[mapguide-commits] r7239 - in sandbox/adsk/2.5k: Common/Foundation/System Common/Geometry Server/src/UnitTesting
svn_mapguide at osgeo.org
Fri Nov 30 12:46:07 PST 2012
Author: waltweltonlair
Date: 2012-11-30 12:46:07 -0800 (Fri, 30 Nov 2012)
New Revision: 7239
sandbox/adsk/2.5k/Common/Foundation/System/StreamReader.h
sandbox/adsk/2.5k/Common/Geometry/AgfStream.h
sandbox/adsk/2.5k/Common/Geometry/MultiGeometry.cpp
sandbox/adsk/2.5k/Server/src/UnitTesting/TestGeometry.cpp
Merge trunk changeset 7238 into adsk/2.4k branch stream.
This is for ticket #2192 (MgMultiGeometry::Deserialize doesn't work with MgAgfStream).
Modified: sandbox/adsk/2.5k/Common/Foundation/System/StreamReader.h
--- sandbox/adsk/2.5k/Common/Foundation/System/StreamReader.h 2012-11-30 20:03:14 UTC (rev 7238)
+++ sandbox/adsk/2.5k/Common/Foundation/System/StreamReader.h 2012-11-30 20:46:07 UTC (rev 7239)
@@ -129,7 +129,7 @@
/// \return
/// Nothing
- virtual void GetInt16(INT16& value);
+ virtual void GetInt16(INT16& value);
/// \brief
Modified: sandbox/adsk/2.5k/Common/Geometry/AgfStream.h
--- sandbox/adsk/2.5k/Common/Geometry/AgfStream.h 2012-11-30 20:03:14 UTC (rev 7238)
+++ sandbox/adsk/2.5k/Common/Geometry/AgfStream.h 2012-11-30 20:46:07 UTC (rev 7239)
@@ -90,7 +90,7 @@
/// \return
/// Nothing
/// \brief
Modified: sandbox/adsk/2.5k/Common/Geometry/MultiGeometry.cpp
--- sandbox/adsk/2.5k/Common/Geometry/MultiGeometry.cpp 2012-11-30 20:03:14 UTC (rev 7238)
+++ sandbox/adsk/2.5k/Common/Geometry/MultiGeometry.cpp 2012-11-30 20:46:07 UTC (rev 7239)
@@ -133,7 +133,7 @@
stream->WriteInt32(numGeometries);
//Geometries
- for(INT32 i = 0; i < numGeometries; i++)
+ for (INT32 i = 0; i < numGeometries; i++)
Ptr<MgGeometry> geometry = m_geometries->GetItem(i);
if (tcpipStream)
@@ -164,29 +164,37 @@
//Geometries
Ptr<MgStreamHelper> streamHelper = stream->GetStreamHelper();
bool tcpipStream = (typeid(*streamHelper.p) == typeid(MgAceStreamHelper));
+ const type_info& streamType = typeid(*stream);
m_geometries = new MgGeometryCollection();
INT32 geomType;
- if(tcpipStream)
+ if (tcpipStream)
stream->GetInt32(geomType);
else
// HACK!
