[mapguide-commits] r7198 - in trunk/Tools/Maestro/Maestro.Base: . Commands/SiteExplorer UI
svn_mapguide at osgeo.org
Tue Nov 6 23:10:26 PST 2012
Author: jng
Date: 2012-11-06 23:10:26 -0800 (Tue, 06 Nov 2012)
New Revision: 7198
Added:
trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.Designer.cs
trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.cs
trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.resx
trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs
trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs
trunk/Tools/Maestro/Maestro.Base/Strings.resx
#2119: Show a more detailed dialog when we're about to delete one or more resources with dependent resources. For folders, we display a different confirmation message (we don't actually walk references here as it could be potentially costly). Otherwise the stock confirmation message that's currently used will be shown.
Modified: trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs 2012-11-07 06:14:02 UTC (rev 7197)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteExplorer/DeleteSelectedItemsCommand.cs 2012-11-07 07:10:26 UTC (rev 7198)
@@ -47,7 +47,8 @@
//Ascertain the parent connection that requires refresh post-delete
string connName = items.First().ConnectionName;
- if (MessageService.AskQuestion(Strings.ConfirmDelete))
+ var dependentResourceIds = CollectDependentResources(items, svc);
+ if (Confirm(dependentResourceIds))
if (ConfirmDeleteOpenResources(items, omgr.OpenEditors))
@@ -87,6 +88,45 @@
+ private Maestro.Editors.RepositoryHandle[] CollectDependentResources(RepositoryItem[] items, ServerConnectionManager connMgr)
+ var ids = new List<Maestro.Editors.RepositoryHandle>();
+ foreach (var it in items)
+ var conn = connMgr.GetConnection(it.ConnectionName);
+ if (it.IsFolder)
+ ids.Add(new Editors.RepositoryHandle(new ResourceIdentifier(it.ResourceId), conn));
+ break;
+ try
+ var references = conn.ResourceService.EnumerateResourceReferences(it.ResourceId);
+ ids.AddRange(references.ResourceId.Select(x => new Maestro.Editors.RepositoryHandle(new ResourceIdentifier(x), conn)));
+ catch //Back-referencing may not be supported
+ return ids.ToArray();
+ private bool Confirm(IEnumerable<Maestro.Editors.RepositoryHandle> dependentResourceIds)
+ if (dependentResourceIds.Count() > 0)
+ if (dependentResourceIds.Any(x => x.ResourceId.IsFolder))
+ return MessageService.AskQuestion(Strings.ConfirmDeleteFolders);
+ else
+ return ConfirmDeleteResourcesDialog.AskQuestion(dependentResourceIds);
+ else
+ return MessageService.AskQuestion(Strings.ConfirmDelete);
private static bool ConfirmDeleteOpenResources(RepositoryItem[] items, Maestro.Base.Editor.IEditorViewContent[] editors)
Check.NotNull(items, "items"); //NOXLATE
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2012-11-07 06:14:02 UTC (rev 7197)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj 2012-11-07 07:10:26 UTC (rev 7198)
@@ -299,6 +299,12 @@
<DependentUpon>BoundsPicker.cs</DependentUpon>
</Compile>
<Compile Include="UI\BroadcastTextWriter.cs" />
+ <Compile Include="UI\ConfirmDeleteResourcesDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="UI\ConfirmDeleteResourcesDialog.Designer.cs">
+ <DependentUpon>ConfirmDeleteResourcesDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="UI\DirtyStateConfirmationDialog.cs">
</Compile>
@@ -588,6 +594,9 @@
<SubType>Designer</SubType>
</EmbeddedResource>
+ <EmbeddedResource Include="UI\ConfirmDeleteResourcesDialog.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="UI\DirtyStateConfirmationDialog.resx">
<DependentUpon>DirtyStateConfirmationDialog.cs</DependentUpon>
</EmbeddedResource>
Modified: trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs 2012-11-07 06:14:02 UTC (rev 7197)
+++ trunk/Tools/Maestro/Maestro.Base/Strings.Designer.cs 2012-11-07 07:10:26 UTC (rev 7198)
@@ -334,6 +334,15 @@
/// <summary>
+ /// Looks up a localized string similar to You about to delete one or more folders which may contain dependent resources. Are you sure you want to proceed with delete?.
