[mapguide-commits] r7228 - in sandbox/jng/swig-java: BuildTools/WebTools/IMake BuildTools/WebTools/IMake/Win32 Web/src/DotNetApi/Foundation Web/src/DotNetApi/Geometry Web/src/DotNetApi/MapGuideCommon Web/src/DotNetApi/PlatformBase Web/src/DotNetApi/Web Web/src/DotNetUnmanagedApi/Foundation Web/src/DotNetUnmanagedApi/Geometry Web/src/DotNetUnmanagedApi/MapGuideCommon Web/src/DotNetUnmanagedApi/PlatformBase Web/src/DotNetUnmanagedApi/Web Web/src/JavaApiEx
svn_mapguide at osgeo.org
Mon Nov 26 08:00:08 PST 2012
Author: jng
Date: 2012-11-26 08:00:07 -0800 (Mon, 26 Nov 2012)
New Revision: 7228
sandbox/jng/swig-java/BuildTools/WebTools/IMake/IMake.cpp
sandbox/jng/swig-java/BuildTools/WebTools/IMake/Win32/IMake.exe
sandbox/jng/swig-java/Web/src/DotNetApi/Foundation/FoundationMakefile
sandbox/jng/swig-java/Web/src/DotNetApi/Geometry/GeometryMakefile
sandbox/jng/swig-java/Web/src/DotNetApi/MapGuideCommon/MapGuideCommonMakefile
sandbox/jng/swig-java/Web/src/DotNetApi/PlatformBase/PlatformBaseMakefile
sandbox/jng/swig-java/Web/src/DotNetApi/Web/WebMakefile
sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml
sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml
sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml
sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml
sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml
sandbox/jng/swig-java/Web/src/JavaApiEx/getclassid.code
sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i
#9, #2114:
- Add IMake support for transplanting doxygen to .net XML documentation. Having this in IMake effectively eliminates the need for the DoxyTransform tool and the need for a doxygen XML output step that the DoxyTransform tools requires.
- Update DotNetApi makefiles to include the /doc switch, that generates the XML documentation files
- Update the DotNetApi gen xml files to include the _doc.i files
- Fix bad getclassid JNI method for our enhanced java wrapper
- Add more MapGuide collection classes with java.util.Collection support
- Add stock equals() and hashCode() implementations for classes that are contained in collection classes. This is required for contains() and other equality/containment tests in the java collections API to work.
- Fix bad ItemIterator behavior for java collection proxy classes
- Fix bad toArray() implementation for collection proxy classes
Modified: sandbox/jng/swig-java/BuildTools/WebTools/IMake/IMake.cpp
--- sandbox/jng/swig-java/BuildTools/WebTools/IMake/IMake.cpp 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/BuildTools/WebTools/IMake/IMake.cpp 2012-11-26 16:00:07 UTC (rev 7228)
@@ -540,6 +540,72 @@
return str.length() > 3; //A "///" does not count
+string linkifyCSharpDocFragment(const string& str)
+ // Explode the fragment into a space delimited list.
+ // Go through the delimited tokens and surround any
+ // token containing "Mg" with {@link <token>}
+ // Re-combine each delimited token to form the linkified result
+ std::vector<std::string> elems;
+ std::stringstream ss(str);
+ std::string item;
+ while(std::getline(ss, item, ' ')) {
+ //We can't process these yet, so skip them as they may
+ //interfere with doxygen directive translation
+ if (item == "\\link" || item == "\\endlink")
+ continue;
+ elems.push_back(item);
+ std::string nspace = nameSpace;
+ if (nspace.empty()) //Faulty logic if this is the case
+ nspace = "OSGeo.MapGuide";
+ std::string output;
+ for (int i = 0; i < elems.size(); i++) {
+ if (i != 0) {
+ output.append(" ");
+ //If it contains "Mg", assume it's a MapGuide class name and link-ify it
+ //TODO: Resolve :: to member links. Right now it just linkifies the Mg class name
+ int idx = elems[i].find("Mg");
+ if (idx != std::string::npos) {
+ std::string prefix;
+ std::string mgClassName;
+ std::string suffix;
+ //Collect characters before Mg
+ if (idx > 0) {
+ prefix = elems[i].substr(0, idx);
+ int cont = -1;
+ //Collect the characters in the MapGuide class name
+ for (int j = idx; j < elems[i].length(); j++) {
+ if (!isalnum(elems[i][j])) {
+ cont = j;
+ break;
+ } else {
+ mgClassName += elems[i][j];
+ //Collect any characters afterwards
+ for (int j = cont; j < elems[i].length(); j++) {
+ suffix += elems[i][j];
