[mapguide-commits] r7209 - trunk/Tools/Maestro/Maestro.Base/UI
svn_mapguide at osgeo.org
Mon Nov 19 02:40:13 PST 2012
Author: jng
Date: 2012-11-19 02:40:12 -0800 (Mon, 19 Nov 2012)
New Revision: 7209
trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
#2107: Fix cross connection copying logic to be more intuitive to what's expected.
Modified: trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs
--- trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2012-11-15 08:14:21 UTC (rev 7208)
+++ trunk/Tools/Maestro/Maestro.Base/UI/SiteExplorer.cs 2012-11-19 10:40:12 UTC (rev 7209)
@@ -452,7 +452,107 @@
else
- CopyResourcesToFolder(data, connectionName, folderId);
+ * Consider the following layout:
+ * ConnectionA (Root):
+ * Samples
+ * Sheboygan
+ * Data
+ * *.FeatureSource
+ * Layers
+ * *.LayerDefinition
+ * Maps
+ * *.MapDefinition
+ * ConnectionB (Root):
+ * Foo
+ * Bar
+ * Snafu
+ * These are the possible scenarios and outcomes:
+ * Case 1 - Copy folder Samples/Sheboygan/Data into ConnectionB root:
+ * Expect:
+ * Data
+ * *.FeatureSource
+ * Foo
+ * Bar
+ * Snafu
+ * Case 2 - Copy Samples/Sheboygan/Data/*.FeatureSource into ConnectionB root:
+ * Expect:
+ * *.FeatureSource
+ * Foo
+ * Bar
+ * Snafu
+ * Case 3 - Copy Samples/Sheboygan/Data/*.FeatureSource into Connection B/Foo:
+ * Expect:
+ * Foo
+ * *.FeatureSource
+ * Bar
+ * Snafu
+ * Case 4 - Copy Samples/Sheboygan/Data into Connection B/Foo:
+ * Expect:
+ * Foo
+ * Data
+ * *.FeatureSource
+ * Bar
+ * Snafu
+ * Case 5 - Copy Samples/Sheboygan/Data into Connection B/Bar/Snafu:
+ * Expect:
+ * Foo
+ * Bar
+ * Snafu
+ * Data
+ * *.FeatureSource
+ * Case 6 - Copy Samples/Sheboygan/Data/*.FeatureSource into Connection B/Bar/Snafu:
+ * Foo
+ * Bar
+ * Snafu
+ * *.FeatureSource
+ if (data.All(x => x.ResourceId.IsFolder))
+ if (data.Length > 1)
+ //folderId = GetCommonParent(data);
+ CopyResourcesToFolder(data, connectionName, folderId);
+ else
+ folderId += data.First().ResourceId.Name + "/";
+ else
@@ -478,20 +578,6 @@
- //If we're dropping to the root, the common parent becomes our
- //target root
- if (folderId == StringConstants.RootIdentifier)
- folderId = rootSourceParent;
- //If common parent is not root, we want the name of the folder to append
- //to our target
- if (rootSourceParent != StringConstants.RootIdentifier)
- ResourceIdentifier resId = new ResourceIdentifier(rootSourceParent);
- folderId = folderId + resId.Name + "/"; //NOXLATE
var targets = new List<string>();
foreach (var resId in sourceIds)
@@ -553,15 +639,19 @@
//Use first one as a sample to see how far we can go. Keep going until we have
//a parent that doesn't match all of them. The one we recorded before then will
//be the common parent
- while (matches == data.Length)
+ while (true)
- parent = test;
partIndex++;
- if (partIndex < parts.Length) //Shouldn't happen, but just in case
+ if (partIndex > parts.Length) //Shouldn't happen, but just in case
break;
- test = test + parts[partIndex];
- matches = data.Where(x => x.ResourceId.ResourceId.StartsWith(test)).Count();
+ parent = test;
+ test = test + parts[partIndex - 1] + "/";
+ matches = data.Where(x => x.ResourceId.ResourceId.StartsWith(test)).Count();
+ if (matches > 0 && matches != data.Length)
+ break;
return parent;
More information about the mapguide-commits