+ /// </summary>
+ internal static string ConfirmDeleteFolders {
+ get {
+ return ResourceManager.GetString("ConfirmDeleteFolders", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to You are about to delete one or more resources which are currently open in an editor. Close these editors and proceed with delete?.
/// </summary>
internal static string ConfirmDeleteOpenResource {
Modified: trunk/Tools/Maestro/Maestro.Base/Strings.resx
--- trunk/Tools/Maestro/Maestro.Base/Strings.resx 2012-11-07 06:14:02 UTC (rev 7197)
+++ trunk/Tools/Maestro/Maestro.Base/Strings.resx 2012-11-07 07:10:26 UTC (rev 7198)
@@ -986,4 +986,7 @@
<data name="SiteExplorer_SelectedItem_CompileDependencyList" xml:space="preserve">
<value>Compile Full Dependency List</value>
</data>
+ <data name="ConfirmDeleteFolders" xml:space="preserve">
+ <value>You about to delete one or more folders which may contain dependent resources. Are you sure you want to proceed with delete?</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.Designer.cs 2012-11-07 07:10:26 UTC (rev 7198)
@@ -0,0 +1,98 @@
+namespace Maestro.Base.UI
+ partial class ConfirmDeleteResourcesDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ConfirmDeleteResourcesDialog));
+ this.label1 = new System.Windows.Forms.Label();
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.btnYes = new System.Windows.Forms.Button();
+ this.btnNo = new System.Windows.Forms.Button();
+ this.trvDependents = new System.Windows.Forms.TreeView();
+ this.groupBox1.SuspendLayout();
+ this.SuspendLayout();
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // groupBox1
+ resources.ApplyResources(this.groupBox1, "groupBox1");
+ this.groupBox1.Controls.Add(this.trvDependents);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.TabStop = false;
+ // btnYes
+ resources.ApplyResources(this.btnYes, "btnYes");
+ this.btnYes.Name = "btnYes";
+ this.btnYes.UseVisualStyleBackColor = true;
+ this.btnYes.Click += new System.EventHandler(this.btnYes_Click);
+ // btnNo
+ resources.ApplyResources(this.btnNo, "btnNo");
+ this.btnNo.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ this.btnNo.Name = "btnNo";
+ this.btnNo.UseVisualStyleBackColor = true;
+ this.btnNo.Click += new System.EventHandler(this.btnNo_Click);
+ // trvDependents
+ resources.ApplyResources(this.trvDependents, "trvDependents");
+ this.trvDependents.Name = "trvDependents";
+ // ConfirmDeleteResourcesDialog
+ this.AcceptButton = this.btnYes;
+ resources.ApplyResources(this, "$this");
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.CancelButton = this.btnNo;
+ this.ControlBox = false;
+ this.Controls.Add(this.btnNo);
+ this.Controls.Add(this.btnYes);
+ this.Controls.Add(this.groupBox1);
+ this.Controls.Add(this.label1);
+ this.Name = "ConfirmDeleteResourcesDialog";
+ this.groupBox1.ResumeLayout(false);
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.Button btnYes;
+ private System.Windows.Forms.Button btnNo;
+ private System.Windows.Forms.TreeView trvDependents;
Added: trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.cs 2012-11-07 07:10:26 UTC (rev 7198)
@@ -0,0 +1,73 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+using System.Windows.Forms;
+ public partial class ConfirmDeleteResourcesDialog : Form
+ private ConfirmDeleteResourcesDialog()
+ InitializeComponent();
+ public ConfirmDeleteResourcesDialog(IEnumerable<Editors.RepositoryHandle> dependents)
+ : this()
+ var connNames = dependents.Select(x => x.Connection.DisplayName).Distinct();
+ foreach (var name in connNames)
+ var node = trvDependents.Nodes.Add(name);
+ foreach (var res in dependents.Where(x => x.Connection.DisplayName == name))
+ node.Nodes.Add(res.ResourceId);
+ node.Text += " (" + node.Nodes.Count + ")"; //NOXLATE
+ internal static bool AskQuestion(IEnumerable<Editors.RepositoryHandle> dependentResourceIds)
+ var diag = new ConfirmDeleteResourcesDialog(dependentResourceIds);
+ if (diag.ShowDialog() == DialogResult.OK)
+ return true;
+ return false;
+ private void btnYes_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.OK;
