[mapguide-commits] r7795 - in trunk/MgDev/Doc/samples/ol2samples: . commercial mixed tiled
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Aug 21 09:37:18 PDT 2013
Author: jng
Date: 2013-08-21 09:37:17 -0700 (Wed, 21 Aug 2013)
New Revision: 7795
Added:
   trunk/MgDev/Doc/samples/ol2samples/commercial/SheboyganCommercial.MapDefinition.xml
   trunk/MgDev/Doc/samples/ol2samples/commercial/index.html
   trunk/MgDev/Doc/samples/ol2samples/mixed/
   trunk/MgDev/Doc/samples/ol2samples/mixed/SheboyganMixed.MapDefinition.xml
   trunk/MgDev/Doc/samples/ol2samples/mixed/index.html
Removed:
   trunk/MgDev/Doc/samples/ol2samples/querymap/
   trunk/MgDev/Doc/samples/ol2samples/tiled/index.html
#2344: Add more samples
 - An example of a mixed tiled/untiled Map Definition
 - An example of a WGS84.PseudoMercator Map Definition with Google/OSM layers
Added: trunk/MgDev/Doc/samples/ol2samples/commercial/SheboyganCommercial.MapDefinition.xml
--- trunk/MgDev/Doc/samples/ol2samples/commercial/SheboyganCommercial.MapDefinition.xml	                        (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/commercial/SheboyganCommercial.MapDefinition.xml	2013-08-21 16:37:17 UTC (rev 7795)
@@ -0,0 +1,116 @@
+<?xml version="1.0"?>
+<MapDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="MapDefinition-1.0.0.xsd">
+  <Name>Sheboygan Map</Name>
+  <CoordinateSystem>PROJCS["WGS84.PseudoMercator",GEOGCS["LL84",DATUM["WGS84",SPHEROID["WGS84",6378137.000,298.25722293]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Popular Visualisation Pseudo Mercator"],PARAMETER["false_easting",0.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",0.00000000000000],UNIT["Meter",1.00000000000000]]</CoordinateSystem>
+  <Extents>
+    <MinX>-9769953.6613122653</MinX>
+    <MaxX>-9762220.7994439267</MaxX>
+    <MinY>5417808.8801717851</MinY>
+    <MaxY>5434161.2241863841</MaxY>
+  </Extents>
+  <BackgroundColor>ffcdbd9c</BackgroundColor>
+  <MapLayer>
+    <Name>Roads</Name>
+    <ResourceId>Library://Samples/Sheboygan/Layers/Roads.LayerDefinition</ResourceId>
+    <Selectable>false</Selectable>
+    <ShowInLegend>true</ShowInLegend>
+    <LegendLabel>Roads</LegendLabel>
+    <ExpandInLegend>true</ExpandInLegend>
+    <Visible>true</Visible>
+    <Group>Transportation</Group>
+  </MapLayer>
+  <MapLayer>
+    <Name>Rail Lines</Name>
+    <ResourceId>Library://Samples/Sheboygan/Layers/Tracks.LayerDefinition</ResourceId>
+    <LegendLabel>Rail Lines</LegendLabel>
+    <Visible>false</Visible>
+  </MapLayer>
+  <MapLayer>
+    <Name>Districts</Name>
+    <ResourceId>Library://Samples/Sheboygan/Layers/Districts.LayerDefinition</ResourceId>
+    <LegendLabel>Districts</LegendLabel>
+    <Group>Municipal</Group>
+  </MapLayer>
+  <MapLayer>
+    <Name>Buildings</Name>
+    <ResourceId>Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition</ResourceId>
+    <LegendLabel>Buildings</LegendLabel>
+  </MapLayer>
+  <MapLayer>
+    <Name>Parcels</Name>
+    <ResourceId>Library://Samples/Sheboygan/Layers/Parcels.LayerDefinition</ResourceId>
+    <Selectable>true</Selectable>
+    <LegendLabel>Parcels</LegendLabel>
+  </MapLayer>
+  <MapLayer>
+    <Name>Islands</Name>
+    <ResourceId>Library://Samples/Sheboygan/Layers/Islands.LayerDefinition</ResourceId>
+    <LegendLabel>Islands</LegendLabel>
+    <Group>Base Map</Group>
+  </MapLayer>
+  <MapLayer>
+    <Name>Hydrography</Name>
+    <ResourceId>Library://Samples/Sheboygan/Layers/Hydrography.LayerDefinition</ResourceId>
+    <LegendLabel>Hydrography</LegendLabel>
+  </MapLayer>
+  <MapLayer>
+    <Name>CityLimits</Name>
+    <ResourceId>Library://Samples/Sheboygan/Layers/CityLimits.LayerDefinition</ResourceId>
+    <LegendLabel>CityLimits</LegendLabel>
+  </MapLayer>
+  <MapLayerGroup>
+    <Name>Base Map</Name>
+    <LegendLabel>Base Map</LegendLabel>
+    <Group />
+  </MapLayerGroup>
+  <MapLayerGroup>
+    <Name>Municipal</Name>
+    <LegendLabel>Municipal</LegendLabel>
+    <Group />
+  </MapLayerGroup>
+  <MapLayerGroup>
+    <Name>Transportation</Name>
