[mapguide-commits] r7466 - in sandbox/jng/querydef: Common/MdfModel Common/MdfParser Common/PlatformBase Common/PlatformBase/Exception Common/PlatformBase/Services Common/Schema Server Server/src/Services/Feature Server/src/UnitTesting UnitTest/TestData/FeatureService/SQLite
svn_mapguide at osgeo.org
Tue Apr 30 13:43:25 PDT 2013
Author: jng
Date: 2013-04-30 13:43:25 -0700 (Tue, 30 Apr 2013)
New Revision: 7466
Added:
sandbox/jng/querydef/Common/MdfParser/IOComputedPropertyCollection.cpp
sandbox/jng/querydef/Common/MdfParser/IOComputedPropertyCollection.h
sandbox/jng/querydef/Common/PlatformBase/Exception/InvalidQueryDefinitionException.cpp
sandbox/jng/querydef/Common/PlatformBase/Exception/InvalidQueryDefinitionException.h
sandbox/jng/querydef/Server/src/Services/Feature/ServerExecuteQueryDefinition.cpp
sandbox/jng/querydef/Server/src/Services/Feature/ServerExecuteQueryDefinition.h
sandbox/jng/querydef/Server/src/Services/Feature/ServerQueryDefinitionReader.cpp
sandbox/jng/querydef/Server/src/Services/Feature/ServerQueryDefinitionReader.h
sandbox/jng/querydef/Common/MdfModel/GeometryInfo.cpp
sandbox/jng/querydef/Common/MdfParser/IOAggregateQueryDefinition.cpp
sandbox/jng/querydef/Common/MdfParser/IOFeatureQueryDefinition.cpp
sandbox/jng/querydef/Common/MdfParser/IOGeometryInfo.cpp
sandbox/jng/querydef/Common/MdfParser/IOGeometryInfo.h
sandbox/jng/querydef/Common/MdfParser/IOSQLQueryDefinition.cpp
sandbox/jng/querydef/Common/MdfParser/MdfParser.vcxproj
sandbox/jng/querydef/Common/MdfParser/MdfParser.vcxproj.filters
sandbox/jng/querydef/Common/MdfParser/SAX2Parser.cpp
sandbox/jng/querydef/Common/PlatformBase/PlatformBase.h
sandbox/jng/querydef/Common/PlatformBase/PlatformBase.vcxproj
sandbox/jng/querydef/Common/PlatformBase/PlatformBase.vcxproj.filters
sandbox/jng/querydef/Common/PlatformBase/PlatformBaseBuild.cpp
sandbox/jng/querydef/Common/PlatformBase/Services/PlatformBaseClassId.h
sandbox/jng/querydef/Common/Schema/QueryDefinition-2.6.0.xsd
sandbox/jng/querydef/Server/Server_VS2010.sln
sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.cpp
sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.vcxproj
sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.vcxproj.filters
sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureServiceBuild.cpp
sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureUtil.cpp
sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureUtil.h
sandbox/jng/querydef/Server/src/UnitTesting/TestFeatureService.cpp
sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_AggregateCount.QueryDefinition
sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_AggregateSpatialExtents.QueryDefinition
sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicAllElements.QueryDefinition
sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicWithExplicitPropertyList.QueryDefinition
sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicWithFilter.QueryDefinition
sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_SQLBasic.QueryDefinition
sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_SQLWhereJoin.QueryDefinition
This submission includes the following changes:
- Fix defects in QueryDefinition parsing
- Fix unititialized members in MdfModel::GeometryInfo
- Add a new MgInvalidQueryDefinitionException class to cover all errors relating to bad query definitions
- Update ComputedProperty in QueryDefinition-2.6.0.xsd to better make re-use of existing parsing code
- Implement the ExecuteQueryDefinition API on the server
- Add a new MgServerExecuteQueryDefinition class to handle all QueryDefinition related concerns
- Add a new MgServerQueryDefinitionReader class that provides a MgFeatureService adapter to the internal query reader result, which could be a MgFeatureReader, a MgDataReader, or a MgSqlDataReader
- Add a new ExecuteQueryDefinition method to MgServerFeatureUtil. This method does the grunt of this work.
- Fix bad asserts our new unit tests and correct some of the query definition test data
With this submission, our entire Query Definition test suite passes.
Modified: sandbox/jng/querydef/Common/MdfModel/GeometryInfo.cpp
--- sandbox/jng/querydef/Common/MdfModel/GeometryInfo.cpp 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/MdfModel/GeometryInfo.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -21,7 +21,9 @@
using namespace MDFMODEL_NAMESPACE;
GeometryInfo::GeometryInfo(const MdfString& strGeometry, const int& iGeomTypes)
- : m_geometry(strGeometry), m_geometryTypes(iGeomTypes)
+ : m_geometry(strGeometry), m_geometryTypes(iGeomTypes), m_lowerLeftCoordinate(NULL), m_upperRightCoordinate(NULL),
+ m_scDescription(L""), m_scName(L""), m_csName(L""), m_csWkt(L""), m_extentType(SpatialContextExtentType::Dynamic),
+ m_xyTolerance(0.0), m_zTolerance(0.0)
GeometryInfo::~GeometryInfo()
Modified: sandbox/jng/querydef/Common/MdfParser/IOAggregateQueryDefinition.cpp
--- sandbox/jng/querydef/Common/MdfParser/IOAggregateQueryDefinition.cpp 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/MdfParser/IOAggregateQueryDefinition.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -16,7 +16,7 @@
#include "stdafx.h"
#include "IOAggregateQueryDefinition.h"
-#include "IONameStringPair.h"
+#include "IOComputedPropertyCollection.h"
#include "IOGeometryInfo.h"
#include "IOQueryParameter.h"
#include "Common/IOStringObjectCollection.h"
@@ -65,8 +65,7 @@
case eGeometryInfo:
- GeometryInfo* geom = this->m_query->GetGeometryInfo();
- IOGeometryInfo* IO = new IOGeometryInfo(geom, this->m_version);
+ IOGeometryInfo* IO = new IOGeometryInfo(this->m_query, this->m_version);
handlerStack->push(IO);
IO->StartElement(name, handlerStack);
@@ -101,7 +100,7 @@
case eComputedProperties:
- IONameStringPair* IO = new IONameStringPair(this->m_query, this->m_version);
+ IOComputedPropertyCollection* IO = new IOComputedPropertyCollection(this->m_query, this->m_version);
Added: sandbox/jng/querydef/Common/MdfParser/IOComputedPropertyCollection.cpp
--- sandbox/jng/querydef/Common/MdfParser/IOComputedPropertyCollection.cpp (rev 0)
+++ sandbox/jng/querydef/Common/MdfParser/IOComputedPropertyCollection.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -0,0 +1,82 @@
+// Copyright (C) 2004-2013 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#include "stdafx.h"
+#include "IONameStringPair.h"
+using namespace XERCES_CPP_NAMESPACE;
+using namespace MDFMODEL_NAMESPACE;
+using namespace MDFPARSER_NAMESPACE;
+CREATE_ELEMENT_MAP;
+ELEM_MAP_ENTRY(1, ComputedProperties);
+ELEM_MAP_ENTRY(2, ComputedProperty);
+IOComputedPropertyCollection::IOComputedPropertyCollection(Version& version) : SAX2ElementHandler(version)
+ m_query = NULL;
+IOComputedPropertyCollection::IOComputedPropertyCollection(BaseSelectQueryDefinition* query, Version& version) : SAX2ElementHandler(version)
+ m_query = query;
+IOComputedPropertyCollection::~IOComputedPropertyCollection()
+void IOComputedPropertyCollection::StartElement(const wchar_t* name, HandlerStack* handlerStack)
+ this->m_currElemName = name;
+ this->m_currElemId = _ElementIdFromName(name);
+ switch (this->m_currElemId)
+ case eComputedProperties:
+ this->m_startElemName = name;
+ break;
+ case eComputedProperty:
+ IONameStringPair* IO = new IONameStringPair(this->m_query, this->m_version);
+ handlerStack->push(IO);
+ IO->StartElement(name, handlerStack);
+ break;
+void IOComputedPropertyCollection::ElementChars(const wchar_t* ch)
+void IOComputedPropertyCollection::EndElement(const wchar_t* name, HandlerStack* handlerStack)
+ if (this->m_startElemName == name)
+ this->m_query->SetUnknownXml(this->m_unknownXml);
+ this->m_query = NULL;
+ this->m_startElemName = L"";
+ handlerStack->pop();
+ delete this;
+void IOComputedPropertyCollection::Write(MdfStream& fd, BaseSelectQueryDefinition* query, Version* version, MgTab& tab)
\ No newline at end of file
Added: sandbox/jng/querydef/Common/MdfParser/IOComputedPropertyCollection.h
--- sandbox/jng/querydef/Common/MdfParser/IOComputedPropertyCollection.h (rev 0)
+++ sandbox/jng/querydef/Common/MdfParser/IOComputedPropertyCollection.h 2013-04-30 20:43:25 UTC (rev 7466)
@@ -0,0 +1,48 @@
+#ifndef _IOCOMPUTEDPROPERTYCOLLECTION_H
+#define _IOCOMPUTEDPROPERTYCOLLECTION_H
+#include "SAX2ElementHandler.h"
+#include "BaseSelectQueryDefinition.h"
+#include "Version.h"
+BEGIN_NAMESPACE_MDFPARSER
+class IOComputedPropertyCollection : public SAX2ElementHandler
+ public:
+ IOComputedPropertyCollection(Version& version);
+ IOComputedPropertyCollection(BaseSelectQueryDefinition* query, Version& version);
+ virtual ~IOComputedPropertyCollection();
+ virtual void StartElement(const wchar_t* name, HandlerStack* handlerStack);
+ virtual void ElementChars(const wchar_t* ch);
+ virtual void EndElement(const wchar_t* name, HandlerStack* handlerStack);
+ static void Write(MdfStream& fd, BaseSelectQueryDefinition* query, Version* version, MgTab& tab);
+ private:
+ BaseSelectQueryDefinition* m_query;
+END_NAMESPACE_MDFPARSER
+#endif //_IOCOMPUTEDPROPERTYCOLLECTION_H
Modified: sandbox/jng/querydef/Common/MdfParser/IOFeatureQueryDefinition.cpp
--- sandbox/jng/querydef/Common/MdfParser/IOFeatureQueryDefinition.cpp 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/MdfParser/IOFeatureQueryDefinition.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -16,7 +16,7 @@
#include "stdafx.h"
#include "IOFeatureQueryDefinition.h"
@@ -65,8 +65,7 @@
case eGeometryInfo:
@@ -101,7 +100,7 @@
Modified: sandbox/jng/querydef/Common/MdfParser/IOGeometryInfo.cpp
--- sandbox/jng/querydef/Common/MdfParser/IOGeometryInfo.cpp 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/MdfParser/IOGeometryInfo.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -30,12 +30,14 @@
IOGeometryInfo::IOGeometryInfo(Version& version) : SAX2ElementHandler(version)
this->m_geom = NULL;
-IOGeometryInfo::IOGeometryInfo(GeometryInfo* geom, Version& version) : SAX2ElementHandler(version)
+IOGeometryInfo::IOGeometryInfo(QueryDefinition* query, Version& version) : SAX2ElementHandler(version)
- this->m_geom = geom;
+ this->m_query = query;
+ this->m_geom = NULL;
IOGeometryInfo::~IOGeometryInfo()
@@ -50,6 +52,10 @@
case eGeometryInfo:
+ if (this->m_geom == NULL)
+ this->m_geom = new GeometryInfo(L"", 7); //7 - all types
break;
case eSpatialContext:
@@ -82,7 +88,17 @@
void IOGeometryInfo::EndElement(const wchar_t* name, HandlerStack* handlerStack)
+ this->m_geom->SetUnknownXml(this->m_unknownXml);
+ this->m_query->AdoptGeometryInfo(this->m_geom);
+ delete this;
void IOGeometryInfo::Write(MdfStream& fd, GeometryInfo* geom, Version* version, MgTab& tab)
Modified: sandbox/jng/querydef/Common/MdfParser/IOGeometryInfo.h
--- sandbox/jng/querydef/Common/MdfParser/IOGeometryInfo.h 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/MdfParser/IOGeometryInfo.h 2013-04-30 20:43:25 UTC (rev 7466)
@@ -18,7 +18,7 @@
#define _IOGEOMETRYINFO_H
-#include "GeometryInfo.h"
+#include "QueryDefinition.h"
@@ -30,7 +30,7 @@
public:
IOGeometryInfo(Version& version);
- IOGeometryInfo(GeometryInfo* geom, Version& version);
+ IOGeometryInfo(QueryDefinition* query, Version& version);
virtual ~IOGeometryInfo();
