[mapguide-commits] r7221 - in sandbox/jng/swig-java/Oem/SWIGEx: Source/Modules Win32
svn_mapguide at osgeo.org
Fri Nov 23 06:29:56 PST 2012
Author: jng
Date: 2012-11-23 06:29:55 -0800 (Fri, 23 Nov 2012)
New Revision: 7221
sandbox/jng/swig-java/Oem/SWIGEx/Source/Modules/main.cxx
sandbox/jng/swig-java/Oem/SWIGEx/Win32/Swig.exe
Clean up tab/space discrepancy in swig
Modified: sandbox/jng/swig-java/Oem/SWIGEx/Source/Modules/main.cxx
--- sandbox/jng/swig-java/Oem/SWIGEx/Source/Modules/main.cxx 2012-11-23 14:28:48 UTC (rev 7220)
+++ sandbox/jng/swig-java/Oem/SWIGEx/Source/Modules/main.cxx 2012-11-23 14:29:55 UTC (rev 7221)
@@ -71,11 +71,11 @@
static char *usage = (char*)"\
\nGeneral Options\n\
- -baseexception <name> - Name of the exception base class\n\
+ -baseexception <name> - Name of the exception base class\n\
-c++ - Enable C++ processing\n\
- -clsiddata <member> - Data member used as class identifier\n\
- -clsidcode <file> - Name of the file implementing getClassId()\n\
- -catchallcode <file> - Name of the file implementing onCatchAll()\n\
+ -clsiddata <member> - Data member used as class identifier\n\
+ -clsidcode <file> - Name of the file implementing getClassId()\n\
+ -catchallcode <file> - Name of the file implementing onCatchAll()\n\
-co - Check a file out of the SWIG library\n\
-dispose <code> - Code to call to replace 'delete arg1'\n\
-dirprot - Turn on wrapping of protected members for director classes\n\
Modified: sandbox/jng/swig-java/Oem/SWIGEx/Win32/Swig.exe
(Binary files differ)
More information about the mapguide-commits
