAAAAAP///ydYF5fYTmBfDJlmAGYzALWEU8yZZtSmeP/jyP///wAAAAAAAAAAAAAA
+        ACH/C05FVFNDQVBFMi4wAwEBAAAh+QQBAAALACwAAAAAEAAQAAAIcwAXCBxIcIGAgwUTGhQQAKHAAhAj
+        FiDAcMAAhBATINioAEFFixchKhhJUsFBARcPFtC4kWNLlAIMLFiZoGZNBTZhyixwoKdPBT51zvT5M+jF
+        nSWTmjy4k2hPoE6bOoVKVCpRqj6tFo0604DXr2DBKhwrMCAAOw==
+</value>
+  </data>
+  <metadata name="mgLoadPackageComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>1019, 95</value>
+  </metadata>
+  <data name="mgLoadPackageComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="toolStripMenuItem2.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="toolStripMenuItem3.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="toolStripMenuItem4.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        RK5CYII=
+</value>
+  </data>
+  <data name="toolStripMenuItem28.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="toolStripMenuItem12.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="toolStripMenuItem13.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="toolStripMenuItem14.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAIESURBVDhPnZPNSxtRFMX9T2ppN7axH2SjqaGpsU0TjJJi
+        RhsZm0WaUqVRBCmIMX9BV3Xl0pWgpFAsFNS46aJQsRRqxQkx5sPPmIzGmRhJMsd3B6ZkTCPFgcN9783h
+        9+6cyzQ0VD2vR0aHHS5X9E7zA6Xx5m00Ge4rtKfzat8/1509nGB5+hzTc2GsrG/gWzSm1un5MFrNFjhc
+        XLQupMvNCR8+TuF7LI61ZBo/mVYTKfzYTqra3NvHqzdvQb4ayNDY++F2mwNr2wms7+7hIH8K6fwcTzrs
+        +JXe+avVrTjaLO0gvw7SzXmE2YUv2Nw/QFoUUVEUnBQKKmCD3VytmfAndHOXujDce6j8SaWRyOZQLJWg
+        MMCOeKwCYpkjnX4nU7jLAtZ1cKPxFhJHWewen6CH68cLtwcu90sVQFVTKicifpgBTUcHMDBikr3InErI
+        SrJaKQcCUK3WFsuI/DoA188LX5cjEOWCTgS4fBb+vADy6wDj48FAq8kMuViEzNLXRABtTdnk8nm0mNpA
+        /ppR9vUNRAMjo5DPzlCqVGoksakMDr0DP+CFteOZPgONxvO88JjNORJZgcSyKJfLrEpYXFyC6ZEZvb0e
+        OJ1O+P3++pBgKBQgUDMbLU2HKu3pnG42Go2w2+3w+Xz1IVf9NBrEZrPB673ic/4HYrVar9cFwakT0sTE
+        JC4A2evLqnFhjAkAAAAASUVORK5CYII=
+</value>
+  </data>
+  <data name="toolStripMenuItem15.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAH5SURBVDhPnZPLSxtRFMb9T2qpm7ZRW7KpqaHBaNMEU0kx
+        o42MZpGmqDSKIIL4+Atc6cplVwUlhWKhoMaNi0LFUvCBE5KYh48Yk9E4EyNJ5vOegJIxiS0d+Dj33vn4
+        3TPfYWpqSp4PwyNDFpvN/6T+mVL7sA6PNY0K7em81Fdx3d7JCYa2N5hf8GJtexfr/kCxzi960aQ3wGLj
+        /FUhb+2cMDM7h5+BEDYjMfxm2ghH8Ws/UtTe0TH6PvaDfGWQwdGxoRaTBZv7YWwfHiGevoB0dVVc/4kd
+        3GojGEKzoQXkV0E6OIfwZek79o7jiIkiCoqC80wGQvwEu+zmUn32fkUHd6cLTcNzZScaQziZQjaXg8IA
+        B+IZgolTBO5oKxLFUxawqoMHtY8QPk3i8OwcnVwP3tkdsNnflymaEhE6SYCmowJoGDHCXiQuJCQluVgp
+        h0oKslzIrwJwPbzwY9UHUc78Vd5vSyC/CjA+Pulp0ukhZ7OQWfqVRNmk0mm80DWD/GWj7O7u9XuGRyBf
+        XiJXKJRJYlMZGPwEvtcJY+trdQY3NJ7nhVdszj7fGiSWRT6fZ1XC8vIKdC/16OpywGq1wu12V4dMTk97
+        CFTPRkvToUp7OqebtVotzGYzXC5Xdch9P80NxGQywem853P+BWI0Gv+vC4JTJ6SJiSlcA6LH15rL3j8W
+        AAAAAElFTkSuQmCC
+</value>
+  </data>
+  <data name="toolStripMenuItem16.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        R0lGODlhEAAQAIZvAISChAEBAXBJJai7zsfb8Nrn9M/a5Nnm81tgZNDh8sXa77jH16jR4+fu9dDh8brT
+        7erv89jm8uzw9ODq9Ku0vNHh8mRrcvT3+aStttri6oOGiJqbncrc7oaKjZ+fn9Di6JSVl67C1a6yt5u2
+        0F5cWsjd5IiOlM3U2Tg3N398ezAvLujjjKCnr5u83uXq73V5fnh3d+nv9OLaid/s76/N6pyzy9fn65mi
+        rLCurXahzJDO1tfb3+Do8dDg8UdKTb7L2EpMTFhYWZy20K22v6jG5KWqsaq8z+7sj7C/z6amp6C50uLr
+        9evw9aTF52RgX250esjQ2ISAf2xtb7S3u+Tr8WBocMPT43yQo7vU7cbb7+Hr9JGRkt7m7YSFiL7H0cza
+        6IWUo7bBzeqxd6uvs6uoqOLs9c7X31xbXbe/x+fs8evv84SHi8vY5XyPoq7L5wAAAAAAAAAAAAAAAAAA
+        AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH/C05FVFNDQVBFMi4wAwEBAAAh+QQB
+        AABvACwAAAAAEAAQAAAIwgABvBFIcOCbgwgTJsQRxUkKMgkFBpj4xsMULz/CFNmiMMCRNxugcEkTg8cX
+        JGsOSlyRRAQENRcaTIjAAQwIhAFkwDghIQMVLQd6KKhxxuBEEi6YsLFSoIKCB0RQKJSyo0GZAgmyMKAh
