[mapguide-commits] r6710 - in branches/2.4/MgDev: Common/Foundation/Data Common/Foundation/System Common/MapGuideCommon/Resources Common/PlatformBase/Services Server/src/Services/Feature Server/src/UnitTesting
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu May 31 00:54:06 PDT 2012
Author: jng
Date: 2012-05-31 00:54:05 -0700 (Thu, 31 May 2012)
New Revision: 6710
   branches/2.4/MgDev/Common/Foundation/Data/NamedCollection.cpp
   branches/2.4/MgDev/Common/Foundation/System/Util.h
   branches/2.4/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
   branches/2.4/MgDev/Common/PlatformBase/Services/FeatureReader.cpp
   branches/2.4/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
   branches/2.4/MgDev/Server/src/UnitTesting/UnitTesting.cpp
   branches/2.4/MgDev/Server/src/UnitTesting/UnitTesting.vcxproj
#2013: Improve the quality of common exception messages. Also includes a new unit test to exercise some of the common exception macros.
Modified: branches/2.4/MgDev/Common/Foundation/Data/NamedCollection.cpp
--- branches/2.4/MgDev/Common/Foundation/Data/NamedCollection.cpp	2012-05-30 13:06:57 UTC (rev 6709)
+++ branches/2.4/MgDev/Common/Foundation/Data/NamedCollection.cpp	2012-05-31 07:54:05 UTC (rev 6710)
@@ -111,7 +111,11 @@
     MgNamedSerializable* item = FindItem(name);
     if (!item)
-        throw new MgObjectNotFoundException(L"GetItem", __LINE__, __WFILE__, NULL, L"", NULL); // EXC::Create(Exception::NLSGetMessage(NLSID(38_ITEMNOTFOUND),name));
+		MgStringCollection args;
+		args.Add(name);
+        throw new MgObjectNotFoundException(L"GetItem", __LINE__, __WFILE__, NULL, L"MgNoNameForObject", &args); // EXC::Create(Exception::NLSGetMessage(NLSID(38_ITEMNOTFOUND),name));
     return item;
Modified: branches/2.4/MgDev/Common/Foundation/System/Util.h
--- branches/2.4/MgDev/Common/Foundation/System/Util.h	2012-05-30 13:06:57 UTC (rev 6709)
+++ branches/2.4/MgDev/Common/Foundation/System/Util.h	2012-05-31 07:54:05 UTC (rev 6710)
@@ -583,15 +583,19 @@
 #define CHECKNULL(pointer, methodname)      \
 if (pointer == NULL)     \
+	MgStringCollection args; \
+	args.Add(L#pointer); \
     throw new MgNullReferenceException(methodname, \
-                                       __LINE__, __WFILE__, NULL, L"", NULL); \
+                                       __LINE__, __WFILE__, NULL, L"MgNullPointer", &args); \
 #define CHECKARGUMENTNULL(pointer, methodname)      \
     throw new MgNullArgumentException(methodname, \
+                                       __LINE__, __WFILE__, NULL, L"MgNullArgument", &args); \
 #define MG_CHECK_RANGE(value, min, max, methodName)                           \
@@ -599,8 +603,12 @@
         if (NULL != methodName)                                               \
+			args.Add(L#min);												  \
+			args.Add(L#max);												  \
+			args.Add(L#value);												  \
             throw new MgArgumentOutOfRangeException(                          \
-                methodName, __LINE__, __WFILE__, NULL, L"", NULL);            \
+                methodName, __LINE__, __WFILE__, NULL, L"MgArgumentOutOfRange", &args); \
         else if (value < min)                                                 \
Modified: branches/2.4/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res
--- branches/2.4/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res	2012-05-30 13:06:57 UTC (rev 6709)
+++ branches/2.4/MgDev/Common/MapGuideCommon/Resources/mapguide_en.res	2012-05-31 07:54:05 UTC (rev 6710)
@@ -157,6 +157,7 @@
 [ErrorDescription]
 MgArgumentsMismatch                                   = The arguments needed do not match the arguments provided.
+MgArgumentOutOfRange                                  = Argument out of range [%1, %2]: %3
 MgClassWOIdentity                                     = A class definition has no identity property.
 MgCollectionEmpty                                     = The collection cannot be empty.
 MgCoordinateSystemNotReadyException                   = The object is not ready for this operation.
@@ -298,6 +299,9 @@
 MgMissingSrs                                          = No coordinate system specified.
 MgNameNotFound                                        = The name was not found.
 MgNoDataFromRenderer                                  = No data from renderer.
+MgNoNameForObject                                     = No object found for name (%1)
+MgNullArgument                                        = Null argument: %1
+MgNullPointer                                         = Null pointer: %1
 MgPropertyValuesEmpty                                 = The property values cannot be empty.
 MgReaderIdNotFound                                    = The reader ID was not found.
 MgRepositoryAlreadyOpened                             = The repository is already opened by another process (e.g. If you are running the server interactively as an application from the command line, are you also running the server as a service?).
