[mapguide-commits] r7057 - in branches/maestro-4.0.x: . OSGeo.MapGuide.MaestroAPI.Local OSGeo.MapGuide.MaestroAPI.Native
svn_mapguide at osgeo.org
Mon Oct 1 06:37:48 PDT 2012
Author: jng
Date: 2012-10-01 06:37:48 -0700 (Mon, 01 Oct 2012)
New Revision: 7057
branches/maestro-4.0.x/
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
Backport r7056 to 4.0.x
Property changes on: branches/maestro-4.0.x
___________________________________________________________________
Modified: svn:mergeinfo
- /trunk/Tools/Maestro:6490-6494,6923-6924,6926,6928,7026,7034
+ /trunk/Tools/Maestro:6490-6494,6923-6924,6926,6928,7026,7034,7056
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2012-10-01 13:12:08 UTC (rev 7056)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Local/LocalConnection.cs 2012-10-01 13:37:48 UTC (rev 7057)
@@ -307,18 +307,50 @@
return result;
+ const int MAX_INPUT_STREAM_SIZE_MB = 30;
public override void SetResourceData(string resourceid, string dataname, ResourceDataType datatype, System.IO.Stream stream, Utility.StreamCopyProgressDelegate callback)
- byte[] data = Utility.StreamAsArray(stream);
- if (callback != null)
- callback(0, data.Length, data.Length);
var res = GetResourceService();
- MgByteSource source = new MgByteSource(data, data.Length);
- MgByteReader reader = source.GetReader();
- res.SetResourceData(new MgResourceIdentifier(resourceid), dataname, datatype.ToString(), reader);
- LogMethodCall("MgResourceService::SetResourceData", true, resourceid, dataname, datatype.ToString(), "MgByteReader");
- callback(data.Length, 0, data.Length);
+ MgByteReader reader = null;
+ string tmpPath = null;
+ //If stream is under our hard-coded limit (and it's seekable, which is how we're able to get that number), use the
+ //overload of MgByteSource that accepts a byte[]. Otherwise dump the stream to a temp file and use the
+ //file name overload (otherwise if our input stream happens to be several GBs, we run risk of
+ //System.OutOfMemoryExceptions being thrown back at us)
+ if (stream.CanSeek && stream.Length < (MAX_INPUT_STREAM_SIZE_MB * 1024 * 1024))
+ byte[] data = Utility.StreamAsArray(stream);
+ MgByteSource source = new MgByteSource(data, data.Length);
+ reader = source.GetReader();
+ else
+ tmpPath = Path.GetTempFileName();
+ using (FileStream fs = File.OpenWrite(tmpPath))
+ MaestroAPI.Utility.CopyStream(stream, fs, false);
+ MgByteSource source = new MgByteSource(tmpPath);
+ try
+ res.SetResourceData(new MgResourceIdentifier(resourceid), dataname, datatype.ToString(), reader);
+ LogMethodCall("MgResourceService::SetResourceData", true, resourceid, dataname, datatype.ToString(), "MgByteReader");
+ finally
+ if (!string.IsNullOrEmpty(tmpPath) && File.Exists(tmpPath))
+ //Be a responsible citizen and clean up our temp files when done
+ try
+ File.Delete(tmpPath);
+ catch { }
public override void UploadPackage(string filename, Utility.StreamCopyProgressDelegate callback)
Modified: branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
--- branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2012-10-01 13:12:08 UTC (rev 7056)
+++ branches/maestro-4.0.x/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2012-10-01 13:37:48 UTC (rev 7057)
@@ -944,17 +944,50 @@
return this;
public override void SetResourceData(string resourceid, string dataname, ResourceDataType datatype, Stream stream, OSGeo.MapGuide.MaestroAPI.Utility.StreamCopyProgressDelegate callback)
MgResourceService res = this.Connection.CreateService(MgServiceType.ResourceService) as MgResourceService;
- MgByteReader reader = new MgByteReader(data, data.Length, "binary/octet-stream");
+ else
+ try
+ finally
+ try
+ catch { }
public override void UploadPackage(string filename, OSGeo.MapGuide.MaestroAPI.Utility.StreamCopyProgressDelegate callback)
More information about the mapguide-commits
