[mapguide-commits] r7204 - in trunk/Tools/Maestro: Maestro Maestro.Base Maestro.Base/Editor Maestro.Base/Services Maestro.Base/Services/DragDropHandlers Maestro.Editors/Common Maestro.Editors/DrawingSource Maestro.Editors/FeatureSource/Providers/Odbc Maestro.Shared.UI MaestroAPITests MaestroAPITests/UserTestData OSGeo.MapGuide.MaestroAPI/Commands OSGeo.MapGuide.MaestroAPI/Mapping OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Tue Nov 13 03:44:54 PST 2012
Author: jng
Date: 2012-11-13 03:44:53 -0800 (Tue, 13 Nov 2012)
New Revision: 7204
Added:
trunk/Tools/Maestro/MaestroAPITests/UserTestData/SpaceShip.xml
trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/DwfFileHandler.cs
trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs
trunk/Tools/Maestro/Maestro.Base/WorkbenchInitializer.cs
trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/DrawingSource/SourceSectionCtrl.cs
trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs
trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.cs
trunk/Tools/Maestro/Maestro.Shared.UI/IWorkbenchInitializer.cs
trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs
trunk/Tools/Maestro/Maestro/Program.cs
trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/DrawingSourceInterfaces.cs
This submission includes the following changes:
- Another Mono hack, default the Workbench to non-minimized state on startup. This reduces the likelihood of deadlocks when background preview preparation is happening.
- Modify the BusyWaitDialog API to allow exceptions in the worker delegate to be properly propagated back up.
- Fix sheet extents when dropping a DWF into the Site Explorer
- Add a new extension method to allow sheet list regeneration in a IDrawingSource
- Add a new unit test to exercise adding of a DWF-based runtime layer
Modified: trunk/Tools/Maestro/Maestro/Program.cs
--- trunk/Tools/Maestro/Maestro/Program.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/Maestro/Program.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -140,7 +140,9 @@
// Workbench is our class from the base project, this method creates an instance
// of the main form.
ServiceRegistry.Initialize(() => {
- Workbench.InitializeWorkbench(new WorkbenchInitializer());
+ //DIRTY DIRTY HACK: I'm getting tired of Mono workarounds. But background resource
+ //preview preparation has a chance of clogging up if the main window is initially maximized
+ Workbench.InitializeWorkbench(new WorkbenchInitializer(!Platform.IsRunningOnMono));
try
LoggingService.Info("Running application..."); //NOXLATE
Modified: trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs
--- trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/Maestro.Base/Editor/EditorContentBase.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -171,7 +171,10 @@
return errors;
- BusyWaitDialog.Run(Strings.PrgPreSaveValidation, del, (result) => {
+ BusyWaitDialog.Run(Strings.PrgPreSaveValidation, del, (result, ex) => {
+ if (ex != null)
+ throw ex;
ValidationIssue[] errors = result as ValidationIssue[];
if (errors.Length > 0)
Modified: trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/DwfFileHandler.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/DwfFileHandler.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/Maestro.Base/Services/DragDropHandlers/DwfFileHandler.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -26,6 +26,7 @@
using OSGeo.MapGuide.ObjectModels;
using Maestro.Shared.UI;
using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.ObjectModels.DrawingSource;
namespace Maestro.Base.Services.DragDropHandlers
@@ -71,6 +72,10 @@
ds.SetResourceData(fileName, OSGeo.MapGuide.ObjectModels.Common.ResourceDataType.File, stream);
+ ds.RegenerateSheetList();
+ conn.ResourceService.SaveResource(ds); //Need to re-save for the next call to work
+ ds.UpdateExtents();
return true;
catch (Exception ex)
Modified: trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs
--- trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/Maestro.Base/Services/ResourcePreviewerFactory.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -171,8 +171,11 @@
else
