[mapguide-commits] r7069 - in branches/2.4/MgDev/Desktop: MapViewer/AppLayoutEngine MgDesktop Samples Samples/FreeFormExample Samples/FreeFormExample/Properties Samples/FreeFormExample/Resources Samples/Lib Samples/SampleExtension
svn_mapguide at osgeo.org
Wed Oct 3 09:47:53 PDT 2012
Author: jng
Date: 2012-10-03 09:47:53 -0700 (Wed, 03 Oct 2012)
New Revision: 7069
Added:
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/FreeFormExample.csproj
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.Designer.cs
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.cs
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.resx
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Program.cs
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/AssemblyInfo.cs
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Resources.Designer.cs
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Resources.resx
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Settings.Designer.cs
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Settings.settings
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/icon_pan.gif
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/lc_select.gif
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-clear.png
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-features.png
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-polygon.png
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-radius.png
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/view-refresh.png
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-full.png
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-in-fixed.png
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-in.png
branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-out-fixed.png
branches/2.4/MgDev/Desktop/Samples/Lib/SheboyganSample.AppLayout
branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/Shell.cs
branches/2.4/MgDev/Desktop/MgDesktop/changelog.txt
branches/2.4/MgDev/Desktop/Samples/MgDesktopSamples.sln
branches/2.4/MgDev/Desktop/Samples/SampleExtension/SampleExtension.csproj
branches/2.4/MgDev/Desktop/Samples/samples_readme.txt
mg-desktop: This submission includes the following changes:
- Add a new sample (FreeFormExample) that demonstrates that the MgMapViewer control functions like any other WinForms control and can have other controls placed on top of it, allowing for minimal user interfaces.
- Fix AppLayout Shell not using the referenced Map Definition for components using the map: value prefix
- Add a sample-specific AppLayout for the SampleExtension project
Modified: branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/Shell.cs
--- branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/Shell.cs 2012-10-03 15:01:55 UTC (rev 7068)
+++ branches/2.4/MgDev/Desktop/MapViewer/AppLayoutEngine/Shell.cs 2012-10-03 16:47:53 UTC (rev 7069)
@@ -407,7 +407,7 @@
var mapName = prop.Value.Substring(StringPrefixes.MAPDEFINITION.Length);
//TODO: Update for multi-maps if/when we support it
if (layout.Map.Name == mapName)
- comp.SetPropertyValue(prop.Name, mapName);
+ comp.SetPropertyValue(prop.Name, layout.Map.MapDefinition);
else
throw new InvalidOperationException(string.Format(Strings.ErrorMapNotFound, mapName));
@@ -449,15 +449,21 @@
//Apply viewer properties. We do this here because we want to respect the viewer options component
//So we apply before the viewer options component gets its chance to
foreach (var prop in layout.Settings)
+ //Special case
+ if (prop.Name == "InvokeOnStartup") //NOXLATE
+ _invokeComponentOnStartup = prop.Value.Substring(StringPrefixes.COMPONENTID.Length);
+ continue;
if (prop.Value.StartsWith(StringPrefixes.MAPDEFINITION))
- mapViewer.SetPropertyValue(prop.Name, mapName);
+ mapViewer.SetPropertyValue(prop.Name, layout.Map.MapDefinition);
else
Modified: branches/2.4/MgDev/Desktop/MgDesktop/changelog.txt
--- branches/2.4/MgDev/Desktop/MgDesktop/changelog.txt 2012-10-03 15:01:55 UTC (rev 7068)
+++ branches/2.4/MgDev/Desktop/MgDesktop/changelog.txt 2012-10-03 16:47:53 UTC (rev 7069)
@@ -1,9 +1,20 @@
API Changelog:
- MgdPlatform::Terminate() did not call MgdFdoConnectionPool::Cleanup() leaving that to the static initializer to cleanup. This caused problems for the GDAL provider if connection pooling is enabled. The call has been put into MgdPlatform::Terminate() and connection pooling for the GDAL provider has been re-enabled in Platform.ini
- Add support for MapGuide's PreCacheMaps configuration property in Platform.ini
+ - MgMapViewer is now an IMapComponent, and any properties tagged with MgComponentPropertyAttribute can be dynamically set by the AppLayout engine.
Viewer Changelog:
- Support for Localization
+ - New Viewer properties to support display of Tiled Maps:
+ - UseRenderMapIfTiledLayersExist (if true will use the RenderMap API, which includes tiled layers in the rendered image)
+ - RespectFiniteDisplayScales (if true will cause all zooms to snap to the nearest finite display scale)
+ - NOTE: Because RenderMap pre-fills the map's background color into the final image, setting the viewer to use the RenderMap API makes it impossible to use the viewer's Pre-Rendering hook as the rendered image will be drawn completely over it.
+ - MgQueryResultsDialog now allows for unbounded size in search results (passing a limit of -1 will instruct the dialog to spin through the entire feature reader)
+ - Fix legend node display for tiled layers (checkboxes should not show)
+ - Fix illegal attempts to fetch theme icons at scales where they're not applicable.
+ - New simple search component. Similar to the search command in the AJAX/Fusion viewer
+ - AppLayout schema change to accomodate dynamic assignment of viewer properties. See updated AppLayout examples.