@@ -40,6 +40,7 @@
static void Write(MdfStream& fd, GeometryInfo* geom, Version* version, MgTab& tab);
private:
+ QueryDefinition* m_query;
GeometryInfo* m_geom;
Modified: sandbox/jng/querydef/Common/MdfParser/IOSQLQueryDefinition.cpp
--- sandbox/jng/querydef/Common/MdfParser/IOSQLQueryDefinition.cpp 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/MdfParser/IOSQLQueryDefinition.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -59,8 +59,7 @@
case eGeometryInfo:
Modified: sandbox/jng/querydef/Common/MdfParser/MdfParser.vcxproj
--- sandbox/jng/querydef/Common/MdfParser/MdfParser.vcxproj 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/MdfParser/MdfParser.vcxproj 2013-04-30 20:43:25 UTC (rev 7466)
@@ -196,6 +196,7 @@
<ClCompile Include="Common\IOStringObjectCollection.cpp" />
<ClCompile Include="Common\IOVector3D.cpp" />
<ClCompile Include="IOAggregateQueryDefinition.cpp" />
+ <ClCompile Include="IOComputedPropertyCollection.cpp" />
<ClCompile Include="IOFeatureQueryDefinition.cpp" />
<ClCompile Include="IOGeometryInfo.cpp" />
<ClCompile Include="IOQueryParameter.cpp" />
@@ -317,6 +318,7 @@
<ClInclude Include="Common\IOStringObjectCollection.h" />
<ClInclude Include="Common\IOVector3D.h" />
<ClInclude Include="IOAggregateQueryDefinition.h" />
+ <ClInclude Include="IOComputedPropertyCollection.h" />
<ClInclude Include="IOFeatureQueryDefinition.h" />
<ClInclude Include="IOGeometryInfo.h" />
<ClInclude Include="IOQueryParameter.h" />
Modified: sandbox/jng/querydef/Common/MdfParser/MdfParser.vcxproj.filters
--- sandbox/jng/querydef/Common/MdfParser/MdfParser.vcxproj.filters 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/MdfParser/MdfParser.vcxproj.filters 2013-04-30 20:43:25 UTC (rev 7466)
@@ -202,6 +202,9 @@
<ClCompile Include="IOQueryParameterCollection.cpp">
<Filter>QueryDefinition</Filter>
</ClCompile>
+ <ClCompile Include="IOComputedPropertyCollection.cpp">
+ <Filter>QueryDefinition</Filter>
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="Common\IOColor.h">
@@ -391,6 +394,9 @@
<ClInclude Include="IOQueryParameterCollection.h">
</ClInclude>
+ <ClInclude Include="IOComputedPropertyCollection.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="MdfParser.rc" />
Modified: sandbox/jng/querydef/Common/MdfParser/SAX2Parser.cpp
--- sandbox/jng/querydef/Common/MdfParser/SAX2Parser.cpp 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/MdfParser/SAX2Parser.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -75,6 +75,9 @@
delete m_vLayer;
delete m_dLayer;
delete m_gLayer;
+ delete m_aggregateQuery;
+ delete m_featureQuery;
+ delete m_sqlQuery;
delete m_sSymbol;
delete m_cSymbol;
delete m_printLayout;
@@ -91,6 +94,9 @@
m_vLayer = NULL;
m_dLayer = NULL;
m_gLayer = NULL;
+ m_featureQuery = NULL;
+ m_aggregateQuery = NULL;
+ m_sqlQuery = NULL;
m_sSymbol = NULL;
m_cSymbol = NULL;
m_printLayout = NULL;
Added: sandbox/jng/querydef/Common/PlatformBase/Exception/InvalidQueryDefinitionException.cpp
--- sandbox/jng/querydef/Common/PlatformBase/Exception/InvalidQueryDefinitionException.cpp (rev 0)
+++ sandbox/jng/querydef/Common/PlatformBase/Exception/InvalidQueryDefinitionException.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -0,0 +1,40 @@
+#include "PlatformBase.h"
+IMPLEMENT_EXCEPTION_DEFAULTS(MgInvalidQueryDefinitionException, MgApplicationException)
+/// \brief
+/// Construct a MgInvalidQueryDefinitionException object.
+MgInvalidQueryDefinitionException::MgInvalidQueryDefinitionException(CREFSTRING methodName,
+ INT32 lineNumber, CREFSTRING fileName, MgStringCollection* whatArguments,
+ CREFSTRING whyMessageId, MgStringCollection* whyArguments) throw() :
+ MgApplicationException(methodName, lineNumber, fileName,
+ whatArguments, whyMessageId, whyArguments)
+/// \brief
+/// Destruct the object.
+MgInvalidQueryDefinitionException::~MgInvalidQueryDefinitionException() throw()
Added: sandbox/jng/querydef/Common/PlatformBase/Exception/InvalidQueryDefinitionException.h
--- sandbox/jng/querydef/Common/PlatformBase/Exception/InvalidQueryDefinitionException.h (rev 0)
+++ sandbox/jng/querydef/Common/PlatformBase/Exception/InvalidQueryDefinitionException.h 2013-04-30 20:43:25 UTC (rev 7466)
@@ -0,0 +1,71 @@
+#ifndef MG_INVALID_QUERY_DEFINITION_EXCEPTION_H_
+#define MG_INVALID_QUERY_DEFINITION_EXCEPTION_H_
+/// \ingroup Exceptions_Module
+/// \brief
+/// Thrown when a map definition resource is invalid.
+class MG_PLATFORMBASE_API MgInvalidQueryDefinitionException : public MgApplicationException
+ DECLARE_CLASSNAME(MgInvalidQueryDefinitionException)
+EXTERNAL_API:
+ /// \brief
+ /// Construct a MgInvalidQueryDefinitionException object.
+ /// \param methodName
+ /// Name of the method where the exception occurred.
+ /// \param lineNumber
+ /// Line number where the exception occurred.
+ /// \param fileName
+ /// File name where the exception occurred.
+ /// \param whatArguments
+ /// Collection of arguments used to format the message that describes what the exception is.
+ /// \param whyMessageId
+ /// ID of the message that describes why the exception occurs.
+ /// \param whyArguments
+ /// Collection of arguments used to format the message that describes why the exception occurs.
+ MgInvalidQueryDefinitionException(CREFSTRING methodName, INT32 lineNumber,
+ CREFSTRING fileName, MgStringCollection* whatArguments,
+ CREFSTRING whyMessageId, MgStringCollection* whyArguments) throw();
+ /// \brief
+ /// Destructor for a MgInvalidQueryDefinitionException object.
+ virtual ~MgInvalidQueryDefinitionException() throw();
+INTERNAL_API:
+ DECLARE_EXCEPTION_DEFAULTS(MgInvalidQueryDefinitionException)
+CLASS_ID:
+ static const INT32 m_cls_id = PlatformBase_Exception_MgInvalidQueryDefinitionException;
+#endif
Modified: sandbox/jng/querydef/Common/PlatformBase/PlatformBase.h
--- sandbox/jng/querydef/Common/PlatformBase/PlatformBase.h 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/PlatformBase/PlatformBase.h 2013-04-30 20:43:25 UTC (rev 7466)
@@ -62,6 +62,7 @@
#include "Exception/FeatureServiceException.h"
#include "Exception/InvalidLayerDefinitionException.h"
#include "Exception/InvalidMapDefinitionException.h"
+#include "Exception/InvalidQueryDefinitionException.h"
#include "Exception/InvalidWatermarkDefinitionException.h"
#include "Exception/InvalidRepositoryNameException.h"
#include "Exception/InvalidRepositoryTypeException.h"
Modified: sandbox/jng/querydef/Common/PlatformBase/PlatformBase.vcxproj
--- sandbox/jng/querydef/Common/PlatformBase/PlatformBase.vcxproj 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/PlatformBase/PlatformBase.vcxproj 2013-04-30 20:43:25 UTC (rev 7466)
@@ -340,6 +340,12 @@
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
<ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
</ClCompile>
+ <ClCompile Include="Exception\InvalidQueryDefinitionException.cpp">
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">true</ExcludedFromBuild>
+ <ExcludedFromBuild Condition="'$(Configuration)|$(Platform)'=='Release|x64'">true</ExcludedFromBuild>
+ </ClCompile>
<ClCompile Include="Exception\InvalidRepositoryNameException.cpp">
@@ -874,6 +880,7 @@
<ClInclude Include="Exception\FeatureServiceException.h" />
<ClInclude Include="Exception\InvalidLayerDefinitionException.h" />
<ClInclude Include="Exception\InvalidMapDefinitionException.h" />
+ <ClInclude Include="Exception\InvalidQueryDefinitionException.h" />
<ClInclude Include="Exception\InvalidRepositoryNameException.h" />
<ClInclude Include="Exception\InvalidRepositoryTypeException.h" />
<ClInclude Include="Exception\InvalidResourceDataNameException.h" />
Modified: sandbox/jng/querydef/Common/PlatformBase/PlatformBase.vcxproj.filters
--- sandbox/jng/querydef/Common/PlatformBase/PlatformBase.vcxproj.filters 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/PlatformBase/PlatformBase.vcxproj.filters 2013-04-30 20:43:25 UTC (rev 7466)
@@ -352,6 +352,9 @@
<Filter>MapLayer</Filter>
</ClCompile>
<ClCompile Include="PlatformBaseBuild.cpp" />
+ <Filter>Exception</Filter>
+ </ClCompile>
</ItemGroup>
<ItemGroup>
<ClInclude Include="Data\BlobProperty.h">
@@ -736,6 +739,9 @@
</ClInclude>
<ClInclude Include="PlatformBase.h" />
+ <ClInclude Include="Exception\InvalidQueryDefinitionException.h">
+ </ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="PlatformBase.rc" />
Modified: sandbox/jng/querydef/Common/PlatformBase/PlatformBaseBuild.cpp
--- sandbox/jng/querydef/Common/PlatformBase/PlatformBaseBuild.cpp 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/PlatformBase/PlatformBaseBuild.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -42,6 +42,7 @@
#include "Exception/FeatureServiceException.cpp"
#include "Exception/InvalidMapDefinitionException.cpp"
#include "Exception/InvalidLayerDefinitionException.cpp"
+#include "Exception/InvalidQueryDefinitionException.cpp"
#include "Exception/InvalidWatermarkDefinitionException.cpp"
#include "Exception/InvalidRepositoryNameException.cpp"
#include "Exception/InvalidRepositoryTypeException.cpp"
Modified: sandbox/jng/querydef/Common/PlatformBase/Services/PlatformBaseClassId.h
--- sandbox/jng/querydef/Common/PlatformBase/Services/PlatformBaseClassId.h 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/PlatformBase/Services/PlatformBaseClassId.h 2013-04-30 20:43:25 UTC (rev 7466)
@@ -79,7 +79,8 @@
#define PlatformBase_Exception_MgServiceNotAvailableException PLATFORMBASE_EXCEPTION_ID+21
#define PlatformBase_Exception_MgServiceNotSupportedException PLATFORMBASE_EXCEPTION_ID+22
#define PlatformBase_Exception_MgUserNotFoundException PLATFORMBASE_EXCEPTION_ID+23
-#define PlatformBase_Exception_MgInvalidWatermarkDefinitionException PLATFORMBASE_EXCEPTION_ID+24
+#define PlatformBase_Exception_MgInvalidWatermarkDefinitionException PLATFORMBASE_EXCEPTION_ID+24
+#define PlatformBase_Exception_MgInvalidQueryDefinitionException PLATFORMBASE_EXCEPTION_ID+25
// MapLayer API
#define PlatformBase_MapLayer_MapBase PLATFORMBASE_MAPLAYER_ID+0
Modified: sandbox/jng/querydef/Common/Schema/QueryDefinition-2.6.0.xsd
--- sandbox/jng/querydef/Common/Schema/QueryDefinition-2.6.0.xsd 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Common/Schema/QueryDefinition-2.6.0.xsd 2013-04-30 20:43:25 UTC (rev 7466)
@@ -188,7 +188,7 @@
<xs:documentation>Specifies the alias for this computed property</xs:documentation>
</xs:annotation>
</xs:element>
- <xs:element name="Expression" type="xs:string">
+ <xs:element name="Value" type="xs:string">
<xs:annotation>
<xs:documentation>Specifies the FDO expression for this computed property</xs:documentation>
</xs:annotation>
Modified: sandbox/jng/querydef/Server/Server_VS2010.sln
--- sandbox/jng/querydef/Server/Server_VS2010.sln 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Server/Server_VS2010.sln 2013-04-30 20:43:25 UTC (rev 7466)
@@ -1,5 +1,5 @@
-Microsoft Visual Studio Solution File, Format Version 11.00
-# Visual Studio 2010
+Microsoft Visual Studio Solution File, Format Version 12.00
+# Visual Studio Express 2012 for Windows Desktop
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "ServerCore", "src\Core\ServerCore.vcxproj", "{FDF553DE-0D30-4456-8A84-5009C9EAAED2}"
