[mapguide-commits] r7214 - in branches/maestro-4.0.x: Maestro Maestro.AddIn.Local Maestro.AddIn.Local/Commands Maestro.AddIn.Local/FDO OSGeo.MapGuide.MaestroAPI.Local
svn_mapguide at osgeo.org
Mon Nov 19 04:25:26 PST 2012
Author: jng
Date: 2012-11-19 04:25:25 -0800 (Mon, 19 Nov 2012)
New Revision: 7214
branches/maestro-4.0.x/Maestro.AddIn.Local/ACE.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/Commands/ConnectionPoolStatusCommand.cs
branches/maestro-4.0.x/Maestro.AddIn.Local/Commands/StartupCommand.cs
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/ExpressionEngine.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/FDOCommon.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/FDOGeometry.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/FDOMessage.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/FDOSpatial.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/Fdo.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/GRFPMessage.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/GRFPOverrides.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/GRFPProvider.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/OGRProvider.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/OWS.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SDFMessage.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SDFProvider.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SHPMessage.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SHPOverrides.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SHPProvider.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SQLiteProvider.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/WFSMessage.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/WFSProvider.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/WMSMessage.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/WMSOverrides.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/WMSProvider.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/Xalan-C_1_11.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/XalanMessages_1_11.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/boost_date_time-vc90-mt-1_42.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/boost_thread-vc90-mt-1_42.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/gdal19.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/xerces-c_3_1.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/FoundationUnmanagedApi.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/GEOS.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/GeometryUnmanagedApi.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MapGuideDesktopUnmanagedApi.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MgDesktop.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MgFoundation.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MgGeometry.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MgGwsCommon.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MgGwsQueryEngine.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MgGwsResource.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MgMdfModel.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MgMdfParser.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MgPlatformBase.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MgRenderers.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/MgStylization.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.Desktop.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.Foundation.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.Geometry.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.PlatformBase.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.Viewer.Desktop.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.Viewer.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/PlatformBaseUnmanagedApi.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/gd.dll
branches/maestro-4.0.x/Maestro.AddIn.Local/xerces-c_3_1mg.dll
branches/maestro-4.0.x/Maestro/changelog.txt
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
4.0.x branch changes:
- mg-desktop binary update (2.4.0.7152)
- changelog.txt update
Modified: branches/maestro-4.0.x/Maestro/changelog.txt
--- branches/maestro-4.0.x/Maestro/changelog.txt 2012-11-19 12:24:40 UTC (rev 7213)
+++ branches/maestro-4.0.x/Maestro/changelog.txt 2012-11-19 12:25:25 UTC (rev 7214)
@@ -1,7 +1,11 @@
4.0.4
+ - mg-desktop binary update (2.4.0.7152)
- Improved WMS Feature Source editor
+ - Added support for opening affected resources from the Validation Results dialog
- Fix: Un-intuitive cross-connection copying logic
+ - Fix: Layer selection persisted when moving between Groups and Draw Order tabs
+ - Fix: Layer display property changes sometimes not taking effect
- Fix: Web Layout editor - Available command selection wackiness
- Fix: XSD data type case-sensitivity when parsing FDO Data properties
- Fix: Improve memory usage in SetResourceData (Local/LocalNative) for really large files
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/ACE.dll
(Binary files differ)
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/Commands/ConnectionPoolStatusCommand.cs
--- branches/maestro-4.0.x/Maestro.AddIn.Local/Commands/ConnectionPoolStatusCommand.cs 2012-11-19 12:24:40 UTC (rev 7213)
+++ branches/maestro-4.0.x/Maestro.AddIn.Local/Commands/ConnectionPoolStatusCommand.cs 2012-11-19 12:25:25 UTC (rev 7214)
@@ -30,7 +30,7 @@
public override void Run()
- MgServiceFactory fact = new MgServiceFactory();
+ MgdServiceFactory fact = new MgdServiceFactory();
MgdFeatureService featSvc = (MgdFeatureService)fact.CreateService(MgServiceType.FeatureService);
MgByteReader br = featSvc.QueryCacheInfo();
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/Commands/StartupCommand.cs
--- branches/maestro-4.0.x/Maestro.AddIn.Local/Commands/StartupCommand.cs 2012-11-19 12:24:40 UTC (rev 7213)
+++ branches/maestro-4.0.x/Maestro.AddIn.Local/Commands/StartupCommand.cs 2012-11-19 12:25:25 UTC (rev 7214)
@@ -53,7 +53,7 @@
try
- MgPlatform.Terminate();
+ MgdPlatform.Terminate();
catch (MgException ex)
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/ExpressionEngine.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/FDOCommon.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/FDOGeometry.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/FDOMessage.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/FDOSpatial.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/Fdo.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/GRFPMessage.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/GRFPOverrides.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/GRFPProvider.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/OGRProvider.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/OWS.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SDFMessage.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SDFProvider.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SHPMessage.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SHPOverrides.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SHPProvider.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/SQLiteProvider.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/WFSMessage.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/WFSProvider.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/WMSMessage.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/WMSOverrides.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/WMSProvider.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/Xalan-C_1_11.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/XalanMessages_1_11.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/boost_date_time-vc90-mt-1_42.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/boost_thread-vc90-mt-1_42.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/gdal19.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FDO/xerces-c_3_1.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/FoundationUnmanagedApi.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/GEOS.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/GeometryUnmanagedApi.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MapGuideDesktopUnmanagedApi.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MgDesktop.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MgFoundation.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MgGeometry.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MgGwsCommon.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MgGwsQueryEngine.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MgGwsResource.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MgMdfModel.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MgMdfParser.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MgPlatformBase.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MgRenderers.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/MgStylization.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.Desktop.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.Foundation.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.Geometry.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.PlatformBase.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.Viewer.Desktop.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/OSGeo.MapGuide.Viewer.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/PlatformBaseUnmanagedApi.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/gd.dll
Modified: branches/maestro-4.0.x/Maestro.AddIn.Local/xerces-c_3_1mg.dll
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2012-11-19 12:24:40 UTC (rev 7213)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2012-11-19 12:25:25 UTC (rev 7214)
@@ -52,17 +52,17 @@
static bool _init = false;
- private MgServiceFactory _fact;
+ private MgdServiceFactory _fact;
protected LocalConnection(NameValueCollection initParams) : base()
- _fact = new MgServiceFactory();
+ _fact = new MgdServiceFactory();
_sessionId = Guid.NewGuid().ToString();
_configFile = initParams[PARAM_CONFIG];
var sw = new Stopwatch();
sw.Start();
- MgPlatform.Initialize(_configFile);
+ MgdPlatform.Initialize(_configFile);
_init = true;
sw.Stop();
Trace.TraceInformation("MapGuide Platform initialized in {0}ms", sw.ElapsedMilliseconds);
More information about the mapguide-commits