+ private void btnNo_Click(object sender, EventArgs e)
+ this.DialogResult = System.Windows.Forms.DialogResult.Cancel;
Added: trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.resx
--- trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/UI/ConfirmDeleteResourcesDialog.resx 2012-11-07 07:10:26 UTC (rev 7198)
@@ -0,0 +1,273 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 19</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>154, 13</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>Delete the selected resources?</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>3</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="groupBox1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Bottom, Left, Right</value>
+ </data>
+ <data name="trvDependents.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Fill</value>
+ </data>
+ <data name="trvDependents.Location" type="System.Drawing.Point, System.Drawing">
+ <value>3, 16</value>
+ </data>
+ <data name="trvDependents.Size" type="System.Drawing.Size, System.Drawing">
+ <value>470, 199</value>
+ </data>
+ <data name="trvDependents.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>trvDependents.Name" xml:space="preserve">
+ <value>trvDependents</value>
+ </data>
+ <data name=">>trvDependents.Type" xml:space="preserve">
+ <value>System.Windows.Forms.TreeView, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>trvDependents.Parent" xml:space="preserve">
+ <value>groupBox1</value>
+ </data>
+ <data name=">>trvDependents.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="groupBox1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>12, 45</value>
+ </data>
+ <data name="groupBox1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>476, 218</value>
+ </data>
+ <data name="groupBox1.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="groupBox1.Text" xml:space="preserve">
+ <value>Affected Resources</value>
+ </data>
+ <data name=">>groupBox1.Name" xml:space="preserve">
+ </data>
+ <data name=">>groupBox1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.GroupBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>groupBox1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>groupBox1.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="btnYes.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Right</value>
+ </data>
+ <data name="btnYes.Location" type="System.Drawing.Point, System.Drawing">
+ <value>332, 269</value>
+ </data>
+ <data name="btnYes.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="btnYes.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="btnYes.Text" xml:space="preserve">
+ <value>Yes</value>
+ </data>
+ <data name=">>btnYes.Name" xml:space="preserve">
+ <value>btnYes</value>
+ </data>
+ <data name=">>btnYes.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>btnYes.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnYes.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="btnNo.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ </data>
+ <data name="btnNo.Location" type="System.Drawing.Point, System.Drawing">
+ <value>413, 269</value>
+ </data>
+ <data name="btnNo.Size" type="System.Drawing.Size, System.Drawing">
+ </data>
+ <data name="btnNo.TabIndex" type="System.Int32, mscorlib">
+ <value>3</value>
+ </data>
+ <data name="btnNo.Text" xml:space="preserve">
+ <value>No</value>
+ </data>
+ <data name=">>btnNo.Name" xml:space="preserve">
+ <value>btnNo</value>
+ </data>
+ <data name=">>btnNo.Type" xml:space="preserve">
+ </data>
+ <data name=">>btnNo.Parent" xml:space="preserve">
+ </data>
+ <data name=">>btnNo.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+ <value>6, 13</value>
+ </data>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>500, 304</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Delete Resources</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>ConfirmDeleteResourcesDialog</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
More information about the mapguide-commits