EndProject
Project("{8BC9CEB8-8B4A-11D0-8D11-00A0C91BC942}") = "Foundation", "..\Common\Foundation\Foundation.vcxproj", "{A82ADC7D-4DA4-42F2-9BF6-DF5DCFB44425}"
@@ -277,7 +277,9 @@
{42491401-B624-440D-91D7-1F2633EFB4E3}.Release|x64.ActiveCfg = Release|x64
{42491401-B624-440D-91D7-1F2633EFB4E3}.Release|x64.Build.0 = Release|x64
{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Debug|Win32.ActiveCfg = Debug|Win32
+ {DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Debug|Win32.Build.0 = Debug|Win32
{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Debug|x64.ActiveCfg = Debug|x64
+ {DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Debug|x64.Build.0 = Debug|x64
{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Release|Win32.ActiveCfg = Release|Win32
{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Release|Win32.Build.0 = Release|Win32
{DD0284A0-1ECE-4387-AED3-E9BF5EE74FF8}.Release|x64.ActiveCfg = Release|x64
Added: sandbox/jng/querydef/Server/src/Services/Feature/ServerExecuteQueryDefinition.cpp
--- sandbox/jng/querydef/Server/src/Services/Feature/ServerExecuteQueryDefinition.cpp (rev 0)
+++ sandbox/jng/querydef/Server/src/Services/Feature/ServerExecuteQueryDefinition.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -0,0 +1,211 @@
+#include "FeatureQueryDefinition.h"
+#include "AggregateQueryDefinition.h"
+#include "SQLQueryDefinition.h"
+#include "SAX2Parser.h"
+#include "ServerFeatureServiceDefs.h"
+#include "ServerExecuteQueryDefinition.h"
+MgServerExecuteQueryDefinition::MgServerExecuteQueryDefinition(MgFeatureService* featureService)
+ m_featureService = SAFE_ADDREF(featureService);
+MgServerExecuteQueryDefinition::~MgServerExecuteQueryDefinition()
+ m_featureService = NULL;
+MdfModel::QueryDefinition* MgServerExecuteQueryDefinition::GetQueryDefinition(MgResourceIdentifier* queryId)
+ Ptr<MgResourceService> resourceService = GetResourceService();
+ CHECKNULL(resourceService, L"MgServerExecuteQueryDefinition.GetQueryDefinition");
+ Ptr<MgByteReader> content = resourceService->GetResourceContent(queryId);
+ Ptr<MgByteSink> sink = new MgByteSink(content);
+ Ptr<MgByte> bytes = sink->ToBuffer();
+ assert(bytes->GetLength() > 0);
+ MdfParser::SAX2Parser parser;
+ parser.ParseString((const char*)bytes->Bytes(), bytes->GetLength());
+ if (!parser.GetSucceeded())
+ STRING errorMsg = parser.GetErrorMessage();
+ MgStringCollection arguments;
+ arguments.Add(errorMsg);
+ throw new MgInvalidQueryDefinitionException(L"MgServerExecuteQueryDefinition.GetQueryDefinition", __LINE__, __WFILE__, &arguments, L"", NULL);
+ MdfModel::QueryDefinition* qdef = parser.DetachQueryDefinition();
+ assert(qdef != NULL);
+ return qdef;
+MgFeatureReader* MgServerExecuteQueryDefinition::ExecuteQueryDefinition(MgResourceIdentifier* queryId)
+ MdfModel::QueryDefinition* qdef = GetQueryDefinition(queryId);
+ //Farm it off to MgServerFeatureUtil
+ return MgServerFeatureUtil::ExecuteQueryDefinition(m_featureService, qdef, NULL);
+MgFeatureReader* MgServerExecuteQueryDefinition::ExecuteQueryDefinition(MgResourceIdentifier* queryId, MgPropertyCollection* queryParameters)
+ return MgServerFeatureUtil::ExecuteQueryDefinition(m_featureService, qdef, queryParameters);
+MgSpatialContextReader* MgServerExecuteQueryDefinition::GetSpatialContexts(MgResourceIdentifier* queryId)
+ return GetSpatialContexts(queryId, true);
+MgSpatialContextReader* MgServerExecuteQueryDefinition::GetSpatialContexts(MgResourceIdentifier* queryId, bool bActiveOnly)
+ MdfModel::GeometryInfo* geomInfo = qdef->GetGeometryInfo();
+ Ptr<MgSpatialContextReader> scReader = new MgSpatialContextReader();
+ if (geomInfo != NULL)
+ Ptr<MgSpatialContextData> scData = new MgSpatialContextData();
+ scData->SetActiveStatus(true);
+ scData->SetName(geomInfo->GetSpatialContextName());
+ scData->SetCoordinateSystem(geomInfo->GetCoordinateSystemName());
+ scData->SetCoordinateSystemWkt(geomInfo->GetCoordinateSystemWkt());
+ scData->SetDescription(geomInfo->GetSpatialContextDescription());
+ //Extent
+ MdfModel::SpatialContextCoordinate* ll = geomInfo->GetSpatialContextLowerLeftCoordinate();
+ MdfModel::SpatialContextCoordinate* ur = geomInfo->GetSpatialContextUpperRightCoordinate();
+ if (ll && ur)
+ MgAgfReaderWriter agfRw;
+ Ptr<MgCoordinateXY> c1 = new MgCoordinateXY(ll->GetX(), ll->GetY());
+ Ptr<MgCoordinateXY> c2 = new MgCoordinateXY(ur->GetX(), ll->GetY());
+ Ptr<MgCoordinateXY> c3 = new MgCoordinateXY(ur->GetX(), ur->GetY());
+ Ptr<MgCoordinateXY> c4 = new MgCoordinateXY(ll->GetX(), ur->GetY());
+ Ptr<MgCoordinateXY> c5 = new MgCoordinateXY(ll->GetX(), ll->GetY());
+ Ptr<MgCoordinateCollection> cc = new MgCoordinateCollection();
+ cc->Add(c1);
+ cc->Add(c2);
+ cc->Add(c3);
+ cc->Add(c4);
+ cc->Add(c5);
+ Ptr<MgLinearRing> outer = new MgLinearRing(cc);
+ Ptr<MgPolygon> poly = new MgPolygon(outer, NULL);
+ Ptr<MgByteReader> agf = agfRw.Write(poly);
+ Ptr<MgByteSink> agfSink = new MgByteSink(agf);
+ Ptr<MgByte> agfBytes = agfSink->ToBuffer();
+ scData->SetExtent(agfBytes);
+ scData->SetExtentType((geomInfo->GetSpatialContextExtentType() == GeometryInfo::Dynamic) ? MgSpatialContextExtentType::scDynamic : MgSpatialContextExtentType::scStatic);
+ scData->SetXYTolerance(geomInfo->GetSpatialContextXYTolerance());
+ scData->SetZTolerance(geomInfo->GetSpatialContextZTolerance());
+ scReader->AddSpatialData(scData);
+ return scReader.Detach();
+MgFeatureSchemaCollection* MgServerExecuteQueryDefinition::DescribeSchema(MgResourceIdentifier* queryId, CREFSTRING schemaName, MgStringCollection* classNames, bool /* serialize */)
+ //This is simple, there will only ever be one schema (Default) and one class (Query), so reject
+ //any invalid schema/class names
+ if (!schemaName.empty() && L"Default" != schemaName) //NOXLATE
+ //throw
+ if (NULL != classNames)
+ if (classNames->GetCount() > 1)
+ //throw
+ else if (classNames->GetCount() == 1)
+ if (classNames->GetItem(0) != L"Query") //NOXLATE
+ //throw
+ Ptr<MgFeatureSchemaCollection> schemas = new MgFeatureSchemaCollection();
+ Ptr<MgFeatureReader> fr = MgServerFeatureUtil::ExecuteQueryDefinition(m_featureService, qdef, NULL);
+ Ptr<MgFeatureSchema> schema = new MgFeatureSchema(L"Default", L"System-generated schema");
+ Ptr<MgClassDefinitionCollection> classes = schema->GetClasses();
+ Ptr<MgClassDefinition> clsDef = fr->GetClassDefinition();
+ classes->Add(clsDef);
+ schemas->Add(schema);
+ //We're done with the reader, we only wanted the class definition.
+ fr->Close();
+ return schemas.Detach();
+STRING MgServerExecuteQueryDefinition::DescribeSchemaAsXml(MgResourceIdentifier* queryId, CREFSTRING schemaName, MgStringCollection* classNames)
+ Ptr<MgFeatureSchemaCollection> schemas = DescribeSchema(queryId, schemaName, classNames);
+ return m_featureService->SchemaToXml(schemas);
+MgStringCollection* MgServerExecuteQueryDefinition::GetSchemas(MgResourceIdentifier* queryId)
+ Ptr<MgStringCollection> names = new MgStringCollection();
+ names->Add(L"Default"); //NOXLATE
+ return names.Detach();
+MgStringCollection* MgServerExecuteQueryDefinition::GetClasses(MgResourceIdentifier* queryId, CREFSTRING schemaName)
+ names->Add(L"Query"); //NOXLATE
+MgClassDefinition* MgServerExecuteQueryDefinition::GetClassDefinition(MgResourceIdentifier* queryId, CREFSTRING schemaName, CREFSTRING className, bool serialize)
+ throw new MgNotImplementedException(L"MgServerExecuteQueryDefinition.GetClassDefinition", __LINE__, __WFILE__, NULL, L"", NULL);
+MgResourceService* MgServerExecuteQueryDefinition::GetResourceService()
+ MgServiceManager* serviceMan = MgServiceManager::GetInstance();
+ if (NULL != serviceMan)
+ MgResourceService* resourceService = dynamic_cast<MgResourceService*>(
+ serviceMan->RequestService(MgServiceType::ResourceService));
+ return resourceService;
+ return NULL;
Added: sandbox/jng/querydef/Server/src/Services/Feature/ServerExecuteQueryDefinition.h
--- sandbox/jng/querydef/Server/src/Services/Feature/ServerExecuteQueryDefinition.h (rev 0)
+++ sandbox/jng/querydef/Server/src/Services/Feature/ServerExecuteQueryDefinition.h 2013-04-30 20:43:25 UTC (rev 7466)
@@ -0,0 +1,44 @@
+#ifndef _MG_SERVER_EXECUTE_QUERY_DEFINITION_H_
+#define _MG_SERVER_EXECUTE_QUERY_DEFINITION_H_
+class MgServerExecuteQueryDefinition
+public:
+ MgServerExecuteQueryDefinition(MgFeatureService* featSvc);
+ ~MgServerExecuteQueryDefinition();
+ MgFeatureReader* ExecuteQueryDefinition(MgResourceIdentifier* queryId);
+ MgFeatureReader* ExecuteQueryDefinition(MgResourceIdentifier* queryId, MgPropertyCollection* queryParameters);
+ MgSpatialContextReader* GetSpatialContexts(MgResourceIdentifier* queryId);
+ MgSpatialContextReader* GetSpatialContexts(MgResourceIdentifier* queryId, bool bActiveOnly);
+ MgFeatureSchemaCollection* DescribeSchema(MgResourceIdentifier* queryId, CREFSTRING schemaName, MgStringCollection* classNames, bool serialize = true);
+ STRING DescribeSchemaAsXml(MgResourceIdentifier* queryId, CREFSTRING schemaName, MgStringCollection* classNames);
+ MgStringCollection* GetSchemas(MgResourceIdentifier* queryId);
+ MgStringCollection* GetClasses(MgResourceIdentifier* queryId, CREFSTRING schemaName);
+ MgClassDefinition* GetClassDefinition(MgResourceIdentifier* queryId, CREFSTRING schemaName, CREFSTRING className, bool serialize = true);
+private:
+ MdfModel::QueryDefinition* GetQueryDefinition(MgResourceIdentifier* queryId);
+ MgResourceService* GetResourceService();
+ Ptr<MgFeatureService> m_featureService;
+#endif
Modified: sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.cpp
--- sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.cpp 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -39,6 +39,7 @@
#include "ServerFdoFeatureReader.h"
#include "ServerEnumerateDataStores.h"
#include "ServerGetSchemaMapping.h"
#include "FilterUtil.h"
#include "LongTransactionManager.h"
#include "TransformCache.h"
@@ -337,8 +338,16 @@
logDetail.AddObject(L"ClassNames", classNames);
logDetail.Create();
- MgServerDescribeSchema msds;
- schemas = msds.DescribeSchema(resource, schemaName, classNames);
+ if (resource->GetResourceType() == MgResourceType::QueryDefinition)
+ MgServerExecuteQueryDefinition exec(this);
+ schemas = exec.DescribeSchema(resource, schemaName, classNames);
+ else
+ MgServerDescribeSchema msds;
+ schemas = msds.DescribeSchema(resource, schemaName, classNames);
MG_FEATURE_SERVICE_CATCH_AND_THROW_WITH_FEATURE_SOURCE(L"MgServerFeatureService.DescribeSchema", resource);
@@ -382,8 +391,16 @@
logDetail.Create();
- schemaXml = msds.DescribeSchemaAsXml(resource, schemaName, classNames);
+ schemaXml = exec.DescribeSchemaAsXml(resource, schemaName, classNames);
+ else
+ schemaXml = msds.DescribeSchemaAsXml(resource, schemaName, classNames);
MG_FEATURE_SERVICE_CATCH_AND_THROW_WITH_FEATURE_SOURCE(L"MgServerFeatureService.DescribeSchemaAsXml", resource);
@@ -542,11 +559,8 @@
MgFeatureReader* MgServerFeatureService::ExecuteQueryDefinition(MgResourceIdentifier* resource)
- throw new MgNotImplementedException(
- L"MgServerFeatureService::ExecuteQueryDefinition",