+ output.append(prefix);
+ output.append("<see cref=\"");
+ output.append(nspace);
+ output.append(".");
+ output.append(mgClassName);
+ output.append("\" />");
+ output.append(suffix);
+ } else {
+ output.append(elems[i]);
+ return output;
string linkifyJavaDocFragment(const string& str)
@@ -643,9 +709,7 @@
// \since - @since
// \exception - @exception
- //Re-tokenize the method declaration
- //We want the bits between '(' and ')' (parentheses included) and the first token before the '('
+ //Re-tokenize the doxygen comments
std::stringstream ss(commentStr);
std::string item;
@@ -796,7 +860,185 @@
string doxygenToCsharpDoc(const string& commentStr)
- return commentStr;
+ //See doxygenToJavaDoc for how we do this sorcery
+ std::stringstream ss(commentStr);
+ std::string item;
+ while(std::getline(ss, item, '\n')) {
+ int i = 0;
+ bool isDeprecated = false;
+ std::vector<std::string> descriptionParts;
+ std::vector<std::string> paramParts;
+ std::vector<std::string> returnParts;
+ std::vector<std::string> exceptionParts;
+ while(i < elems.size()) {
+ if (elems[i].find("<!-- Syntax in .Net, Java, and PHP -->") != std::string::npos ||
+ elems[i].find("<!-- Example (PHP) -->") != std::string::npos ||
+ elems[i].find("<!-- Example (Java) -->") != std::string::npos ||
+ elems[i].find("<!-- Example (C#) -->") != std::string::npos) {
+ i++;
+ continue;
+ if (elems[i].find("\\brief") != std::string::npos) {
+ i++;
+ //Keep going until we find the next doxygen directive or end of comments
+ while (i < elems.size() && elems[i].find("\\") == std::string::npos) {
+ i++;
+ continue;
+ std::string token = elems[i].substr(3);
+ if (!token.empty())
+ descriptionParts.push_back(token);
+ i++;
+ continue;
+ else if (elems[i].find("\\param") != std::string::npos) {
+ std::string paramPart = elems[i].substr(elems[i].find("\\param") + 6);
+ paramPart.append(" ");
+ i++;
+ if (!token.empty()) {
+ paramPart.append(token);
+ i++;
+ paramParts.push_back(paramPart);
+ continue;
+ else if (elems[i].find("\\return") != std::string::npos) {
+ i++;
+ i++;
+ continue;
+ returnParts.push_back(token);
+ i++;
+ continue;
+ else if (elems[i].find("\\deprecated") != std::string::npos) {
+ i++;
+ isDeprecated = true;
+ continue;
+ else if (elems[i].find("\\exception") != std::string::npos) {
+ std::string except = elems[i].substr(elems[i].find("\\exception") + 10);
+ exceptionParts.push_back(except);
+ i++;
+ continue;
+ i++;
+ // ---------------------- csharpDoc START ------------------------ //
+ std::string csharpDoc = "\n///<summary>\n";
+ if (descriptionParts.size() > 0) {
+ for (int i = 0; i < descriptionParts.size(); i++) {
+ csharpDoc.append("///");
+ csharpDoc.append(linkifyCSharpDocFragment(descriptionParts[i]));
+ csharpDoc.append("\n");
+ csharpDoc.append("///</summary>\n");
+ } else {
+ csharpDoc.append("///TODO: API Documentation is missing or failed to translate doxygen brief directive (message inserted by IMake.exe)\n///</summary>\n");
+ if (paramParts.size() > 0) {
+ for (int i = 0; i < paramParts.size(); i++) {
+ std::vector<std::string> pelems;
+ std::stringstream pss(linkifyCSharpDocFragment(paramParts[i]));
+ std::string pitem;
+ while(std::getline(pss, pitem, ' ')) {
+ if (!pitem.empty())
+ pelems.push_back(pitem);
+ if (pelems.size() > 1) { //Should be
+ csharpDoc.append("///<param name=\"");
+ csharpDoc.append(pelems[0]);
+ csharpDoc.append("\">");
+ csharpDoc.append("\n///");
+ for (int i = 1; i < pelems.size(); i++) {
+ csharpDoc.append(" ");
+ csharpDoc.append(pelems[i]);
+ csharpDoc.append("\n///</param>\n");
+ if (returnParts.size() > 0) {
+ csharpDoc.append("///<returns>");
+ for (int i = 0; i < returnParts.size(); i++) {
+ csharpDoc.append(linkifyCSharpDocFragment(returnParts[i]));
+ if (i < returnParts.size() - 1)
+ csharpDoc.append("\n/// ");
+ csharpDoc.append("\n///</returns>\n");
+ if (exceptionParts.size() > 0) {
+ for (int i = 0; i < exceptionParts.size(); i++) {
+ std::vector<std::string> eelems;
+ std::stringstream ess(exceptionParts[i]);
+ std::string eitem;
+ while(std::getline(ess, eitem, ' ')) {
+ if (!eitem.empty())
+ eelems.push_back(eitem);
+ csharpDoc.append("///<exception cref=\"");
