[mapguide-commits] r7095 - branches/2.4/MgDev
svn_mapguide at osgeo.org
Mon Oct 8 05:50:46 PDT 2012
Author: jng
Date: 2012-10-08 05:50:46 -0700 (Mon, 08 Oct 2012)
New Revision: 7095
branches/2.4/MgDev/build_fusion.bat
Update build_fusion.bat to support the new "selfbuild" target. This creates a buildtools.zip for fusion containing the necessary files and tools (outside of Apache Ant) to "re-compile" a fusionSF.js and fusionSF-compressed.js from scratch on a production Fusion installation.
Modified: branches/2.4/MgDev/build_fusion.bat
--- branches/2.4/MgDev/build_fusion.bat 2012-10-08 12:04:00 UTC (rev 7094)
+++ branches/2.4/MgDev/build_fusion.bat 2012-10-08 12:50:46 UTC (rev 7095)
@@ -6,4 +6,6 @@
echo [build]: Web Tier - Build Fusion API docs
call %ANT% docs -f "%MG_OEM%\fusion\build.xml"
echo [build]: Web Tier - fusion
-call %ANT% deploy -Ddeploy.home="%MG_OEM%\fusion_build" -f "%MG_OEM%\fusion\build.xml"
\ No newline at end of file
+call %ANT% deploy -Ddeploy.home="%MG_OEM%\fusion_build" -f "%MG_OEM%\fusion\build.xml"
+echo [build]: Fusion - build pack
+call %ANT% selfbuild -Dselfbuild.home="%MG_OUTPUT%\fusion-selfbuild" -f "%MG_OEM%\fusion\build.xml"
More information about the mapguide-commits