- __LINE__, __WFILE__, NULL, L"", NULL);
- return NULL; // to make some compiler happy
+ return exec.ExecuteQueryDefinition(resource);
@@ -581,11 +595,8 @@
MgFeatureReader* MgServerFeatureService::ExecuteQueryDefinition(MgResourceIdentifier* resource, MgPropertyCollection* parameters)
+ return exec.ExecuteQueryDefinition(resource, parameters);
@@ -1043,8 +1054,16 @@
logDetail.AddBool(L"ActiveOnly", bActiveOnly);
logDetail.Create();
- MgServerGetSpatialContexts msgsc;
- reader = msgsc.GetSpatialContexts(resource);
+ reader = exec.GetSpatialContexts(resource);
+ else
+ MgServerGetSpatialContexts msgsc;
+ reader = msgsc.GetSpatialContexts(resource);
MG_FEATURE_SERVICE_CATCH_AND_THROW_WITH_FEATURE_SOURCE(L"MgServerFeatureService.GetSpatialContexts", resource)
@@ -1511,20 +1530,38 @@
MgStringCollection* MgServerFeatureService::GetSchemas( MgResourceIdentifier* resource )
+ CHECKARGUMENTNULL(resource, L"MgServerFeatureService.GetSchemas");
MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetSchemas()");
- return msds.GetSchemas(resource);
+ return exec.GetSchemas(resource);
+ else
+ return msds.GetSchemas(resource);
MgStringCollection* MgServerFeatureService::GetClasses( MgResourceIdentifier* resource, CREFSTRING schemaName )
+ CHECKARGUMENTNULL(resource, L"MgServerFeatureService.GetClasses");
MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetClasses()");
- return msds.GetClasses(resource, schemaName);
+ return exec.GetClasses(resource, schemaName);
+ else
+ return msds.GetClasses(resource, schemaName);
@@ -1533,10 +1570,19 @@
CREFSTRING className)
MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetClassDefinition()");
- return msds.GetClassDefinition(resource, schemaName, className, true);
+ return exec.GetClassDefinition(resource, schemaName, className, true);
+ else
+ return msds.GetClassDefinition(resource, schemaName, className, true);
@@ -1546,10 +1592,19 @@
bool serialize)
- return msds.GetClassDefinition(resource, schemaName, className, serialize);
+ return exec.GetClassDefinition(resource, schemaName, className, serialize);
+ else
+ return msds.GetClassDefinition(resource, schemaName, className, serialize);
Modified: sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.vcxproj
--- sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.vcxproj 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.vcxproj 2013-04-30 20:43:25 UTC (rev 7466)
@@ -639,6 +639,12 @@
</ClCompile>
+ <ClCompile Include="ServerExecuteQueryDefinition.cpp">
+ </ClCompile>
<ClCompile Include="ServerFdoFeatureReader.cpp">
@@ -744,6 +750,12 @@
</ClCompile>
+ <ClCompile Include="ServerQueryDefinitionReader.cpp">
+ </ClCompile>
<ClCompile Include="ServerSelectFeatures.cpp">
@@ -873,6 +885,7 @@
<ClInclude Include="ServerDeleteCommand.h" />
<ClInclude Include="ServerDescribeSchema.h" />
<ClInclude Include="ServerEnumerateDataStores.h" />
+ <ClInclude Include="ServerExecuteQueryDefinition.h" />
<ClInclude Include="ServerFdoFeatureReader.h" />
<ClInclude Include="ServerFeatureConnection.h" />
<ClInclude Include="ServerFeatureDllExport.h" />
@@ -897,6 +910,7 @@
</CustomBuildStep>
<ClInclude Include="ServerInsertCommand.h" />
+ <ClInclude Include="ServerQueryDefinitionReader.h" />
<ClInclude Include="ServerSelectFeatures.h" />
<ClInclude Include="ServerSqlCommand.h" />
<ClInclude Include="ServerSqlDataReader.h" />
Modified: sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.vcxproj.filters
--- sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.vcxproj.filters 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureService.vcxproj.filters 2013-04-30 20:43:25 UTC (rev 7466)
@@ -191,6 +191,8 @@
<ClCompile Include="OpExecuteQueryDefinition.cpp">
<Filter>Ops</Filter>
</ClCompile>
+ <ClCompile Include="ServerExecuteQueryDefinition.cpp" />
+ <ClCompile Include="ServerQueryDefinitionReader.cpp" />
</ItemGroup>
<ItemGroup>
<ClInclude Include="FeatureOperation.h">
@@ -391,6 +393,8 @@
<ClInclude Include="OpExecuteQueryDefinition.h">
</ClInclude>
</ItemGroup>
<ItemGroup>
<ResourceCompile Include="ServerFeatureService.rc" />
Modified: sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureServiceBuild.cpp
--- sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureServiceBuild.cpp 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureServiceBuild.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -46,11 +46,13 @@
#include "ServerGetFeatureProviders.cpp"
#include "ServerGetProviderCapabilities.cpp"
#include "ServerSelectFeatures.cpp"
+#include "ServerExecuteQueryDefinition.cpp"
#include "OpCloseFeatureReader.cpp"
#include "OpGetFeatures.cpp"
#include "ServerFeatureReader.cpp"
#include "ServerFdoFeatureReader.cpp"
#include "ServerFeatureReaderPool.cpp"
+#include "ServerQueryDefinitionReader.cpp"
#include "OpGetLongTransactions.cpp"
#include "ServerGetConnectionPropertyValues.cpp"
#include "ServerGetLongTransactions.cpp"
Modified: sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureUtil.cpp
--- sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureUtil.cpp 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureUtil.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -3624,3 +3624,250 @@
MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureUtil.ExtractIdentifiers")
return ret.Detach();
+MgFeatureReader* MgServerFeatureUtil::ExecuteQueryDefinition(MgFeatureService* featureService, MdfModel::QueryDefinition* qdef, MgPropertyCollection* queryParameters)
+ CHECKARGUMENTNULL(featureService, L"MgServerFeatureUtil.ExecuteQueryDefinition");
+ CHECKARGUMENTNULL(qdef, L"MgServerFeatureUtil.ExecuteQueryDefinition");
+ Ptr<MgFeatureReader> reader;
+ MG_FEATURE_SERVICE_TRY()
+ MdfModel::FeatureQueryDefinition* fq = dynamic_cast<MdfModel::FeatureQueryDefinition*>(qdef);
+ MdfModel::AggregateQueryDefinition* aq = dynamic_cast<MdfModel::AggregateQueryDefinition*>(qdef);
+ MdfModel::SQLQueryDefinition* sq = dynamic_cast<MdfModel::SQLQueryDefinition*>(qdef);
+ Ptr<MgReader> innerReader;
+ Ptr<MgClassDefinition> classDef;
+ const MdfModel::MdfString& resIdStr = qdef->GetResourceID();
+ if (resIdStr.empty())
+ throw new MgInvalidQueryDefinitionException(L"MgServerFeatureUtil.ExecuteQueryDefinition", __LINE__, __WFILE__, NULL, L"MgQueryDefinitionEmptyResourceId", NULL);
+ Ptr<MgResourceIdentifier> fsId = new MgResourceIdentifier(resIdStr);
+ if (fq || aq)
+ Ptr<MgFeatureQueryOptions> queryOpts;
+ MdfModel::BaseSelectQueryDefinition* bsq = NULL;
+ if (fq)
+ queryOpts = new MgFeatureQueryOptions();
+ bsq = fq;
+ else if (aq)
+ //Apply aggregate-specific options
+ Ptr<MgFeatureAggregateOptions> aggOpts = new MgFeatureAggregateOptions();
+ MdfModel::StringObjectCollection* groupBy = aq->GetGrouping();
+ const MdfString& groupByFilter = aq->GetGroupFilter();
+ if (groupBy->GetCount() > 0 && !groupByFilter.empty())
+ Ptr<MgStringCollection> props = new MgStringCollection();
+ for (INT32 i = 0; i < groupBy->GetCount(); i++)
+ MdfModel::StringObject* str = groupBy->GetAt(i);
+ props->Add(str->GetString());
+ aggOpts->SetGroupingFilter(props, groupByFilter);
+ queryOpts = aggOpts;
+ bsq = aq;
+ //Now apply what's common to both
+ //Filter (spatial filter is assumed to be already in here)
+ if (!bsq->GetFilter().empty())
+ queryOpts->SetFilter(bsq->GetFilter());
+ //Properties
+ MdfModel::StringObjectCollection* clsProps = bsq->GetProperties();
+ if (clsProps->GetCount() > 0)
+ for (INT32 i = 0; i < clsProps->GetCount(); i++)
+ queryOpts->AddFeatureProperty(clsProps->GetAt(i)->GetString());
+ //Computed
+ MdfModel::NameStringPairCollection* computed = bsq->GetComputedProperties();
+ if (computed->GetCount() > 0)
+ for (INT32 i = 0; i < computed->GetCount(); i++)
+ queryOpts->AddComputedProperty(computed->GetAt(i)->GetName(),
+ computed->GetAt(i)->GetValue());
+ //Order By
+ MdfModel::StringObjectCollection* orderByProps = bsq->GetOrdering();
+ if (orderByProps->GetCount() > 0)
+ Ptr<MgStringCollection> orderProps = new MgStringCollection();
+ for (INT32 i = 0; i < orderByProps->GetCount(); i++)
+ orderProps->Add(orderByProps->GetAt(i)->GetString());
+ queryOpts->SetOrderingFilter(orderProps, (bsq->GetOrderingOption() == BaseSelectQueryDefinition::Ascending) ? MgOrderingOption::Ascending : MgOrderingOption::Descending);
+ if (fq)
+ innerReader = featureService->SelectFeatures(fsId, bsq->GetFeatureClass(), queryOpts);
+ classDef = ((MgFeatureReader*)innerReader.p)->GetClassDefinition();
+ else if (aq)
+ innerReader = featureService->SelectAggregate(fsId, bsq->GetFeatureClass(), ((MgFeatureAggregateOptions*)queryOpts.p));
+ //We construct a class definition based on the inner reader's structure, then apply any geometry
+ //identity overrides from the query definition
+ classDef = new MgClassDefinition();
+ Ptr<MgPropertyDefinitionCollection> clsIdProps = classDef->GetIdentityProperties();
+ Ptr<MgPropertyDefinitionCollection> clsProps = classDef->GetProperties();
+ for (INT32 i = 0; i < innerReader->GetPropertyCount(); i++)
+ INT32 ptype = innerReader->GetPropertyType(i);
+ STRING pName = innerReader->GetPropertyName(i);
+ if (ptype == MgPropertyType::Geometry)
+ Ptr<MgGeometricPropertyDefinition> geomProp = new MgGeometricPropertyDefinition(pName);
+ geomProp->SetGeometryTypes(MgFeatureGeometricType::Point | MgFeatureGeometricType::Curve | MgFeatureGeometricType::Surface);
+ //Don't know spatial context association. Will be set below if there is one
+ clsProps->Add(geomProp);
+ else if (ptype != MgPropertyType::Feature &&
+ ptype != MgPropertyType::Null &&
+ ptype != MgPropertyType::Raster) //We can skip rasters because this is a *vector* feature query after all
+ Ptr<MgDataPropertyDefinition> dataProp = new MgDataPropertyDefinition(pName);
+ dataProp->SetDataType(ptype);
+ //Flub some defaults in case someone actually *tries* to use this class definition as a basis for a new
+ //Feature Source
+ dataProp->SetNullable(true);
+ if (ptype != MgPropertyType::String)
+ dataProp->SetLength(512);
+ //Don't know if identity. Will be set below if query definition specifies it
+ clsProps->Add(dataProp);
+ else if (sq)
+ innerReader = featureService->ExecuteSqlQuery(fsId, sq->GetSQL());
+ //Feature Source
+ //If the Query Definition resolves to a known sub-type, processing will give us an inner MgReader and a modified
+ //MgClassDefinition. We can only return a wrapped MgServerQueryDefinitionReader if these two things exist at this
+ //point
+ if (innerReader.p && classDef.p)
+ //Make any necessary modifications to the designated geometry an identity properties
+ MdfModel::StringObjectCollection* idProps = qdef->GetIdentityProperties();
+ if (idProps->GetCount() > 0)
+ //Clear existing identity props, we're overriding based on what's declared in the query
+ clsIdProps->Clear();
+ for (INT32 i = 0; i < idProps->GetCount(); i++)
+ INT32 pidx = clsProps->IndexOf(idProps->GetAt(i)->GetString());
+ if (pidx < 0)
+ throw new MgInvalidQueryDefinitionException(L"MgServerFeatureUtil.ExecuteQueryDefinition", __LINE__, __WFILE__, NULL, L"MgIdentityPropertyNotFound", NULL);
+ Ptr<MgPropertyDefinition> idProp = clsProps->GetItem(pidx);