- Improve performance of MgMapViewerProvider
2.4.0.6971 (Aug 30 2012)
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample
___________________________________________________________________
Added: svn:ignore
+ bin
obj
Added: bugtraq:number
+ true
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/FreeFormExample.csproj
--- branches/2.4/MgDev/Desktop/Samples/FreeFormExample/FreeFormExample.csproj (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/FreeFormExample/FreeFormExample.csproj 2012-10-03 16:47:53 UTC (rev 7069)
@@ -0,0 +1,155 @@
+<?xml version="1.0" encoding="utf-8"?>
+<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <PropertyGroup>
+ <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+ <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+ <ProductVersion>9.0.30729</ProductVersion>
+ <SchemaVersion>2.0</SchemaVersion>
+ <ProjectGuid>{41EF1524-D186-4079-BAA9-1A99F0AC31CA}</ProjectGuid>
+ <OutputType>WinExe</OutputType>
+ <AppDesignerFolder>Properties</AppDesignerFolder>
+ <RootNamespace>FreeFormExample</RootNamespace>
+ <AssemblyName>FreeFormExample</AssemblyName>
+ <TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
+ <FileAlignment>512</FileAlignment>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|x86' ">
+ <DebugSymbols>true</DebugSymbols>
+ <OutputPath>bin\x86\Debug\</OutputPath>
+ <DefineConstants>DEBUG;TRACE</DefineConstants>
+ <DebugType>full</DebugType>
+ <PlatformTarget>x86</PlatformTarget>
+ <ErrorReport>prompt</ErrorReport>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|x86' ">
+ <OutputPath>bin\x86\Release\</OutputPath>
+ <DefineConstants>TRACE</DefineConstants>
+ <Optimize>true</Optimize>
+ <DebugType>pdbonly</DebugType>
+ </PropertyGroup>
+ <ItemGroup>
+ <Reference Include="OSGeo.MapGuide.Desktop, Version=2.4.0.0, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f, processorArchitecture=x86">
+ <SpecificVersion>False</SpecificVersion>
+ <HintPath>..\Lib\OSGeo.MapGuide.Desktop.dll</HintPath>
+ <Private>False</Private>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.Foundation, Version=2.4.0.7019, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=x86">
+ <HintPath>..\Lib\OSGeo.MapGuide.Foundation.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.Geometry, Version=2.4.0.7019, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=x86">
+ <HintPath>..\Lib\OSGeo.MapGuide.Geometry.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.PlatformBase, Version=2.4.0.7019, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=x86">
+ <HintPath>..\Lib\OSGeo.MapGuide.PlatformBase.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.Viewer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f, processorArchitecture=MSIL">
+ <HintPath>..\Lib\OSGeo.MapGuide.Viewer.dll</HintPath>
+ </Reference>
+ <Reference Include="OSGeo.MapGuide.Viewer.Desktop, Version=1.0.0.0, Culture=neutral, PublicKeyToken=e75f9fd7cf82dc3f, processorArchitecture=MSIL">
+ <HintPath>..\Lib\OSGeo.MapGuide.Viewer.Desktop.dll</HintPath>
+ </Reference>
+ <Reference Include="System" />
+ <Reference Include="System.Data" />
+ <Reference Include="System.Deployment" />
+ <Reference Include="System.Drawing" />
+ <Reference Include="System.Windows.Forms" />
+ <Reference Include="System.Xml" />
+ </ItemGroup>
+ <ItemGroup>
+ <Compile Include="MainForm.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="MainForm.Designer.cs">
+ <DependentUpon>MainForm.cs</DependentUpon>
+ </Compile>
+ <Compile Include="Program.cs" />
+ <Compile Include="Properties\AssemblyInfo.cs" />
+ <EmbeddedResource Include="MainForm.resx">
+ </EmbeddedResource>
+ <EmbeddedResource Include="Properties\Resources.resx">
+ <Generator>ResXFileCodeGenerator</Generator>
+ <LastGenOutput>Resources.Designer.cs</LastGenOutput>
+ <SubType>Designer</SubType>
+ <Compile Include="Properties\Resources.Designer.cs">
+ <AutoGen>True</AutoGen>
+ <DependentUpon>Resources.resx</DependentUpon>
+ <DesignTime>True</DesignTime>
+ </Compile>
+ <None Include="Properties\Settings.settings">
+ <Generator>SettingsSingleFileGenerator</Generator>
+ <LastGenOutput>Settings.Designer.cs</LastGenOutput>
+ </None>
+ <Compile Include="Properties\Settings.Designer.cs">
+ <DependentUpon>Settings.settings</DependentUpon>
+ <DesignTimeSharedInput>True</DesignTimeSharedInput>
+ </Compile>
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\zoom-in-fixed.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\zoom-out-fixed.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\zoom-in.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\zoom-full.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\lc_select.gif" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\select-features.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\select-polygon.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\select-radius.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\select-clear.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\view-refresh.png" />
+ </ItemGroup>
+ <ItemGroup>
+ <None Include="Resources\icon_pan.gif" />
+ </ItemGroup>
+ <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+ <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+ Other similar extension points exist, see Microsoft.Common.targets.
+ <Target Name="BeforeBuild">
+ </Target>
+ <Target Name="AfterBuild">
+ </Target>
+ <PropertyGroup>
+ <PostBuildEvent>if not exist "$(TargetDir)FDO" md "$(TargetDir)FDO"
+xcopy /s /y "$(SolutionDir)Lib\FDO" "$(TargetDir)FDO"
+if not exist "$(TargetDir)Dictionaries" md "$(TargetDir)Dictionaries"
+xcopy /s /y "$(SolutionDir)Lib\Dictionaries" "$(TargetDir)Dictionaries"
+if not exist "$(TargetDir)Resources" md "$(TargetDir)Resources"
+xcopy /s /y "$(SolutionDir)Lib\Resources" "$(TargetDir)Resources"
+if not exist "$(TargetDir)Schema" md "$(TargetDir)Schema"
+xcopy /s /y "$(SolutionDir)Lib\Schema" "$(TargetDir)Schema"
+copy /y "$(SolutionDir)Lib\*.dll" "$(TargetDir)"
+copy /y "$(SolutionDir)Lib\Platform.ini" "$(TargetDir)"</PostBuildEvent>
+ </PropertyGroup>
+</Project>
\ No newline at end of file
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.Designer.cs
--- branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.Designer.cs (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.Designer.cs 2012-10-03 16:47:53 UTC (rev 7069)
@@ -0,0 +1,335 @@
+namespace FreeFormExample
+ partial class MainForm
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.splitContainer1 = new System.Windows.Forms.SplitContainer();
+ this.splitContainer2 = new System.Windows.Forms.SplitContainer();
+ this.mgLegend1 = new OSGeo.MapGuide.Viewer.MgLegend();
+ this.mgPropertyPane1 = new OSGeo.MapGuide.Viewer.MgPropertyPane();
+ this.mgMapViewer1 = new OSGeo.MapGuide.Viewer.MgMapViewer();