+        xIfBNwFMjFlywAEBBjqaXHmCcwaaLmYSEMDSIoeSKhSM2njDQsONEG5GtLGAIGGADyXeDOkQRAWQFxgQ
+        CBAjECxFAwuMLDDwZoAAAQpDI/RcsHToAaJTvwkIADs=
+</value>
+  </data>
+  <metadata name="mgZoomToSelectionComponent1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>590, 134</value>
+  </metadata>
+  <data name="mgZoomToSelectionComponent1.Icon" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="toolStripMenuItem17.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAFqSURBVDhPpZPbTsJAEIZ5NaPxAXgI5UK50Qt9LmPSeBYQ
+        g2gFEWiVIsUWSjm2pdfjzOyyFbyrF1/+Ofwz2c1mMztb2bPd7SykgWYzNOj5k1TQLC+o6K1UqAXVmgHV
+        Whsh3Yhf23+uJ7yizifQGx/w8kaYoKOu0cAakts7Uot09pnJgnqzA2u0MCdk/Vy7Y3Nu/5i13vrknjpB
+        0/iCpokYXQHFTBe0yyIbtYsCvGNOMSnNqAWm1QezYyOoGBsE5lfXJTaRmpbsr3zoVQss2wGr54JlIz2K
+        Hbi5f2TDLSr1OrLOPo7dZIHteEDQAGmx9MRxoVThXDAU+i3yvvTzK7hDH1xvzEP5gxPWh/IzDLDmeqJH
+        DCgekgrUFfzxDEbjqXqm/OEp5z4yot6EFFmp7KkF0/kCiM3/MJ0HXBesYqmzIDnBIgxhEUYQICIWeQLm
+        AeYbqBNEyxii5RKJIWRF4qTG/VjWf3l5wX+/8w9/3Qe1qQ/dtwAAAABJRU5ErkJggg==
+</value>
+  </data>
+  <data name="toolStripMenuItem18.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="toolStripMenuItem19.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAACcSURBVDhPY2BMZZzJmMb4nywM1MsA0rjxRDMcv//y7D8I
+        I4vhYoP0YjXA0t6DKEPwGkCMIXgN+PPn739ChuA14NWb9/9BGJ8heA34+u37fxjGZQheA/6jAWyGEG0A
+        SDMMI0cxQQNAmkAAZjt6+iAYjcgGfPz6EiNxEUxIIBvRXYGcKrEaAFIAcyrZBqDnDZKikZhMBFMD8QKF
+        2RkA39ChmP3112gAAAAASUVORK5CYII=
+</value>
+  </data>
+  <data name="toolStripMenuItem20.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="toolStripMenuItem21.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="toolStripMenuItem22.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
+  <data name="toolStripMenuItem23.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+        RK5CYII=
+</value>
+  </data>
+  <data name="toolStripMenuItem24.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+    <value>
+</value>
+  </data>
   <metadata name="mgLayerSelectionHandler1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>122, 329</value>
+    <value>705, 173</value>
   </metadata>
   <metadata name="$this.TrayHeight" type="System.Int32, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
     <value>111</value>
Modified: branches/2.4/MgDev/Desktop/MgAppLayout/Sheboygan.AppLayout
--- branches/2.4/MgDev/Desktop/MgAppLayout/Sheboygan.AppLayout	2012-05-29 13:59:28 UTC (rev 6707)
+++ branches/2.4/MgDev/Desktop/MgAppLayout/Sheboygan.AppLayout	2012-05-30 12:54:00 UTC (rev 6708)
@@ -99,6 +99,15 @@
       </ItemBase>
       <ItemBase xsi:type="SeparatorItem" />
       <ItemBase xsi:type="CommandItem">
+        <ComponentID>ZoomPrev</ComponentID>
+        <ShowLabel>false</ShowLabel>
+      </ItemBase>
+      <ItemBase xsi:type="CommandItem">
+        <ComponentID>ZoomNext</ComponentID>
+      </ItemBase>
+      <ItemBase xsi:type="SeparatorItem" />
         <ComponentID>Select</ComponentID>
       </ItemBase>
@@ -409,10 +418,18 @@
       <ClassName>OSGeo.MapGuide.Viewer.MgZoomInComponent</ClassName>
     </ComponentDefinition>
     <ComponentDefinition>
+      <ClassName>OSGeo.MapGuide.Viewer.MgZoomNextComponent</ClassName>
+    </ComponentDefinition>
+    <ComponentDefinition>
       <ComponentID>ZoomOut</ComponentID>
       <ClassName>OSGeo.MapGuide.Viewer.MgZoomOutComponent</ClassName>
+      <ClassName>OSGeo.MapGuide.Viewer.MgZoomPreviousComponent</ClassName>
       <ComponentID>ZoomToSelection</ComponentID>
       <ClassName>OSGeo.MapGuide.Viewer.MgZoomToSelectionComponent</ClassName>
More information about the mapguide-commits mailing list
