[mapguide-commits] r7162 - in trunk/Tools/Maestro: Maestro.AddIn.Scripting Maestro.AddIn.Scripting/Lang/Python Maestro.AddIn.Scripting/Properties Maestro.AddIn.Scripting/Resources Maestro.AddIn.Scripting/UI Maestro.Editors Maestro.Editors/Common Maestro.Editors/Common/Expression OSGeo.MapGuide.MaestroAPI Thirdparty/SharpDevelop/ICSharpCode.TextEditor Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources
svn_mapguide at osgeo.org
Mon Oct 29 06:32:01 PDT 2012
Author: jng
Date: 2012-10-29 06:32:01 -0700 (Mon, 29 Oct 2012)
New Revision: 7162
Added:
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Resources/control.png
trunk/Tools/Maestro/Maestro.Editors/Common/Expression/
trunk/Tools/Maestro/Maestro.Editors/Common/Expression/FdoExpressionCompletionDataProvider.cs
trunk/Tools/Maestro/Maestro.Editors/Common/ITextEditor.cs
trunk/Tools/Maestro/Maestro.Editors/Common/TextEditor.cs
trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/FDO.xshd
trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/SQL.xshd
Removed:
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/ITextEditor.cs
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/TextEditor.cs
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsole.cs
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleCompletionDataProvider.cs
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleHost.cs
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonOutputStream.cs
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Maestro.AddIn.Scripting.csproj
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Properties/Resources.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Scripting/Properties/Resources.resx
trunk/Tools/Maestro/Maestro.AddIn.Scripting/UI/IronPythonRepl.Designer.cs
trunk/Tools/Maestro/Maestro.AddIn.Scripting/UI/IronPythonRepl.cs
trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs
trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.designer.cs
trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.resx
trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
trunk/Tools/Maestro/Maestro.Editors/Strings.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx
trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/ICSharpCode.TextEditor.csproj
trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/SyntaxModes.xml
This submission includes the following changes:
- #2161: Move some of the REPL classes up the Maestro.Editors
- Update the FDO Expression Editor to use the ICSharpCode.TextEditor control, with auto-complete support
- Add syntax highlighting definitions for SQL and FDO expressions
Deleted: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/ITextEditor.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/ITextEditor.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/ITextEditor.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -1,133 +0,0 @@
-#region Disclaimer / License
-// Copyright (C) 2012, Jackie Ng
-// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
-// Original code from SharpDevelop 3.2.1 licensed under the same terms (LGPL 2.1)
-// Copyright 2002-2010 by
-// AlphaSierraPapa, Christoph Wille
-// Vordernberger Strasse 27/8
-// A-8700 Leoben
-// Austria
-// email: office at alphasierrapapa.com
-// court of jurisdiction: Landesgericht Leoben
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of the GNU Lesser General Public
-// License as published by the Free Software Foundation; either
-// version 2.1 of the License, or (at your option) any later version.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
-#endregion
-using ICSharpCode.TextEditor;
-using ICSharpCode.TextEditor.Document;
-using ICSharpCode.TextEditor.Gui.CompletionWindow;
-using System;
-using System.Collections.Generic;
-using System.Drawing;
-using System.Linq;
-using System.Text;
-namespace Maestro.AddIn.Scripting.Lang.Python
- /// <summary>
- /// The interface that the text editor used by the PythonConsole needs to be implement. Note that
- /// all the methods will be called on another thread not the main UI thread and will therefore need to
- /// be invoked.
- /// </summary>
- internal interface ITextEditor
- /// <summary>
- /// Fired when a key is pressed but before any text has been added to the text editor.
- /// </summary>
- /// <remarks>
- /// The KeyPress handler should return true if the text editor should not process the key and not
- /// insert any text.
- /// </remarks>
- event KeyEventHandler KeyPress;
- /// <summary>
- /// Fired when dialog key is pressed but before any text has been added to the text editor.
- /// </summary>
- /// <remarks>
- /// The DialogKeyPress handler should return true if the text editor should not process the
- /// dialog key.
- /// </remarks>
- event DialogKeyProcessor DialogKeyPress;
- /// <summary>
- /// Gets or sets the indentation style.
- /// </summary>
- IndentStyle IndentStyle { get; set; }
- /// <summary>
- /// Inserts text at the current cursor location.
- /// </summary>
- void Write(string text);
- /// <summary>
- /// Inserts text at the current cursor location with the specified colour.
- /// </summary>
- void Write(string text, Color backgroundColor);
- /// <summary>
- /// Replaces the text at the specified index on the current line with the specified text.
- /// </summary>
- void Replace(int index, int length, string text);
- /// <summary>
- /// Gets or sets the current column position of the cursor on the current line. This is zero based.
- /// </summary>
- int Column { get; set; }
- /// <summary>
- /// Gets the length of the currently selected text.
- /// </summary>
- int SelectionLength { get; }
- /// <summary>
- /// Gets the start position of the currently selected text.
- /// </summary>
- int SelectionStart { get; }
- /// <summary>
- /// Gets the current line the cursor is on. This is zero based.
- /// </summary>
- int Line { get; }
- /// <summary>
- /// Gets the total number of lines in the text editor.
- /// </summary>
- int TotalLines { get; }
- /// <summary>
- /// Gets the text for the specified line.
- /// </summary>
- string GetLine(int index);
- /// <summary>
- /// Shows the code completion window.
- /// </summary>
- void ShowCompletionWindow(ICompletionDataProvider completionDataProvider);
- /// <summary>
- /// Indicates whether the completion window is currently being displayed.
- /// </summary>
- bool IsCompletionWindowDisplayed { get; }
- /// <summary>
- /// Makes the current text content read only. Text can be entered at the end.
- /// </summary>
- void MakeCurrentContentReadOnly();
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsole.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsole.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsole.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -30,6 +30,7 @@
#endregion
+using Maestro.Editors.Common;
using Microsoft.Scripting.Hosting.Shell;
using System;
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleCompletionDataProvider.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleCompletionDataProvider.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleCompletionDataProvider.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -69,12 +69,13 @@
public ICompletionData[] GenerateCompletionData(string line)
List<DefaultCompletionData> items = new List<DefaultCompletionData>();
- //TODO: Breaks down on compound python expressions
string name = GetName(line);
if (!String.IsNullOrEmpty(name))
try
+ //TODO: It would be nice if we could get extra information besides the name. I'm not sure
+ //if the DLR hosting API can give us anymore information
foreach (string member in memberProvider.GetMemberNames(name))
items.Add(new DefaultCompletionData(member, String.Empty, 0)); //ClassBrowserIconService.MethodIndex));
@@ -90,7 +91,10 @@
string GetName(string text)
- int startIndex = text.LastIndexOfAny(new char[] { ' ', '+', '(' });
+ //Assume compacted expressions, meaning we need to take into account operators and non-whitespace tokens
+ //TODO: Still imperfect. A dot after a function expression brings up nothing. But a dot after a named variable will
+ //trigger auto-complete most of the time
+ int startIndex = text.LastIndexOfAny(new char[] { ' ', '+', '/', '*', '-', '%', '=', '>', '<', '&', '|', '^', '~', '(', ')' });
string res = text.Substring(startIndex + 1);
Debug.WriteLine("Evaluating python auto-complete options for: " + res);
return res;
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleHost.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleHost.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonConsoleHost.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -34,6 +34,7 @@
using IronPython.Runtime;
using Maestro.AddIn.Scripting.Services;
using Maestro.AddIn.Scripting.UI;
using Microsoft.Scripting.Hosting;
using Microsoft.Scripting.Hosting.Providers;
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonOutputStream.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonOutputStream.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/PythonOutputStream.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -34,6 +34,7 @@
using System.IO;
using System.Linq;
using System.Text;
Deleted: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/TextEditor.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/TextEditor.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Lang/Python/TextEditor.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -1,245 +0,0 @@
-// A-8700 Leoben
-// Austria
-#endregion
-using System;
-using System.Linq;
-using System.Text;
- internal class TextEditor : ITextEditor
- delegate string GetLineInvoker(int index);
- delegate void WriteInvoker(string text, Color color);
- TextEditorControl textEditorControl;
- TextArea textArea;
- Color customLineColour = Color.LightGray;
- TextMarker readOnlyMarker;
- CodeCompletionWindow completionWindow;
- public TextEditor(TextEditorControl textEditorControl)
- this.textEditorControl = textEditorControl;
- this.textArea = textEditorControl.ActiveTextAreaControl.TextArea;
- textEditorControl.TextEditorProperties.SupportReadOnlySegments = true;
- public IndentStyle IndentStyle
- get { return textEditorControl.IndentStyle; }
- set { SetIndentStyle(value); }
- public event KeyEventHandler KeyPress
- add { textArea.KeyEventHandler += value; }
- remove { textArea.KeyEventHandler -= value; }
- public event DialogKeyProcessor DialogKeyPress
- add { textArea.DoProcessDialogKey += value; }
- remove { textArea.DoProcessDialogKey -= value; }
- public Color CustomLineColour
- get { return customLineColour; }
- public void Write(string text)
- Write(text, Color.Empty);
- public void Write(string text, Color backgroundColour)
- if (textEditorControl.InvokeRequired)
- WriteInvoker invoker = new WriteInvoker(Write);
- textEditorControl.Invoke(invoker, new object[] { text, backgroundColour });
- else
- int offset = textEditorControl.Document.PositionToOffset(new TextLocation(Column, Line));
- textEditorControl.ActiveTextAreaControl.TextArea.InsertString(text);
- if (!backgroundColour.IsEmpty)
- TextMarker marker = new TextMarker(offset, text.Length, TextMarkerType.SolidBlock, backgroundColour);
- textEditorControl.Document.MarkerStrategy.AddMarker(marker);
- textEditorControl.Refresh();
- public int Column
- get { return textEditorControl.ActiveTextAreaControl.Caret.Column; }
- set { textEditorControl.ActiveTextAreaControl.Caret.Column = value; }
- public int SelectionStart
- get
- ColumnRange range = GetSelectionRange();
- if (range != ColumnRange.NoColumn)
- return range.StartColumn;
- return Column;
- public int SelectionLength
- get
- return range.EndColumn - range.StartColumn;
- /// <summary>
- /// Gets the current cursor line.
- /// </summary>
- public int Line
- get { return textArea.Caret.Line; }
- /// <summary>
- /// </summary>
- public int TotalLines
- get { return textEditorControl.Document.TotalNumberOfLines; }
- /// <summary>
- /// </summary>
- public string GetLine(int index)
- GetLineInvoker invoker = new GetLineInvoker(GetLine);
- return (string)textEditorControl.Invoke(invoker, new object[] { index });
- else
- LineSegment lineSegment = textEditorControl.Document.GetLineSegment(index);
- return textEditorControl.Document.GetText(lineSegment);
- /// <summary>
- /// </summary>
- public void Replace(int index, int length, string text)
- int currentLine = textEditorControl.ActiveTextAreaControl.Caret.Line;
- LineSegment lineSegment = textEditorControl.Document.GetLineSegment(currentLine);
- textEditorControl.Document.Replace(lineSegment.Offset + index, length, text);
- /// <summary>
- /// Makes the current text read only. Text can still be entered at the end.
- /// </summary>
- public void MakeCurrentContentReadOnly()
- IDocument doc = textEditorControl.Document;
- if (readOnlyMarker == null)
- readOnlyMarker = new TextMarker(0, doc.TextLength, TextMarkerType.Invisible);
- readOnlyMarker.IsReadOnly = true;
- doc.MarkerStrategy.AddMarker(readOnlyMarker);
- readOnlyMarker.Offset = 0;
- readOnlyMarker.Length = doc.TextLength;
- doc.UndoStack.ClearAll();
- public void ShowCompletionWindow(ICompletionDataProvider completionDataProvider)
- completionWindow = CodeCompletionWindow.ShowCompletionWindow(textEditorControl.ParentForm, textEditorControl, String.Empty, completionDataProvider, ' ');
- if (completionWindow != null)
- completionWindow.Width = 250;
- completionWindow.Closed += CompletionWindowClosed;
- public bool IsCompletionWindowDisplayed
- get { return completionWindow != null; }
- /// <summary>
- /// Gets the range of the currently selected text.
- /// </summary>
- ColumnRange GetSelectionRange()
- return textArea.SelectionManager.GetSelectionAtLine(textArea.Caret.Line);
- void SetIndentStyle(IndentStyle style)
- Action<IndentStyle> action = SetIndentStyle;
- textEditorControl.Invoke(action, new object[] { style });
- else
- textEditorControl.IndentStyle = style;
- void CompletionWindowClosed(object source, EventArgs e)
- completionWindow.Closed -= CompletionWindowClosed;
- completionWindow.Dispose();
- completionWindow = null;
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Maestro.AddIn.Scripting.csproj
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Maestro.AddIn.Scripting.csproj 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Maestro.AddIn.Scripting.csproj 2012-10-29 13:32:01 UTC (rev 7162)
@@ -72,12 +72,10 @@
<Compile Include="Commands\StartupCommand.cs" />
<Compile Include="Lang\Python\CommandLineHistory.cs" />
<Compile Include="Lang\Python\IMemberProvider.cs" />
- <Compile Include="Lang\Python\ITextEditor.cs" />
<Compile Include="Lang\Python\PythonConsole.cs" />
<Compile Include="Lang\Python\PythonConsoleCompletionDataProvider.cs" />
<Compile Include="Lang\Python\PythonConsoleHost.cs" />
<Compile Include="Lang\Python\PythonOutputStream.cs" />
- <Compile Include="Lang\Python\TextEditor.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
<Compile Include="Properties\Resources.Designer.cs">
<AutoGen>True</AutoGen>
@@ -108,6 +106,7 @@
<Content Include="Manifest.addin">
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
</Content>
+ <None Include="Resources\control.png" />
<None Include="Resources\cross-script.png" />
<None Include="Resources\block.png" />
</ItemGroup>
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Properties/Resources.Designer.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Properties/Resources.Designer.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -73,6 +73,16 @@
/// <summary>
/// Looks up a localized resource of type System.Drawing.Bitmap.
