[mapguide-commits] r7219 - sandbox/jng/swig-java/Web/src/JavaApiEx
svn_mapguide at osgeo.org
Fri Nov 23 00:40:00 PST 2012
Author: jng
Date: 2012-11-23 00:40:00 -0800 (Fri, 23 Nov 2012)
New Revision: 7219
Added:
sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i
sandbox/jng/swig-java/Web/src/JavaApiEx/java.i
Add new javaextensions.i which will contain java-specific augmentations to swig-generated java proxy classes
Modified: sandbox/jng/swig-java/Web/src/JavaApiEx/java.i
--- sandbox/jng/swig-java/Web/src/JavaApiEx/java.i 2012-11-23 07:19:11 UTC (rev 7218)
+++ sandbox/jng/swig-java/Web/src/JavaApiEx/java.i 2012-11-23 08:40:00 UTC (rev 7219)
@@ -15,6 +15,8 @@
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+%include "javaextensions.i"
%typemap(jni) STRINGPARAM "jstring"
%typemap(jtype) STRINGPARAM "String"
%typemap(jstype) STRINGPARAM "String"
Added: sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i
--- sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i (rev 0)
+++ sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i 2012-11-23 08:40:00 UTC (rev 7219)
@@ -0,0 +1,24 @@
+// Copyright (C) 2004-2011 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+//NOTE: If we're eventually targeting JDK7, change to AutoCloseable for automatic try-with-resources syntax support
+%typemap(javainterfaces) MgReader "java.io.Closeable"
+%typemap(javainterfaces) MgFeatureReader "java.io.Closeable"
+%typemap(javainterfaces) MgDataReader "java.io.Closeable"
+%typemap(javainterfaces) MgSqlDataReader "java.io.Closeable"
+%typemap(javainterfaces) MgLongTransactionReader "java.io.Closeable"
+%typemap(javainterfaces) MgSpatialContextReader "java.io.Closeable"
\ No newline at end of file
More information about the mapguide-commits