+ this.statusStrip1 = new System.Windows.Forms.StatusStrip();
+ this.lblCoords = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblSelected = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblScale = new System.Windows.Forms.ToolStripStatusLabel();
+ this.lblSize = new System.Windows.Forms.ToolStripStatusLabel();
+ this.btnPan = new System.Windows.Forms.Button();
+ this.btnRefresh = new System.Windows.Forms.Button();
+ this.btnClearSelection = new System.Windows.Forms.Button();
+ this.btnSelectCircle = new System.Windows.Forms.Button();
+ this.btnSelectPolygon = new System.Windows.Forms.Button();
+ this.btnSelect = new System.Windows.Forms.Button();
+ this.btnZoomExtents = new System.Windows.Forms.Button();
+ this.btnZoomOut = new System.Windows.Forms.Button();
+ this.btnZoomIn = new System.Windows.Forms.Button();
+ this.splitContainer1.Panel1.SuspendLayout();
+ this.splitContainer1.Panel2.SuspendLayout();
+ this.splitContainer1.SuspendLayout();
+ this.splitContainer2.Panel1.SuspendLayout();
+ this.splitContainer2.Panel2.SuspendLayout();
+ this.splitContainer2.SuspendLayout();
+ this.statusStrip1.SuspendLayout();
+ this.SuspendLayout();
+ // splitContainer1
+ this.splitContainer1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.splitContainer1.Location = new System.Drawing.Point(0, 0);
+ this.splitContainer1.Name = "splitContainer1";
+ // splitContainer1.Panel1
+ this.splitContainer1.Panel1.Controls.Add(this.splitContainer2);
+ // splitContainer1.Panel2
+ this.splitContainer1.Panel2.Controls.Add(this.btnPan);
+ this.splitContainer1.Panel2.Controls.Add(this.btnRefresh);
+ this.splitContainer1.Panel2.Controls.Add(this.btnClearSelection);
+ this.splitContainer1.Panel2.Controls.Add(this.btnSelectCircle);
+ this.splitContainer1.Panel2.Controls.Add(this.btnSelectPolygon);
+ this.splitContainer1.Panel2.Controls.Add(this.btnSelect);
+ this.splitContainer1.Panel2.Controls.Add(this.btnZoomExtents);
+ this.splitContainer1.Panel2.Controls.Add(this.btnZoomOut);
+ this.splitContainer1.Panel2.Controls.Add(this.btnZoomIn);
+ this.splitContainer1.Panel2.Controls.Add(this.mgMapViewer1);
+ this.splitContainer1.Size = new System.Drawing.Size(607, 495);
+ this.splitContainer1.SplitterDistance = 202;
+ this.splitContainer1.TabIndex = 3;
+ // splitContainer2
+ this.splitContainer2.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.splitContainer2.Location = new System.Drawing.Point(0, 0);
+ this.splitContainer2.Name = "splitContainer2";
+ this.splitContainer2.Orientation = System.Windows.Forms.Orientation.Horizontal;
+ // splitContainer2.Panel1
+ this.splitContainer2.Panel1.Controls.Add(this.mgLegend1);
+ // splitContainer2.Panel2
+ this.splitContainer2.Panel2.Controls.Add(this.mgPropertyPane1);
+ this.splitContainer2.Size = new System.Drawing.Size(202, 495);
+ this.splitContainer2.SplitterDistance = 235;
+ this.splitContainer2.TabIndex = 0;
+ // mgLegend1
+ this.mgLegend1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.mgLegend1.GroupContextMenu = null;
+ this.mgLegend1.LayerContextMenu = null;
+ this.mgLegend1.Location = new System.Drawing.Point(0, 0);
+ this.mgLegend1.Name = "mgLegend1";
+ this.mgLegend1.ShowTooltips = true;
+ this.mgLegend1.Size = new System.Drawing.Size(202, 235);
+ this.mgLegend1.TabIndex = 0;
+ this.mgLegend1.ThemeCompressionLimit = 0;
+ // mgPropertyPane1
+ this.mgPropertyPane1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.mgPropertyPane1.Location = new System.Drawing.Point(0, 0);
+ this.mgPropertyPane1.Name = "mgPropertyPane1";
+ this.mgPropertyPane1.Size = new System.Drawing.Size(202, 256);
+ this.mgPropertyPane1.TabIndex = 0;
+ // mgMapViewer1
+ this.mgMapViewer1.Cursor = System.Windows.Forms.Cursors.Default;
+ this.mgMapViewer1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.mgMapViewer1.Location = new System.Drawing.Point(0, 0);
+ this.mgMapViewer1.MaxScale = 1000000000;
+ this.mgMapViewer1.MinScale = 10;
+ this.mgMapViewer1.MouseWheelDelayRenderInterval = 800;
+ this.mgMapViewer1.Name = "mgMapViewer1";
+ this.mgMapViewer1.PointPixelBuffer = 2;
+ this.mgMapViewer1.RespectFiniteDisplayScales = false;
+ this.mgMapViewer1.SelectionColor = System.Drawing.Color.Blue;
+ this.mgMapViewer1.Size = new System.Drawing.Size(401, 495);
+ this.mgMapViewer1.TabIndex = 0;
+ this.mgMapViewer1.Text = "mgMapViewer1";
+ this.mgMapViewer1.TooltipDelayInterval = 1000;
+ this.mgMapViewer1.UseRenderMapIfTiledLayersExist = false;
+ this.mgMapViewer1.ZoomInFactor = 0.5;
+ this.mgMapViewer1.ZoomOutFactor = 2;
+ this.mgMapViewer1.SelectionChanged += new System.EventHandler(this.mgMapViewer1_SelectionChanged);
+ this.mgMapViewer1.PropertyChanged += new System.ComponentModel.PropertyChangedEventHandler(this.mgMapViewer1_PropertyChanged);
+ // statusStrip1
+ this.statusStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.lblCoords,
+ this.lblSelected,
+ this.lblScale,
+ this.lblSize});
+ this.statusStrip1.Location = new System.Drawing.Point(0, 495);
+ this.statusStrip1.Name = "statusStrip1";
+ this.statusStrip1.Size = new System.Drawing.Size(607, 22);
+ this.statusStrip1.TabIndex = 4;
+ this.statusStrip1.Text = "statusStrip1";
+ // lblCoords
+ this.lblCoords.Name = "lblCoords";
+ this.lblCoords.Size = new System.Drawing.Size(0, 17);
+ // lblSelected
+ this.lblSelected.Name = "lblSelected";
+ this.lblSelected.Size = new System.Drawing.Size(592, 17);
+ this.lblSelected.Spring = true;
+ this.lblSelected.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
+ // lblScale
+ this.lblScale.Name = "lblScale";
+ this.lblScale.Size = new System.Drawing.Size(0, 17);
+ this.lblScale.TextAlign = System.Drawing.ContentAlignment.MiddleLeft;
+ // lblSize
+ this.lblSize.Name = "lblSize";
+ this.lblSize.Size = new System.Drawing.Size(0, 17);
+ // btnPan
+ this.btnPan.BackColor = System.Drawing.Color.Transparent;
+ this.btnPan.FlatStyle = System.Windows.Forms.FlatStyle.Flat;
+ this.btnPan.Image = global::FreeFormExample.Properties.Resources.icon_pan;
+ this.btnPan.Location = new System.Drawing.Point(13, 44);
+ this.btnPan.Name = "btnPan";
+ this.btnPan.Size = new System.Drawing.Size(26, 26);
+ this.btnPan.TabIndex = 12;
+ this.btnPan.UseVisualStyleBackColor = false;
+ this.btnPan.Click += new System.EventHandler(this.btnPan_Click);
+ // btnRefresh
+ this.btnRefresh.BackColor = System.Drawing.Color.Transparent;
+ this.btnRefresh.FlatStyle = System.Windows.Forms.FlatStyle.Flat;
+ this.btnRefresh.Image = global::FreeFormExample.Properties.Resources.view_refresh;
+ this.btnRefresh.Location = new System.Drawing.Point(77, 44);
+ this.btnRefresh.Name = "btnRefresh";
+ this.btnRefresh.Size = new System.Drawing.Size(26, 26);
+ this.btnRefresh.TabIndex = 11;
+ this.btnRefresh.UseVisualStyleBackColor = false;
