[mapguide-commits] r7183 - in trunk/Tools/Maestro: Maestro.Base Maestro.Base/Editor Maestro.Base/Events Maestro.Base/Services Maestro.Base/UI Maestro.Base/UI/Preferences Maestro.Editors/Common Maestro.MapViewer
svn_mapguide at osgeo.org
Fri Nov 2 04:16:16 PDT 2012
Author: jng
Date: 2012-11-02 04:16:16 -0700 (Fri, 02 Nov 2012)
New Revision: 7183
Added:
trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.cs
trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.resx
trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs
trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs
trunk/Tools/Maestro/Maestro.Base/UI/Preferences/ConfigProperties.cs
trunk/Tools/Maestro/Maestro.Base/UI/Preferences/EditorPreferencesCtrl.Designer.cs
trunk/Tools/Maestro/Maestro.Base/UI/Preferences/EditorPreferencesCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/Common/RepositoryTreeModel.cs
trunk/Tools/Maestro/Maestro.MapViewer/Interfaces.cs
trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs
#2167: Implement MapViewer-driven previews for resources that it can be applicable to (Layer Definitions, Watermarks, Map Definitions). The choice to use MapViewer previews is controlled by a new UseLocalPreview configuration property, configurable via Tools - Options.
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs 2012-11-02 05:31:02 UTC (rev 7182)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -285,11 +285,7 @@
if (res != null)
var type = res.CurrentConnection.ProviderName;
- var previewer = ResourcePreviewerFactory.GetPreviewer(type);
- if (previewer != null)
- return previewer.IsPreviewable(res);
+ return ResourcePreviewerFactory.IsPreviewable(type, res);
return false;
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs 2012-11-02 05:31:02 UTC (rev 7182)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/ResourcePreviewEngine.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -73,28 +73,18 @@
var sessionId = _edSvc.SessionID;
var conn = res.CurrentConnection;
- //Create temp map definition to house our current layer
- var mdfId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".MapDefinition"; //NOXLATE
- string csWkt;
- var extent = ldf.GetSpatialExtent(true, out csWkt);
- //TODO: Based on the visible scales in this layer, size this extents accordingly
- var mdf = ObjectFactory.CreateMapDefinition(conn, Strings.PreviewMap, csWkt, extent);
- var layer = mdf.AddLayer(null, ResourceIdentifier.GetName(_edSvc.ResourceID), ldf.ResourceID);
+ string layerName = string.Empty;
//Use feature source as name/label if new and unsaved
if (_edSvc.IsNew)
- layer.Name = layer.LegendLabel = ResourceIdentifier.GetName(ldf.SubLayer.ResourceId);
+ layerName = ResourceIdentifier.GetName(ldf.SubLayer.ResourceId);
else
- layer.Name = layer.LegendLabel = ResourceIdentifier.GetName(_edSvc.ResourceID);
+ layerName = ResourceIdentifier.GetName(_edSvc.ResourceID);
- conn.ResourceService.SaveResourceAs(mdf, mdfId);
+ var mdf = CreateLayerPreviewMapDefinition(ldf, sessionId, layerName, conn);
if (PropertyService.Get(ConfigProperties.PreviewViewerType, "AJAX").Equals("AJAX")) //NOXLATE
//Create temp web layout to house this map
- var wl = ObjectFactory.CreateWebLayout(_edSvc.GetEditedResource().CurrentConnection, new Version(1, 0, 0), mdfId);
+ var wl = ObjectFactory.CreateWebLayout(_edSvc.GetEditedResource().CurrentConnection, new Version(1, 0, 0), mdf.ResourceID);
//Add a custom zoom command (to assist previews of layers that aren't [0, infinity] scale)
AttachPreviewCommands(wl);
@@ -119,6 +109,22 @@
return url;
+ internal static IMapDefinition CreateLayerPreviewMapDefinition(ILayerDefinition ldf, string sessionId, string layerName, IServerConnection conn)
+ //Create temp map definition to house our current layer
+ var mdfId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".MapDefinition"; //NOXLATE
+ string csWkt;
+ var extent = ldf.GetSpatialExtent(true, out csWkt);
+ //TODO: Based on the visible scales in this layer, size this extents accordingly
+ var mdf = ObjectFactory.CreateMapDefinition(conn, Strings.PreviewMap, csWkt, extent);
+ var layer = mdf.AddLayer(null, layerName, ldf.ResourceID);
+ conn.ResourceService.SaveResourceAs(mdf, mdfId);
+ mdf.ResourceID = mdfId;
+ return mdf;
private static void AttachPreviewCommands(IWebLayout wl)
var cmd = wl.CreateInvokeScriptCommand();
@@ -185,11 +191,17 @@
if (wmd.CurrentConnection.SiteVersion < new Version(2, 3))
throw new InvalidOperationException(Strings.SiteVersionDoesntSupportWatermarks);
+ IMapDefinition2 map = CreateWatermarkPreviewMapDefinition(wmd);
+ return GenerateMapPreviewUrl(map, locale);
+ internal static IMapDefinition2 CreateWatermarkPreviewMapDefinition(IWatermarkDefinition wmd)
IMapDefinition2 map = (IMapDefinition2)ObjectFactory.CreateMapDefinition(wmd.CurrentConnection, wmd.SupportedMapDefinitionVersion, "Watermark Definition Preview"); //NOXLATE