/// </summary>
+ internal static System.Drawing.Bitmap control {
+ get {
+ object obj = ResourceManager.GetObject("control", resourceCulture);
+ return ((System.Drawing.Bitmap)(obj));
+ /// <summary>
+ /// Looks up a localized resource of type System.Drawing.Bitmap.
+ /// </summary>
internal static System.Drawing.Bitmap cross_script {
get {
object obj = ResourceManager.GetObject("cross-script", resourceCulture);
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/Properties/Resources.resx 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/Properties/Resources.resx 2012-10-29 13:32:01 UTC (rev 7162)
@@ -124,4 +124,7 @@
<data name="cross-script" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\cross-script.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="control" type="System.Resources.ResXFileRef, System.Windows.Forms">
+ <value>..\Resources\control.png;System.Drawing.Bitmap, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ </data>
</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Resources/control.png
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro.AddIn.Scripting/Resources/control.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/UI/IronPythonRepl.Designer.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/UI/IronPythonRepl.Designer.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/UI/IronPythonRepl.Designer.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -30,6 +30,8 @@
this.textEditorControl = new ICSharpCode.TextEditor.TextEditorControl();
this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.toolStripSeparator1 = new System.Windows.Forms.ToolStripSeparator();
+ this.btnLoadFile = new System.Windows.Forms.ToolStripButton();
this.btnClear = new System.Windows.Forms.ToolStripButton();
this.toolStrip1.SuspendLayout();
this.SuspendLayout();
@@ -46,6 +48,8 @@
// toolStrip1
this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.btnLoadFile,
+ this.toolStripSeparator1,
this.btnClear});
this.toolStrip1.Location = new System.Drawing.Point(0, 0);
this.toolStrip1.Name = "toolStrip1";
@@ -53,6 +57,20 @@
this.toolStrip1.TabIndex = 1;
this.toolStrip1.Text = "toolStrip1";
+ // toolStripSeparator1
+ this.toolStripSeparator1.Name = "toolStripSeparator1";
+ this.toolStripSeparator1.Size = new System.Drawing.Size(6, 25);
+ // btnLoadFile
+ this.btnLoadFile.Image = global::Maestro.AddIn.Scripting.Properties.Resources.control;
+ this.btnLoadFile.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnLoadFile.Name = "btnLoadFile";
+ this.btnLoadFile.Size = new System.Drawing.Size(69, 22);
+ this.btnLoadFile.Text = "Run File";
+ this.btnLoadFile.Click += new System.EventHandler(this.btnLoadFile_Click);
// btnClear
this.btnClear.Image = global::Maestro.AddIn.Scripting.Properties.Resources.cross_script;
@@ -82,5 +100,7 @@
private ICSharpCode.TextEditor.TextEditorControl textEditorControl;
private System.Windows.Forms.ToolStrip toolStrip1;
private System.Windows.Forms.ToolStripButton btnClear;
+ private System.Windows.Forms.ToolStripButton btnLoadFile;
+ private System.Windows.Forms.ToolStripSeparator toolStripSeparator1;
Modified: trunk/Tools/Maestro/Maestro.AddIn.Scripting/UI/IronPythonRepl.cs
--- trunk/Tools/Maestro/Maestro.AddIn.Scripting/UI/IronPythonRepl.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.AddIn.Scripting/UI/IronPythonRepl.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -9,10 +9,12 @@
using Maestro.Shared.UI;
using System.IO;
+using Microsoft.Scripting.Hosting.Shell;
namespace Maestro.AddIn.Scripting.UI
using Lang.Python;
+ using Maestro.Editors.Common;
internal partial class IronPythonRepl : SingletonViewContent
@@ -24,6 +26,7 @@
InitializeComponent();
textEditorControl.CreateControl();
+ textEditorControl.ShowLineNumbers = false;
textEditorControl.ShowVRuler = false;
textEditorControl.ShowHRuler = false;
@@ -52,14 +55,35 @@
+ private static void NewPrompt(IConsole con)
+ //HACK: Should be a way to get this from IronPython
+ con.Write(">>> ", Microsoft.Scripting.Hosting.Shell.Style.Prompt);
private void btnClear_Click(object sender, EventArgs e)
textEditorControl.Text = string.Empty;
var con = host.Console;
var cmdline = con.CommandLine;
- //HACK: Should be a way to get this from IronPython
- con.Write(">>> ", Microsoft.Scripting.Hosting.Shell.Style.Prompt);
+ NewPrompt(con);
+ private void btnLoadFile_Click(object sender, EventArgs e)
+ using (var picker = DialogFactory.OpenFile())
+ picker.Filter = "*.py|*.py"; //NOXLATE
+ if (picker.ShowDialog() == DialogResult.OK)
+ var con = host.Console;
+ var cmdline = con.CommandLine;
+ con.WriteLine();
+ cmdline.ScriptScope.Engine.ExecuteFile(picker.FileName);
+ NewPrompt(con);
Property changes on: trunk/Tools/Maestro/Maestro.Editors/Common/Expression
Added: bugtraq:number
+ true
Added: trunk/Tools/Maestro/Maestro.Editors/Common/Expression/FdoExpressionCompletionDataProvider.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/Expression/FdoExpressionCompletionDataProvider.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/Expression/FdoExpressionCompletionDataProvider.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -0,0 +1,387 @@
+using ICSharpCode.TextEditor;
+using ICSharpCode.TextEditor.Document;
+using ICSharpCode.TextEditor.Gui.CompletionWindow;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Schema;
+using OSGeo.MapGuide.ObjectModels.Capabilities;
+using System;
+using System.Collections.Generic;
+using System.Diagnostics;
+using System.Linq;
+using System.Text;
+namespace Maestro.Editors.Common.Expression
+ //NOTE:
+ //It seems the auto-complete capabilities of the ICSharpCode.TextEditor assume object-oriented languages or languages
+ //that involve a member access operator (., -> or anything similar), so we have to use a custom ICompletionData that
+ //compensates for the lack of such contexts
+ //NOTE/TODO:
+ //Auto-completions are currently case-sensitive and will only trigger on the correct case.
+ internal class FdoExpressionCompletionDataProvider : ICompletionDataProvider
+ private ClassDefinition _klass;
+ private FdoProviderCapabilities _caps;
+ public FdoExpressionCompletionDataProvider(ClassDefinition cls, FdoProviderCapabilities caps)
+ _klass = cls;
+ _caps = caps;
+ this.DefaultIndex = 0;
+ this.PreSelection = null;
+ this.ImageList = new System.Windows.Forms.ImageList();
+ this.ImageList.Images.Add(Properties.Resources.block);
+ this.ImageList.Images.Add(Properties.Resources.property);
+ this.ImageList.Images.Add(Properties.Resources.funnel);
+ public System.Windows.Forms.ImageList ImageList
+ get;
+ private set;
+ public string PreSelection
+ get;
+ private set;
+ public int DefaultIndex
+ get;
+ private set;
+ public bool InsertSpace
+ get;
+ set;
+ public CompletionDataProviderKeyResult ProcessKey(char key)
+ CompletionDataProviderKeyResult res;
+ if (key == ' ' && this.InsertSpace)
+ this.InsertSpace = false; // insert space only once
+ res = CompletionDataProviderKeyResult.BeforeStartKey;
+ else if (char.IsLetterOrDigit(key) || key == '_')
+ this.InsertSpace = false; // don't insert space if user types normally
+ res = CompletionDataProviderKeyResult.NormalKey;
+ else
+ // do not reset insertSpace when doing an insertion!
+ res = CompletionDataProviderKeyResult.InsertionKey;
+ return res;
+ public bool InsertAction(ICompletionData data, TextArea textArea, int insertionOffset, char key)
+ if (this.InsertSpace)
+ textArea.Document.Insert(insertionOffset++, " ");
+ textArea.Caret.Position = textArea.Document.OffsetToPosition(insertionOffset);
+ var res = data.InsertAction(textArea, key);
+ var fdoComp = (FdoCompletionData)data;
+ if (fdoComp.ImageIndex == 0 && fdoComp.AppendText.Length > 2) //Function and not an empty function call
+ //Rewind caret so it is at the start of the function call (at first parameter)
+ var offset = textArea.Caret.Offset;
+ offset -= (fdoComp.AppendText.Length - 1);
+ textArea.Caret.Position = textArea.Document.OffsetToPosition(offset);
+ textArea.SelectionManager.ClearSelection();
+ textArea.SelectionManager.SetSelection(textArea.Caret.Position, textArea.Document.OffsetToPosition(offset + (fdoComp.HighlightLength - 1)));
+ return res;
+ /// <summary>
+ /// Gets the line of text up to the cursor position.
+ /// </summary>
+ string GetLineText(TextArea textArea)
+ LineSegment lineSegment = textArea.Document.GetLineSegmentForOffset(textArea.Caret.Offset);
+ return textArea.Document.GetText(lineSegment);
+ public ICompletionData[] GenerateCompletionData(string fileName, TextArea textArea, char charTyped)
+ return GenerateCompletionData((GetLineText(textArea) + charTyped).Trim());
+ class FdoCompletionData : DefaultCompletionData
+ private string _insertText;
+ private string _appendText;
+ private int _highlightLength = 0;
+ public int HighlightLength { get { return _highlightLength; } }
+ public string InsertText { get { return _insertText; } }
+ public string AppendText { get { return _appendText; } }
+ public FdoCompletionData(string prefix, string text, string description, int imageIndex)
+ : base(text, description, imageIndex)
+ _insertText = text.Substring(prefix.Length);
+ _appendText = string.Empty;
+ public FdoCompletionData(string prefix, string text, string description, string appendText, int highlightLength, int imageIndex)
+ : this(prefix, text, description, imageIndex)
+ _appendText = appendText;
+ _highlightLength = highlightLength;
+ public override bool InsertAction(TextArea textArea, char ch)
+ textArea.InsertString(_insertText + _appendText);
+ return false;
+ private ICompletionData[] GenerateCompletionData(string line)
+ Debug.WriteLine("FDO auto-complete: " + line);
+ List<DefaultCompletionData> items = new List<DefaultCompletionData>();
+ string name = GetName(line);
+ if (!String.IsNullOrEmpty(name))
+ try
+ foreach (var func in GetMatchingFdoFunctions(name))
+ var member = CreateFdoFunctionDescriptor(func);
+ int highlightLength = 0;
+ if (func.ArgumentDefinitionList.Count > 0)
+ highlightLength = func.ArgumentDefinitionList[0].Name.Length + 2; // [ and ]
+ items.Add(new FdoCompletionData(name, member.Name, member.Description, member.AppendText, highlightLength, 0));
+ foreach (var member in GetMatchingClassProperties(name))
+ items.Add(new FdoCompletionData(name, member.Name, member.Description, 1));
+ foreach (var member in GetMatchingFdoConditions(name))
+ items.Add(new FdoCompletionData(name, member.Name, member.Description, member.AppendText, member.AppendText.Length - 1, 2));
+ foreach (var member in GetMatchingFdoOperators(name))
+ items.Add(new FdoCompletionData(name, member.Name, member.Description, member.AppendText, 0, 2));
+ items.Sort((a, b) => { return a.Text.CompareTo(b.Text); });
+ catch
+ // Do nothing.
