[mapguide-commits] r7761 - trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Aug 12 07:46:48 PDT 2013
Author: jng
Date: 2013-08-12 07:46:48 -0700 (Mon, 12 Aug 2013)
New Revision: 7761
   trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
#2339: Fix Layer Definition editor NRE on multi-schema Feature Sources. The problem was our GetClassDefinitionInternal() method naively assumes a single schema, which obviously is not the case.
Modified: trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2013-08-11 15:55:40 UTC (rev 7760)
+++ trunk/Tools/Maestro/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs	2013-08-12 14:46:48 UTC (rev 7761)
@@ -1987,24 +1987,31 @@
                 var fsd = new FeatureSourceDescription(s);
                 //We can't just assume first class item is the one, as ones that do not take
                 //class name hints will return the full schema
-                var schema = fsd.Schemas[0];
-                if (schema.Classes.Count > 1)
+                var schema = fsd.GetSchema(schemaName);
+                if (schema != null)
-                    //Since we have the full schema anyway, let's cache these other classes
-                    ClassDefinition ret = null;
-                    foreach (var cls in schema.Classes)
+                    if (schema.Classes.Count > 1)
-                        string key = resourceId + "!" + cls.QualifiedName;
-                        m_classDefinitionCache[key] = cls;
+                        //Since we have the full schema anyway, let's cache these other classes
+                        ClassDefinition ret = null;
+                        foreach (var cls in schema.Classes)
+                            string key = resourceId + "!" + cls.QualifiedName;
+                            m_classDefinitionCache[key] = cls;
-                        if (cls.Name == className)
-                            ret = cls;
+                            if (cls.Name == className)
+                                ret = cls;
+                        return ret;
-                    return ret;
+                    else
+                        return schema.GetClass(className);
                 else
-                    return schema.GetClass(className);
+                    return null;
More information about the mapguide-commits mailing list
