[mapguide-commits] r7225 - in sandbox/jng/swig-java: BuildTools/WebTools/IMake BuildTools/WebTools/IMake/Win32 Web/src/JavaApiEx
svn_mapguide at osgeo.org
Mon Nov 26 00:18:15 PST 2012
Author: jng
Date: 2012-11-26 00:18:14 -0800 (Mon, 26 Nov 2012)
New Revision: 7225
sandbox/jng/swig-java/BuildTools/WebTools/IMake/IMake.cpp
sandbox/jng/swig-java/BuildTools/WebTools/IMake/Win32/IMake.exe
sandbox/jng/swig-java/BuildTools/WebTools/IMake/stdafx.h
sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i
#9, #2114: Add IMake support for transplanting class API documentation and javadoc linkification of MapGuide class names
Modified: sandbox/jng/swig-java/BuildTools/WebTools/IMake/IMake.cpp
--- sandbox/jng/swig-java/BuildTools/WebTools/IMake/IMake.cpp 2012-11-26 06:38:45 UTC (rev 7224)
+++ sandbox/jng/swig-java/BuildTools/WebTools/IMake/IMake.cpp 2012-11-26 08:18:14 UTC (rev 7225)
@@ -23,6 +23,7 @@
static string typedefs;
static string nameSpace;
static string package;
+static set<string> classesWithDocs;
static map<string, string> typeReplacements;
static map<string, bool> classes;
static vector<string> headers;
@@ -530,6 +531,65 @@
return itMethod != rootObjectMethods.end();
+bool isAllSlashes(const string& str)
+ for (int i = 0; i < str.length(); i++) {
+ if (str[i] != '/')
+ return false;
+ return str.length() > 3; //A "///" does not count
+string linkifyJavaDocFragment(const string& str)
+ std::vector<std::string> elems;
+ std::stringstream ss(str);
+ std::string item;
+ while(std::getline(ss, item, ' ')) {
+ elems.push_back(item);
+ std::string output;
+ for (int i = 0; i < elems.size(); i++) {
+ if (i != 0) {
+ output.append(" ");
+ //If it contains "Mg", assume it's a MapGuide class name and link-ify it
+ //TODO: Resolve :: to member links. Right now it just linkifies the Mg class name
+ int idx = elems[i].find("Mg");
+ if (idx != std::string::npos) {
+ std::string prefix;
+ std::string mgClassName;
+ std::string suffix;
+ //Collect characters before Mg
+ if (idx > 0) {
+ prefix = elems[i].substr(0, idx);
+ int cont = -1;
+ //Collect the characters in the MapGuide class name
+ for (int j = idx; j < elems[i].length(); j++) {
+ if (!isalnum(elems[i][j])) {
+ cont = j;
+ break;
+ } else {
+ mgClassName += elems[i][j];
+ //Collect any characters afterwards
+ for (int j = cont; j < elems[i].length(); j++) {
+ suffix += elems[i][j];
+ output.append(prefix);
+ output.append("{@link ");
+ output.append(mgClassName);
+ output.append("}");
+ output.append(suffix);
+ } else {
+ output.append(elems[i]);
+ return output;
string doxygenToJavaDoc(const string& commentStr)
// Doxygen documentation translation overview:
@@ -658,18 +718,18 @@
if (descriptionParts.size() > 0) {
for (int i = 0; i < descriptionParts.size(); i++) {
javaDoc.append(" *");
- javaDoc.append(descriptionParts[i]);
+ javaDoc.append(linkifyJavaDocFragment(descriptionParts[i]));
javaDoc.append("\n");
javaDoc.append(" *\n");
} else {
- javaDoc.append(" * TODO: Missing API Documentation here\n");
+ javaDoc.append(" * TODO: Missing API Documentation here (message inserted by IMake.exe)\n");
if (paramParts.size() > 0) {
for (int i = 0; i < paramParts.size(); i++) {
javaDoc.append(" * @param ");
- javaDoc.append(paramParts[i]);
+ javaDoc.append(linkifyJavaDocFragment(paramParts[i]));
@@ -677,7 +737,7 @@
if (returnParts.size() > 0) {
javaDoc.append(" * @return ");
for (int i = 0; i < returnParts.size(); i++) {
- javaDoc.append(returnParts[i]);
+ javaDoc.append(linkifyJavaDocFragment(returnParts[i]));
if (i < returnParts.size() - 1)
javaDoc.append("\n * ");
@@ -696,6 +756,22 @@
return commentStr;
+void outputClassDoc(const string& className, const string& commentStr)
+ //Nothing for PHP
+ if (language == php)
+ return;
+ string convertedDoc;
+ if (language == java) {
+ convertedDoc = doxygenToJavaDoc(commentStr);
+ fprintf(docOutFile, "\n%%typemap(javaclassmodifiers) %s %%{%s public%%}\n", className.c_str(), convertedDoc.c_str());
+ } else if(language == csharp) {
+ convertedDoc = doxygenToCsharpDoc(commentStr);
+ fprintf(docOutFile, "\n%%typemap(csclassmodifiers) %s %%{%s public%%}\n", className.c_str(), convertedDoc.c_str());
void outputMethodDoc(const string& className, const string& methodDecl, const string& commentStr)
//Nothing for PHP
@@ -774,6 +850,39 @@
string commentStr;
string methodDecl;
+ //NOTE: This can get called multiple times for a given class with various offsets, so use a std::set to guard
+ //against duplicate class documentation entries
+ if (!translateMode && classesWithDocs.find(className) == classesWithDocs.end() && begin > 0) {
+ int slashesCount = 0;
+ for (int i = 0; i < begin; i++) {
+ string token = tokens[i];
+ if(token == "")
+ continue;
+ //pickup the doc comments for the class, if any.