+ return items.ToArray();
+ class Descriptor
+ public string Name;
+ public string Description;
+ public string AppendText;
+ private IEnumerable<FdoProviderCapabilitiesExpressionFunctionDefinition> GetMatchingFdoFunctions(string name)
+ foreach (var func in _caps.Expression.FunctionDefinitionList.Concat(Utility.GetStylizationFunctions()))
+ if (func.Name.StartsWith(name))
+ yield return func;
+ private IEnumerable<Descriptor> GetMatchingFdoConditions(string name)
+ foreach (var cond in _caps.Filter.Condition)
+ if (cond.ToString().ToUpper().StartsWith(name))
+ var desc = CreateFdoConditionDescriptor(cond);
+ if (desc != null)
+ yield return desc;
+ private Descriptor CreateFdoConditionDescriptor(FdoProviderCapabilitiesFilterType cond)
+ if (cond == FdoProviderCapabilitiesFilterType.Null)
+ return new Descriptor()
+ Name = cond.ToString().ToUpper(),
+ Description = "[property] NULL" //NOXLATE
+ else if (cond == FdoProviderCapabilitiesFilterType.In)
+ Description = "[property] IN ([value1], [value2], ..., [valueN])", //NOXLATE
+ AppendText = " ([value1], [value2])" //NOXLATE
+ else if (cond == FdoProviderCapabilitiesFilterType.Like)
+ Description = "[property] LIKE [string value]", //NOXLATE
+ AppendText = " [string value]" //NOXLATE
+ return null; //Handled by operators
+ private static Descriptor CreateBinaryDistanceOperator(string opName)
+ Name = opName.ToUpper(),
+ Description = "[property] " + opName + " [number]", //NOXLATE
+ AppendText = " [number]" //NOXLATE
+ private static Descriptor CreateBinarySpatialOperator(string opName)
+ Description = "[geometry] " + opName + " GeomFromText('geometry wkt')", //NOXLATE
+ AppendText = " GeomFromText('geometry wkt')" //NOXLATE
+ private IEnumerable<Descriptor> GetMatchingFdoOperators(string name)
+ foreach (var op in _caps.Filter.Distance)
+ var opName = op.ToString().ToUpper();
+ if (opName.StartsWith(name))
+ yield return CreateBinaryDistanceOperator(opName);
+ foreach (var op in _caps.Filter.Spatial)
+ yield return CreateBinarySpatialOperator(opName);
+ private IEnumerable<Descriptor> GetMatchingClassProperties(string name)
+ foreach (var prop in _klass.Properties)
+ if (prop.Name.StartsWith(name))
+ yield return CreatePropertyDescriptor(prop);
+ private Descriptor CreateFdoFunctionDescriptor(FdoProviderCapabilitiesExpressionFunctionDefinition func)
+ var desc = new Descriptor();
+ desc.Name = func.Name;
+ string fmt = "{0}({1})"; //NOXLATE
+ List<string> args = new List<string>();
+ foreach (FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinition argDef in func.ArgumentDefinitionList)
+ args.Add(argDef.Name.Trim());
+ string argsStr = StringifyFunctionArgs(args);
+ string expr = string.Format(fmt, func.Name, argsStr); //NOXLATE
+ desc.Description = string.Format(Strings.ExprEditorFunctionDesc, expr, func.Description, func.ReturnType, Environment.NewLine);
+ desc.AppendText = "(" + argsStr + ")";
+ return desc;
+ internal static string StringifyFunctionArgs(List<string> args)
+ string argsStr = args.Count > 0 ? "[" + string.Join("], [", args.ToArray()) + "]" : string.Empty; //NOXLATE
+ return argsStr;
+ private static Descriptor CreatePropertyDescriptor(PropertyDefinition prop)
+ desc.Name = prop.Name;
+ if (prop.Type == PropertyDefinitionType.Geometry)
+ var g = (GeometricPropertyDefinition)prop;
+ desc.Description = string.Format(Strings.FsPreview_GeometryPropertyNodeTooltip,
+ g.Name,
+ g.Description,
+ g.GeometryTypesToString(),
+ g.IsReadOnly,
+ g.HasElevation,
+ g.HasMeasure,
+ g.SpatialContextAssociation,
+ Environment.NewLine);
+ else if (prop.Type == PropertyDefinitionType.Data)
+ var d = (DataPropertyDefinition)prop;
+ desc.Description = string.Format(Strings.FsPreview_DataPropertyNodeTooltip,
+ d.Name,
+ d.Description,
+ d.DataType.ToString(),
+ d.IsNullable,
+ d.IsReadOnly,
+ d.Length,
+ d.Precision,
+ d.Scale,
+ else if (prop.Type == PropertyDefinitionType.Raster)
+ var r = (RasterPropertyDefinition)prop;
+ desc.Description = string.Format(Strings.FsPreview_RasterPropertyNodeTooltip,
+ r.Name,
+ r.Description,
+ r.IsNullable,
+ r.DefaultImageXSize,
+ r.DefaultImageYSize,
+ r.SpatialContextAssociation,
+ else
+ desc.Description = string.Format(Strings.FsPreview_GenericPropertyTooltip,
+ prop.Name,
+ prop.Type.ToString(),
+ return desc;
+ private string GetName(string text)
+ int startIndex = text.LastIndexOfAny(new char[] { ' ', '+', '/', '*', '-', '%', '=', '>', '<', '&', '|', '^', '~', '(', ',', ')' }); //NOXLATE
+ string res = text.Substring(startIndex + 1);
+ Debug.WriteLine("Evaluating FDO auto-complete options for: " + res);
+ return res;
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -30,6 +30,8 @@
using OSGeo.MapGuide.MaestroAPI.Exceptions;
+using Maestro.Editors.Common.Expression;
@@ -77,9 +79,10 @@
public partial class ExpressionEditor : Form
private ClassDefinition _cls;
private IFeatureService _featSvc;
private string m_featureSource = null;
+ private ITextEditor _editor;
/// <summary>
/// Initializes a new instance of the <see cref="ExpressionEditor"/> class.
@@ -87,9 +90,20 @@
public ExpressionEditor()
- InitAutoComplete();
+ ExpressionText.SetHighlighting("FDO");
+ _editor = new TextEditor(ExpressionText);
+ _editor.KeyPress += OnEditorKeyPress;
+ bool OnEditorKeyPress(char ch)
+ if (Char.IsLetter(ch))
+ ShowAutoComplete(ch);
+ return false;
/// <summary>
/// Gets or sets the expression.
/// </summary>
@@ -115,8 +129,8 @@
_cls = cls;
_featSvc = featSvc;
m_featureSource = featuresSourceId;
+ _caps = caps;
- //TODO: Perhaps add column type and indication of primary key
SortedList<string, PropertyDefinition> sortedCols = new SortedList<string, PropertyDefinition>();
foreach (var col in _cls.Properties)
@@ -144,10 +158,6 @@
if (ColumnName.Items.Count > 0)
ColumnName.SelectedIndex = 0;
- LoadCompletableProperties(_cls.Properties);
- //TODO: Figure out how to translate the enums into something usefull
//Functions
SortedList<string, FdoProviderCapabilitiesExpressionFunctionDefinition> sortedFuncs = new SortedList<string, FdoProviderCapabilitiesExpressionFunctionDefinition>();
foreach (FdoProviderCapabilitiesExpressionFunctionDefinition func in caps.Expression.FunctionDefinitionList)
@@ -157,7 +167,7 @@
if (attachStylizationFunctions)
- foreach (var func in GetStylizationFunctions())
+ foreach (var func in Utility.GetStylizationFunctions())
sortedFuncs.Add(func.Name, func);
@@ -170,22 +180,20 @@
btn.Name = name;
btn.Text = name;
btn.ToolTipText = func.Description;
- string expr = string.Format(fmt, name, string.Join(", ", args.ToArray()));
+ string expr = string.Format(fmt, name, FdoExpressionCompletionDataProvider.StringifyFunctionArgs(args));
btn.Click += delegate
InsertText(expr);
btnFunctions.DropDown.Items.Add(btn);
- LoadCompletableFunctions(caps.Expression.FunctionDefinitionList);
- if (attachStylizationFunctions)
- LoadCompletableFunctions(GetStylizationFunctions());
//Spatial Operators
foreach (FdoProviderCapabilitiesFilterOperation op in caps.Filter.Spatial)
@@ -195,7 +203,7 @@
btn.Name = btn.Text = btn.ToolTipText = op.ToString();
- InsertFilter(name);
+ InsertSpatialFilter(name);
btnSpatial.DropDown.Items.Add(btn);
@@ -208,7 +216,7 @@
btnDistance.DropDown.Items.Add(btn);
@@ -221,745 +229,45 @@
btnCondition.DropDown.Items.Add(btn);
- /*try
- /*FdoProviderCapabilities cap = m_connection.GetProviderCapabilities(m_providername);
- foreach (FdoProviderCapabilitiesFilterType cmd in cap.Filter.Condition)
- FunctionCombo.Items.Add(cmd.ToString());
- FunctionLabel.Enabled = FunctionCombo.Enabled = true;
- catch
- FunctionLabel.Enabled = FunctionCombo.Enabled = false;
catch
- private IEnumerable<FdoProviderCapabilitiesExpressionFunctionDefinition> GetStylizationFunctions()
- //ARGB
- yield return new FdoProviderCapabilitiesExpressionFunctionDefinition()
- ArgumentDefinitionList = new BindingList<FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinition>()
- new FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinition()
- Name = "aValue", //NOXLATE
- Description = Strings.Func_ARGB_AValueDescription,
- DataType = FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinitionDataType.Int32
- Name = "rValue", //NOXLATE
- Description = Strings.Func_ARGB_RValueDescription,
- Name = "gValue", //NOXLATE
- Description = Strings.Func_ARGB_GValueDescription,
- Name = "bValue", //NOXLATE
- Description = Strings.Func_ARGB_BValueDescription,
- Description = Strings.Func_ARGB_Description,
- Name = "ARGB", //NOXLATE
- ReturnType = "Int32" //NOXLATE
- //DECAP
- Name = "strValue", //NOXLATE
- Description = Strings.Func_DECAP_StringValueDescription,
- DataType = FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinitionDataType.String
- Description = Strings.Func_DECAP_Description,
- Name = "DECAP", //NOXLATE
- ReturnType = "String" //NOXLATE
- //FEATURECLASS
- ArgumentDefinitionList = new BindingList<FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinition>(),
- Description = Strings.Func_FEATURECLASS_Description,
- Name = "FEATURECLASS", //NOXLATE
- //FEATUREID
- Description = Strings.Func_FEATUREID_Description,
- Name = "FEATUREID", //NOXLATE
- //IF
- Name = "condition", //NOXLATE
- Description = Strings.Func_IF_ConditionDescription,
- Name = "trueValue", //NOXLATE
- Description = Strings.Func_IF_TrueValueDescription,
- Name = "falseValue", //NOXLATE
- Description = Strings.Func_IF_FalseValueDescription,
- Description = Strings.Func_IF_Description,
- Name = "IF", //NOXLATE
- //LAYERID
- Description = Strings.Func_LAYERID_Description,
- Name = "LAYERID", //NOXLATE
- //LOOKUP
- Name = "expression", //NOXLATE
- Description = Strings.Func_LOOKUP_ExpressionDescription,
- Name = "defaultValue", //NOXLATE
- Description = Strings.Func_LOOKUP_DefaultValueDescription,
- Name = "index", //NOXLATE
- Description = Strings.Func_LOOKUP_IndexDescription,
- Name = "value", //NOXLATE
- Description = Strings.Func_LOOKUP_ValueDescription,
- Description = Strings.Func_LOOKUP_Description,
- Name = "LOOKUP", //NOXLATE
- //MAPNAME
- Description = Strings.Func_MAPNAME_Description,
- Name = "MAPNAME", //NOXLATE
- //RANGE
- Description = Strings.Func_RANGE_ExpressionDescription,
- Name = "rangeMin", //NOXLATE
- Description = Strings.Func_RANGE_MinDescription,
- Name = "rangeMax", //NOXLATE
- Description = Strings.Func_RANGE_MaxDescription,
- Description = Strings.Func_RANGE_DefaultValueDescription,
- Description = Strings.Func_RANGE_ValueDescription,
- Description = Strings.Func_RANGE_Description,
- Name = "RANGE", //NOXLATE
- //SESSION
- Description = Strings.Func_SESSION_Description,
- Name = "SESSION", //NOXLATE
- //URLENCODE
- Description = Strings.Func_URLENCODE_StringValueDescription,
- Description = Strings.Func_URLENCODE_Description,
- Name = "URLENCODE", //NOXLATE
- private void InsertText(string exprText)
- int index = ExpressionText.SelectionStart;
- if (ExpressionText.SelectionLength > 0)
- ExpressionText.SelectedText = exprText;
- ExpressionText.SelectionStart = index;
- else
- if (index > 0)
- string text = ExpressionText.Text;
- ExpressionText.Text = text.Insert(index, exprText);
- else
- ExpressionText.Text = exprText;
- private void InsertFilter(string op)
- if (!string.IsNullOrEmpty(op))
- string filterTemplate = Strings.GeomFilterTemplate;
- string exprText = string.Format(filterTemplate, op);
- InsertText(exprText);
private void OKBtn_Click(object sender, EventArgs e)
this.DialogResult = DialogResult.OK;
this.Close();
- private SortedList<string, AutoCompleteItem> _autoCompleteItems = new SortedList<string, AutoCompleteItem>();
- private ImageListBox _autoBox;
+ private CodeCompletionWindow completionWindow;
- enum AutoCompleteItemType : int
+ private void ShowAutoComplete(char ch)
- Property = 0,
- Function = 1,
- /// <summary>
- /// Base auto-complete item
- /// </summary>
- abstract class AutoCompleteItem
- public abstract AutoCompleteItemType Type { get; }
- public abstract string Name { get; }
- public abstract string ToolTipText { get; }
- public abstract string AutoCompleteText { get; }
- /// <summary>
- /// Property auto-complete item
- /// </summary>
- class PropertyItem : AutoCompleteItem