map.CoordinateSystem = @"LOCAL_CS[""*XY-M*"", LOCAL_DATUM[""*X-Y*"", 10000], UNIT[""Meter"", 1], AXIS[""X"", EAST], AXIS[""Y"", NORTH]]"; //NOXLATE
map.Extents = ObjectFactory.CreateEnvelope(-1000000, -1000000, 1000000, 1000000);
map.AddWatermark(wmd);
- return GenerateMapPreviewUrl(map, locale);
+ return map;
private string GenerateMapPreviewUrl(IResource res, string locale)
Modified: trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs
--- trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs 2012-11-02 05:31:02 UTC (rev 7182)
+++ trunk/Tools/Maestro/Maestro.Base/Events/EventWatcher.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -28,6 +28,7 @@
using ICSharpCode.Core;
using System.Windows.Forms;
using Maestro.Shared.UI;
+using Maestro.Base.UI.Preferences;
namespace Maestro.Base.Events
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2012-11-02 05:31:02 UTC (rev 7182)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2012-11-02 11:16:16 UTC (rev 7183)
@@ -318,6 +318,12 @@
<Compile Include="UI\LabelLocalizationDialog.Designer.cs">
<DependentUpon>LabelLocalizationDialog.cs</DependentUpon>
</Compile>
+ <Compile Include="UI\MapPreviewDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="UI\MapPreviewDialog.Designer.cs">
+ <DependentUpon>MapPreviewDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="UI\MessageViewer.cs">
<SubType>UserControl</SubType>
</Compile>
@@ -591,6 +597,9 @@
<EmbeddedResource Include="UI\LabelLocalizationDialog.resx">
</EmbeddedResource>
+ <EmbeddedResource Include="UI\MapPreviewDialog.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="UI\MessageViewer.resx">
<DependentUpon>MessageViewer.cs</DependentUpon>
<SubType>Designer</SubType>
@@ -662,6 +671,10 @@
<Project>{07588440-5F9F-4C30-AA06-9CF30BA6DDE6}</Project>
<Name>Maestro.Login</Name>
</ProjectReference>
+ <ProjectReference Include="..\Maestro.MapViewer\Maestro.MapViewer.csproj">
+ <Project>{4F9658DE-D16F-4B40-B830-BB1E0136DBD7}</Project>
+ <Name>Maestro.MapViewer</Name>
+ </ProjectReference>
<ProjectReference Include="..\Maestro.Packaging\Maestro.Packaging.csproj">
<Project>{0EA33E36-9C33-4D60-B378-B87FADAA0F40}</Project>
<Name>Maestro.Packaging</Name>
Modified: trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs 2012-11-02 05:31:02 UTC (rev 7182)
+++ trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -30,6 +30,12 @@
using OSGeo.MapGuide.ObjectModels;
using OSGeo.MapGuide.MaestroAPI.Services;
using Maestro.Editors.SymbolDefinition;
+using ICSharpCode.Core;
+using OSGeo.MapGuide.ObjectModels.MapDefinition;
+using OSGeo.MapGuide.ObjectModels.WatermarkDefinition;
+using Maestro.Base.UI;
+using OSGeo.MapGuide.MaestroAPI.Mapping;
namespace Maestro.Base.Services
@@ -65,6 +71,106 @@
void Preview(IResource res, IEditorService edSvc, string locale);
+ public class LocalMapPreviewer : IResourcePreviewer
+ private IResourcePreviewer _inner;
+ public LocalMapPreviewer(IResourcePreviewer inner)
+ _inner = inner;
+ public bool UseLocal
+ get { return PropertyService.Get(ConfigProperties.UseLocalPreview, ConfigProperties.DefaultUseLocalPreview); }
+ public bool IsPreviewable(IResource res)
+ if (this.UseLocal)
+ if (IsLocalPreviewableType(res))
+ return true;
+ return _inner.IsPreviewable(res);
+ private static bool IsLocalPreviewableType(IResource res)
+ return res.ResourceType == ResourceTypes.LayerDefinition ||
+ res.ResourceType == ResourceTypes.MapDefinition ||
+ res.ResourceType == ResourceTypes.WatermarkDefinition;
+ public void Preview(IResource res, IEditorService edSvc)
+ Preview(res, edSvc, null);
+ static bool SupportsMappingService(IServerConnection conn)
+ return Array.IndexOf(conn.Capabilities.SupportedServices, (int)ServiceType.Mapping) >= 0;
+ public void Preview(IResource res, IEditorService edSvc, string locale)
+ IServerConnection conn = res.CurrentConnection;
+ if (this.UseLocal && IsLocalPreviewableType(res) && SupportsMappingService(conn))
+ BusyWaitDialog.Run(Strings.PrgPreparingResourcePreview, () => {
+ IMappingService mapSvc = (IMappingService)conn.GetService((int)ServiceType.Mapping);
+ IMapDefinition previewMdf = null;
+ switch (res.ResourceType)
+ case ResourceTypes.LayerDefinition:
+ ILayerDefinition ldf = (ILayerDefinition)res;
+ if (edSvc.IsNew)
+ else
+ layerName = ResourceIdentifier.GetName(edSvc.ResourceID);
+ previewMdf = ResourcePreviewEngine.CreateLayerPreviewMapDefinition(ldf, edSvc.SessionID, layerName, conn);
+ break;
+ case ResourceTypes.WatermarkDefinition:
+ previewMdf = ResourcePreviewEngine.CreateWatermarkPreviewMapDefinition((IWatermarkDefinition)res);
+ break;
+ case ResourceTypes.MapDefinition:
+ previewMdf = (IMapDefinition)res;
+ break;
+ if (previewMdf != null)
+ return mapSvc.CreateMap(previewMdf);
+ else
+ return null;
+ }, (obj) => {
+ if (obj != null)
+ var rtMap = (RuntimeMap)obj;
+ var launcher = ServiceRegistry.GetService<UrlLauncherService>();
+ var diag = new MapPreviewDialog(rtMap, launcher, (edSvc.IsNew) ? null : edSvc.ResourceID);