+ if (idProp->GetPropertyType() != MgFeaturePropertyType::DataProperty)
+ throw new MgInvalidQueryDefinitionException(L"MgServerFeatureUtil.ExecuteQueryDefinition", __LINE__, __WFILE__, NULL, L"MgInvalidIdentityProperty", NULL);
+ //Force non-nullability just in case
+ Ptr<MgDataPropertyDefinition> dataProp = (MgDataPropertyDefinition*)(SAFE_ADDREF(idProp.p));
+ dataProp->SetNullable(false);
+ clsIdProps->Add(idProp);
+ if (NULL != geomInfo)
+ //The geometry property we want to override must exist
+ INT32 pidx = clsProps->IndexOf(geomInfo->GetGeometry());
+ if (pidx < 0)
+ throw new MgInvalidQueryDefinitionException(L"MgServerFeatureUtil.ExecuteQueryDefinition", __LINE__, __WFILE__, NULL, L"MgGeometryPropertyNotFound", NULL);
+ Ptr<MgPropertyDefinition> prop = clsProps->GetItem(pidx);
+ //Must be geometric too
+ if (prop->GetPropertyType() != MgFeaturePropertyType::GeometricProperty)
+ Ptr<MgGeometricPropertyDefinition> geomProp = (MgGeometricPropertyDefinition*)(SAFE_ADDREF(prop.p));
+ //Override the bits we want to override
+ geomProp->SetSpatialContextAssociation(geomInfo->GetSpatialContextName());
+ geomProp->SetGeometryTypes(geomInfo->GetGeometryTypes());
+ classDef->SetDefaultGeometryPropertyName(geomInfo->GetGeometry());
+ else
+ //Scrub out designated geometry
+ classDef->SetDefaultGeometryPropertyName(L"");
+ //Scrub out spatial context associations as well
+ Ptr<MgPropertyDefinition> prop = clsProps->GetItem(i);
+ if (prop->GetPropertyType() == MgFeaturePropertyType::GeometricProperty)
+ ((MgGeometricPropertyDefinition*)prop.p)->SetSpatialContextAssociation(L"");
+ classDef->SetName(L"Query"); //NOXLATE
+ reader = new MgServerQueryDefinitionReader(innerReader, classDef);
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureUtil.ExecuteQueryDefinition")
+ return reader.Detach();
Modified: sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureUtil.h
--- sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureUtil.h 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Server/src/Services/Feature/ServerFeatureUtil.h 2013-04-30 20:43:25 UTC (rev 7466)
@@ -45,6 +45,11 @@
class MgReader;
+namespace MdfModel
+ class QueryDefinition;
class MgServerFeatureUtil
public:
@@ -130,6 +135,8 @@
static void UpdateObjectPropertyDefinition(MgObjectPropertyDefinition* objPropDef, FdoObjectPropertyDefinition* fdoPropDef, FdoClassCollection* fdoClassCol);
static void UpdateGeometricPropertyDefinition(MgGeometricPropertyDefinition* mgPropDef, FdoGeometricPropertyDefinition* fdoPropDef);
static void UpdateRasterPropertyDefinition(MgRasterPropertyDefinition* mgPropDef, FdoRasterPropertyDefinition* fdoPropDef);
+ static MgFeatureReader* ExecuteQueryDefinition(MgFeatureService* featureService, MdfModel::QueryDefinition* qdef, MgPropertyCollection* queryParameters);
private:
static bool Initialize();
Added: sandbox/jng/querydef/Server/src/Services/Feature/ServerQueryDefinitionReader.cpp
--- sandbox/jng/querydef/Server/src/Services/Feature/ServerQueryDefinitionReader.cpp (rev 0)
+++ sandbox/jng/querydef/Server/src/Services/Feature/ServerQueryDefinitionReader.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -0,0 +1,891 @@
+#include "ServerQueryDefinitionReader.h"
+#include "ServerFeatureUtil.h"
+//NOTE: MgServerQueryDefinitionReader is a MgFeatureReader facade for *vector* data queries, thus any raster
+//related APIs that we cannot pass down to the underlying reader, we don't implement.
+MgServerQueryDefinitionReader::MgServerQueryDefinitionReader(MgReader* innerReader, MgClassDefinition* classDef)
+ CHECKARGUMENTNULL(innerReader, L"MgServerQueryDefinitionReader.MgServerQueryDefinitionReader");
+ CHECKARGUMENTNULL(classDef, L"MgServerQueryDefinitionReader.MgServerQueryDefinitionReader");
+ m_innerReader = SAFE_ADDREF(innerReader);
+ m_classDef = SAFE_ADDREF(classDef);
+ m_featureSet = NULL;
+MgServerQueryDefinitionReader::~MgServerQueryDefinitionReader()
+ MG_TRY()
+ Close();
+ MG_CATCH_AND_RELEASE()
+ m_innerReader = NULL;
+ m_classDef = NULL;
+/// <summary>
+/// Advances the reader to the next item and returns true if there is
+/// another object to read or false if reading is complete. The default
+/// position of the reader is prior to the first item. Thus you must
+/// call ReadNext to begin accessing any data.
+/// </summary>
+/// <returns>
+/// Returns true if there is a next item.
+/// </returns>
+bool MgServerQueryDefinitionReader::ReadNext()
+ return m_innerReader->ReadNext();
+/// <summary>
+/// Gets the definition of the object currently being read. If the user
+/// has requested only a subset of the class properties, the class
+/// definition reflects what the user has asked, rather than the full class
+/// definition.
+/// </summary>
+/// <returns>A MgClassDefinition representing the current object
+///</returns>
+MgClassDefinition* MgServerQueryDefinitionReader::GetClassDefinition()
+ return SAFE_ADDREF(m_classDef.p);
+/// <summary>
+/// Returns true if the value of the specified property is null.
+/// </summary>
+/// <param name="propertyName">Property name.</param>
+/// <returns>Returns true if the value is null.</returns>
+bool MgServerQueryDefinitionReader::IsNull(CREFSTRING propertyName)
+ return m_innerReader->IsNull(propertyName);
+/// <summary>
+/// Gets the Boolean value of the specified property. No conversion is
+/// performed, thus the property must be a of boolean type the result
+/// is undertermined</summary>
+/// <returns>Returns the Boolean value.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not boolean
+bool MgServerQueryDefinitionReader::GetBoolean(CREFSTRING propertyName)
+ return m_innerReader->GetBoolean(propertyName);
+/// <summary>
+/// Gets the Byte value of the specified property. No conversion is
+/// performed, thus the property must be a of byte type or the result
+/// <returns>Returns the Byte value.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not byte
+BYTE MgServerQueryDefinitionReader::GetByte(CREFSTRING propertyName)
+ return m_innerReader->GetByte(propertyName);
+/// <summary>
+/// Gets the DTime value of the specified property. No conversion is
+/// performed, thus the property must be a of date type or the result
+/// is NULL</summary>
+/// <returns>Returns the DTime value.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not date/time
+MgDateTime* MgServerQueryDefinitionReader::GetDateTime(CREFSTRING propertyName)
+ return m_innerReader->GetDateTime(propertyName);
+/// <summary>
+/// Gets the Single value of the specified property. No conversion is
+/// performed, thus the property must be a of type single or the result
+/// is undetermined</summary>
+/// <returns>Returns the single value.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not float
+float MgServerQueryDefinitionReader::GetSingle(CREFSTRING propertyName)
+ return m_innerReader->GetSingle(propertyName);
+/// <summary>
+/// Gets the Double value of the specified property. No conversion is
+/// performed, thus the property must be a of type double or the result
+/// <returns>Returns the double value.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not double
+double MgServerQueryDefinitionReader::GetDouble(CREFSTRING propertyName)
+ return m_innerReader->GetDouble(propertyName);
+/// <summary>
+/// Gets the integer 16 bits value of the specified property. No conversion is
+/// performed, thus the property must be a of type integer 16 bits or the result
+/// <returns>Returns the integer 16 bits value.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not int16
+INT16 MgServerQueryDefinitionReader::GetInt16(CREFSTRING propertyName)
+ return m_innerReader->GetInt16(propertyName);
+/// <summary>
+/// Gets the integer 32 bits value of the specified property. No conversion is
+/// performed, thus the property must be a of type integer 32 bits or the result
+/// <returns>Returns the integer 32 bits value.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not int32
+INT32 MgServerQueryDefinitionReader::GetInt32(CREFSTRING propertyName)
+ return m_innerReader->GetInt32(propertyName);
+/// <summary>
+/// Gets the integer 64 bits value of the specified property. No conversion is
+/// performed, thus the property must be a of type integer 64 bits or the result
+/// <returns>Returns the integer 64 bits value.
+/// Note: INT64 is actually a pointer to an Integer64 object
+///</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not int64
+INT64 MgServerQueryDefinitionReader::GetInt64(CREFSTRING propertyName)
+ return m_innerReader->GetInt64(propertyName);
+/// <summary>
+/// Gets the string value of the specified property. No conversion is
+/// performed, thus the property must be a of type string or the result
+/// <returns>Returns the string value.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not a string
+STRING MgServerQueryDefinitionReader::GetString(CREFSTRING propertyName)
+ return m_innerReader->GetString(propertyName);
+/// <summary>
+/// Gets the BLOB value of the specified property. No conversion is
+/// performed, thus the property must be a of type BLOBs or the result
+/// <returns>Returns the BLOB value.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not a BLOB
+MgByteReader* MgServerQueryDefinitionReader::GetBLOB(CREFSTRING propertyName)
+ return m_innerReader->GetBLOB(propertyName);
+/// <summary>
+/// Gets the CLOB value of the specified property. No conversion is
+/// performed, thus the property must be a of type CLOB or the result
+/// <returns>Returns the CLOB value.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not a CLOB
+MgByteReader* MgServerQueryDefinitionReader::GetCLOB(CREFSTRING propertyName)
+ return m_innerReader->GetCLOB(propertyName);
+/// <summary>
+/// Gets the FeatureReader to access this object value.
+/// The property must be of an object type; otherwise, the result is NULL.
+/// </summary>
+/// <param name="propertyName">Input the property name.</param>
+/// <returns>Returns the feature reader to access this object.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not a feature
+MgFeatureReader* MgServerQueryDefinitionReader::GetFeatureObject(CREFSTRING propertyName)
+ throw new MgNotImplementedException(L"MgServerQueryDefinitionReader.GetFeatureObject", __LINE__, __WFILE__, NULL, L"", NULL);
+/// <summary>
+/// Gets the geometry value of the specified property as a GeometryReader.
+/// Because no conversion is performed, the property must be
+/// of Geometric type; otherwise, the result is NULL.</summary>
+/// <returns>Returns the Geometry object.</returns>
+/// EXCEPTIONS:
+/// MgInvalidArgumentException if the property type is not geometry
+MgByteReader* MgServerQueryDefinitionReader::GetGeometry(CREFSTRING propertyName)
+ return m_innerReader->GetGeometry(propertyName);
+/// <summary>
+/// </summary>
+/// <returns>Returns the Raster object.</returns>
+/// EXCEPTIONS:
+MgRaster* MgServerQueryDefinitionReader::GetRaster(CREFSTRING propertyName)
+ return m_innerReader->GetRaster(propertyName);
+/// <summary>
+/// Returns true if the value of the property at the specified index is null.