+ this.btnRefresh.Click += new System.EventHandler(this.btnRefresh_Click);
+ // btnClearSelection
+ this.btnClearSelection.BackColor = System.Drawing.Color.Transparent;
+ this.btnClearSelection.FlatStyle = System.Windows.Forms.FlatStyle.Flat;
+ this.btnClearSelection.Image = global::FreeFormExample.Properties.Resources.select_clear;
+ this.btnClearSelection.Location = new System.Drawing.Point(45, 44);
+ this.btnClearSelection.Name = "btnClearSelection";
+ this.btnClearSelection.Size = new System.Drawing.Size(26, 26);
+ this.btnClearSelection.TabIndex = 10;
+ this.btnClearSelection.UseVisualStyleBackColor = false;
+ this.btnClearSelection.Click += new System.EventHandler(this.btnClearSelection_Click);
+ // btnSelectCircle
+ this.btnSelectCircle.BackColor = System.Drawing.Color.Transparent;
+ this.btnSelectCircle.FlatStyle = System.Windows.Forms.FlatStyle.Flat;
+ this.btnSelectCircle.Image = global::FreeFormExample.Properties.Resources.select_radius;
+ this.btnSelectCircle.Location = new System.Drawing.Point(77, 76);
+ this.btnSelectCircle.Name = "btnSelectCircle";
+ this.btnSelectCircle.Size = new System.Drawing.Size(26, 26);
+ this.btnSelectCircle.TabIndex = 9;
+ this.btnSelectCircle.UseVisualStyleBackColor = false;
+ this.btnSelectCircle.Click += new System.EventHandler(this.btnSelectCircle_Click);
+ // btnSelectPolygon
+ this.btnSelectPolygon.BackColor = System.Drawing.Color.Transparent;
+ this.btnSelectPolygon.FlatStyle = System.Windows.Forms.FlatStyle.Flat;
+ this.btnSelectPolygon.Image = global::FreeFormExample.Properties.Resources.select_polygon;
+ this.btnSelectPolygon.Location = new System.Drawing.Point(45, 76);
+ this.btnSelectPolygon.Name = "btnSelectPolygon";
+ this.btnSelectPolygon.Size = new System.Drawing.Size(26, 26);
+ this.btnSelectPolygon.TabIndex = 8;
+ this.btnSelectPolygon.UseVisualStyleBackColor = false;
+ this.btnSelectPolygon.Click += new System.EventHandler(this.btnSelectPolygon_Click);
+ // btnSelect
+ this.btnSelect.BackColor = System.Drawing.Color.Transparent;
+ this.btnSelect.FlatStyle = System.Windows.Forms.FlatStyle.Flat;
+ this.btnSelect.Image = global::FreeFormExample.Properties.Resources.select_features;
+ this.btnSelect.Location = new System.Drawing.Point(13, 76);
+ this.btnSelect.Name = "btnSelect";
+ this.btnSelect.Size = new System.Drawing.Size(26, 26);
+ this.btnSelect.TabIndex = 7;
+ this.btnSelect.UseVisualStyleBackColor = false;
+ this.btnSelect.Click += new System.EventHandler(this.btnSelect_Click);
+ // btnZoomExtents
+ this.btnZoomExtents.BackColor = System.Drawing.Color.Transparent;
+ this.btnZoomExtents.FlatStyle = System.Windows.Forms.FlatStyle.Flat;
+ this.btnZoomExtents.Image = global::FreeFormExample.Properties.Resources.zoom_full;
+ this.btnZoomExtents.Location = new System.Drawing.Point(77, 12);
+ this.btnZoomExtents.Name = "btnZoomExtents";
+ this.btnZoomExtents.Size = new System.Drawing.Size(26, 26);
+ this.btnZoomExtents.TabIndex = 6;
+ this.btnZoomExtents.UseVisualStyleBackColor = false;
+ this.btnZoomExtents.Click += new System.EventHandler(this.btnZoomExtents_Click);
+ // btnZoomOut
+ this.btnZoomOut.BackColor = System.Drawing.Color.Transparent;
+ this.btnZoomOut.FlatStyle = System.Windows.Forms.FlatStyle.Flat;
+ this.btnZoomOut.Image = global::FreeFormExample.Properties.Resources.zoom_out_fixed;
+ this.btnZoomOut.Location = new System.Drawing.Point(45, 12);
+ this.btnZoomOut.Name = "btnZoomOut";
+ this.btnZoomOut.Size = new System.Drawing.Size(26, 26);
+ this.btnZoomOut.TabIndex = 4;
+ this.btnZoomOut.UseVisualStyleBackColor = false;
+ this.btnZoomOut.Click += new System.EventHandler(this.btnZoomOut_Click);
+ // btnZoomIn
+ this.btnZoomIn.BackColor = System.Drawing.Color.Transparent;
+ this.btnZoomIn.FlatStyle = System.Windows.Forms.FlatStyle.Flat;
+ this.btnZoomIn.Image = global::FreeFormExample.Properties.Resources.zoom_in_fixed;
+ this.btnZoomIn.Location = new System.Drawing.Point(13, 12);
+ this.btnZoomIn.Name = "btnZoomIn";
+ this.btnZoomIn.Size = new System.Drawing.Size(26, 26);
+ this.btnZoomIn.TabIndex = 3;
+ this.btnZoomIn.UseVisualStyleBackColor = false;
+ this.btnZoomIn.Click += new System.EventHandler(this.btnZoomIn_Click);
+ // MainForm
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.ClientSize = new System.Drawing.Size(607, 517);
+ this.Controls.Add(this.splitContainer1);
+ this.Controls.Add(this.statusStrip1);
+ this.Name = "MainForm";
+ this.Text = "mg-desktop free-form map viewer example";
+ this.splitContainer1.Panel1.ResumeLayout(false);
+ this.splitContainer1.Panel2.ResumeLayout(false);
+ this.splitContainer1.ResumeLayout(false);
+ this.splitContainer2.Panel1.ResumeLayout(false);
+ this.splitContainer2.Panel2.ResumeLayout(false);
+ this.splitContainer2.ResumeLayout(false);
+ this.statusStrip1.ResumeLayout(false);
+ this.statusStrip1.PerformLayout();
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.SplitContainer splitContainer1;
+ private System.Windows.Forms.SplitContainer splitContainer2;
+ private OSGeo.MapGuide.Viewer.MgLegend mgLegend1;
+ private OSGeo.MapGuide.Viewer.MgPropertyPane mgPropertyPane1;
+ private OSGeo.MapGuide.Viewer.MgMapViewer mgMapViewer1;
+ private System.Windows.Forms.Button btnZoomIn;
+ private System.Windows.Forms.Button btnZoomExtents;
+ private System.Windows.Forms.Button btnZoomOut;
+ private System.Windows.Forms.Button btnSelect;
+ private System.Windows.Forms.Button btnSelectPolygon;
+ private System.Windows.Forms.Button btnSelectCircle;
+ private System.Windows.Forms.Button btnRefresh;
+ private System.Windows.Forms.Button btnClearSelection;
+ private System.Windows.Forms.StatusStrip statusStrip1;
+ private System.Windows.Forms.ToolStripStatusLabel lblCoords;
+ private System.Windows.Forms.ToolStripStatusLabel lblSelected;
+ private System.Windows.Forms.ToolStripStatusLabel lblScale;
+ private System.Windows.Forms.ToolStripStatusLabel lblSize;
+ private System.Windows.Forms.Button btnPan;
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.cs
--- branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.cs (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.cs 2012-10-03 16:47:53 UTC (rev 7069)
@@ -0,0 +1,233 @@
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.Viewer.Desktop;
+using OSGeo.MapGuide;
+using OSGeo.MapGuide.Viewer;
+using System.Globalization;
+ public partial class MainForm : Form, IMapStatusBar
+ public MainForm()
+ InitializeComponent();
+ private MgWktReaderWriter _wktRw;
+ private MgGeometryFactory _geomFact;
+ protected override void OnLoad(EventArgs e)
+ _wktRw = new MgWktReaderWriter();
+ _geomFact = new MgGeometryFactory();
+ new MapViewerController(mgMapViewer1, //The MgMapViewer
+ mgLegend1, //The MgLegend
+ this, //The IMapStatusBar
+ mgPropertyPane1); //The MgPropertyPane