+    <LegendLabel>Transportation</LegendLabel>
+    <Group />
+  </MapLayerGroup>
+</MapDefinition>
\ No newline at end of file
Added: trunk/MgDev/Doc/samples/ol2samples/commercial/index.html
--- trunk/MgDev/Doc/samples/ol2samples/commercial/index.html	                        (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/commercial/index.html	2013-08-21 16:37:17 UTC (rev 7795)
@@ -0,0 +1,241 @@
+<html>
+    <head>
+        <title>Sheboygan map with Google/OSM layers</title>
+        <link rel="stylesheet" href="../assets/theme/default/style.css" />
+        <style type="text/css">
+            body { font-family: Verdana; font-size: 0.9em; }
+            #error { color: red; }
+            #wrap { width: 900; }
+            #map { width: 650; height: 500; float: right; }
+            #layers { width: 250; height: 500; overflow: auto; display: block-inline; float: left; }
+            #rootList { list-style-type: none; margin-left: -20px; }
+            #rootList li { list-style-type: none; }
+            .olControlMousePosition { background: #ffff66; font-size: 0.6em !important; padding: 2px; }
+            #baseLayerSwitcher { background: #6699FF; color: white; padding: 5px; }
+            #baseLayerSwitcher .baseLayersDiv { font-size: 0.7em; }
+        </style>
+        <script src="http://maps.google.com/maps/api/js?v=3&sensor=false"></script>
+        <script type="text/javascript" src="../assets/jquery-1.10.2.min.js"></script>
+        <script type="text/javascript" src="../assets/OpenLayers.js"></script>
+        <script type="text/javascript" src="../assets/legend.js"></script>
+        <script type="text/javascript">
+        //This sample is assumed to be hosted at http://servername/mapguide/ol2samples/untiled/index.html
+        var mapAgentUrl = "../../mapagent/mapagent.fcgi";
+        //Various features you can include in the CREATERUNTIMEMAP response.
+        var REQ_NONE = 0;                   //Nothing. This the default.
+        var REQ_LAYER_STRUCTURE = 1;        //Information about layers and groups (required for the mask values below to have any effect)
+        var REQ_LAYER_ICONS = 2;            //Icons for each layer (has no effect if REQ_LAYER_STRUCTURE is not in the bitmask)
+        var REQ_LAYER_FEATURE_SOURCE = 4;   //Feature Source information for each layer (has no effect if REQ_LAYER_STRUCTURE is not in the bitmask)
+        var gMimeType = null;
+        var map = null;
+        var mgLayer = null;
+        var sessionId = null;
+        $(document).ready(function() {
+            OpenLayers.Control.DragPan.prototype.enableKinetic = false;
+            //Have a play with the bitmask values to see the differences in JSON payload size
+            //and to see how our legend control gracefully handles such situations
+            //createMap(REQ_NONE);
+            //createMap(REQ_LAYER_STRUCTURE);
+            createMap(REQ_LAYER_STRUCTURE | REQ_LAYER_FEATURE_SOURCE | REQ_LAYER_ICONS);
+        function createMap(reqFeatures) {
+            $.getJSON(mapAgentUrl, {
+                "OPERATION": "CREATERUNTIMEMAP",
+                "VERSION": "2.6.0",
+                "MAPDEFINITION": "Library://Samples/Sheboygan/Maps/SheboyganCommercial.MapDefinition",
+                "USERNAME": "Anonymous", //Or you can use "SESSION": "<my session id>"
+                "REQUESTEDFEATURES": reqFeatures,
+                //Optional parameters you can specify and/or experiment with
+                //"ICONFORMAT": "GIF",    //Uncomment to override desired image format (default: PNG)
+                //"ICONWIDTH": 32,         //Uncomment to override desired icon width (default: 16)
+                //"ICONHEIGHT": 32,        //Uncomment to override desired icon height (default: 16)
+                //"ICONSPERSCALERANGE": 3, //Uncomment to observe theme compression for themes exceeding this number of rules (default: 25)
+                //"TARGETMAPNAME": "MyRuntimeMapForOpenLayers", //Uncomment if you require a specific map name be given (default: inferred from Map Definition)
