[mapguide-commits] r7830 - in sandbox/jng/webtier_upgrade_v2/MgDev: . Server/src/Core Web/src/ApacheAgent Web/src/PhpApi
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Aug 31 10:36:01 PDT 2013
Author: jng
Date: 2013-08-31 10:36:00 -0700 (Sat, 31 Aug 2013)
New Revision: 7830
   sandbox/jng/webtier_upgrade_v2/MgDev/Server/src/Core/Makefile.am
   sandbox/jng/webtier_upgrade_v2/MgDev/Web/src/ApacheAgent/Makefile.am
   sandbox/jng/webtier_upgrade_v2/MgDev/Web/src/PhpApi/Makefile.am
   sandbox/jng/webtier_upgrade_v2/MgDev/build_oem.sh
   sandbox/jng/webtier_upgrade_v2/MgDev/configure.in
This submission contains the following changes:
 - Update FDO and MapGuide version numbers in configure.in
 - #2280: Define $(httpd_src) and $(php_src) in configure.in which points to the sources of httpd and php respectively. These point to the extracted locations under Oem\LinuxApt
 - #2347: Use automake silent rules
Modified: sandbox/jng/webtier_upgrade_v2/MgDev/Server/src/Core/Makefile.am
--- sandbox/jng/webtier_upgrade_v2/MgDev/Server/src/Core/Makefile.am	2013-08-31 15:21:17 UTC (rev 7829)
+++ sandbox/jng/webtier_upgrade_v2/MgDev/Server/src/Core/Makefile.am	2013-08-31 17:36:00 UTC (rev 7830)
@@ -97,7 +97,7 @@
   -ldwftk \
   -ldwfemap \
   -lexpat \
-  -lFDO-3.8.0 \
+  -lFDO-3.8.1 \
   -lExpressionEngine \
   -lxalanMsg \
   -lxalan-c \
Modified: sandbox/jng/webtier_upgrade_v2/MgDev/Web/src/ApacheAgent/Makefile.am
--- sandbox/jng/webtier_upgrade_v2/MgDev/Web/src/ApacheAgent/Makefile.am	2013-08-31 15:21:17 UTC (rev 7829)
+++ sandbox/jng/webtier_upgrade_v2/MgDev/Web/src/ApacheAgent/Makefile.am	2013-08-31 17:36:00 UTC (rev 7830)
@@ -10,10 +10,10 @@
               -I../../../Common/MapGuideCommon \
               -I../../../Common/MdfModel \
               -I../../../Oem/ACE/ACE_wrappers \
-              -I../../../Oem/LinuxApt/httpd-2.2.21/include \
-              -I../../../Oem/LinuxApt/httpd-2.2.21/srclib/apr/include \
-              -I../../../Oem/LinuxApt/httpd-2.2.21/srclib/apr-util/include \
-              -I../../../Oem/LinuxApt/httpd-2.2.21/os/unix \
+              -I$(httpd_src)/include \
+              -I$(httpd_src)/srclib/apr/include \
+              -I$(httpd_src)/srclib/apr-util/include \
+              -I$(httpd_src)/os/unix \
               -I/usr/local/mapguideopensource/webserverextensions/apache2/include\
               -I../HttpHandler \
               -I../WebSupport \
Modified: sandbox/jng/webtier_upgrade_v2/MgDev/Web/src/PhpApi/Makefile.am
--- sandbox/jng/webtier_upgrade_v2/MgDev/Web/src/PhpApi/Makefile.am	2013-08-31 15:21:17 UTC (rev 7829)
+++ sandbox/jng/webtier_upgrade_v2/MgDev/Web/src/PhpApi/Makefile.am	2013-08-31 17:36:00 UTC (rev 7830)
@@ -14,10 +14,10 @@
            -I../../../Common/Geometry \
            -I../../../Common/PlatformBase \
-           -I../../../Oem/php/TSRM \
-           -I../../../Oem/php/Zend \
-           -I../../../Oem/php/main \
-           -I../../../Oem/php \
+           -I$(php_src)/TSRM \
+           -I$(php_src)/Zend \
+           -I$(php_src)/main \
+           -I$(php_src) \
            -I../HttpHandler \
            -I../WebSupport \
Modified: sandbox/jng/webtier_upgrade_v2/MgDev/build_oem.sh
--- sandbox/jng/webtier_upgrade_v2/MgDev/build_oem.sh	2013-08-31 15:21:17 UTC (rev 7829)
+++ sandbox/jng/webtier_upgrade_v2/MgDev/build_oem.sh	2013-08-31 17:36:00 UTC (rev 7830)
@@ -222,20 +222,19 @@
 init_php()
-    LIB_NAME="PHP 5.3.1"
+    LIB_NAME="PHP 5.5.3"
 build_php()
-    pushd php
-    sh ./configure
-    check_build
+    # Nothing to do here. build_apt.sh builds PHP
+    pushd LinuxApt/php-5.5.3
     popd
 clean_php()
-    pushd php
     make distclean
     check_clean
     popd
Modified: sandbox/jng/webtier_upgrade_v2/MgDev/configure.in
--- sandbox/jng/webtier_upgrade_v2/MgDev/configure.in	2013-08-31 15:21:17 UTC (rev 7829)