+ MgdServiceFactory factory = new MgdServiceFactory();
+ MgdResourceService resSvc = (MgdResourceService)factory.CreateService(MgServiceType.ResourceService);
+ MgResourceIdentifier mapDefId = new MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
+ //If this map definition doesn't exist, we ask the user to
+ //load the Sheboygan package
+ if (!resSvc.ResourceExists(mapDefId))
+ using (OpenFileDialog diag = new OpenFileDialog())
+ diag.Filter = "MapGuide Packages (*.mgp)|*.mgp";
+ if (diag.ShowDialog() == DialogResult.OK)
+ MgByteSource source = new MgByteSource(diag.FileName);
+ MgByteReader reader = source.GetReader();
+ resSvc.ApplyResourcePackage(reader);
+ else
+ //No map, nothing to do here
+ Application.Exit();
+ //Create our runtime map
+ MgdMap map = new MgdMap(mapDefId);
+ //Create our viewer provider
+ MgMapViewerProvider provider = new MgDesktopMapViewerProvider(map);
+ //Initialize our viewer with this provider
+ mgMapViewer1.Init(provider);
+ UpdateButtonCheckedState();
+ public void SetCursorPositionMessage(string message)
+ lblCoords.Text = message;
+ public void SetFeatureSelectedMessage(string message)
+ lblSelected.Text = message;
+ public void SetMapScaleMessage(string message)
+ lblScale.Text = message;
+ public void SetMapSizeMessage(string message)
+ lblSize.Text = message;
+ private void mgMapViewer1_SelectionChanged(object sender, EventArgs e)
+ MgSelectionBase selection = mgMapViewer1.GetSelection();
+ MgReadOnlyLayerCollection layers = selection.GetLayers();
+ if (layers != null)
+ for (int i = 0; i < layers.GetCount(); i++)
+ MgLayerBase layer = layers.GetItem(i);
+ if (layer.Name == "Parcels") //The selected layer is parcels
+ //Check that we only have one selected object
+ int count = selection.GetSelectedFeaturesCount(layer, layer.FeatureClassName);
+ if (count == 1)
+ MgFeatureReader reader = null;
+ try
+ reader = selection.GetSelectedFeatures(layer, layer.FeatureClassName, false);
+ if (reader.ReadNext())
+ //Address is in the RPROPAD property
+ if (reader.IsNull("RPROPAD"))
+ MessageBox.Show("Selected parcel has no address");
+ else
+ MessageBox.Show("Address: " + reader.GetString("RPROPAD"));
+ finally //Must close all readers, otherwise connections will leak
+ reader.Close();
+ else
+ MessageBox.Show("Please select only one parcel");
+ break;
+ private void btnZoomIn_Click(object sender, EventArgs e)
+ mgMapViewer1.ActiveTool = MapActiveTool.ZoomIn;
+ private void btnZoomOut_Click(object sender, EventArgs e)
+ mgMapViewer1.ActiveTool = MapActiveTool.ZoomOut;
+ private void btnZoomExtents_Click(object sender, EventArgs e)
+ mgMapViewer1.InitialMapView();
+ private void btnSelect_Click(object sender, EventArgs e)
+ mgMapViewer1.ActiveTool = MapActiveTool.Select;
+ private void btnSelectPolygon_Click(object sender, EventArgs e)
+ mgMapViewer1.DigitizePolygon((coordinates) =>
+ MgCoordinateCollection coords = new MgCoordinateCollection();
+ for (int i = 0; i < coordinates.GetLength(0); i++)
+ coords.Add(_geomFact.CreateCoordinateXY(coordinates[i, 0], coordinates[i, 1]));
+ coords.Add(_geomFact.CreateCoordinateXY(coordinates[0, 0], coordinates[0, 1]));
+ MgLinearRing ring = _geomFact.CreateLinearRing(coords);
+ MgGeometry poly = _geomFact.CreatePolygon(ring, null);
+ mgMapViewer1.SelectByGeometry(poly);
+ static string MakeWktCircle(double x, double y, double r)
+ return "CURVEPOLYGON ((" + (x - r).ToString(CultureInfo.InvariantCulture) + " " + y.ToString(CultureInfo.InvariantCulture) + " (CIRCULARARCSEGMENT (" + x.ToString(CultureInfo.InvariantCulture) + " " + (y - r).ToString(CultureInfo.InvariantCulture) + ", " + (x + r).ToString(CultureInfo.InvariantCulture) + " " + y.ToString(CultureInfo.InvariantCulture) + "), CIRCULARARCSEGMENT (" + x.ToString(CultureInfo.InvariantCulture) + " " + (y + r).ToString(CultureInfo.InvariantCulture) + ", " + (x - r).ToString(CultureInfo.InvariantCulture) + " " + y.ToString(CultureInfo.InvariantCulture) + "))))"; //NOXLATE
+ static string MakeWktPolygon(double x1, double y1, double x2, double y2)
+ string x1str = x1.ToString(CultureInfo.InvariantCulture);
+ string y1str = y1.ToString(CultureInfo.InvariantCulture);
+ string x2str = x2.ToString(CultureInfo.InvariantCulture);
+ string y2str = y2.ToString(CultureInfo.InvariantCulture);
+ return "POLYGON((" + x1str + " " + y1str + ", " + x2str + " " + y1str + ", " + x2str + " " + y2str + ", " + x1str + " " + y2str + ", " + x1str + " " + y1str + "))"; //NOXLATE
+ private void btnSelectCircle_Click(object sender, EventArgs e)
+ mgMapViewer1.DigitizeCircle((x, y, r) =>
+ MgGeometry geom = _wktRw.Read(MakeWktCircle(x, y, r));
+ mgMapViewer1.SelectByGeometry(geom);
+ private void btnClearSelection_Click(object sender, EventArgs e)
+ mgMapViewer1.ClearSelection();
+ private void btnRefresh_Click(object sender, EventArgs e)
+ mgMapViewer1.RefreshMap();
+ private void mgMapViewer1_PropertyChanged(object sender, PropertyChangedEventArgs e)
+ if (e.PropertyName == "IsBusy") //NOXLATE
+ var busy = mgMapViewer1.IsBusy;
+ btnZoomExtents.Enabled = btnZoomIn.Enabled
+ = btnZoomOut.Enabled
+ = btnClearSelection.Enabled
+ = btnPan.Enabled
+ = btnSelect.Enabled
+ = btnSelectPolygon.Enabled
+ = btnSelectCircle.Enabled
+ = btnRefresh.Enabled = !busy;
+ else if (e.PropertyName == "ActiveTool" || e.PropertyName == "DigitizingType") //NOXLATE
+ private void UpdateButtonCheckedState()
+ var at = (mgMapViewer1 == null) ? MapActiveTool.None : mgMapViewer1.ActiveTool;
+ btnPan.BackColor = (at == MapActiveTool.Pan) ? Color.LemonChiffon : Control.DefaultBackColor;
+ btnSelect.BackColor = (at == MapActiveTool.Select) ? Color.LemonChiffon : Control.DefaultBackColor;
+ btnZoomIn.BackColor = (at == MapActiveTool.ZoomIn) ? Color.LemonChiffon : Control.DefaultBackColor;
+ btnZoomOut.BackColor = (at == MapActiveTool.ZoomOut) ? Color.LemonChiffon : Control.DefaultBackColor;
+ private void btnPan_Click(object sender, EventArgs e)
+ mgMapViewer1.ActiveTool = MapActiveTool.Pan;
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.resx
--- branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.resx (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/FreeFormExample/MainForm.resx 2012-10-03 16:47:53 UTC (rev 7069)
@@ -0,0 +1,123 @@
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <metadata name="statusStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+</root>
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Program.cs
--- branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Program.cs (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Program.cs 2012-10-03 16:47:53 UTC (rev 7069)
@@ -0,0 +1,23 @@
+using System;
+ static class Program
+ /// <summary>
+ /// The main entry point for the application.