return null;
- Action<object> onComplete = (obj) =>
+ Action<object, Exception> onComplete = (obj, ex) =>
+ if (ex != null)
+ throw ex;
if (obj != null)
var rtMap = (RuntimeMap)obj;
@@ -288,7 +291,7 @@
return new UrlPreviewResult() { Url = url };
- Action<object> onComplete = (result) => {
+ Action<object, Exception> onComplete = (result, ex) => {
var urlResult = result as UrlPreviewResult;
var imgResult = result as ImagePreviewResult;
if (urlResult != null)
Modified: trunk/Tools/Maestro/Maestro.Base/WorkbenchInitializer.cs
--- trunk/Tools/Maestro/Maestro.Base/WorkbenchInitializer.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/Maestro.Base/WorkbenchInitializer.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -32,6 +32,10 @@
/// </summary>
public class WorkbenchInitializer : IWorkbenchInitializer
+ public WorkbenchInitializer(bool bStartMaximized) { this.StartMaximized = bStartMaximized; }
+ public bool StartMaximized { get; private set; }
/// <summary>
/// Gets the main window icon
/// </summary>
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ResourceDataCtrl.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -207,7 +207,7 @@
//TODO: Obviously support progress
BusyWaitDelegate method = () => { DoFileUpload(fileName); return null; };
- BusyWaitDialog.Run(Strings.TextUploading, method, (obj) =>
+ BusyWaitDialog.Run(Strings.TextUploading, method, (obj, ex) =>
LoadResourceData();
OnDataListChanged();
@@ -280,8 +280,10 @@
return null;
- BusyWaitDialog.Run(Strings.TextDownloading, method, (obj) =>
+ BusyWaitDialog.Run(Strings.TextDownloading, method, (obj, ex) =>
+ if (ex != null)
+ throw ex;
MessageBox.Show(string.Format(Strings.FileDownloaded, fn));
Modified: trunk/Tools/Maestro/Maestro.Editors/DrawingSource/SourceSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/DrawingSource/SourceSectionCtrl.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/Maestro.Editors/DrawingSource/SourceSectionCtrl.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -82,12 +82,7 @@
_edSvc.SyncSessionCopy();
//Re-populate sheets
- IDrawingService dwSvc = (IDrawingService)_dws.CurrentConnection.GetService((int)ServiceType.Drawing);
- var sheets = dwSvc.EnumerateDrawingSections(_dws.ResourceID);
- foreach (var sht in sheets.Section)
- _dws.AddSheet(_dws.CreateSheet(sht.Name, 0, 0, 0, 0));
+ _dws.RegenerateSheetList();
//Re-calc extents
Modified: trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/Maestro.Editors/FeatureSource/Providers/Odbc/OdbcProviderCtrl.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -336,8 +336,10 @@
return null;
- BusyWaitDialog.Run(Strings.TextPreparingConfigurationDocument, worker, (obj) =>
+ BusyWaitDialog.Run(Strings.TextPreparingConfigurationDocument, worker, (obj, ex) =>
+ if (ex != null)
+ throw ex;
//Done
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/BusyWaitDialog.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -52,13 +52,14 @@
public object ReturnValue { get; private set; }
+ public Exception Error { get; private set; }
- public static void Run(string message, BusyWaitDelegate action, Action<object> onComplete)
+ public static void Run(string message, BusyWaitDelegate action, Action<object, Exception> onComplete)
Run(message, action, onComplete, true);
- public static void Run(string message, BusyWaitDelegate action, Action<object> onComplete, bool bPreserveThreadCulture)
+ public static void Run(string message, BusyWaitDelegate action, Action<object, Exception> onComplete, bool bPreserveThreadCulture)
if (action == null)
throw new ArgumentNullException("action"); //NOXLATE
@@ -69,7 +70,7 @@
frm.lblBusy.Text = message;
if (frm.ShowDialog() == DialogResult.OK)
- onComplete.Invoke(frm.ReturnValue);
+ onComplete.Invoke(frm.ReturnValue, frm.Error);
@@ -88,7 +89,7 @@
if (e.Error != null)
- ErrorDialog.Show(e.Error);
+ this.Error = e.Error;
else
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/IWorkbenchInitializer.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/IWorkbenchInitializer.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/IWorkbenchInitializer.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -31,6 +31,10 @@