- private PropertyDefinition _propDef;
- public PropertyItem(PropertyDefinition pd)
+ var provider = new FdoExpressionCompletionDataProvider(_cls, _caps);
+ completionWindow = CodeCompletionWindow.ShowCompletionWindow(ExpressionText.ParentForm, ExpressionText, String.Empty, provider, ch);
+ if (completionWindow != null)
- _propDef = pd;
+ completionWindow.Width = 250;
+ completionWindow.Closed += CompletionWindowClosed;
- public override AutoCompleteItemType Type
- get { return AutoCompleteItemType.Property; }
- public override string Name
- get { return _propDef.Name; }
- private string _ttText;
- public override string ToolTipText
- get
- if (string.IsNullOrEmpty(_ttText))
- _ttText = string.Format(Strings.PropertyTooltip, _propDef.Name, _propDef.Type.ToString());
- return _ttText;
- public override string AutoCompleteText
- get { return this.Name; }
- /// <summary>
- /// Function auto-complete item
- /// </summary>
- class FunctionItem : AutoCompleteItem
+ void CompletionWindowClosed(object source, EventArgs e)
- private FdoProviderCapabilitiesExpressionFunctionDefinition _func;
- public FunctionItem(FdoProviderCapabilitiesExpressionFunctionDefinition fd)
- _func = fd;
+ completionWindow.Closed -= CompletionWindowClosed;
+ completionWindow.Dispose();
+ completionWindow = null;
- get { return AutoCompleteItemType.Function; }
- get { return _func.Name; }
- get
- _ttText = string.Format(Strings.FunctionTooltip, GetReturnTypeString(), _func.Name, GetArgumentString(), _func.Description);
- return _ttText;
- private string _argStr;
- private string GetArgumentString()
- if (string.IsNullOrEmpty(_argStr))
- List<string> tokens = new List<string>();
- foreach (FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinition argDef in _func.ArgumentDefinitionList)
- tokens.Add("[" + argDef.Name.Trim() + "]"); //NOXLATE
- _argStr = string.Join(", ", tokens.ToArray()); //NOXLATE
- return _argStr;
- private string GetReturnTypeString()
- return _func.ReturnType;
- get
- return this.Name + "(" + GetArgumentString() + ")"; //NOXLATE
- private void InitAutoComplete()
- _autoBox = new ImageListBox();
- _autoBox.Visible = false;
- _autoBox.ImageList = new ImageList();
- _autoBox.ImageList.Images.Add(Properties.Resources.property); //Property
- _autoBox.ImageList.Images.Add(Properties.Resources.block); //Function
- _autoBox.DoubleClick += new EventHandler(OnAutoCompleteDoubleClick);
- _autoBox.SelectedIndexChanged += new EventHandler(OnAutoCompleteSelectedIndexChanged);
- _autoBox.KeyDown += new KeyEventHandler(OnAutoCompleteKeyDown);
- _autoBox.KeyUp += new KeyEventHandler(OnAutoCompleteKeyUp);
- _autoBox.ValueMember = "Name"; //NOXLATE
- _autoBox.Font = new Font(FontFamily.GenericMonospace, 10.0f);
- ExpressionText.Controls.Add(_autoBox);
- void OnAutoCompleteKeyDown(object sender, KeyEventArgs e)
- ExpressionText.Focus();
- void OnAutoCompleteKeyUp(object sender, KeyEventArgs e)
- if (e.KeyCode == Keys.Return || e.KeyCode == Keys.Enter)
- PutAutoCompleteSuggestion();
- _autoBox.Hide();
- _autoCompleteTooltip.Hide(this);
- void OnAutoCompleteSelectedIndexChanged(object sender, EventArgs e)
- if (_autoBox.Visible && _autoBox.SelectedIndex >= 0 && _autoBox.Items.Count > 0)
- string tt = ((_autoBox.SelectedItem as ImageListBoxItem).Tag as AutoCompleteItem).ToolTipText;
- Point pt = GetCaretPoint();
- pt.X += _autoBox.Width + 10;
- pt.Y += 65;
- _autoCompleteTooltip.Show(tt, this, pt.X, pt.Y);
- void OnAutoCompleteDoubleClick(object sender, EventArgs e)
- _autoBox.Hide();
- private void MoveAutoCompleteSelectionDown()
- if (_autoBox.SelectedIndex < 0)
- _autoBox.SelectedIndex = 0;
- else
- int idx = _autoBox.SelectedIndex;
- if ((idx + 1) <= _autoBox.Items.Count - 1)
- _autoBox.SelectedIndex = idx + 1;
- private void MoveAutoCompleteSelectionUp()
- else
- if ((idx - 1) >= 0)
- _autoBox.SelectedIndex = idx - 1;
- private void LoadCompletableProperties(IEnumerable<PropertyDefinition> cols)
- foreach (var col in cols)
- _autoCompleteItems[col.Name] = new PropertyItem(col);
- private void LoadCompletableFunctions(IEnumerable<FdoProviderCapabilitiesExpressionFunctionDefinition> funcs)
- foreach (FdoProviderCapabilitiesExpressionFunctionDefinition func in funcs)
- _autoCompleteItems[func.Name] = new FunctionItem(func);
- private void PutAutoCompleteSuggestion()
- if (_autoBox.SelectedItems.Count == 1)
- int pos = ExpressionText.SelectionStart;
- string context;
- char? c = GetContextBuffer(out context);
- AutoCompleteItem aci = (_autoBox.SelectedItem as ImageListBoxItem).Tag as AutoCompleteItem;
- string fullText = aci.AutoCompleteText;
- int start = pos - context.Length;
- int newPos = start + fullText.Length;
- int selLength = -1;
- //if it's a function, highlight the parameter (or the first parameter if there is multiple arguments
- if (aci.Type == AutoCompleteItemType.Function)
- newPos = start + aci.Name.Length + 1; //Position the caret just after the opening bracket
- //Has at least two arguments
- int idx = fullText.IndexOf(","); //NOXLATE
- if (idx > 0)
- selLength = idx - aci.Name.Length - 1;
- else
- selLength = fullText.IndexOf(")") - fullText.IndexOf("(") - 1; //NOXLATE
- string prefix = ExpressionText.Text.Substring(0, start);
- string suffix = ExpressionText.Text.Substring(pos, ExpressionText.Text.Length - pos);
- ExpressionText.Text = prefix + fullText + suffix;
- ExpressionText.SelectionStart = newPos;
- if (selLength > 0)
- ExpressionText.SelectionLength = selLength;
- ExpressionText.ScrollToCaret();
- private Point GetCaretPoint()
- Point pt = ExpressionText.GetPositionFromCharIndex(ExpressionText.SelectionStart);
- pt.Y += (int)Math.Ceiling(ExpressionText.Font.GetHeight()) + 2;
- pt.X += 2; // for Courier, may need a better method
- return pt;
- private char? GetContextBuffer(out string buffer)
- buffer = string.Empty;
- int caretPos = ExpressionText.SelectionStart;
- int currentPos = caretPos;
- char? res = null;
- if (caretPos > 0)
- //Walk backwards
- caretPos--;
- char c = ExpressionText.Text[caretPos];
- while (Char.IsLetterOrDigit(c))
- caretPos--;
- if (caretPos < 0)
- break;
- c = ExpressionText.Text[caretPos];
- if (caretPos > 0)
- res = ExpressionText.Text[caretPos];
- buffer = ExpressionText.Text.Substring(caretPos + 1, currentPos - caretPos - 1);
- return res;
- private void HandleKeyDown(KeyEventArgs e)
- Keys code = e.KeyCode;
- if (code == Keys.Escape)
- if (_autoBox.Visible)
- e.SuppressKeyPress = true;
- _autoBox.Hide();
- else if (code == Keys.Enter || code == Keys.Return)
- if (_autoBox.Visible && _autoBox.SelectedItems.Count == 1)
- _autoBox.Hide();
- private void HandleKeyUp(KeyEventArgs e)
- if (code == Keys.Oemcomma || code == Keys.OemOpenBrackets)
- Complete(string.Empty);
- else if (code == Keys.OemQuotes)
- if (e.Modifiers == Keys.Shift) // "
- InsertText("\""); //NOXLATE
- else // '
- InsertText("'"); //NOXLATE
- else if (code == Keys.D9 && e.Modifiers == Keys.Shift) // (
- InsertText(")"); //NOXLATE
- else if (code == Keys.Up || code == Keys.Down)
- if (code == Keys.Up)
- MoveAutoCompleteSelectionUp();
- else
- MoveAutoCompleteSelectionDown();
- else if (code == Keys.Back)
- string context;
- if (!string.IsNullOrEmpty(context))
- Complete(context);
- else
- _autoBox.Hide();
- else if (e.Modifiers == Keys.Alt && e.KeyCode == Keys.Right)
- string context;
- else
- if (e.Modifiers == Keys.None)
- bool alpha = (code >= Keys.A && code <= Keys.Z);
- bool numeric = (code >= Keys.D0 && code <= Keys.D9) || (code >= Keys.NumPad0 && code <= Keys.NumPad9);
- if (alpha || numeric)
- string context;
- private List<AutoCompleteItem> GetItemsStartingWith(string text)
- List<AutoCompleteItem> ati = new List<AutoCompleteItem>();
- foreach (string key in _autoCompleteItems.Keys)
- if (key.ToLower().StartsWith(text.Trim().ToLower()))
- ati.Add(_autoCompleteItems[key]);
- return ati;
- private void Complete(string text)
- List<AutoCompleteItem> items = GetItemsStartingWith(text);
- _autoBox.Items.Clear();
- int width = 0;
- foreach (AutoCompleteItem it in items)
- ImageListBoxItem litem = new ImageListBoxItem();
- litem.Text = it.Name;
- litem.ImageIndex = (int)it.Type;
- litem.Tag = it;
- _autoBox.Items.Add(litem);
- int length = TextRenderer.MeasureText(it.Name, _autoBox.Font).Width + 30; //For icon size
- if (length > width)
- width = length;
- _autoBox.Width = width;
- if (!_autoBox.Visible)
- if (_autoBox.Items.Count > 0)
- _autoBox.BringToFront();
- _autoBox.Show();
- _autoBox.Location = pt;
- private void ExpressionText_KeyDown(object sender, KeyEventArgs e)
- HandleKeyDown(e);
- private void ExpressionText_KeyUp(object sender, KeyEventArgs e)
- HandleKeyUp(e);
private void ColumnName_Click(object sender, EventArgs e)
@@ -1107,102 +415,15 @@
- // ImageListBoxItem class
- internal class ImageListBoxItem
- private string _myText;
- private int _myImageIndex;
- // properties
- public string Text
+ private void InsertSpatialFilter(string text)
- get { return _myText; }
- set { _myText = value; }
+ InsertText("[geometry] " + text + " GeomFromText('geometry wkt')");
- public int ImageIndex
- get { return _myImageIndex; }
- set { _myImageIndex = value; }
- //constructor
- public ImageListBoxItem(string text, int index)
- _myText = text;
- _myImageIndex = index;
- public ImageListBoxItem(string text) : this(text, -1) { }
- public ImageListBoxItem() : this("") { } //NOXLATE
- private object _tag;
- public object Tag
+ private void InsertText(string text)
- get { return _tag; }
- set { _tag = value; }
+ ExpressionText.ActiveTextAreaControl.TextArea.InsertString(text);
- public override string ToString()
- return _myText;
- }//End of ImageListBoxItem class
- // ImageListBox class
- // Based on GListBox
- // http://www.codeproject.com/KB/combobox/glistbox.aspx
- internal class ImageListBox : ListBox
- private ImageList _myImageList;
- public ImageList ImageList
- get { return _myImageList; }
- set { _myImageList = value; }
- public ImageListBox()
- // Set owner draw mode
- this.DrawMode = DrawMode.OwnerDrawFixed;
- protected override void OnDrawItem(System.Windows.Forms.DrawItemEventArgs e)
- e.DrawBackground();
- e.DrawFocusRectangle();
- ImageListBoxItem item;
- Rectangle bounds = e.Bounds;
- Size imageSize = _myImageList.ImageSize;
- try
- item = (ImageListBoxItem)Items[e.Index];
- if (item.ImageIndex != -1)
- _myImageList.Draw(e.Graphics, bounds.Left, bounds.Top, item.ImageIndex);
- e.Graphics.DrawString(item.Text, e.Font, new SolidBrush(e.ForeColor),
- bounds.Left + imageSize.Width, bounds.Top);
- else
- bounds.Left, bounds.Top);
- catch
- if (e.Index != -1)
- e.Graphics.DrawString(Items[e.Index].ToString(), e.Font,
- new SolidBrush(e.ForeColor), bounds.Left, bounds.Top);
- else
- e.Graphics.DrawString(Text, e.Font, new SolidBrush(e.ForeColor),
- base.OnDrawItem(e);
- }//End of ImageListBox class
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.designer.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.designer.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -33,7 +33,6 @@
this.OKBtn = new System.Windows.Forms.Button();
this.CancelBtn = new System.Windows.Forms.Button();
this.panel1 = new System.Windows.Forms.Panel();
- this.lblHint = new System.Windows.Forms.Label();
this.btnProperties = new System.Windows.Forms.ToolStripDropDownButton();
this.btnFunctions = new System.Windows.Forms.ToolStripDropDownButton();
@@ -45,8 +44,8 @@
this.ColumnValue = new System.Windows.Forms.ToolStripComboBox();
this.LookupValues = new System.Windows.Forms.ToolStripButton();
this.ColumnName = new System.Windows.Forms.ToolStripComboBox();
- this.ExpressionText = new System.Windows.Forms.TextBox();
this._autoCompleteTooltip = new System.Windows.Forms.ToolTip(this.components);
+ this.ExpressionText = new ICSharpCode.TextEditor.TextEditorControl();
this.panel1.SuspendLayout();
@@ -67,17 +66,11 @@
// panel1
- this.panel1.Controls.Add(this.lblHint);
this.panel1.Controls.Add(this.CancelBtn);
this.panel1.Controls.Add(this.OKBtn);
resources.ApplyResources(this.panel1, "panel1");
this.panel1.Name = "panel1";
- // lblHint
- resources.ApplyResources(this.lblHint, "lblHint");
- this.lblHint.Name = "lblHint";
// toolStrip1
