[mapguide-commits] r7060 - trunk/Tools/Maestro/MaestroAPITests
svn_mapguide at osgeo.org
Mon Oct 1 09:28:35 PDT 2012
Author: jng
Date: 2012-10-01 09:28:35 -0700 (Mon, 01 Oct 2012)
New Revision: 7060
trunk/Tools/Maestro/MaestroAPITests/SchemaTests.cs
#2136: Add the failing test case. This is a verbatim copy of the class names used for the XmlTest::testNameAdjust() test case in FDO.
Modified: trunk/Tools/Maestro/MaestroAPITests/SchemaTests.cs
--- trunk/Tools/Maestro/MaestroAPITests/SchemaTests.cs 2012-10-01 13:58:32 UTC (rev 7059)
+++ trunk/Tools/Maestro/MaestroAPITests/SchemaTests.cs 2012-10-01 16:28:35 UTC (rev 7060)
@@ -24,6 +24,7 @@
using OSGeo.MapGuide.MaestroAPI.Schema;
using System.IO;
using System.Xml;
+using OSGeo.MapGuide.MaestroAPI;
namespace MaestroAPITests
@@ -31,7 +32,7 @@
public class SchemaTests
//These tests are to verify that we can read FDO XML configuration and schema documents without problems
[Test]
public void TestMySqlSchema()
@@ -307,5 +308,114 @@
schema.AddClass(cls);
Assert.AreEqual(schema, cls.Parent);
+ [Test]
+ public void TestClassNameEncoding()
+ // Round-trip various invalid XML names. Copied from FDO test suite
+ string name1 = "Abc def";
+ string name2 = Utility.EncodeFDOName(name1);
+ Assert.AreEqual( name2, "Abc-x20-def" );
+ Assert.AreEqual( name1, Utility.DecodeFDOName(name2) );
+ name1 = " Abc#defg$$";
+ name2 = Utility.EncodeFDOName(name1);
+ Assert.AreEqual( name2, "_x20-Abc-x23-defg-x24--x24-" );
+ name1 = " Abc#defg hij";
+ Assert.AreEqual( name2, "_x20-Abc-x23-defg-x20-hij" );
+ name1 = "--abc-def---ghi--";
+ Assert.AreEqual( name2, "_x2d--abc-def---ghi--" );
+ name1 = "--abc-x20-def-x23--x24-ghi--";
+ Assert.AreEqual( name2, "_x2d--abc-x2d-x20-def-x2d-x23--x2d-x24-ghi--" );
+ name1 = "-xab";
+ Assert.AreEqual( name2, "_x2d-xab" );
+ name1 = "&Entity";
+ Assert.AreEqual( name2, "_x26-Entity" );
+ name1 = "11ab";
+ Assert.AreEqual( name2, "_x31-1ab" );
+ name1 = "2_Class";
+ Assert.AreEqual( name2, "_x32-_Class" );
+ name1 = "2%Class";
+ Assert.AreEqual( name2, "_x32--x25-Class" );
+ name1 = "2-Class";
+ Assert.AreEqual( name2, "_x32--Class" );
+ name1 = "2-x2f-Class";
+ Assert.AreEqual( name2, "_x32--x2d-x2f-Class" );
+ name1 = "_x2d-";
+ Assert.AreEqual( name2, "_x00-_x2d-" );
+ name1 = "-x3d-";
+ Assert.AreEqual( name2, "_x2d-x3d-" );
+ name1 = "_x2d-_x3f-";
+ Assert.AreEqual( name2, "_x00-_x2d-_x3f-" );
+ name1 = "__x2d-_x3f-";
+ Assert.AreEqual( name2, "__x2d-_x3f-" );
+ name1 = "_Class";
+ Assert.AreEqual( name2, "_Class" );
+ name1 = "_5Class";
+ Assert.AreEqual( name2, "_5Class" );
+ name1 = "_-5Class";
+ Assert.AreEqual( name2, "_-5Class" );
+ name1 = "-_x2f-Class";
+ Assert.AreEqual( name2, "_x2d-_x2f-Class" );
+ // Backward compatibility check. Make sure old-style 1st character encodings get decoded.
+ name2 = "-x40-A";
+ Assert.AreEqual( Utility.DecodeFDOName(name2), "@A" );
More information about the mapguide-commits