+ /// </summary>
+ [STAThread]
+ static void Main()
+ MgdPlatform.Initialize("Platform.ini");
+ Application.EnableVisualStyles();
+ Application.SetCompatibleTextRenderingDefault(false);
+ Application.Run(new MainForm());
+ MgdPlatform.Terminate();
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties
+ true
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/AssemblyInfo.cs
--- branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/AssemblyInfo.cs (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/AssemblyInfo.cs 2012-10-03 16:47:53 UTC (rev 7069)
@@ -0,0 +1,36 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("FreeFormExample")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyProduct("FreeFormExample")]
+[assembly: AssemblyCopyright("Copyright © 2012")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components. If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("9b7750d6-26d1-4791-b252-b4b40ebc057a")]
+// Version information for an assembly consists of the following four values:
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// You can specify all the values or you can default the Build and Revision Numbers
+// by using the '*' as shown below:
+// [assembly: AssemblyVersion("1.0.*")]
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Resources.Designer.cs
--- branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Resources.Designer.cs (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Resources.Designer.cs 2012-10-03 16:47:53 UTC (rev 7069)
@@ -0,0 +1,140 @@
+// <auto-generated>
+// This code was generated by a tool.
+// Runtime Version:2.0.50727.5420
+// Changes to this file may cause incorrect behavior and will be lost if
+// the code is regenerated.
+// </auto-generated>
+namespace FreeFormExample.Properties {
+ using System;
+ /// <summary>
+ /// A strongly-typed resource class, for looking up localized strings, etc.
+ /// </summary>
+ // This class was auto-generated by the StronglyTypedResourceBuilder
+ // class via a tool like ResGen or Visual Studio.
+ // To add or remove a member, edit your .ResX file then rerun ResGen
+ // with the /str option, or rebuild your VS project.
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "2.0.0.0")]
+ [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
+ [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
+ internal class Resources {
+ private static global::System.Resources.ResourceManager resourceMan;
+ private static global::System.Globalization.CultureInfo resourceCulture;
+ [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
+ internal Resources() {
+ /// <summary>
+ /// Returns the cached ResourceManager instance used by this class.
+ /// </summary>
+ [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
+ internal static global::System.Resources.ResourceManager ResourceManager {
+ get {
+ if (object.ReferenceEquals(resourceMan, null)) {
+ global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("FreeFormExample.Properties.Resources", typeof(Resources).Assembly);
+ resourceMan = temp;
+ return resourceMan;
+ /// <summary>
+ /// Overrides the current thread's CurrentUICulture property for all
+ /// resource lookups using this strongly typed resource class.
+ /// </summary>
+ internal static global::System.Globalization.CultureInfo Culture {
+ get {
+ return resourceCulture;
+ set {
+ resourceCulture = value;
+ internal static System.Drawing.Bitmap icon_pan {
+ get {
+ object obj = ResourceManager.GetObject("icon_pan", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
+ internal static System.Drawing.Bitmap lc_select {
+ get {
+ object obj = ResourceManager.GetObject("lc_select", resourceCulture);
+ internal static System.Drawing.Bitmap select_clear {
+ get {
+ object obj = ResourceManager.GetObject("select-clear", resourceCulture);
+ internal static System.Drawing.Bitmap select_features {
+ get {
+ object obj = ResourceManager.GetObject("select-features", resourceCulture);
+ internal static System.Drawing.Bitmap select_polygon {
+ get {
+ object obj = ResourceManager.GetObject("select-polygon", resourceCulture);
+ internal static System.Drawing.Bitmap select_radius {
+ get {
+ object obj = ResourceManager.GetObject("select-radius", resourceCulture);
+ internal static System.Drawing.Bitmap view_refresh {
+ get {
+ object obj = ResourceManager.GetObject("view-refresh", resourceCulture);
+ internal static System.Drawing.Bitmap zoom_full {
+ get {
+ object obj = ResourceManager.GetObject("zoom-full", resourceCulture);
+ internal static System.Drawing.Bitmap zoom_in {
+ get {
+ object obj = ResourceManager.GetObject("zoom-in", resourceCulture);
+ internal static System.Drawing.Bitmap zoom_in_fixed {
+ get {
+ object obj = ResourceManager.GetObject("zoom-in-fixed", resourceCulture);
+ internal static System.Drawing.Bitmap zoom_out_fixed {
+ get {
+ object obj = ResourceManager.GetObject("zoom-out-fixed", resourceCulture);
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Resources.resx
--- branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Resources.resx (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Resources.resx 2012-10-03 16:47:53 UTC (rev 7069)
@@ -0,0 +1,154 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="zoom-out-fixed" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\zoom-out-fixed.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="lc_select" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\lc_select.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="view-refresh" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\view-refresh.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="select-radius" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\select-radius.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="select-features" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\select-features.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="zoom-full" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\zoom-full.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="zoom-in" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\zoom-in.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="select-polygon" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\select-polygon.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="select-clear" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\select-clear.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="zoom-in-fixed" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\zoom-in-fixed.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+ <data name="icon_pan" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\icon_pan.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