+/// </summary>
+/// <param name="index">Property index.</param>
+bool MgServerQueryDefinitionReader::IsNull(INT32 index)
+ return m_innerReader->IsNull(index);
+/// <summary>
+/// Gets the Boolean value of the property at the specified index. No conversion is
+/// EXCEPTIONS:
+bool MgServerQueryDefinitionReader::GetBoolean(INT32 index)
+ return m_innerReader->GetBoolean(index);
+/// <summary>
+/// Gets the Byte value of the property at the specified index. No conversion is
+/// EXCEPTIONS:
+BYTE MgServerQueryDefinitionReader::GetByte(INT32 index)
+ return m_innerReader->GetByte(index);
+/// <summary>
+/// Gets the DTime value of the property at the specified index. No conversion is
+/// EXCEPTIONS:
+MgDateTime* MgServerQueryDefinitionReader::GetDateTime(INT32 index)
+ return m_innerReader->GetDateTime(index);
+/// <summary>
+/// Gets the Single value of the property at the specified index. No conversion is
+/// EXCEPTIONS:
+float MgServerQueryDefinitionReader::GetSingle(INT32 index)
+ return m_innerReader->GetSingle(index);
+/// <summary>
+/// Gets the Double value of the property at the specified index. No conversion is
+/// EXCEPTIONS:
+double MgServerQueryDefinitionReader::GetDouble(INT32 index)
+ return m_innerReader->GetDouble(index);
+/// <summary>
+/// Gets the integer 16 bits value of the property at the specified index. No conversion is
+/// EXCEPTIONS:
+INT16 MgServerQueryDefinitionReader::GetInt16(INT32 index)
+ return m_innerReader->GetInt16(index);
+/// <summary>
+/// Gets the integer 32 bits value of the property at the specified index. No conversion is
+/// EXCEPTIONS:
+INT32 MgServerQueryDefinitionReader::GetInt32(INT32 index)
+ return m_innerReader->GetInt32(index);
+/// <summary>
+/// Gets the integer 64 bits value of the property at the specified index. No conversion is
+///</returns>
+/// EXCEPTIONS:
+INT64 MgServerQueryDefinitionReader::GetInt64(INT32 index)
+ return m_innerReader->GetInt64(index);
+/// <summary>
+/// Gets the string value of the property at the specified index. No conversion is
+/// EXCEPTIONS:
+STRING MgServerQueryDefinitionReader::GetString(INT32 index)
+ return m_innerReader->GetString(index);
+/// <summary>
+/// Gets the BLOB value of the property at the specified index. No conversion is
+/// EXCEPTIONS:
+MgByteReader* MgServerQueryDefinitionReader::GetBLOB(INT32 index)
+ return m_innerReader->GetBLOB(index);
+/// <summary>
+/// Gets the CLOB value of the property at the specified index. No conversion is
+/// EXCEPTIONS:
+MgByteReader* MgServerQueryDefinitionReader::GetCLOB(INT32 index)
+ return m_innerReader->GetCLOB(index);
+/// <summary>
+/// </summary>
+/// EXCEPTIONS:
+MgFeatureReader* MgServerQueryDefinitionReader::GetFeatureObject(INT32 index)
+/// <summary>
+/// Gets the geometry value of the property at the specified index as a GeometryReader.
+/// EXCEPTIONS:
+MgByteReader* MgServerQueryDefinitionReader::GetGeometry(INT32 index)
+ return m_innerReader->GetGeometry(index);
+/// <summary>
+/// </summary>
+/// EXCEPTIONS:
+MgRaster* MgServerQueryDefinitionReader::GetRaster(INT32 index)
+ return m_innerReader->GetRaster(index);
+/// <summary>
+/// Serializes all features into an XML.
+/// XML is serialized from the current position of feature reader in the order
+/// data are retrieved.
+/// <returns>MgByteReader holding XML.</returns>
+MgByteReader* MgServerQueryDefinitionReader::ToXml()
+ return m_innerReader->ToXml();
+/// <summary>
+/// Releases all the resources of feature reader.
+/// This must be called when user is done with Feature Reader
+/// <returns>Nothing</returns>
+void MgServerQueryDefinitionReader::Close()
+ m_innerReader->Close();
+/// \brief
+/// Returns the starting element name as a UTF-8 string. The mime
+/// type must be a text type, for example text/xml.
+/// \param str
+/// Destination string.
+string MgServerQueryDefinitionReader::GetResponseElementName()
+ throw new MgNotImplementedException(L"MgServerQueryDefinitionReader.GetResponseElementName", __LINE__, __WFILE__, NULL, L"", NULL);
+/// \brief
+/// Returns the body starting element name as a UTF-8 string. The mime
+/// \param str
+string MgServerQueryDefinitionReader::GetBodyElementName()
+ throw new MgNotImplementedException(L"MgServerQueryDefinitionReader.GetBodyElementName", __LINE__, __WFILE__, NULL, L"", NULL);
+/// \brief
+/// Returns the start of the response as a UTF-8 string. The mime
+/// \param str
+void MgServerQueryDefinitionReader::ResponseStartUtf8(string& str)
+ throw new MgNotImplementedException(L"MgServerQueryDefinitionReader.ResponseStartUtf8", __LINE__, __WFILE__, NULL, L"", NULL);
+/// \brief
+/// Returns the end of the response as a UTF-8 string. The mime
+/// \param str
+void MgServerQueryDefinitionReader::ResponseEndUtf8(string& str)
+ throw new MgNotImplementedException(L"MgServerQueryDefinitionReader.ResponseEndUtf8", __LINE__, __WFILE__, NULL, L"", NULL);
+/// \brief
+/// Returns the start of the response body as a UTF-8 string. The mime
+/// \param str
+void MgServerQueryDefinitionReader::BodyStartUtf8(string& str)
+ throw new MgNotImplementedException(L"MgServerQueryDefinitionReader.BodyStartUtf8", __LINE__, __WFILE__, NULL, L"", NULL);
+/// \brief
+/// Returns the end of the response body as a UTF-8 string. The mime
+/// \param str
+void MgServerQueryDefinitionReader::BodyEndUtf8(string& str)
+ throw new MgNotImplementedException(L"MgServerQueryDefinitionReader.BodyEndUtf8", __LINE__, __WFILE__, NULL, L"", NULL);
+/// \brief
+/// Returns the contents of the header in this reader as a UTF-8 string. The mime
+/// \param str
+void MgServerQueryDefinitionReader::HeaderToStringUtf8(string& str)
+ throw new MgNotImplementedException(L"MgServerQueryDefinitionReader.HeaderToStringUtf8", __LINE__, __WFILE__, NULL, L"", NULL);
+/// \brief
+/// Returns the contents of the current record/feature in the reader as a UTF-8 string. The mime
+/// \param str
+void MgServerQueryDefinitionReader::CurrentToStringUtf8(string& str)
+ throw new MgNotImplementedException(L"MgServerQueryDefinitionReader.CurrentToStringUtf8", __LINE__, __WFILE__, NULL, L"", NULL);
+/// <summary>
+/// definition.
+/// </summary>
+///</returns>
+/// NOTE: This is internal API used by the mapping service
+/// in the case where we do not want to spend time
+/// serializing the class definition to XML
+MgClassDefinition* MgServerQueryDefinitionReader::GetClassDefinitionNoXml()
+/// <summary>
+/// Gets the Geometry for the specified property. No conversion is
+/// performed, thus the property must be a of type Geometry or the result
+/// <returns>Returns a ByteReader object</returns>
+BYTE_ARRAY_OUT MgServerQueryDefinitionReader::GetGeometry(CREFSTRING propertyName, INT32& length)
+ //Pass the buck if it's the right reader type, otherwise we're not implemented
+ if (m_innerReader->GetReaderType() == MgReaderType::FeatureReader)
+ return ((MgFeatureReader*)m_innerReader.p)->GetGeometry(propertyName, length);
+ throw new MgNotImplementedException(L"MgServerQueryDefinitionReader.GetGeometry", __LINE__, __WFILE__, NULL, L"", NULL);
+/// <summary>
+/// Gets the Geometry for the property at the specified index. No conversion is
+BYTE_ARRAY_OUT MgServerQueryDefinitionReader::GetGeometry(INT32 index, INT32& length)
+ return ((MgFeatureReader*)m_innerReader.p)->GetGeometry(index, length);
+/// <summary>
+const wchar_t* MgServerQueryDefinitionReader::GetString(CREFSTRING propertyName, INT32& length)
+ return m_innerReader->GetString(propertyName, length);
+/// <summary>
+const wchar_t* MgServerQueryDefinitionReader::GetString(INT32 index, INT32& length)
+ STRING propName = m_innerReader->GetPropertyName(index);
+ return m_innerReader->GetString(propName, length);
+///<summary>
+/// Serialize data to TCP/IP stream
+///</summary>
+///<param name="stream">
+/// Stream
+///</param>
+void MgServerQueryDefinitionReader::Serialize(MgStream* stream)
+ INT32 count = 1; // Get value from MgConfiguration
+ bool operationCompleted = false;
+ Ptr<MgFeatureSet> featureSet;
+ STRING featureReader = L"";
+ // Find out the counts from Configuration
+ MgConfiguration* config = MgConfiguration::GetInstance();
+ config->GetIntValue(MgConfigProperties::FeatureServicePropertiesSection,
+ MgConfigProperties::FeatureServicePropertyDataCacheSize,
+ count,
+ MgConfigProperties::DefaultFeatureServicePropertyDataCacheSize);
+ // Collect the feature reader into a pool for ReadNext operation
+ MgServerFeatureReaderPool* featPool = MgServerFeatureReaderPool::GetInstance();
+ CHECKNULL(featPool, L"MgServerFeatureReader.Serialize");
+ featureReader = featPool->GetReaderId(this);
+ if (L"" == featureReader)
+ // The feature reader is not in the pool
+ featureReader = featPool->Add(this); // Add the reference
+ featureSet = GetFeatures(count);
+ operationCompleted = true;
+ MG_FEATURE_SERVICE_CATCH(L"MgServerFeatureReader.Serialize");
+ // Mark operation is completed successfully
+ stream->WriteBoolean(operationCompleted);
+ if (operationCompleted && (mgException == 0))
+ stream->WriteString(featureReader); // Write the reader ID so we can retrieve it for later use
+ stream->WriteObject((MgFeatureSet*)featureSet); // Write the feature set
+ else
+ stream->WriteObject((MgException*)mgException);
+ // Serialize method must not THROW the exception because it has already been written to the stream
+ // and in doing so would only end up writing the same exception to the stream twice.
+///<summary>
+/// Deserialize data from TCP/IP stream
+///</summary>
+/// Stream
+///</param>
+void MgServerQueryDefinitionReader::Deserialize(MgStream* stream)
+ throw new MgInvalidOperationException(L"MgServerQueryDefinitionReader.Deserialize",
+ __LINE__, __WFILE__, NULL, L"", NULL);
+MgFeatureSet* MgServerQueryDefinitionReader::GetFeatures(INT32 count)
+ CHECKNULL((MgReader*)m_innerReader, L"MgServerQueryDefinitionReader.GetFeatures");
+ INT32 featCount = count;
+ if (NULL == (MgClassDefinition*)m_classDef)
+ // Get MgClassDefinition
+ m_classDef = GetClassDefinition();
+ CHECKNULL(m_classDef.p, L"MgServerQueryDefinitionReader.GetFeatures");
+ if (NULL == (MgFeatureSet*)m_featureSet)
+ // Create a feature set for a pool of features
+ m_featureSet = new MgFeatureSet();
+ CHECKNULL((MgFeatureSet*)m_featureSet, L"MgServerQueryDefinitionReader.GetFeatures");
+ // Assign feature class definition to Feature Set
+ m_featureSet->SetClassDefinition(m_classDef);
+ else
+ m_featureSet->ClearFeatures();
+ // If class definition contains raster property
+ // we can only retrieve one feature at a time
+ // because, user would need to supply x,y and extents before
+ // they could fetch the raster data. Therefore we can not
+ // advance FdoIReader.