+                "FORMAT": "application/json"
+            }, function(data, textStatus, jqXHR) {
+                $("#jsonSize").html(jqXHR.responseText.length);
+                loadMap(data);
+            }).error(function(jqXHR, textStatus, errorThrown) {
+                $("#error").html(jqXHR.responseText);
+        function loadMap(rtMapInfo) {
+            if (rtMapInfo.RuntimeMap.IconMimeType) {
+                gMimeType = rtMapInfo.RuntimeMap.IconMimeType[0];
+                $("#iconFormat").html(gMimeType);
+            var extent = new OpenLayers.Bounds(
+                parseFloat(rtMapInfo.RuntimeMap.Extents[0].LowerLeftCoordinate[0].X[0]),
+                parseFloat(rtMapInfo.RuntimeMap.Extents[0].LowerLeftCoordinate[0].Y[0]),
+                parseFloat(rtMapInfo.RuntimeMap.Extents[0].UpperRightCoordinate[0].X[0]),
+                parseFloat(rtMapInfo.RuntimeMap.Extents[0].UpperRightCoordinate[0].Y[0]));
+            OpenLayers.Control.CustomNavToolbar = OpenLayers.Class(OpenLayers.Control.Panel, {
+                 * Constructor: OpenLayers.Control.NavToolbar
+                 * Add our two mousedefaults controls.
+                 * Parameters:
+                 * options - {Object} An optional object whose properties will be used
+                 *     to extend the control.
+                initialize: function(options) {
+                    OpenLayers.Control.Panel.prototype.initialize.apply(this, [options]);
+                    this.addControls([
+                      new OpenLayers.Control.Navigation(),
+                      //Here it come
+                      new OpenLayers.Control.ZoomBox({alwaysZoom:true})
+                    // To make the custom navtoolbar use the regular navtoolbar style
+                    this.displayClass = 'olControlNavToolbar'
+                 * Method: draw
+                 * calls the default draw, and then activates mouse defaults.
+                draw: function() {
+                    var div = OpenLayers.Control.Panel.prototype.draw.apply(this, arguments);
+                    this.defaultControl = this.controls[0];
+                    return div;
+            var mapOptions = {
+                theme: null,
+                projection: 'EPSG:900913',
+                maxExtent: extent,
+                maxResolution: 'auto',
+                controls: [
+                    new OpenLayers.Control.Attribution(),
+                    new OpenLayers.Control.Zoom(),
+                    new OpenLayers.Control.ScaleLine(),
+                    new OpenLayers.Control.MousePosition(),
+                    new OpenLayers.Control.LayerSwitcher({ div: $("#baseLayerSwitcher")[0] }),
+                    new OpenLayers.Control.CustomNavToolbar({alwaysZoom:true})
+            if (rtMapInfo.RuntimeMap.CoordinateSystem[0].EpsgCode[0].length > 0) {
+                mapOptions.projection = "EPSG:" + rtMapInfo.RuntimeMap.CoordinateSystem[0].EpsgCode[0];
+            var options = {
+                isBaseLayer: false,
+                transitionEffect: "resize",
+                buffer: 1,
+                useOverlay: true,
+                useAsyncOverlay: true,
+                singleTile: true
+            var params = {
+                mapname: rtMapInfo.RuntimeMap.Name[0],
+                session: rtMapInfo.RuntimeMap.SessionId[0],
+                selectioncolor: '0xFF000000',
+                behavior: 2
+            sessionId = rtMapInfo.RuntimeMap.SessionId[0];
+            //Adjust the scale assumptions for MapGuide layers
+            //Tiled layers MUST use a DPI value of 96, untiled layers can use a
+            //different DPI value which will be passed to the server as a parameter.
+            //Tiled and untiled layers must adjust the OL INCHES_PER_UNIT values
+            //for any degree-based projections.
+            //You'll still need to do these adjustments manually, but CREATERUNTIMEMAP
+            //now provides the necessary meters-per-unit value for you to do this.
