[mapguide-commits] r7356 - in trunk/MgDev: . BuildTools/WebTools/IMake Common/Foundation/System Common/MapGuideCommon/System Oem/DWFTK7.1/develop/global/build/gnu/dwfcore Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files Oem/DWFTK7.1/develop/global/src/dwfcore Oem/DWFTK7.1/develop/global/src/dwfcore/x64 Oem/SWIGEx Oem/agg-2.4/src Oem/gd/jpeg Server/src/Core Server/src/Gws/GwsQueryEngine Server/src/Gws/GwsQueryEngine/inc Server/src/Services/Feature Web/src/JavaApi Web/src/JavaApiEx
svn_mapguide at osgeo.org
Fri Feb 15 04:16:10 PST 2013
Author: jng
Date: 2013-02-15 04:16:10 -0800 (Fri, 15 Feb 2013)
New Revision: 7356
Added:
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/AUTHORS
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/COPYING
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ChangeLog
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/Doxyfile
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/INSTALL
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/NEWS
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/README
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/TODO
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.guess
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.sub
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/configure.in
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/depcomp
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/install-sh
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ltmain.sh
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/missing
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/mkinstalldirs
trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Makefile.am
Removed:
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/build_files.tar.gz
trunk/MgDev/BuildTools/WebTools/IMake/Makefile
trunk/MgDev/Common/Foundation/System/Resources.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/build_setup.sh
trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/Core.h
trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/Makefile.am
trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Core.cpp
trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Timer.cpp
trunk/MgDev/Oem/SWIGEx/Makefile
trunk/MgDev/Oem/agg-2.4/src/Makefile
trunk/MgDev/Oem/gd/jpeg/config.guess
trunk/MgDev/Oem/gd/jpeg/config.sub
trunk/MgDev/Server/src/Core/serverconfig.ini
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureQueryResults.cpp
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp
trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h
trunk/MgDev/Web/src/JavaApi/JavaApi.vcxproj
trunk/MgDev/Web/src/JavaApi/Makefile.am
trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj
trunk/MgDev/Web/src/JavaApiEx/Makefile.am
trunk/MgDev/configure.in
This is a merge to trunk of recent submissions made to the 2.5 branch
Tickets affected: #1657,#2202,#2105,#2181,#263,#2114,#2213
Revisions merged: r7314,r7315,r7316,r7317,r7318,r7319,r7320,r7321,r7322,r7323,r7327,r7329,r7331,r7333,r7334,r7338,r7344,r7345,r7349
Modified: trunk/MgDev/BuildTools/WebTools/IMake/Makefile
--- trunk/MgDev/BuildTools/WebTools/IMake/Makefile 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/BuildTools/WebTools/IMake/Makefile 2013-02-15 12:16:10 UTC (rev 7356)
@@ -12,8 +12,8 @@
CXX = g++
LEX = flex
YACC = yacc
-CFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions -DNDEBUG
-CXXFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions -DNDEBUG
+CFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -fno-use-cxa-atexit -fexceptions -DNDEBUG
+CXXFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -fno-use-cxa-atexit -fexceptions -DNDEBUG
LEXFLAGS =
YACCFLAGS= -d
INCPATH = -I$(QTDIR)/mkspecs/default -I.
Modified: trunk/MgDev/Common/Foundation/System/Resources.cpp
--- trunk/MgDev/Common/Foundation/System/Resources.cpp 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Common/Foundation/System/Resources.cpp 2013-02-15 12:16:10 UTC (rev 7356)
@@ -38,8 +38,8 @@
const STRING MgResources::ServerShuttingDown = L"Server shutting down...";
const STRING MgResources::ServerStarted = L"Server started.";
const STRING MgResources::ServerStopped = L"Server stopped.";
-const STRING MgResources::ServerServiceName = L"MapGuideServer2.4"; // Do not translate
-const STRING MgResources::ServerServiceDisplayName = L"MapGuide Server v2.4"; // Do not translate
+const STRING MgResources::ServerServiceName = L"MapGuideServer2.5"; // Do not translate
+const STRING MgResources::ServerServiceDisplayName = L"MapGuide Server v2.5"; // Do not translate
const STRING MgResources::ServerServiceDescription = L"The MapGuide Server process.";
const STRING MgResources::UsingDefaultResourceFile = L"Defaulting to the \"en\" resource file.";
const STRING MgResources::RegisteredLicenseDetected = L"Registered license detected...";
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2013-02-15 12:16:10 UTC (rev 7356)
@@ -280,6 +280,8 @@
const INT32 MgConfigProperties::DefaultFeatureServicePropertyDataTransactionTimerInterval = 60;
const STRING MgConfigProperties::FeatureServicePropertyFDOConnectionTimeoutCustom = L"FDOConnectionTimeoutCustom";
const STRING MgConfigProperties::DefaultFeatureServicePropertyFDOConnectionTimeoutCustom = L"OSGeo.WMS:120";
+const STRING MgConfigProperties::FeatureServicePropertyUseFdoJoinOptimization = L"UseFdoJoinOptimization";
+const bool MgConfigProperties::DefaultFeatureServicePropertyUseFdoJoinOptimization = true;
// Mapping Service Properties
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2013-02-15 12:16:10 UTC (rev 7356)
@@ -351,6 +351,10 @@
static const STRING FeatureServicePropertyFDOConnectionTimeoutCustom; /// value("FDOConnectionTimeoutCustom")
static const STRING DefaultFeatureServicePropertyFDOConnectionTimeoutCustom; /// value("OSGeo.WMS:120")
+ /// Defines whether to use the FDO Join APIs for Feature Joins where applicable and supported
+ static const STRING FeatureServicePropertyUseFdoJoinOptimization; /// value("UseFdoJoinOptimization")
+ static const bool DefaultFeatureServicePropertyUseFdoJoinOptimization; /// value(true)
/// MAPPING SERVICE PROPERTIES SECTION -------------------------------------------------------------------------------
/// Mapping Service properties
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/build_files.tar.gz
(Binary files differ)
Modified: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/build_setup.sh
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/build_setup.sh 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/build_setup.sh 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,12 +1,19 @@
#! /bin/bash
+# Backported from DWF Toolkit 7.7
+echo "Ensuring that files have no dos-ness..."
+cd files
+chmod +w *
+dos2unix -q *
+cd ..
+echo "Copying files..."
cd ../../../src/dwfcore
-tar -xzf ../../build/gnu/dwfcore/build_files.tar.gz
+cp -f ../../build/gnu/dwfcore/files/* .
+echo "Configuring..."
rm -rf autom4te.cache/
autoreconf --force
+echo "Done."
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/AUTHORS
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/AUTHORS 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/AUTHORS 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1 +0,0 @@
-Autodesk, Inc. <http://www.autodesk.com/dwf>
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/AUTHORS (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/AUTHORS)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/AUTHORS (rev 0)
@@ -0,0 +1 @@
+Autodesk, Inc. <http://www.autodesk.com/dwf>
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/COPYING
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/COPYING 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/COPYING 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,340 +0,0 @@
- GNU GENERAL PUBLIC LICENSE
- Version 2, June 1991
- Copyright (C) 1989, 1991 Free Software Foundation, Inc.
- 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
- Everyone is permitted to copy and distribute verbatim copies
- of this license document, but changing it is not allowed.
- Preamble
- The licenses for most software are designed to take away your
-freedom to share and change it. By contrast, the GNU General Public
-License is intended to guarantee your freedom to share and change free
-software--to make sure the software is free for all its users. This
-General Public License applies to most of the Free Software
-Foundation's software and to any other program whose authors commit to
-using it. (Some other Free Software Foundation software is covered by
-the GNU Library General Public License instead.) You can apply it to
-your programs, too.
- When we speak of free software, we are referring to freedom, not
-price. Our General Public Licenses are designed to make sure that you
-have the freedom to distribute copies of free software (and charge for
-this service if you wish), that you receive source code or can get it
-if you want it, that you can change the software or use pieces of it
-in new free programs; and that you know you can do these things.
- To protect your rights, we need to make restrictions that forbid
-anyone to deny you these rights or to ask you to surrender the rights.
-These restrictions translate to certain responsibilities for you if you
-distribute copies of the software, or if you modify it.
- For example, if you distribute copies of such a program, whether
-gratis or for a fee, you must give the recipients all the rights that
-you have. You must make sure that they, too, receive or can get the
-source code. And you must show them these terms so they know their
-rights.
- We protect your rights with two steps: (1) copyright the software, and
-(2) offer you this license which gives you legal permission to copy,
-distribute and/or modify the software.
- Also, for each author's protection and ours, we want to make certain
-that everyone understands that there is no warranty for this free
-software. If the software is modified by someone else and passed on, we
-want its recipients to know that what they have is not the original, so
-that any problems introduced by others will not reflect on the original
-authors' reputations.
- Finally, any free program is threatened constantly by software
-patents. We wish to avoid the danger that redistributors of a free
-program will individually obtain patent licenses, in effect making the
-program proprietary. To prevent this, we have made it clear that any
-patent must be licensed for everyone's free use or not licensed at all.
- The precise terms and conditions for copying, distribution and
-modification follow.
- TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
- 0. This License applies to any program or other work which contains
-a notice placed by the copyright holder saying it may be distributed
-under the terms of this General Public License. The "Program", below,
-refers to any such program or work, and a "work based on the Program"
-means either the Program or any derivative work under copyright law:
-that is to say, a work containing the Program or a portion of it,
-either verbatim or with modifications and/or translated into another
-language. (Hereinafter, translation is included without limitation in
-the term "modification".) Each licensee is addressed as "you".
-Activities other than copying, distribution and modification are not
-covered by this License; they are outside its scope. The act of
-running the Program is not restricted, and the output from the Program
-is covered only if its contents constitute a work based on the
-Program (independent of having been made by running the Program).
-Whether that is true depends on what the Program does.
- 1. You may copy and distribute verbatim copies of the Program's
-source code as you receive it, in any medium, provided that you
-conspicuously and appropriately publish on each copy an appropriate
-copyright notice and disclaimer of warranty; keep intact all the
-notices that refer to this License and to the absence of any warranty;
-and give any other recipients of the Program a copy of this License
-along with the Program.
-You may charge a fee for the physical act of transferring a copy, and
-you may at your option offer warranty protection in exchange for a fee.
- 2. You may modify your copy or copies of the Program or any portion
-of it, thus forming a work based on the Program, and copy and
-distribute such modifications or work under the terms of Section 1
-above, provided that you also meet all of these conditions:
- a) You must cause the modified files to carry prominent notices
- stating that you changed the files and the date of any change.
- b) You must cause any work that you distribute or publish, that in
- whole or in part contains or is derived from the Program or any
- part thereof, to be licensed as a whole at no charge to all third
- parties under the terms of this License.
- c) If the modified program normally reads commands interactively
- when run, you must cause it, when started running for such
- interactive use in the most ordinary way, to print or display an
- announcement including an appropriate copyright notice and a
- notice that there is no warranty (or else, saying that you provide
- a warranty) and that users may redistribute the program under
- these conditions, and telling the user how to view a copy of this
- License. (Exception: if the Program itself is interactive but
- does not normally print such an announcement, your work based on
- the Program is not required to print an announcement.)
-These requirements apply to the modified work as a whole. If
-identifiable sections of that work are not derived from the Program,
-and can be reasonably considered independent and separate works in
-themselves, then this License, and its terms, do not apply to those
-sections when you distribute them as separate works. But when you
-distribute the same sections as part of a whole which is a work based
-on the Program, the distribution of the whole must be on the terms of
-this License, whose permissions for other licensees extend to the
-entire whole, and thus to each and every part regardless of who wrote it.
-Thus, it is not the intent of this section to claim rights or contest
-your rights to work written entirely by you; rather, the intent is to
-exercise the right to control the distribution of derivative or
-collective works based on the Program.
-In addition, mere aggregation of another work not based on the Program
-with the Program (or with a work based on the Program) on a volume of
-a storage or distribution medium does not bring the other work under
-the scope of this License.
- 3. You may copy and distribute the Program (or a work based on it,
-under Section 2) in object code or executable form under the terms of
-Sections 1 and 2 above provided that you also do one of the following:
- a) Accompany it with the complete corresponding machine-readable
- source code, which must be distributed under the terms of Sections
- 1 and 2 above on a medium customarily used for software interchange; or,
- b) Accompany it with a written offer, valid for at least three
- years, to give any third party, for a charge no more than your
- cost of physically performing source distribution, a complete
- machine-readable copy of the corresponding source code, to be
- distributed under the terms of Sections 1 and 2 above on a medium
- customarily used for software interchange; or,
- c) Accompany it with the information you received as to the offer
- to distribute corresponding source code. (This alternative is
- allowed only for noncommercial distribution and only if you
- received the program in object code or executable form with such
- an offer, in accord with Subsection b above.)
-The source code for a work means the preferred form of the work for
-making modifications to it. For an executable work, complete source
-code means all the source code for all modules it contains, plus any
-associated interface definition files, plus the scripts used to
-control compilation and installation of the executable. However, as a
-special exception, the source code distributed need not include
-anything that is normally distributed (in either source or binary
-form) with the major components (compiler, kernel, and so on) of the
-operating system on which the executable runs, unless that component
-itself accompanies the executable.
-If distribution of executable or object code is made by offering
-access to copy from a designated place, then offering equivalent
-access to copy the source code from the same place counts as
-distribution of the source code, even though third parties are not
-compelled to copy the source along with the object code.
- 4. You may not copy, modify, sublicense, or distribute the Program
-except as expressly provided under this License. Any attempt
-otherwise to copy, modify, sublicense or distribute the Program is
-void, and will automatically terminate your rights under this License.
-However, parties who have received copies, or rights, from you under
-this License will not have their licenses terminated so long as such
-parties remain in full compliance.
- 5. You are not required to accept this License, since you have not
-signed it. However, nothing else grants you permission to modify or
-distribute the Program or its derivative works. These actions are
-prohibited by law if you do not accept this License. Therefore, by
-modifying or distributing the Program (or any work based on the
-Program), you indicate your acceptance of this License to do so, and
-all its terms and conditions for copying, distributing or modifying
-the Program or works based on it.
- 6. Each time you redistribute the Program (or any work based on the
-Program), the recipient automatically receives a license from the
-original licensor to copy, distribute or modify the Program subject to
-these terms and conditions. You may not impose any further
-restrictions on the recipients' exercise of the rights granted herein.
-You are not responsible for enforcing compliance by third parties to
-this License.
- 7. If, as a consequence of a court judgment or allegation of patent
-infringement or for any other reason (not limited to patent issues),
-conditions are imposed on you (whether by court order, agreement or
-otherwise) that contradict the conditions of this License, they do not
-excuse you from the conditions of this License. If you cannot
-distribute so as to satisfy simultaneously your obligations under this
-License and any other pertinent obligations, then as a consequence you
-may not distribute the Program at all. For example, if a patent
-license would not permit royalty-free redistribution of the Program by
-all those who receive copies directly or indirectly through you, then
-the only way you could satisfy both it and this License would be to
-refrain entirely from distribution of the Program.
-If any portion of this section is held invalid or unenforceable under
-any particular circumstance, the balance of the section is intended to
-apply and the section as a whole is intended to apply in other
-circumstances.
-It is not the purpose of this section to induce you to infringe any
-patents or other property right claims or to contest validity of any
-such claims; this section has the sole purpose of protecting the
-integrity of the free software distribution system, which is
-implemented by public license practices. Many people have made
-generous contributions to the wide range of software distributed
-through that system in reliance on consistent application of that
-system; it is up to the author/donor to decide if he or she is willing
-to distribute software through any other system and a licensee cannot
-impose that choice.
-This section is intended to make thoroughly clear what is believed to
-be a consequence of the rest of this License.
- 8. If the distribution and/or use of the Program is restricted in
-certain countries either by patents or by copyrighted interfaces, the
-original copyright holder who places the Program under this License
-may add an explicit geographical distribution limitation excluding
-those countries, so that distribution is permitted only in or among
-countries not thus excluded. In such case, this License incorporates
-the limitation as if written in the body of this License.
- 9. The Free Software Foundation may publish revised and/or new versions
-of the General Public License from time to time. Such new versions will
-be similar in spirit to the present version, but may differ in detail to
-address new problems or concerns.
-Each version is given a distinguishing version number. If the Program
-specifies a version number of this License which applies to it and "any
-later version", you have the option of following the terms and conditions
-either of that version or of any later version published by the Free
-Software Foundation. If the Program does not specify a version number of
-this License, you may choose any version ever published by the Free Software
-Foundation.
- 10. If you wish to incorporate parts of the Program into other free
-programs whose distribution conditions are different, write to the author
-to ask for permission. For software which is copyrighted by the Free
-Software Foundation, write to the Free Software Foundation; we sometimes
-make exceptions for this. Our decision will be guided by the two goals
-of preserving the free status of all derivatives of our free software and
-of promoting the sharing and reuse of software generally.
- NO WARRANTY
- 11. BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY
-FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW. EXCEPT WHEN
-OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES
-PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED
-OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
-MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS
-TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE
-PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING,
-REPAIR OR CORRECTION.
- 12. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING
-WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY AND/OR
-REDISTRIBUTE THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES,
-INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING
-OUT OF THE USE OR INABILITY TO USE THE PROGRAM (INCLUDING BUT NOT LIMITED
-TO LOSS OF DATA OR DATA BEING RENDERED INACCURATE OR LOSSES SUSTAINED BY
-YOU OR THIRD PARTIES OR A FAILURE OF THE PROGRAM TO OPERATE WITH ANY OTHER
-PROGRAMS), EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE
-POSSIBILITY OF SUCH DAMAGES.
- END OF TERMS AND CONDITIONS
- How to Apply These Terms to Your New Programs
- If you develop a new program, and you want it to be of the greatest
-possible use to the public, the best way to achieve this is to make it
-free software which everyone can redistribute and change under these terms.
- To do so, attach the following notices to the program. It is safest
-to attach them to the start of each source file to most effectively
-convey the exclusion of warranty; and each file should have at least
-the "copyright" line and a pointer to where the full notice is found.
- <one line to give the program's name and a brief idea of what it does.>
- Copyright (C) <year> <name of author>
- This program is free software; you can redistribute it and/or modify
- it under the terms of the GNU General Public License as published by
- the Free Software Foundation; either version 2 of the License, or
- (at your option) any later version.
- This program is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- GNU General Public License for more details.
- You should have received a copy of the GNU General Public License
- along with this program; if not, write to the Free Software
- Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
-Also add information on how to contact you by electronic and paper mail.
-If the program is interactive, make it output a short notice like this
-when it starts in an interactive mode:
- Gnomovision version 69, Copyright (C) year name of author
- Gnomovision comes with ABSOLUTELY NO WARRANTY; for details type `show w'.
- This is free software, and you are welcome to redistribute it
- under certain conditions; type `show c' for details.
-The hypothetical commands `show w' and `show c' should show the appropriate
-parts of the General Public License. Of course, the commands you use may
-be called something other than `show w' and `show c'; they could even be
-mouse-clicks or menu items--whatever suits your program.
-You should also get your employer (if you work as a programmer) or your
-school, if any, to sign a "copyright disclaimer" for the program, if
-necessary. Here is a sample; alter the names:
- Yoyodyne, Inc., hereby disclaims all copyright interest in the program
- `Gnomovision' (which makes passes at compilers) written by James Hacker.
- <signature of Ty Coon>, 1 April 1989
- Ty Coon, President of Vice
-This General Public License does not permit incorporating your program into
-proprietary programs. If your program is a subroutine library, you may
-consider it more useful to permit linking proprietary applications with the
-library. If this is what you want to do, use the GNU Library General
-Public License instead of this License.
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/COPYING (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/COPYING)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/COPYING (rev 0)
@@ -0,0 +1,340 @@
+ GNU GENERAL PUBLIC LICENSE
+ Version 2, June 1991
+ Copyright (C) 1989, 1991 Free Software Foundation, Inc.
+ 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
+ Everyone is permitted to copy and distribute verbatim copies
+ of this license document, but changing it is not allowed.
+ Preamble
+ The licenses for most software are designed to take away your
+freedom to share and change it. By contrast, the GNU General Public
+License is intended to guarantee your freedom to share and change free
+software--to make sure the software is free for all its users. This
+General Public License applies to most of the Free Software
+Foundation's software and to any other program whose authors commit to
+using it. (Some other Free Software Foundation software is covered by
+the GNU Library General Public License instead.) You can apply it to
+your programs, too.
+ When we speak of free software, we are referring to freedom, not
+price. Our General Public Licenses are designed to make sure that you
+have the freedom to distribute copies of free software (and charge for
+this service if you wish), that you receive source code or can get it
+if you want it, that you can change the software or use pieces of it
+in new free programs; and that you know you can do these things.
+ To protect your rights, we need to make restrictions that forbid
+anyone to deny you these rights or to ask you to surrender the rights.
+These restrictions translate to certain responsibilities for you if you
+distribute copies of the software, or if you modify it.
+ For example, if you distribute copies of such a program, whether
+gratis or for a fee, you must give the recipients all the rights that
+you have. You must make sure that they, too, receive or can get the
+source code. And you must show them these terms so they know their
+rights.
+ We protect your rights with two steps: (1) copyright the software, and
+(2) offer you this license which gives you legal permission to copy,
+distribute and/or modify the software.
+ Also, for each author's protection and ours, we want to make certain
+that everyone understands that there is no warranty for this free
+software. If the software is modified by someone else and passed on, we
+want its recipients to know that what they have is not the original, so
+that any problems introduced by others will not reflect on the original
+authors' reputations.
+ Finally, any free program is threatened constantly by software
+patents. We wish to avoid the danger that redistributors of a free
+program will individually obtain patent licenses, in effect making the
+program proprietary. To prevent this, we have made it clear that any
+patent must be licensed for everyone's free use or not licensed at all.
+ The precise terms and conditions for copying, distribution and
+modification follow.
+ TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
+ 0. This License applies to any program or other work which contains
+a notice placed by the copyright holder saying it may be distributed
+under the terms of this General Public License. The "Program", below,
+refers to any such program or work, and a "work based on the Program"
+means either the Program or any derivative work under copyright law:
+that is to say, a work containing the Program or a portion of it,
+either verbatim or with modifications and/or translated into another
+language. (Hereinafter, translation is included without limitation in
+the term "modification".) Each licensee is addressed as "you".
+Activities other than copying, distribution and modification are not
+covered by this License; they are outside its scope. The act of
+running the Program is not restricted, and the output from the Program
+is covered only if its contents constitute a work based on the
+Program (independent of having been made by running the Program).
+Whether that is true depends on what the Program does.
+ 1. You may copy and distribute verbatim copies of the Program's
+source code as you receive it, in any medium, provided that you
+conspicuously and appropriately publish on each copy an appropriate
+copyright notice and disclaimer of warranty; keep intact all the
+notices that refer to this License and to the absence of any warranty;
+and give any other recipients of the Program a copy of this License
+along with the Program.
+You may charge a fee for the physical act of transferring a copy, and
+you may at your option offer warranty protection in exchange for a fee.
+ 2. You may modify your copy or copies of the Program or any portion
+of it, thus forming a work based on the Program, and copy and
+distribute such modifications or work under the terms of Section 1
+above, provided that you also meet all of these conditions:
+ a) You must cause the modified files to carry prominent notices
+ stating that you changed the files and the date of any change.
+ b) You must cause any work that you distribute or publish, that in
+ whole or in part contains or is derived from the Program or any
+ part thereof, to be licensed as a whole at no charge to all third
+ parties under the terms of this License.
+ c) If the modified program normally reads commands interactively
+ when run, you must cause it, when started running for such
+ interactive use in the most ordinary way, to print or display an
+ announcement including an appropriate copyright notice and a
+ notice that there is no warranty (or else, saying that you provide
+ a warranty) and that users may redistribute the program under
+ these conditions, and telling the user how to view a copy of this
+ License. (Exception: if the Program itself is interactive but
+ does not normally print such an announcement, your work based on
+ the Program is not required to print an announcement.)
+These requirements apply to the modified work as a whole. If
+identifiable sections of that work are not derived from the Program,
+and can be reasonably considered independent and separate works in
+themselves, then this License, and its terms, do not apply to those
+sections when you distribute them as separate works. But when you
+distribute the same sections as part of a whole which is a work based
+on the Program, the distribution of the whole must be on the terms of
+this License, whose permissions for other licensees extend to the
+entire whole, and thus to each and every part regardless of who wrote it.
+Thus, it is not the intent of this section to claim rights or contest
+your rights to work written entirely by you; rather, the intent is to
+exercise the right to control the distribution of derivative or
+collective works based on the Program.
+In addition, mere aggregation of another work not based on the Program
+with the Program (or with a work based on the Program) on a volume of
+a storage or distribution medium does not bring the other work under
+the scope of this License.
+ 3. You may copy and distribute the Program (or a work based on it,
+under Section 2) in object code or executable form under the terms of
+Sections 1 and 2 above provided that you also do one of the following:
+ a) Accompany it with the complete corresponding machine-readable
+ source code, which must be distributed under the terms of Sections
+ 1 and 2 above on a medium customarily used for software interchange; or,
+ b) Accompany it with a written offer, valid for at least three
+ years, to give any third party, for a charge no more than your
+ cost of physically performing source distribution, a complete
+ machine-readable copy of the corresponding source code, to be
+ distributed under the terms of Sections 1 and 2 above on a medium
+ customarily used for software interchange; or,
+ c) Accompany it with the information you received as to the offer
+ to distribute corresponding source code. (This alternative is
+ allowed only for noncommercial distribution and only if you
+ received the program in object code or executable form with such
+ an offer, in accord with Subsection b above.)
+The source code for a work means the preferred form of the work for
+making modifications to it. For an executable work, complete source
+code means all the source code for all modules it contains, plus any
+associated interface definition files, plus the scripts used to
+control compilation and installation of the executable. However, as a
+special exception, the source code distributed need not include
+anything that is normally distributed (in either source or binary
+form) with the major components (compiler, kernel, and so on) of the
+operating system on which the executable runs, unless that component
+itself accompanies the executable.
+If distribution of executable or object code is made by offering
+access to copy from a designated place, then offering equivalent
+access to copy the source code from the same place counts as
+distribution of the source code, even though third parties are not
+compelled to copy the source along with the object code.
+ 4. You may not copy, modify, sublicense, or distribute the Program
+except as expressly provided under this License. Any attempt
+otherwise to copy, modify, sublicense or distribute the Program is
+void, and will automatically terminate your rights under this License.
+However, parties who have received copies, or rights, from you under
+this License will not have their licenses terminated so long as such
+parties remain in full compliance.
+ 5. You are not required to accept this License, since you have not
+signed it. However, nothing else grants you permission to modify or
+distribute the Program or its derivative works. These actions are
+prohibited by law if you do not accept this License. Therefore, by
+modifying or distributing the Program (or any work based on the
+Program), you indicate your acceptance of this License to do so, and
+all its terms and conditions for copying, distributing or modifying
+the Program or works based on it.
+ 6. Each time you redistribute the Program (or any work based on the
+Program), the recipient automatically receives a license from the
+original licensor to copy, distribute or modify the Program subject to
+these terms and conditions. You may not impose any further
+restrictions on the recipients' exercise of the rights granted herein.
+You are not responsible for enforcing compliance by third parties to
+this License.
+ 7. If, as a consequence of a court judgment or allegation of patent
+infringement or for any other reason (not limited to patent issues),
+conditions are imposed on you (whether by court order, agreement or
+otherwise) that contradict the conditions of this License, they do not
+excuse you from the conditions of this License. If you cannot
+distribute so as to satisfy simultaneously your obligations under this
+License and any other pertinent obligations, then as a consequence you
+may not distribute the Program at all. For example, if a patent
+license would not permit royalty-free redistribution of the Program by
+all those who receive copies directly or indirectly through you, then
+the only way you could satisfy both it and this License would be to
+refrain entirely from distribution of the Program.
+If any portion of this section is held invalid or unenforceable under
+any particular circumstance, the balance of the section is intended to
+apply and the section as a whole is intended to apply in other
+circumstances.
+It is not the purpose of this section to induce you to infringe any
+patents or other property right claims or to contest validity of any
+such claims; this section has the sole purpose of protecting the
+integrity of the free software distribution system, which is
+implemented by public license practices. Many people have made
+generous contributions to the wide range of software distributed
+through that system in reliance on consistent application of that
+system; it is up to the author/donor to decide if he or she is willing
+to distribute software through any other system and a licensee cannot
+impose that choice.
+This section is intended to make thoroughly clear what is believed to
+be a consequence of the rest of this License.
+ 8. If the distribution and/or use of the Program is restricted in
+certain countries either by patents or by copyrighted interfaces, the
+original copyright holder who places the Program under this License
+may add an explicit geographical distribution limitation excluding
+those countries, so that distribution is permitted only in or among
+countries not thus excluded. In such case, this License incorporates
+the limitation as if written in the body of this License.
+ 9. The Free Software Foundation may publish revised and/or new versions
+of the General Public License from time to time. Such new versions will
+be similar in spirit to the present version, but may differ in detail to
+address new problems or concerns.
+Each version is given a distinguishing version number. If the Program
+specifies a version number of this License which applies to it and "any
+later version", you have the option of following the terms and conditions
+either of that version or of any later version published by the Free
+Software Foundation. If the Program does not specify a version number of
+this License, you may choose any version ever published by the Free Software
+Foundation.
+ 10. If you wish to incorporate parts of the Program into other free
+programs whose distribution conditions are different, write to the author
+to ask for permission. For software which is copyrighted by the Free
+Software Foundation, write to the Free Software Foundation; we sometimes
+make exceptions for this. Our decision will be guided by the two goals
+of preserving the free status of all derivatives of our free software and
+of promoting the sharing and reuse of software generally.
+ NO WARRANTY
+ 11. BECAUSE THE PROGRAM IS LICENSED FREE OF CHARGE, THERE IS NO WARRANTY
+FOR THE PROGRAM, TO THE EXTENT PERMITTED BY APPLICABLE LAW. EXCEPT WHEN
+OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR OTHER PARTIES
+PROVIDE THE PROGRAM "AS IS" WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESSED
+OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. THE ENTIRE RISK AS
+TO THE QUALITY AND PERFORMANCE OF THE PROGRAM IS WITH YOU. SHOULD THE
+PROGRAM PROVE DEFECTIVE, YOU ASSUME THE COST OF ALL NECESSARY SERVICING,
+REPAIR OR CORRECTION.
+ 12. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN WRITING
+WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY AND/OR
+REDISTRIBUTE THE PROGRAM AS PERMITTED ABOVE, BE LIABLE TO YOU FOR DAMAGES,
+INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR CONSEQUENTIAL DAMAGES ARISING
+OUT OF THE USE OR INABILITY TO USE THE PROGRAM (INCLUDING BUT NOT LIMITED
+TO LOSS OF DATA OR DATA BEING RENDERED INACCURATE OR LOSSES SUSTAINED BY
+YOU OR THIRD PARTIES OR A FAILURE OF THE PROGRAM TO OPERATE WITH ANY OTHER
+PROGRAMS), EVEN IF SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE
+POSSIBILITY OF SUCH DAMAGES.
+ END OF TERMS AND CONDITIONS
+ How to Apply These Terms to Your New Programs
+ If you develop a new program, and you want it to be of the greatest
+possible use to the public, the best way to achieve this is to make it
+free software which everyone can redistribute and change under these terms.
+ To do so, attach the following notices to the program. It is safest
+to attach them to the start of each source file to most effectively
+convey the exclusion of warranty; and each file should have at least
+the "copyright" line and a pointer to where the full notice is found.
+ <one line to give the program's name and a brief idea of what it does.>
+ Copyright (C) <year> <name of author>
+ This program is free software; you can redistribute it and/or modify
+ it under the terms of the GNU General Public License as published by
+ the Free Software Foundation; either version 2 of the License, or
+ (at your option) any later version.
+ This program is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ GNU General Public License for more details.
+ You should have received a copy of the GNU General Public License
+ along with this program; if not, write to the Free Software
+ Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
+Also add information on how to contact you by electronic and paper mail.
+If the program is interactive, make it output a short notice like this
+when it starts in an interactive mode:
+ Gnomovision version 69, Copyright (C) year name of author
+ Gnomovision comes with ABSOLUTELY NO WARRANTY; for details type `show w'.
+ This is free software, and you are welcome to redistribute it
+ under certain conditions; type `show c' for details.
+The hypothetical commands `show w' and `show c' should show the appropriate
+parts of the General Public License. Of course, the commands you use may
+be called something other than `show w' and `show c'; they could even be
+mouse-clicks or menu items--whatever suits your program.
+You should also get your employer (if you work as a programmer) or your
+school, if any, to sign a "copyright disclaimer" for the program, if
+necessary. Here is a sample; alter the names:
+ Yoyodyne, Inc., hereby disclaims all copyright interest in the program
+ `Gnomovision' (which makes passes at compilers) written by James Hacker.
+ <signature of Ty Coon>, 1 April 1989
+ Ty Coon, President of Vice
+This General Public License does not permit incorporating your program into
+proprietary programs. If your program is a subroutine library, you may
+consider it more useful to permit linking proprietary applications with the
+library. If this is what you want to do, use the GNU Library General
+Public License instead of this License.
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ChangeLog
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ChangeLog (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ChangeLog)
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/Doxyfile
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/Doxyfile 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/Doxyfile 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,248 +0,0 @@
-# Doxyfile 1.3.5-KDevelop
-# Project related configuration options
-PROJECT_NAME = dwfcore.kdevelop
-PROJECT_NUMBER = 1.0
-OUTPUT_DIRECTORY =
-OUTPUT_LANGUAGE = English
-USE_WINDOWS_ENCODING = NO
-BRIEF_MEMBER_DESC = YES
-REPEAT_BRIEF = YES
-ABBREVIATE_BRIEF = "The $name class" \
- "The $name widget" \
- "The $name file" \
- is \
- provides \
- specifies \
- contains \
- represents \
- a \
- an \
- the
-ALWAYS_DETAILED_SEC = NO
-INLINE_INHERITED_MEMB = NO
-FULL_PATH_NAMES = NO
-STRIP_FROM_PATH = /home/garrick/development/autodesk/Bianchi/develop/global/build/KDevelop3.0/dwfcore/
-SHORT_NAMES = NO
-JAVADOC_AUTOBRIEF = NO
-MULTILINE_CPP_IS_BRIEF = NO
-DETAILS_AT_TOP = NO
-INHERIT_DOCS = YES
-DISTRIBUTE_GROUP_DOC = NO
-TAB_SIZE = 8
-ALIASES =
-OPTIMIZE_OUTPUT_FOR_C = NO
-OPTIMIZE_OUTPUT_JAVA = NO
-SUBGROUPING = YES
-# Build related configuration options
-EXTRACT_ALL = NO
-EXTRACT_PRIVATE = NO
-EXTRACT_STATIC = NO
-EXTRACT_LOCAL_CLASSES = YES
-HIDE_UNDOC_MEMBERS = NO
-HIDE_UNDOC_CLASSES = NO
-HIDE_FRIEND_COMPOUNDS = NO
-HIDE_IN_BODY_DOCS = NO
-INTERNAL_DOCS = NO
-CASE_SENSE_NAMES = YES
-HIDE_SCOPE_NAMES = NO
-SHOW_INCLUDE_FILES = YES
-INLINE_INFO = YES
-SORT_MEMBER_DOCS = YES
-SORT_BRIEF_DOCS = NO
-SORT_BY_SCOPE_NAME = NO
-GENERATE_TODOLIST = YES
-GENERATE_TESTLIST = YES
-GENERATE_BUGLIST = YES
-GENERATE_DEPRECATEDLIST= YES
-ENABLED_SECTIONS =
-MAX_INITIALIZER_LINES = 30
-SHOW_USED_FILES = YES
-# configuration options related to warning and progress messages
-QUIET = NO
-WARNINGS = YES
-WARN_IF_UNDOCUMENTED = YES
-WARN_IF_DOC_ERROR = YES
-WARN_FORMAT = "$file:$line: $text"
-WARN_LOGFILE =
-# configuration options related to the input files
-INPUT = /home/garrick/development/autodesk/Bianchi/develop/global/build/KDevelop3.0/dwfcore
-FILE_PATTERNS = *.c \
- *.cc \
- *.cxx \
- *.cpp \
- *.c++ \
- *.java \
- *.ii \
- *.ixx \
- *.ipp \
- *.i++ \
- *.inl \
- *.h \
- *.hh \
- *.hxx \
- *.hpp \
- *.h++ \
- *.idl \
- *.odl \
- *.cs \
- *.php \
- *.php3 \
- *.inc \
- *.C \
- *.H \
- *.tlh \
- *.diff \
- *.patch \
- *.moc \
- *.xpm \
- *.dox
-RECURSIVE = yes
-EXCLUDE =
-EXCLUDE_SYMLINKS = NO
-EXCLUDE_PATTERNS =
-EXAMPLE_PATH =
-EXAMPLE_PATTERNS = *
-EXAMPLE_RECURSIVE = NO
-IMAGE_PATH =
-INPUT_FILTER =
-FILTER_SOURCE_FILES = NO
-# configuration options related to source browsing
-SOURCE_BROWSER = NO
-INLINE_SOURCES = NO
-STRIP_CODE_COMMENTS = YES
-REFERENCED_BY_RELATION = YES
-REFERENCES_RELATION = YES
-VERBATIM_HEADERS = YES
-# configuration options related to the alphabetical class index
-ALPHABETICAL_INDEX = NO
-COLS_IN_ALPHA_INDEX = 5
-IGNORE_PREFIX =
-# configuration options related to the HTML output
-GENERATE_HTML = YES
-HTML_OUTPUT = html
-HTML_FILE_EXTENSION = .html
-HTML_HEADER =
-HTML_FOOTER =
-HTML_STYLESHEET =
-HTML_ALIGN_MEMBERS = YES
-GENERATE_HTMLHELP = NO
-CHM_FILE =
-HHC_LOCATION =
-GENERATE_CHI = NO
-BINARY_TOC = NO
-TOC_EXPAND = NO
-DISABLE_INDEX = NO
-ENUM_VALUES_PER_LINE = 4
-GENERATE_TREEVIEW = NO
-TREEVIEW_WIDTH = 250
-# configuration options related to the LaTeX output
-GENERATE_LATEX = YES
-LATEX_OUTPUT = latex
-LATEX_CMD_NAME = latex
-MAKEINDEX_CMD_NAME = makeindex
-COMPACT_LATEX = NO
-PAPER_TYPE = a4wide
-EXTRA_PACKAGES =
-LATEX_HEADER =
-PDF_HYPERLINKS = NO
-USE_PDFLATEX = NO
-LATEX_BATCHMODE = NO
-LATEX_HIDE_INDICES = NO
-# configuration options related to the RTF output
-GENERATE_RTF = NO
-RTF_OUTPUT = rtf
-COMPACT_RTF = NO
-RTF_HYPERLINKS = NO
-RTF_STYLESHEET_FILE =
-RTF_EXTENSIONS_FILE =
-# configuration options related to the man page output
-GENERATE_MAN = NO
-MAN_OUTPUT = man
-MAN_EXTENSION = .3
-MAN_LINKS = NO
-# configuration options related to the XML output
-GENERATE_XML = yes
-XML_OUTPUT = xml
-XML_SCHEMA =
-XML_DTD =
-XML_PROGRAMLISTING = YES
-# configuration options for the AutoGen Definitions output
-GENERATE_AUTOGEN_DEF = NO
-# configuration options related to the Perl module output
-GENERATE_PERLMOD = NO
-PERLMOD_LATEX = NO
-PERLMOD_PRETTY = YES
-PERLMOD_MAKEVAR_PREFIX =
-# Configuration options related to the preprocessor
-ENABLE_PREPROCESSING = YES
-MACRO_EXPANSION = NO
-EXPAND_ONLY_PREDEF = NO
-SEARCH_INCLUDES = YES
-INCLUDE_PATH =
-INCLUDE_FILE_PATTERNS =
-PREDEFINED =
-EXPAND_AS_DEFINED =
-SKIP_FUNCTION_MACROS = YES
-# Configuration::additions related to external references
-TAGFILES =
-GENERATE_TAGFILE =
-ALLEXTERNALS = NO
-EXTERNAL_GROUPS = YES
-PERL_PATH = /usr/bin/perl
-# Configuration options related to the dot tool
-CLASS_DIAGRAMS = YES
-HIDE_UNDOC_RELATIONS = YES
-HAVE_DOT = NO
-CLASS_GRAPH = YES
-COLLABORATION_GRAPH = YES
-UML_LOOK = NO
-TEMPLATE_RELATIONS = NO
-INCLUDE_GRAPH = YES
-INCLUDED_BY_GRAPH = YES
-CALL_GRAPH = NO
-GRAPHICAL_HIERARCHY = YES
-DOT_IMAGE_FORMAT = png
-DOT_PATH =
-DOTFILE_DIRS =
-MAX_DOT_GRAPH_WIDTH = 1024
-MAX_DOT_GRAPH_HEIGHT = 1024
-MAX_DOT_GRAPH_DEPTH = 1000
-GENERATE_LEGEND = YES
-DOT_CLEANUP = YES
-# Configuration::additions related to the search engine
-SEARCHENGINE = NO
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/Doxyfile (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/Doxyfile)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/Doxyfile (rev 0)
@@ -0,0 +1,248 @@
+# Doxyfile 1.3.5-KDevelop
+# Project related configuration options
+PROJECT_NAME = dwfcore.kdevelop
+PROJECT_NUMBER = 1.0
+OUTPUT_DIRECTORY =
+OUTPUT_LANGUAGE = English
+USE_WINDOWS_ENCODING = NO
+BRIEF_MEMBER_DESC = YES
+REPEAT_BRIEF = YES
+ABBREVIATE_BRIEF = "The $name class" \
+ "The $name widget" \
+ "The $name file" \
+ is \
+ provides \
+ specifies \
+ contains \
+ represents \
+ a \
+ an \
+ the
+ALWAYS_DETAILED_SEC = NO
+INLINE_INHERITED_MEMB = NO
+FULL_PATH_NAMES = NO
+STRIP_FROM_PATH = /home/garrick/development/autodesk/Bianchi/develop/global/build/KDevelop3.0/dwfcore/
+SHORT_NAMES = NO
+JAVADOC_AUTOBRIEF = NO
+MULTILINE_CPP_IS_BRIEF = NO
+DETAILS_AT_TOP = NO
+INHERIT_DOCS = YES
+DISTRIBUTE_GROUP_DOC = NO
+TAB_SIZE = 8
+ALIASES =
+OPTIMIZE_OUTPUT_FOR_C = NO
+OPTIMIZE_OUTPUT_JAVA = NO
+SUBGROUPING = YES
+# Build related configuration options
+EXTRACT_ALL = NO
+EXTRACT_PRIVATE = NO
+EXTRACT_STATIC = NO
+EXTRACT_LOCAL_CLASSES = YES
+HIDE_UNDOC_MEMBERS = NO
+HIDE_UNDOC_CLASSES = NO
+HIDE_FRIEND_COMPOUNDS = NO
+HIDE_IN_BODY_DOCS = NO
+INTERNAL_DOCS = NO
+CASE_SENSE_NAMES = YES
+HIDE_SCOPE_NAMES = NO
+SHOW_INCLUDE_FILES = YES
+INLINE_INFO = YES
+SORT_MEMBER_DOCS = YES
+SORT_BRIEF_DOCS = NO
+SORT_BY_SCOPE_NAME = NO
+GENERATE_TODOLIST = YES
+GENERATE_TESTLIST = YES
+GENERATE_BUGLIST = YES
+GENERATE_DEPRECATEDLIST= YES
+ENABLED_SECTIONS =
+MAX_INITIALIZER_LINES = 30
+SHOW_USED_FILES = YES
+# configuration options related to warning and progress messages
+QUIET = NO
+WARNINGS = YES
+WARN_IF_UNDOCUMENTED = YES
+WARN_IF_DOC_ERROR = YES
+WARN_FORMAT = "$file:$line: $text"
+WARN_LOGFILE =
+# configuration options related to the input files
+INPUT = /home/garrick/development/autodesk/Bianchi/develop/global/build/KDevelop3.0/dwfcore
+FILE_PATTERNS = *.c \
+ *.cc \
+ *.cxx \
+ *.cpp \
+ *.c++ \
+ *.java \
+ *.ii \
+ *.ixx \
+ *.ipp \
+ *.i++ \
+ *.inl \
+ *.h \
+ *.hh \
+ *.hxx \
+ *.hpp \
+ *.h++ \
+ *.idl \
+ *.odl \
+ *.cs \
+ *.php \
+ *.php3 \
+ *.inc \
+ *.C \
+ *.H \
+ *.tlh \
+ *.diff \
+ *.patch \
+ *.moc \
+ *.xpm \
+ *.dox
+RECURSIVE = yes
+EXCLUDE =
+EXCLUDE_SYMLINKS = NO
+EXCLUDE_PATTERNS =
+EXAMPLE_PATH =
+EXAMPLE_PATTERNS = *
+EXAMPLE_RECURSIVE = NO
+IMAGE_PATH =
+INPUT_FILTER =
+FILTER_SOURCE_FILES = NO
+# configuration options related to source browsing
+SOURCE_BROWSER = NO
+INLINE_SOURCES = NO
+STRIP_CODE_COMMENTS = YES
+REFERENCED_BY_RELATION = YES
+REFERENCES_RELATION = YES
+VERBATIM_HEADERS = YES
+# configuration options related to the alphabetical class index
+ALPHABETICAL_INDEX = NO
+COLS_IN_ALPHA_INDEX = 5
+IGNORE_PREFIX =
+# configuration options related to the HTML output
+GENERATE_HTML = YES
+HTML_OUTPUT = html
+HTML_FILE_EXTENSION = .html
+HTML_HEADER =
+HTML_FOOTER =
+HTML_STYLESHEET =
+HTML_ALIGN_MEMBERS = YES
+GENERATE_HTMLHELP = NO
+CHM_FILE =
+HHC_LOCATION =
+GENERATE_CHI = NO
+BINARY_TOC = NO
+TOC_EXPAND = NO
+DISABLE_INDEX = NO
+ENUM_VALUES_PER_LINE = 4
+GENERATE_TREEVIEW = NO
+TREEVIEW_WIDTH = 250
+# configuration options related to the LaTeX output
+GENERATE_LATEX = YES
+LATEX_OUTPUT = latex
+LATEX_CMD_NAME = latex
+MAKEINDEX_CMD_NAME = makeindex
+COMPACT_LATEX = NO
+PAPER_TYPE = a4wide
+EXTRA_PACKAGES =
+LATEX_HEADER =
+PDF_HYPERLINKS = NO
+USE_PDFLATEX = NO
+LATEX_BATCHMODE = NO
+LATEX_HIDE_INDICES = NO
+# configuration options related to the RTF output
+GENERATE_RTF = NO
+RTF_OUTPUT = rtf
+COMPACT_RTF = NO
+RTF_HYPERLINKS = NO
+RTF_STYLESHEET_FILE =
+RTF_EXTENSIONS_FILE =
+# configuration options related to the man page output
+GENERATE_MAN = NO
+MAN_OUTPUT = man
+MAN_EXTENSION = .3
+MAN_LINKS = NO
+# configuration options related to the XML output
+GENERATE_XML = yes
+XML_OUTPUT = xml
+XML_SCHEMA =
+XML_DTD =
+XML_PROGRAMLISTING = YES
+# configuration options for the AutoGen Definitions output
+GENERATE_AUTOGEN_DEF = NO
+# configuration options related to the Perl module output
+GENERATE_PERLMOD = NO
+PERLMOD_LATEX = NO
+PERLMOD_PRETTY = YES
+PERLMOD_MAKEVAR_PREFIX =
+# Configuration options related to the preprocessor
+ENABLE_PREPROCESSING = YES
+MACRO_EXPANSION = NO
+EXPAND_ONLY_PREDEF = NO
+SEARCH_INCLUDES = YES
+INCLUDE_PATH =
+INCLUDE_FILE_PATTERNS =
+PREDEFINED =
+EXPAND_AS_DEFINED =
+SKIP_FUNCTION_MACROS = YES
+# Configuration::additions related to external references
+TAGFILES =
+GENERATE_TAGFILE =
+ALLEXTERNALS = NO
+EXTERNAL_GROUPS = YES
+PERL_PATH = /usr/bin/perl
+# Configuration options related to the dot tool
+CLASS_DIAGRAMS = YES
+HIDE_UNDOC_RELATIONS = YES
+HAVE_DOT = NO
+CLASS_GRAPH = YES
+COLLABORATION_GRAPH = YES
+UML_LOOK = NO
+TEMPLATE_RELATIONS = NO
+INCLUDE_GRAPH = YES
+INCLUDED_BY_GRAPH = YES
+CALL_GRAPH = NO
+GRAPHICAL_HIERARCHY = YES
+DOT_IMAGE_FORMAT = png
+DOT_PATH =
+DOTFILE_DIRS =
+MAX_DOT_GRAPH_WIDTH = 1024
+MAX_DOT_GRAPH_HEIGHT = 1024
+MAX_DOT_GRAPH_DEPTH = 1000
+GENERATE_LEGEND = YES
+DOT_CLEANUP = YES
+# Configuration::additions related to the search engine
+SEARCHENGINE = NO
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/INSTALL
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/INSTALL 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/INSTALL 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,167 +0,0 @@
-Basic Installation
- These are generic installation instructions.
- The `configure' shell script attempts to guess correct values for
-various system-dependent variables used during compilation. It uses
-those values to create a `Makefile' in each directory of the package.
-It may also create one or more `.h' files containing system-dependent
-definitions. Finally, it creates a shell script `config.status' that
-you can run in the future to recreate the current configuration, a file
-`config.cache' that saves the results of its tests to speed up
-reconfiguring, and a file `config.log' containing compiler output
-(useful mainly for debugging `configure').
- If you need to do unusual things to compile the package, please try
-to figure out how `configure' could check whether to do them, and mail
-diffs or instructions to the address given in the `README' so they can
-be considered for the next release. If at some point `config.cache'
-contains results you don't want to keep, you may remove or edit it.
- The file `configure.in' is used to create `configure' by a program
-called `autoconf'. You only need `configure.in' if you want to change
-it or regenerate `configure' using a newer version of `autoconf'.
-The simplest way to compile this package is:
- 1. `cd' to the directory containing the package's source code and type
- `./configure' to configure the package for your system. If you're
- using `csh' on an old version of System V, you might need to type
- `sh ./configure' instead to prevent `csh' from trying to execute
- `configure' itself.
- Running `configure' takes a while. While running, it prints some
- messages telling which features it is checking for.
- 2. Type `make' to compile the package.
- 3. Type `make install' to install the programs and any data files and
- documentation.
- 4. You can remove the program binaries and object files from the
- source code directory by typing `make clean'.
-Compilers and Options
- Some systems require unusual options for compilation or linking that
-the `configure' script does not know about. You can give `configure'
-initial values for variables by setting them in the environment. Using
-a Bourne-compatible shell, you can do that on the command line like
-this:
- CC=c89 CFLAGS=-O2 LIBS=-lposix ./configure
-Or on systems that have the `env' program, you can do it like this:
- env CPPFLAGS=-I/usr/local/include LDFLAGS=-s ./configure
-Compiling For Multiple Architectures
- You can compile the package for more than one kind of computer at the
-same time, by placing the object files for each architecture in their
-own directory. To do this, you must use a version of `make' that
-supports the `VPATH' variable, such as GNU `make'. `cd' to the
-directory where you want the object files and executables to go and run
-the `configure' script. `configure' automatically checks for the
-source code in the directory that `configure' is in and in `..'.
- If you have to use a `make' that does not supports the `VPATH'
-variable, you have to compile the package for one architecture at a time
-in the source code directory. After you have installed the package for
-one architecture, use `make distclean' before reconfiguring for another
-architecture.
-Installation Names
- By default, `make install' will install the package's files in
-`/usr/local/bin', `/usr/local/man', etc. You can specify an
-installation prefix other than `/usr/local' by giving `configure' the
-option `--prefix=PATH'.
- You can specify separate installation prefixes for
-architecture-specific files and architecture-independent files. If you
-give `configure' the option `--exec-prefix=PATH', the package will use
-PATH as the prefix for installing programs and libraries.
-Documentation and other data files will still use the regular prefix.
- If the package supports it, you can cause programs to be installed
-with an extra prefix or suffix on their names by giving `configure' the
-option `--program-prefix=PREFIX' or `--program-suffix=SUFFIX'.
-Optional Features
- Some packages pay attention to `--enable-FEATURE' options to
-`configure', where FEATURE indicates an optional part of the package.
-They may also pay attention to `--with-PACKAGE' options, where PACKAGE
-is something like `gnu-as' or `x' (for the X Window System). The
-`README' should mention any `--enable-' and `--with-' options that the
-package recognizes.
- For packages that use the X Window System, `configure' can usually
-find the X include and library files automatically, but if it doesn't,
-you can use the `configure' options `--x-includes=DIR' and
-`--x-libraries=DIR' to specify their locations.
-Specifying the System Type
- There may be some features `configure' can not figure out
-automatically, but needs to determine by the type of host the package
-will run on. Usually `configure' can figure that out, but if it prints
-a message saying it can not guess the host type, give it the
-`--host=TYPE' option. TYPE can either be a short name for the system
-type, such as `sun4', or a canonical name with three fields:
- CPU-COMPANY-SYSTEM
-See the file `config.sub' for the possible values of each field. If
-`config.sub' isn't included in this package, then this package doesn't
-need to know the host type.
- If you are building compiler tools for cross-compiling, you can also
-use the `--target=TYPE' option to select the type of system they will
-produce code for and the `--build=TYPE' option to select the type of
-system on which you are compiling the package.
-Sharing Defaults
- If you want to set default values for `configure' scripts to share,
-you can create a site shell script called `config.site' that gives
-default values for variables like `CC', `cache_file', and `prefix'.
-`configure' looks for `PREFIX/share/config.site' if it exists, then
-`PREFIX/etc/config.site' if it exists. Or, you can set the
-`CONFIG_SITE' environment variable to the location of the site script.
-A warning: not all `configure' scripts look for a site script.
-Operation Controls
- `configure' recognizes the following options to control how it
-operates.
-`--cache-file=FILE'
- Use and save the results of the tests in FILE instead of
- `./config.cache'. Set FILE to `/dev/null' to disable caching, for
- debugging `configure'.
-`--help'
- Print a summary of the options to `configure', and exit.
-`--quiet'
-`--silent'
-`-q'
- Do not print messages saying which checks are being made.
-`--srcdir=DIR'
- Look for the package's source code in directory DIR. Usually
- `configure' can determine that directory automatically.
-`--version'
- Print the version of Autoconf used to generate the `configure'
- script, and exit.
-`configure' also accepts some other, not widely useful, options.
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/INSTALL (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/INSTALL)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/INSTALL (rev 0)
@@ -0,0 +1,167 @@
+Basic Installation
+ These are generic installation instructions.
+ The `configure' shell script attempts to guess correct values for
+various system-dependent variables used during compilation. It uses
+those values to create a `Makefile' in each directory of the package.
+It may also create one or more `.h' files containing system-dependent
+definitions. Finally, it creates a shell script `config.status' that
+you can run in the future to recreate the current configuration, a file
+`config.cache' that saves the results of its tests to speed up
+reconfiguring, and a file `config.log' containing compiler output
+(useful mainly for debugging `configure').
+ If you need to do unusual things to compile the package, please try
+to figure out how `configure' could check whether to do them, and mail
+diffs or instructions to the address given in the `README' so they can
+be considered for the next release. If at some point `config.cache'
+contains results you don't want to keep, you may remove or edit it.
+ The file `configure.in' is used to create `configure' by a program
+called `autoconf'. You only need `configure.in' if you want to change
+it or regenerate `configure' using a newer version of `autoconf'.
+The simplest way to compile this package is:
+ 1. `cd' to the directory containing the package's source code and type
+ `./configure' to configure the package for your system. If you're
+ using `csh' on an old version of System V, you might need to type
+ `sh ./configure' instead to prevent `csh' from trying to execute
+ `configure' itself.
+ Running `configure' takes a while. While running, it prints some
+ messages telling which features it is checking for.
+ 2. Type `make' to compile the package.
+ 3. Type `make install' to install the programs and any data files and
+ documentation.
+ 4. You can remove the program binaries and object files from the
+ source code directory by typing `make clean'.
+Compilers and Options
+ Some systems require unusual options for compilation or linking that
+the `configure' script does not know about. You can give `configure'
+initial values for variables by setting them in the environment. Using
+a Bourne-compatible shell, you can do that on the command line like
+this:
+ CC=c89 CFLAGS=-O2 LIBS=-lposix ./configure
+Or on systems that have the `env' program, you can do it like this:
+ env CPPFLAGS=-I/usr/local/include LDFLAGS=-s ./configure
+Compiling For Multiple Architectures
+ You can compile the package for more than one kind of computer at the
+same time, by placing the object files for each architecture in their
+own directory. To do this, you must use a version of `make' that
+supports the `VPATH' variable, such as GNU `make'. `cd' to the
+directory where you want the object files and executables to go and run
+the `configure' script. `configure' automatically checks for the
+source code in the directory that `configure' is in and in `..'.
+ If you have to use a `make' that does not supports the `VPATH'
+variable, you have to compile the package for one architecture at a time
+in the source code directory. After you have installed the package for
+one architecture, use `make distclean' before reconfiguring for another
+architecture.
+Installation Names
+ By default, `make install' will install the package's files in
+`/usr/local/bin', `/usr/local/man', etc. You can specify an
+installation prefix other than `/usr/local' by giving `configure' the
+option `--prefix=PATH'.
+ You can specify separate installation prefixes for
+architecture-specific files and architecture-independent files. If you
+give `configure' the option `--exec-prefix=PATH', the package will use
+PATH as the prefix for installing programs and libraries.
+Documentation and other data files will still use the regular prefix.
+ If the package supports it, you can cause programs to be installed
+with an extra prefix or suffix on their names by giving `configure' the
+option `--program-prefix=PREFIX' or `--program-suffix=SUFFIX'.
+Optional Features
+ Some packages pay attention to `--enable-FEATURE' options to
+`configure', where FEATURE indicates an optional part of the package.
+They may also pay attention to `--with-PACKAGE' options, where PACKAGE
+is something like `gnu-as' or `x' (for the X Window System). The
+`README' should mention any `--enable-' and `--with-' options that the
+package recognizes.
+ For packages that use the X Window System, `configure' can usually
+find the X include and library files automatically, but if it doesn't,
+you can use the `configure' options `--x-includes=DIR' and
+`--x-libraries=DIR' to specify their locations.
+Specifying the System Type
+ There may be some features `configure' can not figure out
+automatically, but needs to determine by the type of host the package
+will run on. Usually `configure' can figure that out, but if it prints
+a message saying it can not guess the host type, give it the
+`--host=TYPE' option. TYPE can either be a short name for the system
+type, such as `sun4', or a canonical name with three fields:
+ CPU-COMPANY-SYSTEM
+See the file `config.sub' for the possible values of each field. If
+`config.sub' isn't included in this package, then this package doesn't
+need to know the host type.
+ If you are building compiler tools for cross-compiling, you can also
+use the `--target=TYPE' option to select the type of system they will
+produce code for and the `--build=TYPE' option to select the type of
+system on which you are compiling the package.
+Sharing Defaults
+ If you want to set default values for `configure' scripts to share,
+you can create a site shell script called `config.site' that gives
+default values for variables like `CC', `cache_file', and `prefix'.
+`configure' looks for `PREFIX/share/config.site' if it exists, then
+`PREFIX/etc/config.site' if it exists. Or, you can set the
+`CONFIG_SITE' environment variable to the location of the site script.
+A warning: not all `configure' scripts look for a site script.
+Operation Controls
+ `configure' recognizes the following options to control how it
+operates.
+`--cache-file=FILE'
+ Use and save the results of the tests in FILE instead of
+ `./config.cache'. Set FILE to `/dev/null' to disable caching, for
+ debugging `configure'.
+`--help'
+ Print a summary of the options to `configure', and exit.
+`--quiet'
+`--silent'
+`-q'
+ Do not print messages saying which checks are being made.
+`--srcdir=DIR'
+ Look for the package's source code in directory DIR. Usually
+ `configure' can determine that directory automatically.
+`--version'
+ Print the version of Autoconf used to generate the `configure'
+ script, and exit.
+`configure' also accepts some other, not widely useful, options.
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/NEWS
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/NEWS 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/NEWS 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1 +0,0 @@
\ No newline at end of file
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/NEWS (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/NEWS)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/NEWS (rev 0)
@@ -0,0 +1 @@
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/README
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/README 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/README 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,33 +0,0 @@
-Setup:
-$/dwfcore - the project root for the GNU make system as well as the KDevelop project
-$/dwfcore/src - the start of the source tree for the project
-$/dwfcore/src/dwfcore - a SYMBOLIC LINK to the real source base at $/Bianchi/develop/global/src/dwfcore
-Depending on how you got your distribution this link might be missing or broken, please confirm its existance and create it if necessary.
-Within each of the real source code folders are two files that MUST NOT BE DELETED:
- Makefile.in
- Makefile.am
-If configure fails with:
- permission denied or similar - chmod +x ./configure
- already configured; run 'make distclean' - but you can't and seem stuck forever, rm config.status
-Build notes:
-There are two build configurations:
-debug - enables full debugging and no optimization
-optimized - O2 level optimizations plus others, for a more finely tuned build, try -march=pentium4 (e.g.)
-ZLIB - by default, libdwfcore is built using the system zlib. there is an internal zlib that can be turned on by defining -DDWFCORE_BUILD_ZLIB. If defined, the -lz LDFLAG must be removed.
-libdwfcore will be installed to /usr/local/lib by default
-and header will be installed to /usr/local/include/dwfcore by default.
-Read the INSTALL file.
-After installing libdwfcore, you may need to run ldconfig before linking.
-use libtool to link against the shared library simply by adding -ldwfcore to your LDFLAGS
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/README (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/README)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/README (rev 0)
@@ -0,0 +1,33 @@
+Setup:
+$/dwfcore - the project root for the GNU make system as well as the KDevelop project
+$/dwfcore/src - the start of the source tree for the project
+$/dwfcore/src/dwfcore - a SYMBOLIC LINK to the real source base at $/Bianchi/develop/global/src/dwfcore
+Depending on how you got your distribution this link might be missing or broken, please confirm its existance and create it if necessary.
+Within each of the real source code folders are two files that MUST NOT BE DELETED:
+ Makefile.in
+ Makefile.am
+If configure fails with:
+ permission denied or similar - chmod +x ./configure
+ already configured; run 'make distclean' - but you can't and seem stuck forever, rm config.status
+Build notes:
+There are two build configurations:
+debug - enables full debugging and no optimization
+optimized - O2 level optimizations plus others, for a more finely tuned build, try -march=pentium4 (e.g.)
+ZLIB - by default, libdwfcore is built using the system zlib. there is an internal zlib that can be turned on by defining -DDWFCORE_BUILD_ZLIB. If defined, the -lz LDFLAG must be removed.
+libdwfcore will be installed to /usr/local/lib by default
+and header will be installed to /usr/local/include/dwfcore by default.
+Read the INSTALL file.
+After installing libdwfcore, you may need to run ldconfig before linking.
+use libtool to link against the shared library simply by adding -ldwfcore to your LDFLAGS
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/TODO
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/TODO 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/TODO 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,3 +0,0 @@
-- Implement thread stuff
-- Implement POSIX events, synch objects
-- Concurrency in zip file i/o
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/TODO (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/TODO)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/TODO (rev 0)
@@ -0,0 +1,3 @@
+- Implement thread stuff
+- Implement POSIX events, synch objects
+- Concurrency in zip file i/o
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.guess
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.guess 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.guess 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,1363 +0,0 @@
-#! /bin/sh
-# Attempt to guess a canonical system name.
-# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
-# 2000, 2001, 2002 Free Software Foundation, Inc.
-timestamp='2002-10-21'
-# This file is free software; you can redistribute it and/or modify it
-# under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# Originally written by Per Bothner <per at bothner.com>.
-# Please send patches to <config-patches at gnu.org>. Submit a context
-# diff and a properly formatted ChangeLog entry.
-# This script attempts to guess a canonical system name similar to
-# config.sub. If it succeeds, it prints the system name on stdout, and
-# exits with 0. Otherwise, it exits with 1.
-# The plan is that this can be called by configure scripts if you
-# don't specify an explicit build system type.
-me=`echo "$0" | sed -e 's,.*/,,'`
-usage="\
-Usage: $0 [OPTION]
-Output the configuration name of the system \`$me' is run on.
-Operation modes:
- -h, --help print this help, then exit
- -t, --time-stamp print date of last modification, then exit
- -v, --version print version number, then exit
-Report bugs and patches to <config-patches at gnu.org>."
-version="\
-GNU config.guess ($timestamp)
-Originally written by Per Bothner.
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001
-Free Software Foundation, Inc.
-This is free software; see the source for copying conditions. There is NO
-warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
-help="
-Try \`$me --help' for more information."
-# Parse command line
-while test $# -gt 0 ; do
- case $1 in
- --time-stamp | --time* | -t )
- echo "$timestamp" ; exit 0 ;;
- --version | -v )
- echo "$version" ; exit 0 ;;
- --help | --h* | -h )
- echo "$usage"; exit 0 ;;
- -- ) # Stop option processing
- shift; break ;;
- - ) # Use stdin as input.
- break ;;
- echo "$me: invalid option $1$help" >&2
- exit 1 ;;
- break ;;
- esac
-done
-if test $# != 0; then
- echo "$me: too many arguments$help" >&2
- exit 1
-fi
-trap 'exit 1' 1 2 15
-# CC_FOR_BUILD -- compiler used by this script. Note that the use of a
-# compiler to aid in system detection is discouraged as it requires
-# temporary files to be created and, as you can see below, it is a
-# headache to deal with in a portable fashion.
-# Historically, `CC_FOR_BUILD' used to be named `HOST_CC'. We still
-# use `HOST_CC' if defined, but it is deprecated.
-# This shell variable is my proudest work .. or something. --bje
-set_cc_for_build='tmpdir=${TMPDIR-/tmp}/config-guess-$$ ;
-(old=`umask` && umask 077 && mkdir $tmpdir && umask $old && unset old)
- || (echo "$me: cannot create $tmpdir" >&2 && exit 1) ;
-dummy=$tmpdir/dummy ;
-files="$dummy.c $dummy.o $dummy.rel $dummy" ;
-trap '"'"'rm -f $files; rmdir $tmpdir; exit 1'"'"' 1 2 15 ;
-case $CC_FOR_BUILD,$HOST_CC,$CC in
- ,,) echo "int x;" > $dummy.c ;
- for c in cc gcc c89 c99 ; do
- if ($c -c -o $dummy.o $dummy.c) >/dev/null 2>&1 ; then
- CC_FOR_BUILD="$c"; break ;
- fi ;
- done ;
- rm -f $files ;
- if test x"$CC_FOR_BUILD" = x ; then
- CC_FOR_BUILD=no_compiler_found ;
- fi
- ,,*) CC_FOR_BUILD=$CC ;;
- ,*,*) CC_FOR_BUILD=$HOST_CC ;;
-esac ;
-unset files'
-# This is needed to find uname on a Pyramid OSx when run in the BSD universe.
-# (ghazi at noc.rutgers.edu 1994-08-24)
-if (test -f /.attbin/uname) >/dev/null 2>&1 ; then
- PATH=$PATH:/.attbin ; export PATH
-fi
-UNAME_MACHINE=`(uname -m) 2>/dev/null` || UNAME_MACHINE=unknown
-UNAME_RELEASE=`(uname -r) 2>/dev/null` || UNAME_RELEASE=unknown
-UNAME_SYSTEM=`(uname -s) 2>/dev/null` || UNAME_SYSTEM=unknown
-UNAME_VERSION=`(uname -v) 2>/dev/null` || UNAME_VERSION=unknown
-# Note: order is significant - the case branches are not exclusive.
-case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
- *:NetBSD:*:*)
- # NetBSD (nbsd) targets should (where applicable) match one or
- # more of the tupples: *-*-netbsdelf*, *-*-netbsdaout*,
- # *-*-netbsdecoff* and *-*-netbsd*. For targets that recently
- # switched to ELF, *-*-netbsd* would select the old
- # object file format. This provides both forward
- # compatibility and a consistent mechanism for selecting the
- # Note: NetBSD doesn't particularly care about the vendor
- # portion of the name. We always set it to "unknown".
- sysctl="sysctl -n hw.machine_arch"
- UNAME_MACHINE_ARCH=`(/sbin/$sysctl 2>/dev/null || \
- /usr/sbin/$sysctl 2>/dev/null || echo unknown)`
- case "${UNAME_MACHINE_ARCH}" in
- armeb) machine=armeb-unknown ;;
- arm*) machine=arm-unknown ;;
- sh3el) machine=shl-unknown ;;
- sh3eb) machine=sh-unknown ;;
- *) machine=${UNAME_MACHINE_ARCH}-unknown ;;
- esac
- # The Operating System including object format, if it has switched
- # to ELF recently, or will in the future.
- arm*|i386|m68k|ns32k|sh3*|sparc|vax)
- eval $set_cc_for_build
- if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
- | grep __ELF__ >/dev/null
- then
- # Once all utilities can be ECOFF (netbsdecoff) or a.out (netbsdaout).
- # Return netbsd for either. FIX?
- os=netbsd
- else
- os=netbsdelf
- fi
- os=netbsd
- esac
- # The OS release
- release=`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
- # Since CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM:
- # contains redundant information, the shorter form:
- # CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
- echo "${machine}-${os}${release}"
- exit 0 ;;
- amiga:OpenBSD:*:*)
- echo m68k-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- arc:OpenBSD:*:*)
- echo mipsel-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- hp300:OpenBSD:*:*)
- exit 0 ;;
- mac68k:OpenBSD:*:*)
- exit 0 ;;
- macppc:OpenBSD:*:*)
- echo powerpc-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- mvme68k:OpenBSD:*:*)
- exit 0 ;;
- mvme88k:OpenBSD:*:*)
- echo m88k-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- mvmeppc:OpenBSD:*:*)
- exit 0 ;;
- pmax:OpenBSD:*:*)
- exit 0 ;;
- sgi:OpenBSD:*:*)
- echo mipseb-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- sun3:OpenBSD:*:*)
- exit 0 ;;
- wgrisc:OpenBSD:*:*)
- exit 0 ;;
- *:OpenBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- alpha:OSF1:*:*)
- if test $UNAME_RELEASE = "V4.0"; then
- UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $3}'`
- fi
- # A Vn.n version is a released version.
- # A Tn.n version is a released field test version.
- # A Xn.n version is an unreleased experimental baselevel.
- # 1.2 uses "1.2" for uname -r.
- cat <<EOF >$dummy.s
- .data
-\$Lformat:
- .byte 37,100,45,37,120,10,0 # "%d-%x\n"
- .text
- .globl main
- .align 4
- .ent main
-main:
- .frame \$30,16,\$26,0
- ldgp \$29,0(\$27)
- .prologue 1
- .long 0x47e03d80 # implver \$0
- lda \$2,-1
- .long 0x47e20c21 # amask \$2,\$1
- lda \$16,\$Lformat
- mov \$0,\$17
- not \$1,\$18
- jsr \$26,printf
- ldgp \$29,0(\$26)
- mov 0,\$16
- jsr \$26,exit
- .end main
-EOF
- $CC_FOR_BUILD -o $dummy $dummy.s 2>/dev/null
- if test "$?" = 0 ; then
- case `$dummy` in
- 0-0)
- UNAME_MACHINE="alpha"
- 1-0)
- UNAME_MACHINE="alphaev5"
- 1-1)
- UNAME_MACHINE="alphaev56"
- 1-101)
- UNAME_MACHINE="alphapca56"
- 2-303)
- UNAME_MACHINE="alphaev6"
- 2-307)
- UNAME_MACHINE="alphaev67"
- 2-1307)
- UNAME_MACHINE="alphaev68"
- 3-1307)
- UNAME_MACHINE="alphaev7"
- esac
- fi
- rm -f $dummy.s $dummy && rmdir $tmpdir
- echo ${UNAME_MACHINE}-dec-osf`echo ${UNAME_RELEASE} | sed -e 's/^[VTX]//' | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
- exit 0 ;;
- Alpha\ *:Windows_NT*:*)
- # How do we know it's Interix rather than the generic POSIX subsystem?
- # Should we change UNAME_MACHINE based on the output of uname instead
- # of the specific Alpha model?
- echo alpha-pc-interix
- exit 0 ;;
- 21064:Windows_NT:50:3)
- echo alpha-dec-winnt3.5
- exit 0 ;;
- Amiga*:UNIX_System_V:4.0:*)
- echo m68k-unknown-sysv4
- exit 0;;
- *:[Aa]miga[Oo][Ss]:*:*)
- echo ${UNAME_MACHINE}-unknown-amigaos
- exit 0 ;;
- *:[Mm]orph[Oo][Ss]:*:*)
- echo ${UNAME_MACHINE}-unknown-morphos
- exit 0 ;;
- *:OS/390:*:*)
- echo i370-ibm-openedition
- exit 0 ;;
- arm:RISC*:1.[012]*:*|arm:riscix:1.[012]*:*)
- echo arm-acorn-riscix${UNAME_RELEASE}
- exit 0;;
- SR2?01:HI-UX/MPP:*:* | SR8000:HI-UX/MPP:*:*)
- echo hppa1.1-hitachi-hiuxmpp
- exit 0;;
- Pyramid*:OSx*:*:* | MIS*:OSx*:*:* | MIS*:SMP_DC-OSx*:*:*)
- # akee at wpdis03.wpafb.af.mil (Earle F. Ake) contributed MIS and NILE.
- if test "`(/bin/universe) 2>/dev/null`" = att ; then
- echo pyramid-pyramid-sysv3
- else
- echo pyramid-pyramid-bsd
- fi
- exit 0 ;;
- NILE*:*:*:dcosx)
- echo pyramid-pyramid-svr4
- exit 0 ;;
- DRS?6000:UNIX_SV:4.2*:7*)
- case `/usr/bin/uname -p` in
- sparc) echo sparc-icl-nx7 && exit 0 ;;
- esac ;;
- sun4H:SunOS:5.*:*)
- echo sparc-hal-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
- sun4*:SunOS:5.*:* | tadpole*:SunOS:5.*:*)
- echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
- i86pc:SunOS:5.*:*)
- echo i386-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
- sun4*:SunOS:6*:*)
- # According to config.sub, this is the proper way to canonicalize
- # SunOS6. Hard to guess exactly what SunOS6 will be like, but
- # it's likely to be more like Solaris than SunOS4.
- echo sparc-sun-solaris3`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
- sun4*:SunOS:*:*)
- case "`/usr/bin/arch -k`" in
- Series*|S4*)
- UNAME_RELEASE=`uname -v`
- esac
- # Japanese Language versions have a version number like `4.1.3-JL'.
- echo sparc-sun-sunos`echo ${UNAME_RELEASE}|sed -e 's/-/_/'`
- exit 0 ;;
- sun3*:SunOS:*:*)
- echo m68k-sun-sunos${UNAME_RELEASE}
- exit 0 ;;
- sun*:*:4.2BSD:*)
- UNAME_RELEASE=`(sed 1q /etc/motd | awk '{print substr($5,1,3)}') 2>/dev/null`
- test "x${UNAME_RELEASE}" = "x" && UNAME_RELEASE=3
- case "`/bin/arch`" in
- sun3)
- sun4)
- echo sparc-sun-sunos${UNAME_RELEASE}
- esac
- exit 0 ;;
- aushp:SunOS:*:*)
- echo sparc-auspex-sunos${UNAME_RELEASE}
- exit 0 ;;
- # The situation for MiNT is a little confusing. The machine name
- # can be virtually everything (everything which is not
- # "atarist" or "atariste" at least should have a processor
- # > m68000). The system name ranges from "MiNT" over "FreeMiNT"
- # to the lowercase version "mint" (or "freemint"). Finally
- # the system name "TOS" denotes a system which is actually not
- # MiNT. But MiNT is downward compatible to TOS, so this should
- # be no problem.
- atarist[e]:*MiNT:*:* | atarist[e]:*mint:*:* | atarist[e]:*TOS:*:*)
- echo m68k-atari-mint${UNAME_RELEASE}
- exit 0 ;;
- atari*:*MiNT:*:* | atari*:*mint:*:* | atarist[e]:*TOS:*:*)
- exit 0 ;;
- *falcon*:*MiNT:*:* | *falcon*:*mint:*:* | *falcon*:*TOS:*:*)
- exit 0 ;;
- milan*:*MiNT:*:* | milan*:*mint:*:* | *milan*:*TOS:*:*)
- echo m68k-milan-mint${UNAME_RELEASE}
- exit 0 ;;
- hades*:*MiNT:*:* | hades*:*mint:*:* | *hades*:*TOS:*:*)
- echo m68k-hades-mint${UNAME_RELEASE}
- exit 0 ;;
- *:*MiNT:*:* | *:*mint:*:* | *:*TOS:*:*)
- echo m68k-unknown-mint${UNAME_RELEASE}
- exit 0 ;;
- powerpc:machten:*:*)
- echo powerpc-apple-machten${UNAME_RELEASE}
- exit 0 ;;
- RISC*:Mach:*:*)
- echo mips-dec-mach_bsd4.3
- exit 0 ;;
- RISC*:ULTRIX:*:*)
- echo mips-dec-ultrix${UNAME_RELEASE}
- exit 0 ;;
- VAX*:ULTRIX*:*:*)
- echo vax-dec-ultrix${UNAME_RELEASE}
- exit 0 ;;
- 2020:CLIX:*:* | 2430:CLIX:*:*)
- echo clipper-intergraph-clix${UNAME_RELEASE}
- exit 0 ;;
- mips:*:*:UMIPS | mips:*:*:RISCos)
- sed 's/^ //' << EOF >$dummy.c
-#ifdef __cplusplus
-#include <stdio.h> /* for printf() prototype */
- int main (int argc, char *argv[]) {
-#else
- int main (argc, argv) int argc; char *argv[]; {
-#endif
- #if defined (host_mips) && defined (MIPSEB)
- #if defined (SYSTYPE_SYSV)
- printf ("mips-mips-riscos%ssysv\n", argv[1]); exit (0);
- #endif
- #if defined (SYSTYPE_SVR4)
- printf ("mips-mips-riscos%ssvr4\n", argv[1]); exit (0);
- #endif
- #if defined (SYSTYPE_BSD43) || defined(SYSTYPE_BSD)
- printf ("mips-mips-riscos%sbsd\n", argv[1]); exit (0);
- #endif
- #endif
- exit (-1);
-EOF
- $CC_FOR_BUILD -o $dummy $dummy.c \
- && $dummy `echo "${UNAME_RELEASE}" | sed -n 's/\([0-9]*\).*/\1/p'` \
- && rm -f $dummy.c $dummy && rmdir $tmpdir && exit 0
- rm -f $dummy.c $dummy && rmdir $tmpdir
- echo mips-mips-riscos${UNAME_RELEASE}
- exit 0 ;;
- Motorola:PowerMAX_OS:*:*)
- echo powerpc-motorola-powermax
- exit 0 ;;
- Motorola:*:4.3:PL8-*)
- echo powerpc-harris-powermax
- exit 0 ;;
- Night_Hawk:*:*:PowerMAX_OS)
- exit 0 ;;
- Night_Hawk:Power_UNIX:*:*)
- echo powerpc-harris-powerunix
- exit 0 ;;
- m88k:CX/UX:7*:*)
- echo m88k-harris-cxux7
- exit 0 ;;
- m88k:*:4*:R4*)
- echo m88k-motorola-sysv4
- exit 0 ;;
- m88k:*:3*:R3*)
- echo m88k-motorola-sysv3
- exit 0 ;;
- AViiON:dgux:*:*)
- # DG/UX returns AViiON for all architectures
- UNAME_PROCESSOR=`/usr/bin/uname -p`
- if [ $UNAME_PROCESSOR = mc88100 ] || [ $UNAME_PROCESSOR = mc88110 ]
- then
- if [ ${TARGET_BINARY_INTERFACE}x = m88kdguxelfx ] || \
- [ ${TARGET_BINARY_INTERFACE}x = x ]
- then
- echo m88k-dg-dgux${UNAME_RELEASE}
- else
- echo m88k-dg-dguxbcs${UNAME_RELEASE}
- fi
- else
- echo i586-dg-dgux${UNAME_RELEASE}
- fi
- exit 0 ;;
- M88*:DolphinOS:*:*) # DolphinOS (SVR3)
- echo m88k-dolphin-sysv3
- exit 0 ;;
- M88*:*:R3*:*)
- # Delta 88k system running SVR3
- exit 0 ;;
- XD88*:*:*:*) # Tektronix XD88 system running UTekV (SVR3)
- echo m88k-tektronix-sysv3
- exit 0 ;;
- Tek43[0-9][0-9]:UTek:*:*) # Tektronix 4300 system running UTek (BSD)
- echo m68k-tektronix-bsd
- exit 0 ;;
- *:IRIX*:*:*)
- echo mips-sgi-irix`echo ${UNAME_RELEASE}|sed -e 's/-/_/g'`
- exit 0 ;;
- ????????:AIX?:[12].1:2) # AIX 2.2.1 or AIX 2.1.1 is RT/PC AIX.
- echo romp-ibm-aix # uname -m gives an 8 hex-code CPU id
- exit 0 ;; # Note that: echo "'`uname -s`'" gives 'AIX '
- i*86:AIX:*:*)
- echo i386-ibm-aix
- exit 0 ;;
- ia64:AIX:*:*)
- if [ -x /usr/bin/oslevel ] ; then
- IBM_REV=`/usr/bin/oslevel`
- else
- IBM_REV=${UNAME_VERSION}.${UNAME_RELEASE}
- fi
- echo ${UNAME_MACHINE}-ibm-aix${IBM_REV}
- exit 0 ;;
- *:AIX:2:3)
- if grep bos325 /usr/include/stdio.h >/dev/null 2>&1; then
- #include <sys/systemcfg.h>
- main()
- if (!__power_pc())
- exit(1);
- puts("powerpc-ibm-aix3.2.5");
- exit(0);
-EOF
- $CC_FOR_BUILD -o $dummy $dummy.c && $dummy && rm -f $dummy.c $dummy && rmdir $tmpdir && exit 0
- echo rs6000-ibm-aix3.2.5
- elif grep bos324 /usr/include/stdio.h >/dev/null 2>&1; then
- echo rs6000-ibm-aix3.2.4
- else
- fi
- exit 0 ;;
- *:AIX:*:[45])
- IBM_CPU_ID=`/usr/sbin/lsdev -C -c processor -S available | sed 1q | awk '{ print $1 }'`
- if /usr/sbin/lsattr -El ${IBM_CPU_ID} | grep ' POWER' >/dev/null 2>&1; then
- IBM_ARCH=rs6000
- else
- IBM_ARCH=powerpc
- fi
- else
- fi
- echo ${IBM_ARCH}-ibm-aix${IBM_REV}
- exit 0 ;;
- *:AIX:*:*)
- exit 0 ;;
- ibmrt:4.4BSD:*|romp-ibm:BSD:*)
- echo romp-ibm-bsd4.4
- exit 0 ;;
- ibmrt:*BSD:*|romp-ibm:BSD:*) # covers RT/PC BSD and
- echo romp-ibm-bsd${UNAME_RELEASE} # 4.3 with uname added to
- exit 0 ;; # report: romp-ibm BSD 4.3
- *:BOSX:*:*)
- echo rs6000-bull-bosx
- exit 0 ;;
- DPX/2?00:B.O.S.:*:*)
- echo m68k-bull-sysv3
- exit 0 ;;
- 9000/[34]??:4.3bsd:1.*:*)
- echo m68k-hp-bsd
- exit 0 ;;
- hp300:4.4BSD:*:* | 9000/[34]??:4.3bsd:2.*:*)
- echo m68k-hp-bsd4.4
- exit 0 ;;
- 9000/[34678]??:HP-UX:*:*)
- HPUX_REV=`echo ${UNAME_RELEASE}|sed -e 's/[^.]*.[0B]*//'`
- case "${UNAME_MACHINE}" in
- 9000/31? ) HP_ARCH=m68000 ;;
- 9000/[34]?? ) HP_ARCH=m68k ;;
- 9000/[678][0-9][0-9])
- if [ -x /usr/bin/getconf ]; then
- sc_cpu_version=`/usr/bin/getconf SC_CPU_VERSION 2>/dev/null`
- sc_kernel_bits=`/usr/bin/getconf SC_KERNEL_BITS 2>/dev/null`
- case "${sc_cpu_version}" in
- 523) HP_ARCH="hppa1.0" ;; # CPU_PA_RISC1_0
- 528) HP_ARCH="hppa1.1" ;; # CPU_PA_RISC1_1
- 532) # CPU_PA_RISC2_0
- case "${sc_kernel_bits}" in
- 32) HP_ARCH="hppa2.0n" ;;
- 64) HP_ARCH="hppa2.0w" ;;
- '') HP_ARCH="hppa2.0" ;; # HP-UX 10.20
- esac ;;
- esac
- fi
- if [ "${HP_ARCH}" = "" ]; then
- #define _HPUX_SOURCE
- #include <stdlib.h>
- #include <unistd.h>
- int main ()
- #if defined(_SC_KERNEL_BITS)
- long bits = sysconf(_SC_KERNEL_BITS);
- #endif
- long cpu = sysconf (_SC_CPU_VERSION);
- switch (cpu)
- case CPU_PA_RISC1_0: puts ("hppa1.0"); break;
- case CPU_PA_RISC1_1: puts ("hppa1.1"); break;
- case CPU_PA_RISC2_0:
- switch (bits)
- case 64: puts ("hppa2.0w"); break;
- case 32: puts ("hppa2.0n"); break;
- default: puts ("hppa2.0"); break;
- } break;
- #else /* !defined(_SC_KERNEL_BITS) */
- puts ("hppa2.0"); break;
- #endif
- default: puts ("hppa1.0"); break;
- exit (0);
-EOF
- (CCOPTS= $CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null) && HP_ARCH=`$dummy`
- if test -z "$HP_ARCH"; then HP_ARCH=hppa; fi
- fi ;;
- esac
- echo ${HP_ARCH}-hp-hpux${HPUX_REV}
- exit 0 ;;
- ia64:HP-UX:*:*)
- echo ia64-hp-hpux${HPUX_REV}
- exit 0 ;;
- 3050*:HI-UX:*:*)
- int
- main ()
- /* The order matters, because CPU_IS_HP_MC68K erroneously returns
- true for CPU_PA_RISC1_0. CPU_IS_PA_RISC returns correct
- results, however. */
- if (CPU_IS_PA_RISC (cpu))
- switch (cpu)
- case CPU_PA_RISC1_0: puts ("hppa1.0-hitachi-hiuxwe2"); break;
- case CPU_PA_RISC1_1: puts ("hppa1.1-hitachi-hiuxwe2"); break;
- case CPU_PA_RISC2_0: puts ("hppa2.0-hitachi-hiuxwe2"); break;
- default: puts ("hppa-hitachi-hiuxwe2"); break;
- else if (CPU_IS_HP_MC68K (cpu))
- puts ("m68k-hitachi-hiuxwe2");
- else puts ("unknown-hitachi-hiuxwe2");
- exit (0);
-EOF
- echo unknown-hitachi-hiuxwe2
- exit 0 ;;
- 9000/7??:4.3bsd:*:* | 9000/8?[79]:4.3bsd:*:* )
- echo hppa1.1-hp-bsd
- exit 0 ;;
- 9000/8??:4.3bsd:*:*)
- echo hppa1.0-hp-bsd
- exit 0 ;;
- *9??*:MPE/iX:*:* | *3000*:MPE/iX:*:*)
- echo hppa1.0-hp-mpeix
- exit 0 ;;
- hp7??:OSF1:*:* | hp8?[79]:OSF1:*:* )
- echo hppa1.1-hp-osf
- exit 0 ;;
- hp8??:OSF1:*:*)
- echo hppa1.0-hp-osf
- exit 0 ;;
- i*86:OSF1:*:*)
- if [ -x /usr/sbin/sysversion ] ; then
- echo ${UNAME_MACHINE}-unknown-osf1mk
- else
- fi
- exit 0 ;;
- parisc*:Lites*:*:*)
- echo hppa1.1-hp-lites
- exit 0 ;;
- C1*:ConvexOS:*:* | convex:ConvexOS:C1*:*)
- echo c1-convex-bsd
- exit 0 ;;
- C2*:ConvexOS:*:* | convex:ConvexOS:C2*:*)
- if getsysinfo -f scalar_acc
- then echo c32-convex-bsd
- else echo c2-convex-bsd
- fi
- exit 0 ;;
- C34*:ConvexOS:*:* | convex:ConvexOS:C34*:*)
- echo c34-convex-bsd
- exit 0 ;;
- C38*:ConvexOS:*:* | convex:ConvexOS:C38*:*)
- echo c38-convex-bsd
- exit 0 ;;
- C4*:ConvexOS:*:* | convex:ConvexOS:C4*:*)
- echo c4-convex-bsd
- exit 0 ;;
- CRAY*Y-MP:*:*:*)
- echo ymp-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit 0 ;;
- CRAY*[A-Z]90:*:*:*)
- echo ${UNAME_MACHINE}-cray-unicos${UNAME_RELEASE} \
- | sed -e 's/CRAY.*\([A-Z]90\)/\1/' \
- -e y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/ \
- -e 's/\.[^.]*$/.X/'
- exit 0 ;;
- CRAY*TS:*:*:*)
- echo t90-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit 0 ;;
- CRAY*T3D:*:*:*)
- echo alpha-cray-unicosmk${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit 0 ;;
- CRAY*T3E:*:*:*)
- echo alphaev5-cray-unicosmk${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit 0 ;;
- CRAY*SV1:*:*:*)
- echo sv1-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
- exit 0 ;;
- F30[01]:UNIX_System_V:*:* | F700:UNIX_System_V:*:*)
- FUJITSU_PROC=`uname -m | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
- FUJITSU_SYS=`uname -p | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/\///'`
- FUJITSU_REL=`echo ${UNAME_RELEASE} | sed -e 's/ /_/'`
- echo "${FUJITSU_PROC}-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
- exit 0 ;;
- i*86:BSD/386:*:* | i*86:BSD/OS:*:* | *:Ascend\ Embedded/OS:*:*)
- echo ${UNAME_MACHINE}-pc-bsdi${UNAME_RELEASE}
- exit 0 ;;
- sparc*:BSD/OS:*:*)
- echo sparc-unknown-bsdi${UNAME_RELEASE}
- exit 0 ;;
- *:BSD/OS:*:*)
- echo ${UNAME_MACHINE}-unknown-bsdi${UNAME_RELEASE}
- exit 0 ;;
- *:FreeBSD:*:*)
- # Determine whether the default compiler uses glibc.
- #include <features.h>
- #if __GLIBC__ >= 2
- LIBC=gnu
- #else
- LIBC=
- #endif
-EOF
- eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^LIBC=`
- rm -f $dummy.c && rmdir $tmpdir
- echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`${LIBC:+-$LIBC}
- exit 0 ;;
- i*:CYGWIN*:*)
- echo ${UNAME_MACHINE}-pc-cygwin
- exit 0 ;;
- i*:MINGW*:*)
- echo ${UNAME_MACHINE}-pc-mingw32
- exit 0 ;;
- i*:PW*:*)
- echo ${UNAME_MACHINE}-pc-pw32
- exit 0 ;;
- x86:Interix*:3*)
- echo i386-pc-interix3
- exit 0 ;;
- i*:Windows_NT*:* | Pentium*:Windows_NT*:*)
- # It also conflicts with pre-2.0 versions of AT&T UWIN. Should we
- # UNAME_MACHINE based on the output of uname instead of i386?
- exit 0 ;;
- i*:UWIN*:*)
- echo ${UNAME_MACHINE}-pc-uwin
- exit 0 ;;
- p*:CYGWIN*:*)
- echo powerpcle-unknown-cygwin
- exit 0 ;;
- prep*:SunOS:5.*:*)
- echo powerpcle-unknown-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
- *:GNU:*:*)
- echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-gnu`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
- exit 0 ;;
- i*86:Minix:*:*)
- echo ${UNAME_MACHINE}-pc-minix
- exit 0 ;;
- arm*:Linux:*:*)
- echo ${UNAME_MACHINE}-unknown-linux-gnu
- exit 0 ;;
- ia64:Linux:*:*)
- exit 0 ;;
- m68*:Linux:*:*)
- exit 0 ;;
- mips:Linux:*:*)
- #undef CPU
- #undef mips
- #undef mipsel
- #if defined(__MIPSEL__) || defined(__MIPSEL) || defined(_MIPSEL) || defined(MIPSEL)
- CPU=mipsel
- #else
- #if defined(__MIPSEB__) || defined(__MIPSEB) || defined(_MIPSEB) || defined(MIPSEB)
- CPU=mips
- #else
- CPU=
- #endif
- #endif
-EOF
- eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^CPU=`
- test x"${CPU}" != x && echo "${CPU}-pc-linux-gnu" && exit 0
- ppc:Linux:*:*)
- echo powerpc-unknown-linux-gnu
- exit 0 ;;
- ppc64:Linux:*:*)
- echo powerpc64-unknown-linux-gnu
- exit 0 ;;
- alpha:Linux:*:*)
- case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
- EV5) UNAME_MACHINE=alphaev5 ;;
- EV56) UNAME_MACHINE=alphaev56 ;;
- PCA56) UNAME_MACHINE=alphapca56 ;;
- PCA57) UNAME_MACHINE=alphapca56 ;;
- EV6) UNAME_MACHINE=alphaev6 ;;
- EV67) UNAME_MACHINE=alphaev67 ;;
- EV68*) UNAME_MACHINE=alphaev68 ;;
- esac
- objdump --private-headers /bin/sh | grep ld.so.1 >/dev/null
- if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
- echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
- exit 0 ;;
- parisc:Linux:*:* | hppa:Linux:*:*)
- # Look for CPU level
- case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
- PA7*) echo hppa1.1-unknown-linux-gnu ;;
- PA8*) echo hppa2.0-unknown-linux-gnu ;;
- *) echo hppa-unknown-linux-gnu ;;
- esac
- exit 0 ;;
- parisc64:Linux:*:* | hppa64:Linux:*:*)
- echo hppa64-unknown-linux-gnu
- exit 0 ;;
- s390:Linux:*:* | s390x:Linux:*:*)
- echo ${UNAME_MACHINE}-ibm-linux
- exit 0 ;;
- sh*:Linux:*:*)
- exit 0 ;;
- sparc:Linux:*:* | sparc64:Linux:*:*)
- exit 0 ;;
- x86_64:Linux:*:*)
- echo x86_64-unknown-linux-gnu
- exit 0 ;;
- i*86:Linux:*:*)
- # The BFD linker knows what the default object file format is, so
- # first see if it will tell us. cd to the root directory to prevent
- # problems with other programs or directories called `ld' in the path.