// get the geometry type without removing it from the stream
- // NOTE: to get to the geometry type we have to also read the
- // packet header and argument type
- UINT32 buffer[3];
-// UINT32 packetHeader = buffer[0];
-// UINT32 argumentType = buffer[1];
-// UINT32 data = buffer[2];
- streamHelper->GetData(buffer, 3*sizeof(UINT32), true, true);
- assert(buffer[1] == (UINT32)MgPacketParser::matINT32);
- geomType = (INT32)buffer[2];
+ if (streamType == typeid(MgStream))
+ // NOTE: in the case of MgStream we have to also read the packet
+ // header and argument type to get to the geometry type
+ UINT32 buffer[3];
+// UINT32 packetHeader = buffer[0];
+// UINT32 argumentType = buffer[1];
+// UINT32 data = buffer[2];
+ streamHelper->GetData(buffer, 3*sizeof(UINT32), true, true);
+ assert(buffer[1] == (UINT32)MgPacketParser::matINT32);
+ geomType = (INT32)buffer[2];
+ else
+ streamHelper->GetUINT32((UINT32&)geomType, true, true);
- //create the adequate geometry based on its type id and deserialize
+ // create the geometry based on its type and deserialize
Ptr<MgGeometry> geometry = MgGeometryFactory::CreateGeometry(geomType);
geometry->Deserialize(stream);
m_geometries->Add(geometry);
Modified: sandbox/adsk/2.5k/Server/src/UnitTesting/TestGeometry.cpp
--- sandbox/adsk/2.5k/Server/src/UnitTesting/TestGeometry.cpp 2012-11-30 20:03:14 UTC (rev 7238)
+++ sandbox/adsk/2.5k/Server/src/UnitTesting/TestGeometry.cpp 2012-11-30 20:46:07 UTC (rev 7239)
@@ -337,7 +337,7 @@
MgGeometryFactory factory;
Ptr<MgCurvePolygonCollection> curvePolys = new MgCurvePolygonCollection();
- for (INT32 i=0; i < numCurvePolys; i++)
+ for (INT32 i=0; i<numCurvePolys; ++i)
Ptr<MgCurvePolygon> curvePoly = CreateCurvePolygon(i+offset);
curvePolys->Add(curvePoly);
@@ -434,7 +434,7 @@
Ptr<MgGeometry> lineString = readerWriter.Read(wkt);
Ptr<MgCoordinateIterator> baselineIterator = lineString->GetCoordinates();
- while(iterator->MoveNext() && baselineIterator->MoveNext())
+ while (iterator->MoveNext() && baselineIterator->MoveNext())
Ptr<MgCoordinate> coord = iterator->GetCurrent();
Ptr<MgCoordinate> baselineCoord = baselineIterator->GetCurrent();
@@ -462,9 +462,9 @@
Ptr<MgCoordinateIterator> baseCoords = baseGeom->GetCoordinates();
Ptr<MgCoordinateIterator> calculatedCoords = calculatedGeom->GetCoordinates();
- if(baseCoords->GetCount() == calculatedCoords->GetCount())
+ if (baseCoords->GetCount() == calculatedCoords->GetCount())
- for(int i=0;i<baseCoords->GetCount();i++)
+ for (int i=0; i<baseCoords->GetCount(); ++i)
baseCoords->MoveNext();
calculatedCoords->MoveNext();
@@ -495,11 +495,11 @@
try
- MgWktReaderWriter readerWriter;
STRING base = L"POINT XYZ (5 3 2)";
Ptr<MgGeometry> geom = CreatePoint();
+ MgWktReaderWriter readerWriter;
STRING found = readerWriter.Write(geom);
CPPUNIT_ASSERT(CheckGeometry(geom, base));
CPPUNIT_ASSERT(CheckGeometry(geom, found));
@@ -515,7 +515,11 @@
point1->Serialize(stream);
point2->Deserialize(stream);
CPPUNIT_ASSERT(CheckGeometry(point2, base));
- CPPUNIT_ASSERT(CheckGeometry(point2, found));
+ MgAgfReaderWriter agfReaderWriter;
