[mapguide-commits] r7353 - branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal
svn_mapguide at osgeo.org
Fri Feb 15 01:26:51 PST 2013
Author: jng
Date: 2013-02-15 01:26:50 -0800 (Fri, 15 Feb 2013)
New Revision: 7353
branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.Designer.cs
branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.cs
branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.resx
#2217: Support the new resampling method parameter in GDAL Feature Source editor
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.Designer.cs
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.Designer.cs 2013-02-15 08:54:00 UTC (rev 7352)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.Designer.cs 2013-02-15 09:26:50 UTC (rev 7353)
@@ -35,11 +35,15 @@
this.btnTest = new System.Windows.Forms.Button();
this.label1 = new System.Windows.Forms.Label();
this.txtStatus = new System.Windows.Forms.TextBox();
+ this.lblResamplingMethod = new System.Windows.Forms.Label();
+ this.cmbResamplingMethod = new System.Windows.Forms.ComboBox();
this.contentPanel.SuspendLayout();
this.SuspendLayout();
// contentPanel
+ this.contentPanel.Controls.Add(this.cmbResamplingMethod);
+ this.contentPanel.Controls.Add(this.lblResamplingMethod);
this.contentPanel.Controls.Add(this.txtStatus);
this.contentPanel.Controls.Add(this.label1);
this.contentPanel.Controls.Add(this.btnTest);
@@ -88,12 +92,24 @@
this.txtStatus.Name = "txtStatus";
this.txtStatus.ReadOnly = true;
+ // lblResamplingMethod
+ resources.ApplyResources(this.lblResamplingMethod, "lblResamplingMethod");
+ this.lblResamplingMethod.Name = "lblResamplingMethod";
+ // cmbResamplingMethod
+ resources.ApplyResources(this.cmbResamplingMethod, "cmbResamplingMethod");
+ this.cmbResamplingMethod.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+ this.cmbResamplingMethod.FormattingEnabled = true;
+ this.cmbResamplingMethod.Name = "cmbResamplingMethod";
+ this.cmbResamplingMethod.SelectedIndexChanged += new System.EventHandler(this.cmbResamplingMethod_SelectedIndexChanged);
// GdalProviderCtrl
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
- this.HeaderText = "GDAL Feature Source";
+ resources.ApplyResources(this, "$this");
this.Name = "GdalProviderCtrl";
- resources.ApplyResources(this, "$this");
this.contentPanel.ResumeLayout(false);
this.contentPanel.PerformLayout();
this.ResumeLayout(false);
@@ -108,5 +124,7 @@
private System.Windows.Forms.Button btnTest;
private System.Windows.Forms.Label label1;
private System.Windows.Forms.TextBox txtStatus;
+ private System.Windows.Forms.ComboBox cmbResamplingMethod;
+ private System.Windows.Forms.Label lblResamplingMethod;
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.cs
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.cs 2013-02-15 08:54:00 UTC (rev 7352)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.cs 2013-02-15 09:26:50 UTC (rev 7353)
@@ -49,13 +49,37 @@
private bool _init = false;
+ private bool _bSupportsResample = false;
public override void Bind(IEditorService service)
try
_init = true;
+ _bSupportsResample = false;
_service = service;
_fs = (IFeatureSource)_service.GetEditedResource();
+ var provInfo = _service.FeatureService.GetFeatureProvider("OSGeo.Gdal");
+ foreach (var prop in provInfo.ConnectionProperties)
+ if (prop.Name == "ResamplingMethod")
+ lblResamplingMethod.Visible =
+ cmbResamplingMethod.Visible =
+ cmbResamplingMethod.Enabled = true;
+ cmbResamplingMethod.DataSource = new List<string>(prop.Value);
+ var method = _fs.GetConnectionProperty("ResamplingMethod");
+ if (!string.IsNullOrEmpty(method))
+ cmbResamplingMethod.SelectedItem = method;
+ else
+ cmbResamplingMethod.SelectedIndex = 0;
+ _bSupportsResample = true;
+ break;
_sing.Bind(service);
_comp.Bind(service);
if (!string.IsNullOrEmpty(_fs.GetConfigurationContent()))
@@ -101,5 +125,14 @@
string result = _fs.TestConnection();
txtStatus.Text = string.Format(Properties.Resources.FdoConnectionStatus, result);
+ private void cmbResamplingMethod_SelectedIndexChanged(object sender, EventArgs e)
+ if (!_bSupportsResample)
+ return;
+ if (cmbResamplingMethod.SelectedItem != null)
+ _fs.SetConnectionProperty("ResamplingMethod", cmbResamplingMethod.SelectedItem.ToString());
Modified: branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.resx
--- branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.resx 2013-02-15 08:54:00 UTC (rev 7352)
+++ branches/maestro-4.0.x/Maestro.Editors/FeatureSource/Providers/Gdal/GdalProviderCtrl.resx 2013-02-15 09:26:50 UTC (rev 7353)
@@ -112,20 +112,77 @@
<value>2.0</value>
</resheader>
<resheader name="reader">
- <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
<resheader name="writer">
- <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="cmbResamplingMethod.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Top, Left, Right</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="cmbResamplingMethod.Location" type="System.Drawing.Point, System.Drawing">
+ <value>316, 14</value>
+ </data>
+ <data name="cmbResamplingMethod.Size" type="System.Drawing.Size, System.Drawing">
+ <value>119, 21</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="cmbResamplingMethod.TabIndex" type="System.Int32, mscorlib">
+ <value>7</value>
+ </data>
+ <data name="cmbResamplingMethod.Visible" type="System.Boolean, mscorlib">
+ <value>False</value>
+ </data>
+ <data name=">>cmbResamplingMethod.Name" xml:space="preserve">
+ <value>cmbResamplingMethod</value>
+ </data>