this.toolStrip1.GripStyle = System.Windows.Forms.ToolStripGripStyle.Hidden;
@@ -167,10 +160,10 @@
// ExpressionText
resources.ApplyResources(this.ExpressionText, "ExpressionText");
- this.ExpressionText.HideSelection = false;
+ this.ExpressionText.IsReadOnly = false;
this.ExpressionText.Name = "ExpressionText";
- this.ExpressionText.KeyDown += new System.Windows.Forms.KeyEventHandler(this.ExpressionText_KeyDown);
- this.ExpressionText.KeyUp += new System.Windows.Forms.KeyEventHandler(this.ExpressionText_KeyUp);
+ this.ExpressionText.ShowLineNumbers = false;
+ this.ExpressionText.ShowVRuler = false;
// ExpressionEditor
@@ -182,7 +175,6 @@
this.Controls.Add(this.panel1);
this.Name = "ExpressionEditor";
this.panel1.ResumeLayout(false);
- this.panel1.PerformLayout();
this.toolStrip1.ResumeLayout(false);
this.toolStrip1.PerformLayout();
this.ResumeLayout(false);
@@ -196,18 +188,17 @@
private System.Windows.Forms.Button CancelBtn;
private System.Windows.Forms.Panel panel1;
- private System.Windows.Forms.TextBox ExpressionText;
private System.Windows.Forms.ToolStripDropDownButton btnFilter;
private System.Windows.Forms.ToolStripMenuItem btnCondition;
private System.Windows.Forms.ToolStripMenuItem btnSpatial;
private System.Windows.Forms.ToolStripMenuItem btnDistance;
private System.Windows.Forms.ToolTip _autoCompleteTooltip;
- private System.Windows.Forms.Label lblHint;
private System.Windows.Forms.ToolStripComboBox ColumnName;
private System.Windows.Forms.ToolStripButton LookupValues;
private System.Windows.Forms.ToolStripComboBox ColumnValue;
private System.Windows.Forms.ToolStripDropDownButton btnProperties;
private System.Windows.Forms.ToolStripDropDownButton btnFunctions;
+ private ICSharpCode.TextEditor.TextEditorControl ExpressionText;
Modified: trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.resx
--- trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.resx 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ExpressionEditor.resx 2012-10-29 13:32:01 UTC (rev 7162)
@@ -123,7 +123,7 @@
</data>
<assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="OKBtn.Location" type="System.Drawing.Point, System.Drawing">
- <value>342, 6</value>
+ <value>368, 6</value>
</data>
<data name="OKBtn.Size" type="System.Drawing.Size, System.Drawing">
<value>75, 23</value>
@@ -145,13 +145,13 @@
<value>panel1</value>
</data>
<data name=">>OKBtn.ZOrder" xml:space="preserve">
- <value>2</value>
+ <value>1</value>
</data>
<data name="CancelBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Bottom, Right</value>
</data>
<data name="CancelBtn.Location" type="System.Drawing.Point, System.Drawing">
- <value>423, 6</value>
+ <value>449, 6</value>
</data>
<data name="CancelBtn.Size" type="System.Drawing.Size, System.Drawing">
@@ -172,43 +172,16 @@
</data>
<data name=">>CancelBtn.ZOrder" xml:space="preserve">
- <value>1</value>
- </data>
- <data name="lblHint.AutoSize" type="System.Boolean, mscorlib">
- <value>True</value>
- </data>
- <data name="lblHint.Location" type="System.Drawing.Point, System.Drawing">
- <value>12, 11</value>
- </data>
- <data name="lblHint.Size" type="System.Drawing.Size, System.Drawing">
- <value>202, 13</value>
- </data>
- <data name="lblHint.TabIndex" type="System.Int32, mscorlib">
- <value>4</value>
- </data>
- <data name="lblHint.Text" xml:space="preserve">
- <value>Press Alt + Right to invoke auto-complete</value>
- </data>
- <data name=">>lblHint.Name" xml:space="preserve">
- <value>lblHint</value>
- </data>
- <data name=">>lblHint.Type" xml:space="preserve">
- <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>lblHint.Parent" xml:space="preserve">
- <value>panel1</value>
- </data>
- <data name=">>lblHint.ZOrder" xml:space="preserve">
<value>0</value>
</data>
<data name="panel1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Bottom</value>
</data>
<data name="panel1.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 249</value>
+ <value>0, 244</value>
</data>
<data name="panel1.Size" type="System.Drawing.Size, System.Drawing">
- <value>510, 40</value>
+ <value>536, 40</value>
</data>
<data name="panel1.TabIndex" type="System.Int32, mscorlib">
<value>4</value>
@@ -304,7 +277,7 @@
<value>0, 0</value>
</data>
<data name="toolStrip1.Size" type="System.Drawing.Size, System.Drawing">
- <value>510, 25</value>
+ <value>536, 25</value>
</data>
<data name="toolStrip1.TabIndex" type="System.Int32, mscorlib">
<value>5</value>
@@ -324,20 +297,17 @@
<data name=">>toolStrip1.ZOrder" xml:space="preserve">
<value>1</value>
</data>
+ <metadata name="_autoCompleteTooltip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>116, 17</value>
+ </metadata>
<data name="ExpressionText.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
<value>Fill</value>
</data>
- <data name="ExpressionText.Font" type="System.Drawing.Font, System.Drawing">
- <value>Courier New, 12pt</value>
- </data>
<data name="ExpressionText.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 25</value>
</data>
- <data name="ExpressionText.Multiline" type="System.Boolean, mscorlib">
- </data>
<data name="ExpressionText.Size" type="System.Drawing.Size, System.Drawing">
- <value>510, 224</value>
+ <value>536, 219</value>
</data>
<data name="ExpressionText.TabIndex" type="System.Int32, mscorlib">
<value>6</value>
@@ -346,7 +316,7 @@
<value>ExpressionText</value>
</data>
<data name=">>ExpressionText.Type" xml:space="preserve">
- <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>ICSharpCode.TextEditor.TextEditorControl, ICSharpCode.TextEditor, Version=4.2.0.8783, Culture=neutral, PublicKeyToken=4d61825e8dd49f1a</value>
</data>
<data name=">>ExpressionText.Parent" xml:space="preserve">
<value>$this</value>
@@ -354,14 +324,11 @@
<data name=">>ExpressionText.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <metadata name="_autoCompleteTooltip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>116, 17</value>
- </metadata>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
<data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
- <value>510, 289</value>
+ <value>536, 284</value>
</data>
<data name="$this.MinimumSize" type="System.Drawing.Size, System.Drawing">
<value>500, 300</value>
Added: trunk/Tools/Maestro/Maestro.Editors/Common/ITextEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/ITextEditor.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/ITextEditor.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -0,0 +1,133 @@
+#region Disclaimer / License
+// Copyright (C) 2012, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// Original code from SharpDevelop 3.2.1 licensed under the same terms (LGPL 2.1)
+// Copyright 2002-2010 by
+// AlphaSierraPapa, Christoph Wille
+// Vordernberger Strasse 27/8
+// A-8700 Leoben
+// Austria
+// email: office at alphasierrapapa.com
+// court of jurisdiction: Landesgericht Leoben
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Drawing;
+using System.Linq;
+using System.Text;
+ /// <summary>
+ /// A text editor controller interface that supports auto-completion. Note that
+ /// all the methods will be called on another thread not the main UI thread and will therefore need to
+ /// be invoked.
+ /// </summary>
+ public interface ITextEditor
+ /// <summary>
+ /// Fired when a key is pressed but before any text has been added to the text editor.
+ /// </summary>
+ /// <remarks>
+ /// The KeyPress handler should return true if the text editor should not process the key and not
+ /// insert any text.
+ /// </remarks>
+ event KeyEventHandler KeyPress;
+ /// <summary>
+ /// Fired when dialog key is pressed but before any text has been added to the text editor.
+ /// </summary>
+ /// <remarks>
+ /// The DialogKeyPress handler should return true if the text editor should not process the
+ /// dialog key.
+ /// </remarks>
+ event DialogKeyProcessor DialogKeyPress;
+ /// <summary>
+ /// Gets or sets the indentation style.
+ /// </summary>
+ IndentStyle IndentStyle { get; set; }
+ /// <summary>
+ /// Inserts text at the current cursor location.
+ /// </summary>
+ void Write(string text);
+ /// <summary>
+ /// Inserts text at the current cursor location with the specified colour.
+ /// </summary>
+ void Write(string text, Color backgroundColor);
+ /// <summary>
+ /// Replaces the text at the specified index on the current line with the specified text.
+ /// </summary>
+ void Replace(int index, int length, string text);
+ /// <summary>
+ /// Gets or sets the current column position of the cursor on the current line. This is zero based.
+ /// </summary>
+ int Column { get; set; }
+ /// <summary>
+ /// Gets the length of the currently selected text.
+ /// </summary>
+ int SelectionLength { get; }
+ /// <summary>
+ /// Gets the start position of the currently selected text.
+ /// </summary>
+ int SelectionStart { get; }
+ /// <summary>
+ /// Gets the current line the cursor is on. This is zero based.
+ /// </summary>
+ int Line { get; }
+ /// <summary>
+ /// Gets the total number of lines in the text editor.
+ /// </summary>
+ int TotalLines { get; }
+ /// <summary>
+ /// Gets the text for the specified line.
+ /// </summary>
+ string GetLine(int index);
+ /// <summary>
+ /// Shows the code completion window.
+ /// </summary>
+ void ShowCompletionWindow(ICompletionDataProvider completionDataProvider);
+ /// <summary>
+ /// Indicates whether the completion window is currently being displayed.
+ /// </summary>
+ bool IsCompletionWindowDisplayed { get; }
+ /// <summary>
+ /// Makes the current text content read only. Text can be entered at the end.
+ /// </summary>
+ void MakeCurrentContentReadOnly();
Added: trunk/Tools/Maestro/Maestro.Editors/Common/TextEditor.cs
--- trunk/Tools/Maestro/Maestro.Editors/Common/TextEditor.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro.Editors/Common/TextEditor.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -0,0 +1,245 @@
+// A-8700 Leoben
+// Austria
+#endregion
+using System;
+using System.Linq;
+using System.Text;
+ public class TextEditor : ITextEditor
+ delegate string GetLineInvoker(int index);
+ delegate void WriteInvoker(string text, Color color);
+ TextEditorControl textEditorControl;
+ TextArea textArea;
+ Color customLineColour = Color.LightGray;
+ TextMarker readOnlyMarker;
+ CodeCompletionWindow completionWindow;
+ public TextEditor(TextEditorControl textEditorControl)
+ this.textEditorControl = textEditorControl;
+ this.textArea = textEditorControl.ActiveTextAreaControl.TextArea;
+ textEditorControl.TextEditorProperties.SupportReadOnlySegments = true;
+ public IndentStyle IndentStyle
+ get { return textEditorControl.IndentStyle; }
+ set { SetIndentStyle(value); }
+ public event KeyEventHandler KeyPress
+ add { textArea.KeyEventHandler += value; }
+ remove { textArea.KeyEventHandler -= value; }
+ public event DialogKeyProcessor DialogKeyPress
+ add { textArea.DoProcessDialogKey += value; }
+ remove { textArea.DoProcessDialogKey -= value; }
+ public Color CustomLineColour
+ get { return customLineColour; }
+ public void Write(string text)
+ Write(text, Color.Empty);
+ public void Write(string text, Color backgroundColour)
+ if (textEditorControl.InvokeRequired)
+ WriteInvoker invoker = new WriteInvoker(Write);
+ textEditorControl.Invoke(invoker, new object[] { text, backgroundColour });
+ else
+ int offset = textEditorControl.Document.PositionToOffset(new TextLocation(Column, Line));
+ textEditorControl.ActiveTextAreaControl.TextArea.InsertString(text);
+ if (!backgroundColour.IsEmpty)
+ TextMarker marker = new TextMarker(offset, text.Length, TextMarkerType.SolidBlock, backgroundColour);
+ textEditorControl.Document.MarkerStrategy.AddMarker(marker);
+ textEditorControl.Refresh();
+ public int Column
+ get { return textEditorControl.ActiveTextAreaControl.Caret.Column; }
+ set { textEditorControl.ActiveTextAreaControl.Caret.Column = value; }
+ public int SelectionStart
+ get
+ ColumnRange range = GetSelectionRange();
+ if (range != ColumnRange.NoColumn)
+ return range.StartColumn;
+ return Column;
+ public int SelectionLength
+ get
+ return range.EndColumn - range.StartColumn;
+ /// <summary>
+ /// Gets the current cursor line.