- # Set LC_ALL=C to ensure ld outputs messages in English.
- ld_supported_targets=`cd /; LC_ALL=C ld --help 2>&1 \
- | sed -ne '/supported targets:/!d
- s/[ ][ ]*/ /g
- s/.*supported targets: *//
- s/ .*//
- p'`
- case "$ld_supported_targets" in
- elf32-i386)
- TENTATIVE="${UNAME_MACHINE}-pc-linux-gnu"
- a.out-i386-linux)
- echo "${UNAME_MACHINE}-pc-linux-gnuaout"
- exit 0 ;;
- coff-i386)
- echo "${UNAME_MACHINE}-pc-linux-gnucoff"
- exit 0 ;;
- # Either a pre-BFD a.out linker (linux-gnuoldld) or
- # one that does not give us useful --help.
- echo "${UNAME_MACHINE}-pc-linux-gnuoldld"
- exit 0 ;;
- esac
- # Determine whether the default compiler is a.out or elf
- #ifdef __ELF__
- # ifdef __GLIBC__
- # if __GLIBC__ >= 2
- LIBC=gnu
- # else
- LIBC=gnulibc1
- # endif
- # else
- LIBC=gnulibc1
- # endif
- #else
- #ifdef __INTEL_COMPILER
- LIBC=gnu
- #else
- LIBC=gnuaout
- #endif
- #endif
-EOF
- test x"${LIBC}" != x && echo "${UNAME_MACHINE}-pc-linux-${LIBC}" && exit 0
- test x"${TENTATIVE}" != x && echo "${TENTATIVE}" && exit 0
- i*86:DYNIX/ptx:4*:*)
- # ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
- # earlier versions are messed up and put the nodename in both
- # sysname and nodename.
- echo i386-sequent-sysv4
- exit 0 ;;
- i*86:UNIX_SV:4.2MP:2.*)
- # Unixware is an offshoot of SVR4, but it has its own version
- # number series starting with 2...
- # I am not positive that other SVR4 systems won't match this,
- # I just have to hope. -- rms.
- # Use sysv4.2uw... so that sysv4* matches it.
- echo ${UNAME_MACHINE}-pc-sysv4.2uw${UNAME_VERSION}
- exit 0 ;;
- i*86:*:4.*:* | i*86:SYSTEM_V:4.*:*)
- UNAME_REL=`echo ${UNAME_RELEASE} | sed 's/\/MP$//'`
- if grep Novell /usr/include/link.h >/dev/null 2>/dev/null; then
- echo ${UNAME_MACHINE}-univel-sysv${UNAME_REL}
- else
- echo ${UNAME_MACHINE}-pc-sysv${UNAME_REL}
- fi
- exit 0 ;;
- i*86:*:5:[78]*)
- case `/bin/uname -X | grep "^Machine"` in
- *486*) UNAME_MACHINE=i486 ;;
- *Pentium) UNAME_MACHINE=i586 ;;
- *Pent*|*Celeron) UNAME_MACHINE=i686 ;;
- esac
- echo ${UNAME_MACHINE}-unknown-sysv${UNAME_RELEASE}${UNAME_SYSTEM}${UNAME_VERSION}
- exit 0 ;;
- i*86:*:3.2:*)
- if test -f /usr/options/cb.name; then
- UNAME_REL=`sed -n 's/.*Version //p' </usr/options/cb.name`
- echo ${UNAME_MACHINE}-pc-isc$UNAME_REL
- elif /bin/uname -X 2>/dev/null >/dev/null ; then
- UNAME_REL=`(/bin/uname -X|grep Release|sed -e 's/.*= //')`
- (/bin/uname -X|grep i80486 >/dev/null) && UNAME_MACHINE=i486
- (/bin/uname -X|grep '^Machine.*Pentium' >/dev/null) \
- && UNAME_MACHINE=i586
- (/bin/uname -X|grep '^Machine.*Pent *II' >/dev/null) \
- && UNAME_MACHINE=i686
- (/bin/uname -X|grep '^Machine.*Pentium Pro' >/dev/null) \
- echo ${UNAME_MACHINE}-pc-sco$UNAME_REL
- else
- echo ${UNAME_MACHINE}-pc-sysv32
- fi
- exit 0 ;;
- i*86:*DOS:*:*)
- echo ${UNAME_MACHINE}-pc-msdosdjgpp
- exit 0 ;;
- pc:*:*:*)
- # Left here for compatibility:
- # uname -m prints for DJGPP always 'pc', but it prints nothing about
- # the processor, so we play safe by assuming i386.
- echo i386-pc-msdosdjgpp
- exit 0 ;;
- Intel:Mach:3*:*)
- echo i386-pc-mach3
- exit 0 ;;
- paragon:*:*:*)
- echo i860-intel-osf1
- exit 0 ;;
- i860:*:4.*:*) # i860-SVR4
- if grep Stardent /usr/include/sys/uadmin.h >/dev/null 2>&1 ; then
- echo i860-stardent-sysv${UNAME_RELEASE} # Stardent Vistra i860-SVR4
- else # Add other i860-SVR4 vendors below as they are discovered.
- echo i860-unknown-sysv${UNAME_RELEASE} # Unknown i860-SVR4
- fi
- exit 0 ;;
- mini*:CTIX:SYS*5:*)
- # "miniframe"
- echo m68010-convergent-sysv
- exit 0 ;;
- mc68k:UNIX:SYSTEM5:3.51m)
- echo m68k-convergent-sysv
- exit 0 ;;
- M68*:*:R3V[567]*:*)
- test -r /sysV68 && echo 'm68k-motorola-sysv' && exit 0 ;;
- 3[34]??:*:4.0:3.0 | 3[34]??A:*:4.0:3.0 | 3[34]??,*:*:4.0:3.0 | 3[34]??/*:*:4.0:3.0 | 4400:*:4.0:3.0 | 4850:*:4.0:3.0 | SKA40:*:4.0:3.0)
- OS_REL=''
- test -r /etc/.relid \
- && OS_REL=.`sed -n 's/[^ ]* [^ ]* \([0-9][0-9]\).*/\1/p' < /etc/.relid`
- /bin/uname -p 2>/dev/null | grep 86 >/dev/null \
- && echo i486-ncr-sysv4.3${OS_REL} && exit 0
- /bin/uname -p 2>/dev/null | /bin/grep entium >/dev/null \
- && echo i586-ncr-sysv4.3${OS_REL} && exit 0 ;;
- 3[34]??:*:4.0:* | 3[34]??,*:*:4.0:*)
- && echo i486-ncr-sysv4 && exit 0 ;;
- m68*:LynxOS:2.*:* | m68*:LynxOS:3.0*:*)
- echo m68k-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
- mc68030:UNIX_System_V:4.*:*)
- echo m68k-atari-sysv4
- exit 0 ;;
- i*86:LynxOS:2.*:* | i*86:LynxOS:3.[01]*:* | i*86:LynxOS:4.0*:*)
- echo i386-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
- TSUNAMI:LynxOS:2.*:*)
- echo sparc-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
- rs6000:LynxOS:2.*:*)
- echo rs6000-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
- PowerPC:LynxOS:2.*:* | PowerPC:LynxOS:3.[01]*:* | PowerPC:LynxOS:4.0*:*)
- echo powerpc-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
- SM[BE]S:UNIX_SV:*:*)
- echo mips-dde-sysv${UNAME_RELEASE}
- exit 0 ;;
- RM*:ReliantUNIX-*:*:*)
- echo mips-sni-sysv4
- exit 0 ;;
- RM*:SINIX-*:*:*)
- exit 0 ;;
- *:SINIX-*:*:*)
- if uname -p 2>/dev/null >/dev/null ; then
- UNAME_MACHINE=`(uname -p) 2>/dev/null`
- echo ${UNAME_MACHINE}-sni-sysv4
- else
- echo ns32k-sni-sysv
- fi
- exit 0 ;;
- PENTIUM:*:4.0*:*) # Unisys `ClearPath HMP IX 4000' SVR4/MP effort
- # says <Richard.M.Bartel at ccMail.Census.GOV>
- echo i586-unisys-sysv4
- exit 0 ;;
- *:UNIX_System_V:4*:FTX*)
- # From Gerald Hewes <hewes at openmarket.com>.
- # How about differentiating between stratus architectures? -djm
- echo hppa1.1-stratus-sysv4
- exit 0 ;;
- *:*:*:FTX*)
- # From seanf at swdc.stratus.com.
- echo i860-stratus-sysv4
- exit 0 ;;
- *:VOS:*:*)
- # From Paul.Green at stratus.com.
- echo hppa1.1-stratus-vos
- exit 0 ;;
- mc68*:A/UX:*:*)
- echo m68k-apple-aux${UNAME_RELEASE}
- exit 0 ;;
- news*:NEWS-OS:6*:*)
- echo mips-sony-newsos6
- exit 0 ;;
- R[34]000:*System_V*:*:* | R4000:UNIX_SYSV:*:* | R*000:UNIX_SV:*:*)
- if [ -d /usr/nec ]; then
- echo mips-nec-sysv${UNAME_RELEASE}
- else
- echo mips-unknown-sysv${UNAME_RELEASE}
- fi
- exit 0 ;;
- BeBox:BeOS:*:*) # BeOS running on hardware made by Be, PPC only.
- echo powerpc-be-beos
- exit 0 ;;
- BeMac:BeOS:*:*) # BeOS running on Mac or Mac clone, PPC only.
- echo powerpc-apple-beos
- exit 0 ;;
- BePC:BeOS:*:*) # BeOS running on Intel PC compatible.
- echo i586-pc-beos
- exit 0 ;;
- SX-4:SUPER-UX:*:*)
- echo sx4-nec-superux${UNAME_RELEASE}
- exit 0 ;;
- SX-5:SUPER-UX:*:*)
- echo sx5-nec-superux${UNAME_RELEASE}
- exit 0 ;;
- SX-6:SUPER-UX:*:*)
- echo sx6-nec-superux${UNAME_RELEASE}
- exit 0 ;;
- Power*:Rhapsody:*:*)
- echo powerpc-apple-rhapsody${UNAME_RELEASE}
- exit 0 ;;
- *:Rhapsody:*:*)
- echo ${UNAME_MACHINE}-apple-rhapsody${UNAME_RELEASE}
- exit 0 ;;
- *:Darwin:*:*)
- echo `uname -p`-apple-darwin${UNAME_RELEASE}
- exit 0 ;;
- *:procnto*:*:* | *:QNX:[0123456789]*:*)
- UNAME_PROCESSOR=`uname -p`
- if test "$UNAME_PROCESSOR" = "x86"; then
- UNAME_PROCESSOR=i386
- UNAME_MACHINE=pc
- fi
- echo ${UNAME_PROCESSOR}-${UNAME_MACHINE}-nto-qnx${UNAME_RELEASE}
- exit 0 ;;
- *:QNX:*:4*)
- echo i386-pc-qnx
- exit 0 ;;
- NSR-[DGKLNPTVW]:NONSTOP_KERNEL:*:*)
- echo nsr-tandem-nsk${UNAME_RELEASE}
- exit 0 ;;
- *:NonStop-UX:*:*)
- echo mips-compaq-nonstopux
- exit 0 ;;
- BS2000:POSIX*:*:*)
- echo bs2000-siemens-sysv
- exit 0 ;;
- DS/*:UNIX_System_V:*:*)
- echo ${UNAME_MACHINE}-${UNAME_SYSTEM}-${UNAME_RELEASE}
- exit 0 ;;
- *:Plan9:*:*)
- # "uname -m" is not consistent, so use $cputype instead. 386
- # is converted to i386 for consistency with other x86
- # operating systems.
- if test "$cputype" = "386"; then
- UNAME_MACHINE=i386
- else
- UNAME_MACHINE="$cputype"
- fi
- echo ${UNAME_MACHINE}-unknown-plan9
- exit 0 ;;
- i*86:OS/2:*:*)
- # If we were able to find `uname', then EMX Unix compatibility
- # is probably installed.
- echo ${UNAME_MACHINE}-pc-os2-emx
- exit 0 ;;
- *:TOPS-10:*:*)
- echo pdp10-unknown-tops10
- exit 0 ;;
- *:TENEX:*:*)
- echo pdp10-unknown-tenex
- exit 0 ;;
- KS10:TOPS-20:*:* | KL10:TOPS-20:*:* | TYPE4:TOPS-20:*:*)
- echo pdp10-dec-tops20
- exit 0 ;;
- XKL-1:TOPS-20:*:* | TYPE5:TOPS-20:*:*)
- echo pdp10-xkl-tops20
- exit 0 ;;
- *:TOPS-20:*:*)
- echo pdp10-unknown-tops20
- exit 0 ;;
- *:ITS:*:*)
- echo pdp10-unknown-its
- exit 0 ;;
- i*86:XTS-300:*:STOP)
- echo ${UNAME_MACHINE}-unknown-stop
- exit 0 ;;
- i*86:atheos:*:*)
- echo ${UNAME_MACHINE}-unknown-atheos
- exit 0 ;;
-esac
-#echo '(No uname command or uname output not recognized.)' 1>&2
-#echo "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" 1>&2
-eval $set_cc_for_build
-cat >$dummy.c <<EOF
-#ifdef _SEQUENT_
-# include <sys/types.h>
-# include <sys/utsname.h>
-#endif
-main ()
-#if defined (sony)
-#if defined (MIPSEB)
- /* BFD wants "bsd" instead of "newsos". Perhaps BFD should be changed,
- I don't know.... */
- printf ("mips-sony-bsd\n"); exit (0);
-#else
-#include <sys/param.h>
- printf ("m68k-sony-newsos%s\n",
-#ifdef NEWSOS4
- "4"
-#else
-#endif
- ); exit (0);
-#endif
-#endif
-#if defined (__arm) && defined (__acorn) && defined (__unix)
- printf ("arm-acorn-riscix"); exit (0);
-#endif
-#if defined (hp300) && !defined (hpux)
- printf ("m68k-hp-bsd\n"); exit (0);
-#endif
-#if defined (NeXT)
-#if !defined (__ARCHITECTURE__)
-#define __ARCHITECTURE__ "m68k"
-#endif
- int version;
- version=`(hostinfo | sed -n 's/.*NeXT Mach \([0-9]*\).*/\1/p') 2>/dev/null`;
- if (version < 4)
- printf ("%s-next-nextstep%d\n", __ARCHITECTURE__, version);
- else
- printf ("%s-next-openstep%d\n", __ARCHITECTURE__, version);
- exit (0);
-#endif
-#if defined (MULTIMAX) || defined (n16)
-#if defined (UMAXV)
- printf ("ns32k-encore-sysv\n"); exit (0);
-#else
-#if defined (CMU)
- printf ("ns32k-encore-mach\n"); exit (0);
-#else
- printf ("ns32k-encore-bsd\n"); exit (0);
-#endif
-#endif
-#endif
-#if defined (__386BSD__)
- printf ("i386-pc-bsd\n"); exit (0);
-#endif
-#if defined (sequent)
-#if defined (i386)
- printf ("i386-sequent-dynix\n"); exit (0);
-#endif
-#if defined (ns32000)
- printf ("ns32k-sequent-dynix\n"); exit (0);
-#endif
-#endif
-#if defined (_SEQUENT_)
- struct utsname un;
- uname(&un);
- if (strncmp(un.version, "V2", 2) == 0) {
- printf ("i386-sequent-ptx2\n"); exit (0);
- if (strncmp(un.version, "V1", 2) == 0) { /* XXX is V1 correct? */
- printf ("i386-sequent-ptx1\n"); exit (0);
- printf ("i386-sequent-ptx\n"); exit (0);
-#endif
-#if defined (vax)
-# if !defined (ultrix)
-# include <sys/param.h>
-# if defined (BSD)
-# if BSD == 43
- printf ("vax-dec-bsd4.3\n"); exit (0);
-# else
-# if BSD == 199006
- printf ("vax-dec-bsd4.3reno\n"); exit (0);
-# else
- printf ("vax-dec-bsd\n"); exit (0);
-# endif
-# endif
-# else
-# endif
-# else
- printf ("vax-dec-ultrix\n"); exit (0);
-# endif
-#endif
-#if defined (alliant) && defined (i860)
- printf ("i860-alliant-bsd\n"); exit (0);
-#endif
- exit (1);
-EOF
-$CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null && $dummy && rm -f $dummy.c $dummy && rmdir $tmpdir && exit 0
-rm -f $dummy.c $dummy && rmdir $tmpdir
-# Apollos put the system type in the environment.
-test -d /usr/apollo && { echo ${ISP}-apollo-${SYSTYPE}; exit 0; }
-# Convex versions that predate uname can use getsysinfo(1)
-if [ -x /usr/convex/getsysinfo ]
-then
- case `getsysinfo -f cpu_type` in
- c1*)
- exit 0 ;;
- c2*)
- fi
- exit 0 ;;
- c34*)
- exit 0 ;;
- c38*)
- exit 0 ;;
- c4*)
- exit 0 ;;
- esac
-fi
-cat >&2 <<EOF
-$0: unable to guess system type
-This script, last modified $timestamp, has failed to recognize
-the operating system you are using. It is advised that you
-download the most up to date version of the config scripts from
- ftp://ftp.gnu.org/pub/gnu/config/
-If the version you run ($0) is already up to date, please
-send the following data and any information you think might be
-pertinent to <config-patches at gnu.org> in order to provide the needed
-information to handle your system.
-config.guess timestamp = $timestamp
-uname -m = `(uname -m) 2>/dev/null || echo unknown`
-uname -r = `(uname -r) 2>/dev/null || echo unknown`
-uname -s = `(uname -s) 2>/dev/null || echo unknown`
-uname -v = `(uname -v) 2>/dev/null || echo unknown`
-/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null`
-/bin/uname -X = `(/bin/uname -X) 2>/dev/null`
-hostinfo = `(hostinfo) 2>/dev/null`
-/bin/universe = `(/bin/universe) 2>/dev/null`
-/usr/bin/arch -k = `(/usr/bin/arch -k) 2>/dev/null`
-/bin/arch = `(/bin/arch) 2>/dev/null`
-/usr/bin/oslevel = `(/usr/bin/oslevel) 2>/dev/null`
-/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null`
-UNAME_MACHINE = ${UNAME_MACHINE}
-UNAME_RELEASE = ${UNAME_RELEASE}
-UNAME_SYSTEM = ${UNAME_SYSTEM}
-UNAME_VERSION = ${UNAME_VERSION}
-EOF
-exit 1
-# Local variables:
-# eval: (add-hook 'write-file-hooks 'time-stamp)
-# time-stamp-start: "timestamp='"
-# time-stamp-format: "%:y-%02m-%02d"
-# time-stamp-end: "'"
-# End:
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.guess (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.guess)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.guess (rev 0)
@@ -0,0 +1,1363 @@
+#! /bin/sh
+# Attempt to guess a canonical system name.
+# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
+# 2000, 2001, 2002 Free Software Foundation, Inc.
+timestamp='2002-10-21'
+# This file is free software; you can redistribute it and/or modify it
+# under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful, but
+# WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+# General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+# As a special exception to the GNU General Public License, if you
+# distribute this file as part of a program that contains a
+# configuration script generated by Autoconf, you may include it under
+# the same distribution terms that you use for the rest of that program.
+# Originally written by Per Bothner <per at bothner.com>.
+# Please send patches to <config-patches at gnu.org>. Submit a context
+# diff and a properly formatted ChangeLog entry.
+# This script attempts to guess a canonical system name similar to
+# config.sub. If it succeeds, it prints the system name on stdout, and
+# exits with 0. Otherwise, it exits with 1.
+# The plan is that this can be called by configure scripts if you
+# don't specify an explicit build system type.
+me=`echo "$0" | sed -e 's,.*/,,'`
+usage="\
+Usage: $0 [OPTION]
+Output the configuration name of the system \`$me' is run on.
+Operation modes:
+ -h, --help print this help, then exit
+ -t, --time-stamp print date of last modification, then exit
+ -v, --version print version number, then exit
+Report bugs and patches to <config-patches at gnu.org>."
+version="\
+GNU config.guess ($timestamp)
+Originally written by Per Bothner.
+Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001
+Free Software Foundation, Inc.
+This is free software; see the source for copying conditions. There is NO
+warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
+help="
+Try \`$me --help' for more information."
+# Parse command line
+while test $# -gt 0 ; do
+ case $1 in
+ --time-stamp | --time* | -t )
+ echo "$timestamp" ; exit 0 ;;
+ --version | -v )
+ echo "$version" ; exit 0 ;;
+ --help | --h* | -h )
+ echo "$usage"; exit 0 ;;
+ -- ) # Stop option processing
+ shift; break ;;
+ - ) # Use stdin as input.
+ break ;;
+ echo "$me: invalid option $1$help" >&2
+ exit 1 ;;
+ break ;;
+ esac
+done
+if test $# != 0; then
+ echo "$me: too many arguments$help" >&2
+ exit 1
+fi
+trap 'exit 1' 1 2 15
+# CC_FOR_BUILD -- compiler used by this script. Note that the use of a
+# compiler to aid in system detection is discouraged as it requires
+# temporary files to be created and, as you can see below, it is a
+# headache to deal with in a portable fashion.
+# Historically, `CC_FOR_BUILD' used to be named `HOST_CC'. We still
+# use `HOST_CC' if defined, but it is deprecated.
+# This shell variable is my proudest work .. or something. --bje
+set_cc_for_build='tmpdir=${TMPDIR-/tmp}/config-guess-$$ ;
+(old=`umask` && umask 077 && mkdir $tmpdir && umask $old && unset old)
+ || (echo "$me: cannot create $tmpdir" >&2 && exit 1) ;
+dummy=$tmpdir/dummy ;
+files="$dummy.c $dummy.o $dummy.rel $dummy" ;
+trap '"'"'rm -f $files; rmdir $tmpdir; exit 1'"'"' 1 2 15 ;
+case $CC_FOR_BUILD,$HOST_CC,$CC in
+ ,,) echo "int x;" > $dummy.c ;
+ for c in cc gcc c89 c99 ; do
+ if ($c -c -o $dummy.o $dummy.c) >/dev/null 2>&1 ; then
+ CC_FOR_BUILD="$c"; break ;
+ fi ;
+ done ;
+ rm -f $files ;
+ if test x"$CC_FOR_BUILD" = x ; then
+ CC_FOR_BUILD=no_compiler_found ;
+ fi
+ ,,*) CC_FOR_BUILD=$CC ;;
+ ,*,*) CC_FOR_BUILD=$HOST_CC ;;
+esac ;
+unset files'
+# This is needed to find uname on a Pyramid OSx when run in the BSD universe.
+# (ghazi at noc.rutgers.edu 1994-08-24)
+if (test -f /.attbin/uname) >/dev/null 2>&1 ; then
+ PATH=$PATH:/.attbin ; export PATH
+fi
+UNAME_MACHINE=`(uname -m) 2>/dev/null` || UNAME_MACHINE=unknown
+UNAME_RELEASE=`(uname -r) 2>/dev/null` || UNAME_RELEASE=unknown
+UNAME_SYSTEM=`(uname -s) 2>/dev/null` || UNAME_SYSTEM=unknown
+UNAME_VERSION=`(uname -v) 2>/dev/null` || UNAME_VERSION=unknown
+# Note: order is significant - the case branches are not exclusive.
+case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
+ *:NetBSD:*:*)
+ # NetBSD (nbsd) targets should (where applicable) match one or
+ # more of the tupples: *-*-netbsdelf*, *-*-netbsdaout*,
+ # *-*-netbsdecoff* and *-*-netbsd*. For targets that recently
+ # switched to ELF, *-*-netbsd* would select the old
+ # object file format. This provides both forward
+ # compatibility and a consistent mechanism for selecting the
+ # Note: NetBSD doesn't particularly care about the vendor
+ # portion of the name. We always set it to "unknown".
+ sysctl="sysctl -n hw.machine_arch"
+ UNAME_MACHINE_ARCH=`(/sbin/$sysctl 2>/dev/null || \
+ /usr/sbin/$sysctl 2>/dev/null || echo unknown)`
+ case "${UNAME_MACHINE_ARCH}" in
+ armeb) machine=armeb-unknown ;;
+ arm*) machine=arm-unknown ;;
+ sh3el) machine=shl-unknown ;;
+ sh3eb) machine=sh-unknown ;;
+ *) machine=${UNAME_MACHINE_ARCH}-unknown ;;
+ esac
+ # The Operating System including object format, if it has switched
+ # to ELF recently, or will in the future.
+ arm*|i386|m68k|ns32k|sh3*|sparc|vax)
+ eval $set_cc_for_build
+ if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
+ | grep __ELF__ >/dev/null
+ then
+ # Once all utilities can be ECOFF (netbsdecoff) or a.out (netbsdaout).
+ # Return netbsd for either. FIX?
+ os=netbsd
+ else
+ os=netbsdelf
+ fi
+ os=netbsd
+ esac
+ # The OS release
+ release=`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
+ # Since CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM:
+ # contains redundant information, the shorter form:
+ # CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
+ echo "${machine}-${os}${release}"
+ exit 0 ;;
+ amiga:OpenBSD:*:*)
+ echo m68k-unknown-openbsd${UNAME_RELEASE}
+ exit 0 ;;
+ arc:OpenBSD:*:*)
+ echo mipsel-unknown-openbsd${UNAME_RELEASE}
+ exit 0 ;;
+ hp300:OpenBSD:*:*)
+ exit 0 ;;
+ mac68k:OpenBSD:*:*)
+ exit 0 ;;
+ macppc:OpenBSD:*:*)
+ echo powerpc-unknown-openbsd${UNAME_RELEASE}
+ exit 0 ;;
+ mvme68k:OpenBSD:*:*)
+ exit 0 ;;
+ mvme88k:OpenBSD:*:*)
+ echo m88k-unknown-openbsd${UNAME_RELEASE}
+ exit 0 ;;
+ mvmeppc:OpenBSD:*:*)
+ exit 0 ;;
+ pmax:OpenBSD:*:*)
+ exit 0 ;;
+ sgi:OpenBSD:*:*)
+ echo mipseb-unknown-openbsd${UNAME_RELEASE}
+ exit 0 ;;
+ sun3:OpenBSD:*:*)
+ exit 0 ;;
+ wgrisc:OpenBSD:*:*)
+ exit 0 ;;
+ *:OpenBSD:*:*)
+ echo ${UNAME_MACHINE}-unknown-openbsd${UNAME_RELEASE}
+ exit 0 ;;
+ alpha:OSF1:*:*)
+ if test $UNAME_RELEASE = "V4.0"; then
+ UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $3}'`
+ fi
+ # A Vn.n version is a released version.
+ # A Tn.n version is a released field test version.
+ # A Xn.n version is an unreleased experimental baselevel.
+ # 1.2 uses "1.2" for uname -r.
+ cat <<EOF >$dummy.s
+ .data
+\$Lformat:
+ .byte 37,100,45,37,120,10,0 # "%d-%x\n"
+ .text
+ .globl main
+ .align 4
+ .ent main
+main:
+ .frame \$30,16,\$26,0
+ ldgp \$29,0(\$27)
+ .prologue 1
+ .long 0x47e03d80 # implver \$0
+ lda \$2,-1
+ .long 0x47e20c21 # amask \$2,\$1
+ lda \$16,\$Lformat
+ mov \$0,\$17
+ not \$1,\$18
+ jsr \$26,printf
+ ldgp \$29,0(\$26)
+ mov 0,\$16
+ jsr \$26,exit
+ .end main
+EOF
+ $CC_FOR_BUILD -o $dummy $dummy.s 2>/dev/null
+ if test "$?" = 0 ; then
+ case `$dummy` in
+ 0-0)
+ UNAME_MACHINE="alpha"
+ 1-0)
+ UNAME_MACHINE="alphaev5"
+ 1-1)
+ UNAME_MACHINE="alphaev56"
+ 1-101)
+ UNAME_MACHINE="alphapca56"
+ 2-303)
+ UNAME_MACHINE="alphaev6"
+ 2-307)
+ UNAME_MACHINE="alphaev67"
+ 2-1307)
+ UNAME_MACHINE="alphaev68"
+ 3-1307)
+ UNAME_MACHINE="alphaev7"
+ esac
+ fi
+ rm -f $dummy.s $dummy && rmdir $tmpdir
+ echo ${UNAME_MACHINE}-dec-osf`echo ${UNAME_RELEASE} | sed -e 's/^[VTX]//' | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
+ exit 0 ;;
+ Alpha\ *:Windows_NT*:*)
+ # How do we know it's Interix rather than the generic POSIX subsystem?
+ # Should we change UNAME_MACHINE based on the output of uname instead
+ # of the specific Alpha model?
+ echo alpha-pc-interix
+ exit 0 ;;
+ 21064:Windows_NT:50:3)
+ echo alpha-dec-winnt3.5
+ exit 0 ;;
+ Amiga*:UNIX_System_V:4.0:*)
+ echo m68k-unknown-sysv4
+ exit 0;;
+ *:[Aa]miga[Oo][Ss]:*:*)
+ echo ${UNAME_MACHINE}-unknown-amigaos
+ exit 0 ;;
+ *:[Mm]orph[Oo][Ss]:*:*)
+ echo ${UNAME_MACHINE}-unknown-morphos
+ exit 0 ;;
+ *:OS/390:*:*)
+ echo i370-ibm-openedition
+ exit 0 ;;
+ arm:RISC*:1.[012]*:*|arm:riscix:1.[012]*:*)
+ echo arm-acorn-riscix${UNAME_RELEASE}
+ exit 0;;
+ SR2?01:HI-UX/MPP:*:* | SR8000:HI-UX/MPP:*:*)
+ echo hppa1.1-hitachi-hiuxmpp
+ exit 0;;
+ Pyramid*:OSx*:*:* | MIS*:OSx*:*:* | MIS*:SMP_DC-OSx*:*:*)
+ # akee at wpdis03.wpafb.af.mil (Earle F. Ake) contributed MIS and NILE.
+ if test "`(/bin/universe) 2>/dev/null`" = att ; then
+ echo pyramid-pyramid-sysv3
+ else
+ echo pyramid-pyramid-bsd
+ fi
+ exit 0 ;;
+ NILE*:*:*:dcosx)
+ echo pyramid-pyramid-svr4
+ exit 0 ;;
+ DRS?6000:UNIX_SV:4.2*:7*)
+ case `/usr/bin/uname -p` in
+ sparc) echo sparc-icl-nx7 && exit 0 ;;
+ esac ;;
+ sun4H:SunOS:5.*:*)
+ echo sparc-hal-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+ exit 0 ;;
+ sun4*:SunOS:5.*:* | tadpole*:SunOS:5.*:*)
+ echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+ exit 0 ;;
+ i86pc:SunOS:5.*:*)
+ echo i386-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+ exit 0 ;;
+ sun4*:SunOS:6*:*)
+ # According to config.sub, this is the proper way to canonicalize
+ # SunOS6. Hard to guess exactly what SunOS6 will be like, but
+ # it's likely to be more like Solaris than SunOS4.
+ echo sparc-sun-solaris3`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+ exit 0 ;;
+ sun4*:SunOS:*:*)
+ case "`/usr/bin/arch -k`" in
+ Series*|S4*)
+ UNAME_RELEASE=`uname -v`
+ esac
+ # Japanese Language versions have a version number like `4.1.3-JL'.
+ echo sparc-sun-sunos`echo ${UNAME_RELEASE}|sed -e 's/-/_/'`
+ exit 0 ;;
+ sun3*:SunOS:*:*)
+ echo m68k-sun-sunos${UNAME_RELEASE}
+ exit 0 ;;
+ sun*:*:4.2BSD:*)
+ UNAME_RELEASE=`(sed 1q /etc/motd | awk '{print substr($5,1,3)}') 2>/dev/null`
+ test "x${UNAME_RELEASE}" = "x" && UNAME_RELEASE=3
+ case "`/bin/arch`" in
+ sun3)
+ sun4)
+ echo sparc-sun-sunos${UNAME_RELEASE}
+ esac
+ exit 0 ;;
+ aushp:SunOS:*:*)
+ echo sparc-auspex-sunos${UNAME_RELEASE}
+ exit 0 ;;
+ # The situation for MiNT is a little confusing. The machine name
+ # can be virtually everything (everything which is not
+ # "atarist" or "atariste" at least should have a processor
+ # > m68000). The system name ranges from "MiNT" over "FreeMiNT"
+ # to the lowercase version "mint" (or "freemint"). Finally
+ # the system name "TOS" denotes a system which is actually not
+ # MiNT. But MiNT is downward compatible to TOS, so this should
+ # be no problem.
+ atarist[e]:*MiNT:*:* | atarist[e]:*mint:*:* | atarist[e]:*TOS:*:*)
+ echo m68k-atari-mint${UNAME_RELEASE}
+ exit 0 ;;
+ atari*:*MiNT:*:* | atari*:*mint:*:* | atarist[e]:*TOS:*:*)
+ exit 0 ;;
+ *falcon*:*MiNT:*:* | *falcon*:*mint:*:* | *falcon*:*TOS:*:*)
+ exit 0 ;;
+ milan*:*MiNT:*:* | milan*:*mint:*:* | *milan*:*TOS:*:*)
+ echo m68k-milan-mint${UNAME_RELEASE}
+ exit 0 ;;
+ hades*:*MiNT:*:* | hades*:*mint:*:* | *hades*:*TOS:*:*)
+ echo m68k-hades-mint${UNAME_RELEASE}
+ exit 0 ;;
+ *:*MiNT:*:* | *:*mint:*:* | *:*TOS:*:*)
+ echo m68k-unknown-mint${UNAME_RELEASE}
+ exit 0 ;;
+ powerpc:machten:*:*)
+ echo powerpc-apple-machten${UNAME_RELEASE}
+ exit 0 ;;
+ RISC*:Mach:*:*)
+ echo mips-dec-mach_bsd4.3
+ exit 0 ;;
+ RISC*:ULTRIX:*:*)
+ echo mips-dec-ultrix${UNAME_RELEASE}
+ exit 0 ;;
+ VAX*:ULTRIX*:*:*)
+ echo vax-dec-ultrix${UNAME_RELEASE}
+ exit 0 ;;
+ 2020:CLIX:*:* | 2430:CLIX:*:*)
+ echo clipper-intergraph-clix${UNAME_RELEASE}
+ exit 0 ;;
+ mips:*:*:UMIPS | mips:*:*:RISCos)
+ sed 's/^ //' << EOF >$dummy.c
+#ifdef __cplusplus
+#include <stdio.h> /* for printf() prototype */
+ int main (int argc, char *argv[]) {
+#else
+ int main (argc, argv) int argc; char *argv[]; {
+#endif
+ #if defined (host_mips) && defined (MIPSEB)
+ #if defined (SYSTYPE_SYSV)
+ printf ("mips-mips-riscos%ssysv\n", argv[1]); exit (0);
+ #endif
+ #if defined (SYSTYPE_SVR4)
+ printf ("mips-mips-riscos%ssvr4\n", argv[1]); exit (0);
+ #endif
+ #if defined (SYSTYPE_BSD43) || defined(SYSTYPE_BSD)
+ printf ("mips-mips-riscos%sbsd\n", argv[1]); exit (0);
+ #endif
+ #endif
+ exit (-1);
+EOF
+ $CC_FOR_BUILD -o $dummy $dummy.c \
+ && $dummy `echo "${UNAME_RELEASE}" | sed -n 's/\([0-9]*\).*/\1/p'` \
+ && rm -f $dummy.c $dummy && rmdir $tmpdir && exit 0
+ rm -f $dummy.c $dummy && rmdir $tmpdir
+ echo mips-mips-riscos${UNAME_RELEASE}
+ exit 0 ;;
+ Motorola:PowerMAX_OS:*:*)
+ echo powerpc-motorola-powermax
+ exit 0 ;;
+ Motorola:*:4.3:PL8-*)
+ echo powerpc-harris-powermax
+ exit 0 ;;
+ Night_Hawk:*:*:PowerMAX_OS)
+ exit 0 ;;
+ Night_Hawk:Power_UNIX:*:*)
+ echo powerpc-harris-powerunix
+ exit 0 ;;
+ m88k:CX/UX:7*:*)
+ echo m88k-harris-cxux7
+ exit 0 ;;
+ m88k:*:4*:R4*)
+ echo m88k-motorola-sysv4
+ exit 0 ;;
+ m88k:*:3*:R3*)
+ echo m88k-motorola-sysv3
+ exit 0 ;;
+ AViiON:dgux:*:*)
+ # DG/UX returns AViiON for all architectures
+ UNAME_PROCESSOR=`/usr/bin/uname -p`
+ if [ $UNAME_PROCESSOR = mc88100 ] || [ $UNAME_PROCESSOR = mc88110 ]
+ then
+ if [ ${TARGET_BINARY_INTERFACE}x = m88kdguxelfx ] || \
+ [ ${TARGET_BINARY_INTERFACE}x = x ]
+ then
+ echo m88k-dg-dgux${UNAME_RELEASE}
+ else
+ echo m88k-dg-dguxbcs${UNAME_RELEASE}
+ fi
+ else
+ echo i586-dg-dgux${UNAME_RELEASE}
+ fi
+ exit 0 ;;
+ M88*:DolphinOS:*:*) # DolphinOS (SVR3)
+ echo m88k-dolphin-sysv3
+ exit 0 ;;
+ M88*:*:R3*:*)
+ # Delta 88k system running SVR3
+ exit 0 ;;
+ XD88*:*:*:*) # Tektronix XD88 system running UTekV (SVR3)
+ echo m88k-tektronix-sysv3
+ exit 0 ;;
+ Tek43[0-9][0-9]:UTek:*:*) # Tektronix 4300 system running UTek (BSD)
+ echo m68k-tektronix-bsd
+ exit 0 ;;
+ *:IRIX*:*:*)
+ echo mips-sgi-irix`echo ${UNAME_RELEASE}|sed -e 's/-/_/g'`
+ exit 0 ;;
+ ????????:AIX?:[12].1:2) # AIX 2.2.1 or AIX 2.1.1 is RT/PC AIX.
+ echo romp-ibm-aix # uname -m gives an 8 hex-code CPU id
+ exit 0 ;; # Note that: echo "'`uname -s`'" gives 'AIX '
+ i*86:AIX:*:*)
+ echo i386-ibm-aix
+ exit 0 ;;
+ ia64:AIX:*:*)
+ if [ -x /usr/bin/oslevel ] ; then
+ IBM_REV=`/usr/bin/oslevel`
+ else
+ IBM_REV=${UNAME_VERSION}.${UNAME_RELEASE}
+ fi
+ echo ${UNAME_MACHINE}-ibm-aix${IBM_REV}
+ exit 0 ;;
+ *:AIX:2:3)
+ if grep bos325 /usr/include/stdio.h >/dev/null 2>&1; then
+ #include <sys/systemcfg.h>
+ main()
+ if (!__power_pc())
+ exit(1);
+ puts("powerpc-ibm-aix3.2.5");
+ exit(0);
+EOF
+ $CC_FOR_BUILD -o $dummy $dummy.c && $dummy && rm -f $dummy.c $dummy && rmdir $tmpdir && exit 0
+ echo rs6000-ibm-aix3.2.5
+ elif grep bos324 /usr/include/stdio.h >/dev/null 2>&1; then
+ echo rs6000-ibm-aix3.2.4
+ else
+ fi
+ exit 0 ;;
+ *:AIX:*:[45])
+ IBM_CPU_ID=`/usr/sbin/lsdev -C -c processor -S available | sed 1q | awk '{ print $1 }'`
+ if /usr/sbin/lsattr -El ${IBM_CPU_ID} | grep ' POWER' >/dev/null 2>&1; then
+ IBM_ARCH=rs6000
+ else
+ IBM_ARCH=powerpc
+ fi
+ else
+ fi
+ echo ${IBM_ARCH}-ibm-aix${IBM_REV}
+ exit 0 ;;
+ *:AIX:*:*)
+ exit 0 ;;
+ ibmrt:4.4BSD:*|romp-ibm:BSD:*)
+ echo romp-ibm-bsd4.4
+ exit 0 ;;
+ ibmrt:*BSD:*|romp-ibm:BSD:*) # covers RT/PC BSD and
+ echo romp-ibm-bsd${UNAME_RELEASE} # 4.3 with uname added to
+ exit 0 ;; # report: romp-ibm BSD 4.3
+ *:BOSX:*:*)
+ echo rs6000-bull-bosx
+ exit 0 ;;
+ DPX/2?00:B.O.S.:*:*)
+ echo m68k-bull-sysv3
+ exit 0 ;;
+ 9000/[34]??:4.3bsd:1.*:*)
+ echo m68k-hp-bsd
+ exit 0 ;;
+ hp300:4.4BSD:*:* | 9000/[34]??:4.3bsd:2.*:*)
+ echo m68k-hp-bsd4.4
+ exit 0 ;;
+ 9000/[34678]??:HP-UX:*:*)
+ HPUX_REV=`echo ${UNAME_RELEASE}|sed -e 's/[^.]*.[0B]*//'`
+ case "${UNAME_MACHINE}" in
+ 9000/31? ) HP_ARCH=m68000 ;;
+ 9000/[34]?? ) HP_ARCH=m68k ;;
+ 9000/[678][0-9][0-9])
+ if [ -x /usr/bin/getconf ]; then
+ sc_cpu_version=`/usr/bin/getconf SC_CPU_VERSION 2>/dev/null`
+ sc_kernel_bits=`/usr/bin/getconf SC_KERNEL_BITS 2>/dev/null`
+ case "${sc_cpu_version}" in
+ 523) HP_ARCH="hppa1.0" ;; # CPU_PA_RISC1_0
+ 528) HP_ARCH="hppa1.1" ;; # CPU_PA_RISC1_1
+ 532) # CPU_PA_RISC2_0
+ case "${sc_kernel_bits}" in
+ 32) HP_ARCH="hppa2.0n" ;;
+ 64) HP_ARCH="hppa2.0w" ;;
+ '') HP_ARCH="hppa2.0" ;; # HP-UX 10.20
+ esac ;;
+ esac
+ fi
+ if [ "${HP_ARCH}" = "" ]; then
+ #define _HPUX_SOURCE
+ #include <stdlib.h>
+ #include <unistd.h>
+ int main ()
+ #if defined(_SC_KERNEL_BITS)
+ long bits = sysconf(_SC_KERNEL_BITS);
+ #endif
+ long cpu = sysconf (_SC_CPU_VERSION);
+ switch (cpu)
+ case CPU_PA_RISC1_0: puts ("hppa1.0"); break;
+ case CPU_PA_RISC1_1: puts ("hppa1.1"); break;
+ case CPU_PA_RISC2_0:
+ switch (bits)
+ case 64: puts ("hppa2.0w"); break;
+ case 32: puts ("hppa2.0n"); break;
+ default: puts ("hppa2.0"); break;
+ } break;
+ #else /* !defined(_SC_KERNEL_BITS) */
+ puts ("hppa2.0"); break;
+ #endif
+ default: puts ("hppa1.0"); break;
+ exit (0);
+EOF
+ (CCOPTS= $CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null) && HP_ARCH=`$dummy`
+ if test -z "$HP_ARCH"; then HP_ARCH=hppa; fi
+ fi ;;
+ esac
+ echo ${HP_ARCH}-hp-hpux${HPUX_REV}
+ exit 0 ;;
+ ia64:HP-UX:*:*)
+ echo ia64-hp-hpux${HPUX_REV}
+ exit 0 ;;
+ 3050*:HI-UX:*:*)
+ int
+ main ()
+ /* The order matters, because CPU_IS_HP_MC68K erroneously returns
+ true for CPU_PA_RISC1_0. CPU_IS_PA_RISC returns correct
+ results, however. */
+ if (CPU_IS_PA_RISC (cpu))
+ switch (cpu)
+ case CPU_PA_RISC1_0: puts ("hppa1.0-hitachi-hiuxwe2"); break;
+ case CPU_PA_RISC1_1: puts ("hppa1.1-hitachi-hiuxwe2"); break;
+ case CPU_PA_RISC2_0: puts ("hppa2.0-hitachi-hiuxwe2"); break;
+ default: puts ("hppa-hitachi-hiuxwe2"); break;
+ else if (CPU_IS_HP_MC68K (cpu))
+ puts ("m68k-hitachi-hiuxwe2");
+ else puts ("unknown-hitachi-hiuxwe2");
+ exit (0);
+EOF
+ echo unknown-hitachi-hiuxwe2
+ exit 0 ;;
+ 9000/7??:4.3bsd:*:* | 9000/8?[79]:4.3bsd:*:* )
+ echo hppa1.1-hp-bsd
+ exit 0 ;;
+ 9000/8??:4.3bsd:*:*)
+ echo hppa1.0-hp-bsd
+ exit 0 ;;
+ *9??*:MPE/iX:*:* | *3000*:MPE/iX:*:*)
+ echo hppa1.0-hp-mpeix
+ exit 0 ;;
+ hp7??:OSF1:*:* | hp8?[79]:OSF1:*:* )
+ echo hppa1.1-hp-osf
+ exit 0 ;;
+ hp8??:OSF1:*:*)
+ echo hppa1.0-hp-osf
+ exit 0 ;;
+ i*86:OSF1:*:*)
+ if [ -x /usr/sbin/sysversion ] ; then
+ echo ${UNAME_MACHINE}-unknown-osf1mk
+ else
+ fi
+ exit 0 ;;
+ parisc*:Lites*:*:*)
+ echo hppa1.1-hp-lites
+ exit 0 ;;
+ C1*:ConvexOS:*:* | convex:ConvexOS:C1*:*)
+ echo c1-convex-bsd
+ exit 0 ;;
+ C2*:ConvexOS:*:* | convex:ConvexOS:C2*:*)
+ if getsysinfo -f scalar_acc
+ then echo c32-convex-bsd
+ else echo c2-convex-bsd
+ fi
+ exit 0 ;;
+ C34*:ConvexOS:*:* | convex:ConvexOS:C34*:*)
+ echo c34-convex-bsd
+ exit 0 ;;
+ C38*:ConvexOS:*:* | convex:ConvexOS:C38*:*)
+ echo c38-convex-bsd
+ exit 0 ;;
+ C4*:ConvexOS:*:* | convex:ConvexOS:C4*:*)
+ echo c4-convex-bsd
+ exit 0 ;;
+ CRAY*Y-MP:*:*:*)
+ echo ymp-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+ exit 0 ;;
+ CRAY*[A-Z]90:*:*:*)
+ echo ${UNAME_MACHINE}-cray-unicos${UNAME_RELEASE} \
+ | sed -e 's/CRAY.*\([A-Z]90\)/\1/' \
+ -e y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/ \
+ -e 's/\.[^.]*$/.X/'
+ exit 0 ;;
+ CRAY*TS:*:*:*)
+ echo t90-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+ exit 0 ;;
+ CRAY*T3D:*:*:*)
+ echo alpha-cray-unicosmk${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+ exit 0 ;;
+ CRAY*T3E:*:*:*)
+ echo alphaev5-cray-unicosmk${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+ exit 0 ;;
+ CRAY*SV1:*:*:*)
+ echo sv1-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+ exit 0 ;;
+ F30[01]:UNIX_System_V:*:* | F700:UNIX_System_V:*:*)
+ FUJITSU_PROC=`uname -m | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
+ FUJITSU_SYS=`uname -p | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/\///'`
+ FUJITSU_REL=`echo ${UNAME_RELEASE} | sed -e 's/ /_/'`
+ echo "${FUJITSU_PROC}-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
+ exit 0 ;;
+ i*86:BSD/386:*:* | i*86:BSD/OS:*:* | *:Ascend\ Embedded/OS:*:*)
+ echo ${UNAME_MACHINE}-pc-bsdi${UNAME_RELEASE}
+ exit 0 ;;
+ sparc*:BSD/OS:*:*)
+ echo sparc-unknown-bsdi${UNAME_RELEASE}
+ exit 0 ;;
+ *:BSD/OS:*:*)
+ echo ${UNAME_MACHINE}-unknown-bsdi${UNAME_RELEASE}
+ exit 0 ;;
+ *:FreeBSD:*:*)
+ # Determine whether the default compiler uses glibc.
+ #include <features.h>
+ #if __GLIBC__ >= 2
+ LIBC=gnu
+ #else
+ LIBC=
+ #endif
+EOF
+ eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^LIBC=`
+ rm -f $dummy.c && rmdir $tmpdir
+ echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`${LIBC:+-$LIBC}
+ exit 0 ;;
+ i*:CYGWIN*:*)
+ echo ${UNAME_MACHINE}-pc-cygwin
+ exit 0 ;;
+ i*:MINGW*:*)
+ echo ${UNAME_MACHINE}-pc-mingw32
+ exit 0 ;;
+ i*:PW*:*)
+ echo ${UNAME_MACHINE}-pc-pw32
+ exit 0 ;;
+ x86:Interix*:3*)
+ echo i386-pc-interix3
+ exit 0 ;;
+ i*:Windows_NT*:* | Pentium*:Windows_NT*:*)
+ # It also conflicts with pre-2.0 versions of AT&T UWIN. Should we
+ # UNAME_MACHINE based on the output of uname instead of i386?
+ exit 0 ;;
+ i*:UWIN*:*)
+ echo ${UNAME_MACHINE}-pc-uwin
+ exit 0 ;;
+ p*:CYGWIN*:*)
+ echo powerpcle-unknown-cygwin
+ exit 0 ;;
+ prep*:SunOS:5.*:*)
+ echo powerpcle-unknown-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+ exit 0 ;;
+ *:GNU:*:*)
+ echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-gnu`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
+ exit 0 ;;
+ i*86:Minix:*:*)
+ echo ${UNAME_MACHINE}-pc-minix
+ exit 0 ;;
+ arm*:Linux:*:*)
+ echo ${UNAME_MACHINE}-unknown-linux-gnu
+ exit 0 ;;
+ ia64:Linux:*:*)
+ exit 0 ;;
+ m68*:Linux:*:*)
+ exit 0 ;;
+ mips:Linux:*:*)
+ #undef CPU
+ #undef mips
+ #undef mipsel
+ #if defined(__MIPSEL__) || defined(__MIPSEL) || defined(_MIPSEL) || defined(MIPSEL)
+ CPU=mipsel
+ #else
+ #if defined(__MIPSEB__) || defined(__MIPSEB) || defined(_MIPSEB) || defined(MIPSEB)
+ CPU=mips
+ #else
+ CPU=
+ #endif
+ #endif
+EOF
+ eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^CPU=`
+ test x"${CPU}" != x && echo "${CPU}-pc-linux-gnu" && exit 0
+ ppc:Linux:*:*)
+ echo powerpc-unknown-linux-gnu
+ exit 0 ;;
+ ppc64:Linux:*:*)
+ echo powerpc64-unknown-linux-gnu
+ exit 0 ;;
+ alpha:Linux:*:*)
+ case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
+ EV5) UNAME_MACHINE=alphaev5 ;;
+ EV56) UNAME_MACHINE=alphaev56 ;;
+ PCA56) UNAME_MACHINE=alphapca56 ;;
+ PCA57) UNAME_MACHINE=alphapca56 ;;
+ EV6) UNAME_MACHINE=alphaev6 ;;
+ EV67) UNAME_MACHINE=alphaev67 ;;
+ EV68*) UNAME_MACHINE=alphaev68 ;;
+ esac
+ objdump --private-headers /bin/sh | grep ld.so.1 >/dev/null
+ if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
+ echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
+ exit 0 ;;
+ parisc:Linux:*:* | hppa:Linux:*:*)
+ # Look for CPU level
+ case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
+ PA7*) echo hppa1.1-unknown-linux-gnu ;;
+ PA8*) echo hppa2.0-unknown-linux-gnu ;;
+ *) echo hppa-unknown-linux-gnu ;;
+ esac
+ exit 0 ;;
+ parisc64:Linux:*:* | hppa64:Linux:*:*)
+ echo hppa64-unknown-linux-gnu
+ exit 0 ;;
+ s390:Linux:*:* | s390x:Linux:*:*)
+ echo ${UNAME_MACHINE}-ibm-linux
+ exit 0 ;;
+ sh*:Linux:*:*)
+ exit 0 ;;
+ sparc:Linux:*:* | sparc64:Linux:*:*)
+ exit 0 ;;
+ x86_64:Linux:*:*)
+ echo x86_64-unknown-linux-gnu
+ exit 0 ;;
+ i*86:Linux:*:*)
+ # The BFD linker knows what the default object file format is, so
+ # first see if it will tell us. cd to the root directory to prevent
+ # problems with other programs or directories called `ld' in the path.
+ # Set LC_ALL=C to ensure ld outputs messages in English.
+ ld_supported_targets=`cd /; LC_ALL=C ld --help 2>&1 \
+ | sed -ne '/supported targets:/!d
+ s/[ ][ ]*/ /g
+ s/.*supported targets: *//
+ s/ .*//
+ p'`
+ case "$ld_supported_targets" in
+ elf32-i386)
+ TENTATIVE="${UNAME_MACHINE}-pc-linux-gnu"
+ a.out-i386-linux)
+ echo "${UNAME_MACHINE}-pc-linux-gnuaout"
+ exit 0 ;;
+ coff-i386)
+ echo "${UNAME_MACHINE}-pc-linux-gnucoff"
+ exit 0 ;;
+ # Either a pre-BFD a.out linker (linux-gnuoldld) or
+ # one that does not give us useful --help.
+ echo "${UNAME_MACHINE}-pc-linux-gnuoldld"
+ exit 0 ;;
+ esac
+ # Determine whether the default compiler is a.out or elf
+ #ifdef __ELF__
+ # ifdef __GLIBC__
+ # if __GLIBC__ >= 2
+ LIBC=gnu
+ # else
+ LIBC=gnulibc1
+ # endif
+ # else
+ LIBC=gnulibc1
+ # endif
+ #else
+ #ifdef __INTEL_COMPILER
+ LIBC=gnu
+ #else
+ LIBC=gnuaout
+ #endif
+ #endif
+EOF
+ test x"${LIBC}" != x && echo "${UNAME_MACHINE}-pc-linux-${LIBC}" && exit 0
+ test x"${TENTATIVE}" != x && echo "${TENTATIVE}" && exit 0
+ i*86:DYNIX/ptx:4*:*)
+ # ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
+ # earlier versions are messed up and put the nodename in both
+ # sysname and nodename.
+ echo i386-sequent-sysv4
+ exit 0 ;;
+ i*86:UNIX_SV:4.2MP:2.*)
+ # Unixware is an offshoot of SVR4, but it has its own version
+ # number series starting with 2...
+ # I am not positive that other SVR4 systems won't match this,
+ # I just have to hope. -- rms.
+ # Use sysv4.2uw... so that sysv4* matches it.
+ echo ${UNAME_MACHINE}-pc-sysv4.2uw${UNAME_VERSION}
+ exit 0 ;;
+ i*86:*:4.*:* | i*86:SYSTEM_V:4.*:*)
+ UNAME_REL=`echo ${UNAME_RELEASE} | sed 's/\/MP$//'`
+ if grep Novell /usr/include/link.h >/dev/null 2>/dev/null; then
+ echo ${UNAME_MACHINE}-univel-sysv${UNAME_REL}
+ else
+ echo ${UNAME_MACHINE}-pc-sysv${UNAME_REL}
+ fi
+ exit 0 ;;
+ i*86:*:5:[78]*)
+ case `/bin/uname -X | grep "^Machine"` in
+ *486*) UNAME_MACHINE=i486 ;;
+ *Pentium) UNAME_MACHINE=i586 ;;
+ *Pent*|*Celeron) UNAME_MACHINE=i686 ;;
+ esac
+ echo ${UNAME_MACHINE}-unknown-sysv${UNAME_RELEASE}${UNAME_SYSTEM}${UNAME_VERSION}
+ exit 0 ;;
+ i*86:*:3.2:*)
+ if test -f /usr/options/cb.name; then
+ UNAME_REL=`sed -n 's/.*Version //p' </usr/options/cb.name`
+ echo ${UNAME_MACHINE}-pc-isc$UNAME_REL
+ elif /bin/uname -X 2>/dev/null >/dev/null ; then
+ UNAME_REL=`(/bin/uname -X|grep Release|sed -e 's/.*= //')`
+ (/bin/uname -X|grep i80486 >/dev/null) && UNAME_MACHINE=i486
+ (/bin/uname -X|grep '^Machine.*Pentium' >/dev/null) \
+ && UNAME_MACHINE=i586
+ (/bin/uname -X|grep '^Machine.*Pent *II' >/dev/null) \
+ && UNAME_MACHINE=i686
+ (/bin/uname -X|grep '^Machine.*Pentium Pro' >/dev/null) \
+ echo ${UNAME_MACHINE}-pc-sco$UNAME_REL
+ else
+ echo ${UNAME_MACHINE}-pc-sysv32
+ fi
+ exit 0 ;;
+ i*86:*DOS:*:*)
+ echo ${UNAME_MACHINE}-pc-msdosdjgpp
+ exit 0 ;;
+ pc:*:*:*)
+ # Left here for compatibility:
+ # uname -m prints for DJGPP always 'pc', but it prints nothing about
+ # the processor, so we play safe by assuming i386.
+ echo i386-pc-msdosdjgpp
+ exit 0 ;;
+ Intel:Mach:3*:*)
+ echo i386-pc-mach3
+ exit 0 ;;
+ paragon:*:*:*)
+ echo i860-intel-osf1
+ exit 0 ;;
+ i860:*:4.*:*) # i860-SVR4
+ if grep Stardent /usr/include/sys/uadmin.h >/dev/null 2>&1 ; then
+ echo i860-stardent-sysv${UNAME_RELEASE} # Stardent Vistra i860-SVR4
+ else # Add other i860-SVR4 vendors below as they are discovered.
+ echo i860-unknown-sysv${UNAME_RELEASE} # Unknown i860-SVR4
+ fi
+ exit 0 ;;
+ mini*:CTIX:SYS*5:*)
+ # "miniframe"
+ echo m68010-convergent-sysv
+ exit 0 ;;
+ mc68k:UNIX:SYSTEM5:3.51m)
+ echo m68k-convergent-sysv
+ exit 0 ;;
+ M68*:*:R3V[567]*:*)
+ test -r /sysV68 && echo 'm68k-motorola-sysv' && exit 0 ;;
+ 3[34]??:*:4.0:3.0 | 3[34]??A:*:4.0:3.0 | 3[34]??,*:*:4.0:3.0 | 3[34]??/*:*:4.0:3.0 | 4400:*:4.0:3.0 | 4850:*:4.0:3.0 | SKA40:*:4.0:3.0)
+ OS_REL=''
+ test -r /etc/.relid \
+ && OS_REL=.`sed -n 's/[^ ]* [^ ]* \([0-9][0-9]\).*/\1/p' < /etc/.relid`
+ /bin/uname -p 2>/dev/null | grep 86 >/dev/null \
+ && echo i486-ncr-sysv4.3${OS_REL} && exit 0
+ /bin/uname -p 2>/dev/null | /bin/grep entium >/dev/null \
+ && echo i586-ncr-sysv4.3${OS_REL} && exit 0 ;;
+ 3[34]??:*:4.0:* | 3[34]??,*:*:4.0:*)
+ && echo i486-ncr-sysv4 && exit 0 ;;
+ m68*:LynxOS:2.*:* | m68*:LynxOS:3.0*:*)
+ echo m68k-unknown-lynxos${UNAME_RELEASE}
+ exit 0 ;;
+ mc68030:UNIX_System_V:4.*:*)
+ echo m68k-atari-sysv4
+ exit 0 ;;
+ i*86:LynxOS:2.*:* | i*86:LynxOS:3.[01]*:* | i*86:LynxOS:4.0*:*)
+ echo i386-unknown-lynxos${UNAME_RELEASE}
+ exit 0 ;;
+ TSUNAMI:LynxOS:2.*:*)
+ echo sparc-unknown-lynxos${UNAME_RELEASE}
+ exit 0 ;;
+ rs6000:LynxOS:2.*:*)
+ echo rs6000-unknown-lynxos${UNAME_RELEASE}
+ exit 0 ;;
+ PowerPC:LynxOS:2.*:* | PowerPC:LynxOS:3.[01]*:* | PowerPC:LynxOS:4.0*:*)
+ echo powerpc-unknown-lynxos${UNAME_RELEASE}
+ exit 0 ;;
+ SM[BE]S:UNIX_SV:*:*)
+ echo mips-dde-sysv${UNAME_RELEASE}
+ exit 0 ;;
+ RM*:ReliantUNIX-*:*:*)
+ echo mips-sni-sysv4
+ exit 0 ;;
+ RM*:SINIX-*:*:*)
+ exit 0 ;;
+ *:SINIX-*:*:*)
+ if uname -p 2>/dev/null >/dev/null ; then
+ UNAME_MACHINE=`(uname -p) 2>/dev/null`
+ echo ${UNAME_MACHINE}-sni-sysv4
+ else
+ echo ns32k-sni-sysv
+ fi
+ exit 0 ;;
+ PENTIUM:*:4.0*:*) # Unisys `ClearPath HMP IX 4000' SVR4/MP effort
+ # says <Richard.M.Bartel at ccMail.Census.GOV>
+ echo i586-unisys-sysv4
+ exit 0 ;;
+ *:UNIX_System_V:4*:FTX*)
+ # From Gerald Hewes <hewes at openmarket.com>.
+ # How about differentiating between stratus architectures? -djm
+ echo hppa1.1-stratus-sysv4
+ exit 0 ;;
+ *:*:*:FTX*)
+ # From seanf at swdc.stratus.com.
+ echo i860-stratus-sysv4
+ exit 0 ;;
+ *:VOS:*:*)
+ # From Paul.Green at stratus.com.
+ echo hppa1.1-stratus-vos
+ exit 0 ;;
+ mc68*:A/UX:*:*)
+ echo m68k-apple-aux${UNAME_RELEASE}
+ exit 0 ;;
+ news*:NEWS-OS:6*:*)
+ echo mips-sony-newsos6
+ exit 0 ;;
+ R[34]000:*System_V*:*:* | R4000:UNIX_SYSV:*:* | R*000:UNIX_SV:*:*)
+ if [ -d /usr/nec ]; then
+ echo mips-nec-sysv${UNAME_RELEASE}
+ else
+ echo mips-unknown-sysv${UNAME_RELEASE}
+ fi
+ exit 0 ;;
+ BeBox:BeOS:*:*) # BeOS running on hardware made by Be, PPC only.
+ echo powerpc-be-beos
+ exit 0 ;;
+ BeMac:BeOS:*:*) # BeOS running on Mac or Mac clone, PPC only.
+ echo powerpc-apple-beos
+ exit 0 ;;
+ BePC:BeOS:*:*) # BeOS running on Intel PC compatible.
+ echo i586-pc-beos
+ exit 0 ;;
+ SX-4:SUPER-UX:*:*)
+ echo sx4-nec-superux${UNAME_RELEASE}
+ exit 0 ;;
+ SX-5:SUPER-UX:*:*)
+ echo sx5-nec-superux${UNAME_RELEASE}
+ exit 0 ;;
+ SX-6:SUPER-UX:*:*)
+ echo sx6-nec-superux${UNAME_RELEASE}
+ exit 0 ;;
+ Power*:Rhapsody:*:*)
+ echo powerpc-apple-rhapsody${UNAME_RELEASE}
+ exit 0 ;;
+ *:Rhapsody:*:*)
+ echo ${UNAME_MACHINE}-apple-rhapsody${UNAME_RELEASE}
+ exit 0 ;;
+ *:Darwin:*:*)
+ echo `uname -p`-apple-darwin${UNAME_RELEASE}
+ exit 0 ;;
+ *:procnto*:*:* | *:QNX:[0123456789]*:*)
+ UNAME_PROCESSOR=`uname -p`
+ if test "$UNAME_PROCESSOR" = "x86"; then
+ UNAME_PROCESSOR=i386
+ UNAME_MACHINE=pc
+ fi
+ echo ${UNAME_PROCESSOR}-${UNAME_MACHINE}-nto-qnx${UNAME_RELEASE}
+ exit 0 ;;
+ *:QNX:*:4*)
+ echo i386-pc-qnx
+ exit 0 ;;
+ NSR-[DGKLNPTVW]:NONSTOP_KERNEL:*:*)
+ echo nsr-tandem-nsk${UNAME_RELEASE}
+ exit 0 ;;
+ *:NonStop-UX:*:*)
+ echo mips-compaq-nonstopux
+ exit 0 ;;
+ BS2000:POSIX*:*:*)
+ echo bs2000-siemens-sysv
+ exit 0 ;;
+ DS/*:UNIX_System_V:*:*)
+ echo ${UNAME_MACHINE}-${UNAME_SYSTEM}-${UNAME_RELEASE}
+ exit 0 ;;
+ *:Plan9:*:*)
+ # "uname -m" is not consistent, so use $cputype instead. 386
+ # is converted to i386 for consistency with other x86
+ # operating systems.
+ if test "$cputype" = "386"; then
+ UNAME_MACHINE=i386
+ else
+ UNAME_MACHINE="$cputype"
+ fi
+ echo ${UNAME_MACHINE}-unknown-plan9
+ exit 0 ;;
+ i*86:OS/2:*:*)
+ # If we were able to find `uname', then EMX Unix compatibility
+ # is probably installed.
+ echo ${UNAME_MACHINE}-pc-os2-emx
+ exit 0 ;;
+ *:TOPS-10:*:*)
+ echo pdp10-unknown-tops10
+ exit 0 ;;
+ *:TENEX:*:*)
+ echo pdp10-unknown-tenex
+ exit 0 ;;
+ KS10:TOPS-20:*:* | KL10:TOPS-20:*:* | TYPE4:TOPS-20:*:*)
+ echo pdp10-dec-tops20
+ exit 0 ;;
+ XKL-1:TOPS-20:*:* | TYPE5:TOPS-20:*:*)
+ echo pdp10-xkl-tops20
+ exit 0 ;;
+ *:TOPS-20:*:*)
+ echo pdp10-unknown-tops20
+ exit 0 ;;
+ *:ITS:*:*)
+ echo pdp10-unknown-its
+ exit 0 ;;
+ i*86:XTS-300:*:STOP)
+ echo ${UNAME_MACHINE}-unknown-stop
+ exit 0 ;;
+ i*86:atheos:*:*)
+ echo ${UNAME_MACHINE}-unknown-atheos
+ exit 0 ;;
+esac
+#echo '(No uname command or uname output not recognized.)' 1>&2
+#echo "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" 1>&2
+eval $set_cc_for_build
+cat >$dummy.c <<EOF
+#ifdef _SEQUENT_
+# include <sys/types.h>
+# include <sys/utsname.h>
+#endif
+main ()
+#if defined (sony)
+#if defined (MIPSEB)
+ /* BFD wants "bsd" instead of "newsos". Perhaps BFD should be changed,
+ I don't know.... */
+ printf ("mips-sony-bsd\n"); exit (0);
+#else
+#include <sys/param.h>
+ printf ("m68k-sony-newsos%s\n",
+#ifdef NEWSOS4
+ "4"
+#else
+#endif
+ ); exit (0);
+#endif
+#endif
+#if defined (__arm) && defined (__acorn) && defined (__unix)
+ printf ("arm-acorn-riscix"); exit (0);
+#endif
+#if defined (hp300) && !defined (hpux)
+ printf ("m68k-hp-bsd\n"); exit (0);
+#endif
+#if defined (NeXT)
+#if !defined (__ARCHITECTURE__)
+#define __ARCHITECTURE__ "m68k"
+#endif
+ int version;
+ version=`(hostinfo | sed -n 's/.*NeXT Mach \([0-9]*\).*/\1/p') 2>/dev/null`;
+ if (version < 4)
+ printf ("%s-next-nextstep%d\n", __ARCHITECTURE__, version);
+ else
+ printf ("%s-next-openstep%d\n", __ARCHITECTURE__, version);
+ exit (0);
+#endif
+#if defined (MULTIMAX) || defined (n16)
+#if defined (UMAXV)
+ printf ("ns32k-encore-sysv\n"); exit (0);
+#else
+#if defined (CMU)
+ printf ("ns32k-encore-mach\n"); exit (0);
+#else
+ printf ("ns32k-encore-bsd\n"); exit (0);
+#endif
+#endif
+#endif
+#if defined (__386BSD__)
+ printf ("i386-pc-bsd\n"); exit (0);
+#endif
+#if defined (sequent)
+#if defined (i386)
+ printf ("i386-sequent-dynix\n"); exit (0);
+#endif
+#if defined (ns32000)
+ printf ("ns32k-sequent-dynix\n"); exit (0);
+#endif
+#endif
+#if defined (_SEQUENT_)
+ struct utsname un;
+ uname(&un);
+ if (strncmp(un.version, "V2", 2) == 0) {
+ printf ("i386-sequent-ptx2\n"); exit (0);
+ if (strncmp(un.version, "V1", 2) == 0) { /* XXX is V1 correct? */
+ printf ("i386-sequent-ptx1\n"); exit (0);
+ printf ("i386-sequent-ptx\n"); exit (0);
+#endif
+#if defined (vax)
+# if !defined (ultrix)
+# include <sys/param.h>
+# if defined (BSD)
+# if BSD == 43
+ printf ("vax-dec-bsd4.3\n"); exit (0);
+# else
+# if BSD == 199006
+ printf ("vax-dec-bsd4.3reno\n"); exit (0);
+# else
+ printf ("vax-dec-bsd\n"); exit (0);
+# endif
+# endif
+# else
+# endif
+# else
+ printf ("vax-dec-ultrix\n"); exit (0);
+# endif
+#endif
+#if defined (alliant) && defined (i860)
+ printf ("i860-alliant-bsd\n"); exit (0);
+#endif
+ exit (1);
+EOF
+$CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null && $dummy && rm -f $dummy.c $dummy && rmdir $tmpdir && exit 0
+rm -f $dummy.c $dummy && rmdir $tmpdir
+# Apollos put the system type in the environment.
+test -d /usr/apollo && { echo ${ISP}-apollo-${SYSTYPE}; exit 0; }
+# Convex versions that predate uname can use getsysinfo(1)
+if [ -x /usr/convex/getsysinfo ]
+then
+ case `getsysinfo -f cpu_type` in
+ c1*)
+ exit 0 ;;
+ c2*)
+ fi
+ exit 0 ;;
+ c34*)
+ exit 0 ;;
+ c38*)
+ exit 0 ;;
+ c4*)
+ exit 0 ;;
+ esac
+fi
+cat >&2 <<EOF
+$0: unable to guess system type
+This script, last modified $timestamp, has failed to recognize
+the operating system you are using. It is advised that you
+download the most up to date version of the config scripts from
+ ftp://ftp.gnu.org/pub/gnu/config/
+If the version you run ($0) is already up to date, please
+send the following data and any information you think might be
+pertinent to <config-patches at gnu.org> in order to provide the needed
+information to handle your system.
+config.guess timestamp = $timestamp
+uname -m = `(uname -m) 2>/dev/null || echo unknown`
+uname -r = `(uname -r) 2>/dev/null || echo unknown`
+uname -s = `(uname -s) 2>/dev/null || echo unknown`
+uname -v = `(uname -v) 2>/dev/null || echo unknown`
+/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null`
+/bin/uname -X = `(/bin/uname -X) 2>/dev/null`
+hostinfo = `(hostinfo) 2>/dev/null`
+/bin/universe = `(/bin/universe) 2>/dev/null`
+/usr/bin/arch -k = `(/usr/bin/arch -k) 2>/dev/null`
+/bin/arch = `(/bin/arch) 2>/dev/null`
+/usr/bin/oslevel = `(/usr/bin/oslevel) 2>/dev/null`
+/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null`
+UNAME_MACHINE = ${UNAME_MACHINE}
+UNAME_RELEASE = ${UNAME_RELEASE}
+UNAME_SYSTEM = ${UNAME_SYSTEM}
+UNAME_VERSION = ${UNAME_VERSION}
+EOF
+exit 1
+# Local variables:
+# eval: (add-hook 'write-file-hooks 'time-stamp)
+# time-stamp-start: "timestamp='"
+# time-stamp-format: "%:y-%02m-%02d"
+# time-stamp-end: "'"
+# End:
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.sub
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.sub 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.sub 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,1470 +0,0 @@
-#! /bin/sh
-# Configuration validation subroutine script.
-# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
-# 2000, 2001, 2002 Free Software Foundation, Inc.
-timestamp='2002-09-05'
-# This file is (in principle) common to ALL GNU software.
-# The presence of a machine in this file suggests that SOME GNU software
-# can handle that machine. It does not imply ALL GNU software can.
-# This file is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330,
-# Boston, MA 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# Please send patches to <config-patches at gnu.org>. Submit a context
-# diff and a properly formatted ChangeLog entry.
-# Configuration subroutine to validate and canonicalize a configuration type.
-# Supply the specified configuration type as an argument.
-# If it is invalid, we print an error message on stderr and exit with code 1.
-# Otherwise, we print the canonical config type on stdout and succeed.
-# This file is supposed to be the same for all GNU packages
-# and recognize all the CPU types, system types and aliases
-# that are meaningful with *any* GNU software.
-# Each package is responsible for reporting which valid configurations
-# it does not support. The user should be able to distinguish
-# a failure to support a valid configuration from a meaningless
-# configuration.
-# The goal of this file is to map all the various variations of a given
-# machine specification into a single specification in the form:
-# CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM
-# or in some cases, the newer four-part form:
-# CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM
-# It is wrong to echo any other type of specification.
-me=`echo "$0" | sed -e 's,.*/,,'`
-usage="\
-Usage: $0 [OPTION] CPU-MFR-OPSYS
- $0 [OPTION] ALIAS
-Canonicalize a configuration name.
-Operation modes:
- -h, --help print this help, then exit
- -t, --time-stamp print date of last modification, then exit
- -v, --version print version number, then exit
-Report bugs and patches to <config-patches at gnu.org>."
-version="\
-GNU config.sub ($timestamp)
-Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001
-Free Software Foundation, Inc.
-This is free software; see the source for copying conditions. There is NO
-warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
-help="
-Try \`$me --help' for more information."
-# Parse command line
-while test $# -gt 0 ; do
- case $1 in
- --time-stamp | --time* | -t )
- echo "$timestamp" ; exit 0 ;;
- --version | -v )
- echo "$version" ; exit 0 ;;
- --help | --h* | -h )
- echo "$usage"; exit 0 ;;
- -- ) # Stop option processing
- shift; break ;;
- - ) # Use stdin as input.
- break ;;
- echo "$me: invalid option $1$help"
- exit 1 ;;
- *local*)
- # First pass through any local machine types.
- echo $1
- exit 0;;
- break ;;
- esac
-done
-case $# in
- 0) echo "$me: missing argument$help" >&2
- exit 1;;
- 1) ;;
- *) echo "$me: too many arguments$help" >&2
- exit 1;;
-esac
-# Separate what the user gave into CPU-COMPANY and OS or KERNEL-OS (if any).
-# Here we must recognize all the valid KERNEL-OS combinations.
-maybe_os=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
-case $maybe_os in
- nto-qnx* | linux-gnu* | freebsd*-gnu* | storm-chaos* | os2-emx* | windows32-* | rtmk-nova*)
- os=-$maybe_os
- basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
- basic_machine=`echo $1 | sed 's/-[^-]*$//'`
- if [ $basic_machine != $1 ]
- then os=`echo $1 | sed 's/.*-/-/'`
- else os=; fi
-esac
-### Let's recognize common machines as not being operating systems so
-### that things like config.sub decstation-3100 work. We also
-### recognize some manufacturers as not being operating systems, so we
-### can provide default operating systems below.
-case $os in
- -sun*os*)
- # Prevent following clause from handling this invalid input.
- -dec* | -mips* | -sequent* | -encore* | -pc532* | -sgi* | -sony* | \
- -att* | -7300* | -3300* | -delta* | -motorola* | -sun[234]* | \
- -unicom* | -ibm* | -next | -hp | -isi* | -apollo | -altos* | \
- -convergent* | -ncr* | -news | -32* | -3600* | -3100* | -hitachi* |\
- -c[123]* | -convex* | -sun | -crds | -omron* | -dg | -ultra | -tti* | \
- -harris | -dolphin | -highlevel | -gould | -cbm | -ns | -masscomp | \
- -apple | -axis)
- os=
- basic_machine=$1
- -sim | -cisco | -oki | -wec | -winbond)
- os=
- basic_machine=$1
- -scout)
- -wrs)
- os=-vxworks
- basic_machine=$1
- -chorusos*)
- os=-chorusos
- basic_machine=$1
- -chorusrdb)
- os=-chorusrdb
- basic_machine=$1
- -hiux*)
- os=-hiuxwe2
- -sco5)
- os=-sco3.2v5
- basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
- -sco4)
- os=-sco3.2v4
- -sco3.2.[4-9]*)
- os=`echo $os | sed -e 's/sco3.2./sco3.2v/'`
- -sco3.2v[4-9]*)
- # Don't forget version if it is 3.2v4 or newer.
- -sco*)
- os=-sco3.2v2
- -udk*)
- -isc)
- os=-isc2.2
- -clix*)
- basic_machine=clipper-intergraph
- -isc*)
- -lynx*)
- os=-lynxos
- -ptx*)
- basic_machine=`echo $1 | sed -e 's/86-.*/86-sequent/'`
- -windowsnt*)
- os=`echo $os | sed -e 's/windowsnt/winnt/'`
- -psos*)
- os=-psos
- -mint | -mint[0-9]*)
- basic_machine=m68k-atari
- os=-mint
-esac
-# Decode aliases for certain CPU-COMPANY combinations.
-case $basic_machine in
- # Recognize the basic CPU types without company name.
- # Some are omitted here because they have special meanings below.
- 1750a | 580 \
- | a29k \
- | alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
- | alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
- | arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr \
- | clipper \
- | d10v | d30v | dlx | dsp16xx \
- | fr30 | frv \
- | h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
- | i370 | i860 | i960 | ia64 \
- | ip2k \
- | m32r | m68000 | m68k | m88k | mcore \
- | mips | mipsbe | mipseb | mipsel | mipsle \
- | mips16 \
- | mips64 | mips64el \
- | mips64vr | mips64vrel \
- | mips64orion | mips64orionel \
- | mips64vr4100 | mips64vr4100el \
- | mips64vr4300 | mips64vr4300el \
- | mips64vr5000 | mips64vr5000el \
- | mipsisa32 | mipsisa32el \
- | mipsisa64 | mipsisa64el \
- | mipsisa64sb1 | mipsisa64sb1el \
- | mipsisa64sr71k | mipsisa64sr71kel \
- | mipstx39 | mipstx39el \
- | mn10200 | mn10300 \
- | ns16k | ns32k \
- | openrisc | or32 \
- | pdp10 | pdp11 | pj | pjl \
- | powerpc | powerpc64 | powerpc64le | powerpcle | ppcbe \
- | pyramid \
- | sh | sh[1234] | sh3e | sh[34]eb | shbe | shle | sh[1234]le | sh3ele \
- | sh64 | sh64le \
- | sparc | sparc64 | sparc86x | sparclet | sparclite | sparcv9 | sparcv9b \
- | strongarm \
- | tahoe | thumb | tic80 | tron \
- | v850 | v850e \
- | we32k \
- | x86 | xscale | xstormy16 | xtensa \
- | z8k)
- basic_machine=$basic_machine-unknown
- m6811 | m68hc11 | m6812 | m68hc12)
- # Motorola 68HC11/12.
- os=-none
- m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
- # We use `pc' rather than `unknown'
- # because (1) that's what they normally are, and
- # (2) the word "unknown" tends to confuse beginning users.
- i*86 | x86_64)
- basic_machine=$basic_machine-pc
- # Object if more than one company name word.
- echo Invalid configuration \`$1\': machine \`$basic_machine\' not recognized 1>&2
- exit 1
- # Recognize the basic CPU types with company name.
- 580-* \
- | a29k-* \
- | alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
- | alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
- | alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
- | arm-* | armbe-* | armle-* | armeb-* | armv*-* \
- | avr-* \
- | bs2000-* \
- | c[123]* | c30-* | [cjt]90-* | c4x-* | c54x-* \
- | clipper-* | cydra-* \
- | d10v-* | d30v-* | dlx-* \
- | elxsi-* \
- | f30[01]-* | f700-* | fr30-* | frv-* | fx80-* \
- | h8300-* | h8500-* \
- | hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
- | i*86-* | i860-* | i960-* | ia64-* \
- | ip2k-* \
- | m32r-* \
- | m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
- | m88110-* | m88k-* | mcore-* \
- | mips-* | mipsbe-* | mipseb-* | mipsel-* | mipsle-* \
- | mips16-* \
- | mips64-* | mips64el-* \
- | mips64vr-* | mips64vrel-* \
- | mips64orion-* | mips64orionel-* \
- | mips64vr4100-* | mips64vr4100el-* \
- | mips64vr4300-* | mips64vr4300el-* \
- | mips64vr5000-* | mips64vr5000el-* \
- | mipsisa32-* | mipsisa32el-* \
- | mipsisa64-* | mipsisa64el-* \
- | mipsisa64sb1-* | mipsisa64sb1el-* \
- | mipsisa64sr71k-* | mipsisa64sr71kel-* \
- | none-* | np1-* | ns16k-* | ns32k-* \
- | orion-* \
- | pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
- | powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* | ppcbe-* \
- | pyramid-* \
- | romp-* | rs6000-* \
- | sh-* | sh[1234]-* | sh3e-* | sh[34]eb-* | shbe-* \
- | shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
- | sparc-* | sparc64-* | sparc86x-* | sparclet-* | sparclite-* \
- | sparcv9-* | sparcv9b-* | strongarm-* | sv1-* | sx?-* \
- | tahoe-* | thumb-* | tic30-* | tic4x-* | tic54x-* | tic80-* | tron-* \
- | v850-* | v850e-* | vax-* \
- | we32k-* \
- | x86-* | x86_64-* | xps100-* | xscale-* | xstormy16-* \
- | xtensa-* \
- | ymp-* \
- | z8k-*)
- # Recognize the various machine names and aliases which stand
- # for a CPU type and a company and sometimes even an OS.
- 386bsd)
- basic_machine=i386-unknown
- os=-bsd
- 3b1 | 7300 | 7300-att | att-7300 | pc7300 | safari | unixpc)
- basic_machine=m68000-att
- 3b*)
- basic_machine=we32k-att
- a29khif)
- basic_machine=a29k-amd
- os=-udi
- adobe68k)
- basic_machine=m68010-adobe
- os=-scout
- alliant | fx80)
- basic_machine=fx80-alliant
- altos | altos3068)
- basic_machine=m68k-altos
- am29k)
- basic_machine=a29k-none
- os=-bsd
- amdahl)
- basic_machine=580-amdahl
- os=-sysv
- amiga | amiga-*)
- basic_machine=m68k-unknown
- amigaos | amigados)
- os=-amigaos
- amigaunix | amix)
- os=-sysv4
- apollo68)
- basic_machine=m68k-apollo
- os=-sysv
- apollo68bsd)
- os=-bsd
- aux)
- basic_machine=m68k-apple
- os=-aux
- balance)
- basic_machine=ns32k-sequent
- os=-dynix
- c90)
- basic_machine=c90-cray
- os=-unicos
- convex-c1)
- basic_machine=c1-convex
- os=-bsd
- convex-c2)
- basic_machine=c2-convex
- os=-bsd
- convex-c32)
- basic_machine=c32-convex
- os=-bsd
- convex-c34)
- basic_machine=c34-convex
- os=-bsd
- convex-c38)
- basic_machine=c38-convex
- os=-bsd
- cray | j90)
- basic_machine=j90-cray
- os=-unicos
- crds | unos)
- basic_machine=m68k-crds
- cris | cris-* | etrax*)
- basic_machine=cris-axis
- da30 | da30-*)
- basic_machine=m68k-da30
- decstation | decstation-3100 | pmax | pmax-* | pmin | dec3100 | decstatn)
- basic_machine=mips-dec
- decsystem10* | dec10*)
- basic_machine=pdp10-dec
- os=-tops10
- decsystem20* | dec20*)
- os=-tops20
- delta | 3300 | motorola-3300 | motorola-delta \
- | 3300-motorola | delta-motorola)
- basic_machine=m68k-motorola
- delta88)
- basic_machine=m88k-motorola
- os=-sysv3
- dpx20 | dpx20-*)
- basic_machine=rs6000-bull
- os=-bosx
- dpx2* | dpx2*-bull)
- basic_machine=m68k-bull
- os=-sysv3
- ebmon29k)
- os=-ebmon
- elxsi)
- basic_machine=elxsi-elxsi
- os=-bsd
- encore | umax | mmax)
- basic_machine=ns32k-encore
- es1800 | OSE68k | ose68k | ose | OSE)
- basic_machine=m68k-ericsson
- os=-ose
- fx2800)
- basic_machine=i860-alliant
- genix)
- basic_machine=ns32k-ns
- gmicro)
- basic_machine=tron-gmicro
- os=-sysv
- go32)
- basic_machine=i386-pc
- os=-go32
- h3050r* | hiux*)
- basic_machine=hppa1.1-hitachi
- os=-hiuxwe2
- h8300hms)
- basic_machine=h8300-hitachi
- os=-hms
- h8300xray)
- os=-xray
- h8500hms)
- basic_machine=h8500-hitachi
- os=-hms
- harris)
- basic_machine=m88k-harris
- os=-sysv3
- hp300-*)
- basic_machine=m68k-hp
- hp300bsd)
- os=-bsd
- hp300hpux)
- os=-hpux
- hp3k9[0-9][0-9] | hp9[0-9][0-9])
- basic_machine=hppa1.0-hp
- hp9k2[0-9][0-9] | hp9k31[0-9])
- basic_machine=m68000-hp
- hp9k3[2-9][0-9])
- hp9k6[0-9][0-9] | hp6[0-9][0-9])
- hp9k7[0-79][0-9] | hp7[0-79][0-9])
- basic_machine=hppa1.1-hp
- hp9k78[0-9] | hp78[0-9])
- # FIXME: really hppa2.0-hp
- hp9k8[67]1 | hp8[67]1 | hp9k80[24] | hp80[24] | hp9k8[78]9 | hp8[78]9 | hp9k893 | hp893)
- hp9k8[0-9][13679] | hp8[0-9][13679])
- hp9k8[0-9][0-9] | hp8[0-9][0-9])
- hppa-next)
- os=-nextstep3
- hppaosf)
- os=-osf
- hppro)
- os=-proelf
- i370-ibm* | ibm*)
- basic_machine=i370-ibm
-# I'm not sure what "Sysv32" means. Should this be sysv3.2?
- i*86v32)
- basic_machine=`echo $1 | sed -e 's/86.*/86-pc/'`
- os=-sysv32
- i*86v4*)
- os=-sysv4
- i*86v)
- os=-sysv
- i*86sol2)
- os=-solaris2
- i386mach)
- basic_machine=i386-mach
- os=-mach
- i386-vsta | vsta)
- os=-vsta
- iris | iris4d)
- basic_machine=mips-sgi
- case $os in
- -irix*)
- os=-irix4
- esac
- isi68 | isi)
- basic_machine=m68k-isi
- os=-sysv
- m88k-omron*)
- basic_machine=m88k-omron
- magnum | m3230)
- basic_machine=mips-mips
- os=-sysv
- merlin)
- basic_machine=ns32k-utek
- os=-sysv
- mingw32)
- os=-mingw32
- miniframe)
- basic_machine=m68000-convergent
- *mint | -mint[0-9]* | *MiNT | *MiNT[0-9]*)
- os=-mint
- mips3*-*)
- basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`
- mips3*)
- basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`-unknown
- mmix*)
- basic_machine=mmix-knuth
- os=-mmixware
- monitor)
- basic_machine=m68k-rom68k
- os=-coff
- morphos)
- basic_machine=powerpc-unknown
- os=-morphos
- msdos)
- os=-msdos
- mvs)
- os=-mvs
- ncr3000)
- basic_machine=i486-ncr
- os=-sysv4
- netbsd386)
- os=-netbsd
- netwinder)
- basic_machine=armv4l-rebel
- os=-linux
- news | news700 | news800 | news900)
- basic_machine=m68k-sony
- os=-newsos
- news1000)
- basic_machine=m68030-sony
- os=-newsos
- news-3600 | risc-news)
- basic_machine=mips-sony
- os=-newsos
- necv70)
- basic_machine=v70-nec
- os=-sysv
- next | m*-next )
- basic_machine=m68k-next
- case $os in
- -nextstep* )
- -ns2*)
- os=-nextstep2
- os=-nextstep3
- esac
- nh3000)
- basic_machine=m68k-harris
- os=-cxux
- nh[45]000)
- os=-cxux
- nindy960)
- basic_machine=i960-intel
- os=-nindy
- mon960)
- os=-mon960
- nonstopux)
- basic_machine=mips-compaq
- os=-nonstopux
- np1)
- basic_machine=np1-gould
- nsr-tandem)
- basic_machine=nsr-tandem
- op50n-* | op60c-*)
- basic_machine=hppa1.1-oki
- os=-proelf
- or32 | or32-*)
- basic_machine=or32-unknown
- os=-coff
- OSE68000 | ose68000)
- basic_machine=m68000-ericsson
- os=-ose
- os68k)
- basic_machine=m68k-none
- os=-os68k
- pa-hitachi)
- os=-hiuxwe2
- paragon)
- basic_machine=i860-intel
- os=-osf
- pbd)
- basic_machine=sparc-tti
- pbb)
- basic_machine=m68k-tti
- pc532 | pc532-*)
- basic_machine=ns32k-pc532
- pentium | p5 | k5 | k6 | nexgen | viac3)
- basic_machine=i586-pc
- pentiumpro | p6 | 6x86 | athlon | athlon_*)
- basic_machine=i686-pc
- pentiumii | pentium2)
- pentium-* | p5-* | k5-* | k6-* | nexgen-* | viac3-*)
- basic_machine=i586-`echo $basic_machine | sed 's/^[^-]*-//'`
- pentiumpro-* | p6-* | 6x86-* | athlon-*)
- basic_machine=i686-`echo $basic_machine | sed 's/^[^-]*-//'`
- pentiumii-* | pentium2-*)
- pn)
- basic_machine=pn-gould
- power) basic_machine=power-ibm
- ppc) basic_machine=powerpc-unknown
- ppc-*) basic_machine=powerpc-`echo $basic_machine | sed 's/^[^-]*-//'`
- ppcle | powerpclittle | ppc-le | powerpc-little)
- basic_machine=powerpcle-unknown
- ppcle-* | powerpclittle-*)
- basic_machine=powerpcle-`echo $basic_machine | sed 's/^[^-]*-//'`
- ppc64) basic_machine=powerpc64-unknown
- ppc64-*) basic_machine=powerpc64-`echo $basic_machine | sed 's/^[^-]*-//'`
- ppc64le | powerpc64little | ppc64-le | powerpc64-little)
- basic_machine=powerpc64le-unknown
- ppc64le-* | powerpc64little-*)
- basic_machine=powerpc64le-`echo $basic_machine | sed 's/^[^-]*-//'`
- ps2)
- basic_machine=i386-ibm
- pw32)
- basic_machine=i586-unknown
- os=-pw32
- rom68k)
- os=-coff
- rm[46]00)
- basic_machine=mips-siemens
- rtpc | rtpc-*)
- basic_machine=romp-ibm
- s390 | s390-*)
- basic_machine=s390-ibm
- s390x | s390x-*)
- basic_machine=s390x-ibm
- sa29200)
- os=-udi
- sb1)
- basic_machine=mipsisa64sb1-unknown
- sb1el)
- basic_machine=mipsisa64sb1el-unknown
- sequent)
- basic_machine=i386-sequent
- sh)
- basic_machine=sh-hitachi
- os=-hms
- sparclite-wrs | simso-wrs)
- basic_machine=sparclite-wrs
- os=-vxworks
- sps7)
- os=-sysv2
- spur)
- basic_machine=spur-unknown
- st2000)
- basic_machine=m68k-tandem
- stratus)
- basic_machine=i860-stratus
- os=-sysv4
- sun2)
- basic_machine=m68000-sun
- sun2os3)
- os=-sunos3
- sun2os4)
- os=-sunos4
- sun3os3)
- basic_machine=m68k-sun
- os=-sunos3
- sun3os4)
- os=-sunos4
- sun4os3)
- basic_machine=sparc-sun
- os=-sunos3
- sun4os4)
- os=-sunos4
- sun4sol2)
- os=-solaris2
- sun3 | sun3-*)
- sun4)
- sun386 | sun386i | roadrunner)
- basic_machine=i386-sun
- sv1)
- basic_machine=sv1-cray
- os=-unicos
- symmetry)
- os=-dynix
- t3d)
- basic_machine=alpha-cray
- os=-unicos
- t3e)
- basic_machine=alphaev5-cray
- os=-unicos
- t90)
- basic_machine=t90-cray
- os=-unicos
- tic4x | c4x*)
- basic_machine=tic4x-unknown
- os=-coff
- tic54x | c54x*)
- basic_machine=tic54x-unknown
- os=-coff
- tx39)
- basic_machine=mipstx39-unknown
- tx39el)
- basic_machine=mipstx39el-unknown
- toad1)
- basic_machine=pdp10-xkl
- os=-tops20
- tower | tower-32)
- basic_machine=m68k-ncr
- udi29k)
- os=-udi
- ultra3)
- basic_machine=a29k-nyu
- os=-sym1
- v810 | necv810)
- basic_machine=v810-nec
- os=-none
- vaxv)
- basic_machine=vax-dec
- os=-sysv
- vms)
- os=-vms
- vpp*|vx|vx-*)
- basic_machine=f301-fujitsu
- vxworks960)
- basic_machine=i960-wrs
- os=-vxworks
- vxworks68)
- basic_machine=m68k-wrs
- os=-vxworks
- vxworks29k)
- basic_machine=a29k-wrs
- os=-vxworks
- w65*)
- basic_machine=w65-wdc
- os=-none
- w89k-*)
- basic_machine=hppa1.1-winbond
- os=-proelf
- windows32)
- os=-windows32-msvcrt
- xps | xps100)
- basic_machine=xps100-honeywell
- ymp)
- basic_machine=ymp-cray
- os=-unicos
- z8k-*-coff)
- basic_machine=z8k-unknown
- os=-sim
- none)
- basic_machine=none-none
- os=-none
-# Here we handle the default manufacturer of certain CPU types. It is in
-# some cases the only manufacturer, in others, it is the most popular.