+ diag.Show(null);
+ else //Fallback, shouldn't happen
+ _inner.Preview(res, edSvc, locale);
+ else
/// <summary>
/// The default resource previewer implementation
/// </summary>
@@ -211,7 +317,7 @@
/// <param name="previewer">The previewer implementation</param>
public static void RegisterPreviewer(string provider, IResourcePreviewer previewer)
- _previewers[provider.ToUpper()] = previewer;
+ _previewers[provider.ToUpper()] = new LocalMapPreviewer(previewer);
/// <summary>
@@ -223,7 +329,22 @@
return _previewers.ContainsKey(provider.ToUpper());
+ /// <summary>
+ /// Gets whether the given resource type is previewable for the given connection provider
+ /// </summary>
+ /// <param name="provider"></param>
+ /// <param name="resource"></param>
+ /// <returns></returns>
+ public static bool IsPreviewable(string provider, IResource resource)
+ var preview = GetPreviewer(provider);
+ if (preview != null)
+ return preview.IsPreviewable(resource);
+ return false;
/// <summary>
/// Gets the registered previewer for the specified connection provider
/// </summary>
Added: trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.Designer.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -0,0 +1,401 @@
+namespace Maestro.Base.UI
+ partial class MapPreviewDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.defaultToolbar = new Maestro.MapViewer.DefaultToolbar();
+ this.mapViewer = new Maestro.MapViewer.MapViewer();
+ this.statusStrip1 = new System.Windows.Forms.StatusStrip();
+ this.lblCoordinates = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblSelected = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblScale = new System.Windows.Forms.ToolStripStatusLabel();
+ this.splitContainer1 = new System.Windows.Forms.SplitContainer();
+ this.legend = new Maestro.MapViewer.Legend();
+ this.mapStatusTracker = new Maestro.MapViewer.MapStatusTracker();
+ this.splitContainer2 = new System.Windows.Forms.SplitContainer();
+ this.panel1 = new System.Windows.Forms.Panel();
+ this.grpOtherTools = new System.Windows.Forms.GroupBox();
+ this.btnGetMapKml = new System.Windows.Forms.Button();
+ this.lnkZoomToScale = new System.Windows.Forms.LinkLabel();
+ this.numZoomToScale = new System.Windows.Forms.NumericUpDown();
+ this.label5 = new System.Windows.Forms.Label();
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.txtMaxY = new System.Windows.Forms.TextBox();
+ this.label4 = new System.Windows.Forms.Label();
+ this.txtMaxX = new System.Windows.Forms.TextBox();
+ this.label3 = new System.Windows.Forms.Label();
+ this.txtMinY = new System.Windows.Forms.TextBox();
+ this.label2 = new System.Windows.Forms.Label();
+ this.txtMinX = new System.Windows.Forms.TextBox();
+ this.label1 = new System.Windows.Forms.Label();
+ this.statusStrip1.SuspendLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).BeginInit();
+ this.splitContainer1.Panel1.SuspendLayout();
+ this.splitContainer1.Panel2.SuspendLayout();
+ this.splitContainer1.SuspendLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer2)).BeginInit();
+ this.splitContainer2.Panel1.SuspendLayout();
+ this.splitContainer2.Panel2.SuspendLayout();
+ this.splitContainer2.SuspendLayout();
+ this.panel1.SuspendLayout();
+ this.grpOtherTools.SuspendLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numZoomToScale)).BeginInit();
+ this.groupBox1.SuspendLayout();
+ this.SuspendLayout();
+ // defaultToolbar
+ this.defaultToolbar.Location = new System.Drawing.Point(0, 0);
+ this.defaultToolbar.Name = "defaultToolbar";
+ this.defaultToolbar.Size = new System.Drawing.Size(784, 25);
+ this.defaultToolbar.TabIndex = 0;
+ this.defaultToolbar.Viewer = this.mapViewer;
+ // mapViewer
+ this.mapViewer.Cursor = System.Windows.Forms.Cursors.Default;
+ this.mapViewer.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.mapViewer.Location = new System.Drawing.Point(0, 0);
+ this.mapViewer.MaxScale = 1000000000;
+ this.mapViewer.MinScale = 10;
+ this.mapViewer.MouseWheelDelayRenderInterval = 800;
+ this.mapViewer.Name = "mapViewer";
+ this.mapViewer.PointPixelBuffer = 2;
+ this.mapViewer.SelectionColor = System.Drawing.Color.Blue;
+ this.mapViewer.Size = new System.Drawing.Size(381, 515);
+ this.mapViewer.TabIndex = 0;
+ this.mapViewer.Text = "mapViewer1";
+ this.mapViewer.TooltipDelayInterval = 1000;
+ this.mapViewer.ZoomInFactor = 0.5D;
+ this.mapViewer.ZoomOutFactor = 2D;
+ this.mapViewer.MapScaleChanged += new System.EventHandler(this.mapViewer_MapScaleChanged);
+ this.mapViewer.PropertyChanged += new System.ComponentModel.PropertyChangedEventHandler(this.mapViewer_PropertyChanged);
+ // statusStrip1
+ this.statusStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.lblCoordinates,
+ this.lblSelected,
+ this.lblScale});
+ this.statusStrip1.Location = new System.Drawing.Point(0, 540);
+ this.statusStrip1.Name = "statusStrip1";
+ this.statusStrip1.Size = new System.Drawing.Size(784, 22);
+ this.statusStrip1.TabIndex = 1;