+ csharpDoc.append(nspace);
+ csharpDoc.append(".");
+ if (eelems.size() > 1) {
+ csharpDoc.append(eelems[0]);
+ for (int j = 1; j < eelems.size(); j++) {
+ csharpDoc.append(eelems[j]);
+ csharpDoc.append("</exception>\n");
+ } else {
+ csharpDoc.append("\"></exception>\n");
+ // ---------------------- csharpDoc END ------------------------ //
+ csharpDoc.append("///\n");
+ if (isDeprecated)
+ csharpDoc.append("[Obsolete(\"This method is deprecated\")]\n");
+ return csharpDoc;
void outputClassDoc(const string& className, const string& commentStr)
Modified: sandbox/jng/swig-java/BuildTools/WebTools/IMake/Win32/IMake.exe
(Binary files differ)
Modified: sandbox/jng/swig-java/Web/src/DotNetApi/Foundation/FoundationMakefile
--- sandbox/jng/swig-java/Web/src/DotNetApi/Foundation/FoundationMakefile 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/DotNetApi/Foundation/FoundationMakefile 2012-11-26 16:00:07 UTC (rev 7228)
@@ -12,8 +12,8 @@
release: $(OUTDIR)\OSGeo.MapGuide.Foundation.dll
$(OUTDIR)\OSGeo.MapGuide.Foundation.Temp.dll:
- csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /platform:$(PLATFORM) /target:library .\*.cs
+ csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Foundation.xml /platform:$(PLATFORM) /target:library .\*.cs
copy /y $(OUTDIR)\OSGeo.MapGuide.Foundation.dll $(OUTDIR)\OSGeo.MapGuide.Foundation.Temp.dll
$(OUTDIR)\OSGeo.MapGuide.Foundation.dll:
- csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /platform:$(PLATFORM) /target:library .\*.cs
+ csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Foundation.xml /platform:$(PLATFORM) /target:library .\*.cs
Modified: sandbox/jng/swig-java/Web/src/DotNetApi/Geometry/GeometryMakefile
--- sandbox/jng/swig-java/Web/src/DotNetApi/Geometry/GeometryMakefile 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/DotNetApi/Geometry/GeometryMakefile 2012-11-26 16:00:07 UTC (rev 7228)
@@ -12,8 +12,8 @@
release: $(OUTDIR)\OSGeo.MapGuide.Geometry.dll
$(OUTDIR)\OSGeo.MapGuide.Geometry.Temp.dll:
- csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Geometry.dll /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /target:library .\*.cs
+ csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Geometry.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Geometry.xml /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /target:library .\*.cs
copy /y $(OUTDIR)\OSGeo.MapGuide.Geometry.dll $(OUTDIR)\OSGeo.MapGuide.Geometry.Temp.dll
$(OUTDIR)\OSGeo.MapGuide.Geometry.dll:
- csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Geometry.dll /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /target:library .\*.cs
+ csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Geometry.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Geometry.xml /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll /target:library .\*.cs
Modified: sandbox/jng/swig-java/Web/src/DotNetApi/MapGuideCommon/MapGuideCommonMakefile
--- sandbox/jng/swig-java/Web/src/DotNetApi/MapGuideCommon/MapGuideCommonMakefile 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/DotNetApi/MapGuideCommon/MapGuideCommonMakefile 2012-11-26 16:00:07 UTC (rev 7228)
@@ -12,8 +12,8 @@
release: $(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll
$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.Temp.dll:
- csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll .\*.cs
+ csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll /doc:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.xml /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll .\*.cs
copy /y $(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll $(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.Temp.dll
$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll:
- csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll /target:library /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll .\*.cs
+ csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll /doc:$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.xml /target:library /platform:$(PLATFORM) /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll .\*.cs
Modified: sandbox/jng/swig-java/Web/src/DotNetApi/PlatformBase/PlatformBaseMakefile