- w89k)
- op50n)
- op60c)
- romp)
- rs6000)
- basic_machine=rs6000-ibm
- vax)
- pdp10)
- # there are many clones, so DEC is not a safe bet
- basic_machine=pdp10-unknown
- pdp11)
- basic_machine=pdp11-dec
- we32k)
- sh3 | sh4 | sh3eb | sh4eb | sh[1234]le | sh3ele)
- basic_machine=sh-unknown
- sh64)
- basic_machine=sh64-unknown
- sparc | sparcv9 | sparcv9b)
- cydra)
- basic_machine=cydra-cydrome
- orion)
- basic_machine=orion-highlevel
- orion105)
- basic_machine=clipper-highlevel
- mac | mpw | mac-mpw)
- pmac | pmac-mpw)
- basic_machine=powerpc-apple
- *-unknown)
- # Make sure to match an already-canonicalized machine name.
- exit 1
-esac
-# Here we canonicalize certain aliases for manufacturers.
- *-digital*)
- basic_machine=`echo $basic_machine | sed 's/digital.*/dec/'`
- *-commodore*)
- basic_machine=`echo $basic_machine | sed 's/commodore.*/cbm/'`
-esac
-# Decode manufacturer-specific aliases for certain operating systems.
-if [ x"$os" != x"" ]
-then
-case $os in
- # First match some system type aliases
- # that might get confused with valid system types.
- # -solaris* is a basic system type, with this one exception.
- -solaris1 | -solaris1.*)
- os=`echo $os | sed -e 's|solaris1|sunos4|'`
- -solaris)
- os=-solaris2
- -svr4*)
- os=-sysv4
- -unixware*)
- os=-sysv4.2uw
- -gnu/linux*)
- os=`echo $os | sed -e 's|gnu/linux|linux-gnu|'`
- # First accept the basic system types.
- # The portable systems comes first.
- # Each alternative MUST END IN A *, to match a version number.
- # -sysv* is not here because it comes later, after sysvr4.
- -gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
- | -*vms* | -sco* | -esix* | -isc* | -aix* | -sunos | -sunos[34]*\
- | -hpux* | -unos* | -osf* | -luna* | -dgux* | -solaris* | -sym* \
- | -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
- | -aos* \
- | -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
- | -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
- | -hiux* | -386bsd* | -netbsd* | -openbsd* | -freebsd* | -riscix* \
- | -lynxos* | -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
- | -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
- | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
- | -chorusos* | -chorusrdb* \
- | -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
- | -mingw32* | -linux-gnu* | -uxpv* | -beos* | -mpeix* | -udk* \
- | -interix* | -uwin* | -rhapsody* | -darwin* | -opened* \
- | -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
- | -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
- | -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
- | -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* | -powermax*)
- # Remember, each alternative MUST END IN *, to match a version number.
- -qnx*)
- case $basic_machine in
- x86-* | i*86-*)
- os=-nto$os
- esac
- -nto*)
- os=-nto-qnx
- -sim | -es1800* | -hms* | -xray | -os68k* | -none* | -v88r* \
- | -windows* | -osx | -abug | -netware* | -os9* | -beos* \
- | -macos* | -mpw* | -magic* | -mmixware* | -mon960* | -lnews*)
- -mac*)
- os=`echo $os | sed -e 's|mac|macos|'`
- -linux*)
- os=`echo $os | sed -e 's|linux|linux-gnu|'`
- -sunos5*)
- os=`echo $os | sed -e 's|sunos5|solaris2|'`
- -sunos6*)
- os=`echo $os | sed -e 's|sunos6|solaris3|'`
- -opened*)
- os=-openedition
- -wince*)
- os=-wince
- -osfrose*)
- os=-osfrose
- -osf*)
- os=-osf
- -utek*)
- os=-bsd
- -dynix*)
- os=-bsd
- -acis*)
- os=-aos
- -atheos*)
- os=-atheos
- -386bsd)
- os=-bsd
- -ctix* | -uts*)
- os=-sysv
- -nova*)
- os=-rtmk-nova
- -ns2 )
- os=-nextstep2
- -nsk*)
- os=-nsk
- # Preserve the version number of sinix5.
- -sinix5.*)
- os=`echo $os | sed -e 's|sinix|sysv|'`
- -sinix*)
- os=-sysv4
- -triton*)
- os=-sysv3
- -oss*)
- os=-sysv3
- -svr4)
- os=-sysv4
- -svr3)
- os=-sysv3
- -sysvr4)
- os=-sysv4
- # This must come after -sysvr4.
- -sysv*)
- -ose*)
- os=-ose
- -es1800*)
- os=-ose
- -xenix)
- os=-xenix
- -*mint | -mint[0-9]* | -*MiNT | -MiNT[0-9]*)
- os=-mint
- -none)
- # Get rid of the `-' at the beginning of $os.
- os=`echo $os | sed 's/[^-]*-//'`
- echo Invalid configuration \`$1\': system \`$os\' not recognized 1>&2
- exit 1
-esac
-else
-# Here we handle the default operating systems that come with various machines.
-# The value should be what the vendor currently ships out the door with their
-# machine or put another way, the most popular os provided with the machine.
-# Note that if you're going to try to match "-MANUFACTURER" here (say,
-# "-sun"), then you have to tell the case statement up towards the top
-# that MANUFACTURER isn't an operating system. Otherwise, code above
-# will signal an error saying that MANUFACTURER isn't an operating
-# system, and we'll never get to this point.
- *-acorn)
- os=-riscix1.2
- arm*-rebel)
- os=-linux
- arm*-semi)
- os=-aout
- # This must come before the *-dec entry.
- pdp10-*)
- os=-tops20
- pdp11-*)
- os=-none
- *-dec | vax-*)
- os=-ultrix4.2
- m68*-apollo)
- os=-domain
- i386-sun)
- os=-sunos4.0.2
- m68000-sun)
- os=-sunos3
- # This also exists in the configure program, but was not the
- # default.
- # os=-sunos4
- m68*-cisco)
- os=-aout
- mips*-cisco)
- os=-elf
- mips*-*)
- os=-elf
- or32-*)
- os=-coff
- *-tti) # must be before sparc entry or we get the wrong os.
- os=-sysv3
- sparc-* | *-sun)
- os=-sunos4.1.1
- *-be)
- os=-beos
- *-ibm)
- os=-aix
- *-wec)
- os=-proelf
- *-winbond)
- os=-proelf
- *-oki)
- os=-proelf
- *-hp)
- os=-hpux
- *-hitachi)
- os=-hiux
- i860-* | *-att | *-ncr | *-altos | *-motorola | *-convergent)
- os=-sysv
- *-cbm)
- os=-amigaos
- *-dg)
- os=-dgux
- *-dolphin)
- os=-sysv3
- m68k-ccur)
- os=-rtu
- m88k-omron*)
- os=-luna
- *-next )
- os=-nextstep
- *-sequent)
- os=-ptx
- *-crds)
- os=-unos
- *-ns)
- os=-genix
- i370-*)
- os=-mvs
- *-next)
- os=-nextstep3
- *-gould)
- os=-sysv
- *-highlevel)
- os=-bsd
- *-encore)
- os=-bsd
- *-sgi)
- os=-irix
- *-siemens)
- os=-sysv4
- *-masscomp)
- os=-rtu
- f30[01]-fujitsu | f700-fujitsu)
- os=-uxpv
- *-rom68k)
- os=-coff
- *-*bug)
- os=-coff
- *-apple)
- os=-macos
- *-atari*)
- os=-mint
- os=-none
-esac
-fi
-# Here we handle the case where we know the os, and the CPU type, but not the
-# manufacturer. We pick the logical manufacturer.
-vendor=unknown
- *-unknown)
- case $os in
- -riscix*)
- vendor=acorn
- -sunos*)
- vendor=sun
- -aix*)
- vendor=ibm
- -beos*)
- vendor=be
- -hpux*)
- vendor=hp
- -mpeix*)
- vendor=hp
- -hiux*)
- vendor=hitachi
- -unos*)
- vendor=crds
- -dgux*)
- vendor=dg
- -luna*)
- vendor=omron
- -genix*)
- vendor=ns
- -mvs* | -opened*)
- vendor=ibm
- -ptx*)
- vendor=sequent
- -vxsim* | -vxworks* | -windiss*)
- vendor=wrs
- -aux*)
- vendor=apple
- -hms*)
- vendor=hitachi
- -mpw* | -macos*)
- vendor=apple
- vendor=atari
- -vos*)
- vendor=stratus
- esac
- basic_machine=`echo $basic_machine | sed "s/unknown/$vendor/"`
-esac
-echo $basic_machine$os
-exit 0
-# Local variables:
-# eval: (add-hook 'write-file-hooks 'time-stamp)
-# time-stamp-start: "timestamp='"
-# time-stamp-format: "%:y-%02m-%02d"
-# time-stamp-end: "'"
-# End:
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.sub (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.sub)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/config.sub (rev 0)
@@ -0,0 +1,1470 @@
+#! /bin/sh
+# Configuration validation subroutine script.
+# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
+# 2000, 2001, 2002 Free Software Foundation, Inc.
+timestamp='2002-09-05'
+# This file is (in principle) common to ALL GNU software.
+# The presence of a machine in this file suggests that SOME GNU software
+# can handle that machine. It does not imply ALL GNU software can.
+# This file is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330,
+# Boston, MA 02111-1307, USA.
+# As a special exception to the GNU General Public License, if you
+# distribute this file as part of a program that contains a
+# configuration script generated by Autoconf, you may include it under
+# the same distribution terms that you use for the rest of that program.
+# Please send patches to <config-patches at gnu.org>. Submit a context
+# diff and a properly formatted ChangeLog entry.
+# Configuration subroutine to validate and canonicalize a configuration type.
+# Supply the specified configuration type as an argument.
+# If it is invalid, we print an error message on stderr and exit with code 1.
+# Otherwise, we print the canonical config type on stdout and succeed.
+# This file is supposed to be the same for all GNU packages
+# and recognize all the CPU types, system types and aliases
+# that are meaningful with *any* GNU software.
+# Each package is responsible for reporting which valid configurations
+# it does not support. The user should be able to distinguish
+# a failure to support a valid configuration from a meaningless
+# configuration.
+# The goal of this file is to map all the various variations of a given
+# machine specification into a single specification in the form:
+# CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM
+# or in some cases, the newer four-part form:
+# CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM
+# It is wrong to echo any other type of specification.
+me=`echo "$0" | sed -e 's,.*/,,'`
+usage="\
+Usage: $0 [OPTION] CPU-MFR-OPSYS
+ $0 [OPTION] ALIAS
+Canonicalize a configuration name.
+Operation modes:
+ -h, --help print this help, then exit
+ -t, --time-stamp print date of last modification, then exit
+ -v, --version print version number, then exit
+Report bugs and patches to <config-patches at gnu.org>."
+version="\
+GNU config.sub ($timestamp)
+Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001
+Free Software Foundation, Inc.
+This is free software; see the source for copying conditions. There is NO
+warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
+help="
+Try \`$me --help' for more information."
+# Parse command line
+while test $# -gt 0 ; do
+ case $1 in
+ --time-stamp | --time* | -t )
+ echo "$timestamp" ; exit 0 ;;
+ --version | -v )
+ echo "$version" ; exit 0 ;;
+ --help | --h* | -h )
+ echo "$usage"; exit 0 ;;
+ -- ) # Stop option processing
+ shift; break ;;
+ - ) # Use stdin as input.
+ break ;;
+ echo "$me: invalid option $1$help"
+ exit 1 ;;
+ *local*)
+ # First pass through any local machine types.
+ echo $1
+ exit 0;;
+ break ;;
+ esac
+done
+case $# in
+ 0) echo "$me: missing argument$help" >&2
+ exit 1;;
+ 1) ;;
+ *) echo "$me: too many arguments$help" >&2
+ exit 1;;
+esac
+# Separate what the user gave into CPU-COMPANY and OS or KERNEL-OS (if any).
+# Here we must recognize all the valid KERNEL-OS combinations.
+maybe_os=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
+case $maybe_os in
+ nto-qnx* | linux-gnu* | freebsd*-gnu* | storm-chaos* | os2-emx* | windows32-* | rtmk-nova*)
+ os=-$maybe_os
+ basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
+ basic_machine=`echo $1 | sed 's/-[^-]*$//'`
+ if [ $basic_machine != $1 ]
+ then os=`echo $1 | sed 's/.*-/-/'`
+ else os=; fi
+esac
+### Let's recognize common machines as not being operating systems so
+### that things like config.sub decstation-3100 work. We also
+### recognize some manufacturers as not being operating systems, so we
+### can provide default operating systems below.
+case $os in
+ -sun*os*)
+ # Prevent following clause from handling this invalid input.
+ -dec* | -mips* | -sequent* | -encore* | -pc532* | -sgi* | -sony* | \
+ -att* | -7300* | -3300* | -delta* | -motorola* | -sun[234]* | \
+ -unicom* | -ibm* | -next | -hp | -isi* | -apollo | -altos* | \
+ -convergent* | -ncr* | -news | -32* | -3600* | -3100* | -hitachi* |\
+ -c[123]* | -convex* | -sun | -crds | -omron* | -dg | -ultra | -tti* | \
+ -harris | -dolphin | -highlevel | -gould | -cbm | -ns | -masscomp | \
+ -apple | -axis)
+ os=
+ basic_machine=$1
+ -sim | -cisco | -oki | -wec | -winbond)
+ os=
+ basic_machine=$1
+ -scout)
+ -wrs)
+ os=-vxworks
+ basic_machine=$1
+ -chorusos*)
+ os=-chorusos
+ basic_machine=$1
+ -chorusrdb)
+ os=-chorusrdb
+ basic_machine=$1
+ -hiux*)
+ os=-hiuxwe2
+ -sco5)
+ os=-sco3.2v5
+ basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
+ -sco4)
+ os=-sco3.2v4
+ -sco3.2.[4-9]*)
+ os=`echo $os | sed -e 's/sco3.2./sco3.2v/'`
+ -sco3.2v[4-9]*)
+ # Don't forget version if it is 3.2v4 or newer.
+ -sco*)
+ os=-sco3.2v2
+ -udk*)
+ -isc)
+ os=-isc2.2
+ -clix*)
+ basic_machine=clipper-intergraph
+ -isc*)
+ -lynx*)
+ os=-lynxos
+ -ptx*)
+ basic_machine=`echo $1 | sed -e 's/86-.*/86-sequent/'`
+ -windowsnt*)
+ os=`echo $os | sed -e 's/windowsnt/winnt/'`
+ -psos*)
+ os=-psos
+ -mint | -mint[0-9]*)
+ basic_machine=m68k-atari
+ os=-mint
+esac
+# Decode aliases for certain CPU-COMPANY combinations.
+case $basic_machine in
+ # Recognize the basic CPU types without company name.
+ # Some are omitted here because they have special meanings below.
+ 1750a | 580 \
+ | a29k \
+ | alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
+ | alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
+ | arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr \
+ | clipper \
+ | d10v | d30v | dlx | dsp16xx \
+ | fr30 | frv \
+ | h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
+ | i370 | i860 | i960 | ia64 \
+ | ip2k \
+ | m32r | m68000 | m68k | m88k | mcore \
+ | mips | mipsbe | mipseb | mipsel | mipsle \
+ | mips16 \
+ | mips64 | mips64el \
+ | mips64vr | mips64vrel \
+ | mips64orion | mips64orionel \
+ | mips64vr4100 | mips64vr4100el \
+ | mips64vr4300 | mips64vr4300el \
+ | mips64vr5000 | mips64vr5000el \
+ | mipsisa32 | mipsisa32el \
+ | mipsisa64 | mipsisa64el \
+ | mipsisa64sb1 | mipsisa64sb1el \
+ | mipsisa64sr71k | mipsisa64sr71kel \
+ | mipstx39 | mipstx39el \
+ | mn10200 | mn10300 \
+ | ns16k | ns32k \
+ | openrisc | or32 \
+ | pdp10 | pdp11 | pj | pjl \
+ | powerpc | powerpc64 | powerpc64le | powerpcle | ppcbe \
+ | pyramid \
+ | sh | sh[1234] | sh3e | sh[34]eb | shbe | shle | sh[1234]le | sh3ele \
+ | sh64 | sh64le \
+ | sparc | sparc64 | sparc86x | sparclet | sparclite | sparcv9 | sparcv9b \
+ | strongarm \
+ | tahoe | thumb | tic80 | tron \
+ | v850 | v850e \
+ | we32k \
+ | x86 | xscale | xstormy16 | xtensa \
+ | z8k)
+ basic_machine=$basic_machine-unknown
+ m6811 | m68hc11 | m6812 | m68hc12)
+ # Motorola 68HC11/12.
+ os=-none
+ m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
+ # We use `pc' rather than `unknown'
+ # because (1) that's what they normally are, and
+ # (2) the word "unknown" tends to confuse beginning users.
+ i*86 | x86_64)
+ basic_machine=$basic_machine-pc
+ # Object if more than one company name word.
+ echo Invalid configuration \`$1\': machine \`$basic_machine\' not recognized 1>&2
+ exit 1
+ # Recognize the basic CPU types with company name.
+ 580-* \
+ | a29k-* \
+ | alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
+ | alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
+ | alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
+ | arm-* | armbe-* | armle-* | armeb-* | armv*-* \
+ | avr-* \
+ | bs2000-* \
+ | c[123]* | c30-* | [cjt]90-* | c4x-* | c54x-* \
+ | clipper-* | cydra-* \
+ | d10v-* | d30v-* | dlx-* \
+ | elxsi-* \
+ | f30[01]-* | f700-* | fr30-* | frv-* | fx80-* \
+ | h8300-* | h8500-* \
+ | hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
+ | i*86-* | i860-* | i960-* | ia64-* \
+ | ip2k-* \
+ | m32r-* \
+ | m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
+ | m88110-* | m88k-* | mcore-* \
+ | mips-* | mipsbe-* | mipseb-* | mipsel-* | mipsle-* \
+ | mips16-* \
+ | mips64-* | mips64el-* \
+ | mips64vr-* | mips64vrel-* \
+ | mips64orion-* | mips64orionel-* \
+ | mips64vr4100-* | mips64vr4100el-* \
+ | mips64vr4300-* | mips64vr4300el-* \
+ | mips64vr5000-* | mips64vr5000el-* \
+ | mipsisa32-* | mipsisa32el-* \
+ | mipsisa64-* | mipsisa64el-* \
+ | mipsisa64sb1-* | mipsisa64sb1el-* \
+ | mipsisa64sr71k-* | mipsisa64sr71kel-* \
+ | none-* | np1-* | ns16k-* | ns32k-* \
+ | orion-* \
+ | pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
+ | powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* | ppcbe-* \
+ | pyramid-* \
+ | romp-* | rs6000-* \
+ | sh-* | sh[1234]-* | sh3e-* | sh[34]eb-* | shbe-* \
+ | shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
+ | sparc-* | sparc64-* | sparc86x-* | sparclet-* | sparclite-* \
+ | sparcv9-* | sparcv9b-* | strongarm-* | sv1-* | sx?-* \
+ | tahoe-* | thumb-* | tic30-* | tic4x-* | tic54x-* | tic80-* | tron-* \
+ | v850-* | v850e-* | vax-* \
+ | we32k-* \
+ | x86-* | x86_64-* | xps100-* | xscale-* | xstormy16-* \
+ | xtensa-* \
+ | ymp-* \
+ | z8k-*)
+ # Recognize the various machine names and aliases which stand
+ # for a CPU type and a company and sometimes even an OS.
+ 386bsd)
+ basic_machine=i386-unknown
+ os=-bsd
+ 3b1 | 7300 | 7300-att | att-7300 | pc7300 | safari | unixpc)
+ basic_machine=m68000-att
+ 3b*)
+ basic_machine=we32k-att
+ a29khif)
+ basic_machine=a29k-amd
+ os=-udi
+ adobe68k)
+ basic_machine=m68010-adobe
+ os=-scout
+ alliant | fx80)
+ basic_machine=fx80-alliant
+ altos | altos3068)
+ basic_machine=m68k-altos
+ am29k)
+ basic_machine=a29k-none
+ os=-bsd
+ amdahl)
+ basic_machine=580-amdahl
+ os=-sysv
+ amiga | amiga-*)
+ basic_machine=m68k-unknown
+ amigaos | amigados)
+ os=-amigaos
+ amigaunix | amix)
+ os=-sysv4
+ apollo68)
+ basic_machine=m68k-apollo
+ os=-sysv
+ apollo68bsd)
+ os=-bsd
+ aux)
+ basic_machine=m68k-apple
+ os=-aux
+ balance)
+ basic_machine=ns32k-sequent
+ os=-dynix
+ c90)
+ basic_machine=c90-cray
+ os=-unicos
+ convex-c1)
+ basic_machine=c1-convex
+ os=-bsd
+ convex-c2)
+ basic_machine=c2-convex
+ os=-bsd
+ convex-c32)
+ basic_machine=c32-convex
+ os=-bsd
+ convex-c34)
+ basic_machine=c34-convex
+ os=-bsd
+ convex-c38)
+ basic_machine=c38-convex
+ os=-bsd
+ cray | j90)
+ basic_machine=j90-cray
+ os=-unicos
+ crds | unos)
+ basic_machine=m68k-crds
+ cris | cris-* | etrax*)
+ basic_machine=cris-axis
+ da30 | da30-*)
+ basic_machine=m68k-da30
+ decstation | decstation-3100 | pmax | pmax-* | pmin | dec3100 | decstatn)
+ basic_machine=mips-dec
+ decsystem10* | dec10*)
+ basic_machine=pdp10-dec
+ os=-tops10
+ decsystem20* | dec20*)
+ os=-tops20
+ delta | 3300 | motorola-3300 | motorola-delta \
+ | 3300-motorola | delta-motorola)
+ basic_machine=m68k-motorola
+ delta88)
+ basic_machine=m88k-motorola
+ os=-sysv3
+ dpx20 | dpx20-*)
+ basic_machine=rs6000-bull
+ os=-bosx
+ dpx2* | dpx2*-bull)
+ basic_machine=m68k-bull
+ os=-sysv3
+ ebmon29k)
+ os=-ebmon
+ elxsi)
+ basic_machine=elxsi-elxsi
+ os=-bsd
+ encore | umax | mmax)
+ basic_machine=ns32k-encore
+ es1800 | OSE68k | ose68k | ose | OSE)
+ basic_machine=m68k-ericsson
+ os=-ose
+ fx2800)
+ basic_machine=i860-alliant
+ genix)
+ basic_machine=ns32k-ns
+ gmicro)
+ basic_machine=tron-gmicro
+ os=-sysv
+ go32)
+ basic_machine=i386-pc
+ os=-go32
+ h3050r* | hiux*)
+ basic_machine=hppa1.1-hitachi
+ os=-hiuxwe2
+ h8300hms)
+ basic_machine=h8300-hitachi
+ os=-hms
+ h8300xray)
+ os=-xray
+ h8500hms)
+ basic_machine=h8500-hitachi
+ os=-hms
+ harris)
+ basic_machine=m88k-harris
+ os=-sysv3
+ hp300-*)
+ basic_machine=m68k-hp
+ hp300bsd)
+ os=-bsd
+ hp300hpux)
+ os=-hpux
+ hp3k9[0-9][0-9] | hp9[0-9][0-9])
+ basic_machine=hppa1.0-hp
+ hp9k2[0-9][0-9] | hp9k31[0-9])
+ basic_machine=m68000-hp
+ hp9k3[2-9][0-9])
+ hp9k6[0-9][0-9] | hp6[0-9][0-9])
+ hp9k7[0-79][0-9] | hp7[0-79][0-9])
+ basic_machine=hppa1.1-hp
+ hp9k78[0-9] | hp78[0-9])
+ # FIXME: really hppa2.0-hp
+ hp9k8[67]1 | hp8[67]1 | hp9k80[24] | hp80[24] | hp9k8[78]9 | hp8[78]9 | hp9k893 | hp893)
+ hp9k8[0-9][13679] | hp8[0-9][13679])
+ hp9k8[0-9][0-9] | hp8[0-9][0-9])
+ hppa-next)
+ os=-nextstep3
+ hppaosf)
+ os=-osf
+ hppro)
+ os=-proelf
+ i370-ibm* | ibm*)
+ basic_machine=i370-ibm
+# I'm not sure what "Sysv32" means. Should this be sysv3.2?
+ i*86v32)
+ basic_machine=`echo $1 | sed -e 's/86.*/86-pc/'`
+ os=-sysv32
+ i*86v4*)
+ os=-sysv4
+ i*86v)
+ os=-sysv
+ i*86sol2)
+ os=-solaris2
+ i386mach)
+ basic_machine=i386-mach
+ os=-mach
+ i386-vsta | vsta)
+ os=-vsta
+ iris | iris4d)
+ basic_machine=mips-sgi
+ case $os in
+ -irix*)
+ os=-irix4
+ esac
+ isi68 | isi)
+ basic_machine=m68k-isi
+ os=-sysv
+ m88k-omron*)
+ basic_machine=m88k-omron
+ magnum | m3230)
+ basic_machine=mips-mips
+ os=-sysv
+ merlin)
+ basic_machine=ns32k-utek
+ os=-sysv
+ mingw32)
+ os=-mingw32
+ miniframe)
+ basic_machine=m68000-convergent
+ *mint | -mint[0-9]* | *MiNT | *MiNT[0-9]*)
+ os=-mint
+ mips3*-*)
+ basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`
+ mips3*)
+ basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`-unknown
+ mmix*)
+ basic_machine=mmix-knuth
+ os=-mmixware
+ monitor)
+ basic_machine=m68k-rom68k
+ os=-coff
+ morphos)
+ basic_machine=powerpc-unknown
+ os=-morphos
+ msdos)
+ os=-msdos
+ mvs)
+ os=-mvs
+ ncr3000)
+ basic_machine=i486-ncr
+ os=-sysv4
+ netbsd386)
+ os=-netbsd
+ netwinder)
+ basic_machine=armv4l-rebel
+ os=-linux
+ news | news700 | news800 | news900)
+ basic_machine=m68k-sony
+ os=-newsos
+ news1000)
+ basic_machine=m68030-sony
+ os=-newsos
+ news-3600 | risc-news)
+ basic_machine=mips-sony
+ os=-newsos
+ necv70)
+ basic_machine=v70-nec
+ os=-sysv
+ next | m*-next )
+ basic_machine=m68k-next
+ case $os in
+ -nextstep* )
+ -ns2*)
+ os=-nextstep2
+ os=-nextstep3
+ esac
+ nh3000)
+ basic_machine=m68k-harris
+ os=-cxux
+ nh[45]000)
+ os=-cxux
+ nindy960)
+ basic_machine=i960-intel
+ os=-nindy
+ mon960)
+ os=-mon960
+ nonstopux)
+ basic_machine=mips-compaq
+ os=-nonstopux
+ np1)
+ basic_machine=np1-gould
+ nsr-tandem)
+ basic_machine=nsr-tandem
+ op50n-* | op60c-*)
+ basic_machine=hppa1.1-oki
+ os=-proelf
+ or32 | or32-*)
+ basic_machine=or32-unknown
+ os=-coff
+ OSE68000 | ose68000)
+ basic_machine=m68000-ericsson
+ os=-ose
+ os68k)
+ basic_machine=m68k-none
+ os=-os68k
+ pa-hitachi)
+ os=-hiuxwe2
+ paragon)
+ basic_machine=i860-intel
+ os=-osf
+ pbd)
+ basic_machine=sparc-tti
+ pbb)
+ basic_machine=m68k-tti
+ pc532 | pc532-*)
+ basic_machine=ns32k-pc532
+ pentium | p5 | k5 | k6 | nexgen | viac3)
+ basic_machine=i586-pc
+ pentiumpro | p6 | 6x86 | athlon | athlon_*)
+ basic_machine=i686-pc
+ pentiumii | pentium2)
+ pentium-* | p5-* | k5-* | k6-* | nexgen-* | viac3-*)
+ basic_machine=i586-`echo $basic_machine | sed 's/^[^-]*-//'`
+ pentiumpro-* | p6-* | 6x86-* | athlon-*)
+ basic_machine=i686-`echo $basic_machine | sed 's/^[^-]*-//'`
+ pentiumii-* | pentium2-*)
+ pn)
+ basic_machine=pn-gould
+ power) basic_machine=power-ibm
+ ppc) basic_machine=powerpc-unknown
+ ppc-*) basic_machine=powerpc-`echo $basic_machine | sed 's/^[^-]*-//'`
+ ppcle | powerpclittle | ppc-le | powerpc-little)
+ basic_machine=powerpcle-unknown
+ ppcle-* | powerpclittle-*)
+ basic_machine=powerpcle-`echo $basic_machine | sed 's/^[^-]*-//'`
+ ppc64) basic_machine=powerpc64-unknown
+ ppc64-*) basic_machine=powerpc64-`echo $basic_machine | sed 's/^[^-]*-//'`
+ ppc64le | powerpc64little | ppc64-le | powerpc64-little)
+ basic_machine=powerpc64le-unknown
+ ppc64le-* | powerpc64little-*)
+ basic_machine=powerpc64le-`echo $basic_machine | sed 's/^[^-]*-//'`
+ ps2)
+ basic_machine=i386-ibm
+ pw32)
+ basic_machine=i586-unknown
+ os=-pw32
+ rom68k)
+ os=-coff
+ rm[46]00)
+ basic_machine=mips-siemens
+ rtpc | rtpc-*)
+ basic_machine=romp-ibm
+ s390 | s390-*)
+ basic_machine=s390-ibm
+ s390x | s390x-*)
+ basic_machine=s390x-ibm
+ sa29200)
+ os=-udi
+ sb1)
+ basic_machine=mipsisa64sb1-unknown
+ sb1el)
+ basic_machine=mipsisa64sb1el-unknown
+ sequent)
+ basic_machine=i386-sequent
+ sh)
+ basic_machine=sh-hitachi
+ os=-hms
+ sparclite-wrs | simso-wrs)
+ basic_machine=sparclite-wrs
+ os=-vxworks
+ sps7)
+ os=-sysv2
+ spur)
+ basic_machine=spur-unknown
+ st2000)
+ basic_machine=m68k-tandem
+ stratus)
+ basic_machine=i860-stratus
+ os=-sysv4
+ sun2)
+ basic_machine=m68000-sun
+ sun2os3)
+ os=-sunos3
+ sun2os4)
+ os=-sunos4
+ sun3os3)
+ basic_machine=m68k-sun
+ os=-sunos3
+ sun3os4)
+ os=-sunos4
+ sun4os3)
+ basic_machine=sparc-sun
+ os=-sunos3
+ sun4os4)
+ os=-sunos4
+ sun4sol2)
+ os=-solaris2
+ sun3 | sun3-*)
+ sun4)
+ sun386 | sun386i | roadrunner)
+ basic_machine=i386-sun
+ sv1)
+ basic_machine=sv1-cray
+ os=-unicos
+ symmetry)
+ os=-dynix
+ t3d)
+ basic_machine=alpha-cray
+ os=-unicos
+ t3e)
+ basic_machine=alphaev5-cray
+ os=-unicos
+ t90)
+ basic_machine=t90-cray
+ os=-unicos
+ tic4x | c4x*)
+ basic_machine=tic4x-unknown
+ os=-coff
+ tic54x | c54x*)
+ basic_machine=tic54x-unknown
+ os=-coff
+ tx39)
+ basic_machine=mipstx39-unknown
+ tx39el)
+ basic_machine=mipstx39el-unknown
+ toad1)
+ basic_machine=pdp10-xkl
+ os=-tops20
+ tower | tower-32)
+ basic_machine=m68k-ncr
+ udi29k)
+ os=-udi
+ ultra3)
+ basic_machine=a29k-nyu
+ os=-sym1
+ v810 | necv810)
+ basic_machine=v810-nec
+ os=-none
+ vaxv)
+ basic_machine=vax-dec
+ os=-sysv
+ vms)
+ os=-vms
+ vpp*|vx|vx-*)
+ basic_machine=f301-fujitsu
+ vxworks960)
+ basic_machine=i960-wrs
+ os=-vxworks
+ vxworks68)
+ basic_machine=m68k-wrs
+ os=-vxworks
+ vxworks29k)
+ basic_machine=a29k-wrs
+ os=-vxworks
+ w65*)
+ basic_machine=w65-wdc
+ os=-none
+ w89k-*)
+ basic_machine=hppa1.1-winbond
+ os=-proelf
+ windows32)
+ os=-windows32-msvcrt
+ xps | xps100)
+ basic_machine=xps100-honeywell
+ ymp)
+ basic_machine=ymp-cray
+ os=-unicos
+ z8k-*-coff)
+ basic_machine=z8k-unknown
+ os=-sim
+ none)
+ basic_machine=none-none
+ os=-none
+# Here we handle the default manufacturer of certain CPU types. It is in
+# some cases the only manufacturer, in others, it is the most popular.
+ w89k)
+ op50n)
+ op60c)
+ romp)
+ rs6000)
+ basic_machine=rs6000-ibm
+ vax)
+ pdp10)
+ # there are many clones, so DEC is not a safe bet
+ basic_machine=pdp10-unknown
+ pdp11)
+ basic_machine=pdp11-dec
+ we32k)
+ sh3 | sh4 | sh3eb | sh4eb | sh[1234]le | sh3ele)
+ basic_machine=sh-unknown
+ sh64)
+ basic_machine=sh64-unknown
+ sparc | sparcv9 | sparcv9b)
+ cydra)
+ basic_machine=cydra-cydrome
+ orion)
+ basic_machine=orion-highlevel
+ orion105)
+ basic_machine=clipper-highlevel
+ mac | mpw | mac-mpw)
+ pmac | pmac-mpw)
+ basic_machine=powerpc-apple
+ *-unknown)
+ # Make sure to match an already-canonicalized machine name.
+ exit 1
+esac
+# Here we canonicalize certain aliases for manufacturers.
+ *-digital*)
+ basic_machine=`echo $basic_machine | sed 's/digital.*/dec/'`
+ *-commodore*)
+ basic_machine=`echo $basic_machine | sed 's/commodore.*/cbm/'`
+esac
+# Decode manufacturer-specific aliases for certain operating systems.
+if [ x"$os" != x"" ]
+then
+case $os in
+ # First match some system type aliases
+ # that might get confused with valid system types.
+ # -solaris* is a basic system type, with this one exception.
+ -solaris1 | -solaris1.*)
+ os=`echo $os | sed -e 's|solaris1|sunos4|'`
+ -solaris)
+ os=-solaris2
+ -svr4*)
+ os=-sysv4
+ -unixware*)
+ os=-sysv4.2uw
+ -gnu/linux*)
+ os=`echo $os | sed -e 's|gnu/linux|linux-gnu|'`
+ # First accept the basic system types.
+ # The portable systems comes first.
+ # Each alternative MUST END IN A *, to match a version number.
+ # -sysv* is not here because it comes later, after sysvr4.
+ -gnu* | -bsd* | -mach* | -minix* | -genix* | -ultrix* | -irix* \
+ | -*vms* | -sco* | -esix* | -isc* | -aix* | -sunos | -sunos[34]*\
+ | -hpux* | -unos* | -osf* | -luna* | -dgux* | -solaris* | -sym* \
+ | -amigaos* | -amigados* | -msdos* | -newsos* | -unicos* | -aof* \
+ | -aos* \
+ | -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
+ | -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
+ | -hiux* | -386bsd* | -netbsd* | -openbsd* | -freebsd* | -riscix* \
+ | -lynxos* | -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
+ | -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
+ | -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
+ | -chorusos* | -chorusrdb* \
+ | -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
+ | -mingw32* | -linux-gnu* | -uxpv* | -beos* | -mpeix* | -udk* \
+ | -interix* | -uwin* | -rhapsody* | -darwin* | -opened* \
+ | -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
+ | -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
+ | -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
+ | -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* | -powermax*)
+ # Remember, each alternative MUST END IN *, to match a version number.
+ -qnx*)
+ case $basic_machine in
+ x86-* | i*86-*)
+ os=-nto$os
+ esac
+ -nto*)
+ os=-nto-qnx
+ -sim | -es1800* | -hms* | -xray | -os68k* | -none* | -v88r* \
+ | -windows* | -osx | -abug | -netware* | -os9* | -beos* \
+ | -macos* | -mpw* | -magic* | -mmixware* | -mon960* | -lnews*)
+ -mac*)
+ os=`echo $os | sed -e 's|mac|macos|'`
+ -linux*)
+ os=`echo $os | sed -e 's|linux|linux-gnu|'`
+ -sunos5*)
+ os=`echo $os | sed -e 's|sunos5|solaris2|'`
+ -sunos6*)
+ os=`echo $os | sed -e 's|sunos6|solaris3|'`
+ -opened*)
+ os=-openedition
+ -wince*)
+ os=-wince
+ -osfrose*)
+ os=-osfrose
+ -osf*)
+ os=-osf
+ -utek*)
+ os=-bsd
+ -dynix*)
+ os=-bsd
+ -acis*)
+ os=-aos
+ -atheos*)
+ os=-atheos
+ -386bsd)
+ os=-bsd
+ -ctix* | -uts*)
+ os=-sysv
+ -nova*)
+ os=-rtmk-nova
+ -ns2 )
+ os=-nextstep2
+ -nsk*)
+ os=-nsk
+ # Preserve the version number of sinix5.
+ -sinix5.*)
+ os=`echo $os | sed -e 's|sinix|sysv|'`
+ -sinix*)
+ os=-sysv4
+ -triton*)
+ os=-sysv3
+ -oss*)
+ os=-sysv3
+ -svr4)
+ os=-sysv4
+ -svr3)
+ os=-sysv3
+ -sysvr4)
+ os=-sysv4
+ # This must come after -sysvr4.
+ -sysv*)
+ -ose*)
+ os=-ose
+ -es1800*)
+ os=-ose
+ -xenix)
+ os=-xenix
+ -*mint | -mint[0-9]* | -*MiNT | -MiNT[0-9]*)
+ os=-mint
+ -none)
+ # Get rid of the `-' at the beginning of $os.
+ os=`echo $os | sed 's/[^-]*-//'`
+ echo Invalid configuration \`$1\': system \`$os\' not recognized 1>&2
+ exit 1
+esac
+else
+# Here we handle the default operating systems that come with various machines.
+# The value should be what the vendor currently ships out the door with their
+# machine or put another way, the most popular os provided with the machine.
+# Note that if you're going to try to match "-MANUFACTURER" here (say,
+# "-sun"), then you have to tell the case statement up towards the top
+# that MANUFACTURER isn't an operating system. Otherwise, code above
+# will signal an error saying that MANUFACTURER isn't an operating
+# system, and we'll never get to this point.
+ *-acorn)
+ os=-riscix1.2
+ arm*-rebel)
+ os=-linux
+ arm*-semi)
+ os=-aout
+ # This must come before the *-dec entry.
+ pdp10-*)
+ os=-tops20
+ pdp11-*)
+ os=-none
+ *-dec | vax-*)
+ os=-ultrix4.2
+ m68*-apollo)
+ os=-domain
+ i386-sun)
+ os=-sunos4.0.2
+ m68000-sun)
+ os=-sunos3
+ # This also exists in the configure program, but was not the
+ # default.
+ # os=-sunos4
+ m68*-cisco)
+ os=-aout
+ mips*-cisco)
+ os=-elf
+ mips*-*)
+ os=-elf
+ or32-*)
+ os=-coff
+ *-tti) # must be before sparc entry or we get the wrong os.
+ os=-sysv3
+ sparc-* | *-sun)
+ os=-sunos4.1.1
+ *-be)
+ os=-beos
+ *-ibm)
+ os=-aix
+ *-wec)
+ os=-proelf
+ *-winbond)
+ os=-proelf
+ *-oki)
+ os=-proelf
+ *-hp)
+ os=-hpux
+ *-hitachi)
+ os=-hiux
+ i860-* | *-att | *-ncr | *-altos | *-motorola | *-convergent)
+ os=-sysv
+ *-cbm)
+ os=-amigaos
+ *-dg)
+ os=-dgux
+ *-dolphin)
+ os=-sysv3
+ m68k-ccur)
+ os=-rtu
+ m88k-omron*)
+ os=-luna
+ *-next )
+ os=-nextstep
+ *-sequent)
+ os=-ptx
+ *-crds)
+ os=-unos
+ *-ns)
+ os=-genix
+ i370-*)
+ os=-mvs
+ *-next)
+ os=-nextstep3
+ *-gould)
+ os=-sysv
+ *-highlevel)
+ os=-bsd
+ *-encore)
+ os=-bsd
+ *-sgi)
+ os=-irix
+ *-siemens)
+ os=-sysv4
+ *-masscomp)
+ os=-rtu
+ f30[01]-fujitsu | f700-fujitsu)
+ os=-uxpv
+ *-rom68k)
+ os=-coff
+ *-*bug)
+ os=-coff
+ *-apple)
+ os=-macos
+ *-atari*)
+ os=-mint
+ os=-none
+esac
+fi
+# Here we handle the case where we know the os, and the CPU type, but not the
+# manufacturer. We pick the logical manufacturer.
+vendor=unknown
+ *-unknown)
+ case $os in
+ -riscix*)
+ vendor=acorn
+ -sunos*)
+ vendor=sun
+ -aix*)
+ vendor=ibm
+ -beos*)
+ vendor=be
+ -hpux*)
+ vendor=hp
+ -mpeix*)
+ vendor=hp
+ -hiux*)
+ vendor=hitachi
+ -unos*)
+ vendor=crds
+ -dgux*)
+ vendor=dg
+ -luna*)
+ vendor=omron
+ -genix*)
+ vendor=ns
+ -mvs* | -opened*)
+ vendor=ibm
+ -ptx*)
+ vendor=sequent
+ -vxsim* | -vxworks* | -windiss*)
+ vendor=wrs
+ -aux*)
+ vendor=apple
+ -hms*)
+ vendor=hitachi
+ -mpw* | -macos*)
+ vendor=apple
+ vendor=atari
+ -vos*)
+ vendor=stratus
+ esac
+ basic_machine=`echo $basic_machine | sed "s/unknown/$vendor/"`
+esac
+echo $basic_machine$os
+exit 0
+# Local variables:
+# End:
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/configure.in
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/configure.in 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/configure.in 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,112 +0,0 @@
-AC_INIT(dwfcore, 1.0, http://www.autodesk.com/dwf)
-AC_CONFIG_SRCDIR(configure.in)
-AM_INIT_AUTOMAKE
-AM_CONFIG_HEADER(config.h)
-AC_LANG_CPLUSPLUS
-AC_PROG_CXX
-AM_PROG_LIBTOOL
-AC_CHECK_HEADERS(asm/atomic.h)
-AC_CHECK_HEADERS(alsa/iatomic.h)
-AC_CHECK_HEADERS(netinet/ether.h)
-if test HAVE_ASM_ATOMIC_H; then
-AC_COMPILE_IFELSE(
- [AC_LANG_PROGRAM([[#include <asm/atomic.h>]],
- [[int i = 0;
- atomic_t tValue;
- atomic_set( &tValue, i );
- atomic_inc( &tValue );
- atomic_dec( &tValue );
- i = atomic_read( &tValue );]]
- [AC_MSG_NOTICE([OK to use atomic operations from asm/atomic.h])
- AC_DEFINE(_DWFCORE_USE_ASM_ATOMIC_H,1,[OK to use atomic operations from asm/atomic.h])
- [ AC_MSG_NOTICE([asm/atomic.h available but required operations are missing])
- if test HAVE_ALSA_IATOMIC_H; then
- AC_COMPILE_IFELSE(
- [AC_LANG_PROGRAM([[#include <alsa/iatomic.h>]],
- [[int i = 0;
- atomic_t tValue;
- [AC_MSG_NOTICE([OK to use atomic operations from alsa/iatomic.h])
- AC_DEFINE(_DWFCORE_USE_ALSA_IATOMIC_H,1,[OK to use atomic operations from alsa/iatomic.h])
- [AC_MSG_NOTICE([alsa/iatomic.h available but required operations are missing])]
- fi
-fi
-AC_CHECK_LIB(pthread, pthread_create,, AC_MSG_ERROR([POSIX thread library is required]))
-AC_CHECK_LIB(uuid, uuid_generate,,)
-AC_ARG_WITH([zlib],
- AC_HELP_STRING([--with-zlib],
- [use system zlib [[default=yes]]]),
- [with_zlib=$withval],
- [with_zlib=yes])
-if test $with_zlib = yes; then
-AC_CHECK_LIB(z, inflate,, AC_MSG_ERROR([System zlib is required]))
-else
-AC_MSG_NOTICE([Building zlib into dwfcore])
-AC_DEFINE(DWFCORE_BUILD_ZLIB, 1, [Build zlib into dwfcore])
-fi
-gcc --version > gccver.txt
-sed -e '/^gcc version 3.2/ p' gccver.txt > gcc32.txt
-AC_ARG_ENABLE([optimized],
- AC_HELP_STRING([--enable-optimized],
- [enable optimized build [[default=no]]]),
- [enable_optimized=$enableval],
- [enable_optimized=no])
-if test $enable_optimized = no; then
-AC_MSG_NOTICE([Using debug configuration])
-if test -s gcc32.txt
-then
-AC_MSG_NOTICE([gcc 3.2.x requires less strict compiler flags. Please pay attention to warnings!])
-AC_SUBST(CXXFLAGS, ["-g3 -ggdb -p -O0 -pipe -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes"])
-else
-AC_SUBST(CXXFLAGS, ["-g3 -ggdb -p -O0 -pipe -pedantic-errors -Wall -Werror -Wno-long-long -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes -Wunreachable-code"])
-fi
-else
-AC_MSG_NOTICE([Using optimized configuration])
-then
-AC_SUBST(CXXFLAGS, ["-g0 -O2 -pipe -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr -finline-functions -ffast-math -fno-strict-aliasing"])
-else
-AC_SUBST(CXXFLAGS, ["-g0 -O2 -pipe -pedantic-errors -Wall -Werror -Wno-long-long -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes -Wunreachable-code -fforce-addr -fomit-frame-pointer -finline-functions -ffast-math -fno-strict-aliasing"])
-fi
-fi
-rm gccver.txt
-rm gcc32.txt
-AC_OUTPUT(Makefile ansi/Makefile mac/Makefile zip/Makefile zlib/Makefile x86/Makefile x64/Makefile)
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/configure.in (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/configure.in)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/configure.in (rev 0)
@@ -0,0 +1,112 @@
+AC_INIT(dwfcore, 1.0, http://www.autodesk.com/dwf)
+AC_CONFIG_SRCDIR(configure.in)
+AM_INIT_AUTOMAKE
+AM_CONFIG_HEADER(config.h)
+AC_LANG_CPLUSPLUS
+AC_PROG_CXX
+AM_PROG_LIBTOOL
+AC_CHECK_HEADERS(asm/atomic.h)
+AC_CHECK_HEADERS(alsa/iatomic.h)
+AC_CHECK_HEADERS(netinet/ether.h)
+if test HAVE_ASM_ATOMIC_H; then
+AC_COMPILE_IFELSE(
+ [AC_LANG_PROGRAM([[#include <asm/atomic.h>]],
+ [[int i = 0;
+ atomic_t tValue;
+ atomic_set( &tValue, i );
+ atomic_inc( &tValue );
+ atomic_dec( &tValue );
+ i = atomic_read( &tValue );]]
+ [AC_MSG_NOTICE([OK to use atomic operations from asm/atomic.h])
+ AC_DEFINE(_DWFCORE_USE_ASM_ATOMIC_H,1,[OK to use atomic operations from asm/atomic.h])
+ [ AC_MSG_NOTICE([asm/atomic.h available but required operations are missing])
+ if test HAVE_ALSA_IATOMIC_H; then
+ AC_COMPILE_IFELSE(
+ [AC_LANG_PROGRAM([[#include <alsa/iatomic.h>]],
+ [[int i = 0;
+ atomic_t tValue;
+ [AC_MSG_NOTICE([OK to use atomic operations from alsa/iatomic.h])
+ AC_DEFINE(_DWFCORE_USE_ALSA_IATOMIC_H,1,[OK to use atomic operations from alsa/iatomic.h])
+ [AC_MSG_NOTICE([alsa/iatomic.h available but required operations are missing])]
+ fi
+fi
+AC_CHECK_LIB(pthread, pthread_create,, AC_MSG_ERROR([POSIX thread library is required]))
+AC_CHECK_LIB(uuid, uuid_generate,,)
+AC_ARG_WITH([zlib],
+ AC_HELP_STRING([--with-zlib],
+ [use system zlib [[default=yes]]]),
+ [with_zlib=$withval],
+ [with_zlib=yes])
+if test $with_zlib = yes; then
+AC_CHECK_LIB(z, inflate,, AC_MSG_ERROR([System zlib is required]))
+else
+AC_MSG_NOTICE([Building zlib into dwfcore])
+AC_DEFINE(DWFCORE_BUILD_ZLIB, 1, [Build zlib into dwfcore])
+fi
+gcc --version > gccver.txt
+sed -e '/^gcc version 3.2/ p' gccver.txt > gcc32.txt
+AC_ARG_ENABLE([optimized],
+ AC_HELP_STRING([--enable-optimized],
+ [enable optimized build [[default=no]]]),
+ [enable_optimized=$enableval],
+ [enable_optimized=no])
+if test $enable_optimized = no; then
+AC_MSG_NOTICE([Using debug configuration])
+if test -s gcc32.txt
+then
+AC_MSG_NOTICE([gcc 3.2.x requires less strict compiler flags. Please pay attention to warnings!])
+AC_SUBST(CXXFLAGS, ["-g3 -ggdb -p -O0 -pipe -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes"])
+else
+AC_SUBST(CXXFLAGS, ["-g3 -ggdb -p -O0 -pipe -pedantic-errors -Wall -Werror -Wno-long-long -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes -Wunreachable-code"])
+fi
+else
+AC_MSG_NOTICE([Using optimized configuration])
+then
+AC_SUBST(CXXFLAGS, ["-g0 -O2 -pipe -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr -finline-functions -ffast-math -fno-strict-aliasing"])
+else
+AC_SUBST(CXXFLAGS, ["-g0 -O2 -pipe -pedantic-errors -Wall -Werror -Wno-long-long -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes -Wunreachable-code -fforce-addr -fomit-frame-pointer -finline-functions -ffast-math -fno-strict-aliasing"])
+fi
+fi
+rm gccver.txt
+rm gcc32.txt
+AC_OUTPUT(Makefile ansi/Makefile mac/Makefile zip/Makefile zlib/Makefile x86/Makefile x64/Makefile)
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/depcomp
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/depcomp 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/depcomp 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,441 +0,0 @@
-#! /bin/sh
-# depcomp - compile a program generating dependencies as side-effects
-# Copyright 1999, 2000 Free Software Foundation, Inc.
-# This program is free software; you can redistribute it and/or modify
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
-# 02111-1307, USA.
-# Originally written by Alexandre Oliva <oliva at dcc.unicamp.br>.
-if test -z "$depmode" || test -z "$source" || test -z "$object"; then
- echo "depcomp: Variables source, object and depmode must be set" 1>&2
- exit 1
-fi
-# `libtool' can also be set to `yes' or `no'.
-depfile=${depfile-`echo "$object" | sed 's,\([^/]*\)$,.deps/\1,;s/\.\([^.]*\)$/.P\1/'`}
-tmpdepfile=${tmpdepfile-`echo "$depfile" | sed 's/\.\([^.]*\)$/.T\1/'`}
-rm -f "$tmpdepfile"
-# Some modes work just like other modes, but use different flags. We
-# parameterize here, but still list the modes in the big case below,
-# to make depend.m4 easier to write. Note that we *cannot* use a case
-# here, because this file can only contain one case statement.
-if test "$depmode" = hp; then
- # HP compiler uses -M and no extra arg.
- gccflag=-M
- depmode=gcc
-fi
-if test "$depmode" = dashXmstdout; then
- # This is just like dashmstdout with a different argument.
- dashmflag=-xM
- depmode=dashmstdout
-fi
-case "$depmode" in
-gcc3)
-## gcc 3 implements dependency tracking that does exactly what
-## we want. Yay! Note: for some reason libtool 1.4 doesn't like
-## it if -MD -MP comes after the -MF stuff. Hmm.
- "$@" -MT "$object" -MD -MP -MF "$tmpdepfile"
- stat=$?
- if test $stat -eq 0; then :
- else
- rm -f "$tmpdepfile"
- exit $stat
- fi
- mv "$tmpdepfile" "$depfile"
-gcc)
-## There are various ways to get dependency output from gcc. Here's
-## why we pick this rather obscure method:
-## - Don't want to use -MD because we'd like the dependencies to end
-## up in a subdir. Having to rename by hand is ugly.
-## (We might end up doing this anyway to support other compilers.)
-## - The DEPENDENCIES_OUTPUT environment variable makes gcc act like
-## -MM, not -M (despite what the docs say).
-## - Using -M directly means running the compiler twice (even worse
-## than renaming).
- if test -z "$gccflag"; then
- gccflag=-MD,
- fi
- "$@" -Wp,"$gccflag$tmpdepfile"
- stat=$?
- else
- exit $stat
- fi
- rm -f "$depfile"
- echo "$object : \\" > "$depfile"
- alpha=ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz
-## The second -e expression handles DOS-style file names with drive letters.
- sed -e 's/^[^:]*: / /' \
- -e 's/^['$alpha']:\/[^:]*: / /' < "$tmpdepfile" >> "$depfile"
-## This next piece of magic avoids the `deleted header file' problem.
-## The problem is that when a header file which appears in a .P file
-## is deleted, the dependency causes make to die (because there is
-## typically no way to rebuild the header). We avoid this by adding
-## dummy dependencies for each header file. Too bad gcc doesn't do
-## this for us directly.
- tr ' ' '
-' < "$tmpdepfile" |
-## Some versions of gcc put a space before the `:'. On the theory
-## that the space means something, we add a space to the output as
-## well.
-## Some versions of the HPUX 10.20 sed can't process this invocation
-## correctly. Breaking it into two sed invocations is a workaround.
- sed -e 's/^\\$//' -e '/^$/d' -e '/:$/d' | sed -e 's/$/ :/' >> "$depfile"
-hp)
- # This case exists only to let depend.m4 do its work. It works by
- # looking at the text of this script. This case will never be run,
- # since it is checked for above.
- exit 1
-sgi)
- if test "$libtool" = yes; then
- "$@" "-Wp,-MDupdate,$tmpdepfile"
- else
- "$@" -MDupdate "$tmpdepfile"
- fi
- stat=$?
- else
- exit $stat
- fi
- rm -f "$depfile"
- if test -f "$tmpdepfile"; then # yes, the sourcefile depend on other files
- # Clip off the initial element (the dependent). Don't try to be
- # clever and replace this with sed code, as IRIX sed won't handle
- # lines with more than a fixed number of characters (4096 in
- # IRIX 6.2 sed, 8192 in IRIX 6.5). We also remove comment lines;
- # the IRIX cc adds comments like `#:fec' to the end of the
- # dependency line.
- tr ' ' '
-' < "$tmpdepfile" \
- | sed -e 's/^.*\.o://' -e 's/#.*$//' -e '/^$/ d' | \
- tr '
-' ' ' >> $depfile
- echo >> $depfile
- # The second pass generates a dummy entry for each header file.
- tr ' ' '
- | sed -e 's/^.*\.o://' -e 's/#.*$//' -e '/^$/ d' -e 's/$/:/' \
- >> $depfile
- else
- # The sourcefile does not contain any dependencies, so just
- # store a dummy comment line, to avoid errors with the Makefile
- # "include basename.Plo" scheme.
- echo "#dummy" > "$depfile"
- fi
-aix)
- # The C for AIX Compiler uses -M and outputs the dependencies
- # in a .u file. This file always lives in the current directory.
- # Also, the AIX compiler puts `$object:' at the start of each line;
- # $object doesn't have directory information.
- stripped=`echo "$object" | sed -e 's,^.*/,,' -e 's/\(.*\)\..*$/\1/'`
- tmpdepfile="$stripped.u"
- outname="$stripped.o"
- "$@" -Wc,-M
- else
- "$@" -M
- fi
- stat=$?
- else
- exit $stat
- fi
- # Each line is of the form `foo.o: dependent.h'.
- # Do two passes, one to just change these to
- # `$object: dependent.h' and one to simply `dependent.h:'.
- sed -e "s,^$outname:,$object :," < "$tmpdepfile" > "$depfile"
- sed -e "s,^$outname: \(.*\)$,\1:," < "$tmpdepfile" >> "$depfile"
- else
- fi
-icc)
- # Must come before tru64.
- # Intel's C compiler understands `-MD -MF file'. However
- # icc -MD -MF foo.d -c -o sub/foo.o sub/foo.c
- # will fill foo.d with something like
- # foo.o: sub/foo.c
- # foo.o: sub/foo.h
- # which is wrong. We want:
- # sub/foo.o: sub/foo.c
- # sub/foo.o: sub/foo.h
- # sub/foo.c:
- # sub/foo.h:
- "$@" -MD -MF "$tmpdepfile"
- stat=$?
- else
- exit $stat
- fi
- rm -f "$depfile"
- sed -e "s,^[^:]*:,$object :," < "$tmpdepfile" > "$depfile"
- sed -e "s,^[^:]*: \(.*\)$,\1:," < "$tmpdepfile" >> "$depfile"
-tru64)
- # The Tru64 AIX compiler uses -MD to generate dependencies as a side
- # effect. `cc -MD -o foo.o ...' puts the dependencies into `foo.o.d'.
- # At least on Alpha/Redhat 6.1, Compaq CCC V6.2-504 seems to put
- # dependencies in `foo.d' instead, so we check for that too.
- # Subdirectories are respected.
- tmpdepfile1="$object.d"
- tmpdepfile2=`echo "$object" | sed -e 's/.o$/.d/'`
- "$@" -Wc,-MD
- else
- "$@" -MD
- fi
- stat=$?
- else
- rm -f "$tmpdepfile1" "$tmpdepfile2"
- exit $stat
- fi
- if test -f "$tmpdepfile1"; then
- tmpdepfile="$tmpdepfile1"
- else
- tmpdepfile="$tmpdepfile2"
- fi
- sed -e "s,^.*\.[a-z]*:,$object:," < "$tmpdepfile" > "$depfile"
- # That's a space and a tab in the [].
- sed -e 's,^.*\.[a-z]*:[ ]*,,' -e 's,$,:,' < "$tmpdepfile" >> "$depfile"
- else
- fi
-#nosideeffect)
- # This comment above is used by automake to tell side-effect
- # dependency tracking mechanisms from slower ones.
-dashmstdout)
- # Important note: in order to support this mode, a compiler *must*
- # always write the proprocessed file to stdout, regardless of -o,
- # because we must use -o when running libtool.
- test -z "$dashmflag" && dashmflag=-M
- ( IFS=" "
- case " $* " in
- *" --mode=compile "*) # this is libtool, let us make it quiet
- for arg
- do # cycle over the arguments
- case "$arg" in
- "--mode=compile")
- # insert --quiet before "--mode=compile"
- set fnord "$@" --quiet
- shift # fnord
- esac
- set fnord "$@" "$arg"
- shift # fnord
- shift # "$arg"
- done
- esac
- "$@" $dashmflag | sed 's:^[^:]*\:[ ]*:'"$object"'\: :' > "$tmpdepfile"
- proc=$!
- stat=$?
- wait "$proc"
- if test "$stat" != 0; then exit $stat; fi
- rm -f "$depfile"
- cat < "$tmpdepfile" > "$depfile"
- tr ' ' '
-' < "$tmpdepfile" | \
-dashXmstdout)
- # This case only exists to satisfy depend.m4. It is never actually
- # run, as this mode is specially recognized in the preamble.
- exit 1
-makedepend)
- # X makedepend
- shift
- cleared=no
- for arg in "$@"; do
- case $cleared in no)
- set ""; shift
- cleared=yes
- esac
- case "$arg" in
- -D*|-I*)
- set fnord "$@" "$arg"; shift;;
- esac
- done
- obj_suffix="`echo $object | sed 's/^.*\././'`"
- touch "$tmpdepfile"
- ${MAKEDEPEND-makedepend} 2>/dev/null -o"$obj_suffix" -f"$tmpdepfile" "$@"
- proc=$!
- stat=$?
- wait "$proc"
- rm -f "$depfile"
- tail +3 "$tmpdepfile" | tr ' ' '
- rm -f "$tmpdepfile" "$tmpdepfile".bak
-cpp)
- ( IFS=" "
- case " $* " in
- for arg
- case $arg in
- "--mode=compile")
- shift # fnord
- esac
- shift # fnord
- shift # "$arg"
- done
- esac
- "$@" -E |
- sed -n '/^# [0-9][0-9]* "\([^"]*\)".*/ s:: \1 \\:p' |
- sed '$ s: \\$::' > "$tmpdepfile"
- proc=$!
- stat=$?
- wait "$proc"
- rm -f "$depfile"
- cat < "$tmpdepfile" >> "$depfile"
- sed < "$tmpdepfile" '/^$/d;s/^ //;s/ \\$//;s/$/ :/' >> "$depfile"
-msvisualcpp)
- ( IFS=" "
- case " $* " in
- for arg
- case $arg in
- "--mode=compile")
- shift # fnord
- esac
- shift # fnord
- shift # "$arg"
- done
- esac
- "$@" -E |
- sed -n '/^#line [0-9][0-9]* "\([^"]*\)"/ s::echo "`cygpath -u \\"\1\\"`":p' | sort | uniq > "$tmpdepfile"
- proc=$!
- stat=$?
- wait "$proc"
- rm -f "$depfile"
- . "$tmpdepfile" | sed 's% %\\ %g' | sed -n '/^\(.*\)$/ s:: \1 \\:p' >> "$depfile"
- echo " " >> "$depfile"
- . "$tmpdepfile" | sed 's% %\\ %g' | sed -n '/^\(.*\)$/ s::\1\::p' >> "$depfile"
-none)
- exec "$@"
- echo "Unknown depmode $depmode" 1>&2
- exit 1
-esac
-exit 0
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/depcomp (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/depcomp)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/depcomp (rev 0)
@@ -0,0 +1,441 @@
+#! /bin/sh
+# depcomp - compile a program generating dependencies as side-effects
+# Copyright 1999, 2000 Free Software Foundation, Inc.
+# This program is free software; you can redistribute it and/or modify
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
+# 02111-1307, USA.
+# Originally written by Alexandre Oliva <oliva at dcc.unicamp.br>.
+if test -z "$depmode" || test -z "$source" || test -z "$object"; then
+ echo "depcomp: Variables source, object and depmode must be set" 1>&2
+ exit 1
+fi
+# `libtool' can also be set to `yes' or `no'.
+depfile=${depfile-`echo "$object" | sed 's,\([^/]*\)$,.deps/\1,;s/\.\([^.]*\)$/.P\1/'`}
+tmpdepfile=${tmpdepfile-`echo "$depfile" | sed 's/\.\([^.]*\)$/.T\1/'`}
+rm -f "$tmpdepfile"
+# Some modes work just like other modes, but use different flags. We
+# parameterize here, but still list the modes in the big case below,
+# to make depend.m4 easier to write. Note that we *cannot* use a case
+# here, because this file can only contain one case statement.
+if test "$depmode" = hp; then
+ # HP compiler uses -M and no extra arg.
+ gccflag=-M
+ depmode=gcc
+fi
+if test "$depmode" = dashXmstdout; then
+ # This is just like dashmstdout with a different argument.
+ dashmflag=-xM
+ depmode=dashmstdout
+fi
+case "$depmode" in
+gcc3)
+## gcc 3 implements dependency tracking that does exactly what
+## we want. Yay! Note: for some reason libtool 1.4 doesn't like
+## it if -MD -MP comes after the -MF stuff. Hmm.
+ "$@" -MT "$object" -MD -MP -MF "$tmpdepfile"
+ stat=$?
+ if test $stat -eq 0; then :
+ else
+ rm -f "$tmpdepfile"
+ exit $stat
+ fi
+ mv "$tmpdepfile" "$depfile"
+gcc)
+## There are various ways to get dependency output from gcc. Here's
+## why we pick this rather obscure method:
+## - Don't want to use -MD because we'd like the dependencies to end
+## up in a subdir. Having to rename by hand is ugly.
+## (We might end up doing this anyway to support other compilers.)
+## - The DEPENDENCIES_OUTPUT environment variable makes gcc act like
+## -MM, not -M (despite what the docs say).
+## - Using -M directly means running the compiler twice (even worse
+## than renaming).
+ if test -z "$gccflag"; then
+ gccflag=-MD,
+ fi
+ "$@" -Wp,"$gccflag$tmpdepfile"
+ stat=$?
+ else
+ exit $stat
+ fi
+ rm -f "$depfile"
+ echo "$object : \\" > "$depfile"
+ alpha=ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz
+## The second -e expression handles DOS-style file names with drive letters.
+ sed -e 's/^[^:]*: / /' \
+ -e 's/^['$alpha']:\/[^:]*: / /' < "$tmpdepfile" >> "$depfile"
+## This next piece of magic avoids the `deleted header file' problem.
+## The problem is that when a header file which appears in a .P file
+## is deleted, the dependency causes make to die (because there is
+## typically no way to rebuild the header). We avoid this by adding
+## dummy dependencies for each header file. Too bad gcc doesn't do
+## this for us directly.
+ tr ' ' '
+' < "$tmpdepfile" |
+## Some versions of gcc put a space before the `:'. On the theory
+## that the space means something, we add a space to the output as
+## well.
+## Some versions of the HPUX 10.20 sed can't process this invocation
+## correctly. Breaking it into two sed invocations is a workaround.
+ sed -e 's/^\\$//' -e '/^$/d' -e '/:$/d' | sed -e 's/$/ :/' >> "$depfile"
+hp)
+ # This case exists only to let depend.m4 do its work. It works by
+ # looking at the text of this script. This case will never be run,
+ # since it is checked for above.
+ exit 1
+sgi)
+ if test "$libtool" = yes; then
+ "$@" "-Wp,-MDupdate,$tmpdepfile"
+ else
+ "$@" -MDupdate "$tmpdepfile"
+ fi
+ stat=$?
+ else
+ exit $stat
+ fi
+ rm -f "$depfile"
+ if test -f "$tmpdepfile"; then # yes, the sourcefile depend on other files
+ # Clip off the initial element (the dependent). Don't try to be
+ # clever and replace this with sed code, as IRIX sed won't handle
+ # lines with more than a fixed number of characters (4096 in
+ # IRIX 6.2 sed, 8192 in IRIX 6.5). We also remove comment lines;
+ # the IRIX cc adds comments like `#:fec' to the end of the
+ # dependency line.
+ tr ' ' '
+' < "$tmpdepfile" \
+ | sed -e 's/^.*\.o://' -e 's/#.*$//' -e '/^$/ d' | \
+ tr '
+' ' ' >> $depfile
+ echo >> $depfile
+ # The second pass generates a dummy entry for each header file.
+ tr ' ' '
+ | sed -e 's/^.*\.o://' -e 's/#.*$//' -e '/^$/ d' -e 's/$/:/' \
+ >> $depfile
+ else
+ # The sourcefile does not contain any dependencies, so just
+ # store a dummy comment line, to avoid errors with the Makefile
+ # "include basename.Plo" scheme.
+ echo "#dummy" > "$depfile"
+ fi
+aix)
+ # The C for AIX Compiler uses -M and outputs the dependencies
+ # in a .u file. This file always lives in the current directory.
+ # Also, the AIX compiler puts `$object:' at the start of each line;
+ # $object doesn't have directory information.
+ stripped=`echo "$object" | sed -e 's,^.*/,,' -e 's/\(.*\)\..*$/\1/'`
+ tmpdepfile="$stripped.u"
+ outname="$stripped.o"
+ "$@" -Wc,-M
+ else
+ "$@" -M
+ fi
+ stat=$?
+ else
+ exit $stat
+ fi
+ # Each line is of the form `foo.o: dependent.h'.
+ # Do two passes, one to just change these to
+ # `$object: dependent.h' and one to simply `dependent.h:'.
+ sed -e "s,^$outname:,$object :," < "$tmpdepfile" > "$depfile"
+ sed -e "s,^$outname: \(.*\)$,\1:," < "$tmpdepfile" >> "$depfile"
+ else
+ fi
+icc)
+ # Must come before tru64.
+ # Intel's C compiler understands `-MD -MF file'. However
+ # icc -MD -MF foo.d -c -o sub/foo.o sub/foo.c
+ # will fill foo.d with something like
+ # foo.o: sub/foo.c
+ # foo.o: sub/foo.h
+ # which is wrong. We want:
+ # sub/foo.o: sub/foo.c
+ # sub/foo.o: sub/foo.h
+ # sub/foo.c:
+ # sub/foo.h:
+ "$@" -MD -MF "$tmpdepfile"
+ stat=$?
+ else
+ exit $stat
+ fi
+ rm -f "$depfile"
+ sed -e "s,^[^:]*:,$object :," < "$tmpdepfile" > "$depfile"
+ sed -e "s,^[^:]*: \(.*\)$,\1:," < "$tmpdepfile" >> "$depfile"
+tru64)
+ # The Tru64 AIX compiler uses -MD to generate dependencies as a side
+ # effect. `cc -MD -o foo.o ...' puts the dependencies into `foo.o.d'.
+ # At least on Alpha/Redhat 6.1, Compaq CCC V6.2-504 seems to put
+ # dependencies in `foo.d' instead, so we check for that too.
+ # Subdirectories are respected.
+ tmpdepfile1="$object.d"
+ tmpdepfile2=`echo "$object" | sed -e 's/.o$/.d/'`
+ "$@" -Wc,-MD
+ else
+ "$@" -MD
+ fi
+ stat=$?
+ else
+ rm -f "$tmpdepfile1" "$tmpdepfile2"
+ exit $stat
+ fi
+ if test -f "$tmpdepfile1"; then
+ tmpdepfile="$tmpdepfile1"
+ else
+ tmpdepfile="$tmpdepfile2"
+ fi
+ sed -e "s,^.*\.[a-z]*:,$object:," < "$tmpdepfile" > "$depfile"
+ # That's a space and a tab in the [].
+ sed -e 's,^.*\.[a-z]*:[ ]*,,' -e 's,$,:,' < "$tmpdepfile" >> "$depfile"
+ else
+ fi
+#nosideeffect)
+ # This comment above is used by automake to tell side-effect
+ # dependency tracking mechanisms from slower ones.
+dashmstdout)
+ # Important note: in order to support this mode, a compiler *must*
+ # always write the proprocessed file to stdout, regardless of -o,
+ # because we must use -o when running libtool.
+ test -z "$dashmflag" && dashmflag=-M
+ ( IFS=" "
+ case " $* " in
+ *" --mode=compile "*) # this is libtool, let us make it quiet
+ for arg
+ do # cycle over the arguments
+ case "$arg" in
+ "--mode=compile")
+ # insert --quiet before "--mode=compile"
+ set fnord "$@" --quiet
+ shift # fnord
+ esac
+ set fnord "$@" "$arg"
+ shift # fnord
+ shift # "$arg"
+ done
+ esac
+ "$@" $dashmflag | sed 's:^[^:]*\:[ ]*:'"$object"'\: :' > "$tmpdepfile"
+ proc=$!
+ stat=$?
+ wait "$proc"
+ if test "$stat" != 0; then exit $stat; fi
+ rm -f "$depfile"
+ cat < "$tmpdepfile" > "$depfile"
+ tr ' ' '
+' < "$tmpdepfile" | \
+dashXmstdout)
+ # This case only exists to satisfy depend.m4. It is never actually
+ # run, as this mode is specially recognized in the preamble.
+ exit 1
+makedepend)
+ # X makedepend
+ shift
+ cleared=no
+ for arg in "$@"; do
+ case $cleared in no)
+ set ""; shift
+ cleared=yes
+ esac
+ case "$arg" in
+ -D*|-I*)
+ set fnord "$@" "$arg"; shift;;
+ esac
+ done
+ obj_suffix="`echo $object | sed 's/^.*\././'`"
+ touch "$tmpdepfile"
+ ${MAKEDEPEND-makedepend} 2>/dev/null -o"$obj_suffix" -f"$tmpdepfile" "$@"
+ proc=$!
+ stat=$?
+ wait "$proc"
+ rm -f "$depfile"
+ tail +3 "$tmpdepfile" | tr ' ' '
+ rm -f "$tmpdepfile" "$tmpdepfile".bak
+cpp)
+ ( IFS=" "
+ case " $* " in
+ for arg
+ case $arg in
+ "--mode=compile")
+ shift # fnord
+ esac
+ shift # fnord
+ shift # "$arg"
+ done
+ esac
+ "$@" -E |
+ sed -n '/^# [0-9][0-9]* "\([^"]*\)".*/ s:: \1 \\:p' |
+ sed '$ s: \\$::' > "$tmpdepfile"
+ proc=$!
+ stat=$?
+ wait "$proc"
+ rm -f "$depfile"
+ cat < "$tmpdepfile" >> "$depfile"
+ sed < "$tmpdepfile" '/^$/d;s/^ //;s/ \\$//;s/$/ :/' >> "$depfile"
+msvisualcpp)
+ ( IFS=" "
+ case " $* " in
+ for arg
+ case $arg in
+ "--mode=compile")
+ shift # fnord
+ esac
+ shift # fnord
+ shift # "$arg"
+ done
+ esac
+ "$@" -E |
+ sed -n '/^#line [0-9][0-9]* "\([^"]*\)"/ s::echo "`cygpath -u \\"\1\\"`":p' | sort | uniq > "$tmpdepfile"
+ proc=$!
+ stat=$?
+ wait "$proc"
+ rm -f "$depfile"
+ . "$tmpdepfile" | sed 's% %\\ %g' | sed -n '/^\(.*\)$/ s:: \1 \\:p' >> "$depfile"
+ echo " " >> "$depfile"
+ . "$tmpdepfile" | sed 's% %\\ %g' | sed -n '/^\(.*\)$/ s::\1\::p' >> "$depfile"
+none)
+ exec "$@"
+ echo "Unknown depmode $depmode" 1>&2
+ exit 1
+esac
+exit 0
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/install-sh
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/install-sh 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/install-sh 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,276 +0,0 @@
-#!/bin/sh
-# install - install a program, script, or datafile
-# This comes from X11R5 (mit/util/scripts/install.sh).
-# Copyright 1991 by the Massachusetts Institute of Technology
-# Permission to use, copy, modify, distribute, and sell this software and its
-# documentation for any purpose is hereby granted without fee, provided that
-# the above copyright notice appear in all copies and that both that
-# copyright notice and this permission notice appear in supporting
-# documentation, and that the name of M.I.T. not be used in advertising or
-# publicity pertaining to distribution of the software without specific,
-# written prior permission. M.I.T. makes no representations about the
-# suitability of this software for any purpose. It is provided "as is"
-# without express or implied warranty.
-# Calling this script install-sh is preferred over install.sh, to prevent
-# `make' implicit rules from creating a file called install from it
-# when there is no Makefile.
-# This script is compatible with the BSD install script, but was written
-# from scratch. It can only install one file at a time, a restriction
-# shared with many OS's install programs.
-# set DOITPROG to echo to test this script
-# Don't use :- since 4.3BSD and earlier shells don't like it.
-doit="${DOITPROG-}"
-# put in absolute paths if you don't have them in your path; or use env. vars.
-mvprog="${MVPROG-mv}"
-cpprog="${CPPROG-cp}"
-chmodprog="${CHMODPROG-chmod}"
-chownprog="${CHOWNPROG-chown}"
-chgrpprog="${CHGRPPROG-chgrp}"
-stripprog="${STRIPPROG-strip}"
-rmprog="${RMPROG-rm}"
-mkdirprog="${MKDIRPROG-mkdir}"
-transformbasename=""
-transform_arg=""
-instcmd="$mvprog"
-chmodcmd="$chmodprog 0755"
-chowncmd=""
-chgrpcmd=""
-stripcmd=""
-rmcmd="$rmprog -f"
-mvcmd="$mvprog"
-src=""
-dst=""
-dir_arg=""
-while [ x"$1" != x ]; do
- case $1 in
- -c) instcmd=$cpprog
- shift
- continue;;
- -d) dir_arg=true
- shift
- continue;;
- -m) chmodcmd="$chmodprog $2"
- shift
- shift
- continue;;
- -o) chowncmd="$chownprog $2"
- shift
- shift
- continue;;
- -g) chgrpcmd="$chgrpprog $2"
- shift
- shift
- continue;;
- -s) stripcmd=$stripprog
- shift
- continue;;
- -t=*) transformarg=`echo $1 | sed 's/-t=//'`
- shift
- continue;;
- -b=*) transformbasename=`echo $1 | sed 's/-b=//'`
- shift
- continue;;
- *) if [ x"$src" = x ]
- then
- src=$1
- else
- # this colon is to work around a 386BSD /bin/sh bug
- dst=$1
- fi
- shift
- continue;;
- esac
-done
-if [ x"$src" = x ]
-then
- echo "$0: no input file specified" >&2
- exit 1
-else
-fi
-if [ x"$dir_arg" != x ]; then
- dst=$src
- src=""
- if [ -d "$dst" ]; then
- instcmd=:
- chmodcmd=""
- else
- instcmd=$mkdirprog
- fi
-else
-# Waiting for this to be detected by the "$instcmd $src $dsttmp" command
-# might cause directories to be created, which would be especially bad
-# if $src (and thus $dsttmp) contains '*'.
- if [ -f "$src" ] || [ -d "$src" ]
- then
- else
- echo "$0: $src does not exist" >&2
- exit 1
- fi
- if [ x"$dst" = x ]
- then
- echo "$0: no destination specified" >&2
- exit 1
- else
- fi
-# If destination is a directory, append the input filename; if your system
-# does not like double slashes in filenames, you may need to add some logic
- if [ -d "$dst" ]
- then
- dst=$dst/`basename "$src"`
- else
- fi
-fi
-## this sed command emulates the dirname command
-dstdir=`echo "$dst" | sed -e 's,[^/]*$,,;s,/$,,;s,^$,.,'`
-# Make sure that the destination directory exists.
-# this part is taken from Noah Friedman's mkinstalldirs script
-# Skip lots of stat calls in the usual case.
-if [ ! -d "$dstdir" ]; then
-defaultIFS='
-IFS="${IFS-$defaultIFS}"
-oIFS=$IFS
-# Some sh's can't handle IFS=/ for some reason.
-IFS='%'
-set - `echo "$dstdir" | sed -e 's@/@%@g' -e 's@^%@/@'`
-IFS=$oIFS
-pathcomp=''
-while [ $# -ne 0 ] ; do
- pathcomp=$pathcomp$1
- shift
- if [ ! -d "$pathcomp" ] ;
- then
- $mkdirprog "$pathcomp"
- else
- fi
- pathcomp=$pathcomp/
-done
-fi
-then
- $doit $instcmd "$dst" &&
- if [ x"$chowncmd" != x ]; then $doit $chowncmd "$dst"; else : ; fi &&
- if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd "$dst"; else : ; fi &&
- if [ x"$stripcmd" != x ]; then $doit $stripcmd "$dst"; else : ; fi &&
- if [ x"$chmodcmd" != x ]; then $doit $chmodcmd "$dst"; else : ; fi
-else
-# If we're going to rename the final executable, determine the name now.
- if [ x"$transformarg" = x ]
- then
- dstfile=`basename "$dst"`
- else
- dstfile=`basename "$dst" $transformbasename |
- sed $transformarg`$transformbasename
- fi
-# don't allow the sed command to completely eliminate the filename
- if [ x"$dstfile" = x ]
- then
- else
- fi
-# Make a couple of temp file names in the proper directory.
- dsttmp=$dstdir/#inst.$$#
- rmtmp=$dstdir/#rm.$$#
-# Trap to clean up temp files at exit.
- trap 'status=$?; rm -f "$dsttmp" "$rmtmp" && exit $status' 0
- trap '(exit $?); exit' 1 2 13 15
-# Move or copy the file name to the temp name
- $doit $instcmd "$src" "$dsttmp" &&
-# and set any options; do chmod last to preserve setuid bits
-# If any of these fail, we abort the whole thing. If we want to
-# ignore errors from any of these, just make sure not to ignore
-# errors from the above "$doit $instcmd $src $dsttmp" command.
- if [ x"$chowncmd" != x ]; then $doit $chowncmd "$dsttmp"; else :;fi &&
- if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd "$dsttmp"; else :;fi &&
- if [ x"$stripcmd" != x ]; then $doit $stripcmd "$dsttmp"; else :;fi &&
- if [ x"$chmodcmd" != x ]; then $doit $chmodcmd "$dsttmp"; else :;fi &&
-# Now remove or move aside any old file at destination location. We try this
-# two ways since rm can't unlink itself on some systems and the destination
-# file might be busy for other reasons. In this case, the final cleanup
-# might fail but the new file should still install successfully.
- if [ -f "$dstdir/$dstfile" ]
- then
- $doit $rmcmd -f "$dstdir/$dstfile" 2>/dev/null ||
- $doit $mvcmd -f "$dstdir/$dstfile" "$rmtmp" 2>/dev/null ||
- echo "$0: cannot unlink or rename $dstdir/$dstfile" >&2
- (exit 1); exit
- else
- fi
-# Now rename the file to the real destination.
- $doit $mvcmd "$dsttmp" "$dstdir/$dstfile"
-fi &&
-# The final little trick to "correctly" pass the exit status to the exit trap.
- (exit 0); exit
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/install-sh (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/install-sh)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/install-sh (rev 0)
@@ -0,0 +1,276 @@
+#!/bin/sh
+# install - install a program, script, or datafile
+# This comes from X11R5 (mit/util/scripts/install.sh).
+# Copyright 1991 by the Massachusetts Institute of Technology
+# Permission to use, copy, modify, distribute, and sell this software and its
+# documentation for any purpose is hereby granted without fee, provided that
+# the above copyright notice appear in all copies and that both that
+# copyright notice and this permission notice appear in supporting
+# documentation, and that the name of M.I.T. not be used in advertising or
+# publicity pertaining to distribution of the software without specific,
+# written prior permission. M.I.T. makes no representations about the
+# suitability of this software for any purpose. It is provided "as is"
+# without express or implied warranty.
+# Calling this script install-sh is preferred over install.sh, to prevent
+# `make' implicit rules from creating a file called install from it
+# when there is no Makefile.
+# This script is compatible with the BSD install script, but was written
+# from scratch. It can only install one file at a time, a restriction
+# shared with many OS's install programs.
+# set DOITPROG to echo to test this script
+# Don't use :- since 4.3BSD and earlier shells don't like it.
+doit="${DOITPROG-}"
+# put in absolute paths if you don't have them in your path; or use env. vars.
+mvprog="${MVPROG-mv}"
+cpprog="${CPPROG-cp}"
+chmodprog="${CHMODPROG-chmod}"
+chownprog="${CHOWNPROG-chown}"
+chgrpprog="${CHGRPPROG-chgrp}"
+stripprog="${STRIPPROG-strip}"
+rmprog="${RMPROG-rm}"
+mkdirprog="${MKDIRPROG-mkdir}"
+transformbasename=""
+transform_arg=""
+instcmd="$mvprog"
+chmodcmd="$chmodprog 0755"
+chowncmd=""
+chgrpcmd=""
+stripcmd=""
+rmcmd="$rmprog -f"
+mvcmd="$mvprog"
+src=""
+dst=""
+dir_arg=""
+while [ x"$1" != x ]; do
+ case $1 in
+ -c) instcmd=$cpprog
+ shift
+ continue;;
+ -d) dir_arg=true
+ shift
+ continue;;
+ -m) chmodcmd="$chmodprog $2"
+ shift
+ shift
+ continue;;
+ -o) chowncmd="$chownprog $2"
+ shift
+ shift
+ continue;;
+ -g) chgrpcmd="$chgrpprog $2"
+ shift
+ shift
+ continue;;
+ -s) stripcmd=$stripprog
+ shift
+ continue;;
+ -t=*) transformarg=`echo $1 | sed 's/-t=//'`
+ shift
+ continue;;
+ -b=*) transformbasename=`echo $1 | sed 's/-b=//'`
+ shift
+ continue;;
+ *) if [ x"$src" = x ]
+ then
+ src=$1
+ else
+ # this colon is to work around a 386BSD /bin/sh bug
+ dst=$1
+ fi
+ shift
+ continue;;
+ esac
+done
+if [ x"$src" = x ]
+then
+ echo "$0: no input file specified" >&2
+ exit 1
+else
+fi
+if [ x"$dir_arg" != x ]; then
+ dst=$src
+ src=""
+ if [ -d "$dst" ]; then
+ instcmd=:
+ chmodcmd=""
+ else
+ instcmd=$mkdirprog
+ fi
+else
+# Waiting for this to be detected by the "$instcmd $src $dsttmp" command
+# might cause directories to be created, which would be especially bad
+# if $src (and thus $dsttmp) contains '*'.
+ if [ -f "$src" ] || [ -d "$src" ]
+ then
+ else
+ echo "$0: $src does not exist" >&2
+ exit 1
+ fi
+ if [ x"$dst" = x ]
+ then
+ echo "$0: no destination specified" >&2
+ exit 1
+ else
+ fi
+# If destination is a directory, append the input filename; if your system
+# does not like double slashes in filenames, you may need to add some logic
+ if [ -d "$dst" ]
+ then
+ dst=$dst/`basename "$src"`
+ else
+ fi
+fi
+## this sed command emulates the dirname command
+dstdir=`echo "$dst" | sed -e 's,[^/]*$,,;s,/$,,;s,^$,.,'`
+# Make sure that the destination directory exists.
+# this part is taken from Noah Friedman's mkinstalldirs script
+# Skip lots of stat calls in the usual case.
+if [ ! -d "$dstdir" ]; then
+defaultIFS='
+IFS="${IFS-$defaultIFS}"
+oIFS=$IFS
+# Some sh's can't handle IFS=/ for some reason.
+IFS='%'
+set - `echo "$dstdir" | sed -e 's@/@%@g' -e 's@^%@/@'`
+IFS=$oIFS
+pathcomp=''
+while [ $# -ne 0 ] ; do
+ pathcomp=$pathcomp$1
+ shift
+ if [ ! -d "$pathcomp" ] ;
+ then
+ $mkdirprog "$pathcomp"
+ else
+ fi
+ pathcomp=$pathcomp/
+done
+fi
+then
+ $doit $instcmd "$dst" &&
+ if [ x"$chowncmd" != x ]; then $doit $chowncmd "$dst"; else : ; fi &&
+ if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd "$dst"; else : ; fi &&
+ if [ x"$stripcmd" != x ]; then $doit $stripcmd "$dst"; else : ; fi &&
+ if [ x"$chmodcmd" != x ]; then $doit $chmodcmd "$dst"; else : ; fi
+else
+# If we're going to rename the final executable, determine the name now.
+ if [ x"$transformarg" = x ]
+ then
+ dstfile=`basename "$dst"`
+ else
+ dstfile=`basename "$dst" $transformbasename |
+ sed $transformarg`$transformbasename
+ fi
+# don't allow the sed command to completely eliminate the filename
+ if [ x"$dstfile" = x ]
+ then
+ else
+ fi
+# Make a couple of temp file names in the proper directory.
+ dsttmp=$dstdir/#inst.$$#
+ rmtmp=$dstdir/#rm.$$#
+# Trap to clean up temp files at exit.
+ trap 'status=$?; rm -f "$dsttmp" "$rmtmp" && exit $status' 0
+ trap '(exit $?); exit' 1 2 13 15
+# Move or copy the file name to the temp name
+ $doit $instcmd "$src" "$dsttmp" &&
+# and set any options; do chmod last to preserve setuid bits
+# If any of these fail, we abort the whole thing. If we want to
+# ignore errors from any of these, just make sure not to ignore
+# errors from the above "$doit $instcmd $src $dsttmp" command.
+ if [ x"$chowncmd" != x ]; then $doit $chowncmd "$dsttmp"; else :;fi &&
+ if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd "$dsttmp"; else :;fi &&
+ if [ x"$stripcmd" != x ]; then $doit $stripcmd "$dsttmp"; else :;fi &&
+ if [ x"$chmodcmd" != x ]; then $doit $chmodcmd "$dsttmp"; else :;fi &&
+# Now remove or move aside any old file at destination location. We try this
+# two ways since rm can't unlink itself on some systems and the destination
+# file might be busy for other reasons. In this case, the final cleanup
+# might fail but the new file should still install successfully.
+ if [ -f "$dstdir/$dstfile" ]
+ then
+ $doit $rmcmd -f "$dstdir/$dstfile" 2>/dev/null ||
+ $doit $mvcmd -f "$dstdir/$dstfile" "$rmtmp" 2>/dev/null ||
+ echo "$0: cannot unlink or rename $dstdir/$dstfile" >&2
+ (exit 1); exit
+ else
+ fi
+# Now rename the file to the real destination.
+ $doit $mvcmd "$dsttmp" "$dstdir/$dstfile"
+fi &&
+# The final little trick to "correctly" pass the exit status to the exit trap.
+ (exit 0); exit
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ltmain.sh
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ltmain.sh 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ltmain.sh 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,6343 +0,0 @@
-# ltmain.sh - Provide generalized library-building support services.
-# NOTE: Changing this file will not affect anything until you rerun configure.
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2003
-# Free Software Foundation, Inc.
-# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# Check that we have a working $echo.
-if test "X$1" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
-elif test "X$1" = X--fallback-echo; then
- # Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t'; then
- # Yippee, $echo works!
-else
- # Restart under the correct shell, and then maybe $echo will work.
- exec $SHELL "$0" --no-reexec ${1+"$@"}
-fi
-if test "X$1" = X--fallback-echo; then
- # used as fallback echo
- shift
- cat <<EOF
-EOF
- exit 0
-fi
-# The name of this program.
-progname=`$echo "$0" | ${SED} 's%^.*/%%'`
-modename="$progname"
-# Constants.
-PROGRAM=ltmain.sh
-PACKAGE=libtool
-VERSION=1.5a
-TIMESTAMP=" (1.1240 2003/06/26 06:55:19)"
-default_mode=
-help="Try \`$progname --help' for more information."
-magic="%%%MAGIC variable%%%"
-mkdir="mkdir"
-mv="mv -f"
-rm="rm -f"
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed="${SED}"' -e 1s/^X//'
-sed_quote_subst='s/\([\\`\\"$\\\\]\)/\\\1/g'
-# test EBCDIC or ASCII
-case `echo A|tr A '\301'` in
- A) # EBCDIC based system
- SP2NL="tr '\100' '\n'"
- NL2SP="tr '\r\n' '\100\100'"
- *) # Assume ASCII based system
- SP2NL="tr '\040' '\012'"
- NL2SP="tr '\015\012' '\040\040'"
-esac
-# NLS nuisances.
-# Only set LANG and LC_ALL to C if already set.
-# These must not be set unconditionally because not all systems understand
-# e.g. LANG=C (notably SCO).
-# We save the old values to restore during execute mode.
-if test "${LC_ALL+set}" = set; then
- save_LC_ALL="$LC_ALL"; LC_ALL=C; export LC_ALL
-fi
-if test "${LANG+set}" = set; then
- save_LANG="$LANG"; LANG=C; export LANG
-fi
-# Make sure IFS has a sensible default
-: ${IFS=" "}
-if test "$build_libtool_libs" != yes && test "$build_old_libs" != yes; then
- $echo "$modename: not configured to build any kind of library" 1>&2
- $echo "Fatal configuration error. See the $PACKAGE docs for more information." 1>&2
- exit 1
-fi
-# Global variables.
-mode=$default_mode
-nonopt=
-prev=
-prevopt=
-run=
-show="$echo"
-show_help=
-execute_dlfiles=
-lo2o="s/\\.lo\$/.${objext}/"
-o2lo="s/\\.${objext}\$/.lo/"
-# Shell function definitions:
-# This seems to be the best place for them
-# Need a lot of goo to handle *both* DLLs and import libs
-# Has to be a shell function in order to 'eat' the argument
-# that is supplied when $file_magic_command is called.
-win32_libid () {
- win32_libid_type="unknown"
- win32_fileres=`file -L $1 2>/dev/null`
- case $win32_fileres in
- *ar\ archive\ import\ library*) # definitely import
- win32_libid_type="x86 archive import"
- *ar\ archive*) # could be an import, or static
- if eval $OBJDUMP -f $1 | $SED -e '10q' 2>/dev/null | \
- grep -E 'file format pe-i386(.*architecture: i386)?' >/dev/null ; then
- win32_nmres=`eval $NM -f posix -A $1 | \
- sed -n -e '1,100{/ I /{x;/import/!{s/^/import/;h;p;};x;};}'`
- if test "X$win32_nmres" = "Ximport" ; then
- else
- win32_libid_type="x86 archive static"
- fi
- fi
- *DLL*)
- win32_libid_type="x86 DLL"
- *executable*) # but shell scripts are "executable" too...
- *MS\ Windows\ PE\ Intel*)
- esac
- esac
- $echo $win32_libid_type
-# End of Shell function definitions
-# Parse our command line options once, thoroughly.
-while test "$#" -gt 0
-do
- arg="$1"
- shift
- case $arg in
- -*=*) optarg=`$echo "X$arg" | $Xsed -e 's/[-_a-zA-Z0-9]*=//'` ;;
- *) optarg= ;;
- esac
- # If the previous option needs an argument, assign it.