+ this.statusStrip1.Text = "statusStrip1";
+ // lblCoordinates
+ this.lblCoordinates.Name = "lblCoordinates";
+ this.lblCoordinates.Size = new System.Drawing.Size(0, 17);
+ // lblSelected
+ this.lblSelected.Name = "lblSelected";
+ this.lblSelected.Size = new System.Drawing.Size(769, 17);
+ this.lblSelected.Spring = true;
+ this.lblSelected.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
+ // lblScale
+ this.lblScale.Name = "lblScale";
+ this.lblScale.Size = new System.Drawing.Size(0, 17);
+ // splitContainer1
+ this.splitContainer1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.splitContainer1.FixedPanel = System.Windows.Forms.FixedPanel.Panel1;
+ this.splitContainer1.Location = new System.Drawing.Point(0, 0);
+ this.splitContainer1.Name = "splitContainer1";
+ // splitContainer1.Panel1
+ this.splitContainer1.Panel1.Controls.Add(this.legend);
+ // splitContainer1.Panel2
+ this.splitContainer1.Panel2.Controls.Add(this.mapViewer);
+ this.splitContainer1.Size = new System.Drawing.Size(584, 515);
+ this.splitContainer1.SplitterDistance = 199;
+ this.splitContainer1.TabIndex = 2;
+ // legend
+ this.legend.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.legend.GroupContextMenu = null;
+ this.legend.LayerContextMenu = null;
+ this.legend.Location = new System.Drawing.Point(0, 0);
+ this.legend.Name = "legend";
+ this.legend.SelectOnRightClick = false;
+ this.legend.ShowAllLayersAndGroups = false;
+ this.legend.ShowTooltips = true;
+ this.legend.Size = new System.Drawing.Size(199, 515);
+ this.legend.TabIndex = 0;
+ this.legend.ThemeCompressionLimit = 25;
+ this.legend.Viewer = this.mapViewer;
+ // mapStatusTracker
+ this.mapStatusTracker.CoordinatesLabel = this.lblCoordinates;
+ this.mapStatusTracker.ScaleLabel = this.lblScale;
+ this.mapStatusTracker.SelectedLabel = this.lblSelected;
+ this.mapStatusTracker.Viewer = this.mapViewer;
+ // splitContainer2
+ this.splitContainer2.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.splitContainer2.FixedPanel = System.Windows.Forms.FixedPanel.Panel2;
+ this.splitContainer2.Location = new System.Drawing.Point(0, 25);
+ this.splitContainer2.Name = "splitContainer2";
+ // splitContainer2.Panel1
+ this.splitContainer2.Panel1.Controls.Add(this.splitContainer1);
+ // splitContainer2.Panel2
+ this.splitContainer2.Panel2.Controls.Add(this.panel1);
+ this.splitContainer2.Size = new System.Drawing.Size(784, 515);
+ this.splitContainer2.SplitterDistance = 584;
+ this.splitContainer2.TabIndex = 3;
+ // panel1
+ this.panel1.AutoScroll = true;
+ this.panel1.Controls.Add(this.grpOtherTools);
+ this.panel1.Controls.Add(this.groupBox1);
+ this.panel1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.panel1.Location = new System.Drawing.Point(0, 0);
+ this.panel1.Name = "panel1";
+ this.panel1.Size = new System.Drawing.Size(196, 515);
+ this.panel1.TabIndex = 1;
+ // grpOtherTools
+ this.grpOtherTools.Controls.Add(this.btnGetMapKml);
+ this.grpOtherTools.Controls.Add(this.lnkZoomToScale);
+ this.grpOtherTools.Controls.Add(this.numZoomToScale);
+ this.grpOtherTools.Controls.Add(this.label5);
+ this.grpOtherTools.Location = new System.Drawing.Point(16, 222);
+ this.grpOtherTools.Name = "grpOtherTools";
+ this.grpOtherTools.Size = new System.Drawing.Size(165, 260);
+ this.grpOtherTools.TabIndex = 1;
+ this.grpOtherTools.TabStop = false;
+ this.grpOtherTools.Text = "Other Tools";
+ // btnGetMapKml
+ this.btnGetMapKml.Location = new System.Drawing.Point(10, 108);
+ this.btnGetMapKml.Name = "btnGetMapKml";
+ this.btnGetMapKml.Size = new System.Drawing.Size(94, 23);
+ this.btnGetMapKml.TabIndex = 4;
+ this.btnGetMapKml.Text = "Get Map KML";
+ this.btnGetMapKml.UseVisualStyleBackColor = true;
+ this.btnGetMapKml.Click += new System.EventHandler(this.btnGetMapKml_Click);
+ // lnkZoomToScale
+ this.lnkZoomToScale.AutoSize = true;
+ this.lnkZoomToScale.Location = new System.Drawing.Point(93, 32);
+ this.lnkZoomToScale.Name = "lnkZoomToScale";
+ this.lnkZoomToScale.Size = new System.Drawing.Size(40, 13);
+ this.lnkZoomToScale.TabIndex = 3;
+ this.lnkZoomToScale.TabStop = true;
+ this.lnkZoomToScale.Text = "(Zoom)";
+ this.lnkZoomToScale.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkZoomToScale_LinkClicked);
+ // numZoomToScale
+ this.numZoomToScale.Location = new System.Drawing.Point(10, 48);
+ this.numZoomToScale.Name = "numZoomToScale";
+ this.numZoomToScale.Size = new System.Drawing.Size(135, 20);
+ this.numZoomToScale.TabIndex = 2;
+ // label5
+ this.label5.AutoSize = true;
+ this.label5.Location = new System.Drawing.Point(7, 32);
+ this.label5.Name = "label5";
+ this.label5.Size = new System.Drawing.Size(80, 13);
+ this.label5.TabIndex = 1;
+ this.label5.Text = "Zoom To Scale";
+ // groupBox1
+ this.groupBox1.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.groupBox1.Controls.Add(this.txtMaxY);
+ this.groupBox1.Controls.Add(this.label4);
+ this.groupBox1.Controls.Add(this.txtMaxX);