+ //all contiguous doc comment will be considered part of the class comment
+ if(strncmp(token.c_str(), "///", 3) == 0)
+ if (isAllSlashes(token))
+ slashesCount++;
+ if (slashesCount > 1) //Stop here, as this is generally the start of the documentation for the first method in the class
+ break;
+ commentStr.append(token);
+ commentStr.append("\n");
+ continue;
+ if (!commentStr.empty()) {
+ outputClassDoc(className, commentStr);
+ commentStr.clear();
+ classesWithDocs.insert(className);
for(int i = begin; i <= end; i++)
assignmentAdded = false;
Modified: sandbox/jng/swig-java/BuildTools/WebTools/IMake/Win32/IMake.exe
(Binary files differ)
Modified: sandbox/jng/swig-java/BuildTools/WebTools/IMake/stdafx.h
--- sandbox/jng/swig-java/BuildTools/WebTools/IMake/stdafx.h 2012-11-26 06:38:45 UTC (rev 7224)
+++ sandbox/jng/swig-java/BuildTools/WebTools/IMake/stdafx.h 2012-11-26 08:18:14 UTC (rev 7225)
@@ -12,6 +12,7 @@
#include <algorithm>
#include <deque>
#include <map>
+#include <set>
#include <iostream>
#include <sstream>
#include <time.h>
Modified: sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i
--- sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i 2012-11-26 06:38:45 UTC (rev 7224)
+++ sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i 2012-11-26 08:18:14 UTC (rev 7225)
@@ -68,39 +68,61 @@
%typemap(javainterfaces) collection_type "Collection<item_type>"
//This is the java.util.Collection implementation that is injected into each java proxy class
%typemap(javacode) collection_type %{
+ * An iterator to iterate over this collection
class ItemIterator implements Iterator<item_type> {
private collection_type _collection;
private int _pos;
+ private int _count;
public ItemIterator(collection_type c) {
_collection = c;
+ _count = _collection.getCount();
_pos = -1;
+ * Returns true if the iteration has more elements
public boolean hasNext() {
- return _pos + 1 <= _collection.getCount();
+ return _pos + 1 <= _count;
+ * Returns the next item_type in the collection
public item_type next() {
_pos++;
- if (_pos >= _collection.getCount())
+ if (_pos >= _count)
throw new NoSuchElementException();
return _collection.getItem(_pos);
+ * Removes from the underlying collection the last element returned by the iterator (not supported).
public void remove() {
throw new UnsupportedOperationException();
+ * Returns an iterator over the elements in this collection.
public Iterator<item_type> iterator() { return new ItemIterator(this); }
+ * Ensures that this collection contains the specified element (optional operation).
public boolean add(item_type item) {
this.addItem(item);
return true;
+ * Adds all of the elements in the specified collection to this collection (optional operation).
public boolean addAll(Collection<? extends item_type> c) {
int added = 0;
for (item_type item : c) {
@@ -110,6 +132,9 @@
return added > 0;
+ * Returns true if this collection contains the specified element.
public boolean contains(Object o) {
if (o instanceof item_type) {
return this.contains((item_type)o);
@@ -117,6 +142,9 @@
return false;
+ * Returns true if this collection contains all of the elements in the specified collection.
public boolean containsAll(Collection<?> c) {
for (Object o : c) {
if (!this.contains(o))
@@ -125,8 +153,14 @@
return true;
+ * Returns true if this collection contains no elements.
public boolean isEmpty() { return this.getCount() == 0; }
+ * Removes a single instance of the specified element from this collection, if it is present (optional operation).
public boolean remove(Object o) {
return this.remove((item_type)o);
@@ -134,6 +168,9 @@
return false;
+ * Removes all of this collection's elements that are also contained in the specified collection (optional operation).
public boolean removeAll(Collection<?> c) {
int removed = 0;
@@ -143,6 +180,9 @@
return removed > 0;
+ * Retains only the elements in this collection that are contained in the specified collection (optional operation).
public boolean retainAll(Collection<?> c) {
int removed = 0;
ArrayList<item_type> remove = new ArrayList<item_type>();
@@ -158,8 +198,14 @@
+ * Returns the number of elements in this collection.
public int size() { return this.getCount(); }
+ * Returns an array containing all of the elements in this collection.
public Object[] toArray() {
int count = this.getCount();
Object[] items = new Object[count];
@@ -169,6 +215,9 @@
return items;
+ * Returns an array containing all of the elements in this collection; the runtime type of the returned array is that of the specified array.
public <item_type> item_type[] toArray(item_type[] a) {
Object[] items = this.toArray();
if (a.length >= items.length) {
@@ -199,32 +248,48 @@
%typemap(javainterfaces) collection_type "java.lang.Iterable<item_type>"
//This is the java.lang.Iterable<T> implementation that is injected into each java proxy class
private int _pos;
_collection = c;
_pos = -1;
_pos++;
More information about the mapguide-commits