+ <data name=">>cmbResamplingMethod.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ComboBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>cmbResamplingMethod.Parent" xml:space="preserve">
+ <value>contentPanel</value>
+ </data>
+ <data name=">>cmbResamplingMethod.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="lblResamplingMethod.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="lblResamplingMethod.Location" type="System.Drawing.Point, System.Drawing">
+ <value>209, 17</value>
+ </data>
+ <data name="lblResamplingMethod.Size" type="System.Drawing.Size, System.Drawing">
+ <value>101, 13</value>
+ </data>
+ <data name="lblResamplingMethod.TabIndex" type="System.Int32, mscorlib">
+ <value>6</value>
+ </data>
+ <data name="lblResamplingMethod.Text" xml:space="preserve">
+ <value>Resampling Method</value>
+ </data>
+ <data name="lblResamplingMethod.Visible" type="System.Boolean, mscorlib">
+ </data>
+ <data name=">>lblResamplingMethod.Name" xml:space="preserve">
+ <value>lblResamplingMethod</value>
+ </data>
+ <data name=">>lblResamplingMethod.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>lblResamplingMethod.Parent" xml:space="preserve">
+ </data>
+ <data name=">>lblResamplingMethod.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
<data name="txtStatus.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Bottom, Left, Right</value>
</data>
- <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="txtStatus.Location" type="System.Drawing.Point, System.Drawing">
<value>125, 209</value>
</data>
- <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="txtStatus.Multiline" type="System.Boolean, mscorlib">
<value>True</value>
</data>
@@ -139,13 +196,13 @@
<value>txtStatus</value>
</data>
<data name=">>txtStatus.Type" xml:space="preserve">
- <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.TextBox, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>txtStatus.Parent" xml:space="preserve">
</data>
<data name=">>txtStatus.ZOrder" xml:space="preserve">
- <value>0</value>
+ <value>2</value>
</data>
<data name="label1.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
@@ -166,13 +223,13 @@
<value>label1</value>
</data>
<data name=">>label1.Type" xml:space="preserve">
- <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>label1.Parent" xml:space="preserve">
</data>
<data name=">>label1.ZOrder" xml:space="preserve">
- <value>1</value>
+ <value>3</value>
</data>
<data name="btnTest.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Bottom, Left</value>
@@ -193,13 +250,13 @@
<value>btnTest</value>
</data>
<data name=">>btnTest.Type" xml:space="preserve">
- <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>btnTest.Parent" xml:space="preserve">
</data>
<data name=">>btnTest.ZOrder" xml:space="preserve">
- <value>2</value>
+ <value>4</value>
</data>
<data name="panel1.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -217,19 +274,19 @@
<value>panel1</value>
</data>
<data name=">>panel1.Type" xml:space="preserve">
- <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>panel1.Parent" xml:space="preserve">
</data>
<data name=">>panel1.ZOrder" xml:space="preserve">
- <value>3</value>
+ <value>5</value>
</data>
<data name="rdComposite.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
<data name="rdComposite.Location" type="System.Drawing.Point, System.Drawing">
- <value>125, 15</value>
+ <value>115, 15</value>
</data>
<data name="rdComposite.Size" type="System.Drawing.Size, System.Drawing">
<value>74, 17</value>
@@ -244,19 +301,19 @@
<value>rdComposite</value>
</data>
<data name=">>rdComposite.Type" xml:space="preserve">
- <value>System.Windows.Forms.RadioButton, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>System.Windows.Forms.RadioButton, System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name=">>rdComposite.Parent" xml:space="preserve">
</data>
<data name=">>rdComposite.ZOrder" xml:space="preserve">
- <value>4</value>
+ <value>6</value>
</data>
<data name="rdSingle.AutoSize" type="System.Boolean, mscorlib">
<value>True</value>
</data>
<data name="rdSingle.Location" type="System.Drawing.Point, System.Drawing">
- <value>65, 15</value>
+ <value>55, 15</value>
</data>
<data name="rdSingle.Size" type="System.Drawing.Size, System.Drawing">
<value>54, 17</value>
@@ -271,13 +328,13 @@
<value>rdSingle</value>
</data>
<data name=">>rdSingle.Type" xml:space="preserve">
</data>
<data name=">>rdSingle.Parent" xml:space="preserve">
</data>
<data name=">>rdSingle.ZOrder" xml:space="preserve">
- <value>5</value>
+ <value>7</value>
</data>
<data name="contentPanel.Size" type="System.Drawing.Size, System.Drawing">
<value>449, 250</value>
@@ -286,7 +343,7 @@
</data>
<data name=">>contentPanel.Type" xml:space="preserve">
</data>
<data name=">>contentPanel.Parent" xml:space="preserve">
<value>$this</value>
@@ -294,9 +351,12 @@
<data name=">>contentPanel.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
+ <data name="$this.HeaderText" xml:space="preserve">
+ <value>GDAL Feature Source</value>
+ </data>
<data name="$this.Size" type="System.Drawing.Size, System.Drawing">
<value>449, 277</value>
</data>
@@ -304,6 +364,6 @@
<value>GdalProviderCtrl</value>
</data>
<data name=">>$this.Type" xml:space="preserve">
- <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=3.0.0.5475, Culture=neutral, PublicKeyToken=null</value>
+ <value>Maestro.Editors.Common.EditorBindableCollapsiblePanel, Maestro.Editors, Version=5.0.0.6640, Culture=neutral, PublicKeyToken=f526c48929fda856</value>
</data>
</root>
\ No newline at end of file
More information about the mapguide-commits