+ this.groupBox1.Controls.Add(this.label3);
+ this.groupBox1.Controls.Add(this.txtMinY);
+ this.groupBox1.Controls.Add(this.label2);
+ this.groupBox1.Controls.Add(this.txtMinX);
+ this.groupBox1.Controls.Add(this.label1);
+ this.groupBox1.Location = new System.Drawing.Point(16, 10);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.Size = new System.Drawing.Size(165, 205);
+ this.groupBox1.TabIndex = 0;
+ this.groupBox1.TabStop = false;
+ this.groupBox1.Text = "Current Extents";
+ // txtMaxY
+ this.txtMaxY.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtMaxY.Location = new System.Drawing.Point(10, 167);
+ this.txtMaxY.Name = "txtMaxY";
+ this.txtMaxY.ReadOnly = true;
+ this.txtMaxY.Size = new System.Drawing.Size(135, 20);
+ this.txtMaxY.TabIndex = 7;
+ // label4
+ this.label4.AutoSize = true;
+ this.label4.Location = new System.Drawing.Point(7, 150);
+ this.label4.Name = "label4";
+ this.label4.Size = new System.Drawing.Size(37, 13);
+ this.label4.TabIndex = 6;
+ this.label4.Text = "Max Y";
+ // txtMaxX
+ this.txtMaxX.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtMaxX.Location = new System.Drawing.Point(10, 129);
+ this.txtMaxX.Name = "txtMaxX";
+ this.txtMaxX.ReadOnly = true;
+ this.txtMaxX.Size = new System.Drawing.Size(135, 20);
+ this.txtMaxX.TabIndex = 5;
+ // label3
+ this.label3.AutoSize = true;
+ this.label3.Location = new System.Drawing.Point(7, 112);
+ this.label3.Name = "label3";
+ this.label3.Size = new System.Drawing.Size(37, 13);
+ this.label3.TabIndex = 4;
+ this.label3.Text = "Max X";
+ // txtMinY
+ this.txtMinY.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtMinY.Location = new System.Drawing.Point(10, 89);
+ this.txtMinY.Name = "txtMinY";
+ this.txtMinY.ReadOnly = true;
+ this.txtMinY.Size = new System.Drawing.Size(135, 20);
+ this.txtMinY.TabIndex = 3;
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Location = new System.Drawing.Point(7, 72);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(34, 13);
+ this.label2.TabIndex = 2;
+ this.label2.Text = "Min Y";
+ // txtMinX
+ this.txtMinX.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtMinX.Location = new System.Drawing.Point(10, 49);
+ this.txtMinX.Name = "txtMinX";
+ this.txtMinX.ReadOnly = true;
+ this.txtMinX.Size = new System.Drawing.Size(135, 20);
+ this.txtMinX.TabIndex = 1;
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(7, 32);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(34, 13);
+ this.label1.TabIndex = 0;
+ this.label1.Text = "Min X";
+ // MapPreviewDialog
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.ClientSize = new System.Drawing.Size(784, 562);
+ this.Controls.Add(this.splitContainer2);
+ this.Controls.Add(this.statusStrip1);
+ this.Controls.Add(this.defaultToolbar);
+ this.Name = "MapPreviewDialog";
+ this.Text = "Map Preview";
+ this.statusStrip1.ResumeLayout(false);
+ this.statusStrip1.PerformLayout();
+ this.splitContainer1.Panel1.ResumeLayout(false);
+ this.splitContainer1.Panel2.ResumeLayout(false);
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer1)).EndInit();
+ this.splitContainer1.ResumeLayout(false);
+ this.splitContainer2.Panel1.ResumeLayout(false);
+ this.splitContainer2.Panel2.ResumeLayout(false);
+ ((System.ComponentModel.ISupportInitialize)(this.splitContainer2)).EndInit();
+ this.splitContainer2.ResumeLayout(false);
+ this.panel1.ResumeLayout(false);
+ this.grpOtherTools.ResumeLayout(false);
+ this.grpOtherTools.PerformLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numZoomToScale)).EndInit();
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox1.PerformLayout();
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private MapViewer.DefaultToolbar defaultToolbar;
+ private System.Windows.Forms.StatusStrip statusStrip1;
+ private System.Windows.Forms.ToolStripStatusLabel lblCoordinates;
+ private System.Windows.Forms.ToolStripStatusLabel lblSelected;
+ private System.Windows.Forms.ToolStripStatusLabel lblScale;
+ private System.Windows.Forms.SplitContainer splitContainer1;
+ private MapViewer.Legend legend;
+ private MapViewer.MapViewer mapViewer;
+ private MapViewer.MapStatusTracker mapStatusTracker;
+ private System.Windows.Forms.SplitContainer splitContainer2;
+ private System.Windows.Forms.Panel panel1;
+ private System.Windows.Forms.GroupBox grpOtherTools;
+ private System.Windows.Forms.LinkLabel lnkZoomToScale;
+ private System.Windows.Forms.NumericUpDown numZoomToScale;
+ private System.Windows.Forms.Label label5;
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.TextBox txtMaxY;
+ private System.Windows.Forms.Label label4;
+ private System.Windows.Forms.TextBox txtMaxX;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.TextBox txtMinY;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.TextBox txtMinX;
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.Button btnGetMapKml;
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -0,0 +1,111 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using Maestro.Base.Services;