- if test -n "$prev"; then
- case $prev in
- execute_dlfiles)
- execute_dlfiles="$execute_dlfiles $arg"
- tag)
- tagname="$arg"
- # Check whether tagname contains only valid characters
- case $tagname in
- *[!-_A-Za-z0-9,/]*)
- $echo "$progname: invalid tag name: $tagname" 1>&2
- exit 1
- esac
- case $tagname in
- CC)
- # Don't test for the "default" C tag, as we know, it's there, but
- # not specially marked.
- if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "$0" > /dev/null; then
- taglist="$taglist $tagname"
- # Evaluate the configuration.
- eval "`${SED} -n -e '/^# ### BEGIN LIBTOOL TAG CONFIG: '$tagname'$/,/^# ### END LIBTOOL TAG CONFIG: '$tagname'$/p' < $0`"
- else
- $echo "$progname: ignoring unknown tag $tagname" 1>&2
- fi
- esac
- eval "$prev=\$arg"
- esac
- prev=
- prevopt=
- continue
- fi
- # Have we seen a non-optional argument yet?
- case $arg in
- --help)
- show_help=yes
- --version)
- $echo "$PROGRAM (GNU $PACKAGE) $VERSION$TIMESTAMP"
- $echo
- $echo "Copyright (C) 2003 Free Software Foundation, Inc."
- $echo "This is free software; see the source for copying conditions. There is NO"
- $echo "warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
- exit 0
- --config)
- ${SED} -e '1,/^# ### BEGIN LIBTOOL CONFIG/d' -e '/^# ### END LIBTOOL CONFIG/,$d' $0
- # Now print the configurations for the tags.
- for tagname in $taglist; do
- ${SED} -n -e "/^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$/,/^# ### END LIBTOOL TAG CONFIG: $tagname$/p" < "$0"
- done
- exit 0
- --debug)
- $echo "$progname: enabling shell trace mode"
- set -x
- --dry-run | -n)
- run=:
- --features)
- $echo "host: $host"
- if test "$build_libtool_libs" = yes; then
- $echo "enable shared libraries"
- else
- $echo "disable shared libraries"
- fi
- if test "$build_old_libs" = yes; then
- $echo "enable static libraries"
- else
- $echo "disable static libraries"
- fi
- exit 0
- --finish) mode="finish" ;;
- --mode) prevopt="--mode" prev=mode ;;
- --mode=*) mode="$optarg" ;;
- --preserve-dup-deps) duplicate_deps="yes" ;;
- --quiet | --silent)
- show=:
- --tag) prevopt="--tag" prev=tag ;;
- --tag=*)
- set tag "$optarg" ${1+"$@"}
- shift
- prev=tag
- -dlopen)
- prevopt="-dlopen"
- prev=execute_dlfiles
- $echo "$modename: unrecognized option \`$arg'" 1>&2
- $echo "$help" 1>&2
- exit 1
- nonopt="$arg"
- break
- esac
-done
-if test -n "$prevopt"; then
- $echo "$modename: option \`$prevopt' requires an argument" 1>&2
- exit 1
-fi
-# If this variable is set in any of the actions, the command in it
-# will be execed at the end. This prevents here-documents from being
-# left over by shells.
-exec_cmd=
-if test -z "$show_help"; then
- # Infer the operation mode.
- if test -z "$mode"; then
- $echo "*** Warning: inferring the mode of operation is deprecated." 1>&2
- $echo "*** Future versions of Libtool will require -mode=MODE be specified." 1>&2
- case $nonopt in
- *cc | cc* | *++ | gcc* | *-gcc* | g++* | xlc*)
- mode=link
- for arg
- do
- case $arg in
- -c)
- mode=compile
- break
- esac
- done
- *db | *dbx | *strace | *truss)
- mode=execute
- *install*|cp|mv)
- mode=install
- *rm)
- mode=uninstall
- # If we have no mode, but dlfiles were specified, then do execute mode.
- test -n "$execute_dlfiles" && mode=execute
- # Just use the default operation mode.
- if test -n "$nonopt"; then
- $echo "$modename: warning: cannot infer operation mode from \`$nonopt'" 1>&2
- else
- $echo "$modename: warning: cannot infer operation mode without MODE-ARGS" 1>&2
- fi
- fi
- esac
- fi
- # Only execute mode is allowed to have -dlopen flags.
- if test -n "$execute_dlfiles" && test "$mode" != execute; then
- $echo "$modename: unrecognized option \`-dlopen'" 1>&2
- exit 1
- fi
- # Change the help message to a mode-specific one.
- generic_help="$help"
- help="Try \`$modename --help --mode=$mode' for more information."
- # These modes are in order of execution frequency so that they run quickly.
- case $mode in
- # libtool compile mode
- compile)
- modename="$modename: compile"
- # Get the compilation command and the source file.
- base_compile=
- srcfile="$nonopt" # always keep a non-empty value in "srcfile"
- suppress_output=
- arg_mode=normal
- libobj=
- for arg
- do
- case "$arg_mode" in
- arg )
- # do not "continue". Instead, add this to base_compile
- lastarg="$arg"
- arg_mode=normal
- target )
- libobj="$arg"
- arg_mode=normal
- continue
- normal )
- # Accept any command-line options.
- case $arg in
- -o)
- if test -n "$libobj" ; then
- $echo "$modename: you cannot specify \`-o' more than once" 1>&2
- exit 1
- fi
- arg_mode=target
- continue
- -static)
- build_old_libs=yes
- continue
- -prefer-pic)
- pic_mode=yes
- continue
- -prefer-non-pic)
- pic_mode=no
- continue
- -Xcompiler)
- arg_mode=arg # the next one goes into the "base_compile" arg list
- continue # The current "srcfile" will either be retained or
- ;; # replaced later. I would guess that would be a bug.
- -Wc,*)
- args=`$echo "X$arg" | $Xsed -e "s/^-Wc,//"`
- lastarg=
- save_ifs="$IFS"; IFS=','
- for arg in $args; do
- IFS="$save_ifs"
- # Double-quote args containing other shell metacharacters.
- # Many Bourne shells cannot handle close brackets correctly
- # in scan sets, so we specify it separately.
- case $arg in
- arg="\"$arg\""
- esac
- lastarg="$lastarg $arg"
- done
- IFS="$save_ifs"
- lastarg=`$echo "X$lastarg" | $Xsed -e "s/^ //"`
- # Add the arguments to base_compile.
- base_compile="$base_compile $lastarg"
- continue
- # Accept the current argument as the source file.
- # The previous "srcfile" becomes the current argument.
- lastarg="$srcfile"
- srcfile="$arg"
- esac # case $arg
- esac # case $arg_mode
- # Aesthetically quote the previous argument.
- lastarg=`$echo "X$lastarg" | $Xsed -e "$sed_quote_subst"`
- case $lastarg in
- lastarg="\"$lastarg\""
- esac
- done # for arg
- case $arg_mode in
- arg)
- $echo "$modename: you must specify an argument for -Xcompile"
- exit 1
- target)
- $echo "$modename: you must specify a target with \`-o'" 1>&2
- exit 1
- # Get the name of the library object.
- [ -z "$libobj" ] && libobj=`$echo "X$srcfile" | $Xsed -e 's%^.*/%%'`
- esac
- # Recognize several different file suffixes.
- # If the user specifies -o file.o, it is replaced with file.lo
- xform='[cCFSifmso]'
- case $libobj in
- *.ada) xform=ada ;;
- *.adb) xform=adb ;;
- *.ads) xform=ads ;;
- *.asm) xform=asm ;;
- *.c++) xform=c++ ;;
- *.cc) xform=cc ;;
- *.ii) xform=ii ;;
- *.class) xform=class ;;
- *.cpp) xform=cpp ;;
- *.cxx) xform=cxx ;;
- *.f90) xform=f90 ;;
- *.for) xform=for ;;
- *.java) xform=java ;;
- esac
- libobj=`$echo "X$libobj" | $Xsed -e "s/\.$xform$/.lo/"`
- case $libobj in
- *.lo) obj=`$echo "X$libobj" | $Xsed -e "$lo2o"` ;;
- $echo "$modename: cannot determine name of library object from \`$libobj'" 1>&2
- exit 1
- esac
- # Infer tagged configuration to use if any are available and
- # if one wasn't chosen via the "--tag" command line option.
- # Only attempt this if the compiler in the base compile
- # command doesn't match the default compiler.
- if test -n "$available_tags" && test -z "$tagname"; then
- case $base_compile in
- # Blanks in the command may have been stripped by the calling shell,
- # but not from the CC environment variable when configure was run.
- " $CC "* | "$CC "* | " `$echo $CC` "* | "`$echo $CC` "*) ;;
- # Blanks at the start of $base_compile will cause this to fail
- # if we don't check for them as well.
- for z in $available_tags; do
- if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $z$" < "$0" > /dev/null; then
- eval "`${SED} -n -e '/^# ### BEGIN LIBTOOL TAG CONFIG: '$z'$/,/^# ### END LIBTOOL TAG CONFIG: '$z'$/p' < $0`"
- case "$base_compile " in
- "$CC "* | " $CC "* | "`$echo $CC` "* | " `$echo $CC` "*)
- # The compiler in the base compile command matches
- # the one in the tagged configuration.
- # Assume this is the tagged configuration we want.
- tagname=$z
- break
- esac
- fi
- done
- # If $tagname still isn't set, then no tagged configuration
- # was found and let the user know that the "--tag" command
- # line option must be used.
- if test -z "$tagname"; then
- $echo "$modename: unable to infer tagged configuration"
- $echo "$modename: specify a tag with \`--tag'" 1>&2
- exit 1
-# else
-# $echo "$modename: using $tagname tagged configuration"
- fi
- esac
- fi
- objname=`$echo "X$obj" | $Xsed -e 's%^.*/%%'`
- xdir=`$echo "X$obj" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$xdir" = "X$obj"; then
- xdir=
- else
- xdir=$xdir/
- fi
- lobj=${xdir}$objdir/$objname
- if test -z "$base_compile"; then
- $echo "$modename: you must specify a compilation command" 1>&2
- exit 1
- fi
- # Delete any leftover library objects.
- removelist="$obj $lobj $libobj ${libobj}T"
- else
- removelist="$lobj $libobj ${libobj}T"
- fi
- $run $rm $removelist
- trap "$run $rm $removelist; exit 1" 1 2 15
- # On Cygwin there's no "real" PIC flag so we must build both object types
- case $host_os in
- cygwin* | mingw* | pw32* | os2*)
- pic_mode=default
- esac
- if test "$pic_mode" = no && test "$deplibs_check_method" != pass_all; then
- # non-PIC code in shared libraries is not supported
- pic_mode=default
- fi
- # Calculate the filename of the output object if compiler does
- # not support -o with -c
- if test "$compiler_c_o" = no; then
- output_obj=`$echo "X$srcfile" | $Xsed -e 's%^.*/%%' -e 's%\.[^.]*$%%'`.${objext}
- lockfile="$output_obj.lock"
- removelist="$removelist $output_obj $lockfile"
- else
- output_obj=
- need_locks=no
- lockfile=
- fi
- # Lock this critical section if it is needed
- # We use this script file to make the link, it avoids creating a new file
- if test "$need_locks" = yes; then
- until $run ln "$0" "$lockfile" 2>/dev/null; do
- $show "Waiting for $lockfile to be removed"
- sleep 2
- done
- elif test "$need_locks" = warn; then
- if test -f "$lockfile"; then
- $echo "\
-*** ERROR, $lockfile exists and contains:
-`cat $lockfile 2>/dev/null`
-This indicates that another process is trying to use the same
-temporary object file, and libtool could not work around it because
-your compiler does not support \`-c' and \`-o' together. If you
-repeat this compilation, it may succeed, by chance, but you had better
-avoid parallel builds (make -j) in this platform, or get a better
-compiler."
- exit 1
- fi
- $echo $srcfile > "$lockfile"
- fi
- if test -n "$fix_srcfile_path"; then
- eval srcfile=\"$fix_srcfile_path\"
- fi
- $run $rm "$libobj" "${libobj}T"
- # Create a libtool object file (analogous to a ".la" file),
- # but don't create it if we're doing a dry run.
- test -z "$run" && cat > ${libobj}T <<EOF
-# $libobj - a libtool object file
-# Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP
-# Please DO NOT delete this file!
-# It is necessary for linking the library.
-# Name of the PIC object.
-EOF
- # Only build a PIC object if we are building libtool libraries.
- # Without this assignment, base_compile gets emptied.
- fbsd_hideous_sh_bug=$base_compile
- if test "$pic_mode" != no; then
- command="$base_compile $srcfile $pic_flag"
- else
- # Don't build PIC code
- command="$base_compile $srcfile"
- fi
- if test ! -d "${xdir}$objdir"; then
- $show "$mkdir ${xdir}$objdir"
- $run $mkdir ${xdir}$objdir
- status=$?
- if test "$status" -ne 0 && test ! -d "${xdir}$objdir"; then
- exit $status
- fi
- fi
- if test -z "$output_obj"; then
- # Place PIC objects in $objdir
- command="$command -o $lobj"
- fi
- $run $rm "$lobj" "$output_obj"
- $show "$command"
- if $run eval "$command"; then :
- else
- test -n "$output_obj" && $run $rm $removelist
- exit 1
- fi
- if test "$need_locks" = warn &&
- test "X`cat $lockfile 2>/dev/null`" != "X$srcfile"; then
- $echo "\
-*** ERROR, $lockfile contains:
-but it should contain:
-$srcfile
-compiler."
- exit 1
- fi
- # Just move the object if needed, then go on to compile the next one
- if test -n "$output_obj" && test "X$output_obj" != "X$lobj"; then
- $show "$mv $output_obj $lobj"
- if $run $mv $output_obj $lobj; then :
- else
- error=$?
- exit $error
- fi
- fi
- # Append the name of the PIC object to the libtool object file.
- test -z "$run" && cat >> ${libobj}T <<EOF
-pic_object='$objdir/$objname'
-EOF
- # Allow error messages only from the first compilation.
- suppress_output=' >/dev/null 2>&1'
- else
- # No PIC object so indicate it doesn't exist in the libtool
- # object file.
-pic_object=none
-EOF
- fi
- # Only build a position-dependent object if we build old libraries.
- if test "$pic_mode" != yes; then
- else
- fi
- if test "$compiler_c_o" = yes; then
- command="$command -o $obj"
- fi
- # Suppress compiler output if we already did a PIC compilation.
- command="$command$suppress_output"
- $run $rm "$obj" "$output_obj"
- $show "$command"
- else
- exit 1
- fi
- $echo "\
-$srcfile
-compiler."
- exit 1
- fi
- if test -n "$output_obj" && test "X$output_obj" != "X$obj"; then
- $show "$mv $output_obj $obj"
- if $run $mv $output_obj $obj; then :
- else
- error=$?
- exit $error
- fi
- fi
- # Append the name of the non-PIC object the libtool object file.
- # Only append if the libtool object file exists.
-# Name of the non-PIC object.
-non_pic_object='$objname'
-EOF
- else
-non_pic_object=none
-EOF
- fi
- $run $mv "${libobj}T" "${libobj}"
- # Unlock the critical section if it was locked
- if test "$need_locks" != no; then
- $run $rm "$lockfile"
- fi
- exit 0
- # libtool link mode
- link | relink)
- modename="$modename: link"
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2*)
- # It is impossible to link a dll without this setting, and
- # we shouldn't force the makefile maintainer to figure out
- # which system we are compiling for in order to pass an extra
- # flag for every libtool invocation.
- # allow_undefined=no
- # FIXME: Unfortunately, there are problems with the above when trying
- # to make a dll which has undefined symbols, in which case not
- # even a static library is built. For now, we need to specify
- # -no-undefined on the libtool link line when we can be certain
- # that all symbols are satisfied, otherwise we get a static library.
- allow_undefined=yes
- esac
- libtool_args="$nonopt"
- base_compile="$nonopt"
- compile_command="$nonopt"
- finalize_command="$nonopt"
- compile_rpath=
- finalize_rpath=
- compile_shlibpath=
- finalize_shlibpath=
- convenience=
- old_convenience=
- deplibs=
- old_deplibs=
- add_flags=
- compiler_flags=
- linker_flags=
- dllsearchpath=
- lib_search_path=`pwd`
- inst_prefix_dir=
- avoid_version=no
- dlfiles=
- dlprefiles=
- dlself=no
- export_dynamic=no
- export_symbols=
- export_symbols_regex=
- generated=
- libobjs=
- ltlibs=
- module=no
- no_install=no
- objs=
- non_pic_objects=
- prefer_static_libs=no
- preload=no
- prev=
- prevarg=
- release=
- rpath=
- xrpath=
- perm_rpath=
- temp_rpath=
- thread_safe=no
- vinfo=
- vinfo_number=no
- # We need to know -static, to get the right output filenames.
- for arg
- do
- case $arg in
- -all-static | -static)
- if test "X$arg" = "X-all-static"; then
- if test "$build_libtool_libs" = yes && test -z "$link_static_flag"; then
- $echo "$modename: warning: complete static linking is impossible in this configuration" 1>&2
- fi
- if test -n "$link_static_flag"; then
- dlopen_self=$dlopen_self_static
- fi
- else
- if test -z "$pic_flag" && test -n "$link_static_flag"; then
- fi
- fi
- build_libtool_libs=no
- prefer_static_libs=yes
- break
- esac
- done
- # See if our shared archives depend on static archives.
- test -n "$old_archive_from_new_cmds" && build_old_libs=yes
- # Go through the arguments, transforming them on the way.
- while test "$#" -gt 0; do
- arg="$1"
- base_compile="$base_compile $arg"
- shift
- case $arg in
- qarg=\"`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`\" ### testsuite: skip nested quoting test
- *) qarg=$arg ;;
- esac
- libtool_args="$libtool_args $qarg"
- case $prev in
- output)
- compile_command="$compile_command @OUTPUT@"
- finalize_command="$finalize_command @OUTPUT@"
- esac
- case $prev in
- dlfiles|dlprefiles)
- if test "$preload" = no; then
- # Add the symbol object into the linking commands.
- compile_command="$compile_command @SYMFILE@"
- finalize_command="$finalize_command @SYMFILE@"
- preload=yes
- fi
- case $arg in
- *.la | *.lo) ;; # We handle these cases below.
- force)
- if test "$dlself" = no; then
- dlself=needless
- export_dynamic=yes
- fi
- prev=
- continue
- self)
- if test "$prev" = dlprefiles; then
- dlself=yes
- elif test "$prev" = dlfiles && test "$dlopen_self" != yes; then
- dlself=yes
- else
- dlself=needless
- fi
- prev=
- continue
- if test "$prev" = dlfiles; then
- dlfiles="$dlfiles $arg"
- else
- dlprefiles="$dlprefiles $arg"
- fi
- prev=
- continue
- esac
- expsyms)
- export_symbols="$arg"
- if test ! -f "$arg"; then
- $echo "$modename: symbol file \`$arg' does not exist"
- exit 1
- fi
- prev=
- continue
- expsyms_regex)
- export_symbols_regex="$arg"
- prev=
- continue
- inst_prefix)
- inst_prefix_dir="$arg"
- prev=
- continue
- release)
- release="-$arg"
- prev=
- continue
- objectlist)
- if test -f "$arg"; then
- save_arg=$arg
- moreargs=
- for fil in `cat $save_arg`
- do
-# moreargs="$moreargs $fil"
- arg=$fil
- # A libtool-controlled object.
- # Check to see that this really is a libtool object.
- if (${SED} -e '2q' $arg | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
- pic_object=
- non_pic_object=
- # Read the .lo file
- # If there is no directory component, then add one.
- case $arg in
- */* | *\\*) . $arg ;;
- *) . ./$arg ;;
- esac
- if test -z "$pic_object" || \
- test -z "$non_pic_object" ||
- test "$pic_object" = none && \
- test "$non_pic_object" = none; then
- $echo "$modename: cannot find name of object for \`$arg'" 1>&2
- exit 1
- fi
- # Extract subdirectory from the argument.
- xdir=`$echo "X$arg" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$xdir" = "X$arg"; then
- xdir=
- else
- xdir="$xdir/"
- fi
- if test "$pic_object" != none; then
- # Prepend the subdirectory the object is found in.
- pic_object="$xdir$pic_object"
- if test "$build_libtool_libs" = yes && test "$dlopen_support" = yes; then
- dlfiles="$dlfiles $pic_object"
- prev=
- continue
- else
- # If libtool objects are unsupported, then we need to preload.
- prev=dlprefiles
- fi
- fi
- # CHECK ME: I think I busted this. -Ossama
- # Preload the old-style object.
- dlprefiles="$dlprefiles $pic_object"
- prev=
- fi
- # A PIC object.
- libobjs="$libobjs $pic_object"
- arg="$pic_object"
- fi
- # Non-PIC object.
- if test "$non_pic_object" != none; then
- non_pic_object="$xdir$non_pic_object"
- # A standard non-PIC object
- non_pic_objects="$non_pic_objects $non_pic_object"
- if test -z "$pic_object" || test "$pic_object" = none ; then
- arg="$non_pic_object"
- fi
- fi
- else
- # Only an error if not doing a dry-run.
- if test -z "$run"; then
- $echo "$modename: \`$arg' is not a valid libtool object" 1>&2
- exit 1
- else
- # Dry-run case.
- xdir=
- else
- xdir="$xdir/"
- fi
- pic_object=`$echo "X${xdir}${objdir}/${arg}" | $Xsed -e "$lo2o"`
- non_pic_object=`$echo "X${xdir}${arg}" | $Xsed -e "$lo2o"`
- fi
- fi
- done
- else
- $echo "$modename: link input file \`$save_arg' does not exist"
- exit 1
- fi
- arg=$save_arg
- prev=
- continue
- rpath | xrpath)
- # We need an absolute path.
- case $arg in
- [\\/]* | [A-Za-z]:[\\/]*) ;;
- $echo "$modename: only absolute run-paths are allowed" 1>&2
- exit 1
- esac
- if test "$prev" = rpath; then
- case "$rpath " in
- *" $arg "*) ;;
- *) rpath="$rpath $arg" ;;
- esac
- else
- case "$xrpath " in
- *" $arg "*) ;;
- *) xrpath="$xrpath $arg" ;;
- esac
- fi
- prev=
- continue
- xcompiler)
- compiler_flags="$compiler_flags $qarg"
- prev=
- compile_command="$compile_command $qarg"
- finalize_command="$finalize_command $qarg"
- continue
- xlinker)
- linker_flags="$linker_flags $qarg"
- compiler_flags="$compiler_flags $wl$qarg"
- prev=
- compile_command="$compile_command $wl$qarg"
- finalize_command="$finalize_command $wl$qarg"
- continue
- xcclinker)
- prev=
- continue
- eval "$prev=\"\$arg\""
- prev=
- continue
- esac
- fi # test -n "$prev"
- prevarg="$arg"
- case $arg in
- -all-static)
- compile_command="$compile_command $link_static_flag"
- finalize_command="$finalize_command $link_static_flag"
- fi
- continue
- -allow-undefined)
- # FIXME: remove this flag sometime in the future.
- $echo "$modename: \`-allow-undefined' is deprecated because it is the default" 1>&2
- continue
- -avoid-version)
- avoid_version=yes
- continue
- -dlopen)
- prev=dlfiles
- continue
- -dlpreopen)
- prev=dlprefiles
- continue
- -export-dynamic)
- continue
- -export-symbols | -export-symbols-regex)
- if test -n "$export_symbols" || test -n "$export_symbols_regex"; then
- $echo "$modename: more than one -exported-symbols argument is not allowed"
- exit 1
- fi
- if test "X$arg" = "X-export-symbols"; then
- prev=expsyms
- else
- prev=expsyms_regex
- fi
- continue
- -inst-prefix-dir)
- prev=inst_prefix
- continue
- # The native IRIX linker understands -LANG:*, -LIST:* and -LNO:*
- # so, if we see these flags be careful not to treat them like -L
- -L[A-Z][A-Z]*:*)
- case $with_gcc/$host in
- no/*-*-irix* | /*-*-irix*)
- compile_command="$compile_command $arg"
- finalize_command="$finalize_command $arg"
- esac
- continue
- -L*)
- dir=`$echo "X$arg" | $Xsed -e 's/^-L//'`
- case $dir in
- absdir=`cd "$dir" && pwd`
- if test -z "$absdir"; then
- $echo "$modename: cannot determine absolute directory name of \`$dir'" 1>&2
- exit 1
- fi
- dir="$absdir"
- esac
- case "$deplibs " in
- *" -L$dir "*) ;;
- deplibs="$deplibs -L$dir"
- lib_search_path="$lib_search_path $dir"
- esac
- case $host in
- case :$dllsearchpath: in
- *":$dir:"*) ;;
- *) dllsearchpath="$dllsearchpath:$dir";;
- esac
- esac
- continue
- -l*)
- if test "X$arg" = "X-lc" || test "X$arg" = "X-lm"; then
- case $host in
- *-*-cygwin* | *-*-pw32* | *-*-beos*)
- # These systems don't actually have a C or math library (as such)
- continue
- *-*-freebsd*-gnu*)
- # prevent being parsed by the freebsd regexp below
- *-*-mingw* | *-*-os2*)
- # These systems don't actually have a C library (as such)
- test "X$arg" = "X-lc" && continue
- *-*-openbsd* | *-*-freebsd*)
- # Do not include libc due to us having libc/libc_r.
- *-*-rhapsody* | *-*-darwin1.[012])
- # Rhapsody C and math libraries are in the System framework
- deplibs="$deplibs -framework System"
- continue
- esac
- elif test "X$arg" = "X-lc_r"; then
- case $host in
- *-*-openbsd*)
- # Do not include libc_r directly, use -pthread flag.
- continue
- esac
- fi
- deplibs="$deplibs $arg"
- continue
- -module)
- module=yes
- continue
- # gcc -m* arguments should be passed to the linker via $compiler_flags
- # in order to pass architecture information to the linker
- # (e.g. 32 vs 64-bit). This may also be accomplished via -Wl,-mfoo
- # but this is not reliable with gcc because gcc may use -mfoo to
- # select a different linker, different libraries, etc, while
- # -Wl,-mfoo simply passes -mfoo to the linker.
- -m*)
- # Unknown arguments in both finalize_command and compile_command need
- # to be aesthetically quoted because they are evaled later.
- arg=`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- arg="\"$arg\""
- esac
- if test "$with_gcc" = "yes" ; then
- compiler_flags="$compiler_flags $arg"
- fi
- continue
- -shrext)
- prev=shrext
- continue
- -no-fast-install)
- fast_install=no
- continue
- -no-install)
- case $host in
- # The PATH hackery in wrapper scripts is required on Windows
- # in order for the loader to find any dlls it needs.
- $echo "$modename: warning: \`-no-install' is ignored for $host" 1>&2
- $echo "$modename: warning: assuming \`-no-fast-install' instead" 1>&2
- fast_install=no
- *) no_install=yes ;;
- esac
- continue
- -no-undefined)
- allow_undefined=no
- continue
- -objectlist)
- prev=objectlist
- continue
- -o) prev=output ;;
- -release)
- prev=release
- continue
- -rpath)
- prev=rpath
- continue
- -R)
- prev=xrpath
- continue
- -R*)
- dir=`$echo "X$arg" | $Xsed -e 's/^-R//'`
- case $dir in
- exit 1
- esac
- *" $dir "*) ;;
- *) xrpath="$xrpath $dir" ;;
- esac
- continue
- -static)
- # The effects of -static are defined in a previous loop.
- # We used to do the same as -all-static on platforms that
- # didn't have a PIC flag, but the assumption that the effects
- # would be equivalent was wrong. It would break on at least
- # Digital Unix and AIX.
- continue
- -thread-safe)
- thread_safe=yes
- continue
- -version-info)
- prev=vinfo
- continue
- -version-number)
- prev=vinfo
- vinfo_number=yes
- continue
- -Wc,*)
- args=`$echo "X$arg" | $Xsed -e "$sed_quote_subst" -e 's/^-Wc,//'`
- arg=
- for flag in $args; do
- IFS="$save_ifs"
- case $flag in
- flag="\"$flag\""
- esac
- arg="$arg $wl$flag"
- compiler_flags="$compiler_flags $flag"
- done
- IFS="$save_ifs"
- arg=`$echo "X$arg" | $Xsed -e "s/^ //"`
- -Wl,*)
- args=`$echo "X$arg" | $Xsed -e "$sed_quote_subst" -e 's/^-Wl,//'`
- arg=
- IFS="$save_ifs"
- case $flag in
- flag="\"$flag\""
- esac
- compiler_flags="$compiler_flags $wl$flag"
- linker_flags="$linker_flags $flag"
- done
- IFS="$save_ifs"
- -Xcompiler)
- prev=xcompiler
- continue
- -Xlinker)
- prev=xlinker
- continue
- -XCClinker)
- prev=xcclinker
- continue
- # Some other compiler flag.
- case $arg in
- arg="\"$arg\""
- esac
- add_flags="$add_flags $arg"
- *.$objext)
- # A standard object.
- objs="$objs $arg"
- *.lo)
- pic_object=
- non_pic_object=
- case $arg in
- *) . ./$arg ;;
- esac
- exit 1
- fi
- xdir=
- else
- xdir="$xdir/"
- fi
- prev=
- continue
- else
- prev=dlprefiles
- fi
- fi
- prev=
- fi
- # A PIC object.
- arg="$pic_object"
- fi
- # Non-PIC object.
- fi
- fi
- else
- exit 1
- else
- # Dry-run case.
- xdir=
- else
- xdir="$xdir/"
- fi
- fi
- fi
- *.$libext)
- # An archive.
- old_deplibs="$old_deplibs $arg"
- continue
- *.la)
- # A libtool-controlled library.
- # This library was specified with -dlopen.
- prev=
- elif test "$prev" = dlprefiles; then
- # The library was specified with -dlpreopen.
- prev=
- else
- fi
- continue
- # Some other compiler argument.
- case $arg in
- arg="\"$arg\""
- esac
- esac # arg
- # Now actually substitute the argument into the commands.
- if test -n "$arg"; then
- fi
- done # argument parsing loop
- $echo "$modename: the \`$prevarg' option requires an argument" 1>&2
- exit 1
- fi
- # Only attempt this if the compiler in the base link
- "$CC "* | " $CC "* | "`$echo $CC` "* | " `$echo $CC` "*) ;;
- # The compiler in $compile_command matches
- tagname=$z
- break
- esac
- fi
- done
- exit 1
-# else
- fi
- esac
- fi
- if test "$export_dynamic" = yes && test -n "$export_dynamic_flag_spec"; then
- eval arg=\"$export_dynamic_flag_spec\"
- fi
- oldlibs=
- # calculate the name of the file, without its directory
- outputname=`$echo "X$output" | $Xsed -e 's%^.*/%%'`
- libobjs_save="$libobjs"
- if test -n "$shlibpath_var"; then
- # get the directories listed in $shlibpath_var
- eval shlib_search_path=\`\$echo \"X\${$shlibpath_var}\" \| \$Xsed -e \'s/:/ /g\'\`
- else
- shlib_search_path=
- fi
- eval sys_lib_search_path=\"$sys_lib_search_path_spec\"
- eval sys_lib_dlsearch_path=\"$sys_lib_dlsearch_path_spec\"
- output_objdir=`$echo "X$output" | $Xsed -e 's%/[^/]*$%%'`
- if test "X$output_objdir" = "X$output"; then
- output_objdir="$objdir"
- else
- output_objdir="$output_objdir/$objdir"
- fi
- # Create the object directory.
- if test ! -d "$output_objdir"; then
- $show "$mkdir $output_objdir"
- $run $mkdir $output_objdir
- status=$?
- if test "$status" -ne 0 && test ! -d "$output_objdir"; then
- exit $status
- fi
- fi
- # Determine the type of output
- case $output in
- $echo "$modename: you must specify an output file" 1>&2
- exit 1
- *.$libext) linkmode=oldlib ;;
- *.lo | *.$objext) linkmode=obj ;;
- *.la) linkmode=lib ;;
- *) linkmode=prog ;; # Anything else should be a program.
- esac
- case $host in
- *cygwin* | *mingw* | *pw32*)
- # don't eliminate duplcations in $postdeps and $predeps
- duplicate_compiler_generated_deps=yes
- duplicate_compiler_generated_deps=$duplicate_deps
- esac
- specialdeplibs=
- libs=
- # Find all interdependent deplibs by searching for libraries
- # that are linked more than once (e.g. -la -lb -la)
- for deplib in $deplibs; do
- if test "X$duplicate_deps" = "Xyes" ; then
- case "$libs " in
- *" $deplib "*) specialdeplibs="$specialdeplibs $deplib" ;;
- esac
- fi
- libs="$libs $deplib"
- done
- if test "$linkmode" = lib; then
- libs="$predeps $libs $compiler_lib_search_path $postdeps"
- # Compute libraries that are listed more than once in $predeps
- # $postdeps and mark them as special (i.e., whose duplicates are
- # not to be eliminated).
- pre_post_deps=
- if test "X$duplicate_compiler_generated_deps" = "Xyes" ; then
- for pre_post_dep in $predeps $postdeps; do
- case "$pre_post_deps " in
- *" $pre_post_dep "*) specialdeplibs="$specialdeplibs $pre_post_deps" ;;
- esac
- pre_post_deps="$pre_post_deps $pre_post_dep"
- done
- fi
- pre_post_deps=
- fi
- deplibs=
- newdependency_libs=
- newlib_search_path=
- need_relink=no # whether we're linking any uninstalled libtool libraries
- notinst_deplibs= # not-installed libtool libraries
- notinst_path= # paths that contain not-installed libtool libraries
- case $linkmode in
- lib)
- passes="conv link"
- for file in $dlfiles $dlprefiles; do
- case $file in
- *.la) ;;
- $echo "$modename: libraries can \`-dlopen' only libtool libraries: $file" 1>&2
- exit 1
- esac
- done
- prog)
- compile_deplibs=
- finalize_deplibs=
- alldeplibs=no
- newdlfiles=
- newdlprefiles=
- passes="conv scan dlopen dlpreopen link"
- *) passes="conv"
- esac
- for pass in $passes; do
- if test "$linkmode,$pass" = "lib,link" ||
- test "$linkmode,$pass" = "prog,scan"; then
- libs="$deplibs"
- deplibs=
- fi
- if test "$linkmode" = prog; then
- case $pass in
- dlopen) libs="$dlfiles" ;;
- dlpreopen) libs="$dlprefiles" ;;
- link) libs="$deplibs %DEPLIBS% $dependency_libs" ;;
- esac
- fi
- if test "$pass" = dlopen; then
- # Collect dlpreopened libraries
- save_deplibs="$deplibs"
- deplibs=
- fi
- for deplib in $libs; do
- lib=
- found=no
- case $deplib in
- -l*)
- if test "$linkmode" != lib && test "$linkmode" != prog; then
- $echo "$modename: warning: \`-l' is ignored for archives/objects" 1>&2
- continue
- fi
- if test "$pass" = conv && test "$allow_undefined" = yes; then
- deplibs="$deplib $deplibs"
- continue
- fi
- name=`$echo "X$deplib" | $Xsed -e 's/^-l//'`
- for searchdir in $newlib_search_path $lib_search_path $sys_lib_search_path $shlib_search_path; do
- for search_ext in .la $shrext .so .a; do
- # Search the libtool library
- lib="$searchdir/lib${name}${search_ext}"
- if test -f "$lib"; then
- if test "$search_ext" = ".la"; then
- found=yes
- else
- found=no
- fi
- break 2
- fi
- done
- done
- if test "$found" != yes; then
- # deplib doesn't seem to be a libtool library
- if test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$deplib $compile_deplibs"
- finalize_deplibs="$deplib $finalize_deplibs"
- else
- test "$linkmode" = lib && newdependency_libs="$deplib $newdependency_libs"
- fi
- continue
- else # deplib is a libtool library
- # If $allow_libtool_libs_with_static_runtimes && $deplib is a stdlib,
- # We need to do some special things here, and not later.
- if test "X$allow_libtool_libs_with_static_runtimes" = "Xyes" ; then
- case " $predeps $postdeps " in
- *" $deplib "*)
- if (${SED} -e '2q' $lib |
- grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
- library_names=
- old_library=
- case $lib in
- */* | *\\*) . $lib ;;
- *) . ./$lib ;;
- esac
- for l in $old_library $library_names; do
- ll="$l"
- done
- if test "X$ll" = "X$old_library" ; then # only static version available
- found=no
- ladir=`$echo "X$lib" | $Xsed -e 's%/[^/]*$%%'`
- test "X$ladir" = "X$lib" && ladir="."
- lib=$ladir/$old_library
- else
- fi
- continue
- fi
- fi
- esac
- fi
- fi
- ;; # -l
- -L*)
- case $linkmode in
- lib)
- test "$pass" = conv && continue
- newdependency_libs="$deplib $newdependency_libs"
- newlib_search_path="$newlib_search_path "`$echo "X$deplib" | $Xsed -e 's/^-L//'`
- prog)
- if test "$pass" = conv; then
- continue
- fi
- if test "$pass" = scan; then
- else
- fi
- $echo "$modename: warning: \`-L' is ignored for archives/objects" 1>&2
- esac # linkmode
- continue
- ;; # -L
- -R*)
- if test "$pass" = link; then
- dir=`$echo "X$deplib" | $Xsed -e 's/^-R//'`
- # Make sure the xrpath contains only unique directories.
- *" $dir "*) ;;
- esac
- fi
- continue
- *.la) lib="$deplib" ;;
- *.$libext)
- continue
- fi
- case $linkmode in
- lib)
- if test "$deplibs_check_method" != pass_all; then
- $echo
- $echo "*** Warning: Trying to link with static lib archive $deplib."
- $echo "*** I have the capability to make that library automatically link in when"
- $echo "*** you link to this library. But I can only do this if you have a"
- $echo "*** shared version of the library, which you do not appear to have"
- $echo "*** because the file extensions .$libext of this argument makes me believe"
- $echo "*** that it is just a static archive that I should not used here."
- else
- $echo
- $echo "*** Warning: Linking the shared library $output against the"
- $echo "*** static library $deplib is not portable!"
- fi
- continue
- prog)
- if test "$pass" != link; then
- else
- fi
- continue
- esac # linkmode
- ;; # *.$libext
- *.lo | *.$objext)
- elif test "$linkmode" = prog; then
- if test "$pass" = dlpreopen || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
- # If there is no dlopen support or we're linking statically,
- # we need to preload.
- newdlprefiles="$newdlprefiles $deplib"
- else
- newdlfiles="$newdlfiles $deplib"
- fi
- fi
- continue
- %DEPLIBS%)
- alldeplibs=yes
- continue
- esac # case $deplib
- if test "$found" = yes || test -f "$lib"; then :
- else
- $echo "$modename: cannot find the library \`$lib'" 1>&2
- exit 1
- fi
- # Check to see that this really is a libtool archive.
- if (${SED} -e '2q' $lib | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then :
- else
- $echo "$modename: \`$lib' is not a valid libtool archive" 1>&2
- exit 1
- fi
- dlname=
- dlopen=
- dlpreopen=
- libdir=
- library_names=
- old_library=
- # If the library was installed with an old release of libtool,
- # it will not redefine variables installed, or shouldnotlink
- installed=yes
- shouldnotlink=no
- # Read the .la file
- case $lib in
- *) . ./$lib ;;
- esac
- test "$linkmode,$pass" = "prog,scan" ||
- { test "$linkmode" != prog && test "$linkmode" != lib; }; then
- test -n "$dlopen" && dlfiles="$dlfiles $dlopen"
- test -n "$dlpreopen" && dlprefiles="$dlprefiles $dlpreopen"
- fi
- # Only check for convenience libraries
- deplibs="$lib $deplibs"
- tmp_libs=
- for deplib in $dependency_libs; do
- #echo "Adding $deplib to \$deplibs"
- case "$tmp_libs " in
- esac
- fi
- tmp_libs="$tmp_libs $deplib"
- done
- if test -z "$libdir"; then
- if test -z "$old_library"; then
- $echo "$modename: cannot find name of link library for \`$lib'" 1>&2
- exit 1
- fi
- # It is a libtool convenience library, so add in its objects.
- convenience="$convenience $ladir/$objdir/$old_library"
- old_convenience="$old_convenience $ladir/$objdir/$old_library"
- elif test "$linkmode" != prog && test "$linkmode" != lib; then
- $echo "$modename: \`$lib' is not a convenience library" 1>&2
- exit 1
- fi
- continue
- fi # $pass = conv
- # Get the name of the library we link against.
- linklib=
- linklib="$l"
- done
- if test -z "$linklib"; then
- exit 1
- fi
- $echo "$modename: cannot -dlopen a convenience library: \`$lib'" 1>&2
- exit 1
- fi
- if test -z "$dlname" || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
- # If there is no dlname, no dlopen support or we're linking
- # statically, we need to preload. We also need to preload any
- # dependent libraries so libltdl's deplib preloader doesn't
- # bomb out in the load deplibs phase.
- dlprefiles="$dlprefiles $lib $dependency_libs"
- else
- newdlfiles="$newdlfiles $lib"
- fi
- continue
- fi # $pass = dlopen
- case $ladir in
- [\\/]* | [A-Za-z]:[\\/]*) abs_ladir="$ladir" ;;
- abs_ladir=`cd "$ladir" && pwd`
- if test -z "$abs_ladir"; then
- $echo "$modename: warning: cannot determine absolute directory name of \`$ladir'" 1>&2
- $echo "$modename: passing it literally to the linker, although it might fail" 1>&2
- abs_ladir="$ladir"
- fi
- esac
- laname=`$echo "X$lib" | $Xsed -e 's%^.*/%%'`
- # Find the relevant object directory and library name.
- if test "X$installed" = Xyes; then
- if test ! -f "$libdir/$linklib" && test -f "$abs_ladir/$linklib"; then
- $echo "$modename: warning: library \`$lib' was moved." 1>&2
- dir="$ladir"
- absdir="$abs_ladir"
- libdir="$abs_ladir"
- else
- dir="$libdir"
- absdir="$libdir"
- fi
- else
- dir="$ladir/$objdir"
- absdir="$abs_ladir/$objdir"
- # Remove this search path later
- notinst_path="$notinst_path $abs_ladir"
- fi # $installed = yes
- name=`$echo "X$laname" | $Xsed -e 's/\.la$//' -e 's/^lib//'`
- # This library was specified with -dlpreopen.
- if test "$pass" = dlpreopen; then
- $echo "$modename: cannot -dlpreopen a convenience library: \`$lib'" 1>&2
- exit 1
- fi
- # Prefer using a static library (so that no silly _DYNAMIC symbols
- # are required to link).
- if test -n "$old_library"; then
- newdlprefiles="$newdlprefiles $dir/$old_library"
- # Otherwise, use the dlname, so that lt_dlopen finds it.
- elif test -n "$dlname"; then
- newdlprefiles="$newdlprefiles $dir/$dlname"
- else
- newdlprefiles="$newdlprefiles $dir/$linklib"
- fi
- fi # $pass = dlpreopen
- # Link the convenience library
- deplibs="$dir/$old_library $deplibs"
- elif test "$linkmode,$pass" = "prog,link"; then
- compile_deplibs="$dir/$old_library $compile_deplibs"
- finalize_deplibs="$dir/$old_library $finalize_deplibs"
- else
- deplibs="$lib $deplibs" # used for prog,scan pass
- fi
- continue
- fi
- if test "$linkmode" = prog && test "$pass" != link; then
- newlib_search_path="$newlib_search_path $ladir"
- linkalldeplibs=no
- if test "$link_all_deplibs" != no || test -z "$library_names" ||
- test "$build_libtool_libs" = no; then
- linkalldeplibs=yes
- fi
- tmp_libs=
- case $deplib in
- -L*) newlib_search_path="$newlib_search_path "`$echo "X$deplib" | $Xsed -e 's/^-L//'`;; ### testsuite: skip nested quoting test
- esac
- # Need to link against all dependency_libs?
- if test "$linkalldeplibs" = yes; then
- else
- # Need to hardcode shared library paths
- # or/and link against static libraries
- fi
- esac
- fi
- done # for deplib
- continue
- fi # $linkmode = prog...
- if test -n "$library_names" &&
- { test "$prefer_static_libs" = no || test -z "$old_library"; }; then
- # We need to hardcode the library path
- # Make sure the rpath contains only unique directories.
- case "$temp_rpath " in
- *" $dir "*) ;;
- *" $absdir "*) ;;
- *) temp_rpath="$temp_rpath $dir" ;;
- esac
- fi
- # Hardcode the library path.
- # Skip directories that are in the system default run-time
- # search path.
- case " $sys_lib_dlsearch_path " in
- *" $absdir "*) ;;
- case "$compile_rpath " in
- *" $absdir "*) ;;
- *) compile_rpath="$compile_rpath $absdir"
- esac
- esac
- *" $libdir "*) ;;
- case "$finalize_rpath " in
- *" $libdir "*) ;;
- *) finalize_rpath="$finalize_rpath $libdir"
- esac
- esac
- fi # $linkmode,$pass = prog,link...
- if test "$alldeplibs" = yes &&
- { test "$deplibs_check_method" = pass_all ||
- { test "$build_libtool_libs" = yes &&
- test -n "$library_names"; }; }; then
- # We only need to search for static libraries
- continue
- fi
- fi
- link_static=no # Whether the deplib will be linked statically
- if test "$installed" = no; then
- notinst_deplibs="$notinst_deplibs $lib"
- need_relink=yes
- fi
- # This is a shared library
- # Warn about portability, can't link against -module's on some systems (darwin)
- if test "$shouldnotlink" = yes && test "$pass" = link ; then
- $echo
- $echo "*** Warning: Linking the executable $output against the loadable module"
- else
- $echo "*** Warning: Linking the shared library $output against the loadable module"
- fi
- $echo "*** $linklib is not portable!"
- fi
- if test "$linkmode" = lib &&
- test "$hardcode_into_libs" = yes; then
- # search path.
- *" $absdir "*) ;;
- *" $absdir "*) ;;
- esac
- esac
- *" $libdir "*) ;;
- *" $libdir "*) ;;
- esac
- esac
- fi
- if test -n "$old_archive_from_expsyms_cmds"; then
- # figure out the soname
- set dummy $library_names
- realname="$2"
- shift; shift
- libname=`eval \\$echo \"$libname_spec\"`
- # use dlname if we got it. it's perfectly good, no?
- if test -n "$dlname"; then
- soname="$dlname"
- elif test -n "$soname_spec"; then
- # bleh windows
- case $host in
- *cygwin* | mingw*)
- major=`expr $current - $age`
- versuffix="-$major"
- esac
- eval soname=\"$soname_spec\"
- else
- soname="$realname"
- fi
- # Make a new name for the extract_expsyms_cmds to use
- soroot="$soname"
- soname=`$echo $soroot | ${SED} -e 's/^.*\///'`
- newlib="libimp-`$echo $soname | ${SED} 's/^lib//;s/\.dll$//'`.a"
- # If the library has no export list, then create one now
- if test -f "$output_objdir/$soname-def"; then :
- else
- $show "extracting exported symbol list from \`$soname'"
- save_ifs="$IFS"; IFS='~'
- eval cmds=\"$extract_expsyms_cmds\"
- for cmd in $cmds; do
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd" || exit $?
- done
- IFS="$save_ifs"
- fi
- # Create $newlib
- if test -f "$output_objdir/$newlib"; then :; else
- $show "generating import library for \`$soname'"
- eval cmds=\"$old_archive_from_expsyms_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- fi
- # make sure the library variables are pointing to the new library
- dir=$output_objdir
- linklib=$newlib
- fi # test -n "$old_archive_from_expsyms_cmds"
- if test "$linkmode" = prog || test "$mode" != relink; then
- add_shlibpath=
- add_dir=
- add=
- lib_linked=yes
- case $hardcode_action in
- immediate | unsupported)
- if test "$hardcode_direct" = no; then
- add="$dir/$linklib"
- case $host in
- *-*-sco3.2v5* ) add_dir="-L$dir" ;;
- *-*-darwin* )
- # if the lib is a module then we can not link against it, someone
- # is ignoring the new warnings I added
- if /usr/bin/file -L $add 2> /dev/null | grep "bundle" >/dev/null ; then
- $echo "** Warning, lib $linklib is a module, not a shared library"
- if test -z "$old_library" ; then
- $echo
- $echo "** And there doesn't seem to be a static archive available"
- $echo "** The link will probably fail, sorry"
- else
- add="$dir/$old_library"
- fi
- fi
- esac
- elif test "$hardcode_minus_L" = no; then
- case $host in
- *-*-sunos*) add_shlibpath="$dir" ;;
- esac
- add_dir="-L$dir"
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = no; then
- add_shlibpath="$dir"
- add="-l$name"
- else
- lib_linked=no
- fi
- relink)
- if test "$hardcode_direct" = yes; then
- elif test "$hardcode_minus_L" = yes; then
- add_dir="-L$dir"
- # Try looking first in the location we're being installed to.
- if test -n "$inst_prefix_dir"; then
- case "$libdir" in
- add_dir="-L$inst_prefix_dir$libdir $add_dir"
- esac
- fi
- add="-l$name"
- elif test "$hardcode_shlibpath_var" = yes; then
- add="-l$name"
- else
- lib_linked=no
- fi
- *) lib_linked=no ;;
- esac
- if test "$lib_linked" != yes; then
- $echo "$modename: configuration error: unsupported hardcode properties"
- exit 1
- fi
- if test -n "$add_shlibpath"; then
- case :$compile_shlibpath: in
- *":$add_shlibpath:"*) ;;
- *) compile_shlibpath="$compile_shlibpath$add_shlibpath:" ;;
- esac
- fi
- test -n "$add_dir" && compile_deplibs="$add_dir $compile_deplibs"
- test -n "$add" && compile_deplibs="$add $compile_deplibs"
- else
- test -n "$add_dir" && deplibs="$add_dir $deplibs"
- test -n "$add" && deplibs="$add $deplibs"
- if test "$hardcode_direct" != yes && \
- test "$hardcode_minus_L" != yes && \
- test "$hardcode_shlibpath_var" = yes; then
- case :$finalize_shlibpath: in
- *":$libdir:"*) ;;
- *) finalize_shlibpath="$finalize_shlibpath$libdir:" ;;
- esac
- fi
- fi
- fi
- if test "$linkmode" = prog || test "$mode" = relink; then
- add_shlibpath=
- add_dir=
- add=
- # Finalize command for both is simple: just hardcode it.
- add="$libdir/$linklib"
- add_dir="-L$libdir"
- add="-l$name"
- *":$libdir:"*) ;;
- esac
- add="-l$name"
- elif test "$hardcode_automatic" = yes; then
- if test -n "$inst_prefix_dir" && test -f "$inst_prefix_dir$libdir/$linklib" ; then
- add="$inst_prefix_dir$libdir/$linklib"
- else
- fi
- else
- # We cannot seem to hardcode it, guess we'll fake it.
- case "$libdir" in
- esac
- fi
- add="-l$name"
- fi
- test -n "$add_dir" && finalize_deplibs="$add_dir $finalize_deplibs"
- test -n "$add" && finalize_deplibs="$add $finalize_deplibs"
- else
- fi
- fi
- # Here we assume that one of hardcode_direct or hardcode_minus_L
- # is not unsupported. This is valid on all known static and
- # shared platforms.
- if test "$hardcode_direct" != unsupported; then
- test -n "$old_library" && linklib="$old_library"
- compile_deplibs="$dir/$linklib $compile_deplibs"
- finalize_deplibs="$dir/$linklib $finalize_deplibs"
- else
- compile_deplibs="-l$name -L$dir $compile_deplibs"
- finalize_deplibs="-l$name -L$dir $finalize_deplibs"
- fi
- elif test "$build_libtool_libs" = yes; then
- # Not a shared library
- # We're trying link a shared library against a static one
- # but the system doesn't support it.
- # Just print a warning and add the library to dependency_libs so
- # that the program can be linked against the static library.
- $echo
- $echo "*** Warning: This system can not link to static lib archive $lib."
- $echo "*** shared version of the library, which you do not appear to have."
- if test "$module" = yes; then
- $echo "*** But as you try to build a module library, libtool will still create "
- $echo "*** a static module, that should work as long as the dlopening application"
- $echo "*** is linked with the -dlopen flag to resolve symbols at runtime."
- if test -z "$global_symbol_pipe"; then
- $echo
- $echo "*** However, this would only work if libtool was able to extract symbol"
- $echo "*** lists from a program, using \`nm' or equivalent, but libtool could"
- $echo "*** not find such a program. So, this module is probably useless."
- $echo "*** \`nm' from GNU binutils and a full rebuild may help."
- fi
- if test "$build_old_libs" = no; then
- build_libtool_libs=module
- else
- fi
- fi
- else
- convenience="$convenience $dir/$old_library"
- old_convenience="$old_convenience $dir/$old_library"
- link_static=yes
- fi
- fi # link shared/static library?
- #if test -n "$dependency_libs" &&
- # { test "$hardcode_into_libs" != yes || test "$build_old_libs" = yes ||
- # test "$link_static" = yes; }; then
- # Extract -R from dependency_libs
- temp_deplibs=
- for libdir in $dependency_libs; do
- case $libdir in
- -R*) temp_xrpath=`$echo "X$libdir" | $Xsed -e 's/^-R//'`
- case " $xrpath " in
- *" $temp_xrpath "*) ;;
- *) xrpath="$xrpath $temp_xrpath";;
- esac;;
- *) temp_deplibs="$temp_deplibs $libdir";;
- esac
- done
- dependency_libs="$temp_deplibs"
- #fi
- newlib_search_path="$newlib_search_path $absdir"
- # Link against this library
- test "$link_static" = no && newdependency_libs="$abs_ladir/$laname $newdependency_libs"
- # ... and its dependency_libs
- tmp_libs=
- esac
- fi
- done
- if test "$link_all_deplibs" != no; then
- # Add the search paths of all dependency libraries
- case $deplib in
- -L*) path="$deplib" ;;
- *.la)
- dir=`$echo "X$deplib" | $Xsed -e 's%/[^/]*$%%'`
- test "X$dir" = "X$deplib" && dir="."
- case $dir in
- [\\/]* | [A-Za-z]:[\\/]*) absdir="$dir" ;;
- $echo "$modename: warning: cannot determine absolute directory name of \`$dir'" 1>&2
- absdir="$dir"
- fi
- esac
- if grep "^installed=no" $deplib > /dev/null; then
- path="$absdir/$objdir"
- else
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $deplib`
- $echo "$modename: \`$deplib' is not a valid libtool archive" 1>&2
- exit 1
- fi
- if test "$absdir" != "$libdir"; then
- # Sure, some shells/systems don't implement the -ef.
- # Those will have to live with the warning.
- test "$absdir" -ef "$libdir" > /dev/null 2>&1 ||
- $echo "$modename: warning: \`$deplib' seems to be moved" 1>&2
- fi
- path="$absdir"
- fi
- depdepl=
- case $host in
- *-*-darwin*)
- # we do not want to link against static libs, but need to link against shared
- eval deplibrary_names=`${SED} -n -e 's/^library_names=\(.*\)$/\1/p' $deplib`
- if test -n "$deplibrary_names" ; then
- for tmp in $deplibrary_names ; do
- depdepl=$tmp
- done
- if test -f "$path/$depdepl" ; then
- depdepl="$path/$depdepl"
- fi
- # do not add paths which are already there
- case " $newlib_search_path " in
- *" $path "*) ;;
- *) newlib_search_path="$newlib_search_path $path";;
- esac
- path=""
- fi
- path="-L$path"
- esac
- -l*)
- case $host in
- *-*-darwin*)
- # Again, we only want to link against shared libraries
- eval tmp_libs=`$echo "X$deplib" | $Xsed -e "s,^\-l,,"`
- for tmp in $newlib_search_path ; do
- if test -f "$tmp/lib$tmp_libs.dylib" ; then
- eval depdepl="$tmp/lib$tmp_libs.dylib"
- break
- fi
- done
- path=""
- *) continue ;;
- esac
- *) continue ;;
- esac
- case " $deplibs " in
- *" $depdepl "*) ;;
- *) deplibs="$deplibs $depdepl" ;;
- esac
- *" $path "*) ;;
- *) deplibs="$deplibs $path" ;;
- esac
- done
- fi # link_all_deplibs != no
- fi # linkmode = lib
- done # for deplib in $libs
- dependency_libs="$newdependency_libs"
- # Link the dlpreopened libraries before other libraries
- for deplib in $save_deplibs; do
- done
- fi
- if test "$pass" != dlopen; then
- if test "$pass" != conv; then
- # Make sure lib_search_path contains only unique directories.
- lib_search_path=
- for dir in $newlib_search_path; do
- case "$lib_search_path " in
- *" $dir "*) ;;
- *) lib_search_path="$lib_search_path $dir" ;;
- esac
- done
- fi
- if test "$linkmode,$pass" != "prog,link"; then
- vars="deplibs"
- else
- vars="compile_deplibs finalize_deplibs"
- fi
- for var in $vars dependency_libs; do
- # Add libraries to $var in reverse order
- eval tmp_libs=\"\$$var\"
- new_libs=
- for deplib in $tmp_libs; do
- # FIXME: Pedantically, this is the right thing to do, so
- # that some nasty dependency loop isn't accidentally
- # broken:
- #new_libs="$deplib $new_libs"
- # Pragmatically, this seems to cause very few problems in
- # practice:
- case $deplib in
- -L*) new_libs="$deplib $new_libs" ;;
- -R*) ;;
- # And here is the reason: when a library appears more
- # than once as an explicit dependence of a library, or
- # is implicitly linked in more than once by the
- # compiler, it is considered special, and multiple
- # occurrences thereof are not removed. Compare this
- # with having the same library being listed as a
- # dependency of multiple other libraries: in this case,
- # we know (pedantically, we assume) the library does not
- # need to be listed more than once, so we keep only the
- # last copy. This is not always right, but it is rare
- # enough that we require users that really mean to play
- # such unportable linking tricks to link the library
- # using -Wl,-lname, so that libtool does not consider it
- # for duplicate removal.
- case " $specialdeplibs " in
- *" $deplib "*) new_libs="$deplib $new_libs" ;;
- case " $new_libs " in
- *" $deplib "*) ;;
- *) new_libs="$deplib $new_libs" ;;
- esac
- esac
- esac
- done
- tmp_libs=
- for deplib in $new_libs; do
- case $deplib in
- -L*)
- case " $tmp_libs " in
- *" $deplib "*) ;;
- *) tmp_libs="$tmp_libs $deplib" ;;
- esac
- esac
- done
- eval $var=\"$tmp_libs\"
- done # for var
- fi
- # Last step: remove runtime libs from dependency_libs (they stay in deplibs)
- tmp_libs=
- for i in $dependency_libs ; do
- case " $predeps $postdeps $compiler_lib_search_path " in
- *" $i "*)
- i=""
- esac
- if test -n "$i" ; then
- tmp_libs="$tmp_libs $i"
- fi
- done
- dependency_libs=$tmp_libs
- done # for pass
- dlfiles="$newdlfiles"
- dlprefiles="$newdlprefiles"
- fi
- case $linkmode in
- oldlib)
- if test -n "$deplibs"; then
- $echo "$modename: warning: \`-l' and \`-L' are ignored for archives" 1>&2
- fi
- if test -n "$dlfiles$dlprefiles" || test "$dlself" != no; then
- $echo "$modename: warning: \`-dlopen' is ignored for archives" 1>&2
- fi
- if test -n "$rpath"; then
- $echo "$modename: warning: \`-rpath' is ignored for archives" 1>&2
- fi
- if test -n "$xrpath"; then
- $echo "$modename: warning: \`-R' is ignored for archives" 1>&2
- fi
- if test -n "$vinfo"; then
- $echo "$modename: warning: \`-version-info/-version-number' is ignored for archives" 1>&2
- fi
- if test -n "$release"; then
- $echo "$modename: warning: \`-release' is ignored for archives" 1>&2
- fi
- $echo "$modename: warning: \`-export-symbols' is ignored for archives" 1>&2
- fi
- # Now set the variables for building old libraries.
- oldlibs="$output"
- objs="$objs$old_deplibs"
- lib)
- # Make sure we only generate libraries of the form `libNAME.la'.
- case $outputname in
- lib*)
- name=`$echo "X$outputname" | $Xsed -e 's/\.la$//' -e 's/^lib//'`
- eval shared_ext=\"$shrext\"
- eval libname=\"$libname_spec\"
- if test "$module" = no; then
- $echo "$modename: libtool library \`$output' must begin with \`lib'" 1>&2
- exit 1
- fi
- if test "$need_lib_prefix" != no; then
- # Add the "lib" prefix for modules if required
- name=`$echo "X$outputname" | $Xsed -e 's/\.la$//'`
- else
- libname=`$echo "X$outputname" | $Xsed -e 's/\.la$//'`
- fi
- esac
- if test -n "$objs"; then
- $echo "$modename: cannot build libtool library \`$output' from non-libtool objects on this host:$objs" 2>&1
- exit 1
- else
- $echo
- $echo "*** Warning: Linking the shared library $output against the non-libtool"
- $echo "*** objects $objs is not portable!"
- libobjs="$libobjs $objs"
- fi
- fi
- if test "$dlself" != no; then
- $echo "$modename: warning: \`-dlopen self' is ignored for libtool libraries" 1>&2
- fi
- set dummy $rpath
- if test "$#" -gt 2; then
- $echo "$modename: warning: ignoring multiple \`-rpath's for a libtool library" 1>&2
- fi
- install_libdir="$2"
- oldlibs=
- if test -z "$rpath"; then
- # Building a libtool convenience library.
- # Some compilers have problems with a `.al' extension so
- # convenience libraries should have the same extension an
- # archive normally would.
- oldlibs="$output_objdir/$libname.$libext $oldlibs"
- build_libtool_libs=convenience
- fi
- $echo "$modename: warning: \`-version-info/-version-number' is ignored for convenience libraries" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for convenience libraries" 1>&2
- fi
- else
- # Parse the version information argument.
- save_ifs="$IFS"; IFS=':'
- set dummy $vinfo 0 0 0
- IFS="$save_ifs"
- if test -n "$8"; then
- $echo "$modename: too many parameters to \`-version-info'" 1>&2
- exit 1
- fi
- # convert absolute version numbers to libtool ages
- # this retains compatibility with .la files and attempts
- # to make the code below a bit more comprehensible
- case $vinfo_number in
- yes)
- number_major="$2"
- number_minor="$3"
- number_revision="$4"
- # There are really only two kinds -- those that
- # use the current revision as the major version
- # and those that subtract age and use age as
- # a minor version. But, then there is irix
- # which has an extra 1 added just for fun
- case $version_type in
- darwin|linux|osf|windows)
- current=`expr $number_major + $number_minor`
- age="$number_minor"
- revision="$number_revision"
- freebsd-aout|freebsd-elf|sunos)
- current="$number_major"
- revision="$number_minor"
- age="0"
- irix|nonstopux)
- current=`expr $number_major + $number_minor - 1`
- esac
- no)
- current="$2"
- revision="$3"
- age="$4"
- esac
- # Check that each of the things are valid numbers.
- case $current in
- 0 | [1-9] | [1-9][0-9] | [1-9][0-9][0-9]) ;;
- $echo "$modename: CURRENT \`$current' is not a nonnegative integer" 1>&2
- $echo "$modename: \`$vinfo' is not valid version information" 1>&2
- exit 1
- esac
- case $revision in
- $echo "$modename: REVISION \`$revision' is not a nonnegative integer" 1>&2
- exit 1
- esac
- case $age in
- $echo "$modename: AGE \`$age' is not a nonnegative integer" 1>&2
- exit 1
- esac
- if test "$age" -gt "$current"; then
- $echo "$modename: AGE \`$age' is greater than the current interface number \`$current'" 1>&2
- exit 1
- fi
- # Calculate the version variables.
- major=
- versuffix=
- verstring=
- none) ;;
- darwin)
- # Like Linux, but with the current version available in
- # verstring for coding it into the library header
- major=.`expr $current - $age`
- versuffix="$major.$age.$revision"
- # Darwin ld doesn't like 0 for these options...
- minor_current=`expr $current + 1`
- verstring="-compatibility_version $minor_current -current_version $minor_current.$revision"
- freebsd-aout)
- major=".$current"
- versuffix=".$current.$revision";
- freebsd-elf)
- major=".$current"
- versuffix=".$current";
- irix | nonstopux)
- major=`expr $current - $age + 1`
- nonstopux) verstring_prefix=nonstopux ;;
- *) verstring_prefix=sgi ;;
- esac
- verstring="$verstring_prefix$major.$revision"
- # Add in all the interfaces that we are compatible with.
- loop=$revision
- while test "$loop" -ne 0; do
- iface=`expr $revision - $loop`
- loop=`expr $loop - 1`
- verstring="$verstring_prefix$major.$iface:$verstring"
- done
- # Before this point, $major must not contain `.'.
- major=.$major
- versuffix="$major.$revision"
- linux)
- osf)
- versuffix=".$current.$age.$revision"
- verstring="$current.$age.$revision"
- loop=$age
- iface=`expr $current - $loop`
- verstring="$verstring:${iface}.0"
- done
- # Make executables depend on our current version.
- verstring="$verstring:${current}.0"
- sunos)
- major=".$current"
- windows)
- # Use '-' rather than '.', since we only want one
- # extension on DOS 8.3 filesystems.
- $echo "$modename: unknown library version type \`$version_type'" 1>&2
- exit 1
- esac
- # Clear the version info if we defaulted, and they specified a release.
- if test -z "$vinfo" && test -n "$release"; then
- major=
- darwin)
- # we can't check for "0.0" in archive_cmds due to quoting
- # problems, so we reset it completely
- verstring=
- verstring="0.0"
- esac
- if test "$need_version" = no; then
- versuffix=
- else
- versuffix=".0.0"
- fi
- fi
- # Remove version info from name if versioning should be avoided
- if test "$avoid_version" = yes && test "$need_version" = no; then
- major=
- versuffix=
- verstring=""
- fi
- # Check to see if the archive will have undefined symbols.
- if test "$allow_undefined" = yes; then
- if test "$allow_undefined_flag" = unsupported; then
- $echo "$modename: warning: undefined symbols not allowed in $host shared libraries" 1>&2
- fi
- else
- # Don't allow undefined symbols.
- allow_undefined_flag="$no_undefined_flag"
- fi
- fi
- if test "$mode" != relink; then
- # Remove our outputs, but don't remove object files since they
- # may have been created when compiling PIC objects.
- removelist=
- tempremovelist=`$echo "$output_objdir/*"`
- for p in $tempremovelist; do
- case $p in
- *.$objext)
- $output_objdir/$outputname | $output_objdir/$libname.* | $output_objdir/${libname}${release}.*)
- removelist="$removelist $p"
- esac
- done
- if test -n "$removelist"; then
- $show "${rm}r $removelist"
- $run ${rm}r $removelist
- fi
- fi
- if test "$build_old_libs" = yes && test "$build_libtool_libs" != convenience ; then
- oldlibs="$oldlibs $output_objdir/$libname.$libext"
- # Transform .lo files to .o files.
- oldobjs="$objs "`$echo "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}'$/d' -e "$lo2o" | $NL2SP`
- fi
- # Eliminate all temporary directories.
- for path in $notinst_path; do
- lib_search_path=`$echo "$lib_search_path " | ${SED} -e 's% $path % %g'`
- deplibs=`$echo "$deplibs " | ${SED} -e 's% -L$path % %g'`
- dependency_libs=`$echo "$dependency_libs " | ${SED} -e 's% -L$path % %g'`
- done
- # If the user specified any rpath flags, then add them.
- temp_xrpath=
- for libdir in $xrpath; do
- temp_xrpath="$temp_xrpath -R$libdir"
- *" $libdir "*) ;;
- *) finalize_rpath="$finalize_rpath $libdir" ;;
- esac
- done
- if true || test "$hardcode_into_libs" != yes || test "$build_old_libs" = yes; then
- dependency_libs="$temp_xrpath $dependency_libs"
- fi
- fi
- # Make sure dlfiles contains only unique files that won't be dlpreopened
- old_dlfiles="$dlfiles"
- dlfiles=
- for lib in $old_dlfiles; do
- case " $dlprefiles $dlfiles " in
- *" $lib "*) ;;
- *) dlfiles="$dlfiles $lib" ;;
- esac
- done
- # Make sure dlprefiles contains only unique files
- old_dlprefiles="$dlprefiles"
- dlprefiles=
- for lib in $old_dlprefiles; do
- case "$dlprefiles " in
- *" $lib "*) ;;
- *) dlprefiles="$dlprefiles $lib" ;;
- esac
- done
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-*-beos*)
- # these systems don't actually have a c library (as such)!
- # Rhapsody C library is in the System framework
- *-*-netbsd*)
- # Don't link with libc until the a.out ld.so is fixed.
- # Prevent $arg from being parsed by the freebsd regexp below.
- if test "$build_libtool_need_lc" = "yes"; then
- deplibs="$deplibs -lc"
- fi
- # Add libc to deplibs on all other systems if necessary.
- fi
- esac
- fi
- # Transform deplibs into only deplibs that can be linked in shared.
- name_save=$name
- libname_save=$libname
- release_save=$release
- versuffix_save=$versuffix
- major_save=$major
- # I'm not sure if I'm treating the release correctly. I think
- # release should show up in the -l (ie -lgmp5) so we don't want to
- # add it in twice. Is that correct?
- release=""
- versuffix=""
- major=""
- newdeplibs=
- droppeddeps=no
- case $deplibs_check_method in
- pass_all)
- # Don't check for shared/static. Everything works.
- # This might be a little naive. We might want to check
- # whether the library exists or not. But this is on
- # osf3 & osf4 and I'm not really sure... Just
- # implementing what was already the behavior.
- newdeplibs=$deplibs
- test_compile)
- # This code stresses the "libraries are programs" paradigm to its
- # limits. Maybe even breaks it. We compile a program, linking it
- # against the deplibs as a proxy for the library. Then we can check
- # whether they linked in statically or dynamically with ldd.
- $rm conftest.c
- cat > conftest.c <<EOF
- int main() { return 0; }
-EOF
- $rm conftest
- $LTCC -o conftest conftest.c $deplibs
- if test "$?" -eq 0 ; then
- ldd_output=`ldd conftest`
- for i in $deplibs; do
- name="`expr $i : '-l\(.*\)'`"
- # If $name is empty we are operating on a -L argument.
- if test "$name" != "" && test "$name" -ne "0"; then
- *" $i "*)
- newdeplibs="$newdeplibs $i"
- i=""
- esac
- fi
- deplib_matches=`eval \\$echo \"$library_names_spec\"`
- set dummy $deplib_matches
- deplib_match=$2
- if test `expr "$ldd_output" : ".*$deplib_match"` -ne 0 ; then
- else
- droppeddeps=yes
- $echo
- $echo "*** Warning: dynamic linker does not accept needed library $i."
- $echo "*** shared version of the library, which I believe you do not have"
- $echo "*** because a test_compile did reveal that the linker did not use it for"
- $echo "*** its dynamic dependency list that programs get resolved with at runtime."
- fi
- fi
- else
- fi
- done
- else
- # Error occurred in the first compile. Let's try to salvage
- # the situation: Compile a separate program for each library.
- if test "$name" != "" && test "$name" != "0"; then
- $rm conftest
- $LTCC -o conftest conftest.c $i
- # Did it work?
- *" $i "*)
- i=""
- esac
- fi
- deplib_match=$2
- else
- droppeddeps=yes
- $echo
- $echo "*** because a test_compile did reveal that the linker did not use this one"
- $echo "*** as a dynamic dependency that programs can get resolved with at runtime."
- fi
- fi
- else
- droppeddeps=yes
- $echo
- $echo "*** Warning! Library $i is needed by this library but I was not able to"
- $echo "*** make it link in! You will probably need to install it or some"
- $echo "*** library that it depends on before this library will be fully"
- $echo "*** functional. Installing it before continuing would be even better."
- fi
- else
- fi
- done
- fi
- file_magic*)
- set dummy $deplibs_check_method
- file_magic_regex=`expr "$deplibs_check_method" : "$2 \(.*\)"`
- for a_deplib in $deplibs; do
- name="`expr $a_deplib : '-l\(.*\)'`"
- *" $a_deplib "*)
- newdeplibs="$newdeplibs $a_deplib"
- a_deplib=""
- esac
- fi
- if test -n "$a_deplib" ; then
- for i in $lib_search_path $sys_lib_search_path $shlib_search_path; do
- potential_libs=`ls $i/$libname[.-]* 2>/dev/null`
- for potent_lib in $potential_libs; do
- # Follow soft links.
- if ls -lLd "$potent_lib" 2>/dev/null \
- | grep " -> " >/dev/null; then
- continue
- fi
- # The statement above tries to avoid entering an
- # endless loop below, in case of cyclic links.
- # We might still enter an endless loop, since a link
- # loop can be closed while we follow links,
- # but so what?
- potlib="$potent_lib"
- while test -h "$potlib" 2>/dev/null; do
- potliblink=`ls -ld $potlib | ${SED} 's/.* -> //'`
- case $potliblink in
- [\\/]* | [A-Za-z]:[\\/]*) potlib="$potliblink";;
- *) potlib=`$echo "X$potlib" | $Xsed -e 's,[^/]*$,,'`"$potliblink";;
- esac
- done
- if eval $file_magic_cmd \"\$potlib\" 2>/dev/null \
- | ${SED} 10q \
- | $EGREP "$file_magic_regex" > /dev/null; then
- a_deplib=""
- break 2
- fi
- done
- done
- fi
- droppeddeps=yes
- $echo
- $echo "*** Warning: linker path does not have real file for library $a_deplib."
- $echo "*** because I did check the linker path looking for a file starting"
- if test -z "$potlib" ; then
- $echo "*** with $libname but no candidates were found. (...for file magic test)"
- else
- $echo "*** with $libname and none of the candidates passed a file format test"
- $echo "*** using a file magic. Last file checked: $potlib"
- fi
- fi
- else
- # Add a -L argument.
- fi
- done # Gone through all deplibs.
- match_pattern*)
- match_pattern_regex=`expr "$deplibs_check_method" : "$2 \(.*\)"`
- if test -n "$name" && test "$name" != "0"; then
- *" $a_deplib "*)
- a_deplib=""
- esac
- fi
- potlib="$potent_lib" # see symlink-check above in file_magic test
- if eval $echo \"$potent_lib\" 2>/dev/null \
- | ${SED} 10q \
- | $EGREP "$match_pattern_regex" > /dev/null; then
- a_deplib=""
- break 2
- fi
- done
- done
- fi
- droppeddeps=yes
- $echo
- $echo "*** with $libname but no candidates were found. (...for regex pattern test)"
- else
- $echo "*** using a regex pattern. Last file checked: $potlib"
- fi
- fi
- else
- fi
- none | unknown | *)
- newdeplibs=""
- tmp_deplibs=`$echo "X $deplibs" | $Xsed -e 's/ -lc$//' \
- -e 's/ -[LR][^ ]*//g'`
- for i in $predeps $postdeps ; do
- # can't use Xsed below, because $i might contain '/'
- tmp_deplibs=`$echo "X $tmp_deplibs" | ${SED} -e "1s,^X,," -e "s,$i,,"`
- done
- fi
- if $echo "X $tmp_deplibs" | $Xsed -e 's/[ ]//g' \
- | grep . >/dev/null; then
- $echo
- if test "X$deplibs_check_method" = "Xnone"; then
- $echo "*** Warning: inter-library dependencies are not supported in this platform."
- else
- $echo "*** Warning: inter-library dependencies are not known to be supported."
- fi
- $echo "*** All declared inter-library dependencies are being dropped."
- droppeddeps=yes
- fi
- esac
- versuffix=$versuffix_save
- major=$major_save
- release=$release_save
- libname=$libname_save
- name=$name_save
- case $host in
- # On Rhapsody replace the C library is the System framework
- newdeplibs=`$echo "X $newdeplibs" | $Xsed -e 's/ -lc / -framework System /'`
- esac
- if test "$droppeddeps" = yes; then
- $echo
- $echo "*** Warning: libtool could not satisfy all declared inter-library"
- $echo "*** dependencies of module $libname. Therefore, libtool will create"
- $echo "*** a static module, that should work as long as the dlopening"
- $echo "*** application is linked with the -dlopen flag."
- $echo
- fi
- oldlibs="$output_objdir/$libname.$libext"
- build_old_libs=yes
- else
- fi
- else
- $echo "*** The inter-library dependencies that have been dropped here will be"
- $echo "*** automatically added whenever a program is linked with this library"
- $echo "*** or is declared to -dlopen it."
- if test "$allow_undefined" = no; then
- $echo
- $echo "*** Since this library must not contain undefined symbols,"
- $echo "*** because either the platform does not support them or"
- $echo "*** it was explicitly requested with -no-undefined,"
- $echo "*** libtool will only create a static version of it."
- else
- fi
- fi
- fi
- fi
- # Done checking deplibs!
- deplibs=$newdeplibs
- fi
- # All the library-specific variables (install_libdir is set above).
- library_names=
- old_library=
- dlname=
- # Test again, we may have decided not to build it any more
- if test "$build_libtool_libs" = yes; then
- if test "$hardcode_into_libs" = yes; then
- # Hardcode the library paths
- hardcode_libdirs=
- dep_rpath=
- rpath="$finalize_rpath"
- test "$mode" != relink && test "$fast_install" = no && rpath="$compile_rpath$rpath"
- for libdir in $rpath; do
- if test -n "$hardcode_libdir_flag_spec"; then
- if test -n "$hardcode_libdir_separator"; then
- if test -z "$hardcode_libdirs"; then
- hardcode_libdirs="$libdir"
- else
- # Just accumulate the unique libdirs.
- case $hardcode_libdir_separator$hardcode_libdirs$hardcode_libdir_separator in
- *"$hardcode_libdir_separator$libdir$hardcode_libdir_separator"*)
- hardcode_libdirs="$hardcode_libdirs$hardcode_libdir_separator$libdir"
- esac
- fi
- else
- eval flag=\"$hardcode_libdir_flag_spec\"
- dep_rpath="$dep_rpath $flag"
- fi
- elif test -n "$runpath_var"; then
- case "$perm_rpath " in
- *" $libdir "*) ;;
- *) perm_rpath="$perm_rpath $libdir" ;;
- esac
- fi
- done
- # Substitute the hardcoded libdirs into the rpath.
- if test -n "$hardcode_libdir_separator" &&
- test -n "$hardcode_libdirs"; then
- libdir="$hardcode_libdirs"
- if test -n "$hardcode_libdir_flag_spec_ld"; then
- eval dep_rpath=\"$hardcode_libdir_flag_spec_ld\"
- else
- eval dep_rpath=\"$hardcode_libdir_flag_spec\"
- fi
- fi
- if test -n "$runpath_var" && test -n "$perm_rpath"; then
- # We should set the runpath_var.
- rpath=
- for dir in $perm_rpath; do
- rpath="$rpath$dir:"
- done
- eval "$runpath_var='$rpath\$$runpath_var'; export $runpath_var"
- fi
- test -n "$dep_rpath" && deplibs="$dep_rpath $deplibs"
- fi
- shlibpath="$finalize_shlibpath"
- test "$mode" != relink && shlibpath="$compile_shlibpath$shlibpath"
- if test -n "$shlibpath"; then
- eval "$shlibpath_var='$shlibpath\$$shlibpath_var'; export $shlibpath_var"
- fi
- # Get the real and link names of the library.
- eval library_names=\"$library_names_spec\"
- realname="$2"
- shift; shift
- if test -n "$soname_spec"; then
- else
- fi
- if test -z "$dlname"; then
- dlname=$soname
- fi
- lib="$output_objdir/$realname"
- for link
- do
- linknames="$linknames $link"
- done
- # Use standard objects if they are pic
- test -z "$pic_flag" && libobjs=`$echo "X$libobjs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- # Prepare the list of exported symbols
- if test -z "$export_symbols"; then
- if test "$always_export_symbols" = yes || test -n "$export_symbols_regex"; then
- $show "generating symbol list for \`$libname.la'"
- export_symbols="$output_objdir/$libname.exp"
- $run $rm $export_symbols
- eval cmds=\"$export_symbols_cmds\"
- IFS="$save_ifs"
- if len=`expr "X$cmd" : ".*"` &&
- test "$len" -le "$max_cmd_len" || test "$max_cmd_len" -le -1; then
- $show "$cmd"
- skipped_export=false
- else
- # The command line is too long to execute in one step.
- $show "using reloadable object file for export list..."
- skipped_export=:
- fi
- done
- IFS="$save_ifs"
- if test -n "$export_symbols_regex"; then
- $show "$EGREP -e \"$export_symbols_regex\" \"$export_symbols\" > \"${export_symbols}T\""
- $run eval '$EGREP -e "$export_symbols_regex" "$export_symbols" > "${export_symbols}T"'
- $show "$mv \"${export_symbols}T\" \"$export_symbols\""
- $run eval '$mv "${export_symbols}T" "$export_symbols"'
- fi
- fi
- fi
- if test -n "$export_symbols" && test -n "$include_expsyms"; then
- $run eval '$echo "X$include_expsyms" | $SP2NL >> "$export_symbols"'
- fi
- tmp_deplibs=
- for test_deplib in $deplibs; do
- case " $convenience " in
- *" $test_deplib "*) ;;
- tmp_deplibs="$tmp_deplibs $test_deplib"
- esac
- done
- deplibs="$tmp_deplibs"
- if test -n "$convenience"; then
- if test -n "$whole_archive_flag_spec"; then
- save_libobjs=$libobjs
- eval libobjs=\"\$libobjs $whole_archive_flag_spec\"
- else
- gentop="$output_objdir/${outputname}x"
- $show "${rm}r $gentop"
- $run ${rm}r "$gentop"
- $show "$mkdir $gentop"
- $run $mkdir "$gentop"
- status=$?
- if test "$status" -ne 0 && test ! -d "$gentop"; then
- exit $status
- fi
- generated="$generated $gentop"
- for xlib in $convenience; do
- # Extract the objects.
- case $xlib in
- [\\/]* | [A-Za-z]:[\\/]*) xabs="$xlib" ;;
- *) xabs=`pwd`"/$xlib" ;;
- esac
- xlib=`$echo "X$xlib" | $Xsed -e 's%^.*/%%'`
- xdir="$gentop/$xlib"
- $show "${rm}r $xdir"
- $run ${rm}r "$xdir"
- $show "$mkdir $xdir"
- $run $mkdir "$xdir"
- status=$?
- if test "$status" -ne 0 && test ! -d "$xdir"; then
- exit $status
- fi
- # We will extract separately just the conflicting names and we will no
- # longer touch any unique names. It is faster to leave these extract
- # automatically by $AR in one run.
- $show "(cd $xdir && $AR x $xabs)"
- $run eval "(cd \$xdir && $AR x \$xabs)" || exit $?
- if ($AR t "$xabs" | sort | sort -uc >/dev/null 2>&1); then
- else
- $echo "$modename: warning: object name conflicts; renaming object files" 1>&2
- $echo "$modename: warning: to ensure that they will not overwrite" 1>&2
- $AR t "$xabs" | sort | uniq -cd | while read -r count name
- do
- i=1
- while test "$i" -le "$count"
- do
- # Put our $i before any first dot (extension)
- # Never overwrite any file
- name_to="$name"
- while test "X$name_to" = "X$name" || test -f "$xdir/$name_to"
- do
- name_to=`$echo "X$name_to" | $Xsed -e "s/\([^.]*\)/\1-$i/"`
- done
- $show "(cd $xdir && $AR xN $i $xabs '$name' && $mv '$name' '$name_to')"
- $run eval "(cd \$xdir && $AR xN $i \$xabs '$name' && $mv '$name' '$name_to')" || exit $?
- i=`expr $i + 1`
- done
- done
- fi
- libobjs="$libobjs "`find $xdir -name \*.$objext -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- fi
- if test "$thread_safe" = yes && test -n "$thread_safe_flag_spec"; then
- eval flag=\"$thread_safe_flag_spec\"
- fi
- # Make a backup of the uninstalled library when relinking
- if test "$mode" = relink; then
- $run eval '(cd $output_objdir && $rm ${realname}U && $mv $realname ${realname}U)' || exit $?
- fi
- # Add all flags from the command line. We here create a library,
- # but those flags were only added to compile_command and
- # finalize_command, which are only used when creating executables.
- # So do it by hand here.
- compiler_flags="$compiler_flags $add_flags"
- # Only add it to commands which use CC, instead of LD, i.e.
- # only to $compiler_flags
- #linker_flags="$linker_flags $add_flags"
- # Do each of the archive commands.
- if test "$module" = yes && test -n "$module_cmds" ; then
- if test -n "$export_symbols" && test -n "$module_expsym_cmds"; then
- eval cmds=\"$module_expsym_cmds\"
- else
- eval cmds=\"$module_cmds\"
- fi
- else
- if test -n "$export_symbols" && test -n "$archive_expsym_cmds"; then
- eval cmds=\"$archive_expsym_cmds\"
- else
- eval cmds=\"$archive_cmds\"
- fi
- fi
- if test "X$skipped_export" != "X:" && len=`expr "X$cmds" : ".*"` &&
- else
- # The command line is too long to link in one step, link piecewise.
- $echo "creating reloadable object files..."
- # Save the value of $output and $libobjs because we want to
- # use them later. If we have whole_archive_flag_spec, we
- # want to use save_libobjs as it was before
- # whole_archive_flag_spec was expanded, because we can't
- # assume the linker understands whole_archive_flag_spec.
- # This may have to be revisited, in case too many
- # convenience libraries get linked in and end up exceeding
- # the spec.
- if test -z "$convenience" || test -z "$whole_archive_flag_spec"; then
- fi
- save_output=$output
- # Clear the reloadable object creation command queue and
- # initialize k to one.
- test_cmds=
- concat_cmds=
- objlist=
- delfiles=
- last_robj=
- k=1
- output=$output_objdir/$save_output-${k}.$objext
- # Loop over the list of objects to be linked.
- for obj in $save_libobjs
- do
- eval test_cmds=\"$reload_cmds $objlist $last_robj\"
- if test "X$objlist" = X ||
- { len=`expr "X$test_cmds" : ".*"` &&
- test "$len" -le "$max_cmd_len"; }; then
- objlist="$objlist $obj"
- else
- # The command $test_cmds is almost too long, add a
- # command to the queue.
- if test "$k" -eq 1 ; then
- # The first file doesn't have a previous command to add.
- eval concat_cmds=\"$reload_cmds $objlist $last_robj\"
- else
- # All subsequent reloadable object files will link in
- # the last one created.
- eval concat_cmds=\"\$concat_cmds~$reload_cmds $objlist $last_robj\"
- fi
- last_robj=$output_objdir/$save_output-${k}.$objext
- k=`expr $k + 1`
- objlist=$obj
- len=1
- fi
- done
- # Handle the remaining objects by creating one last
- # reloadable object file. All subsequent reloadable object
- # files will link in the last one created.
- test -z "$concat_cmds" || concat_cmds=$concat_cmds~
- eval concat_cmds=\"\${concat_cmds}$reload_cmds $objlist $last_robj\"
- if ${skipped_export-false}; then
- libobjs=$output
- # Append the command to create the export file.
- eval concat_cmds=\"\$concat_cmds~$export_symbols_cmds\"
- fi
- # Set up a command to remove the reloadale object files
- # after they are used.
- i=0
- while test "$i" -lt "$k"
- do
- i=`expr $i + 1`
- delfiles="$delfiles $output_objdir/$save_output-${i}.$objext"
- done
- $echo "creating a temporary reloadable object file: $output"
- # Loop through the commands generated above and execute them.
- for cmd in $concat_cmds; do
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- libobjs=$output
- # Restore the value of output.
- output=$save_output
- if test -n "$convenience" && test -n "$whole_archive_flag_spec"; then
- fi
- # Expand the library linking commands again to reset the
- # value of $libobjs for piecewise linking.
- else
- fi
- # Append the command to remove the reloadable object files
- # to the just-reset $cmds.
- eval cmds=\"\$cmds~$rm $delfiles\"
- fi
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- # Restore the uninstalled library and exit
- $run eval '(cd $output_objdir && $rm ${realname}T && $mv $realname ${realname}T && $mv "$realname"U $realname)' || exit $?
- exit 0
- fi
- # Create links to the real library.
- for linkname in $linknames; do
- if test "$realname" != "$linkname"; then
- $show "(cd $output_objdir && $rm $linkname && $LN_S $realname $linkname)"
- $run eval '(cd $output_objdir && $rm $linkname && $LN_S $realname $linkname)' || exit $?
- fi
- done
- # If -module or -export-dynamic was specified, set the dlname.
- if test "$module" = yes || test "$export_dynamic" = yes; then
- # On all known operating systems, these are identical.
- dlname="$soname"
- fi
- fi
- obj)
- $echo "$modename: warning: \`-l' and \`-L' are ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-dlopen' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-rpath' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-R' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-version-info' is ignored for objects" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for objects" 1>&2
- fi
- case $output in
- *.lo)
- if test -n "$objs$old_deplibs"; then
- $echo "$modename: cannot build library object \`$output' from non-libtool objects" 1>&2
- exit 1
- fi
- libobj="$output"
- obj=`$echo "X$output" | $Xsed -e "$lo2o"`
- libobj=
- obj="$output"
- esac
- # Delete the old objects.
- $run $rm $obj $libobj
- # Objects from convenience libraries. This assumes
- # single-version convenience libraries. Whenever we create
- # different ones for PIC/non-PIC, this we'll have to duplicate
- # the extraction.
- reload_conv_objs=
- gentop=
- # reload_cmds runs $LD directly, so let us get rid of
- # -Wl from whole_archive_flag_spec
- wl=
- eval reload_conv_objs=\"\$reload_objs $whole_archive_flag_spec\"
- else
- gentop="$output_objdir/${obj}x"
- status=$?
- exit $status
- fi
- case $xlib in
- esac
- status=$?
- exit $status
- fi
- else
- do
- i=1
- do
- name_to="$name"
- do
- done
- i=`expr $i + 1`
- done
- done
- fi
- reload_conv_objs="$reload_objs "`find $xdir -name \*.$objext -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- fi
- # Create the old-style object.
- reload_objs="$objs$old_deplibs "`$echo "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}$'/d' -e '/\.lib$/d' -e "$lo2o" | $NL2SP`" $reload_conv_objs" ### testsuite: skip nested quoting test
- output="$obj"
- eval cmds=\"$reload_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- # Exit if we aren't doing a library object file.
- if test -z "$libobj"; then
- if test -n "$gentop"; then
- $run ${rm}r $gentop
- fi
- exit 0
- fi
- if test "$build_libtool_libs" != yes; then
- fi
- # Create an invalid libtool object if no PIC, so that we don't
- # accidentally link it into a program.
- # $show "echo timestamp > $libobj"
- # $run eval "echo timestamp > $libobj" || exit $?
- exit 0
- fi
- if test -n "$pic_flag" || test "$pic_mode" != default; then
- # Only do commands if we really have different PIC objects.
- reload_objs="$libobjs $reload_conv_objs"
- output="$libobj"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- fi
- fi
- exit 0
- prog)
- case $host in
- *cygwin*) output=`$echo $output | ${SED} -e 's,.exe$,,;s,$,.exe,'` ;;
- esac
- $echo "$modename: warning: \`-version-info' is ignored for programs" 1>&2
- fi
- $echo "$modename: warning: \`-release' is ignored for programs" 1>&2
- fi
- if test "$preload" = yes; then
- if test "$dlopen_support" = unknown && test "$dlopen_self" = unknown &&
- test "$dlopen_self_static" = unknown; then
- $echo "$modename: warning: \`AC_LIBTOOL_DLOPEN' not used. Assuming no dlopen support."
- fi
- fi
- case $host in
- compile_deplibs=`$echo "X $compile_deplibs" | $Xsed -e 's/ -lc / -framework System /'`
- finalize_deplibs=`$echo "X $finalize_deplibs" | $Xsed -e 's/ -lc / -framework System /'`
- esac
- case $host in
- *darwin*)
- # Don't allow lazy linking, it breaks C++ global constructors
- if test "$tagname" = CXX ; then
- compile_command="$compile_command ${wl}-bind_at_load"
- finalize_command="$finalize_command ${wl}-bind_at_load"
- fi
- esac
- compile_command="$compile_command $compile_deplibs"
- finalize_command="$finalize_command $finalize_deplibs"
- if test -n "$rpath$xrpath"; then
- for libdir in $rpath $xrpath; do
- # This is the magic to use -rpath.
- *" $libdir "*) ;;
- esac
- done
- fi
- # Now hardcode the library paths
- rpath=
- hardcode_libdirs=
- for libdir in $compile_rpath $finalize_rpath; do
- else
- esac
- fi
- else
- rpath="$rpath $flag"
- fi
- *" $libdir "*) ;;
- esac
- fi
- case $host in
- *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2*)
- case :$dllsearchpath: in
- *":$libdir:"*) ;;
- *) dllsearchpath="$dllsearchpath:$libdir";;
- esac
- esac
- done
- eval rpath=\" $hardcode_libdir_flag_spec\"
- fi
- compile_rpath="$rpath"
- rpath=
- hardcode_libdirs=
- for libdir in $finalize_rpath; do
- else
- esac
- fi
- else
- fi
- case "$finalize_perm_rpath " in
- *" $libdir "*) ;;
- *) finalize_perm_rpath="$finalize_perm_rpath $libdir" ;;
- esac
- fi
- done
- fi
- finalize_rpath="$rpath"
- if test -n "$libobjs" && test "$build_old_libs" = yes; then
- # Transform all the library objects into standard objects.
- compile_command=`$echo "X$compile_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- finalize_command=`$echo "X$finalize_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- fi
- dlsyms=
- if test -n "$NM" && test -n "$global_symbol_pipe"; then
- dlsyms="${outputname}S.c"
- else
- $echo "$modename: not configured to extract global symbols from dlpreopened files" 1>&2
- fi
- fi
- if test -n "$dlsyms"; then
- case $dlsyms in
- *.c)
- # Discover the nlist of each of the dlfiles.
- nlist="$output_objdir/${outputname}.nm"
- $show "$rm $nlist ${nlist}S ${nlist}T"
- $run $rm "$nlist" "${nlist}S" "${nlist}T"
- # Parse the name list into a source file.