--- sandbox/jng/swig-java/Web/src/DotNetApi/PlatformBase/PlatformBaseMakefile 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/DotNetApi/PlatformBase/PlatformBaseMakefile 2012-11-26 16:00:07 UTC (rev 7228)
@@ -12,8 +12,8 @@
release: $(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll
$(OUTDIR)\OSGeo.MapGuide.PlatformBase.Temp.dll:
- csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll .\*.cs
+ csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll /doc:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.xml /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll .\*.cs
copy /y $(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll $(OUTDIR)\OSGeo.MapGuide.PlatformBase.Temp.dll
$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll:
- csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll .\*.cs
+ csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll /doc:$(OUTDIR)\OSGeo.MapGuide.PlatformBase.xml /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll .\*.cs
Modified: sandbox/jng/swig-java/Web/src/DotNetApi/Web/WebMakefile
--- sandbox/jng/swig-java/Web/src/DotNetApi/Web/WebMakefile 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/DotNetApi/Web/WebMakefile 2012-11-26 16:00:07 UTC (rev 7228)
@@ -12,8 +12,8 @@
release: $(OUTDIR)\OSGeo.MapGuide.Web.dll
$(OUTDIR)\OSGeo.MapGuide.Web.Temp.dll:
- csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Web.dll /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll;$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll .\*.cs
+ csc.exe /debug+ /debug:full /optimize- /out:$(OUTDIR)\OSGeo.MapGuide.Web.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Web.xml /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll;$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll .\*.cs
copy /y $(OUTDIR)\OSGeo.MapGuide.Web.dll $(OUTDIR)\OSGeo.MapGuide.Web.Temp.dll
$(OUTDIR)\OSGeo.MapGuide.Web.dll:
- csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Web.dll /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll;$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll .\*.cs
+ csc.exe /debug+ /debug:pdbonly /optimize+ /out:$(OUTDIR)\OSGeo.MapGuide.Web.dll /doc:$(OUTDIR)\OSGeo.MapGuide.Web.xml /platform:$(PLATFORM) /target:library /reference:$(OUTDIR)\OSGeo.MapGuide.Foundation.dll;$(OUTDIR)\OSGeo.MapGuide.Geometry.dll;$(OUTDIR)\OSGeo.MapGuide.PlatformBase.dll;$(OUTDIR)\OSGeo.MapGuide.MapGuideCommon.dll .\*.cs
Modified: sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml
--- sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml 2012-11-26 16:00:07 UTC (rev 7228)
@@ -48,6 +48,7 @@
Swig inline section.
<SwigInline>
+ %include "FoundationApi_Doc.i" //doc fragments
%include "language.i" //typemaps specific for each language
%include "../../../../Common/Foundation/System/FoundationClassId.h"
Modified: sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml
--- sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml 2012-11-26 16:00:07 UTC (rev 7228)
@@ -50,6 +50,7 @@
<SwigInline>
%import "../Foundation/FoundationApi.i"
+ %include "GeometryApi_Doc.i" //doc fragments
%include "../../../../Common/Geometry/GeometryClassId.h"
Modified: sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml
--- sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml 2012-11-26 16:00:07 UTC (rev 7228)
@@ -53,6 +53,7 @@
%import "../Geometry/GeometryApi.i"
%import "../PlatformBase/PlatformBaseApi.i"
+ %include "MapGuideCommonApi_Doc.i" //doc fragments
%include "../../../../Common/MapGuideCommon/System/MapGuideCommonClassId.h"
Modified: sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml
--- sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml 2012-11-26 16:00:07 UTC (rev 7228)
@@ -52,6 +52,7 @@
<SwigInline>
+ %include "PlatformBaseApi_Doc.i" //doc fragments
%include "../../../../Common/PlatformBase/Services/PlatformBaseClassId.h"
Modified: sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml
--- sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml 2012-11-26 16:00:07 UTC (rev 7228)
@@ -14,7 +14,7 @@
Target section.
<Target path="./MapGuideApi.i" />
-<DocTarget path="./MapGuideApi_Doc.i" />
+<DocTarget path="./WebApi_Doc.i" />
C++ inline section.