+using OSGeo.MapGuide.MaestroAPI;
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Globalization;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+ internal partial class MapPreviewDialog : Form
+ private RuntimeMap _map;
+ private IUrlLauncherService _launcher;
+ private IServerConnection _conn;
+ public MapPreviewDialog(RuntimeMap map, IUrlLauncherService urlLauncher, string resourceId)
+ InitializeComponent();
+ _map = map;
+ if (!string.IsNullOrEmpty(resourceId))
+ this.Text += " - " + resourceId;
+ numZoomToScale.Minimum = 1;
+ numZoomToScale.Maximum = Int32.MaxValue;
+ _launcher = urlLauncher;
+ _conn = map.CurrentConnection;
+ btnGetMapKml.Enabled = (_conn.ProviderName.ToUpper() == "MAESTRO.HTTP"); //NOXLATE
+ protected override void OnLoad(EventArgs e)
+ base.OnLoad(e);
+ if (_map.Layers.Count == 1) //Single-layer preview
+ var maxScale = _map.Layers.Max(x => x.ScaleRanges.Max(y => y.MaxScale));
+ var initScale = Math.Floor(maxScale - 0.5);
+ var env = _map.MapExtent;
+ double mcsW = env.MaxX - env.MinX;
+ double mcsH = env.MaxY - env.MinY;
+ var bboxScale = Maestro.MapViewer.MapViewer.CalculateScale(_map, mcsW, mcsH, mapViewer.Width, mapViewer.Height);
+ double desiredScale = Math.Min(initScale, bboxScale);
+ mapViewer.LoadMap(_map, desiredScale);
+ else
+ mapViewer.LoadMap(_map);
+ private void mapViewer_MapScaleChanged(object sender, EventArgs e)
+ numZoomToScale.Value = Convert.ToDecimal(mapViewer.GetMap().ViewScale);
+ private void lnkZoomToScale_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+ mapViewer.ZoomToScale(Convert.ToDouble(numZoomToScale.Value));
+ private void mapViewer_PropertyChanged(object sender, PropertyChangedEventArgs e)
+ if (e.PropertyName == "IsBusy") //NOXLATE
+ grpOtherTools.Enabled = !mapViewer.IsBusy;
+ if (!mapViewer.IsBusy)
+ double minx, miny, maxx, maxy;
+ mapViewer.GetViewExtent(out minx, out miny, out maxx, out maxy);
+ txtMinX.Text = minx.ToString(CultureInfo.InvariantCulture);
+ txtMinY.Text = miny.ToString(CultureInfo.InvariantCulture);
+ txtMaxX.Text = maxx.ToString(CultureInfo.InvariantCulture);
+ txtMaxY.Text = maxy.ToString(CultureInfo.InvariantCulture);
+ private void btnGetMapKml_Click(object sender, EventArgs e)
+ var mapagent = _conn.GetCustomProperty("BaseUrl").ToString(); //NOXLATE
+ mapagent += "mapagent/mapagent.fcgi?SESSION=" + _conn.SessionID + "&VERSION=1.0.0&OPERATION=GETMAPKML&DPI=96&MAPDEFINITION=" + _map.MapDefinition + "&FORMAT=KML&CLIENTAGENT=Maestro Local Map Previewer"; //NOXLATE
+ _launcher.OpenUrl(mapagent);
Added: trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/MapPreviewDialog.resx 2012-11-02 11:16:16 UTC (rev 7183)
@@ -0,0 +1,129 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <metadata name="defaultToolbar.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <metadata name="statusStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>155, 17</value>
+ </metadata>
+ <metadata name="mapStatusTracker.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>271, 17</value>
+ </metadata>
+</root>
Modified: trunk/Tools/Maestro/Maestro.Base/UI/Preferences/ConfigProperties.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/Preferences/ConfigProperties.cs 2012-11-02 05:31:02 UTC (rev 7182)
+++ trunk/Tools/Maestro/Maestro.Base/UI/Preferences/ConfigProperties.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -93,6 +93,11 @@
public const string XsdSchemaPath = "Editor.XsdSchemaPath"; //NOXLATE
/// <summary>
+ /// Use the local preview using Maestro's Map Viewer component
+ /// </summary>
+ public const string UseLocalPreview = "Editor.UseLocalPreview"; //NOXLATE
+ /// <summary>
/// Show the tip of the day on startup
/// </summary>
public const string ShowTipOfTheDay = "General.ShowTipOfTheDay"; //NOXLATE
@@ -113,6 +118,7 @@
Props.Set(ConfigProperties.PreviewLocale, DefaultPreviewLocale);
Props.Set(ConfigProperties.ValidateOnSave, DefaultValidateOnSave);
Props.Set(ConfigProperties.XsdSchemaPath, DefaultXsdSchemaPath);
+ Props.Set(ConfigProperties.UseLocalPreview, DefaultUseLocalPreview);
internal static void ApplyGeneralDefaults()
@@ -158,6 +164,11 @@
public static string DefaultLiveMapEditorPath { get { return Path.Combine(FileUtility.ApplicationRootPath, "Maestro.LiveMapEditor.exe"); } } //NOXLATE
/// <summary>
+ /// Default setting for using local previews
+ /// </summary>
+ public static bool DefaultUseLocalPreview { get { return true; } }
+ /// <summary>
/// Default color for open resources in the Site Explorer
/// </summary>
public static Color DefaultOpenColor { get { return Color.LightGreen; } }
Modified: trunk/Tools/Maestro/Maestro.Base/UI/Preferences/EditorPreferencesCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/Preferences/EditorPreferencesCtrl.Designer.cs 2012-11-02 05:31:02 UTC (rev 7182)