- $show "creating $output_objdir/$dlsyms"
- test -z "$run" && $echo > "$output_objdir/$dlsyms" "\
-/* $dlsyms - symbol resolution table for \`$outputname' dlsym emulation. */
-/* Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP */
-#ifdef __cplusplus
-extern \"C\" {
-#endif
-/* Prevent the only kind of declaration conflicts we can make. */
-#define lt_preloaded_symbols some_other_symbol
-/* External symbol declarations for the compiler. */\
- if test "$dlself" = yes; then
- $show "generating symbol list for \`$output'"
- test -z "$run" && $echo ': @PROGRAM@ ' > "$nlist"
- # Add our own program objects to the symbol list.
- progfiles=`$echo "X$objs$old_deplibs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
- for arg in $progfiles; do
- $show "extracting global C symbols from \`$arg'"
- $run eval "$NM $arg | $global_symbol_pipe >> '$nlist'"
- done
- if test -n "$exclude_expsyms"; then
- $run eval '$EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T'
- $run eval '$mv "$nlist"T "$nlist"'
- fi
- $run eval '$EGREP -e "$export_symbols_regex" "$nlist" > "$nlist"T'
- fi
- export_symbols="$output_objdir/$output.exp"
- $run eval "${SED} -n -e '/^: @PROGRAM@$/d' -e 's/^.* \(.*\)$/\1/p' "'< "$nlist" > "$export_symbols"'
- else
- $run eval "${SED} -e 's/\([][.*^$]\)/\\\1/g' -e 's/^/ /' -e 's/$/$/'"' < "$export_symbols" > "$output_objdir/$output.exp"'
- $run eval 'grep -f "$output_objdir/$output.exp" < "$nlist" > "$nlist"T'
- $run eval 'mv "$nlist"T "$nlist"'
- fi
- fi
- for arg in $dlprefiles; do
- name=`$echo "$arg" | ${SED} -e 's%^.*/%%'`
- $run eval '$echo ": $name " >> "$nlist"'
- done
- if test -z "$run"; then
- # Make sure we have at least an empty file.
- test -f "$nlist" || : > "$nlist"
- $EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T
- $mv "$nlist"T "$nlist"
- fi
- # Try sorting and uniquifying the output.
- if grep -v "^: " < "$nlist" |
- if sort -k 3 </dev/null >/dev/null 2>&1; then
- sort -k 3
- else
- sort +2
- fi |
- uniq > "$nlist"S; then
- else
- grep -v "^: " < "$nlist" > "$nlist"S
- fi
- if test -f "$nlist"S; then
- eval "$global_symbol_to_cdecl"' < "$nlist"S >> "$output_objdir/$dlsyms"'
- else
- $echo '/* NONE */' >> "$output_objdir/$dlsyms"
- fi
- $echo >> "$output_objdir/$dlsyms" "\
-#undef lt_preloaded_symbols
-#if defined (__STDC__) && __STDC__
-# define lt_ptr void *
-#else
-# define lt_ptr char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr address;
-lt_preloaded_symbols[] =
- eval "$global_symbol_to_c_name_address" < "$nlist" >> "$output_objdir/$dlsyms"
- {0, (lt_ptr) 0}
-/* This works around a problem in FreeBSD linker */
-#ifdef FREEBSD_WORKAROUND
-static const void *lt_preloaded_setup() {
- return lt_preloaded_symbols;
-#endif
-#ifdef __cplusplus
-#endif\
- fi
- pic_flag_for_symtable=
- case $host in
- # compiling the symbol table file with pic_flag works around
- # a FreeBSD bug that causes programs to crash when -lm is
- # linked before any other PIC object. But we must not use
- # pic_flag when linking with -static. The problem exists in
- # FreeBSD 2.2.6 and is fixed in FreeBSD 3.1.
- *-*-freebsd2*|*-*-freebsd3.0*|*-*-freebsdelf3.0*)
- case "$compile_command " in
- *" -static "*) ;;
- *) pic_flag_for_symtable=" $pic_flag -DFREEBSD_WORKAROUND";;
- esac;;
- *-*-hpux*)
- *" -static "*) ;;
- *) pic_flag_for_symtable=" $pic_flag";;
- esac
- esac
- # Now compile the dynamic symbol file.
- $show "(cd $output_objdir && $LTCC -c$no_builtin_flag$pic_flag_for_symtable \"$dlsyms\")"
- $run eval '(cd $output_objdir && $LTCC -c$no_builtin_flag$pic_flag_for_symtable "$dlsyms")' || exit $?
- # Clean up the generated files.
- $show "$rm $output_objdir/$dlsyms $nlist ${nlist}S ${nlist}T"
- $run $rm "$output_objdir/$dlsyms" "$nlist" "${nlist}S" "${nlist}T"
- # Transform the symbol file into the correct name.
- compile_command=`$echo "X$compile_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/${outputname}S.${objext}%"`
- finalize_command=`$echo "X$finalize_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/${outputname}S.${objext}%"`
- $echo "$modename: unknown suffix for \`$dlsyms'" 1>&2
- exit 1
- esac
- else
- # We keep going just in case the user didn't refer to
- # lt_preloaded_symbols. The linker will fail if global_symbol_pipe
- # really was required.
- # Nullify the symbol file.
- compile_command=`$echo "X$compile_command" | $Xsed -e "s% @SYMFILE@%%"`
- finalize_command=`$echo "X$finalize_command" | $Xsed -e "s% @SYMFILE@%%"`
- fi
- # AIX runtime linking requires linking programs with -Wl,-brtl and libs with -Wl,-G
- # Also add -bnolibpath to the beginning of the link line, to clear the hardcoded runpath.
- # Otherwise, things like the -L path to libgcc.a are accidentally hardcoded by ld.
- # This does not apply on AIX for ia64, which uses a SysV linker.
- case "$host" in
- ia64-*-aix5*) ;;
- *-*-aix4* | *-*-aix5*)
- compile_command=`$echo "X$compile_command $wl-brtl" | $Xsed -e "s/\$CC/\$CC $wl-bnolibpath/1"`
- finalize_command=`$echo "X$finalize_command $wl-brtl" | $Xsed -e "s/\$CC/\$CC $wl-bnolibpath/1"` ;;
- esac
- if test "$need_relink" = no || test "$build_libtool_libs" != yes; then
- # Replace the output file specification.
- compile_command=`$echo "X$compile_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
- link_command="$compile_command$compile_rpath"
- # We have no uninstalled library dependencies, so finalize right now.
- $show "$link_command"
- $run eval "$link_command"
- status=$?
- # Delete the generated files.
- $show "$rm $output_objdir/${outputname}S.${objext}"
- $run $rm "$output_objdir/${outputname}S.${objext}"
- fi
- exit $status
- fi
- if test -n "$shlibpath_var"; then
- # We should set the shlibpath_var
- rpath=
- for dir in $temp_rpath; do
- case $dir in
- # Absolute path.
- # Relative path: add a thisdir entry.
- rpath="$rpath\$thisdir/$dir:"
- esac
- done
- temp_rpath="$rpath"
- fi
- if test -n "$compile_shlibpath$finalize_shlibpath"; then
- compile_command="$shlibpath_var=\"$compile_shlibpath$finalize_shlibpath\$$shlibpath_var\" $compile_command"
- fi
- if test -n "$finalize_shlibpath"; then
- finalize_command="$shlibpath_var=\"$finalize_shlibpath\$$shlibpath_var\" $finalize_command"
- fi
- compile_var=
- finalize_var=
- if test -n "$runpath_var"; then
- if test -n "$perm_rpath"; then
- rpath=
- done
- compile_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- if test -n "$finalize_perm_rpath"; then
- rpath=
- for dir in $finalize_perm_rpath; do
- done
- finalize_var="$runpath_var=\"$rpath\$$runpath_var\" "
- fi
- fi
- if test "$no_install" = yes; then
- # We don't need to create a wrapper script.
- link_command="$compile_var$compile_command$compile_rpath"
- link_command=`$echo "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
- # Delete the old output file.
- $run $rm $output
- # Link the executable and exit
- $run eval "$link_command" || exit $?
- exit 0
- fi
- if test "$hardcode_action" = relink; then
- # Fast installation is not supported
- relink_command="$finalize_var$finalize_command$finalize_rpath"
- $echo "$modename: warning: this platform does not like uninstalled shared libraries" 1>&2
- $echo "$modename: \`$output' will be relinked during installation" 1>&2
- else
- if test "$fast_install" != no; then
- link_command="$finalize_var$compile_command$finalize_rpath"
- if test "$fast_install" = yes; then
- relink_command=`$echo "X$compile_var$compile_command$compile_rpath" | $Xsed -e 's%@OUTPUT@%\$progdir/\$file%g'`
- else
- # fast_install is set to needless
- relink_command=
- fi
- else
- fi
- fi
- link_command=`$echo "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output_objdir/$outputname"'%g'`
- # Delete the old output files.
- $run $rm $output $output_objdir/$outputname $output_objdir/lt-$outputname
- # Now create the wrapper script.
- $show "creating $output"
- # Quote the relink command for shipping.
- if test -n "$relink_command"; then
- # Preserve any variables that may affect compiler behavior
- for var in $variables_saved_for_relink; do
- if eval test -z \"\${$var+set}\"; then
- relink_command="{ test -z \"\${$var+set}\" || unset $var || { $var=; export $var; }; }; $relink_command"
- elif eval var_value=\$$var; test -z "$var_value"; then
- relink_command="$var=; export $var; $relink_command"
- else
- var_value=`$echo "X$var_value" | $Xsed -e "$sed_quote_subst"`
- relink_command="$var=\"$var_value\"; export $var; $relink_command"
- fi
- done
- relink_command="(cd `pwd`; $relink_command)"
- relink_command=`$echo "X$relink_command" | $Xsed -e "$sed_quote_subst"`
- fi
- # Quote $echo for shipping.
- if test "X$echo" = "X$SHELL $0 --fallback-echo"; then
- case $0 in
- [\\/]* | [A-Za-z]:[\\/]*) qecho="$SHELL $0 --fallback-echo";;
- *) qecho="$SHELL `pwd`/$0 --fallback-echo";;
- esac
- qecho=`$echo "X$qecho" | $Xsed -e "$sed_quote_subst"`
- else
- qecho=`$echo "X$echo" | $Xsed -e "$sed_quote_subst"`
- fi
- # Only actually do things if our run command is non-null.
- # win32 will think the script is a binary if it has
- # a .exe suffix, so we strip it off here.
- case $output in
- *.exe) output=`$echo $output|${SED} 's,.exe$,,'` ;;
- esac
- # test for cygwin because mv fails w/o .exe extensions
- case $host in
- *cygwin*)
- exeext=.exe
- outputname=`$echo $outputname|${SED} 's,.exe$,,'` ;;
- *) exeext= ;;
- esac
- case $host in
- *cygwin* | *mingw* )
- cwrappersource=`$echo ${objdir}/lt-${output}.c`
- cwrapper=`$echo ${output}.exe`
- $rm $cwrappersource $cwrapper
- trap "$rm $cwrappersource $cwrapper; exit 1" 1 2 15
- cat > $cwrappersource <<EOF
-/* $cwrappersource - temporary wrapper executable for $objdir/$outputname
- Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP
- The $output program cannot be directly executed until all the libtool
- libraries that it depends on are installed.
- This wrapper executable should never be moved out of the build directory.
- If it is, it will not operate correctly.
- Currently, it simply execs the wrapper *script* "/bin/sh $output",
- but could eventually absorb all of the scripts functionality and
- exec $objdir/$outputname directly.
-EOF
- cat >> $cwrappersource<<"EOF"
-#include <stdio.h>
-#include <stdlib.h>
-#include <unistd.h>
-#include <malloc.h>
-#include <stdarg.h>
-#include <assert.h>
-#if defined(PATH_MAX)
-# define LT_PATHMAX PATH_MAX
-#elif defined(MAXPATHLEN)
-# define LT_PATHMAX MAXPATHLEN
-#else
-# define LT_PATHMAX 1024
-#endif
-#ifndef DIR_SEPARATOR
-#define DIR_SEPARATOR '/'
-#endif
-#if defined (_WIN32) || defined (__MSDOS__) || defined (__DJGPP__) || \
- defined (__OS2__)
-#define HAVE_DOS_BASED_FILE_SYSTEM
-#ifndef DIR_SEPARATOR_2
-#define DIR_SEPARATOR_2 '\\'
-#endif
-#endif
-# define IS_DIR_SEPARATOR(ch) ((ch) == DIR_SEPARATOR)
-#else /* DIR_SEPARATOR_2 */
-# define IS_DIR_SEPARATOR(ch) \
- (((ch) == DIR_SEPARATOR) || ((ch) == DIR_SEPARATOR_2))
-#endif /* DIR_SEPARATOR_2 */
-#define XMALLOC(type, num) ((type *) xmalloc ((num) * sizeof(type)))
-#define XFREE(stale) do { \
- if (stale) { free ((void *) stale); stale = 0; } \
-} while (0)
-const char *program_name = NULL;
-void * xmalloc (size_t num);
-char * xstrdup (const char *string);
-char * basename (const char *name);
-char * fnqualify(const char *path);
-char * strendzap(char *str, const char *pat);
-void lt_fatal (const char *message, ...);
-int
-main (int argc, char *argv[])
- char **newargz;
- int i;
- program_name = (char *) xstrdup ((char *) basename (argv[0]));
- newargz = XMALLOC(char *, argc+2);
-EOF
- cat >> $cwrappersource <<EOF
- newargz[0] = "$SHELL";
-EOF
- cat >> $cwrappersource <<"EOF"
- newargz[1] = fnqualify(argv[0]);
- /* we know the script has the same name, without the .exe */
- /* so make sure newargz[1] doesn't end in .exe */
- strendzap(newargz[1],".exe");
- for (i = 1; i < argc; i++)
- newargz[i+1] = xstrdup(argv[i]);
- newargz[argc+1] = NULL;
-EOF
- execv("$SHELL",newargz);
-EOF
-void *
-xmalloc (size_t num)
- void * p = (void *) malloc (num);
- if (!p)
- lt_fatal ("Memory exhausted");
- return p;
-char *
-xstrdup (const char *string)
- return string ? strcpy ((char *) xmalloc (strlen (string) + 1), string) : NULL
-char *
-basename (const char *name)
- const char *base;
-#if defined (HAVE_DOS_BASED_FILE_SYSTEM)
- /* Skip over the disk name in MSDOS pathnames. */
- if (isalpha (name[0]) && name[1] == ':')
- name += 2;
-#endif
- for (base = name; *name; name++)
- if (IS_DIR_SEPARATOR (*name))
- base = name + 1;
- return (char *) base;
-char *
-fnqualify(const char *path)
- size_t size;
- char *p;
- char tmp[LT_PATHMAX + 1];
- assert(path != NULL);
- /* Is it qualified already? */
- if (isalpha (path[0]) && path[1] == ':')
- return xstrdup (path);
-#endif
- if (IS_DIR_SEPARATOR (path[0]))
- /* prepend the current directory */
- /* doesn't handle '~' */
- if (getcwd (tmp, LT_PATHMAX) == NULL)
- lt_fatal ("getcwd failed");
- size = strlen(tmp) + 1 + strlen(path) + 1; /* +2 for '/' and '\0' */
- p = XMALLOC(char, size);
- sprintf(p, "%s%c%s", tmp, DIR_SEPARATOR, path);
- return p;
-char *
-strendzap(char *str, const char *pat)
- size_t len, patlen;
- assert(str != NULL);
- assert(pat != NULL);
- len = strlen(str);
- patlen = strlen(pat);
- if (patlen <= len)
- str += len - patlen;
- if (strcmp(str, pat) == 0)
- *str = '\0';
- return str;
-static void
-lt_error_core (int exit_status, const char * mode,
- const char * message, va_list ap)
- fprintf (stderr, "%s: %s: ", program_name, mode);
- vfprintf (stderr, message, ap);
- fprintf (stderr, ".\n");
- if (exit_status >= 0)
- exit (exit_status);
-void
-lt_fatal (const char *message, ...)
- va_list ap;
- va_start (ap, message);
- lt_error_core (EXIT_FAILURE, "FATAL", message, ap);
- va_end (ap);
-EOF
- # we should really use a build-platform specific compiler
- # here, but OTOH, the wrappers (shell script and this C one)
- # are only useful if you want to execute the "real" binary.
- # Since the "real" binary is built for $host, then this
- # wrapper might as well be built for $host, too.
- $run $LTCC -s -o $cwrapper $cwrappersource
- esac
- $rm $output
- trap "$rm $output; exit 1" 1 2 15
- $echo > $output "\
-#! $SHELL
-# $output - temporary wrapper script for $objdir/$outputname
-# Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP
-# The $output program cannot be directly executed until all the libtool
-# libraries that it depends on are installed.
-# This wrapper script should never be moved out of the build directory.
-# If it is, it will not operate correctly.
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='${SED} -e 1s/^X//'
-sed_quote_subst='$sed_quote_subst'
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-if test \"\${CDPATH+set}\" = set; then CDPATH=:; export CDPATH; fi
-relink_command=\"$relink_command\"
-# This environment variable determines our operation mode.
-if test \"\$libtool_install_magic\" = \"$magic\"; then
- # install mode needs the following variable:
- notinst_deplibs='$notinst_deplibs'
-else
- # When we are sourced in execute mode, \$file and \$echo are already set.
- if test \"\$libtool_execute_magic\" != \"$magic\"; then
- echo=\"$qecho\"
- file=\"\$0\"
- # Make sure echo works.
- if test \"X\$1\" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
- elif test \"X\`(\$echo '\t') 2>/dev/null\`\" = 'X\t'; then
- # Yippee, \$echo works!
- else
- # Restart under the correct shell, and then maybe \$echo will work.
- exec $SHELL \"\$0\" --no-reexec \${1+\"\$@\"}
- fi
- fi\
- $echo >> $output "\
- # Find the directory that this script lives in.
- thisdir=\`\$echo \"X\$file\" | \$Xsed -e 's%/[^/]*$%%'\`
- test \"x\$thisdir\" = \"x\$file\" && thisdir=.
- # Follow symbolic links until we get to the real thisdir.
- file=\`ls -ld \"\$file\" | ${SED} -n 's/.*-> //p'\`
- while test -n \"\$file\"; do
- destdir=\`\$echo \"X\$file\" | \$Xsed -e 's%/[^/]*\$%%'\`
- # If there was a directory component, then change thisdir.
- if test \"x\$destdir\" != \"x\$file\"; then
- case \"\$destdir\" in
- [\\\\/]* | [A-Za-z]:[\\\\/]*) thisdir=\"\$destdir\" ;;
- *) thisdir=\"\$thisdir/\$destdir\" ;;
- esac
- fi
- file=\`\$echo \"X\$file\" | \$Xsed -e 's%^.*/%%'\`
- file=\`ls -ld \"\$thisdir/\$file\" | ${SED} -n 's/.*-> //p'\`
- done
- # Try to get the absolute directory name.
- absdir=\`cd \"\$thisdir\" && pwd\`
- test -n \"\$absdir\" && thisdir=\"\$absdir\"
- program=lt-'$outputname'$exeext
- progdir=\"\$thisdir/$objdir\"
- if test ! -f \"\$progdir/\$program\" || \\
- { file=\`ls -1dt \"\$progdir/\$program\" \"\$progdir/../\$program\" 2>/dev/null | ${SED} 1q\`; \\
- test \"X\$file\" != \"X\$progdir/\$program\"; }; then
- file=\"\$\$-\$program\"
- if test ! -d \"\$progdir\"; then
- $mkdir \"\$progdir\"
- else
- $rm \"\$progdir/\$file\"
- fi"
- # relink executable if necessary
- if test -n \"\$relink_command\"; then
- if relink_command_output=\`eval \$relink_command 2>&1\`; then :
- else
- $echo \"\$relink_command_output\" >&2
- exit 1
- fi
- fi
- $mv \"\$progdir/\$file\" \"\$progdir/\$program\" 2>/dev/null ||
- { $rm \"\$progdir/\$program\";
- $mv \"\$progdir/\$file\" \"\$progdir/\$program\"; }
- fi"
- else
- program='$outputname'
- fi
- if test -f \"\$progdir/\$program\"; then"
- # Export our shlibpath_var if we have one.
- if test "$shlibpath_overrides_runpath" = yes && test -n "$shlibpath_var" && test -n "$temp_rpath"; then
- # Add our own library path to $shlibpath_var
- $shlibpath_var=\"$temp_rpath\$$shlibpath_var\"
- # Some systems cannot cope with colon-terminated $shlibpath_var
- # The second colon is a workaround for a bug in BeOS R4 sed
- $shlibpath_var=\`\$echo \"X\$$shlibpath_var\" | \$Xsed -e 's/::*\$//'\`
- export $shlibpath_var
- fi
- # fixup the dll searchpath if we need to.
- if test -n "$dllsearchpath"; then
- # Add the dll search path components to the executable PATH
- PATH=$dllsearchpath:\$PATH
- fi
- # Run the actual program with our arguments.
- case $host in
- # Backslashes separate directories on plain windows
- *-*-mingw | *-*-os2*)
- exec \$progdir\\\\\$program \${1+\"\$@\"}
- exec \$progdir/\$program \${1+\"\$@\"}
- esac
- \$echo \"\$0: cannot exec \$program \${1+\"\$@\"}\"
- exit 1
- fi
- else
- # The program doesn't exist.
- \$echo \"\$0: error: \$progdir/\$program does not exist\" 1>&2
- \$echo \"This script is just a wrapper for \$program.\" 1>&2
- $echo \"See the $PACKAGE documentation for more information.\" 1>&2
- exit 1
- fi
-fi\
- chmod +x $output
- fi
- exit 0
- esac
- # See if we need to build an old-fashioned archive.
- for oldlib in $oldlibs; do
- if test "$build_libtool_libs" = convenience; then
- oldobjs="$libobjs_save"
- addlibs="$convenience"
- build_libtool_libs=no
- else
- if test "$build_libtool_libs" = module; then
- else
- oldobjs="$old_deplibs $non_pic_objects"
- fi
- addlibs="$old_convenience"
- fi
- if test -n "$addlibs"; then
- status=$?
- exit $status
- fi
- # Add in members from convenience archives.
- for xlib in $addlibs; do
- case $xlib in
- esac
- status=$?
- exit $status
- fi
- else
- do
- i=1
- do
- name_to="$name"
- do
- done
- i=`expr $i + 1`
- done
- done
- fi
- oldobjs="$oldobjs "`find $xdir -name \*.${objext} -print -o -name \*.lo -print | $NL2SP`
- done
- fi
- # Do each command in the archive commands.
- if test -n "$old_archive_from_new_cmds" && test "$build_libtool_libs" = yes; then
- eval cmds=\"$old_archive_from_new_cmds\"
- else
- eval cmds=\"$old_archive_cmds\"
- if len=`expr "X$cmds" : ".*"` &&
- else
- # the command line is too long to link in one step, link in parts
- $echo "using piecewise archive linking..."
- save_RANLIB=$RANLIB
- RANLIB=:
- objlist=
- concat_cmds=
- save_oldobjs=$oldobjs
- # GNU ar 2.10+ was changed to match POSIX; thus no paths are
- # encoded into archives. This makes 'ar r' malfunction in
- # this piecewise linking case whenever conflicting object
- # names appear in distinct ar calls; check, warn and compensate.
- if (for obj in $save_oldobjs
- do
- $echo "X$obj" | $Xsed -e 's%^.*/%%'
- done | sort | sort -uc >/dev/null 2>&1); then
- else
- $echo "$modename: warning: object name conflicts; overriding AR_FLAGS to 'cq'" 1>&2
- $echo "$modename: warning: to ensure that POSIX-compatible ar will work" 1>&2
- AR_FLAGS=cq
- fi
- # Is there a better way of finding the last object in the list?
- for obj in $save_oldobjs
- do
- last_oldobj=$obj
- done
- do
- oldobjs="$objlist $obj"
- eval test_cmds=\"$old_archive_cmds\"
- if len=`expr "X$test_cmds" : ".*"` &&
- test "$len" -le "$max_cmd_len"; then
- else
- # the above command should be used before it gets too long
- oldobjs=$objlist
- if test "$obj" = "$last_oldobj" ; then
- RANLIB=$save_RANLIB
- fi
- eval concat_cmds=\"\${concat_cmds}$old_archive_cmds\"
- objlist=
- fi
- done
- oldobjs=$objlist
- if test "X$oldobjs" = "X" ; then
- eval cmds=\"\$concat_cmds\"
- else
- eval cmds=\"\$concat_cmds~$old_archive_cmds\"
- fi
- fi
- fi
- save_ifs="$IFS"; IFS='~'
- for cmd in $cmds; do
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd" || exit $?
- done
- IFS="$save_ifs"
- done
- if test -n "$generated"; then
- $show "${rm}r$generated"
- $run ${rm}r$generated
- fi
- # Now create the libtool archive.
- case $output in
- *.la)
- old_library=
- test "$build_old_libs" = yes && old_library="$libname.$libext"
- else
- fi
- done
- # Quote the link command for shipping.
- relink_command="(cd `pwd`; $SHELL $0 --mode=relink $libtool_args @inst_prefix_dir@)"
- if test "$hardcode_automatic" = yes ; then
- relink_command=
- fi
- # Only create the output if not a dry run.
- for installed in no yes; do
- if test "$installed" = yes; then
- if test -z "$install_libdir"; then
- break
- fi
- output="$output_objdir/$outputname"i
- # Replace all uninstalled libtool libraries with the installed ones
- newdependency_libs=
- for deplib in $dependency_libs; do
- case $deplib in
- *.la)
- name=`$echo "X$deplib" | $Xsed -e 's%^.*/%%'`
- if test -z "$libdir"; then
- exit 1
- fi
- newdependency_libs="$newdependency_libs $libdir/$name"
- *) newdependency_libs="$newdependency_libs $deplib" ;;
- esac
- done
- newdlfiles=
- for lib in $dlfiles; do
- name=`$echo "X$lib" | $Xsed -e 's%^.*/%%'`
- eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $lib`
- $echo "$modename: \`$lib' is not a valid libtool archive" 1>&2
- exit 1
- fi
- newdlfiles="$newdlfiles $libdir/$name"
- done
- newdlprefiles=
- for lib in $dlprefiles; do
- exit 1
- fi
- newdlprefiles="$newdlprefiles $libdir/$name"
- done
- fi
- $rm $output
- # place dlname in correct position for cygwin
- tdlname=$dlname
- case $host,$output,$installed,$module,$dlname in
- *cygwin*,*lai,yes,no,*.dll | *mingw*,*lai,yes,no,*.dll) tdlname=../bin/$dlname ;;
- esac
-# $outputname - a libtool library file
-# Please DO NOT delete this file!
-# It is necessary for linking the library.
-# The name that we can dlopen(3).
-dlname='$tdlname'
-# Names of this library.
-library_names='$library_names'
-# The name of the static archive.
-old_library='$old_library'
-# Libraries that this one depends upon.
-dependency_libs='$dependency_libs'
-# Version information for $libname.
-current=$current
-age=$age
-revision=$revision
-# Is this an already installed library?
-installed=$installed
-# Should we warn about portability when linking against -modules?
-shouldnotlink=$module
-# Files to dlopen/dlpreopen
-dlopen='$dlfiles'
-dlpreopen='$dlprefiles'
-# Directory that this library needs to be installed in:
-libdir='$install_libdir'"
- if test "$installed" = no && test "$need_relink" = yes && test "$fast_install" = no; then
-relink_command=\"$relink_command\""
- fi
- done
- fi
- # Do a symbolic link so that the libtool archive can be found in
- # LD_LIBRARY_PATH before the program is installed.
- $show "(cd $output_objdir && $rm $outputname && $LN_S ../$outputname $outputname)"
- $run eval '(cd $output_objdir && $rm $outputname && $LN_S ../$outputname $outputname)' || exit $?
- esac
- exit 0
- # libtool install mode
- install)
- modename="$modename: install"
- # There may be an optional sh(1) argument at the beginning of
- # install_prog (especially on Windows NT).
- if test "$nonopt" = "$SHELL" || test "$nonopt" = /bin/sh ||
- # Allow the use of GNU shtool's install command.
- $echo "X$nonopt" | $Xsed | grep shtool > /dev/null; then
- # Aesthetically quote it.
- arg=`$echo "X$nonopt" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$arg "
- arg="$1"
- shift
- else
- install_prog=
- arg="$nonopt"
- fi
- # The real first argument should be the name of the installation program.
- arg=`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$install_prog$arg"
- # We need to accept at least all the BSD install flags.
- dest=
- files=
- opts=
- prev=
- install_type=
- isdir=no
- stripme=
- for arg
- do
- if test -n "$dest"; then
- files="$files $dest"
- dest="$arg"
- continue
- fi
- case $arg in
- -d) isdir=yes ;;
- -f) prev="-f" ;;
- -g) prev="-g" ;;
- -m) prev="-m" ;;
- -o) prev="-o" ;;
- -s)
- stripme=" -s"
- continue
- # If the previous option needed an argument, then skip it.
- if test -n "$prev"; then
- prev=
- else
- dest="$arg"
- continue
- fi
- esac
- # Aesthetically quote the argument.
- case $arg in
- arg="\"$arg\""
- esac
- install_prog="$install_prog $arg"
- done
- if test -z "$install_prog"; then
- $echo "$modename: you must specify an install program" 1>&2
- $echo "$help" 1>&2
- exit 1
- fi
- $echo "$modename: the \`$prev' option requires an argument" 1>&2
- exit 1
- fi
- if test -z "$files"; then
- if test -z "$dest"; then
- $echo "$modename: no file or destination specified" 1>&2
- else
- $echo "$modename: you must specify a destination" 1>&2
- fi
- exit 1
- fi
- # Strip any trailing slash from the destination.
- dest=`$echo "X$dest" | $Xsed -e 's%/$%%'`
- # Check to see that the destination is a directory.
- test -d "$dest" && isdir=yes
- if test "$isdir" = yes; then
- destdir="$dest"
- destname=
- else
- destdir=`$echo "X$dest" | $Xsed -e 's%/[^/]*$%%'`
- test "X$destdir" = "X$dest" && destdir=.
- destname=`$echo "X$dest" | $Xsed -e 's%^.*/%%'`
- # Not a directory, so check to see that there is only one file specified.
- set dummy $files
- $echo "$modename: \`$dest' is not a directory" 1>&2
- exit 1
- fi
- fi
- case $destdir in
- [\\/]* | [A-Za-z]:[\\/]*) ;;
- for file in $files; do
- case $file in
- *.lo) ;;
- $echo "$modename: \`$destdir' must be an absolute directory name" 1>&2
- exit 1
- esac
- done
- esac
- # This variable tells wrapper scripts just to set variables rather
- # than running their programs.
- libtool_install_magic="$magic"
- staticlibs=
- future_libdirs=
- current_libdirs=
- # Do each installation.
- case $file in
- *.$libext)
- # Do the static libraries later.
- staticlibs="$staticlibs $file"
- *.la)
- # Check to see that this really is a libtool archive.
- if (${SED} -e '2q' $file | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then :
- else
- $echo "$modename: \`$file' is not a valid libtool archive" 1>&2
- exit 1
- fi
- library_names=
- old_library=
- relink_command=
- # If there is no directory component, then add one.
- case $file in
- */* | *\\*) . $file ;;
- *) . ./$file ;;
- esac
- # Add the libdir to current_libdirs if it is the destination.
- if test "X$destdir" = "X$libdir"; then
- case "$current_libdirs " in
- *" $libdir "*) ;;
- *) current_libdirs="$current_libdirs $libdir" ;;
- esac
- else
- # Note the libdir as a future libdir.
- case "$future_libdirs " in
- *" $libdir "*) ;;
- *) future_libdirs="$future_libdirs $libdir" ;;
- esac
- fi
- dir=`$echo "X$file" | $Xsed -e 's%/[^/]*$%%'`/
- test "X$dir" = "X$file/" && dir=
- dir="$dir$objdir"
- # Determine the prefix the user has applied to our future dir.
- inst_prefix_dir=`$echo "$destdir" | $SED "s%$libdir\$%%"`
- # Don't allow the user to place us outside of our expected
- # location b/c this prevents finding dependent libraries that
- # are installed to the same prefix.
- # At present, this check doesn't affect windows .dll's that
- # are installed into $libdir/../bin (currently, that works fine)
- # but it's something to keep an eye on.
- if test "$inst_prefix_dir" = "$destdir"; then
- $echo "$modename: error: cannot install \`$file' to a directory not ending in $libdir" 1>&2
- exit 1
- fi
- if test -n "$inst_prefix_dir"; then
- # Stick the inst_prefix_dir data into the link command.
- relink_command=`$echo "$relink_command" | $SED "s%@inst_prefix_dir@%-inst-prefix-dir $inst_prefix_dir%"`
- else
- relink_command=`$echo "$relink_command" | $SED "s%@inst_prefix_dir@%%"`
- fi
- $echo "$modename: warning: relinking \`$file'" 1>&2
- $show "$relink_command"
- if $run eval "$relink_command"; then :
- else
- $echo "$modename: error: relink \`$file' with the above command before installing it" 1>&2
- exit 1
- fi
- fi
- # See the names of the shared library.
- set dummy $library_names
- if test -n "$2"; then
- realname="$2"
- shift
- shift
- srcname="$realname"
- test -n "$relink_command" && srcname="$realname"T
- # Install the shared library and build the symlinks.
- $show "$install_prog $dir/$srcname $destdir/$realname"
- $run eval "$install_prog $dir/$srcname $destdir/$realname" || exit $?
- if test -n "$stripme" && test -n "$striplib"; then
- $show "$striplib $destdir/$realname"
- $run eval "$striplib $destdir/$realname" || exit $?
- fi
- if test "$#" -gt 0; then
- # Delete the old symlinks, and create new ones.
- for linkname
- do
- if test "$linkname" != "$realname"; then
- $show "(cd $destdir && $rm $linkname && $LN_S $realname $linkname)"
- $run eval "(cd $destdir && $rm $linkname && $LN_S $realname $linkname)"
- fi
- done
- fi
- # Do each command in the postinstall commands.
- lib="$destdir/$realname"
- eval cmds=\"$postinstall_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- fi
- # Install the pseudo-library for information purposes.
- name=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
- instname="$dir/$name"i
- $show "$install_prog $instname $destdir/$name"
- $run eval "$install_prog $instname $destdir/$name" || exit $?
- # Maybe install the static library, too.
- test -n "$old_library" && staticlibs="$staticlibs $dir/$old_library"
- *.lo)
- # Install (i.e. copy) a libtool object.
- # Figure out destination file name, if it wasn't already specified.
- if test -n "$destname"; then
- destfile="$destdir/$destname"
- else
- destfile=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
- destfile="$destdir/$destfile"
- fi
- # Deduce the name of the destination old-style object file.
- case $destfile in
- *.lo)
- staticdest=`$echo "X$destfile" | $Xsed -e "$lo2o"`
- *.$objext)
- staticdest="$destfile"
- destfile=
- $echo "$modename: cannot copy a libtool object to \`$destfile'" 1>&2
- exit 1
- esac
- # Install the libtool object if requested.
- if test -n "$destfile"; then
- $show "$install_prog $file $destfile"
- $run eval "$install_prog $file $destfile" || exit $?
- fi
- # Install the old object if enabled.
- if test "$build_old_libs" = yes; then
- # Deduce the name of the old-style object file.
- staticobj=`$echo "X$file" | $Xsed -e "$lo2o"`
- $show "$install_prog $staticobj $staticdest"
- $run eval "$install_prog \$staticobj \$staticdest" || exit $?
- fi
- exit 0
- else
- fi
- # If the file is missing, and there is a .exe on the end, strip it
- # because it is most likely a libtool script we actually want to
- # install
- stripped_ext=""
- case $file in
- *.exe)
- if test ! -f "$file"; then
- file=`$echo $file|${SED} 's,.exe$,,'`
- stripped_ext=".exe"
- fi
- esac
- # Do a test to see if this is really a libtool program.
- case $host in
- *cygwin*|*mingw*)
- wrapper=`$echo $file | ${SED} -e 's,.exe$,,'`
- wrapper=$file
- esac
- if (${SED} -e '4q' $wrapper | grep "^# Generated by .*$PACKAGE")>/dev/null 2>&1; then
- notinst_deplibs=
- relink_command=
- # To insure that "foo" is sourced, and not "foo.exe",
- # finese the cygwin/MSYS system by explicitly sourcing "foo."
- # which disallows the automatic-append-.exe behavior.
- case $build in
- *cygwin* | *mingw*) wrapperdot=${wrapper}. ;;
- *) wrapperdot=${wrapper} ;;
- esac
- case $file in
- */* | *\\*) . ${wrapperdot} ;;
- *) . ./${wrapperdot} ;;
- esac
- # Check the variables that should have been set.
- if test -z "$notinst_deplibs"; then
- $echo "$modename: invalid libtool wrapper script \`$wrapper'" 1>&2
- exit 1
- fi
- finalize=yes
- for lib in $notinst_deplibs; do
- # Check to see that each library is installed.
- libdir=
- if test -f "$lib"; then
- case $lib in
- */* | *\\*) . $lib ;;
- *) . ./$lib ;;
- esac
- fi
- libfile="$libdir/"`$echo "X$lib" | $Xsed -e 's%^.*/%%g'` ### testsuite: skip nested quoting test
- if test -n "$libdir" && test ! -f "$libfile"; then
- $echo "$modename: warning: \`$lib' has not been installed in \`$libdir'" 1>&2
- finalize=no
- fi
- done
- relink_command=
- case $build in
- esac
- case $file in
- esac
- outputname=
- if test "$fast_install" = no && test -n "$relink_command"; then
- if test "$finalize" = yes && test -z "$run"; then
- tmpdir="/tmp"
- test -n "$TMPDIR" && tmpdir="$TMPDIR"
- tmpdir="$tmpdir/libtool-$$"
- if $mkdir -p "$tmpdir" && chmod 700 "$tmpdir"; then :
- else
- $echo "$modename: error: cannot create temporary directory \`$tmpdir'" 1>&2
- continue
- fi
- file=`$echo "X$file$stripped_ext" | $Xsed -e 's%^.*/%%'`
- outputname="$tmpdir/$file"
- relink_command=`$echo "X$relink_command" | $Xsed -e 's%@OUTPUT@%'"$outputname"'%g'`
- else
- ${rm}r "$tmpdir"
- continue
- fi
- file="$outputname"
- else
- $echo "$modename: warning: cannot relink \`$file'" 1>&2
- fi
- else
- # Install the binary that we compiled earlier.
- file=`$echo "X$file$stripped_ext" | $Xsed -e "s%\([^/]*\)$%$objdir/\1%"`
- fi
- fi
- # remove .exe since cygwin /usr/bin/install will append another
- # one anyways
- case $install_prog,$host in
- */usr/bin/install*,*cygwin*)
- case $file:$destfile in
- *.exe:*.exe)
- # this is ok
- *.exe:*)
- destfile=$destfile.exe
- *:*.exe)
- destfile=`$echo $destfile | ${SED} -e 's,.exe$,,'`
- esac
- esac
- $show "$install_prog$stripme $file $destfile"
- $run eval "$install_prog\$stripme \$file \$destfile" || exit $?
- test -n "$outputname" && ${rm}r "$tmpdir"
- esac
- done
- for file in $staticlibs; do
- # Set up the ranlib parameters.
- oldlib="$destdir/$name"
- $show "$install_prog $file $oldlib"
- $run eval "$install_prog \$file \$oldlib" || exit $?
- $show "$old_striplib $oldlib"
- $run eval "$old_striplib $oldlib" || exit $?
- fi
- eval cmds=\"$old_postinstall_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- done
- IFS="$save_ifs"
- done
- if test -n "$future_libdirs"; then
- $echo "$modename: warning: remember to run \`$progname --finish$future_libdirs'" 1>&2
- fi
- if test -n "$current_libdirs"; then
- # Maybe just do a dry run.
- test -n "$run" && current_libdirs=" -n$current_libdirs"
- exec_cmd='$SHELL $0 --finish$current_libdirs'
- else
- exit 0
- fi
- # libtool finish mode
- finish)
- modename="$modename: finish"
- libdirs="$nonopt"
- admincmds=
- if test -n "$finish_cmds$finish_eval" && test -n "$libdirs"; then
- for dir
- do
- libdirs="$libdirs $dir"
- done
- for libdir in $libdirs; do
- if test -n "$finish_cmds"; then
- # Do each command in the finish commands.
- eval cmds=\"$finish_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd" || admincmds="$admincmds
- $cmd"
- done
- IFS="$save_ifs"
- fi
- if test -n "$finish_eval"; then
- # Do the single finish_eval.
- eval cmds=\"$finish_eval\"
- $run eval "$cmds" || admincmds="$admincmds
- $cmds"
- fi
- done
- fi
- # Exit here if they wanted silent mode.
- exit 0
- $echo "----------------------------------------------------------------------"
- $echo "Libraries have been installed in:"
- $echo " $libdir"
- done
- $echo
- $echo "If you ever happen to want to link against installed libraries"
- $echo "in a given directory, LIBDIR, you must either use libtool, and"
- $echo "specify the full pathname of the library, or use the \`-LLIBDIR'"
- $echo "flag during linking and do at least one of the following:"
- $echo " - add LIBDIR to the \`$shlibpath_var' environment variable"
- $echo " during execution"
- fi
- $echo " - add LIBDIR to the \`$runpath_var' environment variable"
- $echo " during linking"
- fi
- libdir=LIBDIR
- $echo " - use the \`$flag' linker flag"
- fi
- if test -n "$admincmds"; then
- $echo " - have your system administrator run these commands:$admincmds"
- fi
- if test -f /etc/ld.so.conf; then
- $echo " - have your system administrator add LIBDIR to \`/etc/ld.so.conf'"
- fi
- $echo
- $echo "See any operating system documentation about shared libraries for"
- $echo "more information, such as the ld(1) and ld.so(8) manual pages."
- exit 0
- # libtool execute mode
- execute)
- modename="$modename: execute"
- # The first argument is the command name.
- cmd="$nonopt"
- if test -z "$cmd"; then
- $echo "$modename: you must specify a COMMAND" 1>&2
- $echo "$help"
- exit 1
- fi
- # Handle -dlopen flags immediately.
- for file in $execute_dlfiles; do
- $echo "$modename: \`$file' is not a file" 1>&2
- exit 1
- fi
- dir=
- case $file in
- *.la)
- else
- exit 1
- fi
- # Read the libtool library.
- dlname=
- library_names=
- case $file in
- *) . ./$file ;;
- esac
- # Skip this library if it cannot be dlopened.
- # Warn if it was a shared library.
- test -n "$library_names" && $echo "$modename: warning: \`$file' was not linked with \`-export-dynamic'"
- continue
- fi
- test "X$dir" = "X$file" && dir=.
- if test -f "$dir/$objdir/$dlname"; then
- dir="$dir/$objdir"
- else
- $echo "$modename: cannot find \`$dlname' in \`$dir' or \`$dir/$objdir'" 1>&2
- exit 1
- fi
- *.lo)
- # Just add the directory containing the .lo file.
- $echo "$modename: warning \`-dlopen' is ignored for non-libtool libraries and objects" 1>&2
- continue
- esac
- # Get the absolute pathname.
- absdir=`cd "$dir" && pwd`
- test -n "$absdir" && dir="$absdir"
- # Now add the directory to shlibpath_var.
- if eval "test -z \"\$$shlibpath_var\""; then
- eval "$shlibpath_var=\"\$dir\""
- else
- eval "$shlibpath_var=\"\$dir:\$$shlibpath_var\""
- fi
- done
- # This variable tells wrapper scripts just to set shlibpath_var
- # rather than running their programs.
- libtool_execute_magic="$magic"
- # Check if any of the arguments is a wrapper script.
- args=
- for file
- do
- case $file in
- if (${SED} -e '4q' $file | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
- case $file in
- *) . ./$file ;;
- esac
- # Transform arg to wrapped name.
- file="$progdir/$program"
- fi
- esac
- # Quote arguments (to preserve shell metacharacters).
- file=`$echo "X$file" | $Xsed -e "$sed_quote_subst"`
- args="$args \"$file\""
- done
- # Export the shlibpath_var.
- eval "export $shlibpath_var"
- fi
- # Restore saved environment variables
- if test "${save_LC_ALL+set}" = set; then
- LC_ALL="$save_LC_ALL"; export LC_ALL
- fi
- if test "${save_LANG+set}" = set; then
- LANG="$save_LANG"; export LANG
- fi
- # Now prepare to actually exec the command.
- exec_cmd="\$cmd$args"
- else
- # Display what would be done.
- eval "\$echo \"\$shlibpath_var=\$$shlibpath_var\""
- $echo "export $shlibpath_var"
- fi
- $echo "$cmd$args"
- exit 0
- fi
- # libtool clean and uninstall mode
- clean | uninstall)
- modename="$modename: $mode"
- rm="$nonopt"
- files=
- rmforce=
- exit_status=0
- for arg
- do
- case $arg in
- -f) rm="$rm $arg"; rmforce=yes ;;
- -*) rm="$rm $arg" ;;
- *) files="$files $arg" ;;
- esac
- done
- if test -z "$rm"; then
- $echo "$modename: you must specify an RM program" 1>&2
- exit 1
- fi
- rmdirs=
- origobjdir="$objdir"
- if test "X$dir" = "X$file"; then
- dir=.
- objdir="$origobjdir"
- else
- objdir="$dir/$origobjdir"
- fi
- test "$mode" = uninstall && objdir="$dir"
- # Remember objdir for removal later, being careful to avoid duplicates
- if test "$mode" = clean; then
- case " $rmdirs " in
- *" $objdir "*) ;;
- *) rmdirs="$rmdirs $objdir" ;;
- esac
- fi
- # Don't error if the file doesn't exist and rm -f was used.
- if (test -L "$file") >/dev/null 2>&1 \
- || (test -h "$file") >/dev/null 2>&1 \
- || test -f "$file"; then
- elif test -d "$file"; then
- exit_status=1
- continue
- elif test "$rmforce" = yes; then
- continue
- fi
- rmfiles="$file"
- case $name in
- *.la)
- # Possibly a libtool archive, so verify it.
- . $dir/$name
- # Delete the libtool libraries and symlinks.
- for n in $library_names; do
- rmfiles="$rmfiles $objdir/$n"
- done
- test -n "$old_library" && rmfiles="$rmfiles $objdir/$old_library"
- test "$mode" = clean && rmfiles="$rmfiles $objdir/$name $objdir/${name}i"
- if test "$mode" = uninstall; then
- if test -n "$library_names"; then
- # Do each command in the postuninstall commands.
- eval cmds=\"$postuninstall_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd"
- if test "$?" -ne 0 && test "$rmforce" != yes; then
- exit_status=1
- fi
- done
- IFS="$save_ifs"
- fi
- if test -n "$old_library"; then
- # Do each command in the old_postuninstall commands.
- eval cmds=\"$old_postuninstall_cmds\"
- IFS="$save_ifs"
- $show "$cmd"
- $run eval "$cmd"
- exit_status=1
- fi
- done
- IFS="$save_ifs"
- fi
- # FIXME: should reinstall the best remaining shared library.
- fi
- fi
- *.lo)
- # Possibly a libtool object, so verify it.
- # Read the .lo file
- . $dir/$name
- # Add PIC object to the list of files to remove.
- if test -n "$pic_object" \
- && test "$pic_object" != none; then
- rmfiles="$rmfiles $dir/$pic_object"
- fi
- # Add non-PIC object to the list of files to remove.
- if test -n "$non_pic_object" \
- && test "$non_pic_object" != none; then
- rmfiles="$rmfiles $dir/$non_pic_object"
- fi
- fi
- if test "$mode" = clean ; then
- noexename=$name
- case $file in
- *.exe)
- noexename=`$echo $name|${SED} 's,.exe$,,'`
- # $file with .exe has already been added to rmfiles,
- # add $file without .exe
- rmfiles="$rmfiles $file"
- esac
- # Do a test to see if this is a libtool program.
- relink_command=
- . $dir/$noexename
- # note $name still contains .exe if it was in $file originally
- # as does the version of $file that was added into $rmfiles
- rmfiles="$rmfiles $objdir/$name $objdir/${name}S.${objext}"
- if test "$fast_install" = yes && test -n "$relink_command"; then
- rmfiles="$rmfiles $objdir/lt-$name"
- fi
- if test "X$noexename" != "X$name" ; then
- rmfiles="$rmfiles $objdir/lt-${noexename}.c"
- fi
- fi
- fi
- esac
- $show "$rm $rmfiles"
- $run $rm $rmfiles || exit_status=1
- done
- # Try to remove the ${objdir}s in the directories where we deleted files
- for dir in $rmdirs; do
- if test -d "$dir"; then
- $show "rmdir $dir"
- $run rmdir $dir >/dev/null 2>&1
- fi
- done
- exit $exit_status
- $echo "$modename: you must specify a MODE" 1>&2
- $echo "$generic_help" 1>&2
- exit 1
- esac
- if test -z "$exec_cmd"; then
- $echo "$modename: invalid operation mode \`$mode'" 1>&2
- exit 1
- fi
-fi # test -z "$show_help"
-if test -n "$exec_cmd"; then
- eval exec $exec_cmd
- exit 1
-fi
-# We need to display help for each of the modes.
-case $mode in
-"") $echo \
-"Usage: $modename [OPTION]... [MODE-ARG]...
-Provide generalized library-building support services.
- --config show all configuration variables
- --debug enable verbose shell tracing
--n, --dry-run display commands without modifying any files
- --features display basic configuration information and exit
- --finish same as \`--mode=finish'
- --help display this help message and exit
- --mode=MODE use operation mode MODE [default=inferred from MODE-ARGS]
- --quiet same as \`--silent'
- --silent don't print informational messages
- --tag=TAG use configuration variables from tag TAG
- --version print version information
-MODE must be one of the following:
- clean remove files from the build directory
- compile compile a source file into a libtool object
- execute automatically set library path, then run a program
- finish complete the installation of libtool libraries
- install install libraries or executables
- link create a library or an executable
- uninstall remove libraries from an installed directory
-MODE-ARGS vary depending on the MODE. Try \`$modename --help --mode=MODE' for
-a more detailed description of MODE.
-Report bugs to <bug-libtool at gnu.org>."
- exit 0
-clean)
- $echo \
-"Usage: $modename [OPTION]... --mode=clean RM [RM-OPTION]... FILE...
-Remove files from the build directory.
-RM is the name of the program to use to delete files associated with each FILE
-(typically \`/bin/rm'). RM-OPTIONS are options (such as \`-f') to be passed
-to RM.
-If FILE is a libtool library, object or program, all the files associated
-with it are deleted. Otherwise, only FILE itself is deleted using RM."
-compile)
- $echo \
-"Usage: $modename [OPTION]... --mode=compile COMPILE-COMMAND... SOURCEFILE
-Compile a source file into a libtool library object.
-This mode accepts the following additional options:
- -o OUTPUT-FILE set the output file name to OUTPUT-FILE
- -prefer-pic try to building PIC objects only
- -prefer-non-pic try to building non-PIC objects only
- -static always build a \`.o' file suitable for static linking
-COMPILE-COMMAND is a command to be used in creating a \`standard' object file
-from the given SOURCEFILE.
-The output file name is determined by removing the directory component from
-SOURCEFILE, then substituting the C source code suffix \`.c' with the
-library object suffix, \`.lo'."
-execute)
- $echo \
-"Usage: $modename [OPTION]... --mode=execute COMMAND [ARGS]...
-Automatically set library path, then run a program.
- -dlopen FILE add the directory containing FILE to the library path
-This mode sets the library path environment variable according to \`-dlopen'
-flags.
-If any of the ARGS are libtool executable wrappers, then they are translated
-into their corresponding uninstalled binary, and any of their required library
-directories are added to the library path.
-Then, COMMAND is executed, with ARGS as arguments."
-finish)
- $echo \
-"Usage: $modename [OPTION]... --mode=finish [LIBDIR]...
-Complete the installation of libtool libraries.
-Each LIBDIR is a directory that contains libtool libraries.
-The commands that this mode executes may require superuser privileges. Use
-the \`--dry-run' option if you just want to see what would be executed."
-install)
- $echo \
-"Usage: $modename [OPTION]... --mode=install INSTALL-COMMAND...
-Install executables or libraries.
-INSTALL-COMMAND is the installation command. The first component should be
-either the \`install' or \`cp' program.
-The rest of the components are interpreted as arguments to that command (only
-BSD-compatible install options are recognized)."
-link)
- $echo \
-"Usage: $modename [OPTION]... --mode=link LINK-COMMAND...
-Link object files or libraries together to form another library, or to
-create an executable program.
-LINK-COMMAND is a command using the C compiler that you would use to create
-a program from several object files.
-The following components of LINK-COMMAND are treated specially:
- -all-static do not do any dynamic linking at all
- -avoid-version do not add a version suffix if possible
- -dlopen FILE \`-dlpreopen' FILE if it cannot be dlopened at runtime
- -dlpreopen FILE link in FILE and add its symbols to lt_preloaded_symbols
- -export-dynamic allow symbols from OUTPUT-FILE to be resolved with dlsym(3)
- -export-symbols SYMFILE
- try to export only the symbols listed in SYMFILE
- -export-symbols-regex REGEX
- try to export only the symbols matching REGEX
- -LLIBDIR search LIBDIR for required installed libraries
- -lNAME OUTPUT-FILE requires the installed library libNAME
- -module build a library that can dlopened
- -no-fast-install disable the fast-install mode
- -no-install link a not-installable executable
- -no-undefined declare that a library does not refer to external symbols
- -o OUTPUT-FILE create OUTPUT-FILE from the specified objects
- -objectlist FILE Use a list of object files found in FILE to specify objects
- -release RELEASE specify package release information
- -rpath LIBDIR the created library will eventually be installed in LIBDIR
- -R[ ]LIBDIR add LIBDIR to the runtime path of programs and libraries
- -static do not do any dynamic linking of libtool libraries
- -version-info CURRENT[:REVISION[:AGE]]
- specify library version info [each variable defaults to 0]
-All other options (arguments beginning with \`-') are ignored.
-Every other argument is treated as a filename. Files ending in \`.la' are
-treated as uninstalled libtool libraries, other files are standard or library
-object files.
-If the OUTPUT-FILE ends in \`.la', then a libtool library is created,
-only library objects (\`.lo' files) may be specified, and \`-rpath' is
-required, except when creating a convenience library.
-If OUTPUT-FILE ends in \`.a' or \`.lib', then a standard library is created
-using \`ar' and \`ranlib', or on Windows using \`lib'.
-If OUTPUT-FILE ends in \`.lo' or \`.${objext}', then a reloadable object file
-is created, otherwise an executable program is created."
-uninstall)
- $echo \
-"Usage: $modename [OPTION]... --mode=uninstall RM [RM-OPTION]... FILE...
-Remove libraries from an installation directory.
-to RM.
-If FILE is a libtool library, all the files associated with it are deleted.
-Otherwise, only FILE itself is deleted using RM."
- exit 1
-esac
-$echo
-$echo "Try \`$modename --help' for more information about other modes."
-exit 0
-# The TAGs below are defined such that we never get into a situation
-# in which we disable both kinds of libraries. Given conflicting
-# choices, we go for a static library, that is the most portable,
-# since we can't tell whether shared libraries were disabled because
-# the user asked for that or because the platform doesn't support
-# them. This is particularly important on AIX, because we don't
-# support having both static and shared libraries enabled at the same
-# time on that platform, so we default to a shared-only configuration.
-# If a disable-shared tag is given, we'll fallback to a static-only
-# configuration. But we'll never go from static-only to shared-only.
-# ### BEGIN LIBTOOL TAG CONFIG: disable-shared
-build_libtool_libs=no
-build_old_libs=yes
-# ### END LIBTOOL TAG CONFIG: disable-shared
-# ### BEGIN LIBTOOL TAG CONFIG: disable-static
-build_old_libs=`case $build_libtool_libs in yes) $echo no;; *) $echo yes;; esac`
-# ### END LIBTOOL TAG CONFIG: disable-static
-# Local Variables:
-# mode:shell-script
-# sh-indentation:2
-# End:
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ltmain.sh (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ltmain.sh)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ltmain.sh (rev 0)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/ltmain.sh 2013-02-15 12:16:10 UTC (rev 7356)
@@ -0,0 +1,6343 @@
+# ltmain.sh - Provide generalized library-building support services.
+# NOTE: Changing this file will not affect anything until you rerun configure.
+# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001, 2003
+# Free Software Foundation, Inc.
+# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful, but
+# WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+# General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+# As a special exception to the GNU General Public License, if you
+# distribute this file as part of a program that contains a
+# configuration script generated by Autoconf, you may include it under
+# the same distribution terms that you use for the rest of that program.
+# Check that we have a working $echo.
+if test "X$1" = X--no-reexec; then
+ # Discard the --no-reexec flag, and continue.
+ shift
+elif test "X$1" = X--fallback-echo; then
+ # Avoid inline document here, it may be left over
+elif test "X`($echo '\t') 2>/dev/null`" = 'X\t'; then
+ # Yippee, $echo works!
+else
+ # Restart under the correct shell, and then maybe $echo will work.
+ exec $SHELL "$0" --no-reexec ${1+"$@"}
+fi
+if test "X$1" = X--fallback-echo; then
+ # used as fallback echo
+ shift
+ cat <<EOF
+EOF
+ exit 0
+fi
+# The name of this program.
+progname=`$echo "$0" | ${SED} 's%^.*/%%'`
+modename="$progname"
+# Constants.
+PROGRAM=ltmain.sh
+PACKAGE=libtool
+VERSION=1.5a
+TIMESTAMP=" (1.1240 2003/06/26 06:55:19)"
+default_mode=
+help="Try \`$progname --help' for more information."
+magic="%%%MAGIC variable%%%"
+mkdir="mkdir"
+mv="mv -f"
+rm="rm -f"
+# Sed substitution that helps us do robust quoting. It backslashifies
+# metacharacters that are still active within double-quoted strings.
+Xsed="${SED}"' -e 1s/^X//'
+sed_quote_subst='s/\([\\`\\"$\\\\]\)/\\\1/g'
+# test EBCDIC or ASCII
+case `echo A|tr A '\301'` in
+ A) # EBCDIC based system
+ SP2NL="tr '\100' '\n'"
+ NL2SP="tr '\r\n' '\100\100'"
+ *) # Assume ASCII based system
+ SP2NL="tr '\040' '\012'"
+ NL2SP="tr '\015\012' '\040\040'"
+esac
+# NLS nuisances.
+# Only set LANG and LC_ALL to C if already set.
+# These must not be set unconditionally because not all systems understand
+# e.g. LANG=C (notably SCO).
+# We save the old values to restore during execute mode.
+if test "${LC_ALL+set}" = set; then
+ save_LC_ALL="$LC_ALL"; LC_ALL=C; export LC_ALL
+fi
+if test "${LANG+set}" = set; then
+ save_LANG="$LANG"; LANG=C; export LANG
+fi
+# Make sure IFS has a sensible default
+: ${IFS=" "}
+if test "$build_libtool_libs" != yes && test "$build_old_libs" != yes; then
+ $echo "$modename: not configured to build any kind of library" 1>&2
+ $echo "Fatal configuration error. See the $PACKAGE docs for more information." 1>&2
+ exit 1
+fi
+# Global variables.
+mode=$default_mode
+nonopt=
+prev=
+prevopt=
+run=
+show="$echo"
+show_help=
+execute_dlfiles=
+lo2o="s/\\.lo\$/.${objext}/"
+o2lo="s/\\.${objext}\$/.lo/"
+# Shell function definitions:
+# This seems to be the best place for them
+# Need a lot of goo to handle *both* DLLs and import libs
+# Has to be a shell function in order to 'eat' the argument
+# that is supplied when $file_magic_command is called.
+win32_libid () {
+ win32_libid_type="unknown"
+ win32_fileres=`file -L $1 2>/dev/null`
+ case $win32_fileres in
+ *ar\ archive\ import\ library*) # definitely import
+ win32_libid_type="x86 archive import"
+ *ar\ archive*) # could be an import, or static
+ if eval $OBJDUMP -f $1 | $SED -e '10q' 2>/dev/null | \
+ grep -E 'file format pe-i386(.*architecture: i386)?' >/dev/null ; then
+ win32_nmres=`eval $NM -f posix -A $1 | \
+ sed -n -e '1,100{/ I /{x;/import/!{s/^/import/;h;p;};x;};}'`
+ if test "X$win32_nmres" = "Ximport" ; then
+ else
+ win32_libid_type="x86 archive static"
+ fi
+ fi
+ *DLL*)
+ win32_libid_type="x86 DLL"
+ *executable*) # but shell scripts are "executable" too...
+ *MS\ Windows\ PE\ Intel*)
+ esac
+ esac
+ $echo $win32_libid_type
+# End of Shell function definitions
+# Parse our command line options once, thoroughly.
+while test "$#" -gt 0
+do
+ arg="$1"
+ shift
+ case $arg in
+ -*=*) optarg=`$echo "X$arg" | $Xsed -e 's/[-_a-zA-Z0-9]*=//'` ;;
+ *) optarg= ;;
+ esac
+ # If the previous option needs an argument, assign it.
+ if test -n "$prev"; then
+ case $prev in
+ execute_dlfiles)
+ execute_dlfiles="$execute_dlfiles $arg"
+ tag)
+ tagname="$arg"
+ # Check whether tagname contains only valid characters
+ case $tagname in
+ *[!-_A-Za-z0-9,/]*)
+ $echo "$progname: invalid tag name: $tagname" 1>&2
+ exit 1
+ esac
+ case $tagname in
+ CC)
+ # Don't test for the "default" C tag, as we know, it's there, but
+ # not specially marked.
+ if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "$0" > /dev/null; then
+ taglist="$taglist $tagname"
+ # Evaluate the configuration.
+ eval "`${SED} -n -e '/^# ### BEGIN LIBTOOL TAG CONFIG: '$tagname'$/,/^# ### END LIBTOOL TAG CONFIG: '$tagname'$/p' < $0`"
+ else
+ $echo "$progname: ignoring unknown tag $tagname" 1>&2
+ fi
+ esac
+ eval "$prev=\$arg"
+ esac
+ prev=
+ prevopt=
+ continue
+ fi
+ # Have we seen a non-optional argument yet?
+ case $arg in
+ --help)
+ show_help=yes
+ --version)
+ $echo "$PROGRAM (GNU $PACKAGE) $VERSION$TIMESTAMP"
+ $echo
+ $echo "Copyright (C) 2003 Free Software Foundation, Inc."
+ $echo "This is free software; see the source for copying conditions. There is NO"
+ $echo "warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
+ exit 0
+ --config)
+ ${SED} -e '1,/^# ### BEGIN LIBTOOL CONFIG/d' -e '/^# ### END LIBTOOL CONFIG/,$d' $0
+ # Now print the configurations for the tags.
+ for tagname in $taglist; do
+ ${SED} -n -e "/^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$/,/^# ### END LIBTOOL TAG CONFIG: $tagname$/p" < "$0"
+ done
+ exit 0
+ --debug)
+ $echo "$progname: enabling shell trace mode"
+ set -x
+ --dry-run | -n)
+ run=:
+ --features)
+ $echo "host: $host"
+ if test "$build_libtool_libs" = yes; then
+ $echo "enable shared libraries"
+ else
+ $echo "disable shared libraries"
+ fi
+ if test "$build_old_libs" = yes; then
+ $echo "enable static libraries"
+ else
+ $echo "disable static libraries"
+ fi
+ exit 0
+ --finish) mode="finish" ;;
+ --mode) prevopt="--mode" prev=mode ;;
+ --mode=*) mode="$optarg" ;;
+ --preserve-dup-deps) duplicate_deps="yes" ;;
+ --quiet | --silent)
+ show=:
+ --tag) prevopt="--tag" prev=tag ;;
+ --tag=*)
+ set tag "$optarg" ${1+"$@"}
+ shift
+ prev=tag
+ -dlopen)
+ prevopt="-dlopen"
+ prev=execute_dlfiles
+ $echo "$modename: unrecognized option \`$arg'" 1>&2
+ $echo "$help" 1>&2
+ exit 1
+ nonopt="$arg"
+ break
+ esac
+done
+if test -n "$prevopt"; then
+ $echo "$modename: option \`$prevopt' requires an argument" 1>&2
+ exit 1
+fi
+# If this variable is set in any of the actions, the command in it
+# will be execed at the end. This prevents here-documents from being
+# left over by shells.
+exec_cmd=
+if test -z "$show_help"; then
+ # Infer the operation mode.
+ if test -z "$mode"; then
+ $echo "*** Warning: inferring the mode of operation is deprecated." 1>&2
+ $echo "*** Future versions of Libtool will require -mode=MODE be specified." 1>&2
+ case $nonopt in
+ *cc | cc* | *++ | gcc* | *-gcc* | g++* | xlc*)
+ mode=link
+ for arg
+ do
+ case $arg in
+ -c)
+ mode=compile
+ break
+ esac
+ done
+ *db | *dbx | *strace | *truss)
+ mode=execute
+ *install*|cp|mv)
+ mode=install
+ *rm)
+ mode=uninstall
+ # If we have no mode, but dlfiles were specified, then do execute mode.
+ test -n "$execute_dlfiles" && mode=execute
+ # Just use the default operation mode.
+ if test -n "$nonopt"; then
+ $echo "$modename: warning: cannot infer operation mode from \`$nonopt'" 1>&2
+ else
+ $echo "$modename: warning: cannot infer operation mode without MODE-ARGS" 1>&2
+ fi
+ fi
+ esac
+ fi
+ # Only execute mode is allowed to have -dlopen flags.
+ if test -n "$execute_dlfiles" && test "$mode" != execute; then
+ $echo "$modename: unrecognized option \`-dlopen'" 1>&2
+ exit 1
+ fi
+ # Change the help message to a mode-specific one.
+ generic_help="$help"
+ help="Try \`$modename --help --mode=$mode' for more information."
+ # These modes are in order of execution frequency so that they run quickly.
+ case $mode in
+ # libtool compile mode
+ compile)
+ modename="$modename: compile"
+ # Get the compilation command and the source file.
+ base_compile=
+ srcfile="$nonopt" # always keep a non-empty value in "srcfile"
+ suppress_output=
+ arg_mode=normal
+ libobj=
+ for arg
+ do
+ case "$arg_mode" in
+ arg )
+ # do not "continue". Instead, add this to base_compile
+ lastarg="$arg"
+ arg_mode=normal
+ target )
+ libobj="$arg"
+ arg_mode=normal
+ continue
+ normal )
+ # Accept any command-line options.
+ case $arg in
+ -o)
+ if test -n "$libobj" ; then
+ $echo "$modename: you cannot specify \`-o' more than once" 1>&2
+ exit 1
+ fi
+ arg_mode=target
+ continue
+ -static)
+ build_old_libs=yes
+ continue
+ -prefer-pic)
+ pic_mode=yes
+ continue
+ -prefer-non-pic)
+ pic_mode=no
+ continue
+ -Xcompiler)
+ arg_mode=arg # the next one goes into the "base_compile" arg list
+ continue # The current "srcfile" will either be retained or
+ ;; # replaced later. I would guess that would be a bug.
+ -Wc,*)
+ args=`$echo "X$arg" | $Xsed -e "s/^-Wc,//"`
+ lastarg=
+ save_ifs="$IFS"; IFS=','
+ for arg in $args; do
+ IFS="$save_ifs"
+ # Double-quote args containing other shell metacharacters.
+ # Many Bourne shells cannot handle close brackets correctly
+ # in scan sets, so we specify it separately.
+ case $arg in
+ arg="\"$arg\""
+ esac
+ lastarg="$lastarg $arg"
+ done
+ IFS="$save_ifs"
+ lastarg=`$echo "X$lastarg" | $Xsed -e "s/^ //"`
+ # Add the arguments to base_compile.
+ base_compile="$base_compile $lastarg"
+ continue
+ # Accept the current argument as the source file.
+ # The previous "srcfile" becomes the current argument.
+ lastarg="$srcfile"
+ srcfile="$arg"
+ esac # case $arg
+ esac # case $arg_mode
+ # Aesthetically quote the previous argument.
+ lastarg=`$echo "X$lastarg" | $Xsed -e "$sed_quote_subst"`
+ case $lastarg in
+ lastarg="\"$lastarg\""
+ esac
+ done # for arg
+ case $arg_mode in
+ arg)
+ $echo "$modename: you must specify an argument for -Xcompile"
+ exit 1
+ target)
+ $echo "$modename: you must specify a target with \`-o'" 1>&2
+ exit 1
+ # Get the name of the library object.
+ [ -z "$libobj" ] && libobj=`$echo "X$srcfile" | $Xsed -e 's%^.*/%%'`
+ esac
+ # Recognize several different file suffixes.
+ # If the user specifies -o file.o, it is replaced with file.lo
+ xform='[cCFSifmso]'
+ case $libobj in
+ *.ada) xform=ada ;;
+ *.adb) xform=adb ;;
+ *.ads) xform=ads ;;
+ *.asm) xform=asm ;;
+ *.c++) xform=c++ ;;
+ *.cc) xform=cc ;;
+ *.ii) xform=ii ;;
+ *.class) xform=class ;;
+ *.cpp) xform=cpp ;;
+ *.cxx) xform=cxx ;;
+ *.f90) xform=f90 ;;
+ *.for) xform=for ;;
+ *.java) xform=java ;;
+ esac
+ libobj=`$echo "X$libobj" | $Xsed -e "s/\.$xform$/.lo/"`
+ case $libobj in
+ *.lo) obj=`$echo "X$libobj" | $Xsed -e "$lo2o"` ;;
+ $echo "$modename: cannot determine name of library object from \`$libobj'" 1>&2
+ exit 1
+ esac
+ # Infer tagged configuration to use if any are available and
+ # if one wasn't chosen via the "--tag" command line option.
+ # Only attempt this if the compiler in the base compile
+ # command doesn't match the default compiler.
+ if test -n "$available_tags" && test -z "$tagname"; then
+ case $base_compile in
+ # Blanks in the command may have been stripped by the calling shell,
+ # but not from the CC environment variable when configure was run.
+ " $CC "* | "$CC "* | " `$echo $CC` "* | "`$echo $CC` "*) ;;
+ # Blanks at the start of $base_compile will cause this to fail
+ # if we don't check for them as well.
+ for z in $available_tags; do
+ if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $z$" < "$0" > /dev/null; then
+ eval "`${SED} -n -e '/^# ### BEGIN LIBTOOL TAG CONFIG: '$z'$/,/^# ### END LIBTOOL TAG CONFIG: '$z'$/p' < $0`"
+ case "$base_compile " in
+ "$CC "* | " $CC "* | "`$echo $CC` "* | " `$echo $CC` "*)
+ # The compiler in the base compile command matches
+ # the one in the tagged configuration.
+ # Assume this is the tagged configuration we want.
+ tagname=$z
+ break
+ esac
+ fi
+ done
+ # If $tagname still isn't set, then no tagged configuration
+ # was found and let the user know that the "--tag" command
+ # line option must be used.
+ if test -z "$tagname"; then
+ $echo "$modename: unable to infer tagged configuration"
+ $echo "$modename: specify a tag with \`--tag'" 1>&2
+ exit 1
+# else
+# $echo "$modename: using $tagname tagged configuration"
+ fi
+ esac
+ fi
+ objname=`$echo "X$obj" | $Xsed -e 's%^.*/%%'`
+ xdir=`$echo "X$obj" | $Xsed -e 's%/[^/]*$%%'`
+ if test "X$xdir" = "X$obj"; then
+ xdir=
+ else
+ xdir=$xdir/
+ fi
+ lobj=${xdir}$objdir/$objname
+ if test -z "$base_compile"; then
+ $echo "$modename: you must specify a compilation command" 1>&2
+ exit 1
+ fi
+ # Delete any leftover library objects.
+ removelist="$obj $lobj $libobj ${libobj}T"
+ else
+ removelist="$lobj $libobj ${libobj}T"
+ fi
+ $run $rm $removelist
+ trap "$run $rm $removelist; exit 1" 1 2 15
+ # On Cygwin there's no "real" PIC flag so we must build both object types
+ case $host_os in
+ cygwin* | mingw* | pw32* | os2*)
+ pic_mode=default
+ esac
+ if test "$pic_mode" = no && test "$deplibs_check_method" != pass_all; then
+ # non-PIC code in shared libraries is not supported
+ pic_mode=default
+ fi
+ # Calculate the filename of the output object if compiler does
+ # not support -o with -c
+ if test "$compiler_c_o" = no; then
+ output_obj=`$echo "X$srcfile" | $Xsed -e 's%^.*/%%' -e 's%\.[^.]*$%%'`.${objext}
+ lockfile="$output_obj.lock"
+ removelist="$removelist $output_obj $lockfile"
+ else
+ output_obj=
+ need_locks=no
+ lockfile=
+ fi
+ # Lock this critical section if it is needed
+ # We use this script file to make the link, it avoids creating a new file
+ if test "$need_locks" = yes; then
+ until $run ln "$0" "$lockfile" 2>/dev/null; do
+ $show "Waiting for $lockfile to be removed"
+ sleep 2
+ done
+ elif test "$need_locks" = warn; then
+ if test -f "$lockfile"; then
+ $echo "\
+*** ERROR, $lockfile exists and contains:
+`cat $lockfile 2>/dev/null`
+This indicates that another process is trying to use the same
+temporary object file, and libtool could not work around it because
+your compiler does not support \`-c' and \`-o' together. If you
+repeat this compilation, it may succeed, by chance, but you had better
+avoid parallel builds (make -j) in this platform, or get a better
+compiler."
+ exit 1
+ fi
+ $echo $srcfile > "$lockfile"
+ fi
+ if test -n "$fix_srcfile_path"; then
+ eval srcfile=\"$fix_srcfile_path\"
+ fi
+ $run $rm "$libobj" "${libobj}T"
+ # Create a libtool object file (analogous to a ".la" file),
+ # but don't create it if we're doing a dry run.
+ test -z "$run" && cat > ${libobj}T <<EOF
+# $libobj - a libtool object file
+# Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP
+# Please DO NOT delete this file!
+# It is necessary for linking the library.
+# Name of the PIC object.
+EOF
+ # Only build a PIC object if we are building libtool libraries.
+ # Without this assignment, base_compile gets emptied.
+ fbsd_hideous_sh_bug=$base_compile
+ if test "$pic_mode" != no; then
+ command="$base_compile $srcfile $pic_flag"
+ else
+ # Don't build PIC code
+ command="$base_compile $srcfile"
+ fi
+ if test ! -d "${xdir}$objdir"; then
+ $show "$mkdir ${xdir}$objdir"
+ $run $mkdir ${xdir}$objdir
+ status=$?
+ if test "$status" -ne 0 && test ! -d "${xdir}$objdir"; then
+ exit $status
+ fi
+ fi
+ if test -z "$output_obj"; then
+ # Place PIC objects in $objdir
+ command="$command -o $lobj"
+ fi
+ $run $rm "$lobj" "$output_obj"
+ $show "$command"
+ if $run eval "$command"; then :
+ else
+ test -n "$output_obj" && $run $rm $removelist
+ exit 1
+ fi
+ if test "$need_locks" = warn &&
+ test "X`cat $lockfile 2>/dev/null`" != "X$srcfile"; then
+ $echo "\
+*** ERROR, $lockfile contains:
+but it should contain:
+$srcfile
+compiler."
+ exit 1
+ fi
+ # Just move the object if needed, then go on to compile the next one
+ if test -n "$output_obj" && test "X$output_obj" != "X$lobj"; then
+ $show "$mv $output_obj $lobj"
+ if $run $mv $output_obj $lobj; then :
+ else
+ error=$?
+ exit $error
+ fi
+ fi
+ # Append the name of the PIC object to the libtool object file.
+ test -z "$run" && cat >> ${libobj}T <<EOF
+pic_object='$objdir/$objname'
+EOF
+ # Allow error messages only from the first compilation.
+ suppress_output=' >/dev/null 2>&1'
+ else
+ # No PIC object so indicate it doesn't exist in the libtool
+ # object file.
+pic_object=none
+EOF
+ fi
+ # Only build a position-dependent object if we build old libraries.
+ if test "$pic_mode" != yes; then
+ else
+ fi
+ if test "$compiler_c_o" = yes; then
+ command="$command -o $obj"
+ fi
+ # Suppress compiler output if we already did a PIC compilation.
+ command="$command$suppress_output"
+ $run $rm "$obj" "$output_obj"
+ $show "$command"
+ else
+ exit 1
+ fi
+ $echo "\
+$srcfile
+compiler."
+ exit 1
+ fi
+ if test -n "$output_obj" && test "X$output_obj" != "X$obj"; then
+ $show "$mv $output_obj $obj"
+ if $run $mv $output_obj $obj; then :
+ else
+ error=$?
+ exit $error
+ fi
+ fi
+ # Append the name of the non-PIC object the libtool object file.
+ # Only append if the libtool object file exists.
+# Name of the non-PIC object.
+non_pic_object='$objname'
+EOF
+ else
+non_pic_object=none
+EOF
+ fi
+ $run $mv "${libobj}T" "${libobj}"
+ # Unlock the critical section if it was locked
+ if test "$need_locks" != no; then
+ $run $rm "$lockfile"
+ fi
+ exit 0
+ # libtool link mode
+ link | relink)
+ modename="$modename: link"
+ case $host in
+ *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2*)
+ # It is impossible to link a dll without this setting, and
+ # we shouldn't force the makefile maintainer to figure out
+ # which system we are compiling for in order to pass an extra
+ # flag for every libtool invocation.
+ # allow_undefined=no
+ # FIXME: Unfortunately, there are problems with the above when trying
+ # to make a dll which has undefined symbols, in which case not
+ # even a static library is built. For now, we need to specify
+ # -no-undefined on the libtool link line when we can be certain
+ # that all symbols are satisfied, otherwise we get a static library.
+ allow_undefined=yes
+ esac
+ libtool_args="$nonopt"
+ base_compile="$nonopt"
+ compile_command="$nonopt"
+ finalize_command="$nonopt"
+ compile_rpath=
+ finalize_rpath=
+ compile_shlibpath=
+ finalize_shlibpath=
+ convenience=
+ old_convenience=
+ deplibs=
+ old_deplibs=
+ add_flags=
+ compiler_flags=
+ linker_flags=
+ dllsearchpath=
+ lib_search_path=`pwd`
+ inst_prefix_dir=
+ avoid_version=no
+ dlfiles=
+ dlprefiles=
+ dlself=no
+ export_dynamic=no
+ export_symbols=
+ export_symbols_regex=
+ generated=
+ libobjs=
+ ltlibs=
+ module=no
+ no_install=no
+ objs=
+ non_pic_objects=
+ prefer_static_libs=no
+ preload=no
+ prev=
+ prevarg=
+ release=
+ rpath=
+ xrpath=
+ perm_rpath=
+ temp_rpath=
+ thread_safe=no
+ vinfo=
+ vinfo_number=no
+ # We need to know -static, to get the right output filenames.
+ for arg
+ do
+ case $arg in
+ -all-static | -static)
+ if test "X$arg" = "X-all-static"; then
+ if test "$build_libtool_libs" = yes && test -z "$link_static_flag"; then
+ $echo "$modename: warning: complete static linking is impossible in this configuration" 1>&2
+ fi
+ if test -n "$link_static_flag"; then
+ dlopen_self=$dlopen_self_static
+ fi
+ else
+ if test -z "$pic_flag" && test -n "$link_static_flag"; then
+ fi
+ fi
+ build_libtool_libs=no
+ prefer_static_libs=yes
+ break
+ esac
+ done
+ # See if our shared archives depend on static archives.
+ test -n "$old_archive_from_new_cmds" && build_old_libs=yes
+ # Go through the arguments, transforming them on the way.
+ while test "$#" -gt 0; do
+ arg="$1"
+ base_compile="$base_compile $arg"
+ shift
+ case $arg in
+ qarg=\"`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`\" ### testsuite: skip nested quoting test
+ *) qarg=$arg ;;
+ esac
+ libtool_args="$libtool_args $qarg"
+ case $prev in
+ output)
+ compile_command="$compile_command @OUTPUT@"
+ finalize_command="$finalize_command @OUTPUT@"
+ esac
+ case $prev in
+ dlfiles|dlprefiles)
+ if test "$preload" = no; then
+ # Add the symbol object into the linking commands.
+ compile_command="$compile_command @SYMFILE@"
+ finalize_command="$finalize_command @SYMFILE@"
+ preload=yes
+ fi
+ case $arg in
+ *.la | *.lo) ;; # We handle these cases below.
+ force)
+ if test "$dlself" = no; then
+ dlself=needless
+ export_dynamic=yes
+ fi
+ prev=
+ continue
+ self)
+ if test "$prev" = dlprefiles; then
+ dlself=yes
+ elif test "$prev" = dlfiles && test "$dlopen_self" != yes; then
+ dlself=yes
+ else
+ dlself=needless
+ fi
+ prev=
+ continue
+ if test "$prev" = dlfiles; then
+ dlfiles="$dlfiles $arg"
+ else
+ dlprefiles="$dlprefiles $arg"
+ fi
+ prev=
+ continue
+ esac
+ expsyms)
+ export_symbols="$arg"
+ if test ! -f "$arg"; then
+ $echo "$modename: symbol file \`$arg' does not exist"
+ exit 1
+ fi
+ prev=
+ continue
+ expsyms_regex)
+ export_symbols_regex="$arg"
+ prev=
+ continue
+ inst_prefix)
+ inst_prefix_dir="$arg"
+ prev=
+ continue
+ release)
+ release="-$arg"
+ prev=
+ continue
+ objectlist)
+ if test -f "$arg"; then
+ save_arg=$arg
+ moreargs=
+ for fil in `cat $save_arg`
+ do
+# moreargs="$moreargs $fil"
+ arg=$fil
+ # A libtool-controlled object.
+ # Check to see that this really is a libtool object.
+ if (${SED} -e '2q' $arg | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
+ pic_object=
+ non_pic_object=
+ # Read the .lo file
+ # If there is no directory component, then add one.
+ case $arg in
+ */* | *\\*) . $arg ;;
+ *) . ./$arg ;;
+ esac
+ if test -z "$pic_object" || \
+ test -z "$non_pic_object" ||
+ test "$pic_object" = none && \
+ test "$non_pic_object" = none; then
+ $echo "$modename: cannot find name of object for \`$arg'" 1>&2
+ exit 1
+ fi
+ # Extract subdirectory from the argument.
+ xdir=`$echo "X$arg" | $Xsed -e 's%/[^/]*$%%'`
+ if test "X$xdir" = "X$arg"; then
+ xdir=
+ else
+ xdir="$xdir/"
+ fi
+ if test "$pic_object" != none; then
+ # Prepend the subdirectory the object is found in.
+ pic_object="$xdir$pic_object"
+ if test "$build_libtool_libs" = yes && test "$dlopen_support" = yes; then
+ dlfiles="$dlfiles $pic_object"
+ prev=
+ continue
+ else
+ # If libtool objects are unsupported, then we need to preload.
+ prev=dlprefiles
+ fi
+ fi
+ # CHECK ME: I think I busted this. -Ossama
+ # Preload the old-style object.
+ dlprefiles="$dlprefiles $pic_object"
+ prev=
+ fi
+ # A PIC object.
+ libobjs="$libobjs $pic_object"
+ arg="$pic_object"
+ fi
+ # Non-PIC object.
+ if test "$non_pic_object" != none; then
+ non_pic_object="$xdir$non_pic_object"
+ # A standard non-PIC object
+ non_pic_objects="$non_pic_objects $non_pic_object"
+ if test -z "$pic_object" || test "$pic_object" = none ; then
+ arg="$non_pic_object"
+ fi
+ fi
+ else
+ # Only an error if not doing a dry-run.
+ if test -z "$run"; then
+ $echo "$modename: \`$arg' is not a valid libtool object" 1>&2
+ exit 1
+ else
+ # Dry-run case.
+ xdir=
+ else
+ xdir="$xdir/"
+ fi
+ pic_object=`$echo "X${xdir}${objdir}/${arg}" | $Xsed -e "$lo2o"`
+ non_pic_object=`$echo "X${xdir}${arg}" | $Xsed -e "$lo2o"`
+ fi
+ fi
+ done
+ else
+ $echo "$modename: link input file \`$save_arg' does not exist"
+ exit 1
+ fi
+ arg=$save_arg
+ prev=
+ continue
+ rpath | xrpath)
+ # We need an absolute path.
+ case $arg in
+ [\\/]* | [A-Za-z]:[\\/]*) ;;
+ $echo "$modename: only absolute run-paths are allowed" 1>&2
+ exit 1
+ esac
+ if test "$prev" = rpath; then
+ case "$rpath " in
+ *" $arg "*) ;;
+ *) rpath="$rpath $arg" ;;
+ esac
+ else
+ case "$xrpath " in
+ *" $arg "*) ;;
+ *) xrpath="$xrpath $arg" ;;
+ esac
+ fi
+ prev=
+ continue
+ xcompiler)
+ compiler_flags="$compiler_flags $qarg"
+ prev=
+ compile_command="$compile_command $qarg"
+ finalize_command="$finalize_command $qarg"
+ continue
+ xlinker)
+ linker_flags="$linker_flags $qarg"
+ compiler_flags="$compiler_flags $wl$qarg"
+ prev=
+ compile_command="$compile_command $wl$qarg"
+ finalize_command="$finalize_command $wl$qarg"
+ continue
+ xcclinker)
+ prev=
+ continue
+ eval "$prev=\"\$arg\""
+ prev=
+ continue
+ esac
+ fi # test -n "$prev"
+ prevarg="$arg"
+ case $arg in
+ -all-static)
+ compile_command="$compile_command $link_static_flag"
+ finalize_command="$finalize_command $link_static_flag"
+ fi
+ continue
+ -allow-undefined)
+ # FIXME: remove this flag sometime in the future.
+ $echo "$modename: \`-allow-undefined' is deprecated because it is the default" 1>&2
+ continue
+ -avoid-version)
+ avoid_version=yes
+ continue
+ -dlopen)
+ prev=dlfiles
+ continue
+ -dlpreopen)
+ prev=dlprefiles
+ continue
+ -export-dynamic)
+ continue
+ -export-symbols | -export-symbols-regex)
+ if test -n "$export_symbols" || test -n "$export_symbols_regex"; then
+ $echo "$modename: more than one -exported-symbols argument is not allowed"
+ exit 1
+ fi
+ if test "X$arg" = "X-export-symbols"; then
+ prev=expsyms
+ else
+ prev=expsyms_regex
+ fi
+ continue
+ -inst-prefix-dir)
+ prev=inst_prefix
+ continue
+ # The native IRIX linker understands -LANG:*, -LIST:* and -LNO:*
+ # so, if we see these flags be careful not to treat them like -L
+ -L[A-Z][A-Z]*:*)
+ case $with_gcc/$host in
+ no/*-*-irix* | /*-*-irix*)
+ compile_command="$compile_command $arg"
+ finalize_command="$finalize_command $arg"
+ esac
+ continue
+ -L*)
+ dir=`$echo "X$arg" | $Xsed -e 's/^-L//'`
+ case $dir in
+ absdir=`cd "$dir" && pwd`
+ if test -z "$absdir"; then
+ $echo "$modename: cannot determine absolute directory name of \`$dir'" 1>&2
+ exit 1
+ fi
+ dir="$absdir"
+ esac
+ case "$deplibs " in
+ *" -L$dir "*) ;;
+ deplibs="$deplibs -L$dir"
+ lib_search_path="$lib_search_path $dir"
+ esac
+ case $host in
+ case :$dllsearchpath: in
+ *":$dir:"*) ;;
+ *) dllsearchpath="$dllsearchpath:$dir";;
+ esac
+ esac
+ continue
+ -l*)
+ if test "X$arg" = "X-lc" || test "X$arg" = "X-lm"; then
+ case $host in
+ *-*-cygwin* | *-*-pw32* | *-*-beos*)
+ # These systems don't actually have a C or math library (as such)
+ continue
+ *-*-freebsd*-gnu*)
+ # prevent being parsed by the freebsd regexp below
+ *-*-mingw* | *-*-os2*)
+ # These systems don't actually have a C library (as such)
+ test "X$arg" = "X-lc" && continue
+ *-*-openbsd* | *-*-freebsd*)
+ # Do not include libc due to us having libc/libc_r.
+ *-*-rhapsody* | *-*-darwin1.[012])
+ # Rhapsody C and math libraries are in the System framework
+ deplibs="$deplibs -framework System"
+ continue
+ esac
+ elif test "X$arg" = "X-lc_r"; then
+ case $host in
+ *-*-openbsd*)
+ # Do not include libc_r directly, use -pthread flag.
+ continue
+ esac
+ fi
+ deplibs="$deplibs $arg"
+ continue
+ -module)
+ module=yes
+ continue
+ # gcc -m* arguments should be passed to the linker via $compiler_flags
+ # in order to pass architecture information to the linker
+ # (e.g. 32 vs 64-bit). This may also be accomplished via -Wl,-mfoo
+ # but this is not reliable with gcc because gcc may use -mfoo to
+ # select a different linker, different libraries, etc, while
+ # -Wl,-mfoo simply passes -mfoo to the linker.
+ -m*)
+ # Unknown arguments in both finalize_command and compile_command need
+ # to be aesthetically quoted because they are evaled later.
+ arg=`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`
+ case $arg in
+ arg="\"$arg\""
+ esac
+ if test "$with_gcc" = "yes" ; then
+ compiler_flags="$compiler_flags $arg"
+ fi
+ continue
+ -shrext)
+ prev=shrext
+ continue
+ -no-fast-install)
+ fast_install=no
+ continue
+ -no-install)
+ case $host in
+ # The PATH hackery in wrapper scripts is required on Windows
+ # in order for the loader to find any dlls it needs.
+ $echo "$modename: warning: \`-no-install' is ignored for $host" 1>&2
+ $echo "$modename: warning: assuming \`-no-fast-install' instead" 1>&2
+ fast_install=no
+ *) no_install=yes ;;
+ esac
+ continue
+ -no-undefined)
+ allow_undefined=no
+ continue
+ -objectlist)
+ prev=objectlist
+ continue
+ -o) prev=output ;;
+ -release)
+ prev=release
+ continue
+ -rpath)
+ prev=rpath
+ continue
+ -R)
+ prev=xrpath
+ continue
+ -R*)
+ dir=`$echo "X$arg" | $Xsed -e 's/^-R//'`
+ case $dir in
+ exit 1
+ esac
+ *" $dir "*) ;;
+ *) xrpath="$xrpath $dir" ;;
+ esac
+ continue
+ -static)
+ # The effects of -static are defined in a previous loop.
+ # We used to do the same as -all-static on platforms that
+ # didn't have a PIC flag, but the assumption that the effects
+ # would be equivalent was wrong. It would break on at least
+ # Digital Unix and AIX.
+ continue
+ -thread-safe)
+ thread_safe=yes
+ continue
+ -version-info)
+ prev=vinfo
+ continue
+ -version-number)
+ prev=vinfo
+ vinfo_number=yes
+ continue
+ -Wc,*)
+ args=`$echo "X$arg" | $Xsed -e "$sed_quote_subst" -e 's/^-Wc,//'`
+ arg=
+ for flag in $args; do
+ IFS="$save_ifs"
+ case $flag in
+ flag="\"$flag\""
+ esac
+ arg="$arg $wl$flag"
+ compiler_flags="$compiler_flags $flag"
+ done
+ IFS="$save_ifs"
+ arg=`$echo "X$arg" | $Xsed -e "s/^ //"`
+ -Wl,*)
+ args=`$echo "X$arg" | $Xsed -e "$sed_quote_subst" -e 's/^-Wl,//'`
+ arg=
+ IFS="$save_ifs"
+ case $flag in
+ flag="\"$flag\""
+ esac
+ compiler_flags="$compiler_flags $wl$flag"
+ linker_flags="$linker_flags $flag"
+ done
+ IFS="$save_ifs"
+ -Xcompiler)
+ prev=xcompiler
+ continue
+ -Xlinker)
+ prev=xlinker
+ continue
+ -XCClinker)
+ prev=xcclinker
+ continue
+ # Some other compiler flag.
+ case $arg in
+ arg="\"$arg\""
+ esac
+ add_flags="$add_flags $arg"
+ *.$objext)
+ # A standard object.
+ objs="$objs $arg"
+ *.lo)
+ pic_object=
+ non_pic_object=
+ case $arg in
+ *) . ./$arg ;;
+ esac
+ exit 1
+ fi
+ xdir=
+ else
+ xdir="$xdir/"
+ fi
+ prev=
+ continue
+ else
+ prev=dlprefiles
+ fi
+ fi
+ prev=
+ fi
+ # A PIC object.
+ arg="$pic_object"
+ fi
+ # Non-PIC object.
+ fi
+ fi
+ else
+ exit 1
+ else
+ # Dry-run case.
+ xdir=
+ else
+ xdir="$xdir/"
+ fi
+ fi
+ fi
+ *.$libext)
+ # An archive.
+ old_deplibs="$old_deplibs $arg"
+ continue
+ *.la)
+ # A libtool-controlled library.
+ # This library was specified with -dlopen.
+ prev=
+ elif test "$prev" = dlprefiles; then
+ # The library was specified with -dlpreopen.
+ prev=
+ else
+ fi
+ continue
+ # Some other compiler argument.
+ case $arg in
+ arg="\"$arg\""
+ esac
+ esac # arg
+ # Now actually substitute the argument into the commands.
+ if test -n "$arg"; then
+ fi
+ done # argument parsing loop
+ $echo "$modename: the \`$prevarg' option requires an argument" 1>&2
+ exit 1
+ fi
+ # Only attempt this if the compiler in the base link
+ "$CC "* | " $CC "* | "`$echo $CC` "* | " `$echo $CC` "*) ;;
+ # The compiler in $compile_command matches
+ tagname=$z
+ break
+ esac
+ fi
+ done
+ exit 1
+# else
+ fi
+ esac
+ fi
+ if test "$export_dynamic" = yes && test -n "$export_dynamic_flag_spec"; then
+ eval arg=\"$export_dynamic_flag_spec\"
+ fi
+ oldlibs=
+ # calculate the name of the file, without its directory
+ outputname=`$echo "X$output" | $Xsed -e 's%^.*/%%'`
+ libobjs_save="$libobjs"
+ if test -n "$shlibpath_var"; then
+ # get the directories listed in $shlibpath_var
+ eval shlib_search_path=\`\$echo \"X\${$shlibpath_var}\" \| \$Xsed -e \'s/:/ /g\'\`
+ else
+ shlib_search_path=
+ fi
+ eval sys_lib_search_path=\"$sys_lib_search_path_spec\"
+ eval sys_lib_dlsearch_path=\"$sys_lib_dlsearch_path_spec\"
+ output_objdir=`$echo "X$output" | $Xsed -e 's%/[^/]*$%%'`
+ if test "X$output_objdir" = "X$output"; then
+ output_objdir="$objdir"
+ else
+ output_objdir="$output_objdir/$objdir"
+ fi
+ # Create the object directory.
