[mapguide-commits] r7363 - trunk/Tools/JenkinsCI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Feb 15 06:59:50 PST 2013
Author: jng
Date: 2013-02-15 06:59:50 -0800 (Fri, 15 Feb 2013)
New Revision: 7363
Added:
   trunk/Tools/JenkinsCI/readme.txt
#2210: Add readme.txt
Added: trunk/Tools/JenkinsCI/readme.txt
--- trunk/Tools/JenkinsCI/readme.txt	                        (rev 0)
+++ trunk/Tools/JenkinsCI/readme.txt	2013-02-15 14:59:50 UTC (rev 7363)
@@ -0,0 +1,49 @@
+Jenkins CI configuration
+Required Tools
+ * Microsoft .net Framework 4.0
+ * Microsoft Visual C++ Express 2010 with Service Pack 1
+ * Windows SDK 7.1
+ * Java SDK 6u33 (32/64-bit)
+ * Java SDK 7u13 (32/64-bit)
+ * Jenkins 1.465
+ * 7-zip 9.20
+ * ActivePerl 5.14.2 (64-bit)
+ * ActiveState ActivePython 2.7.2.5 (64-bit)
+ * GNU Bison 2.4.1
+ * GNU sed 4.2.1
+ * Sandcastle Help File Builder 1.9.4.0
+ * TortoiseSVN 1.6.x
+ * Slik Subversion 1.6.x
+ * Windows Installer XML Toolset 3.5
+ * Visual C++ SP1 compiler update for Windows SDK (KB2519277)
+VS Installation Order
+Visual C++ 2010 Express
+Windows SDK v7.1 (with Visual C++ compilers option DISABLED and .net tools + reference assemblies ENABLED)
+ - Disable C++ compilers because SP1 will remove them (!)
+ - Enable .net options because they are required for building C++/CLI code
+Visual Studio 2010 SP1
+Visual C++ SP1 compiler update for Windows SDK (KB2519277)
+Filesystem layout
+* Currently configured for MGOS 2.5 and FDO 3.8, adjust these version numbers as necessary
+C:\apache-ant-1.8.3		[extracted location of apache ant v1.8.3]
+C:\builds
+	- revnum.pl [copy from http://svn.osgeo.org/fdo/branches/2.5/Installer/scripts/revnum.pl]
+C:\fdo-3.8-x86 	[svn wc of http://svn.osgeo.org/fdo/branches/3.8]
+C:\fdo-3.8-x64 	[svn wc of http://svn.osgeo.org/fdo/branches/3.8]
+C:\mg-2.5-x86
+	- Installer [svn wc of http://svn.osgeo.org/mapguide/branches/2.5/Installer]
+	- MgDev		[svn wc of http://svn.osgeo.org/mapguide/branches/2.5/MgDev]
+C:\mg-2.5-x64
\ No newline at end of file
More information about the mapguide-commits mailing list