+++ trunk/Tools/Maestro/Maestro.Base/UI/Preferences/EditorPreferencesCtrl.Designer.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -35,8 +35,9 @@
this.txtXsdPath = new System.Windows.Forms.TextBox();
this.groupBox2 = new System.Windows.Forms.GroupBox();
+ this.txtPreviewLocale = new System.Windows.Forms.TextBox();
- this.txtPreviewLocale = new System.Windows.Forms.TextBox();
+ this.chkUseLocalPreview = new System.Windows.Forms.CheckBox();
this.groupBox4.SuspendLayout();
this.groupBox2.SuspendLayout();
@@ -46,13 +47,14 @@
this.groupBox4.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.groupBox4.Controls.Add(this.chkUseLocalPreview);
this.groupBox4.Controls.Add(this.chkValidateOnSave);
this.groupBox4.Location = new System.Drawing.Point(3, 3);
this.groupBox4.Name = "groupBox4";
this.groupBox4.Size = new System.Drawing.Size(399, 50);
this.groupBox4.TabIndex = 10;
this.groupBox4.TabStop = false;
- this.groupBox4.Text = "Editing";
+ this.groupBox4.Text = "General";
// chkValidateOnSave
@@ -60,9 +62,9 @@
this.chkValidateOnSave.ImeMode = System.Windows.Forms.ImeMode.NoControl;
this.chkValidateOnSave.Location = new System.Drawing.Point(19, 19);
this.chkValidateOnSave.Name = "chkValidateOnSave";
- this.chkValidateOnSave.Size = new System.Drawing.Size(163, 17);
+ this.chkValidateOnSave.Size = new System.Drawing.Size(109, 17);
this.chkValidateOnSave.TabIndex = 2;
- this.chkValidateOnSave.Text = "Validate Resources On Save";
+ this.chkValidateOnSave.Text = "Validate On Save";
this.chkValidateOnSave.UseVisualStyleBackColor = true;
// groupBox1
@@ -124,6 +126,13 @@
this.groupBox2.TabStop = false;
this.groupBox2.Text = "Localization";
+ // txtPreviewLocale
+ this.txtPreviewLocale.Location = new System.Drawing.Point(187, 22);
+ this.txtPreviewLocale.Name = "txtPreviewLocale";
+ this.txtPreviewLocale.Size = new System.Drawing.Size(47, 20);
+ this.txtPreviewLocale.TabIndex = 1;
// label1
@@ -133,12 +142,15 @@
this.label1.Text = "Preview using the following locale";
- // txtPreviewLocale
+ // chkUseLocalPreview
- this.txtPreviewLocale.Location = new System.Drawing.Point(187, 22);
- this.txtPreviewLocale.Name = "txtPreviewLocale";
- this.txtPreviewLocale.Size = new System.Drawing.Size(47, 20);
- this.txtPreviewLocale.TabIndex = 1;
+ this.chkUseLocalPreview.AutoSize = true;
+ this.chkUseLocalPreview.Location = new System.Drawing.Point(134, 19);
+ this.chkUseLocalPreview.Name = "chkUseLocalPreview";
+ this.chkUseLocalPreview.Size = new System.Drawing.Size(257, 17);
+ this.chkUseLocalPreview.TabIndex = 3;
+ this.chkUseLocalPreview.Text = "Preview with local map viewer (where applicable)";
+ this.chkUseLocalPreview.UseVisualStyleBackColor = true;
// EditorPreferencesCtrl
@@ -170,5 +182,6 @@
private System.Windows.Forms.GroupBox groupBox2;
private System.Windows.Forms.TextBox txtPreviewLocale;
+ private System.Windows.Forms.CheckBox chkUseLocalPreview;
Modified: trunk/Tools/Maestro/Maestro.Base/UI/Preferences/EditorPreferencesCtrl.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/Preferences/EditorPreferencesCtrl.cs 2012-11-02 05:31:02 UTC (rev 7182)
+++ trunk/Tools/Maestro/Maestro.Base/UI/Preferences/EditorPreferencesCtrl.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -35,6 +35,9 @@
var validate = Props.Get(ConfigProperties.ValidateOnSave, ConfigProperties.DefaultValidateOnSave);
chkValidateOnSave.Checked = validate;
+ var useLocal = Props.Get(ConfigProperties.UseLocalPreview, ConfigProperties.DefaultUseLocalPreview);
+ chkUseLocalPreview.Checked = useLocal;
var path = Props.Get(ConfigProperties.XsdSchemaPath, ConfigProperties.DefaultXsdSchemaPath);
txtXsdPath.Text = path;
@@ -56,6 +59,7 @@
bool restart = false;
Apply(ConfigProperties.ValidateOnSave, chkValidateOnSave.Checked);
+ Apply(ConfigProperties.UseLocalPreview, chkUseLocalPreview.Checked);
Apply(ConfigProperties.PreviewLocale, txtPreviewLocale.Text);
//These changes require restart
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/RepositoryTreeModel.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/RepositoryTreeModel.cs 2012-11-02 05:31:02 UTC (rev 7182)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/RepositoryTreeModel.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -1,21 +1,21 @@
-#region Disclaimer / License
-// Copyright (C) 2012, Jackie Ng
-// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of the GNU Lesser General Public
-// License as published by the Free Software Foundation; either
-// version 2.1 of the License, or (at your option) any later version.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
#endregion
using System;
Modified: trunk/Tools/Maestro/Maestro.MapViewer/Interfaces.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/Interfaces.cs 2012-11-02 05:31:02 UTC (rev 7182)
+++ trunk/Tools/Maestro/Maestro.MapViewer/Interfaces.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -362,6 +362,15 @@
/// Gets the view history stack. The first item being the earliest and the last item being the most recent.