+</root>
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Settings.Designer.cs
--- branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Settings.Designer.cs (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Settings.Designer.cs 2012-10-03 16:47:53 UTC (rev 7069)
@@ -0,0 +1,30 @@
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "9.0.0.0")]
+ internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase
+ private static Settings defaultInstance = ((Settings)(global::System.Configuration.ApplicationSettingsBase.Synchronized(new Settings())));
+ public static Settings Default
+ get
+ return defaultInstance;
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Settings.settings
--- branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Settings.settings (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Properties/Settings.settings 2012-10-03 16:47:53 UTC (rev 7069)
@@ -0,0 +1,7 @@
+<?xml version='1.0' encoding='utf-8'?>
+<SettingsFile xmlns="http://schemas.microsoft.com/VisualStudio/2004/01/settings" CurrentProfile="(Default)">
+ <Profiles>
+ <Profile Name="(Default)" />
+ </Profiles>
+ <Settings />
+</SettingsFile>
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources
+ true
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/icon_pan.gif
(Binary files differ)
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/icon_pan.gif
Added: svn:mime-type
+ application/octet-stream
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/lc_select.gif
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/lc_select.gif
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-clear.png
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-clear.png
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-features.png
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-features.png
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-polygon.png
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-polygon.png
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-radius.png
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/select-radius.png
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/view-refresh.png
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/view-refresh.png
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-full.png
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-full.png
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-in-fixed.png
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-in-fixed.png
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-in.png
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-in.png
Added: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-out-fixed.png
Property changes on: branches/2.4/MgDev/Desktop/Samples/FreeFormExample/Resources/zoom-out-fixed.png
Added: branches/2.4/MgDev/Desktop/Samples/Lib/SheboyganSample.AppLayout
--- branches/2.4/MgDev/Desktop/Samples/Lib/SheboyganSample.AppLayout (rev 0)
+++ branches/2.4/MgDev/Desktop/Samples/Lib/SheboyganSample.AppLayout 2012-10-03 16:47:53 UTC (rev 7069)
@@ -0,0 +1,533 @@
+<?xml version="1.0"?>
+<AppLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
+ <Title>MapGuide Desktop App Layout Example</Title>
+ <Icon>app.ico</Icon>
+ <Settings>
+ <NameValue>
+ <Name>InvokeOnStartup</Name>
+ <Value>component:Startup</Value>
+ </NameValue>
+ <NameValue>
+ <Name>SelectionColor</Name>
+ <Value>color:0000FF</Value>
+ </NameValue>
+ <NameValue>
+ <Name>ConvertTiledGroupsToNonTiled</Name>
+ <Value>false</Value>
+ </NameValue>
+ <NameValue>
+ <Name>UseRenderMapIfTiledLayersExist</Name>
+ </NameValue>
+ <NameValue>
+ <Name>RespectFiniteDisplayScales</Name>
+ </NameValue>
+ <NameValue>
+ <Name>ShowVertexCoordinatesWhenDigitizing</Name>
+ </NameValue>
+ <NameValue>
+ <Name>ZoomInFactor</Name>
+ <Value>0.5</Value>
+ </NameValue>
+ <NameValue>
+ <Name>ZoomOutFactor</Name>
+ <Value>2</Value>
+ </NameValue>
+ <NameValue>
+ <Name>PointPixelBuffer</Name>
+ <Value>3</Value>
+ </NameValue>
+ </Settings>
+ <InfoPane>
+ <Width>200</Width>
+ <Legend>
+ <Visible>true</Visible>
+ <ShowTooltips>true</ShowTooltips>
+ <ThemeCompressionLimit>25</ThemeCompressionLimit>
+ </Legend>
+ <PropertyPane>
+ </PropertyPane>
+ </InfoPane>
+ <Map>
+ <Name>Sheboygan</Name>
+ <MapDefinition>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</MapDefinition>
+ </Map>
+ <Menu>
+ <Items>
+ <ItemBase xsi:type="SubMenu">
+ <Label>File</Label>
+ <Items>
+ <ItemBase xsi:type="CommandItem">
+ <ComponentID>LoadMap</ComponentID>
+ <ShowLabel>false</ShowLabel>
+ </ItemBase>
+ <ComponentID>LoadPackage</ComponentID>
+ </ItemBase>
+ <ItemBase xsi:type="SeparatorItem" />
+ <ComponentID>Quit</ComponentID>
+ </ItemBase>
+ </Items>
+ </ItemBase>
+ <Label>Tools</Label>
+ <Items>
+ <ComponentID>Buffer</ComponentID>
+ </ItemBase>
+ <ComponentID>Measure</ComponentID>
+ </ItemBase>
+ <ComponentID>Query</ComponentID>
+ </ItemBase>
+ <ComponentID>Theme</ComponentID>
+ </ItemBase>
+ <ComponentID>ViewerOptions</ComponentID>
+ </ItemBase>
+ </Items>
+ </ItemBase>
+ </Items>
+ </Menu>
+ <Toolbar>
+ <Items>
+ <ComponentID>PrintMap</ComponentID>
+ </ItemBase>
+ <ComponentID>CopyMap</ComponentID>
+ </ItemBase>
+ <ComponentID>ZoomIn</ComponentID>
+ </ItemBase>
+ <ComponentID>ZoomOut</ComponentID>
+ </ItemBase>
+ <ComponentID>InitialView</ComponentID>
+ </ItemBase>
+ <ComponentID>ZoomPrev</ComponentID>
+ </ItemBase>
+ <ComponentID>ZoomNext</ComponentID>
+ </ItemBase>
+ <ComponentID>Select</ComponentID>
+ </ItemBase>
+ <ComponentID>SelectRadius</ComponentID>
+ </ItemBase>
+ <ComponentID>SelectPolygon</ComponentID>
+ </ItemBase>
+ <ComponentID>Pan</ComponentID>
+ </ItemBase>
+ <ComponentID>ClearSelection</ComponentID>
+ </ItemBase>
+ <ComponentID>RefreshMap</ComponentID>
+ </ItemBase>
+ <ComponentID>TooltipToggle</ComponentID>
+ <ShowLabel>true</ShowLabel>
+ </ItemBase>
+ <Items>
+ </ItemBase>
+ </ItemBase>
+ </ItemBase>
+ </ItemBase>
+ </ItemBase>
+ </Items>
+ </ItemBase>
+ <Label>Custom</Label>
+ <Items>
+ <ComponentID>PlotToDwf</ComponentID>
+ </ItemBase>
+ <ComponentID>Profile</ComponentID>
+ </ItemBase>
+ </Items>
+ </ItemBase>
+ </Items>
+ </Toolbar>
+ <ContextMenu>
+ <Items>
+ </ItemBase>
+ </ItemBase>
+ </ItemBase>
+ <ComponentID>ZoomToSelection</ComponentID>
+ </ItemBase>
+ </ItemBase>
+ </ItemBase>
+ </ItemBase>
+ </ItemBase>
+ <Items>
+ </ItemBase>
+ </ItemBase>
+ </ItemBase>
+ </ItemBase>
+ </Items>
+ </ItemBase>
+ </ItemBase>
+ </Items>
+ </ContextMenu>
+ <TaskPane>
+ <Width>250</Width>
+ <InitialComponentID>SamplesTaskPane</InitialComponentID>
+ <TaskMenu>
+ <Items>
+ </ItemBase>
+ </ItemBase>
+ </ItemBase>
+ </ItemBase>
+ </Items>
+ </TaskMenu>
+ </TaskPane>
+ <Components>
+ <ComponentDefinition>