+ /// </summary>
+ public int Line
+ get { return textArea.Caret.Line; }
+ /// <summary>
+ /// </summary>
+ public int TotalLines
+ get { return textEditorControl.Document.TotalNumberOfLines; }
+ /// <summary>
+ /// </summary>
+ public string GetLine(int index)
+ GetLineInvoker invoker = new GetLineInvoker(GetLine);
+ return (string)textEditorControl.Invoke(invoker, new object[] { index });
+ else
+ LineSegment lineSegment = textEditorControl.Document.GetLineSegment(index);
+ return textEditorControl.Document.GetText(lineSegment);
+ /// <summary>
+ /// </summary>
+ public void Replace(int index, int length, string text)
+ int currentLine = textEditorControl.ActiveTextAreaControl.Caret.Line;
+ LineSegment lineSegment = textEditorControl.Document.GetLineSegment(currentLine);
+ textEditorControl.Document.Replace(lineSegment.Offset + index, length, text);
+ /// <summary>
+ /// Makes the current text read only. Text can still be entered at the end.
+ /// </summary>
+ public void MakeCurrentContentReadOnly()
+ IDocument doc = textEditorControl.Document;
+ if (readOnlyMarker == null)
+ readOnlyMarker = new TextMarker(0, doc.TextLength, TextMarkerType.Invisible);
+ readOnlyMarker.IsReadOnly = true;
+ doc.MarkerStrategy.AddMarker(readOnlyMarker);
+ readOnlyMarker.Offset = 0;
+ readOnlyMarker.Length = doc.TextLength;
+ doc.UndoStack.ClearAll();
+ public void ShowCompletionWindow(ICompletionDataProvider completionDataProvider)
+ completionWindow = CodeCompletionWindow.ShowCompletionWindow(textEditorControl.ParentForm, textEditorControl, String.Empty, completionDataProvider, ' ');
+ public bool IsCompletionWindowDisplayed
+ get { return completionWindow != null; }
+ /// <summary>
+ /// Gets the range of the currently selected text.
+ /// </summary>
+ ColumnRange GetSelectionRange()
+ return textArea.SelectionManager.GetSelectionAtLine(textArea.Caret.Line);
+ void SetIndentStyle(IndentStyle style)
+ Action<IndentStyle> action = SetIndentStyle;
+ textEditorControl.Invoke(action, new object[] { style });
+ else
+ textEditorControl.IndentStyle = style;
Modified: trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj
--- trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.Editors/Maestro.Editors.csproj 2012-10-29 13:32:01 UTC (rev 7162)
@@ -105,6 +105,7 @@
<Compile Include="Common\ExpressionEditor.designer.cs">
<DependentUpon>ExpressionEditor.cs</DependentUpon>
</Compile>
+ <Compile Include="Common\Expression\FdoExpressionCompletionDataProvider.cs" />
<Compile Include="Common\FindReplaceDialog.cs">
<SubType>Form</SubType>
</Compile>
@@ -126,6 +127,7 @@
<Compile Include="Common\GenericItemSelectionDialog.Designer.cs">
<DependentUpon>GenericItemSelectionDialog.cs</DependentUpon>
</Compile>
+ <Compile Include="Common\ITextEditor.cs" />
<Compile Include="Common\NsDoc.cs" />
<Compile Include="Common\RepositoryTreeModel.cs" />
<Compile Include="Common\RepositoryView.cs">
@@ -152,6 +154,7 @@
<Compile Include="Common\SymbolPicker.Designer.cs">
<DependentUpon>SymbolPicker.cs</DependentUpon>
</Compile>
+ <Compile Include="Common\TextEditor.cs" />
<Compile Include="Common\UnmanagedFileBrowser.cs">
</Compile>
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs
--- trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.Designer.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -538,6 +538,15 @@
/// <summary>
+ /// Looks up a localized string similar to {0}{3}{1}{3}Returns: {2}.
+ /// </summary>
+ internal static string ExprEditorFunctionDesc {
+ get {
+ return ResourceManager.GetString("ExprEditorFunctionDesc", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Expression....
/// </summary>
internal static string ExpressionItem {
@@ -763,6 +772,15 @@
/// <summary>
+ /// Looks up a localized string similar to Property: {0}{2}Type: {1}.
+ /// </summary>
+ internal static string FsPreview_GenericPropertyTooltip {
+ get {
+ return ResourceManager.GetString("FsPreview_GenericPropertyTooltip", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Name: {0}{7}Description: {1}{7}Geometry Types: {2}{7}Read Only: {3}{7}Has Elevation: {4}{7}Has Measure: {5}{7}Spatial Context: {6}.
/// </summary>
internal static string FsPreview_GeometryPropertyNodeTooltip {
@@ -790,267 +808,6 @@
/// <summary>
- /// Looks up a localized string similar to Alpha value.
- /// </summary>
- internal static string Func_ARGB_AValueDescription {
- get {
- return ResourceManager.GetString("Func_ARGB_AValueDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Blue value.
- /// </summary>
- internal static string Func_ARGB_BValueDescription {
- get {
- return ResourceManager.GetString("Func_ARGB_BValueDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Color generation function.
- /// </summary>
- internal static string Func_ARGB_Description {
- get {
- return ResourceManager.GetString("Func_ARGB_Description", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Green value.
- /// </summary>
- internal static string Func_ARGB_GValueDescription {
- get {
- return ResourceManager.GetString("Func_ARGB_GValueDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Red value.
- /// </summary>
- internal static string Func_ARGB_RValueDescription {
- get {
- return ResourceManager.GetString("Func_ARGB_RValueDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to String formatting function.
- /// </summary>
- internal static string Func_DECAP_Description {
- get {
- return ResourceManager.GetString("Func_DECAP_Description", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to String to format.
- /// </summary>
- internal static string Func_DECAP_StringValueDescription {
- get {
- return ResourceManager.GetString("Func_DECAP_StringValueDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Returns the active feature class name.
- /// </summary>
- internal static string Func_FEATURECLASS_Description {
- get {
- return ResourceManager.GetString("Func_FEATURECLASS_Description", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Returns the active feature Id.
- /// </summary>
- internal static string Func_FEATUREID_Description {
- get {
- return ResourceManager.GetString("Func_FEATUREID_Description", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Boolean expression (filter) encapsulated in a string.
- /// </summary>
- internal static string Func_IF_ConditionDescription {
- get {
- return ResourceManager.GetString("Func_IF_ConditionDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to If evaluator for style theming.
- /// </summary>
- internal static string Func_IF_Description {
- get {
- return ResourceManager.GetString("Func_IF_Description", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Returned if condition is false.
- /// </summary>
- internal static string Func_IF_FalseValueDescription {
- get {
- return ResourceManager.GetString("Func_IF_FalseValueDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Returned if condition is true.
- /// </summary>
- internal static string Func_IF_TrueValueDescription {
- get {
- return ResourceManager.GetString("Func_IF_TrueValueDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Returns the active layer Id.
- /// </summary>
- internal static string Func_LAYERID_Description {
- get {
- return ResourceManager.GetString("Func_LAYERID_Description", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Default value returned if expression does not evaluate to any of the keys.
- /// </summary>
- internal static string Func_LOOKUP_DefaultValueDescription {
- get {
- return ResourceManager.GetString("Func_LOOKUP_DefaultValueDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Lookup table for style theming.
- /// </summary>
- internal static string Func_LOOKUP_Description {
- get {
- return ResourceManager.GetString("Func_LOOKUP_Description", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Key expression.
- /// </summary>
- internal static string Func_LOOKUP_ExpressionDescription {
- get {
- return ResourceManager.GetString("Func_LOOKUP_ExpressionDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Lookup index that can be matched by the key expression.
- /// </summary>
- internal static string Func_LOOKUP_IndexDescription {
- get {
- return ResourceManager.GetString("Func_LOOKUP_IndexDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Value that is returned when the key expression matches the associated index.
- /// </summary>
- internal static string Func_LOOKUP_ValueDescription {
- get {
- return ResourceManager.GetString("Func_LOOKUP_ValueDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Returns the active map name.
- /// </summary>
- internal static string Func_MAPNAME_Description {
- get {
- return ResourceManager.GetString("Func_MAPNAME_Description", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Default value returned if expression does not fall into any of the ranges.
- /// </summary>
- internal static string Func_RANGE_DefaultValueDescription {
- get {
- return ResourceManager.GetString("Func_RANGE_DefaultValueDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Range table for style theming.
- /// </summary>
- internal static string Func_RANGE_Description {
- get {
- return ResourceManager.GetString("Func_RANGE_Description", resourceCulture);
- /// <summary>
- /// </summary>
- internal static string Func_RANGE_ExpressionDescription {
- get {
- return ResourceManager.GetString("Func_RANGE_ExpressionDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Exclusive maximum of range that can be matched by the key expression.
- /// </summary>
- internal static string Func_RANGE_MaxDescription {
- get {
- return ResourceManager.GetString("Func_RANGE_MaxDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Inclusive minimum of range that can be matched by the key expression.
- /// </summary>
- internal static string Func_RANGE_MinDescription {
- get {
- return ResourceManager.GetString("Func_RANGE_MinDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Value that is returned when the key expression matches the associated range.
- /// </summary>
- internal static string Func_RANGE_ValueDescription {
- get {
- return ResourceManager.GetString("Func_RANGE_ValueDescription", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to Returns the active session.
- /// </summary>
- internal static string Func_SESSION_Description {
- get {
- return ResourceManager.GetString("Func_SESSION_Description", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to String encoding function.
- /// </summary>
- internal static string Func_URLENCODE_Description {
- get {
- return ResourceManager.GetString("Func_URLENCODE_Description", resourceCulture);
- /// <summary>
- /// Looks up a localized string similar to String to URL encode.
- /// </summary>
- internal static string Func_URLENCODE_StringValueDescription {
- get {
- return ResourceManager.GetString("Func_URLENCODE_StringValueDescription", resourceCulture);
- /// <summary>
/// Looks up a localized string similar to Function: {1}({2})
///Description: {3}
///Returns: {0}.
Modified: trunk/Tools/Maestro/Maestro.Editors/Strings.resx
--- trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Maestro.Editors/Strings.resx 2012-10-29 13:32:01 UTC (rev 7162)
@@ -732,93 +732,6 @@
Description: {3}
Returns: {0}</value>
</data>
- <data name="Func_ARGB_AValueDescription" xml:space="preserve">
- <value>Alpha value</value>
- </data>
- <data name="Func_ARGB_BValueDescription" xml:space="preserve">
- <value>Blue value</value>
- </data>
- <data name="Func_ARGB_Description" xml:space="preserve">
- <value>Color generation function</value>
- </data>
- <data name="Func_ARGB_GValueDescription" xml:space="preserve">
- <value>Green value</value>
- </data>
- <data name="Func_ARGB_RValueDescription" xml:space="preserve">
- <value>Red value</value>
- </data>
- <data name="Func_DECAP_Description" xml:space="preserve">
- <value>String formatting function</value>
- </data>
- <data name="Func_DECAP_StringValueDescription" xml:space="preserve">
- <value>String to format</value>
- </data>
- <data name="Func_FEATURECLASS_Description" xml:space="preserve">
- <value>Returns the active feature class name</value>
- </data>
- <data name="Func_FEATUREID_Description" xml:space="preserve">
- <value>Returns the active feature Id</value>
- </data>
- <data name="Func_IF_ConditionDescription" xml:space="preserve">
- <value>Boolean expression (filter) encapsulated in a string</value>
- </data>
- <data name="Func_IF_Description" xml:space="preserve">
- <value>If evaluator for style theming</value>
- </data>
- <data name="Func_IF_FalseValueDescription" xml:space="preserve">
- <value>Returned if condition is false</value>
- </data>
- <data name="Func_IF_TrueValueDescription" xml:space="preserve">
- <value>Returned if condition is true</value>
- </data>
- <data name="Func_LAYERID_Description" xml:space="preserve">
- <value>Returns the active layer Id</value>
- </data>
- <data name="Func_LOOKUP_DefaultValueDescription" xml:space="preserve">
- <value>Default value returned if expression does not evaluate to any of the keys</value>
- </data>
- <data name="Func_LOOKUP_Description" xml:space="preserve">
- <value>Lookup table for style theming</value>
- </data>
- <data name="Func_LOOKUP_ExpressionDescription" xml:space="preserve">
- <value>Key expression</value>
- </data>
- <data name="Func_LOOKUP_IndexDescription" xml:space="preserve">
- <value>Lookup index that can be matched by the key expression</value>
- </data>
- <data name="Func_LOOKUP_ValueDescription" xml:space="preserve">
- <value>Value that is returned when the key expression matches the associated index</value>
- </data>
- <data name="Func_MAPNAME_Description" xml:space="preserve">
- <value>Returns the active map name</value>
- </data>
- <data name="Func_RANGE_DefaultValueDescription" xml:space="preserve">
- <value>Default value returned if expression does not fall into any of the ranges</value>
- </data>
- <data name="Func_RANGE_Description" xml:space="preserve">
- <value>Range table for style theming</value>
- </data>
- <data name="Func_RANGE_ExpressionDescription" xml:space="preserve">
- </data>
- <data name="Func_RANGE_MaxDescription" xml:space="preserve">
- <value>Exclusive maximum of range that can be matched by the key expression</value>
- </data>
- <data name="Func_RANGE_MinDescription" xml:space="preserve">
- <value>Inclusive minimum of range that can be matched by the key expression</value>
- </data>
- <data name="Func_RANGE_ValueDescription" xml:space="preserve">
- <value>Value that is returned when the key expression matches the associated range</value>
- </data>
- <data name="Func_SESSION_Description" xml:space="preserve">
- <value>Returns the active session</value>
- </data>
- <data name="Func_URLENCODE_Description" xml:space="preserve">
- <value>String encoding function</value>
- </data>
- <data name="Func_URLENCODE_StringValueDescription" xml:space="preserve">
- <value>String to URL encode</value>
- </data>
<data name="GenericError" xml:space="preserve">
<value>An error occured: {0}</value>
</data>
@@ -1455,4 +1368,10 @@
<data name="ConfirmWmsLogicalClassSwap" xml:space="preserve">
<value>In some cases, the actual WMS layer name would be generated in the FDO class description. Swap FDO logical class names with their descriptions?</value>
</data>
+ <data name="FsPreview_GenericPropertyTooltip" xml:space="preserve">
+ <value>Property: {0}{2}Type: {1}</value>
+ </data>
+ <data name="ExprEditorFunctionDesc" xml:space="preserve">
+ <value>{0}{3}{1}{3}Returns: {2}</value>
+ </data>
</root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.Designer.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -1494,6 +1494,267 @@
/// <summary>
+ /// Looks up a localized string similar to Alpha value.