+ Ptr<MgByteReader> reader = agfReaderWriter.Write(geom);
+ Ptr<MgGeometry> point3 = agfReaderWriter.Read(reader);
+ CPPUNIT_ASSERT(CheckGeometry(point3, base));
catch (MgException* e)
@@ -534,11 +538,11 @@
try
STRING base = L"LINESTRING (0 1, 2 3, 4 5)";
Ptr<MgGeometry> geom = CreateLineString();
@@ -554,7 +558,11 @@
lineString1->Serialize(stream);
lineString2->Deserialize(stream);
CPPUNIT_ASSERT(CheckGeometry(lineString2, base));
- CPPUNIT_ASSERT(CheckGeometry(lineString2, found));
+ Ptr<MgGeometry> lineString3 = agfReaderWriter.Read(reader);
+ CPPUNIT_ASSERT(CheckGeometry(lineString3, base));
@@ -573,11 +581,11 @@
try
STRING base = L"POLYGON ((0 0, 5 0, 5 5, 0 5, 0 0), (1 1, 2 1, 2 2, 1 1), (3 3, 4 3, 4 4, 3 3))";
Ptr<MgGeometry> geom = CreatePolygon();
@@ -593,7 +601,11 @@
polygon1->Serialize(stream);
polygon2->Deserialize(stream);
CPPUNIT_ASSERT(CheckGeometry(polygon2, base));
- CPPUNIT_ASSERT(CheckGeometry(polygon2, found));
+ Ptr<MgGeometry> polygon3 = agfReaderWriter.Read(reader);
+ CPPUNIT_ASSERT(CheckGeometry(polygon3, base));
@@ -612,11 +624,11 @@
try
STRING base = L"CURVESTRING (0 0 (CIRCULARARCSEGMENT (0 1, 1 2), LINESTRINGSEGMENT (3 0, 3 2)))";
Ptr<MgGeometry> geom = CreateCurveString(0.0);
@@ -632,7 +644,11 @@
curveString1->Serialize(stream);
curveString2->Deserialize(stream);
CPPUNIT_ASSERT(CheckGeometry(curveString2, base));
- CPPUNIT_ASSERT(CheckGeometry(curveString2, found));
+ Ptr<MgGeometry> curveString3 = agfReaderWriter.Read(reader);
+ CPPUNIT_ASSERT(CheckGeometry(curveString3, base));
@@ -651,8 +667,6 @@
try
STRING base = L"(3.14 3.14 (CIRCULARARCSEGMENT (3.14 4.140000000000001, 4.140000000000001 5.140000000000001),"
L" LINESTRINGSEGMENT (3.14 3.14)))";
@@ -678,13 +692,13 @@
try
STRING base = L"CURVEPOLYGON ((200 200 (CIRCULARARCSEGMENT (200 201, 201 202), LINESTRINGSEGMENT (200 200))),"
L" (300 300 (CIRCULARARCSEGMENT (300 301, 301 302), LINESTRINGSEGMENT (300 300))),"
L" (400 400 (CIRCULARARCSEGMENT (400 401, 401 402), LINESTRINGSEGMENT (400 400))))";
Ptr<MgGeometry> geom = CreateCurvePolygon(100.0);
@@ -700,7 +714,11 @@
curvePolygon1->Serialize(stream);
curvePolygon2->Deserialize(stream);
CPPUNIT_ASSERT(CheckGeometry(curvePolygon2, base));
- CPPUNIT_ASSERT(CheckGeometry(curvePolygon2, found));
+ Ptr<MgGeometry> curvePolygon3 = agfReaderWriter.Read(reader);
+ CPPUNIT_ASSERT(CheckGeometry(curvePolygon3, base));
@@ -719,11 +737,11 @@
try
STRING base = L"MULTIPOINT XYZ (1 2 3, 4 5 6, 7 8 9)";
Ptr<MgGeometry> geom = CreateMultiPoint();
@@ -739,7 +757,11 @@
multiPoint1->Serialize(stream);
multiPoint2->Deserialize(stream);
CPPUNIT_ASSERT(CheckGeometry(multiPoint2, base));
- CPPUNIT_ASSERT(CheckGeometry(multiPoint2, found));
+ Ptr<MgGeometry> multiPoint3 = agfReaderWriter.Read(reader);
+ CPPUNIT_ASSERT(CheckGeometry(multiPoint3, base));
@@ -758,11 +780,11 @@
try
STRING base = L"MULTILINESTRING XYZ ((0 1 2, 3 4 5, 6 7 8), (9 10 11, 12 13 14, 15 16 17))";
Ptr<MgGeometry> geom = CreateMultiLineString();
@@ -778,7 +800,11 @@
multiLineString1->Serialize(stream);
multiLineString2->Deserialize(stream);
CPPUNIT_ASSERT(CheckGeometry(multiLineString2, base));