+++ sandbox/jng/webtier_upgrade_v2/MgDev/configure.in	2013-08-31 17:36:00 UTC (rev 7830)
@@ -4,11 +4,14 @@
 # Variables
 # Following are the makefile directories
-AC_INIT(mapguide,2.5.0,http://mapguide.osgeo.org)
+AC_INIT(mapguide,2.6.0,http://mapguide.osgeo.org)
 AC_CONFIG_SRCDIR(configure.in)
 AM_INIT_AUTOMAKE
 AM_INIT_AUTOMAKE([1.9 tar-pax])
+# Enable silent rules if supported. Allows for less verbose output while still displaying any compiler/linker warnings/errors
+m4_ifdef([AM_SILENT_RULES], [AM_SILENT_RULES])
 AC_PREFIX_DEFAULT(/usr/local/mapguideopensource)
 AC_LANG_C
@@ -36,10 +39,8 @@
 map_opt_oem_distsubdirs=""
 dnl *******************************************************
-dnl PHP 5.3.1 Configuration
+dnl PHP 5.5.3 Configuration
-# Check for php
-# Note : Not yet implemented
 AC_ARG_WITH([php],
         MAP_HELP_STRING([--with-php],
                         [specify php headers dir prefix as args [[default=no]]]),
@@ -47,14 +48,44 @@
         [with_php=no])
 if test $with_php = "no"; then
-    AC_MSG_NOTICE([Using php 5.3.1 from included Oem Directory])
+    AC_MSG_NOTICE([Using php 5.5.3 from included Oem Directory])
+	php_src=`pwd`/Oem/LinuxApt/php-5.5.3
 else
-    AC_MSG_NOTICE(["WARNING!!: Using custom specified php include dir is not supported in this release."])
+    AC_MSG_NOTICE([Using custom PHP source directory])
+	php_src=$with_php
 fi
+if test -d $php_src; then
+	AC_MSG_NOTICE([PHP source directory is: $php_src])
+else
+	AC_MSG_ERROR([PHP source directory ($php_src) does not exist])
+fi
+AC_SUBST(php_src)
-dnl FDO 3.8.0 Configuration
+dnl httpd 2.4.6 Configuration
+dnl *******************************************************
+AC_ARG_WITH([httpd],
+		MAP_HELP_STRING([--with-httpd],
+						[specify httpd source dir prefix as args [[default=no]]]),
+		[with_httpd=$withval],
+		[with_httpd=no])
+if test $with_httpd = "no"; then
+    AC_MSG_NOTICE([Using httpd 2.4.6 from included Oem Directory])
+	httpd_src=`pwd`/Oem/LinuxApt/httpd-2.4.6
+else
+    AC_MSG_NOTICE([Using custom httpd source directory])
+	httpd_src=$with_httpd
+fi
+if test -d $http_src; then
+	AC_MSG_NOTICE([httpd source directory is: $httpd_src])
+else
+	AC_MSG_ERROR([httpd source directory ($httpd_src) does not exist])
+fi
+AC_SUBST(httpd_src)
+dnl FDO 3.8.1 Configuration
 dnl Include / lib paths
 # custom Fdo path specification
@@ -65,9 +96,9 @@
         [custom_inc=DEFAULT])
 if test $custom_inc = "DEFAULT"; then
-    map_fdo_include="/usr/local/fdo-3.8.0/include"
+    map_fdo_include="/usr/local/fdo-3.8.1/include"
     if test -d $map_fdo_include; then
-        AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-3.8.0/include])
+        AC_MSG_NOTICE([Building with default location of FDO include files at /usr/local/fdo-3.8.1/include])
     else
         AC_MSG_ERROR([the default FDO include path $map_fdo_include is not a valid directory. Please use the custom option])
     fi
@@ -87,9 +118,9 @@
         [custom_lib=DEFAULT])
 if test $custom_lib = "DEFAULT"; then
-    map_fdo_lib="/usr/local/fdo-3.8.0/lib"
+    map_fdo_lib="/usr/local/fdo-3.8.1/lib"
     if test -d $map_fdo_lib; then
-        AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-3.8.0/lib])
+        AC_MSG_NOTICE([Building with default location of FDO libraries at /usr/local/fdo-3.8.1/lib])
     else
         AC_MSG_ERROR([the default FDO lib path $map_fdo_lib is not a valid directory. Please use the custom option])
     fi
@@ -101,7 +132,7 @@
         AC_MSG_ERROR([the specified FDO library path $custom_lib is not a valid directory])
     fi
 fi
-map_fdo_nls="/usr/local/fdo-3.8.0/nls/%N"
+map_fdo_nls="/usr/local/fdo-3.8.1/nls/%N"
 AC_SUBST(map_fdo_include)
 AC_SUBST(map_fdo_lib)
 AC_SUBST(map_fdo_nls)
More information about the mapguide-commits mailing list