+ if test ! -d "$output_objdir"; then
+ $show "$mkdir $output_objdir"
+ $run $mkdir $output_objdir
+ status=$?
+ if test "$status" -ne 0 && test ! -d "$output_objdir"; then
+ exit $status
+ fi
+ fi
+ # Determine the type of output
+ case $output in
+ $echo "$modename: you must specify an output file" 1>&2
+ exit 1
+ *.$libext) linkmode=oldlib ;;
+ *.lo | *.$objext) linkmode=obj ;;
+ *.la) linkmode=lib ;;
+ *) linkmode=prog ;; # Anything else should be a program.
+ esac
+ case $host in
+ *cygwin* | *mingw* | *pw32*)
+ # don't eliminate duplcations in $postdeps and $predeps
+ duplicate_compiler_generated_deps=yes
+ duplicate_compiler_generated_deps=$duplicate_deps
+ esac
+ specialdeplibs=
+ libs=
+ # Find all interdependent deplibs by searching for libraries
+ # that are linked more than once (e.g. -la -lb -la)
+ for deplib in $deplibs; do
+ if test "X$duplicate_deps" = "Xyes" ; then
+ case "$libs " in
+ *" $deplib "*) specialdeplibs="$specialdeplibs $deplib" ;;
+ esac
+ fi
+ libs="$libs $deplib"
+ done
+ if test "$linkmode" = lib; then
+ libs="$predeps $libs $compiler_lib_search_path $postdeps"
+ # Compute libraries that are listed more than once in $predeps
+ # $postdeps and mark them as special (i.e., whose duplicates are
+ # not to be eliminated).
+ pre_post_deps=
+ if test "X$duplicate_compiler_generated_deps" = "Xyes" ; then
+ for pre_post_dep in $predeps $postdeps; do
+ case "$pre_post_deps " in
+ *" $pre_post_dep "*) specialdeplibs="$specialdeplibs $pre_post_deps" ;;
+ esac
+ pre_post_deps="$pre_post_deps $pre_post_dep"
+ done
+ fi
+ pre_post_deps=
+ fi
+ deplibs=
+ newdependency_libs=
+ newlib_search_path=
+ need_relink=no # whether we're linking any uninstalled libtool libraries
+ notinst_deplibs= # not-installed libtool libraries
+ notinst_path= # paths that contain not-installed libtool libraries
+ case $linkmode in
+ lib)
+ passes="conv link"
+ for file in $dlfiles $dlprefiles; do
+ case $file in
+ *.la) ;;
+ $echo "$modename: libraries can \`-dlopen' only libtool libraries: $file" 1>&2
+ exit 1
+ esac
+ done
+ prog)
+ compile_deplibs=
+ finalize_deplibs=
+ alldeplibs=no
+ newdlfiles=
+ newdlprefiles=
+ passes="conv scan dlopen dlpreopen link"
+ *) passes="conv"
+ esac
+ for pass in $passes; do
+ if test "$linkmode,$pass" = "lib,link" ||
+ test "$linkmode,$pass" = "prog,scan"; then
+ libs="$deplibs"
+ deplibs=
+ fi
+ if test "$linkmode" = prog; then
+ case $pass in
+ dlopen) libs="$dlfiles" ;;
+ dlpreopen) libs="$dlprefiles" ;;
+ link) libs="$deplibs %DEPLIBS% $dependency_libs" ;;
+ esac
+ fi
+ if test "$pass" = dlopen; then
+ # Collect dlpreopened libraries
+ save_deplibs="$deplibs"
+ deplibs=
+ fi
+ for deplib in $libs; do
+ lib=
+ found=no
+ case $deplib in
+ -l*)
+ if test "$linkmode" != lib && test "$linkmode" != prog; then
+ $echo "$modename: warning: \`-l' is ignored for archives/objects" 1>&2
+ continue
+ fi
+ if test "$pass" = conv && test "$allow_undefined" = yes; then
+ deplibs="$deplib $deplibs"
+ continue
+ fi
+ name=`$echo "X$deplib" | $Xsed -e 's/^-l//'`
+ for searchdir in $newlib_search_path $lib_search_path $sys_lib_search_path $shlib_search_path; do
+ for search_ext in .la $shrext .so .a; do
+ # Search the libtool library
+ lib="$searchdir/lib${name}${search_ext}"
+ if test -f "$lib"; then
+ if test "$search_ext" = ".la"; then
+ found=yes
+ else
+ found=no
+ fi
+ break 2
+ fi
+ done
+ done
+ if test "$found" != yes; then
+ # deplib doesn't seem to be a libtool library
+ if test "$linkmode,$pass" = "prog,link"; then
+ compile_deplibs="$deplib $compile_deplibs"
+ finalize_deplibs="$deplib $finalize_deplibs"
+ else
+ test "$linkmode" = lib && newdependency_libs="$deplib $newdependency_libs"
+ fi
+ continue
+ else # deplib is a libtool library
+ # If $allow_libtool_libs_with_static_runtimes && $deplib is a stdlib,
+ # We need to do some special things here, and not later.
+ if test "X$allow_libtool_libs_with_static_runtimes" = "Xyes" ; then
+ case " $predeps $postdeps " in
+ *" $deplib "*)
+ if (${SED} -e '2q' $lib |
+ grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
+ library_names=
+ old_library=
+ case $lib in
+ */* | *\\*) . $lib ;;
+ *) . ./$lib ;;
+ esac
+ for l in $old_library $library_names; do
+ ll="$l"
+ done
+ if test "X$ll" = "X$old_library" ; then # only static version available
+ found=no
+ ladir=`$echo "X$lib" | $Xsed -e 's%/[^/]*$%%'`
+ test "X$ladir" = "X$lib" && ladir="."
+ lib=$ladir/$old_library
+ else
+ fi
+ continue
+ fi
+ fi
+ esac
+ fi
+ fi
+ ;; # -l
+ -L*)
+ case $linkmode in
+ lib)
+ test "$pass" = conv && continue
+ newdependency_libs="$deplib $newdependency_libs"
+ newlib_search_path="$newlib_search_path "`$echo "X$deplib" | $Xsed -e 's/^-L//'`
+ prog)
+ if test "$pass" = conv; then
+ continue
+ fi
+ if test "$pass" = scan; then
+ else
+ fi
+ $echo "$modename: warning: \`-L' is ignored for archives/objects" 1>&2
+ esac # linkmode
+ continue
+ ;; # -L
+ -R*)
+ if test "$pass" = link; then
+ dir=`$echo "X$deplib" | $Xsed -e 's/^-R//'`
+ # Make sure the xrpath contains only unique directories.
+ *" $dir "*) ;;
+ esac
+ fi
+ continue
+ *.la) lib="$deplib" ;;
+ *.$libext)
+ continue
+ fi
+ case $linkmode in
+ lib)
+ if test "$deplibs_check_method" != pass_all; then
+ $echo
+ $echo "*** Warning: Trying to link with static lib archive $deplib."
+ $echo "*** I have the capability to make that library automatically link in when"
+ $echo "*** you link to this library. But I can only do this if you have a"
+ $echo "*** shared version of the library, which you do not appear to have"
+ $echo "*** because the file extensions .$libext of this argument makes me believe"
+ $echo "*** that it is just a static archive that I should not used here."
+ else
+ $echo
+ $echo "*** Warning: Linking the shared library $output against the"
+ $echo "*** static library $deplib is not portable!"
+ fi
+ continue
+ prog)
+ if test "$pass" != link; then
+ else
+ fi
+ continue
+ esac # linkmode
+ ;; # *.$libext
+ *.lo | *.$objext)
+ elif test "$linkmode" = prog; then
+ if test "$pass" = dlpreopen || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
+ # If there is no dlopen support or we're linking statically,
+ # we need to preload.
+ newdlprefiles="$newdlprefiles $deplib"
+ else
+ newdlfiles="$newdlfiles $deplib"
+ fi
+ fi
+ continue
+ %DEPLIBS%)
+ alldeplibs=yes
+ continue
+ esac # case $deplib
+ if test "$found" = yes || test -f "$lib"; then :
+ else
+ $echo "$modename: cannot find the library \`$lib'" 1>&2
+ exit 1
+ fi
+ # Check to see that this really is a libtool archive.
+ if (${SED} -e '2q' $lib | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then :
+ else
+ $echo "$modename: \`$lib' is not a valid libtool archive" 1>&2
+ exit 1
+ fi
+ dlname=
+ dlopen=
+ dlpreopen=
+ libdir=
+ library_names=
+ old_library=
+ # If the library was installed with an old release of libtool,
+ # it will not redefine variables installed, or shouldnotlink
+ installed=yes
+ shouldnotlink=no
+ # Read the .la file
+ case $lib in
+ *) . ./$lib ;;
+ esac
+ test "$linkmode,$pass" = "prog,scan" ||
+ { test "$linkmode" != prog && test "$linkmode" != lib; }; then
+ test -n "$dlopen" && dlfiles="$dlfiles $dlopen"
+ test -n "$dlpreopen" && dlprefiles="$dlprefiles $dlpreopen"
+ fi
+ # Only check for convenience libraries
+ deplibs="$lib $deplibs"
+ tmp_libs=
+ for deplib in $dependency_libs; do
+ #echo "Adding $deplib to \$deplibs"
+ case "$tmp_libs " in
+ esac
+ fi
+ tmp_libs="$tmp_libs $deplib"
+ done
+ if test -z "$libdir"; then
+ if test -z "$old_library"; then
+ $echo "$modename: cannot find name of link library for \`$lib'" 1>&2
+ exit 1
+ fi
+ # It is a libtool convenience library, so add in its objects.
+ convenience="$convenience $ladir/$objdir/$old_library"
+ old_convenience="$old_convenience $ladir/$objdir/$old_library"
+ elif test "$linkmode" != prog && test "$linkmode" != lib; then
+ $echo "$modename: \`$lib' is not a convenience library" 1>&2
+ exit 1
+ fi
+ continue
+ fi # $pass = conv
+ # Get the name of the library we link against.
+ linklib=
+ linklib="$l"
+ done
+ if test -z "$linklib"; then
+ exit 1
+ fi
+ $echo "$modename: cannot -dlopen a convenience library: \`$lib'" 1>&2
+ exit 1
+ fi
+ if test -z "$dlname" || test "$dlopen_support" != yes || test "$build_libtool_libs" = no; then
+ # If there is no dlname, no dlopen support or we're linking
+ # statically, we need to preload. We also need to preload any
+ # dependent libraries so libltdl's deplib preloader doesn't
+ # bomb out in the load deplibs phase.
+ dlprefiles="$dlprefiles $lib $dependency_libs"
+ else
+ newdlfiles="$newdlfiles $lib"
+ fi
+ continue
+ fi # $pass = dlopen
+ case $ladir in
+ [\\/]* | [A-Za-z]:[\\/]*) abs_ladir="$ladir" ;;
+ abs_ladir=`cd "$ladir" && pwd`
+ if test -z "$abs_ladir"; then
+ $echo "$modename: warning: cannot determine absolute directory name of \`$ladir'" 1>&2
+ $echo "$modename: passing it literally to the linker, although it might fail" 1>&2
+ abs_ladir="$ladir"
+ fi
+ esac
+ laname=`$echo "X$lib" | $Xsed -e 's%^.*/%%'`
+ # Find the relevant object directory and library name.
+ if test "X$installed" = Xyes; then
+ if test ! -f "$libdir/$linklib" && test -f "$abs_ladir/$linklib"; then
+ $echo "$modename: warning: library \`$lib' was moved." 1>&2
+ dir="$ladir"
+ absdir="$abs_ladir"
+ libdir="$abs_ladir"
+ else
+ dir="$libdir"
+ absdir="$libdir"
+ fi
+ else
+ dir="$ladir/$objdir"
+ absdir="$abs_ladir/$objdir"
+ # Remove this search path later
+ notinst_path="$notinst_path $abs_ladir"
+ fi # $installed = yes
+ name=`$echo "X$laname" | $Xsed -e 's/\.la$//' -e 's/^lib//'`
+ # This library was specified with -dlpreopen.
+ if test "$pass" = dlpreopen; then
+ $echo "$modename: cannot -dlpreopen a convenience library: \`$lib'" 1>&2
+ exit 1
+ fi
+ # Prefer using a static library (so that no silly _DYNAMIC symbols
+ # are required to link).
+ if test -n "$old_library"; then
+ newdlprefiles="$newdlprefiles $dir/$old_library"
+ # Otherwise, use the dlname, so that lt_dlopen finds it.
+ elif test -n "$dlname"; then
+ newdlprefiles="$newdlprefiles $dir/$dlname"
+ else
+ newdlprefiles="$newdlprefiles $dir/$linklib"
+ fi
+ fi # $pass = dlpreopen
+ # Link the convenience library
+ deplibs="$dir/$old_library $deplibs"
+ elif test "$linkmode,$pass" = "prog,link"; then
+ compile_deplibs="$dir/$old_library $compile_deplibs"
+ finalize_deplibs="$dir/$old_library $finalize_deplibs"
+ else
+ deplibs="$lib $deplibs" # used for prog,scan pass
+ fi
+ continue
+ fi
+ if test "$linkmode" = prog && test "$pass" != link; then
+ newlib_search_path="$newlib_search_path $ladir"
+ linkalldeplibs=no
+ if test "$link_all_deplibs" != no || test -z "$library_names" ||
+ test "$build_libtool_libs" = no; then
+ linkalldeplibs=yes
+ fi
+ tmp_libs=
+ case $deplib in
+ -L*) newlib_search_path="$newlib_search_path "`$echo "X$deplib" | $Xsed -e 's/^-L//'`;; ### testsuite: skip nested quoting test
+ esac
+ # Need to link against all dependency_libs?
+ if test "$linkalldeplibs" = yes; then
+ else
+ # Need to hardcode shared library paths
+ # or/and link against static libraries
+ fi
+ esac
+ fi
+ done # for deplib
+ continue
+ fi # $linkmode = prog...
+ if test -n "$library_names" &&
+ { test "$prefer_static_libs" = no || test -z "$old_library"; }; then
+ # We need to hardcode the library path
+ # Make sure the rpath contains only unique directories.
+ case "$temp_rpath " in
+ *" $dir "*) ;;
+ *" $absdir "*) ;;
+ *) temp_rpath="$temp_rpath $dir" ;;
+ esac
+ fi
+ # Hardcode the library path.
+ # Skip directories that are in the system default run-time
+ # search path.
+ case " $sys_lib_dlsearch_path " in
+ *" $absdir "*) ;;
+ case "$compile_rpath " in
+ *" $absdir "*) ;;
+ *) compile_rpath="$compile_rpath $absdir"
+ esac
+ esac
+ *" $libdir "*) ;;
+ case "$finalize_rpath " in
+ *" $libdir "*) ;;
+ *) finalize_rpath="$finalize_rpath $libdir"
+ esac
+ esac
+ fi # $linkmode,$pass = prog,link...
+ if test "$alldeplibs" = yes &&
+ { test "$deplibs_check_method" = pass_all ||
+ { test "$build_libtool_libs" = yes &&
+ test -n "$library_names"; }; }; then
+ # We only need to search for static libraries
+ continue
+ fi
+ fi
+ link_static=no # Whether the deplib will be linked statically
+ if test "$installed" = no; then
+ notinst_deplibs="$notinst_deplibs $lib"
+ need_relink=yes
+ fi
+ # This is a shared library
+ # Warn about portability, can't link against -module's on some systems (darwin)
+ if test "$shouldnotlink" = yes && test "$pass" = link ; then
+ $echo
+ $echo "*** Warning: Linking the executable $output against the loadable module"
+ else
+ $echo "*** Warning: Linking the shared library $output against the loadable module"
+ fi
+ $echo "*** $linklib is not portable!"
+ fi
+ if test "$linkmode" = lib &&
+ test "$hardcode_into_libs" = yes; then
+ # search path.
+ *" $absdir "*) ;;
+ *" $absdir "*) ;;
+ esac
+ esac
+ *" $libdir "*) ;;
+ *" $libdir "*) ;;
+ esac
+ esac
+ fi
+ if test -n "$old_archive_from_expsyms_cmds"; then
+ # figure out the soname
+ set dummy $library_names
+ realname="$2"
+ shift; shift
+ libname=`eval \\$echo \"$libname_spec\"`
+ # use dlname if we got it. it's perfectly good, no?
+ if test -n "$dlname"; then
+ soname="$dlname"
+ elif test -n "$soname_spec"; then
+ # bleh windows
+ case $host in
+ *cygwin* | mingw*)
+ major=`expr $current - $age`
+ versuffix="-$major"
+ esac
+ eval soname=\"$soname_spec\"
+ else
+ soname="$realname"
+ fi
+ # Make a new name for the extract_expsyms_cmds to use
+ soroot="$soname"
+ soname=`$echo $soroot | ${SED} -e 's/^.*\///'`
+ newlib="libimp-`$echo $soname | ${SED} 's/^lib//;s/\.dll$//'`.a"
+ # If the library has no export list, then create one now
+ if test -f "$output_objdir/$soname-def"; then :
+ else
+ $show "extracting exported symbol list from \`$soname'"
+ save_ifs="$IFS"; IFS='~'
+ eval cmds=\"$extract_expsyms_cmds\"
+ for cmd in $cmds; do
+ IFS="$save_ifs"
+ $show "$cmd"
+ $run eval "$cmd" || exit $?
+ done
+ IFS="$save_ifs"
+ fi
+ # Create $newlib
+ if test -f "$output_objdir/$newlib"; then :; else
+ $show "generating import library for \`$soname'"
+ eval cmds=\"$old_archive_from_expsyms_cmds\"
+ IFS="$save_ifs"
+ $show "$cmd"
+ done
+ IFS="$save_ifs"
+ fi
+ # make sure the library variables are pointing to the new library
+ dir=$output_objdir
+ linklib=$newlib
+ fi # test -n "$old_archive_from_expsyms_cmds"
+ if test "$linkmode" = prog || test "$mode" != relink; then
+ add_shlibpath=
+ add_dir=
+ add=
+ lib_linked=yes
+ case $hardcode_action in
+ immediate | unsupported)
+ if test "$hardcode_direct" = no; then
+ add="$dir/$linklib"
+ case $host in
+ *-*-sco3.2v5* ) add_dir="-L$dir" ;;
+ *-*-darwin* )
+ # if the lib is a module then we can not link against it, someone
+ # is ignoring the new warnings I added
+ if /usr/bin/file -L $add 2> /dev/null | grep "bundle" >/dev/null ; then
+ $echo "** Warning, lib $linklib is a module, not a shared library"
+ if test -z "$old_library" ; then
+ $echo
+ $echo "** And there doesn't seem to be a static archive available"
+ $echo "** The link will probably fail, sorry"
+ else
+ add="$dir/$old_library"
+ fi
+ fi
+ esac
+ elif test "$hardcode_minus_L" = no; then
+ case $host in
+ *-*-sunos*) add_shlibpath="$dir" ;;
+ esac
+ add_dir="-L$dir"
+ add="-l$name"
+ elif test "$hardcode_shlibpath_var" = no; then
+ add_shlibpath="$dir"
+ add="-l$name"
+ else
+ lib_linked=no
+ fi
+ relink)
+ if test "$hardcode_direct" = yes; then
+ elif test "$hardcode_minus_L" = yes; then
+ add_dir="-L$dir"
+ # Try looking first in the location we're being installed to.
+ if test -n "$inst_prefix_dir"; then
+ case "$libdir" in
+ add_dir="-L$inst_prefix_dir$libdir $add_dir"
+ esac
+ fi
+ add="-l$name"
+ elif test "$hardcode_shlibpath_var" = yes; then
+ add="-l$name"
+ else
+ lib_linked=no
+ fi
+ *) lib_linked=no ;;
+ esac
+ if test "$lib_linked" != yes; then
+ $echo "$modename: configuration error: unsupported hardcode properties"
+ exit 1
+ fi
+ if test -n "$add_shlibpath"; then
+ case :$compile_shlibpath: in
+ *":$add_shlibpath:"*) ;;
+ *) compile_shlibpath="$compile_shlibpath$add_shlibpath:" ;;
+ esac
+ fi
+ test -n "$add_dir" && compile_deplibs="$add_dir $compile_deplibs"
+ test -n "$add" && compile_deplibs="$add $compile_deplibs"
+ else
+ test -n "$add_dir" && deplibs="$add_dir $deplibs"
+ test -n "$add" && deplibs="$add $deplibs"
+ if test "$hardcode_direct" != yes && \
+ test "$hardcode_minus_L" != yes && \
+ test "$hardcode_shlibpath_var" = yes; then
+ case :$finalize_shlibpath: in
+ *":$libdir:"*) ;;
+ *) finalize_shlibpath="$finalize_shlibpath$libdir:" ;;
+ esac
+ fi
+ fi
+ fi
+ if test "$linkmode" = prog || test "$mode" = relink; then
+ add_shlibpath=
+ add_dir=
+ add=
+ # Finalize command for both is simple: just hardcode it.
+ add="$libdir/$linklib"
+ add_dir="-L$libdir"
+ add="-l$name"
+ *":$libdir:"*) ;;
+ esac
+ add="-l$name"
+ elif test "$hardcode_automatic" = yes; then
+ if test -n "$inst_prefix_dir" && test -f "$inst_prefix_dir$libdir/$linklib" ; then
+ add="$inst_prefix_dir$libdir/$linklib"
+ else
+ fi
+ else
+ # We cannot seem to hardcode it, guess we'll fake it.
+ case "$libdir" in
+ esac
+ fi
+ add="-l$name"
+ fi
+ test -n "$add_dir" && finalize_deplibs="$add_dir $finalize_deplibs"
+ test -n "$add" && finalize_deplibs="$add $finalize_deplibs"
+ else
+ fi
+ fi
+ # Here we assume that one of hardcode_direct or hardcode_minus_L
+ # is not unsupported. This is valid on all known static and
+ # shared platforms.
+ if test "$hardcode_direct" != unsupported; then
+ test -n "$old_library" && linklib="$old_library"
+ compile_deplibs="$dir/$linklib $compile_deplibs"
+ finalize_deplibs="$dir/$linklib $finalize_deplibs"
+ else
+ compile_deplibs="-l$name -L$dir $compile_deplibs"
+ finalize_deplibs="-l$name -L$dir $finalize_deplibs"
+ fi
+ elif test "$build_libtool_libs" = yes; then
+ # Not a shared library
+ # We're trying link a shared library against a static one
+ # but the system doesn't support it.
+ # Just print a warning and add the library to dependency_libs so
+ # that the program can be linked against the static library.
+ $echo
+ $echo "*** Warning: This system can not link to static lib archive $lib."
+ $echo "*** shared version of the library, which you do not appear to have."
+ if test "$module" = yes; then
+ $echo "*** But as you try to build a module library, libtool will still create "
+ $echo "*** a static module, that should work as long as the dlopening application"
+ $echo "*** is linked with the -dlopen flag to resolve symbols at runtime."
+ if test -z "$global_symbol_pipe"; then
+ $echo
+ $echo "*** However, this would only work if libtool was able to extract symbol"
+ $echo "*** lists from a program, using \`nm' or equivalent, but libtool could"
+ $echo "*** not find such a program. So, this module is probably useless."
+ $echo "*** \`nm' from GNU binutils and a full rebuild may help."
+ fi
+ if test "$build_old_libs" = no; then
+ build_libtool_libs=module
+ else
+ fi
+ fi
+ else
+ convenience="$convenience $dir/$old_library"
+ old_convenience="$old_convenience $dir/$old_library"
+ link_static=yes
+ fi
+ fi # link shared/static library?
+ #if test -n "$dependency_libs" &&
+ # { test "$hardcode_into_libs" != yes || test "$build_old_libs" = yes ||
+ # test "$link_static" = yes; }; then
+ # Extract -R from dependency_libs
+ temp_deplibs=
+ for libdir in $dependency_libs; do
+ case $libdir in
+ -R*) temp_xrpath=`$echo "X$libdir" | $Xsed -e 's/^-R//'`
+ case " $xrpath " in
+ *" $temp_xrpath "*) ;;
+ *) xrpath="$xrpath $temp_xrpath";;
+ esac;;
+ *) temp_deplibs="$temp_deplibs $libdir";;
+ esac
+ done
+ dependency_libs="$temp_deplibs"
+ #fi
+ newlib_search_path="$newlib_search_path $absdir"
+ # Link against this library
+ test "$link_static" = no && newdependency_libs="$abs_ladir/$laname $newdependency_libs"
+ # ... and its dependency_libs
+ tmp_libs=
+ esac
+ fi
+ done
+ if test "$link_all_deplibs" != no; then
+ # Add the search paths of all dependency libraries
+ case $deplib in
+ -L*) path="$deplib" ;;
+ *.la)
+ dir=`$echo "X$deplib" | $Xsed -e 's%/[^/]*$%%'`
+ test "X$dir" = "X$deplib" && dir="."
+ case $dir in
+ [\\/]* | [A-Za-z]:[\\/]*) absdir="$dir" ;;
+ $echo "$modename: warning: cannot determine absolute directory name of \`$dir'" 1>&2
+ absdir="$dir"
+ fi
+ esac
+ if grep "^installed=no" $deplib > /dev/null; then
+ path="$absdir/$objdir"
+ else
+ eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $deplib`
+ $echo "$modename: \`$deplib' is not a valid libtool archive" 1>&2
+ exit 1
+ fi
+ if test "$absdir" != "$libdir"; then
+ # Sure, some shells/systems don't implement the -ef.
+ # Those will have to live with the warning.
+ test "$absdir" -ef "$libdir" > /dev/null 2>&1 ||
+ $echo "$modename: warning: \`$deplib' seems to be moved" 1>&2
+ fi
+ path="$absdir"
+ fi
+ depdepl=
+ case $host in
+ *-*-darwin*)
+ # we do not want to link against static libs, but need to link against shared
+ eval deplibrary_names=`${SED} -n -e 's/^library_names=\(.*\)$/\1/p' $deplib`
+ if test -n "$deplibrary_names" ; then
+ for tmp in $deplibrary_names ; do
+ depdepl=$tmp
+ done
+ if test -f "$path/$depdepl" ; then
+ depdepl="$path/$depdepl"
+ fi
+ # do not add paths which are already there
+ case " $newlib_search_path " in
+ *" $path "*) ;;
+ *) newlib_search_path="$newlib_search_path $path";;
+ esac
+ path=""
+ fi
+ path="-L$path"
+ esac
+ -l*)
+ case $host in
+ *-*-darwin*)
+ # Again, we only want to link against shared libraries
+ eval tmp_libs=`$echo "X$deplib" | $Xsed -e "s,^\-l,,"`
+ for tmp in $newlib_search_path ; do
+ if test -f "$tmp/lib$tmp_libs.dylib" ; then
+ eval depdepl="$tmp/lib$tmp_libs.dylib"
+ break
+ fi
+ done
+ path=""
+ *) continue ;;
+ esac
+ *) continue ;;
+ esac
+ case " $deplibs " in
+ *" $depdepl "*) ;;
+ *) deplibs="$deplibs $depdepl" ;;
+ esac
+ *" $path "*) ;;
+ *) deplibs="$deplibs $path" ;;
+ esac
+ done
+ fi # link_all_deplibs != no
+ fi # linkmode = lib
+ done # for deplib in $libs
+ dependency_libs="$newdependency_libs"
+ # Link the dlpreopened libraries before other libraries
+ for deplib in $save_deplibs; do
+ done
+ fi
+ if test "$pass" != dlopen; then
+ if test "$pass" != conv; then
+ # Make sure lib_search_path contains only unique directories.
+ lib_search_path=
+ for dir in $newlib_search_path; do
+ case "$lib_search_path " in
+ *" $dir "*) ;;
+ *) lib_search_path="$lib_search_path $dir" ;;
+ esac
+ done
+ fi
+ if test "$linkmode,$pass" != "prog,link"; then
+ vars="deplibs"
+ else
+ vars="compile_deplibs finalize_deplibs"
+ fi
+ for var in $vars dependency_libs; do
+ # Add libraries to $var in reverse order
+ eval tmp_libs=\"\$$var\"
+ new_libs=
+ for deplib in $tmp_libs; do
+ # FIXME: Pedantically, this is the right thing to do, so
+ # that some nasty dependency loop isn't accidentally
+ # broken:
+ #new_libs="$deplib $new_libs"
+ # Pragmatically, this seems to cause very few problems in
+ # practice:
+ case $deplib in
+ -L*) new_libs="$deplib $new_libs" ;;
+ -R*) ;;
+ # And here is the reason: when a library appears more
+ # than once as an explicit dependence of a library, or
+ # is implicitly linked in more than once by the
+ # compiler, it is considered special, and multiple
+ # occurrences thereof are not removed. Compare this
+ # with having the same library being listed as a
+ # dependency of multiple other libraries: in this case,
+ # we know (pedantically, we assume) the library does not
+ # need to be listed more than once, so we keep only the
+ # last copy. This is not always right, but it is rare
+ # enough that we require users that really mean to play
+ # such unportable linking tricks to link the library
+ # using -Wl,-lname, so that libtool does not consider it
+ # for duplicate removal.
+ case " $specialdeplibs " in
+ *" $deplib "*) new_libs="$deplib $new_libs" ;;
+ case " $new_libs " in
+ *" $deplib "*) ;;
+ *) new_libs="$deplib $new_libs" ;;
+ esac
+ esac
+ esac
+ done
+ tmp_libs=
+ for deplib in $new_libs; do
+ case $deplib in
+ -L*)
+ case " $tmp_libs " in
+ *" $deplib "*) ;;
+ *) tmp_libs="$tmp_libs $deplib" ;;
+ esac
+ esac
+ done
+ eval $var=\"$tmp_libs\"
+ done # for var
+ fi
+ # Last step: remove runtime libs from dependency_libs (they stay in deplibs)
+ tmp_libs=
+ for i in $dependency_libs ; do
+ case " $predeps $postdeps $compiler_lib_search_path " in
+ *" $i "*)
+ i=""
+ esac
+ if test -n "$i" ; then
+ tmp_libs="$tmp_libs $i"
+ fi
+ done
+ dependency_libs=$tmp_libs
+ done # for pass
+ dlfiles="$newdlfiles"
+ dlprefiles="$newdlprefiles"
+ fi
+ case $linkmode in
+ oldlib)
+ if test -n "$deplibs"; then
+ $echo "$modename: warning: \`-l' and \`-L' are ignored for archives" 1>&2
+ fi
+ if test -n "$dlfiles$dlprefiles" || test "$dlself" != no; then
+ $echo "$modename: warning: \`-dlopen' is ignored for archives" 1>&2
+ fi
+ if test -n "$rpath"; then
+ $echo "$modename: warning: \`-rpath' is ignored for archives" 1>&2
+ fi
+ if test -n "$xrpath"; then
+ $echo "$modename: warning: \`-R' is ignored for archives" 1>&2
+ fi
+ if test -n "$vinfo"; then
+ $echo "$modename: warning: \`-version-info/-version-number' is ignored for archives" 1>&2
+ fi
+ if test -n "$release"; then
+ $echo "$modename: warning: \`-release' is ignored for archives" 1>&2
+ fi
+ $echo "$modename: warning: \`-export-symbols' is ignored for archives" 1>&2
+ fi
+ # Now set the variables for building old libraries.
+ oldlibs="$output"
+ objs="$objs$old_deplibs"
+ lib)
+ # Make sure we only generate libraries of the form `libNAME.la'.
+ case $outputname in
+ lib*)
+ name=`$echo "X$outputname" | $Xsed -e 's/\.la$//' -e 's/^lib//'`
+ eval shared_ext=\"$shrext\"
+ eval libname=\"$libname_spec\"
+ if test "$module" = no; then
+ $echo "$modename: libtool library \`$output' must begin with \`lib'" 1>&2
+ exit 1
+ fi
+ if test "$need_lib_prefix" != no; then
+ # Add the "lib" prefix for modules if required
+ name=`$echo "X$outputname" | $Xsed -e 's/\.la$//'`
+ else
+ libname=`$echo "X$outputname" | $Xsed -e 's/\.la$//'`
+ fi
+ esac
+ if test -n "$objs"; then
+ $echo "$modename: cannot build libtool library \`$output' from non-libtool objects on this host:$objs" 2>&1
+ exit 1
+ else
+ $echo
+ $echo "*** Warning: Linking the shared library $output against the non-libtool"
+ $echo "*** objects $objs is not portable!"
+ libobjs="$libobjs $objs"
+ fi
+ fi
+ if test "$dlself" != no; then
+ $echo "$modename: warning: \`-dlopen self' is ignored for libtool libraries" 1>&2
+ fi
+ set dummy $rpath
+ if test "$#" -gt 2; then
+ $echo "$modename: warning: ignoring multiple \`-rpath's for a libtool library" 1>&2
+ fi
+ install_libdir="$2"
+ oldlibs=
+ if test -z "$rpath"; then
+ # Building a libtool convenience library.
+ # Some compilers have problems with a `.al' extension so
+ # convenience libraries should have the same extension an
+ # archive normally would.
+ oldlibs="$output_objdir/$libname.$libext $oldlibs"
+ build_libtool_libs=convenience
+ fi
+ $echo "$modename: warning: \`-version-info/-version-number' is ignored for convenience libraries" 1>&2
+ fi
+ $echo "$modename: warning: \`-release' is ignored for convenience libraries" 1>&2
+ fi
+ else
+ # Parse the version information argument.
+ save_ifs="$IFS"; IFS=':'
+ set dummy $vinfo 0 0 0
+ IFS="$save_ifs"
+ if test -n "$8"; then
+ $echo "$modename: too many parameters to \`-version-info'" 1>&2
+ exit 1
+ fi
+ # convert absolute version numbers to libtool ages
+ # this retains compatibility with .la files and attempts
+ # to make the code below a bit more comprehensible
+ case $vinfo_number in
+ yes)
+ number_major="$2"
+ number_minor="$3"
+ number_revision="$4"
+ # There are really only two kinds -- those that
+ # use the current revision as the major version
+ # and those that subtract age and use age as
+ # a minor version. But, then there is irix
+ # which has an extra 1 added just for fun
+ case $version_type in
+ darwin|linux|osf|windows)
+ current=`expr $number_major + $number_minor`
+ age="$number_minor"
+ revision="$number_revision"
+ freebsd-aout|freebsd-elf|sunos)
+ current="$number_major"
+ revision="$number_minor"
+ age="0"
+ irix|nonstopux)
+ current=`expr $number_major + $number_minor - 1`
+ esac
+ no)
+ current="$2"
+ revision="$3"
+ age="$4"
+ esac
+ # Check that each of the things are valid numbers.
+ case $current in
+ 0 | [1-9] | [1-9][0-9] | [1-9][0-9][0-9]) ;;
+ $echo "$modename: CURRENT \`$current' is not a nonnegative integer" 1>&2
+ $echo "$modename: \`$vinfo' is not valid version information" 1>&2
+ exit 1
+ esac
+ case $revision in
+ $echo "$modename: REVISION \`$revision' is not a nonnegative integer" 1>&2
+ exit 1
+ esac
+ case $age in
+ $echo "$modename: AGE \`$age' is not a nonnegative integer" 1>&2
+ exit 1
+ esac
+ if test "$age" -gt "$current"; then
+ $echo "$modename: AGE \`$age' is greater than the current interface number \`$current'" 1>&2
+ exit 1
+ fi
+ # Calculate the version variables.
+ major=
+ versuffix=
+ verstring=
+ none) ;;
+ darwin)
+ # Like Linux, but with the current version available in
+ # verstring for coding it into the library header
+ major=.`expr $current - $age`
+ versuffix="$major.$age.$revision"
+ # Darwin ld doesn't like 0 for these options...
+ minor_current=`expr $current + 1`
+ verstring="-compatibility_version $minor_current -current_version $minor_current.$revision"
+ freebsd-aout)
+ major=".$current"
+ versuffix=".$current.$revision";
+ freebsd-elf)
+ major=".$current"
+ versuffix=".$current";
+ irix | nonstopux)
+ major=`expr $current - $age + 1`
+ nonstopux) verstring_prefix=nonstopux ;;
+ *) verstring_prefix=sgi ;;
+ esac
+ verstring="$verstring_prefix$major.$revision"
+ # Add in all the interfaces that we are compatible with.
+ loop=$revision
+ while test "$loop" -ne 0; do
+ iface=`expr $revision - $loop`
+ loop=`expr $loop - 1`
+ verstring="$verstring_prefix$major.$iface:$verstring"
+ done
+ # Before this point, $major must not contain `.'.
+ major=.$major
+ versuffix="$major.$revision"
+ linux)
+ osf)
+ versuffix=".$current.$age.$revision"
+ verstring="$current.$age.$revision"
+ loop=$age
+ iface=`expr $current - $loop`
+ verstring="$verstring:${iface}.0"
+ done
+ # Make executables depend on our current version.
+ verstring="$verstring:${current}.0"
+ sunos)
+ major=".$current"
+ windows)
+ # Use '-' rather than '.', since we only want one
+ # extension on DOS 8.3 filesystems.
+ $echo "$modename: unknown library version type \`$version_type'" 1>&2
+ exit 1
+ esac
+ # Clear the version info if we defaulted, and they specified a release.
+ if test -z "$vinfo" && test -n "$release"; then
+ major=
+ darwin)
+ # we can't check for "0.0" in archive_cmds due to quoting
+ # problems, so we reset it completely
+ verstring=
+ verstring="0.0"
+ esac
+ if test "$need_version" = no; then
+ versuffix=
+ else
+ versuffix=".0.0"
+ fi
+ fi
+ # Remove version info from name if versioning should be avoided
+ if test "$avoid_version" = yes && test "$need_version" = no; then
+ major=
+ versuffix=
+ verstring=""
+ fi
+ # Check to see if the archive will have undefined symbols.
+ if test "$allow_undefined" = yes; then
+ if test "$allow_undefined_flag" = unsupported; then
+ $echo "$modename: warning: undefined symbols not allowed in $host shared libraries" 1>&2
+ fi
+ else
+ # Don't allow undefined symbols.
+ allow_undefined_flag="$no_undefined_flag"
+ fi
+ fi
+ if test "$mode" != relink; then
+ # Remove our outputs, but don't remove object files since they
+ # may have been created when compiling PIC objects.
+ removelist=
+ tempremovelist=`$echo "$output_objdir/*"`
+ for p in $tempremovelist; do
+ case $p in
+ *.$objext)
+ $output_objdir/$outputname | $output_objdir/$libname.* | $output_objdir/${libname}${release}.*)
+ removelist="$removelist $p"
+ esac
+ done
+ if test -n "$removelist"; then
+ $show "${rm}r $removelist"
+ $run ${rm}r $removelist
+ fi
+ fi
+ if test "$build_old_libs" = yes && test "$build_libtool_libs" != convenience ; then
+ oldlibs="$oldlibs $output_objdir/$libname.$libext"
+ # Transform .lo files to .o files.
+ oldobjs="$objs "`$echo "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}'$/d' -e "$lo2o" | $NL2SP`
+ fi
+ # Eliminate all temporary directories.
+ for path in $notinst_path; do
+ lib_search_path=`$echo "$lib_search_path " | ${SED} -e 's% $path % %g'`
+ deplibs=`$echo "$deplibs " | ${SED} -e 's% -L$path % %g'`
+ dependency_libs=`$echo "$dependency_libs " | ${SED} -e 's% -L$path % %g'`
+ done
+ # If the user specified any rpath flags, then add them.
+ temp_xrpath=
+ for libdir in $xrpath; do
+ temp_xrpath="$temp_xrpath -R$libdir"
+ *" $libdir "*) ;;
+ *) finalize_rpath="$finalize_rpath $libdir" ;;
+ esac
+ done
+ if true || test "$hardcode_into_libs" != yes || test "$build_old_libs" = yes; then
+ dependency_libs="$temp_xrpath $dependency_libs"
+ fi
+ fi
+ # Make sure dlfiles contains only unique files that won't be dlpreopened
+ old_dlfiles="$dlfiles"
+ dlfiles=
+ for lib in $old_dlfiles; do
+ case " $dlprefiles $dlfiles " in
+ *" $lib "*) ;;
+ *) dlfiles="$dlfiles $lib" ;;
+ esac
+ done
+ # Make sure dlprefiles contains only unique files
+ old_dlprefiles="$dlprefiles"
+ dlprefiles=
+ for lib in $old_dlprefiles; do
+ case "$dlprefiles " in
+ *" $lib "*) ;;
+ *) dlprefiles="$dlprefiles $lib" ;;
+ esac
+ done
+ case $host in
+ *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2* | *-*-beos*)
+ # these systems don't actually have a c library (as such)!
+ # Rhapsody C library is in the System framework
+ *-*-netbsd*)
+ # Don't link with libc until the a.out ld.so is fixed.
+ # Prevent $arg from being parsed by the freebsd regexp below.
+ if test "$build_libtool_need_lc" = "yes"; then
+ deplibs="$deplibs -lc"
+ fi
+ # Add libc to deplibs on all other systems if necessary.
+ fi
+ esac
+ fi
+ # Transform deplibs into only deplibs that can be linked in shared.
+ name_save=$name
+ libname_save=$libname
+ release_save=$release
+ versuffix_save=$versuffix
+ major_save=$major
+ # I'm not sure if I'm treating the release correctly. I think
+ # release should show up in the -l (ie -lgmp5) so we don't want to
+ # add it in twice. Is that correct?
+ release=""
+ versuffix=""
+ major=""
+ newdeplibs=
+ droppeddeps=no
+ case $deplibs_check_method in
+ pass_all)
+ # Don't check for shared/static. Everything works.
+ # This might be a little naive. We might want to check
+ # whether the library exists or not. But this is on
+ # osf3 & osf4 and I'm not really sure... Just
+ # implementing what was already the behavior.
+ newdeplibs=$deplibs
+ test_compile)
+ # This code stresses the "libraries are programs" paradigm to its
+ # limits. Maybe even breaks it. We compile a program, linking it
+ # against the deplibs as a proxy for the library. Then we can check
+ # whether they linked in statically or dynamically with ldd.
+ $rm conftest.c
+ cat > conftest.c <<EOF
+ int main() { return 0; }
+EOF
+ $rm conftest
+ $LTCC -o conftest conftest.c $deplibs
+ if test "$?" -eq 0 ; then
+ ldd_output=`ldd conftest`
+ for i in $deplibs; do
+ name="`expr $i : '-l\(.*\)'`"
+ # If $name is empty we are operating on a -L argument.
+ if test "$name" != "" && test "$name" -ne "0"; then
+ *" $i "*)
+ newdeplibs="$newdeplibs $i"
+ i=""
+ esac
+ fi
+ deplib_matches=`eval \\$echo \"$library_names_spec\"`
+ set dummy $deplib_matches
+ deplib_match=$2
+ if test `expr "$ldd_output" : ".*$deplib_match"` -ne 0 ; then
+ else
+ droppeddeps=yes
+ $echo
+ $echo "*** Warning: dynamic linker does not accept needed library $i."
+ $echo "*** shared version of the library, which I believe you do not have"
+ $echo "*** because a test_compile did reveal that the linker did not use it for"
+ $echo "*** its dynamic dependency list that programs get resolved with at runtime."
+ fi
+ fi
+ else
+ fi
+ done
+ else
+ # Error occurred in the first compile. Let's try to salvage
+ # the situation: Compile a separate program for each library.
+ if test "$name" != "" && test "$name" != "0"; then
+ $rm conftest
+ $LTCC -o conftest conftest.c $i
+ # Did it work?
+ *" $i "*)
+ i=""
+ esac
+ fi
+ deplib_match=$2
+ else
+ droppeddeps=yes
+ $echo
+ $echo "*** because a test_compile did reveal that the linker did not use this one"
+ $echo "*** as a dynamic dependency that programs can get resolved with at runtime."
+ fi
+ fi
+ else
+ droppeddeps=yes
+ $echo
+ $echo "*** Warning! Library $i is needed by this library but I was not able to"
+ $echo "*** make it link in! You will probably need to install it or some"
+ $echo "*** library that it depends on before this library will be fully"
+ $echo "*** functional. Installing it before continuing would be even better."
+ fi
+ else
+ fi
+ done
+ fi
+ file_magic*)
+ set dummy $deplibs_check_method
+ file_magic_regex=`expr "$deplibs_check_method" : "$2 \(.*\)"`
+ for a_deplib in $deplibs; do
+ name="`expr $a_deplib : '-l\(.*\)'`"
+ *" $a_deplib "*)
+ newdeplibs="$newdeplibs $a_deplib"
+ a_deplib=""
+ esac
+ fi
+ if test -n "$a_deplib" ; then
+ for i in $lib_search_path $sys_lib_search_path $shlib_search_path; do
+ potential_libs=`ls $i/$libname[.-]* 2>/dev/null`
+ for potent_lib in $potential_libs; do
+ # Follow soft links.
+ if ls -lLd "$potent_lib" 2>/dev/null \
+ | grep " -> " >/dev/null; then
+ continue
+ fi
+ # The statement above tries to avoid entering an
+ # endless loop below, in case of cyclic links.
+ # We might still enter an endless loop, since a link
+ # loop can be closed while we follow links,
+ # but so what?
+ potlib="$potent_lib"
+ while test -h "$potlib" 2>/dev/null; do
+ potliblink=`ls -ld $potlib | ${SED} 's/.* -> //'`
+ case $potliblink in
+ [\\/]* | [A-Za-z]:[\\/]*) potlib="$potliblink";;
+ *) potlib=`$echo "X$potlib" | $Xsed -e 's,[^/]*$,,'`"$potliblink";;
+ esac
+ done
+ if eval $file_magic_cmd \"\$potlib\" 2>/dev/null \
+ | ${SED} 10q \
+ | $EGREP "$file_magic_regex" > /dev/null; then
+ a_deplib=""
+ break 2
+ fi
+ done
+ done
+ fi
+ droppeddeps=yes
+ $echo
+ $echo "*** Warning: linker path does not have real file for library $a_deplib."
+ $echo "*** because I did check the linker path looking for a file starting"
+ if test -z "$potlib" ; then
+ $echo "*** with $libname but no candidates were found. (...for file magic test)"
+ else
+ $echo "*** with $libname and none of the candidates passed a file format test"
+ $echo "*** using a file magic. Last file checked: $potlib"
+ fi
+ fi
+ else
+ # Add a -L argument.
+ fi
+ done # Gone through all deplibs.
+ match_pattern*)
+ match_pattern_regex=`expr "$deplibs_check_method" : "$2 \(.*\)"`
+ if test -n "$name" && test "$name" != "0"; then
+ *" $a_deplib "*)
+ a_deplib=""
+ esac
+ fi
+ potlib="$potent_lib" # see symlink-check above in file_magic test
+ if eval $echo \"$potent_lib\" 2>/dev/null \
+ | ${SED} 10q \
+ | $EGREP "$match_pattern_regex" > /dev/null; then
+ a_deplib=""
+ break 2
+ fi
+ done
+ done
+ fi
+ droppeddeps=yes
+ $echo
+ $echo "*** with $libname but no candidates were found. (...for regex pattern test)"
+ else
+ $echo "*** using a regex pattern. Last file checked: $potlib"
+ fi
+ fi
+ else
+ fi
+ none | unknown | *)
+ newdeplibs=""
+ tmp_deplibs=`$echo "X $deplibs" | $Xsed -e 's/ -lc$//' \
+ -e 's/ -[LR][^ ]*//g'`
+ for i in $predeps $postdeps ; do
+ # can't use Xsed below, because $i might contain '/'
+ tmp_deplibs=`$echo "X $tmp_deplibs" | ${SED} -e "1s,^X,," -e "s,$i,,"`
+ done
+ fi
+ if $echo "X $tmp_deplibs" | $Xsed -e 's/[ ]//g' \
+ | grep . >/dev/null; then
+ $echo
+ if test "X$deplibs_check_method" = "Xnone"; then
+ $echo "*** Warning: inter-library dependencies are not supported in this platform."
+ else
+ $echo "*** Warning: inter-library dependencies are not known to be supported."
+ fi
+ $echo "*** All declared inter-library dependencies are being dropped."
+ droppeddeps=yes
+ fi
+ esac
+ versuffix=$versuffix_save
+ major=$major_save
+ release=$release_save
+ libname=$libname_save
+ name=$name_save
+ case $host in
+ # On Rhapsody replace the C library is the System framework
+ newdeplibs=`$echo "X $newdeplibs" | $Xsed -e 's/ -lc / -framework System /'`
+ esac
+ if test "$droppeddeps" = yes; then
+ $echo
+ $echo "*** Warning: libtool could not satisfy all declared inter-library"
+ $echo "*** dependencies of module $libname. Therefore, libtool will create"
+ $echo "*** a static module, that should work as long as the dlopening"
+ $echo "*** application is linked with the -dlopen flag."
+ $echo
+ fi
+ oldlibs="$output_objdir/$libname.$libext"
+ build_old_libs=yes
+ else
+ fi
+ else
+ $echo "*** The inter-library dependencies that have been dropped here will be"
+ $echo "*** automatically added whenever a program is linked with this library"
+ $echo "*** or is declared to -dlopen it."
+ if test "$allow_undefined" = no; then
+ $echo
+ $echo "*** Since this library must not contain undefined symbols,"
+ $echo "*** because either the platform does not support them or"
+ $echo "*** it was explicitly requested with -no-undefined,"
+ $echo "*** libtool will only create a static version of it."
+ else
+ fi
+ fi
+ fi
+ fi
+ # Done checking deplibs!
+ deplibs=$newdeplibs
+ fi
+ # All the library-specific variables (install_libdir is set above).
+ library_names=
+ old_library=
+ dlname=
+ # Test again, we may have decided not to build it any more
+ if test "$build_libtool_libs" = yes; then
+ if test "$hardcode_into_libs" = yes; then
+ # Hardcode the library paths
+ hardcode_libdirs=
+ dep_rpath=
+ rpath="$finalize_rpath"
+ test "$mode" != relink && test "$fast_install" = no && rpath="$compile_rpath$rpath"
+ for libdir in $rpath; do
+ if test -n "$hardcode_libdir_flag_spec"; then
+ if test -n "$hardcode_libdir_separator"; then
+ if test -z "$hardcode_libdirs"; then
+ hardcode_libdirs="$libdir"
+ else
+ # Just accumulate the unique libdirs.
+ case $hardcode_libdir_separator$hardcode_libdirs$hardcode_libdir_separator in
+ *"$hardcode_libdir_separator$libdir$hardcode_libdir_separator"*)
+ hardcode_libdirs="$hardcode_libdirs$hardcode_libdir_separator$libdir"
+ esac
+ fi
+ else
+ eval flag=\"$hardcode_libdir_flag_spec\"
+ dep_rpath="$dep_rpath $flag"
+ fi
+ elif test -n "$runpath_var"; then
+ case "$perm_rpath " in
+ *" $libdir "*) ;;
+ *) perm_rpath="$perm_rpath $libdir" ;;
+ esac
+ fi
+ done
+ # Substitute the hardcoded libdirs into the rpath.
+ if test -n "$hardcode_libdir_separator" &&
+ test -n "$hardcode_libdirs"; then
+ libdir="$hardcode_libdirs"
+ if test -n "$hardcode_libdir_flag_spec_ld"; then
+ eval dep_rpath=\"$hardcode_libdir_flag_spec_ld\"
+ else
+ eval dep_rpath=\"$hardcode_libdir_flag_spec\"
+ fi
+ fi
+ if test -n "$runpath_var" && test -n "$perm_rpath"; then
+ # We should set the runpath_var.
+ rpath=
+ for dir in $perm_rpath; do
+ rpath="$rpath$dir:"
+ done
+ eval "$runpath_var='$rpath\$$runpath_var'; export $runpath_var"
+ fi
+ test -n "$dep_rpath" && deplibs="$dep_rpath $deplibs"
+ fi
+ shlibpath="$finalize_shlibpath"
+ test "$mode" != relink && shlibpath="$compile_shlibpath$shlibpath"
+ if test -n "$shlibpath"; then
+ eval "$shlibpath_var='$shlibpath\$$shlibpath_var'; export $shlibpath_var"
+ fi
+ # Get the real and link names of the library.
+ eval library_names=\"$library_names_spec\"
+ realname="$2"
+ shift; shift
+ if test -n "$soname_spec"; then
+ else
+ fi
+ if test -z "$dlname"; then
+ dlname=$soname
+ fi
+ lib="$output_objdir/$realname"
+ for link
+ do
+ linknames="$linknames $link"
+ done
+ # Use standard objects if they are pic
+ test -z "$pic_flag" && libobjs=`$echo "X$libobjs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
+ # Prepare the list of exported symbols
+ if test -z "$export_symbols"; then
+ if test "$always_export_symbols" = yes || test -n "$export_symbols_regex"; then
+ $show "generating symbol list for \`$libname.la'"
+ export_symbols="$output_objdir/$libname.exp"
+ $run $rm $export_symbols
+ eval cmds=\"$export_symbols_cmds\"
+ IFS="$save_ifs"
+ if len=`expr "X$cmd" : ".*"` &&
+ test "$len" -le "$max_cmd_len" || test "$max_cmd_len" -le -1; then
+ $show "$cmd"
+ skipped_export=false
+ else
+ # The command line is too long to execute in one step.
+ $show "using reloadable object file for export list..."
+ skipped_export=:
+ fi
+ done
+ IFS="$save_ifs"
+ if test -n "$export_symbols_regex"; then
+ $show "$EGREP -e \"$export_symbols_regex\" \"$export_symbols\" > \"${export_symbols}T\""
+ $run eval '$EGREP -e "$export_symbols_regex" "$export_symbols" > "${export_symbols}T"'
+ $show "$mv \"${export_symbols}T\" \"$export_symbols\""
+ $run eval '$mv "${export_symbols}T" "$export_symbols"'
+ fi
+ fi
+ fi
+ if test -n "$export_symbols" && test -n "$include_expsyms"; then
+ $run eval '$echo "X$include_expsyms" | $SP2NL >> "$export_symbols"'
+ fi
+ tmp_deplibs=
+ for test_deplib in $deplibs; do
+ case " $convenience " in
+ *" $test_deplib "*) ;;
+ tmp_deplibs="$tmp_deplibs $test_deplib"
+ esac
+ done
+ deplibs="$tmp_deplibs"
+ if test -n "$convenience"; then
+ if test -n "$whole_archive_flag_spec"; then
+ save_libobjs=$libobjs
+ eval libobjs=\"\$libobjs $whole_archive_flag_spec\"
+ else
+ gentop="$output_objdir/${outputname}x"
+ $show "${rm}r $gentop"
+ $run ${rm}r "$gentop"
+ $show "$mkdir $gentop"
+ $run $mkdir "$gentop"
+ status=$?
+ if test "$status" -ne 0 && test ! -d "$gentop"; then
+ exit $status
+ fi
+ generated="$generated $gentop"
+ for xlib in $convenience; do
+ # Extract the objects.
+ case $xlib in
+ [\\/]* | [A-Za-z]:[\\/]*) xabs="$xlib" ;;
+ *) xabs=`pwd`"/$xlib" ;;
+ esac
+ xlib=`$echo "X$xlib" | $Xsed -e 's%^.*/%%'`
+ xdir="$gentop/$xlib"
+ $show "${rm}r $xdir"
+ $run ${rm}r "$xdir"
+ $show "$mkdir $xdir"
+ $run $mkdir "$xdir"
+ status=$?
+ if test "$status" -ne 0 && test ! -d "$xdir"; then
+ exit $status
+ fi
+ # We will extract separately just the conflicting names and we will no
+ # longer touch any unique names. It is faster to leave these extract
+ # automatically by $AR in one run.
+ $show "(cd $xdir && $AR x $xabs)"
+ $run eval "(cd \$xdir && $AR x \$xabs)" || exit $?
+ if ($AR t "$xabs" | sort | sort -uc >/dev/null 2>&1); then
+ else
+ $echo "$modename: warning: object name conflicts; renaming object files" 1>&2
+ $echo "$modename: warning: to ensure that they will not overwrite" 1>&2
+ $AR t "$xabs" | sort | uniq -cd | while read -r count name
+ do
+ i=1
+ while test "$i" -le "$count"
+ do
+ # Put our $i before any first dot (extension)
+ # Never overwrite any file
+ name_to="$name"
+ while test "X$name_to" = "X$name" || test -f "$xdir/$name_to"
+ do
+ name_to=`$echo "X$name_to" | $Xsed -e "s/\([^.]*\)/\1-$i/"`
+ done
+ $show "(cd $xdir && $AR xN $i $xabs '$name' && $mv '$name' '$name_to')"
+ $run eval "(cd \$xdir && $AR xN $i \$xabs '$name' && $mv '$name' '$name_to')" || exit $?
+ i=`expr $i + 1`
+ done
+ done
+ fi
+ libobjs="$libobjs "`find $xdir -name \*.$objext -print -o -name \*.lo -print | $NL2SP`
+ done
+ fi
+ fi
+ if test "$thread_safe" = yes && test -n "$thread_safe_flag_spec"; then
+ eval flag=\"$thread_safe_flag_spec\"
+ fi
+ # Make a backup of the uninstalled library when relinking
+ if test "$mode" = relink; then
+ $run eval '(cd $output_objdir && $rm ${realname}U && $mv $realname ${realname}U)' || exit $?
+ fi
+ # Add all flags from the command line. We here create a library,
+ # but those flags were only added to compile_command and
+ # finalize_command, which are only used when creating executables.
+ # So do it by hand here.
+ compiler_flags="$compiler_flags $add_flags"
+ # Only add it to commands which use CC, instead of LD, i.e.
+ # only to $compiler_flags
+ #linker_flags="$linker_flags $add_flags"
+ # Do each of the archive commands.
+ if test "$module" = yes && test -n "$module_cmds" ; then
+ if test -n "$export_symbols" && test -n "$module_expsym_cmds"; then
+ eval cmds=\"$module_expsym_cmds\"
+ else
+ eval cmds=\"$module_cmds\"
+ fi
+ else
+ if test -n "$export_symbols" && test -n "$archive_expsym_cmds"; then
+ eval cmds=\"$archive_expsym_cmds\"
+ else
+ eval cmds=\"$archive_cmds\"
+ fi
+ fi
+ if test "X$skipped_export" != "X:" && len=`expr "X$cmds" : ".*"` &&
+ else
+ # The command line is too long to link in one step, link piecewise.
+ $echo "creating reloadable object files..."
+ # Save the value of $output and $libobjs because we want to
+ # use them later. If we have whole_archive_flag_spec, we
+ # want to use save_libobjs as it was before
+ # whole_archive_flag_spec was expanded, because we can't
+ # assume the linker understands whole_archive_flag_spec.
+ # This may have to be revisited, in case too many
+ # convenience libraries get linked in and end up exceeding
+ # the spec.
+ if test -z "$convenience" || test -z "$whole_archive_flag_spec"; then
+ fi
+ save_output=$output
+ # Clear the reloadable object creation command queue and
+ # initialize k to one.
+ test_cmds=
+ concat_cmds=
+ objlist=
+ delfiles=
+ last_robj=
+ k=1
+ output=$output_objdir/$save_output-${k}.$objext
+ # Loop over the list of objects to be linked.
+ for obj in $save_libobjs
+ do
+ eval test_cmds=\"$reload_cmds $objlist $last_robj\"
+ if test "X$objlist" = X ||
+ { len=`expr "X$test_cmds" : ".*"` &&
+ test "$len" -le "$max_cmd_len"; }; then
+ objlist="$objlist $obj"
+ else
+ # The command $test_cmds is almost too long, add a
+ # command to the queue.
+ if test "$k" -eq 1 ; then
+ # The first file doesn't have a previous command to add.
+ eval concat_cmds=\"$reload_cmds $objlist $last_robj\"
+ else
+ # All subsequent reloadable object files will link in
+ # the last one created.
+ eval concat_cmds=\"\$concat_cmds~$reload_cmds $objlist $last_robj\"
+ fi
+ last_robj=$output_objdir/$save_output-${k}.$objext
+ k=`expr $k + 1`
+ objlist=$obj
+ len=1
+ fi
+ done
+ # Handle the remaining objects by creating one last
+ # reloadable object file. All subsequent reloadable object
+ # files will link in the last one created.
+ test -z "$concat_cmds" || concat_cmds=$concat_cmds~
+ eval concat_cmds=\"\${concat_cmds}$reload_cmds $objlist $last_robj\"
+ if ${skipped_export-false}; then
+ libobjs=$output
+ # Append the command to create the export file.
+ eval concat_cmds=\"\$concat_cmds~$export_symbols_cmds\"
+ fi
+ # Set up a command to remove the reloadale object files
+ # after they are used.
+ i=0
+ while test "$i" -lt "$k"
+ do
+ i=`expr $i + 1`
+ delfiles="$delfiles $output_objdir/$save_output-${i}.$objext"
+ done
+ $echo "creating a temporary reloadable object file: $output"
+ # Loop through the commands generated above and execute them.
+ for cmd in $concat_cmds; do
+ IFS="$save_ifs"
+ $show "$cmd"
+ done
+ IFS="$save_ifs"
+ libobjs=$output
+ # Restore the value of output.
+ output=$save_output
+ if test -n "$convenience" && test -n "$whole_archive_flag_spec"; then
+ fi
+ # Expand the library linking commands again to reset the
+ # value of $libobjs for piecewise linking.
+ else
+ fi
+ # Append the command to remove the reloadable object files
+ # to the just-reset $cmds.
+ eval cmds=\"\$cmds~$rm $delfiles\"
+ fi
+ IFS="$save_ifs"
+ $show "$cmd"
+ done
+ IFS="$save_ifs"
+ # Restore the uninstalled library and exit
+ $run eval '(cd $output_objdir && $rm ${realname}T && $mv $realname ${realname}T && $mv "$realname"U $realname)' || exit $?
+ exit 0
+ fi
+ # Create links to the real library.
+ for linkname in $linknames; do
+ if test "$realname" != "$linkname"; then
+ $show "(cd $output_objdir && $rm $linkname && $LN_S $realname $linkname)"
+ $run eval '(cd $output_objdir && $rm $linkname && $LN_S $realname $linkname)' || exit $?
+ fi
+ done
+ # If -module or -export-dynamic was specified, set the dlname.
+ if test "$module" = yes || test "$export_dynamic" = yes; then
+ # On all known operating systems, these are identical.
+ dlname="$soname"
+ fi
+ fi
+ obj)
+ $echo "$modename: warning: \`-l' and \`-L' are ignored for objects" 1>&2
+ fi
+ $echo "$modename: warning: \`-dlopen' is ignored for objects" 1>&2
+ fi
+ $echo "$modename: warning: \`-rpath' is ignored for objects" 1>&2
+ fi
+ $echo "$modename: warning: \`-R' is ignored for objects" 1>&2
+ fi
+ $echo "$modename: warning: \`-version-info' is ignored for objects" 1>&2
+ fi
+ $echo "$modename: warning: \`-release' is ignored for objects" 1>&2
+ fi
+ case $output in
+ *.lo)
+ if test -n "$objs$old_deplibs"; then
+ $echo "$modename: cannot build library object \`$output' from non-libtool objects" 1>&2
+ exit 1
+ fi
+ libobj="$output"
+ obj=`$echo "X$output" | $Xsed -e "$lo2o"`
+ libobj=
+ obj="$output"
+ esac
+ # Delete the old objects.
+ $run $rm $obj $libobj
+ # Objects from convenience libraries. This assumes
+ # single-version convenience libraries. Whenever we create
+ # different ones for PIC/non-PIC, this we'll have to duplicate
+ # the extraction.
+ reload_conv_objs=
+ gentop=
+ # reload_cmds runs $LD directly, so let us get rid of
+ # -Wl from whole_archive_flag_spec
+ wl=
+ eval reload_conv_objs=\"\$reload_objs $whole_archive_flag_spec\"
+ else
+ gentop="$output_objdir/${obj}x"
+ status=$?
+ exit $status
+ fi
+ case $xlib in
+ esac
+ status=$?
+ exit $status
+ fi
+ else
+ do
+ i=1
+ do
+ name_to="$name"
+ do
+ done
+ i=`expr $i + 1`
+ done
+ done
+ fi
+ reload_conv_objs="$reload_objs "`find $xdir -name \*.$objext -print -o -name \*.lo -print | $NL2SP`
+ done
+ fi
+ fi
+ # Create the old-style object.
+ reload_objs="$objs$old_deplibs "`$echo "X$libobjs" | $SP2NL | $Xsed -e '/\.'${libext}$'/d' -e '/\.lib$/d' -e "$lo2o" | $NL2SP`" $reload_conv_objs" ### testsuite: skip nested quoting test
+ output="$obj"
+ eval cmds=\"$reload_cmds\"
+ IFS="$save_ifs"
+ $show "$cmd"
+ done
+ IFS="$save_ifs"
+ # Exit if we aren't doing a library object file.
+ if test -z "$libobj"; then
+ if test -n "$gentop"; then
+ $run ${rm}r $gentop
+ fi
+ exit 0
+ fi
+ if test "$build_libtool_libs" != yes; then
+ fi
+ # Create an invalid libtool object if no PIC, so that we don't
+ # accidentally link it into a program.
+ # $show "echo timestamp > $libobj"
+ # $run eval "echo timestamp > $libobj" || exit $?
+ exit 0
+ fi
+ if test -n "$pic_flag" || test "$pic_mode" != default; then
+ # Only do commands if we really have different PIC objects.
+ reload_objs="$libobjs $reload_conv_objs"
+ output="$libobj"
+ IFS="$save_ifs"
+ $show "$cmd"
+ done
+ IFS="$save_ifs"
+ fi
+ fi
+ exit 0
+ prog)
+ case $host in
+ *cygwin*) output=`$echo $output | ${SED} -e 's,.exe$,,;s,$,.exe,'` ;;
+ esac
+ $echo "$modename: warning: \`-version-info' is ignored for programs" 1>&2
+ fi
+ $echo "$modename: warning: \`-release' is ignored for programs" 1>&2
+ fi
+ if test "$preload" = yes; then
+ if test "$dlopen_support" = unknown && test "$dlopen_self" = unknown &&
+ test "$dlopen_self_static" = unknown; then
+ $echo "$modename: warning: \`AC_LIBTOOL_DLOPEN' not used. Assuming no dlopen support."
+ fi
+ fi
+ case $host in
+ compile_deplibs=`$echo "X $compile_deplibs" | $Xsed -e 's/ -lc / -framework System /'`
+ finalize_deplibs=`$echo "X $finalize_deplibs" | $Xsed -e 's/ -lc / -framework System /'`
+ esac
+ case $host in
+ *darwin*)
+ # Don't allow lazy linking, it breaks C++ global constructors
+ if test "$tagname" = CXX ; then
+ compile_command="$compile_command ${wl}-bind_at_load"
+ finalize_command="$finalize_command ${wl}-bind_at_load"
+ fi
+ esac
+ compile_command="$compile_command $compile_deplibs"
+ finalize_command="$finalize_command $finalize_deplibs"
+ if test -n "$rpath$xrpath"; then
+ for libdir in $rpath $xrpath; do
+ # This is the magic to use -rpath.
+ *" $libdir "*) ;;
+ esac
+ done
+ fi
+ # Now hardcode the library paths
+ rpath=
+ hardcode_libdirs=
+ for libdir in $compile_rpath $finalize_rpath; do
+ else
+ esac
+ fi
+ else
+ rpath="$rpath $flag"
+ fi
+ *" $libdir "*) ;;
+ esac
+ fi
+ case $host in
+ *-*-cygwin* | *-*-mingw* | *-*-pw32* | *-*-os2*)
+ case :$dllsearchpath: in
+ *":$libdir:"*) ;;
+ *) dllsearchpath="$dllsearchpath:$libdir";;
+ esac
+ esac
+ done
+ eval rpath=\" $hardcode_libdir_flag_spec\"
+ fi
+ compile_rpath="$rpath"
+ rpath=
+ hardcode_libdirs=
+ for libdir in $finalize_rpath; do
+ else
+ esac
+ fi
+ else
+ fi
+ case "$finalize_perm_rpath " in
+ *" $libdir "*) ;;
+ *) finalize_perm_rpath="$finalize_perm_rpath $libdir" ;;
+ esac
+ fi
+ done
+ fi
+ finalize_rpath="$rpath"
+ if test -n "$libobjs" && test "$build_old_libs" = yes; then
+ # Transform all the library objects into standard objects.
+ compile_command=`$echo "X$compile_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
+ finalize_command=`$echo "X$finalize_command" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
+ fi
+ dlsyms=
+ if test -n "$NM" && test -n "$global_symbol_pipe"; then
+ dlsyms="${outputname}S.c"
+ else
+ $echo "$modename: not configured to extract global symbols from dlpreopened files" 1>&2
+ fi
+ fi
+ if test -n "$dlsyms"; then
+ case $dlsyms in
+ *.c)
+ # Discover the nlist of each of the dlfiles.
+ nlist="$output_objdir/${outputname}.nm"
+ $show "$rm $nlist ${nlist}S ${nlist}T"
+ $run $rm "$nlist" "${nlist}S" "${nlist}T"
+ # Parse the name list into a source file.
+ $show "creating $output_objdir/$dlsyms"
+ test -z "$run" && $echo > "$output_objdir/$dlsyms" "\
+/* $dlsyms - symbol resolution table for \`$outputname' dlsym emulation. */
+/* Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP */
+#ifdef __cplusplus
+extern \"C\" {
+#endif
+/* Prevent the only kind of declaration conflicts we can make. */
+#define lt_preloaded_symbols some_other_symbol
+/* External symbol declarations for the compiler. */\
+ if test "$dlself" = yes; then
+ $show "generating symbol list for \`$output'"
+ test -z "$run" && $echo ': @PROGRAM@ ' > "$nlist"
+ # Add our own program objects to the symbol list.
+ progfiles=`$echo "X$objs$old_deplibs" | $SP2NL | $Xsed -e "$lo2o" | $NL2SP`
+ for arg in $progfiles; do
+ $show "extracting global C symbols from \`$arg'"
+ $run eval "$NM $arg | $global_symbol_pipe >> '$nlist'"
+ done
+ if test -n "$exclude_expsyms"; then
+ $run eval '$EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T'
+ $run eval '$mv "$nlist"T "$nlist"'
+ fi
+ $run eval '$EGREP -e "$export_symbols_regex" "$nlist" > "$nlist"T'
+ fi
+ export_symbols="$output_objdir/$output.exp"
+ $run eval "${SED} -n -e '/^: @PROGRAM@$/d' -e 's/^.* \(.*\)$/\1/p' "'< "$nlist" > "$export_symbols"'
+ else
+ $run eval "${SED} -e 's/\([][.*^$]\)/\\\1/g' -e 's/^/ /' -e 's/$/$/'"' < "$export_symbols" > "$output_objdir/$output.exp"'
+ $run eval 'grep -f "$output_objdir/$output.exp" < "$nlist" > "$nlist"T'
+ $run eval 'mv "$nlist"T "$nlist"'
+ fi
+ fi
+ for arg in $dlprefiles; do
+ name=`$echo "$arg" | ${SED} -e 's%^.*/%%'`
+ $run eval '$echo ": $name " >> "$nlist"'
+ done
+ if test -z "$run"; then
+ # Make sure we have at least an empty file.
+ test -f "$nlist" || : > "$nlist"
+ $EGREP -v " ($exclude_expsyms)$" "$nlist" > "$nlist"T
+ $mv "$nlist"T "$nlist"
+ fi
+ # Try sorting and uniquifying the output.
+ if grep -v "^: " < "$nlist" |
+ if sort -k 3 </dev/null >/dev/null 2>&1; then
+ sort -k 3
+ else
+ sort +2
+ fi |
+ uniq > "$nlist"S; then
+ else
+ grep -v "^: " < "$nlist" > "$nlist"S
+ fi
+ if test -f "$nlist"S; then
+ eval "$global_symbol_to_cdecl"' < "$nlist"S >> "$output_objdir/$dlsyms"'
+ else
+ $echo '/* NONE */' >> "$output_objdir/$dlsyms"
+ fi
+ $echo >> "$output_objdir/$dlsyms" "\
+#undef lt_preloaded_symbols
+#if defined (__STDC__) && __STDC__
+# define lt_ptr void *
+#else
+# define lt_ptr char *
+# define const
+#endif
+/* The mapping between symbol names and symbols. */
+const struct {
+ const char *name;
+ lt_ptr address;
+lt_preloaded_symbols[] =
+ eval "$global_symbol_to_c_name_address" < "$nlist" >> "$output_objdir/$dlsyms"
+ {0, (lt_ptr) 0}
+/* This works around a problem in FreeBSD linker */
+#ifdef FREEBSD_WORKAROUND
+static const void *lt_preloaded_setup() {
+ return lt_preloaded_symbols;
+#endif
+#ifdef __cplusplus
+#endif\
+ fi
+ pic_flag_for_symtable=
+ case $host in
+ # compiling the symbol table file with pic_flag works around
+ # a FreeBSD bug that causes programs to crash when -lm is
+ # linked before any other PIC object. But we must not use
+ # pic_flag when linking with -static. The problem exists in
+ # FreeBSD 2.2.6 and is fixed in FreeBSD 3.1.
+ *-*-freebsd2*|*-*-freebsd3.0*|*-*-freebsdelf3.0*)
+ case "$compile_command " in
+ *" -static "*) ;;
+ *) pic_flag_for_symtable=" $pic_flag -DFREEBSD_WORKAROUND";;
+ esac;;
+ *-*-hpux*)
+ *" -static "*) ;;
+ *) pic_flag_for_symtable=" $pic_flag";;
+ esac
+ esac
+ # Now compile the dynamic symbol file.
+ $show "(cd $output_objdir && $LTCC -c$no_builtin_flag$pic_flag_for_symtable \"$dlsyms\")"
+ $run eval '(cd $output_objdir && $LTCC -c$no_builtin_flag$pic_flag_for_symtable "$dlsyms")' || exit $?
+ # Clean up the generated files.
+ $show "$rm $output_objdir/$dlsyms $nlist ${nlist}S ${nlist}T"
+ $run $rm "$output_objdir/$dlsyms" "$nlist" "${nlist}S" "${nlist}T"
+ # Transform the symbol file into the correct name.
+ compile_command=`$echo "X$compile_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/${outputname}S.${objext}%"`
+ finalize_command=`$echo "X$finalize_command" | $Xsed -e "s%@SYMFILE@%$output_objdir/${outputname}S.${objext}%"`
+ $echo "$modename: unknown suffix for \`$dlsyms'" 1>&2
+ exit 1
+ esac
+ else
+ # We keep going just in case the user didn't refer to
+ # lt_preloaded_symbols. The linker will fail if global_symbol_pipe
+ # really was required.
+ # Nullify the symbol file.
+ compile_command=`$echo "X$compile_command" | $Xsed -e "s% @SYMFILE@%%"`
+ finalize_command=`$echo "X$finalize_command" | $Xsed -e "s% @SYMFILE@%%"`
+ fi
+ # AIX runtime linking requires linking programs with -Wl,-brtl and libs with -Wl,-G
+ # Also add -bnolibpath to the beginning of the link line, to clear the hardcoded runpath.
+ # Otherwise, things like the -L path to libgcc.a are accidentally hardcoded by ld.
+ # This does not apply on AIX for ia64, which uses a SysV linker.
+ case "$host" in
+ ia64-*-aix5*) ;;
+ *-*-aix4* | *-*-aix5*)
+ compile_command=`$echo "X$compile_command $wl-brtl" | $Xsed -e "s/\$CC/\$CC $wl-bnolibpath/1"`
+ finalize_command=`$echo "X$finalize_command $wl-brtl" | $Xsed -e "s/\$CC/\$CC $wl-bnolibpath/1"` ;;
+ esac
+ if test "$need_relink" = no || test "$build_libtool_libs" != yes; then
+ # Replace the output file specification.
+ compile_command=`$echo "X$compile_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
+ link_command="$compile_command$compile_rpath"
+ # We have no uninstalled library dependencies, so finalize right now.
+ $show "$link_command"
+ $run eval "$link_command"
+ status=$?
+ # Delete the generated files.
+ $show "$rm $output_objdir/${outputname}S.${objext}"
+ $run $rm "$output_objdir/${outputname}S.${objext}"
+ fi
+ exit $status
+ fi
+ if test -n "$shlibpath_var"; then
+ # We should set the shlibpath_var
+ rpath=
+ for dir in $temp_rpath; do
+ case $dir in
+ # Absolute path.
+ # Relative path: add a thisdir entry.
+ rpath="$rpath\$thisdir/$dir:"
+ esac
+ done
+ temp_rpath="$rpath"
+ fi
+ if test -n "$compile_shlibpath$finalize_shlibpath"; then
+ compile_command="$shlibpath_var=\"$compile_shlibpath$finalize_shlibpath\$$shlibpath_var\" $compile_command"
+ fi
+ if test -n "$finalize_shlibpath"; then
+ finalize_command="$shlibpath_var=\"$finalize_shlibpath\$$shlibpath_var\" $finalize_command"
+ fi
+ compile_var=
+ finalize_var=
+ if test -n "$runpath_var"; then
+ if test -n "$perm_rpath"; then
+ rpath=
+ done
+ compile_var="$runpath_var=\"$rpath\$$runpath_var\" "
+ fi
+ if test -n "$finalize_perm_rpath"; then
+ rpath=
+ for dir in $finalize_perm_rpath; do
+ done
+ finalize_var="$runpath_var=\"$rpath\$$runpath_var\" "
+ fi
+ fi
+ if test "$no_install" = yes; then
+ # We don't need to create a wrapper script.
+ link_command="$compile_var$compile_command$compile_rpath"
+ link_command=`$echo "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output"'%g'`
+ # Delete the old output file.
+ $run $rm $output
+ # Link the executable and exit
+ $run eval "$link_command" || exit $?
+ exit 0
+ fi
+ if test "$hardcode_action" = relink; then
+ # Fast installation is not supported
+ relink_command="$finalize_var$finalize_command$finalize_rpath"
+ $echo "$modename: warning: this platform does not like uninstalled shared libraries" 1>&2
+ $echo "$modename: \`$output' will be relinked during installation" 1>&2
+ else
+ if test "$fast_install" != no; then
+ link_command="$finalize_var$compile_command$finalize_rpath"
+ if test "$fast_install" = yes; then
+ relink_command=`$echo "X$compile_var$compile_command$compile_rpath" | $Xsed -e 's%@OUTPUT@%\$progdir/\$file%g'`
+ else
+ # fast_install is set to needless
+ relink_command=
+ fi
+ else
+ fi
+ fi
+ link_command=`$echo "X$link_command" | $Xsed -e 's%@OUTPUT@%'"$output_objdir/$outputname"'%g'`
+ # Delete the old output files.
+ $run $rm $output $output_objdir/$outputname $output_objdir/lt-$outputname
+ # Now create the wrapper script.
+ $show "creating $output"
+ # Quote the relink command for shipping.
+ if test -n "$relink_command"; then
+ # Preserve any variables that may affect compiler behavior
+ for var in $variables_saved_for_relink; do
+ if eval test -z \"\${$var+set}\"; then
+ relink_command="{ test -z \"\${$var+set}\" || unset $var || { $var=; export $var; }; }; $relink_command"
+ elif eval var_value=\$$var; test -z "$var_value"; then
+ relink_command="$var=; export $var; $relink_command"
+ else
+ var_value=`$echo "X$var_value" | $Xsed -e "$sed_quote_subst"`
+ relink_command="$var=\"$var_value\"; export $var; $relink_command"
+ fi
+ done
+ relink_command="(cd `pwd`; $relink_command)"
+ relink_command=`$echo "X$relink_command" | $Xsed -e "$sed_quote_subst"`
+ fi
+ # Quote $echo for shipping.
+ if test "X$echo" = "X$SHELL $0 --fallback-echo"; then
+ case $0 in
+ [\\/]* | [A-Za-z]:[\\/]*) qecho="$SHELL $0 --fallback-echo";;
+ *) qecho="$SHELL `pwd`/$0 --fallback-echo";;
+ esac
+ qecho=`$echo "X$qecho" | $Xsed -e "$sed_quote_subst"`
+ else
+ qecho=`$echo "X$echo" | $Xsed -e "$sed_quote_subst"`
+ fi
+ # Only actually do things if our run command is non-null.
+ # win32 will think the script is a binary if it has
+ # a .exe suffix, so we strip it off here.
+ case $output in
+ *.exe) output=`$echo $output|${SED} 's,.exe$,,'` ;;
+ esac
+ # test for cygwin because mv fails w/o .exe extensions
+ case $host in
+ *cygwin*)
+ exeext=.exe
+ outputname=`$echo $outputname|${SED} 's,.exe$,,'` ;;
+ *) exeext= ;;
+ esac
+ case $host in
+ *cygwin* | *mingw* )
+ cwrappersource=`$echo ${objdir}/lt-${output}.c`
+ cwrapper=`$echo ${output}.exe`
+ $rm $cwrappersource $cwrapper
+ trap "$rm $cwrappersource $cwrapper; exit 1" 1 2 15
+ cat > $cwrappersource <<EOF
+/* $cwrappersource - temporary wrapper executable for $objdir/$outputname
+ Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP
+ The $output program cannot be directly executed until all the libtool
+ libraries that it depends on are installed.
+ This wrapper executable should never be moved out of the build directory.
+ If it is, it will not operate correctly.
+ Currently, it simply execs the wrapper *script* "/bin/sh $output",
+ but could eventually absorb all of the scripts functionality and
+ exec $objdir/$outputname directly.
+EOF
+ cat >> $cwrappersource<<"EOF"
+#include <stdio.h>
+#include <stdlib.h>
+#include <unistd.h>
+#include <malloc.h>
+#include <stdarg.h>
+#include <assert.h>
+#if defined(PATH_MAX)
+# define LT_PATHMAX PATH_MAX
+#elif defined(MAXPATHLEN)
+# define LT_PATHMAX MAXPATHLEN
+#else
+# define LT_PATHMAX 1024
+#endif
+#ifndef DIR_SEPARATOR
+#define DIR_SEPARATOR '/'
+#endif
+#if defined (_WIN32) || defined (__MSDOS__) || defined (__DJGPP__) || \
+ defined (__OS2__)
+#define HAVE_DOS_BASED_FILE_SYSTEM
+#ifndef DIR_SEPARATOR_2
+#define DIR_SEPARATOR_2 '\\'
+#endif
+#endif
+# define IS_DIR_SEPARATOR(ch) ((ch) == DIR_SEPARATOR)
+#else /* DIR_SEPARATOR_2 */
+# define IS_DIR_SEPARATOR(ch) \
+ (((ch) == DIR_SEPARATOR) || ((ch) == DIR_SEPARATOR_2))
+#endif /* DIR_SEPARATOR_2 */
+#define XMALLOC(type, num) ((type *) xmalloc ((num) * sizeof(type)))
+#define XFREE(stale) do { \
+ if (stale) { free ((void *) stale); stale = 0; } \
+} while (0)
+const char *program_name = NULL;
+void * xmalloc (size_t num);
+char * xstrdup (const char *string);
+char * basename (const char *name);
+char * fnqualify(const char *path);
+char * strendzap(char *str, const char *pat);
+void lt_fatal (const char *message, ...);
+int
+main (int argc, char *argv[])
+ char **newargz;
+ int i;
+ program_name = (char *) xstrdup ((char *) basename (argv[0]));
+ newargz = XMALLOC(char *, argc+2);
+EOF
+ cat >> $cwrappersource <<EOF
+ newargz[0] = "$SHELL";
+EOF
+ cat >> $cwrappersource <<"EOF"
+ newargz[1] = fnqualify(argv[0]);
+ /* we know the script has the same name, without the .exe */
+ /* so make sure newargz[1] doesn't end in .exe */
+ strendzap(newargz[1],".exe");
+ for (i = 1; i < argc; i++)
+ newargz[i+1] = xstrdup(argv[i]);
+ newargz[argc+1] = NULL;
+EOF
+ execv("$SHELL",newargz);
+EOF
+void *
+xmalloc (size_t num)
+ void * p = (void *) malloc (num);
+ if (!p)
+ lt_fatal ("Memory exhausted");
+ return p;
+char *
+xstrdup (const char *string)
+ return string ? strcpy ((char *) xmalloc (strlen (string) + 1), string) : NULL
+char *
+basename (const char *name)
+ const char *base;
+#if defined (HAVE_DOS_BASED_FILE_SYSTEM)
+ /* Skip over the disk name in MSDOS pathnames. */
+ if (isalpha (name[0]) && name[1] == ':')
+ name += 2;
+#endif
+ for (base = name; *name; name++)
+ if (IS_DIR_SEPARATOR (*name))
+ base = name + 1;
+ return (char *) base;
+char *
+fnqualify(const char *path)
+ size_t size;
+ char *p;
+ char tmp[LT_PATHMAX + 1];
+ assert(path != NULL);
+ /* Is it qualified already? */
+ if (isalpha (path[0]) && path[1] == ':')
+ return xstrdup (path);
+#endif
+ if (IS_DIR_SEPARATOR (path[0]))
+ /* prepend the current directory */
+ /* doesn't handle '~' */
+ if (getcwd (tmp, LT_PATHMAX) == NULL)
+ lt_fatal ("getcwd failed");
+ size = strlen(tmp) + 1 + strlen(path) + 1; /* +2 for '/' and '\0' */
+ p = XMALLOC(char, size);
+ sprintf(p, "%s%c%s", tmp, DIR_SEPARATOR, path);
+ return p;
+char *
+strendzap(char *str, const char *pat)
+ size_t len, patlen;
+ assert(str != NULL);
+ assert(pat != NULL);
+ len = strlen(str);
+ patlen = strlen(pat);
+ if (patlen <= len)
+ str += len - patlen;
+ if (strcmp(str, pat) == 0)
+ *str = '\0';
+ return str;
+static void
+lt_error_core (int exit_status, const char * mode,
+ const char * message, va_list ap)
+ fprintf (stderr, "%s: %s: ", program_name, mode);
+ vfprintf (stderr, message, ap);
+ fprintf (stderr, ".\n");
+ if (exit_status >= 0)
+ exit (exit_status);
+void
+lt_fatal (const char *message, ...)
+ va_list ap;
+ va_start (ap, message);
+ lt_error_core (EXIT_FAILURE, "FATAL", message, ap);
+ va_end (ap);
+EOF
+ # we should really use a build-platform specific compiler
+ # here, but OTOH, the wrappers (shell script and this C one)
+ # are only useful if you want to execute the "real" binary.
+ # Since the "real" binary is built for $host, then this
+ # wrapper might as well be built for $host, too.
+ $run $LTCC -s -o $cwrapper $cwrappersource
+ esac
+ $rm $output
+ trap "$rm $output; exit 1" 1 2 15
+ $echo > $output "\
+#! $SHELL
+# $output - temporary wrapper script for $objdir/$outputname
+# Generated by $PROGRAM - GNU $PACKAGE $VERSION$TIMESTAMP
+# The $output program cannot be directly executed until all the libtool
+# libraries that it depends on are installed.
+# This wrapper script should never be moved out of the build directory.
+# If it is, it will not operate correctly.
+# Sed substitution that helps us do robust quoting. It backslashifies
+# metacharacters that are still active within double-quoted strings.
+Xsed='${SED} -e 1s/^X//'
+sed_quote_subst='$sed_quote_subst'
+# The HP-UX ksh and POSIX shell print the target directory to stdout
+# if CDPATH is set.
+if test \"\${CDPATH+set}\" = set; then CDPATH=:; export CDPATH; fi
+relink_command=\"$relink_command\"
+# This environment variable determines our operation mode.
+if test \"\$libtool_install_magic\" = \"$magic\"; then
+ # install mode needs the following variable:
+ notinst_deplibs='$notinst_deplibs'
+else
+ # When we are sourced in execute mode, \$file and \$echo are already set.
+ if test \"\$libtool_execute_magic\" != \"$magic\"; then
+ echo=\"$qecho\"
+ file=\"\$0\"
+ # Make sure echo works.
+ if test \"X\$1\" = X--no-reexec; then
+ # Discard the --no-reexec flag, and continue.
+ shift
+ elif test \"X\`(\$echo '\t') 2>/dev/null\`\" = 'X\t'; then
+ # Yippee, \$echo works!
+ else
+ # Restart under the correct shell, and then maybe \$echo will work.
+ exec $SHELL \"\$0\" --no-reexec \${1+\"\$@\"}
+ fi
+ fi\
+ $echo >> $output "\
+ # Find the directory that this script lives in.
+ thisdir=\`\$echo \"X\$file\" | \$Xsed -e 's%/[^/]*$%%'\`
+ test \"x\$thisdir\" = \"x\$file\" && thisdir=.
+ # Follow symbolic links until we get to the real thisdir.
+ file=\`ls -ld \"\$file\" | ${SED} -n 's/.*-> //p'\`
+ while test -n \"\$file\"; do
+ destdir=\`\$echo \"X\$file\" | \$Xsed -e 's%/[^/]*\$%%'\`
+ # If there was a directory component, then change thisdir.
+ if test \"x\$destdir\" != \"x\$file\"; then
+ case \"\$destdir\" in
+ [\\\\/]* | [A-Za-z]:[\\\\/]*) thisdir=\"\$destdir\" ;;
+ *) thisdir=\"\$thisdir/\$destdir\" ;;
+ esac
+ fi
+ file=\`\$echo \"X\$file\" | \$Xsed -e 's%^.*/%%'\`
+ file=\`ls -ld \"\$thisdir/\$file\" | ${SED} -n 's/.*-> //p'\`
+ done
+ # Try to get the absolute directory name.
+ absdir=\`cd \"\$thisdir\" && pwd\`
+ test -n \"\$absdir\" && thisdir=\"\$absdir\"
+ program=lt-'$outputname'$exeext
+ progdir=\"\$thisdir/$objdir\"
+ if test ! -f \"\$progdir/\$program\" || \\
+ { file=\`ls -1dt \"\$progdir/\$program\" \"\$progdir/../\$program\" 2>/dev/null | ${SED} 1q\`; \\
+ test \"X\$file\" != \"X\$progdir/\$program\"; }; then
+ file=\"\$\$-\$program\"
+ if test ! -d \"\$progdir\"; then
+ $mkdir \"\$progdir\"
+ else
+ $rm \"\$progdir/\$file\"
+ fi"
+ # relink executable if necessary
+ if test -n \"\$relink_command\"; then
+ if relink_command_output=\`eval \$relink_command 2>&1\`; then :
+ else
+ $echo \"\$relink_command_output\" >&2
+ exit 1
+ fi
+ fi
+ $mv \"\$progdir/\$file\" \"\$progdir/\$program\" 2>/dev/null ||
+ { $rm \"\$progdir/\$program\";
+ $mv \"\$progdir/\$file\" \"\$progdir/\$program\"; }
+ fi"
+ else
+ program='$outputname'
+ fi
+ if test -f \"\$progdir/\$program\"; then"
+ # Export our shlibpath_var if we have one.
+ if test "$shlibpath_overrides_runpath" = yes && test -n "$shlibpath_var" && test -n "$temp_rpath"; then
+ # Add our own library path to $shlibpath_var
+ $shlibpath_var=\"$temp_rpath\$$shlibpath_var\"
+ # Some systems cannot cope with colon-terminated $shlibpath_var
+ # The second colon is a workaround for a bug in BeOS R4 sed
+ $shlibpath_var=\`\$echo \"X\$$shlibpath_var\" | \$Xsed -e 's/::*\$//'\`
+ export $shlibpath_var
+ fi
+ # fixup the dll searchpath if we need to.
+ if test -n "$dllsearchpath"; then
+ # Add the dll search path components to the executable PATH
+ PATH=$dllsearchpath:\$PATH
+ fi
+ # Run the actual program with our arguments.
+ case $host in
+ # Backslashes separate directories on plain windows
+ *-*-mingw | *-*-os2*)
+ exec \$progdir\\\\\$program \${1+\"\$@\"}
+ exec \$progdir/\$program \${1+\"\$@\"}
+ esac
+ \$echo \"\$0: cannot exec \$program \${1+\"\$@\"}\"
+ exit 1
+ fi
+ else
+ # The program doesn't exist.
+ \$echo \"\$0: error: \$progdir/\$program does not exist\" 1>&2
+ \$echo \"This script is just a wrapper for \$program.\" 1>&2
+ $echo \"See the $PACKAGE documentation for more information.\" 1>&2
+ exit 1
+ fi
+fi\
+ chmod +x $output
+ fi
+ exit 0
+ esac
+ # See if we need to build an old-fashioned archive.
+ for oldlib in $oldlibs; do
+ if test "$build_libtool_libs" = convenience; then
+ oldobjs="$libobjs_save"
+ addlibs="$convenience"
+ build_libtool_libs=no
+ else
+ if test "$build_libtool_libs" = module; then
+ else
+ oldobjs="$old_deplibs $non_pic_objects"
+ fi
+ addlibs="$old_convenience"
+ fi
+ if test -n "$addlibs"; then
+ status=$?
+ exit $status
+ fi
+ # Add in members from convenience archives.
+ for xlib in $addlibs; do
+ case $xlib in
+ esac
+ status=$?
+ exit $status
+ fi
+ else
+ do
+ i=1
+ do
+ name_to="$name"
+ do
+ done
+ i=`expr $i + 1`
+ done
+ done
+ fi
+ oldobjs="$oldobjs "`find $xdir -name \*.${objext} -print -o -name \*.lo -print | $NL2SP`
+ done
+ fi
+ # Do each command in the archive commands.
+ if test -n "$old_archive_from_new_cmds" && test "$build_libtool_libs" = yes; then
+ eval cmds=\"$old_archive_from_new_cmds\"
+ else
+ eval cmds=\"$old_archive_cmds\"
+ if len=`expr "X$cmds" : ".*"` &&
+ else
+ # the command line is too long to link in one step, link in parts
+ $echo "using piecewise archive linking..."