+            var metersPerUnit = parseFloat(rtMapInfo.RuntimeMap.CoordinateSystem[0].MetersPerUnit[0]);
+            var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
+            OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
+            OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
+            OpenLayers.DOTS_PER_INCH = 96;
+            map = new OpenLayers.Map('map', mapOptions );
+            map.addLayers([
+                new OpenLayers.Layer.Google(
+                    "Google Physical",
+                    {type: google.maps.MapTypeId.TERRAIN}
+                    "Google Streets", // the default
+                    {numZoomLevels: 20}
+                    "Google Hybrid",
+                    {type: google.maps.MapTypeId.HYBRID, numZoomLevels: 20}
+                    "Google Satellite",
+                    {type: google.maps.MapTypeId.SATELLITE, numZoomLevels: 22}
+                new OpenLayers.Layer.OSM("OpenStreetMap")
+            mgLayer = new OpenLayers.Layer.MapGuide( "MapGuide (from CREATERUNTIMEMAP)", mapAgentUrl, params, options );
+            map.addLayer(mgLayer);
+            map.zoomToExtent(extent);
+            var legend = new Legend({
+                legendSelector: "#rootList",
+                stdIconRoot: "../../stdicons",
+                runtimeMap: rtMapInfo,
+                map: map,
+                mgLayerOL: mgLayer
+            legend.update();
+            $("#mapName").html("MapGuide mapname: " + rtMapInfo.RuntimeMap.Name[0]);
+            $("#mgSession").html("MapGuide session ID: " + sessionId);
+            $("div.olMap").css("background-color", "#" + rtMapInfo.RuntimeMap.BackgroundColor[0].substring(2));
+            startKeepAlive();
+        function startKeepAlive() {
+            var keepAlive = function() {
+                $.get(mapAgentUrl, {
+                    "OPERATION": "GETSESSIONTIMEOUT",
+                    "VERSION": "1.0.0",
+                    "SESSION": sessionId
+                }, function(data, textStatus, jxXHR) {
+                    $("#mgSession").html("MapGuide session ID: " + sessionId + " (last checked at: " + (new Date()) + ")");
+                    setTimeout(keepAlive, parseInt(data) * 1000);
+            keepAlive();
+        </script>
+    </head>
+    <body>
+        <p>This example demonstrates MapGuide layer integration with Google/OSM. The map is created with CREATERUNTIMEMAP.</p>
+        <p>The Map Definition is in WGS84.PseudoMercator which allows for the MapGuide map to line up with any Google/OSM layer</p>
+        <div id="error">
+        </div>
+        <div id="wrap">
+            <div id="layers">
+                <div id="baseLayerSwitcher">
+                </div>
+                <div id="legend">
+                    <strong>Layer and Groups</strong>
+                    <ul id="rootList">
+                    </ul>
+                </div>
+            </div>
+            <div id="map">
+            </div>
+        </div>
+        <p>JSON payload for CREATERUNTIMEMAP is: <span id="jsonSize"></span> characters</p>
+        <p>Icon format is: <span id="iconFormat"></span></p>
+        <p id="mapName"></p>
+        <p id="mgSession"></p>
+    </body>
+</html>
Added: trunk/MgDev/Doc/samples/ol2samples/mixed/SheboyganMixed.MapDefinition.xml
--- trunk/MgDev/Doc/samples/ol2samples/mixed/SheboyganMixed.MapDefinition.xml	                        (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/mixed/SheboyganMixed.MapDefinition.xml	2013-08-21 16:37:17 UTC (rev 7795)
@@ -0,0 +1,114 @@
+  <CoordinateSystem>GEOGCS["WGS84 Lat/Long's, Degrees, -180 ==> +180",DATUM["D_WGS_1984",SPHEROID["World_Geodetic_System_of_1984",6378137,298.257222932867]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]]</CoordinateSystem>
+  <Extents>
+    <MinX>-87.764986990962839</MinX>
+    <MaxX>-87.695521510899724</MaxX>
+    <MinY>43.691398128787782</MinY>
+    <MaxY>43.797520000480347</MaxY>
+  </Extents>
+  <MapLayer>
+    <Group>Other</Group>
+  </MapLayer>
+  <MapLayer>
+  </MapLayer>
+  <MapLayer>
+  </MapLayer>
+  <MapLayerGroup>