/// </summary>
ReadOnlyCollection<MapViewHistoryEntry> ViewHistory { get; }
+ /// <summary>
+ /// Gets the current view extent in the map's coordinates
+ /// </summary>
+ /// <param name="minX"></param>
+ /// <param name="minY"></param>
+ /// <param name="maxX"></param>
+ /// <param name="maxY"></param>
+ void GetViewExtent(out double minX, out double minY, out double maxX, out double maxY);
/// <summary>
Modified: trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs
--- trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs 2012-11-02 05:31:02 UTC (rev 7182)
+++ trunk/Tools/Maestro/Maestro.MapViewer/MapViewer.cs 2012-11-02 11:16:16 UTC (rev 7183)
@@ -1133,12 +1133,22 @@
/// <param name="map"></param>
public void LoadMap(RuntimeMap map)
+ LoadMap(map, null);
+ /// <summary>
+ /// Load the viewer with the given runtime map
+ /// </summary>
+ /// <param name="map"></param>
+ /// <param name="initialScale"></param>
+ public void LoadMap(RuntimeMap map, double? initialScale)
_map = map;
_map.StrictSelection = false;
- InitViewerFromMap();
+ InitViewerFromMap(initialScale);
- private void InitViewerFromMap()
+ private void InitViewerFromMap(double? initialScale)
this.BackColor = _map.BackgroundColor;
_map.DisplayWidth = this.Width;
@@ -1193,21 +1203,25 @@
if (handler != null)
handler(this, EventArgs.Empty);
- InitialMapView();
+ if (initialScale.HasValue)
+ ZoomToScale(initialScale.Value);
+ else
+ InitialMapView();
- internal double MetersPerUnit
+ /// <summary>
+ /// Utility method to calculate the zoom scale for the give map
+ /// </summary>
+ /// <param name="mcsW"></param>
+ /// <param name="mcsH"></param>
+ /// <param name="devW"></param>
+ /// <param name="devH"></param>
+ public static double CalculateScale(RuntimeMap map, double mcsW, double mcsH, int devW, int devH)
- get
- return _map.MetersPerUnit;
- private double CalculateScale(double mcsW, double mcsH, int devW, int devH)
- var mpu = this.MetersPerUnit;
- var mpp = GetMetersPerPixel(_map.DisplayDpi);
+ var mpu = map.MetersPerUnit;
+ var mpp = GetMetersPerPixel(map.DisplayDpi);
if (devH * mcsW > devW * mcsH)
return mcsW * mpu / (devW * mpp); //width-limited
else
@@ -1612,7 +1626,7 @@
/// </summary>
public void ZoomExtents()
- var scale = CalculateScale((_orgX2 - _orgX1), (_orgY1 - _orgY2), this.Width, this.Height);
+ var scale = CalculateScale(_map, (_orgX2 - _orgX1), (_orgY1 - _orgY2), this.Width, this.Height);
ZoomToView(_orgX1 + ((_orgX2 - _orgX1) / 2), _orgY2 + ((_orgY1 - _orgY2) / 2), scale, true);
@@ -1625,7 +1639,7 @@
/// <param name="ury"></param>
public void ZoomToExtents(double llx, double lly, double urx, double ury)
- var scale = CalculateScale((urx - llx), (ury - lly), this.Width, this.Height);
+ var scale = CalculateScale(_map, (urx - llx), (ury - lly), this.Width, this.Height);
ZoomToView(llx + ((urx - llx) / 2), ury + ((lly - ury) / 2), scale, true);
@@ -1658,7 +1672,7 @@
private void UpdateExtents()
//Update current extents
- double mpu = this.MetersPerUnit;
+ double mpu = _map.MetersPerUnit;
double scale = _map.ViewScale;
double mpp = GetMetersPerPixel(_map.DisplayDpi);
var coord = _map.ViewCenter;
@@ -1671,6 +1685,14 @@
_extX2 = coord.X + mcsWidth / 2;
_extY2 = coord.Y - mcsHeight / 2;
+ public void GetViewExtent(out double minX, out double minY, out double maxX, out double maxY)
+ minX = _extX1;
+ minY = _extY1;
+ maxX = _extX2;
+ maxY = _extY2;
private bool PruneHistoryEntriesFromCurrentView()
@@ -1946,7 +1968,7 @@
private void InitialMapView(bool refreshMap)
ZoomToView(_orgX1 + ((_orgX2 - _orgX1) / 2), _orgY2 + ((_orgY1 - _orgY2) / 2), scale, refreshMap);
@@ -2321,9 +2343,9 @@
double screenZoomCenterY = e.Y - (e.Y - this.Height / 2) / zoomChange;
delayRenderViewCenter = ScreenToMapUnits(screenZoomCenterX, screenZoomCenterY);
+ var mpu = _map.MetersPerUnit;
- var w = (_extX2 - _extX1) * this.MetersPerUnit / (delayRenderScale * mpp);
+ var w = (_extX2 - _extX1) * _map.MetersPerUnit / (delayRenderScale * mpp);
if (w > 20000)
w = 20000;
More information about the mapguide-commits