public interface IWorkbenchInitializer
/// <summary>
+ /// Gets whether to start the workbench maximized
+ /// </summary>
+ bool StartMaximized { get; }
+ /// <summary>
/// </summary>
/// <returns></returns>
Modified: trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs
--- trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/Maestro.Shared.UI/WorkbenchBase.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -55,6 +55,7 @@
_toolstripRegions = new Dictionary<string, ToolbarRegion>();
this.Icon = _workbenchInitializer.GetIcon();
+ this.WindowState = init.StartMaximized ? FormWindowState.Maximized : FormWindowState.Normal;
contentPanel = new DockPanel();
contentPanel.DocumentStyle = DocumentStyle.DockingWindow;
Modified: trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj
--- trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/MaestroAPITests/MaestroAPITests.csproj 2012-11-13 11:44:53 UTC (rev 7204)
@@ -574,6 +574,7 @@
<Content Include="UserTestData\odbc_example_config2.xml">
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
+ <Content Include="UserTestData\SpaceShip.xml" />
<Content Include="UserTestData\wms_config_example1.xml">
</Content>
Modified: trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/MaestroAPITests/RuntimeMapTests.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -39,6 +39,7 @@
using System.Drawing;
using OSGeo.MapGuide.ExtendedObjectModels;
using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+ using OSGeo.MapGuide.ObjectModels.DrawingSource;
[SetUpFixture]
public class TestBootstrap
@@ -101,6 +102,9 @@
resSvc.SetResourceData("Library://UnitTests/Data/HydrographicPolygons.FeatureSource", "UT_HydrographicPolygons.sdf", ResourceDataType.File, File.OpenRead("TestData/MappingService/UT_HydrographicPolygons.sdf"));
resSvc.SetResourceData("Library://UnitTests/Data/Rail.FeatureSource", "UT_Rail.sdf", ResourceDataType.File, File.OpenRead("TestData/MappingService/UT_Rail.sdf"));
resSvc.SetResourceData("Library://UnitTests/Data/Parcels.FeatureSource", "UT_Parcels.sdf", ResourceDataType.File, File.OpenRead("TestData/TileService/UT_Parcels.sdf"));
+ resSvc.SetResourceXmlData("Library://UnitTests/Data/SpaceShip.DrawingSource", File.OpenRead("TestData/DrawingService/SpaceShipDrawingSource.xml"));
+ resSvc.SetResourceData("Library://UnitTests/Data/SpaceShip.DrawingSource", "SpaceShip.dwf", ResourceDataType.File, File.OpenRead("TestData/DrawingService/SpaceShip.dwf"));
[TestFixtureTearDown]
@@ -1021,6 +1025,40 @@
RuntimeMap mymap = mapSvc.OpenMap("Session:" + conn.SessionID + "//" + rtm.Name + ".Map");
+ public virtual void TestMapAddDwfLayer()
+ IServerConnection conn = CreateTestConnection();
+ IMappingService mapSvc = (IMappingService)conn.GetService((int)ServiceType.Mapping);
+ string mapdefinition = "Library://UnitTests/Maps/SheboyganTiled.MapDefinition";
+ IMapDefinition mdef = (IMapDefinition)conn.ResourceService.GetResource(mapdefinition);
+ RuntimeMap rtm = mapSvc.CreateMap(mdef); // Create new runtime map
+ var ds = (IDrawingSource)conn.ResourceService.GetResource("Library://UnitTests/Data/SpaceShip.DrawingSource");
+ //The DWF in question can't be interrogated for extents, so flub it
+ string sheetName = string.Empty;
+ foreach (var sheet in ds.Sheet)
+ sheet.Extent = ObjectFactory.CreateEnvelope(-100000, -100000, 100000, 100000);
+ if (string.IsNullOrEmpty(sheetName))
+ sheetName = sheet.Name;
+ var ldf = ObjectFactory.CreateDefaultLayer(conn, LayerType.Drawing);
+ var dl = (IDrawingLayerDefinition)ldf.SubLayer;
+ dl.ResourceId = ds.ResourceID;
+ dl.Sheet = sheetName;
+ ldf.ResourceID = "Session:" + conn.SessionID + "//TestDrawing.LayerDefinition";
+ conn.ResourceService.SaveResource(ldf);
+ //Add our dwf layer
+ var rtLayer = mapSvc.CreateMapLayer(rtm, ldf);
+ rtm.Layers.Add(rtLayer);
+ rtm.Save();
+ Assert.IsFalse(rtm.IsDirty);
+ RuntimeMap mymap = mapSvc.OpenMap("Session:" + conn.SessionID + "//" + rtm.Name + ".Map");
public virtual void TestResourceEvents()
bool deleteCalled = false;
@@ -1197,6 +1235,12 @@
base.TestMapManipulation5();
+ [Test]