@@ -62,6 +62,7 @@
%import "../MapGuideCommon/MapGuideCommonApi.i"
+ %include "WebApi_Doc.i" //doc fragments
%include "InitializeWebTier.i"
%include "../../WebApp/WebAppClassId.h"
Modified: sandbox/jng/swig-java/Web/src/JavaApiEx/getclassid.code
--- sandbox/jng/swig-java/Web/src/JavaApiEx/getclassid.code 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/JavaApiEx/getclassid.code 2012-11-26 16:00:07 UTC (rev 7228)
@@ -1,6 +1,6 @@
/* Get a class identifier from an Object instance */
-JNIEXPORT jint JNICALL Java_org_osgeo_mapguide_MapGuideJavaApiJNI_getClassId(JNIEnv* jenv, jclass jcls, jlong jarg1)
+JNIEXPORT jint JNICALL Java_org_osgeo_mapguide_MapGuideJavaApiExJNI_getClassId(JNIEnv* jenv, jclass jcls, jlong jarg1)
return ((MgObject*)(void*)jarg1)->GetClassId();
Modified: sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i
--- sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i 2012-11-26 14:27:27 UTC (rev 7227)
+++ sandbox/jng/swig-java/Web/src/JavaApiEx/javaextensions.i 2012-11-26 16:00:07 UTC (rev 7228)
@@ -45,10 +45,37 @@
%rename(addItem) MgBatchPropertyCollection::Add;
%rename(addItem) MgClassDefinitionCollection::Add;
%rename(addItem) MgFeatureSchemaCollection::Add;
+%rename(addItem) MgPropertyDefinitionCollection::Add;
%rename(addItem) MgIntCollection::Add;
%rename(addItem) MgPropertyCollection::Add;
%rename(addItem) MgStringCollection::Add;
+%rename(addItem) MgLayerCollection::Add;
+%rename(addItem) MgLayerGroupCollection::Add;
+//This is a helper macro to implement the required APIs for collection items
+//This could possibly apply to all proxy classes, but for now we're only interested in classes
+//that are part of any collection class that implements java.util.Collection. This is needed for
+//contains() and other container tests for equality to work
+//Implementation borrowed from OGR swig java bindings
+%define IMPLEMENT_MG_ITEM_API(item_type)
+%typemap(javacode) item_type %{
+ public boolean equals(Object obj) {
+ boolean equal=false;
+ if(obj instanceof $javaclassname)
+ equal=((($javaclassname)obj).swigCPtr==this.swigCPtr);
+ return equal;
+ public int hashCode() {
+ return (int)swigCPtr;
+%enddef
//This is a helper macro to implement the bulk of the java.util.Collection interface for any proxy class
//that needs one
@@ -86,7 +113,7 @@
* Returns true if the iteration has more elements
public boolean hasNext() {
- return _pos + 1 <= _count;
+ return _pos + 1 < _count;
@@ -229,7 +256,11 @@
return a;
} else {
- return (item_type[])items;
+ item_type[] retVal = (item_type[])java.lang.reflect.Array.newInstance(a.getClass().getComponentType(), items.length);
+ for (int i = 0; i < retVal.length; i++) {
+ retVal[i] = (item_type)items[i];
+ return retVal;
@@ -266,7 +297,7 @@
@@ -295,10 +326,20 @@
%enddef
-//Plug the stock implementation for our MapGuide collection classes
-IMPLEMENT_MG_JAVA_COLLECTION_API(MgBatchPropertyCollection, MgPropertyCollection)
+//Plug the stock implementation for our MapGuide collection and item classes
+IMPLEMENT_MG_ITEM_API(MgClassDefinition)
+IMPLEMENT_MG_ITEM_API(MgFeatureSchema)
+IMPLEMENT_MG_ITEM_API(MgPropertyDefinition)
+IMPLEMENT_MG_ITEM_API(MgProperty)
+IMPLEMENT_MG_ITEM_API(MgLayerBase)
+IMPLEMENT_MG_ITEM_API(MgLayerGroup)
+//IMPLEMENT_MG_JAVA_COLLECTION_API(MgBatchPropertyCollection, MgPropertyCollection)
IMPLEMENT_MG_JAVA_COLLECTION_API(MgClassDefinitionCollection, MgClassDefinition)
IMPLEMENT_MG_JAVA_COLLECTION_API(MgFeatureSchemaCollection, MgFeatureSchema)
+IMPLEMENT_MG_JAVA_COLLECTION_API(MgPropertyDefinitionCollection, MgPropertyDefinition)
IMPLEMENT_MG_JAVA_COLLECTION_API(MgPropertyCollection, MgProperty)
IMPLEMENT_MG_JAVA_COLLECTION_API(MgStringCollection, String)
+IMPLEMENT_MG_JAVA_COLLECTION_API(MgLayerCollection, MgLayerBase)
+IMPLEMENT_MG_JAVA_COLLECTION_API(MgLayerGroupCollection, MgLayerGroup)
IMPLEMENT_MG_JAVA_ITERABLE_API(MgReadOnlyLayerCollection, MgLayerBase)
\ No newline at end of file
More information about the mapguide-commits