Modified: branches/2.4/MgDev/Common/PlatformBase/Services/FeatureReader.cpp
--- branches/2.4/MgDev/Common/PlatformBase/Services/FeatureReader.cpp	2012-05-30 13:06:57 UTC (rev 6709)
+++ branches/2.4/MgDev/Common/PlatformBase/Services/FeatureReader.cpp	2012-05-31 07:54:05 UTC (rev 6710)
@@ -75,7 +75,9 @@
     else
-        throw new MgObjectNotFoundException(L"MgFeatureReader.GetPropertyIndex", __LINE__, __WFILE__, NULL, L"", NULL);
+		args.Add(propertyName);
+        throw new MgObjectNotFoundException(L"MgFeatureReader.GetPropertyIndex", __LINE__, __WFILE__, NULL, L"MgNoNameForObject", &args);
         return -1; // to suppress compiler warning.
Modified: branches/2.4/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
--- branches/2.4/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp	2012-05-30 13:06:57 UTC (rev 6709)
+++ branches/2.4/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp	2012-05-31 07:54:05 UTC (rev 6710)
@@ -1263,8 +1263,13 @@
             if (NULL == classFound.p)
+				STRING qualifiedName = currSchemaName;
+				qualifiedName += L":";
+				qualifiedName += currClassName;
+				args.Add(qualifiedName);
                 throw new MgObjectNotFoundException(L"DescribeWfsFeatureType",
+                    __LINE__, __WFILE__, NULL, L"MgNoNameForObject", &args);
             else
Modified: branches/2.4/MgDev/Server/src/UnitTesting/UnitTesting.cpp
--- branches/2.4/MgDev/Server/src/UnitTesting/UnitTesting.cpp	2012-05-30 13:06:57 UTC (rev 6709)
+++ branches/2.4/MgDev/Server/src/UnitTesting/UnitTesting.cpp	2012-05-31 07:54:05 UTC (rev 6710)
@@ -53,6 +53,7 @@
             runner.addTest(CppUnit::TestFactoryRegistry::getRegistry("TestMdfModel").makeTest());
             runner.addTest(CppUnit::TestFactoryRegistry::getRegistry("TestKmlService").makeTest());
             runner.addTest(CppUnit::TestFactoryRegistry::getRegistry("TestMappingService").makeTest());
+			runner.addTest(CppUnit::TestFactoryRegistry::getRegistry("TestMisc").makeTest());
             runner.addTest(CppUnit::TestFactoryRegistry::getRegistry("TestRenderingService").makeTest());
             runner.addTest(CppUnit::TestFactoryRegistry::getRegistry("TestResourceService").makeTest());
             runner.addTest(CppUnit::TestFactoryRegistry::getRegistry("TestTileService").makeTest());
@@ -82,6 +83,7 @@
             ACE_OS::printf("  LogManager\n");
             ACE_OS::printf("  MappingService\n");
             ACE_OS::printf("  MdfModel\n");
+			ACE_OS::printf("  Misc\n");
             ACE_OS::printf("  Performance\n");
             ACE_OS::printf("  RenderingService\n");
             ACE_OS::printf("  ResourceService\n");
@@ -132,6 +134,11 @@
             ACE_DEBUG((LM_INFO, ACE_TEXT(">>>>> Running only MdfModel tests. <<<<<\n\n")));
+		else if(ACE_OS::strcasecmp(MG_WCHAR_TO_TCHAR(test), ACE_LIB_TEXT("Misc")) == 0)
+            ACE_DEBUG((LM_INFO, ACE_TEXT(">>>>> Running only Miscellaneous tests. <<<<<\n\n")));
         else if(ACE_OS::strcasecmp(MG_WCHAR_TO_TCHAR(test), ACE_LIB_TEXT("Performance")) == 0)
             ACE_DEBUG((LM_INFO, ACE_TEXT(">>>>> Running only Performance tests. <<<<<\n\n")));
@@ -209,6 +216,7 @@
Modified: branches/2.4/MgDev/Server/src/UnitTesting/UnitTesting.vcxproj
--- branches/2.4/MgDev/Server/src/UnitTesting/UnitTesting.vcxproj	2012-05-30 13:06:57 UTC (rev 6709)
+++ branches/2.4/MgDev/Server/src/UnitTesting/UnitTesting.vcxproj	2012-05-31 07:54:05 UTC (rev 6710)
@@ -201,6 +201,7 @@
     <ClInclude Include="TestLogManagerThread.h" />
     <ClInclude Include="TestMappingService.h" />
     <ClInclude Include="TestMdfModel.h" />
+    <ClInclude Include="TestMisc.h" />
     <ClInclude Include="TestPerformance.h" />
     <ClInclude Include="TestProfilingService.h" />
     <ClInclude Include="TestRenderingService.h" />
@@ -223,6 +224,7 @@
     <ClCompile Include="TestLogManagerThread.cpp" />
     <ClCompile Include="TestMappingService.cpp" />
     <ClCompile Include="TestMdfModel.cpp" />
+    <ClCompile Include="TestMisc.cpp" />
     <ClCompile Include="TestPerformance.cpp" />
     <ClCompile Include="TestProfilingService.cpp" />
     <ClCompile Include="TestRenderingService.cpp" />
More information about the mapguide-commits mailing list
