[mapguide-commits] r7111 - in trunk/MgDev: Common/MapGuideCommon/System Server/src/Core Server/src/UnitTesting
svn_mapguide at osgeo.org
Fri Oct 12 04:26:27 PDT 2012
Author: baertelchen
Date: 2012-10-12 04:26:26 -0700 (Fri, 12 Oct 2012)
New Revision: 7111
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
trunk/MgDev/Server/src/Core/Server.cpp
trunk/MgDev/Server/src/Core/serverconfig.ini
trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.h
Support MentorUserDictionaryPath in serverconfig.ini (part of RFC 127)
Implemented support for the [MentorUserDictionaryPath] setting in the serverconfig.ini file.
If that setting is available (i.e. not an empty string), the server startup code will call into
the MgCoordinateSystemCatalog's SetUserDictionaryDir() method thus overriding
the default location of the user dictionary path - which may or may not have been set before.
While an invalid [MentorDictionaryPath] setting leads to the server to failing to startup, an invalid
[MentorUserDictionaryPath] does not. It will be logged as a warning though.
Changes reviewed by Jackie.
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2012-10-12 03:02:26 UTC (rev 7110)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2012-10-12 11:26:26 UTC (rev 7111)
@@ -134,6 +134,8 @@
const STRING MgConfigProperties::DefaultGeneralPropertyFdoPath = L"";
const STRING MgConfigProperties::GeneralPropertyMentorDictionaryPath = L"MentorDictionaryPath";
const STRING MgConfigProperties::DefaultGeneralPropertyMentorDictionaryPath = L"";
+const STRING MgConfigProperties::GeneralPropertyMentorUserDictionaryPath = L"MentorUserDictionaryPath";
+const STRING MgConfigProperties::DefaultGeneralPropertyMentorUserDictionaryPath = L"";
const STRING MgConfigProperties::GeneralPropertyLicenseServerPath = L"LicenseServerPath";
const STRING MgConfigProperties::DefaultGeneralPropertyLicenseServerPath = L"";
const STRING MgConfigProperties::GeneralPropertyLinuxMemDebug = L"LinuxMemDebug";
@@ -565,6 +567,7 @@
{ MgConfigProperties::GeneralPropertyDisplayName , MgPropertyType::String , MG_CONFIG_MIN_OPTIONAL_STRING_LENGTH , MG_CONFIG_MAX_OPTIONAL_STRING_LENGTH , MG_CONFIG_FILE_NAME_RESERVED_CHARACTERS },
{ MgConfigProperties::GeneralPropertyFdoPath , MgPropertyType::String , MG_CONFIG_MIN_PATH_LENGTH , MG_CONFIG_MAX_PATH_LENGTH , MG_CONFIG_PATH_RESERVED_CHARACTERS },
{ MgConfigProperties::GeneralPropertyMentorDictionaryPath , MgPropertyType::String , MG_CONFIG_MIN_PATH_LENGTH , MG_CONFIG_MAX_PATH_LENGTH , MG_CONFIG_PATH_RESERVED_CHARACTERS },
+ { MgConfigProperties::GeneralPropertyMentorUserDictionaryPath , MgPropertyType::String , MG_CONFIG_MIN_PATH_LENGTH , MG_CONFIG_MAX_PATH_LENGTH , MG_CONFIG_PATH_RESERVED_CHARACTERS },
{ MgConfigProperties::GeneralPropertyLicenseServerPath , MgPropertyType::String , MG_CONFIG_MIN_OPTIONAL_STRING_LENGTH , MG_CONFIG_MAX_OPTIONAL_STRING_LENGTH , L"" },
{ MgConfigProperties::GeneralPropertyLinuxMemDebug , MgPropertyType::Boolean , 0 , 1 , L"" },
{ MgConfigProperties::GeneralPropertyLogsDelimiter , MgPropertyType::String , 1 , 128 , L"" },
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2012-10-12 03:02:26 UTC (rev 7110)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2012-10-12 11:26:26 UTC (rev 7111)
@@ -74,6 +74,10 @@
static const STRING GeneralPropertyMentorDictionaryPath; /// value("MentorDictionaryPath")
static const STRING DefaultGeneralPropertyMentorDictionaryPath; /// value("")
+ /// Mentor User Dictionary Path
+ static const STRING GeneralPropertyMentorUserDictionaryPath; /// value("MentorUserDictionaryPath")
+ static const STRING DefaultGeneralPropertyMentorUserDictionaryPath; /// value("")
/// Path of the license server
static const STRING GeneralPropertyLicenseServerPath; /// value("LicenseServerPath")
static const STRING DefaultGeneralPropertyLicenseServerPath; /// value("");
Modified: trunk/MgDev/Server/src/Core/Server.cpp
--- trunk/MgDev/Server/src/Core/Server.cpp 2012-10-12 03:02:26 UTC (rev 7110)
+++ trunk/MgDev/Server/src/Core/Server.cpp 2012-10-12 11:26:26 UTC (rev 7111)
@@ -721,6 +721,7 @@
ACE_UNUSED_ARG(args);
int nResult = 0;
STRING mentorDictPath;
+ STRING mentorUserDictPath;
MG_TRY()
@@ -882,14 +883,49 @@
// Check if path ends with a '/' if not, add one if needed