+ if (m_classDef->HasRasterProperty())
+ featCount = 1;
+ // Add all features to feature set
+ AddFeatures(featCount);
+ MG_FEATURE_SERVICE_CATCH_AND_THROW(L"MgServerFeatureReader.GetFeatures")
+ return SAFE_ADDREF((MgFeatureSet*)m_featureSet);
+void MgServerQueryDefinitionReader::Dispose() { delete this; }
+void MgServerQueryDefinitionReader::AddFeatures(INT32 count)
+ CHECKNULL((MgReader*)m_innerReader, L"MgServerFeatureReader.AddFeatures");
+ CHECKNULL((MgFeatureSet*)m_featureSet, L"MgServerFeatureReader.AddFeatures");
+ INT32 desiredFeatures = 0;
+ // Access the class definition
+ Ptr<MgClassDefinition> classDef = m_featureSet->GetClassDefinition();
+ CHECKNULL((MgClassDefinition*)classDef, L"MgServerFeatureReader.AddFeatures");
+ // Access the property definition collection
+ // Ptr<MgPropertyDefinitionCollection> propDefCol = classDef->GetProperties();
+ Ptr<MgPropertyDefinitionCollection> propDefCol = classDef->GetPropertiesIncludingBase();
+ CHECKNULL((MgPropertyDefinitionCollection*)propDefCol, L"MgServerFeatureReader.AddFeatures");
+ // How many properties are we fetching, it should be atleast one
+ INT32 cnt = propDefCol->GetCount();
+ // We only read if there is atleast one property requested
+ if (cnt > 0 && count > 0)
+ try
+ while (m_innerReader->ReadNext())
+ AddFeature((MgPropertyDefinitionCollection*)propDefCol);
+ // Collected required features therefore do not process more
+ if (++desiredFeatures == count)
+ break;
+ //some providers will throw if ReadNext is called more than once
+ catch (FdoException* e)
+ // Note: VB 05/10/06 The assert has been commented out as
+ // Linux does not remove them from a release build. The assert
+ // will cause the server to crash on Linux. The Oracle provider will throw
+ // an exception if the ReadNext() method is called after it returns false.
+ // This is a known problem and it is safe to ignore the exception.
+ //assert(false);
+ e->Release();
+ catch(...)
+void MgServerQueryDefinitionReader::AddFeature(MgPropertyDefinitionCollection* propDefCol)
+ CHECKNULL((MgReader*)m_innerReader, L"MgServerQueryDefinitionReader.AddFeature");
+ CHECKARGUMENTNULL((MgPropertyDefinitionCollection*)propDefCol, L"MgServerQueryDefinitionReader.AddFeature");
+ //intentionally turn off duplicate checking for better performance
+ Ptr<MgPropertyCollection> propCol = new MgPropertyCollection(true, true);
+ for (INT32 i=0; i < cnt; i++)
+ Ptr<MgPropertyDefinition> propDef = propDefCol->GetItem(i);
+ // Get the name of property
+ STRING propName = propDef->GetName();
+ INT16 type = MgServerFeatureUtil::GetMgPropertyType(propDef);
+ Ptr<MgProperty> prop = MgServerFeatureUtil::GetMgProperty(this, propName, type);
+ if (prop != NULL)
+ propCol->Add(prop);
+ m_featureSet->AddFeature(propCol);
+MgByteReader* MgServerQueryDefinitionReader::GetRaster(STRING rasterPropName, INT32 xSize, INT32 ySize)
+ throw new MgNotImplementedException(L"MgServerQueryDefinitionReader.GetRaster", __LINE__, __WFILE__, NULL, L"", NULL);
\ No newline at end of file
Added: sandbox/jng/querydef/Server/src/Services/Feature/ServerQueryDefinitionReader.h
--- sandbox/jng/querydef/Server/src/Services/Feature/ServerQueryDefinitionReader.h (rev 0)
+++ sandbox/jng/querydef/Server/src/Services/Feature/ServerQueryDefinitionReader.h 2013-04-30 20:43:25 UTC (rev 7466)
@@ -0,0 +1,576 @@
+// Copyright (C) 2004-2013 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifndef _MG_SERVER_QUERY_DEFINITION_READER_H
+#define _MG_SERVER_QUERY_DEFINITION_READER_H
+#include "ServerFeatureDllExport.h"
+///<summary>
+/// The FeatureReader class provides a one way iterator for reading feature data.
+/// The initial position of the FeatureReader is prior to
+/// the first item. ReadNext should be called to begin accessing the data.
+/// GetClassDefintion returns the feature class definition for
+/// the feature data. The Get* methods operate on the current feature. The
+/// next feature is obtained by calling ReadNext.
+///</summary>
+class MG_SERVER_FEATURE_API MgServerQueryDefinitionReader : public MgFeatureReader
+EXTERNAL_API:
+ /// <summary>
+ /// Advances the reader to the next item and returns true if there is
+ /// another object to read or false if reading is complete. The default
+ /// position of the reader is prior to the first item. Thus you must
+ /// call ReadNext to begin accessing any data.
+ /// </summary>
+ /// <returns>
+ /// Returns true if there is a next item.
+ /// </returns>
+ bool ReadNext();
+ /// <summary>
+ /// Gets the definition of the object currently being read. If the user
+ /// has requested only a subset of the class properties, the class
+ /// definition reflects what the user has asked, rather than the full class
+ /// definition.
+ /// </summary>
+ /// <returns>A MgClassDefinition representing the current object
+ ///</returns>
+ MgClassDefinition* GetClassDefinition();
+ /// <summary>
+ /// Returns true if the value of the specified property is null.
+ /// </summary>
+ /// <param name="propertyName">Property name.</param>
+ /// <returns>Returns true if the value is null.</returns>
+ bool IsNull(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the Boolean value of the specified property. No conversion is
+ /// performed, thus the property must be a of boolean type the result
+ /// is undertermined</summary>
+ /// <returns>Returns the Boolean value.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not boolean
+ bool GetBoolean(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the Byte value of the specified property. No conversion is
+ /// performed, thus the property must be a of byte type or the result
+ /// <returns>Returns the Byte value.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not byte
+ BYTE GetByte(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the DTime value of the specified property. No conversion is
+ /// performed, thus the property must be a of date type or the result
+ /// is NULL</summary>
+ /// <returns>Returns the DTime value.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not date/time
+ MgDateTime* GetDateTime(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the Single value of the specified property. No conversion is
+ /// performed, thus the property must be a of type single or the result
+ /// is undetermined</summary>
+ /// <returns>Returns the single value.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not float
+ float GetSingle(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the Double value of the specified property. No conversion is
+ /// performed, thus the property must be a of type double or the result
+ /// <returns>Returns the double value.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not double
+ double GetDouble(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the integer 16 bits value of the specified property. No conversion is
+ /// performed, thus the property must be a of type integer 16 bits or the result
+ /// <returns>Returns the integer 16 bits value.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not int16
+ INT16 GetInt16(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the integer 32 bits value of the specified property. No conversion is
+ /// performed, thus the property must be a of type integer 32 bits or the result
+ /// <returns>Returns the integer 32 bits value.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not int32
+ INT32 GetInt32(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the integer 64 bits value of the specified property. No conversion is
+ /// performed, thus the property must be a of type integer 64 bits or the result
+ /// <returns>Returns the integer 64 bits value.
+ /// Note: INT64 is actually a pointer to an Integer64 object
+ ///</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not int64
+ INT64 GetInt64(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the string value of the specified property. No conversion is
+ /// performed, thus the property must be a of type string or the result
+ /// <returns>Returns the string value.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not a string
+ STRING GetString(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the BLOB value of the specified property. No conversion is
+ /// performed, thus the property must be a of type BLOBs or the result
+ /// <returns>Returns the BLOB value.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not a BLOB
+ MgByteReader* GetBLOB(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the CLOB value of the specified property. No conversion is
+ /// performed, thus the property must be a of type CLOB or the result
+ /// <returns>Returns the CLOB value.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not a CLOB
+ MgByteReader* GetCLOB(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the FeatureReader to access this object value.
+ /// The property must be of an object type; otherwise, the result is NULL.
+ /// </summary>
+ /// <param name="propertyName">Input the property name.</param>
+ /// <returns>Returns the feature reader to access this object.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not a feature
+ MgFeatureReader* GetFeatureObject(CREFSTRING propertyName);
+ /// <summary>
+ /// Gets the geometry value of the specified property as a GeometryReader.
+ /// Because no conversion is performed, the property must be
+ /// of Geometric type; otherwise, the result is NULL.</summary>
+ /// <returns>Returns the Geometry object.</returns>
+ /// EXCEPTIONS:
+ /// MgInvalidArgumentException if the property type is not geometry
+ MgByteReader* GetGeometry(CREFSTRING propertyName);
+ /// <summary>
+ /// </summary>
+ /// <returns>Returns the Raster object.</returns>
+ /// EXCEPTIONS:
+ MgRaster* GetRaster(CREFSTRING propertyName);
+ /// <summary>
+ /// Returns true if the value of the property at the specified index is null.
+ /// </summary>
+ /// <param name="index">Property index.</param>
+ bool IsNull(INT32 index);
+ /// <summary>
+ /// Gets the Boolean value of the property at the specified index. No conversion is
+ /// EXCEPTIONS:
+ bool GetBoolean(INT32 index);
+ /// <summary>
+ /// Gets the Byte value of the property at the specified index. No conversion is
+ /// EXCEPTIONS:
+ BYTE GetByte(INT32 index);
+ /// <summary>
+ /// Gets the DTime value of the property at the specified index. No conversion is
+ /// EXCEPTIONS:
+ MgDateTime* GetDateTime(INT32 index);
+ /// <summary>
+ /// Gets the Single value of the property at the specified index. No conversion is
+ /// EXCEPTIONS:
+ float GetSingle(INT32 index);
+ /// <summary>
+ /// Gets the Double value of the property at the specified index. No conversion is
+ /// EXCEPTIONS:
+ double GetDouble(INT32 index);
+ /// <summary>
+ /// Gets the integer 16 bits value of the property at the specified index. No conversion is
+ /// EXCEPTIONS:
+ INT16 GetInt16(INT32 index);
+ /// <summary>
+ /// Gets the integer 32 bits value of the property at the specified index. No conversion is
+ /// EXCEPTIONS:
+ INT32 GetInt32(INT32 index);
+ /// <summary>
+ /// Gets the integer 64 bits value of the property at the specified index. No conversion is
+ ///</returns>
+ /// EXCEPTIONS:
+ INT64 GetInt64(INT32 index);
+ /// <summary>
+ /// Gets the string value of the property at the specified index. No conversion is
+ /// EXCEPTIONS:
+ STRING GetString(INT32 index);
+ /// <summary>
+ /// Gets the BLOB value of the property at the specified index. No conversion is
+ /// EXCEPTIONS:
+ MgByteReader* GetBLOB(INT32 index);
+ /// <summary>
+ /// Gets the CLOB value of the property at the specified index. No conversion is
+ /// EXCEPTIONS:
+ MgByteReader* GetCLOB(INT32 index);
+ /// <summary>
+ /// </summary>
+ /// EXCEPTIONS:
+ MgFeatureReader* GetFeatureObject(INT32 index);
+ /// <summary>
+ /// Gets the geometry value of the property at the specified index as a GeometryReader.
+ /// EXCEPTIONS:
+ MgByteReader* GetGeometry(INT32 index);
+ /// <summary>
+ /// </summary>
+ /// EXCEPTIONS:
+ MgRaster* GetRaster(INT32 index);
+ /// <summary>
+ /// Serializes all features into an XML.
+ /// XML is serialized from the current position of feature reader in the order
+ /// data are retrieved.
+ /// <returns>MgByteReader holding XML.</returns>
+ MgByteReader* ToXml();
+ /// <summary>
+ /// Releases all the resources of feature reader.
+ /// This must be called when user is done with Feature Reader
+ /// <returns>Nothing</returns>
+ void Close();
+INTERNAL_API:
+ /// \brief
+ /// Returns the starting element name as a UTF-8 string. The mime
+ /// type must be a text type, for example text/xml.
+ /// \param str
+ /// Destination string.
+ string GetResponseElementName();
+ /// \brief
+ /// Returns the body starting element name as a UTF-8 string. The mime
+ /// \param str
+ string GetBodyElementName();
+ /// \brief
+ /// Returns the start of the response as a UTF-8 string. The mime
+ /// \param str
+ void ResponseStartUtf8(string& str);
+ /// \brief
+ /// Returns the end of the response as a UTF-8 string. The mime
+ /// \param str
+ void ResponseEndUtf8(string& str);
+ /// \brief
+ /// Returns the start of the response body as a UTF-8 string. The mime
+ /// \param str
+ void BodyStartUtf8(string& str);
+ /// \brief
+ /// Returns the end of the response body as a UTF-8 string. The mime
+ /// \param str
+ void BodyEndUtf8(string& str);
+ /// \brief
+ /// Returns the contents of the header in this reader as a UTF-8 string. The mime
+ /// \param str
+ void HeaderToStringUtf8(string& str);
+ /// \brief
+ /// Returns the contents of the current record/feature in the reader as a UTF-8 string. The mime
+ /// \param str
+ void CurrentToStringUtf8(string& str);
+ /// <summary>
+ /// definition.