- CPPUNIT_ASSERT(CheckGeometry(multiLineString2, found));
+ Ptr<MgGeometry> multiLineString3 = agfReaderWriter.Read(reader);
+ CPPUNIT_ASSERT(CheckGeometry(multiLineString3, base));
@@ -797,12 +823,12 @@
try
STRING base = L"MULTIPOLYGON (((0 0, 5 0, 5 5, 0 5, 0 0), (1 1, 2 1, 2 2, 1 1), (3 3, 4 3, 4 4, 3 3)),"
L" ((0 0, 5 0, 5 5, 0 5, 0 0), (1 1, 2 1, 2 2, 1 1), (3 3, 4 3, 4 4, 3 3)))";
Ptr<MgGeometry> geom = CreateMultiPolygon();
@@ -818,7 +844,11 @@
multiPolygon1->Serialize(stream);
multiPolygon2->Deserialize(stream);
CPPUNIT_ASSERT(CheckGeometry(multiPolygon2, base));
- CPPUNIT_ASSERT(CheckGeometry(multiPolygon2, found));
+ Ptr<MgGeometry> multiPolygon3 = agfReaderWriter.Read(reader);
+ CPPUNIT_ASSERT(CheckGeometry(multiPolygon3, base));
@@ -837,13 +867,13 @@
try
STRING base = L"MULTICURVESTRING ((100 100 (CIRCULARARCSEGMENT (100 101, 101 102), LINESTRINGSEGMENT (103 100, 103 102))),"
L" (200 200 (CIRCULARARCSEGMENT (200 201, 201 202), LINESTRINGSEGMENT (203 200, 203 202))),"
L" (300 300 (CIRCULARARCSEGMENT (300 301, 301 302), LINESTRINGSEGMENT (303 300, 303 302))))";
Ptr<MgGeometry> geom = CreateMultiCurveString();
@@ -859,7 +889,11 @@
multiCurveString1->Serialize(stream);
multiCurveString2->Deserialize(stream);
CPPUNIT_ASSERT(CheckGeometry(multiCurveString2, base));
- CPPUNIT_ASSERT(CheckGeometry(multiCurveString2, found));
+ Ptr<MgGeometry> multiCurveString3 = agfReaderWriter.Read(reader);
+ CPPUNIT_ASSERT(CheckGeometry(multiCurveString3, base));
@@ -878,8 +912,6 @@
try
STRING base = L"MULTICURVEPOLYGON (((200 200 (CIRCULARARCSEGMENT (200 201, 201 202), LINESTRINGSEGMENT (200 200))),"
L" (400 400 (CIRCULARARCSEGMENT (400 401, 401 402), LINESTRINGSEGMENT (400 400)))),"
@@ -891,6 +923,8 @@
L" (402 402 (CIRCULARARCSEGMENT (402 403, 403 404), LINESTRINGSEGMENT (402 402)))))";
Ptr<MgGeometry> geom = CreateMultiCurvePolygon(3, 100.0);
@@ -906,7 +940,11 @@
multiCurvePolygon1->Serialize(stream);
multiCurvePolygon2->Deserialize(stream);
CPPUNIT_ASSERT(CheckGeometry(multiCurvePolygon2, base));
- CPPUNIT_ASSERT(CheckGeometry(multiCurvePolygon2, found));
+ Ptr<MgGeometry> multiCurvePolygon3 = agfReaderWriter.Read(reader);
+ CPPUNIT_ASSERT(CheckGeometry(multiCurvePolygon3, base));
@@ -925,8 +963,6 @@
try
STRING base = L"GEOMETRYCOLLECTION (CURVEPOLYGON ((100 100 (CIRCULARARCSEGMENT (100 101, 101 102),"
L" LINESTRINGSEGMENT (100 100))), (200 200 (CIRCULARARCSEGMENT (200 201, 201 202),"
L" LINESTRINGSEGMENT (200 200))), (300 300 (CIRCULARARCSEGMENT (300 301, 301 302),"
@@ -934,6 +970,8 @@
L" LINESTRINGSEGMENT (103 100, 103 102))), LINESTRING (0 1, 2 3, 4 5), POINT XYZ (5 3 2),"
L" POLYGON ((0 0, 5 0, 5 5, 0 5, 0 0), (1 1, 2 1, 2 2, 1 1), (3 3, 4 3, 4 4, 3 3)))";
Ptr<MgGeometry> geom = CreateMultiGeometry();
@@ -950,7 +988,11 @@
multiGeometry1->Serialize(stream);
multiGeometry2->Deserialize(stream);
CPPUNIT_ASSERT(CheckGeometry(multiGeometry2, base));
- CPPUNIT_ASSERT(CheckGeometry(multiGeometry2, found));
+ Ptr<MgGeometry> multiGeometry3 = agfReaderWriter.Read(reader);
+ CPPUNIT_ASSERT(CheckGeometry(multiGeometry3, base));
More information about the mapguide-commits