+ save_RANLIB=$RANLIB
+ RANLIB=:
+ objlist=
+ concat_cmds=
+ save_oldobjs=$oldobjs
+ # GNU ar 2.10+ was changed to match POSIX; thus no paths are
+ # encoded into archives. This makes 'ar r' malfunction in
+ # this piecewise linking case whenever conflicting object
+ # names appear in distinct ar calls; check, warn and compensate.
+ if (for obj in $save_oldobjs
+ do
+ $echo "X$obj" | $Xsed -e 's%^.*/%%'
+ done | sort | sort -uc >/dev/null 2>&1); then
+ else
+ $echo "$modename: warning: object name conflicts; overriding AR_FLAGS to 'cq'" 1>&2
+ $echo "$modename: warning: to ensure that POSIX-compatible ar will work" 1>&2
+ AR_FLAGS=cq
+ fi
+ # Is there a better way of finding the last object in the list?
+ for obj in $save_oldobjs
+ do
+ last_oldobj=$obj
+ done
+ do
+ oldobjs="$objlist $obj"
+ eval test_cmds=\"$old_archive_cmds\"
+ if len=`expr "X$test_cmds" : ".*"` &&
+ test "$len" -le "$max_cmd_len"; then
+ else
+ # the above command should be used before it gets too long
+ oldobjs=$objlist
+ if test "$obj" = "$last_oldobj" ; then
+ RANLIB=$save_RANLIB
+ fi
+ eval concat_cmds=\"\${concat_cmds}$old_archive_cmds\"
+ objlist=
+ fi
+ done
+ oldobjs=$objlist
+ if test "X$oldobjs" = "X" ; then
+ eval cmds=\"\$concat_cmds\"
+ else
+ eval cmds=\"\$concat_cmds~$old_archive_cmds\"
+ fi
+ fi
+ fi
+ save_ifs="$IFS"; IFS='~'
+ for cmd in $cmds; do
+ IFS="$save_ifs"
+ $show "$cmd"
+ $run eval "$cmd" || exit $?
+ done
+ IFS="$save_ifs"
+ done
+ if test -n "$generated"; then
+ $show "${rm}r$generated"
+ $run ${rm}r$generated
+ fi
+ # Now create the libtool archive.
+ case $output in
+ *.la)
+ old_library=
+ test "$build_old_libs" = yes && old_library="$libname.$libext"
+ else
+ fi
+ done
+ # Quote the link command for shipping.
+ relink_command="(cd `pwd`; $SHELL $0 --mode=relink $libtool_args @inst_prefix_dir@)"
+ if test "$hardcode_automatic" = yes ; then
+ relink_command=
+ fi
+ # Only create the output if not a dry run.
+ for installed in no yes; do
+ if test "$installed" = yes; then
+ if test -z "$install_libdir"; then
+ break
+ fi
+ output="$output_objdir/$outputname"i
+ # Replace all uninstalled libtool libraries with the installed ones
+ newdependency_libs=
+ for deplib in $dependency_libs; do
+ case $deplib in
+ *.la)
+ name=`$echo "X$deplib" | $Xsed -e 's%^.*/%%'`
+ if test -z "$libdir"; then
+ exit 1
+ fi
+ newdependency_libs="$newdependency_libs $libdir/$name"
+ *) newdependency_libs="$newdependency_libs $deplib" ;;
+ esac
+ done
+ newdlfiles=
+ for lib in $dlfiles; do
+ name=`$echo "X$lib" | $Xsed -e 's%^.*/%%'`
+ eval libdir=`${SED} -n -e 's/^libdir=\(.*\)$/\1/p' $lib`
+ $echo "$modename: \`$lib' is not a valid libtool archive" 1>&2
+ exit 1
+ fi
+ newdlfiles="$newdlfiles $libdir/$name"
+ done
+ newdlprefiles=
+ for lib in $dlprefiles; do
+ exit 1
+ fi
+ newdlprefiles="$newdlprefiles $libdir/$name"
+ done
+ fi
+ $rm $output
+ # place dlname in correct position for cygwin
+ tdlname=$dlname
+ case $host,$output,$installed,$module,$dlname in
+ *cygwin*,*lai,yes,no,*.dll | *mingw*,*lai,yes,no,*.dll) tdlname=../bin/$dlname ;;
+ esac
+# $outputname - a libtool library file
+# Please DO NOT delete this file!
+# It is necessary for linking the library.
+# The name that we can dlopen(3).
+dlname='$tdlname'
+# Names of this library.
+library_names='$library_names'
+# The name of the static archive.
+old_library='$old_library'
+# Libraries that this one depends upon.
+dependency_libs='$dependency_libs'
+# Version information for $libname.
+current=$current
+age=$age
+revision=$revision
+# Is this an already installed library?
+installed=$installed
+# Should we warn about portability when linking against -modules?
+shouldnotlink=$module
+# Files to dlopen/dlpreopen
+dlopen='$dlfiles'
+dlpreopen='$dlprefiles'
+# Directory that this library needs to be installed in:
+libdir='$install_libdir'"
+ if test "$installed" = no && test "$need_relink" = yes && test "$fast_install" = no; then
+relink_command=\"$relink_command\""
+ fi
+ done
+ fi
+ # Do a symbolic link so that the libtool archive can be found in
+ # LD_LIBRARY_PATH before the program is installed.
+ $show "(cd $output_objdir && $rm $outputname && $LN_S ../$outputname $outputname)"
+ $run eval '(cd $output_objdir && $rm $outputname && $LN_S ../$outputname $outputname)' || exit $?
+ esac
+ exit 0
+ # libtool install mode
+ install)
+ modename="$modename: install"
+ # There may be an optional sh(1) argument at the beginning of
+ # install_prog (especially on Windows NT).
+ if test "$nonopt" = "$SHELL" || test "$nonopt" = /bin/sh ||
+ # Allow the use of GNU shtool's install command.
+ $echo "X$nonopt" | $Xsed | grep shtool > /dev/null; then
+ # Aesthetically quote it.
+ arg=`$echo "X$nonopt" | $Xsed -e "$sed_quote_subst"`
+ case $arg in
+ arg="\"$arg\""
+ esac
+ install_prog="$arg "
+ arg="$1"
+ shift
+ else
+ install_prog=
+ arg="$nonopt"
+ fi
+ # The real first argument should be the name of the installation program.
+ arg=`$echo "X$arg" | $Xsed -e "$sed_quote_subst"`
+ case $arg in
+ arg="\"$arg\""
+ esac
+ install_prog="$install_prog$arg"
+ # We need to accept at least all the BSD install flags.
+ dest=
+ files=
+ opts=
+ prev=
+ install_type=
+ isdir=no
+ stripme=
+ for arg
+ do
+ if test -n "$dest"; then
+ files="$files $dest"
+ dest="$arg"
+ continue
+ fi
+ case $arg in
+ -d) isdir=yes ;;
+ -f) prev="-f" ;;
+ -g) prev="-g" ;;
+ -m) prev="-m" ;;
+ -o) prev="-o" ;;
+ -s)
+ stripme=" -s"
+ continue
+ # If the previous option needed an argument, then skip it.
+ if test -n "$prev"; then
+ prev=
+ else
+ dest="$arg"
+ continue
+ fi
+ esac
+ # Aesthetically quote the argument.
+ case $arg in
+ arg="\"$arg\""
+ esac
+ install_prog="$install_prog $arg"
+ done
+ if test -z "$install_prog"; then
+ $echo "$modename: you must specify an install program" 1>&2
+ $echo "$help" 1>&2
+ exit 1
+ fi
+ $echo "$modename: the \`$prev' option requires an argument" 1>&2
+ exit 1
+ fi
+ if test -z "$files"; then
+ if test -z "$dest"; then
+ $echo "$modename: no file or destination specified" 1>&2
+ else
+ $echo "$modename: you must specify a destination" 1>&2
+ fi
+ exit 1
+ fi
+ # Strip any trailing slash from the destination.
+ dest=`$echo "X$dest" | $Xsed -e 's%/$%%'`
+ # Check to see that the destination is a directory.
+ test -d "$dest" && isdir=yes
+ if test "$isdir" = yes; then
+ destdir="$dest"
+ destname=
+ else
+ destdir=`$echo "X$dest" | $Xsed -e 's%/[^/]*$%%'`
+ test "X$destdir" = "X$dest" && destdir=.
+ destname=`$echo "X$dest" | $Xsed -e 's%^.*/%%'`
+ # Not a directory, so check to see that there is only one file specified.
+ set dummy $files
+ $echo "$modename: \`$dest' is not a directory" 1>&2
+ exit 1
+ fi
+ fi
+ case $destdir in
+ [\\/]* | [A-Za-z]:[\\/]*) ;;
+ for file in $files; do
+ case $file in
+ *.lo) ;;
+ $echo "$modename: \`$destdir' must be an absolute directory name" 1>&2
+ exit 1
+ esac
+ done
+ esac
+ # This variable tells wrapper scripts just to set variables rather
+ # than running their programs.
+ libtool_install_magic="$magic"
+ staticlibs=
+ future_libdirs=
+ current_libdirs=
+ # Do each installation.
+ case $file in
+ *.$libext)
+ # Do the static libraries later.
+ staticlibs="$staticlibs $file"
+ *.la)
+ # Check to see that this really is a libtool archive.
+ if (${SED} -e '2q' $file | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then :
+ else
+ $echo "$modename: \`$file' is not a valid libtool archive" 1>&2
+ exit 1
+ fi
+ library_names=
+ old_library=
+ relink_command=
+ # If there is no directory component, then add one.
+ case $file in
+ */* | *\\*) . $file ;;
+ *) . ./$file ;;
+ esac
+ # Add the libdir to current_libdirs if it is the destination.
+ if test "X$destdir" = "X$libdir"; then
+ case "$current_libdirs " in
+ *" $libdir "*) ;;
+ *) current_libdirs="$current_libdirs $libdir" ;;
+ esac
+ else
+ # Note the libdir as a future libdir.
+ case "$future_libdirs " in
+ *" $libdir "*) ;;
+ *) future_libdirs="$future_libdirs $libdir" ;;
+ esac
+ fi
+ dir=`$echo "X$file" | $Xsed -e 's%/[^/]*$%%'`/
+ test "X$dir" = "X$file/" && dir=
+ dir="$dir$objdir"
+ # Determine the prefix the user has applied to our future dir.
+ inst_prefix_dir=`$echo "$destdir" | $SED "s%$libdir\$%%"`
+ # Don't allow the user to place us outside of our expected
+ # location b/c this prevents finding dependent libraries that
+ # are installed to the same prefix.
+ # At present, this check doesn't affect windows .dll's that
+ # are installed into $libdir/../bin (currently, that works fine)
+ # but it's something to keep an eye on.
+ if test "$inst_prefix_dir" = "$destdir"; then
+ $echo "$modename: error: cannot install \`$file' to a directory not ending in $libdir" 1>&2
+ exit 1
+ fi
+ if test -n "$inst_prefix_dir"; then
+ # Stick the inst_prefix_dir data into the link command.
+ relink_command=`$echo "$relink_command" | $SED "s%@inst_prefix_dir@%-inst-prefix-dir $inst_prefix_dir%"`
+ else
+ relink_command=`$echo "$relink_command" | $SED "s%@inst_prefix_dir@%%"`
+ fi
+ $echo "$modename: warning: relinking \`$file'" 1>&2
+ $show "$relink_command"
+ if $run eval "$relink_command"; then :
+ else
+ $echo "$modename: error: relink \`$file' with the above command before installing it" 1>&2
+ exit 1
+ fi
+ fi
+ # See the names of the shared library.
+ set dummy $library_names
+ if test -n "$2"; then
+ realname="$2"
+ shift
+ shift
+ srcname="$realname"
+ test -n "$relink_command" && srcname="$realname"T
+ # Install the shared library and build the symlinks.
+ $show "$install_prog $dir/$srcname $destdir/$realname"
+ $run eval "$install_prog $dir/$srcname $destdir/$realname" || exit $?
+ if test -n "$stripme" && test -n "$striplib"; then
+ $show "$striplib $destdir/$realname"
+ $run eval "$striplib $destdir/$realname" || exit $?
+ fi
+ if test "$#" -gt 0; then
+ # Delete the old symlinks, and create new ones.
+ for linkname
+ do
+ if test "$linkname" != "$realname"; then
+ $show "(cd $destdir && $rm $linkname && $LN_S $realname $linkname)"
+ $run eval "(cd $destdir && $rm $linkname && $LN_S $realname $linkname)"
+ fi
+ done
+ fi
+ # Do each command in the postinstall commands.
+ lib="$destdir/$realname"
+ eval cmds=\"$postinstall_cmds\"
+ IFS="$save_ifs"
+ $show "$cmd"
+ done
+ IFS="$save_ifs"
+ fi
+ # Install the pseudo-library for information purposes.
+ name=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
+ instname="$dir/$name"i
+ $show "$install_prog $instname $destdir/$name"
+ $run eval "$install_prog $instname $destdir/$name" || exit $?
+ # Maybe install the static library, too.
+ test -n "$old_library" && staticlibs="$staticlibs $dir/$old_library"
+ *.lo)
+ # Install (i.e. copy) a libtool object.
+ # Figure out destination file name, if it wasn't already specified.
+ if test -n "$destname"; then
+ destfile="$destdir/$destname"
+ else
+ destfile=`$echo "X$file" | $Xsed -e 's%^.*/%%'`
+ destfile="$destdir/$destfile"
+ fi
+ # Deduce the name of the destination old-style object file.
+ case $destfile in
+ *.lo)
+ staticdest=`$echo "X$destfile" | $Xsed -e "$lo2o"`
+ *.$objext)
+ staticdest="$destfile"
+ destfile=
+ $echo "$modename: cannot copy a libtool object to \`$destfile'" 1>&2
+ exit 1
+ esac
+ # Install the libtool object if requested.
+ if test -n "$destfile"; then
+ $show "$install_prog $file $destfile"
+ $run eval "$install_prog $file $destfile" || exit $?
+ fi
+ # Install the old object if enabled.
+ if test "$build_old_libs" = yes; then
+ # Deduce the name of the old-style object file.
+ staticobj=`$echo "X$file" | $Xsed -e "$lo2o"`
+ $show "$install_prog $staticobj $staticdest"
+ $run eval "$install_prog \$staticobj \$staticdest" || exit $?
+ fi
+ exit 0
+ else
+ fi
+ # If the file is missing, and there is a .exe on the end, strip it
+ # because it is most likely a libtool script we actually want to
+ # install
+ stripped_ext=""
+ case $file in
+ *.exe)
+ if test ! -f "$file"; then
+ file=`$echo $file|${SED} 's,.exe$,,'`
+ stripped_ext=".exe"
+ fi
+ esac
+ # Do a test to see if this is really a libtool program.
+ case $host in
+ *cygwin*|*mingw*)
+ wrapper=`$echo $file | ${SED} -e 's,.exe$,,'`
+ wrapper=$file
+ esac
+ if (${SED} -e '4q' $wrapper | grep "^# Generated by .*$PACKAGE")>/dev/null 2>&1; then
+ notinst_deplibs=
+ relink_command=
+ # To insure that "foo" is sourced, and not "foo.exe",
+ # finese the cygwin/MSYS system by explicitly sourcing "foo."
+ # which disallows the automatic-append-.exe behavior.
+ case $build in
+ *cygwin* | *mingw*) wrapperdot=${wrapper}. ;;
+ *) wrapperdot=${wrapper} ;;
+ esac
+ case $file in
+ */* | *\\*) . ${wrapperdot} ;;
+ *) . ./${wrapperdot} ;;
+ esac
+ # Check the variables that should have been set.
+ if test -z "$notinst_deplibs"; then
+ $echo "$modename: invalid libtool wrapper script \`$wrapper'" 1>&2
+ exit 1
+ fi
+ finalize=yes
+ for lib in $notinst_deplibs; do
+ # Check to see that each library is installed.
+ libdir=
+ if test -f "$lib"; then
+ case $lib in
+ */* | *\\*) . $lib ;;
+ *) . ./$lib ;;
+ esac
+ fi
+ libfile="$libdir/"`$echo "X$lib" | $Xsed -e 's%^.*/%%g'` ### testsuite: skip nested quoting test
+ if test -n "$libdir" && test ! -f "$libfile"; then
+ $echo "$modename: warning: \`$lib' has not been installed in \`$libdir'" 1>&2
+ finalize=no
+ fi
+ done
+ relink_command=
+ case $build in
+ esac
+ case $file in
+ esac
+ outputname=
+ if test "$fast_install" = no && test -n "$relink_command"; then
+ if test "$finalize" = yes && test -z "$run"; then
+ tmpdir="/tmp"
+ test -n "$TMPDIR" && tmpdir="$TMPDIR"
+ tmpdir="$tmpdir/libtool-$$"
+ if $mkdir -p "$tmpdir" && chmod 700 "$tmpdir"; then :
+ else
+ $echo "$modename: error: cannot create temporary directory \`$tmpdir'" 1>&2
+ continue
+ fi
+ file=`$echo "X$file$stripped_ext" | $Xsed -e 's%^.*/%%'`
+ outputname="$tmpdir/$file"
+ relink_command=`$echo "X$relink_command" | $Xsed -e 's%@OUTPUT@%'"$outputname"'%g'`
+ else
+ ${rm}r "$tmpdir"
+ continue
+ fi
+ file="$outputname"
+ else
+ $echo "$modename: warning: cannot relink \`$file'" 1>&2
+ fi
+ else
+ # Install the binary that we compiled earlier.
+ file=`$echo "X$file$stripped_ext" | $Xsed -e "s%\([^/]*\)$%$objdir/\1%"`
+ fi
+ fi
+ # remove .exe since cygwin /usr/bin/install will append another
+ # one anyways
+ case $install_prog,$host in
+ */usr/bin/install*,*cygwin*)
+ case $file:$destfile in
+ *.exe:*.exe)
+ # this is ok
+ *.exe:*)
+ destfile=$destfile.exe
+ *:*.exe)
+ destfile=`$echo $destfile | ${SED} -e 's,.exe$,,'`
+ esac
+ esac
+ $show "$install_prog$stripme $file $destfile"
+ $run eval "$install_prog\$stripme \$file \$destfile" || exit $?
+ test -n "$outputname" && ${rm}r "$tmpdir"
+ esac
+ done
+ for file in $staticlibs; do
+ # Set up the ranlib parameters.
+ oldlib="$destdir/$name"
+ $show "$install_prog $file $oldlib"
+ $run eval "$install_prog \$file \$oldlib" || exit $?
+ $show "$old_striplib $oldlib"
+ $run eval "$old_striplib $oldlib" || exit $?
+ fi
+ eval cmds=\"$old_postinstall_cmds\"
+ IFS="$save_ifs"
+ $show "$cmd"
+ done
+ IFS="$save_ifs"
+ done
+ if test -n "$future_libdirs"; then
+ $echo "$modename: warning: remember to run \`$progname --finish$future_libdirs'" 1>&2
+ fi
+ if test -n "$current_libdirs"; then
+ # Maybe just do a dry run.
+ test -n "$run" && current_libdirs=" -n$current_libdirs"
+ exec_cmd='$SHELL $0 --finish$current_libdirs'
+ else
+ exit 0
+ fi
+ # libtool finish mode
+ finish)
+ modename="$modename: finish"
+ libdirs="$nonopt"
+ admincmds=
+ if test -n "$finish_cmds$finish_eval" && test -n "$libdirs"; then
+ for dir
+ do
+ libdirs="$libdirs $dir"
+ done
+ for libdir in $libdirs; do
+ if test -n "$finish_cmds"; then
+ # Do each command in the finish commands.
+ eval cmds=\"$finish_cmds\"
+ IFS="$save_ifs"
+ $show "$cmd"
+ $run eval "$cmd" || admincmds="$admincmds
+ $cmd"
+ done
+ IFS="$save_ifs"
+ fi
+ if test -n "$finish_eval"; then
+ # Do the single finish_eval.
+ eval cmds=\"$finish_eval\"
+ $run eval "$cmds" || admincmds="$admincmds
+ $cmds"
+ fi
+ done
+ fi
+ # Exit here if they wanted silent mode.
+ exit 0
+ $echo "----------------------------------------------------------------------"
+ $echo "Libraries have been installed in:"
+ $echo " $libdir"
+ done
+ $echo
+ $echo "If you ever happen to want to link against installed libraries"
+ $echo "in a given directory, LIBDIR, you must either use libtool, and"
+ $echo "specify the full pathname of the library, or use the \`-LLIBDIR'"
+ $echo "flag during linking and do at least one of the following:"
+ $echo " - add LIBDIR to the \`$shlibpath_var' environment variable"
+ $echo " during execution"
+ fi
+ $echo " - add LIBDIR to the \`$runpath_var' environment variable"
+ $echo " during linking"
+ fi
+ libdir=LIBDIR
+ $echo " - use the \`$flag' linker flag"
+ fi
+ if test -n "$admincmds"; then
+ $echo " - have your system administrator run these commands:$admincmds"
+ fi
+ if test -f /etc/ld.so.conf; then
+ $echo " - have your system administrator add LIBDIR to \`/etc/ld.so.conf'"
+ fi
+ $echo
+ $echo "See any operating system documentation about shared libraries for"
+ $echo "more information, such as the ld(1) and ld.so(8) manual pages."
+ exit 0
+ # libtool execute mode
+ execute)
+ modename="$modename: execute"
+ # The first argument is the command name.
+ cmd="$nonopt"
+ if test -z "$cmd"; then
+ $echo "$modename: you must specify a COMMAND" 1>&2
+ $echo "$help"
+ exit 1
+ fi
+ # Handle -dlopen flags immediately.
+ for file in $execute_dlfiles; do
+ $echo "$modename: \`$file' is not a file" 1>&2
+ exit 1
+ fi
+ dir=
+ case $file in
+ *.la)
+ else
+ exit 1
+ fi
+ # Read the libtool library.
+ dlname=
+ library_names=
+ case $file in
+ *) . ./$file ;;
+ esac
+ # Skip this library if it cannot be dlopened.
+ # Warn if it was a shared library.
+ test -n "$library_names" && $echo "$modename: warning: \`$file' was not linked with \`-export-dynamic'"
+ continue
+ fi
+ test "X$dir" = "X$file" && dir=.
+ if test -f "$dir/$objdir/$dlname"; then
+ dir="$dir/$objdir"
+ else
+ $echo "$modename: cannot find \`$dlname' in \`$dir' or \`$dir/$objdir'" 1>&2
+ exit 1
+ fi
+ *.lo)
+ # Just add the directory containing the .lo file.
+ $echo "$modename: warning \`-dlopen' is ignored for non-libtool libraries and objects" 1>&2
+ continue
+ esac
+ # Get the absolute pathname.
+ absdir=`cd "$dir" && pwd`
+ test -n "$absdir" && dir="$absdir"
+ # Now add the directory to shlibpath_var.
+ if eval "test -z \"\$$shlibpath_var\""; then
+ eval "$shlibpath_var=\"\$dir\""
+ else
+ eval "$shlibpath_var=\"\$dir:\$$shlibpath_var\""
+ fi
+ done
+ # This variable tells wrapper scripts just to set shlibpath_var
+ # rather than running their programs.
+ libtool_execute_magic="$magic"
+ # Check if any of the arguments is a wrapper script.
+ args=
+ for file
+ do
+ case $file in
+ if (${SED} -e '4q' $file | grep "^# Generated by .*$PACKAGE") >/dev/null 2>&1; then
+ case $file in
+ *) . ./$file ;;
+ esac
+ # Transform arg to wrapped name.
+ file="$progdir/$program"
+ fi
+ esac
+ # Quote arguments (to preserve shell metacharacters).
+ file=`$echo "X$file" | $Xsed -e "$sed_quote_subst"`
+ args="$args \"$file\""
+ done
+ # Export the shlibpath_var.
+ eval "export $shlibpath_var"
+ fi
+ # Restore saved environment variables
+ if test "${save_LC_ALL+set}" = set; then
+ LC_ALL="$save_LC_ALL"; export LC_ALL
+ fi
+ if test "${save_LANG+set}" = set; then
+ LANG="$save_LANG"; export LANG
+ fi
+ # Now prepare to actually exec the command.
+ exec_cmd="\$cmd$args"
+ else
+ # Display what would be done.
+ eval "\$echo \"\$shlibpath_var=\$$shlibpath_var\""
+ $echo "export $shlibpath_var"
+ fi
+ $echo "$cmd$args"
+ exit 0
+ fi
+ # libtool clean and uninstall mode
+ clean | uninstall)
+ modename="$modename: $mode"
+ rm="$nonopt"
+ files=
+ rmforce=
+ exit_status=0
+ for arg
+ do
+ case $arg in
+ -f) rm="$rm $arg"; rmforce=yes ;;
+ -*) rm="$rm $arg" ;;
+ *) files="$files $arg" ;;
+ esac
+ done
+ if test -z "$rm"; then
+ $echo "$modename: you must specify an RM program" 1>&2
+ exit 1
+ fi
+ rmdirs=
+ origobjdir="$objdir"
+ if test "X$dir" = "X$file"; then
+ dir=.
+ objdir="$origobjdir"
+ else
+ objdir="$dir/$origobjdir"
+ fi
+ test "$mode" = uninstall && objdir="$dir"
+ # Remember objdir for removal later, being careful to avoid duplicates
+ if test "$mode" = clean; then
+ case " $rmdirs " in
+ *" $objdir "*) ;;
+ *) rmdirs="$rmdirs $objdir" ;;
+ esac
+ fi
+ # Don't error if the file doesn't exist and rm -f was used.
+ if (test -L "$file") >/dev/null 2>&1 \
+ || (test -h "$file") >/dev/null 2>&1 \
+ || test -f "$file"; then
+ elif test -d "$file"; then
+ exit_status=1
+ continue
+ elif test "$rmforce" = yes; then
+ continue
+ fi
+ rmfiles="$file"
+ case $name in
+ *.la)
+ # Possibly a libtool archive, so verify it.
+ . $dir/$name
+ # Delete the libtool libraries and symlinks.
+ for n in $library_names; do
+ rmfiles="$rmfiles $objdir/$n"
+ done
+ test -n "$old_library" && rmfiles="$rmfiles $objdir/$old_library"
+ test "$mode" = clean && rmfiles="$rmfiles $objdir/$name $objdir/${name}i"
+ if test "$mode" = uninstall; then
+ if test -n "$library_names"; then
+ # Do each command in the postuninstall commands.
+ eval cmds=\"$postuninstall_cmds\"
+ IFS="$save_ifs"
+ $show "$cmd"
+ $run eval "$cmd"
+ if test "$?" -ne 0 && test "$rmforce" != yes; then
+ exit_status=1
+ fi
+ done
+ IFS="$save_ifs"
+ fi
+ if test -n "$old_library"; then
+ # Do each command in the old_postuninstall commands.
+ eval cmds=\"$old_postuninstall_cmds\"
+ IFS="$save_ifs"
+ $show "$cmd"
+ $run eval "$cmd"
+ exit_status=1
+ fi
+ done
+ IFS="$save_ifs"
+ fi
+ # FIXME: should reinstall the best remaining shared library.
+ fi
+ fi
+ *.lo)
+ # Possibly a libtool object, so verify it.
+ # Read the .lo file
+ . $dir/$name
+ # Add PIC object to the list of files to remove.
+ if test -n "$pic_object" \
+ && test "$pic_object" != none; then
+ rmfiles="$rmfiles $dir/$pic_object"
+ fi
+ # Add non-PIC object to the list of files to remove.
+ if test -n "$non_pic_object" \
+ && test "$non_pic_object" != none; then
+ rmfiles="$rmfiles $dir/$non_pic_object"
+ fi
+ fi
+ if test "$mode" = clean ; then
+ noexename=$name
+ case $file in
+ *.exe)
+ noexename=`$echo $name|${SED} 's,.exe$,,'`
+ # $file with .exe has already been added to rmfiles,
+ # add $file without .exe
+ rmfiles="$rmfiles $file"
+ esac
+ # Do a test to see if this is a libtool program.
+ relink_command=
+ . $dir/$noexename
+ # note $name still contains .exe if it was in $file originally
+ # as does the version of $file that was added into $rmfiles
+ rmfiles="$rmfiles $objdir/$name $objdir/${name}S.${objext}"
+ if test "$fast_install" = yes && test -n "$relink_command"; then
+ rmfiles="$rmfiles $objdir/lt-$name"
+ fi
+ if test "X$noexename" != "X$name" ; then
+ rmfiles="$rmfiles $objdir/lt-${noexename}.c"
+ fi
+ fi
+ fi
+ esac
+ $show "$rm $rmfiles"
+ $run $rm $rmfiles || exit_status=1
+ done
+ # Try to remove the ${objdir}s in the directories where we deleted files
+ for dir in $rmdirs; do
+ if test -d "$dir"; then
+ $show "rmdir $dir"
+ $run rmdir $dir >/dev/null 2>&1
+ fi
+ done
+ exit $exit_status
+ $echo "$modename: you must specify a MODE" 1>&2
+ $echo "$generic_help" 1>&2
+ exit 1
+ esac
+ if test -z "$exec_cmd"; then
+ $echo "$modename: invalid operation mode \`$mode'" 1>&2
+ exit 1
+ fi
+fi # test -z "$show_help"
+if test -n "$exec_cmd"; then
+ eval exec $exec_cmd
+ exit 1
+fi
+# We need to display help for each of the modes.
+case $mode in
+"") $echo \
+"Usage: $modename [OPTION]... [MODE-ARG]...
+Provide generalized library-building support services.
+ --config show all configuration variables
+ --debug enable verbose shell tracing
+-n, --dry-run display commands without modifying any files
+ --features display basic configuration information and exit
+ --finish same as \`--mode=finish'
+ --help display this help message and exit
+ --mode=MODE use operation mode MODE [default=inferred from MODE-ARGS]
+ --quiet same as \`--silent'
+ --silent don't print informational messages
+ --tag=TAG use configuration variables from tag TAG
+ --version print version information
+MODE must be one of the following:
+ clean remove files from the build directory
+ compile compile a source file into a libtool object
+ execute automatically set library path, then run a program
+ finish complete the installation of libtool libraries
+ install install libraries or executables
+ link create a library or an executable
+ uninstall remove libraries from an installed directory
+MODE-ARGS vary depending on the MODE. Try \`$modename --help --mode=MODE' for
+a more detailed description of MODE.
+Report bugs to <bug-libtool at gnu.org>."
+ exit 0
+clean)
+ $echo \
+"Usage: $modename [OPTION]... --mode=clean RM [RM-OPTION]... FILE...
+Remove files from the build directory.
+RM is the name of the program to use to delete files associated with each FILE
+(typically \`/bin/rm'). RM-OPTIONS are options (such as \`-f') to be passed
+to RM.
+If FILE is a libtool library, object or program, all the files associated
+with it are deleted. Otherwise, only FILE itself is deleted using RM."
+compile)
+ $echo \
+"Usage: $modename [OPTION]... --mode=compile COMPILE-COMMAND... SOURCEFILE
+Compile a source file into a libtool library object.
+This mode accepts the following additional options:
+ -o OUTPUT-FILE set the output file name to OUTPUT-FILE
+ -prefer-pic try to building PIC objects only
+ -prefer-non-pic try to building non-PIC objects only
+ -static always build a \`.o' file suitable for static linking
+COMPILE-COMMAND is a command to be used in creating a \`standard' object file
+from the given SOURCEFILE.
+The output file name is determined by removing the directory component from
+SOURCEFILE, then substituting the C source code suffix \`.c' with the
+library object suffix, \`.lo'."
+execute)
+ $echo \
+"Usage: $modename [OPTION]... --mode=execute COMMAND [ARGS]...
+Automatically set library path, then run a program.
+ -dlopen FILE add the directory containing FILE to the library path
+This mode sets the library path environment variable according to \`-dlopen'
+flags.
+If any of the ARGS are libtool executable wrappers, then they are translated
+into their corresponding uninstalled binary, and any of their required library
+directories are added to the library path.
+Then, COMMAND is executed, with ARGS as arguments."
+finish)
+ $echo \
+"Usage: $modename [OPTION]... --mode=finish [LIBDIR]...
+Complete the installation of libtool libraries.
+Each LIBDIR is a directory that contains libtool libraries.
+The commands that this mode executes may require superuser privileges. Use
+the \`--dry-run' option if you just want to see what would be executed."
+install)
+ $echo \
+"Usage: $modename [OPTION]... --mode=install INSTALL-COMMAND...
+Install executables or libraries.
+INSTALL-COMMAND is the installation command. The first component should be
+either the \`install' or \`cp' program.
+The rest of the components are interpreted as arguments to that command (only
+BSD-compatible install options are recognized)."
+link)
+ $echo \
+"Usage: $modename [OPTION]... --mode=link LINK-COMMAND...
+Link object files or libraries together to form another library, or to
+create an executable program.
+LINK-COMMAND is a command using the C compiler that you would use to create
+a program from several object files.
+The following components of LINK-COMMAND are treated specially:
+ -all-static do not do any dynamic linking at all
+ -avoid-version do not add a version suffix if possible
+ -dlopen FILE \`-dlpreopen' FILE if it cannot be dlopened at runtime
+ -dlpreopen FILE link in FILE and add its symbols to lt_preloaded_symbols
+ -export-dynamic allow symbols from OUTPUT-FILE to be resolved with dlsym(3)
+ -export-symbols SYMFILE
+ try to export only the symbols listed in SYMFILE
+ -export-symbols-regex REGEX
+ try to export only the symbols matching REGEX
+ -LLIBDIR search LIBDIR for required installed libraries
+ -lNAME OUTPUT-FILE requires the installed library libNAME
+ -module build a library that can dlopened
+ -no-fast-install disable the fast-install mode
+ -no-install link a not-installable executable
+ -no-undefined declare that a library does not refer to external symbols
+ -o OUTPUT-FILE create OUTPUT-FILE from the specified objects
+ -objectlist FILE Use a list of object files found in FILE to specify objects
+ -release RELEASE specify package release information
+ -rpath LIBDIR the created library will eventually be installed in LIBDIR
+ -R[ ]LIBDIR add LIBDIR to the runtime path of programs and libraries
+ -static do not do any dynamic linking of libtool libraries
+ -version-info CURRENT[:REVISION[:AGE]]
+ specify library version info [each variable defaults to 0]
+All other options (arguments beginning with \`-') are ignored.
+Every other argument is treated as a filename. Files ending in \`.la' are
+treated as uninstalled libtool libraries, other files are standard or library
+object files.
+If the OUTPUT-FILE ends in \`.la', then a libtool library is created,
+only library objects (\`.lo' files) may be specified, and \`-rpath' is
+required, except when creating a convenience library.
+If OUTPUT-FILE ends in \`.a' or \`.lib', then a standard library is created
+using \`ar' and \`ranlib', or on Windows using \`lib'.
+If OUTPUT-FILE ends in \`.lo' or \`.${objext}', then a reloadable object file
+is created, otherwise an executable program is created."
+uninstall)
+ $echo \
+"Usage: $modename [OPTION]... --mode=uninstall RM [RM-OPTION]... FILE...
+Remove libraries from an installation directory.
+to RM.
+If FILE is a libtool library, all the files associated with it are deleted.
+Otherwise, only FILE itself is deleted using RM."
+ exit 1
+esac
+$echo
+$echo "Try \`$modename --help' for more information about other modes."
+exit 0
+# The TAGs below are defined such that we never get into a situation
+# in which we disable both kinds of libraries. Given conflicting
+# choices, we go for a static library, that is the most portable,
+# since we can't tell whether shared libraries were disabled because
+# the user asked for that or because the platform doesn't support
+# them. This is particularly important on AIX, because we don't
+# support having both static and shared libraries enabled at the same
+# time on that platform, so we default to a shared-only configuration.
+# If a disable-shared tag is given, we'll fallback to a static-only
+# configuration. But we'll never go from static-only to shared-only.
+# ### BEGIN LIBTOOL TAG CONFIG: disable-shared
+build_libtool_libs=no
+build_old_libs=yes
+# ### END LIBTOOL TAG CONFIG: disable-shared
+# ### BEGIN LIBTOOL TAG CONFIG: disable-static
+build_old_libs=`case $build_libtool_libs in yes) $echo no;; *) $echo yes;; esac`
+# ### END LIBTOOL TAG CONFIG: disable-static
+# Local Variables:
+# mode:shell-script
+# sh-indentation:2
+# End:
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/missing
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/missing 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/missing 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,336 +0,0 @@
-#! /bin/sh
-# Common stub for a few missing GNU programs while installing.
-# Copyright (C) 1996, 1997, 1999, 2000, 2002 Free Software Foundation, Inc.
-# Originally by Fran,cois Pinard <pinard at iro.umontreal.ca>, 1996.
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
-# 02111-1307, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-if test $# -eq 0; then
- echo 1>&2 "Try \`$0 --help' for more information"
- exit 1
-fi
-run=:
-# In the cases where this matters, `missing' is being run in the
-# srcdir already.
-if test -f configure.ac; then
- configure_ac=configure.ac
-else
- configure_ac=configure.in
-fi
-case "$1" in
---run)
- # Try to run requested program, and just exit if it succeeds.
- run=
- shift
- "$@" && exit 0
-esac
-# If it does not exist, or fails to run (possibly an outdated version),
-# try to emulate it.
-case "$1" in
- -h|--h|--he|--hel|--help)
- echo "\
-$0 [OPTION]... PROGRAM [ARGUMENT]...
-Handle \`PROGRAM [ARGUMENT]...' for when PROGRAM is missing, or return an
-error status if there is no known handling for PROGRAM.
-Options:
- -h, --help display this help and exit
- -v, --version output version information and exit
- --run try to run the given command, and emulate it if it fails
-Supported PROGRAM values:
- aclocal touch file \`aclocal.m4'
- autoconf touch file \`configure'
- autoheader touch file \`config.h.in'
- automake touch all \`Makefile.in' files
- bison create \`y.tab.[ch]', if possible, from existing .[ch]
- flex create \`lex.yy.c', if possible, from existing .c
- help2man touch the output file
- lex create \`lex.yy.c', if possible, from existing .c
- makeinfo touch the output file
- tar try tar, gnutar, gtar, then tar without non-portable flags
- yacc create \`y.tab.[ch]', if possible, from existing .[ch]"
- -v|--v|--ve|--ver|--vers|--versi|--versio|--version)
- echo "missing 0.4 - GNU automake"
- echo 1>&2 "$0: Unknown \`$1' option"
- exit 1
- aclocal*)
- if test -z "$run" && ($1 --version) > /dev/null 2>&1; then
- # We have it, but it failed.
- exit 1
- fi
- echo 1>&2 "\
-WARNING: \`$1' is missing on your system. You should only need it if
- you modified \`acinclude.m4' or \`${configure_ac}'. You might want
- to install the \`Automake' and \`Perl' packages. Grab them from
- any GNU archive site."
- touch aclocal.m4
- autoconf)
- exit 1
- fi
- echo 1>&2 "\
- you modified \`${configure_ac}'. You might want to install the
- \`Autoconf' and \`GNU m4' packages. Grab them from any GNU
- archive site."
- touch configure
- autoheader)
- exit 1
- fi
- echo 1>&2 "\
- you modified \`acconfig.h' or \`${configure_ac}'. You might want
- to install the \`Autoconf' and \`GNU m4' packages. Grab them
- from any GNU archive site."
- files=`sed -n 's/^[ ]*A[CM]_CONFIG_HEADER(\([^)]*\)).*/\1/p' ${configure_ac}`
- test -z "$files" && files="config.h"
- touch_files=
- for f in $files; do
- case "$f" in
- *:*) touch_files="$touch_files "`echo "$f" |
- sed -e 's/^[^:]*://' -e 's/:.*//'`;;
- *) touch_files="$touch_files $f.in";;
- esac
- done
- touch $touch_files
- automake*)
- exit 1
- fi
- echo 1>&2 "\
- you modified \`Makefile.am', \`acinclude.m4' or \`${configure_ac}'.
- You might want to install the \`Automake' and \`Perl' packages.
- Grab them from any GNU archive site."
- find . -type f -name Makefile.am -print |
- sed 's/\.am$/.in/' |
- while read f; do touch "$f"; done
- autom4te)
- exit 1
- fi
- echo 1>&2 "\
-WARNING: \`$1' is needed, and you do not seem to have it handy on your
- system. You might have modified some files without having the
- proper tools for further handling them.
- You can get \`$1Help2man' as part of \`Autoconf' from any GNU
- archive site."
- file=`echo "$*" | sed -n 's/.*--output[ =]*\([^ ]*\).*/\1/p'`
- test -z "$file" && file=`echo "$*" | sed -n 's/.*-o[ ]*\([^ ]*\).*/\1/p'`
- if test -f "$file"; then
- touch $file
- else
- test -z "$file" || exec >$file
- echo "#! /bin/sh"
- echo "# Created by GNU Automake missing as a replacement of"
- echo "# $ $@"
- echo "exit 0"
- chmod +x $file
- exit 1
- fi
- bison|yacc)
- echo 1>&2 "\
- you modified a \`.y' file. You may need the \`Bison' package
- in order for those modifications to take effect. You can get
- \`Bison' from any GNU archive site."
- rm -f y.tab.c y.tab.h
- if [ $# -ne 1 ]; then
- eval LASTARG="\${$#}"
- case "$LASTARG" in
- *.y)
- SRCFILE=`echo "$LASTARG" | sed 's/y$/c/'`
- if [ -f "$SRCFILE" ]; then
- cp "$SRCFILE" y.tab.c
- fi
- SRCFILE=`echo "$LASTARG" | sed 's/y$/h/'`
- cp "$SRCFILE" y.tab.h
- fi
- esac
- fi
- if [ ! -f y.tab.h ]; then
- echo >y.tab.h
- fi
- if [ ! -f y.tab.c ]; then
- echo 'main() { return 0; }' >y.tab.c
- fi
- lex|flex)
- echo 1>&2 "\
- you modified a \`.l' file. You may need the \`Flex' package
- \`Flex' from any GNU archive site."
- rm -f lex.yy.c
- *.l)
- SRCFILE=`echo "$LASTARG" | sed 's/l$/c/'`
- cp "$SRCFILE" lex.yy.c
- fi
- esac
- fi
- if [ ! -f lex.yy.c ]; then
- echo 'main() { return 0; }' >lex.yy.c
- fi
- help2man)
- exit 1
- fi
- echo 1>&2 "\
- you modified a dependency of a manual page. You may need the
- \`Help2man' package in order for those modifications to take
- effect. You can get \`Help2man' from any GNU archive site."
- file=`echo "$*" | sed -n 's/.*-o \([^ ]*\).*/\1/p'`
- if test -z "$file"; then
- file=`echo "$*" | sed -n 's/.*--output=\([^ ]*\).*/\1/p'`
- fi
- if [ -f "$file" ]; then
- touch $file
- else
- echo ".ab help2man is required to generate this page"
- exit 1
- fi
- makeinfo)
- if test -z "$run" && (makeinfo --version) > /dev/null 2>&1; then
- # We have makeinfo, but it failed.
- exit 1
- fi
- echo 1>&2 "\
- you modified a \`.texi' or \`.texinfo' file, or any other file
- indirectly affecting the aspect of the manual. The spurious
- call might also be the consequence of using a buggy \`make' (AIX,
- DU, IRIX). You might want to install the \`Texinfo' package or
- the \`GNU make' package. Grab either from any GNU archive site."
- file=`echo "$*" | sed 's/.* \([^ ]*\) *$/\1/'`
- file=`sed -n '/^@setfilename/ { s/.* \([^ ]*\) *$/\1/; p; q; }' $file`
- fi
- touch $file
- tar)
- shift
- if test -n "$run"; then
- echo 1>&2 "ERROR: \`tar' requires --run"
- exit 1
- fi
- # We have already tried tar in the generic part.
- # Look for gnutar/gtar before invocation to avoid ugly error
- # messages.
- if (gnutar --version > /dev/null 2>&1); then
- gnutar "$@" && exit 0
- fi
- if (gtar --version > /dev/null 2>&1); then
- gtar "$@" && exit 0
- fi
- firstarg="$1"
- if shift; then
- case "$firstarg" in
- *o*)
- firstarg=`echo "$firstarg" | sed s/o//`
- tar "$firstarg" "$@" && exit 0
- esac
- *h*)
- firstarg=`echo "$firstarg" | sed s/h//`
- esac
- fi
- echo 1>&2 "\
-WARNING: I can't seem to be able to run \`tar' with the given arguments.
- You may want to install GNU tar or Free paxutils, or check the
- command line arguments."
- exit 1
- echo 1>&2 "\
- proper tools for further handling them. Check the \`README' file,
- it often tells you about the needed prerequirements for installing
- this package. You may also peek at any GNU archive site, in case
- some other package would contain this missing \`$1' program."
- exit 1
-esac
-exit 0
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/missing (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/missing)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/missing (rev 0)
@@ -0,0 +1,336 @@
+#! /bin/sh
+# Common stub for a few missing GNU programs while installing.
+# Copyright (C) 1996, 1997, 1999, 2000, 2002 Free Software Foundation, Inc.
+# Originally by Fran,cois Pinard <pinard at iro.umontreal.ca>, 1996.
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA
+# 02111-1307, USA.
+# As a special exception to the GNU General Public License, if you
+# distribute this file as part of a program that contains a
+# configuration script generated by Autoconf, you may include it under
+# the same distribution terms that you use for the rest of that program.
+if test $# -eq 0; then
+ echo 1>&2 "Try \`$0 --help' for more information"
+ exit 1
+fi
+run=:
+# In the cases where this matters, `missing' is being run in the
+# srcdir already.
+if test -f configure.ac; then
+ configure_ac=configure.ac
+else
+ configure_ac=configure.in
+fi
+case "$1" in
+--run)
+ # Try to run requested program, and just exit if it succeeds.
+ run=
+ shift
+ "$@" && exit 0
+esac
+# If it does not exist, or fails to run (possibly an outdated version),
+# try to emulate it.
+case "$1" in
+ -h|--h|--he|--hel|--help)
+ echo "\
+$0 [OPTION]... PROGRAM [ARGUMENT]...
+Handle \`PROGRAM [ARGUMENT]...' for when PROGRAM is missing, or return an
+error status if there is no known handling for PROGRAM.
+Options:
+ -h, --help display this help and exit
+ -v, --version output version information and exit
+ --run try to run the given command, and emulate it if it fails
+Supported PROGRAM values:
+ aclocal touch file \`aclocal.m4'
+ autoconf touch file \`configure'
+ autoheader touch file \`config.h.in'
+ automake touch all \`Makefile.in' files
+ bison create \`y.tab.[ch]', if possible, from existing .[ch]
+ flex create \`lex.yy.c', if possible, from existing .c
+ help2man touch the output file
+ lex create \`lex.yy.c', if possible, from existing .c
+ makeinfo touch the output file
+ tar try tar, gnutar, gtar, then tar without non-portable flags
+ yacc create \`y.tab.[ch]', if possible, from existing .[ch]"
+ -v|--v|--ve|--ver|--vers|--versi|--versio|--version)
+ echo "missing 0.4 - GNU automake"
+ echo 1>&2 "$0: Unknown \`$1' option"
+ exit 1
+ aclocal*)
+ if test -z "$run" && ($1 --version) > /dev/null 2>&1; then
+ # We have it, but it failed.
+ exit 1
+ fi
+ echo 1>&2 "\
+WARNING: \`$1' is missing on your system. You should only need it if
+ you modified \`acinclude.m4' or \`${configure_ac}'. You might want
+ to install the \`Automake' and \`Perl' packages. Grab them from
+ any GNU archive site."
+ touch aclocal.m4
+ autoconf)
+ exit 1
+ fi
+ echo 1>&2 "\
+ you modified \`${configure_ac}'. You might want to install the
+ \`Autoconf' and \`GNU m4' packages. Grab them from any GNU
+ archive site."
+ touch configure
+ autoheader)
+ exit 1
+ fi
+ echo 1>&2 "\
+ you modified \`acconfig.h' or \`${configure_ac}'. You might want
+ to install the \`Autoconf' and \`GNU m4' packages. Grab them
+ from any GNU archive site."
+ files=`sed -n 's/^[ ]*A[CM]_CONFIG_HEADER(\([^)]*\)).*/\1/p' ${configure_ac}`
+ test -z "$files" && files="config.h"
+ touch_files=
+ for f in $files; do
+ case "$f" in
+ *:*) touch_files="$touch_files "`echo "$f" |
+ sed -e 's/^[^:]*://' -e 's/:.*//'`;;
+ *) touch_files="$touch_files $f.in";;
+ esac
+ done
+ touch $touch_files
+ automake*)
+ exit 1
+ fi
+ echo 1>&2 "\
+ you modified \`Makefile.am', \`acinclude.m4' or \`${configure_ac}'.
+ You might want to install the \`Automake' and \`Perl' packages.
+ Grab them from any GNU archive site."
+ find . -type f -name Makefile.am -print |
+ sed 's/\.am$/.in/' |
+ while read f; do touch "$f"; done
+ autom4te)
+ exit 1
+ fi
+ echo 1>&2 "\
+WARNING: \`$1' is needed, and you do not seem to have it handy on your
+ system. You might have modified some files without having the
+ proper tools for further handling them.
+ You can get \`$1Help2man' as part of \`Autoconf' from any GNU
+ archive site."
+ file=`echo "$*" | sed -n 's/.*--output[ =]*\([^ ]*\).*/\1/p'`
+ test -z "$file" && file=`echo "$*" | sed -n 's/.*-o[ ]*\([^ ]*\).*/\1/p'`
+ if test -f "$file"; then
+ touch $file
+ else
+ test -z "$file" || exec >$file
+ echo "#! /bin/sh"
+ echo "# Created by GNU Automake missing as a replacement of"
+ echo "# $ $@"
+ echo "exit 0"
+ chmod +x $file
+ exit 1
+ fi
+ bison|yacc)
+ echo 1>&2 "\
+ you modified a \`.y' file. You may need the \`Bison' package
+ in order for those modifications to take effect. You can get
+ \`Bison' from any GNU archive site."
+ rm -f y.tab.c y.tab.h
+ if [ $# -ne 1 ]; then
+ eval LASTARG="\${$#}"
+ case "$LASTARG" in
+ *.y)
+ SRCFILE=`echo "$LASTARG" | sed 's/y$/c/'`
+ if [ -f "$SRCFILE" ]; then
+ cp "$SRCFILE" y.tab.c
+ fi
+ SRCFILE=`echo "$LASTARG" | sed 's/y$/h/'`
+ cp "$SRCFILE" y.tab.h
+ fi
+ esac
+ fi
+ if [ ! -f y.tab.h ]; then
+ echo >y.tab.h
+ fi
+ if [ ! -f y.tab.c ]; then
+ echo 'main() { return 0; }' >y.tab.c
+ fi
+ lex|flex)
+ echo 1>&2 "\
+ you modified a \`.l' file. You may need the \`Flex' package
+ \`Flex' from any GNU archive site."
+ rm -f lex.yy.c
+ *.l)
+ SRCFILE=`echo "$LASTARG" | sed 's/l$/c/'`
+ cp "$SRCFILE" lex.yy.c
+ fi
+ esac
+ fi
+ if [ ! -f lex.yy.c ]; then
+ echo 'main() { return 0; }' >lex.yy.c
+ fi
+ help2man)
+ exit 1
+ fi
+ echo 1>&2 "\
+ you modified a dependency of a manual page. You may need the
+ \`Help2man' package in order for those modifications to take
+ effect. You can get \`Help2man' from any GNU archive site."
+ file=`echo "$*" | sed -n 's/.*-o \([^ ]*\).*/\1/p'`
+ if test -z "$file"; then
+ file=`echo "$*" | sed -n 's/.*--output=\([^ ]*\).*/\1/p'`
+ fi
+ if [ -f "$file" ]; then
+ touch $file
+ else
+ echo ".ab help2man is required to generate this page"
+ exit 1
+ fi
+ makeinfo)
+ if test -z "$run" && (makeinfo --version) > /dev/null 2>&1; then
+ # We have makeinfo, but it failed.
+ exit 1
+ fi
+ echo 1>&2 "\
+ you modified a \`.texi' or \`.texinfo' file, or any other file
+ indirectly affecting the aspect of the manual. The spurious
+ call might also be the consequence of using a buggy \`make' (AIX,
+ DU, IRIX). You might want to install the \`Texinfo' package or
+ the \`GNU make' package. Grab either from any GNU archive site."
+ file=`echo "$*" | sed 's/.* \([^ ]*\) *$/\1/'`
+ file=`sed -n '/^@setfilename/ { s/.* \([^ ]*\) *$/\1/; p; q; }' $file`
+ fi
+ touch $file
+ tar)
+ shift
+ if test -n "$run"; then
+ echo 1>&2 "ERROR: \`tar' requires --run"
+ exit 1
+ fi
+ # We have already tried tar in the generic part.
+ # Look for gnutar/gtar before invocation to avoid ugly error
+ # messages.
+ if (gnutar --version > /dev/null 2>&1); then
+ gnutar "$@" && exit 0
+ fi
+ if (gtar --version > /dev/null 2>&1); then
+ gtar "$@" && exit 0
+ fi
+ firstarg="$1"
+ if shift; then
+ case "$firstarg" in
+ *o*)
+ firstarg=`echo "$firstarg" | sed s/o//`
+ tar "$firstarg" "$@" && exit 0
+ esac
+ *h*)
+ firstarg=`echo "$firstarg" | sed s/h//`
+ esac
+ fi
+ echo 1>&2 "\
+WARNING: I can't seem to be able to run \`tar' with the given arguments.
+ You may want to install GNU tar or Free paxutils, or check the
+ command line arguments."
+ exit 1
+ echo 1>&2 "\
+ proper tools for further handling them. Check the \`README' file,
+ it often tells you about the needed prerequirements for installing
+ this package. You may also peek at any GNU archive site, in case
+ some other package would contain this missing \`$1' program."
+ exit 1
+esac
+exit 0
Deleted: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/mkinstalldirs
--- branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/mkinstalldirs 2013-02-12 13:35:16 UTC (rev 7349)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/mkinstalldirs 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,111 +0,0 @@
-#! /bin/sh
-# mkinstalldirs --- make directory hierarchy
-# Author: Noah Friedman <friedman at prep.ai.mit.edu>
-# Created: 1993-05-16
-# Public domain
-errstatus=0
-dirmode=""
-usage="\
-Usage: mkinstalldirs [-h] [--help] [-m mode] dir ..."
-# process command line arguments
-while test $# -gt 0 ; do
- case $1 in
- -h | --help | --h*) # -h for help
- echo "$usage" 1>&2
- exit 0
- -m) # -m PERM arg
- shift
- test $# -eq 0 && { echo "$usage" 1>&2; exit 1; }
- dirmode=$1
- shift
- --) # stop option processing
- shift
- break
- -*) # unknown option
- exit 1
- *) # first non-opt arg
- break
- esac
-done
-for file
-do
- if test -d "$file"; then
- shift
- else
- break
- fi
-done
-case $# in
- 0) exit 0 ;;
-esac
-case $dirmode in
- if mkdir -p -- . 2>/dev/null; then
- echo "mkdir -p -- $*"
- exec mkdir -p -- "$@"
- fi
- if mkdir -m "$dirmode" -p -- . 2>/dev/null; then
- echo "mkdir -m $dirmode -p -- $*"
- exec mkdir -m "$dirmode" -p -- "$@"
- fi
-esac
-for file
-do
- set fnord `echo ":$file" | sed -ne 's/^:\//#/;s/^://;s/\// /g;s/^#/\//;p'`
- shift
- pathcomp=
- for d
- do
- pathcomp="$pathcomp$d"
- case $pathcomp in
- -*) pathcomp=./$pathcomp ;;
- esac
- if test ! -d "$pathcomp"; then
- echo "mkdir $pathcomp"
- mkdir "$pathcomp" || lasterr=$?
- errstatus=$lasterr
- else
- if test ! -z "$dirmode"; then
- echo "chmod $dirmode $pathcomp"
- lasterr=""
- chmod "$dirmode" "$pathcomp" || lasterr=$?
- if test ! -z "$lasterr"; then
- fi
- fi
- fi
- fi
- pathcomp="$pathcomp/"
- done
-done
-exit $errstatus
-# Local Variables:
-# mode: shell-script
-# sh-indentation: 2
-# End:
-# mkinstalldirs ends here
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/mkinstalldirs (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/mkinstalldirs)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/build/gnu/dwfcore/files/mkinstalldirs (rev 0)
@@ -0,0 +1,111 @@
+#! /bin/sh
+# mkinstalldirs --- make directory hierarchy
+# Author: Noah Friedman <friedman at prep.ai.mit.edu>
+# Created: 1993-05-16
+# Public domain
+errstatus=0
+dirmode=""
+usage="\
+Usage: mkinstalldirs [-h] [--help] [-m mode] dir ..."
+# process command line arguments
+while test $# -gt 0 ; do
+ case $1 in
+ -h | --help | --h*) # -h for help
+ echo "$usage" 1>&2
+ exit 0
+ -m) # -m PERM arg
+ shift
+ test $# -eq 0 && { echo "$usage" 1>&2; exit 1; }
+ dirmode=$1
+ shift
+ --) # stop option processing
+ shift
+ break
+ -*) # unknown option
+ exit 1
+ *) # first non-opt arg
+ break
+ esac
+done
+for file
+do
+ if test -d "$file"; then
+ shift
+ else
+ break
+ fi
+done
+case $# in
+ 0) exit 0 ;;
+esac
+case $dirmode in
+ if mkdir -p -- . 2>/dev/null; then
+ echo "mkdir -p -- $*"
+ exec mkdir -p -- "$@"
+ fi
+ if mkdir -m "$dirmode" -p -- . 2>/dev/null; then
+ echo "mkdir -m $dirmode -p -- $*"
+ exec mkdir -m "$dirmode" -p -- "$@"
+ fi
+esac
+for file
+do
+ set fnord `echo ":$file" | sed -ne 's/^:\//#/;s/^://;s/\// /g;s/^#/\//;p'`
+ shift
+ pathcomp=
+ for d
+ do
+ pathcomp="$pathcomp$d"
+ case $pathcomp in
+ -*) pathcomp=./$pathcomp ;;
+ esac
+ if test ! -d "$pathcomp"; then
+ echo "mkdir $pathcomp"
+ mkdir "$pathcomp" || lasterr=$?
+ errstatus=$lasterr
+ else
+ if test ! -z "$dirmode"; then
+ echo "chmod $dirmode $pathcomp"
+ lasterr=""
+ chmod "$dirmode" "$pathcomp" || lasterr=$?
+ if test ! -z "$lasterr"; then
+ fi
+ fi
+ fi
+ fi
+ pathcomp="$pathcomp/"
+ done
+done
+exit $errstatus
+# Local Variables:
+# mode: shell-script
+# sh-indentation: 2
+# End:
+# mkinstalldirs ends here
Modified: trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/Core.h
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/Core.h 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/Core.h 2013-02-15 12:16:10 UTC (rev 7356)
@@ -44,7 +44,7 @@
#if defined(__i386__) || defined(__i486__) || defined(__i586__) || defined(__i686) || defined(_M_IX86)
#define _DWFCORE_X86_SYSTEM
-#elif defined(_WIN64)
+#elif defined(_M_X64) || defined(__x86_64__) //DWFTK 7.7 backport
#define _DWFCORE_X64_SYSTEM
#elif defined(_M_ALPHA)
#define _DWFCORE_ALPHA_SYSTEM
Modified: trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/Makefile.am
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/Makefile.am 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/Makefile.am 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,6 +1,6 @@
AUTOMAKE_OPTIONS = nostdinc
INCLUDES = -I..
-SUBDIRS = ansi mac x86 zip zlib
+SUBDIRS = ansi mac x86 x64 zip zlib
pkginclude_HEADERS = BufferInputStream.h BufferOutputStream.h Comparator.h Core.h CountedObject.h DecompressingInputStream.h Exception.h File.h FileDescriptor.h FileInputStream.h FileOutputStream.h Hash.h InputStream.h Iterator.h MIME.h MonitoredInputStream.h OutputStream.h Owner.h Pointer.h SkipList.h STL.h StreamFileDescriptor.h String.h Synchronization.h TempFile.h ThreadPool.h Timer.h UnzippingInputStream.h UTF8EncodingOutputStream.h UUID.h Version.h XMLEncodingOutputStream.h ZipFileDescriptor.h ZippingOutputStream.h
@@ -11,4 +11,4 @@
libdwfcore_la_SOURCES = BufferInputStream.cpp BufferOutputStream.cpp DecompressingInputStream.cpp Exception.cpp File.cpp FileInputStream.cpp FileOutputStream.cpp MIME.cpp MonitoredInputStream.cpp Owner.cpp ThreadPool.cpp UnzippingInputStream.cpp UTF8EncodingOutputStream.cpp UUID.cpp XMLEncodingOutputStream.cpp ZipFileDescriptor.cpp ZippingOutputStream.cpp
-libdwfcore_la_LIBADD = $(top_builddir)/ansi/libdwfcoreansi.la $(top_builddir)/mac/libdwfcoremac.la $(top_builddir)/x86/libdwfcorex86.la $(top_builddir)/zlib/libdwfcorezlib.la $(top_builddir)/zip/libdwfcorezip.la
+libdwfcore_la_LIBADD = $(top_builddir)/ansi/libdwfcoreansi.la $(top_builddir)/mac/libdwfcoremac.la $(top_builddir)/x86/libdwfcorex86.la $(top_builddir)/x64/libdwfcorex64.la $(top_builddir)/zlib/libdwfcorezlib.la $(top_builddir)/zip/libdwfcorezip.la
Modified: trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Core.cpp
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Core.cpp 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Core.cpp 2013-02-15 12:16:10 UTC (rev 7356)
@@ -50,14 +50,80 @@
return InterlockedDecrement((volatile long*)pValue);
-#elif _DWFCORE_LINUX_SYSTEM
+#elif defined(_DWFCORE_LINUX_SYSTEM)
// TODO: Need 64-bit Linux
// for AtomicIncrement and AtomicDecrement
+// NOTE: Backported from DWF Toolkit 7.7
+#ifdef HAVE_CONFIG_H
+ #include "dwfcore/config.h"
+ #if !defined( _DWFCORE_USE_ASM_ATOMIC_H ) && !defined( _DWFCORE_USE_ALSA_IATOMIC_H )
+ #if defined( HAVE_ASM_ATOMIC_H )
+ #include <asm/atomic.h>
+ #elif defined( HAVE_ALSA_IATOMIC_H )
+ #include <alsa/iatomic.h>
+ #else
+ #error Missing header file - cannot continue
+ #endif
+ // change LOCK to _DWFCORE_ATOMIC_LOCK
+ // to prevent any unexpected redefinitions
+ #ifdef __SMP__
+ #define _DWFCORE_ATOMIC_LOCK "lock ; "
+ #else
+ #define _DWFCORE_ATOMIC_LOCK ""
+ #endif
+ namespace DWFCore
+ _DWFCORE_API
+ int
+ AtomicIncrement( volatile int* pValue )
+ throw()
+ atomic_t tValue;
+ atomic_set( &tValue, *pValue );
+ __asm__ __volatile__(
+ _DWFCORE_ATOMIC_LOCK "incl %0"
+ :"=m" (tValue.counter)
+ :"m" (tValue.counter));
+ *pValue = atomic_read( &tValue );
+ return *pValue;
+ _DWFCORE_API
+ int
+ AtomicDecrement( volatile int* pValue )
+ throw()
+ atomic_t tValue;
+ _DWFCORE_ATOMIC_LOCK "decl %0"
+ return *pValue;
#endif
+#endif
+#endif
#endif
Copied: trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Makefile.am (from rev 7349, branches/2.5/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Makefile.am)
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Makefile.am (rev 0)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Makefile.am 2013-02-15 12:16:10 UTC (rev 7356)
@@ -0,0 +1,7 @@
+AUTOMAKE_OPTIONS = nostdinc
+INCLUDES = -I../..
+noinst_LTLIBRARIES = libdwfcorex64.la
+libdwfcorex64_la_LDFLAGS = -avoid-version
+libdwfcorex64_la_SOURCES = Core.cpp Timer.cpp
Modified: trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Timer.cpp
--- trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Timer.cpp 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Oem/DWFTK7.1/develop/global/src/dwfcore/x64/Timer.cpp 2013-02-15 12:16:10 UTC (rev 7356)
@@ -131,12 +131,138 @@
return _nTick;
+// NOTE: Implementation backported from DWF Toolkit 7.7
+_DWFCORE_API
+DWFTimer::DWFTimer()
+throw()
+: _nTick( 0 )
+_DWFCORE_API
+DWFTimer::DWFTimer( const DWFTimer& rTimer )
+throw()
+: _nTick( rTimer._nTick )
+_DWFCORE_API
+DWFTimer&
+DWFTimer::operator=( const DWFTimer& rTimer )
+throw()
+ _nTick = rTimer._nTick;
+ return *this;
+_DWFCORE_API
+DWFTimer::~DWFTimer()
+throw()
+_DWFCORE_API
+unsigned long
+DWFTimer::Tick32()
+throw()
+ unsigned long eax = 0L;
+ __asm__ __volatile__( ".byte 15, 49" : : : "eax", "edx" );
+ __asm__ __volatile__( "movq %%rax, %0" : "=r"(eax) );
+ // gcc is checking no return
+ return eax;
+ // lower 32-bits in eax
+_DWFCORE_API
+uint64_t
+DWFTimer::Tick64()
+throw()
+ unsigned long edx = 0L;
+ __asm__ __volatile__( "movq %%rax, %0; movq %%rdx, %1": "=r"(eax), "=r"(edx) );
+ uint64_t nTick64 = edx;
+ nTick64 <<= 32;
+ nTick64 |= eax;
+ return nTick64;
+ // upper 32-bits in edx
+_DWFCORE_API
+void
+DWFTimer::start()
+throw()
+ _nTick = Tick64();
+_DWFCORE_API
+unsigned long
+DWFTimer::tick32()
+throw()
+ return (Tick32() - (unsigned long)(0x00000000ffffffff & _nTick));
+_DWFCORE_API
+uint64_t
+DWFTimer::tick64()
+throw()
+ return (Tick64() - _nTick);
+_DWFCORE_API
+void
+DWFTimer::stop()
+throw()
+ _nTick = (Tick64() - _nTick);
+_DWFCORE_API
+unsigned long
+DWFTimer::timer32()
+throw()
+ return (unsigned long)(0x00000000ffffffff & _nTick);
+_DWFCORE_API
+uint64_t
+DWFTimer::timer64()
+throw()
+ return _nTick;
#endif
Modified: trunk/MgDev/Oem/SWIGEx/Makefile
--- trunk/MgDev/Oem/SWIGEx/Makefile 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Oem/SWIGEx/Makefile 2013-02-15 12:16:10 UTC (rev 7356)
@@ -12,8 +12,8 @@
CXX = g++
LEX = flex
YACC = yacc
-CFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions -DNDEBUG
-CXXFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions -DNDEBUG
+CFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -fno-use-cxa-atexit -fexceptions -DNDEBUG
+CXXFLAGS = -pipe -UZTS -Wall -W -O2 -g -pipe -fno-use-cxa-atexit -fexceptions -DNDEBUG
LEXFLAGS =
YACCFLAGS= -d
INCPATH = -I$(QTDIR)/mkspecs/default -I. -ISource/CParse -ISource/DOH -ISource/Include -ISource/Swig -ISource/Modules -ISource/Preprocessor
Modified: trunk/MgDev/Oem/agg-2.4/src/Makefile
--- trunk/MgDev/Oem/agg-2.4/src/Makefile 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Oem/agg-2.4/src/Makefile 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,6 +1,6 @@
include ../Makefile.in.$(shell uname)
-CXXFLAGS= $(AGGCXXFLAGS) -I../include -L./
+CXXFLAGS= $(AGGCXXFLAGS) $(EXTRACXXFLAGS) -I../include -L./
SRC_CXX=\
agg_arc.cpp \
Modified: trunk/MgDev/Oem/gd/jpeg/config.guess
--- trunk/MgDev/Oem/gd/jpeg/config.guess 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Oem/gd/jpeg/config.guess 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,7 +1,10 @@
#! /bin/sh
# Attempt to guess a canonical system name.
-# Copyright (C) 1992, 93, 94, 95, 96, 1997 Free Software Foundation, Inc.
+# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999,
+# 2000, 2001, 2002, 2003, 2004, 2005 Free Software Foundation, Inc.
+timestamp='2005-09-19'
# This file is free software; you can redistribute it and/or modify it
# under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
@@ -14,154 +17,323 @@
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+# Foundation, Inc., 51 Franklin Street - Fifth Floor, Boston, MA
+# 02110-1301, USA.
-# Written by Per Bothner <bothner at cygnus.com>.
-# The master version of this file is at the FSF in /home/gd/gnu/lib.
+# Originally written by Per Bothner <per at bothner.com>.
+# Please send patches to <config-patches at gnu.org>. Submit a context
+# diff and a properly formatted ChangeLog entry.
# This script attempts to guess a canonical system name similar to
# config.sub. If it succeeds, it prints the system name on stdout, and
# exits with 0. Otherwise, it exits with 1.
# The plan is that this can be called by configure scripts if you
-# don't specify an explicit system type (host/target name).
-# Only a few systems have been added to this list; please add others
-# (but try to keep the structure clean).
+# don't specify an explicit build system type.
+me=`echo "$0" | sed -e 's,.*/,,'`
+usage="\
+Usage: $0 [OPTION]
+Output the configuration name of the system \`$me' is run on.
+Operation modes:
+ -h, --help print this help, then exit
+ -t, --time-stamp print date of last modification, then exit
+ -v, --version print version number, then exit
+Report bugs and patches to <config-patches at gnu.org>."
+version="\
+GNU config.guess ($timestamp)
+Originally written by Per Bothner.
+Copyright (C) 1992, 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005
+Free Software Foundation, Inc.
+This is free software; see the source for copying conditions. There is NO
+warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE."
+help="
+Try \`$me --help' for more information."
+# Parse command line
+ case $1 in
+ --time-stamp | --time* | -t )
+ echo "$timestamp" ; exit ;;
+ --version | -v )
+ echo "$version" ; exit ;;
+ --help | --h* | -h )
+ echo "$usage"; exit ;;
+ -- ) # Stop option processing
+ shift; break ;;
+ - ) # Use stdin as input.
+ break ;;
+ echo "$me: invalid option $1$help" >&2
+ exit 1 ;;
+ break ;;
+ esac
+done
+if test $# != 0; then
+ echo "$me: too many arguments$help" >&2
+ exit 1
+fi
+trap 'exit 1' 1 2 15
+# CC_FOR_BUILD -- compiler used by this script. Note that the use of a
+# compiler to aid in system detection is discouraged as it requires
+# temporary files to be created and, as you can see below, it is a
+# headache to deal with in a portable fashion.
+# Historically, `CC_FOR_BUILD' used to be named `HOST_CC'. We still
+# use `HOST_CC' if defined, but it is deprecated.
+# Portable tmp directory creation inspired by the Autoconf team.
+set_cc_for_build='
+trap "exitcode=\$?; (rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null) && exit \$exitcode" 0 ;
+trap "rm -f \$tmpfiles 2>/dev/null; rmdir \$tmp 2>/dev/null; exit 1" 1 2 13 15 ;
+: ${TMPDIR=/tmp} ;
+ { tmp=`(umask 077 && mktemp -d -q "$TMPDIR/cgXXXXXX") 2>/dev/null` && test -n "$tmp" && test -d "$tmp" ; } ||
+ { test -n "$RANDOM" && tmp=$TMPDIR/cg$$-$RANDOM && (umask 077 && mkdir $tmp) ; } ||
+ { tmp=$TMPDIR/cg-$$ && (umask 077 && mkdir $tmp) && echo "Warning: creating insecure temp directory" >&2 ; } ||
+ { echo "$me: cannot create a temporary directory in $TMPDIR" >&2 ; exit 1 ; } ;
+dummy=$tmp/dummy ;
+tmpfiles="$dummy.c $dummy.o $dummy.rel $dummy" ;
+case $CC_FOR_BUILD,$HOST_CC,$CC in
+ ,,) echo "int x;" > $dummy.c ;
+ for c in cc gcc c89 c99 ; do
+ if ($c -c -o $dummy.o $dummy.c) >/dev/null 2>&1 ; then
+ CC_FOR_BUILD="$c"; break ;
+ fi ;
+ done ;
+ if test x"$CC_FOR_BUILD" = x ; then
+ CC_FOR_BUILD=no_compiler_found ;
+ fi
+ ,,*) CC_FOR_BUILD=$CC ;;
+ ,*,*) CC_FOR_BUILD=$HOST_CC ;;
+esac ; set_cc_for_build= ;'
# This is needed to find uname on a Pyramid OSx when run in the BSD universe.
-# (ghazi at noc.rutgers.edu 8/24/94.)
+# (ghazi at noc.rutgers.edu 1994-08-24)
if (test -f /.attbin/uname) >/dev/null 2>&1 ; then
PATH=$PATH:/.attbin ; export PATH
fi
UNAME_MACHINE=`(uname -m) 2>/dev/null` || UNAME_MACHINE=unknown
UNAME_RELEASE=`(uname -r) 2>/dev/null` || UNAME_RELEASE=unknown
-UNAME_SYSTEM=`(uname -s) 2>/dev/null` || UNAME_SYSTEM=unknown
+UNAME_SYSTEM=`(uname -s) 2>/dev/null` || UNAME_SYSTEM=unknown
UNAME_VERSION=`(uname -v) 2>/dev/null` || UNAME_VERSION=unknown
-trap 'rm -f dummy.c dummy.o dummy; exit 1' 1 2 15
# Note: order is significant - the case branches are not exclusive.
case "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" in
+ *:NetBSD:*:*)
+ # NetBSD (nbsd) targets should (where applicable) match one or
+ # more of the tupples: *-*-netbsdelf*, *-*-netbsdaout*,
+ # *-*-netbsdecoff* and *-*-netbsd*. For targets that recently
+ # switched to ELF, *-*-netbsd* would select the old
+ # object file format. This provides both forward
+ # compatibility and a consistent mechanism for selecting the
+ # Note: NetBSD doesn't particularly care about the vendor
+ # portion of the name. We always set it to "unknown".
+ sysctl="sysctl -n hw.machine_arch"
+ UNAME_MACHINE_ARCH=`(/sbin/$sysctl 2>/dev/null || \
+ /usr/sbin/$sysctl 2>/dev/null || echo unknown)`
+ case "${UNAME_MACHINE_ARCH}" in
+ armeb) machine=armeb-unknown ;;
+ arm*) machine=arm-unknown ;;
+ sh3el) machine=shl-unknown ;;
+ sh3eb) machine=sh-unknown ;;
+ *) machine=${UNAME_MACHINE_ARCH}-unknown ;;
+ esac
+ # The Operating System including object format, if it has switched
+ # to ELF recently, or will in the future.
+ arm*|i386|m68k|ns32k|sh3*|sparc|vax)
+ eval $set_cc_for_build
+ if echo __ELF__ | $CC_FOR_BUILD -E - 2>/dev/null \
+ | grep __ELF__ >/dev/null
+ then
+ # Once all utilities can be ECOFF (netbsdecoff) or a.out (netbsdaout).
+ # Return netbsd for either. FIX?
+ os=netbsd
+ else
+ os=netbsdelf
+ fi
+ os=netbsd
+ esac
+ # The OS release
+ # Debian GNU/NetBSD machines have a different userland, and
+ # thus, need a distinct triplet. However, they do not need
+ # kernel version information, so it can be replaced with a
+ # suitable tag, in the style of linux-gnu.
+ case "${UNAME_VERSION}" in
+ Debian*)
+ release='-gnu'
+ release=`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
+ esac
+ # Since CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM:
+ # contains redundant information, the shorter form:
+ # CPU_TYPE-MANUFACTURER-OPERATING_SYSTEM is used.
+ echo "${machine}-${os}${release}"
+ exit ;;
+ *:OpenBSD:*:*)
+ UNAME_MACHINE_ARCH=`arch | sed 's/OpenBSD.//'`
+ echo ${UNAME_MACHINE_ARCH}-unknown-openbsd${UNAME_RELEASE}
+ exit ;;
+ *:ekkoBSD:*:*)
+ echo ${UNAME_MACHINE}-unknown-ekkobsd${UNAME_RELEASE}
+ exit ;;
+ macppc:MirBSD:*:*)
+ echo powerppc-unknown-mirbsd${UNAME_RELEASE}
+ exit ;;
+ *:MirBSD:*:*)
+ echo ${UNAME_MACHINE}-unknown-mirbsd${UNAME_RELEASE}
+ exit ;;
alpha:OSF1:*:*)
- if test $UNAME_RELEASE = "V4.0"; then
+ case $UNAME_RELEASE in
+ *4.0)
UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $3}'`
- fi
+ *5.*)
+ UNAME_RELEASE=`/usr/sbin/sizer -v | awk '{print $4}'`
+ esac
+ # According to Compaq, /usr/sbin/psrinfo has been available on
+ # OSF/1 and Tru64 systems produced since 1995. I hope that
+ # covers most systems running today. This code pipes the CPU
+ # types through head -n 1, so we only detect the type of CPU 0.
+ ALPHA_CPU_TYPE=`/usr/sbin/psrinfo -v | sed -n -e 's/^ The alpha \(.*\) processor.*$/\1/p' | head -n 1`
+ case "$ALPHA_CPU_TYPE" in
+ "EV4 (21064)")
+ UNAME_MACHINE="alpha" ;;
+ "EV4.5 (21064)")
+ "LCA4 (21066/21068)")
+ "EV5 (21164)")
+ UNAME_MACHINE="alphaev5" ;;
+ "EV5.6 (21164A)")
+ UNAME_MACHINE="alphaev56" ;;
+ "EV5.6 (21164PC)")
+ UNAME_MACHINE="alphapca56" ;;
+ "EV5.7 (21164PC)")
+ UNAME_MACHINE="alphapca57" ;;
+ "EV6 (21264)")
+ UNAME_MACHINE="alphaev6" ;;
+ "EV6.7 (21264A)")
+ UNAME_MACHINE="alphaev67" ;;
+ "EV6.8CB (21264C)")
+ UNAME_MACHINE="alphaev68" ;;
+ "EV6.8AL (21264B)")
+ "EV6.8CX (21264D)")
+ "EV6.9A (21264/EV69A)")
+ UNAME_MACHINE="alphaev69" ;;
+ "EV7 (21364)")
+ UNAME_MACHINE="alphaev7" ;;
+ "EV7.9 (21364A)")
+ UNAME_MACHINE="alphaev79" ;;
+ esac
+ # A Pn.n version is a patched version.
# A Vn.n version is a released version.
# A Tn.n version is a released field test version.
# A Xn.n version is an unreleased experimental baselevel.
# 1.2 uses "1.2" for uname -r.
- cat <<EOF >dummy.s
- .globl main
- .ent main
-main:
- .frame \$30,0,\$26,0
- .prologue 0
- .long 0x47e03d80 # implver $0
- lda \$2,259
- .long 0x47e20c21 # amask $2,$1
- srl \$1,8,\$2
- sll \$2,2,\$2
- sll \$0,3,\$0
- addl \$1,\$0,\$0
- addl \$2,\$0,\$0
- ret \$31,(\$26),1
- .end main
-EOF
- ${CC-cc} dummy.s -o dummy 2>/dev/null
- if test "$?" = 0 ; then
- ./dummy
- case "$?" in
- 7)
- UNAME_MACHINE="alpha"
- 15)
- UNAME_MACHINE="alphaev5"
- 14)
- UNAME_MACHINE="alphaev56"
- 10)
- UNAME_MACHINE="alphapca56"
- 16)
- UNAME_MACHINE="alphaev6"
- esac
- fi
- rm -f dummy.s dummy
- echo ${UNAME_MACHINE}-dec-osf`echo ${UNAME_RELEASE} | sed -e 's/^[VTX]//' | tr [[A-Z]] [[a-z]]`
- exit 0 ;;
+ echo ${UNAME_MACHINE}-dec-osf`echo ${UNAME_RELEASE} | sed -e 's/^[PVTX]//' | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
+ exit ;;
+ Alpha\ *:Windows_NT*:*)
+ # How do we know it's Interix rather than the generic POSIX subsystem?
+ # Should we change UNAME_MACHINE based on the output of uname instead
+ # of the specific Alpha model?
+ echo alpha-pc-interix
+ exit ;;
21064:Windows_NT:50:3)
echo alpha-dec-winnt3.5
- exit 0 ;;
+ exit ;;
Amiga*:UNIX_System_V:4.0:*)
- echo m68k-cbm-sysv4
- exit 0;;
- amiga:NetBSD:*:*)
- echo m68k-cbm-netbsd${UNAME_RELEASE}
- exit 0 ;;
- amiga:OpenBSD:*:*)
- echo m68k-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- arc64:OpenBSD:*:*)
- echo mips64el-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- arc:OpenBSD:*:*)
- echo mipsel-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- hkmips:OpenBSD:*:*)
- echo mips-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
- pmax:OpenBSD:*:*)
- exit 0 ;;
- sgi:OpenBSD:*:*)
- exit 0 ;;
- wgrisc:OpenBSD:*:*)
- exit 0 ;;
+ echo m68k-unknown-sysv4
+ exit ;;
+ *:[Aa]miga[Oo][Ss]:*:*)
+ echo ${UNAME_MACHINE}-unknown-amigaos
+ exit ;;
+ *:[Mm]orph[Oo][Ss]:*:*)
+ echo ${UNAME_MACHINE}-unknown-morphos
+ exit ;;
+ *:OS/390:*:*)
+ echo i370-ibm-openedition
+ exit ;;
+ *:z/VM:*:*)
+ echo s390-ibm-zvmoe
+ exit ;;
+ *:OS400:*:*)
+ echo powerpc-ibm-os400
+ exit ;;
arm:RISC*:1.[012]*:*|arm:riscix:1.[012]*:*)
echo arm-acorn-riscix${UNAME_RELEASE}
- exit 0;;
- arm32:NetBSD:*:*)
- echo arm-unknown-netbsd`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
- exit 0 ;;
- SR2?01:HI-UX/MPP:*:*)
+ exit ;;
+ arm:riscos:*:*|arm:RISCOS:*:*)
+ echo arm-unknown-riscos
+ exit ;;
+ SR2?01:HI-UX/MPP:*:* | SR8000:HI-UX/MPP:*:*)
echo hppa1.1-hitachi-hiuxmpp
- exit 0;;
- Pyramid*:OSx*:*:*|MIS*:OSx*:*:*)
+ exit ;;
+ Pyramid*:OSx*:*:* | MIS*:OSx*:*:* | MIS*:SMP_DC-OSx*:*:*)
# akee at wpdis03.wpafb.af.mil (Earle F. Ake) contributed MIS and NILE.
if test "`(/bin/universe) 2>/dev/null`" = att ; then
echo pyramid-pyramid-sysv3
else
echo pyramid-pyramid-bsd
fi
- exit 0 ;;
- NILE:*:*:dcosx)
+ exit ;;
+ NILE*:*:*:dcosx)
echo pyramid-pyramid-svr4
- exit 0 ;;
+ exit ;;
+ DRS?6000:unix:4.0:6*)
+ echo sparc-icl-nx6
+ exit ;;
+ DRS?6000:UNIX_SV:4.2*:7* | DRS?6000:isis:4.2*:7*)
+ case `/usr/bin/uname -p` in
+ sparc) echo sparc-icl-nx7; exit ;;
+ esac ;;
+ sun4H:SunOS:5.*:*)
+ echo sparc-hal-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
+ exit ;;
sun4*:SunOS:5.*:* | tadpole*:SunOS:5.*:*)
echo sparc-sun-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
+ exit ;;
i86pc:SunOS:5.*:*)
echo i386-pc-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
+ exit ;;
sun4*:SunOS:6*:*)
# According to config.sub, this is the proper way to canonicalize
# SunOS6. Hard to guess exactly what SunOS6 will be like, but
# it's likely to be more like Solaris than SunOS4.
echo sparc-sun-solaris3`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
+ exit ;;
sun4*:SunOS:*:*)
case "`/usr/bin/arch -k`" in
Series*|S4*)
@@ -170,12 +342,12 @@
esac
# Japanese Language versions have a version number like `4.1.3-JL'.
echo sparc-sun-sunos`echo ${UNAME_RELEASE}|sed -e 's/-/_/'`
- exit 0 ;;
+ exit ;;
sun3*:SunOS:*:*)
echo m68k-sun-sunos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
sun*:*:4.2BSD:*)
- UNAME_RELEASE=`(head -1 /etc/motd | awk '{print substr($5,1,3)}') 2>/dev/null`
+ UNAME_RELEASE=`(sed 1q /etc/motd | awk '{print substr($5,1,3)}') 2>/dev/null`
test "x${UNAME_RELEASE}" = "x" && UNAME_RELEASE=3
case "`/bin/arch`" in
sun3)
@@ -185,52 +357,63 @@
echo sparc-sun-sunos${UNAME_RELEASE}
esac
- exit 0 ;;
+ exit ;;
aushp:SunOS:*:*)
echo sparc-auspex-sunos${UNAME_RELEASE}
- exit 0 ;;
- atari*:NetBSD:*:*)
- echo m68k-atari-netbsd${UNAME_RELEASE}
- exit 0 ;;
- atari*:OpenBSD:*:*)
- exit 0 ;;
- sun3*:NetBSD:*:*)
- echo m68k-sun-netbsd${UNAME_RELEASE}
- exit 0 ;;
- sun3*:OpenBSD:*:*)
- exit 0 ;;
- mac68k:NetBSD:*:*)
- echo m68k-apple-netbsd${UNAME_RELEASE}
- exit 0 ;;
- mac68k:OpenBSD:*:*)
- exit 0 ;;
- mvme68k:OpenBSD:*:*)
- exit 0 ;;
- mvme88k:OpenBSD:*:*)
- echo m88k-unknown-openbsd${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
+ # The situation for MiNT is a little confusing. The machine name
+ # can be virtually everything (everything which is not
+ # "atarist" or "atariste" at least should have a processor
+ # > m68000). The system name ranges from "MiNT" over "FreeMiNT"
+ # to the lowercase version "mint" (or "freemint"). Finally
+ # the system name "TOS" denotes a system which is actually not
+ # MiNT. But MiNT is downward compatible to TOS, so this should
+ # be no problem.
+ atarist[e]:*MiNT:*:* | atarist[e]:*mint:*:* | atarist[e]:*TOS:*:*)
+ echo m68k-atari-mint${UNAME_RELEASE}
+ exit ;;
+ atari*:*MiNT:*:* | atari*:*mint:*:* | atarist[e]:*TOS:*:*)
+ exit ;;
+ *falcon*:*MiNT:*:* | *falcon*:*mint:*:* | *falcon*:*TOS:*:*)
+ exit ;;
+ milan*:*MiNT:*:* | milan*:*mint:*:* | *milan*:*TOS:*:*)
+ echo m68k-milan-mint${UNAME_RELEASE}
+ exit ;;
+ hades*:*MiNT:*:* | hades*:*mint:*:* | *hades*:*TOS:*:*)
+ echo m68k-hades-mint${UNAME_RELEASE}
+ exit ;;
+ *:*MiNT:*:* | *:*mint:*:* | *:*TOS:*:*)
+ echo m68k-unknown-mint${UNAME_RELEASE}
+ exit ;;
+ m68k:machten:*:*)
+ echo m68k-apple-machten${UNAME_RELEASE}
+ exit ;;
powerpc:machten:*:*)
echo powerpc-apple-machten${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
RISC*:Mach:*:*)
echo mips-dec-mach_bsd4.3
- exit 0 ;;
+ exit ;;
RISC*:ULTRIX:*:*)
echo mips-dec-ultrix${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
VAX*:ULTRIX*:*:*)
echo vax-dec-ultrix${UNAME_RELEASE}
- exit 0 ;;
- 2020:CLIX:*:*)
+ exit ;;
+ 2020:CLIX:*:* | 2430:CLIX:*:*)
echo clipper-intergraph-clix${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
mips:*:*:UMIPS | mips:*:*:RISCos)
- sed 's/^ //' << EOF >dummy.c
- int main (argc, argv) int argc; char **argv; {
+ sed 's/^ //' << EOF >$dummy.c
+#ifdef __cplusplus
+#include <stdio.h> /* for printf() prototype */
+ int main (int argc, char *argv[]) {
+#else
+ int main (argc, argv) int argc; char *argv[]; {
+#endif
#if defined (host_mips) && defined (MIPSEB)
#if defined (SYSTYPE_SYSV)
printf ("mips-mips-riscos%ssysv\n", argv[1]); exit (0);
@@ -245,62 +428,83 @@
exit (-1);
EOF
- ${CC-cc} dummy.c -o dummy \
- && ./dummy `echo "${UNAME_RELEASE}" | sed -n 's/\([0-9]*\).*/\1/p'` \
- && rm dummy.c dummy && exit 0
- rm -f dummy.c dummy
+ $CC_FOR_BUILD -o $dummy $dummy.c &&
+ dummyarg=`echo "${UNAME_RELEASE}" | sed -n 's/\([0-9]*\).*/\1/p'` &&
+ SYSTEM_NAME=`$dummy $dummyarg` &&
+ { echo "$SYSTEM_NAME"; exit; }
echo mips-mips-riscos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
+ Motorola:PowerMAX_OS:*:*)
+ echo powerpc-motorola-powermax
+ exit ;;
+ Motorola:*:4.3:PL8-*)
+ echo powerpc-harris-powermax
+ exit ;;
+ Night_Hawk:*:*:PowerMAX_OS | Synergy:PowerMAX_OS:*:*)
+ exit ;;
Night_Hawk:Power_UNIX:*:*)
echo powerpc-harris-powerunix
- exit 0 ;;
+ exit ;;
m88k:CX/UX:7*:*)
echo m88k-harris-cxux7
- exit 0 ;;
+ exit ;;
m88k:*:4*:R4*)
echo m88k-motorola-sysv4
- exit 0 ;;
+ exit ;;
m88k:*:3*:R3*)
echo m88k-motorola-sysv3
- exit 0 ;;
+ exit ;;
AViiON:dgux:*:*)
# DG/UX returns AViiON for all architectures
UNAME_PROCESSOR=`/usr/bin/uname -p`
- if [ $UNAME_PROCESSOR = mc88100 -o $UNAME_PROCESSOR = mc88110 ] ; then
- if [ ${TARGET_BINARY_INTERFACE}x = m88kdguxelfx \
- -o ${TARGET_BINARY_INTERFACE}x = x ] ; then
+ if [ $UNAME_PROCESSOR = mc88100 ] || [ $UNAME_PROCESSOR = mc88110 ]
+ then
+ if [ ${TARGET_BINARY_INTERFACE}x = m88kdguxelfx ] || \
+ [ ${TARGET_BINARY_INTERFACE}x = x ]
+ then
echo m88k-dg-dgux${UNAME_RELEASE}
+ else
+ echo m88k-dg-dguxbcs${UNAME_RELEASE}
+ fi
else
- echo m88k-dg-dguxbcs${UNAME_RELEASE}
+ echo i586-dg-dgux${UNAME_RELEASE}
fi
- else echo i586-dg-dgux${UNAME_RELEASE}
- fi
- exit 0 ;;
+ exit ;;
M88*:DolphinOS:*:*) # DolphinOS (SVR3)
echo m88k-dolphin-sysv3
- exit 0 ;;
+ exit ;;
M88*:*:R3*:*)
# Delta 88k system running SVR3
- exit 0 ;;
+ exit ;;
XD88*:*:*:*) # Tektronix XD88 system running UTekV (SVR3)
echo m88k-tektronix-sysv3
- exit 0 ;;
+ exit ;;
Tek43[0-9][0-9]:UTek:*:*) # Tektronix 4300 system running UTek (BSD)
echo m68k-tektronix-bsd
- exit 0 ;;
+ exit ;;
*:IRIX*:*:*)
echo mips-sgi-irix`echo ${UNAME_RELEASE}|sed -e 's/-/_/g'`
- exit 0 ;;
+ exit ;;
????????:AIX?:[12].1:2) # AIX 2.2.1 or AIX 2.1.1 is RT/PC AIX.