MgFileUtil::AppendSlashToEndOfPath(mentorDictPath);
- csCatalog->SetDictionaryDir(mentorDictPath);
+ MG_TRY()
+ csCatalog->SetDictionaryDir(mentorDictPath);
+ MG_CATCH_AND_RELEASE()
+ if (NULL != mgException)
+ ACE_DEBUG((LM_ERROR, ACE_TEXT("(%t) MgServer::open() - The MentorDictionaryPath setting is invalid. The coordinate system engine could not be initialized.\n")));
else
mentorDictPath = L"";
- ACE_DEBUG((LM_INFO, ACE_TEXT("(%t) Warning - No configured dictionary path found. Defaulting to MENTOR_DICTIONARY_PATH environment variable.\n")));
+ ACE_DEBUG((LM_INFO, ACE_TEXT("(%t) MgServer::open() - No configured dictionary path found. Defaulting to [%W].\n"), csCatalog->GetDictionaryDir().c_str()));
+ // Update the user dictionary path with our configured value
+ pConfiguration->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyMentorUserDictionaryPath, mentorUserDictPath, MgConfigProperties::DefaultGeneralPropertyMentorUserDictionaryPath);
+ if (!mentorUserDictPath.empty())
+ // Check if path ends with a '/' if not, add one if needed
+ MgFileUtil::AppendSlashToEndOfPath(mentorUserDictPath);
+ MG_TRY()
+ csCatalog->SetUserDictionaryDir(mentorUserDictPath);
+ //not being able to initialize the user dictionary path doesn't result in the server not starting up
+ ACE_DEBUG((LM_WARNING, ACE_TEXT("(%t) MgServer::open() - The MentorUserDictionaryPath setting is invalid. The user dictionary path setting will not be applied.\n")));
+ else
+ mentorUserDictPath = L"";
+ STRING defaultUserPath = csCatalog->GetUserDictionaryDir();
+ if (defaultUserPath.empty())
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%t) MgServer::open() - No configured user dictionary path found.\n")));
+ else
+ ACE_DEBUG((LM_DEBUG, ACE_TEXT("(%t) MgServer::open() - No configured user dictionary path found. Defaulting to directory [%W].\n"), defaultUserPath.c_str()));
// Did we successfully initialize the coordinate system library?
LibraryStatus status = csCatalog->GetLibraryStatus();
if(lsInitialized != status)
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2012-10-12 03:02:26 UTC (rev 7110)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2012-10-12 11:26:26 UTC (rev 7111)
@@ -70,6 +70,7 @@
# 0 < Value <= 2000000
# MaxLogFileSizeEnabled 0 = max size disabled, 1 = max size enabled
# MentorDictionaryPath The path where the CS-Map Coordinate System Dictionaries are installed
+# MentorUserDictionaryPath The path where user defined CS-Map Coordinate System Dictionaries are stored
# PreCacheMaps The list of maps to precache at server startup.
# Value = Map resource name(s) separated by ","
# Example: Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition
@@ -97,6 +98,7 @@
MaxLogFileSize = 1024
MaxLogFileSizeEnabled = 0
MentorDictionaryPath = ../../../Oem/CsMap/Dictionaries/
+MentorUserDictionaryPath =
PreCacheMaps =
Renderer = AGG
ResourcesPath = Resources/
Modified: trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2012-10-12 03:02:26 UTC (rev 7110)
+++ trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp 2012-10-12 11:26:26 UTC (rev 7111)
@@ -441,15 +441,15 @@
if (userDictionaryDir.empty())
return;
+ pCsCatalog->SetUserDictionaryDir(userDictionaryDir);
STRING setUserDictionaryDir = pCsCatalog->GetUserDictionaryDir();
- pCsCatalog->SetUserDictionaryDir(userDictionaryDir);
MG_TRY()
#ifdef _WIN32
pCsCatalog->SetUserDictionaryDir(L"X:\\I am a hopefully not existing path - if I do, changeme");
#else
- pCsCatalog->SetUserDictionaryDir(L"/I a hopefully not existing path - if I do, changeme");
+ pCsCatalog->SetUserDictionaryDir(L"/I am a hopefully not existing path - if I do, changeme");
#endif
Modified: trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.h
--- trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.h 2012-10-12 03:02:26 UTC (rev 7110)
+++ trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.h 2012-10-12 11:26:26 UTC (rev 7111)
@@ -39,6 +39,7 @@
CPPUNIT_TEST(TestCase_UpdateGeodeticTransformations);
CPPUNIT_TEST(TestCase_UpdateGeodeticPaths);
+ CPPUNIT_TEST(TestCase_InitializeInvalidUserDictionaryDir);
CPPUNIT_TEST(TestCase_InitializeValidUserDictionaryDir);
CPPUNIT_TEST(TestCase_UpdateUserCoordinateSystems);
More information about the mapguide-commits