+ <ClassName>OSGeo.MapGuide.Viewer.MgBufferComponent</ClassName>
+ <Properties>
+ <NameValue>
+ <Name>DefaultLayerName</Name>
+ <Value>BufferLayer</Value>
+ </NameValue>
+ <NameValue>
+ <Name>DefaultBufferUnits</Name>
+ <Value>enum:OSGeo.MapGuide.Viewer.MeasurementUnit:Meters</Value>
+ </NameValue>
+ <NameValue>
+ <Name>Target</Name>
+ <Value>enum:OSGeo.MapGuide.Viewer.MgViewerTarget:TaskPane</Value>
+ </NameValue>
+ <NameValue>
+ <Name>TaskPane</Name>
+ <Value>taskpane:</Value>
+ </NameValue>
+ </Properties>
+ </ComponentDefinition>
+ <ClassName>OSGeo.MapGuide.Viewer.MgCircleSelectComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgClearSelectionComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgCopyMapComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgInitialViewComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgLoadMapComponent</ClassName>
+ <Properties>
+ <NameValue>
+ <Name>Label</Name>
+ <Value>Load Sheboygan Map</Value>
+ </NameValue>
+ <NameValue>
+ <Name>MapDefinition</Name>
+ <Value>map:Sheboygan</Value>
+ </NameValue>
+ </Properties>
+ <ClassName>OSGeo.MapGuide.Viewer.MgLoadPackageComponent</ClassName>
+ <Properties>
+ <NameValue>
+ <Name>InvokeOnPackageLoad</Name>
+ <Value>component:LoadMap</Value>
+ </NameValue>
+ </Properties>
+ <ClassName>OSGeo.MapGuide.Viewer.MgMeasureComponent</ClassName>
+ <Properties>
+ <NameValue>
+ <Name>MeasureMode</Name>
+ <Value>enum:OSGeo.MapGuide.Viewer.MeasureMode:Line</Value>
+ </NameValue>
+ <NameValue>
+ <Name>PreferredUnits</Name>
+ </NameValue>
+ <NameValue>
+ </NameValue>
+ <NameValue>
+ </NameValue>
+ </Properties>
+ <ClassName>OSGeo.MapGuide.Viewer.MgPanComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgPolygonSelectComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgPrintComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgQueryComponent</ClassName>
+ <Properties>
+ <NameValue>
+ </NameValue>
+ <NameValue>
+ </NameValue>
+ </Properties>
+ <ClassName>OSGeo.MapGuide.Viewer.AppLayoutEngine.MgQuitComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgRefreshMapComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgSelectComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgThemeComponent</ClassName>
+ <Properties>
+ <NameValue>
+ </NameValue>
+ <NameValue>
+ </NameValue>
+ </Properties>
+ <ClassName>OSGeo.MapGuide.Viewer.MgTooltipToggleComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgViewerOptionsComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgZoomInComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgZoomNextComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgZoomOutComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgZoomPreviousComponent</ClassName>
+ <ClassName>OSGeo.MapGuide.Viewer.MgZoomToSelectionComponent</ClassName>
+ <Assembly>SampleExtension.dll</Assembly>
+ <ClassName>SampleExtension.MgPlotToDwfComponent</ClassName>
+ <ClassName>SampleExtension.MgProfileComponent</ClassName>
+ <ComponentID>Startup</ComponentID>
+ <ClassName>SampleExtension.MgStartupComponent</ClassName>
+ <ComponentID>SamplesTaskPane</ComponentID>
+ <ClassName>SampleExtension.MgSampleTaskPaneComponent</ClassName>
+ <ComponentID>HelloMap</ComponentID>
+ <ClassName>SampleExtension.MgHelloMapComponent</ClassName>
+ <ComponentID>HelloViewer</ComponentID>
+ <ClassName>SampleExtension.MgHelloViewerComponent</ClassName>
+ <ComponentID>InteractingWithLayers</ComponentID>
+ <ClassName>SampleExtension.MgInteractingWithLayersComponent</ClassName>
+ <ComponentID>WorkingWithFeatureData</ComponentID>
+ <ClassName>SampleExtension.MgWorkingWithFeatureDataComponent</ClassName>
+ <ComponentID>ModifyingMapsAndLayers</ComponentID>
+ <ClassName>SampleExtension.MgModifyingMapsAndLayersComponent</ClassName>
+ <ComponentID>AnalyzingFeatures</ComponentID>
+ <ClassName>SampleExtension.MgAnalyzingFeaturesComponent</ClassName>
+ <ComponentID>DigitizingAndRedlining</ComponentID>
+ <ClassName>SampleExtension.MgDigitizingAndRedliningComponent</ClassName>
+ <ComponentID>CustomOutput</ComponentID>
+ <ClassName>SampleExtension.MgCustomOutputComponent</ClassName>
+ <ComponentID>PrePostRender</ComponentID>
+ <ClassName>SampleExtension.MgPrePostRenderingComponent</ClassName>
+ </Components>
+</AppLayout>
Modified: branches/2.4/MgDev/Desktop/Samples/MgDesktopSamples.sln
--- branches/2.4/MgDev/Desktop/Samples/MgDesktopSamples.sln 2012-10-03 15:01:55 UTC (rev 7068)
+++ branches/2.4/MgDev/Desktop/Samples/MgDesktopSamples.sln 2012-10-03 16:47:53 UTC (rev 7069)
@@ -7,6 +7,8 @@
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "AdvancedSample", "AdvancedSample\AdvancedSample.csproj", "{AB9B45B7-38BF-4FFD-B809-A23F74A6C505}"
EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "FreeFormExample", "FreeFormExample\FreeFormExample.csproj", "{41EF1524-D186-4079-BAA9-1A99F0AC31CA}"
+EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Debug|x86 = Debug|x86
@@ -25,6 +27,10 @@
{AB9B45B7-38BF-4FFD-B809-A23F74A6C505}.Debug|x86.Build.0 = Debug|x86
{AB9B45B7-38BF-4FFD-B809-A23F74A6C505}.Release|x86.ActiveCfg = Release|x86
{AB9B45B7-38BF-4FFD-B809-A23F74A6C505}.Release|x86.Build.0 = Release|x86
+ {41EF1524-D186-4079-BAA9-1A99F0AC31CA}.Debug|x86.ActiveCfg = Debug|x86
+ {41EF1524-D186-4079-BAA9-1A99F0AC31CA}.Debug|x86.Build.0 = Debug|x86
+ {41EF1524-D186-4079-BAA9-1A99F0AC31CA}.Release|x86.ActiveCfg = Release|x86
+ {41EF1524-D186-4079-BAA9-1A99F0AC31CA}.Release|x86.Build.0 = Release|x86
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
Modified: branches/2.4/MgDev/Desktop/Samples/SampleExtension/SampleExtension.csproj
--- branches/2.4/MgDev/Desktop/Samples/SampleExtension/SampleExtension.csproj 2012-10-03 15:01:55 UTC (rev 7068)
+++ branches/2.4/MgDev/Desktop/Samples/SampleExtension/SampleExtension.csproj 2012-10-03 16:47:53 UTC (rev 7069)
@@ -290,6 +290,6 @@
copy /y "$(SolutionDir)Lib\MgAppLayout.exe" "$(TargetDir)"
-copy /y "$(SolutionDir)Lib\Sheboygan.AppLayout" "$(TargetDir)"</PostBuildEvent>
+copy /y "$(SolutionDir)Lib\SheboyganSample.AppLayout" "$(TargetDir)"</PostBuildEvent>
</PropertyGroup>
</Project>
Modified: branches/2.4/MgDev/Desktop/Samples/samples_readme.txt
--- branches/2.4/MgDev/Desktop/Samples/samples_readme.txt 2012-10-03 15:01:55 UTC (rev 7068)
+++ branches/2.4/MgDev/Desktop/Samples/samples_readme.txt 2012-10-03 16:47:53 UTC (rev 7069)
@@ -20,6 +20,11 @@
Demonstrates a Windows Forms Application that embeds the mg-desktop map viewer and shows how to do things like measuring and digitizing
+FreeFormSample
+Demonstrates that the MgMapViewer control is like any other WinForms control, and that you can have your toolbar buttons on top of the viewer control itself, allowing for a minimal user interface.
SampleExtension
More information about the mapguide-commits
