[mapguide-commits] r7231 - trunk/MgDev/Server/src/UnitTesting
svn_mapguide at osgeo.org
Mon Nov 26 20:54:58 PST 2012
Author: jng
Date: 2012-11-26 20:54:58 -0800 (Mon, 26 Nov 2012)
New Revision: 7231
trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp
trunk/MgDev/Server/src/UnitTesting/TestMisc.h
Damn tabs and spaces!
Modified: trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp 2012-11-27 04:51:35 UTC (rev 7230)
+++ trunk/MgDev/Server/src/UnitTesting/TestMisc.cpp 2012-11-27 04:54:58 UTC (rev 7231)
@@ -513,24 +513,24 @@
void TestMisc::TestCase_MapLayerCollections()
- try
- Ptr<MgResourceIdentifier> mapRes1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
+ try
+ Ptr<MgResourceIdentifier> mapRes1 = new MgResourceIdentifier(L"Library://UnitTests/Maps/Sheboygan.MapDefinition");
Ptr<MgMap> map1 = new MgMap(m_siteConnection);
map1->Create(mapRes1, L"UnitTestSheboygan1");
- Ptr<MgLayerGroup> detachedGroup = new MgLayerGroup(L"DetachedGroup");
+ Ptr<MgLayerGroup> detachedGroup = new MgLayerGroup(L"DetachedGroup");
Ptr<MgResourceIdentifier> ldf = new MgResourceIdentifier(L"Library://UnitTests/Layers/Parcels.LayerDefinition");
Ptr<MgLayer> detachedLayer = new MgLayer(ldf, m_svcResource);
- detachedLayer->SetName(L"DetachedLayer");
+ detachedLayer->SetName(L"DetachedLayer");
- Ptr<MgLayerCollection> mapLayers = map1->GetLayers();
- Ptr<MgLayerGroupCollection> mapGroups = map1->GetLayerGroups();
+ Ptr<MgLayerCollection> mapLayers = map1->GetLayers();
+ Ptr<MgLayerGroupCollection> mapGroups = map1->GetLayerGroups();
- //Remove() should be returning false when passing in layers/groups that don't belong
- CPPUNIT_ASSERT(!mapLayers->Remove(detachedLayer));
- CPPUNIT_ASSERT(!mapGroups->Remove(detachedGroup));
+ //Remove() should be returning false when passing in layers/groups that don't belong
+ CPPUNIT_ASSERT(!mapLayers->Remove(detachedLayer));
+ CPPUNIT_ASSERT(!mapGroups->Remove(detachedGroup));
catch (MgException* e)
STRING message = e->GetDetails(TEST_LOCALE);
Modified: trunk/MgDev/Server/src/UnitTesting/TestMisc.h
--- trunk/MgDev/Server/src/UnitTesting/TestMisc.h 2012-11-27 04:51:35 UTC (rev 7230)
+++ trunk/MgDev/Server/src/UnitTesting/TestMisc.h 2012-11-27 04:54:58 UTC (rev 7231)
@@ -28,7 +28,7 @@
CPPUNIT_TEST(TestCase_CommonExceptionMessages);
CPPUNIT_TEST(TestCase_611);
CPPUNIT_TEST(TestCase_1304);
- CPPUNIT_TEST(TestCase_MapLayerCollections);
+ CPPUNIT_TEST(TestCase_MapLayerCollections);
CPPUNIT_TEST(TestEnd); // This must be the very last unit test
CPPUNIT_TEST_SUITE_END();
@@ -45,7 +45,7 @@
void TestCase_CommonExceptionMessages();
void TestCase_611();
void TestCase_1304();
- void TestCase_MapLayerCollections();
+ void TestCase_MapLayerCollections();
private:
Ptr<MgSiteConnection> m_siteConnection;
More information about the mapguide-commits