+ /// </summary>
+ public static string Func_ARGB_AValueDescription {
+ get {
+ return ResourceManager.GetString("Func_ARGB_AValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Blue value.
+ /// </summary>
+ public static string Func_ARGB_BValueDescription {
+ get {
+ return ResourceManager.GetString("Func_ARGB_BValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Color generation function.
+ /// </summary>
+ public static string Func_ARGB_Description {
+ get {
+ return ResourceManager.GetString("Func_ARGB_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Green value.
+ /// </summary>
+ public static string Func_ARGB_GValueDescription {
+ get {
+ return ResourceManager.GetString("Func_ARGB_GValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Red value.
+ /// </summary>
+ public static string Func_ARGB_RValueDescription {
+ get {
+ return ResourceManager.GetString("Func_ARGB_RValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to String formatting function.
+ /// </summary>
+ public static string Func_DECAP_Description {
+ get {
+ return ResourceManager.GetString("Func_DECAP_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to String to format.
+ /// </summary>
+ public static string Func_DECAP_StringValueDescription {
+ get {
+ return ResourceManager.GetString("Func_DECAP_StringValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returns the active feature class name.
+ /// </summary>
+ public static string Func_FEATURECLASS_Description {
+ get {
+ return ResourceManager.GetString("Func_FEATURECLASS_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returns the active feature Id.
+ /// </summary>
+ public static string Func_FEATUREID_Description {
+ get {
+ return ResourceManager.GetString("Func_FEATUREID_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Boolean expression (filter) encapsulated in a string.
+ /// </summary>
+ public static string Func_IF_ConditionDescription {
+ get {
+ return ResourceManager.GetString("Func_IF_ConditionDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to If evaluator for style theming.
+ /// </summary>
+ public static string Func_IF_Description {
+ get {
+ return ResourceManager.GetString("Func_IF_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returned if condition is false.
+ /// </summary>
+ public static string Func_IF_FalseValueDescription {
+ get {
+ return ResourceManager.GetString("Func_IF_FalseValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returned if condition is true.
+ /// </summary>
+ public static string Func_IF_TrueValueDescription {
+ get {
+ return ResourceManager.GetString("Func_IF_TrueValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returns the active layer Id.
+ /// </summary>
+ public static string Func_LAYERID_Description {
+ get {
+ return ResourceManager.GetString("Func_LAYERID_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Default value returned if expression does not evaluate to any of the keys.
+ /// </summary>
+ public static string Func_LOOKUP_DefaultValueDescription {
+ get {
+ return ResourceManager.GetString("Func_LOOKUP_DefaultValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Lookup table for style theming.
+ /// </summary>
+ public static string Func_LOOKUP_Description {
+ get {
+ return ResourceManager.GetString("Func_LOOKUP_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Key expression.
+ /// </summary>
+ public static string Func_LOOKUP_ExpressionDescription {
+ get {
+ return ResourceManager.GetString("Func_LOOKUP_ExpressionDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Lookup index that can be matched by the key expression.
+ /// </summary>
+ public static string Func_LOOKUP_IndexDescription {
+ get {
+ return ResourceManager.GetString("Func_LOOKUP_IndexDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Value that is returned when the key expression matches the associated index.
+ /// </summary>
+ public static string Func_LOOKUP_ValueDescription {
+ get {
+ return ResourceManager.GetString("Func_LOOKUP_ValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returns the active map name.
+ /// </summary>
+ public static string Func_MAPNAME_Description {
+ get {
+ return ResourceManager.GetString("Func_MAPNAME_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Default value returned if expression does not fall into any of the ranges.
+ /// </summary>
+ public static string Func_RANGE_DefaultValueDescription {
+ get {
+ return ResourceManager.GetString("Func_RANGE_DefaultValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Range table for style theming.
+ /// </summary>
+ public static string Func_RANGE_Description {
+ get {
+ return ResourceManager.GetString("Func_RANGE_Description", resourceCulture);
+ /// <summary>
+ /// </summary>
+ public static string Func_RANGE_ExpressionDescription {
+ get {
+ return ResourceManager.GetString("Func_RANGE_ExpressionDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Exclusive maximum of range that can be matched by the key expression.
+ /// </summary>
+ public static string Func_RANGE_MaxDescription {
+ get {
+ return ResourceManager.GetString("Func_RANGE_MaxDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Inclusive minimum of range that can be matched by the key expression.
+ /// </summary>
+ public static string Func_RANGE_MinDescription {
+ get {
+ return ResourceManager.GetString("Func_RANGE_MinDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Value that is returned when the key expression matches the associated range.
+ /// </summary>
+ public static string Func_RANGE_ValueDescription {
+ get {
+ return ResourceManager.GetString("Func_RANGE_ValueDescription", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Returns the active session.
+ /// </summary>
+ public static string Func_SESSION_Description {
+ get {
+ return ResourceManager.GetString("Func_SESSION_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to String encoding function.
+ /// </summary>
+ public static string Func_URLENCODE_Description {
+ get {
+ return ResourceManager.GetString("Func_URLENCODE_Description", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to String to URL encode.
+ /// </summary>
+ public static string Func_URLENCODE_StringValueDescription {
+ get {
+ return ResourceManager.GetString("Func_URLENCODE_StringValueDescription", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to {0} (*.{1})|*.{1}.
/// </summary>
public static string GenericFilter {
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Strings.resx 2012-10-29 13:32:01 UTC (rev 7162)
@@ -3345,4 +3345,91 @@
<data name="ErrorConnectionCannotAutoRestartSession" xml:space="preserve">
<value>This connection cannot auto-restart sessions. Most likely because this connection was just initialized with a session id and not with the credentials required to rebuild a new session</value>
</data>
+ <data name="Func_ARGB_AValueDescription" xml:space="preserve">
+ <value>Alpha value</value>
+ </data>
+ <data name="Func_ARGB_BValueDescription" xml:space="preserve">
+ <value>Blue value</value>
+ </data>
+ <data name="Func_ARGB_Description" xml:space="preserve">
+ <value>Color generation function</value>
+ </data>
+ <data name="Func_ARGB_GValueDescription" xml:space="preserve">
+ <value>Green value</value>
+ </data>
+ <data name="Func_ARGB_RValueDescription" xml:space="preserve">
+ <value>Red value</value>
+ </data>
+ <data name="Func_DECAP_Description" xml:space="preserve">
+ <value>String formatting function</value>
+ </data>
+ <data name="Func_DECAP_StringValueDescription" xml:space="preserve">
+ <value>String to format</value>
+ </data>
+ <data name="Func_FEATURECLASS_Description" xml:space="preserve">
+ <value>Returns the active feature class name</value>
+ </data>
+ <data name="Func_FEATUREID_Description" xml:space="preserve">
+ <value>Returns the active feature Id</value>
+ </data>
+ <data name="Func_IF_ConditionDescription" xml:space="preserve">
+ <value>Boolean expression (filter) encapsulated in a string</value>
+ </data>
+ <data name="Func_IF_Description" xml:space="preserve">
+ <value>If evaluator for style theming</value>
+ </data>
+ <data name="Func_IF_FalseValueDescription" xml:space="preserve">
+ <value>Returned if condition is false</value>
+ </data>
+ <data name="Func_IF_TrueValueDescription" xml:space="preserve">
+ <value>Returned if condition is true</value>
+ </data>
+ <data name="Func_LAYERID_Description" xml:space="preserve">
+ <value>Returns the active layer Id</value>
+ </data>
+ <data name="Func_LOOKUP_DefaultValueDescription" xml:space="preserve">
+ <value>Default value returned if expression does not evaluate to any of the keys</value>
+ </data>
+ <data name="Func_LOOKUP_Description" xml:space="preserve">
+ <value>Lookup table for style theming</value>
+ </data>
+ <data name="Func_LOOKUP_ExpressionDescription" xml:space="preserve">
+ <value>Key expression</value>
+ </data>
+ <data name="Func_LOOKUP_IndexDescription" xml:space="preserve">
+ <value>Lookup index that can be matched by the key expression</value>
+ </data>
+ <data name="Func_LOOKUP_ValueDescription" xml:space="preserve">
+ <value>Value that is returned when the key expression matches the associated index</value>
+ </data>
+ <data name="Func_MAPNAME_Description" xml:space="preserve">
+ <value>Returns the active map name</value>
+ </data>
+ <data name="Func_RANGE_DefaultValueDescription" xml:space="preserve">
+ <value>Default value returned if expression does not fall into any of the ranges</value>
+ </data>
+ <data name="Func_RANGE_Description" xml:space="preserve">
+ <value>Range table for style theming</value>
+ </data>
+ <data name="Func_RANGE_ExpressionDescription" xml:space="preserve">
+ </data>
+ <data name="Func_RANGE_MaxDescription" xml:space="preserve">
+ <value>Exclusive maximum of range that can be matched by the key expression</value>
+ </data>
+ <data name="Func_RANGE_MinDescription" xml:space="preserve">
+ <value>Inclusive minimum of range that can be matched by the key expression</value>
+ </data>
+ <data name="Func_RANGE_ValueDescription" xml:space="preserve">
+ <value>Value that is returned when the key expression matches the associated range</value>
+ </data>
+ <data name="Func_SESSION_Description" xml:space="preserve">
+ <value>Returns the active session</value>
+ </data>
+ <data name="Func_URLENCODE_Description" xml:space="preserve">
+ <value>String encoding function</value>
+ </data>
+ <data name="Func_URLENCODE_StringValueDescription" xml:space="preserve">
+ <value>String to URL encode</value>
+ </data>
</root>
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI/Utility.cs 2012-10-29 13:32:01 UTC (rev 7162)
@@ -32,6 +32,8 @@
using OSGeo.MapGuide.MaestroAPI.Resource;
using System.Text;
using System.Text.RegularExpressions;
+using OSGeo.MapGuide.ObjectModels.Capabilities;
+using System.ComponentModel;
namespace OSGeo.MapGuide.MaestroAPI
@@ -1113,6 +1115,222 @@
return "'" + str + "'"; //NOXLATE
+ /// <summary>
+ /// Returns the list of known FDO stylization expression functions
+ /// </summary>
+ /// <returns></returns>
+ public static IEnumerable<FdoProviderCapabilitiesExpressionFunctionDefinition> GetStylizationFunctions()
+ //ARGB
+ yield return new FdoProviderCapabilitiesExpressionFunctionDefinition()
+ ArgumentDefinitionList = new BindingList<FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinition>()
+ new FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinition()
+ Name = "aValue", //NOXLATE