- echo romp-ibm-aix # uname -m gives an 8 hex-code CPU id
- exit 0 ;; # Note that: echo "'`uname -s`'" gives 'AIX '
- i?86:AIX:*:*)
+ echo romp-ibm-aix # uname -m gives an 8 hex-code CPU id
+ exit ;; # Note that: echo "'`uname -s`'" gives 'AIX '
+ i*86:AIX:*:*)
echo i386-ibm-aix
- exit 0 ;;
+ exit ;;
+ ia64:AIX:*:*)
+ if [ -x /usr/bin/oslevel ] ; then
+ IBM_REV=`/usr/bin/oslevel`
+ else
+ IBM_REV=${UNAME_VERSION}.${UNAME_RELEASE}
+ fi
+ echo ${UNAME_MACHINE}-ibm-aix${IBM_REV}
+ exit ;;
*:AIX:2:3)
if grep bos325 /usr/include/stdio.h >/dev/null 2>&1; then
#include <sys/systemcfg.h>
main()
@@ -311,17 +515,21 @@
exit(0);
EOF
- ${CC-cc} dummy.c -o dummy && ./dummy && rm dummy.c dummy && exit 0
- echo rs6000-ibm-aix3.2.5
+ if $CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy`
+ then
+ echo "$SYSTEM_NAME"
+ else
+ echo rs6000-ibm-aix3.2.5
+ fi
elif grep bos324 /usr/include/stdio.h >/dev/null 2>&1; then
echo rs6000-ibm-aix3.2.4
else
fi
- exit 0 ;;
- *:AIX:*:4)
- if /usr/sbin/lsattr -EHl proc0 | grep POWER >/dev/null 2>&1; then
+ exit ;;
+ *:AIX:*:[45])
+ IBM_CPU_ID=`/usr/sbin/lsdev -C -c processor -S available | sed 1q | awk '{ print $1 }'`
+ if /usr/sbin/lsattr -El ${IBM_CPU_ID} | grep ' POWER' >/dev/null 2>&1; then
IBM_ARCH=rs6000
else
IBM_ARCH=powerpc
@@ -329,43 +537,120 @@
else
- IBM_REV=4.${UNAME_RELEASE}
fi
echo ${IBM_ARCH}-ibm-aix${IBM_REV}
- exit 0 ;;
+ exit ;;
*:AIX:*:*)
echo rs6000-ibm-aix
- exit 0 ;;
+ exit ;;
ibmrt:4.4BSD:*|romp-ibm:BSD:*)
echo romp-ibm-bsd4.4
- exit 0 ;;
- ibmrt:*BSD:*|romp-ibm:BSD:*) # covers RT/PC NetBSD and
+ exit ;;
+ ibmrt:*BSD:*|romp-ibm:BSD:*) # covers RT/PC BSD and
echo romp-ibm-bsd${UNAME_RELEASE} # 4.3 with uname added to
- exit 0 ;; # report: romp-ibm BSD 4.3
+ exit ;; # report: romp-ibm BSD 4.3
*:BOSX:*:*)
echo rs6000-bull-bosx
- exit 0 ;;
+ exit ;;
DPX/2?00:B.O.S.:*:*)
echo m68k-bull-sysv3
- exit 0 ;;
+ exit ;;
9000/[34]??:4.3bsd:1.*:*)
echo m68k-hp-bsd
- exit 0 ;;
+ exit ;;
hp300:4.4BSD:*:* | 9000/[34]??:4.3bsd:2.*:*)
echo m68k-hp-bsd4.4
- exit 0 ;;
- 9000/[3478]??:HP-UX:*:*)
+ exit ;;
+ 9000/[34678]??:HP-UX:*:*)
+ HPUX_REV=`echo ${UNAME_RELEASE}|sed -e 's/[^.]*.[0B]*//'`
case "${UNAME_MACHINE}" in
9000/31? ) HP_ARCH=m68000 ;;
9000/[34]?? ) HP_ARCH=m68k ;;
- 9000/7?? | 9000/8?[1679] ) HP_ARCH=hppa1.1 ;;
- 9000/8?? ) HP_ARCH=hppa1.0 ;;
+ 9000/[678][0-9][0-9])
+ if [ -x /usr/bin/getconf ]; then
+ sc_cpu_version=`/usr/bin/getconf SC_CPU_VERSION 2>/dev/null`
+ sc_kernel_bits=`/usr/bin/getconf SC_KERNEL_BITS 2>/dev/null`
+ case "${sc_cpu_version}" in
+ 523) HP_ARCH="hppa1.0" ;; # CPU_PA_RISC1_0
+ 528) HP_ARCH="hppa1.1" ;; # CPU_PA_RISC1_1
+ 532) # CPU_PA_RISC2_0
+ case "${sc_kernel_bits}" in
+ 32) HP_ARCH="hppa2.0n" ;;
+ 64) HP_ARCH="hppa2.0w" ;;
+ '') HP_ARCH="hppa2.0" ;; # HP-UX 10.20
+ esac ;;
+ esac
+ fi
+ if [ "${HP_ARCH}" = "" ]; then
+ #define _HPUX_SOURCE
+ #include <stdlib.h>
+ #include <unistd.h>
+ int main ()
+ #if defined(_SC_KERNEL_BITS)
+ long bits = sysconf(_SC_KERNEL_BITS);
+ #endif
+ long cpu = sysconf (_SC_CPU_VERSION);
+ switch (cpu)
+ case CPU_PA_RISC1_0: puts ("hppa1.0"); break;
+ case CPU_PA_RISC1_1: puts ("hppa1.1"); break;
+ case CPU_PA_RISC2_0:
+ switch (bits)
+ case 64: puts ("hppa2.0w"); break;
+ case 32: puts ("hppa2.0n"); break;
+ default: puts ("hppa2.0"); break;
+ } break;
+ #else /* !defined(_SC_KERNEL_BITS) */
+ puts ("hppa2.0"); break;
+ #endif
+ default: puts ("hppa1.0"); break;
+ exit (0);
+EOF
+ (CCOPTS= $CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null) && HP_ARCH=`$dummy`
+ test -z "$HP_ARCH" && HP_ARCH=hppa
+ fi ;;
esac
+ if [ ${HP_ARCH} = "hppa2.0w" ]
+ then
+ # hppa2.0w-hp-hpux* has a 64-bit kernel and a compiler generating
+ # 32-bit code. hppa64-hp-hpux* has the same kernel and a compiler
+ # generating 64-bit code. GNU and HP use different nomenclature:
+ # $ CC_FOR_BUILD=cc ./config.guess
+ # => hppa2.0w-hp-hpux11.23
+ # $ CC_FOR_BUILD="cc +DA2.0w" ./config.guess
+ # => hppa64-hp-hpux11.23
+ if echo __LP64__ | (CCOPTS= $CC_FOR_BUILD -E - 2>/dev/null) |
+ grep __LP64__ >/dev/null
+ then
+ HP_ARCH="hppa2.0w"
+ else
+ HP_ARCH="hppa64"
+ fi
+ fi
+ echo ${HP_ARCH}-hp-hpux${HPUX_REV}
+ exit ;;
+ ia64:HP-UX:*:*)
- echo ${HP_ARCH}-hp-hpux${HPUX_REV}
- exit 0 ;;
+ echo ia64-hp-hpux${HPUX_REV}
+ exit ;;
3050*:HI-UX:*:*)
#include <unistd.h>
int
main ()
@@ -390,324 +675,447 @@
exit (0);
EOF
+ $CC_FOR_BUILD -o $dummy $dummy.c && SYSTEM_NAME=`$dummy` &&
echo unknown-hitachi-hiuxwe2
- exit 0 ;;
+ exit ;;
9000/7??:4.3bsd:*:* | 9000/8?[79]:4.3bsd:*:* )
echo hppa1.1-hp-bsd
- exit 0 ;;
+ exit ;;
9000/8??:4.3bsd:*:*)
echo hppa1.0-hp-bsd
- exit 0 ;;
+ exit ;;
+ *9??*:MPE/iX:*:* | *3000*:MPE/iX:*:*)
+ echo hppa1.0-hp-mpeix
+ exit ;;
hp7??:OSF1:*:* | hp8?[79]:OSF1:*:* )
echo hppa1.1-hp-osf
- exit 0 ;;
+ exit ;;
hp8??:OSF1:*:*)
echo hppa1.0-hp-osf
- exit 0 ;;
- i?86:OSF1:*:*)
+ exit ;;
+ i*86:OSF1:*:*)
if [ -x /usr/sbin/sysversion ] ; then
echo ${UNAME_MACHINE}-unknown-osf1mk
else
fi
- exit 0 ;;
+ exit ;;
parisc*:Lites*:*:*)
echo hppa1.1-hp-lites
- exit 0 ;;
+ exit ;;
C1*:ConvexOS:*:* | convex:ConvexOS:C1*:*)
echo c1-convex-bsd
- exit 0 ;;
+ exit ;;
C2*:ConvexOS:*:* | convex:ConvexOS:C2*:*)
if getsysinfo -f scalar_acc
then echo c32-convex-bsd
else echo c2-convex-bsd
fi
- exit 0 ;;
+ exit ;;
C34*:ConvexOS:*:* | convex:ConvexOS:C34*:*)
echo c34-convex-bsd
- exit 0 ;;
+ exit ;;
C38*:ConvexOS:*:* | convex:ConvexOS:C38*:*)
echo c38-convex-bsd
- exit 0 ;;
+ exit ;;
C4*:ConvexOS:*:* | convex:ConvexOS:C4*:*)
echo c4-convex-bsd
- exit 0 ;;
- CRAY*X-MP:*:*:*)
- echo xmp-cray-unicos
- exit 0 ;;
+ exit ;;
CRAY*Y-MP:*:*:*)
- echo ymp-cray-unicos${UNAME_RELEASE}
- exit 0 ;;
+ echo ymp-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+ exit ;;
CRAY*[A-Z]90:*:*:*)
echo ${UNAME_MACHINE}-cray-unicos${UNAME_RELEASE} \
| sed -e 's/CRAY.*\([A-Z]90\)/\1/' \
- -e y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/
- exit 0 ;;
+ -e y/ABCDEFGHIJKLMNOPQRSTUVWXYZ/abcdefghijklmnopqrstuvwxyz/ \
+ -e 's/\.[^.]*$/.X/'
+ exit ;;
CRAY*TS:*:*:*)
- echo t90-cray-unicos${UNAME_RELEASE}
- exit 0 ;;
- CRAY-2:*:*:*)
- echo cray2-cray-unicos
- exit 0 ;;
- F300:UNIX_System_V:*:*)
- FUJITSU_SYS=`uname -p | tr [A-Z] [a-z] | sed -e 's/\///'`
+ echo t90-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+ exit ;;
+ CRAY*T3E:*:*:*)
+ echo alphaev5-cray-unicosmk${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+ exit ;;
+ CRAY*SV1:*:*:*)
+ echo sv1-cray-unicos${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+ exit ;;
+ *:UNICOS/mp:*:*)
+ echo craynv-cray-unicosmp${UNAME_RELEASE} | sed -e 's/\.[^.]*$/.X/'
+ exit ;;
+ F30[01]:UNIX_System_V:*:* | F700:UNIX_System_V:*:*)
+ FUJITSU_PROC=`uname -m | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz'`
+ FUJITSU_SYS=`uname -p | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/\///'`
FUJITSU_REL=`echo ${UNAME_RELEASE} | sed -e 's/ /_/'`
- echo "f300-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
- exit 0 ;;
- F301:UNIX_System_V:*:*)
- echo f301-fujitsu-uxpv`echo $UNAME_RELEASE | sed 's/ .*//'`
- exit 0 ;;
- hp3[0-9][05]:NetBSD:*:*)
- echo m68k-hp-netbsd${UNAME_RELEASE}
- exit 0 ;;
- hp300:OpenBSD:*:*)
- exit 0 ;;
- i?86:BSD/386:*:* | *:BSD/OS:*:*)
+ echo "${FUJITSU_PROC}-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
+ exit ;;
+ 5000:UNIX_System_V:4.*:*)
+ FUJITSU_REL=`echo ${UNAME_RELEASE} | tr 'ABCDEFGHIJKLMNOPQRSTUVWXYZ' 'abcdefghijklmnopqrstuvwxyz' | sed -e 's/ /_/'`
+ echo "sparc-fujitsu-${FUJITSU_SYS}${FUJITSU_REL}"
+ exit ;;
+ i*86:BSD/386:*:* | i*86:BSD/OS:*:* | *:Ascend\ Embedded/OS:*:*)
echo ${UNAME_MACHINE}-pc-bsdi${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
+ sparc*:BSD/OS:*:*)
+ echo sparc-unknown-bsdi${UNAME_RELEASE}
+ exit ;;
+ *:BSD/OS:*:*)
+ echo ${UNAME_MACHINE}-unknown-bsdi${UNAME_RELEASE}
+ exit ;;
*:FreeBSD:*:*)
echo ${UNAME_MACHINE}-unknown-freebsd`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
- exit 0 ;;
- *:NetBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-netbsd`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
- exit 0 ;;
- *:OpenBSD:*:*)
- echo ${UNAME_MACHINE}-unknown-openbsd`echo ${UNAME_RELEASE}|sed -e 's/[-_].*/\./'`
- exit 0 ;;
+ exit ;;
i*:CYGWIN*:*)
- echo i386-pc-cygwin32
- exit 0 ;;
+ echo ${UNAME_MACHINE}-pc-cygwin
+ exit ;;
i*:MINGW*:*)
- echo i386-pc-mingw32
- exit 0 ;;
+ echo ${UNAME_MACHINE}-pc-mingw32
+ exit ;;
+ i*:windows32*:*)
+ # uname -m includes "-pc" on this system.
+ echo ${UNAME_MACHINE}-mingw32
+ exit ;;
+ i*:PW*:*)
+ echo ${UNAME_MACHINE}-pc-pw32
+ exit ;;
+ x86:Interix*:[34]*)
+ echo i586-pc-interix${UNAME_RELEASE}|sed -e 's/\..*//'
+ exit ;;
+ [345]86:Windows_95:* | [345]86:Windows_98:* | [345]86:Windows_NT:*)
+ echo i${UNAME_MACHINE}-pc-mks
+ exit ;;
+ i*:Windows_NT*:* | Pentium*:Windows_NT*:*)
+ # It also conflicts with pre-2.0 versions of AT&T UWIN. Should we
+ # UNAME_MACHINE based on the output of uname instead of i386?
+ exit ;;
+ i*:UWIN*:*)
+ echo ${UNAME_MACHINE}-pc-uwin
+ exit ;;
+ amd64:CYGWIN*:*:* | x86_64:CYGWIN*:*:*)
+ echo x86_64-unknown-cygwin
+ exit ;;
p*:CYGWIN*:*)
- echo powerpcle-unknown-cygwin32
- exit 0 ;;
+ echo powerpcle-unknown-cygwin
+ exit ;;
prep*:SunOS:5.*:*)
echo powerpcle-unknown-solaris2`echo ${UNAME_RELEASE}|sed -e 's/[^.]*//'`
- exit 0 ;;
+ exit ;;
*:GNU:*:*)
+ # the GNU system
echo `echo ${UNAME_MACHINE}|sed -e 's,[-/].*$,,'`-unknown-gnu`echo ${UNAME_RELEASE}|sed -e 's,/.*$,,'`
- exit 0 ;;
- *:Linux:*:*)
+ exit ;;
+ *:GNU/*:*:*)
+ # other systems with GNU libc and userland
+ echo ${UNAME_MACHINE}-unknown-`echo ${UNAME_SYSTEM} | sed 's,^[^/]*/,,' | tr '[A-Z]' '[a-z]'``echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`-gnu
+ exit ;;
+ i*86:Minix:*:*)
+ echo ${UNAME_MACHINE}-pc-minix
+ exit ;;
+ arm*:Linux:*:*)
+ echo ${UNAME_MACHINE}-unknown-linux-gnu
+ exit ;;
+ cris:Linux:*:*)
+ echo cris-axis-linux-gnu
+ exit ;;
+ crisv32:Linux:*:*)
+ echo crisv32-axis-linux-gnu
+ exit ;;
+ frv:Linux:*:*)
+ echo frv-unknown-linux-gnu
+ exit ;;
+ ia64:Linux:*:*)
+ exit ;;
+ m32r*:Linux:*:*)
+ exit ;;
+ m68*:Linux:*:*)
+ exit ;;
+ mips:Linux:*:*)
+ #undef CPU
+ #undef mips
+ #undef mipsel
+ #if defined(__MIPSEL__) || defined(__MIPSEL) || defined(_MIPSEL) || defined(MIPSEL)
+ CPU=mipsel
+ #else
+ #if defined(__MIPSEB__) || defined(__MIPSEB) || defined(_MIPSEB) || defined(MIPSEB)
+ CPU=mips
+ #else
+ CPU=
+ #endif
+ #endif
+EOF
+ eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^CPU=`
+ test x"${CPU}" != x && { echo "${CPU}-unknown-linux-gnu"; exit; }
+ mips64:Linux:*:*)
+ #undef CPU
+ #undef mips64
+ #undef mips64el
+ CPU=mips64el
+ #else
+ CPU=mips64
+ #else
+ CPU=
+ #endif
+ #endif
+EOF
+ or32:Linux:*:*)
+ echo or32-unknown-linux-gnu
+ exit ;;
+ ppc:Linux:*:*)
+ echo powerpc-unknown-linux-gnu
+ exit ;;
+ ppc64:Linux:*:*)
+ echo powerpc64-unknown-linux-gnu
+ exit ;;
+ alpha:Linux:*:*)
+ case `sed -n '/^cpu model/s/^.*: \(.*\)/\1/p' < /proc/cpuinfo` in
+ EV5) UNAME_MACHINE=alphaev5 ;;
+ EV56) UNAME_MACHINE=alphaev56 ;;
+ PCA56) UNAME_MACHINE=alphapca56 ;;
+ PCA57) UNAME_MACHINE=alphapca56 ;;
+ EV6) UNAME_MACHINE=alphaev6 ;;
+ EV67) UNAME_MACHINE=alphaev67 ;;
+ EV68*) UNAME_MACHINE=alphaev68 ;;
+ esac
+ objdump --private-headers /bin/sh | grep ld.so.1 >/dev/null
+ if test "$?" = 0 ; then LIBC="libc1" ; else LIBC="" ; fi
+ echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC}
+ exit ;;
+ parisc:Linux:*:* | hppa:Linux:*:*)
+ # Look for CPU level
+ case `grep '^cpu[^a-z]*:' /proc/cpuinfo 2>/dev/null | cut -d' ' -f2` in
+ PA7*) echo hppa1.1-unknown-linux-gnu ;;
+ PA8*) echo hppa2.0-unknown-linux-gnu ;;
+ *) echo hppa-unknown-linux-gnu ;;
+ esac
+ exit ;;
+ parisc64:Linux:*:* | hppa64:Linux:*:*)
+ echo hppa64-unknown-linux-gnu
+ exit ;;
+ s390:Linux:*:* | s390x:Linux:*:*)
+ echo ${UNAME_MACHINE}-ibm-linux
+ exit ;;
+ sh64*:Linux:*:*)
+ exit ;;
+ sh*:Linux:*:*)
+ exit ;;
+ sparc:Linux:*:* | sparc64:Linux:*:*)
+ exit ;;
+ x86_64:Linux:*:*)
+ echo x86_64-unknown-linux-gnu
+ exit ;;
+ i*86:Linux:*:*)
# The BFD linker knows what the default object file format is, so
- # first see if it will tell us.
- ld_help_string=`ld --help 2>&1`
- ld_supported_emulations=`echo $ld_help_string \
- | sed -ne '/supported emulations:/!d
+ # first see if it will tell us. cd to the root directory to prevent
+ # problems with other programs or directories called `ld' in the path.
+ # Set LC_ALL=C to ensure ld outputs messages in English.
+ ld_supported_targets=`cd /; LC_ALL=C ld --help 2>&1 \
+ | sed -ne '/supported targets:/!d
s/[ ][ ]*/ /g
- s/.*supported emulations: *//
+ s/.*supported targets: *//
s/ .*//
p'`
- case "$ld_supported_emulations" in
- i?86linux) echo "${UNAME_MACHINE}-pc-linux-gnuaout" ; exit 0 ;;
- i?86coff) echo "${UNAME_MACHINE}-pc-linux-gnucoff" ; exit 0 ;;
- sparclinux) echo "${UNAME_MACHINE}-unknown-linux-gnuaout" ; exit 0 ;;
- m68klinux) echo "${UNAME_MACHINE}-unknown-linux-gnuaout" ; exit 0 ;;
- elf32ppc) echo "powerpc-unknown-linux-gnu" ; exit 0 ;;
+ case "$ld_supported_targets" in
+ elf32-i386)
+ TENTATIVE="${UNAME_MACHINE}-pc-linux-gnu"
+ a.out-i386-linux)
+ echo "${UNAME_MACHINE}-pc-linux-gnuaout"
+ exit ;;
+ coff-i386)
+ echo "${UNAME_MACHINE}-pc-linux-gnucoff"
+ exit ;;
+ # Either a pre-BFD a.out linker (linux-gnuoldld) or
+ # one that does not give us useful --help.
+ echo "${UNAME_MACHINE}-pc-linux-gnuoldld"
+ exit ;;
esac
- if test "${UNAME_MACHINE}" = "alpha" ; then
- sed 's/^ //' <<EOF >dummy.s
- .globl main
- .ent main
- main:
- .prologue 0
- lda \$2,259
- srl \$1,8,\$2
- sll \$2,2,\$2
- sll \$0,3,\$0
- addl \$1,\$0,\$0
- addl \$2,\$0,\$0
- ret \$31,(\$26),1
- .end main
+ # Determine whether the default compiler is a.out or elf
+ #include <features.h>
+ #ifdef __ELF__
+ # ifdef __GLIBC__
+ # if __GLIBC__ >= 2
+ LIBC=gnu
+ # else
+ LIBC=gnulibc1
+ # endif
+ # else
+ LIBC=gnulibc1
+ # endif
+ #else
+ #ifdef __INTEL_COMPILER
+ LIBC=gnu
+ #else
+ LIBC=gnuaout
+ #endif
+ #endif
+ #ifdef __dietlibc__
+ LIBC=dietlibc
+ #endif
EOF
- LIBC=""
- ./dummy
- case "$?" in
- 7)
- 15)
- 14)
- 10)
- 16)
- esac
- objdump --private-headers dummy | \
- grep ld.so.1 > /dev/null
- LIBC="libc1"
- fi
- fi
- echo ${UNAME_MACHINE}-unknown-linux-gnu${LIBC} ; exit 0
- elif test "${UNAME_MACHINE}" = "mips" ; then
- cat >dummy.c <<EOF
-main(argc, argv)
- int argc;
- char *argv[];
-#ifdef __MIPSEB__
- printf ("%s-unknown-linux-gnu\n", argv[1]);
-#endif
-#ifdef __MIPSEL__
- printf ("%sel-unknown-linux-gnu\n", argv[1]);
-#endif
- return 0;
-EOF
- ${CC-cc} dummy.c -o dummy 2>/dev/null && ./dummy "${UNAME_MACHINE}" && rm dummy.c dummy && exit 0
- else
- # Either a pre-BFD a.out linker (linux-gnuoldld)
- # or one that does not give us useful --help.
- # GCC wants to distinguish between linux-gnuoldld and linux-gnuaout.
- # If ld does not provide *any* "supported emulations:"
- # that means it is gnuoldld.
- echo "$ld_help_string" | grep >/dev/null 2>&1 "supported emulations:"
- test $? != 0 && echo "${UNAME_MACHINE}-pc-linux-gnuoldld" && exit 0
- case "${UNAME_MACHINE}" in
- i?86)
- VENDOR=pc;
- VENDOR=unknown;
- esac
- # Determine whether the default compiler is a.out or elf
-#include <features.h>
-main(argc, argv)
- int argc;
- char *argv[];
-#ifdef __ELF__
-# ifdef __GLIBC__
-# if __GLIBC__ >= 2
- printf ("%s-${VENDOR}-linux-gnu\n", argv[1]);
-# else
- printf ("%s-${VENDOR}-linux-gnulibc1\n", argv[1]);
-# endif
-# else
-# endif
-#else
- printf ("%s-${VENDOR}-linux-gnuaout\n", argv[1]);
-#endif
- return 0;
-EOF
- fi ;;
-# ptx 4.0 does uname -s correctly, with DYNIX/ptx in there. earlier versions
-# are messed up and put the nodename in both sysname and nodename.
- i?86:DYNIX/ptx:4*:*)
+ eval `$CC_FOR_BUILD -E $dummy.c 2>/dev/null | grep ^LIBC=`
+ test x"${LIBC}" != x && {
+ echo "${UNAME_MACHINE}-pc-linux-${LIBC}"
+ exit
+ test x"${TENTATIVE}" != x && { echo "${TENTATIVE}"; exit; }
+ i*86:DYNIX/ptx:4*:*)
+ # ptx 4.0 does uname -s correctly, with DYNIX/ptx in there.
+ # earlier versions are messed up and put the nodename in both
+ # sysname and nodename.
echo i386-sequent-sysv4
- exit 0 ;;
- i?86:UNIX_SV:4.2MP:2.*)
+ exit ;;
+ i*86:UNIX_SV:4.2MP:2.*)
# Unixware is an offshoot of SVR4, but it has its own version
# number series starting with 2...
# I am not positive that other SVR4 systems won't match this,
# I just have to hope. -- rms.
# Use sysv4.2uw... so that sysv4* matches it.
echo ${UNAME_MACHINE}-pc-sysv4.2uw${UNAME_VERSION}
- exit 0 ;;
- i?86:*:4.*:* | i?86:SYSTEM_V:4.*:*)
+ exit ;;
+ i*86:OS/2:*:*)
+ # If we were able to find `uname', then EMX Unix compatibility
+ # is probably installed.
+ echo ${UNAME_MACHINE}-pc-os2-emx
+ exit ;;
+ i*86:XTS-300:*:STOP)
+ echo ${UNAME_MACHINE}-unknown-stop
+ exit ;;
+ i*86:atheos:*:*)
+ echo ${UNAME_MACHINE}-unknown-atheos
+ exit ;;
+ i*86:syllable:*:*)
+ echo ${UNAME_MACHINE}-pc-syllable
+ exit ;;
+ i*86:LynxOS:2.*:* | i*86:LynxOS:3.[01]*:* | i*86:LynxOS:4.0*:*)
+ echo i386-unknown-lynxos${UNAME_RELEASE}
+ exit ;;
+ i*86:*DOS:*:*)
+ echo ${UNAME_MACHINE}-pc-msdosdjgpp
+ exit ;;
+ i*86:*:4.*:* | i*86:SYSTEM_V:4.*:*)
+ UNAME_REL=`echo ${UNAME_RELEASE} | sed 's/\/MP$//'`
if grep Novell /usr/include/link.h >/dev/null 2>/dev/null; then
- echo ${UNAME_MACHINE}-univel-sysv${UNAME_RELEASE}
+ echo ${UNAME_MACHINE}-univel-sysv${UNAME_REL}
else
- echo ${UNAME_MACHINE}-pc-sysv${UNAME_RELEASE}
+ echo ${UNAME_MACHINE}-pc-sysv${UNAME_REL}
fi
- exit 0 ;;
- i?86:*:3.2:*)
+ exit ;;
+ i*86:*:5:[678]*)
+ # UnixWare 7.x, OpenUNIX and OpenServer 6.
+ case `/bin/uname -X | grep "^Machine"` in
+ *486*) UNAME_MACHINE=i486 ;;
+ *Pentium) UNAME_MACHINE=i586 ;;
+ *Pent*|*Celeron) UNAME_MACHINE=i686 ;;
+ esac
+ echo ${UNAME_MACHINE}-unknown-sysv${UNAME_RELEASE}${UNAME_SYSTEM}${UNAME_VERSION}
+ exit ;;
+ i*86:*:3.2:*)
if test -f /usr/options/cb.name; then
UNAME_REL=`sed -n 's/.*Version //p' </usr/options/cb.name`
echo ${UNAME_MACHINE}-pc-isc$UNAME_REL
elif /bin/uname -X 2>/dev/null >/dev/null ; then
- UNAME_REL=`(/bin/uname -X|egrep Release|sed -e 's/.*= //')`
- (/bin/uname -X|egrep i80486 >/dev/null) && UNAME_MACHINE=i486
- (/bin/uname -X|egrep '^Machine.*Pentium' >/dev/null) \
+ UNAME_REL=`(/bin/uname -X|grep Release|sed -e 's/.*= //')`
+ (/bin/uname -X|grep i80486 >/dev/null) && UNAME_MACHINE=i486
+ (/bin/uname -X|grep '^Machine.*Pentium' >/dev/null) \
&& UNAME_MACHINE=i586
+ (/bin/uname -X|grep '^Machine.*Pent *II' >/dev/null) \
+ && UNAME_MACHINE=i686
+ (/bin/uname -X|grep '^Machine.*Pentium Pro' >/dev/null) \
echo ${UNAME_MACHINE}-pc-sco$UNAME_REL
else
echo ${UNAME_MACHINE}-pc-sysv32
fi
- exit 0 ;;
+ exit ;;
pc:*:*:*)
+ # Left here for compatibility:
# uname -m prints for DJGPP always 'pc', but it prints nothing about
# the processor, so we play safe by assuming i386.
echo i386-pc-msdosdjgpp
- exit 0 ;;
+ exit ;;
Intel:Mach:3*:*)
echo i386-pc-mach3
- exit 0 ;;
+ exit ;;
paragon:*:*:*)
echo i860-intel-osf1
- exit 0 ;;
+ exit ;;
i860:*:4.*:*) # i860-SVR4
if grep Stardent /usr/include/sys/uadmin.h >/dev/null 2>&1 ; then
echo i860-stardent-sysv${UNAME_RELEASE} # Stardent Vistra i860-SVR4
else # Add other i860-SVR4 vendors below as they are discovered.
echo i860-unknown-sysv${UNAME_RELEASE} # Unknown i860-SVR4
fi
- exit 0 ;;
+ exit ;;
mini*:CTIX:SYS*5:*)
# "miniframe"
echo m68010-convergent-sysv
- exit 0 ;;
- M68*:*:R3V[567]*:*)
- test -r /sysV68 && echo 'm68k-motorola-sysv' && exit 0 ;;
- 3[34]??:*:4.0:3.0 | 3[34]??,*:*:4.0:3.0 | 4850:*:4.0:3.0)
+ exit ;;
+ mc68k:UNIX:SYSTEM5:3.51m)
+ echo m68k-convergent-sysv
+ exit ;;
+ M680?0:D-NIX:5.3:*)
+ echo m68k-diab-dnix
+ exit ;;
+ M68*:*:R3V[5678]*:*)
+ test -r /sysV68 && { echo 'm68k-motorola-sysv'; exit; } ;;
+ 3[345]??:*:4.0:3.0 | 3[34]??A:*:4.0:3.0 | 3[34]??,*:*:4.0:3.0 | 3[34]??/*:*:4.0:3.0 | 4400:*:4.0:3.0 | 4850:*:4.0:3.0 | SKA40:*:4.0:3.0 | SDS2:*:4.0:3.0 | SHG2:*:4.0:3.0 | S7501*:*:4.0:3.0)
OS_REL=''
test -r /etc/.relid \
&& OS_REL=.`sed -n 's/[^ ]* [^ ]* \([0-9][0-9]\).*/\1/p' < /etc/.relid`
/bin/uname -p 2>/dev/null | grep 86 >/dev/null \
- && echo i486-ncr-sysv4.3${OS_REL} && exit 0
+ && { echo i486-ncr-sysv4.3${OS_REL}; exit; }
/bin/uname -p 2>/dev/null | /bin/grep entium >/dev/null \
- && echo i586-ncr-sysv4.3${OS_REL} && exit 0 ;;
+ && { echo i586-ncr-sysv4.3${OS_REL}; exit; } ;;
3[34]??:*:4.0:* | 3[34]??,*:*:4.0:*)
- && echo i486-ncr-sysv4 && exit 0 ;;
- m68*:LynxOS:2.*:*)
+ && { echo i486-ncr-sysv4; exit; } ;;
+ m68*:LynxOS:2.*:* | m68*:LynxOS:3.0*:*)
echo m68k-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
mc68030:UNIX_System_V:4.*:*)
echo m68k-atari-sysv4
- exit 0 ;;
- i?86:LynxOS:2.*:*)
- echo i386-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
TSUNAMI:LynxOS:2.*:*)
echo sparc-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
- rs6000:LynxOS:2.*:* | PowerPC:LynxOS:2.*:*)
+ exit ;;
+ rs6000:LynxOS:2.*:*)
echo rs6000-unknown-lynxos${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
+ PowerPC:LynxOS:2.*:* | PowerPC:LynxOS:3.[01]*:* | PowerPC:LynxOS:4.0*:*)
+ echo powerpc-unknown-lynxos${UNAME_RELEASE}
+ exit ;;
SM[BE]S:UNIX_SV:*:*)
echo mips-dde-sysv${UNAME_RELEASE}
- exit 0 ;;
+ exit ;;
+ RM*:ReliantUNIX-*:*:*)
+ echo mips-sni-sysv4
+ exit ;;
RM*:SINIX-*:*:*)
echo mips-sni-sysv4
- exit 0 ;;
+ exit ;;
*:SINIX-*:*:*)
if uname -p 2>/dev/null >/dev/null ; then
UNAME_MACHINE=`(uname -p) 2>/dev/null`
@@ -715,39 +1123,153 @@
else
echo ns32k-sni-sysv
fi
- exit 0 ;;
- PENTIUM:CPunix:4.0*:*) # Unisys `ClearPath HMP IX 4000' SVR4/MP effort
- # says <Richard.M.Bartel at ccMail.Census.GOV>
+ exit ;;
+ PENTIUM:*:4.0*:*) # Unisys `ClearPath HMP IX 4000' SVR4/MP effort
+ # says <Richard.M.Bartel at ccMail.Census.GOV>
echo i586-unisys-sysv4
- exit 0 ;;
+ exit ;;
*:UNIX_System_V:4*:FTX*)
# From Gerald Hewes <hewes at openmarket.com>.
# How about differentiating between stratus architectures? -djm
echo hppa1.1-stratus-sysv4
- exit 0 ;;
+ exit ;;
*:*:*:FTX*)
# From seanf at swdc.stratus.com.
echo i860-stratus-sysv4
- exit 0 ;;
+ exit ;;
+ i*86:VOS:*:*)
+ # From Paul.Green at stratus.com.
+ echo ${UNAME_MACHINE}-stratus-vos
+ exit ;;
+ *:VOS:*:*)
+ echo hppa1.1-stratus-vos
+ exit ;;
mc68*:A/UX:*:*)
echo m68k-apple-aux${UNAME_RELEASE}
- exit 0 ;;
- news*:NEWS-OS:*:6*)
+ exit ;;
+ news*:NEWS-OS:6*:*)
echo mips-sony-newsos6
- exit 0 ;;
- R3000:*System_V*:*:* | R4000:UNIX_SYSV:*:*)
+ exit ;;
+ R[34]000:*System_V*:*:* | R4000:UNIX_SYSV:*:* | R*000:UNIX_SV:*:*)
if [ -d /usr/nec ]; then
echo mips-nec-sysv${UNAME_RELEASE}
else
echo mips-unknown-sysv${UNAME_RELEASE}
fi
- exit 0 ;;
+ exit ;;
+ BeBox:BeOS:*:*) # BeOS running on hardware made by Be, PPC only.
+ echo powerpc-be-beos
+ exit ;;
+ BeMac:BeOS:*:*) # BeOS running on Mac or Mac clone, PPC only.
+ echo powerpc-apple-beos
+ exit ;;
+ BePC:BeOS:*:*) # BeOS running on Intel PC compatible.
+ echo i586-pc-beos
+ exit ;;
+ SX-4:SUPER-UX:*:*)
+ echo sx4-nec-superux${UNAME_RELEASE}
+ exit ;;
+ SX-5:SUPER-UX:*:*)
+ echo sx5-nec-superux${UNAME_RELEASE}
+ exit ;;
+ SX-6:SUPER-UX:*:*)
+ echo sx6-nec-superux${UNAME_RELEASE}
+ exit ;;
+ Power*:Rhapsody:*:*)
+ echo powerpc-apple-rhapsody${UNAME_RELEASE}
+ exit ;;
+ *:Rhapsody:*:*)
+ echo ${UNAME_MACHINE}-apple-rhapsody${UNAME_RELEASE}
+ exit ;;
+ *:Darwin:*:*)
+ UNAME_PROCESSOR=`uname -p` || UNAME_PROCESSOR=unknown
+ case $UNAME_PROCESSOR in
+ unknown) UNAME_PROCESSOR=powerpc ;;
+ esac
+ echo ${UNAME_PROCESSOR}-apple-darwin${UNAME_RELEASE}
+ exit ;;
+ *:procnto*:*:* | *:QNX:[0123456789]*:*)
+ if test "$UNAME_PROCESSOR" = "x86"; then
+ UNAME_PROCESSOR=i386
+ UNAME_MACHINE=pc
+ fi
+ echo ${UNAME_PROCESSOR}-${UNAME_MACHINE}-nto-qnx${UNAME_RELEASE}
+ exit ;;
+ *:QNX:*:4*)
+ echo i386-pc-qnx
+ exit ;;
+ NSE-?:NONSTOP_KERNEL:*:*)
+ echo nse-tandem-nsk${UNAME_RELEASE}
+ exit ;;
+ NSR-?:NONSTOP_KERNEL:*:*)
+ echo nsr-tandem-nsk${UNAME_RELEASE}
+ exit ;;
+ *:NonStop-UX:*:*)
+ echo mips-compaq-nonstopux
+ exit ;;
+ BS2000:POSIX*:*:*)
+ echo bs2000-siemens-sysv
+ exit ;;
+ DS/*:UNIX_System_V:*:*)
+ echo ${UNAME_MACHINE}-${UNAME_SYSTEM}-${UNAME_RELEASE}
+ exit ;;
+ *:Plan9:*:*)
+ # "uname -m" is not consistent, so use $cputype instead. 386
+ # is converted to i386 for consistency with other x86
+ # operating systems.
+ if test "$cputype" = "386"; then
+ UNAME_MACHINE=i386
+ else
+ UNAME_MACHINE="$cputype"
+ fi
+ echo ${UNAME_MACHINE}-unknown-plan9
+ exit ;;
+ *:TOPS-10:*:*)
+ echo pdp10-unknown-tops10
+ exit ;;
+ *:TENEX:*:*)
+ echo pdp10-unknown-tenex
+ exit ;;
+ KS10:TOPS-20:*:* | KL10:TOPS-20:*:* | TYPE4:TOPS-20:*:*)
+ echo pdp10-dec-tops20
+ exit ;;
+ XKL-1:TOPS-20:*:* | TYPE5:TOPS-20:*:*)
+ echo pdp10-xkl-tops20
+ exit ;;
+ *:TOPS-20:*:*)
+ echo pdp10-unknown-tops20
+ exit ;;
+ *:ITS:*:*)
+ echo pdp10-unknown-its
+ exit ;;
+ SEI:*:*:SEIUX)
+ echo mips-sei-seiux${UNAME_RELEASE}
+ exit ;;
+ *:DragonFly:*:*)
+ echo ${UNAME_MACHINE}-unknown-dragonfly`echo ${UNAME_RELEASE}|sed -e 's/[-(].*//'`
+ exit ;;
+ *:*VMS:*:*)
+ UNAME_MACHINE=`(uname -p) 2>/dev/null`
+ case "${UNAME_MACHINE}" in
+ A*) echo alpha-dec-vms ; exit ;;
+ I*) echo ia64-dec-vms ; exit ;;
+ V*) echo vax-dec-vms ; exit ;;
+ esac ;;
+ *:XENIX:*:SysV)
+ echo i386-pc-xenix
+ exit ;;
+ i*86:skyos:*:*)
+ echo ${UNAME_MACHINE}-pc-skyos`echo ${UNAME_RELEASE}` | sed -e 's/ .*$//'
+ exit ;;
esac
#echo '(No uname command or uname output not recognized.)' 1>&2
#echo "${UNAME_MACHINE}:${UNAME_SYSTEM}:${UNAME_RELEASE}:${UNAME_VERSION}" 1>&2
-cat >dummy.c <<EOF
+eval $set_cc_for_build
+cat >$dummy.c <<EOF
#ifdef _SEQUENT_
# include <sys/types.h>
# include <sys/utsname.h>
@@ -772,7 +1294,7 @@
#endif
#if defined (__arm) && defined (__acorn) && defined (__unix)
- printf ("arm-acorn-riscix"); exit (0);
+ printf ("arm-acorn-riscix\n"); exit (0);
#endif
#if defined (hp300) && !defined (hpux)
@@ -785,7 +1307,10 @@
#endif
int version;
version=`(hostinfo | sed -n 's/.*NeXT Mach \([0-9]*\).*/\1/p') 2>/dev/null`;
- printf ("%s-next-nextstep%d\n", __ARCHITECTURE__, version);
+ if (version < 4)
+ printf ("%s-next-nextstep%d\n", __ARCHITECTURE__, version);
+ else
+ printf ("%s-next-openstep%d\n", __ARCHITECTURE__, version);
exit (0);
#endif
@@ -830,12 +1355,25 @@
#endif
#if defined (vax)
-#if !defined (ultrix)
- printf ("vax-dec-bsd\n"); exit (0);
-#else
- printf ("vax-dec-ultrix\n"); exit (0);
+# if !defined (ultrix)
+# include <sys/param.h>
+# if defined (BSD)
+# if BSD == 43
+ printf ("vax-dec-bsd4.3\n"); exit (0);
+# else
+# if BSD == 199006
+ printf ("vax-dec-bsd4.3reno\n"); exit (0);
+# else
+ printf ("vax-dec-bsd\n"); exit (0);
+# endif
+# endif
+# else
+# endif
+# else
+ printf ("vax-dec-ultrix\n"); exit (0);
+# endif
#endif
-#endif
#if defined (alliant) && defined (i860)
printf ("i860-alliant-bsd\n"); exit (0);
@@ -845,12 +1383,12 @@
EOF
-${CC-cc} dummy.c -o dummy 2>/dev/null && ./dummy && rm dummy.c dummy && exit 0
-rm -f dummy.c dummy
+$CC_FOR_BUILD -o $dummy $dummy.c 2>/dev/null && SYSTEM_NAME=`$dummy` &&
# Apollos put the system type in the environment.
-test -d /usr/apollo && { echo ${ISP}-apollo-${SYSTYPE}; exit 0; }
+test -d /usr/apollo && { echo ${ISP}-apollo-${SYSTYPE}; exit; }
# Convex versions that predate uname can use getsysinfo(1)
@@ -859,25 +1397,70 @@
case `getsysinfo -f cpu_type` in
c1*)
echo c1-convex-bsd
- exit 0 ;;
+ exit ;;
c2*)
fi
- exit 0 ;;
+ exit ;;
c34*)
echo c34-convex-bsd
- exit 0 ;;
+ exit ;;
c38*)
echo c38-convex-bsd
- exit 0 ;;
+ exit ;;
c4*)
echo c4-convex-bsd
- exit 0 ;;
+ exit ;;
esac
fi
-#echo '(Unable to guess system type)' 1>&2
+cat >&2 <<EOF
+$0: unable to guess system type
+This script, last modified $timestamp, has failed to recognize
+the operating system you are using. It is advised that you
+download the most up to date version of the config scripts from
+ http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.guess
+and
+ http://savannah.gnu.org/cgi-bin/viewcvs/*checkout*/config/config/config.sub
+If the version you run ($0) is already up to date, please
+send the following data and any information you think might be
+pertinent to <config-patches at gnu.org> in order to provide the needed
+information to handle your system.
+config.guess timestamp = $timestamp
+uname -m = `(uname -m) 2>/dev/null || echo unknown`
+uname -r = `(uname -r) 2>/dev/null || echo unknown`
+uname -s = `(uname -s) 2>/dev/null || echo unknown`
+uname -v = `(uname -v) 2>/dev/null || echo unknown`
+/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null`
+/bin/uname -X = `(/bin/uname -X) 2>/dev/null`
+hostinfo = `(hostinfo) 2>/dev/null`
+/bin/universe = `(/bin/universe) 2>/dev/null`
+/usr/bin/arch -k = `(/usr/bin/arch -k) 2>/dev/null`
+/bin/arch = `(/bin/arch) 2>/dev/null`
+/usr/bin/oslevel = `(/usr/bin/oslevel) 2>/dev/null`
+/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null`
+UNAME_MACHINE = ${UNAME_MACHINE}
+UNAME_RELEASE = ${UNAME_RELEASE}
+UNAME_SYSTEM = ${UNAME_SYSTEM}
+UNAME_VERSION = ${UNAME_VERSION}
+EOF
exit 1
+# Local variables:
+# eval: (add-hook 'write-file-hooks 'time-stamp)
+# time-stamp-start: "timestamp='"
+# time-stamp-format: "%:y-%02m-%02d"
+# time-stamp-end: "'"
+# End:
Modified: trunk/MgDev/Oem/gd/jpeg/config.sub
--- trunk/MgDev/Oem/gd/jpeg/config.sub 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Oem/gd/jpeg/config.sub 2013-02-15 12:16:10 UTC (rev 7356)
@@ -1,6 +1,10 @@
#! /bin/sh
-# Configuration validation subroutine script, version 1.1.
-# Copyright (C) 1991, 92, 93, 94, 95, 96, 1997 Free Software Foundation, Inc.
+# Configuration validation subroutine script.
+timestamp='2005-07-08'
# This file is (in principle) common to ALL GNU software.
# The presence of a machine in this file suggests that SOME GNU software
# can handle that machine. It does not imply ALL GNU software can.
@@ -17,14 +21,18 @@
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
-# Boston, MA 02111-1307, USA.
+# 02110-1301, USA.
# As a special exception to the GNU General Public License, if you
# distribute this file as part of a program that contains a
# configuration script generated by Autoconf, you may include it under
# the same distribution terms that you use for the rest of that program.
# Configuration subroutine to validate and canonicalize a configuration type.
# Supply the specified configuration type as an argument.
# If it is invalid, we print an error message on stderr and exit with code 1.
@@ -45,30 +53,74 @@
# CPU_TYPE-MANUFACTURER-KERNEL-OPERATING_SYSTEM
# It is wrong to echo any other type of specification.
-if [ x$1 = x ]
-then
- echo Configuration name missing. 1>&2
- echo "Usage: $0 CPU-MFR-OPSYS" 1>&2
- echo "or $0 ALIAS" 1>&2
- echo where ALIAS is a recognized configuration type. 1>&2
- exit 1
-fi
-# First pass through any local machine types.
-case $1 in
- *local*)
- echo $1
- exit 0
+usage="\
+Usage: $0 [OPTION] CPU-MFR-OPSYS
+ $0 [OPTION] ALIAS
+Canonicalize a configuration name.
+Operation modes:
+version="\
+GNU config.sub ($timestamp)
+help="
+ case $1 in
+ --version | -v )
+ shift; break ;;
+ break ;;
+ exit 1 ;;
+ *local*)
+ # First pass through any local machine types.
+ echo $1
+ exit ;;
+ break ;;
+ esac
+done
+case $# in
+ 0) echo "$me: missing argument$help" >&2
+ exit 1;;
+ 1) ;;
+ *) echo "$me: too many arguments$help" >&2
+ exit 1;;
esac
# Separate what the user gave into CPU-COMPANY and OS or KERNEL-OS (if any).
# Here we must recognize all the valid KERNEL-OS combinations.
maybe_os=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\2/'`
case $maybe_os in
- linux-gnu*)
+ nto-qnx* | linux-gnu* | linux-dietlibc | linux-uclibc* | uclinux-uclibc* | uclinux-gnu* | \
+ kfreebsd*-gnu* | knetbsd*-gnu* | netbsd*-gnu* | storm-chaos* | os2-emx* | rtmk-nova*)
os=-$maybe_os
basic_machine=`echo $1 | sed 's/^\(.*\)-\([^-]*-[^-]*\)$/\1/'`
@@ -94,15 +146,33 @@
-convergent* | -ncr* | -news | -32* | -3600* | -3100* | -hitachi* |\
-c[123]* | -convex* | -sun | -crds | -omron* | -dg | -ultra | -tti* | \
-harris | -dolphin | -highlevel | -gould | -cbm | -ns | -masscomp | \
- -apple)
+ -apple | -axis | -knuth | -cray)
os=
basic_machine=$1
+ -sim | -cisco | -oki | -wec | -winbond)
+ os=
+ basic_machine=$1
+ -scout)
+ -wrs)
+ os=-vxworks
+ basic_machine=$1
+ -chorusos*)
+ os=-chorusos
+ basic_machine=$1
+ -chorusrdb)
+ os=-chorusrdb
+ basic_machine=$1
-hiux*)
os=-hiuxwe2
-sco5)
- os=sco3.2v5
+ os=-sco3.2v5
basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
-sco4)
@@ -121,6 +191,9 @@
os=-sco3.2v2
+ -udk*)
+ basic_machine=`echo $1 | sed -e 's/86-.*/86-pc/'`
-isc)
os=-isc2.2
@@ -143,26 +216,81 @@
-psos*)
os=-psos
+ -mint | -mint[0-9]*)
+ basic_machine=m68k-atari
+ os=-mint
esac
# Decode aliases for certain CPU-COMPANY combinations.
case $basic_machine in
# Recognize the basic CPU types without company name.
# Some are omitted here because they have special meanings below.
- tahoe | i860 | m32r | m68k | m68000 | m88k | ns32k | arc | arm \
- | arme[lb] | pyramid | mn10200 | mn10300 \
- | tron | a29k | 580 | i960 | h8300 | hppa | hppa1.0 | hppa1.1 \
- | alpha | alphaev5 | alphaev56 | we32k | ns16k | clipper \
- | i370 | sh | powerpc | powerpcle | 1750a | dsp16xx | pdp11 \
- | mips64 | mipsel | mips64el | mips64orion | mips64orionel \
- | mipstx39 | mipstx39el \
- | sparc | sparclet | sparclite | sparc64 | v850)
+ 1750a | 580 \
+ | a29k \
+ | alpha | alphaev[4-8] | alphaev56 | alphaev6[78] | alphapca5[67] \
+ | alpha64 | alpha64ev[4-8] | alpha64ev56 | alpha64ev6[78] | alpha64pca5[67] \
+ | am33_2.0 \
+ | arc | arm | arm[bl]e | arme[lb] | armv[2345] | armv[345][lb] | avr \
+ | bfin \
+ | c4x | clipper \
+ | d10v | d30v | dlx | dsp16xx \
+ | fr30 | frv \
+ | h8300 | h8500 | hppa | hppa1.[01] | hppa2.0 | hppa2.0[nw] | hppa64 \
+ | i370 | i860 | i960 | ia64 \
+ | ip2k | iq2000 \
+ | m32r | m32rle | m68000 | m68k | m88k | maxq | mcore \
+ | mips | mipsbe | mipseb | mipsel | mipsle \
+ | mips16 \
+ | mips64 | mips64el \
+ | mips64vr | mips64vrel \
+ | mips64orion | mips64orionel \
+ | mips64vr4100 | mips64vr4100el \
+ | mips64vr4300 | mips64vr4300el \
+ | mips64vr5000 | mips64vr5000el \
+ | mips64vr5900 | mips64vr5900el \
+ | mipsisa32 | mipsisa32el \
+ | mipsisa32r2 | mipsisa32r2el \
+ | mipsisa64 | mipsisa64el \
+ | mipsisa64r2 | mipsisa64r2el \
+ | mipsisa64sb1 | mipsisa64sb1el \
+ | mipsisa64sr71k | mipsisa64sr71kel \
+ | mipstx39 | mipstx39el \
+ | mn10200 | mn10300 \
+ | ms1 \
+ | msp430 \
+ | ns16k | ns32k \
+ | or32 \
+ | pdp10 | pdp11 | pj | pjl \
+ | powerpc | powerpc64 | powerpc64le | powerpcle | ppcbe \
+ | pyramid \
+ | sh | sh[1234] | sh[24]a | sh[23]e | sh[34]eb | shbe | shle | sh[1234]le | sh3ele \
+ | sh64 | sh64le \
+ | sparc | sparc64 | sparc64b | sparc86x | sparclet | sparclite \
+ | sparcv8 | sparcv9 | sparcv9b \
+ | strongarm \
+ | tahoe | thumb | tic4x | tic80 | tron \
+ | v850 | v850e \
+ | we32k \
+ | x86 | xscale | xscalee[bl] | xstormy16 | xtensa \
+ | z8k)
basic_machine=$basic_machine-unknown
+ m32c)
+ basic_machine=$basic_machine-unknown
+ m6811 | m68hc11 | m6812 | m68hc12)
+ # Motorola 68HC11/12.
+ os=-none
+ m88110 | m680[12346]0 | m683?2 | m68360 | m5200 | v70 | w65 | z8k)
# We use `pc' rather than `unknown'
# because (1) that's what they normally are, and
# (2) the word "unknown" tends to confuse beginning users.
- i[3456]86)
+ i*86 | x86_64)
basic_machine=$basic_machine-pc
# Object if more than one company name word.
@@ -171,27 +299,91 @@
exit 1
# Recognize the basic CPU types with company name.
- vax-* | tahoe-* | i[3456]86-* | i860-* | m32r-* | m68k-* | m68000-* \
- | m88k-* | sparc-* | ns32k-* | fx80-* | arc-* | arm-* | c[123]* \
- | mips-* | pyramid-* | tron-* | a29k-* | romp-* | rs6000-* \
- | power-* | none-* | 580-* | cray2-* | h8300-* | i960-* \
- | xmp-* | ymp-* | hppa-* | hppa1.0-* | hppa1.1-* \
- | alpha-* | alphaev5-* | alphaev56-* | we32k-* | cydra-* \
- | ns16k-* | pn-* | np1-* | xps100-* | clipper-* | orion-* \
- | sparclite-* | pdp11-* | sh-* | powerpc-* | powerpcle-* \
- | sparc64-* | mips64-* | mipsel-* \
- | mips64el-* | mips64orion-* | mips64orionel-* \
- | mipstx39-* | mipstx39el-* \
- | f301-*)
+ 580-* \
+ | a29k-* \
+ | alpha-* | alphaev[4-8]-* | alphaev56-* | alphaev6[78]-* \
+ | alpha64-* | alpha64ev[4-8]-* | alpha64ev56-* | alpha64ev6[78]-* \
+ | alphapca5[67]-* | alpha64pca5[67]-* | arc-* \
+ | arm-* | armbe-* | armle-* | armeb-* | armv*-* \
+ | avr-* \
+ | bfin-* | bs2000-* \
+ | c[123]* | c30-* | [cjt]90-* | c4x-* | c54x-* | c55x-* | c6x-* \
+ | clipper-* | craynv-* | cydra-* \
+ | d10v-* | d30v-* | dlx-* \
+ | elxsi-* \
+ | f30[01]-* | f700-* | fr30-* | frv-* | fx80-* \
+ | h8300-* | h8500-* \
+ | hppa-* | hppa1.[01]-* | hppa2.0-* | hppa2.0[nw]-* | hppa64-* \
+ | i*86-* | i860-* | i960-* | ia64-* \
+ | ip2k-* | iq2000-* \
+ | m32r-* | m32rle-* \
+ | m68000-* | m680[012346]0-* | m68360-* | m683?2-* | m68k-* \
+ | m88110-* | m88k-* | maxq-* | mcore-* \
+ | mips-* | mipsbe-* | mipseb-* | mipsel-* | mipsle-* \
+ | mips16-* \
+ | mips64-* | mips64el-* \
+ | mips64vr-* | mips64vrel-* \
+ | mips64orion-* | mips64orionel-* \
+ | mips64vr4100-* | mips64vr4100el-* \
+ | mips64vr4300-* | mips64vr4300el-* \
+ | mips64vr5000-* | mips64vr5000el-* \
+ | mips64vr5900-* | mips64vr5900el-* \
+ | mipsisa32-* | mipsisa32el-* \
+ | mipsisa32r2-* | mipsisa32r2el-* \
+ | mipsisa64-* | mipsisa64el-* \
+ | mipsisa64r2-* | mipsisa64r2el-* \
+ | mipsisa64sb1-* | mipsisa64sb1el-* \
+ | mipsisa64sr71k-* | mipsisa64sr71kel-* \
+ | mipstx39-* | mipstx39el-* \
+ | mmix-* \
+ | ms1-* \
+ | msp430-* \
+ | none-* | np1-* | ns16k-* | ns32k-* \
+ | orion-* \
+ | pdp10-* | pdp11-* | pj-* | pjl-* | pn-* | power-* \
+ | powerpc-* | powerpc64-* | powerpc64le-* | powerpcle-* | ppcbe-* \
+ | pyramid-* \
+ | romp-* | rs6000-* \
+ | sh-* | sh[1234]-* | sh[24]a-* | sh[23]e-* | sh[34]eb-* | shbe-* \
+ | shle-* | sh[1234]le-* | sh3ele-* | sh64-* | sh64le-* \
+ | sparc-* | sparc64-* | sparc64b-* | sparc86x-* | sparclet-* \
+ | sparclite-* \
+ | sparcv8-* | sparcv9-* | sparcv9b-* | strongarm-* | sv1-* | sx?-* \
+ | tahoe-* | thumb-* \
+ | tic30-* | tic4x-* | tic54x-* | tic55x-* | tic6x-* | tic80-* \
+ | tron-* \
+ | v850-* | v850e-* | vax-* \
+ | we32k-* \
+ | x86-* | x86_64-* | xps100-* | xscale-* | xscalee[bl]-* \
+ | xstormy16-* | xtensa-* \
+ | ymp-* \
+ | z8k-*)
+ m32c-*)
# Recognize the various machine names and aliases which stand
# for a CPU type and a company and sometimes even an OS.
+ 386bsd)
+ basic_machine=i386-unknown
+ os=-bsd
3b1 | 7300 | 7300-att | att-7300 | pc7300 | safari | unixpc)
basic_machine=m68000-att
3b*)
basic_machine=we32k-att
+ a29khif)
+ basic_machine=a29k-amd
+ os=-udi
+ abacus)
+ basic_machine=abacus-unknown
+ adobe68k)
+ basic_machine=m68010-adobe
+ os=-scout
alliant | fx80)
basic_machine=fx80-alliant
@@ -202,25 +394,35 @@
basic_machine=a29k-none
os=-bsd
+ amd64)
+ basic_machine=x86_64-pc
+ amd64-*)
+ basic_machine=x86_64-`echo $basic_machine | sed 's/^[^-]*-//'`
amdahl)
basic_machine=580-amdahl
os=-sysv
amiga | amiga-*)
- basic_machine=m68k-cbm
+ basic_machine=m68k-unknown
amigaos | amigados)
os=-amigaos
amigaunix | amix)
os=-sysv4
apollo68)
basic_machine=m68k-apollo
os=-sysv
+ apollo68bsd)
+ basic_machine=m68k-apollo
+ os=-bsd
aux)
basic_machine=m68k-apple
os=-aux
@@ -229,6 +431,10 @@
basic_machine=ns32k-sequent
os=-dynix
+ c90)
+ basic_machine=c90-cray
+ os=-unicos
convex-c1)
basic_machine=c1-convex
os=-bsd
@@ -249,27 +455,45 @@
basic_machine=c38-convex
os=-bsd
- cray | ymp)
- basic_machine=ymp-cray
+ cray | j90)
+ basic_machine=j90-cray
os=-unicos
- cray2)
- basic_machine=cray2-cray
- os=-unicos
+ craynv)
+ basic_machine=craynv-cray
+ os=-unicosmp
- [ctj]90-cray)
- basic_machine=c90-cray
- os=-unicos
+ cr16c)
+ basic_machine=cr16c-unknown
+ os=-elf
crds | unos)
basic_machine=m68k-crds
+ crisv32 | crisv32-* | etraxfs*)
+ basic_machine=crisv32-axis
+ cris | cris-* | etrax*)
+ basic_machine=cris-axis
+ crx)
+ basic_machine=crx-unknown
+ os=-elf
da30 | da30-*)
basic_machine=m68k-da30
decstation | decstation-3100 | pmax | pmax-* | pmin | dec3100 | decstatn)
basic_machine=mips-dec
+ decsystem10* | dec10*)
+ basic_machine=pdp10-dec
+ os=-tops10
+ decsystem20* | dec20*)
+ os=-tops20
delta | 3300 | motorola-3300 | motorola-delta \
| 3300-motorola | delta-motorola)
basic_machine=m68k-motorola
@@ -278,6 +502,10 @@
basic_machine=m88k-motorola
os=-sysv3
+ djgpp)
+ basic_machine=i586-pc
+ os=-msdosdjgpp
dpx20 | dpx20-*)
basic_machine=rs6000-bull
os=-bosx
@@ -297,6 +525,10 @@
encore | umax | mmax)
basic_machine=ns32k-encore
+ es1800 | OSE68k | ose68k | ose | OSE)
+ basic_machine=m68k-ericsson
+ os=-ose
fx2800)
basic_machine=i860-alliant
@@ -307,6 +539,10 @@
basic_machine=tron-gmicro
os=-sysv
+ go32)
+ basic_machine=i386-pc
+ os=-go32
h3050r* | hiux*)
basic_machine=hppa1.1-hitachi
os=-hiuxwe2
@@ -315,6 +551,14 @@
basic_machine=h8300-hitachi
os=-hms
+ h8300xray)
+ basic_machine=h8300-hitachi
+ os=-xray
+ h8500hms)
+ basic_machine=h8500-hitachi
+ os=-hms
harris)
basic_machine=m88k-harris
os=-sysv3
@@ -330,42 +574,74 @@
basic_machine=m68k-hp
os=-hpux
+ hp3k9[0-9][0-9] | hp9[0-9][0-9])
+ basic_machine=hppa1.0-hp
hp9k2[0-9][0-9] | hp9k31[0-9])
basic_machine=m68000-hp
hp9k3[2-9][0-9])
- hp9k7[0-9][0-9] | hp7[0-9][0-9] | hp9k8[0-9]7 | hp8[0-9]7)
+ hp9k6[0-9][0-9] | hp6[0-9][0-9])
+ hp9k7[0-79][0-9] | hp7[0-79][0-9])
basic_machine=hppa1.1-hp
+ hp9k78[0-9] | hp78[0-9])
+ # FIXME: really hppa2.0-hp
+ basic_machine=hppa1.1-hp
+ hp9k8[67]1 | hp8[67]1 | hp9k80[24] | hp80[24] | hp9k8[78]9 | hp8[78]9 | hp9k893 | hp893)
+ hp9k8[0-9][13679] | hp8[0-9][13679])
hp9k8[0-9][0-9] | hp8[0-9][0-9])
hppa-next)
os=-nextstep3
+ hppaosf)
+ os=-osf
+ hppro)
+ os=-proelf
i370-ibm* | ibm*)
basic_machine=i370-ibm
- os=-mvs
# I'm not sure what "Sysv32" means. Should this be sysv3.2?
- i[3456]86v32)
+ i*86v32)
basic_machine=`echo $1 | sed -e 's/86.*/86-pc/'`
os=-sysv32
- i[3456]86v4*)
+ i*86v4*)
os=-sysv4
- i[3456]86v)
+ i*86v)
os=-sysv
- i[3456]86sol2)
+ i*86sol2)
os=-solaris2
+ i386mach)
+ basic_machine=i386-mach
+ os=-mach
+ i386-vsta | vsta)
+ os=-vsta
iris | iris4d)
basic_machine=mips-sgi
case $os in
@@ -391,27 +667,51 @@
basic_machine=ns32k-utek
os=-sysv
+ mingw32)
+ os=-mingw32
miniframe)
basic_machine=m68000-convergent
- mipsel*-linux*)
- basic_machine=mipsel-unknown
- os=-linux-gnu
+ *mint | -mint[0-9]* | *MiNT | *MiNT[0-9]*)
+ os=-mint
- mips*-linux*)
- basic_machine=mips-unknown
- os=-linux-gnu
mips3*-*)
basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`
mips3*)
basic_machine=`echo $basic_machine | sed -e 's/mips3/mips64/'`-unknown
+ monitor)
+ basic_machine=m68k-rom68k
+ os=-coff
+ morphos)
+ basic_machine=powerpc-unknown
+ os=-morphos
+ msdos)
+ os=-msdos
+ mvs)
+ basic_machine=i370-ibm
+ os=-mvs
ncr3000)
basic_machine=i486-ncr
os=-sysv4
+ netbsd386)
+ os=-netbsd
+ netwinder)
+ basic_machine=armv4l-rebel
+ os=-linux
news | news700 | news800 | news900)
basic_machine=m68k-sony
os=-newsos
@@ -424,6 +724,10 @@
basic_machine=mips-sony
os=-newsos
+ necv70)
+ basic_machine=v70-nec
+ os=-sysv
next | m*-next )
basic_machine=m68k-next
case $os in
@@ -449,9 +753,39 @@
basic_machine=i960-intel
os=-nindy
+ mon960)
+ basic_machine=i960-intel
+ os=-mon960
+ nonstopux)
+ basic_machine=mips-compaq
+ os=-nonstopux
np1)
basic_machine=np1-gould
+ nsr-tandem)
+ basic_machine=nsr-tandem
+ op50n-* | op60c-*)
+ basic_machine=hppa1.1-oki
+ os=-proelf
+ openrisc | openrisc-*)
+ basic_machine=or32-unknown
+ os400)
+ basic_machine=powerpc-ibm
+ os=-os400
+ OSE68000 | ose68000)
+ basic_machine=m68000-ericsson
+ os=-ose
+ os68k)
+ basic_machine=m68k-none
+ os=-os68k
pa-hitachi)
os=-hiuxwe2
@@ -466,53 +800,95 @@
pbb)
basic_machine=m68k-tti
- pc532 | pc532-*)
+ pc532 | pc532-*)
basic_machine=ns32k-pc532
- pentium | p5)
- basic_machine=i586-intel
+ pentium | p5 | k5 | k6 | nexgen | viac3)
- pentiumpro | p6)
- basic_machine=i686-intel
+ pentiumpro | p6 | 6x86 | athlon | athlon_*)
+ basic_machine=i686-pc
- pentium-* | p5-*)
+ pentiumii | pentium2 | pentiumiii | pentium3)
+ pentium4)
+ basic_machine=i786-pc
+ pentium-* | p5-* | k5-* | k6-* | nexgen-* | viac3-*)
basic_machine=i586-`echo $basic_machine | sed 's/^[^-]*-//'`
- pentiumpro-* | p6-*)
+ pentiumpro-* | p6-* | 6x86-* | athlon-*)
basic_machine=i686-`echo $basic_machine | sed 's/^[^-]*-//'`
- k5)
- # We don't have specific support for AMD's K5 yet, so just call it a Pentium
- basic_machine=i586-amd
+ pentiumii-* | pentium2-* | pentiumiii-* | pentium3-*)
+ basic_machine=i686-`echo $basic_machine | sed 's/^[^-]*-//'`
- nexen)
- # We don't have specific support for Nexgen yet, so just call it a Pentium
- basic_machine=i586-nexgen
+ pentium4-*)
+ basic_machine=i786-`echo $basic_machine | sed 's/^[^-]*-//'`
pn)
basic_machine=pn-gould
- power) basic_machine=rs6000-ibm
+ power) basic_machine=power-ibm
ppc) basic_machine=powerpc-unknown
ppc-*) basic_machine=powerpc-`echo $basic_machine | sed 's/^[^-]*-//'`
ppcle | powerpclittle | ppc-le | powerpc-little)
basic_machine=powerpcle-unknown
ppcle-* | powerpclittle-*)
basic_machine=powerpcle-`echo $basic_machine | sed 's/^[^-]*-//'`
+ ppc64) basic_machine=powerpc64-unknown
+ ppc64-*) basic_machine=powerpc64-`echo $basic_machine | sed 's/^[^-]*-//'`
+ ppc64le | powerpc64little | ppc64-le | powerpc64-little)
+ basic_machine=powerpc64le-unknown
+ ppc64le-* | powerpc64little-*)
+ basic_machine=powerpc64le-`echo $basic_machine | sed 's/^[^-]*-//'`
ps2)
basic_machine=i386-ibm
+ pw32)
+ basic_machine=i586-unknown
+ os=-pw32
+ rom68k)
+ os=-coff
rm[46]00)
basic_machine=mips-siemens
rtpc | rtpc-*)
basic_machine=romp-ibm
+ s390 | s390-*)
+ basic_machine=s390-ibm
+ s390x | s390x-*)
+ basic_machine=s390x-ibm
+ sa29200)
+ os=-udi
+ sb1)
+ basic_machine=mipsisa64sb1-unknown
+ sb1el)
+ basic_machine=mipsisa64sb1el-unknown
+ sei)
+ basic_machine=mips-sei
+ os=-seiux
sequent)
basic_machine=i386-sequent
@@ -520,6 +896,13 @@
basic_machine=sh-hitachi
os=-hms
+ sh64)
+ basic_machine=sh64-unknown
+ sparclite-wrs | simso-wrs)
+ basic_machine=sparclite-wrs
+ os=-vxworks
sps7)
basic_machine=m68k-bull
os=-sysv2
@@ -527,6 +910,13 @@
spur)
basic_machine=spur-unknown
+ st2000)
+ basic_machine=m68k-tandem
+ stratus)
+ basic_machine=i860-stratus
+ os=-sysv4
sun2)
basic_machine=m68000-sun
@@ -567,19 +957,51 @@
sun386 | sun386i | roadrunner)
basic_machine=i386-sun
+ sv1)
+ basic_machine=sv1-cray
+ os=-unicos
symmetry)
os=-dynix
+ t3e)
+ basic_machine=alphaev5-cray
+ os=-unicos
+ t90)
+ basic_machine=t90-cray
+ os=-unicos
+ tic54x | c54x*)
+ basic_machine=tic54x-unknown
+ os=-coff
+ tic55x | c55x*)
+ basic_machine=tic55x-unknown
+ os=-coff
+ tic6x | c6x*)
+ basic_machine=tic6x-unknown
+ os=-coff
tx39)
basic_machine=mipstx39-unknown
tx39el)
basic_machine=mipstx39el-unknown
+ toad1)
+ basic_machine=pdp10-xkl
+ os=-tops20
tower | tower-32)
basic_machine=m68k-ncr
+ tpf)
+ os=-tpf
udi29k)
os=-udi
@@ -588,6 +1010,10 @@
basic_machine=a29k-nyu
os=-sym1
+ v810 | necv810)
+ basic_machine=v810-nec
+ os=-none
vaxv)
basic_machine=vax-dec
os=-sysv
@@ -597,8 +1023,8 @@
os=-vms
vpp*|vx|vx-*)
- basic_machine=f301-fujitsu
+ basic_machine=f301-fujitsu
vxworks960)
basic_machine=i960-wrs
os=-vxworks
@@ -611,13 +1037,29 @@
basic_machine=a29k-wrs
os=-vxworks
- xmp)
- basic_machine=xmp-cray
- os=-unicos
+ w65*)
+ basic_machine=w65-wdc
+ os=-none
- xps | xps100)
+ w89k-*)
+ basic_machine=hppa1.1-winbond
+ os=-proelf
+ xbox)
+ os=-mingw32
+ xps | xps100)
basic_machine=xps100-honeywell
+ ymp)
+ basic_machine=ymp-cray
+ os=-unicos
+ z8k-*-coff)
+ basic_machine=z8k-unknown
+ os=-sim
none)
basic_machine=none-none
os=-none
@@ -625,32 +1067,44 @@
# Here we handle the default manufacturer of certain CPU types. It is in
# some cases the only manufacturer, in others, it is the most popular.
- mips)
- if [ x$os = x-linux-gnu ]; then
- else
- basic_machine=mips-mips
- fi
+ w89k)
+ op50n)
+ op60c)
romp)
+ mmix)
+ basic_machine=mmix-knuth
rs6000)
vax)
+ pdp10)
+ # there are many clones, so DEC is not a safe bet
+ basic_machine=pdp10-unknown
pdp11)
basic_machine=pdp11-dec
we32k)
- sparc)
+ sh[1234] | sh[24]a | sh[34]eb | sh[1234]le | sh[23]ele)
+ basic_machine=sh-unknown
+ sparc | sparcv8 | sparcv9 | sparcv9b)
basic_machine=sparc-sun
- cydra)
+ cydra)
basic_machine=cydra-cydrome
orion)
@@ -659,6 +1113,15 @@
orion105)
basic_machine=clipper-highlevel
+ mac | mpw | mac-mpw)
+ basic_machine=m68k-apple
+ pmac | pmac-mpw)
+ basic_machine=powerpc-apple
+ *-unknown)
+ # Make sure to match an already-canonicalized machine name.
echo Invalid configuration \`$1\': machine \`$basic_machine\' not recognized 1>&2
exit 1
@@ -711,14 +1174,47 @@
| -aos* \
| -nindy* | -vxsim* | -vxworks* | -ebmon* | -hms* | -mvs* \
| -clix* | -riscos* | -uniplus* | -iris* | -rtu* | -xenix* \
- | -hiux* | -386bsd* | -netbsd* | -openbsd* | -freebsd* | -riscix* \
- | -lynxos* | -bosx* | -nextstep* | -cxux* | -aout* | -elf* \
+ | -hiux* | -386bsd* | -knetbsd* | -mirbsd* | -netbsd* | -openbsd* \
+ | -ekkobsd* | -kfreebsd* | -freebsd* | -riscix* | -lynxos* \
+ | -bosx* | -nextstep* | -cxux* | -aout* | -elf* | -oabi* \
| -ptx* | -coff* | -ecoff* | -winnt* | -domain* | -vsta* \
| -udi* | -eabi* | -lites* | -ieee* | -go32* | -aux* \
- | -cygwin32* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
- | -mingw32* | -linux-gnu* | -uxpv*)
+ | -chorusos* | -chorusrdb* \
+ | -cygwin* | -pe* | -psos* | -moss* | -proelf* | -rtems* \
+ | -mingw32* | -linux-gnu* | -linux-uclibc* | -uxpv* | -beos* | -mpeix* | -udk* \
+ | -interix* | -uwin* | -mks* | -rhapsody* | -darwin* | -opened* \
+ | -openstep* | -oskit* | -conix* | -pw32* | -nonstopux* \
+ | -storm-chaos* | -tops10* | -tenex* | -tops20* | -its* \
+ | -os2* | -vos* | -palmos* | -uclinux* | -nucleus* \
+ | -morphos* | -superux* | -rtmk* | -rtmk-nova* | -windiss* \
+ | -powermax* | -dnix* | -nx6 | -nx7 | -sei* | -dragonfly* \
+ | -skyos* | -haiku*)
# Remember, each alternative MUST END IN *, to match a version number.
+ -qnx*)
+ case $basic_machine in
+ x86-* | i*86-*)
+ os=-nto$os
+ esac
+ -nto-qnx*)
+ -nto*)
+ os=`echo $os | sed -e 's|nto|nto-qnx|'`
+ -sim | -es1800* | -hms* | -xray | -os68k* | -none* | -v88r* \
+ | -windows* | -osx | -abug | -netware* | -os9* | -beos* | -haiku* \
+ | -macos* | -mpw* | -magic* | -mmixware* | -mon960* | -lnews*)
+ -mac*)
+ os=`echo $os | sed -e 's|mac|macos|'`
+ -linux-dietlibc)
+ os=-linux-dietlibc
-linux*)
os=`echo $os | sed -e 's|linux|linux-gnu|'`
@@ -728,6 +1224,15 @@
-sunos6*)
os=`echo $os | sed -e 's|sunos6|solaris3|'`
+ -opened*)
+ os=-openedition
+ -os400*)
+ os=-os400
+ -wince*)
+ os=-wince
-osfrose*)
os=-osfrose
@@ -743,12 +1248,27 @@
-acis*)
os=-aos
+ -atheos*)
+ os=-atheos
+ -syllable*)
+ os=-syllable
+ -386bsd)
+ os=-bsd
-ctix* | -uts*)
os=-sysv
+ -nova*)
+ os=-rtmk-nova
-ns2 )
- os=-nextstep2
+ os=-nextstep2
+ -nsk*)
+ os=-nsk
# Preserve the version number of sinix5.
-sinix5.*)
os=`echo $os | sed -e 's|sinix|sysv|'`
@@ -756,6 +1276,9 @@
-sinix*)
os=-sysv4
+ -tpf*)
+ os=-tpf
-triton*)
os=-sysv3
@@ -774,9 +1297,27 @@
# This must come after -sysvr4.
-sysv*)
+ -ose*)
+ os=-ose
+ -es1800*)
+ os=-ose
-xenix)
os=-xenix
+ -*mint | -mint[0-9]* | -*MiNT | -MiNT[0-9]*)
+ os=-mint
+ -aros*)
+ os=-aros
+ -kaos*)
+ os=-kaos
+ -zvmoe)
+ os=-zvmoe
-none)
@@ -802,10 +1343,20 @@
*-acorn)
os=-riscix1.2
+ arm*-rebel)
+ os=-linux
arm*-semi)
os=-aout
- pdp11-*)
+ c4x-* | tic4x-*)
+ os=-coff
+ # This must come before the *-dec entry.
+ pdp10-*)
+ os=-tops20
+ pdp11-*)
os=-none
*-dec | vax-*)
@@ -823,15 +1374,45 @@
# default.
# os=-sunos4
+ m68*-cisco)
+ os=-aout
+ mips*-cisco)
+ os=-elf
+ mips*-*)
+ os=-elf
+ or32-*)
+ os=-coff
*-tti) # must be before sparc entry or we get the wrong os.
os=-sysv3
sparc-* | *-sun)
os=-sunos4.1.1
+ *-be)
+ os=-beos
+ *-haiku)
+ os=-haiku
*-ibm)
os=-aix
+ *-knuth)
+ os=-mmixware
+ *-wec)
+ os=-proelf
+ *-winbond)
+ os=-proelf
+ *-oki)
+ os=-proelf
*-hp)
os=-hpux
@@ -874,27 +1455,39 @@
*-next)
os=-nextstep3
- *-gould)
+ *-gould)
os=-sysv
- *-highlevel)
+ *-highlevel)
os=-bsd
*-encore)
os=-bsd
- *-sgi)
+ *-sgi)
os=-irix
- *-siemens)
+ *-siemens)
os=-sysv4
*-masscomp)
os=-rtu
- f301-fujitsu)
+ f30[01]-fujitsu | f700-fujitsu)
os=-uxpv
+ *-rom68k)
+ os=-coff
+ *-*bug)
+ os=-coff
+ *-apple)
+ os=-macos
+ *-atari*)
+ os=-mint
os=-none
@@ -916,9 +1509,15 @@
-aix*)
vendor=ibm
+ -beos*)
+ vendor=be
-hpux*)
vendor=hp
+ -mpeix*)
+ vendor=hp
-hiux*)
vendor=hitachi
@@ -934,21 +1533,48 @@
-genix*)
vendor=ns
- -mvs*)
+ -mvs* | -opened*)
vendor=ibm
+ -os400*)
+ vendor=ibm
-ptx*)
vendor=sequent
- -vxsim* | -vxworks*)
+ -tpf*)
+ vendor=ibm
+ -vxsim* | -vxworks* | -windiss*)
vendor=wrs
-aux*)
vendor=apple
+ -hms*)
+ vendor=hitachi
+ -mpw* | -macos*)
+ vendor=apple
+ vendor=atari
+ -vos*)
+ vendor=stratus
esac
basic_machine=`echo $basic_machine | sed "s/unknown/$vendor/"`
esac
echo $basic_machine$os
+exit
+# Local variables:
+# End:
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2013-02-15 12:16:10 UTC (rev 7356)
@@ -270,6 +270,9 @@
# 0 < Value <= 1800
# FDOConnectionTimeoutCustom Time duration in seconds for an FDO connection
# 0 < Value <= 600
+# UseFdoJoinOptimization Determines whether to use FDO Join APIs for feature joins between
+# classes from the same Feature Source for FDO providers that support it
+# 1 = Use FDO Join APIs if possible, 0 = Fallback to GwsQueryEngine
CacheSize = 100
CacheTimeLimit = 86400
@@ -285,6 +288,7 @@
DataTransactionTimeout = 360
DataTransactionTimerInterval = 60
FDOConnectionTimeoutCustom = OSGeo.WMS:120
+UseFdoJoinOptimization = 1
[MappingServiceProperties]
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureQueryResults.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureQueryResults.cpp 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureQueryResults.cpp 2013-02-15 12:16:10 UTC (rev 7356)
@@ -24,8 +24,6 @@
#include "stdafx.h"
#include "GwsQueryEngineImp.h"
#include "GwsBinaryFeatureWriter.h"
-#include "SDF/IScrollableFeatureReader.h"
-#include "SHP/IScrollableFeatureReader.h"
@@ -75,13 +73,9 @@
if(dynamic_cast<FdoIScrollableFeatureReader*>(pReader) != NULL)
m_extProviderType = eFDO;
- else if(dynamic_cast<SdfIScrollableFeatureReader*>(pReader) != NULL)
- m_extProviderType = eSDF;
- else if(dynamic_cast<ShpIScrollableFeatureReader*>(pReader) != NULL)
- m_extProviderType = eSHP;
else if(dynamic_cast<CGwsFeatureIterator*>(pReader) != NULL)
m_extProviderType = eCGFI;
- else
+ else
m_bScrollableReader = false;
if (pReader)
@@ -714,10 +708,8 @@
CheckReader();
if(!m_bScrollableReader) GWS_THROW(eGwsNotSupported);
- if(dynamic_cast<SdfIScrollableFeatureReader*>(m_reader.p) != NULL)
- return ((SdfIScrollableFeatureReader*)m_reader.p)->Count();
- if(dynamic_cast<ShpIScrollableFeatureReader*>(m_reader.p) != NULL)
- return ((ShpIScrollableFeatureReader*)m_reader.p)->Count();
+ if(dynamic_cast<FdoIScrollableFeatureReader*>(m_reader.p) != NULL)
+ return ((FdoIScrollableFeatureReader*)m_reader.p)->Count();
if(dynamic_cast<CGwsFeatureIterator*>(m_reader.p) != NULL)
return ((CGwsFeatureIterator*)m_reader.p)->Count();
assert(false);
@@ -734,10 +726,8 @@
m_bMutableFeatureSet = false;
m_bGeometryConverted = false;
- return ((SdfIScrollableFeatureReader*)m_reader.p)->ReadFirst();
- return ((ShpIScrollableFeatureReader*)m_reader.p)->ReadFirst();
+ return ((FdoIScrollableFeatureReader*)m_reader.p)->ReadFirst();
return ((CGwsFeatureIterator*)m_reader.p)->ReadFirst();
assert(false);
@@ -754,10 +744,8 @@
- return ((SdfIScrollableFeatureReader*)m_reader.p)->ReadLast();
- return ((ShpIScrollableFeatureReader*)m_reader.p)->ReadLast();
+ return ((FdoIScrollableFeatureReader*)m_reader.p)->ReadLast();
return ((CGwsFeatureIterator*)m_reader.p)->ReadLast();
assert(false);
@@ -774,10 +762,8 @@
- return ((SdfIScrollableFeatureReader*)m_reader.p)->ReadPrevious();
- return ((ShpIScrollableFeatureReader*)m_reader.p)->ReadPrevious();
+ return ((FdoIScrollableFeatureReader*)m_reader.p)->ReadPrevious();
return ((CGwsFeatureIterator*)m_reader.p)->ReadPrevious();
assert(false);
@@ -794,10 +780,8 @@
- return ((SdfIScrollableFeatureReader*)m_reader.p)->ReadAt(key);
- return ((ShpIScrollableFeatureReader*)m_reader.p)->ReadAt(key);
+ return ((FdoIScrollableFeatureReader*)m_reader.p)->ReadAt(key);
return ((CGwsFeatureIterator*)m_reader.p)->ReadAt(key);
assert(false);
@@ -814,10 +798,8 @@
- return ((SdfIScrollableFeatureReader*)m_reader.p)->ReadAtIndex(recordindex);
- return ((ShpIScrollableFeatureReader*)m_reader.p)->ReadAtIndex(recordindex);
+ return ((FdoIScrollableFeatureReader*)m_reader.p)->ReadAtIndex(recordindex);
return ((CGwsFeatureIterator*)m_reader.p)->ReadAtIndex(recordindex);
assert(false);
@@ -831,10 +813,8 @@
CheckReader();
- return ((SdfIScrollableFeatureReader*)m_reader.p)->IndexOf(key);
- return ((ShpIScrollableFeatureReader*)m_reader.p)->IndexOf(key);
+ return ((FdoIScrollableFeatureReader*)m_reader.p)->IndexOf(key);
return ((CGwsFeatureIterator*)m_reader.p)->IndexOf(key);
assert(false);
@@ -848,8 +828,7 @@
CheckReader();
if(NULL == m_reader || !m_bScrollableReader)
return false;
- if( (NULL == dynamic_cast<SdfIScrollableFeatureReader*>(m_reader.p)) &&
- (NULL == dynamic_cast<ShpIScrollableFeatureReader*>(m_reader.p)) &&
+ if( (NULL == dynamic_cast<FdoIScrollableFeatureReader*>(m_reader.p)) &&
(NULL == dynamic_cast<CGwsFeatureIterator*>(m_reader.p)))
return false;
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFeatureSourceQuery.cpp 2013-02-15 12:16:10 UTC (rev 7356)
@@ -23,8 +23,6 @@
#include "stdafx.h"
-#include <SDF/SdfCommandType.h>
-#include <SHP/ShpCommandType.h>
//Uncomment to see what join algorithm is used for the join operation
@@ -52,9 +50,7 @@
bool bSupportsExtendedSelect = false;
for(int i = 0; i < size; i++ )
- if( pTypes[i] == SdfCommandType_ExtendedSelect ||
- pTypes[i] == ShpCommandType_ExtendedSelect ||
- pTypes[i] == FdoCommandType_ExtendedSelect)
+ if( pTypes[i] == FdoCommandType_ExtendedSelect)
bSupportsExtendedSelect = true;
break;
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsPreparedFeatureQuery.cpp 2013-02-15 12:16:10 UTC (rev 7356)
@@ -23,10 +23,6 @@
#include "stdafx.h"
-#include <SDF/IExtendedSelect.h>
-#include <SHP/IExtendedSelect.h>
#include "FdoExpressionEngineCopyFilter.h"
#include "FdoExpressionEngineFilterProcessor.h"
@@ -212,20 +208,6 @@
mExSelProv = eFDO;
break;
- if( pTypes[i] == SdfCommandType_ExtendedSelect)
- m_bExtendedQuerySupported = true;
- selcmd = (SdfIExtendedSelect *) m_connection->CreateCommand (SdfCommandType_ExtendedSelect);
- mExSelProv = eSDF;
- break;
- if( pTypes[i] == ShpCommandType_ExtendedSelect)
- selcmd = (ShpIExtendedSelect *) m_connection->CreateCommand (ShpCommandType_ExtendedSelect);
- mExSelProv = eSHP;
- break;
if(!m_bExtendedQuerySupported)
@@ -245,16 +227,6 @@
FdoIExtendedSelect* pExSelCmd = (FdoIExtendedSelect*)selcmd;
pExSelCmd->SetOrderingOption(orderBy->GetString(0), orderingOption);
- else if(mExSelProv == eSDF)
- SdfIExtendedSelect* pExSelCmd = (SdfIExtendedSelect*)selcmd;
- pExSelCmd->SetOrderingOption(orderBy->GetString(0), orderingOption);
- else if(mExSelProv == eSHP)
- ShpIExtendedSelect* pExSelCmd = (ShpIExtendedSelect*)selcmd;
- }//etc.
else
@@ -426,10 +398,6 @@
if (mExSelProv == eFDO)
reader = ((FdoIExtendedSelect *)m_pCommand.p)->ExecuteScrollable();
- reader = ((SdfIExtendedSelect *)m_pCommand.p)->ExecuteScrollable();
- reader = ((ShpIExtendedSelect *)m_pCommand.p)->ExecuteScrollable();
//If extended query failed or was skipped, do standard query
if(NULL == reader)
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsQuery.h 2013-02-15 12:16:10 UTC (rev 7356)
@@ -269,7 +269,7 @@
GWSCoordinateSystem m_csname;
-typedef enum _GwsExtendedSelProvider { eSDF, eSHP, eCGFI, eFDO } EGwsExtendedSelProvider;
+typedef enum _GwsExtendedSelProvider { eCGFI, eFDO } EGwsExtendedSelProvider;
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.cpp 2013-02-15 12:16:10 UTC (rev 7356)
@@ -49,6 +49,7 @@
// Set a default join query batch size
m_nJoinQueryBatchSize = MgConfigProperties::DefaultFeatureServicePropertyJoinQueryBatchSize;
+ m_bUseFdoJoinOptimization = MgConfigProperties::DefaultFeatureServicePropertyUseFdoJoinOptimization;
MgConfiguration* config = MgConfiguration::GetInstance();
if(config)
@@ -63,6 +64,11 @@
MgConfigProperties::FeatureServicePropertyDataCacheSize,
m_nDataCacheSize,
MgConfigProperties::DefaultFeatureServicePropertyDataCacheSize);
+ // Get FDO Join use flag
+ config->GetBoolValue(MgConfigProperties::FeatureServicePropertiesSection,
+ MgConfigProperties::FeatureServicePropertyUseFdoJoinOptimization,
+ m_bUseFdoJoinOptimization,
+ MgConfigProperties::DefaultFeatureServicePropertyUseFdoJoinOptimization);
@@ -1556,6 +1562,10 @@
bool bSupported = false;
+ //If disabled on a global level, don't even bother continuing
+ if (!m_bUseFdoJoinOptimization)
+ return false;
MG_FEATURE_SERVICE_TRY()
//This could be qualified, so parse it to be sure
Modified: trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h
--- trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Server/src/Services/Feature/ServerSelectFeatures.h 2013-02-15 12:16:10 UTC (rev 7356)
@@ -91,6 +91,9 @@
INT32 m_nJoinQueryBatchSize;
INT32 m_nDataCacheSize;
+ // This is the overriding flag that decides if we should test for and use the FDO Join
+ // APIs if possible
+ bool m_bUseFdoJoinOptimization;
// FDO join optimization
bool IsFunctionOnPrimaryProperty(FdoFunction* function, FdoIConnection* conn, CREFSTRING schemaName, CREFSTRING className);
Modified: trunk/MgDev/Web/src/JavaApi/JavaApi.vcxproj
--- trunk/MgDev/Web/src/JavaApi/JavaApi.vcxproj 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Web/src/JavaApi/JavaApi.vcxproj 2013-02-15 12:16:10 UTC (rev 7356)
@@ -99,7 +99,8 @@
"$(JAVA_HOME)\bin\javac" -classpath . org\osgeo\mapguide\*.java
echo Building JAR file
"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApid.jar org\osgeo\mapguide\*.class
-</Command>
+echo Building -sources JAR file
+"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApid-sources.jar org\osgeo\mapguide\*.java</Command>
</PreBuildEvent>
<ClCompile>
<Optimization>Disabled</Optimization>
@@ -138,7 +139,8 @@
-</Command>
</PreBuildEvent>
<ClCompile>
@@ -177,7 +179,8 @@
"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApi.jar org\osgeo\mapguide\*.class
-</Command>
+"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApi-sources.jar org\osgeo\mapguide\*.java</Command>
</PreBuildEvent>
<ClCompile>
<Optimization>MaxSpeed</Optimization>
@@ -216,7 +219,8 @@
-</Command>
</PreBuildEvent>
<ClCompile>
Modified: trunk/MgDev/Web/src/JavaApi/Makefile.am
--- trunk/MgDev/Web/src/JavaApi/Makefile.am 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Web/src/JavaApi/Makefile.am 2013-02-15 12:16:10 UTC (rev 7356)
@@ -466,3 +466,4 @@
mv -f *.java org/osgeo/mapguide
$(JAVA_HOME)/bin/javac -classpath . org/osgeo/mapguide/*.java
$(JAVA_HOME)/bin/jar cf ../WEB-INF/lib/MapGuideApi.jar org/osgeo/mapguide/*.class
+ $(JAVA_HOME)/bin/jar cf ../WEB-INF/lib/MapGuideApi-sources.jar org/osgeo/mapguide/*.java
Modified: trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj
--- trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Web/src/JavaApiEx/JavaApiEx.vcxproj 2013-02-15 12:16:10 UTC (rev 7356)
@@ -98,8 +98,9 @@
echo Building java classes...
-"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApid.jar org\osgeo\mapguide\*.class
-</Command>
+"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApiExd.jar org\osgeo\mapguide\*.class
+"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApiExd-sources.jar org\osgeo\mapguide\*.java</Command>
</PreBuildEvent>
<ClCompile>
@@ -137,8 +138,9 @@
-</Command>
</PreBuildEvent>
<ClCompile>
@@ -177,6 +179,8 @@
"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApiEx.jar org\osgeo\mapguide\*.class
+"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApiEx-sources.jar org\osgeo\mapguide\*.java
</Command>
</PreBuildEvent>
<ClCompile>
@@ -216,7 +220,8 @@
-</Command>
+"$(JAVA_HOME)\bin\jar" cf ..\WEB-INF\lib\MapGuideApiEx-sources.jar org\osgeo\mapguide\*.java</Command>
</PreBuildEvent>
<ClCompile>
Modified: trunk/MgDev/Web/src/JavaApiEx/Makefile.am
--- trunk/MgDev/Web/src/JavaApiEx/Makefile.am 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/Web/src/JavaApiEx/Makefile.am 2013-02-15 12:16:10 UTC (rev 7356)
@@ -466,3 +466,4 @@
$(JAVA_HOME)/bin/jar cf ../WEB-INF/lib/MapGuideApiEx.jar org/osgeo/mapguide/*.class
+ $(JAVA_HOME)/bin/jar cf ../WEB-INF/lib/MapGuideApiEx-sources.jar org/osgeo/mapguide/*.java
Modified: trunk/MgDev/configure.in
--- trunk/MgDev/configure.in 2013-02-15 10:28:57 UTC (rev 7355)
+++ trunk/MgDev/configure.in 2013-02-15 12:16:10 UTC (rev 7356)
@@ -4,7 +4,7 @@
# Variables
# Following are the makefile directories
-AC_INIT(mapguide,2.4.0,http://mapguide.osgeo.org)
+AC_INIT(mapguide,2.5.0,http://mapguide.osgeo.org)
AC_CONFIG_SRCDIR(configure.in)
AM_INIT_AUTOMAKE
AM_INIT_AUTOMAKE([1.9 tar-pax])
@@ -121,6 +121,12 @@
[enable_optimized=$enableval],
[enable_optimized=no])
+AC_ARG_ENABLE([64bit],
+ MAP_HELP_STRING([--enable-64bit],
+ [enable 64-bit build [[default=no]]]),
+ [enable_64bit=$enableval],
+ [enable_64bit=no])
if test $enable_optimized = no; then
AC_MSG_NOTICE([Using debug configuration])
if test -s gcc32.txt; then
@@ -136,12 +142,32 @@
AC_MSG_NOTICE([Using optimized configuration])
if test -s "gcc32.txt"; then
AC_MSG_NOTICE([gcc 3.2.x . Please pay attention to warnings!])
- CXXFLAGS="-O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions"
- AC_SUBST(CXXFLAGS, ["-O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions"])
+ if test $enable_64bit = no; then
+ AC_MSG_NOTICE([Using 32-bit CXXFLAGS])
+ CXXFLAGS="-O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions"
+ AC_SUBST(CXXFLAGS, ["-O2 -g -pipe -march=i686 -mtune=i686 -fno-use-cxa-atexit -fexceptions"])
+ else
+ #TODO: Review. i686 is not a valid march/mtune value for 64-bit compilation
+ #TODO: Sticking -fPIC globally is probably a bit of a thermonuclear solution, but we
+ # *absolutely* must be sure this flag is used when compiling static libraries
+ AC_MSG_NOTICE([Using 64-bit CXXFLAGS])
+ CXXFLAGS="-O2 -g -pipe -m64 -fPIC -fno-use-cxa-atexit -fexceptions"
+ AC_SUBST(CXXFLAGS, ["-O2 -g -pipe -m64 -fPIC -fno-use-cxa-atexit -fexceptions"])
+ fi
else
AC_MSG_NOTICE([this gcc version is not actively supported.])
+ else
+ fi
fi
fi
More information about the mapguide-commits