+ public override void TestMapAddDwfLayer()
+ base.TestMapAddDwfLayer();
[TestFixture(Ignore = TestControl.IgnoreLocalNativeRuntimeMapTests)]
@@ -1277,6 +1321,12 @@
base.TestLargeMapCreatePerformance();
+ [Test]
[TestFixture(Ignore = TestControl.IgnoreLocalRuntimeMapTests)]
Added: trunk/Tools/Maestro/MaestroAPITests/UserTestData/SpaceShip.xml
--- trunk/Tools/Maestro/MaestroAPITests/UserTestData/SpaceShip.xml (rev 0)
+++ trunk/Tools/Maestro/MaestroAPITests/UserTestData/SpaceShip.xml 2012-11-13 11:44:53 UTC (rev 7204)
@@ -0,0 +1,8 @@
+<?xml version="1.0" encoding="utf-8" ?>
+<LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" version="1.0.0" xsi:noNamespaceSchemaLocation="LayerDefinition-1.0.0.xsd">
+ <DrawingLayerDefinition>
+ <ResourceId>Library://UnitTests/Data/SpaceShip.DrawingSource</ResourceId>
+ <Sheet>com.autodesk.dwf.ePlot_9E2723744244DB8C44482263E654F764</Sheet>
+ <LayerFilter>YELLOW,CYAN,GREEN,RED,BLUE,WHITE</LayerFilter>
+ </DrawingLayerDefinition>
+</LayerDefinition>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Commands/ExecuteLoadProcedure.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -590,22 +590,10 @@
this.Parent.ResourceService.SetResourceData(dsId, dataName, ResourceDataType.File, System.IO.File.OpenRead(file));
cb(this, new LengthyOperationProgressArgs(string.Format(Strings.TemplateLoaded, file), current));
- var dwSvc = (IDrawingService)Parent.GetService((int)ServiceType.Drawing);
- var list = dwSvc.EnumerateDrawingSections(dsId);
- if (list.Section.Count > 0)
- foreach(var sect in list.Section)
- var sht = ds.CreateSheet(sect.Name, 0, 0, 0, 0);
- ds.AddSheet(sht);
- this.Parent.ResourceService.SaveResource(ds);
- ds.UpdateExtents();
+ this.Parent.ResourceService.SaveResource(ds);
else
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Mapping/RuntimeMapLayer.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -168,6 +168,10 @@
+ else if (ldf.SubLayer.LayerType == LayerType.Drawing)
+ _featureSourceId = ldf.SubLayer.ResourceId;
_expandInLegend = false;
this.Name = ResourceIdentifier.GetName(ldf.ResourceID);
@@ -578,13 +582,19 @@
/// <summary>
/// Gets the schema name
/// </summary>
+ /// <remarks>
+ /// For drawing layers, the schema name will always be empty
+ /// </remarks>
public string SchemaName
get
- var tokens = this.QualifiedClassName.Split(':'); //NOXLATE
- if (tokens.Length == 2)
- return tokens[0];
+ if (!this.FeatureSourceID.EndsWith("DrawingSource")) //NOXLATE
+ var tokens = this.QualifiedClassName.Split(':'); //NOXLATE
+ if (tokens.Length == 2)
+ return tokens[0];
return string.Empty;
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/DrawingSourceInterfaces.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/DrawingSourceInterfaces.cs 2012-11-13 11:12:13 UTC (rev 7203)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/ObjectModels/DrawingSourceInterfaces.cs 2012-11-13 11:44:53 UTC (rev 7204)
@@ -104,12 +104,39 @@
public static class DrawingSourceExtensions
/// <summary>
+ /// Regenerates the sheet list in this drawing source.
+ /// </summary>
+ /// <param name="source"></param>
+ /// <returns>True if sheets were regenerated. False otherwise</returns>
+ public static bool RegenerateSheetList(this IDrawingSource source)
+ Check.NotNull(source, "source");
+ Check.NotNull(source.CurrentConnection, "source.CurrentConection"); //NOXLATE
+ Check.NotEmpty(source.ResourceID, "source.ResourceID"); //NOXLATE
+ IDrawingService dwSvc = (IDrawingService)source.CurrentConnection.GetService((int)ServiceType.Drawing);
+ var sheets = dwSvc.EnumerateDrawingSections(source.ResourceID);
+ bool bRegen = sheets.Section.Count > 0;
+ source.RemoveAllSheets();
+ if (bRegen)
+ foreach (var sht in sheets.Section)
+ source.AddSheet(source.CreateSheet(sht.Name, 0, 0, 0, 0));
+ return bRegen;
+ /// <summary>
/// Updates the extents of all sheets based on their respective AutoCAD Viewport Data in the embedded PIA resource
/// </summary>
public static void UpdateExtents(this IDrawingSource source)
Check.NotNull(source, "source"); //NOXLATE
//Need drawing service
More information about the mapguide-commits