+ Description = Strings.Func_ARGB_AValueDescription,
+ DataType = FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinitionDataType.Int32
+ Name = "rValue", //NOXLATE
+ Description = Strings.Func_ARGB_RValueDescription,
+ Name = "gValue", //NOXLATE
+ Description = Strings.Func_ARGB_GValueDescription,
+ Name = "bValue", //NOXLATE
+ Description = Strings.Func_ARGB_BValueDescription,
+ Description = Strings.Func_ARGB_Description,
+ Name = "ARGB", //NOXLATE
+ ReturnType = "Int32" //NOXLATE
+ //DECAP
+ Name = "strValue", //NOXLATE
+ Description = Strings.Func_DECAP_StringValueDescription,
+ DataType = FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinitionDataType.String
+ Description = Strings.Func_DECAP_Description,
+ Name = "DECAP", //NOXLATE
+ ReturnType = "String" //NOXLATE
+ //FEATURECLASS
+ ArgumentDefinitionList = new BindingList<FdoProviderCapabilitiesExpressionFunctionDefinitionArgumentDefinition>(),
+ Description = Strings.Func_FEATURECLASS_Description,
+ Name = "FEATURECLASS", //NOXLATE
+ //FEATUREID
+ Description = Strings.Func_FEATUREID_Description,
+ Name = "FEATUREID", //NOXLATE
+ //IF
+ Name = "condition", //NOXLATE
+ Description = Strings.Func_IF_ConditionDescription,
+ Name = "trueValue", //NOXLATE
+ Description = Strings.Func_IF_TrueValueDescription,
+ Name = "falseValue", //NOXLATE
+ Description = Strings.Func_IF_FalseValueDescription,
+ Description = Strings.Func_IF_Description,
+ Name = "IF", //NOXLATE
+ //LAYERID
+ Description = Strings.Func_LAYERID_Description,
+ Name = "LAYERID", //NOXLATE
+ //LOOKUP
+ Name = "expression", //NOXLATE
+ Description = Strings.Func_LOOKUP_ExpressionDescription,
+ Name = "defaultValue", //NOXLATE
+ Description = Strings.Func_LOOKUP_DefaultValueDescription,
+ Name = "index", //NOXLATE
+ Description = Strings.Func_LOOKUP_IndexDescription,
+ Name = "value", //NOXLATE
+ Description = Strings.Func_LOOKUP_ValueDescription,
+ Description = Strings.Func_LOOKUP_Description,
+ Name = "LOOKUP", //NOXLATE
+ //MAPNAME
+ Description = Strings.Func_MAPNAME_Description,
+ Name = "MAPNAME", //NOXLATE
+ //RANGE
+ Description = Strings.Func_RANGE_ExpressionDescription,
+ Name = "rangeMin", //NOXLATE
+ Description = Strings.Func_RANGE_MinDescription,
+ Name = "rangeMax", //NOXLATE
+ Description = Strings.Func_RANGE_MaxDescription,
+ Description = Strings.Func_RANGE_DefaultValueDescription,
+ Description = Strings.Func_RANGE_ValueDescription,
+ Description = Strings.Func_RANGE_Description,
+ Name = "RANGE", //NOXLATE
+ //SESSION
+ Description = Strings.Func_SESSION_Description,
+ Name = "SESSION", //NOXLATE
+ //URLENCODE
+ Description = Strings.Func_URLENCODE_StringValueDescription,
+ Description = Strings.Func_URLENCODE_Description,
+ Name = "URLENCODE", //NOXLATE
/// <summary>
Modified: trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/ICSharpCode.TextEditor.csproj
--- trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/ICSharpCode.TextEditor.csproj 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/ICSharpCode.TextEditor.csproj 2012-10-29 13:32:01 UTC (rev 7162)
@@ -201,6 +201,7 @@
<EmbeddedResource Include="Resources\Coco-Mode.xshd" />
<EmbeddedResource Include="Resources\CSharp-Mode.xshd" />
<EmbeddedResource Include="Resources\HTML-Mode.xshd" />
+ <EmbeddedResource Include="Resources\FDO.xshd" />
<None Include="Resources\ICSharpCode.TextEditor.snk" />
<EmbeddedResource Include="Resources\TextEditorControl.bmp" />
<EmbeddedResource Include="Resources\Java-Mode.xshd" />
@@ -223,6 +224,7 @@
<Compile Include="Src\Util\WeakCollection.cs" />
<EmbeddedResource Include="Resources\Patch-Mode.xshd" />
<EmbeddedResource Include="Resources\Python.xshd" />
+ <EmbeddedResource Include="Resources\SQL.xshd" />
</ItemGroup>
<Import Project="$(MSBuildBinPath)\Microsoft.CSharp.targets" />
</Project>
Added: trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/FDO.xshd
--- trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/FDO.xshd (rev 0)
+++ trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/FDO.xshd 2012-10-29 13:32:01 UTC (rev 7162)
@@ -0,0 +1,145 @@
+<?xml version = "1.0"?>
+<SyntaxDefinition name = "FDO" extensions = ".fdq">
+ <Environment>
+ <Default color = "SystemColors.WindowText" bgcolor="SystemColors.Window"/>
+ <VRuler color = "Blue"/>
+ <Selection bgcolor = "LightBlue"/>
+ <LineNumbers color = "Teal" bgcolor = "SystemColors.Window"/>
+ <InvalidLines color = "Red"/>
+ <EOLMarkers color = "White"/>
+ <SpaceMarkers color = "#E0E0E5"/>
+ <TabMarkers color = "#E0E0E5"/>
+ <CaretMarker color = "Yellow"/>
+ <FoldLine color = "#808080" bgcolor="Black"/>
+ <FoldMarker color = "#808080" bgcolor="White"/>
+ </Environment>
+ <Properties>
+ <Property name="LineComment" value="--"/>
+ </Properties>
+ <Digits name = "Digits" bold = "false" italic = "false" color = "DarkBlue"/>
+ <RuleSets>
+ <RuleSet ignorecase = "true">
+ <Delimiters>=!><+-/*%&|^~.}{,;][?:()</Delimiters>
+ <Span name ="String" bold ="false" italic ="false" color ="Sienna" stopateol ="false">
+ <Begin>"</Begin>
+ <End>"</End>
+ </Span>
+ <Span name = "Character" bold = "false" italic = "false" color = "Sienna" stopateol = "true">
+ <Begin>'</Begin>
+ <End>'</End>
+ </Span>
+ <KeyWords name ="Punctuation" bold="false" italic = "false" color = "DarkSlateGray">
+ <Key word = "(" />
+ <Key word = ")" />
+ </KeyWords>
+ <KeyWords name ="Operators" bold="false" italic = "false" color = "DarkSlateGray">
+ <Key word = "+" />
+ <Key word = "-" />
+ <Key word = "*" />
+ <Key word = "/" />
+ <Key word = "<" />
+ <Key word = ">" />
+ <Key word = "=" />
+ <Key word = "<=" />
+ <Key word = ">=" />
+ <Key word = "like" />
+ <Key word = "and" />
+ <Key word = "or" />
+ </KeyWords>
+ <KeyWords name ="Functions" bold="false" italic = "false" color = "DarkRed">
+ <!-- Aggregate -->
+ <Key word = "avg" />
+ <Key word = "count" />
+ <Key word = "max" />
+ <Key word = "median" />
+ <Key word = "min" />
+ <Key word = "spatialextents" />
+ <Key word = "stddev" />
+ <Key word = "sum" />
+ <!-- Conversion -->
+ <Key word = "nullvalue" />
+ <Key word = "todate" />
+ <Key word = "todouble" />
+ <Key word = "tofloat" />
+ <Key word = "toint32" />
+ <Key word = "toint64" />
+ <Key word = "tostring" />
+ <!-- Date -->
+ <Key word = "addmonths" />
+ <Key word = "currentdate" />
+ <Key word = "extract" />
+ <Key word = "extracttodouble" />
+ <Key word = "extracttoint" />
+ <Key word = "monthsbetween" />
+ <!-- Geometry -->
+ <Key word = "area2d" />
+ <Key word = "length2d" />
+ <Key word = "m" />
+ <Key word = "x" />
+ <Key word = "y" />
+ <Key word = "z" />
+ <!-- Math -->
+ <Key word = "abs" />
+ <Key word = "acos" />
+ <Key word = "asin" />
+ <Key word = "atan" />
+ <Key word = "atan2" />
+ <Key word = "cos" />
+ <Key word = "exp" />
+ <Key word = "ln" />
+ <Key word = "log" />
+ <Key word = "mod" />
+ <Key word = "power" />
+ <Key word = "remainder" />
+ <Key word = "sin" />
+ <Key word = "sqrt" />
+ <Key word = "tan" />
+ <!-- Numeric -->
+ <Key word = "ceil" />
+ <Key word = "floor" />
+ <Key word = "round" />
+ <Key word = "sign" />
+ <Key word = "trunc" />
+ <!-- String -->
+ <Key word = "concat" />
+ <Key word = "instr" />
+ <Key word = "length" />
+ <Key word = "lower" />
+ <Key word = "lpad" />
+ <Key word = "ltrim" />
+ <Key word = "rpad" />
+ <Key word = "rtrim" />
+ <Key word = "soundex" />
+ <Key word = "substr" />
+ <Key word = "translate" />
+ <Key word = "trim" />
+ <Key word = "upper" />
+ <!-- Stylization -->
+ <Key word = "argb" />
+ <Key word = "decap" />
+ <Key word = "featureclass" />
+ <Key word = "featureid" />
+ <Key word = "if" />
+ <Key word = "layerid" />
+ <Key word = "lookup" />
+ <Key word = "mapname" />
+ <Key word = "range" />
+ <Key word = "session" />
+ <Key word = "urlencode" />
+ <!-- Other -->
+ <Key word = "geomfromtext" />
+ </KeyWords>
+ </RuleSet>
+ </RuleSets>
+</SyntaxDefinition>
Added: trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/SQL.xshd
--- trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/SQL.xshd (rev 0)
+++ trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/SQL.xshd 2012-10-29 13:32:01 UTC (rev 7162)
@@ -0,0 +1,157 @@
+<SyntaxDefinition name = "SQL" extensions = ".sql">
+ <Environment>
+ </Environment>
+ <Properties>
+ </Properties>
+ <RuleSets>
+ <Span name ="LineComment" bold ="false" italic ="true" color ="DarkGreen" stopateol ="true">
+ <Begin>--</Begin>
+ </Span>
+ <Span name ="BlockComment" bold ="false" italic ="false" color ="DarkGreen" stopateol ="false">
+ <Begin>/*</Begin>
+ <End>*/</End>
+ </Span>
+ <Begin>"</Begin>
+ <End>"</End>
+ </Span>
+ <Begin>'</Begin>
+ <End>'</End>
+ </Span>
+ <KeyWords name ="SqlKeywords" bold="false" italic = "false" color = "Blue">
+ <Key word = "from" />
+ <Key word = "where" />
+ <Key word = "in" />
+ <Key word = "on" />
+ <Key word = "exists" />
+ <Key word = "not" />
+ <Key word = "null" />
+ <Key word = "having" />
+ <Key word = "group" />
+ <Key word = "by" />
+ <Key word = "order" />
+ <Key word = "into" />
+ <Key word = "values" />
+ <Key word = "set" />
+ <Key word = "inner" />
+ <Key word = "outer" />
+ <Key word = "join" />
+ <Key word = "union" />
+ <Key word = "desc" />
+ <Key word = "asc" />
+ </KeyWords>
+ <KeyWords name ="SqlActionWords" bold="false" italic = "false" color = "Blue">
+ <Key word = "select" />
+ <Key word = "update" />
+ <Key word = "use" />
+ <Key word = "insert" />
+ <Key word = "create" />
+ <Key word = "drop" />
+ <Key word = "delete" />
+ <Key word = "truncate" />
+ <Key word = "alter" />
+ <Key word = "add" />
+ </KeyWords>
+ <KeyWords name ="SqlTypes" bold="false" italic = "false" color = "DarkRed">
+ <Key word = "varchar" />
+ <Key word = "nvarchar" />
+ <Key word = "char" />
+ <Key word = "nchar" />
+ <Key word = "int" />
+ <Key word = "text" />
+ <Key word = "ntext" />
+ <Key word = "double" />
+ <Key word = "money" />
+ <Key word = "bit" />
+ </KeyWords>
+ <KeyWords name ="SqlObjects" bold="false" italic = "false" color = "DarkRed">
+ <Key word = "table" />
+ <Key word = "proc" />
+ <Key word = "procedure" />
+ <Key word = "function" />
+ <Key word = "view" />
+ <Key word = "trigger" />
+ <Key word = "index" />
+ <Key word = "database" />
+ </KeyWords>
+ <KeyWords name ="TSql" bold="false" italic = "false" color = "DarkBlue">
+ <Key word = "IF" />
+ <Key word = "ELSE" />
+ <Key word = "CASE" />
+ <Key word = "RETURN" />
+ <Key word = "END" />
+ <Key word = "DECLARE" />
+ <Key word = "SWITCH" />
+ <Key word = "BEGIN" />
+ <Key word = "WHEN" />
+ </KeyWords>
+ </KeyWords>
+ </KeyWords>
+ <Key word = "substring" />
+ <Key word = "reverse" />
+ <Key word = "replace" />
+ <Key word = "cast" />
+ </KeyWords>
+ </RuleSet>
+ </RuleSets>
Modified: trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/SyntaxModes.xml
--- trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/SyntaxModes.xml 2012-10-29 08:20:20 UTC (rev 7161)
+++ trunk/Tools/Maestro/Thirdparty/SharpDevelop/ICSharpCode.TextEditor/Resources/SyntaxModes.xml 2012-10-29 13:32:01 UTC (rev 7162)
@@ -26,8 +26,12 @@
<Mode file = "HTML-Mode.xshd"
name = "HTML"
extensions = ".htm;.html"/>
- <Mode file = "Java-Mode.xshd"
+ <Mode file = "FDO.xshd"
+ name = "FDO"
+ extensions = ".fdq"/>
+ <Mode file = "Java-Mode.xshd"
name = "Java"
extensions = ".java"/>
@@ -46,6 +50,10 @@
<Mode file = "Python.xshd"
name = "Python"
extensions = ".py"/>
+ <Mode file = "SQL.xshd"
+ name = "SQL"
+ extensions = ".sql"/>
<Mode file = "Tex-Mode.xshd"
name = "TeX"
More information about the mapguide-commits