+ /// </summary>
+ ///</returns>
+ /// NOTE: This is internal API used by the mapping service
+ /// in the case where we do not want to spend time
+ /// serializing the class definition to XML
+ MgClassDefinition* GetClassDefinitionNoXml();
+ /// <summary>
+ /// Gets the Geometry for the specified property. No conversion is
+ /// performed, thus the property must be a of type Geometry or the result
+ /// <returns>Returns a ByteReader object</returns>
+ BYTE_ARRAY_OUT GetGeometry(CREFSTRING propertyName, INT32& length);
+ /// <summary>
+ /// Gets the Geometry for the property at the specified index. No conversion is
+ BYTE_ARRAY_OUT GetGeometry(INT32 index, INT32& length);
+ /// <summary>
+ const wchar_t* GetString(CREFSTRING propertyName, INT32& length);
+ /// <summary>
+ const wchar_t* GetString(INT32 index, INT32& length);
+ ///<summary>
+ /// Serialize data to TCP/IP stream
+ ///</summary>
+ ///<param name="stream">
+ /// Stream
+ ///</param>
+ virtual void Serialize(MgStream* stream);
+ ///<summary>
+ /// Deserialize data from TCP/IP stream
+ ///</summary>
+ /// Stream
+ ///</param>
+ virtual void Deserialize(MgStream* stream);
+ virtual MgFeatureSet* GetFeatures(INT32 count);
+ void AddFeatures(INT32 count);
+ void AddFeature(MgPropertyDefinitionCollection* propDefCol);
+ MgServerQueryDefinitionReader(MgReader* innerReader, MgClassDefinition* classDef);
+ ~MgServerQueryDefinitionReader();
+ virtual void Dispose();
+ virtual INT32 GetClassId() { return m_cls_id; }
+ //FdoIFeatureReader* GetInternalReader() { return FDO_SAFE_ADDREF(m_fdoReader); }
+ MgByteReader* GetRaster(STRING rasterPropName, INT32 xSize, INT32 ySize);
+private:
+ Ptr<MgClassDefinition> m_classDef;
+ Ptr<MgFeatureSet> m_featureSet;
+ Ptr<MgReader> m_innerReader;
+CLASS_ID:
+ static const INT32 m_cls_id = PlatformBase_FeatureService_FeatureReader;
+#endif
Modified: sandbox/jng/querydef/Server/src/UnitTesting/TestFeatureService.cpp
--- sandbox/jng/querydef/Server/src/UnitTesting/TestFeatureService.cpp 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/Server/src/UnitTesting/TestFeatureService.cpp 2013-04-30 20:43:25 UTC (rev 7466)
@@ -3167,7 +3167,7 @@
INT64 count = fr->GetInt64(L"RecordCount");
INT64 count2 = fr->GetInt64(fr->GetPropertyIndex(L"RecordCount"));
- CPPUNIT_ASSERT(17565L == count);
+ CPPUNIT_ASSERT(80 == count);
CPPUNIT_ASSERT(count == count2);
bRead = fr->ReadNext();
CPPUNIT_ASSERT(!bRead);
@@ -3272,16 +3272,17 @@
CPPUNIT_ASSERT(L"QueryDefault" == ((MgGeometricPropertyDefinition*)prop3.p)->GetSpatialContextAssociation());
Ptr<MgAgfReaderWriter> agfRw = new MgAgfReaderWriter();
+ Ptr<MgWktReaderWriter> wktRw = new MgWktReaderWriter();
//Test spatial contexts
Ptr<MgSpatialContextReader> scReader = pService->GetSpatialContexts(qryId, false);
bool bRead = scReader->ReadNext();
CPPUNIT_ASSERT(bRead); //Query has GeometryInfo so we should have a result
//Test spatial context reader contents. Should match what we have defined in GeometryInfo
- CPPUNIT_ASSERT(L"Default" == scReader->GetName());
- CPPUNIT_ASSERT(L"Spatial Context for Query Definition" == scReader->GetName());
- CPPUNIT_ASSERT(L"LL84" == scReader->GetName());
- CPPUNIT_ASSERT(L"GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137.000,298.25722293]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.01745329251994]]" == scReader->GetName());
+ CPPUNIT_ASSERT(L"QueryDefault" == scReader->GetName());
+ CPPUNIT_ASSERT(L"Spatial Context for Query Definition" == scReader->GetDescription());
+ CPPUNIT_ASSERT(L"LL84" == scReader->GetCoordinateSystem());
+ CPPUNIT_ASSERT(L"GEOGCS[\"LL84\",DATUM[\"WGS84\",SPHEROID[\"WGS84\",6378137.000,298.25722293]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.01745329251994]]" == scReader->GetCoordinateSystemWkt());
CPPUNIT_ASSERT(MgSpatialContextExtentType::scDynamic == scReader->GetExtentType());
Ptr<MgByteReader> scAgf = scReader->GetExtent();
Ptr<MgGeometry> scGeom = agfRw->Read(scAgf);
@@ -3301,10 +3302,10 @@
@@ -3338,7 +3339,14 @@
//Huh? MgFeatureReader inherits MgReader! Why you don't let me?
Ptr<MgByteReader> bbox = ((MgReader*)fr)->GetGeometry(L"MyExtents");
Ptr<MgByteReader> bbox2 = ((MgReader*)fr)->GetGeometry(fr->GetPropertyIndex(L"MyExtents"));
- CPPUNIT_ASSERT(bbox == bbox2);
+ Ptr<MgGeometry> gBox = agfRw->Read(bbox);
+ Ptr<MgGeometry> gBox2 = agfRw->Read(bbox2);
+ STRING wkt = wktRw->Write(gBox);
+ STRING wkt2 = wktRw->Write(gBox2);
+ CPPUNIT_ASSERT(wkt == wkt2);
fr->Close();
@@ -3458,9 +3466,9 @@
@@ -3481,9 +3489,9 @@
@@ -3645,7 +3653,7 @@
CPPUNIT_ASSERT(3 == fr->GetPropertyCount());
CPPUNIT_ASSERT(fr->GetPropertyIndex(L"Geometry") >= 0);
CPPUNIT_ASSERT(fr->GetPropertyIndex(L"SdfId") >= 0);
- CPPUNIT_ASSERT(fr->GetPropertyIndex(L"MyCurrentDate") >= 0);
+ CPPUNIT_ASSERT(fr->GetPropertyIndex(L"ID") >= 0);
Ptr<MgPropertyDefinitionCollection> clsProps = clsDef->GetProperties();
Ptr<MgPropertyDefinitionCollection> idProps = clsDef->GetIdentityProperties();
@@ -3654,7 +3662,7 @@
CPPUNIT_ASSERT(idProps->IndexOf(L"SdfId") >= 0);
CPPUNIT_ASSERT(clsProps->IndexOf(L"Geometry") >= 0);
CPPUNIT_ASSERT(clsProps->IndexOf(L"SdfId") >= 0);
- CPPUNIT_ASSERT(clsProps->IndexOf(L"MyCurrentDate") >= 0);
+ CPPUNIT_ASSERT(clsProps->IndexOf(L"ID") >= 0);
INT32 count = 0;
while(fr->ReadNext()) {
@@ -3778,9 +3786,9 @@
@@ -3801,9 +3809,9 @@
@@ -3965,9 +3973,9 @@
@@ -3988,9 +3996,9 @@
@@ -4031,7 +4039,7 @@
count++;
fr->Close();
- CPPUNIT_ASSERT(17565 == count);
catch(MgException* e)
@@ -4148,9 +4156,9 @@
@@ -4171,9 +4179,9 @@
@@ -4287,10 +4295,13 @@
Ptr<MgPropertyDefinitionCollection> klassIdProps = klass->GetIdentityProperties();
Ptr<MgPropertyDefinitionCollection> klassIdProps2 = klass2->GetIdentityProperties();
Ptr<MgPropertyDefinitionCollection> klassIdProps3 = klass3->GetIdentityProperties();
- CPPUNIT_ASSERT(0 == klassIdProps->GetCount());
+ CPPUNIT_ASSERT(1 == klassIdProps->GetCount());
CPPUNIT_ASSERT(klassIdProps->GetCount() == klassIdProps2->GetCount());
CPPUNIT_ASSERT(klassIdProps3->GetCount() == klassIdProps2->GetCount());
//Our property should be here
+ CPPUNIT_ASSERT(klassIdProps->IndexOf(L"RecordCount") >= 0);
+ CPPUNIT_ASSERT(klassIdProps2->IndexOf(L"RecordCount") >= 0);
+ CPPUNIT_ASSERT(klassIdProps3->IndexOf(L"RecordCount") >= 0);
CPPUNIT_ASSERT(klassProps->IndexOf(L"RecordCount") >= 0);
CPPUNIT_ASSERT(klassProps2->IndexOf(L"RecordCount") >= 0);
CPPUNIT_ASSERT(klassProps3->IndexOf(L"RecordCount") >= 0);
@@ -4320,8 +4331,9 @@
CPPUNIT_ASSERT(1 == clsProps->GetCount());
- CPPUNIT_ASSERT(0 == idProps->GetCount());
+ CPPUNIT_ASSERT(1 == idProps->GetCount());
CPPUNIT_ASSERT(clsProps->IndexOf(L"RecordCount") >= 0);
+ CPPUNIT_ASSERT(idProps->IndexOf(L"RecordCount") >= 0);
INT32 count = 0;
@@ -4449,9 +4461,9 @@
@@ -4472,9 +4484,9 @@
@@ -4633,9 +4645,9 @@
@@ -4656,9 +4668,9 @@
@@ -4830,9 +4842,9 @@
@@ -4853,9 +4865,9 @@
@@ -4903,7 +4915,7 @@
count++;
fr->Close();
- CPPUNIT_ASSERT(80 == count);
+ CPPUNIT_ASSERT(42 == count);
Modified: sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_AggregateCount.QueryDefinition
--- sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_AggregateCount.QueryDefinition 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_AggregateCount.QueryDefinition 2013-04-30 20:43:25 UTC (rev 7466)
@@ -7,7 +7,7 @@
<ComputedProperties>
<ComputedProperty>
<Name>RecordCount</Name>
- <Expression>Count(SdfId)</Expression>
+ <Value>Count(SdfId)</Value>
</ComputedProperty>
</ComputedProperties>
</AggregateQueryDefinition>
Modified: sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_AggregateSpatialExtents.QueryDefinition
--- sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_AggregateSpatialExtents.QueryDefinition 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_AggregateSpatialExtents.QueryDefinition 2013-04-30 20:43:25 UTC (rev 7466)
@@ -29,7 +29,7 @@
<ComputedProperty>
<Name>MyExtents</Name>
- <Expression>SpatialExtents(Geometry)</Expression>
+ <Value>SpatialExtents(Geometry)</Value>
</ComputedProperty>
Modified: sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicAllElements.QueryDefinition
--- sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicAllElements.QueryDefinition 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicAllElements.QueryDefinition 2013-04-30 20:43:25 UTC (rev 7466)
@@ -6,7 +6,7 @@
<Geometry>Geometry</Geometry>
<GeometryTypes>7</GeometryTypes>
<SpatialContext>
- <Name>Default</Name>
+ <Name>QueryDefault</Name>
<Description>Spatial Context for Query Definition</Description>
<CoordinateSystemName>LL84</CoordinateSystemName>
<CoordinateSystemWkt>GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.01745329251994]]</CoordinateSystemWkt>
@@ -37,7 +37,7 @@
<ComputedProperty>
<Name>MyCurrentDate</Name>
- <Expression>CurrentDate()</Expression>
+ <Value>CurrentDate()</Value>
</ComputedProperty>
<OrderBy>
Modified: sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicWithExplicitPropertyList.QueryDefinition
--- sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicWithExplicitPropertyList.QueryDefinition 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicWithExplicitPropertyList.QueryDefinition 2013-04-30 20:43:25 UTC (rev 7466)
@@ -38,11 +38,11 @@
<ComputedProperty>
</ComputedProperty>
<ComputedProperty>
<Name>MyIDLength</Name>
- <Expression>Length(ID)</Expression>
+ <Value>Length(ID)</Value>
</ComputedProperty>
</FeatureQueryDefinition>
Modified: sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicWithFilter.QueryDefinition
--- sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicWithFilter.QueryDefinition 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_BasicWithFilter.QueryDefinition 2013-04-30 20:43:25 UTC (rev 7466)
@@ -6,7 +6,7 @@
<SpatialContext>
Modified: sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_SQLBasic.QueryDefinition
--- sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_SQLBasic.QueryDefinition 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_SQLBasic.QueryDefinition 2013-04-30 20:43:25 UTC (rev 7466)
@@ -6,7 +6,7 @@
<SpatialContext>
Modified: sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_SQLWhereJoin.QueryDefinition
--- sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_SQLWhereJoin.QueryDefinition 2013-04-30 15:21:47 UTC (rev 7465)
+++ sandbox/jng/querydef/UnitTest/TestData/FeatureService/SQLite/UT_SQLWhereJoin.QueryDefinition 2013-04-30 20:43:25 UTC (rev 7466)
@@ -6,7 +6,7 @@
<SpatialContext>
More information about the mapguide-commits