+    <Name>Other</Name>
+    <LegendLabel>Other</LegendLabel>
+    <Group />
+  </MapLayerGroup>
+  <BaseMapDefinition>
+    <FiniteDisplayScale>1000</FiniteDisplayScale>
+    <FiniteDisplayScale>1930.69773</FiniteDisplayScale>
+    <FiniteDisplayScale>3727.59372</FiniteDisplayScale>
+    <FiniteDisplayScale>7196.85673</FiniteDisplayScale>
+    <FiniteDisplayScale>13894.95494</FiniteDisplayScale>
+    <FiniteDisplayScale>26826.95795</FiniteDisplayScale>
+    <FiniteDisplayScale>51794.74679</FiniteDisplayScale>
+    <FiniteDisplayScale>100000</FiniteDisplayScale>
+    <BaseMapLayerGroup>
+      <BaseMapLayer>
+      </BaseMapLayer>
+      <BaseMapLayer>
+      </BaseMapLayer>
+    </BaseMapLayerGroup>
+      <BaseMapLayer>
+      </BaseMapLayer>
+      <BaseMapLayer>
+      </BaseMapLayer>
+      <BaseMapLayer>
+      </BaseMapLayer>
+  </BaseMapDefinition>
+</MapDefinition>
Added: trunk/MgDev/Doc/samples/ol2samples/mixed/index.html
--- trunk/MgDev/Doc/samples/ol2samples/mixed/index.html	                        (rev 0)
+++ trunk/MgDev/Doc/samples/ol2samples/mixed/index.html	2013-08-21 16:37:17 UTC (rev 7795)
@@ -0,0 +1,239 @@
+<html>
+    <head>
+        <title>Basic Sheboygan mixed map (tiled and untiled) example</title>
+            #details { width: 250; height: 500; overflow: auto; display: block-inline; float: left; }
+        </style>
+        var map = null;
+                "MAPDEFINITION": "Library://Samples/Sheboygan/Maps/SheboyganMixed.MapDefinition",
+                loadMap(data);
+                 * Parameters:
+                      //Here it come
+                 * Method: draw
+                    return div;
+            var finiteScales = [];
+            if (rtMapInfo.RuntimeMap.FiniteDisplayScale) {
+                for (var i = rtMapInfo.RuntimeMap.FiniteDisplayScale.length - 1; i >= 0; i--) {
+                    finiteScales.push(parseFloat(rtMapInfo.RuntimeMap.FiniteDisplayScale[i]));
+                theme: null,
+                allOverlays: true,
+                scales: finiteScales,
+                controls: [
+            var options = {
+                buffer: 1,
+                useOverlay: true,
+                singleTile: true
+            var params = {
+                behavior: 2
+            var tiledLayers = {};
+            //Iterate in reverse order so any base layer groups are added in correct draw order
+            for (var i = rtMapInfo.RuntimeMap.Group.length - 1; i >= 0; i--) {
+                var group = rtMapInfo.RuntimeMap.Group[i];
+                if (group.Type[0] == "2") { //MgLayerGroupType.BaseMap
+                    var layer = new OpenLayers.Layer.MapGuide("MapGuide base layer group via CREATERUNTIMEMAP: " + group.Name[0], mapAgentUrl + "?USERNAME=Anonymous", {
+                        mapdefinition: rtMapInfo.RuntimeMap.MapDefinition[0],
+                        basemaplayergroupname: group.Name[0]
+                        singleTile: false
+                    map.addLayer(layer);
+                    tiledLayers[group.Name[0]] = layer;
+            map.zoomToMaxExtent();
+                map: map,
+                mgLayerOL: mgLayer,
+                mgTiledLayers: tiledLayers
+            legend.update();
+            startKeepAlive();
+            keepAlive();
+        </script>
+    </head>
+    <body>
+        <p>This example demonstrates loading a Map Definition with both tiled and untiled layers. The map is created with CREATERUNTIMEMAP</p>
+        <div id="error">
+        </div>
+        <div id="wrap">
+            <div id="details">
+                </ul>
+            </div>
+            <div id="map">
+            </div>
+        </div>
+    </body>
+</html>
Modified: trunk/MgDev/Doc/samples/ol2samples/tiled/index.html
--- trunk/MgDev/Doc/samples/ol2samples/tiled/index.html	2013-08-21 15:40:32 UTC (rev 7794)
+++ trunk/MgDev/Doc/samples/ol2samples/tiled/index.html	2013-08-21 16:37:17 UTC (rev 7795)
@@ -140,7 +140,8 @@
-            for (var i = 0; i < rtMapInfo.RuntimeMap.Group.length; i++) {
More information about the mapguide-commits mailing list
